[GRASS-SVN] r48388 - grass/trunk/raster/r.to.vect
svn_grass at osgeo.org
Tue Sep 20 16:52:57 EDT 2011
Author: neteler
Date: 2011-09-20 13:52:57 -0700 (Tue, 20 Sep 2011)
New Revision: 48388
grass/trunk/raster/r.to.vect/main.c
msg tuning
Modified: grass/trunk/raster/r.to.vect/main.c
--- grass/trunk/raster/r.to.vect/main.c 2011-09-20 14:53:52 UTC (rev 48387)
+++ grass/trunk/raster/r.to.vect/main.c 2011-09-20 20:52:57 UTC (rev 48388)
@@ -85,7 +85,7 @@
column_name = G_define_standard_option(G_OPT_DB_COLUMN);
column_name->label = _("Name of attribute column to store value");
- column_name->description = _("The name must be SQL compliant");
+ column_name->description = _("Name must be SQL compliant");
column_name->answer = "value";
smooth_flg = G_define_flag();
