[GRASS-SVN] r48397 - grass/trunk/lib/raster3d
svn_grass at osgeo.org
Wed Sep 21 13:54:06 EDT 2011
Author: huhabla
Date: 2011-09-21 10:54:06 -0700 (Wed, 21 Sep 2011)
New Revision: 48397
grass/trunk/lib/raster3d/close.c
Fixed wrong map name arguments in error messages. Fixed wrong return value validation when writing map history.
Modified: grass/trunk/lib/raster3d/close.c
--- grass/trunk/lib/raster3d/close.c 2011-09-21 16:20:28 UTC (rev 48396)
+++ grass/trunk/lib/raster3d/close.c 2011-09-21 17:54:06 UTC (rev 48397)
@@ -43,8 +43,8 @@
Rast_command_history(&hist);
/*Use the G3d function to write the history file,
* otherwise the path is wrong */
- if (!Rast3d_write_history(map->fileName, &hist)) {
- G_warning(_("Unable to write history for 3D raster map <%s>"), map);
+ if (Rast3d_write_history(map->fileName, &hist) < 0) {
+ G_warning(_("Unable to write history for 3D raster map <%s>"), map->fileName);
Rast3d_range_write(map);
@@ -96,18 +96,18 @@
if (!Rast3d_write_ints(map->data_fd, map->useXdr, &(map->indexNbytesUsed), 1)) {
- G_warning(_("Unable to write header for 3D raster map <%s>"), map);
+ G_warning(_("Unable to write header for 3D raster map <%s>"), map->fileName);
return 0;
Rast3d_long_encode(&(map->indexOffset), (unsigned char *)<mp, 1);
if (write(map->data_fd, <mp, sizeof(long)) != sizeof(long)) {
return 0;
if (!close_new(map) != 0) {
- G_warning(_("Unable to create 3D raster map <%s>"), map);
+ G_warning(_("Unable to create 3D raster map <%s>"), map->fileName);
return 0;
@@ -117,7 +117,7 @@
static int close_old(RASTER3D_Map * map)
if (close(map->data_fd) != 0) {
- G_warning(_("Unable to close 3D raster map <%s>"), map);
+ G_warning(_("Unable to close 3D raster map <%s>"), map->fileName);
return 0;
@@ -127,7 +127,7 @@
static int close_cell_old(RASTER3D_Map * map)
if (!close_old(map) != 0) {
return 0;
@@ -150,13 +150,13 @@
if (map->operation == RASTER3D_WRITE_DATA) {
if (!close_cell_new(map)) {
return 0;
else {
if (!close_cell_old(map) != 0) {
return 0;
@@ -188,7 +188,7 @@
map->compression, map->useRle, map->useLzw,
map->precision, map->offset, map->useXdr,
map->hasIndex, map->unit)) {
return 0;
