[GRASS-SVN] r48410 - grass/trunk/gui/wxpython/gui_modules
Thu Sep 22 11:22:35 EDT 2011
Author: martinl
Date: 2011-09-22 08:22:35 -0700 (Thu, 22 Sep 2011)
New Revision: 48410
   grass/trunk/gui/wxpython/gui_modules/histogram2.py
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
wxGUI: fix calling Histogram and HistogramPyPlot
Modified: grass/trunk/gui/wxpython/gui_modules/histogram2.py
--- grass/trunk/gui/wxpython/gui_modules/histogram2.py	2011-09-22 13:26:28 UTC (rev 48409)
+++ grass/trunk/gui/wxpython/gui_modules/histogram2.py	2011-09-22 15:22:35 UTC (rev 48410)
@@ -57,7 +57,7 @@
            "standard Python distribution). See the Numeric Python site "
            "(http://numpy.scipy.org) for information on downloading source or "
            "binaries.")
-    print >> sys.stderr, "profile.py: " + msg
+    print >> sys.stderr, "histogram2.py: " + msg
 class HistFrame(wx.Frame):
     """!Mainframe for displaying profile of raster map. Uses wx.lib.plot.
@@ -377,15 +377,16 @@
         try:
             ret = gcmd.RunCommand("r.stats",
-                             input=raster,
-                             flags=freqflag,
-                             nsteps=self.bins,
-                             fs=',',
-                             quiet=True,
-                             read = True)
+                                  parent = self,
+                                  input=raster,
+                                  flags=freqflag,
+                                  nsteps=self.bins,
+                                  fs=',',
+                                  quiet = True,
+                                  read = True)
             if not ret:
-                return dataset
+                return datalist
             for line in ret.splitlines():
                 cellval, histval = line.strip().split(',')
@@ -1376,4 +1377,4 @@
     def OnCancel(self, event):
         """!Button 'Cancel' pressed"""
         self.Close()
\ No newline at end of file
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2011-09-22 13:26:28 UTC (rev 48409)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2011-09-22 15:22:35 UTC (rev 48410)
@@ -45,8 +45,6 @@
 import gcmd
 import dbm
 import dbm_dialogs
-import histogram
-import histogram2
 import profile
 import globalvar
 import utils
@@ -56,7 +54,8 @@
 from preferences import globalSettings as UserSettings
 from mapdisp_window  import BufferedWindow
+from histogram       import HistFrame
+from histogram2      import HistFrame as HistFramePyPlot
 from grass.script import core as grass
 # for standalone app
@@ -1544,12 +1543,12 @@
         histogram2 = wx.MenuItem(toolsmenu, wx.ID_ANY, _("Create histogram with PyPlot"))
         histogram2.SetBitmap(icons["histogram"].GetBitmap(self.iconsize))
         toolsmenu.AppendItem(histogram2)
-        self.Bind(wx.EVT_MENU, self.Histogram2, histogram2)
+        self.Bind(wx.EVT_MENU, self.OnHistogramPyPlot, histogram2)
         histogram = wx.MenuItem(toolsmenu, wx.ID_ANY, icons["histogram"].GetLabel())
         histogram.SetBitmap(icons["histogram"].GetBitmap(self.iconsize))
         toolsmenu.AppendItem(histogram)
-        self.Bind(wx.EVT_MENU, self.Histogram, histogram)
+        self.Bind(wx.EVT_MENU, self.OnHistogram, histogram)
         # Popup the menu.  If an item is selected then its handler
         # will be called before PopupMenu returns.
@@ -1704,33 +1703,35 @@
         return (outdist, outunits)
-    def Histogram(self, event):
+    def OnHistogramPyPlot(self, event):
         """!Init PyPlot histogram display canvas and tools
         raster = []
-        if self.tree.layer_selected and \
-                self.tree.GetPyData(self.tree.layer_selected)[0]['type'] == 'raster':
-            raster.append(self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer'].name)
-        self.histogram2 = histogram2.HistFrame(self,
-                                            id = wx.ID_ANY, pos = wx.DefaultPosition, size = (700,300),
-                                            style = wx.DEFAULT_FRAME_STYLE, rasterList = raster)
-        self.histogram2.Show()
-        # Open raster select dialog to make sure that a raster (and the desired raster)
-        # is selected to be histogrammed
-        self.histogram2.OnSelectRaster(None)
-    def Histogram2(self, event):
+        for layer in self.tree.GetSelections():
+            if self.tree.GetPyData(layer)[0]['maplayer'].GetType() != 'raster':
+                continue
+            raster.append(self.tree.GetPyData(layer)[0]['maplayer'].GetName())
+        print raster
+        self.histogramPyPlot = HistFramePyPlot(parent = self, id = wx.ID_ANY, size = globalvar.HIST_WINDOW_SIZE,
+                                               style = wx.DEFAULT_FRAME_STYLE, rasterList = raster)
+        self.histogramPyPlot.Show()
+        # Open raster select dialog to make sure that a raster (and
+        # the desired raster) is selected to be histogrammed
+        if not raster:
+            self.histogramPyPlot.OnSelectRaster(None)
+        else:
+            self.histogramPyPlot.OnCreateHist(None)
+    def OnHistogram(self, event):
         """!Init histogram display canvas and tools
-                                             id = wx.ID_ANY, size = globalvar.HIST_WINDOW_SIZE,
-                                             style = wx.DEFAULT_FRAME_STYLE)
-        #show new display
-        self.histogram2.Refresh()
+        self.histogram = HistFrame(parent = self, id = wx.ID_ANY, size = globalvar.HIST_WINDOW_SIZE,
+                                   style = wx.DEFAULT_FRAME_STYLE)
+        # show new display
+        self.histogram.Show()
+        self.histogram.Refresh()
     def OnDecoration(self, event):
         """!Decorations overlay menu
