[GRASS-SVN] r48417 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Sep 22 12:56:46 EDT 2011
Author: martinl
Date: 2011-09-22 09:56:46 -0700 (Thu, 22 Sep 2011)
New Revision: 48417
grass/branches/develbranch_6/gui/wxpython/gui_modules/profile.py
wxGUI/profile: update code to follow wxGUI coding rules
(merge r48416 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/profile.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/profile.py 2011-09-22 16:44:40 UTC (rev 48416)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/profile.py 2011-09-22 16:56:46 UTC (rev 48417)
@@ -1,7 +1,7 @@
@package profile
-Profile analysis of GRASS raster maps and images.
+Profile analysis of raster maps and images.
Uses PyPlot (wx.lib.plot.py)
@@ -11,7 +11,7 @@
- TextDialog
- OptDialog
-(C) 2007-2008 by the GRASS Development Team
+(C) 2007-2008, 2011 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@@ -31,36 +31,34 @@
import numpy
import wx.lib.plot as plot
except ImportError:
- msg= _("This module requires the NumPy module, which could not be "
- "imported. It probably is not installed (it's not part of the "
- "standard Python distribution). See the Numeric Python site "
- "(http://numpy.scipy.org) for information on downloading source or "
- "binaries.")
+ msg = _("This module requires the NumPy module, which could not be "
+ "imported. It probably is not installed (it's not part of the "
+ "standard Python distribution). See the Numeric Python site "
+ "(http://numpy.scipy.org) for information on downloading source or "
+ "binaries.")
print >> sys.stderr, "profile.py: " + msg
import globalvar
-import render
-import menuform
-import disp_print
-import gselect
import gcmd
-import toolbars
-from debug import Debug as Debug
-from icon import Icons as Icons
-from preferences import globalSettings as UserSettings
+from render import Map
+from gselect import Select
+from toolbars import ProfileToolbar
+from debug import Debug
+from icon import Icons
+from preferences import globalSettings as UserSettings
from grass.script import core as grass
class ProfileFrame(wx.Frame):
"""!Mainframe for displaying profile of raster map. Uses wx.lib.plot.
- def __init__(self, parent=None, id=wx.ID_ANY, title=_("GRASS Profile Analysis Tool"),
- rasterList=[],
- pos=wx.DefaultPosition, size=wx.DefaultSize,
- style=wx.DEFAULT_FRAME_STYLE):
+ def __init__(self, parent = None, id = wx.ID_ANY, title = _("GRASS Profile Analysis Tool"),
+ rasterList = [],
+ style = wx.DEFAULT_FRAME_STYLE, **kwargs):
self.parent = parent # MapFrame
self.mapwin = self.parent.MapWindow
- self.Map = render.Map() # instance of render.Map to be associated with display
+ self.Map = Map() # instance of render.Map to be associated with display
self.pstyledict = { 'solid' : wx.SOLID,
'dot' : wx.DOT,
@@ -71,7 +69,7 @@
self.ptfilldict = { 'transparent' : wx.TRANSPARENT,
'solid' : wx.SOLID }
- wx.Frame.__init__(self, parent, id, title, pos, size, style)
+ wx.Frame.__init__(self, parent, id, title, style = style, **kwargs)
# Icon
@@ -81,18 +79,13 @@
# Add toolbar
- self.toolbar = toolbars.ProfileToolbar(parent=self)
+ self.toolbar = ProfileToolbar(parent = self)
self.SetToolBar(self.toolbar)
- # Set the size & cursor
- self.SetClientSize(size)
# Add statusbar
- self.statusbar = self.CreateStatusBar(number=2, style=0)
+ self.statusbar = self.CreateStatusBar(number = 2, style = 0)
self.statusbar.SetStatusWidths([-2, -1])
@@ -123,7 +116,7 @@
self.raster[idx]['datalist'] = []
# first (default) profile line
self.raster[idx]['pline'] = None
- self.raster[idx]['prop'] = UserSettings.Get(group='profile', key='raster' + str(idx))
+ self.raster[idx]['prop'] = UserSettings.Get(group = 'profile', key = 'raster' + str(idx))
# changing color string to tuple
colstr = str(self.raster[idx]['prop']['pcolor'])
self.raster[idx]['prop']['pcolor'] = tuple(int(colval) for colval in colstr.strip('()').split(','))
@@ -157,31 +150,31 @@
self.properties = {}
self.properties['font'] = {}
- self.properties['font']['prop'] = UserSettings.Get(group='profile', key='font')
+ self.properties['font']['prop'] = UserSettings.Get(group = 'profile', key = 'font')
self.properties['font']['wxfont'] = wx.Font(11, wx.FONTFAMILY_SWISS,
wx.FONTSTYLE_NORMAL,
wx.FONTWEIGHT_NORMAL)
- self.properties['marker'] = UserSettings.Get(group='profile', key='marker')
+ self.properties['marker'] = UserSettings.Get(group = 'profile', key = 'marker')
colstr = str(self.properties['marker']['color'])
self.properties['marker']['color'] = tuple(int(colval) for colval in colstr.strip('()').split(','))
- self.properties['grid'] = UserSettings.Get(group='profile', key='grid')
+ self.properties['grid'] = UserSettings.Get(group = 'profile', key = 'grid')
colstr = str(self.properties['grid']['color'])
self.properties['grid']['color'] = tuple(int(colval) for colval in colstr.strip('()').split(','))
self.properties['x-axis'] = {}
- self.properties['x-axis']['prop'] = UserSettings.Get(group='profile', key='x-axis')
+ self.properties['x-axis']['prop'] = UserSettings.Get(group = 'profile', key = 'x-axis')
self.properties['x-axis']['axis'] = None
self.properties['y-axis'] = {}
- self.properties['y-axis']['prop'] = UserSettings.Get(group='profile', key='y-axis')
+ self.properties['y-axis']['prop'] = UserSettings.Get(group = 'profile', key = 'y-axis')
self.properties['y-axis']['axis'] = None
- self.properties['legend'] = UserSettings.Get(group='profile', key='legend')
+ self.properties['legend'] = UserSettings.Get(group = 'profile', key = 'legend')
# zooming disabled
self.zoom = False
@@ -223,14 +216,14 @@
self.mapwin.mouse['use'] = 'profile'
self.mapwin.mouse['box'] = 'line'
- self.mapwin.pen = wx.Pen(colour='Red', width=2, style=wx.SHORT_DASH)
- self.mapwin.polypen = wx.Pen(colour='dark green', width=2, style=wx.SHORT_DASH)
+ self.mapwin.pen = wx.Pen(colour = 'Red', width = 2, style = wx.SHORT_DASH)
+ self.mapwin.polypen = wx.Pen(colour = 'dark green', width = 2, style = wx.SHORT_DASH)
self.mapwin.SetCursor(self.Parent.cursors["cross"])
def OnSelectRaster(self, event):
"""!Select raster map(s) to profile
- dlg = SetRasterDialog(parent=self)
+ dlg = SetRasterDialog(parent = self)
if dlg.ShowModal() == wx.ID_OK:
for r in self.raster.keys():
@@ -238,7 +231,7 @@
# plot profile
if self.raster[0]['name'] and len(self.mapwin.polycoords) > 0:
- self.OnCreateProfile(event=None)
+ self.OnCreateProfile(event = None)
dlg.Destroy()
@@ -419,29 +412,25 @@
transect_res = self.transect_length / 500
else: transect_res = curr_res
- try:
- ret = gcmd.RunCommand("r.profile",
- input=raster,
- profile=coords,
- res=transect_res,
- null="nan",
- quiet=True,
- read = True)
+ ret = gcmd.RunCommand("r.profile",
+ parent = self,
+ input = raster,
+ profile = coords,
+ res = transect_res,
+ null = "nan",
+ quiet = True,
+ read = True)
+ if not ret:
+ return dataset
- if not ret:
- return dataset
- for line in ret.splitlines():
- dist, elev = line.split(' ')
- if elev != 'nan':
- datalist.append((dist,elev))
- return datalist
- except gcmd.GException, e:
- gcmd.GError(parent = self,
- message = e.value)
- return None
+ for line in ret.splitlines():
+ dist, elev = line.strip().split(' ')
+ if elev != 'nan':
+ datalist.append((dist,elev))
+ return datalist
def OnCreateProfile(self, event):
"""!Main routine for creating a profile. Uses r.profile to
create a list of distance,cell value pairs. This is passed to
@@ -451,10 +440,10 @@
if len(self.mapwin.polycoords) == 0 or self.raster[0]['name'] == '':
- dlg = wx.MessageDialog(parent=self,
- message=_('You must draw a transect to profile in the map display window.'),
- caption=_('Nothing to profile'),
- style=wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
+ dlg = wx.MessageDialog(parent = self,
+ message = _('You must draw a transect to profile in the map display window.'),
+ caption = _('Nothing to profile'),
+ style = wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
dlg.ShowModal()
dlg.Destroy()
return
@@ -480,14 +469,14 @@
self.plotlist = []
if len(self.seglist) > 0 :
self.ppoints = plot.PolyMarker(self.seglist,
- legend=' ' + self.properties['marker']['legend'],
- colour=wx.Color(self.properties['marker']['color'][0],
+ legend = ' ' + self.properties['marker']['legend'],
+ colour = wx.Color(self.properties['marker']['color'][0],
self.properties['marker']['color'][1],
self.properties['marker']['color'][2],
255),
- size=self.properties['marker']['size'],
- fillstyle=self.ptfilldict[self.properties['marker']['fill']],
- marker=self.properties['marker']['type'])
+ size = self.properties['marker']['size'],
+ fillstyle = self.ptfilldict[self.properties['marker']['fill']],
+ marker = self.properties['marker']['type'])
self.plotlist.append(self.ppoints)
for r in self.raster.itervalues():
@@ -497,10 +486,10 @@
r['prop']['pcolor'][2],
255)
r['pline'] = plot.PolyLine(r['datalist'],
- colour=col,
- width=r['prop']['pwidth'],
- style=self.pstyledict[r['prop']['pstyle']],
- legend=r['plegend'])
+ colour = col,
+ width = r['prop']['pwidth'],
+ style = self.pstyledict[r['prop']['pstyle']],
+ legend = r['plegend'])
self.plotlist.append(r['pline'])
@@ -575,11 +564,10 @@
wildcard = _("Comma separated value (*.csv)|*.csv")
- dlg = wx.FileDialog(
- self, message=_("Path and prefix (for raster name) to save profile values..."),
- defaultDir=os.getcwd(),
- defaultFile="", wildcard=wildcard, style=wx.SAVE
+ dlg = wx.FileDialog(parent = self,
+ message = _("Path and prefix (for raster name) to save profile values..."),
+ defaultDir = os.getcwd(),
+ defaultFile = "", wildcard = wildcard, style = wx.SAVE)
path = dlg.GetPath()
@@ -593,9 +581,9 @@
try:
file = open(pfile, "w")
except IOError:
- wx.MessageBox(parent=self,
- message=_("Unable to open file <%s> for writing.") % pfile,
- caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+ wx.MessageBox(parent = self,
+ message = _("Unable to open file <%s> for writing.") % pfile,
+ caption = _("Error"), style = wx.OK | wx.ICON_ERROR | wx.CENTRE)
return False
for datapair in r['datalist']:
file.write('%d,%d\n' % (float(datapair[0]),float(datapair[1])))
@@ -627,9 +615,9 @@
dc.DrawText(s, sx , sy+1)
def OnMouseLeftDown(self,event):
- s= "Left Mouse Down at Point: (%.4f, %.4f)" % self.client._getXY(event)
- self.SetStatusText(s)
- event.Skip() #allows plotCanvas OnMouseLeftDown to be called
+ self.SetStatusText(_("Left Mouse Down at Point: (%.4f, %.4f)") % \
+ self.client._getXY(event))
+ event.Skip() # allows plotCanvas OnMouseLeftDown to be called
def OnMotion(self, event):
# indicate when mouse is outside the plot area
@@ -638,11 +626,11 @@
if self.client.GetEnablePointLabel() == True:
#make up dict with info for the pointLabel
#I've decided to mark the closest point on the closest curve
- dlst= self.client.GetClosetPoint( self.client._getXY(event), pointScaled= True)
+ dlst= self.client.GetClosetPoint( self.client._getXY(event), pointScaled = True)
if dlst != []: #returns [] if none
curveNum, legend, pIndex, pointXY, scaledXY, distance = dlst
#make up dictionary to pass to my user function (see DrawPointLabel)
- mDataDict= {"curveNum":curveNum, "legend":legend, "pIndex":pIndex,\
+ mDataDict = {"curveNum":curveNum, "legend":legend, "pIndex":pIndex,\
"pointXY":pointXY, "scaledXY":scaledXY}
#pass dict to update the pointLabel
self.client.UpdatePointLabel(mDataDict)
@@ -651,17 +639,14 @@
def ProfileOptionsMenu(self, event):
"""!Popup menu for profile and text options
- point = wx.GetMousePosition()
popt = wx.Menu()
- # Add items to the menu
- settext = wx.MenuItem(popt, -1, 'Profile text settings')
- popt.AppendItem(settext)
- self.Bind(wx.EVT_MENU, self.PText, settext)
- setgrid = wx.MenuItem(popt, -1, 'Profile plot settings')
- popt.AppendItem(setgrid)
- self.Bind(wx.EVT_MENU, self.POptions, setgrid)
+ for title, handler in ((_('Profile text settings'), self.PText),
+ (_('Profile plot settings'), self.POptions)):
+ item = wx.MenuItem(popt, wx.ID_ANY, title)
+ popt.AppendItem(item)
+ self.Bind(wx.EVT_MENU, handler, item)
# Popup the menu. If an item is selected then its handler
# will be called before PopupMenu returns.
self.PopupMenu(popt)
@@ -694,12 +679,12 @@
self.profile.setXLabel(dlg.xlabel)
self.profile.setYLabel(dlg.ylabel)
- self.OnRedraw(event=None)
+ self.OnRedraw(event = None)
def PText(self, event):
"""!Set custom text values for profile title and axis labels.
- dlg = TextDialog(parent=self, id=wx.ID_ANY, title=_('Profile text settings'))
+ dlg = TextDialog(parent = self, id = wx.ID_ANY, title = _('Profile text settings'))
self.OnPText(dlg)
@@ -711,7 +696,7 @@
style; marker size, color, fill, and style; grid and legend
options. Calls OptDialog class.
- dlg = OptDialog(parent=self, id=wx.ID_ANY, title=_('Profile settings'))
+ dlg = OptDialog(parent = self, id = wx.ID_ANY, title = _('Profile settings'))
btnval = dlg.ShowModal()
if btnval == wx.ID_SAVE:
@@ -724,21 +709,15 @@
def PrintMenu(self, event):
"""!Print options and output menu
printmenu = wx.Menu()
- setup = wx.MenuItem(printmenu, -1,'Page setup')
- printmenu.AppendItem(setup)
- self.Bind(wx.EVT_MENU, self.OnPageSetup, setup)
- preview = wx.MenuItem(printmenu, -1,'Print preview')
- printmenu.AppendItem(preview)
- self.Bind(wx.EVT_MENU, self.OnPrintPreview, preview)
- doprint = wx.MenuItem(printmenu, -1,'Print display')
- printmenu.AppendItem(doprint)
- self.Bind(wx.EVT_MENU, self.OnDoPrint, doprint)
+ for title, handler in ((_('Page setup'), self.OnPageSetup),
+ (_('Print preview'), self.OnPrintPreview),
+ (_('Print display'), self.OnDoPrint)):
+ item = wx.MenuItem(printmenu, wx.ID_ANY, title)
+ printmenu.AppendItem(item)
self.PopupMenu(printmenu)
@@ -767,19 +746,17 @@
self.mapwin.polycoords = []
self.mapwin.SetCursor(self.Parent.cursors["default"])
- self.mapwin.UpdateMap(render=False, renderVector=False)
+ self.mapwin.UpdateMap(render = False, renderVector = False)
self.Destroy()
class SetRasterDialog(wx.Dialog):
- def __init__(self, parent, id=wx.ID_ANY, title=_("Select raster map to profile"),
- style=wx.DEFAULT_DIALOG_STYLE):
+ def __init__(self, parent, id = wx.ID_ANY, title = _("Select raster map to profile"),
+ style = wx.DEFAULT_DIALOG_STYLE, **kwargs):
"""!Dialog to select raster maps to profile.
+ wx.Dialog.__init__(self, parent, id, title, style = style, **kwargs)
- wx.Dialog.__init__(self, parent, id, title, pos, size, style)
self.coordstr = self.parent.coordstr
@@ -803,33 +780,33 @@
sizer = wx.BoxSizer(wx.VERTICAL)
- box = wx.GridBagSizer (hgap=3, vgap=3)
+ box = wx.GridBagSizer (hgap = 3, vgap = 3)
i = 0
for txt in [_("Select raster map 1 (required):"),
_("Select raster map 2 (optional):"),
_("Select raster map 3 (optional):")]:
- label = wx.StaticText(parent=self, id=wx.ID_ANY, label=txt)
- box.Add(item=label,
- flag=wx.ALIGN_CENTER_VERTICAL, pos=(i, 0))
+ label = wx.StaticText(parent = self, id = wx.ID_ANY, label = txt)
+ box.Add(item = label,
+ flag = wx.ALIGN_CENTER_VERTICAL, pos = (i, 0))
- selection = gselect.Select(self, id=wx.ID_ANY,
- size=globalvar.DIALOG_GSELECT_SIZE,
- type='cell')
+ selection = Select(self, id = wx.ID_ANY,
+ size = globalvar.DIALOG_GSELECT_SIZE,
+ type = 'cell')
selection.SetValue(str(self.raster[i]['name']))
self.raster[i]['id'] = selection.GetChildren()[0].GetId()
selection.Bind(wx.EVT_TEXT, self.OnSelection)
- box.Add(item=selection, pos=(i, 1))
+ box.Add(item = selection, pos = (i, 1))
i += 1
- sizer.Add(item=box, proportion=0,
- flag=wx.ALL, border=10)
+ sizer.Add(item = box, proportion = 0,
+ flag = wx.ALL, border = 10)
- line = wx.StaticLine(parent=self, id=wx.ID_ANY, size=(20, -1), style=wx.LI_HORIZONTAL)
- sizer.Add(item=line, proportion=0,
- flag=wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.LEFT|wx.RIGHT, border=5)
+ line = wx.StaticLine(parent = self, id = wx.ID_ANY, size = (20, -1), style = wx.LI_HORIZONTAL)
+ sizer.Add(item = line, proportion = 0,
+ flag = wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.LEFT|wx.RIGHT, border = 5)
btnsizer = wx.StdDialogButtonSizer()
@@ -841,7 +818,7 @@
btnsizer.AddButton(btn)
btnsizer.Realize()
- sizer.Add(item=btnsizer, proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=5)
+ sizer.Add(item = btnsizer, proportion = 0, flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
self.SetSizer(sizer)
sizer.Fit(self)
@@ -854,12 +831,12 @@
break
class TextDialog(wx.Dialog):
- def __init__(self, parent, id, title, pos=wx.DefaultPosition, size=wx.DefaultSize,
+ def __init__(self, parent, id, title,
"""!Dialog to set profile text options: font, title
and font size, axis labels and font size
# initialize variables
@@ -900,124 +877,124 @@
# dialog layout
- box = wx.StaticBox(parent=self, id=wx.ID_ANY,
- label=" %s " % _("Text settings"))
+ box = wx.StaticBox(parent = self, id = wx.ID_ANY,
+ label = " %s " % _("Text settings"))
boxSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
- gridSizer = wx.GridBagSizer(vgap=5, hgap=5)
+ gridSizer = wx.GridBagSizer(vgap = 5, hgap = 5)
# profile title
- label = wx.StaticText(parent=self, id=wx.ID_ANY, label=_("Profile title:"))
- gridSizer.Add(item=label, flag=wx.ALIGN_CENTER_VERTICAL, pos=(0, 0))
- self.ptitleentry = wx.TextCtrl(parent=self, id=wx.ID_ANY, value="", size=(250,-1))
+ label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Profile title:"))
+ gridSizer.Add(item = label, flag = wx.ALIGN_CENTER_VERTICAL, pos = (0, 0))
+ self.ptitleentry = wx.TextCtrl(parent = self, id = wx.ID_ANY, value = "", size = (250,-1))
# self.ptitleentry.SetFont(self.font)
self.ptitleentry.SetValue(self.ptitle)
- gridSizer.Add(item=self.ptitleentry, pos=(0, 1))
+ gridSizer.Add(item = self.ptitleentry, pos = (0, 1))
# title font
- tlabel = wx.StaticText(parent=self, id=wx.ID_ANY, label=_("Title font size (pts):"))
- gridSizer.Add(item=tlabel, flag=wx.ALIGN_CENTER_VERTICAL, pos=(1, 0))
- self.ptitlesize = wx.SpinCtrl(parent=self, id=wx.ID_ANY, value="", pos=(30, 50),
- size=(50,-1), style=wx.SP_ARROW_KEYS)
+ tlabel = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Title font size (pts):"))
+ gridSizer.Add(item = tlabel, flag = wx.ALIGN_CENTER_VERTICAL, pos = (1, 0))
+ self.ptitlesize = wx.SpinCtrl(parent = self, id = wx.ID_ANY, value = "", pos = (30, 50),
+ size = (50,-1), style = wx.SP_ARROW_KEYS)
self.ptitlesize.SetRange(5,100)
self.ptitlesize.SetValue(int(self.properties['font']['prop']['titleSize']))
- gridSizer.Add(item=self.ptitlesize, pos=(1, 1))
+ gridSizer.Add(item = self.ptitlesize, pos = (1, 1))
# x-axis label
- label = wx.StaticText(parent=self, id=wx.ID_ANY, label=_("X-axis label:"))
- gridSizer.Add(item=label, flag=wx.ALIGN_CENTER_VERTICAL, pos=(2, 0))
- self.xlabelentry = wx.TextCtrl(parent=self, id=wx.ID_ANY, value="", size=(250,-1))
+ label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("X-axis label:"))
+ gridSizer.Add(item = label, flag = wx.ALIGN_CENTER_VERTICAL, pos = (2, 0))
+ self.xlabelentry = wx.TextCtrl(parent = self, id = wx.ID_ANY, value = "", size = (250,-1))
# self.xlabelentry.SetFont(self.font)
self.xlabelentry.SetValue(self.xlabel)
- gridSizer.Add(item=self.xlabelentry, pos=(2, 1))
+ gridSizer.Add(item = self.xlabelentry, pos = (2, 1))
# y-axis label
- label = wx.StaticText(parent=self, id=wx.ID_ANY, label=_("Y-axis label:"))
- gridSizer.Add(item=label, flag=wx.ALIGN_CENTER_VERTICAL, pos=(3, 0))
- self.ylabelentry = wx.TextCtrl(parent=self, id=wx.ID_ANY, value="", size=(250,-1))
+ label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Y-axis label:"))
+ gridSizer.Add(item = label, flag = wx.ALIGN_CENTER_VERTICAL, pos = (3, 0))
+ self.ylabelentry = wx.TextCtrl(parent = self, id = wx.ID_ANY, value = "", size = (250,-1))
# self.ylabelentry.SetFont(self.font)
self.ylabelentry.SetValue(self.ylabel)
- gridSizer.Add(item=self.ylabelentry, pos=(3, 1))
+ gridSizer.Add(item = self.ylabelentry, pos = (3, 1))
# font size
- llabel = wx.StaticText(parent=self, id=wx.ID_ANY, label=_("Label font size (pts):"))
- gridSizer.Add(item=llabel, flag=wx.ALIGN_CENTER_VERTICAL, pos=(4, 0))
- self.axislabelsize = wx.SpinCtrl(parent=self, id=wx.ID_ANY, value="", pos=(30, 50),
- size=(50, -1), style=wx.SP_ARROW_KEYS)
+ llabel = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Label font size (pts):"))
+ gridSizer.Add(item = llabel, flag = wx.ALIGN_CENTER_VERTICAL, pos = (4, 0))
+ self.axislabelsize = wx.SpinCtrl(parent = self, id = wx.ID_ANY, value = "", pos = (30, 50),
+ size = (50, -1), style = wx.SP_ARROW_KEYS)
self.axislabelsize.SetRange(5, 100)
self.axislabelsize.SetValue(int(self.properties['font']['prop']['axisSize']))
- gridSizer.Add(item=self.axislabelsize, pos=(4,1))
+ gridSizer.Add(item = self.axislabelsize, pos = (4,1))
- boxSizer.Add(item=gridSizer)
- sizer.Add(item=boxSizer, flag=wx.ALL | wx.EXPAND, border=3)
+ boxSizer.Add(item = gridSizer)
+ sizer.Add(item = boxSizer, flag = wx.ALL | wx.EXPAND, border = 3)
# font settings
- label=" %s " % _("Font settings"))
+ label = " %s " % _("Font settings"))
gridSizer.AddGrowableCol(1)
# font family
- label1 = wx.StaticText(parent=self, id=wx.ID_ANY, label=_("Font family:"))
- gridSizer.Add(item=label1, flag=wx.ALIGN_CENTER_VERTICAL, pos=(0, 0))
- self.ffamilycb = wx.ComboBox(parent=self, id=wx.ID_ANY, size=(250, -1),
- choices=self.ffamilydict.keys(), style=wx.CB_DROPDOWN)
+ label1 = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Font family:"))
+ gridSizer.Add(item = label1, flag = wx.ALIGN_CENTER_VERTICAL, pos = (0, 0))
+ self.ffamilycb = wx.ComboBox(parent = self, id = wx.ID_ANY, size = (250, -1),
+ choices = self.ffamilydict.keys(), style = wx.CB_DROPDOWN)
self.ffamilycb.SetStringSelection('swiss')
for item in self.ffamilydict.items():
if self.fontfamily == item[1]:
self.ffamilycb.SetStringSelection(item[0])
break
- gridSizer.Add(item=self.ffamilycb, pos=(0, 1), flag=wx.ALIGN_RIGHT)
+ gridSizer.Add(item = self.ffamilycb, pos = (0, 1), flag = wx.ALIGN_RIGHT)
# font style
- label = wx.StaticText(parent=self, id=wx.ID_ANY, label=_("Style:"))
- gridSizer.Add(item=label, flag=wx.ALIGN_CENTER_VERTICAL, pos=(1, 0))
- self.fstylecb = wx.ComboBox(parent=self, id=wx.ID_ANY, size=(250, -1),
- choices=self.fstyledict.keys(), style=wx.CB_DROPDOWN)
+ label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Style:"))
+ gridSizer.Add(item = label, flag = wx.ALIGN_CENTER_VERTICAL, pos = (1, 0))
+ self.fstylecb = wx.ComboBox(parent = self, id = wx.ID_ANY, size = (250, -1),
+ choices = self.fstyledict.keys(), style = wx.CB_DROPDOWN)
self.fstylecb.SetStringSelection('normal')
for item in self.fstyledict.items():
if self.fontstyle == item[1]:
self.fstylecb.SetStringSelection(item[0])
break
- gridSizer.Add(item=self.fstylecb, pos=(1, 1), flag=wx.ALIGN_RIGHT)
+ gridSizer.Add(item = self.fstylecb, pos = (1, 1), flag = wx.ALIGN_RIGHT)
# font weight
- label = wx.StaticText(parent=self, id=wx.ID_ANY, label=_("Weight:"))
- self.fwtcb = wx.ComboBox(parent=self, size=(250, -1),
- choices=self.fwtdict.keys(), style=wx.CB_DROPDOWN)
+ label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Weight:"))
+ self.fwtcb = wx.ComboBox(parent = self, size = (250, -1),
+ choices = self.fwtdict.keys(), style = wx.CB_DROPDOWN)
self.fwtcb.SetStringSelection('normal')
for item in self.fwtdict.items():
if self.fontweight == item[1]:
self.fwtcb.SetStringSelection(item[0])
break
- gridSizer.Add(item=self.fwtcb, pos=(2, 1), flag=wx.ALIGN_RIGHT)
+ gridSizer.Add(item = self.fwtcb, pos = (2, 1), flag = wx.ALIGN_RIGHT)
- boxSizer.Add(item=gridSizer, flag=wx.EXPAND)
- sizer.Add(item=boxSizer, flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=3)
+ boxSizer.Add(item = gridSizer, flag = wx.EXPAND)
+ sizer.Add(item = boxSizer, flag = wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border = 3)
- flag=wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.LEFT|wx.RIGHT, border=3)
+ flag = wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.LEFT|wx.RIGHT, border = 3)
# buttons
@@ -1047,9 +1024,9 @@
btnStdSizer.Realize()
btnSizer = wx.BoxSizer(wx.HORIZONTAL)
- btnSizer.Add(item=btnSave, proportion=0, flag=wx.ALIGN_LEFT | wx.ALL, border=5)
- btnSizer.Add(item=btnStdSizer, proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=5)
- sizer.Add(item=btnSizer, proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=5)
+ btnSizer.Add(item = btnSave, proportion = 0, flag = wx.ALIGN_LEFT | wx.ALL, border = 5)
+ btnSizer.Add(item = btnStdSizer, proportion = 0, flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
+ sizer.Add(item = btnSizer, proportion = 0, flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
# bindings
@@ -1085,8 +1062,8 @@
"""!Button 'Save' pressed"""
self.UpdateSettings()
fileSettings = {}
- UserSettings.ReadSettingsFile(settings=fileSettings)
- fileSettings['profile'] = UserSettings.Get(group='profile')
+ UserSettings.ReadSettingsFile(settings = fileSettings)
+ fileSettings['profile'] = UserSettings.Get(group = 'profile')
file = UserSettings.SaveToFile(fileSettings)
self.parent.parent.GetLayerManager().goutput.WriteLog(_('Profile settings saved to file \'%s\'.') % file)
self.EndModal(wx.ID_OK)
@@ -1106,13 +1083,13 @@
self.EndModal(wx.ID_CANCEL)
class OptDialog(wx.Dialog):
"""!Dialog to set various profile options, including: line
width, color, style; marker size, color, fill, and style; grid
and legend options.
# init variables
self.pstyledict = parent.pstyledict
self.ptfilldict = parent.ptfilldict
@@ -1148,8 +1125,8 @@
# profile line settings
- label=" %s " % _("Profile line settings"))
+ label = " %s " % _("Profile line settings"))
boxMainSizer = wx.StaticBoxSizer(box, wx.HORIZONTAL)
idx = 1
@@ -1158,113 +1135,113 @@
self.wxId['pstyle'] = []
self.wxId['plegend'] = []
- label=" %s %d " % (_("Profile"), idx))
+ label = " %s %d " % (_("Profile"), idx))
row = 0
- label = wx.StaticText(parent=self, id=wx.ID_ANY, label=_("Line color"))
- gridSizer.Add(item=label, flag=wx.ALIGN_CENTER_VERTICAL, pos=(row, 0))
- pcolor = csel.ColourSelect(parent=self, id=wx.ID_ANY, colour=r['prop']['pcolor'])
+ label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Line color"))
+ gridSizer.Add(item = label, flag = wx.ALIGN_CENTER_VERTICAL, pos = (row, 0))
+ pcolor = csel.ColourSelect(parent = self, id = wx.ID_ANY, colour = r['prop']['pcolor'])
self.wxId['pcolor'].append(pcolor.GetId())
- gridSizer.Add(item=pcolor, pos=(row, 1))
+ gridSizer.Add(item = pcolor, pos = (row, 1))
row += 1
- label = wx.StaticText(parent=self, id=wx.ID_ANY, label=_("Line width"))
- pwidth = wx.SpinCtrl(parent=self, id=wx.ID_ANY, value="",
+ label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Line width"))
+ pwidth = wx.SpinCtrl(parent = self, id = wx.ID_ANY, value = "",
pwidth.SetRange(1, 10)
pwidth.SetValue(r['prop']['pwidth'])
self.wxId['pwidth'].append(pwidth.GetId())
- gridSizer.Add(item=pwidth, pos=(row, 1))
+ gridSizer.Add(item = pwidth, pos = (row, 1))
row +=1
- label = wx.StaticText(parent=self, id=wx.ID_ANY, label=_("Line style"))
- pstyle = wx.ComboBox(parent=self, id=wx.ID_ANY,
- size=(120, -1), choices=self.pstyledict.keys(), style=wx.CB_DROPDOWN)
+ label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Line style"))
+ pstyle = wx.ComboBox(parent = self, id = wx.ID_ANY,
+ size = (120, -1), choices = self.pstyledict.keys(), style = wx.CB_DROPDOWN)
pstyle.SetStringSelection(r['prop']['pstyle'])
self.wxId['pstyle'].append(pstyle.GetId())
- gridSizer.Add(item=pstyle, pos=(row, 1))
+ gridSizer.Add(item = pstyle, pos = (row, 1))
row += 1
- label = wx.StaticText(parent=self, id=wx.ID_ANY, label=_("Legend"))
- plegend = wx.TextCtrl(parent=self, id=wx.ID_ANY, value="", size=(200,-1))
+ label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Legend"))
+ plegend = wx.TextCtrl(parent = self, id = wx.ID_ANY, value = "", size = (200,-1))
plegend.SetValue(r['plegend'])
- gridSizer.Add(item=plegend, pos=(row, 1))
+ gridSizer.Add(item = plegend, pos = (row, 1))
self.wxId['plegend'].append(plegend.GetId())
if idx == 0:
flag = wx.ALL
else:
flag = wx.TOP | wx.BOTTOM | wx.RIGHT
- boxMainSizer.Add(item=boxSizer, flag=flag, border=3)
+ boxMainSizer.Add(item = boxSizer, flag = flag, border = 3)
idx += 1
- sizer.Add(item=boxMainSizer, flag=wx.ALL | wx.EXPAND, border=3)
+ sizer.Add(item = boxMainSizer, flag = wx.ALL | wx.EXPAND, border = 3)
middleSizer = wx.BoxSizer(wx.HORIZONTAL)
# segment marker settings
- label=" %s " % _("Transect segment marker settings"))
+ label = " %s " % _("Transect segment marker settings"))
self.wxId['marker'] = {}
- label = wx.StaticText(parent=self, id=wx.ID_ANY, label=_("Color"))
- ptcolor = csel.ColourSelect(parent=self, id=wx.ID_ANY, colour=self.properties['marker']['color'])
+ label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Color"))
+ ptcolor = csel.ColourSelect(parent = self, id = wx.ID_ANY, colour = self.properties['marker']['color'])
self.wxId['marker']['color'] = ptcolor.GetId()
- gridSizer.Add(item=ptcolor, pos=(0, 1))
+ gridSizer.Add(item = ptcolor, pos = (0, 1))
- label = wx.StaticText(parent=self, id=wx.ID_ANY, label=_("Size"))
- ptsize = wx.SpinCtrl(parent=self, id=wx.ID_ANY, value="",
+ label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Size"))
+ ptsize = wx.SpinCtrl(parent = self, id = wx.ID_ANY, value = "",
ptsize.SetRange(1, 10)
ptsize.SetValue(self.properties['marker']['size'])
self.wxId['marker']['size'] = ptsize.GetId()
- gridSizer.Add(item=ptsize, pos=(1, 1))
+ gridSizer.Add(item = ptsize, pos = (1, 1))
- label = wx.StaticText(parent=self, id=wx.ID_ANY, label=_("Style"))
- ptfill = wx.ComboBox(parent=self, id=wx.ID_ANY,
- size=(120, -1), choices=self.ptfilldict.keys(), style=wx.CB_DROPDOWN)
+ label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Style"))
+ ptfill = wx.ComboBox(parent = self, id = wx.ID_ANY,
+ size = (120, -1), choices = self.ptfilldict.keys(), style = wx.CB_DROPDOWN)
ptfill.SetStringSelection(self.properties['marker']['fill'])
self.wxId['marker']['fill'] = ptfill.GetId()
- gridSizer.Add(item=ptfill, pos=(2, 1))
+ gridSizer.Add(item = ptfill, pos = (2, 1))
- ptlegend = wx.TextCtrl(parent=self, id=wx.ID_ANY, value="", size=(200,-1))
+ ptlegend = wx.TextCtrl(parent = self, id = wx.ID_ANY, value = "", size = (200,-1))
ptlegend.SetValue(self.properties['marker']['legend'])
self.wxId['marker']['legend'] = ptlegend.GetId()
- gridSizer.Add(item=ptlegend, pos=(3, 1))
+ gridSizer.Add(item = ptlegend, pos = (3, 1))
- label = wx.StaticText(parent=self, id=wx.ID_ANY, label=_("Type"))
- gridSizer.Add(item=label, flag=wx.ALIGN_CENTER_VERTICAL, pos=(4, 0))
- pttype = wx.ComboBox(parent=self,
- size=(200, -1), choices=self.pttypelist, style=wx.CB_DROPDOWN)
+ label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Type"))
+ gridSizer.Add(item = label, flag = wx.ALIGN_CENTER_VERTICAL, pos = (4, 0))
+ pttype = wx.ComboBox(parent = self,
+ size = (200, -1), choices = self.pttypelist, style = wx.CB_DROPDOWN)
pttype.SetStringSelection(self.properties['marker']['type'])
self.wxId['marker']['type'] = pttype.GetId()
- gridSizer.Add(item=pttype, pos=(4, 1))
+ gridSizer.Add(item = pttype, pos = (4, 1))
- boxMainSizer.Add(item=gridSizer, flag=wx.ALL, border=3)
- middleSizer.Add(item=boxMainSizer, flag=wx.ALL | wx.EXPAND, border=3)
+ boxMainSizer.Add(item = gridSizer, flag = wx.ALL, border = 3)
+ middleSizer.Add(item = boxMainSizer, flag = wx.ALL | wx.EXPAND, border = 3)
# axis options
- label=" %s " % _("Axis settings"))
+ label = " %s " % _("Axis settings"))
self.wxId['x-axis'] = {}
@@ -1272,55 +1249,55 @@
idx = 0
for axis, atype in [(_("X-Axis"), 'x-axis'),
(_("Y-Axis"), 'y-axis')]:
- label=" %s " % axis)
+ label = " %s " % axis)
boxSizer = wx.StaticBoxSizer(box, wx.HORIZONTAL)
prop = self.properties[atype]['prop']
row = 0
- type = wx.ComboBox(parent=self, id=wx.ID_ANY,
- size=(100, -1), choices=self.axislist, style=wx.CB_DROPDOWN)
+ type = wx.ComboBox(parent = self, id = wx.ID_ANY,
+ size = (100, -1), choices = self.axislist, style = wx.CB_DROPDOWN)
type.SetStringSelection(prop['type'])
self.wxId[atype]['type'] = type.GetId()
- gridSizer.Add(item=type, pos=(row, 1))
+ gridSizer.Add(item = type, pos = (row, 1))
row += 1
- label = wx.StaticText(parent=self, id=wx.ID_ANY, label=_("Custom min"))
- min = wx.TextCtrl(parent=self, id=wx.ID_ANY, value="", size=(70, -1))
+ label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Custom min"))
+ min = wx.TextCtrl(parent = self, id = wx.ID_ANY, value = "", size = (70, -1))
min.SetValue(str(prop['min']))
self.wxId[atype]['min'] = min.GetId()
- gridSizer.Add(item=min, pos=(row, 1))
+ gridSizer.Add(item = min, pos = (row, 1))
row += 1
- label = wx.StaticText(parent=self, id=wx.ID_ANY, label=_("Custom max"))
- max = wx.TextCtrl(parent=self, id=wx.ID_ANY, value="", size=(70, -1))
+ label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Custom max"))
+ max = wx.TextCtrl(parent = self, id = wx.ID_ANY, value = "", size = (70, -1))
max.SetValue(str(prop['max']))
self.wxId[atype]['max'] = max.GetId()
- gridSizer.Add(item=max, pos=(row, 1))
+ gridSizer.Add(item = max, pos = (row, 1))
row += 1
- log = wx.CheckBox(parent=self, id=wx.ID_ANY, label=_("Log scale"))
+ log = wx.CheckBox(parent = self, id = wx.ID_ANY, label = _("Log scale"))
log.SetValue(prop['log'])
self.wxId[atype]['log'] = log.GetId()
- gridSizer.Add(item=log, pos=(row, 0), span=(1, 2))
+ gridSizer.Add(item = log, pos = (row, 0), span = (1, 2))
if idx == 0:
else:
flag = wx.TOP | wx.BOTTOM | wx.RIGHT | wx.EXPAND
- boxSizer.Add(item=gridSizer, flag=wx.ALL, border=3)
+ boxSizer.Add(item = gridSizer, flag = wx.ALL, border = 3)
idx += 1
# grid & legend options
@@ -1328,52 +1305,52 @@
self.wxId['grid'] = {}
self.wxId['legend'] = {}
self.wxId['font'] = {}
- label=" %s " % _("Grid and Legend settings"))
+ label = " %s " % _("Grid and Legend settings"))
row = 0
- label = wx.StaticText(parent=self, id=wx.ID_ANY, label=_("Grid color"))
- gridcolor = csel.ColourSelect(parent=self, id=wx.ID_ANY, colour=self.properties['grid']['color'])
+ label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Grid color"))
+ gridcolor = csel.ColourSelect(parent = self, id = wx.ID_ANY, colour = self.properties['grid']['color'])
self.wxId['grid']['color'] = gridcolor.GetId()
- gridSizer.Add(item=gridcolor, pos=(row, 1))
+ gridSizer.Add(item = gridcolor, pos = (row, 1))
row +=1
- gridshow = wx.CheckBox(parent=self, id=wx.ID_ANY, label=_("Show grid"))
+ gridshow = wx.CheckBox(parent = self, id = wx.ID_ANY, label = _("Show grid"))
gridshow.SetValue(self.properties['grid']['enabled'])
self.wxId['grid']['enabled'] = gridshow.GetId()
- gridSizer.Add(item=gridshow, pos=(row, 0), span=(1, 2))
+ gridSizer.Add(item = gridshow, pos = (row, 0), span = (1, 2))
row +=1
- label = wx.StaticText(parent=self, id=wx.ID_ANY, label=_("Legend font size"))
- legendfontsize = wx.SpinCtrl(parent=self, id=wx.ID_ANY, value="",
+ label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Legend font size"))
+ legendfontsize = wx.SpinCtrl(parent = self, id = wx.ID_ANY, value = "",
legendfontsize.SetRange(5,100)
legendfontsize.SetValue(int(self.properties['font']['prop']['legendSize']))
self.wxId['font']['legendSize'] = legendfontsize.GetId()
- gridSizer.Add(item=legendfontsize, pos=(row, 1))
+ gridSizer.Add(item = legendfontsize, pos = (row, 1))
row += 1
- legendshow = wx.CheckBox(parent=self, id=wx.ID_ANY, label=_("Show legend"))
+ legendshow = wx.CheckBox(parent = self, id = wx.ID_ANY, label = _("Show legend"))
legendshow.SetValue(self.properties['legend']['enabled'])
self.wxId['legend']['enabled'] = legendshow.GetId()
- gridSizer.Add(item=legendshow, pos=(row, 0), span=(1, 2))
+ gridSizer.Add(item = legendshow, pos = (row, 0), span = (1, 2))
- boxMainSizer.Add(item=gridSizer, flag=flag, border=3)
+ boxMainSizer.Add(item = gridSizer, flag = flag, border = 3)
- middleSizer.Add(item=boxMainSizer, flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=3)
+ middleSizer.Add(item = boxMainSizer, flag = wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border = 3)
- sizer.Add(item=middleSizer, flag=wx.ALL, border=0)
+ sizer.Add(item = middleSizer, flag = wx.ALL, border = 0)
# line & buttons
# buttons
@@ -1399,7 +1376,7 @@
btnStdSizer.AddButton(btnApply)
- sizer.Add(item=btnStdSizer, proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=5)
+ sizer.Add(item = btnStdSizer, proportion = 0, flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
sizer.Fit(self)
@@ -1435,8 +1412,8 @@
fileSettings = {}
self.parent.SetGraphStyle()
