[GRASS-SVN] r48425 -
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
svn_grass at osgeo.org
Fri Sep 23 13:18:44 EDT 2011
Author: martinl
Date: 2011-09-23 10:18:44 -0700 (Fri, 23 Sep 2011)
New Revision: 48425
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm.py
wxGUI: #1007 (WxGUI should provide visual feedback when adding new db column)
(merge r48423 from trunk)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm.py 2011-09-23 17:16:04 UTC (rev 48424)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm.py 2011-09-23 17:18:44 UTC (rev 48425)
@@ -18,7 +18,7 @@
- VirtualAttributeList
- AttributeManager
-(C) 2007-2009 by the GRASS Development Team
+(C) 2007-2009, 2011 by the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
@@ -1742,47 +1742,46 @@
"""!Add new column to the table"""
table = self.mapDBInfo.layers[self.layer]['table']
name = self.FindWindowById(self.layerPage[self.layer]['addColName']).GetValue()
if not name:
- wx.MessageBox(parent=self,
- message=_("Unable to add column to the table. "
- "No column name defined."),
- caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+ gcmd.GError(parent = self,
+ message = _("Unable to add column to the table. "
+ "No column name defined."))
return
- type = self.FindWindowById(self.layerPage[self.layer]['addColType']). \
+ ctype = self.FindWindowById(self.layerPage[self.layer]['addColType']). \
GetStringSelection()
# cast type if needed
- if type == 'double':
- type = 'double precision'
- if type == 'varchar':
+ if ctype == 'double':
+ ctype = 'double precision'
+ if ctype == 'varchar':
length = int(self.FindWindowById(self.layerPage[self.layer]['addColLength']). \
GetValue())
else:
length = '' # FIXME
# add item to the list of table columns
- list = self.FindWindowById(self.layerPage[self.layer]['tableData'])
+ tlist = self.FindWindowById(self.layerPage[self.layer]['tableData'])
# check for duplicate items
- if list.FindItem(start=-1, str=name) > -1:
- message=_("Column <%(column)s> already exists in table <%(table)s>.") % \
- {'column' : name, 'table' : self.mapDBInfo.layers[self.layer]["table"]},
+ if tlist.FindItem(start=-1, str=name) > -1:
+ message = _("Column <%(column)s> already exists in table <%(table)s>.") % \
+ {'column' : name, 'table' : self.mapDBInfo.layers[self.layer]["table"]}
return
- index = list.InsertStringItem(sys.maxint, str(name))
- list.SetStringItem(index, 0, str(name))
- list.SetStringItem(index, 1, str(type))
- list.SetStringItem(index, 2, str(length))
+ index = tlist.InsertStringItem(sys.maxint, str(name))
+ tlist.SetStringItem(index, 0, str(name))
+ tlist.SetStringItem(index, 1, str(ctype))
+ tlist.SetStringItem(index, 2, str(length))
# add v.db.addcol command to the list
- type += ' (%d)' % length
+ ctype += ' (%d)' % length
self.listOfCommands.append(('v.db.addcol',
- { 'map' : self.vectorName,
- 'layer' : self.layer,
- 'columns' : '%s %s' % (name, type) }
+ { 'map' : self.vectorName,
+ 'layer' : self.layer,
+ 'columns' : '%s %s' % (name, ctype) }
# apply changes
self.ApplyCommands()
@@ -1857,6 +1856,8 @@
def ApplyCommands(self):
"""!Apply changes"""
# perform GRASS commands (e.g. v.db.addcol)
+ wx.BeginBusyCursor()
if len(self.listOfCommands) > 0:
for cmd in self.listOfCommands:
gcmd.RunCommand(prog = cmd[0],
@@ -1879,7 +1880,7 @@
# reset list of commands
self.listOfCommands = []
# perform SQL non-select statements (e.g. 'delete from table where cat=1')
if len(self.listOfSQLStatements) > 0:
sqlFile = tempfile.NamedTemporaryFile(mode="wt")
@@ -1896,10 +1897,10 @@
driver = self.mapDBInfo.layers[self.layer]["driver"]
database = self.mapDBInfo.layers[self.layer]["database"]
Debug.msg(3, 'AttributeManger.ApplyCommands(): %s' %
';'.join(["%s" % s for s in self.listOfSQLStatements]))
gcmd.RunCommand('db.execute',
parent = self,
input = sqlFile.name,
@@ -1908,13 +1909,17 @@
# reset list of statements
self.listOfSQLStatements = []
+ wx.EndBusyCursor()
def OnApplySqlStatement(self, event):
"""!Apply simple/advanced sql statement"""
keyColumn = -1 # index of key column
listWin = self.FindWindowById(self.layerPage[self.layer]['data'])
sql = None
if self.FindWindowById(self.layerPage[self.layer]['simple']).GetValue():
# simple sql statement
whereCol = self.FindWindowById(self.layerPage[self.layer]['whereColumn']).GetStringSelection()
@@ -1962,6 +1967,8 @@
else:
listWin.SortListItems(col=0, ascending=True)
# update statusbar
self.log.write(_("Number of loaded records: %d") % \
self.FindWindowById(self.layerPage[self.layer]['data']).GetItemCount())
