[GRASS-SVN] r48434 - grass/trunk/vector/v.edit
svn_grass at osgeo.org
Fri Sep 23 15:30:41 EDT 2011
Author: martinl
Date: 2011-09-23 12:30:41 -0700 (Fri, 23 Sep 2011)
New Revision: 48434
grass/trunk/vector/v.edit/args.c
grass/trunk/vector/v.edit/main.c
v.edit: require <input> for `tool=add`
Modified: grass/trunk/vector/v.edit/args.c
--- grass/trunk/vector/v.edit/args.c 2011-09-23 18:28:27 UTC (rev 48433)
+++ grass/trunk/vector/v.edit/args.c 2011-09-23 19:30:41 UTC (rev 48434)
@@ -77,9 +77,9 @@
params->in = G_define_standard_option(G_OPT_F_INPUT);
params->in->required = NO;
- params->in->label = _("ASCII file to be converted to binary vector map");
+ params->in->label = _("Name of file containing data in GRASS ASCII vector format");
params->in->description =
- _("If not given (or \"-\") reads from standard input");
+ _("\"-\" reads from standard input");
params->in->guisection = _("Input");
params->move = G_define_option();
Modified: grass/trunk/vector/v.edit/main.c
--- grass/trunk/vector/v.edit/main.c 2011-09-23 18:28:27 UTC (rev 48433)
+++ grass/trunk/vector/v.edit/main.c 2011-09-23 19:30:41 UTC (rev 48434)
@@ -68,17 +68,19 @@
/* open input file */
- if (params.in->answer &&
- strcmp(params.in->answer, "-") != 0) {
- ascii = fopen(params.in->answer, "r");
- if (ascii == NULL) {
- G_fatal_error(_("Unable to open file <%s>"),
- params.in->answer);
+ if (params.in->answer) {
+ if (strcmp(params.in->answer, "-") != 0) {
+ ascii = fopen(params.in->answer, "r");
+ if (ascii == NULL)
+ G_fatal_error(_("Unable to open file <%s>"),
+ params.in->answer);
+ else {
+ ascii = stdin;
- else if (action_mode != MODE_CREATE) {
- ascii = stdin;
+ if (!ascii && action_mode == MODE_ADD)
+ G_fatal_error(_("Required parameter <%s> not set"), params.in->key);
if (action_mode == MODE_CREATE) {
int overwrite;
