[GRASS-SVN] r48505 - grass/branches/develbranch_6/display/d.vect
svn_grass at osgeo.org
Tue Sep 27 15:07:50 EDT 2011
Author: martinl
Date: 2011-09-27 12:07:50 -0700 (Tue, 27 Sep 2011)
New Revision: 48505
grass/branches/develbranch_6/display/d.vect/main.c
d.vect: sort symbols
(merge r48504 from trunk)
Modified: grass/branches/develbranch_6/display/d.vect/main.c
--- grass/branches/develbranch_6/display/d.vect/main.c 2011-09-27 19:04:27 UTC (rev 48504)
+++ grass/branches/develbranch_6/display/d.vect/main.c 2011-09-27 19:07:50 UTC (rev 48505)
@@ -27,53 +27,9 @@
#include "plot.h"
#include "local_proto.h"
-/* adopted from r.colors */
-static char *icon_files(void)
- char *list = NULL, path[4096], path_i[4096];
- size_t len = 0, l;
- DIR *dir, *dir_i;
- struct dirent *d, *d_i;
+static int cmp(const void *, const void *);
+static char *icon_files(void);
- sprintf(path, "%s/etc/symbol", G_gisbase());
- dir = opendir(path);
- if (!dir)
- return NULL;
- /*loop over etc/symbol */
- while ((d = readdir(dir))) {
- if (d->d_name[0] == '.')
- continue;
- sprintf(path_i, "%s/etc/symbol/%s", G_gisbase(), d->d_name);
- dir_i = opendir(path_i);
- if (!dir_i)
- continue;
- /*loop over each directory in etc/symbols */
- while ((d_i = readdir(dir_i))) {
- if (d_i->d_name[0] == '.')
- continue;
- l = strlen(d->d_name) + strlen(d_i->d_name) + 3;
- list = G_realloc(list, len + l);
- sprintf(list + len, "%s/%s,", d->d_name, d_i->d_name);
- len += l - 1;
- closedir(dir_i);
- closedir(dir);
- if (len)
- list[len - 1] = 0;
- return list;
int main(int argc, char **argv)
char *mapset;
@@ -760,3 +716,78 @@
exit(stat);
+int cmp(const void *a, const void *b)
+ return (strcmp(*(char **)a, *(char **)b));
+/* adopted from r.colors */
+char *icon_files(void)
+ char **list, *ret;
+ char buf[GNAME_MAX], path[GPATH_MAX], path_i[GPATH_MAX];
+ int i, count;
+ size_t len;
+ DIR *dir, *dir_i;
+ struct dirent *d, *d_i;
+ list = NULL;
+ len = 0;
+ sprintf(path, "%s/etc/symbol", G_gisbase());
+ dir = opendir(path);
+ if (!dir)
+ return NULL;
+ count = 0;
+ /* loop over etc/symbol */
+ while ((d = readdir(dir))) {
+ if (d->d_name[0] == '.')
+ continue;
+ sprintf(path_i, "%s/etc/symbol/%s", G_gisbase(), d->d_name);
+ dir_i = opendir(path_i);
+ if (!dir_i)
+ continue;
+ /* loop over each directory in etc/symbols */
+ while ((d_i = readdir(dir_i))) {
+ if (d_i->d_name[0] == '.')
+ continue;
+ list = G_realloc(list, (count + 1) * sizeof(char *));
+ sprintf(buf, "%s/%s", d->d_name, d_i->d_name);
+ list[count++] = G_store(buf);
+ len += strlen(d->d_name) + strlen(d_i->d_name) + 2; /* '/' + ',' */
+ closedir(dir_i);
+ closedir(dir);
+ qsort(list, count, sizeof(char *), cmp);
+ if (len > 0) {
+ ret = G_malloc((len + 1) * sizeof(char)); /* \0 */
+ *ret = '\0';
+ for (i = 0; i < count; i++) {
+ if (i > 0)
+ strcat(ret, ",");
+ strcat(ret, list[i]);
+ G_free(list[i]);
+ G_free(list);
+ else {
+ ret = G_store("");
+ return ret;
