[GRASS-SVN] r48513 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Sep 27 19:50:10 EDT 2011
Author: martinl
Date: 2011-09-27 16:50:10 -0700 (Tue, 27 Sep 2011)
New Revision: 48513
grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
wxGUI: add possibility to define key column when creating new map (#287)
(merge r48512 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py 2011-09-27 23:42:07 UTC (rev 48512)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py 2011-09-27 23:50:10 UTC (rev 48513)
@@ -46,6 +46,7 @@
import gselect
import menuform
import utils
+from debug import Debug
from preferences import globalSettings as UserSettings
class ElementDialog(wx.Dialog):
@@ -242,6 +243,12 @@
if disableTable:
self.table.Enable(False)
+ self.keycol = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY,
+ size = globalvar.DIALOG_SPIN_SIZE)
+ self.keycol.SetValue(UserSettings.Get(group = 'atm', key = 'keycolumn', subkey = 'value'))
+ if disableTable:
+ self.keycol.Enable(False)
self.addbox = wx.CheckBox(parent = self.panel,
label = _('Add created map into layer tree'), style = wx.NO_BORDER)
if disableAdd:
@@ -249,6 +256,8 @@
self.addbox.Enable(False)
else:
self.addbox.SetValue(UserSettings.Get(group = 'cmd', key = 'addNewLayer', subkey = 'enabled'))
+ self.table.Bind(wx.EVT_CHECKBOX, self.OnTable)
self.PostInit()
@@ -259,6 +268,9 @@
"""!Name for vector map layer given"""
self.OnElement(event)
+ def OnTable(self, event):
+ self.keycol.Enable(event.IsChecked())
def _layout(self):
"""!Do layout"""
self.dataSizer.Add(self.element, proportion = 0,
@@ -266,7 +278,17 @@
self.dataSizer.Add(self.table, proportion = 0,
flag = wx.EXPAND | wx.ALL, border = 1)
+ keySizer = wx.BoxSizer(wx.HORIZONTAL)
+ keySizer.Add(item = wx.StaticText(parent = self.panel, label = _("Key column:")),
+ proportion = 0,
+ flag = wx.ALIGN_CENTER_VERTICAL)
+ keySizer.AddSpacer(10)
+ keySizer.Add(item = self.keycol, proportion = 0,
+ flag = wx.ALIGN_RIGHT)
+ self.dataSizer.Add(item = keySizer, proportion = 1,
+ flag = wx.EXPAND | wx.ALL, border = 1)
self.dataSizer.AddSpacer(5)
self.dataSizer.Add(item = self.addbox, proportion = 0,
@@ -289,6 +311,10 @@
return name.split('@', 1)[0]
+ def GetKey(self):
+ """!Get key column name"""
+ return self.keycol.GetValue()
def IsChecked(self, key):
"""!Get dialog properties
@@ -321,83 +347,88 @@
dlg = NewVectorDialog(parent, title = title,
disableAdd = disableAdd, disableTable = disableTable)
- if dlg.ShowModal() == wx.ID_OK:
- outmap = dlg.GetName()
- if outmap == exceptMap:
- gcmd.GError(parent = parent,
- message = _("Unable to create vector map <%s>.") % outmap)
- dlg.Destroy()
- return None
+ if dlg.ShowModal() != wx.ID_OK:
+ dlg.Destroy()
+ return None
+ outmap = dlg.GetName()
+ key = dlg.GetKey()
+ if outmap == exceptMap:
+ gcmd.GError(parent = parent,
+ message = _("Unable to create vector map <%s>.") % outmap)
+ dlg.Destroy()
+ return None
+ if dlg.table.IsEnabled() and not key:
+ message = _("Invalid or empty key column.\n"
+ "Unable to create vector map <%s>.") % outmap)
+ dlg.Destroy()
+ return
- if outmap == '': # should not happen
- dlg.Destroy()
- return None
+ if outmap == '': # should not happen
+ dlg.Destroy()
+ return None
+ # update cmd -> output name defined
+ cmd[1][cmd[2]] = outmap
- cmd[1][cmd[2]] = outmap
- try:
- listOfVectors = grass.list_grouped('vect')[grass.gisenv()['MAPSET']]
- except KeyError:
- listOfVectors = []
- overwrite = False
- if not UserSettings.Get(group = 'cmd', key = 'overwrite', subkey = 'enabled') and \
- outmap in listOfVectors:
- dlgOw = wx.MessageDialog(parent, message = _("Vector map <%s> already exists "
- "in the current mapset. "
- "Do you want to overwrite it?") % outmap,
- caption = _("Overwrite?"),
- style = wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
- if dlgOw.ShowModal() == wx.ID_YES:
- overwrite = True
- else:
- dlgOw.Destroy()
- dlg.Destroy()
- return None
- if UserSettings.Get(group = 'cmd', key = 'overwrite', subkey = 'enabled'):
+ listOfVectors = grass.list_grouped('vect')[grass.gisenv()['MAPSET']]
+ overwrite = False
+ if not UserSettings.Get(group = 'cmd', key = 'overwrite', subkey = 'enabled') and \
+ outmap in listOfVectors:
+ dlgOw = wx.MessageDialog(parent, message = _("Vector map <%s> already exists "
+ "in the current mapset. "
+ "Do you want to overwrite it?") % outmap,
+ caption = _("Overwrite?"),
+ style = wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
+ if dlgOw.ShowModal() == wx.ID_YES:
overwrite = True
- try:
- gcmd.RunCommand(prog = cmd[0],
- overwrite = overwrite,
- **cmd[1])
- except gcmd.GException, e:
- gcmd.GError(parent = self,
- message = e.value)
+ else:
+ dlgOw.Destroy()
dlg.Destroy()
return None
+ if UserSettings.Get(group = 'cmd', key = 'overwrite', subkey = 'enabled'):
+ overwrite = True
- # create attribute table
- if dlg.table.IsEnabled() and dlg.table.IsChecked():
- key = UserSettings.Get(group = 'atm', key = 'keycolumn', subkey = 'value')
- sql = 'CREATE TABLE %s (%s INTEGER)' % (outmap, key)
- gcmd.RunCommand('db.connect',
- flags = 'c')
- gcmd.RunCommand('db.execute',
- quiet = True,
- parent = parent,
- stdin = sql)
- gcmd.RunCommand('v.db.connect',
- quiet = True,
- parent = parent,
- map = outmap,
- table = outmap,
- key = key,
- layer = '1')
+ ret = gcmd.RunCommand(prog = cmd[0],
+ parent = parent,
+ overwrite = overwrite,
+ **cmd[1])
+ if ret != 0:
+ dlg.Destroy()
+ return None
+ # create attribute table
+ if dlg.table.IsEnabled() and dlg.table.IsChecked():
+ sql = 'CREATE TABLE %s (%s INTEGER)' % (outmap, key)
- # return fully qualified map name
- if '@' not in outmap:
- outmap += '@' + grass.gisenv()['MAPSET']
+ gcmd.RunCommand('db.connect',
+ flags = 'c')
- if log:
- log.WriteLog(_("New vector map <%s> created") % outmap)
- return dlg
+ Debug.msg(1, "SQL: %s" % sql)
+ gcmd.RunCommand('db.execute',
+ quiet = True,
+ parent = parent,
+ input = '-',
+ stdin = sql)
+ gcmd.RunCommand('v.db.connect',
+ quiet = True,
+ parent = parent,
+ map = outmap,
+ table = outmap,
+ key = key,
+ layer = '1')
+ # return fully qualified map name
+ if '@' not in outmap:
+ outmap += '@' + grass.gisenv()['MAPSET']
+ if log:
+ log.WriteLog(_("New vector map <%s> created") % outmap)
return dlg
class SavedRegion(wx.Dialog):
