[GRASS-SVN] r48517 - grass-addons/vector/v.out.ascii.mat
svn_grass at osgeo.org
Wed Sep 28 01:42:41 EDT 2011
Author: hamish
Date: 2011-09-27 22:42:41 -0700 (Tue, 27 Sep 2011)
New Revision: 48517
grass-addons/vector/v.out.ascii.mat/v.out.ascii.mat
compatibility with modern v.info
Modified: grass-addons/vector/v.out.ascii.mat/v.out.ascii.mat
--- grass-addons/vector/v.out.ascii.mat/v.out.ascii.mat 2011-09-28 01:24:30 UTC (rev 48516)
+++ grass-addons/vector/v.out.ascii.mat/v.out.ascii.mat 2011-09-28 05:42:41 UTC (rev 48517)
@@ -100,6 +100,11 @@
MAP_IS_3D=`v.info "$GIS_OPT_INPUT" | grep "Map is 3D" | cut -f2 -d: | awk '{print $1}'`
+if [ "$MAP_IS_3D" = "No" ] ; then
+ MAP_IS_3D=0
+elif [ "$MAP_IS_3D" = "Yes" ] ; then
+ MAP_IS_3D=1
+fi
if [ "$MAP_IS_3D" -eq 0 ] ; then
NAN_STR="NaN\tNaN"
