[GRASS-SVN] r48522 -
	grass/branches/releasebranch_6_4/scripts/g.extension
    svn_grass at osgeo.org
    Wed Sep 28 03:38:26 EDT 2011
Author: hamish
Date: 2011-09-28 00:38:25 -0700 (Wed, 28 Sep 2011)
New Revision: 48522
   grass/branches/releasebranch_6_4/scripts/g.extension/description.html
   grass/branches/releasebranch_6_4/scripts/g.extension/g.extension
sync with devbr6
Modified: grass/branches/releasebranch_6_4/scripts/g.extension/description.html
--- grass/branches/releasebranch_6_4/scripts/g.extension/description.html	2011-09-28 07:33:46 UTC (rev 48521)
+++ grass/branches/releasebranch_6_4/scripts/g.extension/description.html	2011-09-28 07:38:25 UTC (rev 48522)
@@ -5,7 +5,11 @@
 <p>
 Re-running the script on an installed GRASS Addon re-installs
 the requested extension which may include updates.
+<P>
+If your GRASS_ADDON_PATH contains more than one path, the default
+action is to use the first directory in the list.
 <h2>EXAMPLES</h2>
 Download and install <em>i.landsat.toar</em> into current GRASS installation:
@@ -13,8 +17,17 @@
 g.extension extension=i.landsat.toar
 </pre></div>
+<h2>BUGS</h2>
+This is a new module and obtaining successful behavior on all platforms
+is rather tricky.  Please report any problems to the GRASS bug tracker.
+If this automatic build fails, instructions for compiling both the GRASS
+source code and GRASS addons by hand can be found in the GRASS wiki.
 <h2>AUTHOR</h2>
 Markus Neteler
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
Modified: grass/branches/releasebranch_6_4/scripts/g.extension/g.extension
--- grass/branches/releasebranch_6_4/scripts/g.extension/g.extension	2011-09-28 07:33:46 UTC (rev 48521)
+++ grass/branches/releasebranch_6_4/scripts/g.extension/g.extension	2011-09-28 07:38:25 UTC (rev 48522)
@@ -6,7 +6,7 @@
 # AUTHOR(S):   	Markus Neteler
 # PURPOSE:      Tool to download and install extensions from GRASS Addons SVN into
 #               local GRASS installation
-# COPYRIGHT:    (C) 2009-2010 by the Markus Neteler, GRASS Development Team
+# COPYRIGHT:    (C) 2009-2011 by Markus Neteler, and the GRASS Development Team
 #               This program is free software under the GNU General Public
 #               License (>=v2). Read the file COPYING that comes with GRASS
@@ -14,13 +14,11 @@
 #%Module
 #% label: Tool to maintain GRASS extensions in local GRASS installation.
 #% description: Downloads, installs extensions from GRASS Addons SVN repository into local GRASS installation or removes installed extensions.
 #% keywords: general, extensions
 #%End
 #%option
 #% key: extension
 #% type: string
@@ -62,6 +60,10 @@
 #% key: s
 #% description: Install system-wide (may need system administrator rights)
 #%end
+#%flag
+#% key: u
+#% description: Install system-wide using sudo
+#%end
 if  [ -z "$GISBASE" ] ; then
@@ -218,9 +220,14 @@
 	GRASS_ADDON_PATH1=`echo "$GRASS_ADDON_PATH" | cut -f1 -d:`
     fi
     PREFIX="$GRASS_ADDON_PATH1"
-elif [ "$PREFIX" = '$GISBASE' ] || [ $GIS_FLAG_S -eq 1 ] ; then
+elif [ "$PREFIX" = '$GISBASE' ] || [ $GIS_FLAG_S -eq 1 ] || [ $GIS_FLAG_U -eq 1 ] ; then
    SYSADMIN=1
    PREFIX="$GISBASE"
+   # just to make later tests happy
+   if [ $GIS_FLAG_S -eq 0 ] && [ $GIS_FLAG_U -eq 1 ] ; then
+      GIS_FLAG_S=1
+   fi
 fi
@@ -273,7 +280,29 @@
 cd "$TMPDIR/$MODULE"
 g.message message="Compiling <$MODULE>..."
-make MODULE_TOPDIR="$GISBASE" ARCH_INC="-I$GISBASE/include -I${MYINST_DIR}/include -I$TMPDIR/dist/include" ARCH_LIBPATH="-L$GISBASE/lib -L${MYINST_DIR}/lib -L$TMPDIR/dist/lib" ARCH_LIBDIR="$GISBASE/lib" ARCH_DISTDIR="$TMPDIR/dist"
+if [ -n "$MACHTYPE" ] ; then
+   DIST_DIR="dist.$MACHTYPE"
+elif [ -x "`which arch`" ] ; then
+   DIST_DIR="dist.`arch`"
+else
+   DIST_DIR="dist.unknown"
+fi
+# $INST_NOW helps compile and install modules directly into $(INST_DIR)
+# without having to install whole distribution even after modifying only
+# one module. It will update both $(GRASS_HOME)/dist.$(ARCH) and $(INST_DIR).
+#   see $GISBASE/include/Make/Grass.make
+INST_NOW=true
+export INST_NOW
+make MODULE_TOPDIR="$GISBASE" \
+   ARCH_INC="-I$GISBASE/include -I${MYINST_DIR}/include -I$TMPDIR/$DIST_DIR/include" \
+   ARCH_LIBPATH="-L$GISBASE/lib -L${MYINST_DIR}/lib -L$TMPDIR/$DIST_DIR/lib" \
+   ARCH_LIBDIR="$GISBASE/lib" \
+   ARCH_DISTDIR="$TMPDIR/$DIST_DIR" \
+   ARCH_BINDIR="$TMPDIR/$DIST_DIR/bin"
 if [ $? -ne 0 ] ; then
    g.message -e message="Compilation failed, sorry. Please check above error messages."
    cleanup
@@ -288,31 +317,48 @@
       PROGTYPE=bin
    fi
    # can we write? Install dir present?
-   if test ! -d "${MYINST_DIR}" ; then
-      mkdir -p "${MYINST_DIR}"
+   if test ! -d "$MYINST_DIR" ; then
+      mkdir -p "$MYINST_DIR"
    fi
-   if test ! -d "${MYINST_DIR}/$PROGTYPE" ; then
-      mkdir -p "${MYINST_DIR}/$PROGTYPE"
+   if test ! -d "$MYINST_DIR/$PROGTYPE" ; then
+      mkdir -p "$MYINST_DIR/$PROGTYPE"
    fi
-   if test ! -d "${MYINST_DIR}/docs/html" ; then
-      mkdir -p "${MYINST_DIR}/docs/html"
+   if test ! -d "$MYINST_DIR/docs/html" ; then
+      mkdir -p "$MYINST_DIR/docs/html"
    fi
-   if test ! -d "${MYINST_DIR}/man/man1" ; then
-      mkdir -p "${MYINST_DIR}/man/man1"
+   if test ! -d "$MYINST_DIR/man/man1" ; then
+      mkdir -p "$MYINST_DIR/man/man1"
    fi
    if [ $SYSADMIN -eq 1 ] ; then
-      if test -f "${MYINST_DIR}/$PROGTYPE/${MODULE}" ; then
-         g.message "You need to enter the root password to remove the previous version of ${MODULE}:"
-         su -c "rm -f \"${MYINST_DIR}/$PROGTYPE/${MODULE}\""
+      if test -f "$MYINST_DIR/$PROGTYPE/$MODULE" ; then
+         if [ $GIS_FLAG_U -eq 1 ] ; then
+            g.message "You may need to enter your password to remove an earlier copy of $MODULE:"
+            sudo rm -f "$MYINST_DIR/$PROGTYPE/$MODULE"
+         else
+            g.message "You need to enter the root password to remove an earlier copy of $MODULE:"
+            su -c "rm -f \"$MYINST_DIR/$PROGTYPE/$MODULE\""
+         fi
       fi
-      g.message "You need to enter the root password next to install ${MODULE}:"
-      su -c "make MODULE_TOPDIR=\"$GISBASE\" ARCH_DISTDIR=\"$TMPDIR/dist\" INST_DIR=\"$MYINST_DIR\" install"
+         g.message "You may need to enter your password to install $MODULE:"
+         sudo make MODULE_TOPDIR="$GISBASE" \
+	     INST_DIR="$MYINST_DIR" install
+      else
+         g.message "You need to enter the root password to install $MODULE:"
+         su -c "make MODULE_TOPDIR=\"$GISBASE\" ARCH_DISTDIR=\"$TMPDIR/$DIST_DIR\" INST_DIR=\"$MYINST_DIR\" install"
+      fi
    else
-         rm -f "${MYINST_DIR}/$PROGTYPE/${MODULE}"
+         rm -f "$MYINST_DIR/$PROGTYPE/$MODULE"
       fi
-      make MODULE_TOPDIR="$GISBASE" ARCH_DISTDIR="$TMPDIR/dist" INST_DIR="$MYINST_DIR" install
+      make MODULE_TOPDIR="$GISBASE" \
    fi
@@ -321,7 +367,7 @@
       exit 1
    fi
-   if [ ! -x "${MYINST_DIR}/$PROGTYPE/${MODULE}" ] ; then
+   if [ ! -x "$MYINST_DIR/$PROGTYPE/$MODULE" ] ; then
      g.message -e "Module did not install properly"
      cleanup
      exit 1
@@ -336,9 +382,10 @@
 cleanup
 g.message message=""
-g.message message="Installation of <$MODULE> in <$MYINST_DIR> successfully finished."
+g.message message="Installation of <$MODULE> in <$MYINST_DIR> complete."
 if [ -n "$ADDON_PATH_EMPTY" ] && [ "$GIS_FLAG_S" -eq 0 ] ; then
+   g.message message=""
    g.message -w message='This add-on module will not function until you set the GRASS_ADDON_PATH environment variable (see "g.manual variables")'
 fi
