[GRASS-SVN] r48572 - grass/branches/develbranch_6/gui/wxpython/xml
svn_grass at osgeo.org
Fri Sep 30 10:40:04 EDT 2011
Author: martinl
Date: 2011-09-30 07:40:04 -0700 (Fri, 30 Sep 2011)
New Revision: 48572
grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
wxGUI: update menu
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2011-09-30 14:27:20 UTC (rev 48571)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2011-09-30 14:40:04 UTC (rev 48572)
@@ -278,14 +278,14 @@
<items>
<menuitem>
<label>ASCII 3D import</label>
- <help>Convert a 3D ASCII raster text file into a (binary) 3D raster map layer</help>
+ <help>Converts a 3D ASCII raster text file into a (binary) 3D raster map layer.</help>
<keywords>raster3d,voxel,import</keywords>
<handler>OnMenuCmd</handler>
<command>r3.in.ascii</command>
</menuitem>
<menuitem>
<label>Vis5D import</label>
- <help>import of 3-dimensional Vis5D files (i.e. the v5d file with 1 variable and 1 time step)</help>
+ <help>Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and 1 time step).</help>
<command>r3.in.v5d</command>
@@ -479,21 +479,21 @@
<items>
<menuitem>
<label>ASCII 3D export</label>
- <help>Converts a 3D raster map layer into an ASCII text file</help>
+ <help>Converts a 3D raster map layer into an ASCII text file.</help>
<keywords>raster3d,voxel,export</keywords>
<command>r3.out.ascii</command>
</menuitem>
<menuitem>
<label>Vis5D export</label>
- <help>Export of GRASS 3D raster map to 3-dimensional Vis5D file.</help>
+ <help>Exports GRASS 3D raster map to 3-dimensional Vis5D file.</help>
<command>r3.out.v5d</command>
</menuitem>
<menuitem>
<label>VTK export</label>
- <help>Converts 3D raster maps (G3D) into the VTK-Ascii format</help>
+ <help>Converts 3D raster maps into the VTK-ASCII format.</help>
<command>r3.out.vtk</command>
@@ -673,7 +673,7 @@
</menuitem>
<menuitem>
<label>3D image rendering</label>
- <help>Allows rendering GIS data is a 3D space.</help>
+ <help>Creates a 3D rendering of GIS data.</help>
<keywords>visualization,raster,vector,raster3d</keywords>
<command>m.nviz.image</command>
@@ -2738,14 +2738,14 @@
</menuitem>
<menuitem>
<label>Cross section</label>
- <help>Creates cross section 2D raster map from 3d raster map based on 2D elevation map</help>
+ <help>Creates cross section 2D raster map from 3D raster map based on 2D elevation map.</help>
<keywords>raster3d,voxel</keywords>
<command>r3.cross.rast</command>
</menuitem>
<menuitem>
<label>Groundwater modeling</label>
- <help>Numerical calculation program for transient, confined groundwater flow in three dimensions</help>
+ <help>Calculates numerically transient, confined groundwater flow in three dimensions.</help>
<command>r3.gwflow</command>
@@ -2770,7 +2770,7 @@
</menuitem>
<menuitem>
<label>Voxel statistics</label>
- <help>Generates volume statistics for raster3d maps.</help>
+ <help>Generates volume statistics for 3D raster maps.</help>
<keywords>raster3d,voxel,statistics</keywords>
<command>r3.stats</command>
