[GRASS-SVN] r51241 - grass-addons/grass6/raster/r.cva
svn_grass at osgeo.org
Mon Apr 2 07:57:50 EDT 2012
Author: neteler
Date: 2012-04-02 04:57:50 -0700 (Mon, 02 Apr 2012)
New Revision: 51241
Removed:
grass-addons/grass6/raster/r.cva/r.cva.tmp.html
rm tmp file
Deleted: grass-addons/grass6/raster/r.cva/r.cva.tmp.html
--- grass-addons/grass6/raster/r.cva/r.cva.tmp.html 2012-04-02 11:49:17 UTC (rev 51240)
+++ grass-addons/grass6/raster/r.cva/r.cva.tmp.html 2012-04-02 11:57:50 UTC (rev 51241)
@@ -1,445 +0,0 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<title>GRASS GIS Manual: r.cva</title>
-<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
-<link rel="stylesheet" href="grassdocs.css" type="text/css">
-</head>
-<body bgcolor="white">
-<img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
-<h2>NAME</h2>
-<em><b>r.cva</b></em>
-<TITLE>r.cva</TITLE>
-<H2>NAME</H2>
-<EM><b>r.cva</b></EM> - Cumulative viewshed analysis program.
-<BR>
-<EM>(GRASS Raster Program)</EM>
-<H2>SYNOPSIS</H2>
-<B>r.cva</B>
-<BR>
-<B>r.cva help</B>
-<BR>
-<B>r.cva</B>
-[<B>-afmnoqrs</B>]
-<B>input=</B><EM>name</EM>
-[<B>target_mask=</B><EM>name</EM>]
-[<B>viewpt_mask=</B><EM>name</EM>]
-[<B>sites=</B><EM>name</EM>]
-<B>output=</B><EM>name</EM>
-[<B>obs_elev=</B><EM>value</EM>]
-[<B>target_elev=</B><EM>value</EM>]
-[<B>max_dist=</B><EM>value</EM>]
-[<B>seed=</B><EM>value</EM>]
-[<B>sample=</B><EM>value</EM>]
-<B>type=</B><EM>value</EM>
-<H2>QUICKSTART</H2>
-To perform the most common cumulative viewshed analysis (for each cell of
-the input elevation raster map: count the number of observer sites from which it
-can be seen) type in the following:
-<p>
-<B>r.cva</B> <B>-f</B> <B>input=</B><EM>elevation</EM> <B>sites=</B><EM>observers</EM> <B>output=</B><EM>result</EM> <B>type=</B><EM>sites</EM>
-<P>
-'elevation' can be a raster map containing elevation values in CELL, FCELL or DCELL format. 'observers' must a map containing vector points.
-'result' will be an output map in CELL format containing the cumulative visibility counts for each cell.
-<A NAME = "description"><H2>DESCRIPTION</H2></A>
-<EM>r.cva</EM> generates a cumulative viewshed map. When run without
-the <EM>-f</EM> flag each viewpoint is marked with the number of cells in its
-viewshed (i.e. that can be seen from it). In this mode the only cells
-that contain genuine data in the output map are the viewpoints.
-Alternatively, if the <EM>-f</EM> flag is set then each cell in the
-<EM>output</EM> map is marked with the number of viewpoints from which
-it can be seen. In either case, viewpoints may be chosen in one of
-four ways. The first (`all') treats every cell as a viewpoint. This
-is so computationally demanding that it is unlikely to be feasible
-unless either the <EM>input</EM> map or <EM>max_dist</EM> is very
-small. The second (`systematic') uses a systematic sample of cells
-arranged on a rectangular grid. The third (`random') uses a random
-sample. By default the random sampling algorithm does not allow
-replacement (i.e. a cell can be treated as a viewpoint only once), but
-this behaviour can be altered by setting the <EM>-r</EM> flag. The
-fourth option (`sites') uses the points in the specified <EM>vector</EM>
-map. The options `systematic' and `random' allow the user to specify
-any sampling frequency between 0% and 100%.
-<p>
-The cells used in viewshed analysis can be constrained by one or both
-of two masks. Both masks should be binary raster maps in which the
-areas of interest are coded `1' and all other cells `0'.
-<EM>target_mask</EM> determines which cells are targets: a cell which
-is not a target will be returned as not visible from a given viewpoint
-even if it is actually visible according to the line-of-sight analysis
-(i.e. this mask performs the same function as <EM>patt_map</EM> in
-<EM><A HREF="../../html/r.los.html">r.los</A></EM>). <EM>viewpt_mask</EM>
-constrains which cells may be treated as viewpoints. For example,
-suppose that the raster map `no_sea' codes sea (elevation = 0) as `0'
-and land (elevation > 0) as `1'. In this case, specifying `no_sea' as
-the <EM>target_mask</EM> would cause <EM>r.cva</EM> to count cells on
-land that are visible from any viewpoint. Alternatively, specifying
-`no_sea' as the <EM>viewpt_mask</EM> would count any cells visible
-from viewpoints on land. Finally, specifying `no_sea' as both the
-<EM>target_mask</EM> and <EM>viewpt_mask</EM> would count cells on
-land that are visible from viewpoints on land.
-<p>
-The geometry of the potential line of sight between each pair of cells
-may be altered by means of two offsets, <EM>obs_elev</EM> and
-<EM>target_elev</EM>. The height <EM>obs_elev</EM> is added to the
-viewpoint and the height <EM>target_elev</EM> to each target cell.
-Note that by swapping these values it is possible to produce maps
-showing the number of cells from which a viewpoint is visible, or if
-the <EM>-f</EM> flag is set, the number of viewpoints which it is
-possible to see from each map cell.
-<p>
-A particular set of viewpoint locations in a random sample can be
-repeated by specifying the same value for <EM>seed</EM>.
-Alternatively, different values can be used to produce independent
-samples for statistical testing.
-<p>
-The program can be run either non-interactively or interactively. To
-run <EM>r.cva</EM> non-interactively the user must minimally specify
-the <B>input</B> and <B>output</B> maps and the <B>type</B> of
-analysis. If the chosen <B>type</B> is `sites' then the
-<B>sites</B> list must also be specified. Any remaining parameters
-whose values have not been specified on the command line will be set
-to their default values (see <A HREF = "#parameters">below</A>). Non-interactive usage format is:
-<DL>
-<DD>
-<B>r.cva</B>
-[<B>-afmnoqrs</B>]
-</DL>
-<H2>OPTIONS</H2>
-<H3>Flags:</H3>
-<DL>
-<DT><B>-a</B>
-<DD> Treat the specified sample size as an absolute number of cells
-rather than a percentage. Note, this flag is only for use with random
-sampling.
-<DT><B>-f</B>
-<DD> Mark each cell in the output map with the number of viewpoints
-from which it can be seen.
-<DT><B>-h</B>
-<DD> Adjust height of oberserver points so that they will never fall
-below surface level. This is only useful in conjunction with the
-<b>spot</b> parameter or attribute (see <A HREF ="#atributes">below</A>).
-<DT><B>-i</B>
-<DD> Do not interpret control attributes in input vector map as
-described <A HREF ="#atributes">below</A>).
-<DT><B>-m</B> <DD> Differentiate between genuine zero data values and
-null data in the output map. When the <EM>-f</EM> flag has not been
-set this ensures that all non-viewpoint cells are coded `-1'. When
-the <EM>-f</EM> flag has been set then all cells coded `0' in the
-<EM>target_mask</EM> (if there is one) are coded `-1'. See <A HREF =
-"#notes">below</A> for guidance when to set this flag.
-<DT><B>-n</B> <DD> In conjunction with <B>-m</B>: write NULL values instead of '-1' to output map.
-<DT><B>-o</B>
-<DD> Overwrite the output raster map if it already exists.
-<DT><B>-q</B>
-<DD> Be quiet about progress, confirming only the output file and
-sampling frequency. This is useful when <EM>r.cva</EM> is invoked from a
-script with standard output redirected to a disk file.
-<DT><B>-r</B>
-<DD> Allow replacement during random sampling (i.e. allow a given cell
-to be picked as a viewpoint more than once). Note that no cumulation
-occurs for replacement viewpoints; this ensures that the resulting
-cumulative viewshed will be as though the viewpoint was selected once
-only (the final output map will, of course, be different because
-replacement effectively results in the use of fewer viewpoints for a
-given sampling frequency).
-<DT><B>-s</B> <DD>Be silent about progress, in which case it is
-strongly recommended that you use <EM><A
-HREF="../../html/r.info.html">r.info</A></EM> to confirm what sampling frequency
-was actually achieved.
-<A NAME = "parameters"><H3>Parameters:</H3></A>
-<DT><B>input=</B><EM>name</EM>
-<DD>Name of a raster map layer containing elevation
-data, used as program input.
-<DT><B>target_mask=</B><EM>name</EM> <DD>Name of a binary raster map
-layer in which target cells within the areas of interest are assigned
-the category value `1' and all other cells are assigned the category
-value `0'. A cell is treated as a target when it is viewed from a
-viewpoint (note, therefore, that viewpoints are targets when viewed
-from other viewpoints).
-<DT><B>viewpt_mask=</B><EM>name</EM>
-<DD>Name of a binary raster map layer in which viewpoints within the areas
-of interest are assigned the category value `1' and all other cells
-are assigned the category value `0'.
-<DT><B>sites=</B><EM>name</EM>
-<DD>The name of a vector map containing the sites (vector points) that are to be treated as
-viewpoints. Sites falling outside the current region are ignored.
-<DT><B>obs_elev=</B><EM>value</EM>
-<DD>Height of the observer (in metres) above the elevation of the
-viewpoint. Default: 1.75 m
-<DT><B>target_elev=</B><EM>value</EM>
-<DD>Height of the object of interest (in metres) above the elevation
-of the target cell. Default: 0.0 m
-<DT><B>max_dist=</B><EM>value</EM>
-<DD>Maximum distance (in metres) from the viewing point within which
-the line-of-sight analysis will be performed. Options: 0-99999
-(stated in map units). Default: 100
-<DT><B>seed=</B><EM>value</EM>
-<DD>The seed for the random number generator used during random
-sampling. This option allows exact reproduction of a previous result.
-Options: 0-32767. Default: 1
-<DT><B>sample=</B><EM>value</EM>
-<DD>The sampling frequency as a percentage of the number of map cells
-in the current region. Options: 0.0-100.0. Default: 10.0
-<DT><B>type=</B><EM>value</EM> <DD>The type of sampling regime used to
-select viewpoints for analysis. See <A HREF = "#description">above</A>
-for details. Options: `all', `systematic', `random', `sites'.
-<DT><B>spot, offseta, offsetb, azimuth1, azimuth2, vert1, vert2, radius1, radius2</B>
-<DD> See <A HREF ="#atributes">below</A>) for a description of what they do.
-<DT><B>curvc=</B><EM>value</EM>
-<DD>Earth curvature correction will be applied if the distance from the observer
-point exceeds the given threshold. Set this to 0.0 to disable curvature correction
-(default). While correction slows down calculations, it is recommend for
-viewing distances of more than about 3 km. The correction uses a simplified
-formula which is accurate to 1 in 10,000 for distances up to 40 km:<p>
-<i>d(height)=dist^2/(2*Re)</i><p>
-With <i>Re</i> being the radius of the earth (ca. 6,356,766 m).
-</DL>
-<A NAME = "attributes"><H3>Vector map attributes:</H3>
-When using 'sites' type operation mode, <EM>r.cva</EM> checks for the
-presence of a number of attributes in the input vector map. The names
-of these attributes are all uppercase and match those used by the
-viewshed module of ESRI's ArcGIS Spatial Extension (trademarks of ESRI Corp.).
-They control <EM>r.cva</EM> operation in an analogous way.
-Each attribute, if present, must store a double value. The following
-attribute names and value ranges are recognised and interpreted:
-<dl>
-<dt>SPOT</dt>
- <dd>This determines absolute observer height. If this attribute is given,
- observer height will no longer be determined from the DEM.
- <EM>r.cva</EM> can automatically raise this value to that of the DEM
- point below the oberserver's position, if the value in SPOT would
- cause the observer to get below ground level (use the <b>-h</b> flag).</dd>
-<dt>OFFSETA</dt>
- <dd>Use this to add an offset to each oberver point's height. This is
- just an alias for the <b>obs_elev</b> option and exists for
- compatibility reasons.</dd>
-<dt>OFFSETB</dt>
- <dd>The value stored in 'OFFSETB' will be added to each target point
- at the moment it is considered for visibility. All blocking points
- on the line-of-sight between observer and target will be left untouched.
- This is different from the <b>target_elev</b> parameter. It can be
- used to simulate visibility of targets with a certain height.</dd>
-<dt>AZIMUTH1, AZIMUTH2</dt>
- <dd>These attributes must be given as values between 0.0 and 360.0 and
- can be used to limit the horizontal scan range of the viewshed.
- Limits are measured in degrees with 0.0 in the North and values
- increasing clock-wise. Thus, if you wanted to limit visibility scans
- to eastward directions only, you would set AZIMUTH1=1 and AZIMUTH2=180.
- </dd>
-<dt>VERT1, VERT2</dt>
- <dd>In analogy to 'AZIMUTH1' and 'AZIMUTH2', these attributes can be
- used to limit the vertical range of the scan. The range is -90 to 0 for
- 'VERT1' and 0 to 90 for 'VERT2'.
- At -90 degrees, the observer looks straight down to the ground and at
- 90 degress up into the sky.
- </dd>
-<dt>RADIUS1, RADIUS2</dt>
- <dd>Finally, two attributes exist to limit the distance of the scan.
- 'RADIUS1' determines the minimum distance from the observer and 'RADIUS2'
- the maximum distance. The latter is thus equivalent to using the
- <b>max_dist</b> parameter and exists for compatibility reasons.
- </dd>
-</dl>
-Interpretation of these attributes can be turned off by using the <b>-i</b> flag.
-<p>
-Note that you can use the same control values in operation modes
-other than 'sites', if you specify the equivalent parameters
-(see <A HREF = "#parameters">above</A>). The latter will also work
-as global settings in 'sites' mode. Attributes stored in the vector
-map table will override these global settings unless the <b>-i</b>
-flag is specified. The meaning of <b>OFFSETA, OFFSETB</b> and <b>RADIUS1</b> is
-the same as <b>obs_elev, target_elev</b> and <b>max_dist</b>. The latter still
-exist for compatibility with earlier versions of <em>r.cva</em>.
-<A NAME = "notes"><H2>NOTES</H2></A>
-<EM>r.cva</EM> works in the current geographic region, but ignores the
-current mask. Masking is achieved by specifying a target_mask and/or a
-viewpt_mask. For accurate results, the program must be run with the
-resolution of the geographic region set equal to the resolution of the
-data (see <EM><A HREF="../../html/g.region.html">g.region</A></EM>).
-<P>
-This program assumes all height and distance measurements in meters.
-Legacy units must be converted to meters by the user before running <EM>r.cva</EM>.
-<P>
-It is also assumed, that N-S and E-W resolution of the current region are the
-same. If they differ, distances calculated for limiting the viewshed will
-be imprecise and results affected accordingly.
-<P>
-The number of cells visible from a given viewpoint includes the
-viewpoint itself only if the viewpoint is a target cell.
-Consequently, if neither the viewpoint nor any other cell within
-<EM>max_dist</EM> of it is a target cell then the size of that
-viewpoint's viewshed will be zero. Set the <EM>-m</EM> flag to locate
-such viewpoints (they will show as cells coded `0' as opposed to
-`-1'). Similarly, set the <EM>-m</EM> flag when the <EM>-f</EM> flag has
-been set in order to differentiate cells which are genuinely not
-visible from any viewpoint as opposed to those that are not target
-cells.
-<P>
-<EM>r.cva</EM> always informs the user what sampling frequency was
-attempted and subsequently achieved. This information is printed to
-standard output and is also placed in the output map's history file
-(which can be viewed using <EM><A HREF="../../html/r.info.html">r.info</A></EM>).
-The sample attempted may differ slightly from that requested owing to
-the need to sample a whole number of cells. Any such discrepancy will
-be greatest in the case of small maps of coarse resolution. The
-sample achieved may be further reduced when a <EM>viewpt_mask</EM> has been
-specified. This will not occur with the option `random', because its
-algorithm repeatedly allocates viewpoints until the number that fall
-within mask cells coded `1' produces the frequency attempted. Such a
-reduction can, however, occur with the options `all', `systematic' and
-`sites', because their algorithms allocate viewpoints without
-reference to the mask and then simply ignore those that fall in mask
-cells coded `0'.
-<P>
-<H2>SEE ALSO</H2>
-<br>
-<EM><A HREF="../../html/r.info.html">r.info</A></EM>
-<br>
-<EM><A HREF="../../html/g.region.html">g.region</A></EM>
-<P>
-Cumulative viewshed analysis was defined by D. Wheatley, 1995,
-`Cumulative viewshed analysis: a GIS-based method for investigating
-intervisibility, and its archaeological application', in G. R. Lock
-and Z. Stancic (eds.) <EM>Archaeology and Geographic Information
-Systems: A European Perspective</EM>, London: Taylor and Francis,
-pp. 171-186.
-<P>
-Lake et al. (M. W. Lake, P. E. Woodman and S. J. Mithen, 1998,
-`Tailoring GIS software for archaeological applications: an example
-concerning viewshed analysis', <EM>Journal of Archaeological
-Science</EM> 25: 27-38) discuss the first version of <EM>r.cva</EM>
-and provide some timing estimates. They also discuss the importance
-of eliminating the edge effect that occurs when calculating the number
-of cells visible from a viewpoint that is closer than
-<EM>max_dist</EM> to the edge of the map.
-<P>
-Fisher et al. (P. Fisher, C. Farrelly, A. Maddocks and C. Ruggles,
-1997, `Spatial Analysis of Visible Areas from the Bronze Age Cairns of
-Mull', <EM>Journal of Archaeological Science</EM> 24: 581--592)
-provide a useful review of some of the pitfalls that may trap unwary
-users of cumulative viewshed analysis. Most of these are easily
-avoided using <EM>r.cva</EM>.
-<H2>AUTHOR</H2>
-Mark Lake, Institute of Archaeology, University College London (the author).
-<P>
-With contributions by:
-Benjamin Ducke, Institute of Archaeology, University of Bamberg, Germany.
-<H2>ACKNOWLEDGEMENTS</H2>
-This version of <EM>r.cva</EM> was completed during the author's
-tenure of a Leverhulme Trust Special Research Fellowship at the
-Institute of Archaeology, University College London, U.K.
-<P>
-The first version of <EM>r.cva</EM> was written by the author as part of the
-MAGICAL Project directed by Dr. Steven Mithen (Dept. of Archaeology,
-University of Reading, U.K.). The MAGICAL Project was made possible
-by a Natural Environment Research Council award (NERC GR3/9540) to
-Dr. Mithen.
-<P>
-<EM>r.cva</EM> draws heavily on the code for <EM><A
-HREF="../../html/r.los.html">r.los</A></EM>, which was written by Kewan
-Q. Khawaja, Intelligent Engineering Systems Laboratory, M.I.T.
-<P>
-Adaptation to GRASS 6 vector and raster formats, additional functionality,
-documentation updates by Benjamin Ducke (2005).
-<H2>BUGS</H2>
-Missing values in site attributes are currently not handled.
-<p>
-Earth curvature correction has not been sufficiently tested. The 'offsetb' option (=target_elev)
-has not been sufficiently tested. Please feel free to test and report!
-<p>
-When <EM>max_dist</EM> is set to 100, the N-S and E-W resolutions are
-50, and a <EM>target_mask</EM> has been specified, the cells
-immediately NE, SE, SW and NW of the viewpoint may not be masked when
-then should be. Please report any others that you find to the author.
-<P>
-Note that <EM>r.cva</EM> fixes two bugs in the current version of
-<EM><A HREF="../../html/r.los.html">r.los</A></EM>: that <EM>obs_elev</EM> is
-truncated to its integer component and that the target mask
-(<EM>patt_map</EM> in <EM><A HREF="../../html/r.los.html">r.los</A></EM>) does
-not apply to the viewpoint or its eight immediate neighbours.
-<HR>
-<P><a href="index.html">Main index</a> - <a href="raster.html">raster index</a> - <a href="full_index.html">Full index</a></P>
-<P>© 2003-2012 <a href="http://grass.osgeo.org">GRASS Development Team</a></p>
-</body>
-</html>
