[GRASS-SVN] r51245 - in grass/trunk: lib/python/temporal temporal/t.register
Tue Apr 3 14:08:20 EDT 2012
Author: huhabla
Date: 2012-04-03 11:08:20 -0700 (Tue, 03 Apr 2012)
New Revision: 51245
   grass/trunk/lib/python/temporal/abstract_dataset.py
   grass/trunk/lib/python/temporal/abstract_map_dataset.py
   grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
   grass/trunk/lib/python/temporal/base.py
   grass/trunk/lib/python/temporal/space_time_datasets_tools.py
   grass/trunk/temporal/t.register/test.t.register.vector.file.layer.sh
   grass/trunk/temporal/t.register/test.t.register.vector.sh
Reorganization of the SQL statement handling. Methods
to gather SQL statements have been implemented to speed up
the registration and unregistration of massive amounts of maps (>10000)
Modified: grass/trunk/lib/python/temporal/abstract_dataset.py
--- grass/trunk/lib/python/temporal/abstract_dataset.py	2012-04-02 14:03:09 UTC (rev 51244)
+++ grass/trunk/lib/python/temporal/abstract_dataset.py	2012-04-03 18:08:20 UTC (rev 51245)
@@ -181,19 +181,12 @@
         bottom = self.spatial_extent.get_bottom()
         return (north, south, east, west, top, bottom)
     def select(self, dbif=None):
 	"""!Select temporal dataset entry from database and fill up the internal structure"""
-        connect = False
+        dbif, connect = init_dbif(dbif)
-        if dbif == None:
-            dbif = sql_database_interface()
-            dbif.connect()
-            connect = True
-        dbif.cursor.execute("BEGIN TRANSACTION")
 	self.base.select(dbif)
 	if self.is_time_absolute():
 	    self.absolute_time.select(dbif)
@@ -202,102 +195,88 @@
 	self.spatial_extent.select(dbif)
 	self.metadata.select(dbif)
-        dbif.cursor.execute("COMMIT TRANSACTION")
         if connect:
             dbif.close()
     def is_in_db(self, dbif=None):
-	"""!Check if the temporal dataset entry is in the database"""
-	return self.base.is_in_db(dbif)
+        """!Check if the temporal dataset entry is in the database"""
+        return self.base.is_in_db(dbif)
     def delete(self):
 	"""!Delete temporal dataset entry from database if it exists"""
         raise IOError("This method must be implemented in the subclasses")
-    def insert(self, dbif=None):
-	"""!Insert temporal dataset entry into database from the internal structure"""
+    def insert(self, dbif=None, execute=True):
+        """!Insert temporal dataset entry into database from the internal structure
-        connect = False
-        if dbif == None:
-            dbif.connect()
-            connect = True
+           @param dbif: The database interface to be used
+           @param execute: If True the SQL statements will be executed.
+                           If False the prepared SQL statements are returned and must be executed by the caller.
-	self.base.insert(dbif)
-	if self.is_time_absolute():
-	    self.absolute_time.insert(dbif)
+        # Build the INSERT SQL statement
+        statement = self.base.get_insert_statement_mogrified(dbif)
+        if self.is_time_absolute():
+            statement += self.absolute_time.get_insert_statement_mogrified(dbif)
         if self.is_time_relative():
-	    self.relative_time.insert(dbif)
-	self.spatial_extent.insert(dbif)
-	self.metadata.insert(dbif)
+            statement += self.relative_time.get_insert_statement_mogrified(dbif)
+        statement += self.spatial_extent.get_insert_statement_mogrified(dbif)
+        statement += self.metadata.get_insert_statement_mogrified(dbif)
+        if execute == True:
+            execute_transaction(statement, dbif)
+            return ""
-        if connect:
-            dbif.close()
-    def update(self, dbif=None):
+        return statement
+    def update(self, dbif=None, execute=True):
 	"""!Update temporal dataset entry of database from the internal structure
 	   excluding None variables
-        connect = False
-        if dbif == None:
-            dbif.connect()
-            connect = True
-	self.base.update(dbif)
+        # Build the UPDATE SQL statement
+        statement = self.base.get_update_statement_mogrified(dbif)
-	    self.absolute_time.update(dbif)
+            statement += self.absolute_time.get_update_statement_mogrified(dbif)
-	    self.relative_time.update(dbif)
-	self.spatial_extent.update(dbif)
-	self.metadata.update(dbif)
+            statement += self.relative_time.get_update_statement_mogrified(dbif)
+        statement += self.spatial_extent.get_update_statement_mogrified(dbif)
+        statement += self.metadata.get_update_statement_mogrified(dbif)
-        if connect:
-            dbif.close()
+            return ""
-    def update_all(self, dbif=None):
+        return statement
+    def update_all(self, dbif=None, execute=True):
 	   and include None varuables.
-        connect = False
-        if dbif == None:
-            dbif.connect()
-            connect = True
-	self.base.update_all(dbif)
+        statement = self.base.get_update_all_statement_mogrified(dbif)
-	    self.absolute_time.update_all(dbif)
+            statement += self.absolute_time.get_update_all_statement_mogrified(dbif)
-	    self.relative_time.update_all(dbif)
-	self.spatial_extent.update_all(dbif)
-	self.metadata.update_all(dbif)
+            statement += self.relative_time.get_update_all_statement_mogrified(dbif)
+        statement += self.spatial_extent.get_update_all_statement_mogrified(dbif)
+        statement += self.metadata.get_update_all_statement_mogrified(dbif)
+            return ""
-        if connect:
-            dbif.close()
+        return statement
     def set_time_to_absolute(self):
 	self.base.set_ttype("absolute")
Modified: grass/trunk/lib/python/temporal/abstract_map_dataset.py
--- grass/trunk/lib/python/temporal/abstract_map_dataset.py	2012-04-02 14:03:09 UTC (rev 51244)
+++ grass/trunk/lib/python/temporal/abstract_map_dataset.py	2012-04-03 18:08:20 UTC (rev 51245)
@@ -211,13 +211,8 @@
            @param end_time: a datetime object specifying the end time of the map
            @param timezone: Thee timezone of the map
-        connect = False
-        if dbif == None:
-            dbif.connect()
-            connect = True
         self.set_absolute_time(start_time, end_time, timezone)
@@ -290,13 +285,8 @@
            @param end_time: A double value
-        connect = False
-        if dbif == None:
-            dbif.connect()
-            connect = True
         if self.set_relative_time(start_time, end_time, unit):
@@ -366,14 +356,9 @@
            @return The SQL statements if execute == False, else an empty string, None in case of a failure
-        connect = False
         statement = ""
-        if dbif == None:
-            dbif.connect()
-            connect = True
         if self.is_in_db(dbif):
             # SELECT all needed information from the database
@@ -389,27 +374,11 @@
             core.verbose(_("Delete %s dataset <%s> from temporal database") % (self.get_type(), self.get_id()))
             # Delete yourself from the database, trigger functions will take care of dependencies
-            statement += self.base.get_delete_statement() + ";\n"
+            statement += self.base.get_delete_statement()
         if execute == True:
-            sql_script = ""
-            sql_script += "BEGIN TRANSACTION;\n"
-            sql_script += statement
-            sql_script += "END TRANSACTION;"
-            # print sql_script
-            try:
-		if dbmi.__name__ == "sqlite3":
-		    dbif.cursor.executescript(statement)
-		else:
-		    dbif.cursor.execute(statement)
-            except:
-                if connect == True:
-                    dbif.close()
-                core.error(_("Unable to correctly delete %s map <%s>") % (self.get_type(), self.get_id()))
-                raise
-            dbif.connection.commit()
         # Remove the timestamp from the file system
         if self.get_type() == "vect":
 	    if self.get_layer():
@@ -428,7 +397,6 @@
             return ""
         return statement
     def unregister(self, dbif=None, update=True, execute=True):
 	"""! Remove the map entry in each space time dataset in which this map is registered
@@ -449,13 +417,8 @@
 	    core.verbose(_("Unregister %s map <%s> from space time datasets") % (self.get_type(), self.get_map_id()))
         statement = ""
-        connect = False
-        if dbif == None:
-            dbif.connect()
-            connect = True
         # Get all datasets in which this map is registered
         rows = self.get_registered_datasets(dbif)
@@ -477,25 +440,10 @@
                     stds.update_from_registered_maps(dbif)
             core.percent(1, 1, 1)
         if execute == True:
-            sql_script = ""
-            try:
-		else:
-            except:
-                    dbif.close()
-                core.error(_("Unable to correctly unregister %s <%s>") % (self.get_type(), self.get_id()))
-                raise
         if connect == True:
             dbif.close()
@@ -511,13 +459,8 @@
-        connect = False
-        if dbif == None:
-            dbif.connect()
-            connect = True
         rows = None
         try:
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2012-04-02 14:03:09 UTC (rev 51244)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2012-04-03 18:08:20 UTC (rev 51245)
@@ -480,13 +480,8 @@
             use_contain = False
             use_equal = False
-        connect = False
-        if dbif == None:
-            dbif.connect()
-            connect = True
         obj_list = []
         sample_maps = stds.get_registered_maps_as_objects_with_gaps(where=None, dbif=dbif)
@@ -559,13 +554,8 @@
            In case nothing found None is returned
-        connect = False
-        if dbif == None:
-            dbif.connect()
-            connect = True
         obj_list = []
         if gran == None:
@@ -623,13 +613,8 @@
-        connect = False
-        if dbif == None:
-            dbif.connect()
-            connect = True
         obj_list = []
         maps = self.get_registered_maps_as_objects(where, "start_time", dbif)
@@ -675,13 +660,8 @@
-        connect = False
-        if dbif == None:
-            dbif.connect()
-            connect = True
         obj_list = []
         rows = self.get_registered_maps("id,start_time,end_time", where, order, dbif)
@@ -718,13 +698,8 @@
-        connect = False
-        if dbif == None:
-            dbif.connect()
-            connect = True
         rows = None
         if self.get_map_register():
@@ -775,19 +750,13 @@
         core.verbose(_("Delete space time %s  dataset <%s> from temporal database") % (self.get_new_map_instance(ident=None).get_type(), self.get_id()))
         statement = ""
-        connect = False
-        if dbif == None:
-            dbif.connect()
-            connect = True
-        core.verbose(_("Drop map register table: %s") %  (self.get_map_register()))
+            core.verbose(_("Drop map register table: %s") %  (self.get_map_register()))
             rows = self.get_registered_maps("id", None, None, dbif)
             # Unregister each registered map in the table
             if rows:
@@ -800,39 +769,26 @@
                     statement += self.unregister_map(map=map, dbif=dbif, execute=False)
                     count += 1
-                # Safe the DROP table statement
-                statement += "DROP TABLE " + self.get_map_register() + ";\n"
+            # Safe the DROP table statement
+            statement += "DROP TABLE " + self.get_map_register() + ";\n"
         # Remove the primary key, the foreign keys will be removed by trigger
         if execute == True:
-            sql_script = ""
-            print sql_script
-            try:
-		else:
-            except:
-                    dbif.close()
-                core.error(_("Unable to correctly delete %s <%s>") % (self.get_type(), self.get_id()))
-                raise
         self.reset(None)
         if connect == True:
             dbif.close()
         if execute:
             return ""
         return statement
     def register_map(self, map, dbif=None):
         """!Register a map in the space time dataset.
@@ -844,13 +800,8 @@
-        connect = False
-        if dbif == None:
-            dbif.connect()
-            connect = True
         if map.is_in_db(dbif) == False:
             dbif.close()
             core.fatal(_("Only maps with absolute or relative valid time can be registered"))
@@ -882,6 +833,9 @@
         stds_mapset = self.base.get_mapset()
         stds_register_table = self.get_map_register()
         stds_ttype = self.get_temporal_type()
+        # The gathered SQL statemets are stroed here
+        statement = ""
         # Check temporal types
         if stds_ttype != map_ttype:
@@ -895,7 +849,7 @@
             self.map_counter == 0 and self.is_time_relative():
             self.set_relative_time_unit(map_rel_time_unit)
-            self.relative_time.update()
             core.verbose(_("Set temporal unit for space time %s dataset <%s> to %s") %  (map.get_type(), self.get_id(), map_rel_time_unit))
         stds_rel_time_unit = self.get_relative_time_unit()
@@ -919,18 +873,23 @@
 		sql = "SELECT id FROM " + stds_register_table + " WHERE id = (?)"
 	    else:
 		sql = "SELECT id FROM " + stds_register_table + " WHERE id = (%s)"
-            dbif.cursor.execute(sql, (map_id,))
-            row = dbif.cursor.fetchone()
-            # In case of no entry make a new one
+            try:
+                dbif.cursor.execute(sql, (map_id,))
+                row = dbif.cursor.fetchone()
+            except:
+                row = None
+                core.warning(_("Error in strds_register_table request"))
+                raise
             if row and row[0] == map_id:
                 if connect == True:
                     dbif.close()
 		if map.get_layer():
 		    core.warning(_("Map <%s> with layer %s is already registered.") % (map.get_map_id(), map.get_layer()))
 		else:
 		    core.warning(_("Map <%s> is already registered.") % (map.get_map_id()))
-                return False
+                return ""
         # Create tables
         sql_path = get_sql_template_path()
@@ -950,25 +909,12 @@
             sql = sql.replace("TABLE_NAME", uuid_rand )
             sql = sql.replace("MAP_ID", map_id)
             sql = sql.replace("STDS", self.get_type())
-            try:
-		    dbif.cursor.executescript(sql)
-		else:
-		    dbif.cursor.execute(sql)
-            except:
-                    dbif.close()
-		if map.get_layer():
-		    core.error(_("Unable to create the space time %s dataset register table for map <%s> with layer %s") % \
-                            (map.get_type(), map.get_map_id(), map.get_layer()))
-                else:
-		    core.error(_("Unable to create the space time %s dataset register table for <%s>") % \
-                            (map.get_type(), map.get_map_id()))
-                raise
+            statement += sql
             # Set the stds register table name and put it into the DB
             map.set_stds_register(map_register_table)
-            map.metadata.update(dbif)
+            statement += map.metadata.get_update_statement_mogrified(dbif)
             if map.get_layer():
 		core.verbose(_("Created register table <%s> for %s map <%s> with layer %s") % \
@@ -988,70 +934,59 @@
             sql = sql.replace("SPACETIME_NAME", stds_name + "_" + stds_mapset )
             sql = sql.replace("SPACETIME_ID", self.base.get_id())
+            statement += sql
-            sql_script = ""
-            sql_script += sql
-            sql_script += "\n"
-            try:
-		    dbif.cursor.executescript(sql_script)
-		else:
-		    dbif.cursor.execute(sql_script)
-            except:
-                    dbif.close()
-                else:
-                raise
             # Set the map register table name and put it into the DB
             self.set_map_register(stds_register_table)
             core.verbose(_("Created register table <%s> for space time %s  dataset <%s>") % \
                           (stds_register_table, map.get_type(), self.get_id()))
+        # We need to execute the statement at this time
+        if statement != "":
+        statement = ""
         # Register the stds in the map stds register table
         # Check if the entry is already there
 	if dbmi.paramstyle == "qmark":
 	    sql = "SELECT id FROM " + map_register_table + " WHERE id = ?"
 	else:
 	    sql = "SELECT id FROM " + map_register_table + " WHERE id = %s"
-        dbif.cursor.execute(sql, (self.base.get_id(),))
+        try:
+            dbif.cursor.execute(sql, (self.base.get_id(),))
+        except:
+            row = None
         if row == None:
-		sql = "INSERT INTO " + map_register_table + " (id) " + "VALUES (?)"
+		sql = "INSERT INTO " + map_register_table + " (id) " + "VALUES (?);\n"
 	    else:
-		sql = "INSERT INTO " + map_register_table + " (id) " + "VALUES (%s)"
-            #print sql
+		sql = "INSERT INTO " + map_register_table + " (id) " + "VALUES (%s);\n"
+            statement += dbif._mogrify_sql_statement((sql, (self.base.get_id(),)), dbif)
         # Now put the raster name in the stds map register table
-	    sql = "INSERT INTO " + stds_register_table + " (id) " + "VALUES (?)"
+	    sql = "INSERT INTO " + stds_register_table + " (id) " + "VALUES (?);\n"
 	else:
-	    sql = "INSERT INTO " + stds_register_table + " (id) " + "VALUES (%s)"
-        #print sql
+	    sql = "INSERT INTO " + stds_register_table + " (id) " + "VALUES (%s);\n"
+        statement += dbif._mogrify_sql_statement((sql, (map_id,)), dbif)
+        # Now execute the insert transaction
         if connect == True:
             dbif.close()
         # increase the counter
         self.map_counter += 1
-        return True
     def unregister_map(self, map, dbif = None, execute=True):
         """!Unregister a map from the space time dataset.
@@ -1068,13 +1003,8 @@
         statement = ""
-        connect = False
-        if dbif == None:
-            dbif.connect()
-            connect = True
         # First select needed data from the database
         map.metadata.select(dbif)
@@ -1092,8 +1022,11 @@
 	else:
+        try:
+        except:
+            row = None
         # Break if the map is not registered
         if row == None:
@@ -1103,34 +1036,29 @@
 		core.warning(_("Map <%s> is not registered in space time dataset <%s>") %(map.get_map_id(), self.base.get_id()))
             if connect == True:
                 dbif.close()
-            return None
+            return ""
         # Remove the space time raster dataset from the raster dataset register
         if map_register_table != None:
+            if dbmi.paramstyle == "qmark":
+                sql = "DELETE FROM " + map_register_table + " WHERE id = ?;\n"
+            else:
+                sql = "DELETE FROM " + map_register_table + " WHERE id = %s;\n"
-            statement += "DELETE FROM " + map_register_table + " WHERE id = \'%s\';\n"%(self.base.get_id())
-            if execute == True:
-                if dbmi.paramstyle == "qmark":
-		    sql = "DELETE FROM " + map_register_table + " WHERE id = ?"
-	        else:
-		    sql = "DELETE FROM " + map_register_table + " WHERE id = %s"
         # Remove the raster map from the space time raster dataset register
         if stds_register_table != None:
+                sql = "DELETE FROM " + stds_register_table + " WHERE id = ?;\n"
+            else:
+                sql = "DELETE FROM " + stds_register_table + " WHERE id = %s;\n"
-            statement += "DELETE FROM " + stds_register_table + " WHERE id = \'%s\';\n"%(map_id)
-		    sql = "DELETE FROM " + stds_register_table + " WHERE id = ?"
-	        else:
-		    sql = "DELETE FROM " + stds_register_table + " WHERE id = %s"
         if connect == True:
             dbif.close()
@@ -1164,13 +1092,8 @@
         if not self.get_map_register():
             return
-        connect = False
-        if dbif == None:
-            dbif.connect()
-            connect = True
         map_time = None
         use_start_time = False
@@ -1182,7 +1105,6 @@
         #We create a transaction
         sql_script = ""
         # Update the spatial and temporal extent from registered maps
         # Read the SQL template
@@ -1205,12 +1127,7 @@
         sql_script += sql
         sql_script += "\n"
-	else:
+	execute_transaction(sql_script, dbif)
         # Read and validate the selected end time
         self.select()
@@ -1280,10 +1197,7 @@
-	    else:
+	    execute_transaction(sql, dbif)
         # Count the temporal map types
         maps = self.get_registered_maps_as_objects(dbif=dbif)
Modified: grass/trunk/lib/python/temporal/base.py
--- grass/trunk/lib/python/temporal/base.py	2012-04-02 14:03:09 UTC (rev 51244)
+++ grass/trunk/lib/python/temporal/base.py	2012-04-03 18:08:20 UTC (rev 51245)
@@ -59,6 +59,7 @@
             sql += ' FROM ' + table + ' '
 	    if where:
 	        sql += where
+            sql += ";\n"
 	# Create insert statement
 	if type =="INSERT":
@@ -90,6 +91,7 @@
 	    if where:
 	        sql += where
+            sql += ";\n"
 	# Create update statement for existing entries
 	if type =="UPDATE":
@@ -114,6 +116,7 @@
 	            args.append(self.D[key])
 	    if where:
 	        sql += where
+            sql += ";\n"
 	# Create update statement for all entries
 	if type =="UPDATE ALL":
@@ -136,6 +139,7 @@
 	    if where:
 	        sql += where
+            sql += ";\n"
     	return sql, tuple(args)
@@ -219,7 +223,7 @@
             self.cursor.execute("PRAGMA journal_mode = MEMORY")
         elif dbmi.__name__ == "psycopg2":
 	    self.connection = dbmi.connect(init)
-	    self.connection.set_isolation_level(dbmi.extensions.ISOLATION_LEVEL_AUTOCOMMIT)
+	    #self.connection.set_isolation_level(dbmi.extensions.ISOLATION_LEVEL_AUTOCOMMIT)
 	    self.cursor = self.connection.cursor(cursor_factory=dbmi.extras.DictCursor)
     def close(self):
@@ -228,8 +232,65 @@
 	self.connection.commit()
         self.cursor.close()
+    def _mogrify_sql_statement(self, content, dbif=None):
+        """!Return the SQL statement and arguments as executable SQL string
+        sql = content[0]
+        args = content[1]
+        if dbmi.__name__ == "psycopg2":
+            if len(args) == 0:
+                return sql
+            else:
+                if dbif:
+                    try:
+                        return dbif.cursor.mogrify(sql, args)
+                    except:
+                        print sql, args
+                        raise
+                else:
+                    self.connect()
+                    statement = self.cursor.mogrify(sql, args)
+                    self.close()
+                    return statement
+        elif dbmi.__name__ == "sqlite3":
+                return sql
+            else:
+                # Unfortunately as sqlite does not support
+                # the transformation of sql strings and qmarked or
+                # named arguments we must make our hands dirty
+                # and do it by ourself. :(
+                # Doors are open for SQL injection because of the
+                # limited python sqlite3 implementation!!!
+                pos = 0
+                count = 0
+                maxcount = 100
+                statement = sql
+                while count < maxcount:
+                    pos = statement.find("?", pos + 1)
+                    if pos == -1:
+                        break
+                    if args[count] == None:
+                        statement = "%sNULL%s"%(statement[0:pos], statement[pos+1:])
+                    elif isinstance(args[count], (int, long)):
+                        statement = "%s%d%s"%(statement[0:pos], args[count],statement[pos+1:])
+                    elif isinstance(args[count], float):
+                        statement = "%s%f%s"%(statement[0:pos], args[count],statement[pos+1:])
+                    else:
+                        # Default is a string, this works for datetime objects too
+                        statement = "%s\'%s\'%s"%(statement[0:pos], str(args[count]),statement[pos+1:])
+                    count += 1
+                return statement
     def get_delete_statement(self):
-	return "DELETE FROM " + self.get_table_name() + " WHERE id = \'" + str(self.ident) + "\'"
+        """!Return the delete string"""
+	return "DELETE FROM " + self.get_table_name() + " WHERE id = \'" + str(self.ident) + "\';\n"
     def delete(self, dbif=None):
         """!Delete the entry of this object from the temporal database"""
@@ -244,7 +305,8 @@
             self.close()
     def get_is_in_db_statement(self):
-	return "SELECT id FROM " + self.get_table_name() + " WHERE id = \'" + str(self.ident) + "\'"
+        """Return the selection string"""
+	return "SELECT id FROM " + self.get_table_name() + " WHERE id = \'" + str(self.ident) + "\';\n"
         """!Check if this object is present in the temporal database
@@ -271,8 +333,13 @@
 	return True
     def get_select_statement(self):
+        """!Return the sql statement and the argument list in database specific style"""
 	return self.serialize("SELECT", self.get_table_name(), "WHERE id = \'" + str(self.ident) + "\'")
+    def get_select_statement_mogrified(self, dbif=None):
+        """!Return the select statement as mogrified string"""
+        return self._mogrify_sql_statement(self.get_select_statement(), dbif)
         """!Select the content from the temporal database and store it
            in the internal dictionary structure
@@ -310,7 +377,12 @@
 	return True
     def get_insert_statement(self):
 	return self.serialize("INSERT", self.get_table_name())
+    def get_insert_statement_mogrified(self, dbif=None):
+        """!Return the insert statement as mogrified string"""
+        return self._mogrify_sql_statement(self.get_insert_statement(), dbif)
         """!Serialize the content of this object and store it in the temporal
@@ -330,8 +402,13 @@
             self.close()
     def get_update_statement(self):
 	return self.serialize("UPDATE", self.get_table_name(), "WHERE id = \'" + str(self.ident) + "\'")
+    def get_update_statement_mogrified(self,dbif=None):
+        """!Return the update statement as mogrified string"""
+        return self._mogrify_sql_statement(self.get_update_statement(), dbif)
         """!Serialize the content of this object and update it in the temporal
            database using the internal identifier
@@ -355,8 +432,13 @@
             self.close()
     def get_update_all_statement(self):
 	return self.serialize("UPDATE ALL", self.get_table_name(), "WHERE id = \'" + str(self.ident) + "\'")
+    def get_update_all_statement_mogrified(self, dbif=None):
+        """!Return the update all statement as mogrified string"""
+        return self._mogrify_sql_statement(self.get_update_all_statement(), dbif)
         """!Serialize the content of this object, including None objects, and update it in the temporal
@@ -672,3 +754,52 @@
         stds_base.__init__(self, "stvds_base", ident, name, mapset, semantic_type, creator, creation_time,\
 	            modification_time, temporal_type, revision)
+def init_dbif(dbif):
+    """!This method checks if the database interface exists, if not a new one
+        will be created and True will be returned
+        Usage code sample:
+        dbif, connect = self._init_dbif(dbif)
+        if connect:
+            dbif.close()
+    if dbif == None:
+        dbif = sql_database_interface()
+        dbif.connect()
+        return dbif, True
+    return dbif, False
+def execute_transaction(statement, dbif=None):
+    """!Execute a transactional SQL statement
+        The BEGIN and END TRANSACTION statements will be added automatically
+        to the sql statement
+        @param statement The executable SQL statement or SQL script
+        @param dbif The database interface, if None a new db interface will be created temporary
+    sql_script = ""
+    sql_script += "BEGIN TRANSACTION;\n"
+    sql_script += statement
+    sql_script += "END TRANSACTION;"
+    try:
+        if dbmi.__name__ == "sqlite3":
+            dbif.cursor.executescript(statement)
+        else:
+            dbif.cursor.execute(statement)
+        dbif.connection.commit()
+    except:
+        if connect == True:
+            dbif.close()
+        core.error(_("Unable to execute transaction:\n %s") % (statement))
+        raise
+    if connect:
+        dbif.close()
Modified: grass/trunk/lib/python/temporal/space_time_datasets_tools.py
--- grass/trunk/lib/python/temporal/space_time_datasets_tools.py	2012-04-02 14:03:09 UTC (rev 51244)
+++ grass/trunk/lib/python/temporal/space_time_datasets_tools.py	2012-04-03 18:08:20 UTC (rev 51245)
@@ -86,13 +86,8 @@
 	    core.fatal(_("Unkown map type: %s")%(type))
-    connect = False
+    dbif, connect = init_dbif(None)
-    if dbif == None:
-        dbif.connect()
-        connect = True
     if name:
 	# Read content from temporal database
 	sp.select(dbif)
@@ -163,6 +158,11 @@
             maplist.append(row)
     num_maps = len(maplist)
+    map_object_list = []
+    statement = ""
+    core.message(_("Gathering map informations"))
     for count in range(len(maplist)):
 	core.percent(count, num_maps, 1)
@@ -174,9 +174,12 @@
             start = maplist[count]["start"]
         if maplist[count].has_key("end"):
             end = maplist[count]["end"]
+        is_in_db = False
         # Put the map into the database
+            is_in_db = False
             # Break in case no valid time is provided
             if start == "" or start == None:
                 dbif.close()
@@ -186,17 +189,14 @@
 		else:
 		    core.fatal(_("Unable to register %s map <%s>. The map has no valid time and the start time is not set.") % \
 				(map.get_type(), map.get_map_id() ))
-            # Load the data from the grass file database
-            map.load()
 	    if unit:
                 map.set_time_to_relative()
             else:
                 map.set_time_to_absolute()
-            #  Put it into the temporal database
-            map.insert(dbif)
         else:
+            is_in_db = True
             map.select(dbif)
             if name and map.get_temporal_type() != sp.get_temporal_type():
                 dbif.close()
@@ -206,20 +206,55 @@
 		    core.fatal(_("Unable to register %s map <%s>. The temporal types are different.") %  \
-        # In case the time is in the input file we ignore the increment counter
-        if start_time_in_file:
-            count = 1
+        # Load the data from the grass file database
+        map.load()
         # Set the valid time
         if start:
-            assign_valid_time_to_map(ttype=map.get_temporal_type(), map=map, start=start, end=end, unit=unit, increment=increment, mult=count, dbif=dbif, interval=interval)
+            # In case the time is in the input file we ignore the increment counter
+            if start_time_in_file:
+                count = 1
+            assign_valid_time_to_map(ttype=map.get_temporal_type(), map=map, start=start, end=end, unit=unit, increment=increment, mult=count, interval=interval)
-        # Finally Register map in the space time dataset
+        if is_in_db:
+           #  Gather the SQL update statement
+           statement += map.update_all(dbif=dbif, execute=True)
+        else:
+           #  Gather the SQL insert statement
+           statement += map.insert(dbif=dbif, execute=False)
+        # Sqlite3 performace better for huge datasets when committing in small chunks
+            if count % 100 == 0:
+                if statement != None and statement != "":
+                    core.message(_("Registering 100 maps in the temporal database"))
+                    statement = ""
+        # Store the maps in a list to register in a space time dataset
         if name:
-	    sp.register_map(map, dbif)
+            map_object_list.append(map)
+    core.percent(num_maps, num_maps, 1)
+        core.message(_("Register maps in the temporal database"))
+    # Finally Register the maps in the space time dataset
+    if name:
+        statement = ""
+        count = 0
+        num_maps = len(map_object_list)
+        core.message(_("Register maps in the space time raster dataset"))
+        for map in map_object_list:
+	    core.percent(count, num_maps, 1)
+	    sp.register_map(map=map, dbif=dbif)
+            count += 1
     # Update the space time tables
     if name:
+        core.message(_("Update space time raster dataset"))
 	sp.update_from_registered_maps(dbif)
     if connect == True:
@@ -230,7 +265,7 @@
-def assign_valid_time_to_map(ttype, map, start, end, unit, increment=None, mult=1, dbif = None, interval=False):
+def assign_valid_time_to_map(ttype, map, start, end, unit, increment=None, mult=1, interval=False):
     """!Assign the valid time to a map dataset
        @param ttype: The temporal type which should be assigned and which the time format is of
@@ -240,24 +275,16 @@
        @param unit: The unit of the relative time: years, months, days, hours, minutes, seconds
        @param increment: Time increment between maps for time stamp creation (format absolute: NNN seconds, minutes, hours, days, weeks, months, years; format relative is integer 1)
        @param multi: A multiplier for the increment
-       @param dbif: The database interface to use for sql queries
        @param interval: If True, time intervals are created in case the start time and an increment is provided
-    connect = False
-    if dbif == None:
-        dbif.connect()
-        connect = True
     if ttype == "absolute":
         start_time = string_to_datetime(start)
         if start_time == None:
             dbif.close()
             core.fatal(_("Unable to convert string \"%s\"into a datetime object")%(start))
         end_time = None
         if end:
             end_time = string_to_datetime(end)
             if end_time == None:
@@ -274,7 +301,7 @@
         else:
 	    core.verbose(_("Set absolute valid time for map <%s> to %s - %s") % (map.get_map_id(), str(start_time), str(end_time)))
-        map.update_absolute_time(start_time, end_time, None, dbif)
+        map.set_absolute_time(start_time, end_time, None)
     else:
         start_time = int(start)
         end_time = None
@@ -292,11 +319,8 @@
         else:
 	    core.verbose(_("Set relative valid time for map <%s> to %i - %s with unit %s") % (map.get_map_id(), start_time,  str(end_time), unit))
-        map.update_relative_time(start_time, end_time, unit, dbif)
+        map.set_relative_time(start_time, end_time, unit)
-        dbif.close()
 def dataset_factory(type, id):
Modified: grass/trunk/temporal/t.register/test.t.register.vector.file.layer.sh
--- grass/trunk/temporal/t.register/test.t.register.vector.file.layer.sh	2012-04-02 14:03:09 UTC (rev 51244)
+++ grass/trunk/temporal/t.register/test.t.register.vector.file.layer.sh	2012-04-03 18:08:20 UTC (rev 51245)
@@ -51,19 +51,19 @@
 # Test with input files
 # File 1
 t.register --v type=vect input=lidar_abs_ds1 file="${n1}" start="2001-01-01" increment="1 months"
-t.list type=vect columns=id,name,start_time,end_time where='name = "lidar_abs_1"'
+t.list type=vect columns=id,name,start_time,end_time where="name='lidar_abs_1'"
 # File 1
 # File 2
 t.register --v type=vect input=lidar_abs_ds1 file="${n2}"
 # File 2
 t.register --v type=vect input=lidar_abs_ds1 -i file="${n2}" start=file increment="1 months"
 # File 3
 t.register --v type=vect input=lidar_abs_ds1 file="${n3}" start=file
 t.unregister --v type=vect maps=lidar_abs_1:1,lidar_abs_1:2,lidar_abs_1:3,lidar_abs_1:4,lidar_abs_1:5,lidar_abs_1:6
 t.remove type=stvds input=lidar_abs_ds1
Modified: grass/trunk/temporal/t.register/test.t.register.vector.sh
--- grass/trunk/temporal/t.register/test.t.register.vector.sh	2012-04-02 14:03:09 UTC (rev 51244)
+++ grass/trunk/temporal/t.register/test.t.register.vector.sh	2012-04-03 18:08:20 UTC (rev 51245)
@@ -62,3 +62,6 @@
 t.unregister --v type=vect maps=lidar_abs_1,lidar_abs_2,lidar_abs_3
 t.remove --v type=stvds input=lidar_abs_ds1,lidar_abs_ds2,lidar_abs_ds3,lidar_abs_ds4,lidar_abs_ds5,lidar_abs_ds6,lidar_abs_ds7
 t.unregister --v type=vect maps=lidar_abs_4,lidar_abs_5,lidar_abs_6
+g.remove vect=lidar_abs_1,lidar_abs_2,lidar_abs_3,lidar_abs_4,lidar_abs_5,lidar_abs_6
