[GRASS-SVN] r51249 - in grass/trunk/temporal: . t.rast3d.extract
svn_grass at osgeo.org
Wed Apr 4 05:31:44 EDT 2012
Author: huhabla
Date: 2012-04-04 02:31:44 -0700 (Wed, 04 Apr 2012)
New Revision: 51249
Added:
grass/trunk/temporal/t.rast3d.extract/
grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.html
grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.py
grass/trunk/temporal/t.rast3d.extract/test.t.rast3d.extract.sh
Removed:
grass/trunk/temporal/t.rast3d.extract/test.tr3.extract.sh
grass/trunk/temporal/t.rast3d.extract/tr3.extract.html
grass/trunk/temporal/t.rast3d.extract/tr3.extract.py
grass/trunk/temporal/tr3.extract/
grass/trunk/temporal/t.rast3d.extract/Makefile
Renaming tr3.extract to meet new naming scheme
Modified: grass/trunk/temporal/t.rast3d.extract/Makefile
--- grass/trunk/temporal/tr3.extract/Makefile 2012-04-02 14:03:09 UTC (rev 51244)
+++ grass/trunk/temporal/t.rast3d.extract/Makefile 2012-04-04 09:31:44 UTC (rev 51249)
@@ -1,6 +1,6 @@
MODULE_TOPDIR = ../../
-PGM = tr3.extract
+PGM = t.rast3d.extract
include $(MODULE_TOPDIR)/include/Make/Script.make
Copied: grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.html (from rev 51244, grass/trunk/temporal/tr3.extract/tr3.extract.html)
Copied: grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.py (from rev 51248, grass/trunk/temporal/tr3.extract/tr3.extract.py)
--- grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.py (rev 0)
+++ grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.py 2012-04-04 09:31:44 UTC (rev 51249)
@@ -0,0 +1,189 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE: t.rast3d.extract
+# AUTHOR(S): Soeren Gebbert
+# PURPOSE: Extract a subset of a space time raster3d dataset
+# COPYRIGHT: (C) 2011 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (version 2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Extract a subset of a space time raster3d dataset
+#% keywords: temporal
+#% keywords: extract
+#%end
+#%option G_OPT_STR3DS_INPUT
+#%end
+#%option G_OPT_T_WHERE
+#%end
+#%option
+#% key: expression
+#% type: string
+#% description: The r3.mapcalc expression assigned to all extracted raster3d maps
+#% required: no
+#% multiple: no
+#%end
+#%option G_OPT_STR3DS_OUTPUT
+#%end
+#%option
+#% key: base
+#% type: string
+#% description: Base name of the new created raster3d maps
+#% required: no
+#% multiple: no
+#%end
+#%flag
+#% key: n
+#% description: Register Null maps
+#%end
+import grass.script as grass
+import grass.temporal as tgis
+def main():
+ # Get the options
+ input = options["input"]
+ output = options["output"]
+ where = options["where"]
+ expression = options["expression"]
+ base = options["base"]
+ register_null = flags["n"]
+ if expression and not base:
+ grass.fatal(_("Please specify %s=")%"base")
+ # Make sure the temporal database exists
+ tgis.create_temporal_database()
+ mapset = grass.gisenv()["MAPSET"]
+ if input.find("@") >= 0:
+ id = input
+ else:
+ id = input + "@" + mapset
+ sp = tgis.space_time_raster3d_dataset(id)
+ if sp.is_in_db() == False:
+ grass.fatal(_("Space time %s dataset <%s> not found") % (sp.get_new_map_instance(None).get_type(), id))
+ dbif = tgis.sql_database_interface()
+ dbif.connect()
+ sp.select(dbif)
+ if output.find("@") >= 0:
+ out_id = output
+ else:
+ out_id = output + "@" + mapset
+ # The new space time raster3d dataset
+ new_sp = tgis.space_time_raster3d_dataset(out_id)
+ if new_sp.is_in_db():
+ if grass.overwrite() == True:
+ new_sp.delete(dbif)
+ else:
+ grass.fatal(_("Space time raster3d dataset <%s> is already in database, use overwrite flag to overwrite") % out_id)
+ temporal_type, semantic_type, title, description = sp.get_initial_values()
+ new_sp.set_initial_values(temporal_type, semantic_type, title, description)
+ new_sp.insert(dbif)
+ rows = sp.get_registered_maps("id", where, "start_time", dbif)
+ if rows:
+ num_rows = len(rows)
+ grass.percent(0, num_rows, 1)
+ count = 0
+ for row in rows:
+ count += 1
+ grass.percent(count, num_rows, 1)
+ old_map = sp.get_new_map_instance(row["id"])
+ old_map.select(dbif)
+ if expression:
+ map_name = "%s_%i" % (base, count)
+ expr = "%s = %s" % (map_name, expression.replace(sp.get_id(), row["id"]))
+ expr = expr.replace(sp.base.get_name(), row["id"])
+ map_id = map_name + "@" + mapset
+ new_map = sp.get_new_map_instance(map_id)
+ # Check if new map is in the temporal database
+ if new_map.is_in_db(dbif):
+ # Remove the existing temporal database entry
+ new_map.delete(dbif)
+ else:
+ grass.error(_("Raster3d map <%s> is already in temporal database, use overwrite flag to overwrite"))
+ continue
+ grass.verbose(_("Apply r3.mapcalc expression: \"%s\"") % expr)
+ ret = grass.run_command("r3.mapcalc", expression=expr, overwrite=grass.overwrite(), quiet=True)
+ if ret != 0:
+ grass.error(_("Error while r3.mapcalc computation, continue with next map"))
+ break
+ # Read the raster3d map data
+ new_map.load()
+ # In case of a null map continue, do not register null maps
+ print new_map.metadata.get_min(), new_map.metadata.get_max()
+ if new_map.metadata.get_min() == None and new_map.metadata.get_max() == None:
+ print("Found null map")
+ if not register_null:
+ continue
+ # Set the time stamp
+ if old_map.is_time_absolute():
+ start, end, tz = old_map.get_absolute_time()
+ new_map.set_absolute_time(start, end, tz)
+ else:
+ start, end = old_map.get_relative_time()
+ new_map.set_relative_time(start, end)
+ # Insert map in temporal database
+ new_map.insert(dbif)
+ new_sp.register_map(new_map, dbif)
+ else:
+ new_sp.register_map(old_map, dbif)
+ # Update the spatio-temporal extent and the raster3d metadata table entries
+ new_sp.update_from_registered_maps(dbif)
+ grass.percent(num_rows, num_rows, 1)
+ dbif.close()
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
Copied: grass/trunk/temporal/t.rast3d.extract/test.t.rast3d.extract.sh (from rev 51244, grass/trunk/temporal/tr3.extract/test.tr3.extract.sh)
--- grass/trunk/temporal/t.rast3d.extract/test.t.rast3d.extract.sh (rev 0)
+++ grass/trunk/temporal/t.rast3d.extract/test.t.rast3d.extract.sh 2012-04-04 09:31:44 UTC (rev 51249)
@@ -0,0 +1,28 @@
+# Test the extraction of a subset of a space time raster input
+# We need to set a specific region in the
+# @preprocess step of this test. We generate
+# raster with r.mapcalc and create two space time raster inputs
+# with relative and absolute time
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
+r3.mapcalc --o expr="prec_1 = rand(0, 550)"
+r3.mapcalc --o expr="prec_2 = rand(0, 450)"
+r3.mapcalc --o expr="prec_3 = rand(0, 320)"
+r3.mapcalc --o expr="prec_4 = rand(0, 510)"
+r3.mapcalc --o expr="prec_5 = rand(0, 300)"
+r3.mapcalc --o expr="prec_6 = rand(0, 650)"
+t.create --o type=str3ds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
+t.register -i type=rast3d input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="3 months"
+# The first @test
+# We create the space time raster inputs and register the raster maps with absolute time interval
+t.rast3d.extract --o input=precip_abs1 output=precip_abs2 where="start_time > '2001-06-01'" expression=" if(precip_abs1 > 400, precip_abs1, null())" base=new_prec
+t.info type=str3ds input=precip_abs2
+t.unregister type=rast3d maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+t.remove type=str3ds input=precip_abs1,precip_abs2
Deleted: grass/trunk/temporal/t.rast3d.extract/test.tr3.extract.sh
--- grass/trunk/temporal/tr3.extract/test.tr3.extract.sh 2012-04-02 14:03:09 UTC (rev 51244)
+++ grass/trunk/temporal/t.rast3d.extract/test.tr3.extract.sh 2012-04-04 09:31:44 UTC (rev 51249)
@@ -1,28 +0,0 @@
-# Test the extraction of a subset of a space time raster input
-# We need to set a specific region in the
-# @preprocess step of this test. We generate
-# raster with r.mapcalc and create two space time raster inputs
-# with relative and absolute time
-# The region setting should work for UTM and LL test locations
-g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
-r3.mapcalc --o expr="prec_1 = rand(0, 550)"
-r3.mapcalc --o expr="prec_2 = rand(0, 450)"
-r3.mapcalc --o expr="prec_3 = rand(0, 320)"
-r3.mapcalc --o expr="prec_4 = rand(0, 510)"
-r3.mapcalc --o expr="prec_5 = rand(0, 300)"
-r3.mapcalc --o expr="prec_6 = rand(0, 650)"
-t.create --o type=str3ds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
-t.register -i type=rast3d input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="3 months"
-# The first @test
-# We create the space time raster inputs and register the raster maps with absolute time interval
-tr3.extract --o input=precip_abs1 output=precip_abs2 where="start_time > '2001-06-01'" expression=" if(precip_abs1 > 400, precip_abs1, null())" base=new_prec
-t.info type=str3ds input=precip_abs2
-t.unregister type=rast3d maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
-t.remove type=str3ds input=precip_abs1,precip_abs2
Deleted: grass/trunk/temporal/t.rast3d.extract/tr3.extract.html
Deleted: grass/trunk/temporal/t.rast3d.extract/tr3.extract.py
--- grass/trunk/temporal/tr3.extract/tr3.extract.py 2012-04-02 14:03:09 UTC (rev 51244)
+++ grass/trunk/temporal/t.rast3d.extract/tr3.extract.py 2012-04-04 09:31:44 UTC (rev 51249)
@@ -1,189 +0,0 @@
-#!/usr/bin/env python
-# -*- coding: utf-8 -*-
-# MODULE: tr3.extract
-# AUTHOR(S): Soeren Gebbert
-# PURPOSE: Extract a subset of a space time raster3d dataset
-# COPYRIGHT: (C) 2011 by the GRASS Development Team
-# This program is free software under the GNU General Public
-# License (version 2). Read the file COPYING that comes with GRASS
-# for details.
-#%module
-#% description: Extract a subset of a space time raster3d dataset
-#% keywords: temporal
-#% keywords: extract
-#%end
-#%option G_OPT_STR3DS_INPUT
-#%end
-#%option G_OPT_T_WHERE
-#%end
-#%option
-#% key: expression
-#% type: string
-#% description: The r3.mapcalc expression assigned to all extracted raster3d maps
-#% required: no
-#% multiple: no
-#%end
-#%option G_OPT_STR3DS_OUTPUT
-#%end
-#%option
-#% key: base
-#% type: string
-#% description: Base name of the new created raster3d maps
-#% required: no
-#% multiple: no
-#%end
-#%flag
-#% key: n
-#% description: Register Null maps
-#%end
-import grass.script as grass
-import grass.temporal as tgis
-def main():
- # Get the options
- input = options["input"]
- output = options["output"]
- where = options["where"]
- expression = options["expression"]
- base = options["base"]
- register_null = flags["n"]
- if expression and not base:
- grass.fatal(_("Please specify %s=")%"base")
- # Make sure the temporal database exists
- tgis.create_temporal_database()
- mapset = grass.gisenv()["MAPSET"]
- if input.find("@") >= 0:
- id = input
- else:
- id = input + "@" + mapset
- sp = tgis.space_time_raster3d_dataset(id)
- if sp.is_in_db() == False:
- grass.fatal(_("Space time raster3d dataset <%s> not found in temporal database") % (id))
- dbif = tgis.sql_database_interface()
- dbif.connect()
- sp.select(dbif)
- if output.find("@") >= 0:
- out_id = output
- else:
- out_id = output + "@" + mapset
- # The new space time raster3d dataset
- new_sp = tgis.space_time_raster3d_dataset(out_id)
- if new_sp.is_in_db():
- if grass.overwrite() == True:
- new_sp.delete(dbif)
- else:
- grass.fatal(_("Space time raster3d dataset <%s> is already in database, use overwrite flag to overwrite") % out_id)
- temporal_type, semantic_type, title, description = sp.get_initial_values()
- new_sp.set_initial_values(temporal_type, semantic_type, title, description)
- new_sp.insert(dbif)
- rows = sp.get_registered_maps("id", where, "start_time", dbif)
- if rows:
- num_rows = len(rows)
- grass.percent(0, num_rows, 1)
- count = 0
- for row in rows:
- count += 1
- grass.percent(count, num_rows, 1)
- old_map = sp.get_new_map_instance(row["id"])
- old_map.select(dbif)
- if expression:
- map_name = "%s_%i" % (base, count)
- expr = "%s = %s" % (map_name, expression.replace(sp.get_id(), row["id"]))
- expr = expr.replace(sp.base.get_name(), row["id"])
- map_id = map_name + "@" + mapset
- new_map = sp.get_new_map_instance(map_id)
- # Check if new map is in the temporal database
- if new_map.is_in_db(dbif):
- # Remove the existing temporal database entry
- new_map.delete(dbif)
- else:
- grass.error(_("Raster3d map <%s> is already in temporal database, use overwrite flag to overwrite"))
- continue
- grass.verbose(_("Apply r3.mapcalc expression: \"%s\"") % expr)
- ret = grass.run_command("r3.mapcalc", expression=expr, overwrite=grass.overwrite(), quiet=True)
- if ret != 0:
- grass.error(_("Error while r3.mapcalc computation, continue with next map"))
- break
- # Read the raster3d map data
- new_map.load()
- # In case of a null map continue, do not register null maps
- print new_map.metadata.get_min(), new_map.metadata.get_max()
- if new_map.metadata.get_min() == None and new_map.metadata.get_max() == None:
- print("Found null map")
- if not register_null:
- continue
- # Set the time stamp
- if old_map.is_time_absolute():
- start, end, tz = old_map.get_absolute_time()
- new_map.set_absolute_time(start, end, tz)
- else:
- start, end = old_map.get_relative_time()
- new_map.set_relative_time(start, end)
- # Insert map in temporal database
- new_map.insert(dbif)
- new_sp.register_map(new_map, dbif)
- else:
- new_sp.register_map(old_map, dbif)
- # Update the spatio-temporal extent and the raster3d metadata table entries
- new_sp.update_from_registered_maps(dbif)
- grass.percent(num_rows, num_rows, 1)
- dbif.close()
-if __name__ == "__main__":
- options, flags = grass.parser()
- main()
