[GRASS-SVN] r51256 - in grass/trunk/temporal: . t.vect.what.strds
Wed Apr 4 08:41:47 EDT 2012
Author: huhabla
Date: 2012-04-04 05:41:47 -0700 (Wed, 04 Apr 2012)
New Revision: 51256
Added:
   grass/trunk/temporal/t.vect.what.strds/
   grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.html
   grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py
   grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.layer.sh
   grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.sh
Removed:
   grass/trunk/temporal/t.vect.what.strds/test.tv.what.strds.layer.sh
   grass/trunk/temporal/t.vect.what.strds/test.tv.what.strds.sh
   grass/trunk/temporal/t.vect.what.strds/tv.what.strds.html
   grass/trunk/temporal/t.vect.what.strds/tv.what.strds.py
   grass/trunk/temporal/t.vect.what.strds/Makefile
Renamed tv.what.strds to meet new naming scheme
Modified: grass/trunk/temporal/t.vect.what.strds/Makefile
--- grass/trunk/temporal/tv.what.strds/Makefile	2012-04-04 09:39:32 UTC (rev 51251)
+++ grass/trunk/temporal/t.vect.what.strds/Makefile	2012-04-04 12:41:47 UTC (rev 51256)
@@ -1,6 +1,6 @@
 MODULE_TOPDIR = ../../
-PGM = tv.what.strds
+PGM = t.vect.what.strds
 include $(MODULE_TOPDIR)/include/Make/Script.make
Copied: grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.html (from rev 51251, grass/trunk/temporal/tv.what.strds/tv.what.strds.html)
Copied: grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py (from rev 51251, grass/trunk/temporal/tv.what.strds/tv.what.strds.py)
--- grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py	                        (rev 0)
+++ grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py	2012-04-04 12:41:47 UTC (rev 51256)
@@ -0,0 +1,175 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE:	t.vect.what.strds
+# AUTHOR(S):	Soeren Gebbert
+# PURPOSE:	Uploads raster map values at spatial and temporal positions of vector points to the tables. The maps are registered in space time datasets
+# COPYRIGHT:	(C) 2011 by the GRASS Development Team
+#		This program is free software under the GNU General Public
+#		License (version 2). Read the file COPYING that comes with GRASS
+#		for details.
+#%module
+#% description: Uploads raster map values at spatial and temporal positions of vector points to the tables. The maps are registered in space time datasets
+#% keywords: temporal
+#% keywords: sampling
+#%end
+#%option G_OPT_STVDS_INPUT
+#%end
+#%option  G_OPT_STRDS_INPUT
+#% key: strds
+#%end
+#%option
+#% key: column
+#% type: string
+#% description: Name of the vector column to be created and to store sampled raster values. The use of a column name forces t.vect.what.rast to sample only values from the first map found in an interval. Otherwise the raster map names are used as column names.
+#% required: no
+#% multiple: no
+#%end
+#%option G_OPT_DB_WHERE
+#%end
+#%option G_OPT_T_WHERE
+#% key: t_where
+#%end
+#%option G_OPT_T_SAMPLE
+#%end
+import grass.script as grass
+import grass.temporal as tgis
+import grass.script.raster as raster
+def main():
+    # Get the options
+    input = options["input"]
+    strds = options["strds"]
+    where = options["where"]
+    column = options["column"]
+    tempwhere = options["t_where"]
+    sampling = options["sampling"]
+    if where == "" or where == " " or where == "\n":
+        where = None
+    # Make sure the temporal database exists
+    tgis.create_temporal_database()
+    # We need a database interface
+    dbif = tgis.sql_database_interface()
+    dbif.connect()
+    mapset =  grass.gisenv()["MAPSET"]
+    if input.find("@") >= 0:
+        id = input
+    else:
+        id = input + "@" + mapset
+    sp = tgis.space_time_vector_dataset(id)
+    if sp.is_in_db() == False:
+        dbif.close()
+        grass.fatal(_("Space time %s dataset <%s> not found") % (sp.get_new_map_instance(None).get_type(), id))
+    sp.select(dbif)
+    if strds.find("@") >= 0:
+        strds_id = strds
+    else:
+        strds_id = strds + "@" + mapset
+    strds_sp = tgis.space_time_raster_dataset(strds_id)
+    if strds_sp.is_in_db() == False:
+        dbif.close()
+        grass.fatal(_("Dataset <%s> not found in temporal database") % (id))
+    strds_sp.select(dbif)
+    if strds_sp.get_temporal_type() != sp.get_temporal_type():
+        dbif.close()
+        grass.fatal(_("Input and aggregation dataset must have the same temporal type"))
+    # Check if intervals are present
+    if sp.get_temporal_type() == "absolute":
+        map_time = strds_sp.absolute_time.get_map_time()
+    else:
+        map_time = strds_sp.relative_time.get_map_time()
+    if map_time != "interval":
+        dbif.close()
+        grass.fatal(_("All registered maps of the space time vector dataset must have time intervals"))
+    rows = sp.get_registered_maps("name,layer,mapset,start_time,end_time", tempwhere, "start_time", dbif)
+    dummy = tgis.vector_dataset(None)
+    if not rows:
+        dbif.close()
+        grass.fatal(_("Space time vector dataset <%s> is empty") % sp.get_id())
+    # Sample the raster dataset with the vector dataset and run v.what.rast
+    for row in rows:
+        start = row["start_time"]
+        end = row["end_time"]
+        vectmap = row["name"] + "@" + row["mapset"]
+        layer = row["layer"]
+        raster_maps = tgis.collect_map_names(strds_sp, dbif, start, end, sampling)
+        if raster_maps:
+            # Collect the names of the raster maps
+            for rastermap in raster_maps:
+                if column:
+                    col_name = column
+                else:
+                    # Create a new column with the SQL compliant name of the sampled raster map
+                    col_name = rastermap.split("@")[0].replace(".", "_")
+                coltype = "DOUBLE PRECISION"
+                # Get raster type
+                rasterinfo = raster.raster_info(rastermap)
+                if rasterinfo["datatype"] == "CELL":
+                    coltype = "INT"
+		if layer:
+		    ret = grass.run_command("v.db.addcolumn", map=vectmap, layer=layer, column="%s %s" % (col_name, coltype), overwrite=grass.overwrite())
+		else:
+		    ret = grass.run_command("v.db.addcolumn", map=vectmap, column="%s %s" % (col_name, coltype), overwrite=grass.overwrite())
+                if ret != 0:
+                    dbif.close()
+                    grass.fatal(_("Unable to add column %s to vector map <%s>")%(col_name, vectmap))
+                # Call v.what.rast
+                if layer:
+		    ret = grass.run_command("v.what.rast", map=vectmap, layer=layer, raster=rastermap, column=col_name, where=where)
+		else:
+		    ret = grass.run_command("v.what.rast", map=vectmap, raster=rastermap, column=col_name, where=where)
+                if ret != 0:
+                    dbif.close()
+                    grass.fatal(_("Unable to run v.what.rast for vector map <%s> and raster map <%s>")%(vectmap, rastermap))
+                # Use the first map in case a column names was provided
+                if column:
+                    break
+    dbif.close()
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    main()
Copied: grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.layer.sh (from rev 51251, grass/trunk/temporal/tv.what.strds/test.tv.what.strds.layer.sh)
--- grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.layer.sh	                        (rev 0)
+++ grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.layer.sh	2012-04-04 12:41:47 UTC (rev 51256)
@@ -0,0 +1,80 @@
+# Test the temporal and spatial sampling of raster maps by vector point maps
+# using timetamped vector tables
+# We need to set a specific region in the
+# @preprocess step of this test.
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
+# The raster maps
+r.mapcalc --o expr="sand_frac   = 50.0"
+r.mapcalc --o expr="sand_frac_1 = 25.0"
+r.mapcalc --o expr="sand_frac_2 = 35.0"
+r.mapcalc --o expr="sand_frac_3 = 45.0"
+r.mapcalc --o expr="sand_frac_4 = 55.0"
+r.mapcalc --o expr="sand_frac_5 = 65.0"
+r.mapcalc --o expr="sand_frac_6 = 75.0"
+# The vector map
+v.random --o -z seed=1 output=soil_orig n=100 zmin=0 zmax=100 column=sand
+# Adding new layer with categories
+v.category input=soil_orig out=soils option=transfer layer=1,2,3,4,5,6 --o
+# Creating new tables for each layer
+db.copy from_table=soil_orig to_table=soils_2
+db.copy from_table=soil_orig to_table=soils_3
+db.copy from_table=soil_orig to_table=soils_4
+db.copy from_table=soil_orig to_table=soils_5
+db.copy from_table=soil_orig to_table=soils_6
+v.db.addtable map=soils table=soils_2 layer=2
+v.db.addtable map=soils table=soils_3 layer=3
+v.db.addtable map=soils table=soils_4 layer=4
+v.db.addtable map=soils table=soils_5 layer=5
+v.db.addtable map=soils table=soils_6 layer=6
+n1=`g.tempfile pid=1 -d`
+cat > "${n1}" << EOF
+soils:1
+soils:2
+soils:3
+soils:4
+soils:5
+soils:6
+EOF
+t.create --o type=stvds temporaltype=absolute output=soil_abs title="A test" descr="A test"
+t.register -i type=vect input=soil_abs file="${n1}" start="2001-03-01 00:00:00" increment="1 months"
+t.vect.list input=soil_abs columns=name,layer,start_time,end_time
+t.create --o type=strds temporaltype=absolute output=sand_frac_abs_1 title="A test" descr="A test"
+t.register -i type=rast input=sand_frac_abs_1 maps=sand_frac start="2001-01-01 00:00:00" increment="12 months"
+tr.list input=sand_frac_abs_1 columns=name,start_time,end_time
+t.create --o type=strds temporaltype=absolute output=sand_frac_abs_2 title="A test" descr="A test"
+t.register -i type=rast input=sand_frac_abs_2 maps=sand_frac_1,sand_frac_2,sand_frac_3,sand_frac_4,sand_frac_5,sand_frac_6 \
+            start="2001-03-01 00:00:00" increment="1 months"
+tr.list input=sand_frac_abs_2 columns=name,start_time,end_time
+# Start the @test
+t.vect.what.strds --v input=soil_abs strds=sand_frac_abs_1 sampling=overlap,during,contain column=sand_frac
+v.db.select map=soils layer=1
+v.db.select map=soils layer=2
+v.db.select map=soils layer=3
+v.db.select map=soils layer=4
+v.db.select map=soils layer=5
+v.db.select map=soils layer=6
+t.vect.what.strds --v input=soil_abs strds=sand_frac_abs_2 sampling=equal
+# @postprocess
+t.unregister type=vect maps=soils:1,soils:2,soils:3,soils:4,soils:5,soils:6
+t.remove type=stvds input=soil_abs
+t.unregister type=rast maps=sand_frac,sand_frac_1,sand_frac_2,sand_frac_3,sand_frac_4,sand_frac_5,sand_frac_6
+t.remove type=strds input=sand_frac_abs_1,sand_frac_abs_2
+g.remove rast=sand_frac,sand_frac_1,sand_frac_2,sand_frac_3,sand_frac_4,sand_frac_5,sand_frac_6
+g.remove vect=soils,soil_orig
Copied: grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.sh (from rev 51251, grass/trunk/temporal/tv.what.strds/test.tv.what.strds.sh)
--- grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.sh	                        (rev 0)
+++ grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.sh	2012-04-04 12:41:47 UTC (rev 51256)
@@ -0,0 +1,52 @@
+r.mapcalc --o expr="prec_1 = 100.0"
+r.mapcalc --o expr="prec_2 = 200.0"
+r.mapcalc --o expr="prec_3 = 300"
+r.mapcalc --o expr="prec_4 = 400"
+r.mapcalc --o expr="prec_5 = 500.0"
+r.mapcalc --o expr="prec_6 = 600.0"
+v.random --o -z output=soil_1 n=5 zmin=0 zmax=100 column=heigh seed=1
+v.random --o -z output=soil_2 n=5 zmin=0 zmax=100 column=height seed=2
+v.random --o -z output=soil_3 n=5 zmin=0 zmax=100 column=height seed=3
+soil_1|2001-01-01|2001-04-01
+soil_2|2001-05-01|2001-07-01
+soil_3|2001-08-01|2001-12-01
+EOF
+t.create --o type=stvds temporaltype=absolute output=soil_abs1 title="A test" descr="A test"
+t.register type=vect input=soil_abs1 file="${n1}"
+t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
+t.register -i type=rast input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-03-01 00:00:00" increment="1 months"
+# The @test
+t.vect.what.strds --v input=soil_abs1 strds=precip_abs1 sampling=start,during column=map_vals
+v.db.select map=soil_1
+v.db.select map=soil_2
+v.db.select map=soil_3
+# @postprocess
+t.unregister type=vect maps=soil_1,soil_2,soil_3
+t.remove type=stvds input=soil_abs1
+t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+t.remove type=strds input=precip_abs1
+g.remove rast=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+g.remove vect=soil_1,soil_2,soil_3
Deleted: grass/trunk/temporal/t.vect.what.strds/test.tv.what.strds.layer.sh
--- grass/trunk/temporal/tv.what.strds/test.tv.what.strds.layer.sh	2012-04-04 09:39:32 UTC (rev 51251)
+++ grass/trunk/temporal/t.vect.what.strds/test.tv.what.strds.layer.sh	2012-04-04 12:41:47 UTC (rev 51256)
@@ -1,80 +0,0 @@
-# Test the temporal and spatial sampling of raster maps by vector point maps
-# using timetamped vector tables
-# We need to set a specific region in the
-# @preprocess step of this test.
-# The region setting should work for UTM and LL test locations
-g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
-# The raster maps
-r.mapcalc --o expr="sand_frac   = 50.0"
-r.mapcalc --o expr="sand_frac_1 = 25.0"
-r.mapcalc --o expr="sand_frac_2 = 35.0"
-r.mapcalc --o expr="sand_frac_3 = 45.0"
-r.mapcalc --o expr="sand_frac_4 = 55.0"
-r.mapcalc --o expr="sand_frac_5 = 65.0"
-r.mapcalc --o expr="sand_frac_6 = 75.0"
-# The vector map
-v.random --o -z seed=1 output=soil_orig n=100 zmin=0 zmax=100 column=sand
-# Adding new layer with categories
-v.category input=soil_orig out=soils option=transfer layer=1,2,3,4,5,6 --o
-# Creating new tables for each layer
-db.copy from_table=soil_orig to_table=soils_2
-db.copy from_table=soil_orig to_table=soils_3
-db.copy from_table=soil_orig to_table=soils_4
-db.copy from_table=soil_orig to_table=soils_5
-db.copy from_table=soil_orig to_table=soils_6
-v.db.addtable map=soils table=soils_2 layer=2
-v.db.addtable map=soils table=soils_3 layer=3
-v.db.addtable map=soils table=soils_4 layer=4
-v.db.addtable map=soils table=soils_5 layer=5
-v.db.addtable map=soils table=soils_6 layer=6
-n1=`g.tempfile pid=1 -d`
-cat > "${n1}" << EOF
-soils:1
-soils:2
-soils:3
-soils:4
-soils:5
-soils:6
-EOF
-t.create --o type=stvds temporaltype=absolute output=soil_abs title="A test" descr="A test"
-t.register -i type=vect input=soil_abs file="${n1}" start="2001-03-01 00:00:00" increment="1 months"
-tv.list input=soil_abs columns=name,layer,start_time,end_time
-t.create --o type=strds temporaltype=absolute output=sand_frac_abs_1 title="A test" descr="A test"
-t.register -i type=rast input=sand_frac_abs_1 maps=sand_frac start="2001-01-01 00:00:00" increment="12 months"
-tr.list input=sand_frac_abs_1 columns=name,start_time,end_time
-t.create --o type=strds temporaltype=absolute output=sand_frac_abs_2 title="A test" descr="A test"
-t.register -i type=rast input=sand_frac_abs_2 maps=sand_frac_1,sand_frac_2,sand_frac_3,sand_frac_4,sand_frac_5,sand_frac_6 \
-            start="2001-03-01 00:00:00" increment="1 months"
-tr.list input=sand_frac_abs_2 columns=name,start_time,end_time
-# Start the @test
-tv.what.strds --v input=soil_abs strds=sand_frac_abs_1 sampling=overlap,during,contain column=sand_frac
-v.db.select map=soils layer=1
-v.db.select map=soils layer=2
-v.db.select map=soils layer=3
-v.db.select map=soils layer=4
-v.db.select map=soils layer=5
-v.db.select map=soils layer=6
-tv.what.strds --v input=soil_abs strds=sand_frac_abs_2 sampling=equal
-# @postprocess
-t.unregister type=vect maps=soils:1,soils:2,soils:3,soils:4,soils:5,soils:6
-t.remove type=stvds input=soil_abs
-t.unregister type=rast maps=sand_frac,sand_frac_1,sand_frac_2,sand_frac_3,sand_frac_4,sand_frac_5,sand_frac_6
-t.remove type=strds input=sand_frac_abs_1,sand_frac_abs_2
-g.remove rast=sand_frac,sand_frac_1,sand_frac_2,sand_frac_3,sand_frac_4,sand_frac_5,sand_frac_6
-g.remove vect=soils,soil_orig
Deleted: grass/trunk/temporal/t.vect.what.strds/test.tv.what.strds.sh
--- grass/trunk/temporal/tv.what.strds/test.tv.what.strds.sh	2012-04-04 09:39:32 UTC (rev 51251)
+++ grass/trunk/temporal/t.vect.what.strds/test.tv.what.strds.sh	2012-04-04 12:41:47 UTC (rev 51256)
@@ -1,52 +0,0 @@
-r.mapcalc --o expr="prec_1 = 100.0"
-r.mapcalc --o expr="prec_2 = 200.0"
-r.mapcalc --o expr="prec_3 = 300"
-r.mapcalc --o expr="prec_4 = 400"
-r.mapcalc --o expr="prec_5 = 500.0"
-r.mapcalc --o expr="prec_6 = 600.0"
-v.random --o -z output=soil_1 n=5 zmin=0 zmax=100 column=heigh seed=1
-v.random --o -z output=soil_2 n=5 zmin=0 zmax=100 column=height seed=2
-v.random --o -z output=soil_3 n=5 zmin=0 zmax=100 column=height seed=3
-soil_1|2001-01-01|2001-04-01
-soil_2|2001-05-01|2001-07-01
-soil_3|2001-08-01|2001-12-01
-EOF
-t.create --o type=stvds temporaltype=absolute output=soil_abs1 title="A test" descr="A test"
-t.register type=vect input=soil_abs1 file="${n1}"
-t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
-t.register -i type=rast input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-03-01 00:00:00" increment="1 months"
-# The @test
-tv.what.strds --v input=soil_abs1 strds=precip_abs1 sampling=start,during column=map_vals
-v.db.select map=soil_1
-v.db.select map=soil_2
-v.db.select map=soil_3
-# @postprocess
-t.unregister type=vect maps=soil_1,soil_2,soil_3
-t.remove type=stvds input=soil_abs1
-t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
-t.remove type=strds input=precip_abs1
-g.remove rast=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
-g.remove vect=soil_1,soil_2,soil_3
Deleted: grass/trunk/temporal/t.vect.what.strds/tv.what.strds.html
Deleted: grass/trunk/temporal/t.vect.what.strds/tv.what.strds.py
--- grass/trunk/temporal/tv.what.strds/tv.what.strds.py	2012-04-04 09:39:32 UTC (rev 51251)
+++ grass/trunk/temporal/t.vect.what.strds/tv.what.strds.py	2012-04-04 12:41:47 UTC (rev 51256)
@@ -1,175 +0,0 @@
-#!/usr/bin/env python
-# -*- coding: utf-8 -*-
-# MODULE:	tv.what.strds
-# AUTHOR(S):	Soeren Gebbert
-# PURPOSE:	Uploads raster map values at spatial and temporal positions of vector points to the tables. The maps are registered in space time datasets
-# COPYRIGHT:	(C) 2011 by the GRASS Development Team
-#		This program is free software under the GNU General Public
-#		License (version 2). Read the file COPYING that comes with GRASS
-#		for details.
-#%module
-#% description: Uploads raster map values at spatial and temporal positions of vector points to the tables. The maps are registered in space time datasets
-#% keywords: temporal
-#% keywords: sampling
-#%end
-#%option G_OPT_STVDS_INPUT
-#%end
-#%option  G_OPT_STRDS_INPUT
-#% key: strds
-#%end
-#%option
-#% key: column
-#% type: string
-#% description: Name of the vector column to be created and to store sampled raster values. The use of a column name forces tv.what.rast to sample only values from the first map found in an interval. Otherwise the raster map names are used as column names.
-#% required: no
-#% multiple: no
-#%end
-#%option G_OPT_DB_WHERE
-#%end
-#%option G_OPT_T_WHERE
-#% key: t_where
-#%end
-#%option G_OPT_T_SAMPLE
-#%end
-import grass.script as grass
-import grass.temporal as tgis
-import grass.script.raster as raster
-def main():
-    # Get the options
-    input = options["input"]
-    strds = options["strds"]
-    where = options["where"]
-    column = options["column"]
-    tempwhere = options["t_where"]
-    sampling = options["sampling"]
-    if where == "" or where == " " or where == "\n":
-        where = None
-    # Make sure the temporal database exists
-    tgis.create_temporal_database()
-    # We need a database interface
-    dbif = tgis.sql_database_interface()
-    dbif.connect()
-    mapset =  grass.gisenv()["MAPSET"]
-    if input.find("@") >= 0:
-        id = input
-    else:
-        id = input + "@" + mapset
-    sp = tgis.space_time_vector_dataset(id)
-    if sp.is_in_db() == False:
-        dbif.close()
-        grass.fatal(_("Space time %s dataset <%s> not found") % (sp.get_new_map_instance(None).get_type(), id))
-    sp.select(dbif)
-    if strds.find("@") >= 0:
-        strds_id = strds
-    else:
-        strds_id = strds + "@" + mapset
-    strds_sp = tgis.space_time_raster_dataset(strds_id)
-    if strds_sp.is_in_db() == False:
-        dbif.close()
-        grass.fatal(_("Dataset <%s> not found in temporal database") % (id))
-    strds_sp.select(dbif)
-    if strds_sp.get_temporal_type() != sp.get_temporal_type():
-        dbif.close()
-        grass.fatal(_("Input and aggregation dataset must have the same temporal type"))
-    # Check if intervals are present
-    if sp.get_temporal_type() == "absolute":
-        map_time = strds_sp.absolute_time.get_map_time()
-    else:
-        map_time = strds_sp.relative_time.get_map_time()
-    if map_time != "interval":
-        dbif.close()
-        grass.fatal(_("All registered maps of the space time vector dataset must have time intervals"))
-    rows = sp.get_registered_maps("name,layer,mapset,start_time,end_time", tempwhere, "start_time", dbif)
-    dummy = tgis.vector_dataset(None)
-    if not rows:
-        dbif.close()
-        grass.fatal(_("Space time vector dataset <%s> is empty") % sp.get_id())
-    # Sample the raster dataset with the vector dataset and run v.what.rast
-    for row in rows:
-        start = row["start_time"]
-        end = row["end_time"]
-        vectmap = row["name"] + "@" + row["mapset"]
-        layer = row["layer"]
-        raster_maps = tgis.collect_map_names(strds_sp, dbif, start, end, sampling)
-        if raster_maps:
-            # Collect the names of the raster maps
-            for rastermap in raster_maps:
-                if column:
-                    col_name = column
-                else:
-                    # Create a new column with the SQL compliant name of the sampled raster map
-                    col_name = rastermap.split("@")[0].replace(".", "_")
-                coltype = "DOUBLE PRECISION"
-                # Get raster type
-                rasterinfo = raster.raster_info(rastermap)
-                if rasterinfo["datatype"] == "CELL":
-                    coltype = "INT"
-		if layer:
-		    ret = grass.run_command("v.db.addcolumn", map=vectmap, layer=layer, column="%s %s" % (col_name, coltype), overwrite=grass.overwrite())
-		else:
-		    ret = grass.run_command("v.db.addcolumn", map=vectmap, column="%s %s" % (col_name, coltype), overwrite=grass.overwrite())
-                if ret != 0:
-                    dbif.close()
-                    grass.fatal(_("Unable to add column %s to vector map <%s>")%(col_name, vectmap))
-                # Call v.what.rast
-                if layer:
-		    ret = grass.run_command("v.what.rast", map=vectmap, layer=layer, raster=rastermap, column=col_name, where=where)
-		else:
-		    ret = grass.run_command("v.what.rast", map=vectmap, raster=rastermap, column=col_name, where=where)
-                if ret != 0:
-                    dbif.close()
-                    grass.fatal(_("Unable to run v.what.rast for vector map <%s> and raster map <%s>")%(vectmap, rastermap))
-                # Use the first map in case a column names was provided
-                if column:
-                    break
-    dbif.close()
-if __name__ == "__main__":
-    options, flags = grass.parser()
-    main()
