[GRASS-SVN] r51271 - in grass/trunk/temporal: . t.rast.extract
svn_grass at osgeo.org
Thu Apr 5 16:52:23 EDT 2012
Author: huhabla
Date: 2012-04-05 13:52:23 -0700 (Thu, 05 Apr 2012)
New Revision: 51271
Added:
grass/trunk/temporal/t.rast.extract/
grass/trunk/temporal/t.rast.extract/t.rast.extract.html
grass/trunk/temporal/t.rast.extract/t.rast.extract.py
grass/trunk/temporal/t.rast.extract/test.t.rast.extract.sh
Removed:
grass/trunk/temporal/t.rast.extract/test.tr.extract.sh
grass/trunk/temporal/t.rast.extract/tr.extract.html
grass/trunk/temporal/t.rast.extract/tr.extract.py
grass/trunk/temporal/t.rast.extract/Makefile
Using new naming scheme
Modified: grass/trunk/temporal/t.rast.extract/Makefile
--- grass/trunk/temporal/tr.extract/Makefile 2012-04-04 21:20:55 UTC (rev 51264)
+++ grass/trunk/temporal/t.rast.extract/Makefile 2012-04-05 20:52:23 UTC (rev 51271)
@@ -1,6 +1,6 @@
MODULE_TOPDIR = ../../
-PGM = tr.extract
+PGM = t.rast.extract
include $(MODULE_TOPDIR)/include/Make/Script.make
Copied: grass/trunk/temporal/t.rast.extract/t.rast.extract.html (from rev 51264, grass/trunk/temporal/tr.extract/tr.extract.html)
Copied: grass/trunk/temporal/t.rast.extract/t.rast.extract.py (from rev 51264, grass/trunk/temporal/tr.extract/tr.extract.py)
--- grass/trunk/temporal/t.rast.extract/t.rast.extract.py (rev 0)
+++ grass/trunk/temporal/t.rast.extract/t.rast.extract.py 2012-04-05 20:52:23 UTC (rev 51271)
@@ -0,0 +1,233 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE: t.rast.extract
+# AUTHOR(S): Soeren Gebbert
+# PURPOSE: Extract a subset of a space time raster dataset
+# COPYRIGHT: (C) 2011 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (version 2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Extract a subset of a space time raster dataset
+#% keywords: temporal
+#% keywords: extract
+#%end
+#%option G_OPT_STRDS_INPUT
+#%end
+#%option G_OPT_T_WHERE
+#%end
+#%option
+#% key: expression
+#% type: string
+#% description: The r.mapcalc expression assigned to all extracted raster maps
+#% required: no
+#% multiple: no
+#%end
+#%option G_OPT_STRDS_OUTPUT
+#%end
+#%option G_OPT_R_BASE
+#%end
+#%option
+#% key: nprocs
+#% type: integer
+#% description: The number of r.mapcalc processes to run in parallel
+#% required: no
+#% multiple: no
+#% answer: 1
+#%end
+#%flag
+#% key: n
+#% description: Register Null maps
+#%end
+import grass.script as grass
+import grass.temporal as tgis
+from multiprocessing import Process
+def main():
+ # Get the options
+ input = options["input"]
+ output = options["output"]
+ where = options["where"]
+ expression = options["expression"]
+ base = options["base"]
+ nprocs = int(options["nprocs"])
+ register_null = flags["n"]
+ # Make sure the temporal database exists
+ tgis.create_temporal_database()
+ mapset = grass.gisenv()["MAPSET"]
+ if input.find("@") >= 0:
+ id = input
+ else:
+ id = input + "@" + mapset
+ sp = tgis.space_time_raster_dataset(id)
+ if sp.is_in_db() == False:
+ grass.fatal(_("Space time %s dataset <%s> not found") % (sp.get_new_map_instance(None).get_type(), id))
+ if expression and not base:
+ grass.fatal(_("Please specify base="))
+ dbif = tgis.sql_database_interface()
+ dbif.connect()
+ sp.select(dbif)
+ if output.find("@") >= 0:
+ out_id = output
+ else:
+ out_id = output + "@" + mapset
+ # The new space time raster dataset
+ new_sp = tgis.space_time_raster_dataset(out_id)
+ if new_sp.is_in_db():
+ if grass.overwrite() == False:
+ grass.fatal(_("Space time raster dataset <%s> is already in database, use overwrite flag to overwrite") % out_id)
+ rows = sp.get_registered_maps("id", where, "start_time", dbif)
+ new_maps = {}
+ if rows:
+ num_rows = len(rows)
+ grass.percent(0, num_rows, 1)
+ # Run the r.mapcalc expression
+ if expression:
+ count = 0
+ proc_count = 0
+ proc_list = []
+ for row in rows:
+ count += 1
+ grass.percent(count, num_rows, 1)
+ map_name = "%s_%i" % (base, count)
+ expr = "%s = %s" % (map_name, expression.replace(sp.get_id(), row["id"]))
+ expr = expr.replace(sp.base.get_name(), row["id"])
+ map_id = map_name + "@" + mapset
+ new_map = sp.get_new_map_instance(map_id)
+ # Check if new map is in the temporal database
+ if new_map.is_in_db(dbif):
+ if grass.overwrite() == True:
+ # Remove the existing temporal database entry
+ new_map.delete(dbif)
+ else:
+ grass.error(_("Raster map <%s> is already in temporal database, use overwrite flag to overwrite"))
+ continue
+ grass.verbose(_("Apply r.mapcalc expression: \"%s\"") % expr)
+ proc_list.append(Process(target=run_mapcalc, args=(expr,)))
+ proc_list[proc_count].start()
+ proc_count += 1
+ if proc_count == nprocs:
+ proc_count = 0
+ exitcodes = 0
+ for proc in proc_list:
+ proc.join()
+ exitcodes += proc.exitcode
+ if exitcodes != 0:
+ grass.fatal(_("Error while r.mapcalc computation"))
+ # Empty proc list
+ proc_list = []
+ new_maps[row["id"]] = new_map
+ # Insert the new space time raster dataset
+ new_sp.delete(dbif)
+ temporal_type, semantic_type, title, description = sp.get_initial_values()
+ new_sp.set_initial_values(temporal_type, semantic_type, title, description)
+ new_sp.insert(dbif)
+ # Register the maps in the database
+ count = 0
+ for row in rows:
+ count += 1
+ old_map = sp.get_new_map_instance(row["id"])
+ old_map.select(dbif)
+ if expression:
+ if new_maps.has_key(row["id"]):
+ new_map = new_maps[row["id"]]
+ # Read the raster map data
+ new_map.load()
+ # In case of a null map continue, do not register null maps
+ if new_map.metadata.get_min() == None and new_map.metadata.get_max() == None:
+ if not register_null:
+ continue
+ # Set the time stamp
+ if old_map.is_time_absolute():
+ start, end, tz = old_map.get_absolute_time()
+ new_map.set_absolute_time(start, end, tz)
+ else:
+ start, end = old_map.get_relative_time()
+ new_map.set_relative_time(start, end)
+ # Insert map in temporal database
+ new_map.insert(dbif)
+ new_sp.register_map(new_map, dbif)
+ else:
+ new_sp.register_map(old_map, dbif)
+ # Update the spatio-temporal extent and the raster metadata table entries
+ new_sp.update_from_registered_maps(dbif)
+ grass.percent(num_rows, num_rows, 1)
+ dbif.close()
+def run_mapcalc(expr):
+ """Helper function to run r.mapcalc in parallel"""
+ return grass.run_command("r.mapcalc", expression=expr, overwrite=grass.overwrite(), quiet=True)
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
Copied: grass/trunk/temporal/t.rast.extract/test.t.rast.extract.sh (from rev 51264, grass/trunk/temporal/tr.extract/test.tr.extract.sh)
--- grass/trunk/temporal/t.rast.extract/test.t.rast.extract.sh (rev 0)
+++ grass/trunk/temporal/t.rast.extract/test.t.rast.extract.sh 2012-04-05 20:52:23 UTC (rev 51271)
@@ -0,0 +1,32 @@
+# Test the extraction of a subset of a space time raster input
+# We need to set a specific region in the
+# @preprocess step of this test. We generate
+# raster with r.mapcalc and create two space time raster inputs
+# with relative and absolute time
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
+r.mapcalc --o expr="prec_1 = rand(0, 550)"
+r.mapcalc --o expr="prec_2 = rand(0, 450)"
+r.mapcalc --o expr="prec_3 = rand(0, 320)"
+r.mapcalc --o expr="prec_4 = rand(0, 510)"
+r.mapcalc --o expr="prec_5 = rand(0, 300)"
+r.mapcalc --o expr="prec_6 = rand(0, 650)"
+t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
+t.register -i type=rast input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="3 months"
+# The first @test
+# We create the space time raster inputs and register the raster maps with absolute time interval
+t.rast.extract --o --v input=precip_abs1 output=precip_abs2 where="start_time > '2001-06-01'" \
+ expression=" if(precip_abs1 > 400, precip_abs1, null())" base=new_prec nprocs=2
+t.info type=strds input=precip_abs2
+t.rast.extract --o --v -n input=precip_abs1 output=precip_abs3 where="start_time > '2001-06-01'" \
+ expression=" if(precip_abs1 > 400, precip_abs1, null())" base=new_prec nprocs=4
+t.info type=strds input=precip_abs3
+t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+t.remove type=strds input=precip_abs1,precip_abs2,precip_abs3
Deleted: grass/trunk/temporal/t.rast.extract/test.tr.extract.sh
--- grass/trunk/temporal/tr.extract/test.tr.extract.sh 2012-04-04 21:20:55 UTC (rev 51264)
+++ grass/trunk/temporal/t.rast.extract/test.tr.extract.sh 2012-04-05 20:52:23 UTC (rev 51271)
@@ -1,32 +0,0 @@
-# Test the extraction of a subset of a space time raster input
-# We need to set a specific region in the
-# @preprocess step of this test. We generate
-# raster with r.mapcalc and create two space time raster inputs
-# with relative and absolute time
-# The region setting should work for UTM and LL test locations
-g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
-r.mapcalc --o expr="prec_1 = rand(0, 550)"
-r.mapcalc --o expr="prec_2 = rand(0, 450)"
-r.mapcalc --o expr="prec_3 = rand(0, 320)"
-r.mapcalc --o expr="prec_4 = rand(0, 510)"
-r.mapcalc --o expr="prec_5 = rand(0, 300)"
-r.mapcalc --o expr="prec_6 = rand(0, 650)"
-t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
-t.register -i type=rast input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="3 months"
-# The first @test
-# We create the space time raster inputs and register the raster maps with absolute time interval
-tr.extract --o --v input=precip_abs1 output=precip_abs2 where="start_time > '2001-06-01'" \
- expression=" if(precip_abs1 > 400, precip_abs1, null())" base=new_prec nprocs=2
-t.info type=strds input=precip_abs2
-tr.extract --o --v -n input=precip_abs1 output=precip_abs3 where="start_time > '2001-06-01'" \
- expression=" if(precip_abs1 > 400, precip_abs1, null())" base=new_prec nprocs=4
-t.info type=strds input=precip_abs3
-t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
-t.remove type=strds input=precip_abs1,precip_abs2,precip_abs3
Deleted: grass/trunk/temporal/t.rast.extract/tr.extract.html
Deleted: grass/trunk/temporal/t.rast.extract/tr.extract.py
--- grass/trunk/temporal/tr.extract/tr.extract.py 2012-04-04 21:20:55 UTC (rev 51264)
+++ grass/trunk/temporal/t.rast.extract/tr.extract.py 2012-04-05 20:52:23 UTC (rev 51271)
@@ -1,233 +0,0 @@
-#!/usr/bin/env python
-# -*- coding: utf-8 -*-
-# MODULE: tr.extract
-# AUTHOR(S): Soeren Gebbert
-# PURPOSE: Extract a subset of a space time raster dataset
-# COPYRIGHT: (C) 2011 by the GRASS Development Team
-# This program is free software under the GNU General Public
-# License (version 2). Read the file COPYING that comes with GRASS
-# for details.
-#%module
-#% description: Extract a subset of a space time raster dataset
-#% keywords: temporal
-#% keywords: extract
-#%end
-#%option G_OPT_STRDS_INPUT
-#%end
-#%option G_OPT_T_WHERE
-#%end
-#%option
-#% key: expression
-#% type: string
-#% description: The r.mapcalc expression assigned to all extracted raster maps
-#% required: no
-#% multiple: no
-#%end
-#%option G_OPT_STRDS_OUTPUT
-#%end
-#%option G_OPT_R_BASE
-#%end
-#%option
-#% key: nprocs
-#% type: integer
-#% description: The number of r.mapcalc processes to run in parallel
-#% required: no
-#% multiple: no
-#% answer: 1
-#%end
-#%flag
-#% key: n
-#% description: Register Null maps
-#%end
-import grass.script as grass
-import grass.temporal as tgis
-from multiprocessing import Process
-def main():
- # Get the options
- input = options["input"]
- output = options["output"]
- where = options["where"]
- expression = options["expression"]
- base = options["base"]
- nprocs = int(options["nprocs"])
- register_null = flags["n"]
- # Make sure the temporal database exists
- tgis.create_temporal_database()
- mapset = grass.gisenv()["MAPSET"]
- if input.find("@") >= 0:
- id = input
- else:
- id = input + "@" + mapset
- sp = tgis.space_time_raster_dataset(id)
- if sp.is_in_db() == False:
- grass.fatal(_("Space time %s dataset <%s> not found") % (sp.get_new_map_instance(None).get_type(), id))
- if expression and not base:
- grass.fatal(_("Please specify base="))
- dbif = tgis.sql_database_interface()
- dbif.connect()
- sp.select(dbif)
- if output.find("@") >= 0:
- out_id = output
- else:
- out_id = output + "@" + mapset
- # The new space time raster dataset
- new_sp = tgis.space_time_raster_dataset(out_id)
- if new_sp.is_in_db():
- if grass.overwrite() == False:
- grass.fatal(_("Space time raster dataset <%s> is already in database, use overwrite flag to overwrite") % out_id)
- rows = sp.get_registered_maps("id", where, "start_time", dbif)
- new_maps = {}
- if rows:
- num_rows = len(rows)
- grass.percent(0, num_rows, 1)
- # Run the r.mapcalc expression
- if expression:
- count = 0
- proc_count = 0
- proc_list = []
- for row in rows:
- count += 1
- grass.percent(count, num_rows, 1)
- map_name = "%s_%i" % (base, count)
- expr = "%s = %s" % (map_name, expression.replace(sp.get_id(), row["id"]))
- expr = expr.replace(sp.base.get_name(), row["id"])
- map_id = map_name + "@" + mapset
- new_map = sp.get_new_map_instance(map_id)
- # Check if new map is in the temporal database
- if new_map.is_in_db(dbif):
- if grass.overwrite() == True:
- # Remove the existing temporal database entry
- new_map.delete(dbif)
- else:
- grass.error(_("Raster map <%s> is already in temporal database, use overwrite flag to overwrite"))
- continue
- grass.verbose(_("Apply r.mapcalc expression: \"%s\"") % expr)
- proc_list.append(Process(target=run_mapcalc, args=(expr,)))
- proc_list[proc_count].start()
- proc_count += 1
- if proc_count == nprocs:
- proc_count = 0
- exitcodes = 0
- for proc in proc_list:
- proc.join()
- exitcodes += proc.exitcode
- if exitcodes != 0:
- grass.fatal(_("Error while r.mapcalc computation"))
- # Empty proc list
- proc_list = []
- new_maps[row["id"]] = new_map
- # Insert the new space time raster dataset
- new_sp.delete(dbif)
- temporal_type, semantic_type, title, description = sp.get_initial_values()
- new_sp.set_initial_values(temporal_type, semantic_type, title, description)
- new_sp.insert(dbif)
- # Register the maps in the database
- count = 0
- for row in rows:
- count += 1
- old_map = sp.get_new_map_instance(row["id"])
- old_map.select(dbif)
- if expression:
- if new_maps.has_key(row["id"]):
- new_map = new_maps[row["id"]]
- # Read the raster map data
- new_map.load()
- # In case of a null map continue, do not register null maps
- if new_map.metadata.get_min() == None and new_map.metadata.get_max() == None:
- if not register_null:
- continue
- # Set the time stamp
- if old_map.is_time_absolute():
- start, end, tz = old_map.get_absolute_time()
- new_map.set_absolute_time(start, end, tz)
- else:
- start, end = old_map.get_relative_time()
- new_map.set_relative_time(start, end)
- # Insert map in temporal database
- new_map.insert(dbif)
- new_sp.register_map(new_map, dbif)
- else:
- new_sp.register_map(old_map, dbif)
- # Update the spatio-temporal extent and the raster metadata table entries
- new_sp.update_from_registered_maps(dbif)
- grass.percent(num_rows, num_rows, 1)
- dbif.close()
-def run_mapcalc(expr):
- """Helper function to run r.mapcalc in parallel"""
- return grass.run_command("r.mapcalc", expression=expr, overwrite=grass.overwrite(), quiet=True)
-if __name__ == "__main__":
- options, flags = grass.parser()
- main()
