[GRASS-SVN] r51275 - in grass/trunk/temporal: . t.rast.mapcalc
Thu Apr 5 17:02:23 EDT 2012
Author: huhabla
Date: 2012-04-05 14:02:22 -0700 (Thu, 05 Apr 2012)
New Revision: 51275
Added:
   grass/trunk/temporal/t.rast.mapcalc/
   grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.html
   grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py
   grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.sh
Removed:
   grass/trunk/temporal/t.rast.mapcalc/test.tr.mapcalc.sh
   grass/trunk/temporal/t.rast.mapcalc/tr.mapcalc.html
   grass/trunk/temporal/t.rast.mapcalc/tr.mapcalc.py
   grass/trunk/temporal/t.rast.mapcalc/Makefile
Using new naming scheme
Modified: grass/trunk/temporal/t.rast.mapcalc/Makefile
--- grass/trunk/temporal/tr.mapcalc/Makefile	2012-04-04 21:20:55 UTC (rev 51264)
+++ grass/trunk/temporal/t.rast.mapcalc/Makefile	2012-04-05 21:02:22 UTC (rev 51275)
@@ -1,6 +1,6 @@
 MODULE_TOPDIR = ../../
-PGM = tr.mapcalc
+PGM = t.rast.mapcalc
 include $(MODULE_TOPDIR)/include/Make/Script.make
Copied: grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.html (from rev 51264, grass/trunk/temporal/tr.mapcalc/tr.mapcalc.html)
Copied: grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py (from rev 51264, grass/trunk/temporal/tr.mapcalc/tr.mapcalc.py)
--- grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py	                        (rev 0)
+++ grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py	2012-04-05 21:02:22 UTC (rev 51275)
@@ -0,0 +1,362 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE:	t.rast.mapcalc
+# AUTHOR(S):	Soeren Gebbert
+# PURPOSE:	Perform r.mapcalc expressions on maps of sampled space time raster datasets
+# COPYRIGHT:	(C) 2012 by the GRASS Development Team
+#		This program is free software under the GNU General Public
+#		License (version 2). Read the file COPYING that comes with GRASS
+#		for details.
+#%module
+#% description: Perform r.mapcalc expressions on maps of sampled space time raster datasets
+#% keywords: temporal
+#% keywords: mapcalc
+#%end
+#%option G_OPT_STRDS_INPUTS
+#%end
+#%option
+#% key: expression
+#% type: string
+#% description: The r.mapcalc expression applied to each time step of the sampled data
+#% required: yes
+#% multiple: no
+#%end
+#%option G_OPT_T_SAMPLE
+#% key: method
+#% answer: during,overlap,contain,equal
+#%end
+#%option G_OPT_STRDS_OUTPUT
+#%end
+#%option G_OPT_R_BASE
+#% required: yes
+#%end
+#%option
+#% key: nprocs
+#% type: integer
+#% description: The number of r.mapcalc processes to run in parallel
+#% required: no
+#% multiple: no
+#% answer: 1
+#%end
+#%flag
+#% key: n
+#% description: Register Null maps
+#%end
+#%flag
+#% key: s
+#% description: Check spatial overlap
+#%end
+from multiprocessing import Process
+import copy
+import grass.script as grass
+import grass.temporal as tgis
+def main():
+    # Get the options
+    inputs = options["inputs"]
+    output = options["output"]
+    expression = options["expression"]
+    base = options["base"]
+    method = options["method"]
+    nprocs = int(options["nprocs"])
+    register_null = flags["n"]
+    spatial = flags["s"]
+    # Create the method list
+    method = method.split(",")
+    # Make sure the temporal database exists
+    tgis.create_temporal_database()
+    # We need a database interface for fast computation
+    dbif = tgis.sql_database_interface()
+    dbif.connect()
+    mapset =  grass.gisenv()["MAPSET"]
+    input_name_list = inputs.split(",")
+    # Process the first input
+    if input_name_list[0].find("@") >= 0:
+	id = input_name_list[0]
+    else:
+	id = input_name_list[0] + "@" + mapset
+    first_input = tgis.space_time_raster_dataset(id)
+    if first_input.is_in_db(dbif) == False:
+	dbif.close()
+        grass.fatal(_("Space time %s dataset <%s> not found") % (sp.get_new_map_instance(None).get_type(), id))
+    # Fill the object with data from the temporal database
+    first_input.select(dbif)
+    # All additional inputs in reverse sorted order to avoid wrong name substitution
+    input_name_list = input_name_list[1:]
+    input_name_list.sort()
+    input_name_list.reverse()
+    input_list = []
+    for input in input_name_list:
+	if input.find("@") >= 0:
+	    id = input
+	else:
+	    id = input + "@" + mapset
+	sp = tgis.space_time_raster_dataset(id)
+	if sp.is_in_db(dbif) == False:
+	    dbif.close()
+	    grass.fatal(_("Space time raster dataset <%s> not found in temporal database") % (id))
+	sp.select(dbif)
+	input_list.append(copy.copy(sp))
+    # Create the new space time raster dataset
+    if output.find("@") >= 0:
+        out_id = output
+    else:
+        out_id = output + "@" + mapset
+    new_sp = tgis.space_time_raster_dataset(out_id)
+    # Check if in database
+    if new_sp.is_in_db(dbif):
+        if grass.overwrite() == False:
+	    dbif.close()
+            grass.fatal(_("Space time raster dataset <%s> is already in database, use overwrite flag to overwrite") % out_id)
+    # Sample all inputs by the first input and create a sample matrix
+    if spatial:
+        grass.message(_("Start spatio-temporal sampling"))
+    else:
+        grass.message(_("Start temporal sampling"))
+    map_matrix = []
+    id_list = []
+    sample_map_list = []
+    # First entry is the first dataset id
+    id_list.append(first_input.get_name())
+    if len(input_list) > 0:
+	has_samples = False
+	for dataset in input_list:
+	    list = dataset.sample_by_dataset(stds=first_input, method=method, spatial=spatial, dbif=dbif)
+	    # In case samples are not found
+	    if not list and len(list) == 0:
+		dbif.close()
+		grass.message(_("No samples found for map calculation"))
+		return 0
+	    # The fist entries are the samples
+	    map_name_list = []
+	    if has_samples == False:
+		for entry in list:
+		    granule = entry["granule"]
+		    # Do not consider gaps
+		    if granule.get_id() == None:
+			continue
+		    sample_map_list.append(granule)
+		    map_name_list.append(granule.get_name())
+		# Attach the map names
+		map_matrix.append(copy.copy(map_name_list))
+		has_samples = True
+		maplist = entry["samples"]
+		# Do not consider gaps in the sampler
+		    continue
+		if len(maplist) > 1:
+		    grass.warning(_("Found more than a single map in a sample granule. "\
+		    "Only the first map is used for computation. "\
+		    "Use t.rast.aggregate.ds to create synchronous datasets."))
+		# Store all maps! This includes non existent maps, identified by id == None
+		map_name_list.append(maplist[0].get_name())
+	    id_list.append(dataset.get_name())
+    else:
+	list = first_input.get_registered_maps_as_objects(dbif=dbif)
+	if list == None:
+	    dbif.close()
+            grass.message(_("No maps in input dataset"))
+            return 0
+	for map in list:
+	    map_name_list.append(map.get_name())
+	    sample_map_list.append(map)
+    # Needed for map registration
+    map_list = []
+    if len(map_matrix) > 0:
+	grass.message(_("Start r.mapcalc computation"))
+	count = 0
+	# Get the number of samples
+	num = len(map_matrix[0])
+	# Parallel processing
+        proc_list = []
+        proc_count = 0
+	# For all samples
+        for i in range(num):
+            count += 1
+	    grass.percent(count, num, 1)
+	    # Create the r.mapcalc statement for the current time step
+	    map_name = "%s_%i" % (base, count)
+	    expr = "%s = %s" % (map_name, expression)
+            # Check that all maps are in the sample
+            valid_maps = True
+            # Replace all dataset names with their map names of the current time step
+            for j in range(len(map_matrix)):
+		if map_matrix[j][i] == None:
+		    valid_maps = False
+		    break
+		# Substitute the dataset name with the map name
+		expr = expr.replace(id_list[j], map_matrix[j][i])
+	    # Proceed with the next sample
+	    if valid_maps == False:
+		continue
+	    # Create the new map id and check if the map is already in the database
+	    map_id = map_name + "@" + mapset
+	    new_map = first_input.get_new_map_instance(map_id)
+	    # Check if new map is in the temporal database
+	    if new_map.is_in_db(dbif):
+		if grass.overwrite() == True:
+		    # Remove the existing temporal database entry
+		    new_map.delete(dbif)
+		else:
+		    grass.error(_("Raster map <%s> is already in temporal database, use overwrite flag to overwrite"))
+		    continue
+	    # Set the time stamp
+	    if sample_map_list[i].is_time_absolute():
+		start, end, tz = sample_map_list[i].get_absolute_time()
+		new_map.set_absolute_time(start, end, tz)
+	    else:
+		start, end = sample_map_list[i].get_relative_time()
+		new_map.set_relative_time(start, end)
+	    map_list.append(new_map)
+	    # Start the parallel r.mapcalc computation
+	    grass.verbose(_("Apply r.mapcalc expression: \"%s\"") % expr)
+	    proc_list.append(Process(target=run_mapcalc, args=(expr,)))
+	    proc_list[proc_count].start()
+	    proc_count += 1
+	    if proc_count == nprocs:
+		proc_count = 0
+		exitcodes = 0
+		for proc in proc_list:
+		    proc.join()
+		    exitcodes += proc.exitcode
+		if exitcodes != 0:
+		    dbif.close()
+		    grass.fatal(_("Error while r.mapcalc computation"))
+		# Empty process list
+		proc_list = []
+	# Register the new maps in the output space time dataset
+	grass.message(_("Start map registration in temporal database"))
+	# Overwrite an existing dataset if requested
+		new_sp.delete(dbif)
+	# Copy the ids from the first input
+	temporal_type, semantic_type, title, description = first_input.get_initial_values()
+	new_sp.set_initial_values(temporal_type, semantic_type, title, description)
+	# Insert the dataset in the temporal database
+	new_sp.insert(dbif)
+	count = 0
+	for new_map in map_list:
+            count += 1
+	    # Read the raster map data
+	    new_map.load()
+	    # In case of a null map continue, do not register null maps
+	    if new_map.metadata.get_min() == None and new_map.metadata.get_max() == None:
+		if not register_null:
+		    continue
+	    # Insert map in temporal database
+	    new_map.insert(dbif)
+	    new_sp.register_map(new_map, dbif)
+        # Update the spatio-temporal extent and the raster metadata table entries
+        new_sp.update_from_registered_maps(dbif)
+	grass.percent(1, 1, 1)
+    dbif.close()
+def run_mapcalc(expr):
+    """Helper function to run r.mapcalc in parallel"""
+    return grass.run_command("r.mapcalc", expression=expr, overwrite=grass.overwrite(), quiet=True)
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    main()
Copied: grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.sh (from rev 51264, grass/trunk/temporal/tr.mapcalc/test.tr.mapcalc.sh)
--- grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.sh	                        (rev 0)
+++ grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.sh	2012-04-05 21:02:22 UTC (rev 51275)
@@ -0,0 +1,37 @@
+# Test for t.rast.mapcalc
+# We need to set a specific region in the
+# @preprocess step of this test. We generate
+# raster with r.mapcalc and create several space time raster datasets
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
+r.mapcalc --o expr="prec_1 = rand(0, 550)"
+r.mapcalc --o expr="prec_2 = rand(0, 450)"
+r.mapcalc --o expr="prec_3 = rand(0, 320)"
+r.mapcalc --o expr="prec_4 = rand(0, 510)"
+r.mapcalc --o expr="prec_5 = rand(0, 300)"
+r.mapcalc --o expr="prec_6 = rand(0, 650)"
+t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
+t.create --o type=strds temporaltype=absolute output=precip_abs2 title="A test" descr="A test"
+t.register -i type=rast input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="3 months"
+t.register type=rast input=precip_abs2 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+t.info precip_abs1
+t.info precip_abs2
+# The first @test
+t.rast.mapcalc --o --v -n inputs=precip_abs1,precip_abs2 output=precip_abs3 \
+           expression=" precip_abs1 + precip_abs2" base=new_prec \
+           method=equal nprocs=6
+t.info type=strds input=precip_abs3
+t.rast.mapcalc --o --v -s inputs=precip_abs1,precip_abs2,precip_abs3 output=precip_abs4 \
+           expression=" (precip_abs1 + precip_abs2) / precip_abs3 at PERMANENT " base=new_prec \
+t.info type=strds input=precip_abs4
+t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+t.unregister type=rast maps=new_prec_1,new_prec_2,new_prec_3,new_prec_4,new_prec_5,new_prec_6
+t.remove type=strds input=precip_abs1,precip_abs2,precip_abs3,precip_abs4
Deleted: grass/trunk/temporal/t.rast.mapcalc/test.tr.mapcalc.sh
--- grass/trunk/temporal/tr.mapcalc/test.tr.mapcalc.sh	2012-04-04 21:20:55 UTC (rev 51264)
+++ grass/trunk/temporal/t.rast.mapcalc/test.tr.mapcalc.sh	2012-04-05 21:02:22 UTC (rev 51275)
@@ -1,38 +0,0 @@
-# Test for tr.mapcalc
-# We need to set a specific region in the
-# @preprocess step of this test. We generate
-# raster with r.mapcalc and create several space time raster inputs
-# with relative and absolute time
-# The region setting should work for UTM and LL test locations
-g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
-r.mapcalc --o expr="prec_1 = rand(0, 550)"
-r.mapcalc --o expr="prec_2 = rand(0, 450)"
-r.mapcalc --o expr="prec_3 = rand(0, 320)"
-r.mapcalc --o expr="prec_4 = rand(0, 510)"
-r.mapcalc --o expr="prec_5 = rand(0, 300)"
-r.mapcalc --o expr="prec_6 = rand(0, 650)"
-t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
-t.create --o type=strds temporaltype=absolute output=precip_abs2 title="A test" descr="A test"
-t.register -i type=rast input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="3 months"
-t.register type=rast input=precip_abs2 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
-t.info precip_abs1
-t.info precip_abs2
-# The first @test
-tr.mapcalc --o --v -n inputs=precip_abs1,precip_abs2 output=precip_abs3 \
-           expression=" precip_abs1 + precip_abs2" base=new_prec \
-           method=equal nprocs=6
-t.info type=strds input=precip_abs3
-tr.mapcalc --o --v -s inputs=precip_abs1,precip_abs2,precip_abs3 output=precip_abs4 \
-           expression=" (precip_abs1 + precip_abs2) / precip_abs3 at PERMANENT " base=new_prec \
-t.info type=strds input=precip_abs4
-t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
-t.unregister type=rast maps=new_prec_1,new_prec_2,new_prec_3,new_prec_4,new_prec_5,new_prec_6
-t.remove type=strds input=precip_abs1,precip_abs2,precip_abs3,precip_abs4
Deleted: grass/trunk/temporal/t.rast.mapcalc/tr.mapcalc.html
Deleted: grass/trunk/temporal/t.rast.mapcalc/tr.mapcalc.py
--- grass/trunk/temporal/tr.mapcalc/tr.mapcalc.py	2012-04-04 21:20:55 UTC (rev 51264)
+++ grass/trunk/temporal/t.rast.mapcalc/tr.mapcalc.py	2012-04-05 21:02:22 UTC (rev 51275)
@@ -1,362 +0,0 @@
-#!/usr/bin/env python
-# -*- coding: utf-8 -*-
-# MODULE:	tr.mapcalc
-# AUTHOR(S):	Soeren Gebbert
-# PURPOSE:	Perform r.mapcalc expressions on maps of sampled space time raster datasets
-# COPYRIGHT:	(C) 2012 by the GRASS Development Team
-#		This program is free software under the GNU General Public
-#		License (version 2). Read the file COPYING that comes with GRASS
-#		for details.
-#%module
-#% description: Perform r.mapcalc expressions on maps of sampled space time raster datasets
-#% keywords: temporal
-#% keywords: mapcalc
-#%end
-#%option G_OPT_STRDS_INPUTS
-#%end
-#%option
-#% key: expression
-#% type: string
-#% description: The r.mapcalc expression applied to each time step of the sampled data
-#% required: yes
-#% multiple: no
-#%end
-#%option G_OPT_T_SAMPLE
-#% key: method
-#% answer: during,overlap,contain,equal
-#%end
-#%option G_OPT_STRDS_OUTPUT
-#%end
-#%option G_OPT_R_BASE
-#% required: yes
-#%end
-#%option
-#% key: nprocs
-#% type: integer
-#% description: The number of r.mapcalc processes to run in parallel
-#% required: no
-#% multiple: no
-#% answer: 1
-#%end
-#%flag
-#% key: n
-#% description: Register Null maps
-#%end
-#%flag
-#% key: s
-#% description: Check spatial overlap
-#%end
-from multiprocessing import Process
-import copy
-import grass.script as grass
-import grass.temporal as tgis
-def main():
-    # Get the options
-    inputs = options["inputs"]
-    output = options["output"]
-    expression = options["expression"]
-    base = options["base"]
-    method = options["method"]
-    nprocs = int(options["nprocs"])
-    register_null = flags["n"]
-    spatial = flags["s"]
-    # Create the method list
-    method = method.split(",")
-    # Make sure the temporal database exists
-    tgis.create_temporal_database()
-    # We need a database interface for fast computation
-    dbif = tgis.sql_database_interface()
-    dbif.connect()
-    mapset =  grass.gisenv()["MAPSET"]
-    input_name_list = inputs.split(",")
-    # Process the first input
-    if input_name_list[0].find("@") >= 0:
-	id = input_name_list[0]
-    else:
-	id = input_name_list[0] + "@" + mapset
-    first_input = tgis.space_time_raster_dataset(id)
-    if first_input.is_in_db(dbif) == False:
-	dbif.close()
-        grass.fatal(_("Space time %s dataset <%s> not found") % (sp.get_new_map_instance(None).get_type(), id))
-    # Fill the object with data from the temporal database
-    first_input.select(dbif)
-    # All additional inputs in reverse sorted order to avoid wrong name substitution
-    input_name_list = input_name_list[1:]
-    input_name_list.sort()
-    input_name_list.reverse()
-    input_list = []
-    for input in input_name_list:
-	if input.find("@") >= 0:
-	    id = input
-	else:
-	    id = input + "@" + mapset
-	sp = tgis.space_time_raster_dataset(id)
-	if sp.is_in_db(dbif) == False:
-	    dbif.close()
-	    grass.fatal(_("Space time raster dataset <%s> not found in temporal database") % (id))
-	sp.select(dbif)
-	input_list.append(copy.copy(sp))
-    # Create the new space time raster dataset
-    if output.find("@") >= 0:
-        out_id = output
-    else:
-        out_id = output + "@" + mapset
-    new_sp = tgis.space_time_raster_dataset(out_id)
-    # Check if in database
-    if new_sp.is_in_db(dbif):
-        if grass.overwrite() == False:
-	    dbif.close()
-            grass.fatal(_("Space time raster dataset <%s> is already in database, use overwrite flag to overwrite") % out_id)
-    # Sample all inputs by the first input and create a sample matrix
-    if spatial:
-        grass.message(_("Start spatio-temporal sampling"))
-    else:
-        grass.message(_("Start temporal sampling"))
-    map_matrix = []
-    id_list = []
-    sample_map_list = []
-    # First entry is the first dataset id
-    id_list.append(first_input.get_name())
-    if len(input_list) > 0:
-	has_samples = False
-	for dataset in input_list:
-	    list = dataset.sample_by_dataset(stds=first_input, method=method, spatial=spatial, dbif=dbif)
-	    # In case samples are not found
-	    if not list and len(list) == 0:
-		dbif.close()
-		grass.message(_("No samples found for map calculation"))
-		return 0
-	    # The fist entries are the samples
-	    map_name_list = []
-	    if has_samples == False:
-		for entry in list:
-		    granule = entry["granule"]
-		    # Do not consider gaps
-		    if granule.get_id() == None:
-			continue
-		    sample_map_list.append(granule)
-		    map_name_list.append(granule.get_name())
-		# Attach the map names
-		map_matrix.append(copy.copy(map_name_list))
-		has_samples = True
-		maplist = entry["samples"]
-		# Do not consider gaps in the sampler
-		    continue
-		if len(maplist) > 1:
-		    grass.warning(_("Found more than a single map in a sample granule. "\
-		    "Only the first map is used for computation. "\
-		    "Use tr.aggregate.ds to create synchronous datasets."))
-		# Store all maps! This includes non existent maps, identified by id == None
-		map_name_list.append(maplist[0].get_name())
-	    id_list.append(dataset.get_name())
-    else:
-	list = first_input.get_registered_maps_as_objects(dbif=dbif)
-	if list == None:
-	    dbif.close()
-            grass.message(_("No maps in input dataset"))
-            return 0
-	for map in list:
-	    map_name_list.append(map.get_name())
-	    sample_map_list.append(map)
-    # Needed for map registration
-    map_list = []
-    if len(map_matrix) > 0:
-	grass.message(_("Start r.mapcalc computation"))
-	count = 0
-	# Get the number of samples
-	num = len(map_matrix[0])
-	# Parallel processing
-        proc_list = []
-        proc_count = 0
-	# For all samples
-        for i in range(num):
-            count += 1
-	    grass.percent(count, num, 1)
-	    # Create the r.mapcalc statement for the current time step
-	    map_name = "%s_%i" % (base, count)
-	    expr = "%s = %s" % (map_name, expression)
-            # Check that all maps are in the sample
-            valid_maps = True
-            # Replace all dataset names with their map names of the current time step
-            for j in range(len(map_matrix)):
-		if map_matrix[j][i] == None:
-		    valid_maps = False
-		    break
-		# Substitute the dataset name with the map name
-		expr = expr.replace(id_list[j], map_matrix[j][i])
-	    # Proceed with the next sample
-	    if valid_maps == False:
-		continue
-	    # Create the new map id and check if the map is already in the database
-	    map_id = map_name + "@" + mapset
-	    new_map = first_input.get_new_map_instance(map_id)
-	    # Check if new map is in the temporal database
-	    if new_map.is_in_db(dbif):
-		if grass.overwrite() == True:
-		    # Remove the existing temporal database entry
-		    new_map.delete(dbif)
-		else:
-		    grass.error(_("Raster map <%s> is already in temporal database, use overwrite flag to overwrite"))
-		    continue
-	    # Set the time stamp
-	    if sample_map_list[i].is_time_absolute():
-		start, end, tz = sample_map_list[i].get_absolute_time()
-		new_map.set_absolute_time(start, end, tz)
-	    else:
-		start, end = sample_map_list[i].get_relative_time()
-		new_map.set_relative_time(start, end)
-	    map_list.append(new_map)
-	    # Start the parallel r.mapcalc computation
-	    grass.verbose(_("Apply r.mapcalc expression: \"%s\"") % expr)
-	    proc_list.append(Process(target=run_mapcalc, args=(expr,)))
-	    proc_list[proc_count].start()
-	    proc_count += 1
-	    if proc_count == nprocs:
-		proc_count = 0
-		exitcodes = 0
-		for proc in proc_list:
-		    proc.join()
-		    exitcodes += proc.exitcode
-		if exitcodes != 0:
-		    dbif.close()
-		    grass.fatal(_("Error while r.mapcalc computation"))
-		# Empty process list
-		proc_list = []
-	# Register the new maps in the output space time dataset
-	grass.message(_("Start map registration in temporal database"))
-	# Overwrite an existing dataset if requested
-		new_sp.delete(dbif)
-	# Copy the ids from the first input
-	temporal_type, semantic_type, title, description = first_input.get_initial_values()
-	new_sp.set_initial_values(temporal_type, semantic_type, title, description)
-	# Insert the dataset in the temporal database
-	new_sp.insert(dbif)
-	count = 0
-	for new_map in map_list:
-            count += 1
-	    # Read the raster map data
-	    new_map.load()
-	    # In case of a null map continue, do not register null maps
-	    if new_map.metadata.get_min() == None and new_map.metadata.get_max() == None:
-		if not register_null:
-		    continue
-	    # Insert map in temporal database
-	    new_map.insert(dbif)
-	    new_sp.register_map(new_map, dbif)
-        # Update the spatio-temporal extent and the raster metadata table entries
-        new_sp.update_from_registered_maps(dbif)
-	grass.percent(1, 1, 1)
-    dbif.close()
-def run_mapcalc(expr):
-    """Helper function to run r.mapcalc in parallel"""
-    return grass.run_command("r.mapcalc", expression=expr, overwrite=grass.overwrite(), quiet=True)
-if __name__ == "__main__":
-    options, flags = grass.parser()
-    main()
