[GRASS-SVN] r51283 - in grass/trunk/temporal: . t.rast.univar
    svn_grass at osgeo.org
    Thu Apr  5 17:23:44 EDT 2012
Author: huhabla
Date: 2012-04-05 14:23:44 -0700 (Thu, 05 Apr 2012)
New Revision: 51283
Added:
   grass/trunk/temporal/t.rast.univar/
   grass/trunk/temporal/t.rast.univar/t.rast.univar.html
   grass/trunk/temporal/t.rast.univar/t.rast.univar.py
   grass/trunk/temporal/t.rast.univar/test.t.rast.univar.sh
Removed:
   grass/trunk/temporal/t.rast.univar/test.tr.univar.sh
   grass/trunk/temporal/t.rast.univar/tr.univar.html
   grass/trunk/temporal/t.rast.univar/tr.univar.py
   grass/trunk/temporal/t.rast.univar/Makefile
Using new naming scheme
Modified: grass/trunk/temporal/t.rast.univar/Makefile
--- grass/trunk/temporal/tr.univar/Makefile	2012-04-04 21:20:55 UTC (rev 51264)
+++ grass/trunk/temporal/t.rast.univar/Makefile	2012-04-05 21:23:44 UTC (rev 51283)
@@ -1,6 +1,6 @@
 MODULE_TOPDIR = ../../
-PGM = tr.univar
+PGM = t.rast.univar
 include $(MODULE_TOPDIR)/include/Make/Script.make
Copied: grass/trunk/temporal/t.rast.univar/t.rast.univar.html (from rev 51264, grass/trunk/temporal/tr.univar/tr.univar.html)
Copied: grass/trunk/temporal/t.rast.univar/t.rast.univar.py (from rev 51264, grass/trunk/temporal/tr.univar/tr.univar.py)
--- grass/trunk/temporal/t.rast.univar/t.rast.univar.py	                        (rev 0)
+++ grass/trunk/temporal/t.rast.univar/t.rast.univar.py	2012-04-05 21:23:44 UTC (rev 51283)
@@ -0,0 +1,125 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE:	t.rast.univar
+# AUTHOR(S):	Soeren Gebbert
+# PURPOSE:	Calculates univariate statistics from the non-null cells for each registered raster map of a space time raster dataset
+# COPYRIGHT:	(C) 2011 by the GRASS Development Team
+#		This program is free software under the GNU General Public
+#		License (version 2). Read the file COPYING that comes with GRASS
+#		for details.
+#%module
+#% description: Calculates univariate statistics from the non-null cells for each registered raster map of a space time raster dataset
+#% keywords: spacetime raster dataset
+#% keywords: raster
+#% keywords: statistics
+#%end
+#%option G_OPT_STRDS_INPUT
+#%end
+#%option G_OPT_T_WHERE
+#%end
+#%option
+#% key: fs
+#% type: string
+#% description: The field separator character between the output columns
+#% required: no
+#% answer: |
+#%end
+#%flag
+#% key: e
+#% description: Calculate extended statistics
+#%end
+#%flag
+#% key: h
+#% description: Print column names
+#%end
+import grass.script as grass
+import grass.temporal as tgis
+def main():
+    # Get the options
+    input = options["input"]
+    where = options["where"]
+    extended = flags["e"]
+    header = flags["h"]
+    fs = options["fs"]
+    # Make sure the temporal database exists
+    tgis.create_temporal_database()
+    # We need a database interface
+    dbif = tgis.sql_database_interface()
+    dbif.connect()
+    mapset =  grass.gisenv()["MAPSET"]
+    if input.find("@") >= 0:
+        id = input
+    else:
+        id = input + "@" + mapset
+    sp = tgis.space_time_raster_dataset(id)
+    if sp.is_in_db(dbif) == False:
+        dbif.close()
+        grass.fatal(_("Space time %s dataset <%s> not found") % (sp.get_new_map_instance(None).get_type(), id))
+    sp.select(dbif)
+    rows = sp.get_registered_maps("id,start_time,end_time", where, "start_time", dbif)
+    if not rows:
+            dbif.close()
+            grass.fatal(_("Space time raster dataset <%s> is empty") % out_id)
+    if header == True:
+        print "id" + fs + "start" + fs + "end" + fs + "mean" + fs + "min" + fs + "max" + fs,
+        print "mean_of_abs" + fs + "stddev" + fs + "variance" + fs,
+        if extended == True:
+            print "coeff_var" + fs + "sum" + fs + "null_cells" + fs + "cells" + fs,
+            print "first_quartile" + fs + "median" + fs + "third_quartile" + fs + "percentile_90"
+        else:
+    for row in rows:
+        id = row["id"]
+        start = row["start_time"]
+        end = row["end_time"]
+        flag="g"
+            flag += "e"
+        stats = grass.parse_command("r.univar", map=id, flags=flag)
+        print str(id) + fs + str(start) + fs + str(end),
+        print fs + str(stats["mean"]) + fs + str(stats["min"]) + fs + str(stats["max"]) + fs + str(stats["mean_of_abs"]),
+        print fs + str(stats["stddev"]) + fs + str(stats["variance"]) + fs + str(stats["coeff_var"]) + fs + str(stats["sum"]),
+            print fs + str(stats["null_cells"]) + fs + str(stats["cells"]) + fs,
+            print str(stats["first_quartile"]) + fs + str(stats["median"]) + fs + str(stats["third_quartile"]) + fs + str(stats["percentile_90"])
+        else:
+    dbif.close()
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    main()
Copied: grass/trunk/temporal/t.rast.univar/test.t.rast.univar.sh (from rev 51264, grass/trunk/temporal/tr.univar/test.tr.univar.sh)
--- grass/trunk/temporal/t.rast.univar/test.t.rast.univar.sh	                        (rev 0)
+++ grass/trunk/temporal/t.rast.univar/test.t.rast.univar.sh	2012-04-05 21:23:44 UTC (rev 51283)
@@ -0,0 +1,22 @@
+# Test the extraction of a subset of a space time raster input
+# We need to set a specific region in the
+# @preprocess step of this test.
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
+# Data generation
+r.mapcalc --o expr="prec_1 = rand(0, 550)"
+r.mapcalc --o expr="prec_2 = rand(0, 450)"
+r.mapcalc --o expr="prec_3 = rand(0, 320)"
+r.mapcalc --o expr="prec_4 = rand(0, 510)"
+r.mapcalc --o expr="prec_5 = rand(0, 300)"
+r.mapcalc --o expr="prec_6 = rand(0, 650)"
+t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
+t.register type=rast --v -i input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-15 12:05:45" increment="14 days"
+# The first @test
+t.rast.univar -he input=precip_abs1
+t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+t.remove type=strds input=precip_abs1
Deleted: grass/trunk/temporal/t.rast.univar/test.tr.univar.sh
--- grass/trunk/temporal/tr.univar/test.tr.univar.sh	2012-04-04 21:20:55 UTC (rev 51264)
+++ grass/trunk/temporal/t.rast.univar/test.tr.univar.sh	2012-04-05 21:23:44 UTC (rev 51283)
@@ -1,22 +0,0 @@
-# Test the extraction of a subset of a space time raster input
-# We need to set a specific region in the
-# @preprocess step of this test.
-# The region setting should work for UTM and LL test locations
-g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
-# Data generation
-r.mapcalc --o expr="prec_1 = rand(0, 550)"
-r.mapcalc --o expr="prec_2 = rand(0, 450)"
-r.mapcalc --o expr="prec_3 = rand(0, 320)"
-r.mapcalc --o expr="prec_4 = rand(0, 510)"
-r.mapcalc --o expr="prec_5 = rand(0, 300)"
-r.mapcalc --o expr="prec_6 = rand(0, 650)"
-t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
-t.register type=rast --v -i input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-15 12:05:45" increment="14 days"
-# The first @test
-tr.univar -he input=precip_abs1
-t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
-t.remove type=strds input=precip_abs1
Deleted: grass/trunk/temporal/t.rast.univar/tr.univar.html
Deleted: grass/trunk/temporal/t.rast.univar/tr.univar.py
--- grass/trunk/temporal/tr.univar/tr.univar.py	2012-04-04 21:20:55 UTC (rev 51264)
+++ grass/trunk/temporal/t.rast.univar/tr.univar.py	2012-04-05 21:23:44 UTC (rev 51283)
@@ -1,125 +0,0 @@
-#!/usr/bin/env python
-# -*- coding: utf-8 -*-
-# MODULE:	tr.univar
-# AUTHOR(S):	Soeren Gebbert
-# PURPOSE:	Calculates univariate statistics from the non-null cells for each registered raster map of a space time raster dataset
-# COPYRIGHT:	(C) 2011 by the GRASS Development Team
-#		This program is free software under the GNU General Public
-#		License (version 2). Read the file COPYING that comes with GRASS
-#		for details.
-#%module
-#% description: Calculates univariate statistics from the non-null cells for each registered raster map of a space time raster dataset
-#% keywords: spacetime raster dataset
-#% keywords: raster
-#% keywords: statistics
-#%end
-#%option G_OPT_STRDS_INPUT
-#%end
-#%option G_OPT_T_WHERE
-#%end
-#%option
-#% key: fs
-#% type: string
-#% description: The field separator character between the output columns
-#% required: no
-#% answer: |
-#%end
-#%flag
-#% key: e
-#% description: Calculate extended statistics
-#%end
-#%flag
-#% key: h
-#% description: Print column names
-#%end
-import grass.script as grass
-import grass.temporal as tgis
-def main():
-    # Get the options
-    input = options["input"]
-    where = options["where"]
-    extended = flags["e"]
-    header = flags["h"]
-    fs = options["fs"]
-    # Make sure the temporal database exists
-    tgis.create_temporal_database()
-    # We need a database interface
-    dbif = tgis.sql_database_interface()
-    dbif.connect()
-    mapset =  grass.gisenv()["MAPSET"]
-    if input.find("@") >= 0:
-        id = input
-    else:
-        id = input + "@" + mapset
-    sp = tgis.space_time_raster_dataset(id)
-    if sp.is_in_db(dbif) == False:
-        dbif.close()
-        grass.fatal(_("Space time %s dataset <%s> not found") % (sp.get_new_map_instance(None).get_type(), id))
-    sp.select(dbif)
-    rows = sp.get_registered_maps("id,start_time,end_time", where, "start_time", dbif)
-    if not rows:
-            dbif.close()
-            grass.fatal(_("Space time raster dataset <%s> is empty") % out_id)
-    if header == True:
-        print "id" + fs + "start" + fs + "end" + fs + "mean" + fs + "min" + fs + "max" + fs,
-        print "mean_of_abs" + fs + "stddev" + fs + "variance" + fs,
-        if extended == True:
-            print "coeff_var" + fs + "sum" + fs + "null_cells" + fs + "cells" + fs,
-            print "first_quartile" + fs + "median" + fs + "third_quartile" + fs + "percentile_90"
-        else:
-    for row in rows:
-        id = row["id"]
-        start = row["start_time"]
-        end = row["end_time"]
-        flag="g"
-            flag += "e"
-        stats = grass.parse_command("r.univar", map=id, flags=flag)
-        print str(id) + fs + str(start) + fs + str(end),
-        print fs + str(stats["mean"]) + fs + str(stats["min"]) + fs + str(stats["max"]) + fs + str(stats["mean_of_abs"]),
-        print fs + str(stats["stddev"]) + fs + str(stats["variance"]) + fs + str(stats["coeff_var"]) + fs + str(stats["sum"]),
-            print fs + str(stats["null_cells"]) + fs + str(stats["cells"]) + fs,
-            print str(stats["first_quartile"]) + fs + str(stats["median"]) + fs + str(stats["third_quartile"]) + fs + str(stats["percentile_90"])
-        else:
-    dbif.close()
-if __name__ == "__main__":
-    options, flags = grass.parser()
-    main()
