[GRASS-SVN] r51285 - in grass/trunk/temporal: . t.rast.aggregate.ds
Thu Apr 5 17:29:53 EDT 2012
Author: huhabla
Date: 2012-04-05 14:29:53 -0700 (Thu, 05 Apr 2012)
New Revision: 51285
Added:
   grass/trunk/temporal/t.rast.aggregate.ds/
   grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.html
   grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py
   grass/trunk/temporal/t.rast.aggregate.ds/test.t.rast.aggregate.ds.sh
Removed:
   grass/trunk/temporal/t.rast.aggregate.ds/test.tr.aggregate.ds.sh
   grass/trunk/temporal/t.rast.aggregate.ds/tr.aggregate.ds.html
   grass/trunk/temporal/t.rast.aggregate.ds/tr.aggregate.ds.py
   grass/trunk/temporal/t.rast.aggregate.ds/Makefile
Using new naming scheme
Modified: grass/trunk/temporal/t.rast.aggregate.ds/Makefile
--- grass/trunk/temporal/tr.aggregate.ds/Makefile	2012-04-04 21:20:55 UTC (rev 51264)
+++ grass/trunk/temporal/t.rast.aggregate.ds/Makefile	2012-04-05 21:29:53 UTC (rev 51285)
@@ -1,6 +1,6 @@
 MODULE_TOPDIR = ../../
-PGM = tr.aggregate.ds
+PGM = t.rast.aggregate.ds
 include $(MODULE_TOPDIR)/include/Make/Script.make
Copied: grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.html (from rev 51264, grass/trunk/temporal/tr.aggregate.ds/tr.aggregate.ds.html)
Copied: grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py (from rev 51264, grass/trunk/temporal/tr.aggregate.ds/tr.aggregate.ds.py)
--- grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py	                        (rev 0)
+++ grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py	2012-04-05 21:29:53 UTC (rev 51285)
@@ -0,0 +1,173 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE:	t.rast.aggregate.ds
+# AUTHOR(S):	Soeren Gebbert
+# PURPOSE:	Aggregated data of an existing space time raster dataset using the temporal topology of a second space time dataset
+# COPYRIGHT:	(C) 2011 by the GRASS Development Team
+#		This program is free software under the GNU General Public
+#		License (version 2). Read the file COPYING that comes with GRASS
+#		for details.
+#%module
+#% description: Aggregated data of an existing space time raster dataset using the temporal topology of a second space time dataset
+#% keywords: temporal
+#% keywords: aggregation
+#%end
+#%option G_OPT_STRDS_INPUT
+#%end
+#%option G_OPT_STDS_INPUT
+#% key: sample
+#% description: The time intervals from this space time dataset (raster, vector or raster3d) are used for aggregation computation.
+#%end
+#%option G_OPT_STDS_TYPE
+#% description: Type of the aggregation space time dataset, default is strds
+#%end
+#%option
+#% key: output
+#% type: string
+#% description: Name of the output space time raster dataset
+#% required: yes
+#% multiple: no
+#%end
+#%option
+#% key: method
+#% type: string
+#% description: Aggregate operation to be peformed on the raster maps
+#% required: yes
+#% multiple: no
+#% options: average,count,median,mode,minimum,min_raster,maximum,max_raster,stddev,range,sum,variance,diversity,slope,offset,detcoeff,quart1,quart3,perc90,quantile,skewness,kurtosis
+#% answer: average
+#%end
+#%option G_OPT_T_SAMPLE
+#%end
+#%option G_OPT_R_BASE
+#%end
+#%flag
+#% key: n
+#% description: Register Null maps
+#%end
+import grass.script as grass
+import grass.temporal as tgis
+def main():
+    # Get the options
+    input = options["input"]
+    output = options["output"]
+    sampler = options["sample"]
+    base = options["base"]
+    register_null = flags["n"]
+    method = options["method"]
+    type = options["type"]
+    sampling = options["sampling"]
+    # Make sure the temporal database exists
+    tgis.create_temporal_database()
+    # We need a database interface
+    dbif = tgis.sql_database_interface()
+    dbif.connect()
+    mapset =  grass.gisenv()["MAPSET"]
+    if input.find("@") >= 0:
+        id = input
+    else:
+        id = input + "@" + mapset
+    sp = tgis.space_time_raster_dataset(id)
+    if sp.is_in_db() == False:
+        dbif.close()
+        grass.fatal(_("Space time %s dataset <%s> not found") % (sp.get_new_map_instance(None).get_type(), id))
+    sp.select(dbif)
+    if sampler.find("@") >= 0:
+        sampler_id = sampler
+    else:
+        sampler_id = sampler + "@" + mapset
+    sampler_sp = tgis.dataset_factory(type, sampler_id)
+    if sampler_sp.is_in_db() == False:
+        dbif.close()
+        grass.fatal(_("Dataset <%s> not found in temporal database") % (id))
+    sampler_sp.select(dbif)
+    if sampler_sp.get_temporal_type() != sp.get_temporal_type():
+        dbif.close()
+        grass.fatal(_("Input and aggregation dataset must have the same temporal type"))
+    # Check if intervals are present
+    if sampler_sp.get_temporal_type() == "absolute":
+        map_time = sampler_sp.absolute_time.get_map_time()
+    else:
+        map_time = sampler_sp.relative_time.get_map_time()
+    if map_time != "interval":
+        dbif.close()
+        grass.fatal(_("All registered maps of the aggregation dataset must have time intervals"))
+    if output.find("@") >= 0:
+        out_id = output
+    else:
+        out_id = output + "@" + mapset
+    # The new space time raster dataset
+    new_sp = tgis.space_time_raster_dataset(out_id)
+    if new_sp.is_in_db(dbif):
+        if grass.overwrite() == True:
+            new_sp.delete(dbif)
+        else:
+            dbif.close()
+            grass.fatal(_("Space time raster dataset <%s> is already in database, use overwrite flag to overwrite") % out_id)
+    temporal_type, semantic_type, title, description = sp.get_initial_values()
+    new_sp.set_initial_values(temporal_type, semantic_type, title, description)
+    new_sp.insert(dbif)
+    rows = sampler_sp.get_registered_maps("id,start_time,end_time", None, "start_time", dbif)
+    if not rows:
+            dbif.close()
+            grass.fatal(_("Aggregation dataset <%s> is empty") % id)
+    count = 0
+    for row in rows:
+        count += 1
+        start = row["start_time"]
+        end = row["end_time"]
+        input_map_names = tgis.collect_map_names(sp, dbif, start, end, sampling)
+        if input_map_names:
+            tgis.aggregate_raster_maps(sp, new_sp, mapset, input_map_names, base, start, end, count, method, register_null, dbif)
+    # Update the spatio-temporal extent and the raster metadata table entries
+    new_sp.update_from_registered_maps(dbif)
+    dbif.close()
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    main()
Copied: grass/trunk/temporal/t.rast.aggregate.ds/test.t.rast.aggregate.ds.sh (from rev 51264, grass/trunk/temporal/tr.aggregate.ds/test.tr.aggregate.ds.sh)
--- grass/trunk/temporal/t.rast.aggregate.ds/test.t.rast.aggregate.ds.sh	                        (rev 0)
+++ grass/trunk/temporal/t.rast.aggregate.ds/test.t.rast.aggregate.ds.sh	2012-04-05 21:29:53 UTC (rev 51285)
@@ -0,0 +1,47 @@
+# Test the extraction of a subset of a space time raster input
+# We need to set a specific region in the
+# @preprocess step of this test. We generate
+# raster with r.mapcalc and create two space time raster inputs
+# with relative and absolute time
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
+r.mapcalc --o expr="prec_1 = 100"
+r.mapcalc --o expr="prec_2 = 150"
+r.mapcalc --o expr="prec_3 = 250"
+r.mapcalc --o expr="prec_4 = 250"
+r.mapcalc --o expr="prec_5 = 150"
+r.mapcalc --o expr="prec_6 = 100"
+v.random --o -z output=soil_1 n=20 zmin=0 zmax=100 column=height
+v.random --o -z output=soil_2 n=20 zmin=0 zmax=100 column=height
+v.random --o -z output=soil_3 n=20 zmin=0 zmax=100 column=height
+n1=`g.tempfile pid=1 -d`
+cat > "${n1}" << EOF
+soil_1|2001-01-01|2001-04-01
+soil_2|2001-05-01|2001-07-01
+soil_3|2001-08-01|2001-12-01
+EOF
+t.create --o type=stvds temporaltype=absolute output=soil_abs1 title="A test" descr="A test"
+t.register type=vect input=soil_abs1 file="${n1}"
+t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
+t.register -i type=rast input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-03-01 00:00:00" increment="1 months"
+# The @test
+t.rast.aggregate.ds --o --v input=precip_abs1 output=precip_abs2 base=prec_sum type=stvds sample=soil_abs1 method=sum sampling=start,during
+t.info type=strds input=precip_abs2
+t.rast.list input=precip_abs2 method=deltagap
+# @postprocess
+t.unregister type=vect maps=soil_1,soil_2,soil_3
+t.remove type=stvds input=soil_abs1
+t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+t.remove type=strds input=precip_abs1,precip_abs2
+g.remove vect=soil_1,soil_2,soil_3
Deleted: grass/trunk/temporal/t.rast.aggregate.ds/test.tr.aggregate.ds.sh
--- grass/trunk/temporal/tr.aggregate.ds/test.tr.aggregate.ds.sh	2012-04-04 21:20:55 UTC (rev 51264)
+++ grass/trunk/temporal/t.rast.aggregate.ds/test.tr.aggregate.ds.sh	2012-04-05 21:29:53 UTC (rev 51285)
@@ -1,46 +0,0 @@
-# Test the extraction of a subset of a space time raster input
-# We need to set a specific region in the
-# @preprocess step of this test. We generate
-# raster with r.mapcalc and create two space time raster inputs
-# with relative and absolute time
-# The region setting should work for UTM and LL test locations
-g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
-r.mapcalc --o expr="prec_1 = 100"
-r.mapcalc --o expr="prec_2 = 150"
-r.mapcalc --o expr="prec_3 = 250"
-r.mapcalc --o expr="prec_4 = 250"
-r.mapcalc --o expr="prec_5 = 150"
-r.mapcalc --o expr="prec_6 = 100"
-v.random --o -z output=soil_1 n=20 zmin=0 zmax=100 column=height
-v.random --o -z output=soil_2 n=20 zmin=0 zmax=100 column=height
-v.random --o -z output=soil_3 n=20 zmin=0 zmax=100 column=height
-n1=`g.tempfile pid=1 -d`
-cat > "${n1}" << EOF
-soil_1|2001-01-01|2001-04-01
-soil_2|2001-05-01|2001-07-01
-soil_3|2001-08-01|2001-12-01
-EOF
-t.create --o type=stvds temporaltype=absolute output=soil_abs1 title="A test" descr="A test"
-t.register type=vect input=soil_abs1 file="${n1}"
-t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
-t.register -i type=rast input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-03-01 00:00:00" increment="1 months"
-# The @test
-tr.aggregate.ds --o --v input=precip_abs1 output=precip_abs2 base=prec_sum type=stvds sample=soil_abs1 method=sum sampling=start,during
-t.info type=strds input=precip_abs2
-tr.list input=precip_abs2 method=deltagap
-# @postprocess
-t.unregister type=vect maps=soil_1,soil_2,soil_3
-t.remove type=stvds input=soil_abs1
-t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
-t.remove type=strds input=precip_abs1,precip_abs2
Deleted: grass/trunk/temporal/t.rast.aggregate.ds/tr.aggregate.ds.html
Deleted: grass/trunk/temporal/t.rast.aggregate.ds/tr.aggregate.ds.py
--- grass/trunk/temporal/tr.aggregate.ds/tr.aggregate.ds.py	2012-04-04 21:20:55 UTC (rev 51264)
+++ grass/trunk/temporal/t.rast.aggregate.ds/tr.aggregate.ds.py	2012-04-05 21:29:53 UTC (rev 51285)
@@ -1,173 +0,0 @@
-#!/usr/bin/env python
-# -*- coding: utf-8 -*-
-# MODULE:	tr.aggregate.ds
-# AUTHOR(S):	Soeren Gebbert
-# PURPOSE:	Aggregated data of an existing space time raster dataset using the temporal topology of a second space time dataset
-# COPYRIGHT:	(C) 2011 by the GRASS Development Team
-#		This program is free software under the GNU General Public
-#		License (version 2). Read the file COPYING that comes with GRASS
-#		for details.
-#%module
-#% description: Aggregated data of an existing space time raster dataset using the temporal topology of a second space time dataset
-#% keywords: temporal
-#% keywords: aggregation
-#%end
-#%option G_OPT_STRDS_INPUT
-#%end
-#%option G_OPT_STDS_INPUT
-#% key: sample
-#% description: The time intervals from this space time dataset (raster, vector or raster3d) are used for aggregation computation.
-#%end
-#%option G_OPT_STDS_TYPE
-#% description: Type of the aggregation space time dataset, default is strds
-#%end
-#%option
-#% key: output
-#% type: string
-#% description: Name of the output space time raster dataset
-#% required: yes
-#% multiple: no
-#%end
-#%option
-#% key: method
-#% type: string
-#% description: Aggregate operation to be peformed on the raster maps
-#% required: yes
-#% multiple: no
-#% options: average,count,median,mode,minimum,min_raster,maximum,max_raster,stddev,range,sum,variance,diversity,slope,offset,detcoeff,quart1,quart3,perc90,quantile,skewness,kurtosis
-#% answer: average
-#%end
-#%option G_OPT_T_SAMPLE
-#%end
-#%option G_OPT_R_BASE
-#%end
-#%flag
-#% key: n
-#% description: Register Null maps
-#%end
-import grass.script as grass
-import grass.temporal as tgis
-def main():
-    # Get the options
-    input = options["input"]
-    output = options["output"]
-    sampler = options["sample"]
-    base = options["base"]
-    register_null = flags["n"]
-    method = options["method"]
-    type = options["type"]
-    sampling = options["sampling"]
-    # Make sure the temporal database exists
-    tgis.create_temporal_database()
-    # We need a database interface
-    dbif = tgis.sql_database_interface()
-    dbif.connect()
-    mapset =  grass.gisenv()["MAPSET"]
-    if input.find("@") >= 0:
-        id = input
-    else:
-        id = input + "@" + mapset
-    sp = tgis.space_time_raster_dataset(id)
-    if sp.is_in_db() == False:
-        dbif.close()
-        grass.fatal(_("Space time %s dataset <%s> not found") % (sp.get_new_map_instance(None).get_type(), id))
-    sp.select(dbif)
-    if sampler.find("@") >= 0:
-        sampler_id = sampler
-    else:
-        sampler_id = sampler + "@" + mapset
-    sampler_sp = tgis.dataset_factory(type, sampler_id)
-    if sampler_sp.is_in_db() == False:
-        dbif.close()
-        grass.fatal(_("Dataset <%s> not found in temporal database") % (id))
-    sampler_sp.select(dbif)
-    if sampler_sp.get_temporal_type() != sp.get_temporal_type():
-        dbif.close()
-        grass.fatal(_("Input and aggregation dataset must have the same temporal type"))
-    # Check if intervals are present
-    if sampler_sp.get_temporal_type() == "absolute":
-        map_time = sampler_sp.absolute_time.get_map_time()
-    else:
-        map_time = sampler_sp.relative_time.get_map_time()
-    if map_time != "interval":
-        dbif.close()
-        grass.fatal(_("All registered maps of the aggregation dataset must have time intervals"))
-    if output.find("@") >= 0:
-        out_id = output
-    else:
-        out_id = output + "@" + mapset
-    # The new space time raster dataset
-    new_sp = tgis.space_time_raster_dataset(out_id)
-    if new_sp.is_in_db(dbif):
-        if grass.overwrite() == True:
-            new_sp.delete(dbif)
-        else:
-            dbif.close()
-            grass.fatal(_("Space time raster dataset <%s> is already in database, use overwrite flag to overwrite") % out_id)
-    temporal_type, semantic_type, title, description = sp.get_initial_values()
-    new_sp.set_initial_values(temporal_type, semantic_type, title, description)
-    new_sp.insert(dbif)
-    rows = sampler_sp.get_registered_maps("id,start_time,end_time", None, "start_time", dbif)
-    if not rows:
-            dbif.close()
-            grass.fatal(_("Aggregation dataset <%s> is empty") % id)
-    count = 0
-    for row in rows:
-        count += 1
-        start = row["start_time"]
-        end = row["end_time"]
-        input_map_names = tgis.collect_map_names(sp, dbif, start, end, sampling)
-        if input_map_names:
-            tgis.aggregate_raster_maps(sp, new_sp, mapset, input_map_names, base, start, end, count, method, register_null, dbif)
-    # Update the spatio-temporal extent and the raster metadata table entries
-    new_sp.update_from_registered_maps(dbif)
-    dbif.close()
-if __name__ == "__main__":
-    options, flags = grass.parser()
-    main()
