[GRASS-SVN] r51310 - grass-addons/grass6/raster/r.basin
svn_grass at osgeo.org
Sun Apr 8 10:56:42 EDT 2012
Author: madi
Date: 2012-04-08 07:56:42 -0700 (Sun, 08 Apr 2012)
New Revision: 51310
grass-addons/grass6/raster/r.basin/r.basin.py
remove small areas created by r.to.vect
Modified: grass-addons/grass6/raster/r.basin/r.basin.py
--- grass-addons/grass6/raster/r.basin/r.basin.py 2012-04-08 08:28:17 UTC (rev 51309)
+++ grass-addons/grass6/raster/r.basin/r.basin.py 2012-04-08 14:56:42 UTC (rev 51310)
@@ -111,6 +111,7 @@
r_outlet = prefix+'_r_outlet'
v_outlet = prefix+'_outlet'
v_basin = prefix+'_basin'
+ v_basins = prefix+'_basins'
v_centroid1 = prefix+'_centroid1'
v_mainchannel = prefix+'_mainchannel'
v_mainchannel_dim = prefix+'_mainchannel_dim'
@@ -205,20 +206,20 @@
# Basin mask (vector)
# Raster to vector
grass.run_command('r.to.vect', input = r_basin,
- output = v_basin,
+ output = v_basins,
feature = 'area',
flags = 's',
overwrite = True)
# Add two columns to the table: area and perimeter
- grass.run_command('v.db.addcol', map = v_basin,
+ grass.run_command('v.db.addcol', map = v_basins,
columns = 'area double precision')
columns = 'perimeter double precision')
# Populate perimeter column
- grass.run_command('v.to.db', map = v_basin,
+ grass.run_command('v.to.db', map = v_basins,
type = 'line,boundary',
layer = 1,
qlayer = 1,
@@ -228,7 +229,7 @@
overwrite = True)
# Read perimeter
- tmp = grass.read_command('v.to.db', map = v_basin,
+ tmp = grass.read_command('v.to.db', map = v_basins,
layer = 1,
qlayer = 1,
@@ -239,7 +240,7 @@
perimeter_basin = float(tmp.split('\n')[1].split('|')[1])
# Populate area column
layer = 1,
qlayer = 1,
@@ -249,7 +250,7 @@
overwrite = True)
# Read area
layer = 1,
qlayer = 1,
@@ -257,8 +258,14 @@
units = 'kilometers',
qcolumn = 'area',
flags = 'p')
- area_basin = float(tmp.split('\n')[1].split('|')[1])
+ area_basin = float(tmp.split('\n')[1].split('|')[1])
+ grass.run_command('v.extract', list = 1,
+ input = v_basins,
+ output = v_basin,
+ type = 'area',
+ overwrite = True)
# Creation of order maps: strahler, horton, hack, shreeve
grass.message( "Creating %s" % r_hack )
grass.run_command('r.stream.order', stream = r_stream_e,
@@ -519,6 +526,7 @@
grass.run_command('g.remove', vect = v_centroid1, quiet = True)
grass.run_command('g.remove', vect = v_mainchannel_dim, quiet = True)
grass.run_command('g.remove', vect = v_ord_1, quiet = True)
+ grass.run_command('g.remove', vect = v_basins, quiet = True)
if nomap :
grass.run_command('g.remove', vect = v_outlet, quiet = True)
