[GRASS-SVN] r51337 - in grass-addons/grass6/raster: .
r.stream.preview
svn_grass at osgeo.org
Mon Apr 9 15:37:32 EDT 2012
Author: madi
Date: 2012-04-09 12:37:31 -0700 (Mon, 09 Apr 2012)
New Revision: 51337
Added:
grass-addons/grass6/raster/r.stream.preview/
grass-addons/grass6/raster/r.stream.preview/Makefile
grass-addons/grass6/raster/r.stream.preview/description.html
grass-addons/grass6/raster/r.stream.preview/r.stream.preview.py
renamed r.preview
Added: grass-addons/grass6/raster/r.stream.preview/Makefile
--- grass-addons/grass6/raster/r.stream.preview/Makefile (rev 0)
+++ grass-addons/grass6/raster/r.stream.preview/Makefile 2012-04-09 19:37:31 UTC (rev 51337)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.stream.preview.py
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass6/raster/r.stream.preview/description.html
--- grass-addons/grass6/raster/r.stream.preview/description.html (rev 0)
+++ grass-addons/grass6/raster/r.stream.preview/description.html 2012-04-09 19:37:31 UTC (rev 51337)
@@ -0,0 +1,26 @@
+<h2>DESCRIPTION</h2>
+<em>r.stream.preview</em> Creates a preview of stream extraction for a threshold value
+and a given flow accumulation map.
+<h2>NOTES</h2>
+<p>In order to find a value of upslope area to be used as input to extract the
+river network using r.stream.extract or r.watershed, it is common to proceed
+by attempts. This tool is useful for quickly display results for various
+attempts of threshold values.
+<h2>EXAMPLE</h2>
+<p>r.stream.preview acc=accumulation_map th=value
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.stream.extract.html">r.stream.extract</a>,
+<a href="r.watershed.html">r.watershed</a>
+</em>
+<h2>AUTHOR</h2>
+<p>Margherita Di Leo (dileomargherita AT gmail DOT com)
Added: grass-addons/grass6/raster/r.stream.preview/r.stream.preview.py
--- grass-addons/grass6/raster/r.stream.preview/r.stream.preview.py (rev 0)
+++ grass-addons/grass6/raster/r.stream.preview/r.stream.preview.py 2012-04-09 19:37:31 UTC (rev 51337)
@@ -0,0 +1,73 @@
+#!/usr/bin/env python
+# MODULE: r.stream.preview.py
+# AUTHOR(S): Margherita Di Leo
+# PURPOSE: Create a preview for threshold value given the flow accumulation map
+# COPYRIGHT: (C) 2012 by Margherita Di Leo
+# dileomargherita at gmail.com
+# This program is free software under the GNU General Public
+# License (>=v3.0) and comes with ABSOLUTELY NO WARRANTY.
+# See the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Create a preview for a threshold value given the flow accumulation map
+#% keywords: raster
+#%end
+#%option
+#% key: acc
+#% type: string
+#% gisprompt: old,raster,raster
+#% key_desc: flow accumulation
+#% description: Name of flow accumulation raster map
+#% required: yes
+#%end
+#%option
+#% key: th
+#% type: double
+#% key_desc: threshold
+#% description: threshold (integer)
+#% required: yes
+#%end
+import sys
+import os
+import grass.script as grass
+if not os.environ.has_key("GISBASE"):
+ grass.message( "You must be in GRASS GIS to run this program." )
+ sys.exit(1)
+def main():
+ r_acc = options['acc']
+ th = options['th']
+ # Creates temp rules file
+ tmp = open('rules', 'w')
+ tmp.write('*:' + th + ':0' + '\n')
+ tmp.write(th + ':*:1')
+ tmp.close()
+ # recode
+ grass.run_command('r.recode', input = r_acc,
+ output = 'r_preview',
+ rules = 'rules',
+ overwrite = 'True')
+ # Delete temp rules file
+ os.remove('rules')
+ # display
+ grass.run_command( 'd.mon', stop = 'x1' )
+ grass.run_command( 'd.mon', start = 'x1' )
+ grass.run_command( 'd.rast', map = 'r_preview' )
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ sys.exit(main())
Property changes on: grass-addons/grass6/raster/r.stream.preview/r.stream.preview.py
___________________________________________________________________
Added: svn:executable
