[GRASS-SVN] r51355 - grass-addons/grass6/raster/r.basin
Tue Apr 10 09:49:02 EDT 2012
Author: madi
Date: 2012-04-10 06:49:01 -0700 (Tue, 10 Apr 2012)
New Revision: 51355
   grass-addons/grass6/raster/r.basin/r.basin.py
clean up
Modified: grass-addons/grass6/raster/r.basin/r.basin.py
--- grass-addons/grass6/raster/r.basin/r.basin.py	2012-04-10 12:43:34 UTC (rev 51354)
+++ grass-addons/grass6/raster/r.basin/r.basin.py	2012-04-10 13:49:01 UTC (rev 51355)
@@ -2,7 +2,7 @@
-# MODULE:      r.basin.py
+# MODULE:      r.basin
 # AUTHOR(S):   Margherita Di Leo, Massimo Di Stefano
 # PURPOSE:     Morphometric characterization of river basins
 # COPYRIGHT:   (C) 2010 by Margherita Di Leo & Massimo Di Stefano
@@ -111,7 +111,6 @@
     r_outlet = prefix+'_r_outlet'
     v_outlet = prefix+'_outlet'
     v_basin = prefix+'_basin'
-    v_basins = prefix+'_basins'
     v_centroid1 = prefix+'_centroid1'
     v_mainchannel = prefix+'_mainchannel'
     v_mainchannel_dim = prefix+'_mainchannel_dim'
@@ -206,20 +205,20 @@
         # Basin mask (vector)
         # Raster to vector
         grass.run_command('r.to.vect', input = r_basin,
-                                       output = v_basins,
+                                       output = v_basin,
                                        feature = 'area',
                                        flags = 'sv',
                                        overwrite = True)
         # Add two columns to the table: area and perimeter
-        grass.run_command('v.db.addcol', map = v_basins,
+        grass.run_command('v.db.addcol', map = v_basin,
                                          columns = 'area double precision')
                                          columns = 'perimeter double precision')
         # Populate perimeter column
-        grass.run_command('v.to.db', map = v_basins,
+        grass.run_command('v.to.db', map = v_basin,
                                  type = 'line,boundary',
                                  layer = 1,
                                  qlayer = 1,
@@ -229,7 +228,7 @@
                                  overwrite = True)
         # Read perimeter
-        tmp = grass.read_command('v.to.db', map = v_basins,
+        tmp = grass.read_command('v.to.db', map = v_basin,
                                  layer = 1,
                                  qlayer = 1,
@@ -240,7 +239,7 @@
         perimeter_basin = float(tmp.split('\n')[1].split('|')[1])
         # Populate area column
                                  layer = 1,
                                  qlayer = 1,
@@ -250,7 +249,7 @@
                                  overwrite = True)
         # Read area
                                  layer = 1,
                                  qlayer = 1,
@@ -258,13 +257,7 @@
                                  units = 'kilometers',
                                  qcolumn = 'area',
                                  flags = 'p')
-        area_basin = float(tmp.split('\n')[1].split('|')[1])
-        grass.run_command('v.extract', list = 1,
-                                       input = v_basins,
-                                       output = v_basin,
-                                       type = 'area',
-                                       overwrite = True)
+        area_basin = float(tmp.split('\n')[1].split('|')[1])
         # Creation of order maps: strahler, horton, hack, shreeve
         grass.message( "Creating %s" % r_hack )
@@ -470,7 +463,6 @@
        map = r_average_hillslope).split('\n')[0].split('=')[1])
         # Magnitudo
-        grass.run_command('r.mapcalculator', amap = r_strahler , formula = 'if(%s==1,1,null())' % (r_strahler) , outfile = r_ord_1)
         grass.mapcalc("$r_ord_1 = if($r_strahler==1,1,null())",
                   r_ord_1 = r_ord_1,
                   r_strahler = r_strahler)
@@ -526,7 +518,6 @@
         grass.run_command('g.remove', vect = v_centroid1, quiet = True)
         grass.run_command('g.remove', vect = v_mainchannel_dim, quiet = True)
         grass.run_command('g.remove', vect = v_ord_1, quiet = True)
-        grass.run_command('g.remove', vect = v_basins, quiet = True)
         if nomap :
             grass.run_command('g.remove', vect = v_outlet, quiet = True)
