[GRASS-SVN] r51363 - grass-addons/grass7/raster/r.in.wms2
Tue Apr 10 15:12:49 EDT 2012
Author: martinl
Date: 2012-04-10 12:12:48 -0700 (Tue, 10 Apr 2012)
New Revision: 51363
   grass-addons/grass7/raster/r.in.wms2/r.in.wms2.py
   grass-addons/grass7/raster/r.in.wms2/wms_base.py
r.in.wms2: don't call GetCapabilities/GetMap in base class constructor
Modified: grass-addons/grass7/raster/r.in.wms2/r.in.wms2.py
--- grass-addons/grass7/raster/r.in.wms2/r.in.wms2.py	2012-04-10 19:00:15 UTC (rev 51362)
+++ grass-addons/grass7/raster/r.in.wms2/r.in.wms2.py	2012-04-10 19:12:48 UTC (rev 51363)
@@ -143,14 +143,17 @@
     if flags['d']:
         grass.debug("Using own driver")
         from wms_drv import WMSDrv
-        wms = WMSDrv(options, flags)
+        wms = WMSDrv()
     else:
         grass.debug("Using GDAL WMS driver")
         from wms_gdal_drv import WMSGdalDrv
-        wms = WMSGdalDrv(options, flags)
+        wms = WMSGdalDrv()
+    if flags['c']:
+        wms.GetCapabilities(options)
+    else:
+        wms.GetMap(options, flags)
     return 0
 if __name__ == "__main__":
Modified: grass-addons/grass7/raster/r.in.wms2/wms_base.py
--- grass-addons/grass7/raster/r.in.wms2/wms_base.py	2012-04-10 19:00:15 UTC (rev 51362)
+++ grass-addons/grass7/raster/r.in.wms2/wms_base.py	2012-04-10 19:12:48 UTC (rev 51363)
@@ -7,32 +7,15 @@
 import grass.script as grass
 class WMSBase:
-    def __init__(self, options, flags):
+    def __init__(self):
         # these variables are information for destructor
         self.temp_files_to_cleanup = []
-        self.cleanup_mask = False
+        self.cleanup_mask   = False
         self.cleanup_layers = False
         self.bbox     = None
         self.temp_map = None
-        if flags['c']:
-            self._getCapabilities(options)
-        else:
-            self._getMap(options, flags)
-    def _getMap(self, options, flags):
-        """!Download data from WMS server and import data
-        (using GDAL library) into GRASS as a raster map."""
-        self._initializeParameters(options, flags)
-        self.bbox     = self._computeBbox()
-        self.temp_map = self._download()
-        self._createOutputMap()
     def __del__(self):
         # removes temporary mask, used for import transparent or warped temp_map
         if self.cleanup_mask:
@@ -185,8 +168,20 @@
         self.gdal_drv_format = "GTiff"
         self._debug("_initialize_parameters", "finished")
+    def GetMap(self, options, flags):
+        """!Download data from WMS server and import data
+        (using GDAL library) into GRASS as a raster map."""
+        self._initializeParameters(options, flags)
+        self.bbox     = self._computeBbox()
-    def _getCapabilities(self, options):
+        self.temp_map = self._download()
+        self._createOutputMap()
+    def GetCapabilities(self, options):
         """!Get capabilities from WMS server
         # download capabilities file
