[GRASS-SVN] r51367 - in grass/trunk/raster: . r.clump r.mode r.series r.statistics r.univar
Tue Apr 10 17:12:48 EDT 2012
Author: neteler
Date: 2012-04-10 14:12:48 -0700 (Tue, 10 Apr 2012)
New Revision: 51367
   grass/trunk/raster/r.clump/r.clump.html
   grass/trunk/raster/r.mode/r.mode.html
   grass/trunk/raster/r.series/r.series.html
   grass/trunk/raster/r.statistics/r.statistics.html
   grass/trunk/raster/r.univar/r.univar.html
   grass/trunk/raster/r.univar/r3.univar.html
   grass/trunk/raster/rasterintro.html
r.average, r.median, r.sum --> r.statistics
Modified: grass/trunk/raster/r.clump/r.clump.html
--- grass/trunk/raster/r.clump/r.clump.html	2012-04-10 19:36:02 UTC (rev 51366)
+++ grass/trunk/raster/r.clump/r.clump.html	2012-04-10 21:12:48 UTC (rev 51367)
@@ -33,16 +33,17 @@
 <h2>SEE ALSO</h2>
-<em><a href="r.average.html">r.average</a></em><br>
-<em><a href="r.buffer.html">r.buffer</a></em><br>
-<em><a href="r.grow.html">r.grow</a><br></em><br>
-<em><a href="r.mapcalc.html">r.mapcalc</a></em><br>
-<em><a href="r.mfilter.html">r.mfilter</a></em><br>
-<em><a href="r.neighbors.html">r.neighbors</a></em><br>
-<em><a href="r.to.vect.html">r.to.vect</a></em><br>
-<em><a href="r.reclass.html">r.reclass</a></em><br>
-<em><a href="r.statistics.html">r.statistics</a></em><br>
-<em><a href="r.support.html">r.support</a></em>
+<em>
+<a href="r.buffer.html">r.buffer</a>,
+<a href="r.grow.html">r.grow</a><br>,
+<a href="r.mapcalc.html">r.mapcalc</a>,
+<a href="r.mfilter.html">r.mfilter</a>,
+<a href="r.neighbors.html">r.neighbors</a>,
+<a href="r.to.vect.html">r.to.vect</a>,
+<a href="r.reclass.html">r.reclass</a>,
+<a href="r.statistics.html">r.statistics</a>,
+<a href="r.support.html">r.support</a>
+</em>
 <h2>AUTHOR</h2>
Modified: grass/trunk/raster/r.mode/r.mode.html
--- grass/trunk/raster/r.mode/r.mode.html	2012-04-10 19:36:02 UTC (rev 51366)
+++ grass/trunk/raster/r.mode/r.mode.html	2012-04-10 21:12:48 UTC (rev 51367)
@@ -41,12 +41,10 @@
 <h2>SEE ALSO</h2>
 <em><a href="g.region.html">g.region</a></em>,
-<em><a href="r.average.html">r.average</a></em>,
 <em><a href="r.category.html">r.category</a></em>,
 <em><a href="r.clump.html">r.clump</a></em>,
 <em><a href="r.describe.html">r.describe</a></em>,
 <em><a href="r.mapcalc.html">r.mapcalc</a></em>,
-<em><a href="r.median.html">r.median</a></em>,
 <em><a href="r.mfilter.html">r.mfilter</a></em>,
 <em><a href="r.neighbors.html">r.neighbors</a></em>,
 <em><a href="r.reclass.html">r.reclass</a></em>,
Modified: grass/trunk/raster/r.series/r.series.html
--- grass/trunk/raster/r.series/r.series.html	2012-04-10 19:36:02 UTC (rev 51366)
+++ grass/trunk/raster/r.series/r.series.html	2012-04-10 21:12:48 UTC (rev 51367)
@@ -110,7 +110,7 @@
 map3
 EOF
-r.series2 file=input.txt out=result_sum meth=sum
+r.series file=input.txt out=result_sum meth=sum
 </pre></div>
 <p>Example to use the file option of r.series including weights. The weight 0.75
@@ -122,7 +122,7 @@
 map3
 EOF
 </pre></div>
 <p>
Modified: grass/trunk/raster/r.statistics/r.statistics.html
--- grass/trunk/raster/r.statistics/r.statistics.html	2012-04-10 19:36:02 UTC (rev 51366)
+++ grass/trunk/raster/r.statistics/r.statistics.html	2012-04-10 21:12:48 UTC (rev 51367)
@@ -51,10 +51,8 @@
 <h2>SEE ALSO</h2>
 <em>
-<a href="r.average.html">r.average</a>,
 <a href="r.clump.html">r.clump</a>,
 <a href="r.mode.html">r.mode</a>,
-<a href="r.median.html">r.median</a>,
 <a href="r.univar.html">r.univar</a>
Modified: grass/trunk/raster/r.univar/r.univar.html
--- grass/trunk/raster/r.univar/r.univar.html	2012-04-10 19:36:02 UTC (rev 51366)
+++ grass/trunk/raster/r.univar/r.univar.html	2012-04-10 21:12:48 UTC (rev 51367)
@@ -108,15 +108,12 @@
 <em>
 <a href="g.region.html">g.region</a><br>
 <a href="r3.univar.html">r3.univar</a><br>
-<a href="r.average.html">r.average</a><br>
-<a href="r.median.html">r.median</a><br>
 <a href="r.mode.html">r.mode</a><br>
 <a href="r.quantile.html">r.quantile</a><br>
-<a href="r.sum.html">r.sum</a><br>
 <a href="r.series.html">r.series</a><br>
 <a href="r.stats.html">r.stats</a><br>
-<a href="v.rast.stats.html">v.rast.stats</a><br>
 <a href="r.statistics.html">r.statistics</a><br>
+<a href="v.rast.stats.html">v.rast.stats</a><br>
 <a href="v.univar.html">v.univar</a><br>
 </em>
Modified: grass/trunk/raster/r.univar/r3.univar.html
--- grass/trunk/raster/r.univar/r3.univar.html	2012-04-10 19:36:02 UTC (rev 51366)
+++ grass/trunk/raster/r.univar/r3.univar.html	2012-04-10 21:12:48 UTC (rev 51367)
@@ -40,11 +40,8 @@
 <em>
 <a href="r.univar.html">r.univar</a><br>
Modified: grass/trunk/raster/rasterintro.html
--- grass/trunk/raster/rasterintro.html	2012-04-10 19:36:02 UTC (rev 51366)
+++ grass/trunk/raster/rasterintro.html	2012-04-10 21:12:48 UTC (rev 51367)
@@ -186,8 +186,8 @@
 A couple of commands are available to calculate local statistics
 (<a href="r.neighbors.html">r.neighbors</a>), and global statistics
-(<a href="r.statistics.html">r.statistics</a>, <a href="r.surf.area.html">r.surf.area</a>,
-<a href="r.sum.html">r.sum</a>).  Profiles and transects can be generated
+(<a href="r.statistics.html">r.statistics</a>, <a href="r.surf.area.html">r.surf.area</a>).
+Profiles and transects can be generated
 (<a href="d.profile.html">d.profile</a>, <a href="r.profile.html">r.profile</a>,
 <a href="r.transect.html">r.transect</a>) as well as histograms
 (<a href="d.histogram.html">d.histogram</a>) and polar diagrams
@@ -202,7 +202,7 @@
 The <a href="r.mapcalc.html">r.mapcalc</a> command provides raster map
 algebra methods.
 The <a href="r.resamp.stats.html">r.resamp.stats</a> command resamples raster
-map layers using various aggregation methods, the <a href="r.average.html">r.average</a>
+map layers using various aggregation methods, the <a href="r.statistics.html">r.statistics</a>
 command aggregates one map based on a second map.
 <a href="r.resamp.interp.html">r.resamp.interp</a> resamples raster map layers using interpolation.
