[GRASS-SVN] r51384 - grass-addons/grass7/raster/r.in.wms2
svn_grass at osgeo.org
Wed Apr 11 18:45:34 EDT 2012
Author: turek
Date: 2012-04-11 15:45:34 -0700 (Wed, 11 Apr 2012)
New Revision: 51384
grass-addons/grass7/raster/r.in.wms2/r.in.wms2.html
r.in.wms2.html: examples which does not worked were removed
Modified: grass-addons/grass7/raster/r.in.wms2/r.in.wms2.html
--- grass-addons/grass7/raster/r.in.wms2/r.in.wms2.html 2012-04-11 22:20:01 UTC (rev 51383)
+++ grass-addons/grass7/raster/r.in.wms2/r.in.wms2.html 2012-04-11 22:45:34 UTC (rev 51384)
@@ -24,72 +24,11 @@
<h3>General Get Capabilities Request</h3>
-A capabilities request like
-<a href="http://wms.jpl.nasa.gov/wms.cgi?request=GetCapabilities">http://wms.jpl.nasa.gov/wms.cgi?request=GetCapabilities</a>
-is where you should start. It tells you what data is offered, the projections
-it is in, where to find meta data, resolutions, scales, and bounds for
-data, etc.
-E.g. lists the layers available from the NASA OnEarth server.
<div class="code"><pre>
-r.in.wms2 mapserver=http://wms.jpl.nasa.gov/wms.cgi -l
+r.in.wms2 -c mapserver=http://wms.cuzk.cz/wms.asp
</pre></div>
-<h3>US NED Elevation from OnEarth server download (metric units)</h3>
-Set the resolution to 30 (assuming you're in metric units):
-<div class="code"><pre>
-g.region res=30 -ap
-r.in.wms2 output=elevation_meters mapserver=http://wms.jpl.nasa.gov/wms.cgi \
- layers=us_ned styles=real
-</pre></div>
-<h3>US NED Elevation from OnEarth server download (feet units)</h3>
-Set the resolution to 90 (assuming you're in feet units) a save this
-region with a name; this makes resuming downloads possible or rather
-easier:
-g.region res=90 -ap
-g.region save=panhandle-90ft
-r.in.wms2 output=elevation_feet mapserver=http://wms.jpl.nasa.gov/wms.cgi \
- layers=us_ned styles=feet_real region=panhandle-90ft
-</pre></div>
-Downloads real number feet elevation from OnEarth to cover the current
-region.
-<h3>LANDSAT from OnEarth server download</h3>
-Set the resolution to 30 meters for LANDSAT:
-r.in.wms2 layers=global_mosaic mapserver=http://wms.jpl.nasa.gov/wms.cgi \
- output=wms_global_mosaic
-</pre></div>
-Downloads LANDSAT color scene.
-<h3>DRG from Terraserver server download</h3>
-Set the resolution to 1.2 meters for DRGs. Their native resolution is
-2.4 meters, so this is some pretty hefty oversampling:
-g.region res=1.2 -ap
-g.region save=drg-resolution
-r.in.wms2 output=terraserver-drg mapserver=http://terraserver.microsoft.com/ogcmap6.ashx \
- layers=DRG region=drg-resolution format=jpeg srs=EPSG:26910
-</pre></div>
-Downloads digital raster graphics from Microsoft TerraServer. Note that
-srs will need to be changed to a projection that is appropriate for your
-region.
<h3>CUZK download</h3>
