[GRASS-SVN] r51390 - grass/trunk/scripts/g.extension
svn_grass at osgeo.org
Thu Apr 12 10:16:29 EDT 2012
Author: martinl
Date: 2012-04-12 07:16:29 -0700 (Thu, 12 Apr 2012)
New Revision: 51390
grass/trunk/scripts/g.extension/g.extension.py
g.extension: fix file URIs in manual page
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py 2012-04-12 12:48:19 UTC (rev 51389)
+++ grass/trunk/scripts/g.extension/g.extension.py 2012-04-12 14:16:29 UTC (rev 51390)
@@ -4,10 +4,10 @@
# MODULE: g.extension
# AUTHOR(S): Markus Neteler
-# Pythonized & upgraded for GRASS 7 by Martin Landa
+# Pythonized & upgraded for GRASS 7 by Martin Landa <landa.martin gmail.com>
# PURPOSE: Tool to download and install extensions from GRASS Addons SVN into
# local GRASS installation
-# COPYRIGHT: (C) 2009-2011 by Markus Neteler, and the GRASS Development Team
+# COPYRIGHT: (C) 2009-2012 by Markus Neteler, and the GRASS Development Team
# This program is free software under the GNU General
# Public License (>=v2). Read the file COPYING that
@@ -455,6 +455,8 @@
ret += install_extension_other(module)
if len(mlist) > 1:
print '-' * 60
+ grass.verbose(_("Updating manual page for <%s>...") % module)
+ update_manual_page(module)
if ret != 0:
grass.warning(_('Installation failed, sorry. Please check above error messages.'))
@@ -921,6 +923,48 @@
create_dir(os.path.join(options['prefix'], 'docs', 'man', 'man1'))
create_dir(os.path.join(options['prefix'], 'scripts'))
+# fix file URI in manual page
+def update_manual_page(module):
+ # read original html file
+ htmlfile = os.path.join(options['prefix'], 'docs', 'html', module + '.html')
+ try:
+ f = open(htmlfile)
+ shtml = f.read()
+ except IOError, e:
+ grass.fatal(_("Unable to read manual page: %s") % e)
+ else:
+ f.close()
+ # find URIs
+ pattern = r'''<a href="([^"]+)">([^>]+)</a>'''
+ addons = get_installed_extensions(force = True)
+ pos = []
+ for match in re.finditer(pattern, shtml):
+ if match.group(1)[:7] == 'http://':
+ continue
+ if match.group(1).replace('.html', '') in addons:
+ continue
+ pos.append(match.start(1))
+ if not pos:
+ return # no match
+ # replace file URIs
+ prefix = 'file://' + os.path.join(os.getenv('GISBASE'), 'docs', 'html')
+ ohtml = shtml[:pos[0]]
+ for i in range(1, len(pos)):
+ ohtml += prefix + '/' + shtml[pos[i-1]:pos[i]]
+ ohtml += prefix + '/' + shtml[pos[-1]:]
+ # write updated html file
+ try:
+ f = open(htmlfile, 'w')
+ f.write(ohtml)
+ grass.fatal(_("Unable for write manual page: %s") % e)
+ else:
+ f.close()
def main():
# check dependecies
if sys.platform != "win32":
