[GRASS-SVN] r51397 - grass/trunk/db/db.login
svn_grass at osgeo.org
Thu Apr 12 12:44:00 EDT 2012
Author: martinl
Date: 2012-04-12 09:44:00 -0700 (Thu, 12 Apr 2012)
New Revision: 51397
grass/trunk/db/db.login/main.c
db.login: more guisections
untabify
Modified: grass/trunk/db/db.login/main.c
--- grass/trunk/db/db.login/main.c 2012-04-12 15:16:12 UTC (rev 51396)
+++ grass/trunk/db/db.login/main.c 2012-04-12 16:44:00 UTC (rev 51397)
@@ -3,9 +3,10 @@
* MODULE: db.login
* AUTHOR(S): Radim Blazek <radim.blazek gmail.com> (original contributor)
- * Glynn Clements <glynn gclements.plus.com>, Markus Neteler <neteler itc.it>
+ * Glynn Clements <glynn gclements.plus.com>
+ * Markus Neteler <neteler itc.it>
* PURPOSE: Store db login settings
- * COPYRIGHT: (C) 2004-2009 by the GRASS Development Team
+ * COPYRIGHT: (C) 2004-2009, 2012 by the GRASS Development Team
* This program is free software under the GNU General
* Public License (>=v2). Read the file COPYING that
@@ -37,7 +38,7 @@
module = G_define_module();
G_add_keyword(_("database"));
G_add_keyword(_("connection settings"));
- module->description = _("Sets user/password for driver/database.");
+ module->description = _("Sets user/password for DB driver/database.");
driver = G_define_standard_option(G_OPT_DB_DRIVER);
driver->options = db_list_drivers();
@@ -54,24 +55,26 @@
user->required = NO;
user->multiple = NO;
user->description = _("Username");
+ user->guisection = _("Settings");
password = G_define_option();
password->key = "password";
password->type = TYPE_STRING;
password->required = NO;
password->multiple = NO;
password->description = _("Password");
+ password->guisection = _("Settings");
if (G_parser(argc, argv))
- exit(EXIT_FAILURE);
+ exit(EXIT_FAILURE);
if (db_set_login(driver->answer, database->answer, user->answer,
- password->answer) == DB_FAILED) {
- G_fatal_error(_("Unable to set user/password"));
+ password->answer) == DB_FAILED) {
+ G_fatal_error(_("Unable to set user/password"));
if (password->answer)
- G_important_message(_("The password was stored in file (%s/dblogin)"), CONFIG_DIR);
+ G_important_message(_("The password was stored in file (%s/dblogin)"), CONFIG_DIR);
exit(EXIT_SUCCESS);
