[GRASS-SVN] r51400 - grass/trunk/gui/wxpython/mapdisp
svn_grass at osgeo.org
Thu Apr 12 14:04:47 EDT 2012
Author: mmetz
Date: 2012-04-12 11:04:47 -0700 (Thu, 12 Apr 2012)
New Revision: 51400
grass/trunk/gui/wxpython/mapdisp/mapwindow.py
wxGUI: fix OnIdle after resizing
Modified: grass/trunk/gui/wxpython/mapdisp/mapwindow.py
--- grass/trunk/gui/wxpython/mapdisp/mapwindow.py 2012-04-12 17:20:04 UTC (rev 51399)
+++ grass/trunk/gui/wxpython/mapdisp/mapwindow.py 2012-04-12 18:04:47 UTC (rev 51400)
@@ -102,7 +102,7 @@
self.redrawAll = True
# will store an off screen empty bitmap for saving to file
- self._buffer = None
+ self._buffer = wx.EmptyBitmap(max(1, self.Map.width), max(1, self.Map.height))
self.Bind(wx.EVT_ERASE_BACKGROUND, lambda x:None)
@@ -315,7 +315,7 @@
If self.redrawAll is False on self.pdcTmp content is re-drawn
Debug.msg(4, "BufferedWindow.OnPaint(): redrawAll=%s" % self.redrawAll)
- dc = wx.BufferedPaintDC(self, self.buffer)
+ dc = wx.BufferedPaintDC(self, self._buffer)
dc.Clear()
# use PrepareDC to set position correctly
@@ -385,44 +385,51 @@
def OnSize(self, event):
"""!Scale map image so that it is the same size as the Window
- Debug.msg(3, "BufferedWindow.OnSize():")
- # set size of the input image
- self.Map.ChangeMapSize(self.GetClientSize())
- # align extent based on center point and display resolution
- # this causes that image is not resized when display windows is resized
- ### self.Map.AlignExtentFromDisplay()
- # Make new off screen bitmap: this bitmap will always have the
- # current drawing in it, so it can be used to save the image to
- # a file, or whatever.
- self.buffer = wx.EmptyBitmap(max(1, self.Map.width), max(1, self.Map.height))
- # get the image to be rendered
- self.img = self.GetImage()
- # update map display
- if self.img and self.Map.width + self.Map.height > 0: # scale image during resize
- self.img = self.img.Scale(self.Map.width, self.Map.height)
- if len(self.Map.GetListOfLayers()) > 0:
- self.UpdateMap()
# re-render image on idle
- self.resize = True
+ self.resize = time.clock()
- # reposition checkbox in statusbar
- self.parent.StatusbarReposition()
- # update statusbar
- self.parent.StatusbarUpdate()
def OnIdle(self, event):
"""!Only re-render a composite map image from GRASS during
idle time instead of multiple times during resizing.
- if self.resize:
- self.UpdateMap(render = True)
+ # use OnInternalIdle() instead ?
+ if self.resize and self.resize + 0.2 < time.clock():
+ Debug.msg(3, "BufferedWindow.OnSize():")
+ # set size of the input image
+ self.Map.ChangeMapSize(self.GetClientSize())
+ # Make new off screen bitmap: this bitmap will always have the
+ # current drawing in it, so it can be used to save the image to
+ # a file, or whatever.
+ self._buffer.Destroy()
+ # get the image to be rendered
+ self.img = self.GetImage()
+ # update map display
+ updatemap = True
+ if self.img and self.Map.width + self.Map.height > 0: # scale image after resize
+ self.img = self.img.Scale(self.Map.width, self.Map.height)
+ if len(self.Map.GetListOfLayers()) > 0:
+ self.UpdateMap()
+ updatemap = False
+ # reposition checkbox in statusbar
+ self.parent.StatusbarReposition()
+ # update statusbar
+ self.parent.StatusbarUpdate()
+ if updatemap:
+ self.UpdateMap(render = True)
+ self.resize = False
+ elif self.resize:
+ event.RequestMore()
event.Skip()
def SaveToFile(self, FileName, FileType, width, height):
@@ -440,7 +447,7 @@
self.Map.ChangeMapSize((width, height))
ibuffer = wx.EmptyBitmap(max(1, width), max(1, height))
- self.Map.Render(force = True, windres = True)
+ self.Map.Render(force = True, windres = False)
self.pdc.RemoveAll()
self.Draw(self.pdc, img, drawid = 99)
@@ -449,7 +456,7 @@
cSize = self.GetClientSizeTuple()
ratio = float(width) / cSize[0], float(height) / cSize[1]
- # redraw lagend, scalebar
+ # redraw legend, scalebar
for img in self.GetOverlay():
# draw any active and defined overlays
if self.imagedict[img]['layer'].IsActive():
@@ -728,7 +735,7 @@
dc.SetBackground(wx.Brush("White"))
dc.Clear()
- self.dragimg = wx.DragImage(self.buffer)
+ self.dragimg = wx.DragImage(self._buffer)
self.dragimg.BeginDrag((0, 0), self)
self.dragimg.GetImageRect(moveto)
self.dragimg.Move(moveto)
