[GRASS-SVN] r51404 - in grass/trunk: lib/init scripts/g.manual
Thu Apr 12 18:19:03 EDT 2012
Author: martinl
Date: 2012-04-12 15:19:03 -0700 (Thu, 12 Apr 2012)
New Revision: 51404
   grass/trunk/lib/init/grass.py
   grass/trunk/scripts/g.manual/g.manual.py
define MANPATH also for addons (GRASS_ADDON_BASE)
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py	2012-04-12 22:06:21 UTC (rev 51403)
+++ grass/trunk/lib/init/grass.py	2012-04-12 22:19:03 UTC (rev 51404)
@@ -343,8 +343,10 @@
     # set path for the GRASS man pages
     grass_man_path = os.path.join(gisbase, 'docs', 'man')
+    addons_man_path = os.path.join(addon_base, 'docs', 'man')
     man_path = os.getenv('MANPATH')
     if man_path:
+        path_prepend(addons_man_path, 'MANPATH')
         path_prepend(grass_man_path, 'MANPATH')
     else:
         try:
@@ -354,14 +356,17 @@
             sys_man_path = s.strip()
         except:
             pass
         if sys_man_path:
             os.environ['MANPATH'] = sys_man_path
         else:
-            os.environ['MANPATH'] = grass_man_path
-    # Add .py (Python) to list of executable extensions to search for in MS-Windows PATH
+            os.environ['MANPATH'] = addons_man_path
+            path_prepend(os.path.join(grass_man_path, 'MANPATH'))
+    # Add .py (Python) to list of executable extensions to search for
+    # in MS-Windows PATH
     if windows:
         path_append('.PY', 'PATHEXT')
Modified: grass/trunk/scripts/g.manual/g.manual.py
--- grass/trunk/scripts/g.manual/g.manual.py	2012-04-12 22:06:21 UTC (rev 51403)
+++ grass/trunk/scripts/g.manual/g.manual.py	2012-04-12 22:19:03 UTC (rev 51404)
@@ -58,8 +58,8 @@
 def start_man(entry):
     path = os.path.join(gisbase, 'docs', 'man', 'man1', entry + '.1')
-    if not os.path.exists(path) and os.getenv('GRASS_ADDON_PATH'):
-        path = os.path.join(os.getenv('GRASS_ADDON_PATH'), 'man', 'man1', entry + '.1')
+    if not os.path.exists(path) and os.getenv('GRASS_ADDON_BASE'):
+        path = os.path.join(os.getenv('GRASS_ADDON_BASE'), 'docs', 'man', 'man1', entry + '.1')
     for ext in ['', '.gz', '.bz2']:
 	if os.path.exists(path + ext):
