[GRASS-SVN] r51409 - in grass/trunk: lib/python/temporal temporal
temporal/t.rast.univar temporal/t.rast3d.univar
svn_grass at osgeo.org
Fri Apr 13 08:54:40 EDT 2012
Author: huhabla
Date: 2012-04-13 05:54:40 -0700 (Fri, 13 Apr 2012)
New Revision: 51409
Added:
grass/trunk/lib/python/temporal/univar_statistics.py
grass/trunk/temporal/t.rast3d.univar/
grass/trunk/temporal/t.rast3d.univar/Makefile
grass/trunk/temporal/t.rast3d.univar/t.rast3d.univar.html
grass/trunk/temporal/t.rast3d.univar/t.rast3d.univar.py
grass/trunk/temporal/t.rast3d.univar/test.t.rast3d.univar.sh
grass/trunk/lib/python/temporal/Makefile
grass/trunk/lib/python/temporal/__init__.py
grass/trunk/temporal/Makefile
grass/trunk/temporal/t.rast.univar/t.rast.univar.py
grass/trunk/temporal/t.rast.univar/test.t.rast.univar.sh
Added univariate statistics module for space time raster3d datasets
Modified: grass/trunk/lib/python/temporal/Makefile
--- grass/trunk/lib/python/temporal/Makefile 2012-04-13 12:02:39 UTC (rev 51408)
+++ grass/trunk/lib/python/temporal/Makefile 2012-04-13 12:54:40 UTC (rev 51409)
@@ -8,7 +8,7 @@
GDIR = $(PYDIR)/grass
DSTDIR = $(GDIR)/temporal
-MODULES = base core abstract_dataset abstract_map_dataset abstract_space_time_dataset space_time_datasets space_time_datasets_tools metadata spatial_extent temporal_extent datetime_math temporal_granularity temporal_relationships unit_tests aggregation extract mapcalc
+MODULES = base core abstract_dataset abstract_map_dataset abstract_space_time_dataset space_time_datasets space_time_datasets_tools metadata spatial_extent temporal_extent datetime_math temporal_granularity temporal_relationships unit_tests aggregation extract mapcalc univar_statistics
PYFILES := $(patsubst %,$(DSTDIR)/%.py,$(MODULES) __init__)
PYCFILES := $(patsubst %,$(DSTDIR)/%.pyc,$(MODULES) __init__)
Modified: grass/trunk/lib/python/temporal/__init__.py
--- grass/trunk/lib/python/temporal/__init__.py 2012-04-13 12:02:39 UTC (rev 51408)
+++ grass/trunk/lib/python/temporal/__init__.py 2012-04-13 12:54:40 UTC (rev 51409)
@@ -15,3 +15,4 @@
from aggregation import *
from extract import *
from mapcalc import *
+from univar_statistics import *
Added: grass/trunk/lib/python/temporal/univar_statistics.py
--- grass/trunk/lib/python/temporal/univar_statistics.py (rev 0)
+++ grass/trunk/lib/python/temporal/univar_statistics.py 2012-04-13 12:54:40 UTC (rev 51409)
@@ -0,0 +1,102 @@
+"""!@package grass.temporal
+ at brief GRASS Python scripting module (temporal GIS functions)
+Temporal GIS related functions to be used in Python scripts.
+Usage:
+ at code
+import grass.temporal as tgis
+tgis.print_gridded_dataset_univar_statistics(type, input, where, extended, header, fs)
+ at endcode
+(C) 2008-2011 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Soeren Gebbert
+from space_time_datasets_tools import *
+def print_gridded_dataset_univar_statistics(type, input, where, extended, header, fs):
+ """!Print univariate statistics for a space time raster or raster3d dataset
+ @param type Must be "strds" or "str3ds"
+ @param input The name of the space time dataset
+ @param where A temporal database where statement
+ @param extended If True compute extended statistics
+ @param header If True print column names as header
+ @param fs Field separator
+ # We need a database interface
+ dbif = sql_database_interface_connection()
+ dbif.connect()
+ mapset = core.gisenv()["MAPSET"]
+ if input.find("@") >= 0:
+ id = input
+ else:
+ id = input + "@" + mapset
+ sp = dataset_factory(type, id)
+ if sp.is_in_db(dbif) == False:
+ dbif.close()
+ core.fatal(_("Space time %s dataset <%s> not found") % (sp.get_new_map_instance(None).get_type(), id))
+ sp.select(dbif)
+ rows = sp.get_registered_maps("id,start_time,end_time", where, "start_time", dbif)
+ if not rows:
+ dbif.close()
+ core.fatal(_("Space time %s dataset <%s> is empty") % (sp.get_new_map_instance(None).get_type(), out_id))
+ if header == True:
+ print "id" + fs + "start" + fs + "end" + fs + "mean" + fs + "min" + fs + "max" + fs,
+ print "mean_of_abs" + fs + "stddev" + fs + "variance" + fs,
+ if extended == True:
+ print "coeff_var" + fs + "sum" + fs + "null_cells" + fs + "cells" + fs,
+ print "first_quartile" + fs + "median" + fs + "third_quartile" + fs + "percentile_90"
+ else:
+ for row in rows:
+ id = row["id"]
+ start = row["start_time"]
+ end = row["end_time"]
+ flag="g"
+ flag += "e"
+ if type == "strds":
+ stats = core.parse_command("r.univar", map=id, flags=flag)
+ elif type == "str3ds":
+ stats = core.parse_command("r3.univar", map=id, flags=flag)
+ print str(id) + fs + str(start) + fs + str(end),
+ print fs + str(stats["mean"]) + fs + str(stats["min"]) + fs + str(stats["max"]) + fs + str(stats["mean_of_abs"]),
+ print fs + str(stats["stddev"]) + fs + str(stats["variance"]) + fs + str(stats["coeff_var"]) + fs + str(stats["sum"]),
+ print fs + str(stats["null_cells"]) + fs + str(stats["cells"]) + fs,
+ print str(stats["first_quartile"]) + fs + str(stats["median"]) + fs + str(stats["third_quartile"]) + fs + str(stats["percentile_90"])
+ else:
+ dbif.close()
+if __name__ == "__main__":
+ options, flags = core.parser()
+ main()
Property changes on: grass/trunk/lib/python/temporal/univar_statistics.py
___________________________________________________________________
Added: svn:executable
Modified: grass/trunk/temporal/Makefile
--- grass/trunk/temporal/Makefile 2012-04-13 12:02:39 UTC (rev 51408)
+++ grass/trunk/temporal/Makefile 2012-04-13 12:54:40 UTC (rev 51409)
@@ -24,6 +24,7 @@
t.rast3d.list \
t.rast3d.extract \
t.rast3d.mapcalc \
+ t.rast3d.univar \
t.vect.list \
t.vect.extract \
t.vect.what.strds \
Modified: grass/trunk/temporal/t.rast.univar/t.rast.univar.py
--- grass/trunk/temporal/t.rast.univar/t.rast.univar.py 2012-04-13 12:02:39 UTC (rev 51408)
+++ grass/trunk/temporal/t.rast.univar/t.rast.univar.py 2012-04-13 12:54:40 UTC (rev 51409)
@@ -16,9 +16,9 @@
#%module
#% description: Calculates univariate statistics from the non-null cells for each registered raster map of a space time raster dataset
-#% keywords: spacetime raster dataset
-#% keywords: raster
+#% keywords: temporal
#% keywords: statistics
+#% keywords: raster
#%end
#%option G_OPT_STRDS_INPUT
@@ -61,64 +61,9 @@
# Make sure the temporal database exists
tgis.create_temporal_database()
- # We need a database interface
- dbif = tgis.sql_database_interface_connection()
- dbif.connect()
- mapset = grass.gisenv()["MAPSET"]
- if input.find("@") >= 0:
- id = input
- else:
- id = input + "@" + mapset
- sp = tgis.space_time_raster_dataset(id)
- if sp.is_in_db(dbif) == False:
- dbif.close()
- grass.fatal(_("Space time %s dataset <%s> not found") % (sp.get_new_map_instance(None).get_type(), id))
+ tgis.print_gridded_dataset_univar_statistics("strds", input, where, extended, header, fs)
- sp.select(dbif)
- rows = sp.get_registered_maps("id,start_time,end_time", where, "start_time", dbif)
- if not rows:
- dbif.close()
- grass.fatal(_("Space time raster dataset <%s> is empty") % out_id)
- if header == True:
- print "id" + fs + "start" + fs + "end" + fs + "mean" + fs + "min" + fs + "max" + fs,
- print "mean_of_abs" + fs + "stddev" + fs + "variance" + fs,
- if extended == True:
- print "coeff_var" + fs + "sum" + fs + "null_cells" + fs + "cells" + fs,
- print "first_quartile" + fs + "median" + fs + "third_quartile" + fs + "percentile_90"
- else:
- for row in rows:
- id = row["id"]
- start = row["start_time"]
- end = row["end_time"]
- flag="g"
- flag += "e"
- stats = grass.parse_command("r.univar", map=id, flags=flag)
- print str(id) + fs + str(start) + fs + str(end),
- print fs + str(stats["mean"]) + fs + str(stats["min"]) + fs + str(stats["max"]) + fs + str(stats["mean_of_abs"]),
- print fs + str(stats["stddev"]) + fs + str(stats["variance"]) + fs + str(stats["coeff_var"]) + fs + str(stats["sum"]),
- print fs + str(stats["null_cells"]) + fs + str(stats["cells"]) + fs,
- print str(stats["first_quartile"]) + fs + str(stats["median"]) + fs + str(stats["third_quartile"]) + fs + str(stats["percentile_90"])
- else:
- dbif.close()
options, flags = grass.parser()
main()
Modified: grass/trunk/temporal/t.rast.univar/test.t.rast.univar.sh
--- grass/trunk/temporal/t.rast.univar/test.t.rast.univar.sh 2012-04-13 12:02:39 UTC (rev 51408)
+++ grass/trunk/temporal/t.rast.univar/test.t.rast.univar.sh 2012-04-13 12:54:40 UTC (rev 51409)
@@ -20,3 +20,4 @@
t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
t.remove type=strds input=precip_abs1
+g.remove rast=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
\ No newline at end of file
Added: grass/trunk/temporal/t.rast3d.univar/Makefile
--- grass/trunk/temporal/t.rast3d.univar/Makefile (rev 0)
+++ grass/trunk/temporal/t.rast3d.univar/Makefile 2012-04-13 12:54:40 UTC (rev 51409)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../../
+PGM = t.rast3d.univar
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script $(TEST_DST)
Added: grass/trunk/temporal/t.rast3d.univar/t.rast3d.univar.html
Added: grass/trunk/temporal/t.rast3d.univar/t.rast3d.univar.py
--- grass/trunk/temporal/t.rast3d.univar/t.rast3d.univar.py (rev 0)
+++ grass/trunk/temporal/t.rast3d.univar/t.rast3d.univar.py 2012-04-13 12:54:40 UTC (rev 51409)
@@ -0,0 +1,70 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE: t.rast3d.univar
+# AUTHOR(S): Soeren Gebbert
+# PURPOSE: Calculates univariate statistics from the non-null cells for each registered raster3d map of a space time raster3d dataset
+# COPYRIGHT: (C) 2011 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (version 2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Calculates univariate statistics from the non-null cells for each registered raster3d map of a space time raster3d dataset
+#% keywords: statistics
+#%end
+#%option G_OPT_STR3DS_INPUT
+#%end
+#%option G_OPT_T_WHERE
+#%end
+#%option
+#% key: fs
+#% type: string
+#% description: The field separator character between the output columns
+#% required: no
+#% answer: |
+#%end
+#%flag
+#% key: e
+#% description: Calculate extended statistics
+#%end
+#%flag
+#% key: h
+#% description: Print column names
+#%end
+import grass.script as grass
+def main():
+ # Get the options
+ input = options["input"]
+ where = options["where"]
+ extended = flags["e"]
+ header = flags["h"]
+ fs = options["fs"]
+ # Make sure the temporal database exists
+ tgis.create_temporal_database()
+ tgis.print_gridded_dataset_univar_statistics("str3ds", input, where, extended, header, fs)
+ options, flags = grass.parser()
+ main()
Property changes on: grass/trunk/temporal/t.rast3d.univar/t.rast3d.univar.py
Added: grass/trunk/temporal/t.rast3d.univar/test.t.rast3d.univar.sh
--- grass/trunk/temporal/t.rast3d.univar/test.t.rast3d.univar.sh (rev 0)
+++ grass/trunk/temporal/t.rast3d.univar/test.t.rast3d.univar.sh 2012-04-13 12:54:40 UTC (rev 51409)
@@ -0,0 +1,24 @@
+# Univariate statitsics for space time raster3d datasets
+# We need to set a specific region in the
+# @preprocess step of this test.
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
+# Data generation
+r3.mapcalc --o expr="prec_1 = rand(0, 550)"
+r3.mapcalc --o expr="prec_2 = rand(0, 450)"
+r3.mapcalc --o expr="prec_3 = rand(0, 320)"
+r3.mapcalc --o expr="prec_4 = rand(0, 510)"
+r3.mapcalc --o expr="prec_5 = rand(0, 300)"
+r3.mapcalc --o expr="prec_6 = rand(0, 650)"
+t.create --o type=str3ds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
+t.register type=rast3d --v -i input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-15 12:05:45" increment="14 days"
+# The first @test
+t.rast3d.univar -he input=precip_abs1
+t.unregister type=rast3d maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+t.remove type=str3ds input=precip_abs1
+g.remove rast3d=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
Property changes on: grass/trunk/temporal/t.rast3d.univar/test.t.rast3d.univar.sh
