[GRASS-SVN] r51416 - in grass/trunk/gui/wxpython: core gui_core
svn_grass at osgeo.org
Fri Apr 13 12:54:19 EDT 2012
Author: martinl
Date: 2012-04-13 09:54:18 -0700 (Fri, 13 Apr 2012)
New Revision: 51416
grass/trunk/gui/wxpython/core/gcmd.py
grass/trunk/gui/wxpython/gui_core/dialogs.py
grass/trunk/gui/wxpython/gui_core/goutput.py
grass/trunk/gui/wxpython/gui_core/gselect.py
wxGUI: RunCmd() use valid env variables
various fixes related to GdalSelect
Modified: grass/trunk/gui/wxpython/core/gcmd.py
--- grass/trunk/gui/wxpython/core/gcmd.py 2012-04-13 13:27:42 UTC (rev 51415)
+++ grass/trunk/gui/wxpython/core/gcmd.py 2012-04-13 16:54:18 UTC (rev 51416)
@@ -474,10 +474,11 @@
class CommandThread(Thread):
"""!Create separate thread for command. Used for commands launched
on the background."""
- def __init__ (self, cmd, stdin = None,
+ def __init__ (self, cmd, env = None, stdin = None,
stdout = sys.stdout, stderr = sys.stderr):
@param cmd command (given as list)
+ @param env environmental variables
@param stdin standard input stream
@param stdout redirect standard output or None
@param stderr redirect standard error output or None
@@ -488,6 +489,7 @@
self.stdin = stdin
self.stdout = stdout
self.stderr = stderr
+ self.env = env
self.module = None
self.error = ''
@@ -532,7 +534,8 @@
stdin = subprocess.PIPE,
stdout = subprocess.PIPE,
stderr = subprocess.PIPE,
- shell = sys.platform == "win32")
+ shell = sys.platform == "win32",
+ env = self.env)
except OSError, e:
self.error = str(e)
Modified: grass/trunk/gui/wxpython/gui_core/dialogs.py
--- grass/trunk/gui/wxpython/gui_core/dialogs.py 2012-04-13 13:27:42 UTC (rev 51415)
+++ grass/trunk/gui/wxpython/gui_core/dialogs.py 2012-04-13 16:54:18 UTC (rev 51416)
@@ -1758,9 +1758,18 @@
"""!Import/Link data (each layes as separate vector map)"""
self.commandId = -1
data = self.list.GetLayers()
+ dsn = self.dsnInput.GetDsn()
+ ext = self.dsnInput.GetFormatExt()
- dsn = self.dsnInput.GetDsn()
- ext = self.dsnInput.GetFormatExt()
+ # determine data driver for PostGIS links
+ popOGR = False
+ if self.importType == 'ogr' and \
+ self.dsnInput.GetType() == 'db' and \
+ self.dsnInput.GetFormat() == 'PostgreSQL' and \
+ 'GRASS_VECTOR_OGR' not in os.environ:
+ popOGR = True
+ os.environ['GRASS_VECTOR_OGR'] = '1'
for layer, output in data:
if self.importType == 'ogr':
if ext and layer.rfind(ext) > -1:
@@ -1797,13 +1806,17 @@
if self.options[key].IsChecked():
cmd.append('-%s' % key)
- if UserSettings.Get(group = 'cmd', key = 'overwrite', subkey = 'enabled'):
+ if UserSettings.Get(group = 'cmd', key = 'overwrite', subkey = 'enabled') and \
+ '--overwrite' not in cmd:
cmd.append('--overwrite')
# run in Layer Manager
self.parent.goutput.RunCmd(cmd, switchPage = True,
onDone = self.AddLayers)
+ if popOGR:
+ os.environ.pop('GRASS_VECTOR_OGR')
def _getCommand(self):
"""!Get command"""
if self.link:
Modified: grass/trunk/gui/wxpython/gui_core/goutput.py
--- grass/trunk/gui/wxpython/gui_core/goutput.py 2012-04-13 13:27:42 UTC (rev 51415)
+++ grass/trunk/gui/wxpython/gui_core/goutput.py 2012-04-13 16:54:18 UTC (rev 51416)
@@ -52,9 +52,9 @@
wxCmdAbort, EVT_CMD_ABORT = NewEvent()
wxCmdPrepare, EVT_CMD_PREPARE = NewEvent()
-def GrassCmd(cmd, stdout = None, stderr = None):
+def GrassCmd(cmd, env = None, stdout = None, stderr = None):
"""!Return GRASS command thread"""
- return CommandThread(cmd,
+ return CommandThread(cmd, env = env,
stdout = stdout, stderr = stderr)
class CmdThread(threading.Thread):
@@ -70,7 +70,7 @@
self.requestQ = requestQ
self.resultQ = resultQ
self.start()
def RunCmd(self, *args, **kwds):
@@ -578,7 +578,8 @@
# process GRASS command with argument
self.cmdThread.RunCmd(command, stdout = self.cmdStdOut, stderr = self.cmdStdErr,
- onDone = onDone, onPrepare = onPrepare, userData = userData)
+ onDone = onDone, onPrepare = onPrepare, userData = userData,
+ env = os.environ.copy())
self.cmdOutputTimer.Start(50)
# deactivate computational region and return to display settings
Modified: grass/trunk/gui/wxpython/gui_core/gselect.py
--- grass/trunk/gui/wxpython/gui_core/gselect.py 2012-04-13 13:27:42 UTC (rev 51415)
+++ grass/trunk/gui/wxpython/gui_core/gselect.py 2012-04-13 16:54:18 UTC (rev 51416)
@@ -23,7 +23,7 @@
- gselect::ElementSelect
- gselect::OgrTypeSelect
-(C) 2007-2011 by the GRASS Development Team
+(C) 2007-2012 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@@ -1151,13 +1151,16 @@
self.settingsFile = os.path.join(GetSettingsPath(), 'wxOGR')
else:
self.settingsFile = os.path.join(GetSettingsPath(), 'wxGDAL')
- self._settings = self._loadSettings()
self.settingsChoice = wx.Choice(parent = self, id = wx.ID_ANY)
self.settingsChoice.Bind(wx.EVT_CHOICE, self.OnSettingsLoad)
- self.settingsChoice.SetItems(self._settings.keys())
- self.btnSettings = wx.Button(parent = self, id = wx.ID_SAVE)
- self.btnSettings.Bind(wx.EVT_BUTTON, self.OnSettingsSave)
+ self._settings = self._loadSettings() # -> self.settingsChoice.SetItems()
+ self.btnSettingsSave = wx.Button(parent = self, id = wx.ID_SAVE)
+ self.btnSettingsSave.Bind(wx.EVT_BUTTON, self.OnSettingsSave)
+ self.btnSettingsSave.SetToolTipString(_("Save current settings"))
+ self.btnSettingsDel = wx.Button(parent = self, id = wx.ID_REMOVE)
+ self.btnSettingsDel.Bind(wx.EVT_BUTTON, self.OnSettingsDelete)
+ self.btnSettingsSave.SetToolTipString(_("Delete currently selected settings"))
self.source = wx.RadioBox(parent = self, id = wx.ID_ANY,
style = wx.RA_SPECIFY_COLS,
@@ -1305,9 +1308,12 @@
settingsSizer.Add(item = self.settingsChoice,
proportion = 1,
flag = wx.EXPAND)
- settingsSizer.Add(item = self.btnSettings,
- flag = wx.LEFT,
+ settingsSizer.Add(item = self.btnSettingsSave,
+ flag = wx.LEFT | wx.RIGHT,
border = 5)
+ settingsSizer.Add(item = self.btnSettingsDel,
+ flag = wx.RIGHT,
+ border = 5)
inputSizer = wx.StaticBoxSizer(self.inputBox, wx.HORIZONTAL)
@@ -1392,41 +1398,69 @@
if dlg.ShowModal() != wx.ID_OK:
return
+ # check required params
if not dlg.GetValue():
GMessage(parent = self,
message = _("Name not given, settings is not saved."))
return
+ if not self.GetDsn():
+ GMessage(parent = self,
+ message = _("No data source defined, settings is not saved."))
+ return
name = dlg.GetValue()
# check if settings item already exists
if name in self._settings:
dlgOwt = wx.MessageDialog(self, message = _("Settings <%s> already exists. "
- "Do you want to overwrite the settings?") % name,
- caption = _("Save settings"), style = wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
+ "Do you want to overwrite the settings?") % name,
+ caption = _("Save settings"), style = wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
if dlgOwt.ShowModal() != wx.ID_YES:
dlgOwt.Destroy()
return
self._settings[name] = (self.dsnType, self.GetDsn(),
self.format.GetStringSelection(),
self.creationOpt.GetValue())
+ if self._saveSettings() == 0:
+ self.settingsChoice.SetStringSelection(name)
+ dlg.Destroy()
+ def OnSettingsDelete(self, event):
+ """!Save settings"""
+ name = self.settingsChoice.GetStringSelection()
+ if not name:
+ message = _("No settings is defined. Operation canceled."))
+ return
+ self._settings.pop(name)
+ def _saveSettings(self):
+ """!Save settings into the file
+ @return 0 on success
+ @return -1 on failure
try:
fd = open(self.settingsFile, 'w')
- for name, value in self._settings.iteritems():
- fd.write('%s;%s;%s;%s\n' % (name, value[0], value[1], value[2]))
+ for key, value in self._settings.iteritems():
+ fd.write('%s;%s;%s;%s\n' % (key, value[0], value[1], value[2]))
except IOError:
GError(parent = self,
message = _("Unable to save settings"))
- return
- fd.close()
+ return -1
+ else:
+ fd.close()
- self.settingsChoice.Append(name)
- self.settingsChoice.SetStringSelection(name)
- dlg.Destroy()
+ return 0
def _loadSettings(self):
"""!Load settings from the file
@@ -1453,8 +1487,10 @@
pass
except IOError:
return data
+ else:
+ fd.close()
- fd.close()
+ self.settingsChoice.SetItems(sorted(data.keys()))
return data
@@ -1572,7 +1608,9 @@
for item in path.split(':', 1)[1].split(','):
key, value = item.split('=', 1)
if key == 'dbname':
- self.input[self.dsnType][1].SetStringSelection(value)
+ if not self.input[self.dsnType][1].SetStringSelection(value):
+ GMessage(_("Database <%s> not accessible.") % value,
+ parent = self)
break
else:
self.input[self.dsnType][1].SetValue(path)
