[GRASS-SVN] r51440 - grass/trunk/db/drivers/postgres
svn_grass at osgeo.org
Sat Apr 14 11:27:52 EDT 2012
Author: martinl
Date: 2012-04-14 08:27:52 -0700 (Sat, 14 Apr 2012)
New Revision: 51440
grass/trunk/db/drivers/postgres/db.c
grass/trunk/db/drivers/postgres/describe.c
grass/trunk/db/drivers/postgres/globals.h
dbdriver(pg): ignore topogeometry columns
Modified: grass/trunk/db/drivers/postgres/db.c
--- grass/trunk/db/drivers/postgres/db.c 2012-04-14 08:56:35 UTC (rev 51439)
+++ grass/trunk/db/drivers/postgres/db.c 2012-04-14 15:27:52 UTC (rev 51440)
@@ -99,7 +99,7 @@
"'float4', 'float8', 'numeric', "
"'char', 'bpchar', 'varchar', 'text', "
"'time', 'date', 'timestamp', "
- "'bool', 'geometry' ) order by oid");
+ "'bool', 'geometry', 'topogeometry') order by oid");
if (!res || PQresultStatus(res) != PGRES_TUPLES_OK) {
db_d_append_error(_("Unable to select data types"));
@@ -118,6 +118,7 @@
pg_types[row][0] = pgtype;
+ G_debug(3, "row = %d value = %s", row, PQgetvalue(res, row, 1));
if (strcmp(PQgetvalue(res, row, 1), "bit") == 0)
type = PG_TYPE_BIT;
else if (strcmp(PQgetvalue(res, row, 1), "int2") == 0)
@@ -154,6 +155,8 @@
type = PG_TYPE_BOOL;
else if (strcmp(PQgetvalue(res, row, 1), "geometry") == 0)
type = PG_TYPE_POSTGIS_GEOM;
+ else if (strcmp(PQgetvalue(res, row, 1), "topogeometry") == 0)
+ type = PG_TYPE_POSTGIS_TOPOGEOM;
else
type = PG_TYPE_UNKNOWN;
Modified: grass/trunk/db/drivers/postgres/describe.c
--- grass/trunk/db/drivers/postgres/describe.c 2012-04-14 08:56:35 UTC (rev 51439)
+++ grass/trunk/db/drivers/postgres/describe.c 2012-04-14 15:27:52 UTC (rev 51440)
@@ -113,6 +113,11 @@
"will not be converted", fname);
continue;
+ else if (gpgtype == PG_TYPE_POSTGIS_TOPOGEOM) {
+ G_debug(1, "PostgreSQL driver: PostGIS column '%s', type 'topogeometry' "
+ "will not be converted", fname);
+ continue;
else {
/* Warn, ignore and continue */
G_warning(_("PostgreSQL driver: column '%s', type %d is not supported"),
Modified: grass/trunk/db/drivers/postgres/globals.h
--- grass/trunk/db/drivers/postgres/globals.h 2012-04-14 08:56:35 UTC (rev 51439)
+++ grass/trunk/db/drivers/postgres/globals.h 2012-04-14 15:27:52 UTC (rev 51440)
@@ -18,7 +18,7 @@
} PGCONN;
/* PostgreSQL data types defined in GRASS
- (see also: /usr/include/pgsql/server/catalog/pg_type.h)
+ (see also: /usr/include/postgresql/<version>/server/catalog/pg_type.h)
PostGIS types are encoded as 17xxx.
Types/OIDs are fetched in db.c from server.
@@ -48,7 +48,8 @@
PG_TYPE_BOOL, /* bool, boolean */
- PG_TYPE_POSTGIS_GEOM /* geometry column of PostGIS, GRASS internal type */
+ PG_TYPE_POSTGIS_GEOM, /* geometry column of PostGIS, GRASS internal type */
+ PG_TYPE_POSTGIS_TOPOGEOM /* topogeometry column of PostGIS, GRASS internal type */
} PG_TYPES;
