[GRASS-SVN] r51445 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Sat Apr 14 20:48:41 EDT 2012
Author: huhabla
Date: 2012-04-14 17:48:41 -0700 (Sat, 14 Apr 2012)
New Revision: 51445
grass/trunk/lib/python/temporal/space_time_datasets.py
grass/trunk/lib/python/temporal/univar_statistics.py
Univariate statistics for space time vector datasets
Modified: grass/trunk/lib/python/temporal/space_time_datasets.py
--- grass/trunk/lib/python/temporal/space_time_datasets.py 2012-04-14 19:07:52 UTC (rev 51444)
+++ grass/trunk/lib/python/temporal/space_time_datasets.py 2012-04-15 00:48:41 UTC (rev 51445)
@@ -583,9 +583,9 @@
if libvector.Vect_open_old_head2(byref(Map), name, mapset, "1") < 2:
# force level 1, open fully
# NOTE: number of points, lines, boundaries, centroids, faces, kernels is still available
- libvector.Vect_close(byref(Map))
libvector.Vect_set_open_level(1) # no topology
with_topo = False
+ core.message(_("Open map without topology support"))
if libvector.Vect_open_old2(byref(Map), name, mapset, "1") < 1:
core.fatal(_("Unable to open vector map <%s>"%(libvector.Vect_get_full_name(byref(Map)))))
@@ -603,26 +603,33 @@
kvp["is_3d"] = bool(libvector.Vect_is_3d(byref(Map)))
# Read number of features
- kvp["points"] = libvector.Vect_get_num_primitives(byref(Map), libvector.GV_POINT)
- kvp["lines"] = libvector.Vect_get_num_primitives(byref(Map), libvector.GV_LINE)
- kvp["boundaries"] = libvector.Vect_get_num_primitives(byref(Map), libvector.GV_BOUNDARY)
- kvp["centroids"] = libvector.Vect_get_num_primitives(byref(Map), libvector.GV_CENTROID)
- kvp["faces"] = libvector.Vect_get_num_primitives(byref(Map), libvector.GV_FACE)
- kvp["kernels"] = libvector.Vect_get_num_primitives(byref(Map), libvector.GV_KERNEL)
+ if with_topo:
+ kvp["points"] = libvector.Vect_get_num_primitives(byref(Map), libvector.GV_POINT)
+ kvp["lines"] = libvector.Vect_get_num_primitives(byref(Map), libvector.GV_LINE)
+ kvp["boundaries"] = libvector.Vect_get_num_primitives(byref(Map), libvector.GV_BOUNDARY)
+ kvp["centroids"] = libvector.Vect_get_num_primitives(byref(Map), libvector.GV_CENTROID)
+ kvp["faces"] = libvector.Vect_get_num_primitives(byref(Map), libvector.GV_FACE)
+ kvp["kernels"] = libvector.Vect_get_num_primitives(byref(Map), libvector.GV_KERNEL)
- # Summarize the primitives
- kvp["primitives"] = kvp["points"] + kvp["lines"] + kvp["boundaries"] + kvp["centroids"]
- if kvp["is_3d"]:
- kvp["primitives"] += kvp["faces"] + kvp["kernels"]
- # Read topology information
- if with_topo:
+ # Summarize the primitives
+ kvp["primitives"] = kvp["points"] + kvp["lines"] + kvp["boundaries"] + kvp["centroids"]
+ if kvp["is_3d"]:
+ kvp["primitives"] += kvp["faces"] + kvp["kernels"]
+ # Read topology information
kvp["nodes"] = libvector.Vect_get_num_nodes(byref(Map))
kvp["areas"] = libvector.Vect_get_num_areas(byref(Map))
kvp["islands"] = libvector.Vect_get_num_islands(byref(Map))
kvp["holes"] = libvector.Vect_get_num_holes(byref(Map))
kvp["volumes"] = libvector.Vect_get_num_primitives(byref(Map), libvector.GV_VOLUME)
else:
+ kvp["points"] = None
+ kvp["lines"] = None
+ kvp["boundaries"] = None
+ kvp["centroids"] = None
+ kvp["faces"] = None
+ kvp["kernels"] = None
+ kvp["primitives"] = None
kvp["nodes"] = None
kvp["areas"] = None
kvp["islands"] = None
Modified: grass/trunk/lib/python/temporal/univar_statistics.py
--- grass/trunk/lib/python/temporal/univar_statistics.py 2012-04-14 19:07:52 UTC (rev 51444)
+++ grass/trunk/lib/python/temporal/univar_statistics.py 2012-04-15 00:48:41 UTC (rev 51445)
@@ -23,11 +23,13 @@
from space_time_datasets_tools import *
def print_gridded_dataset_univar_statistics(type, input, where, extended, header, fs):
"""!Print univariate statistics for a space time raster or raster3d dataset
- @param type Must be "strds" or "str3ds"
+ param type Must be "strds" or "str3ds"
@param input The name of the space time dataset
@param where A temporal database where statement
@param extended If True compute extended statistics
@@ -57,8 +59,8 @@
rows = sp.get_registered_maps("id,start_time,end_time", where, "start_time", dbif)
if not rows:
- dbif.close()
- core.fatal(_("Space time %s dataset <%s> is empty") % (sp.get_new_map_instance(None).get_type(), out_id))
+ dbif.close()
+ core.fatal(_("Space time %s dataset <%s> is empty") % (sp.get_new_map_instance(None).get_type(), out_id))
if header == True:
print "id" + fs + "start" + fs + "end" + fs + "mean" + fs + "min" + fs + "max" + fs,
@@ -96,7 +98,99 @@
dbif.close()
-if __name__ == "__main__":
- options, flags = core.parser()
- main()
+def print_vector_dataset_univar_statistics(input, twhere, layer, type, column, where, extended, header, fs):
+ """!Print univariate statistics for a space time raster or raster3d dataset
+ @param input The name of the space time dataset
+ @param twhere A temporal database where statement
+ @param layer The layer number used in case no layer is present in the temporal dataset
+ @param type options: point,line,boundary,centroid,area
+ @param column The name of the attribute column
+ @param where A temporal database where statement
+ @param extended If True compute extended statistics
+ @param header If True print column names as header
+ @param fs Field separator
+ # We need a database interface
+ dbif = sql_database_interface_connection()
+ dbif.connect()
+ mapset = core.gisenv()["MAPSET"]
+ if input.find("@") >= 0:
+ id = input
+ else:
+ id = input + "@" + mapset
+ sp = dataset_factory("stvds", id)
+ if sp.is_in_db(dbif) == False:
+ dbif.close()
+ core.fatal(_("Space time %s dataset <%s> not found") % (sp.get_new_map_instance(None).get_type(), id))
+ sp.select(dbif)
+ rows = sp.get_registered_maps("id,start_time,end_time,layer", twhere, "start_time", dbif)
+ if not rows:
+ dbif.close()
+ string = ""
+ if header == True:
+ string += "id" + fs + "start" + fs + "end" + fs + "n" + fs + "nmissing" + fs + "nnull" + fs
+ string += "min" + fs + "max" + fs + "range"
+ if type == "point" or type == "centroid":
+ string += fs + "mean" + fs + "mean_abs" + fs + "population_stddev" + fs + "population_variance" + fs
+ string += "population_coeff_variation" + fs + "sample_stddev" + fs + "sample_variance" + fs
+ string += "kurtosis" + fs + "skewness"
+ if extended == True:
+ string+= fs + "first_quartile" + fs + "median" + fs + "third_quartile" + fs + "percentile_90"
+ print string
+ for row in rows:
+ id = row["id"]
+ start = row["start_time"]
+ end = row["end_time"]
+ mylayer = row["layer"]
+ flags="g"
+ flags += "e"
+ if not mylayer:
+ mylayer = layer
+ stats = core.parse_command("v.univar", map=id, where=where, column=column, layer=mylayer, type=type, flags=flags)
+ string = ""
+ if stats:
+ string += str(id) + fs + str(start) + fs + str(end)
+ string += fs + str(stats["n"]) + fs + str(stats["nmissing"]) + fs + str(stats["nnull"])
+ if stats.has_key("min"):
+ string += fs + str(stats["min"]) + fs + str(stats["max"]) + fs + str(stats["range"])
+ else:
+ string += fs + fs + fs
+ if stats.has_key("mean"):
+ string += fs + str(stats["mean"]) + fs + str(stats["mean_abs"]) + fs + str(stats["population_stddev"]) + fs + str(stats["population_variance"])
+ string += fs + str(stats["population_coeff_variation"]) + fs + str(stats["sample_stddev"]) + fs + str(stats["sample_variance"])
+ string += fs + str(stats["kurtosis"]) + fs + str(stats["skewness"])
+ else:
+ string += fs + fs + fs + fs + fs + fs + fs + fs + fs
+ if stats.has_key("first_quartile"):
+ string += fs + str(stats["first_quartile"]) + fs + str(stats["median"]) + fs + str(stats["third_quartile"]) + fs + str(stats["percentile_90"])
+ else:
+ print string
+ dbif.close()
