[GRASS-SVN] r51448 -
grass/branches/releasebranch_6_4/vector/v.net.allpairs
svn_grass at osgeo.org
Sun Apr 15 02:53:31 EDT 2012
Author: mmetz
Date: 2012-04-14 23:53:31 -0700 (Sat, 14 Apr 2012)
New Revision: 51448
grass/branches/releasebranch_6_4/vector/v.net.allpairs/description.html
grass/branches/releasebranch_6_4/vector/v.net.allpairs/main.c
update documentation
Modified: grass/branches/releasebranch_6_4/vector/v.net.allpairs/description.html
--- grass/branches/releasebranch_6_4/vector/v.net.allpairs/description.html 2012-04-15 01:03:13 UTC (rev 51447)
+++ grass/branches/releasebranch_6_4/vector/v.net.allpairs/description.html 2012-04-15 06:53:31 UTC (rev 51448)
@@ -3,29 +3,30 @@
<em>v.net.allpairs</em> computes the shortest path between each selected
node and all other selected nodes.
<p>
-<b><font color="red">WARNING:</font></b> This module is experimental
-and will produce unexpected results if the input vector has been
-prepared with <em>v.net</em>. A stable version is available in the next
-version of GRASS (GRASS 7).
+If the input vector has been prepared with <em>v.net</em> and
+<em>v.net.allpairs</em> should use cost columns, further preparation is
+of the input vector required. In contrast to the output of <em>v.net</em>
+and the behaviour of other <em>v.net.*</em> modules, <em>v.net.allpairs</em>
+uses the same layer to read cost columns for arcs and to read node
+categories. Therefore new, unique categories for points must be added
+to the layer with cost columns for lines with <em>v.category</em>.
+<br>
+If <b>abcolumn</b> is not given then then the same costs are used for
+forward and backward arcs.
<h2>NOTES</h2>
-An attribute table is created and linked to <b>layer</b>. The table
+An attribute table is created and linked to layer 1. The table
contains three columns: <em>cat</em>, <em>to_cat</em>, <em>cost</em>.
Each entry denotes the cost of the shortest path from <em>cat</em> to
<em>to_cat</em>. If the cost is negative then no path exists. If points
are specified by <b>cats, layer</b> or <b>where</b> parameters then
-the table is filled only for the selected points. In other words,
-<em>cat</em> columns contains only selected points but the distances
-are computed and updated for <em>all</em> other nodes.<br> If flag
-<b>-a</b> is set then new points are added on nodes without nodes.
-These points have the largest categorie. Precisely, category of each
-new point is larger than any of the old categories. If the flag is not
-set then no new points are created and hence the attribute table
-stores the costs only between the points already present in the input.
-Output consists of all points mentioned in either of the columns.<br>
-If <b>abcolumn</b> is not given then then the same costs are used for
-forward and backward arcs.
+the table is filled only for the selected points.
+<br>
+If the <b>-a</b> flag is set then new points are added on nodes without
+nodes. These points have the largest category. Precisely, the category
+value of each new point is larger than any of the old categories. Note
+that these new points are not included in the output table.
<h2>EXAMPLE</h2>
@@ -67,7 +68,8 @@
<h2>AUTHORS</h2>
Daniel Bundala, Google Summer of Code 2009, Student<br>
-Wolf Bergenheim, Mentor
+Wolf Bergenheim, Mentor<br>
+Markus Metz
<p>
<i>Last changed: $Date$</i>
Modified: grass/branches/releasebranch_6_4/vector/v.net.allpairs/main.c
--- grass/branches/releasebranch_6_4/vector/v.net.allpairs/main.c 2012-04-15 01:03:13 UTC (rev 51447)
+++ grass/branches/releasebranch_6_4/vector/v.net.allpairs/main.c 2012-04-15 06:53:31 UTC (rev 51448)
@@ -4,6 +4,7 @@
* MODULE: v.net.allpairs
* AUTHOR(S): Daniel Bundala
+ * Markus Metz
* PURPOSE: Shortest paths between all nodes
