[GRASS-SVN] r51456 - in grass-web/trunk: . images user_map user_map/image user_map/lib user_map/lib/grass_theme user_map/lib/grass_theme/images user_map/lib/grass_theme/images/box user_map/lib/grass_theme/images/button user_map/lib/grass_theme/images/dd user_map/lib/grass_theme/images/editor user_map/lib/grass_theme/images/form user_map/lib/grass_theme/images/grid user_map/lib/grass_theme/images/layout user_map/lib/grass_theme/images/menu user_map/lib/grass_theme/images/panel user_map/lib/grass_theme/images/progress user_map/lib/grass_theme/images/qtip user_map/lib/grass_theme/images/shared user_map/lib/grass_theme/images/sizer user_map/lib/grass_theme/images/slider user_map/lib/grass_theme/images/tabs user_map/lib/grass_theme/images/toolbar user_map/lib/grass_theme/images/tree user_map/lib/grass_theme/images/window user_map/lib/img user_map/lib/theme user_map/lib/theme/default user_map/lib/theme/default/img
Tue Apr 17 09:42:26 EDT 2012
Author: lucadelu
Date: 2012-04-17 06:42:26 -0700 (Tue, 17 Apr 2012)
New Revision: 51456
Added:
   grass-web/trunk/images/grassusers_small.jpg
   grass-web/trunk/map.inc
   grass-web/trunk/map.php
   grass-web/trunk/user_map/
   grass-web/trunk/user_map/connection.php
   grass-web/trunk/user_map/image/
   grass-web/trunk/user_map/image/email.gif
   grass-web/trunk/user_map/image/grass.png
   grass-web/trunk/user_map/image/icon_pan.png
   grass-web/trunk/user_map/image/icon_zoomfull.png
   grass-web/trunk/user_map/image/icon_zoomin.png
   grass-web/trunk/user_map/image/icon_zoomout.png
   grass-web/trunk/user_map/image/info.png
   grass-web/trunk/user_map/insert.php
   grass-web/trunk/user_map/lib/
   grass-web/trunk/user_map/lib/GeoExt.js
   grass-web/trunk/user_map/lib/OpenLayers_grass.js
   grass-web/trunk/user_map/lib/ext-all.js
   grass-web/trunk/user_map/lib/ext-base.js
   grass-web/trunk/user_map/lib/grass_theme/
   grass-web/trunk/user_map/lib/grass_theme/convert_color_ranges.sh
   grass-web/trunk/user_map/lib/grass_theme/ext-all.css
   grass-web/trunk/user_map/lib/grass_theme/images/
   grass-web/trunk/user_map/lib/grass_theme/images/box/
   grass-web/trunk/user_map/lib/grass_theme/images/box/corners-blue.gif
   grass-web/trunk/user_map/lib/grass_theme/images/box/corners.gif
   grass-web/trunk/user_map/lib/grass_theme/images/box/l-blue.gif
   grass-web/trunk/user_map/lib/grass_theme/images/box/l.gif
   grass-web/trunk/user_map/lib/grass_theme/images/box/r-blue.gif
   grass-web/trunk/user_map/lib/grass_theme/images/box/r.gif
   grass-web/trunk/user_map/lib/grass_theme/images/box/tb-blue.gif
   grass-web/trunk/user_map/lib/grass_theme/images/box/tb.gif
   grass-web/trunk/user_map/lib/grass_theme/images/button/
   grass-web/trunk/user_map/lib/grass_theme/images/button/arrow.gif
   grass-web/trunk/user_map/lib/grass_theme/images/button/btn.gif
   grass-web/trunk/user_map/lib/grass_theme/images/button/group-cs.gif
   grass-web/trunk/user_map/lib/grass_theme/images/button/group-lr.gif
   grass-web/trunk/user_map/lib/grass_theme/images/button/group-tb.gif
   grass-web/trunk/user_map/lib/grass_theme/images/button/s-arrow-b-noline.gif
   grass-web/trunk/user_map/lib/grass_theme/images/button/s-arrow-b.gif
   grass-web/trunk/user_map/lib/grass_theme/images/button/s-arrow-bo.gif
   grass-web/trunk/user_map/lib/grass_theme/images/button/s-arrow-noline.gif
   grass-web/trunk/user_map/lib/grass_theme/images/button/s-arrow-o.gif
   grass-web/trunk/user_map/lib/grass_theme/images/button/s-arrow.gif
   grass-web/trunk/user_map/lib/grass_theme/images/dd/
   grass-web/trunk/user_map/lib/grass_theme/images/dd/drop-add.gif
   grass-web/trunk/user_map/lib/grass_theme/images/dd/drop-no.gif
   grass-web/trunk/user_map/lib/grass_theme/images/dd/drop-yes.gif
   grass-web/trunk/user_map/lib/grass_theme/images/editor/
   grass-web/trunk/user_map/lib/grass_theme/images/editor/tb-sprite.gif
   grass-web/trunk/user_map/lib/grass_theme/images/form/
   grass-web/trunk/user_map/lib/grass_theme/images/form/checkbox.gif
   grass-web/trunk/user_map/lib/grass_theme/images/form/clear-trigger.gif
   grass-web/trunk/user_map/lib/grass_theme/images/form/clear-trigger.psd
   grass-web/trunk/user_map/lib/grass_theme/images/form/date-trigger.gif
   grass-web/trunk/user_map/lib/grass_theme/images/form/date-trigger.psd
   grass-web/trunk/user_map/lib/grass_theme/images/form/error-tip-corners.gif
   grass-web/trunk/user_map/lib/grass_theme/images/form/exclamation.gif
   grass-web/trunk/user_map/lib/grass_theme/images/form/radio.gif
   grass-web/trunk/user_map/lib/grass_theme/images/form/search-trigger.gif
   grass-web/trunk/user_map/lib/grass_theme/images/form/search-trigger.psd
   grass-web/trunk/user_map/lib/grass_theme/images/form/text-bg.gif
   grass-web/trunk/user_map/lib/grass_theme/images/form/trigger-square.gif
   grass-web/trunk/user_map/lib/grass_theme/images/form/trigger-square.psd
   grass-web/trunk/user_map/lib/grass_theme/images/form/trigger-tpl.gif
   grass-web/trunk/user_map/lib/grass_theme/images/form/trigger.gif
   grass-web/trunk/user_map/lib/grass_theme/images/form/trigger.psd
   grass-web/trunk/user_map/lib/grass_theme/images/gradient-bg.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/
   grass-web/trunk/user_map/lib/grass_theme/images/grid/arrow-left-white.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/arrow-right-white.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/col-move-bottom.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/col-move-top.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/columns.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/dirty.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/done.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/drop-no.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/drop-yes.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/footer-bg.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/grid-blue-hd.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/grid-blue-split.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/grid-hrow.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/grid-loading.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/grid-split.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/grid-vista-hd.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/grid3-hd-btn.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/grid3-hrow-over.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/grid3-hrow.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/grid3-rowheader.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/grid3-special-col-bg.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/grid3-special-col-sel-bg.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/group-by.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/group-collapse.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/group-expand-sprite.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/group-expand.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/hd-pop.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/hmenu-asc.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/hmenu-desc.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/hmenu-lock.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/hmenu-lock.png
   grass-web/trunk/user_map/lib/grass_theme/images/grid/hmenu-unlock.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/hmenu-unlock.png
   grass-web/trunk/user_map/lib/grass_theme/images/grid/invalid_line.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/loading.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/mso-hd.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/nowait.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/page-first-disabled.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/page-first.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/page-last-disabled.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/page-last.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/page-next-disabled.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/page-next.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/page-prev-disabled.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/page-prev.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/pick-button.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/refresh-disabled.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/refresh.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/row-check-sprite.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/row-expand-sprite.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/row-over.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/row-sel.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/sort-hd.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/sort_asc.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/sort_desc.gif
   grass-web/trunk/user_map/lib/grass_theme/images/grid/wait.gif
   grass-web/trunk/user_map/lib/grass_theme/images/layout/
   grass-web/trunk/user_map/lib/grass_theme/images/layout/collapse.gif
   grass-web/trunk/user_map/lib/grass_theme/images/layout/expand.gif
   grass-web/trunk/user_map/lib/grass_theme/images/layout/gradient-bg.gif
   grass-web/trunk/user_map/lib/grass_theme/images/layout/mini-bottom.gif
   grass-web/trunk/user_map/lib/grass_theme/images/layout/mini-left.gif
   grass-web/trunk/user_map/lib/grass_theme/images/layout/mini-right.gif
   grass-web/trunk/user_map/lib/grass_theme/images/layout/mini-top.gif
   grass-web/trunk/user_map/lib/grass_theme/images/layout/ns-collapse.gif
   grass-web/trunk/user_map/lib/grass_theme/images/layout/ns-expand.gif
   grass-web/trunk/user_map/lib/grass_theme/images/layout/panel-close.gif
   grass-web/trunk/user_map/lib/grass_theme/images/layout/panel-title-bg.gif
   grass-web/trunk/user_map/lib/grass_theme/images/layout/panel-title-light-bg.gif
   grass-web/trunk/user_map/lib/grass_theme/images/layout/stick.gif
   grass-web/trunk/user_map/lib/grass_theme/images/layout/stuck.gif
   grass-web/trunk/user_map/lib/grass_theme/images/layout/tab-close-on.gif
   grass-web/trunk/user_map/lib/grass_theme/images/layout/tab-close.gif
   grass-web/trunk/user_map/lib/grass_theme/images/menu/
   grass-web/trunk/user_map/lib/grass_theme/images/menu/checked.gif
   grass-web/trunk/user_map/lib/grass_theme/images/menu/group-checked.gif
   grass-web/trunk/user_map/lib/grass_theme/images/menu/item-over.gif
   grass-web/trunk/user_map/lib/grass_theme/images/menu/menu-parent.gif
   grass-web/trunk/user_map/lib/grass_theme/images/menu/menu.gif
   grass-web/trunk/user_map/lib/grass_theme/images/menu/unchecked.gif
   grass-web/trunk/user_map/lib/grass_theme/images/panel/
   grass-web/trunk/user_map/lib/grass_theme/images/panel/corners-sprite.gif
   grass-web/trunk/user_map/lib/grass_theme/images/panel/left-right.gif
   grass-web/trunk/user_map/lib/grass_theme/images/panel/light-hd.gif
   grass-web/trunk/user_map/lib/grass_theme/images/panel/tool-sprite-tpl.gif
   grass-web/trunk/user_map/lib/grass_theme/images/panel/tool-sprites.gif
   grass-web/trunk/user_map/lib/grass_theme/images/panel/tools-sprites-trans.gif
   grass-web/trunk/user_map/lib/grass_theme/images/panel/top-bottom.gif
   grass-web/trunk/user_map/lib/grass_theme/images/panel/top-bottom.png
   grass-web/trunk/user_map/lib/grass_theme/images/panel/white-corners-sprite.gif
   grass-web/trunk/user_map/lib/grass_theme/images/panel/white-left-right.gif
   grass-web/trunk/user_map/lib/grass_theme/images/panel/white-top-bottom.gif
   grass-web/trunk/user_map/lib/grass_theme/images/progress/
   grass-web/trunk/user_map/lib/grass_theme/images/progress/progress-bg.gif
   grass-web/trunk/user_map/lib/grass_theme/images/qtip/
   grass-web/trunk/user_map/lib/grass_theme/images/qtip/bg.gif
   grass-web/trunk/user_map/lib/grass_theme/images/qtip/close.gif
   grass-web/trunk/user_map/lib/grass_theme/images/qtip/tip-anchor-sprite.gif
   grass-web/trunk/user_map/lib/grass_theme/images/qtip/tip-sprite.gif
   grass-web/trunk/user_map/lib/grass_theme/images/s.gif
   grass-web/trunk/user_map/lib/grass_theme/images/shadow-c.png
   grass-web/trunk/user_map/lib/grass_theme/images/shadow-lr.png
   grass-web/trunk/user_map/lib/grass_theme/images/shadow.png
   grass-web/trunk/user_map/lib/grass_theme/images/shared/
   grass-web/trunk/user_map/lib/grass_theme/images/shared/blue-loading.gif
   grass-web/trunk/user_map/lib/grass_theme/images/shared/calendar.gif
   grass-web/trunk/user_map/lib/grass_theme/images/shared/glass-bg.gif
   grass-web/trunk/user_map/lib/grass_theme/images/shared/hd-sprite.gif
   grass-web/trunk/user_map/lib/grass_theme/images/shared/large-loading.gif
   grass-web/trunk/user_map/lib/grass_theme/images/shared/left-btn.gif
   grass-web/trunk/user_map/lib/grass_theme/images/shared/loading-balls.gif
   grass-web/trunk/user_map/lib/grass_theme/images/shared/right-btn.gif
   grass-web/trunk/user_map/lib/grass_theme/images/shared/warning.gif
   grass-web/trunk/user_map/lib/grass_theme/images/sizer/
   grass-web/trunk/user_map/lib/grass_theme/images/sizer/e-handle-dark.gif
   grass-web/trunk/user_map/lib/grass_theme/images/sizer/e-handle.gif
   grass-web/trunk/user_map/lib/grass_theme/images/sizer/ne-handle-dark.gif
   grass-web/trunk/user_map/lib/grass_theme/images/sizer/ne-handle.gif
   grass-web/trunk/user_map/lib/grass_theme/images/sizer/nw-handle-dark.gif
   grass-web/trunk/user_map/lib/grass_theme/images/sizer/nw-handle.gif
   grass-web/trunk/user_map/lib/grass_theme/images/sizer/s-handle-dark.gif
   grass-web/trunk/user_map/lib/grass_theme/images/sizer/s-handle.gif
   grass-web/trunk/user_map/lib/grass_theme/images/sizer/se-handle-dark.gif
   grass-web/trunk/user_map/lib/grass_theme/images/sizer/se-handle.gif
   grass-web/trunk/user_map/lib/grass_theme/images/sizer/square.gif
   grass-web/trunk/user_map/lib/grass_theme/images/sizer/sw-handle-dark.gif
   grass-web/trunk/user_map/lib/grass_theme/images/sizer/sw-handle.gif
   grass-web/trunk/user_map/lib/grass_theme/images/slider/
   grass-web/trunk/user_map/lib/grass_theme/images/slider/slider-bg.png
   grass-web/trunk/user_map/lib/grass_theme/images/slider/slider-thumb.png
   grass-web/trunk/user_map/lib/grass_theme/images/slider/slider-v-bg.png
   grass-web/trunk/user_map/lib/grass_theme/images/slider/slider-v-thumb.png
   grass-web/trunk/user_map/lib/grass_theme/images/tabs/
   grass-web/trunk/user_map/lib/grass_theme/images/tabs/scroll-left.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tabs/scroll-right.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tabs/scroller-bg.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tabs/tab-btm-inactive-left-bg.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tabs/tab-btm-inactive-right-bg.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tabs/tab-btm-left-bg.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tabs/tab-btm-over-left-bg.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tabs/tab-btm-over-right-bg.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tabs/tab-btm-right-bg.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tabs/tab-close.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tabs/tab-strip-bg.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tabs/tab-strip-bg.png
   grass-web/trunk/user_map/lib/grass_theme/images/tabs/tab-strip-btm-bg.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tabs/tabs-sprite.gif
   grass-web/trunk/user_map/lib/grass_theme/images/toolbar/
   grass-web/trunk/user_map/lib/grass_theme/images/toolbar/bg.gif
   grass-web/trunk/user_map/lib/grass_theme/images/toolbar/btn-arrow-light.gif
   grass-web/trunk/user_map/lib/grass_theme/images/toolbar/btn-arrow.gif
   grass-web/trunk/user_map/lib/grass_theme/images/toolbar/btn-over-bg.gif
   grass-web/trunk/user_map/lib/grass_theme/images/toolbar/gray-bg.gif
   grass-web/trunk/user_map/lib/grass_theme/images/toolbar/more.gif
   grass-web/trunk/user_map/lib/grass_theme/images/toolbar/tb-bg.gif
   grass-web/trunk/user_map/lib/grass_theme/images/toolbar/tb-btn-sprite.gif
   grass-web/trunk/user_map/lib/grass_theme/images/toolbar/tb-xl-btn-sprite.gif
   grass-web/trunk/user_map/lib/grass_theme/images/toolbar/tb-xl-sep.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tree/
   grass-web/trunk/user_map/lib/grass_theme/images/tree/arrows.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tree/drop-add.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tree/drop-between.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tree/drop-no.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tree/drop-over.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tree/drop-under.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tree/drop-yes.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow-end-minus-nl.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow-end-minus.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow-end-plus-nl.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow-end-plus.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow-end.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow-line.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow-minus-nl.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow-minus.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow-plus-nl.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow-plus.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tree/folder-open.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tree/folder.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tree/leaf.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tree/loading.gif
   grass-web/trunk/user_map/lib/grass_theme/images/tree/s.gif
   grass-web/trunk/user_map/lib/grass_theme/images/window/
   grass-web/trunk/user_map/lib/grass_theme/images/window/icon-error.gif
   grass-web/trunk/user_map/lib/grass_theme/images/window/icon-info.gif
   grass-web/trunk/user_map/lib/grass_theme/images/window/icon-question.gif
   grass-web/trunk/user_map/lib/grass_theme/images/window/icon-warning.gif
   grass-web/trunk/user_map/lib/grass_theme/images/window/left-corners.png
   grass-web/trunk/user_map/lib/grass_theme/images/window/left-corners.psd
   grass-web/trunk/user_map/lib/grass_theme/images/window/left-right.png
   grass-web/trunk/user_map/lib/grass_theme/images/window/left-right.psd
   grass-web/trunk/user_map/lib/grass_theme/images/window/right-corners.png
   grass-web/trunk/user_map/lib/grass_theme/images/window/right-corners.psd
   grass-web/trunk/user_map/lib/grass_theme/images/window/top-bottom.png
   grass-web/trunk/user_map/lib/grass_theme/images/window/top-bottom.psd
   grass-web/trunk/user_map/lib/img/
   grass-web/trunk/user_map/lib/img/blank.gif
   grass-web/trunk/user_map/lib/img/cloud-popup-relative.png
   grass-web/trunk/user_map/lib/img/drag-rectangle-off.png
   grass-web/trunk/user_map/lib/img/drag-rectangle-on.png
   grass-web/trunk/user_map/lib/img/east-mini.png
   grass-web/trunk/user_map/lib/img/layer-switcher-maximize.png
   grass-web/trunk/user_map/lib/img/layer-switcher-minimize.png
   grass-web/trunk/user_map/lib/img/marker-blue.png
   grass-web/trunk/user_map/lib/img/marker-gold.png
   grass-web/trunk/user_map/lib/img/marker-green.png
   grass-web/trunk/user_map/lib/img/marker.png
   grass-web/trunk/user_map/lib/img/measuring-stick-off.png
   grass-web/trunk/user_map/lib/img/measuring-stick-on.png
   grass-web/trunk/user_map/lib/img/north-mini.png
   grass-web/trunk/user_map/lib/img/panning-hand-off.png
   grass-web/trunk/user_map/lib/img/panning-hand-on.png
   grass-web/trunk/user_map/lib/img/slider.png
   grass-web/trunk/user_map/lib/img/south-mini.png
   grass-web/trunk/user_map/lib/img/west-mini.png
   grass-web/trunk/user_map/lib/img/zoom-minus-mini.png
   grass-web/trunk/user_map/lib/img/zoom-plus-mini.png
   grass-web/trunk/user_map/lib/img/zoom-world-mini.png
   grass-web/trunk/user_map/lib/img/zoombar.png
   grass-web/trunk/user_map/lib/theme/
   grass-web/trunk/user_map/lib/theme/default/
   grass-web/trunk/user_map/lib/theme/default/framedCloud.css
   grass-web/trunk/user_map/lib/theme/default/google.css
   grass-web/trunk/user_map/lib/theme/default/google.tidy.css
   grass-web/trunk/user_map/lib/theme/default/ie6-style.css
   grass-web/trunk/user_map/lib/theme/default/ie6-style.tidy.css
   grass-web/trunk/user_map/lib/theme/default/img/
   grass-web/trunk/user_map/lib/theme/default/img/add_point_off.png
   grass-web/trunk/user_map/lib/theme/default/img/add_point_on.png
   grass-web/trunk/user_map/lib/theme/default/img/blank.gif
   grass-web/trunk/user_map/lib/theme/default/img/close.gif
   grass-web/trunk/user_map/lib/theme/default/img/drag-rectangle-off.png
   grass-web/trunk/user_map/lib/theme/default/img/drag-rectangle-on.png
   grass-web/trunk/user_map/lib/theme/default/img/draw_line_off.png
   grass-web/trunk/user_map/lib/theme/default/img/draw_line_on.png
   grass-web/trunk/user_map/lib/theme/default/img/draw_point_off.png
   grass-web/trunk/user_map/lib/theme/default/img/draw_point_on.png
   grass-web/trunk/user_map/lib/theme/default/img/draw_polygon_off.png
   grass-web/trunk/user_map/lib/theme/default/img/draw_polygon_on.png
   grass-web/trunk/user_map/lib/theme/default/img/editing_tool_bar.png
   grass-web/trunk/user_map/lib/theme/default/img/move_feature_off.png
   grass-web/trunk/user_map/lib/theme/default/img/move_feature_on.png
   grass-web/trunk/user_map/lib/theme/default/img/navigation_history.png
   grass-web/trunk/user_map/lib/theme/default/img/overview_replacement.gif
   grass-web/trunk/user_map/lib/theme/default/img/pan-panel-NOALPHA.png
   grass-web/trunk/user_map/lib/theme/default/img/pan-panel.png
   grass-web/trunk/user_map/lib/theme/default/img/pan_off.png
   grass-web/trunk/user_map/lib/theme/default/img/pan_on.png
   grass-web/trunk/user_map/lib/theme/default/img/panning-hand-off.png
   grass-web/trunk/user_map/lib/theme/default/img/panning-hand-on.png
   grass-web/trunk/user_map/lib/theme/default/img/remove_point_off.png
   grass-web/trunk/user_map/lib/theme/default/img/remove_point_on.png
   grass-web/trunk/user_map/lib/theme/default/img/ruler.png
   grass-web/trunk/user_map/lib/theme/default/img/save_features_off.png
   grass-web/trunk/user_map/lib/theme/default/img/save_features_on.png
   grass-web/trunk/user_map/lib/theme/default/img/view_next_off.png
   grass-web/trunk/user_map/lib/theme/default/img/view_next_on.png
   grass-web/trunk/user_map/lib/theme/default/img/view_previous_off.png
   grass-web/trunk/user_map/lib/theme/default/img/view_previous_on.png
   grass-web/trunk/user_map/lib/theme/default/img/zoom-panel-NOALPHA.png
   grass-web/trunk/user_map/lib/theme/default/img/zoom-panel.png
   grass-web/trunk/user_map/lib/theme/default/style.css
   grass-web/trunk/user_map/lib/theme/default/style.tidy.css
   grass-web/trunk/user_map/n_users.php
   grass-web/trunk/user_map/read_spatialite.php
   grass-web/trunk/user_map/user_grass.sqlite
   grass-web/trunk/user_map/user_map.js
   grass-web/trunk/main.inc
   grass-web/trunk/sitestyle.css
new grass user map
Added: grass-web/trunk/images/grassusers_small.jpg
(Binary files differ)
Property changes on: grass-web/trunk/images/grassusers_small.jpg
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Modified: grass-web/trunk/main.inc
--- grass-web/trunk/main.inc	2012-04-17 12:53:28 UTC (rev 51455)
+++ grass-web/trunk/main.inc	2012-04-17 13:42:26 UTC (rev 51456)
@@ -12,15 +12,8 @@
 </td>
 <td valign="top">
  <center>
-<!-- mapserver temporarily broken
- <a href="javascript:openPmapper(890, 630, 1, '&mapwidth=600&mapheight=400')">
- <a href="images/grassusers_big.jpg">
- <img src="images/grassusers_small.jpg" alt="GRASS users map" border="0" hspace="5"></a><br>
- <small>&nbsp;&nbsp;<i>GRASS User map
-<!-- (<a href="http://mapserver.gdf-hannover.de/grassusers/map.phtml?winwidth=890&winheight=630&language=1&mapwidth=600&mapheight=400">without pop-up</a>)
- </i></small>
+ <a href="http://grass.osgeo.org/map.php"><img src="images/grassusers_small.jpg" alt="GRASS users map" border="0" hspace="5"></a><br>
+ <small>&nbsp;&nbsp;<i>GRASS GIS User map</i></small>
  </center>
 </td>
 <td valign="top">
@@ -44,20 +37,6 @@
 the <a href="http://www.osgeo.org/">Open Source Geospatial Foundation</a>.
 <p>
-<SCRIPT LANGUAGE="JavaScript" type="text/javascript">
-  function openPmapper(winwidth, winheight, gLanguage, startParameters)
-  { var mapurl = "http://mapserver.gdf-hannover.de/grassusers/map.phtml?winwidth=" +
-        winwidth + "&winheight=" + winheight + "&language=" + gLanguage + startParameters;
-    var maptitle = "GRASS Usermap with pmapper";
-    var options  = "width=" + winwidth + ",height="
-        + winheight + ",menubar=no,scrollbars=yes,resizable=yes," +
-                        "top=0,left=0,status=yes";
-        myw = window.open(mapurl, maptitle, options);
-</SCRIPT>
 <center>
 <table border=1 width="50%" CELLPADDING=5>
 <tr>
Added: grass-web/trunk/map.inc
--- grass-web/trunk/map.inc	                        (rev 0)
+++ grass-web/trunk/map.inc	2012-04-17 13:42:26 UTC (rev 51456)
@@ -0,0 +1,4 @@
+<center>
+    <div id="mappanel"></div>
+</center>
Added: grass-web/trunk/map.php
--- grass-web/trunk/map.php	                        (rev 0)
+++ grass-web/trunk/map.php	2012-04-17 13:42:26 UTC (rev 51456)
@@ -0,0 +1,153 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+  <title>GRASS GIS - The World Leading Free Software GIS</title>
+  <meta name="robots" content="index,follow">
+  <meta name="description"
+        content="GRASS GIS (Geographic Resources Analysis Support System) is an open source,
+	 free software (FOSS) Geographical Information System (GIS) with raster, topological
+         vector, image processing, and visualization functionality">
+  <meta name="keywords"
+        content="open source gps, GRASS, FOSS, open source gis, open source gis grass, open source web gis, open source gis software, free open source gis, gis, mapping, open source software, mapping software, cartography, gis data, geospatial, open source 3d, geographic information system, geographic information systems, gis software, mapping data, free software, raster, topology, vector, image processing, visualization, hydrology, archeology, archaeology, 3D GIS">
+  <meta name="Author" content="GRASS Development Team">
+  <meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1">
+  <link rel="stylesheet" href="sitestyle.css" type="text/css">
+  <link rel="alternate" type="application/rss+xml" title="RSS" href="rss.xml">
+  <script src="user_map/lib/ext-base.js" type="text/javascript"></script>
+  <script src="user_map/lib/ext-all.js"  type="text/javascript"></script>
+  <script src="user_map/lib/OpenLayers_grass.js" type="text/javascript"></script>
+  <script src="user_map/lib/GeoExt.js" type="text/javascript"></script>
+  <script src="user_map/user_map.js" type="text/javascript"></script>
+</head>
+<body>
+   <!-- TOP LOGO LINE -->
+<table bgcolor="#ffffff" cellspacing="0" cellpadding="0" border="0" width="100%">
+ <tbody>
+ <tr><td>
+   <table cellspacing="1" cellpadding="0" border="0" width="100%" >
+   <tbody>
+      <tr bgcolor="#ffffff">
+       <td nowrap="nowrap"> <img src="images/grasslogo_vector_tiny.png" alt="GRASS GIS (Geographic Resources Analysis Support System)" hspace="22">
+       </td>
+          <table cellspacing="0" cellpadding="1" border="0" width="100%">
+          <tbody>
+                <center><br>
+                  <h1>Welcome to GRASS GIS</h1>
+<?php
+// avoid PHP warning noise
+error_reporting(1);
+if ( $MYIP != "202.158.214.106" ) {
+ if (function_exists('curl_init')) {
+  $ch = curl_init();
+  $MYIP = $_SERVER['SERVER_ADDR'];
+  $timeout = 5; // set to zero for no timeout
+  curl_setopt ($ch, CURLOPT_URL, "http://api.hostip.info/get_html.php?ip=$MYIP");
+  curl_setopt ($ch, CURLOPT_RETURNTRANSFER, 1);
+  curl_setopt ($ch, CURLOPT_CONNECTTIMEOUT, $timeout);
+  $file_contents = curl_exec($ch);
+  curl_close($ch);
+  if (!$file_contents) {
+     echo "<font size=\"-1\"><i>You are at an official GRASS site (other <a href=\"mirrors.php\">mirror sites</a>)<br>";
+  } else {
+     if (preg_match("/Internal Server Error/i", $file_contents)) {
+     } else {
+      // e.g.: "Country: UNITED STATES (US) City: San Diego, CA"
+      $MYSTATETMP = explode(":", $file_contents);
+      $MYSTATETMP2 = explode(")", $MYSTATETMP[1]);
+      $MYSTATE = $MYSTATETMP2[0] . ")";
+      if ($MYIP == "140.211.15.75") {
+	echo "<font size=\"-1\"><i>You are at the official GRASS site in $MYSTATE
+                   (<a href=\"mirrors.php\">mirror sites</a>)<br>";
+      } else {
+	echo "<font size=\"-1\"><i>You are at a GRASS mirror site in $MYSTATE (other <a href=\"mirrors.php\">mirror sites</a>)<br>";
+ } elseif (function_exists('fopen') && allow_url_fopen ) {
+     $file = fopen ("http://api.hostip.info/get_html.php?ip=$MYIP", "r");
+     if (!$file) {
+                   <a href=\"mirrors.php\">mirror sites</a>)<br>";
+     } else {
+	 $line = fgets ($file, 34);
+	 $MYSTATETMP = explode(":", $line);
+	 $MYSTATE = $MYSTATETMP[1];
+	 } else {
+	 fclose($file);
+ } else {
+	   (other <a href=\"mirrors.php\">mirror sites</a>)<br>";
+                   This site is updated daily: LASTUPDATED</i> <!-- processed by cron/sed -->
+                   </font>
+		</center>
+              </td>
+            </tr>
+          </tbody>
+          </table>
+       </td>
+      </tr>
+    </tbody>
+    </table>
+   </td>
+  </tr>
+ </tbody>
+</table>
+<table cellspacing="0" cellpadding="1" border="0" width="100%">
+<tbody>
+ <tr>
+    <td valign="top">
+    <?php
+        include("main_menu_search.inc");
+   </td>
+   <td valign="top">
+     <?php
+       include("main_menu_top.inc");
+   </td>
+ </tr>
+ <tr>
+  <td valign="top">
+     <?php
+       include("main_menu_side.inc");
+   </td>
+  <td valign="top" class="leftmenu"> <!-- MAIN PART -->
+     <?php
+       include("map.inc");
+   <!-- END MAIN PART -->
+  </td>
+ </tr>
+ </tbody>
+</table>
+<hr>
+   <div align="right">&copy; 1999-2012 GRASS Development Team<br>
+   <a href="impressum.html">Imprint</a> |
+   <a href="contact.php">Comments</a> about this page
+   </div>
+</body>
+</html>
Modified: grass-web/trunk/sitestyle.css
--- grass-web/trunk/sitestyle.css	2012-04-17 12:53:28 UTC (rev 51455)
+++ grass-web/trunk/sitestyle.css	2012-04-17 13:42:26 UTC (rev 51456)
@@ -60,3 +60,56 @@
         -moz-border-radius: 6px ;
+.pan {
+    background-image: url(user_map/image/icon_pan.png) !important;
+    height: 20px !important;
+    width: 20px !important;
+.infobox {
+    background-image: url(user_map/image/info.png) !important;
+.addbox {
+    background-image: url(user_map/image/grass.png) !important;
+    height: 22px !important;
+.zoommax {
+    background-image: url(user_map/image/icon_zoomfull.png) !important;
+.zoomin {
+    background-image:url(user_map/image/icon_zoomin.png) !important;
+    height:20px !important;
+    width:20px !important;
+.zoomout {
+    background-image:url(user_map/image/icon_zoomout.png) !important;
+div.olControlAttribution {
+	position: absolute;
+	font-size: 1em;
+	top: 10;
+	left: 35;
+	color: rgb(50,102,0);
+div.olControlPermalink {
+	font-size: 1em;
+	bottom: 10;
+	right: 5;
+div.olControlMousePosition {
+	font-family: Verdana;
+	font-size: 1em;
+	bottom: 25;
+	right: 5;
Added: grass-web/trunk/user_map/connection.php
--- grass-web/trunk/user_map/connection.php	                        (rev 0)
+++ grass-web/trunk/user_map/connection.php	2012-04-17 13:42:26 UTC (rev 51456)
@@ -0,0 +1,12 @@
+<?php
+// $grassuserdb = new PDO('sqlite:/var/www/grass-web/user_map/user_grass.sqlite');
+$grassuserdb = new SQLite3('/var/www/grass-web/user_map/user_grass.sqlite');
+if (!$grassuserdb){
+	echo "{success: false, errors: {reason: 'Error opening database'}}";
+	exit;
Property changes on: grass-web/trunk/user_map/connection.php
Added: svn:executable
Added: grass-web/trunk/user_map/image/email.gif
Property changes on: grass-web/trunk/user_map/image/email.gif
Added: grass-web/trunk/user_map/image/grass.png
Property changes on: grass-web/trunk/user_map/image/grass.png
Added: grass-web/trunk/user_map/image/icon_pan.png
Property changes on: grass-web/trunk/user_map/image/icon_pan.png
Added: grass-web/trunk/user_map/image/icon_zoomfull.png
Property changes on: grass-web/trunk/user_map/image/icon_zoomfull.png
Added: grass-web/trunk/user_map/image/icon_zoomin.png
Property changes on: grass-web/trunk/user_map/image/icon_zoomin.png
Added: grass-web/trunk/user_map/image/icon_zoomout.png
Property changes on: grass-web/trunk/user_map/image/icon_zoomout.png
Added: grass-web/trunk/user_map/image/info.png
Property changes on: grass-web/trunk/user_map/image/info.png
Added: grass-web/trunk/user_map/insert.php
--- grass-web/trunk/user_map/insert.php	                        (rev 0)
+++ grass-web/trunk/user_map/insert.php	2012-04-17 13:42:26 UTC (rev 51456)
@@ -0,0 +1,29 @@
+<?php
+# required for connection
+require_once 'connection.php';
+# load spatialite library
+$grassuserdb->loadExtension('libspatialite.so');
+# read data from the form
+$name=pg_escape_string($_POST["uname"]);
+$istitute=pg_escape_string($_POST["iname"]);
+$lat=$_POST["lat"];
+$long=$_POST["long"];
+# some check
+if ($name == "test" or $istitute == "test"){
+    exit("{success: false, errors: {reason: 'It is not possible to use \'test\' as value'}}");
+} else if ($name == $istitute){
+    exit("{success: false, errors: {reason: 'Values for user and institute may not be the same'}}");
+# try to load data on spatialite database
+try {
+    $grassuserdb->exec("INSERT INTO users (name, company, x, y, data_insert) VALUES ('$name', '$istitute', $long, $lat, datetime('now'))");
+} catch (Exception $e) {
+    exit("{success: false, errors: {reason: 'Error during insert; $e'}}");
+# update geometry column
+$grassuserdb->exec("update users set geom = GeomFromText('POINT(' || x ||' '|| y || ')',4326)");
+$grassuserdb->close();
+echo "{success: true}";
Property changes on: grass-web/trunk/user_map/insert.php
Added: grass-web/trunk/user_map/lib/GeoExt.js
--- grass-web/trunk/user_map/lib/GeoExt.js	                        (rev 0)
+++ grass-web/trunk/user_map/lib/GeoExt.js	2012-04-17 13:42:26 UTC (rev 51456)
@@ -0,0 +1,360 @@
+Copyright (c) 2008-2011, The Open Source Geospatial Foundation
+All rights reserved.
+Redistribution and use in source and binary forms, with or without
+modification, are permitted provided that the following conditions are met:
+    * Redistributions of source code must retain the above copyright notice,
+      this list of conditions and the following disclaimer.
+    * Redistributions in binary form must reproduce the above copyright
+      notice, this list of conditions and the following disclaimer in the
+      documentation and/or other materials provided with the distribution.
+    * Neither the name of the Open Source Geospatial Foundation nor the names
+      of its contributors may be used to endorse or promote products derived
+      from this software without specific prior written permission.
+THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+POSSIBILITY OF SUCH DAMAGE.
+Ext.namespace('GeoExt');GeoExt.LayerLegend=Ext.extend(Ext.Container,{layerRecord:null,showTitle:true,legendTitle:null,labelCls:null,layerStore:null,initComponent:function(){GeoExt.LayerLegend.superclass.initComponent.call(this);this.autoEl={};this.add({xtype:"label",html:this.getLayerTitle(this.layerRecord),cls:'x-form-item x-form-item-label'+
+(this.labelCls?' '+this.labelCls:'')});if(this.layerRecord&&this.layerRecord.store){this.layerStore=this.layerRecord.store;this.layerStore.on("update",this.onStoreUpdate,this);this.layerStore.on("add",this.onStoreAdd,this);this.layerStore.on("remove",this.onStoreRemove,this);}},getLabel:function(){var label=this.items.get(0);return label.rendered?label.el.dom.innerHTML:label.html;},onStoreRemove:function(store,record,index){},onStoreAdd:function(store,record,index){},onStoreUpdate:function(store,record,operation){if(record===this.layerRecord&&this.items.getCount()>0){var layer=record.getLayer();this.setVisible(layer.getVisibility()&&layer.calculateInRange()&&layer.displayInLayerSwitcher&&!record.get('hideInLegend'));this.update();}},update:function(){var title=this.getLayerTitle(this.layerRecord);var item=this.items.get(0);if(item instanceof Ext.form.Label&&this.getLabel()!==title){item.setText(title,false);}},getLayerTitle:function(record){var title=this.legendTitle||"";if(
 this.showTitle&&!title){if(record&&!record.get("hideTitle")){title=record.get("title")||record.get("name")||record.getLayer().name||"";}}
+return title;},beforeDestroy:function(){if(this.layerStore){this.layerStore.un("update",this.onStoreUpdate,this);this.layerStore.un("remove",this.onStoreRemove,this);this.layerStore.un("add",this.onStoreAdd,this);}
+GeoExt.LayerLegend.superclass.beforeDestroy.apply(this,arguments);},onDestroy:function(){this.layerRecord=null;this.layerStore=null;GeoExt.LayerLegend.superclass.onDestroy.apply(this,arguments);}});GeoExt.LayerLegend.getTypes=function(layerRecord,preferredTypes){var types=(preferredTypes||[]).concat(),scoredTypes=[],score,type;for(type in GeoExt.LayerLegend.types){score=GeoExt.LayerLegend.types[type].supports(layerRecord);if(score>0){if(types.indexOf(type)==-1){scoredTypes.push({type:type,score:score});}}else{types.remove(type);}}
+scoredTypes.sort(function(a,b){return a.score<b.score?1:(a.score==b.score?0:-1);});var len=scoredTypes.length,goodTypes=new Array(len);for(var i=0;i<len;++i){goodTypes[i]=scoredTypes[i].type;}
+return types.concat(goodTypes);};GeoExt.LayerLegend.supports=function(layerRecord){};GeoExt.LayerLegend.types={};Ext.namespace('GeoExt');GeoExt.VectorLegend=Ext.extend(GeoExt.LayerLegend,{layerRecord:null,layer:null,rules:null,symbolType:null,untitledPrefix:"Untitled ",clickableSymbol:false,clickableTitle:false,selectOnClick:false,enableDD:false,bodyBorder:false,feature:null,selectedRule:null,currentScaleDenominator:null,initComponent:function(){GeoExt.VectorLegend.superclass.initComponent.call(this);if(this.layerRecord){this.layer=this.layerRecord.getLayer();if(this.layer.map){this.map=this.layer.map;this.currentScaleDenominator=this.layer.map.getScale();this.layer.map.events.on({"zoomend":this.onMapZoom,scope:this});}}
+if(!this.symbolType){if(this.feature){this.symbolType=this.symbolTypeFromFeature(this.feature);}else if(this.layer){if(this.layer.features.length>0){var feature=this.layer.features[0].clone();feature.attributes={};this.feature=feature;this.symbolType=this.symbolTypeFromFeature(this.feature);}else{this.layer.events.on({featuresadded:this.onFeaturesAdded,scope:this});}}}
+if(this.layer&&this.feature&&!this.rules){this.setRules();}
+this.rulesContainer=new Ext.Container({autoEl:{}});this.add(this.rulesContainer);this.addEvents("titleclick","symbolclick","ruleclick","ruleselected","ruleunselected","rulemoved");this.update();},onMapZoom:function(){this.setCurrentScaleDenominator(this.layer.map.getScale());},symbolTypeFromFeature:function(feature){var match=feature.geometry.CLASS_NAME.match(/Point|Line|Polygon/);return(match&&match[0])||"Point";},onFeaturesAdded:function(){this.layer.events.un({featuresadded:this.onFeaturesAdded,scope:this});var feature=this.layer.features[0].clone();feature.attributes={};this.feature=feature;this.symbolType=this.symbolTypeFromFeature(this.feature);if(!this.rules){this.setRules();}
+this.update();},setRules:function(){var style=this.layer.styleMap&&this.layer.styleMap.styles["default"];if(!style){style=new OpenLayers.Style();}
+if(style.rules.length===0){this.rules=[new OpenLayers.Rule({title:style.title,symbolizer:style.createSymbolizer(this.feature)})];}else{this.rules=style.rules;}},setCurrentScaleDenominator:function(scale){if(scale!==this.currentScaleDenominator){this.currentScaleDenominator=scale;this.update();}},getRuleEntry:function(rule){return this.rulesContainer.items.get(this.rules.indexOf(rule));},addRuleEntry:function(rule,noDoLayout){this.rulesContainer.add(this.createRuleEntry(rule));if(!noDoLayout){this.doLayout();}},removeRuleEntry:function(rule,noDoLayout){var ruleEntry=this.getRuleEntry(rule);if(ruleEntry){this.rulesContainer.remove(ruleEntry);if(!noDoLayout){this.doLayout();}}},selectRuleEntry:function(rule){var newSelection=rule!=this.selectedRule;if(this.selectedRule){this.unselect();}
+if(newSelection){var ruleEntry=this.getRuleEntry(rule);ruleEntry.body.addClass("x-grid3-row-selected");this.selectedRule=rule;this.fireEvent("ruleselected",this,rule);}},unselect:function(){this.rulesContainer.items.each(function(item,i){if(this.rules[i]==this.selectedRule){item.body.removeClass("x-grid3-row-selected");this.selectedRule=null;this.fireEvent("ruleunselected",this,this.rules[i]);}},this);},createRuleEntry:function(rule){var applies=true;if(this.currentScaleDenominator!=null){if(rule.minScaleDenominator){applies=applies&&(this.currentScaleDenominator>=rule.minScaleDenominator);}
+if(rule.maxScaleDenominator){applies=applies&&(this.currentScaleDenominator<rule.maxScaleDenominator);}}
+return{xtype:"panel",layout:"column",border:false,hidden:!applies,bodyStyle:this.selectOnClick?{cursor:"pointer"}:undefined,defaults:{border:false},items:[this.createRuleRenderer(rule),this.createRuleTitle(rule)],listeners:{render:function(comp){this.selectOnClick&&comp.getEl().on({click:function(comp){this.selectRuleEntry(rule);},scope:this});if(this.enableDD==true){this.addDD(comp);}},scope:this}};},createRuleRenderer:function(rule){var types=[this.symbolType,"Point","Line","Polygon"];var type,haveType;var symbolizers=rule.symbolizers;if(!symbolizers){var symbolizer=rule.symbolizer;for(var i=0,len=types.length;i<len;++i){type=types[i];if(symbolizer[type]){symbolizer=symbolizer[type];haveType=true;break;}}
+symbolizers=[symbolizer];}else{var Type;outer:for(var i=0,ii=types.length;i<ii;++i){type=types[i];Type=OpenLayers.Symbolizer[type];if(Type){for(var j=0,jj=symbolizers.length;j<jj;++j){if(symbolizers[j]instanceof Type){haveType=true;break outer;}}}}}
+return{xtype:"gx_renderer",symbolType:haveType?type:this.symbolType,symbolizers:symbolizers,style:this.clickableSymbol?{cursor:"pointer"}:undefined,listeners:{click:function(){if(this.clickableSymbol){this.fireEvent("symbolclick",this,rule);this.fireEvent("ruleclick",this,rule);}},scope:this}};},createRuleTitle:function(rule){return{cls:"x-form-item",style:"padding: 0.2em 0.5em 0;",bodyStyle:Ext.applyIf({background:"transparent"},this.clickableTitle?{cursor:"pointer"}:undefined),html:this.getRuleTitle(rule),listeners:{render:function(comp){this.clickableTitle&&comp.getEl().on({click:function(){this.fireEvent("titleclick",this,rule);this.fireEvent("ruleclick",this,rule);},scope:this});},scope:this}};},addDD:function(component){var ct=component.ownerCt;var panel=this;new Ext.dd.DragSource(component.getEl(),{ddGroup:ct.id,onDragOut:function(e,targetId){var target=Ext.getCmp(targetId);target.removeClass("gx-ruledrag-insert-above");target.removeClass("gx-ruledrag-insert-below");r
 eturn Ext.dd.DragZone.prototype.onDragOut.apply(this,arguments);},onDragEnter:function(e,targetId){var target=Ext.getCmp(targetId);var cls;var sourcePos=ct.items.indexOf(component);var targetPos=ct.items.indexOf(target);if(sourcePos>targetPos){cls="gx-ruledrag-insert-above";}else if(sourcePos<targetPos){cls="gx-ruledrag-insert-below";}
+cls&&target.addClass(cls);return Ext.dd.DragZone.prototype.onDragEnter.apply(this,arguments);},onDragDrop:function(e,targetId){panel.moveRule(ct.items.indexOf(component),ct.items.indexOf(Ext.getCmp(targetId)));return Ext.dd.DragZone.prototype.onDragDrop.apply(this,arguments);},getDragData:function(e){var sourceEl=e.getTarget(".x-column-inner");if(sourceEl){var d=sourceEl.cloneNode(true);d.id=Ext.id();return{sourceEl:sourceEl,repairXY:Ext.fly(sourceEl).getXY(),ddel:d}}}});new Ext.dd.DropTarget(component.getEl(),{ddGroup:ct.id,notifyDrop:function(){return true;}});},update:function(){GeoExt.VectorLegend.superclass.update.apply(this,arguments);if(this.symbolType&&this.rules){if(this.rulesContainer.items){var comp;for(var i=this.rulesContainer.items.length-1;i>=0;--i){comp=this.rulesContainer.getComponent(i);this.rulesContainer.remove(comp,true);}}
+for(var i=0,ii=this.rules.length;i<ii;++i){this.addRuleEntry(this.rules[i],true);}
+this.doLayout();if(this.selectedRule){this.getRuleEntry(this.selectedRule).body.addClass("x-grid3-row-selected");}}},updateRuleEntry:function(rule){var ruleEntry=this.getRuleEntry(rule);if(ruleEntry){ruleEntry.removeAll();ruleEntry.add(this.createRuleRenderer(rule));ruleEntry.add(this.createRuleTitle(rule));ruleEntry.doLayout();}},moveRule:function(sourcePos,targetPos){var srcRule=this.rules[sourcePos];this.rules.splice(sourcePos,1);this.rules.splice(targetPos,0,srcRule);this.update();this.fireEvent("rulemoved",this,srcRule);},getRuleTitle:function(rule){var title=rule.title||rule.name||"";if(!title&&this.untitledPrefix){title=this.untitledPrefix+(this.rules.indexOf(rule)+1);}
+return title;},beforeDestroy:function(){if(this.layer){if(this.layer.events){this.layer.events.un({featuresadded:this.onFeaturesAdded,scope:this});}
+if(this.layer.map&&this.layer.map.events){this.layer.map.events.un({"zoomend":this.onMapZoom,scope:this});}}
+delete this.layer;delete this.map;delete this.rules;GeoExt.VectorLegend.superclass.beforeDestroy.apply(this,arguments);},onStoreRemove:function(store,record,index){if(record.getLayer()===this.layer){if(this.map&&this.map.events){this.map.events.un({"zoomend":this.onMapZoom,scope:this});}}},onStoreAdd:function(store,records,index){for(var i=0,len=records.length;i<len;i++){var record=records[i];if(record.getLayer()===this.layer){if(this.layer.map&&this.layer.map.events){this.layer.map.events.on({"zoomend":this.onMapZoom,scope:this});}}}}});GeoExt.VectorLegend.supports=function(layerRecord){return layerRecord.getLayer()instanceof OpenLayers.Layer.Vector?1:0;};GeoExt.LayerLegend.types["gx_vectorlegend"]=GeoExt.VectorLegend;Ext.reg("gx_vectorlegend",GeoExt.VectorLegend);Ext.namespace("GeoExt.tree");GeoExt.tree.LayerContainer=Ext.extend(Ext.tree.AsyncTreeNode,{text:'Layers',constructor:function(config){config=Ext.applyIf(config||{},{text:this.text});this.loader=config.loader insta
 nceof GeoExt.tree.LayerLoader?config.loader:new GeoExt.tree.LayerLoader(Ext.applyIf(config.loader||{},{store:config.layerStore}));GeoExt.tree.LayerContainer.superclass.constructor.call(this,config);},recordIndexToNodeIndex:function(index){var store=this.loader.store;var count=store.getCount();var nodeCount=this.childNodes.length;var nodeIndex=-1;for(var i=count-1;i>=0;--i){if(this.loader.filter(store.getAt(i))===true){++nodeIndex;if(index===i||nodeIndex>nodeCount-1){break;}}}
+return nodeIndex;},destroy:function(){delete this.layerStore;GeoExt.tree.LayerContainer.superclass.destroy.apply(this,arguments);}});Ext.tree.TreePanel.nodeTypes.gx_layercontainer=GeoExt.tree.LayerContainer;Ext.namespace("GeoExt.tree");GeoExt.tree.BaseLayerContainer=Ext.extend(GeoExt.tree.LayerContainer,{text:'Base Layer',constructor:function(config){config=Ext.applyIf(config||{},{text:this.text,loader:{}});config.loader=Ext.applyIf(config.loader,{baseAttrs:Ext.applyIf(config.loader.baseAttrs||{},{iconCls:'gx-tree-baselayer-icon',checkedGroup:'baselayer'}),filter:function(record){var layer=record.getLayer();return layer.displayInLayerSwitcher===true&&layer.isBaseLayer===true;}});GeoExt.tree.BaseLayerContainer.superclass.constructor.call(this,config);}});Ext.tree.TreePanel.nodeTypes.gx_baselayercontainer=GeoExt.tree.BaseLayerContainer;Ext.namespace("GeoExt.plugins");GeoExt.plugins.PrintExtent=Ext.extend(Ext.util.Observable,{initialConfig:null,printProvider:null,map:null,layer
 :null,control:null,pages:null,page:null,constructor:function(config){config=config||{};Ext.apply(this,config);this.initialConfig=config;if(!this.printProvider){this.printProvider=this.pages[0].printProvider;}
+if(!this.pages){this.pages=[];}
+this.addEvents("selectpage");GeoExt.plugins.PrintExtent.superclass.constructor.apply(this,arguments);},print:function(options){this.printProvider.print(this.map,this.pages,options);},init:function(mapPanel){this.map=mapPanel.map;mapPanel.on("destroy",this.onMapPanelDestroy,this);if(!this.layer){this.layer=new OpenLayers.Layer.Vector(null,{displayInLayerSwitcher:false});}
+this.createControl();for(var i=0,len=this.pages.length;i<len;++i){this.addPage(this.pages[i]);}
+this.show();},addPage:function(page){page=page||new GeoExt.data.PrintPage({printProvider:this.printProvider});if(this.pages.indexOf(page)===-1){this.pages.push(page);}
+this.layer.addFeatures([page.feature]);page.on("change",this.onPageChange,this);this.page=page;var map=this.map;if(map.getCenter()){this.fitPage();}else{map.events.register("moveend",this,function(){map.events.unregister("moveend",this,arguments.callee);this.fitPage();});}
+return page;},removePage:function(page){this.pages.remove(page);if(page.feature.layer){this.layer.removeFeatures([page.feature]);}
+page.un("change",this.onPageChange,this);},selectPage:function(page){this.control.active&&this.control.setFeature(page.feature);},show:function(){this.map.addLayer(this.layer);this.map.addControl(this.control);this.control.activate();if(this.page&&this.map.getCenter()){this.updateBox();}},hide:function(){var map=this.map,layer=this.layer,control=this.control;if(control&&control.events){control.deactivate();if(map&&map.events&&control.map){map.removeControl(control);}}
+if(map&&map.events&&layer&&layer.map){map.removeLayer(layer);}},onMapPanelDestroy:function(){var map=this.map;for(var len=this.pages.length-1,i=len;i>=0;i--){this.removePage(this.pages[i]);}
+this.hide();var control=this.control;if(map&&map.events&&control&&control.events){control.destroy();}
+var layer=this.layer;if(!this.initialConfig.layer&&map&&map.events&&layer&&layer.events){layer.destroy();}
+delete this.layer;delete this.control;delete this.page;this.map=null;},createControl:function(){this.control=new OpenLayers.Control.TransformFeature(this.layer,{preserveAspectRatio:true,eventListeners:{"beforesetfeature":function(e){for(var i=0,len=this.pages.length;i<len;++i){if(this.pages[i].feature===e.feature){this.page=this.pages[i];e.object.rotation=-this.pages[i].rotation;break;}}},"setfeature":function(e){for(var i=0,len=this.pages.length;i<len;++i){if(this.pages[i].feature===e.feature){this.fireEvent("selectpage",this.pages[i]);break;}}},"beforetransform":function(e){this._updating=true;var page=this.page;if(e.rotation){if(this.printProvider.layout.get("rotation")){page.setRotation(-e.object.rotation);}else{e.object.setFeature(page.feature);}}else if(e.center){page.setCenter(OpenLayers.LonLat.fromString(e.center.toShortString()));}else{page.fit(e.object.box,{mode:"closest"});var minScale=this.printProvider.scales.getAt(0);var maxScale=this.printProvider.scales.getAt
 (this.printProvider.scales.getCount()-1);var boxBounds=e.object.box.geometry.getBounds();var pageBounds=page.feature.geometry.getBounds();var tooLarge=page.scale===minScale&&boxBounds.containsBounds(pageBounds);var tooSmall=page.scale===maxScale&&pageBounds.containsBounds(boxBounds);if(tooLarge===true||tooSmall===true){this.updateBox();}}
+delete this._updating;return false;},"transformcomplete":this.updateBox,scope:this}});},fitPage:function(){if(this.page){this.page.fit(this.map,{mode:"screen"});}},updateBox:function(){var page=this.page;this.control.active&&this.control.setFeature(page.feature,{rotation:-page.rotation});},onPageChange:function(page,mods){if(!this._updating){this.control.active&&this.control.setFeature(page.feature,{rotation:-page.rotation});}}});Ext.preg("gx_printextent",GeoExt.plugins.PrintExtent);Ext.namespace("GeoExt");GeoExt.SliderTip=Ext.extend(Ext.slider.Tip,{hover:true,minWidth:10,offsets:[0,-10],dragging:false,init:function(slider){GeoExt.SliderTip.superclass.init.apply(this,arguments);if(this.hover){slider.on("render",this.registerThumbListeners,this);}
+this.slider=slider;},registerThumbListeners:function(){var thumb,el;for(var i=0,ii=this.slider.thumbs.length;i<ii;++i){thumb=this.slider.thumbs[i];el=thumb.tracker.el;(function(thumb,el){el.on({mouseover:function(e){this.onSlide(this.slider,e,thumb);this.dragging=false;},mouseout:function(){if(!this.dragging){this.hide.apply(this,arguments);}},scope:this})}).apply(this,[thumb,el]);}},onSlide:function(slider,e,thumb){this.dragging=true;return GeoExt.SliderTip.superclass.onSlide.apply(this,arguments);}});Ext.namespace("GeoExt");GeoExt.Lang=new(Ext.extend(Ext.util.Observable,{locale:navigator.language||navigator.userLanguage,dict:null,constructor:function(){this.addEvents("localize");this.dict={};Ext.util.Observable.constructor.apply(this,arguments);},add:function(locale,lookup){var obj=this.dict[locale];if(!obj){this.dict[locale]=Ext.apply({},lookup);}else{for(var key in lookup){obj[key]=Ext.apply(obj[key]||{},lookup[key]);}}
+if(!locale||locale===this.locale){this.set(locale);}else if(this.locale.indexOf(locale+"-")===0){this.set(this.locale);}},set:function(locale){var tags=locale?locale.split("-"):[];var id="";var lookup={},parent;for(var i=0,ii=tags.length;i<ii;++i){id+=(id&&"-"||"")+tags[i];if(id in this.dict){parent=this.dict[id];for(var str in parent){if(str in lookup){Ext.apply(lookup[str],parent[str]);}else{lookup[str]=Ext.apply({},parent[str]);}}}}
+for(var str in lookup){var obj=window;var parts=str.split(".");var missing=false;for(var i=0,ii=parts.length;i<ii;++i){var name=parts[i];if(name in obj){obj=obj[name];}else{missing=true;break;}}
+if(!missing){Ext.apply(obj,lookup[str]);}}
+this.locale=locale;this.fireEvent("localize",locale);}}))();Ext.namespace("GeoExt");GeoExt.ZoomSlider=Ext.extend(Ext.slider.SingleSlider,{map:null,baseCls:"gx-zoomslider",aggressive:false,updating:false,initComponent:function(){GeoExt.ZoomSlider.superclass.initComponent.call(this);if(this.map){if(this.map instanceof GeoExt.MapPanel){this.map=this.map.map;}
+this.bind(this.map);}
+if(this.aggressive===true){this.on('change',this.changeHandler,this);}else{this.on('changecomplete',this.changeHandler,this);}
+this.on("beforedestroy",this.unbind,this);},onRender:function(){GeoExt.ZoomSlider.superclass.onRender.apply(this,arguments);this.el.addClass(this.baseCls);},afterRender:function(){Ext.slider.SingleSlider.superclass.afterRender.apply(this,arguments);this.update();},addToMapPanel:function(panel){this.on({render:function(){var el=this.getEl();el.setStyle({position:"absolute",zIndex:panel.map.Z_INDEX_BASE.Control});el.on({mousedown:this.stopMouseEvents,click:this.stopMouseEvents});},afterrender:function(){this.bind(panel.map);},scope:this});},stopMouseEvents:function(e){e.stopEvent();},removeFromMapPanel:function(panel){var el=this.getEl();el.un("mousedown",this.stopMouseEvents,this);el.un("click",this.stopMouseEvents,this);this.unbind();},bind:function(map){this.map=map;this.map.events.on({zoomend:this.update,changebaselayer:this.initZoomValues,scope:this});if(this.map.baseLayer){this.initZoomValues();this.update();}},unbind:function(){if(this.map&&this.map.events){this.map.eve
 nts.un({zoomend:this.update,changebaselayer:this.initZoomValues,scope:this});}},initZoomValues:function(){var layer=this.map.baseLayer;if(this.initialConfig.minValue===undefined){this.minValue=layer.minZoomLevel||0;}
+if(this.initialConfig.maxValue===undefined){this.maxValue=layer.minZoomLevel==null?layer.numZoomLevels-1:layer.maxZoomLevel;}},getZoom:function(){return this.getValue();},getScale:function(){return OpenLayers.Util.getScaleFromResolution(this.map.getResolutionForZoom(this.getValue()),this.map.getUnits());},getResolution:function(){return this.map.getResolutionForZoom(this.getValue());},changeHandler:function(){if(this.map&&!this.updating){this.map.zoomTo(this.getValue());}},update:function(){if(this.rendered&&this.map){this.updating=true;this.setValue(this.map.getZoom());this.updating=false;}}});Ext.reg('gx_zoomslider',GeoExt.ZoomSlider);Ext.namespace("GeoExt.tree");GeoExt.tree.WMSCapabilitiesLoader=function(config){Ext.apply(this,config);GeoExt.tree.WMSCapabilitiesLoader.superclass.constructor.call(this);};Ext.extend(GeoExt.tree.WMSCapabilitiesLoader,Ext.tree.TreeLoader,{url:null,layerOptions:null,layerParams:null,requestMethod:'GET',getParams:function(node){return{'service'
 :'WMS','request':'GetCapabilities'};},processResponse:function(response,node,callback,scope){var capabilities=new OpenLayers.Format.WMSCapabilities().read(response.responseXML||response.responseText);capabilities.capability&&this.processLayer(capabilities.capability,capabilities.capability.request.getmap.href,node);if(typeof callback=="function"){callback.apply(scope||node,[node]);}},createWMSLayer:function(layer,url){if(layer.name){return new OpenLayers.Layer.WMS(layer.title,url,OpenLayers.Util.extend({formats:layer.formats[0],layers:layer.name},this.layerParams),OpenLayers.Util.extend({minScale:layer.minScale,queryable:layer.queryable,maxScale:layer.maxScale,metadata:layer},this.layerOptions));}else{return null;}},processLayer:function(layer,url,node){Ext.each(layer.nestedLayers,function(el){var n=this.createNode({text:el.title||el.name,nodeType:'node',layer:this.createWMSLayer(el,url),leaf:(el.nestedLayers.length===0)});if(n){node.appendChild(n);}
+if(el.nestedLayers){this.processLayer(el,url,n);}},this);}});Ext.namespace("GeoExt.data");GeoExt.data.WMSCapabilitiesReader=function(meta,recordType){meta=meta||{};if(!meta.format){meta.format=new OpenLayers.Format.WMSCapabilities();}
+if(typeof recordType!=="function"){recordType=GeoExt.data.LayerRecord.create(recordType||meta.fields||[{name:"name",type:"string"},{name:"title",type:"string"},{name:"abstract",type:"string"},{name:"queryable",type:"boolean"},{name:"opaque",type:"boolean"},{name:"noSubsets",type:"boolean"},{name:"cascaded",type:"int"},{name:"fixedWidth",type:"int"},{name:"fixedHeight",type:"int"},{name:"minScale",type:"float"},{name:"maxScale",type:"float"},{name:"prefix",type:"string"},{name:"formats"},{name:"styles"},{name:"srs"},{name:"dimensions"},{name:"bbox"},{name:"llbbox"},{name:"attribution"},{name:"keywords"},{name:"identifiers"},{name:"authorityURLs"},{name:"metadataURLs"},{name:"infoFormats"}]);}
+GeoExt.data.WMSCapabilitiesReader.superclass.constructor.call(this,meta,recordType);};Ext.extend(GeoExt.data.WMSCapabilitiesReader,Ext.data.DataReader,{attributionCls:"gx-attribution",read:function(request){var data=request.responseXML;if(!data||!data.documentElement){data=request.responseText;}
+return this.readRecords(data);},serviceExceptionFormat:function(formats){if(OpenLayers.Util.indexOf(formats,"application/vnd.ogc.se_inimage")>-1){return"application/vnd.ogc.se_inimage";}
+if(OpenLayers.Util.indexOf(formats,"application/vnd.ogc.se_xml")>-1){return"application/vnd.ogc.se_xml";}
+return formats[0];},imageFormat:function(layer){var formats=layer.formats;if(layer.opaque&&OpenLayers.Util.indexOf(formats,"image/jpeg")>-1){return"image/jpeg";}
+if(OpenLayers.Util.indexOf(formats,"image/png")>-1){return"image/png";}
+if(OpenLayers.Util.indexOf(formats,"image/png; mode=24bit")>-1){return"image/png; mode=24bit";}
+if(OpenLayers.Util.indexOf(formats,"image/gif")>-1){return"image/gif";}
+return formats[0];},imageTransparent:function(layer){return layer.opaque==undefined||!layer.opaque;},readRecords:function(data){if(typeof data==="string"||data.nodeType){data=this.meta.format.read(data);}
+if(!!data.error){throw new Ext.data.DataReader.Error("invalid-response",data.error);}
+var version=data.version;var capability=data.capability||{};var url=capability.request&&capability.request.getmap&&capability.request.getmap.href;var layers=capability.layers;var formats=capability.exception?capability.exception.formats:[];var exceptions=this.serviceExceptionFormat(formats);var records=[];if(url&&layers){var fields=this.recordType.prototype.fields;var layer,values,options,params,field,v;for(var i=0,lenI=layers.length;i<lenI;i++){layer=layers[i];if(layer.name){values={};for(var j=0,lenJ=fields.length;j<lenJ;j++){field=fields.items[j];v=layer[field.mapping||field.name]||field.defaultValue;v=field.convert(v);values[field.name]=v;}
+options={attribution:layer.attribution?this.attributionMarkup(layer.attribution):undefined,minScale:layer.minScale,maxScale:layer.maxScale};if(this.meta.layerOptions){Ext.apply(options,this.meta.layerOptions);}
+params={layers:layer.name,exceptions:exceptions,format:this.imageFormat(layer),transparent:this.imageTransparent(layer),version:version};if(this.meta.layerParams){Ext.apply(params,this.meta.layerParams);}
+values.layer=new OpenLayers.Layer.WMS(layer.title||layer.name,url,params,options);records.push(new this.recordType(values,values.layer.id));}}}
+return{totalRecords:records.length,success:true,records:records};},attributionMarkup:function(attribution){var markup=[];if(attribution.logo){markup.push("<img class='"+this.attributionCls+"-image' "
++"src='"+attribution.logo.href+"' />");}
+if(attribution.title){markup.push("<span class='"+this.attributionCls+"-title'>"
++attribution.title
++"</span>");}
+if(attribution.href){for(var i=0;i<markup.length;i++){markup[i]="<a class='"
++this.attributionCls+"-link' "
++"href="
++attribution.href
++markup[i]
++"</a>";}}
+return markup.join(" ");}});Ext.namespace("GeoExt.data");GeoExt.data.LayerStoreMixin=function(){return{map:null,reader:null,constructor:function(config){config=config||{};config.reader=config.reader||new GeoExt.data.LayerReader({},config.fields);delete config.fields;var map=config.map instanceof GeoExt.MapPanel?config.map.map:config.map;delete config.map;if(config.layers){config.data=config.layers;}
+delete config.layers;var options={initDir:config.initDir};delete config.initDir;arguments.callee.superclass.constructor.call(this,config);this.addEvents("bind");if(map){this.bind(map,options);}},bind:function(map,options){if(this.map){return;}
+this.map=map;options=options||{};var initDir=options.initDir;if(options.initDir==undefined){initDir=GeoExt.data.LayerStore.MAP_TO_STORE|GeoExt.data.LayerStore.STORE_TO_MAP;}
+var layers=map.layers.slice(0);if(initDir&GeoExt.data.LayerStore.STORE_TO_MAP){this.each(function(record){this.map.addLayer(record.getLayer());},this);}
+if(initDir&GeoExt.data.LayerStore.MAP_TO_STORE){this.loadData(layers,true);}
+map.events.on({"changelayer":this.onChangeLayer,"addlayer":this.onAddLayer,"removelayer":this.onRemoveLayer,scope:this});this.on({"load":this.onLoad,"clear":this.onClear,"add":this.onAdd,"remove":this.onRemove,"update":this.onUpdate,scope:this});this.data.on({"replace":this.onReplace,scope:this});this.fireEvent("bind",this,map);},unbind:function(){if(this.map){this.map.events.un({"changelayer":this.onChangeLayer,"addlayer":this.onAddLayer,"removelayer":this.onRemoveLayer,scope:this});this.un("load",this.onLoad,this);this.un("clear",this.onClear,this);this.un("add",this.onAdd,this);this.un("remove",this.onRemove,this);this.data.un("replace",this.onReplace,this);this.map=null;}},onChangeLayer:function(evt){var layer=evt.layer;var recordIndex=this.findBy(function(rec,id){return rec.getLayer()===layer;});if(recordIndex>-1){var record=this.getAt(recordIndex);if(evt.property==="order"){if(!this._adding&&!this._removing){var layerIndex=this.map.getLayerIndex(layer);if(layerIndex!==
 recordIndex){this._removing=true;this.remove(record);delete this._removing;this._adding=true;this.insert(layerIndex,[record]);delete this._adding;}}}else if(evt.property==="name"){record.set("title",layer.name);}else{this.fireEvent("update",this,record,Ext.data.Record.EDIT);}}},onAddLayer:function(evt){if(!this._adding){var layer=evt.layer;this._adding=true;this.loadData([layer],true);delete this._adding;}},onRemoveLayer:function(evt){if(this.map.unloadDestroy){if(!this._removing){var layer=evt.layer;this._removing=true;this.remove(this.getById(layer.id));delete this._removing;}}else{this.unbind();}},onLoad:function(store,records,options){if(!Ext.isArray(records)){records=[records];}
+if(options&&!options.add){this._removing=true;for(var i=this.map.layers.length-1;i>=0;i--){this.map.removeLayer(this.map.layers[i]);}
+delete this._removing;var len=records.length;if(len>0){var layers=new Array(len);for(var j=0;j<len;j++){layers[j]=records[j].getLayer();}
+this._adding=true;this.map.addLayers(layers);delete this._adding;}}},onClear:function(store){this._removing=true;for(var i=this.map.layers.length-1;i>=0;i--){this.map.removeLayer(this.map.layers[i]);}
+delete this._removing;},onAdd:function(store,records,index){if(!this._adding){this._adding=true;var layer;for(var i=records.length-1;i>=0;--i){layer=records[i].getLayer();this.map.addLayer(layer);if(index!==this.map.layers.length-1){this.map.setLayerIndex(layer,index);}}
+delete this._adding;}},onRemove:function(store,record,index){if(!this._removing){var layer=record.getLayer();if(this.map.getLayer(layer.id)!=null){this._removing=true;this.removeMapLayer(record);delete this._removing;}}},onUpdate:function(store,record,operation){if(operation===Ext.data.Record.EDIT){if(record.modified&&record.modified.title){var layer=record.getLayer();var title=record.get("title");if(title!==layer.name){layer.setName(title);}}}},removeMapLayer:function(record){this.map.removeLayer(record.getLayer());},onReplace:function(key,oldRecord,newRecord){this.removeMapLayer(oldRecord);},getByLayer:function(layer){var index=this.findBy(function(r){return r.getLayer()===layer;});if(index>-1){return this.getAt(index);}},destroy:function(){this.unbind();GeoExt.data.LayerStore.superclass.destroy.call(this);}};};GeoExt.data.LayerStore=Ext.extend(Ext.data.Store,new GeoExt.data.LayerStoreMixin);GeoExt.data.LayerStore.MAP_TO_STORE=1;GeoExt.data.LayerStore.STORE_TO_MAP=2;Ext.na
 mespace("GeoExt.tree");GeoExt.tree.LayerLoader=function(config){Ext.apply(this,config);this.addEvents("beforeload","load");GeoExt.tree.LayerLoader.superclass.constructor.call(this);};Ext.extend(GeoExt.tree.LayerLoader,Ext.util.Observable,{store:null,filter:function(record){return record.getLayer().displayInLayerSwitcher==true;},baseAttrs:null,uiProviders:null,load:function(node,callback){if(this.fireEvent("beforeload",this,node)){this.removeStoreHandlers();while(node.firstChild){node.removeChild(node.firstChild);}
+if(!this.uiProviders){this.uiProviders=node.getOwnerTree().getLoader().uiProviders;}
+if(!this.store){this.store=GeoExt.MapPanel.guess().layers;}
+this.store.each(function(record){this.addLayerNode(node,record);},this);this.addStoreHandlers(node);if(typeof callback=="function"){callback();}
+this.fireEvent("load",this,node);}},onStoreAdd:function(store,records,index,node){if(!this._reordering){var nodeIndex=node.recordIndexToNodeIndex(index+records.length-1);for(var i=0;i<records.length;++i){this.addLayerNode(node,records[i],nodeIndex);}}},onStoreRemove:function(store,record,index,node){if(!this._reordering){this.removeLayerNode(node,record);}},addLayerNode:function(node,layerRecord,index){index=index||0;if(this.filter(layerRecord)===true){var child=this.createNode({nodeType:'gx_layer',layer:layerRecord.getLayer(),layerStore:this.store});var sibling=node.item(index);if(sibling){node.insertBefore(child,sibling);}else{node.appendChild(child);}
+child.on("move",this.onChildMove,this);}},removeLayerNode:function(node,layerRecord){if(this.filter(layerRecord)===true){var child=node.findChildBy(function(node){return node.layer==layerRecord.getLayer();});if(child){child.un("move",this.onChildMove,this);child.remove();node.reload();}}},onChildMove:function(tree,node,oldParent,newParent,index){this._reordering=true;var record=this.store.getByLayer(node.layer);if(newParent instanceof GeoExt.tree.LayerContainer&&this.store===newParent.loader.store){newParent.loader._reordering=true;this.store.remove(record);var newRecordIndex;if(newParent.childNodes.length>1){var searchIndex=(index===0)?index+1:index-1;newRecordIndex=this.store.findBy(function(r){return newParent.childNodes[searchIndex].layer===r.getLayer();});index===0&&newRecordIndex++;}else if(oldParent.parentNode===newParent.parentNode){var prev=newParent;do{prev=prev.previousSibling;}while(prev&&!(prev instanceof GeoExt.tree.LayerContainer&&prev.lastChild));if(prev){new
 RecordIndex=this.store.findBy(function(r){return prev.lastChild.layer===r.getLayer();});}else{var next=newParent;do{next=next.nextSibling;}while(next&&!(next instanceof GeoExt.tree.LayerContainer&&next.firstChild));if(next){newRecordIndex=this.store.findBy(function(r){return next.firstChild.layer===r.getLayer();});}
+newRecordIndex++;}}
+if(newRecordIndex!==undefined){this.store.insert(newRecordIndex,[record]);window.setTimeout(function(){newParent.reload();oldParent.reload();});}else{this.store.insert(oldRecordIndex,[record]);}
+delete newParent.loader._reordering;}
+delete this._reordering;},addStoreHandlers:function(node){if(!this._storeHandlers){this._storeHandlers={"add":this.onStoreAdd.createDelegate(this,[node],true),"remove":this.onStoreRemove.createDelegate(this,[node],true)};for(var evt in this._storeHandlers){this.store.on(evt,this._storeHandlers[evt],this);}}},removeStoreHandlers:function(){if(this._storeHandlers){for(var evt in this._storeHandlers){this.store.un(evt,this._storeHandlers[evt],this);}
+delete this._storeHandlers;}},createNode:function(attr){if(this.baseAttrs){Ext.apply(attr,this.baseAttrs);}
+if(typeof attr.uiProvider=='string'){attr.uiProvider=this.uiProviders[attr.uiProvider]||eval(attr.uiProvider);}
+attr.nodeType=attr.nodeType||"gx_layer";return new Ext.tree.TreePanel.nodeTypes[attr.nodeType](attr);},destroy:function(){this.removeStoreHandlers();}});Ext.namespace("GeoExt.plugins");GeoExt.plugins.PrintProviderField=Ext.extend(Ext.util.Observable,{target:null,constructor:function(config){this.initialConfig=config;Ext.apply(this,config);GeoExt.plugins.PrintProviderField.superclass.constructor.apply(this,arguments);},init:function(target){this.target=target;var onCfg={scope:this,"render":this.onRender,"beforedestroy":this.onBeforeDestroy};onCfg[target instanceof Ext.form.ComboBox?"select":"valid"]=this.onFieldChange;target.on(onCfg);},onRender:function(field){var printProvider=this.printProvider||field.ownerCt.printProvider;if(field.store===printProvider.layouts){field.setValue(printProvider.layout.get(field.displayField));printProvider.on({"layoutchange":this.onProviderChange,scope:this});}else if(field.store===printProvider.dpis){field.setValue(printProvider.dpi.get(field
 .displayField));printProvider.on({"dpichange":this.onProviderChange,scope:this});}else if(field.initialConfig.value===undefined){field.setValue(printProvider.customParams[field.name]);}},onFieldChange:function(field,record){var printProvider=this.printProvider||field.ownerCt.printProvider;var value=field.getValue();this._updating=true;if(record){switch(field.store){case printProvider.layouts:printProvider.setLayout(record);break;case printProvider.dpis:printProvider.setDpi(record);}}else{printProvider.customParams[field.name]=value;}
+delete this._updating;},onProviderChange:function(printProvider,rec){if(!this._updating){this.target.setValue(rec.get(this.target.displayField));}},onBeforeDestroy:function(){var target=this.target;target.un("beforedestroy",this.onBeforeDestroy,this);target.un("render",this.onRender,this);target.un("select",this.onFieldChange,this);target.un("valid",this.onFieldChange,this);var printProvider=this.printProvider||target.ownerCt.printProvider;printProvider.un("layoutchange",this.onProviderChange,this);printProvider.un("dpichange",this.onProviderChange,this);}});Ext.preg("gx_printproviderfield",GeoExt.plugins.PrintProviderField);Ext.namespace("GeoExt","GeoExt.data");GeoExt.data.LayerReader=function(meta,recordType){meta=meta||{};if(!(recordType instanceof Function)){recordType=GeoExt.data.LayerRecord.create(recordType||meta.fields||{});}
+GeoExt.data.LayerReader.superclass.constructor.call(this,meta,recordType);};Ext.extend(GeoExt.data.LayerReader,Ext.data.DataReader,{totalRecords:null,readRecords:function(layers){var records=[];if(layers){var recordType=this.recordType,fields=recordType.prototype.fields;var i,lenI,j,lenJ,layer,values,field,v;for(i=0,lenI=layers.length;i<lenI;i++){layer=layers[i];values={};for(j=0,lenJ=fields.length;j<lenJ;j++){field=fields.items[j];v=layer[field.mapping||field.name]||field.defaultValue;v=field.convert(v);values[field.name]=v;}
+values.layer=layer;records[records.length]=new recordType(values,layer.id);}}
+return{records:records,totalRecords:this.totalRecords!=null?this.totalRecords:records.length};}});Ext.namespace("GeoExt.data");GeoExt.data.WMSDescribeLayerStore=function(c){c=c||{};GeoExt.data.WMSDescribeLayerStore.superclass.constructor.call(this,Ext.apply(c,{proxy:c.proxy||(!c.data?new Ext.data.HttpProxy({url:c.url,disableCaching:false,method:"GET"}):undefined),reader:new GeoExt.data.WMSDescribeLayerReader(c,c.fields)}));};Ext.extend(GeoExt.data.WMSDescribeLayerStore,Ext.data.Store);Ext.namespace("GeoExt.form");GeoExt.form.BasicForm=Ext.extend(Ext.form.BasicForm,{protocol:null,prevResponse:null,autoAbort:true,doAction:function(action,options){if(action=="search"){options=Ext.applyIf(options||{},{protocol:this.protocol,abortPrevious:this.autoAbort});action=new GeoExt.form.SearchAction(this,options);}
+return GeoExt.form.BasicForm.superclass.doAction.call(this,action,options);},search:function(options){return this.doAction("search",options);}});Ext.namespace("GeoExt.plugins");GeoExt.plugins.TreeNodeRadioButton=Ext.extend(Ext.util.Observable,{constructor:function(config){Ext.apply(this.initialConfig,Ext.apply({},config));Ext.apply(this,config);this.addEvents("radiochange");GeoExt.plugins.TreeNodeRadioButton.superclass.constructor.apply(this,arguments);},init:function(tree){tree.on({"rendernode":this.onRenderNode,"rawclicknode":this.onRawClickNode,"beforedestroy":this.onBeforeDestroy,scope:this});},onRenderNode:function(node){var a=node.attributes;if(a.radioGroup&&!a.radio){a.radio=Ext.DomHelper.insertBefore(node.ui.anchor,['<input type="radio" class="gx-tree-radio" name="',a.radioGroup,'_radio"></input>'].join(""));}},onRawClickNode:function(node,e){var el=e.getTarget('.gx-tree-radio',1);if(el){el.defaultChecked=el.checked;this.fireEvent("radiochange",node);return false;}},
 onBeforeDestroy:function(tree){tree.un("rendernode",this.onRenderNode,this);tree.un("rawclicknode",this.onRawClickNode,this);tree.un("beforedestroy",this.onBeforeDestroy,this);}});Ext.preg("gx_treenoderadiobutton",GeoExt.plugins.TreeNodeRadioButton);Ext.namespace("GeoExt.data");GeoExt.data.StyleReader=Ext.extend(Ext.data.JsonReader,{onMetaChange:function(){GeoExt.data.StyleReader.superclass.onMetaChange.apply(this,arguments);this.recordType.prototype.commit=Ext.createInterceptor(this.recordType.prototype.commit,function(){var reader=this.store.reader;reader.raw[reader.meta.root]=reader.meta.storeToData(this.store);});},readRecords:function(o){var type,rows;if(o instanceof OpenLayers.Symbolizer.Raster){type="colorMap";}else{type="rules";}
+this.raw=o;Ext.applyIf(this.meta,GeoExt.data.StyleReader.metaData[type]);var data={metaData:this.meta};data[type]=o[type];return GeoExt.data.StyleReader.superclass.readRecords.call(this,data);}});GeoExt.data.StyleReader.metaData={colorMap:{root:"colorMap",idProperty:"filter",fields:[{name:"symbolizers",mapping:function(v){return{fillColor:v.color,fillOpacity:v.opacity,stroke:false};}},{name:"filter",mapping:"quantity",type:"float"},{name:"label",mapping:function(v){return v.label||v.quantity;}}],storeToData:function(store){store.sort("filter","ASC");var colorMap=[];store.each(function(rec){var symbolizer=rec.get("symbolizers"),label=rec.get("label"),labelModified=rec.isModified("label");var quantity=Number(rec.get("filter"));rec.data.filter=quantity;if((!rec.json.label&&!labelModified&&rec.isModified("filter"))||(labelModified&&!label)){rec.data.label=quantity;}
+colorMap.push(Ext.apply(rec.json,{color:symbolizer.fillColor,label:typeof label=="string"?label:undefined,opacity:symbolizer.opacity,quantity:quantity}));});return colorMap;}},rules:{root:"rules",fields:["symbolizers","filter",{name:"label",mapping:"title"},"name","description","elseFilter","minScaleDenominator","maxScaleDenominator"],storeToData:function(store){var rules=[];store.each(function(rec){var filter=rec.get("filter");if(typeof filter==="string"){filter=filter?OpenLayers.Format.CQL.prototype.read(filter):null;}
+rules.push(Ext.apply(rec.json,{symbolizers:rec.get("symbolizers"),filter:filter,title:rec.get("label"),name:rec.get("name"),description:rec.get("description"),elseFilter:rec.get("elseFilter"),minScaleDenominator:rec.get("minScaleDenominator"),maxScaleDenominator:rec.get("maxScaleDenominator")}));});return rules;}}};Ext.namespace('GeoExt','GeoExt.data');GeoExt.data.FeatureReader=function(meta,recordType){meta=meta||{};if(!(recordType instanceof Function)){recordType=GeoExt.data.FeatureRecord.create(recordType||meta.fields||{});}
+GeoExt.data.FeatureReader.superclass.constructor.call(this,meta,recordType);};Ext.extend(GeoExt.data.FeatureReader,Ext.data.DataReader,{totalRecords:null,read:function(response){return this.readRecords(response.features);},readRecords:function(features){var records=[];if(features){var recordType=this.recordType,fields=recordType.prototype.fields;var i,lenI,j,lenJ,feature,values,field,v;for(i=0,lenI=features.length;i<lenI;i++){feature=features[i];values={};if(feature.attributes){for(j=0,lenJ=fields.length;j<lenJ;j++){field=fields.items[j];if(/[\[\.]/.test(field.mapping)){try{v=new Function("obj","return obj."+field.mapping)(feature.attributes);}catch(e){v=field.defaultValue;}}
+else{v=feature.attributes[field.mapping||field.name]||field.defaultValue;}
+if(field.convert){v=field.convert(v);}
+values[field.name]=v;}}
+values.feature=feature;values.state=feature.state;values.fid=feature.fid;var id=(feature.state===OpenLayers.State.INSERT)?undefined:feature.id;records[records.length]=new recordType(values,id);}}
+return{records:records,totalRecords:this.totalRecords!=null?this.totalRecords:records.length};}});Ext.namespace('GeoExt');GeoExt.WMSLegend=Ext.extend(GeoExt.LayerLegend,{defaultStyleIsFirst:true,useScaleParameter:true,baseParams:null,initComponent:function(){GeoExt.WMSLegend.superclass.initComponent.call(this);var layer=this.layerRecord.getLayer();this._noMap=!layer.map;layer.events.register("moveend",this,this.onLayerMoveend);this.update();},onLayerMoveend:function(e){if((e.zoomChanged===true&&this.useScaleParameter===true)||this._noMap){delete this._noMap;this.update();}},getLegendUrl:function(layerName,layerNames){var rec=this.layerRecord;var url;var styles=rec&&rec.get("styles");var layer=rec.getLayer();layerNames=layerNames||[layer.params.LAYERS].join(",").split(",");var styleNames=layer.params.STYLES&&[layer.params.STYLES].join(",").split(",");var idx=layerNames.indexOf(layerName);var styleName=styleNames&&styleNames[idx];if(styles&&styles.length>0){if(styleName){Ext.e
 ach(styles,function(s){url=(s.name==styleName&&s.legend)&&s.legend.href;return!url;});}else if(this.defaultStyleIsFirst===true&&!styleNames&&!layer.params.SLD&&!layer.params.SLD_BODY){url=styles[0].legend&&styles[0].legend.href;}}
+if(!url){url=layer.getFullRequestString({REQUEST:"GetLegendGraphic",WIDTH:null,HEIGHT:null,EXCEPTIONS:"application/vnd.ogc.se_xml",LAYER:layerName,LAYERS:null,STYLE:(styleName!=='')?styleName:null,STYLES:null,SRS:null,FORMAT:null,TIME:null});}
+if(url.toLowerCase().indexOf("request=getlegendgraphic")!=-1){if(url.toLowerCase().indexOf("format=")==-1){url=Ext.urlAppend(url,"FORMAT=image/gif");}
+if(this.useScaleParameter===true){var scale=layer.map.getScale();url=Ext.urlAppend(url,"SCALE="+scale);}}
+var params=Ext.apply({},this.baseParams);if(layer.params._OLSALT){params._OLSALT=layer.params._OLSALT;}
+url=Ext.urlAppend(url,Ext.urlEncode(params));return url;},update:function(){var layer=this.layerRecord.getLayer();if(!(layer&&layer.map)){return;}
+GeoExt.WMSLegend.superclass.update.apply(this,arguments);var layerNames,layerName,i,len;layerNames=[layer.params.LAYERS].join(",").split(",");var destroyList=[];var textCmp=this.items.get(0);this.items.each(function(cmp){i=layerNames.indexOf(cmp.itemId);if(i<0&&cmp!=textCmp){destroyList.push(cmp);}else if(cmp!==textCmp){layerName=layerNames[i];var newUrl=this.getLegendUrl(layerName,layerNames);if(!OpenLayers.Util.isEquivalentUrl(newUrl,cmp.url)){cmp.setUrl(newUrl);}}},this);for(i=0,len=destroyList.length;i<len;i++){var cmp=destroyList[i];this.remove(cmp);cmp.destroy();}
+for(i=0,len=layerNames.length;i<len;i++){layerName=layerNames[i];if(!this.items||!this.getComponent(layerName)){this.add({xtype:"gx_legendimage",url:this.getLegendUrl(layerName,layerNames),itemId:layerName});}}
+this.doLayout();},beforeDestroy:function(){if(this.useScaleParameter===true){var layer=this.layerRecord.getLayer();layer&&layer.events&&layer.events.unregister("moveend",this,this.onLayerMoveend);}
+GeoExt.WMSLegend.superclass.beforeDestroy.apply(this,arguments);}});GeoExt.WMSLegend.supports=function(layerRecord){return layerRecord.getLayer()instanceof OpenLayers.Layer.WMS?1:0;};GeoExt.LayerLegend.types["gx_wmslegend"]=GeoExt.WMSLegend;Ext.reg('gx_wmslegend',GeoExt.WMSLegend);Ext.namespace("GeoExt.data");GeoExt.data.WMSDescribeLayerReader=function(meta,recordType){meta=meta||{};if(!meta.format){meta.format=new OpenLayers.Format.WMSDescribeLayer();}
+if(!(typeof recordType==="function")){recordType=Ext.data.Record.create(recordType||meta.fields||[{name:"owsType",type:"string"},{name:"owsURL",type:"string"},{name:"typeName",type:"string"}]);}
+GeoExt.data.WMSDescribeLayerReader.superclass.constructor.call(this,meta,recordType);};Ext.extend(GeoExt.data.WMSDescribeLayerReader,Ext.data.DataReader,{read:function(request){var data=request.responseXML;if(!data||!data.documentElement){data=request.responseText;}
+return this.readRecords(data);},readRecords:function(data){if(typeof data==="string"||data.nodeType){data=this.meta.format.read(data);}
+var records=[],description;for(var i=0,len=data.length;i<len;i++){description=data[i];if(description){records.push(new this.recordType(description));}}
+return{totalRecords:records.length,success:true,records:records};}});Ext.namespace("GeoExt.form");GeoExt.form.SearchAction=Ext.extend(Ext.form.Action,{type:"search",response:null,constructor:function(form,options){GeoExt.form.SearchAction.superclass.constructor.call(this,form,options);},run:function(){var o=this.options;var f=GeoExt.form.toFilter(this.form,o.logicalOp,o.wildcard);if(o.clientValidation===false||this.form.isValid()){if(o.abortPrevious&&this.form.prevResponse){o.protocol.abort(this.form.prevResponse);}
+this.form.prevResponse=o.protocol.read(Ext.applyIf({filter:f,callback:this.handleResponse,scope:this},o));}else if(o.clientValidation!==false){this.failureType=Ext.form.Action.CLIENT_INVALID;this.form.afterAction(this,false);}},handleResponse:function(response){this.form.prevResponse=null;this.response=response;if(response.success()){this.form.afterAction(this,true);}else{this.form.afterAction(this,false);}
+var o=this.options;if(o.callback){o.callback.call(o.scope,response);}}});Ext.namespace("GeoExt.data");GeoExt.data.FeatureRecord=Ext.data.Record.create([{name:"feature"},{name:"state"},{name:"fid"}]);GeoExt.data.FeatureRecord.prototype.getFeature=function(){return this.get("feature");};GeoExt.data.FeatureRecord.prototype.setFeature=function(feature){if(feature!==this.data.feature){this.dirty=true;if(!this.modified){this.modified={};}
+if(this.modified.feature===undefined){this.modified.feature=this.data.feature;}
+this.data.feature=feature;if(!this.editing){this.afterEdit();}}};GeoExt.data.FeatureRecord.create=function(o){var f=Ext.extend(GeoExt.data.FeatureRecord,{});var p=f.prototype;p.fields=new Ext.util.MixedCollection(false,function(field){return field.name;});GeoExt.data.FeatureRecord.prototype.fields.each(function(f){p.fields.add(f);});if(o){for(var i=0,len=o.length;i<len;i++){p.fields.add(new Ext.data.Field(o[i]));}}
+f.getField=function(name){return p.fields.get(name);};return f;};Ext.namespace("GeoExt.tree");GeoExt.tree.LayerParamLoader=function(config){Ext.apply(this,config);this.addEvents("beforeload","load");GeoExt.tree.LayerParamLoader.superclass.constructor.call(this);};Ext.extend(GeoExt.tree.LayerParamLoader,Ext.util.Observable,{param:null,delimiter:",",load:function(node,callback){if(this.fireEvent("beforeload",this,node)){while(node.firstChild){node.removeChild(node.firstChild);}
+var paramValue=(node.layer instanceof OpenLayers.Layer.HTTPRequest)&&node.layer.params[this.param];if(paramValue){var items=(paramValue instanceof Array)?paramValue.slice():paramValue.split(this.delimiter);Ext.each(items,function(item,index,allItems){this.addParamNode(item,allItems,node);},this);}
+if(typeof callback=="function"){callback();}
+this.fireEvent("load",this,node);}},addParamNode:function(paramItem,allParamItems,node){var child=this.createNode({layer:node.layer,param:this.param,item:paramItem,allItems:allParamItems,delimiter:this.delimiter});var sibling=node.item(0);if(sibling){node.insertBefore(child,sibling);}else{node.appendChild(child);}},createNode:function(attr){if(this.baseAttrs){Ext.apply(attr,this.baseAttrs);}
+attr.nodeType=attr.nodeType||"gx_layerparam";return new Ext.tree.TreePanel.nodeTypes[attr.nodeType](attr);}});Ext.namespace("GeoExt.data");GeoExt.data.PrintPage=Ext.extend(Ext.util.Observable,{printProvider:null,feature:null,center:null,scale:null,rotation:0,customParams:null,constructor:function(config){this.initialConfig=config;Ext.apply(this,config);if(!this.customParams){this.customParams={};}
+this.addEvents("change");GeoExt.data.PrintPage.superclass.constructor.apply(this,arguments);this.feature=new OpenLayers.Feature.Vector(OpenLayers.Geometry.fromWKT("POLYGON((-1 -1,1 -1,1 1,-1 1,-1 -1))"));if(this.printProvider.capabilities){this.setScale(this.printProvider.scales.getAt(0));}else{this.printProvider.on({"loadcapabilities":function(){this.setScale(this.printProvider.scales.getAt(0));},scope:this,single:true});}
+this.printProvider.on({"layoutchange":this.onLayoutChange,scope:this});},getPrintExtent:function(map){map=map instanceof GeoExt.MapPanel?map.map:map;return this.calculatePageBounds(this.scale,map.getUnits());},setScale:function(scale,units){var bounds=this.calculatePageBounds(scale,units);var geom=bounds.toGeometry();var rotation=this.rotation;if(rotation!=0){geom.rotate(-rotation,geom.getCentroid());}
+this.updateFeature(geom,{scale:scale});},setCenter:function(center){var geom=this.feature.geometry;var oldCenter=geom.getBounds().getCenterLonLat();var dx=center.lon-oldCenter.lon;var dy=center.lat-oldCenter.lat;geom.move(dx,dy);this.updateFeature(geom,{center:center});},setRotation:function(rotation,force){if(force||this.printProvider.layout.get("rotation")===true){var geom=this.feature.geometry;geom.rotate(this.rotation-rotation,geom.getCentroid());this.updateFeature(geom,{rotation:rotation});}},fit:function(fitTo,options){options=options||{};var map=fitTo,extent;if(fitTo instanceof GeoExt.MapPanel){map=fitTo.map;}else if(fitTo instanceof OpenLayers.Feature.Vector){map=fitTo.layer.map;extent=fitTo.geometry.getBounds();}
+if(!extent){extent=map.getExtent();if(!extent){return;}}
+this._updating=true;var center=extent.getCenterLonLat();this.setCenter(center);var units=map.getUnits();var scale=this.printProvider.scales.getAt(0);var closest=Number.POSITIVE_INFINITY;var mapWidth=extent.getWidth();var mapHeight=extent.getHeight();this.printProvider.scales.each(function(rec){var bounds=this.calculatePageBounds(rec,units);if(options.mode=="closest"){var diff=Math.abs(bounds.getWidth()-mapWidth)+
+Math.abs(bounds.getHeight()-mapHeight);if(diff<closest){closest=diff;scale=rec;}}else{var contains=options.mode=="screen"?!extent.containsBounds(bounds):bounds.containsBounds(extent);if(contains||(options.mode=="screen"&&!contains)){scale=rec;}
+return contains;}},this);this.setScale(scale,units);delete this._updating;this.updateFeature(this.feature.geometry,{center:center,scale:scale});},updateFeature:function(geometry,mods){var f=this.feature;var modified=f.geometry!==geometry;geometry.id=f.geometry.id;f.geometry=geometry;if(!this._updating){for(var property in mods){if(mods[property]===this[property]){delete mods[property];}else{this[property]=mods[property];modified=true;}}
+Ext.apply(this,mods);f.layer&&f.layer.drawFeature(f);modified&&this.fireEvent("change",this,mods);}},calculatePageBounds:function(scale,units){var s=scale.get("value");var f=this.feature;var geom=this.feature.geometry;var center=geom.getBounds().getCenterLonLat();var size=this.printProvider.layout.get("size");var units=units||(f.layer&&f.layer.map&&f.layer.map.getUnits())||"dd";var unitsRatio=OpenLayers.INCHES_PER_UNIT[units];var w=size.width/72/unitsRatio*s/2;var h=size.height/72/unitsRatio*s/2;return new OpenLayers.Bounds(center.lon-w,center.lat-h,center.lon+w,center.lat+h);},onLayoutChange:function(){if(this.printProvider.layout.get("rotation")===false){this.setRotation(0,true);}
+this.scale&&this.setScale(this.scale);},destroy:function(){this.printProvider.un("layoutchange",this.onLayoutChange,this);}});Ext.namespace("GeoExt.data");GeoExt.data.LayerRecord=Ext.data.Record.create([{name:"layer"},{name:"title",type:"string",mapping:"name"}]);GeoExt.data.LayerRecord.prototype.getLayer=function(){return this.get("layer");};GeoExt.data.LayerRecord.prototype.setLayer=function(layer){if(layer!==this.data.layer){this.dirty=true;if(!this.modified){this.modified={};}
+if(this.modified.layer===undefined){this.modified.layer=this.data.layer;}
+this.data.layer=layer;if(!this.editing){this.afterEdit();}}};GeoExt.data.LayerRecord.prototype.clone=function(id){var layer=this.getLayer()&&this.getLayer().clone();return new this.constructor(Ext.applyIf({layer:layer},this.data),id||layer.id);};GeoExt.data.LayerRecord.create=function(o){var f=Ext.extend(GeoExt.data.LayerRecord,{});var p=f.prototype;p.fields=new Ext.util.MixedCollection(false,function(field){return field.name;});GeoExt.data.LayerRecord.prototype.fields.each(function(f){p.fields.add(f);});if(o){for(var i=0,len=o.length;i<len;i++){p.fields.add(new Ext.data.Field(o[i]));}}
+f.getField=function(name){return p.fields.get(name);};return f;};Ext.namespace("GeoExt.form");GeoExt.form.toFilter=function(form,logicalOp,wildcard){if(form instanceof Ext.form.FormPanel){form=form.getForm();}
+var filters=[],values=form.getValues(false);for(var prop in values){var s=prop.split("__");var value=values[prop],type;if(s.length>1&&(type=GeoExt.form.toFilter.FILTER_MAP[s[1]])!==undefined){prop=s[0];}else{type=OpenLayers.Filter.Comparison.EQUAL_TO;}
+if(type===OpenLayers.Filter.Comparison.LIKE){switch(wildcard){case GeoExt.form.ENDS_WITH:value='.*'+value;break;case GeoExt.form.STARTS_WITH:value+='.*';break;case GeoExt.form.CONTAINS:value='.*'+value+'.*';break;default:break;}}
+filters.push(new OpenLayers.Filter.Comparison({type:type,value:value,property:prop}));}
+return filters.length==1&&logicalOp!=OpenLayers.Filter.Logical.NOT?filters[0]:new OpenLayers.Filter.Logical({type:logicalOp||OpenLayers.Filter.Logical.AND,filters:filters});};GeoExt.form.toFilter.FILTER_MAP={"eq":OpenLayers.Filter.Comparison.EQUAL_TO,"ne":OpenLayers.Filter.Comparison.NOT_EQUAL_TO,"lt":OpenLayers.Filter.Comparison.LESS_THAN,"le":OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO,"gt":OpenLayers.Filter.Comparison.GREATER_THAN,"ge":OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO,"like":OpenLayers.Filter.Comparison.LIKE};GeoExt.form.ENDS_WITH=1;GeoExt.form.STARTS_WITH=2;GeoExt.form.CONTAINS=3;GeoExt.form.recordToField=function(record,options){options=options||{};var type=record.get("type");if(typeof type==="object"&&type.xtype){return type;}
+type=type.split(":").pop();var field;var name=record.get("name");var restriction=record.get("restriction")||{};var nillable=record.get("nillable")||false;var label=record.get("label");var labelTpl=options.labelTpl;if(labelTpl){var tpl=(labelTpl instanceof Ext.Template)?labelTpl:new Ext.XTemplate(labelTpl);label=tpl.apply(record.data);}else if(label==null){label=name;}
+var baseOptions={name:name,labelStyle:nillable?'':options.mandatoryFieldLabelStyle!=null?options.mandatoryFieldLabelStyle:'font-weight:bold;'};var r=GeoExt.form.recordToField.REGEXES;if(type.match(r["text"])){var maxLength=restriction["maxLength"]!==undefined?parseFloat(restriction["maxLength"]):undefined;var minLength=restriction["minLength"]!==undefined?parseFloat(restriction["minLength"]):undefined;field=Ext.apply({xtype:"textfield",fieldLabel:label,maxLength:maxLength,minLength:minLength},baseOptions);}else if(type.match(r["number"])){var maxValue=restriction["maxInclusive"]!==undefined?parseFloat(restriction["maxInclusive"]):undefined;var minValue=restriction["minInclusive"]!==undefined?parseFloat(restriction["minInclusive"]):undefined;field=Ext.apply({xtype:"numberfield",fieldLabel:label,maxValue:maxValue,minValue:minValue},baseOptions);}else if(type.match(r["boolean"])){field=Ext.apply({xtype:"checkbox"},baseOptions);var labelProperty=options.checkboxLabelProperty||"b
 oxLabel";field[labelProperty]=label;}else if(type.match(r["date"])){field=Ext.apply({xtype:"datefield",fieldLabel:label,format:'c'},baseOptions);}
+return field;};GeoExt.form.recordToField.REGEXES={"text":new RegExp("^(text|string)$","i"),"number":new RegExp("^(number|float|decimal|double|int|long|integer|short)$","i"),"boolean":new RegExp("^(boolean)$","i"),"date":new RegExp("^(date|dateTime)$","i")};Ext.namespace('GeoExt');GeoExt.FeatureRenderer=Ext.extend(Ext.BoxComponent,{feature:undefined,symbolizers:[OpenLayers.Feature.Vector.style["default"]],symbolType:"Polygon",resolution:1,minWidth:20,minHeight:20,renderers:["SVG","VML","Canvas"],rendererOptions:null,pointFeature:undefined,lineFeature:undefined,polygonFeature:undefined,renderer:null,initComponent:function(){GeoExt.FeatureRenderer.superclass.initComponent.apply(this,arguments);Ext.applyIf(this,{pointFeature:new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(0,0)),lineFeature:new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString([new OpenLayers.Geometry.Point(-8,-3),new OpenLayers.Geometry.Point(-3,3),new OpenLayers.Geometry.Point(3,-3),new O
 penLayers.Geometry.Point(8,3)])),polygonFeature:new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing([new OpenLayers.Geometry.Point(-8,-4),new OpenLayers.Geometry.Point(-6,-6),new OpenLayers.Geometry.Point(6,-6),new OpenLayers.Geometry.Point(8,-4),new OpenLayers.Geometry.Point(8,4),new OpenLayers.Geometry.Point(6,6),new OpenLayers.Geometry.Point(-6,6),new OpenLayers.Geometry.Point(-8,4)])]))});if(!this.feature){this.setFeature(null,{draw:false});}
+this.addEvents("click");},initCustomEvents:function(){this.clearCustomEvents();this.el.on("click",this.onClick,this);},clearCustomEvents:function(){if(this.el&&this.el.removeAllListeners){this.el.removeAllListeners();}},onClick:function(){this.fireEvent("click",this);},onRender:function(ct,position){if(!this.el){this.el=document.createElement("div");this.el.id=this.getId();}
+if(!this.renderer||!this.renderer.supported()){this.assignRenderer();}
+this.renderer.map={getResolution:(function(){return this.resolution;}).createDelegate(this)};GeoExt.FeatureRenderer.superclass.onRender.apply(this,arguments);this.drawFeature();},afterRender:function(){GeoExt.FeatureRenderer.superclass.afterRender.apply(this,arguments);this.initCustomEvents();},onResize:function(w,h){this.setRendererDimensions();GeoExt.FeatureRenderer.superclass.onResize.apply(this,arguments);},setRendererDimensions:function(){var gb=this.feature.geometry.getBounds();var gw=gb.getWidth();var gh=gb.getHeight();var resolution=this.initialConfig.resolution;if(!resolution){resolution=Math.max(gw/this.width||0,gh/this.height||0)||1;}
+this.resolution=resolution;var width=Math.max(this.width||this.minWidth,gw/resolution);var height=Math.max(this.height||this.minHeight,gh/resolution);var center=gb.getCenterPixel();var bhalfw=width*resolution/2;var bhalfh=height*resolution/2;var bounds=new OpenLayers.Bounds(center.x-bhalfw,center.y-bhalfh,center.x+bhalfw,center.y+bhalfh);this.renderer.setSize(new OpenLayers.Size(Math.round(width),Math.round(height)));this.renderer.setExtent(bounds,true);},assignRenderer:function(){for(var i=0,len=this.renderers.length;i<len;++i){var Renderer=OpenLayers.Renderer[this.renderers[i]];if(Renderer&&Renderer.prototype.supported()){this.renderer=new Renderer(this.el,this.rendererOptions);break;}}},setSymbolizers:function(symbolizers,options){this.symbolizers=symbolizers;if(!options||options.draw){this.drawFeature();}},setSymbolType:function(type,options){this.symbolType=type;this.setFeature(null,options);},setFeature:function(feature,options){this.feature=feature||this[this.symbolTy
 pe.toLowerCase()+"Feature"];if(!options||options.draw){this.drawFeature();}},drawFeature:function(){this.renderer.clear();this.setRendererDimensions();var Symbolizer=OpenLayers.Symbolizer;var Text=Symbolizer&&Symbolizer.Text;var symbolizer,feature,geomType;for(var i=0,len=this.symbolizers.length;i<len;++i){symbolizer=this.symbolizers[i];feature=this.feature;if(!Text||!(symbolizer instanceof Text)){if(Symbolizer&&(symbolizer instanceof Symbolizer)){symbolizer=symbolizer.clone();if(!this.initialConfig.feature){geomType=symbolizer.CLASS_NAME.split(".").pop().toLowerCase();feature=this[geomType+"Feature"];}}else{symbolizer=Ext.apply({},symbolizer);}
+this.renderer.drawFeature(feature.clone(),symbolizer);}}},update:function(options){options=options||{};if(options.feature){this.setFeature(options.feature,{draw:false});}else if(options.symbolType){this.setSymbolType(options.symbolType,{draw:false});}
+if(options.symbolizers){this.setSymbolizers(options.symbolizers,{draw:false});}
+this.drawFeature();},beforeDestroy:function(){this.clearCustomEvents();if(this.renderer){this.renderer.destroy();}}});Ext.reg('gx_renderer',GeoExt.FeatureRenderer);Ext.namespace("GeoExt");GeoExt.Popup=Ext.extend(Ext.Window,{anchored:true,map:null,panIn:true,unpinnable:true,location:null,insideViewport:null,animCollapse:false,draggable:false,shadow:false,popupCls:"gx-popup",ancCls:null,anchorPosition:"auto",initComponent:function(){if(this.map instanceof GeoExt.MapPanel){this.map=this.map.map;}
+if(!this.map&&this.location instanceof OpenLayers.Feature.Vector&&this.location.layer){this.map=this.location.layer.map;}
+if(this.location instanceof OpenLayers.Feature.Vector){this.location=this.location.geometry;}
+if(this.location instanceof OpenLayers.Geometry){if(typeof this.location.getCentroid=="function"){this.location=this.location.getCentroid();}
+this.location=this.location.getBounds().getCenterLonLat();}else if(this.location instanceof OpenLayers.Pixel){this.location=this.map.getLonLatFromViewPortPx(this.location);}
+var mapExtent=this.map.getExtent();if(mapExtent&&this.location){this.insideViewport=mapExtent.containsLonLat(this.location);}
+if(this.anchored){this.addAnchorEvents();}
+this.baseCls=this.popupCls+" "+this.baseCls;this.elements+=',anc';GeoExt.Popup.superclass.initComponent.call(this);},onRender:function(ct,position){GeoExt.Popup.superclass.onRender.call(this,ct,position);this.ancCls=this.popupCls+"-anc";this.createElement("anc",this.el.dom);},initTools:function(){if(this.unpinnable){this.addTool({id:'unpin',handler:this.unanchorPopup.createDelegate(this,[])});}
+GeoExt.Popup.superclass.initTools.call(this);},show:function(){GeoExt.Popup.superclass.show.apply(this,arguments);if(this.anchored){this.position();if(this.panIn&&!this._mapMove){this.panIntoView();}}},maximize:function(){if(!this.maximized&&this.anc){this.unanchorPopup();}
+GeoExt.Popup.superclass.maximize.apply(this,arguments);},setSize:function(w,h){if(this.anc){var ancSize=this.anc.getSize();if(typeof w=='object'){h=w.height-ancSize.height;w=w.width;}else if(!isNaN(h)){h=h-ancSize.height;}}
+GeoExt.Popup.superclass.setSize.call(this,w,h);},position:function(){if(this._mapMove===true){this.insideViewport=this.map.getExtent().containsLonLat(this.location);if(this.insideViewport!==this.isVisible()){this.setVisible(this.insideViewport);}}
+if(this.isVisible()){var locationPx=this.map.getPixelFromLonLat(this.location),mapBox=Ext.fly(this.map.div).getBox(true),top=locationPx.y+mapBox.y,left=locationPx.x+mapBox.x,elSize=this.el.getSize(),ancSize=this.anc.getSize(),ancPos=this.anchorPosition;if(ancPos.indexOf("right")>-1||locationPx.x>mapBox.width/2){this.anc.addClass("right");var ancRight=this.el.getX(true)+elSize.width-
+this.anc.getX(true)-ancSize.width;left-=elSize.width-ancRight-ancSize.width/2;}else{this.anc.removeClass("right");var ancLeft=this.anc.getLeft(true);left-=ancLeft+ancSize.width/2;}
+if(ancPos.indexOf("bottom")>-1||locationPx.y>mapBox.height/2){this.anc.removeClass("top");top-=elSize.height+ancSize.height;}else{this.anc.addClass("top");top+=ancSize.height;}
+this.setPosition(left,top);}},unanchorPopup:function(){this.removeAnchorEvents();this.draggable=true;this.header.addClass("x-window-draggable");this.dd=new Ext.Window.DD(this);this.anc.remove();this.anc=null;this.tools.unpin.hide();},panIntoView:function(){var mapBox=Ext.fly(this.map.div).getBox(true);var popupPos=this.getPosition(true);popupPos[0]-=mapBox.x;popupPos[1]-=mapBox.y;var panelSize=[mapBox.width,mapBox.height];var popupSize=this.getSize();var newPos=[popupPos[0],popupPos[1]];var padding=this.map.paddingForPopups;if(popupPos[0]<padding.left){newPos[0]=padding.left;}else if(popupPos[0]+popupSize.width>panelSize[0]-padding.right){newPos[0]=panelSize[0]-padding.right-popupSize.width;}
+if(popupPos[1]<padding.top){newPos[1]=padding.top;}else if(popupPos[1]+popupSize.height>panelSize[1]-padding.bottom){newPos[1]=panelSize[1]-padding.bottom-popupSize.height;}
+var dx=popupPos[0]-newPos[0];var dy=popupPos[1]-newPos[1];this.map.pan(dx,dy);},onMapMove:function(){if(!(this.hidden&&this.insideViewport)){this._mapMove=true;this.position();delete this._mapMove;}},addAnchorEvents:function(){this.map.events.on({"move":this.onMapMove,scope:this});this.on({"resize":this.position,"collapse":this.position,"expand":this.position,scope:this});},removeAnchorEvents:function(){this.map.events.un({"move":this.onMapMove,scope:this});this.un("resize",this.position,this);this.un("collapse",this.position,this);this.un("expand",this.position,this);},beforeDestroy:function(){if(this.anchored){this.removeAnchorEvents();}
+GeoExt.Popup.superclass.beforeDestroy.call(this);}});Ext.reg('gx_popup',GeoExt.Popup);Ext.namespace("GeoExt.data");GeoExt.data.AttributeStoreMixin=function(){return{constructor:function(c){c=c||{};arguments.callee.superclass.constructor.call(this,Ext.apply(c,{proxy:c.proxy||(!c.data?new Ext.data.HttpProxy({url:c.url,disableCaching:false,method:"GET"}):undefined),reader:new GeoExt.data.AttributeReader(c,c.fields||["name","type","restriction",{name:"nillable",type:"boolean"}])}));if(this.feature){this.bind();}},bind:function(){this.on({"update":this.onUpdate,"load":this.onLoad,"add":this.onAdd,scope:this});var records=[];this.each(function(record){records.push(record);});this.updateFeature(records);},onUpdate:function(store,record,operation){this.updateFeature([record]);},onLoad:function(store,records,options){if(!options||options.add!==true){this.updateFeature(records);}},onAdd:function(store,records,index){this.updateFeature(records);},updateFeature:function(records){var fea
 ture=this.feature,layer=feature.layer;var i,len,record,name,value,oldValue,dirty;for(i=0,len=records.length;i<len;i++){record=records[i];name=record.get("name");value=record.get("value");oldValue=feature.attributes[name];if(oldValue!==value){dirty=true;}}
+if(dirty&&layer&&layer.events&&layer.events.triggerEvent("beforefeaturemodified",{feature:feature})!==false){for(i=0,len=records.length;i<len;i++){record=records[i];name=record.get("name");value=record.get("value");feature.attributes[name]=value;}
+layer.events.triggerEvent("featuremodified",{feature:feature});layer.drawFeature(feature);}}};};GeoExt.data.AttributeStore=Ext.extend(Ext.data.Store,GeoExt.data.AttributeStoreMixin());Ext.namespace("GeoExt.form");GeoExt.form.FormPanel=Ext.extend(Ext.form.FormPanel,{protocol:null,createForm:function(){delete this.initialConfig.listeners;return new GeoExt.form.BasicForm(null,this.initialConfig);},search:function(options){this.getForm().search(options);}});Ext.reg("gx_formpanel",GeoExt.form.FormPanel);Ext.namespace("GeoExt.data");GeoExt.data.WMCReader=function(meta,recordType){meta=meta||{};if(!meta.format){meta.format=new OpenLayers.Format.WMC();}
+if(!(typeof recordType==="function")){recordType=GeoExt.data.LayerRecord.create(recordType||meta.fields||[{name:"abstract",type:"string"},{name:"metadataURL",type:"string"},{name:"queryable",type:"boolean"},{name:"formats"},{name:"styles"}]);}
+GeoExt.data.WMCReader.superclass.constructor.call(this,meta,recordType);};Ext.extend(GeoExt.data.WMCReader,Ext.data.DataReader,{read:function(request){var data=request.responseXML;if(!data||!data.documentElement){data=request.responseText;}
+return this.readRecords(data);},readRecords:function(data){var format=this.meta.format;if(typeof data==="string"||data.nodeType){data=format.read(data);}
+var layersContext=data?data.layersContext:undefined;var records=[];if(layersContext){var recordType=this.recordType,fields=recordType.prototype.fields;var i,lenI,j,lenJ,layerContext,values,field,v;for(i=0,lenI=layersContext.length;i<lenI;i++){layerContext=layersContext[i];values={};for(j=0,lenJ=fields.length;j<lenJ;j++){field=fields.items[j];v=layerContext[field.mapping||field.name]||field.defaultValue;v=field.convert(v);values[field.name]=v;}
+values.layer=format.getLayerFromContext(layerContext);records.push(new this.recordType(values,values.layer.id));}}
+return{totalRecords:records.length,success:true,records:records};}});GeoExt.Lang.add("fr",{"GeoExt.tree.LayerContainer.prototype":{text:"Couches"},"GeoExt.tree.BaseLayerContainer.prototype":{text:"Couches de base"},"GeoExt.tree.OverlayLayerContainer.prototype":{text:"Couches additionnelles"}});Ext.namespace("GeoExt.tree");GeoExt.tree.OverlayLayerContainer=Ext.extend(GeoExt.tree.LayerContainer,{text:'Overlays',constructor:function(config){config=Ext.applyIf(config||{},{text:this.text});config.loader=Ext.applyIf(config.loader||{},{filter:function(record){var layer=record.getLayer();return layer.displayInLayerSwitcher===true&&layer.isBaseLayer===false;}});GeoExt.tree.OverlayLayerContainer.superclass.constructor.call(this,config);}});Ext.tree.TreePanel.nodeTypes.gx_overlaylayercontainer=GeoExt.tree.OverlayLayerContainer;Ext.namespace("GeoExt.data");GeoExt.data.WFSCapabilitiesReader=function(meta,recordType){meta=meta||{};if(!meta.format){meta.format=new OpenLayers.Format.WFSCapa
 bilities();}
+if(!(typeof recordType==="function")){recordType=GeoExt.data.LayerRecord.create(recordType||meta.fields||[{name:"name",type:"string"},{name:"title",type:"string"},{name:"namespace",type:"string",mapping:"featureNS"},{name:"abstract",type:"string"}]);}
+GeoExt.data.WFSCapabilitiesReader.superclass.constructor.call(this,meta,recordType);};Ext.extend(GeoExt.data.WFSCapabilitiesReader,Ext.data.DataReader,{read:function(request){var data=request.responseXML;if(!data||!data.documentElement){data=request.responseText;}
+var featureTypes=data.featureTypeList.featureTypes;var fields=this.recordType.prototype.fields;var featureType,values,field,v,parts,layer;var layerOptions,protocolOptions;var protocolDefaults={url:data.capability.request.getfeature.href.post};var records=[];for(var i=0,lenI=featureTypes.length;i<lenI;i++){featureType=featureTypes[i];if(featureType.name){values={};for(var j=0,lenJ=fields.length;j<lenJ;j++){field=fields.items[j];v=featureType[field.mapping||field.name]||field.defaultValue;v=field.convert(v);values[field.name]=v;}
+protocolOptions={featureType:featureType.name,featureNS:featureType.featureNS};if(this.meta.protocolOptions){Ext.apply(protocolOptions,this.meta.protocolOptions,protocolDefaults);}else{Ext.apply(protocolOptions,{},protocolDefaults);}
+layerOptions={protocol:new OpenLayers.Protocol.WFS(protocolOptions),strategies:[new OpenLayers.Strategy.Fixed()]};var metaLayerOptions=this.meta.layerOptions;if(metaLayerOptions){Ext.apply(layerOptions,Ext.isFunction(metaLayerOptions)?metaLayerOptions():metaLayerOptions);}
+values.layer=new OpenLayers.Layer.Vector(featureType.title||featureType.name,layerOptions);records.push(new this.recordType(values,values.layer.id));}}
+return{totalRecords:records.length,success:true,records:records};}});Ext.namespace('GeoExt');GeoExt.LegendPanel=Ext.extend(Ext.Panel,{dynamic:true,layerStore:null,preferredTypes:null,filter:function(record){return true;},initComponent:function(){GeoExt.LegendPanel.superclass.initComponent.call(this);},onRender:function(){GeoExt.LegendPanel.superclass.onRender.apply(this,arguments);if(!this.layerStore){this.layerStore=GeoExt.MapPanel.guess().layers;}
+this.layerStore.each(function(record){this.addLegend(record);},this);if(this.dynamic){this.layerStore.on({"add":this.onStoreAdd,"remove":this.onStoreRemove,"clear":this.onStoreClear,scope:this});}},recordIndexToPanelIndex:function(index){var store=this.layerStore;var count=store.getCount();var panelIndex=-1;var legendCount=this.items?this.items.length:0;var record,layer;for(var i=count-1;i>=0;--i){record=store.getAt(i);layer=record.getLayer();var types=GeoExt.LayerLegend.getTypes(record);if(layer.displayInLayerSwitcher&&types.length>0&&(store.getAt(i).get("hideInLegend")!==true)){++panelIndex;if(index===i||panelIndex>legendCount-1){break;}}}
+return panelIndex;},getIdForLayer:function(layer){return this.id+"-"+layer.id;},onStoreAdd:function(store,records,index){var panelIndex=this.recordIndexToPanelIndex(index+records.length-1);for(var i=0,len=records.length;i<len;i++){this.addLegend(records[i],panelIndex);}
+this.doLayout();},onStoreRemove:function(store,record,index){this.removeLegend(record);},removeLegend:function(record){if(this.items){var legend=this.getComponent(this.getIdForLayer(record.getLayer()));if(legend){this.remove(legend,true);this.doLayout();}}},onStoreClear:function(store){this.removeAllLegends();},removeAllLegends:function(){this.removeAll(true);this.doLayout();},addLegend:function(record,index){if(this.filter(record)===true){var layer=record.getLayer();index=index||0;var legend;var types=GeoExt.LayerLegend.getTypes(record,this.preferredTypes);if(layer.displayInLayerSwitcher&&!record.get('hideInLegend')&&types.length>0){this.insert(index,{xtype:types[0],id:this.getIdForLayer(layer),layerRecord:record,hidden:!((!layer.map&&layer.visibility)||(layer.getVisibility()&&layer.calculateInRange()))});}}},onDestroy:function(){if(this.layerStore){this.layerStore.un("add",this.onStoreAdd,this);this.layerStore.un("remove",this.onStoreRemove,this);this.layerStore.un("clear"
 ,this.onStoreClear,this);}
+GeoExt.LegendPanel.superclass.onDestroy.apply(this,arguments);}});Ext.reg('gx_legendpanel',GeoExt.LegendPanel);Ext.namespace("GeoExt.plugins");GeoExt.plugins.TreeNodeActions=Ext.extend(Ext.util.Observable,{actionsCls:"gx-tree-layer-actions",actionCls:"gx-tree-layer-action",constructor:function(config){Ext.apply(this.initialConfig,Ext.apply({},config));Ext.apply(this,config);this.addEvents("action");GeoExt.plugins.TreeNodeActions.superclass.constructor.apply(this,arguments);},init:function(tree){tree.on({"rendernode":this.onRenderNode,"rawclicknode":this.onRawClickNode,"beforedestroy":this.onBeforeDestroy,scope:this});},onRenderNode:function(node){var rendered=node.rendered;if(!rendered){var attr=node.attributes;var actions=attr.actions||this.actions;if(actions&&actions.length>0){var html=['<div class="',this.actionsCls,'">'];for(var i=0,len=actions.length;i<len;i++){var a=actions[i];html=html.concat(['<img id="'+node.id+'_'+a.action,'" ext:qtip="'+a.qtip,'" src="'+Ext.BLANK_
 IMAGE_URL,'" class="'+this.actionCls+' '+a.action+'" />']);}
+html.concat(['</div>']);Ext.DomHelper.insertFirst(node.ui.elNode,html.join(""));}
+if(node.layer&&node.layer.map){this.updateActions(node);}else if(node.layerStore){node.layerStore.on({'bind':function(){this.updateActions(node);},scope:this});}}},updateActions:function(node){var actions=node.attributes.actions||this.actions||[];Ext.each(actions,function(a,index){var el=Ext.get(node.id+'_'+a.action);if(el&&typeof a.update=="function"){a.update.call(node,el);}});},onRawClickNode:function(node,e){if(e.getTarget('.'+this.actionCls,1)){var t=e.getTarget('.'+this.actionCls,1);var action=t.className.replace(this.actionCls+' ','');this.fireEvent("action",node,action,e);return false;}},onBeforeDestroy:function(tree){tree.un("rendernode",this.onRenderNode,this);tree.un("rawclicknode",this.onRawClickNode,this);tree.un("beforedestroy",this.onBeforeDestroy,this);}});Ext.preg("gx_treenodeactions",GeoExt.plugins.TreeNodeActions);GeoExt.Lang.add("nl",{"GeoExt.tree.LayerContainer.prototype":{text:"Kaartlagen"},"GeoExt.tree.BaseLayerContainer.prototype":{text:"Basis kaarten
 "},"GeoExt.tree.OverlayLayerContainer.prototype":{text:"Kaart overlays"}});Ext.namespace("GeoExt.plugins");GeoExt.plugins.PrintPageField=Ext.extend(Ext.util.Observable,{printPage:null,target:null,constructor:function(config){this.initialConfig=config;Ext.apply(this,config);GeoExt.plugins.PrintPageField.superclass.constructor.apply(this,arguments);},init:function(target){this.target=target;var onCfg={"beforedestroy":this.onBeforeDestroy,scope:this};var eventName=target instanceof Ext.form.ComboBox?"select":target instanceof Ext.form.Checkbox?"check":"valid";onCfg[eventName]=this.onFieldChange;target.on(onCfg);this.printPage.on({"change":this.onPageChange,scope:this});this.printPage.printProvider.on({"layoutchange":this.onLayoutChange,scope:this});this.setValue(this.printPage);},onFieldChange:function(field,record){var printProvider=this.printPage.printProvider;var value=field.getValue();this._updating=true;if(field.store===printProvider.scales||field.name==="scale"){this.prin
 tPage.setScale(record);}else if(field.name=="rotation"){!isNaN(value)&&this.printPage.setRotation(value);}else{this.printPage.customParams[field.name]=value;}
+delete this._updating;},onPageChange:function(printPage){if(!this._updating){this.setValue(printPage);}},onLayoutChange:function(printProvider,layout){var t=this.target;t.name=="rotation"&&t.setDisabled(!layout.get("rotation"));},setValue:function(printPage){var t=this.target;t.suspendEvents();if(t.store===printPage.printProvider.scales||t.name==="scale"){if(printPage.scale){t.setValue(printPage.scale.get(t.displayField));}}else if(t.name=="rotation"){t.setValue(printPage.rotation);}
+t.resumeEvents();},onBeforeDestroy:function(){this.target.un("beforedestroy",this.onBeforeDestroy,this);this.target.un("select",this.onFieldChange,this);this.target.un("valid",this.onFieldChange,this);this.printPage.un("change",this.onPageChange,this);this.printPage.printProvider.un("layoutchange",this.onLayoutChange,this);}});Ext.preg("gx_printpagefield",GeoExt.plugins.PrintPageField);Ext.namespace("GeoExt.tree");GeoExt.tree.LayerNodeUI=Ext.extend(Ext.tree.TreeNodeUI,{constructor:function(config){GeoExt.tree.LayerNodeUI.superclass.constructor.apply(this,arguments);},render:function(bulkRender){var a=this.node.attributes;if(a.checked===undefined){a.checked=this.node.layer.getVisibility();}
+GeoExt.tree.LayerNodeUI.superclass.render.apply(this,arguments);var cb=this.checkbox;if(a.checkedGroup){var radio=Ext.DomHelper.insertAfter(cb,['<input type="radio" name="',a.checkedGroup,'_checkbox" class="',cb.className,cb.checked?'" checked="checked"':'','"></input>'].join(""));radio.defaultChecked=cb.defaultChecked;Ext.get(cb).remove();this.checkbox=radio;}
+this.enforceOneVisible();},onClick:function(e){if(e.getTarget('.x-tree-node-cb',1)){this.toggleCheck(this.isChecked());}else{GeoExt.tree.LayerNodeUI.superclass.onClick.apply(this,arguments);}},toggleCheck:function(value){value=(value===undefined?!this.isChecked():value);GeoExt.tree.LayerNodeUI.superclass.toggleCheck.call(this,value);this.enforceOneVisible();},enforceOneVisible:function(){var attributes=this.node.attributes;var group=attributes.checkedGroup;if(group&&group!=="gx_baselayer"){var layer=this.node.layer;var checkedNodes=this.node.getOwnerTree().getChecked();var checkedCount=0;Ext.each(checkedNodes,function(n){var l=n.layer
+if(!n.hidden&&n.attributes.checkedGroup===group){checkedCount++;if(l!=layer&&attributes.checked){l.setVisibility(false);}}});if(checkedCount===0&&attributes.checked==false){layer.setVisibility(true);}}},appendDDGhost:function(ghostNode){var n=this.elNode.cloneNode(true);var radio=Ext.DomQuery.select("input[type='radio']",n);Ext.each(radio,function(r){r.name=r.name+"_clone";});ghostNode.appendChild(n);}});GeoExt.tree.LayerNode=Ext.extend(Ext.tree.AsyncTreeNode,{layer:null,layerStore:null,constructor:function(config){config.leaf=config.leaf||!(config.children||config.loader);if(!config.iconCls&&!config.children){config.iconCls="gx-tree-layer-icon";}
+if(config.loader&&!(config.loader instanceof Ext.tree.TreeLoader)){config.loader=new GeoExt.tree.LayerParamLoader(config.loader);}
+this.defaultUI=this.defaultUI||GeoExt.tree.LayerNodeUI;Ext.apply(this,{layer:config.layer,layerStore:config.layerStore});if(config.text){this.fixedText=true;}
+GeoExt.tree.LayerNode.superclass.constructor.apply(this,arguments);},render:function(bulkRender){var layer=this.layer instanceof OpenLayers.Layer&&this.layer;if(!layer){if(!this.layerStore||this.layerStore=="auto"){this.layerStore=GeoExt.MapPanel.guess().layers;}
+var i=this.layerStore.findBy(function(o){return o.get("title")==this.layer;},this);if(i!=-1){layer=this.layerStore.getAt(i).getLayer();}}
+if(!this.rendered||!layer){var ui=this.getUI();if(layer){this.layer=layer;if(layer.isBaseLayer){this.draggable=false;Ext.applyIf(this.attributes,{checkedGroup:"gx_baselayer"});}
+if(!this.text){this.text=layer.name;}
+ui.show();this.addVisibilityEventHandlers();}else{ui.hide();}
+if(this.layerStore instanceof GeoExt.data.LayerStore){this.addStoreEventHandlers(layer);}}
+GeoExt.tree.LayerNode.superclass.render.apply(this,arguments);},addVisibilityEventHandlers:function(){this.layer.events.on({"visibilitychanged":this.onLayerVisibilityChanged,scope:this});this.on({"checkchange":this.onCheckChange,scope:this});},onLayerVisibilityChanged:function(){if(!this._visibilityChanging){this.getUI().toggleCheck(this.layer.getVisibility());}},onCheckChange:function(node,checked){if(checked!=this.layer.getVisibility()){this._visibilityChanging=true;var layer=this.layer;if(checked&&layer.isBaseLayer&&layer.map){layer.map.setBaseLayer(layer);}else{layer.setVisibility(checked);}
+delete this._visibilityChanging;}},addStoreEventHandlers:function(){this.layerStore.on({"add":this.onStoreAdd,"remove":this.onStoreRemove,"update":this.onStoreUpdate,scope:this});},onStoreAdd:function(store,records,index){var l;for(var i=0;i<records.length;++i){l=records[i].getLayer();if(this.layer==l){this.getUI().show();break;}else if(this.layer==l.name){this.render();break;}}},onStoreRemove:function(store,record,index){if(this.layer==record.getLayer()){this.getUI().hide();}},onStoreUpdate:function(store,record,operation){var layer=record.getLayer();if(!this.fixedText&&(this.layer==layer&&this.text!==layer.name)){this.setText(layer.name);}},destroy:function(){var layer=this.layer;if(layer instanceof OpenLayers.Layer){layer.events.un({"visibilitychanged":this.onLayerVisibilityChanged,scope:this});}
+delete this.layer;var layerStore=this.layerStore;if(layerStore){layerStore.un("add",this.onStoreAdd,this);layerStore.un("remove",this.onStoreRemove,this);layerStore.un("update",this.onStoreUpdate,this);}
+delete this.layerStore;this.un("checkchange",this.onCheckChange,this);GeoExt.tree.LayerNode.superclass.destroy.apply(this,arguments);}});Ext.tree.TreePanel.nodeTypes.gx_layer=GeoExt.tree.LayerNode;Ext.namespace("GeoExt.tree");GeoExt.tree.LayerParamNode=Ext.extend(Ext.tree.TreeNode,{layer:null,param:null,item:null,delimiter:null,allItems:null,constructor:function(attributes){var config=attributes||{};config.iconCls=config.iconCls||"gx-tree-layerparam-icon";config.text=config.text||config.item;this.param=config.param;this.item=config.item;this.delimiter=config.delimiter||",";this.allItems=config.allItems;GeoExt.tree.LayerParamNode.superclass.constructor.apply(this,arguments);this.getLayer();if(this.layer){if(!this.allItems){this.allItems=this.getItemsFromLayer();}
+if(this.attributes.checked==null){this.attributes.checked=this.layer.getVisibility()&&this.getItemsFromLayer().indexOf(this.item)>=0;}else{this.onCheckChange(this,this.attributes.checked);}
+this.layer.events.on({"visibilitychanged":this.onLayerVisibilityChanged,scope:this});this.on({"checkchange":this.onCheckChange,scope:this});}},getLayer:function(){if(!this.layer){var layer=this.attributes.layer;if(typeof layer=="string"){var store=this.attributes.layerStore||GeoExt.MapPanel.guess().layers;var i=store.findBy(function(o){return o.get("title")==layer;});layer=i!=-1?store.getAt(i).getLayer():null;}
+this.layer=layer;}
+return this.layer;},getItemsFromLayer:function(){var paramValue=this.layer.params[this.param];return paramValue instanceof Array?paramValue:(paramValue?paramValue.split(this.delimiter):[]);},createParams:function(items){var params={};params[this.param]=this.layer.params[this.param]instanceof Array?items:items.join(this.delimiter);return params;},onLayerVisibilityChanged:function(){if(this.getItemsFromLayer().length===0){this.layer.mergeNewParams(this.createParams(this.allItems));}
+var visible=this.layer.getVisibility();if(visible&&this.getItemsFromLayer().indexOf(this.item)!==-1){this.getUI().toggleCheck(true);}
+if(!visible){this.layer.mergeNewParams(this.createParams([]));this.getUI().toggleCheck(false);}},onCheckChange:function(node,checked){var layer=this.layer;var newItems=[];var curItems=this.getItemsFromLayer();if(checked===true&&layer.getVisibility()===false&&curItems.length===this.allItems.length){curItems=[];}
+Ext.each(this.allItems,function(item){if((item!==this.item&&curItems.indexOf(item)!==-1)||(checked===true&&item===this.item)){newItems.push(item);}},this);var visible=(newItems.length>0);visible&&layer.mergeNewParams(this.createParams(newItems));if(visible!==layer.getVisibility()){layer.setVisibility(visible);}
+(!visible)&&layer.mergeNewParams(this.createParams([]));},destroy:function(){var layer=this.layer;if(layer instanceof OpenLayers.Layer){layer.events.un({"visibilitychanged":this.onLayerVisibilityChanged,scope:this});}
+delete this.layer;this.un("checkchange",this.onCheckChange,this);GeoExt.tree.LayerParamNode.superclass.destroy.apply(this,arguments);}});Ext.tree.TreePanel.nodeTypes.gx_layerparam=GeoExt.tree.LayerParamNode;Ext.namespace('GeoExt');GeoExt.UrlLegend=Ext.extend(GeoExt.LayerLegend,{initComponent:function(){GeoExt.UrlLegend.superclass.initComponent.call(this);this.add(new GeoExt.LegendImage({url:this.layerRecord.get("legendURL")}));},update:function(){GeoExt.UrlLegend.superclass.update.apply(this,arguments);this.items.get(1).setUrl(this.layerRecord.get("legendURL"));}});GeoExt.UrlLegend.supports=function(layerRecord){return layerRecord.get("legendURL")==null?0:10;};GeoExt.LayerLegend.types["gx_urllegend"]=GeoExt.UrlLegend;Ext.reg('gx_urllegend',GeoExt.UrlLegend);Ext.namespace("GeoExt.state");GeoExt.state.PermalinkProvider=function(config){GeoExt.state.PermalinkProvider.superclass.constructor.apply(this,arguments);config=config||{};var url=config.url;delete config.url;Ext.apply(th
 is,config);this.state=this.readURL(url);};Ext.extend(GeoExt.state.PermalinkProvider,Ext.state.Provider,{encodeType:true,readURL:function(url){var state={};var params=OpenLayers.Util.getParameters(url);var k,split,stateId;for(k in params){if(params.hasOwnProperty(k)){split=k.split("_");if(split.length>1){stateId=split[0];state[stateId]=state[stateId]||{};state[stateId][split.slice(1).join("_")]=this.encodeType?this.decodeValue(params[k]):params[k];}}}
+return state;},getLink:function(base){base=base||document.location.href;var params={};var id,k,state=this.state;for(id in state){if(state.hasOwnProperty(id)){for(k in state[id]){params[id+"_"+k]=this.encodeType?unescape(this.encodeValue(state[id][k])):state[id][k];}}}
+OpenLayers.Util.applyDefaults(params,OpenLayers.Util.getParameters(base));var paramsStr=OpenLayers.Util.getParameterString(params);var qMark=base.indexOf("?");if(qMark>0){base=base.substring(0,qMark);}
+return Ext.urlAppend(base,paramsStr);}});Ext.namespace('GeoExt');GeoExt.LegendImage=Ext.extend(Ext.BoxComponent,{url:null,defaultImgSrc:null,imgCls:null,initComponent:function(){GeoExt.LegendImage.superclass.initComponent.call(this);if(this.defaultImgSrc===null){this.defaultImgSrc=Ext.BLANK_IMAGE_URL;}
+this.autoEl={tag:"img","class":(this.imgCls?this.imgCls:""),src:this.defaultImgSrc};},setUrl:function(url){this.url=url;var el=this.getEl();if(el){el.un("error",this.onImageLoadError,this);el.on("error",this.onImageLoadError,this,{single:true});el.dom.src=url;}},onRender:function(ct,position){GeoExt.LegendImage.superclass.onRender.call(this,ct,position);if(this.url){this.setUrl(this.url);}},onDestroy:function(){var el=this.getEl();if(el){el.un("error",this.onImageLoadError,this);}
+GeoExt.LegendImage.superclass.onDestroy.apply(this,arguments);},onImageLoadError:function(){this.getEl().dom.src=this.defaultImgSrc;}});Ext.reg('gx_legendimage',GeoExt.LegendImage);Ext.namespace("GeoExt");GeoExt.LayerOpacitySlider=Ext.extend(Ext.slider.SingleSlider,{layer:null,complementaryLayer:null,delay:5,changeVisibilityDelay:5,aggressive:false,changeVisibility:false,value:null,inverse:false,constructor:function(config){if(config.layer){this.layer=this.getLayer(config.layer);this.bind();this.complementaryLayer=this.getLayer(config.complementaryLayer);if(config.inverse!==undefined){this.inverse=config.inverse;}
+config.value=(config.value!==undefined)?config.value:this.getOpacityValue(this.layer);delete config.layer;delete config.complementaryLayer;}
+GeoExt.LayerOpacitySlider.superclass.constructor.call(this,config);},bind:function(){if(this.layer&&this.layer.map){this.layer.map.events.on({changelayer:this.update,scope:this});}},unbind:function(){if(this.layer&&this.layer.map&&this.layer.map.events){this.layer.map.events.un({changelayer:this.update,scope:this});}},update:function(evt){if(evt.property==="opacity"&&evt.layer==this.layer&&!this._settingOpacity){this.setValue(this.getOpacityValue(this.layer));}},setLayer:function(layer){this.unbind();this.layer=this.getLayer(layer);this.setValue(this.getOpacityValue(layer));this.bind();},getOpacityValue:function(layer){var value;if(layer&&layer.opacity!==null){value=parseInt(layer.opacity*(this.maxValue-this.minValue));}else{value=this.maxValue;}
+if(this.inverse===true){value=(this.maxValue-this.minValue)-value;}
+return value;},getLayer:function(layer){if(layer instanceof OpenLayers.Layer){return layer;}else if(layer instanceof GeoExt.data.LayerRecord){return layer.getLayer();}},initComponent:function(){GeoExt.LayerOpacitySlider.superclass.initComponent.call(this);if(this.changeVisibility&&this.layer&&(this.layer.opacity==0||(this.inverse===false&&this.value==this.minValue)||(this.inverse===true&&this.value==this.maxValue))){this.layer.setVisibility(false);}
+if(this.complementaryLayer&&((this.layer&&this.layer.opacity==1)||(this.inverse===false&&this.value==this.maxValue)||(this.inverse===true&&this.value==this.minValue))){this.complementaryLayer.setVisibility(false);}
+if(this.aggressive===true){this.on('change',this.changeLayerOpacity,this,{buffer:this.delay});}else{this.on('changecomplete',this.changeLayerOpacity,this);}
+if(this.changeVisibility===true){this.on('change',this.changeLayerVisibility,this,{buffer:this.changeVisibilityDelay});}
+if(this.complementaryLayer){this.on('change',this.changeComplementaryLayerVisibility,this,{buffer:this.changeVisibilityDelay});}
+this.on("beforedestroy",this.unbind,this);},changeLayerOpacity:function(slider,value){if(this.layer){value=value/(this.maxValue-this.minValue);if(this.inverse===true){value=1-value;}
+this._settingOpacity=true;this.layer.setOpacity(value);delete this._settingOpacity;}},changeLayerVisibility:function(slider,value){var currentVisibility=this.layer.getVisibility();if((this.inverse===false&&value==this.minValue)||(this.inverse===true&&value==this.maxValue)&&currentVisibility===true){this.layer.setVisibility(false);}else if((this.inverse===false&&value>this.minValue)||(this.inverse===true&&value<this.maxValue)&&currentVisibility==false){this.layer.setVisibility(true);}},changeComplementaryLayerVisibility:function(slider,value){var currentVisibility=this.complementaryLayer.getVisibility();if((this.inverse===false&&value==this.maxValue)||(this.inverse===true&&value==this.minValue)&&currentVisibility===true){this.complementaryLayer.setVisibility(false);}else if((this.inverse===false&&value<this.maxValue)||(this.inverse===true&&value>this.minValue)&&currentVisibility==false){this.complementaryLayer.setVisibility(true);}},addToMapPanel:function(panel){this.on({rend
 er:function(){var el=this.getEl();el.setStyle({position:"absolute",zIndex:panel.map.Z_INDEX_BASE.Control});el.on({mousedown:this.stopMouseEvents,click:this.stopMouseEvents});},scope:this});},removeFromMapPanel:function(panel){var el=this.getEl();el.un({mousedown:this.stopMouseEvents,click:this.stopMouseEvents,scope:this});this.unbind();},stopMouseEvents:function(e){e.stopEvent();}});Ext.reg('gx_opacityslider',GeoExt.LayerOpacitySlider);Ext.namespace("GeoExt.data");GeoExt.data.AttributeReader=function(meta,recordType){meta=meta||{};if(!meta.format){meta.format=new OpenLayers.Format.WFSDescribeFeatureType();}
+GeoExt.data.AttributeReader.superclass.constructor.call(this,meta,recordType||meta.fields);if(meta.feature){this.recordType.prototype.fields.add(new Ext.data.Field("value"));}};Ext.extend(GeoExt.data.AttributeReader,Ext.data.DataReader,{read:function(request){var data=request.responseXML;if(!data||!data.documentElement){data=request.responseText;}
+return this.readRecords(data);},readRecords:function(data){var attributes;if(data instanceof Array){attributes=data;}else{attributes=this.meta.format.read(data).featureTypes[0].properties;}
+var feature=this.meta.feature;var recordType=this.recordType;var fields=recordType.prototype.fields;var numFields=fields.length;var attr,values,name,record,ignore,value,field,records=[];for(var i=0,len=attributes.length;i<len;++i){ignore=false;attr=attributes[i];values={};for(var j=0;j<numFields;++j){field=fields.items[j];name=field.name;value=field.convert(attr[name]);if(this.ignoreAttribute(name,value)){ignore=true;break;}
+values[name]=value;}
+if(feature){value=feature.attributes[values["name"]];if(value!==undefined){if(this.ignoreAttribute("value",value)){ignore=true;}else{values["value"]=value;}}}
+if(!ignore){records[records.length]=new recordType(values);}}
+return{success:true,records:records,totalRecords:records.length};},ignoreAttribute:function(name,value){var ignore=false;if(this.meta.ignore&&this.meta.ignore[name]){var matches=this.meta.ignore[name];if(typeof matches=="string"){ignore=(matches===value);}else if(matches instanceof Array){ignore=(matches.indexOf(value)>-1);}else if(matches instanceof RegExp){ignore=(matches.test(value));}}
+return ignore;}});Ext.namespace('GeoExt.grid');GeoExt.grid.SymbolizerColumn=Ext.extend(Ext.grid.Column,{renderer:function(value,meta){if(value!=null){var id=Ext.id();window.setTimeout(function(){var ct=Ext.get(id);if(ct){new GeoExt.FeatureRenderer({symbolizers:value instanceof Array?value:[value],renderTo:ct});}},0);meta.css="gx-grid-symbolizercol";return'<div id="'+id+'"></div>';}}});Ext.grid.Column.types.gx_symbolizercolumn=GeoExt.grid.SymbolizerColumn;Ext.namespace("GeoExt.plugins");GeoExt.plugins.TreeNodeComponent=Ext.extend(Ext.util.Observable,{constructor:function(config){Ext.apply(this.initialConfig,Ext.apply({},config));Ext.apply(this,config);GeoExt.plugins.TreeNodeComponent.superclass.constructor.apply(this,arguments);},init:function(tree){tree.on({"rendernode":this.onRenderNode,"beforedestroy":this.onBeforeDestroy,scope:this});},onRenderNode:function(node){var rendered=node.rendered;var attr=node.attributes;var component=attr.component||this.component;if(!rendered&
 &component){var elt=Ext.DomHelper.append(node.ui.elNode,[{"tag":"div"}]);if(typeof component=="function"){component=component(node,elt);}else if(typeof component=="object"&&typeof component.fn=="function"){component=component.fn.apply(component.scope,[node,elt]);}
+if(typeof component=="object"&&typeof component.xtype=="string"){component=Ext.ComponentMgr.create(component);}
+if(component instanceof Ext.Component){component.render(elt);node.component=component;}}},onBeforeDestroy:function(tree){tree.un("rendernode",this.onRenderNode,this);tree.un("beforedestroy",this.onBeforeDestroy,this);}});Ext.preg("gx_treenodecomponent",GeoExt.plugins.TreeNodeComponent);Ext.namespace("GeoExt");GeoExt.ZoomSliderTip=Ext.extend(GeoExt.SliderTip,{template:'<div>Zoom Level: {zoom}</div>'+'<div>Resolution: {resolution}</div>'+'<div>Scale: 1 : {scale}</div>',compiledTemplate:null,init:function(slider){this.compiledTemplate=new Ext.Template(this.template);GeoExt.ZoomSliderTip.superclass.init.call(this,slider);},getText:function(thumb){var data={zoom:thumb.value,resolution:this.slider.getResolution(),scale:Math.round(this.slider.getScale())};return this.compiledTemplate.apply(data);}});Ext.namespace("GeoExt.data");GeoExt.data.PrintProvider=Ext.extend(Ext.util.Observable,{url:null,capabilities:null,method:"POST",encoding:document.charset||document.characterSet||"UTF-8"
 ,timeout:30000,customParams:null,scales:null,dpis:null,layouts:null,dpi:null,layout:null,constructor:function(config){this.initialConfig=config;Ext.apply(this,config);if(!this.customParams){this.customParams={};}
+this.addEvents("loadcapabilities","layoutchange","dpichange","beforeprint","print","printexception","beforeencodelayer","encodelayer","beforedownload");GeoExt.data.PrintProvider.superclass.constructor.apply(this,arguments);this.scales=new Ext.data.JsonStore({root:"scales",sortInfo:{field:"value",direction:"DESC"},fields:["name",{name:"value",type:"float"}]});this.dpis=new Ext.data.JsonStore({root:"dpis",fields:["name",{name:"value",type:"float"}]});this.layouts=new Ext.data.JsonStore({root:"layouts",fields:["name",{name:"size",mapping:"map"},{name:"rotation",type:"boolean"}]});if(config.capabilities){this.loadStores();}else{if(this.url.split("/").pop()){this.url+="/";}
+this.initialConfig.autoLoad&&this.loadCapabilities();}},setLayout:function(layout){this.layout=layout;this.fireEvent("layoutchange",this,layout);},setDpi:function(dpi){this.dpi=dpi;this.fireEvent("dpichange",this,dpi);},print:function(map,pages,options){if(map instanceof GeoExt.MapPanel){map=map.map;}
+pages=pages instanceof Array?pages:[pages];options=options||{};if(this.fireEvent("beforeprint",this,map,pages,options)===false){return;}
+var jsonData=Ext.apply({units:map.getUnits(),srs:map.baseLayer.projection.getCode(),layout:this.layout.get("name"),dpi:this.dpi.get("value")},this.customParams);var pagesLayer=pages[0].feature.layer;var encodedLayers=[];var layers=map.layers.concat();layers.remove(map.baseLayer);layers.unshift(map.baseLayer);Ext.each(layers,function(layer){if(layer!==pagesLayer&&layer.getVisibility()===true){var enc=this.encodeLayer(layer);enc&&encodedLayers.push(enc);}},this);jsonData.layers=encodedLayers;var encodedPages=[];Ext.each(pages,function(page){encodedPages.push(Ext.apply({center:[page.center.lon,page.center.lat],scale:page.scale.get("value"),rotation:page.rotation},page.customParams));},this);jsonData.pages=encodedPages;if(options.overview){var encodedOverviewLayers=[];Ext.each(options.overview.layers,function(layer){var enc=this.encodeLayer(layer);enc&&encodedOverviewLayers.push(enc);},this);jsonData.overviewLayers=encodedOverviewLayers;}
+if(options.legend){var legend=options.legend;var rendered=legend.rendered;if(!rendered){legend=legend.cloneConfig({renderTo:document.body,hidden:true});}
+var encodedLegends=[];legend.items&&legend.items.each(function(cmp){if(!cmp.hidden){var encFn=this.encoders.legends[cmp.getXType()];encodedLegends=encodedLegends.concat(encFn.call(this,cmp,jsonData.pages[0].scale));}},this);if(!rendered){legend.destroy();}
+jsonData.legends=encodedLegends;}
+if(this.method==="GET"){var url=Ext.urlAppend(this.capabilities.printURL,"spec="+encodeURIComponent(Ext.encode(jsonData)));this.download(url);}else{Ext.Ajax.request({url:this.capabilities.createURL,timeout:this.timeout,jsonData:jsonData,headers:{"Content-Type":"application/json; charset="+this.encoding},success:function(response){var url=Ext.decode(response.responseText).getURL;this.download(url);},failure:function(response){this.fireEvent("printexception",this,response);},params:this.initialConfig.baseParams,scope:this});}},download:function(url){if(this.fireEvent("beforedownload",this,url)!==false){if(Ext.isOpera){window.open(url);}else{window.location.href=url;}}
+this.fireEvent("print",this,url);},loadCapabilities:function(){if(!this.url){return;}
+var url=this.url+"info.json";Ext.Ajax.request({url:url,method:"GET",disableCaching:false,success:function(response){this.capabilities=Ext.decode(response.responseText);this.loadStores();},params:this.initialConfig.baseParams,scope:this});},loadStores:function(){this.scales.loadData(this.capabilities);this.dpis.loadData(this.capabilities);this.layouts.loadData(this.capabilities);this.setLayout(this.layouts.getAt(0));this.setDpi(this.dpis.getAt(0));this.fireEvent("loadcapabilities",this,this.capabilities);},encodeLayer:function(layer){var encLayer;for(var c in this.encoders.layers){if(OpenLayers.Layer[c]&&layer instanceof OpenLayers.Layer[c]){if(this.fireEvent("beforeencodelayer",this,layer)===false){return;}
+encLayer=this.encoders.layers[c].call(this,layer);this.fireEvent("encodelayer",this,layer,encLayer);break;}}
+return(encLayer&&encLayer.type)?encLayer:null;},getAbsoluteUrl:function(url){var a;if(Ext.isIE6||Ext.isIE7||Ext.isIE8){a=document.createElement("<a href='"+url+"'/>");a.style.display="none";document.body.appendChild(a);a.href=a.href;document.body.removeChild(a);}else{a=document.createElement("a");a.href=url;}
+return a.href;},encoders:{"layers":{"Layer":function(layer){var enc={};if(layer.options&&layer.options.maxScale){enc.minScaleDenominator=layer.options.maxScale;}
+if(layer.options&&layer.options.minScale){enc.maxScaleDenominator=layer.options.minScale;}
+return enc;},"WMS":function(layer){var enc=this.encoders.layers.HTTPRequest.call(this,layer);Ext.apply(enc,{type:'WMS',layers:[layer.params.LAYERS].join(",").split(","),format:layer.params.FORMAT,styles:[layer.params.STYLES].join(",").split(",")});var param;for(var p in layer.params){param=p.toLowerCase();if(!layer.DEFAULT_PARAMS[param]&&"layers,styles,width,height,srs".indexOf(param)==-1){if(!enc.customParams){enc.customParams={};}
+enc.customParams[p]=layer.params[p];}}
+return enc;},"OSM":function(layer){var enc=this.encoders.layers.TileCache.call(this,layer);return Ext.apply(enc,{type:'OSM',baseURL:enc.baseURL.substr(0,enc.baseURL.indexOf("$")),extension:"png"});},"TMS":function(layer){var enc=this.encoders.layers.TileCache.call(this,layer);return Ext.apply(enc,{type:'TMS',format:layer.type});},"TileCache":function(layer){var enc=this.encoders.layers.HTTPRequest.call(this,layer);return Ext.apply(enc,{type:'TileCache',layer:layer.layername,maxExtent:layer.maxExtent.toArray(),tileSize:[layer.tileSize.w,layer.tileSize.h],extension:layer.extension,resolutions:layer.serverResolutions||layer.resolutions});},"WMTS":function(layer){var enc=this.encoders.layers.HTTPRequest.call(this,layer);return Ext.apply(enc,{type:'WMTS',layer:layer.layer,version:layer.version,requestEncoding:layer.requestEncoding,tileOrigin:[layer.tileOrigin.lon,layer.tileOrigin.lat],tileSize:[layer.tileSize.w,layer.tileSize.h],style:layer.style,formatSuffix:layer.formatSuffix,d
 imensions:layer.dimensions,params:layer.params,maxExtent:(layer.tileFullExtent!=null)?layer.tileFullExtent.toArray():layer.maxExtent.toArray(),matrixSet:layer.matrixSet,zoomOffset:layer.zoomOffset,resolutions:layer.serverResolutions||layer.resolutions});},"KaMapCache":function(layer){var enc=this.encoders.layers.KaMap.call(this,layer);return Ext.apply(enc,{type:'KaMapCache',group:layer.params['g'],metaTileWidth:layer.params['metaTileSize']['w'],metaTileHeight:layer.params['metaTileSize']['h']});},"KaMap":function(layer){var enc=this.encoders.layers.HTTPRequest.call(this,layer);return Ext.apply(enc,{type:'KaMap',map:layer.params['map'],extension:layer.params['i'],group:layer.params['g']||"",maxExtent:layer.maxExtent.toArray(),tileSize:[layer.tileSize.w,layer.tileSize.h],resolutions:layer.serverResolutions||layer.resolutions});},"HTTPRequest":function(layer){var enc=this.encoders.layers.Layer.call(this,layer);return Ext.apply(enc,{baseURL:this.getAbsoluteUrl(layer.url instance
 of Array?layer.url[0]:layer.url),opacity:(layer.opacity!=null)?layer.opacity:1.0,singleTile:layer.singleTile});},"Image":function(layer){var enc=this.encoders.layers.Layer.call(this,layer);return Ext.apply(enc,{type:'Image',baseURL:this.getAbsoluteUrl(layer.getURL(layer.extent)),opacity:(layer.opacity!=null)?layer.opacity:1.0,extent:layer.extent.toArray(),pixelSize:[layer.size.w,layer.size.h],name:layer.name});},"Vector":function(layer){if(!layer.features.length){return;}
+var encFeatures=[];var encStyles={};var features=layer.features;var featureFormat=new OpenLayers.Format.GeoJSON();var styleFormat=new OpenLayers.Format.JSON();var nextId=1;var styleDict={};var feature,style,dictKey,dictItem,styleName;for(var i=0,len=features.length;i<len;++i){feature=features[i];style=feature.style||layer.style||layer.styleMap.createSymbolizer(feature,feature.renderIntent);dictKey=styleFormat.write(style);dictItem=styleDict[dictKey];if(dictItem){styleName=dictItem;}else{styleDict[dictKey]=styleName=nextId++;if(style.externalGraphic){encStyles[styleName]=Ext.applyIf({externalGraphic:this.getAbsoluteUrl(style.externalGraphic)},style);}else{encStyles[styleName]=style;}}
+var featureGeoJson=featureFormat.extract.feature.call(featureFormat,feature);featureGeoJson.properties=OpenLayers.Util.extend({_gx_style:styleName},featureGeoJson.properties);encFeatures.push(featureGeoJson);}
+var enc=this.encoders.layers.Layer.call(this,layer);return Ext.apply(enc,{type:'Vector',styles:encStyles,styleProperty:'_gx_style',geoJson:{type:"FeatureCollection",features:encFeatures},name:layer.name,opacity:(layer.opacity!=null)?layer.opacity:1.0});},"Markers":function(layer){var features=[];for(var i=0,len=layer.markers.length;i<len;i++){var marker=layer.markers[i];var geometry=new OpenLayers.Geometry.Point(marker.lonlat.lon,marker.lonlat.lat);var style={externalGraphic:marker.icon.url,graphicWidth:marker.icon.size.w,graphicHeight:marker.icon.size.h,graphicXOffset:marker.icon.offset.x,graphicYOffset:marker.icon.offset.y};var feature=new OpenLayers.Feature.Vector(geometry,{},style);features.push(feature);}
+var vector=new OpenLayers.Layer.Vector(layer.name);vector.addFeatures(features);var output=this.encoders.layers.Vector.call(this,vector);vector.destroy();return output;}},"legends":{"gx_wmslegend":function(legend,scale){var enc=this.encoders.legends.base.call(this,legend);var icons=[];for(var i=1,len=legend.items.getCount();i<len;++i){var url=legend.items.get(i).url;if(legend.useScaleParameter===true&&url.toLowerCase().indexOf('request=getlegendgraphic')!=-1){var split=url.split("?");var params=Ext.urlDecode(split[1]);params['SCALE']=scale;url=split[0]+"?"+Ext.urlEncode(params);}
+icons.push(this.getAbsoluteUrl(url));}
+enc[0].classes[0]={name:"",icons:icons};return enc;},"gx_urllegend":function(legend){var enc=this.encoders.legends.base.call(this,legend);enc[0].classes.push({name:"",icon:this.getAbsoluteUrl(legend.items.get(1).url)});return enc;},"base":function(legend){return[{name:legend.getLabel(),classes:[]}];}}}});Ext.namespace("GeoExt");GeoExt.MapPanel=Ext.extend(Ext.Panel,{map:null,layers:null,center:null,zoom:null,extent:null,prettyStateKeys:false,stateEvents:["aftermapmove","afterlayervisibilitychange","afterlayeropacitychange","afterlayerorderchange","afterlayernamechange","afterlayeradd","afterlayerremove"],initComponent:function(){if(!(this.map instanceof OpenLayers.Map)){this.map=new OpenLayers.Map(Ext.applyIf(this.map||{},{allOverlays:true}));}
+var layers=this.layers;if(!layers||layers instanceof Array){this.layers=new GeoExt.data.LayerStore({layers:layers,map:this.map.layers.length>0?this.map:null});}
+if(typeof this.center=="string"){this.center=OpenLayers.LonLat.fromString(this.center);}else if(this.center instanceof Array){this.center=new OpenLayers.LonLat(this.center[0],this.center[1]);}
+if(typeof this.extent=="string"){this.extent=OpenLayers.Bounds.fromString(this.extent);}else if(this.extent instanceof Array){this.extent=OpenLayers.Bounds.fromArray(this.extent);}
+GeoExt.MapPanel.superclass.initComponent.call(this);this.addEvents("aftermapmove","afterlayervisibilitychange","afterlayeropacitychange","afterlayerorderchange","afterlayernamechange","afterlayeradd","afterlayerremove");this.map.events.on({"moveend":this.onMoveend,"changelayer":this.onChangelayer,"addlayer":this.onAddlayer,"removelayer":this.onRemovelayer,scope:this});},onMoveend:function(){this.fireEvent("aftermapmove");},onChangelayer:function(e){if(e.property){if(e.property==="visibility"){this.fireEvent("afterlayervisibilitychange");}else if(e.property==="order"){this.fireEvent("afterlayerorderchange");}else if(e.property==="name"){this.fireEvent("afterlayernamechange");}else if(e.property==="opacity"){this.fireEvent("afterlayeropacitychange");}}},onAddlayer:function(){this.fireEvent("afterlayeradd");},onRemovelayer:function(){this.fireEvent("afterlayerremove");},applyState:function(state){this.center=new OpenLayers.LonLat(state.x,state.y);this.zoom=state.zoom;var i,l,la
 yer,layerId,visibility,opacity;var layers=this.map.layers;for(i=0,l=layers.length;i<l;i++){layer=layers[i];layerId=this.prettyStateKeys?layer.name:layer.id;visibility=state["visibility_"+layerId];if(visibility!==undefined){visibility=(/^true$/i).test(visibility);if(layer.isBaseLayer){if(visibility){this.map.setBaseLayer(layer);}}else{layer.setVisibility(visibility);}}
+opacity=state["opacity_"+layerId];if(opacity!==undefined){layer.setOpacity(opacity);}}},getState:function(){var state;if(!this.map){return;}
+var center=this.map.getCenter();state=center?{x:center.lon,y:center.lat,zoom:this.map.getZoom()}:{};var i,l,layer,layerId,layers=this.map.layers;for(i=0,l=layers.length;i<l;i++){layer=layers[i];layerId=this.prettyStateKeys?layer.name:layer.id;state["visibility_"+layerId]=layer.getVisibility();state["opacity_"+layerId]=layer.opacity==null?1:layer.opacity;}
+return state;},updateMapSize:function(){if(this.map){this.map.updateSize();}},renderMap:function(){var map=this.map;map.render(this.body.dom);this.layers.bind(map);if(map.layers.length>0){this.setInitialExtent();}else{this.layers.on("add",this.setInitialExtent,this,{single:true});}},setInitialExtent:function(){var map=this.map;if(this.center||this.zoom!=null){map.setCenter(this.center,this.zoom);}else if(this.extent){map.zoomToExtent(this.extent);}else{map.zoomToMaxExtent();}},afterRender:function(){GeoExt.MapPanel.superclass.afterRender.apply(this,arguments);if(!this.ownerCt){this.renderMap();}else{this.ownerCt.on("move",this.updateMapSize,this);this.ownerCt.on({"afterlayout":this.afterLayout,scope:this});}},afterLayout:function(){var width=this.getInnerWidth()-
+this.body.getBorderWidth("lr");var height=this.getInnerHeight()-
+this.body.getBorderWidth("tb");if(width>0&&height>0){this.ownerCt.un("afterlayout",this.afterLayout,this);this.renderMap();}},onResize:function(){GeoExt.MapPanel.superclass.onResize.apply(this,arguments);this.updateMapSize();},onBeforeAdd:function(item){if(typeof item.addToMapPanel==="function"){item.addToMapPanel(this);}
+GeoExt.MapPanel.superclass.onBeforeAdd.apply(this,arguments);},remove:function(item,autoDestroy){if(typeof item.removeFromMapPanel==="function"){item.removeFromMapPanel(this);}
+GeoExt.MapPanel.superclass.remove.apply(this,arguments);},beforeDestroy:function(){if(this.ownerCt){this.ownerCt.un("move",this.updateMapSize,this);}
+if(this.map&&this.map.events){this.map.events.un({"moveend":this.onMoveend,"changelayer":this.onChangelayer,"addlayer":this.onAddlayer,"removelayer":this.onRemovelayer,scope:this});}
+if(!this.initialConfig.map||!(this.initialConfig.map instanceof OpenLayers.Map)){if(this.map&&this.map.destroy){this.map.destroy();}}
+delete this.map;GeoExt.MapPanel.superclass.beforeDestroy.apply(this,arguments);}});GeoExt.MapPanel.guess=function(){return Ext.ComponentMgr.all.find(function(o){return o instanceof GeoExt.MapPanel;});};Ext.reg('gx_mappanel',GeoExt.MapPanel);Ext.namespace("GeoExt");GeoExt.PrintMapPanel=Ext.extend(GeoExt.MapPanel,{sourceMap:null,printProvider:null,printPage:null,previewScales:null,center:null,zoom:null,extent:null,currentZoom:null,initComponent:function(){if(this.sourceMap instanceof GeoExt.MapPanel){this.sourceMap=this.sourceMap.map;}
+if(!this.map){this.map={};}
+Ext.applyIf(this.map,{projection:this.sourceMap.getProjection(),maxExtent:this.sourceMap.getMaxExtent(),maxResolution:this.sourceMap.getMaxResolution(),units:this.sourceMap.getUnits()});if(!(this.printProvider instanceof GeoExt.data.PrintProvider)){this.printProvider=new GeoExt.data.PrintProvider(this.printProvider);}
+this.printPage=new GeoExt.data.PrintPage({printProvider:this.printProvider});this.previewScales=new Ext.data.Store();this.previewScales.add(this.printProvider.scales.getRange());this.layers=[];var layer;Ext.each(this.sourceMap.layers,function(layer){layer.getVisibility()===true&&this.layers.push(layer.clone());},this);this.extent=this.sourceMap.getExtent();GeoExt.PrintMapPanel.superclass.initComponent.call(this);},bind:function(){this.printPage.on("change",this.fitZoom,this);this.printProvider.on("layoutchange",this.syncSize,this);this.map.events.register("moveend",this,this.updatePage);this.printPage.fit(this.sourceMap);if(this.initialConfig.limitScales===true){this.on("resize",this.calculatePreviewScales,this);this.calculatePreviewScales();}},afterRender:function(){GeoExt.PrintMapPanel.superclass.afterRender.apply(this,arguments);this.syncSize();if(!this.ownerCt){this.bind();}else{this.ownerCt.on({"afterlayout":{fn:this.bind,scope:this,single:true}});}},adjustSize:function
 (width,height){var printSize=this.printProvider.layout.get("size");var ratio=printSize.width/printSize.height;var ownerCt=this.ownerCt;var targetWidth=(ownerCt&&ownerCt.autoWidth)?0:(width||this.initialConfig.width);var targetHeight=(ownerCt&&ownerCt.autoHeight)?0:(height||this.initialConfig.height);if(targetWidth){height=targetWidth/ratio;if(targetHeight&&height>targetHeight){height=targetHeight;width=height*ratio;}else{width=targetWidth;}}else if(targetHeight){width=targetHeight*ratio;height=targetHeight;}
+return{width:width,height:height};},fitZoom:function(){if(!this._updating&&this.printPage.scale){this._updating=true;var printBounds=this.printPage.getPrintExtent(this.map);this.currentZoom=this.map.getZoomForExtent(printBounds);this.map.zoomToExtent(printBounds);delete this._updating;}},updatePage:function(){if(!this._updating){var zoom=this.map.getZoom();this._updating=true;if(zoom===this.currentZoom){this.printPage.setCenter(this.map.getCenter());}else{this.printPage.fit(this.map);}
+delete this._updating;this.currentZoom=zoom;}},calculatePreviewScales:function(){this.previewScales.removeAll();this.printPage.suspendEvents();var scale=this.printPage.scale;var viewSize=this.map.getSize();var scalesByZoom={};var zooms=[];this.printProvider.scales.each(function(rec){this.printPage.setScale(rec);var extent=this.printPage.getPrintExtent(this.map);var zoom=this.map.getZoomForExtent(extent);var idealResolution=Math.max(extent.getWidth()/viewSize.w,extent.getHeight()/viewSize.h);var resolution=this.map.getResolutionForZoom(zoom);var diff=Math.abs(idealResolution-resolution);if(!(zoom in scalesByZoom)||scalesByZoom[zoom].diff>diff){scalesByZoom[zoom]={rec:rec,diff:diff};zooms.indexOf(zoom)==-1&&zooms.push(zoom);}},this);for(var i=0,ii=zooms.length;i<ii;++i){this.previewScales.add(scalesByZoom[zooms[i]].rec);}
+scale&&this.printPage.setScale(scale);this.printPage.resumeEvents();if(scale&&this.previewScales.getCount()>0){var maxScale=this.previewScales.getAt(0);var minScale=this.previewScales.getAt(this.previewScales.getCount()-1);if(scale.get("value")<minScale.get("value")){this.printPage.setScale(minScale);}else if(scale.get("value")>maxScale.get("value")){this.printPage.setScale(maxScale);}}
+this.fitZoom();},print:function(options){this.printProvider.print(this.map,[this.printPage],options);},beforeDestroy:function(){this.map.events.unregister("moveend",this,this.updatePage);this.printPage.un("change",this.fitZoom,this);this.printProvider.un("layoutchange",this.syncSize,this);GeoExt.PrintMapPanel.superclass.beforeDestroy.apply(this,arguments);}});Ext.reg('gx_printmappanel',GeoExt.PrintMapPanel);Ext.namespace("GeoExt.data");GeoExt.data.ScaleStore=Ext.extend(Ext.data.Store,{map:null,constructor:function(config){var map=(config.map instanceof GeoExt.MapPanel?config.map.map:config.map);delete config.map;config=Ext.applyIf(config,{reader:new Ext.data.JsonReader({},["level","resolution","scale"])});GeoExt.data.ScaleStore.superclass.constructor.call(this,config);if(map){this.bind(map);}},bind:function(map,options){this.map=(map instanceof GeoExt.MapPanel?map.map:map);this.map.events.register('changebaselayer',this,this.populateFromMap);if(this.map.baseLayer){this.popul
 ateFromMap();}else{this.map.events.register('addlayer',this,this.populateOnAdd);}},unbind:function(){if(this.map){this.map.events.unregister('addlayer',this,this.populateOnAdd);this.map.events.unregister('changebaselayer',this,this.populateFromMap);delete this.map;}},populateOnAdd:function(evt){if(evt.layer.isBaseLayer){this.populateFromMap();this.map.events.unregister('addlayer',this,this.populateOnAdd);}},populateFromMap:function(){var zooms=[];var resolutions=this.map.baseLayer.resolutions;var units=this.map.baseLayer.units;for(var i=resolutions.length-1;i>=0;i--){var res=resolutions[i];zooms.push({level:i,resolution:res,scale:OpenLayers.Util.getScaleFromResolution(res,units)});}
+this.loadData(zooms);},destroy:function(){this.unbind();GeoExt.data.ScaleStore.superclass.destroy.apply(this,arguments);}});Ext.namespace("GeoExt.data");GeoExt.data.FeatureStoreMixin=function(){return{layer:null,reader:null,featureFilter:null,constructor:function(config){config=config||{};config.reader=config.reader||new GeoExt.data.FeatureReader({},config.fields);var layer=config.layer;delete config.layer;if(config.features){config.data=config.features;}
+delete config.features;var options={initDir:config.initDir};delete config.initDir;arguments.callee.superclass.constructor.call(this,config);if(layer){this.bind(layer,options);}},bind:function(layer,options){if(this.layer){return;}
+this.layer=layer;options=options||{};var initDir=options.initDir;if(options.initDir==undefined){initDir=GeoExt.data.FeatureStore.LAYER_TO_STORE|GeoExt.data.FeatureStore.STORE_TO_LAYER;}
+var features=layer.features.slice(0);if(initDir&GeoExt.data.FeatureStore.STORE_TO_LAYER){var records=this.getRange();for(var i=records.length-1;i>=0;i--){this.layer.addFeatures([records[i].getFeature()]);}}
+if(initDir&GeoExt.data.FeatureStore.LAYER_TO_STORE){this.loadData(features,true);}
+layer.events.on({"featuresadded":this.onFeaturesAdded,"featuresremoved":this.onFeaturesRemoved,"featuremodified":this.onFeatureModified,scope:this});this.on({"load":this.onLoad,"clear":this.onClear,"add":this.onAdd,"remove":this.onRemove,"update":this.onUpdate,scope:this});},unbind:function(){if(this.layer){this.layer.events.un({"featuresadded":this.onFeaturesAdded,"featuresremoved":this.onFeaturesRemoved,"featuremodified":this.onFeatureModified,scope:this});this.un("load",this.onLoad,this);this.un("clear",this.onClear,this);this.un("add",this.onAdd,this);this.un("remove",this.onRemove,this);this.un("update",this.onUpdate,this);this.layer=null;}},getRecordFromFeature:function(feature){return this.getByFeature(feature)||null;},getByFeature:function(feature){var record;if(feature.state!==OpenLayers.State.INSERT){record=this.getById(feature.id);}else{var index=this.findBy(function(r){return r.getFeature()===feature;});if(index>-1){record=this.getAt(index);}}
+return record;},onFeaturesAdded:function(evt){if(!this._adding){var features=evt.features,toAdd=features;if(this.featureFilter){toAdd=[];var i,len,feature;for(var i=0,len=features.length;i<len;i++){feature=features[i];if(this.featureFilter.evaluate(feature)!==false){toAdd.push(feature);}}}
+this._adding=true;this.loadData(toAdd,true);delete this._adding;}},onFeaturesRemoved:function(evt){if(!this._removing){var features=evt.features,feature,record,i;for(i=features.length-1;i>=0;i--){feature=features[i];record=this.getByFeature(feature);if(record!==undefined){this._removing=true;this.remove(record);delete this._removing;}}}},onFeatureModified:function(evt){if(!this._updating){var feature=evt.feature;var record=this.getByFeature(feature);if(record!==undefined){record.beginEdit();var attributes=feature.attributes;if(attributes){var fields=this.recordType.prototype.fields;for(var i=0,len=fields.length;i<len;i++){var field=fields.items[i];var key=field.mapping||field.name;if(key in attributes){record.set(field.name,field.convert(attributes[key]));}}}
+record.set("state",feature.state);record.set("fid",feature.fid);record.setFeature(feature);this._updating=true;record.endEdit();delete this._updating;}}},addFeaturesToLayer:function(records){var i,len,features;features=new Array((len=records.length));for(i=0;i<len;i++){features[i]=records[i].getFeature();}
+if(features.length>0){this._adding=true;this.layer.addFeatures(features);delete this._adding;}},onLoad:function(store,records,options){if(!options||options.add!==true){this._removing=true;this.layer.removeFeatures(this.layer.features);delete this._removing;this.addFeaturesToLayer(records);}},onClear:function(store){this._removing=true;this.layer.removeFeatures(this.layer.features);delete this._removing;},onAdd:function(store,records,index){if(!this._adding){this.addFeaturesToLayer(records);}},onRemove:function(store,record,index){if(!this._removing){var feature=record.getFeature();if(this.layer.getFeatureById(feature.id)!=null){this._removing=true;this.layer.removeFeatures([record.getFeature()]);delete this._removing;}}},onUpdate:function(store,record,operation){if(!this._updating){var defaultFields=new GeoExt.data.FeatureRecord().fields;var feature=record.getFeature();if(feature.state!==OpenLayers.State.INSERT){feature.state=OpenLayers.State.UPDATE;}
+if(record.fields){var cont=this.layer.events.triggerEvent("beforefeaturemodified",{feature:feature});if(cont!==false){var attributes=feature.attributes;record.fields.each(function(field){var key=field.mapping||field.name;if(!defaultFields.containsKey(key)){attributes[key]=record.get(field.name);}});this._updating=true;this.layer.events.triggerEvent("featuremodified",{feature:feature});delete this._updating;if(this.layer.getFeatureById(feature.id)!=null){this.layer.drawFeature(feature);}}}}},destroy:function(){this.unbind();GeoExt.data.FeatureStore.superclass.destroy.call(this);}};};GeoExt.data.FeatureStore=Ext.extend(Ext.data.Store,new GeoExt.data.FeatureStoreMixin);GeoExt.data.FeatureStore.LAYER_TO_STORE=1;GeoExt.data.FeatureStore.STORE_TO_LAYER=2;Ext.namespace("GeoExt.data");GeoExt.data.WFSCapabilitiesStore=function(c){c=c||{};GeoExt.data.WFSCapabilitiesStore.superclass.constructor.call(this,Ext.apply(c,{proxy:c.proxy||(!c.data?new Ext.data.HttpProxy({url:c.url,disableCach
 ing:false,method:"GET"}):undefined),reader:new GeoExt.data.WFSCapabilitiesReader(c,c.fields)}));};Ext.extend(GeoExt.data.WFSCapabilitiesStore,Ext.data.Store);Ext.namespace("GeoExt.plugins");GeoExt.plugins.AttributeForm=function(config){Ext.apply(this,config);};GeoExt.plugins.AttributeForm.prototype={attributeStore:null,formPanel:null,init:function(formPanel){this.formPanel=formPanel;if(this.attributeStore instanceof Ext.data.Store){this.fillForm();this.bind(this.attributeStore);}
+formPanel.on("destroy",this.onFormDestroy,this);},bind:function(store){this.unbind();store.on({"load":this.onLoad,scope:this});this.attributeStore=store;},unbind:function(){if(this.attributeStore){this.attributeStore.un("load",this.onLoad,this);}},onLoad:function(){if(this.formPanel.items){this.formPanel.removeAll();}
+this.fillForm();},fillForm:function(){this.attributeStore.each(function(record){var field=GeoExt.form.recordToField(record,Ext.apply({checkboxLabelProperty:'fieldLabel'},this.recordToFieldOptions||{}));if(field){this.formPanel.add(field);}},this);this.formPanel.doLayout();},onFormDestroy:function(){this.unbind();}};Ext.preg("gx_attributeform",GeoExt.plugins.AttributeForm);Ext.namespace('GeoExt','GeoExt.data');GeoExt.data.ProtocolProxy=function(config){Ext.apply(this,config);GeoExt.data.ProtocolProxy.superclass.constructor.apply(this,arguments);};Ext.extend(GeoExt.data.ProtocolProxy,Ext.data.DataProxy,{protocol:null,abortPrevious:true,setParamsAsOptions:false,response:null,load:function(params,reader,callback,scope,arg){if(this.fireEvent("beforeload",this,params)!==false){var o={params:params||{},request:{callback:callback,scope:scope,arg:arg},reader:reader};var cb=OpenLayers.Function.bind(this.loadResponse,this,o);if(this.abortPrevious){this.abortRequest();}
+var options={params:params,callback:cb,scope:this};Ext.applyIf(options,arg);if(this.setParamsAsOptions===true){Ext.applyIf(options,options.params);delete options.params;}
+this.response=this.protocol.read(options);}else{callback.call(scope||this,null,arg,false);}},abortRequest:function(){if(this.response){this.protocol.abort(this.response);this.response=null;}},loadResponse:function(o,response){if(response.success()){var result=o.reader.read(response);this.fireEvent("load",this,o,o.request.arg);o.request.callback.call(o.request.scope,result,o.request.arg,true);}else{this.fireEvent("loadexception",this,o,response);o.request.callback.call(o.request.scope,null,o.request.arg,false);}}});Ext.namespace("GeoExt");GeoExt.Action=Ext.extend(Ext.Action,{control:null,activateOnEnable:false,deactivateOnDisable:false,map:null,uScope:null,uHandler:null,uToggleHandler:null,uCheckHandler:null,constructor:function(config){this.uScope=config.scope;this.uHandler=config.handler;this.uToggleHandler=config.toggleHandler;this.uCheckHandler=config.checkHandler;config.scope=this;config.handler=this.pHandler;config.toggleHandler=this.pToggleHandler;config.checkHandler=t
 his.pCheckHandler;var ctrl=this.control=config.control;delete config.control;this.activateOnEnable=!!config.activateOnEnable;delete config.activateOnEnable;this.deactivateOnDisable=!!config.deactivateOnDisable;delete config.deactivateOnDisable;if(ctrl){if(config.map){config.map.addControl(ctrl);delete config.map;}
+if((config.pressed||config.checked)&&ctrl.map){ctrl.activate();}
+if(ctrl.active){config.pressed=true;config.checked=true;}
+ctrl.events.on({activate:this.onCtrlActivate,deactivate:this.onCtrlDeactivate,scope:this});}
+arguments.callee.superclass.constructor.call(this,config);},pHandler:function(cmp){var ctrl=this.control;if(ctrl&&ctrl.type==OpenLayers.Control.TYPE_BUTTON){ctrl.trigger();}
+if(this.uHandler){this.uHandler.apply(this.uScope,arguments);}},pToggleHandler:function(cmp,state){this.changeControlState(state);if(this.uToggleHandler){this.uToggleHandler.apply(this.uScope,arguments);}},pCheckHandler:function(cmp,state){this.changeControlState(state);if(this.uCheckHandler){this.uCheckHandler.apply(this.uScope,arguments);}},changeControlState:function(state){if(state){if(!this._activating){this._activating=true;this.control.activate();this.initialConfig.pressed=true;this.initialConfig.checked=true;this._activating=false;}}else{if(!this._deactivating){this._deactivating=true;this.control.deactivate();this.initialConfig.pressed=false;this.initialConfig.checked=false;this._deactivating=false;}}},onCtrlActivate:function(){var ctrl=this.control;if(ctrl.type==OpenLayers.Control.TYPE_BUTTON){this.enable();}else{this.safeCallEach("toggle",[true]);this.safeCallEach("setChecked",[true]);}},onCtrlDeactivate:function(){var ctrl=this.control;if(ctrl.type==OpenLayers.Co
 ntrol.TYPE_BUTTON){this.disable();}else{this.safeCallEach("toggle",[false]);this.safeCallEach("setChecked",[false]);}},safeCallEach:function(fnName,args){var cs=this.items;for(var i=0,len=cs.length;i<len;i++){if(cs[i][fnName]){cs[i].rendered?cs[i][fnName].apply(cs[i],args):cs[i].on({"render":cs[i][fnName].createDelegate(cs[i],args),single:true});}}},setDisabled:function(v){if(!v&&this.activateOnEnable&&this.control&&!this.control.active){this.control.activate();}
+if(v&&this.deactivateOnDisable&&this.control&&this.control.active){this.control.deactivate();}
+return GeoExt.Action.superclass.setDisabled.apply(this,arguments);}});Ext.namespace("GeoExt.tree");GeoExt.tree.TreeNodeUIEventMixin=function(){return{constructor:function(node){node.addEvents("rendernode","rawclicknode");this.superclass=arguments.callee.superclass;this.superclass.constructor.apply(this,arguments);},render:function(bulkRender){if(!this.rendered){this.superclass.render.apply(this,arguments);this.fireEvent("rendernode",this.node);}},onClick:function(e){if(this.fireEvent("rawclicknode",this.node,e)!==false){this.superclass.onClick.apply(this,arguments);}}};};Ext.namespace('GeoExt.grid');GeoExt.grid.FeatureSelectionModelMixin=function(){return{autoActivateControl:true,layerFromStore:true,selectControl:null,bound:false,superclass:null,selectedFeatures:[],autoPanMapOnSelection:false,constructor:function(config){config=config||{};if(config.selectControl instanceof OpenLayers.Control.SelectFeature){if(!config.singleSelect){var ctrl=config.selectControl;config.singleS
 elect=!(ctrl.multiple||!!ctrl.multipleKey);}}else if(config.layer instanceof OpenLayers.Layer.Vector){this.selectControl=this.createSelectControl(config.layer,config.selectControl);delete config.layer;delete config.selectControl;}
+if(config.autoPanMapOnSelection){this.autoPanMapOnSelection=true;delete config.autoPanMapOnSelection;}
+this.superclass=arguments.callee.superclass;this.superclass.constructor.call(this,config);},initEvents:function(){this.superclass.initEvents.call(this);if(this.layerFromStore){var layer=this.grid.getStore()&&this.grid.getStore().layer;if(layer&&!(this.selectControl instanceof OpenLayers.Control.SelectFeature)){this.selectControl=this.createSelectControl(layer,this.selectControl);}}
+if(this.selectControl){this.bind(this.selectControl);}},createSelectControl:function(layer,config){config=config||{};var singleSelect=config.singleSelect!==undefined?config.singleSelect:this.singleSelect;config=OpenLayers.Util.extend({toggle:true,multipleKey:singleSelect?null:(Ext.isMac?"metaKey":"ctrlKey")},config);var selectControl=new OpenLayers.Control.SelectFeature(layer,config);layer.map.addControl(selectControl);return selectControl;},bind:function(obj,options){if(!this.bound){options=options||{};this.selectControl=obj;if(obj instanceof OpenLayers.Layer.Vector){this.selectControl=this.createSelectControl(obj,options.controlConfig);}
+if(this.autoActivateControl){this.selectControl.activate();}
+var layers=this.getLayers();for(var i=0,len=layers.length;i<len;i++){layers[i].events.on({featureselected:this.featureSelected,featureunselected:this.featureUnselected,scope:this});}
+this.on("rowselect",this.rowSelected,this);this.on("rowdeselect",this.rowDeselected,this);this.bound=true;}
+return this.selectControl;},unbind:function(){var selectControl=this.selectControl;if(this.bound){var layers=this.getLayers();for(var i=0,len=layers.length;i<len;i++){layers[i].events.un({featureselected:this.featureSelected,featureunselected:this.featureUnselected,scope:this});}
+this.un("rowselect",this.rowSelected,this);this.un("rowdeselect",this.rowDeselected,this);if(this.autoActivateControl){selectControl.deactivate();}
+this.selectControl=null;this.bound=false;}
+return selectControl;},featureSelected:function(evt){if(!this._selecting){var store=this.grid.store;var row=store.findBy(function(record,id){return record.getFeature()==evt.feature;});if(row!=-1&&!this.isSelected(row)){this._selecting=true;this.selectRow(row,!this.singleSelect);this._selecting=false;this.grid.getView().focusRow(row);}}},featureUnselected:function(evt){if(!this._selecting){var store=this.grid.store;var row=store.findBy(function(record,id){return record.getFeature()==evt.feature;});if(row!=-1&&this.isSelected(row)){this._selecting=true;this.deselectRow(row);this._selecting=false;this.grid.getView().focusRow(row);}}},rowSelected:function(model,row,record){var feature=record.getFeature();if(!this._selecting&&feature){var layers=this.getLayers();for(var i=0,len=layers.length;i<len;i++){if(layers[i].selectedFeatures.indexOf(feature)==-1){this._selecting=true;this.selectControl.select(feature);this._selecting=false;this.selectedFeatures.push(feature);break;}}
+if(this.autoPanMapOnSelection){this.recenterToSelectionExtent();}}},rowDeselected:function(model,row,record){var feature=record.getFeature();if(!this._selecting&&feature){var layers=this.getLayers();for(var i=0,len=layers.length;i<len;i++){if(layers[i].selectedFeatures.indexOf(feature)!=-1){this._selecting=true;this.selectControl.unselect(feature);this._selecting=false;OpenLayers.Util.removeItem(this.selectedFeatures,feature);break;}}
+if(this.autoPanMapOnSelection&&this.selectedFeatures.length>0){this.recenterToSelectionExtent();}}},getLayers:function(){return this.selectControl.layers||[this.selectControl.layer];},recenterToSelectionExtent:function(){var map=this.selectControl.map;var selectionExtent=this.getSelectionExtent();var selectionExtentZoom=map.getZoomForExtent(selectionExtent,false);if(selectionExtentZoom>map.getZoom()){map.setCenter(selectionExtent.getCenterLonLat());}
+else{map.zoomToExtent(selectionExtent);}},getSelectionExtent:function(){var maxExtent=null;var features=this.selectedFeatures;if(features&&(features.length>0)){var geometry=null;for(var i=0,len=features.length;i<len;i++){geometry=features[i].geometry;if(geometry){if(maxExtent===null){maxExtent=new OpenLayers.Bounds();}
+maxExtent.extend(geometry.getBounds());}}}
+return maxExtent;}};};GeoExt.grid.FeatureSelectionModel=Ext.extend(Ext.grid.RowSelectionModel,new GeoExt.grid.FeatureSelectionModelMixin);Ext.namespace("GeoExt.data");GeoExt.data.WMSCapabilitiesStore=function(c){c=c||{};GeoExt.data.WMSCapabilitiesStore.superclass.constructor.call(this,Ext.apply(c,{proxy:c.proxy||(!c.data?new Ext.data.HttpProxy({url:c.url,disableCaching:false,method:"GET"}):undefined),reader:new GeoExt.data.WMSCapabilitiesReader(c,c.fields)}));};Ext.extend(GeoExt.data.WMSCapabilitiesStore,Ext.data.Store);Ext.namespace("GeoExt");GeoExt.LayerOpacitySliderTip=Ext.extend(GeoExt.SliderTip,{template:'<div>{opacity}%</div>',compiledTemplate:null,init:function(slider){this.compiledTemplate=new Ext.Template(this.template);GeoExt.LayerOpacitySliderTip.superclass.init.call(this,slider);},getText:function(thumb){var data={opacity:thumb.value};return this.compiledTemplate.apply(data);}});GeoExt.version='1.1';
Added: grass-web/trunk/user_map/lib/OpenLayers_grass.js
--- grass-web/trunk/user_map/lib/OpenLayers_grass.js	                        (rev 0)
+++ grass-web/trunk/user_map/lib/OpenLayers_grass.js	2012-04-17 13:42:26 UTC (rev 51456)
@@ -0,0 +1,1289 @@
+  OpenLayers.js -- OpenLayers Map Viewer Library
+  Copyright 2005-2011 OpenLayers Contributors, released under the FreeBSD
+  license. Please see http://svn.openlayers.org/trunk/openlayers/license.txt
+  for the full text of the license.
+  Includes compressed code under the following licenses:
+  (For uncompressed versions of the code used please see the
+  OpenLayers SVN repository: <http://openlayers.org/>)
+/* Contains portions of Prototype.js:
+ * Prototype JavaScript framework, version 1.4.0
+ *  (c) 2005 Sam Stephenson <sam at conio.net>
+ *  Prototype is freely distributable under the terms of an MIT-style license.
+ *  For details, see the Prototype web site: http://prototype.conio.net/
+*  Contains portions of Rico <http://openrico.org/>
+*  Copyright 2005 Sabre Airline Solutions
+*  Licensed under the Apache License, Version 2.0 (the "License"); you
+*  may not use this file except in compliance with the License. You
+*  may obtain a copy of the License at
+*         http://www.apache.org/licenses/LICENSE-2.0
+*  Unless required by applicable law or agreed to in writing, software
+*  distributed under the License is distributed on an "AS IS" BASIS,
+*  WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
+*  implied. See the License for the specific language governing
+*  permissions and limitations under the License.
+ * Contains XMLHttpRequest.js <http://code.google.com/p/xmlhttprequest/>
+ * Copyright 2007 Sergey Ilinsky (http://www.ilinsky.com)
+ * Licensed under the Apache License, Version 2.0 (the "License");
+ * you may not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ * http://www.apache.org/licenses/LICENSE-2.0
+ * Contains portions of Gears <http://code.google.com/apis/gears/>
+ * Copyright 2007, Google Inc.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following conditions are met:
+ *  1. Redistributions of source code must retain the above copyright notice,
+ *     this list of conditions and the following disclaimer.
+ *  2. Redistributions in binary form must reproduce the above copyright notice,
+ *     this list of conditions and the following disclaimer in the documentation
+ *     and/or other materials provided with the distribution.
+ *  3. Neither the name of Google Inc. nor the names of its contributors may be
+ *     used to endorse or promote products derived from this software without
+ *     specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+ * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO
+ * EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
+ * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
+ * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
+ * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
+ * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
+ * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * Sets up google.gears.*, which is *the only* supported way to access Gears.
+ * Circumvent this file at your own risk!
+ * In the future, Gears may automatically define google.gears.* without this
+ * file. Gears may use these objects to transparently fix bugs and compatibility
+ * issues. Applications that use the code below will continue to work seamlessly
+ * when that happens.
+ * OpenLayers.Util.pagePosition is based on Yahoo's getXY method, which is
+ * Copyright (c) 2006, Yahoo! Inc.
+ * All rights reserved.
+ * Redistribution and use of this software in source and binary forms, with or
+ * without modification, are permitted provided that the following conditions
+ * are met:
+ * * Redistributions of source code must retain the above copyright notice,
+ * * Redistributions in binary form must reproduce the above copyright notice,
+ * * Neither the name of Yahoo! Inc. nor the names of its contributors may be
+ *   specific prior written permission of Yahoo! Inc.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+ * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+ * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+ * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+ * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+ * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+ * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+ * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+ * POSSIBILITY OF SUCH DAMAGE.
+ */var OpenLayers={VERSION_NUMBER:"Release 2.11",singleFile:true,_getScriptLocation:(function(){var r=new RegExp("(^|(.*?\\/))(OpenLayers\.js)(\\?|$)"),s=document.getElementsByTagName('script'),src,m,l="";for(var i=0,len=s.length;i<len;i++){src=s[i].getAttribute('src');if(src){var m=src.match(r);if(m){l=m[1];break;}}}
+return(function(){return l;});})()};(function(){var singleFile=(typeof OpenLayers=="object"&&OpenLayers.singleFile);var scriptName=(!singleFile)?"lib/OpenLayers.js":"OpenLayers.js";var jsFiles=window.OpenLayers;window.OpenLayers={_getScriptLocation:(function(){var r=new RegExp("(^|(.*?\\/))("+scriptName+")(\\?|$)"),s=document.getElementsByTagName('script'),src,m,l="";for(var i=0,len=s.length;i<len;i++){src=s[i].getAttribute('src');if(src){var m=src.match(r);if(m){l=m[1];break;}}}
+return(function(){return l;});})()};if(!singleFile){if(!jsFiles){jsFiles=["OpenLayers/BaseTypes/Class.js","OpenLayers/Util.js","OpenLayers/BaseTypes.js","OpenLayers/BaseTypes/Bounds.js","OpenLayers/BaseTypes/Date.js","OpenLayers/BaseTypes/Element.js","OpenLayers/BaseTypes/LonLat.js","OpenLayers/BaseTypes/Pixel.js","OpenLayers/BaseTypes/Size.js","OpenLayers/Console.js","OpenLayers/Tween.js","OpenLayers/Kinetic.js","Rico/Corner.js","Rico/Color.js","OpenLayers/Ajax.js","OpenLayers/Events.js","OpenLayers/Request.js","OpenLayers/Request/XMLHttpRequest.js","OpenLayers/Projection.js","OpenLayers/Map.js","OpenLayers/Layer.js","OpenLayers/Icon.js","OpenLayers/Marker.js","OpenLayers/Marker/Box.js","OpenLayers/Popup.js","OpenLayers/Tile.js","OpenLayers/Tile/Image.js","OpenLayers/Tile/Image/IFrame.js","OpenLayers/Tile/WFS.js","OpenLayers/Layer/Image.js","OpenLayers/Layer/SphericalMercator.js","OpenLayers/Layer/EventPane.js","OpenLayers/Layer/FixedZoomLevels.js","OpenLayers/Layer/Google.
 js","OpenLayers/Layer/Google/v3.js","OpenLayers/Layer/VirtualEarth.js","OpenLayers/Layer/Yahoo.js","OpenLayers/Layer/HTTPRequest.js","OpenLayers/Layer/Grid.js","OpenLayers/Layer/MapGuide.js","OpenLayers/Layer/MapServer.js","OpenLayers/Layer/MapServer/Untiled.js","OpenLayers/Layer/KaMap.js","OpenLayers/Layer/KaMapCache.js","OpenLayers/Layer/MultiMap.js","OpenLayers/Layer/Markers.js","OpenLayers/Layer/Text.js","OpenLayers/Layer/WorldWind.js","OpenLayers/Layer/ArcGIS93Rest.js","OpenLayers/Layer/WMS.js","OpenLayers/Layer/WMS/Untiled.js","OpenLayers/Layer/WMS/Post.js","OpenLayers/Layer/WMTS.js","OpenLayers/Layer/ArcIMS.js","OpenLayers/Layer/GeoRSS.js","OpenLayers/Layer/Boxes.js","OpenLayers/Layer/XYZ.js","OpenLayers/Layer/Bing.js","OpenLayers/Layer/TMS.js","OpenLayers/Layer/TileCache.js","OpenLayers/Layer/Zoomify.js","OpenLayers/Layer/ArcGISCache.js","OpenLayers/Popup/Anchored.js","OpenLayers/Popup/AnchoredBubble.js","OpenLayers/Popup/Framed.js","OpenLayers/Popup/FramedCloud.js",
 "OpenLayers/Feature.js","OpenLayers/Feature/Vector.js","OpenLayers/Feature/WFS.js","OpenLayers/Handler.js","OpenLayers/Handler/Click.js","OpenLayers/Handler/Hover.js","OpenLayers/Handler/Point.js","OpenLayers/Handler/Path.js","OpenLayers/Handler/Polygon.js","OpenLayers/Handler/Feature.js","OpenLayers/Handler/Drag.js","OpenLayers/Handler/Pinch.js","OpenLayers/Handler/RegularPolygon.js","OpenLayers/Handler/Box.js","OpenLayers/Handler/MouseWheel.js","OpenLayers/Handler/Keyboard.js","OpenLayers/Control.js","OpenLayers/Control/Attribution.js","OpenLayers/Control/Button.js","OpenLayers/Control/ZoomBox.js","OpenLayers/Control/ZoomToMaxExtent.js","OpenLayers/Control/DragPan.js","OpenLayers/Control/Navigation.js","OpenLayers/Control/PinchZoom.js","OpenLayers/Control/TouchNavigation.js","OpenLayers/Control/MouseDefaults.js","OpenLayers/Control/MousePosition.js","OpenLayers/Control/OverviewMap.js","OpenLayers/Control/KeyboardDefaults.js","OpenLayers/Control/PanZoom.js","OpenLayers/Cont
 rol/PanZoomBar.js","OpenLayers/Control/ArgParser.js","OpenLayers/Control/Permalink.js","OpenLayers/Control/Scale.js","OpenLayers/Control/ScaleLine.js","OpenLayers/Control/Snapping.js","OpenLayers/Control/Split.js","OpenLayers/Control/LayerSwitcher.js","OpenLayers/Control/DrawFeature.js","OpenLayers/Control/DragFeature.js","OpenLayers/Control/ModifyFeature.js","OpenLayers/Control/Panel.js","OpenLayers/Control/SelectFeature.js","OpenLayers/Control/NavigationHistory.js","OpenLayers/Control/Measure.js","OpenLayers/Control/WMSGetFeatureInfo.js","OpenLayers/Control/WMTSGetFeatureInfo.js","OpenLayers/Control/Graticule.js","OpenLayers/Control/TransformFeature.js","OpenLayers/Control/SLDSelect.js","OpenLayers/Geometry.js","OpenLayers/Geometry/Rectangle.js","OpenLayers/Geometry/Collection.js","OpenLayers/Geometry/Point.js","OpenLayers/Geometry/MultiPoint.js","OpenLayers/Geometry/Curve.js","OpenLayers/Geometry/LineString.js","OpenLayers/Geometry/LinearRing.js","OpenLayers/Geometry/Poly
 gon.js","OpenLayers/Geometry/MultiLineString.js","OpenLayers/Geometry/MultiPolygon.js","OpenLayers/Geometry/Surface.js","OpenLayers/Renderer.js","OpenLayers/Renderer/Elements.js","OpenLayers/Renderer/NG.js","OpenLayers/Renderer/SVG.js","OpenLayers/Renderer/SVG2.js","OpenLayers/Renderer/Canvas.js","OpenLayers/Renderer/VML.js","OpenLayers/Layer/Vector.js","OpenLayers/Layer/PointGrid.js","OpenLayers/Layer/Vector/RootContainer.js","OpenLayers/Strategy.js","OpenLayers/Strategy/Filter.js","OpenLayers/Strategy/Fixed.js","OpenLayers/Strategy/Cluster.js","OpenLayers/Strategy/Paging.js","OpenLayers/Strategy/BBOX.js","OpenLayers/Strategy/Save.js","OpenLayers/Strategy/Refresh.js","OpenLayers/Filter.js","OpenLayers/Filter/FeatureId.js","OpenLayers/Filter/Logical.js","OpenLayers/Filter/Comparison.js","OpenLayers/Filter/Spatial.js","OpenLayers/Filter/Function.js","OpenLayers/Protocol.js","OpenLayers/Protocol/HTTP.js","OpenLayers/Protocol/SQL.js","OpenLayers/Protocol/SQL/Gears.js","OpenLaye
 rs/Protocol/WFS.js","OpenLayers/Protocol/WFS/v1.js","OpenLayers/Protocol/WFS/v1_0_0.js","OpenLayers/Protocol/WFS/v1_1_0.js","OpenLayers/Protocol/Script.js","OpenLayers/Protocol/SOS.js","OpenLayers/Protocol/SOS/v1_0_0.js","OpenLayers/Layer/PointTrack.js","OpenLayers/Layer/GML.js","OpenLayers/Style.js","OpenLayers/Style2.js","OpenLayers/StyleMap.js","OpenLayers/Rule.js","OpenLayers/Format.js","OpenLayers/Format/QueryStringFilter.js","OpenLayers/Format/XML.js","OpenLayers/Format/XML/VersionedOGC.js","OpenLayers/Format/Context.js","OpenLayers/Format/ArcXML.js","OpenLayers/Format/ArcXML/Features.js","OpenLayers/Format/GML.js","OpenLayers/Format/GML/Base.js","OpenLayers/Format/GML/v2.js","OpenLayers/Format/GML/v3.js","OpenLayers/Format/Atom.js","OpenLayers/Format/KML.js","OpenLayers/Format/GeoRSS.js","OpenLayers/Format/WFS.js","OpenLayers/Format/WFSCapabilities.js","OpenLayers/Format/WFSCapabilities/v1.js","OpenLayers/Format/WFSCapabilities/v1_0_0.js","OpenLayers/Format/WFSCapabil
 ities/v1_1_0.js","OpenLayers/Format/WFSDescribeFeatureType.js","OpenLayers/Format/WMSDescribeLayer.js","OpenLayers/Format/WMSDescribeLayer/v1_1.js","OpenLayers/Format/WKT.js","OpenLayers/Format/CQL.js","OpenLayers/Format/OSM.js","OpenLayers/Format/GPX.js","OpenLayers/Format/Filter.js","OpenLayers/Format/Filter/v1.js","OpenLayers/Format/Filter/v1_0_0.js","OpenLayers/Format/Filter/v1_1_0.js","OpenLayers/Format/SLD.js","OpenLayers/Format/SLD/v1.js","OpenLayers/Format/SLD/v1_0_0.js","OpenLayers/Format/OWSCommon.js","OpenLayers/Format/OWSCommon/v1.js","OpenLayers/Format/OWSCommon/v1_0_0.js","OpenLayers/Format/OWSCommon/v1_1_0.js","OpenLayers/Format/CSWGetDomain.js","OpenLayers/Format/CSWGetDomain/v2_0_2.js","OpenLayers/Format/CSWGetRecords.js","OpenLayers/Format/CSWGetRecords/v2_0_2.js","OpenLayers/Format/WFST.js","OpenLayers/Format/WFST/v1.js","OpenLayers/Format/WFST/v1_0_0.js","OpenLayers/Format/WFST/v1_1_0.js","OpenLayers/Format/Text.js","OpenLayers/Format/JSON.js","OpenLayers
 /Format/GeoJSON.js","OpenLayers/Format/WMC.js","OpenLayers/Format/WMC/v1.js","OpenLayers/Format/WMC/v1_0_0.js","OpenLayers/Format/WMC/v1_1_0.js","OpenLayers/Format/WCSGetCoverage.js","OpenLayers/Format/WMSCapabilities.js","OpenLayers/Format/WMSCapabilities/v1.js","OpenLayers/Format/WMSCapabilities/v1_1.js","OpenLayers/Format/WMSCapabilities/v1_1_0.js","OpenLayers/Format/WMSCapabilities/v1_1_1.js","OpenLayers/Format/WMSCapabilities/v1_3.js","OpenLayers/Format/WMSCapabilities/v1_3_0.js","OpenLayers/Format/WMSCapabilities/v1_1_1_WMSC.js","OpenLayers/Format/WMSGetFeatureInfo.js","OpenLayers/Format/SOSCapabilities.js","OpenLayers/Format/SOSCapabilities/v1_0_0.js","OpenLayers/Format/SOSGetFeatureOfInterest.js","OpenLayers/Format/SOSGetObservation.js","OpenLayers/Format/OWSContext.js","OpenLayers/Format/OWSContext/v0_3_1.js","OpenLayers/Format/WMTSCapabilities.js","OpenLayers/Format/WMTSCapabilities/v1_0_0.js","OpenLayers/Format/WPSCapabilities.js","OpenLayers/Format/WPSCapabilitie
 s/v1_0_0.js","OpenLayers/Format/WPSDescribeProcess.js","OpenLayers/Format/WPSExecute.js","OpenLayers/Format/XLS.js","OpenLayers/Format/XLS/v1.js","OpenLayers/Format/XLS/v1_1_0.js","OpenLayers/Format/OGCExceptionReport.js","OpenLayers/Layer/WFS.js","OpenLayers/Control/GetFeature.js","OpenLayers/Control/MouseToolbar.js","OpenLayers/Control/NavToolbar.js","OpenLayers/Control/PanPanel.js","OpenLayers/Control/Pan.js","OpenLayers/Control/ZoomIn.js","OpenLayers/Control/ZoomOut.js","OpenLayers/Control/ZoomPanel.js","OpenLayers/Control/EditingToolbar.js","OpenLayers/Control/Geolocate.js","OpenLayers/Symbolizer.js","OpenLayers/Symbolizer/Point.js","OpenLayers/Symbolizer/Line.js","OpenLayers/Symbolizer/Polygon.js","OpenLayers/Symbolizer/Text.js","OpenLayers/Symbolizer/Raster.js","OpenLayers/Lang.js","OpenLayers/Lang/en.js"];}
+var scriptTags=new Array(jsFiles.length);var host=OpenLayers._getScriptLocation()+"lib/";for(var i=0,len=jsFiles.length;i<len;i++){scriptTags[i]="<script src='"+host+jsFiles[i]+"'></script>";}
+if(scriptTags.length>0){document.write(scriptTags.join(""));}}})();OpenLayers.VERSION_NUMBER="Release 2.11";OpenLayers.String={startsWith:function(str,sub){return(str.indexOf(sub)==0);},contains:function(str,sub){return(str.indexOf(sub)!=-1);},trim:function(str){return str.replace(/^\s\s*/,'').replace(/\s\s*$/,'');},camelize:function(str){var oStringList=str.split('-');var camelizedString=oStringList[0];for(var i=1,len=oStringList.length;i<len;i++){var s=oStringList[i];camelizedString+=s.charAt(0).toUpperCase()+s.substring(1);}
+return camelizedString;},format:function(template,context,args){if(!context){context=window;}
+var replacer=function(str,match){var replacement;var subs=match.split(/\.+/);for(var i=0;i<subs.length;i++){if(i==0){replacement=context;}
+replacement=replacement[subs[i]];}
+if(typeof replacement=="function"){replacement=args?replacement.apply(null,args):replacement();}
+if(typeof replacement=='undefined'){return'undefined';}else{return replacement;}};return template.replace(OpenLayers.String.tokenRegEx,replacer);},tokenRegEx:/\$\{([\w.]+?)\}/g,numberRegEx:/^([+-]?)(?=\d|\.\d)\d*(\.\d*)?([Ee]([+-]?\d+))?$/,isNumeric:function(value){return OpenLayers.String.numberRegEx.test(value);},numericIf:function(value){return OpenLayers.String.isNumeric(value)?parseFloat(value):value;}};if(!String.prototype.startsWith){String.prototype.startsWith=function(sStart){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.startsWith'}));return OpenLayers.String.startsWith(this,sStart);};}
+if(!String.prototype.contains){String.prototype.contains=function(str){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.contains'}));return OpenLayers.String.contains(this,str);};}
+if(!String.prototype.trim){String.prototype.trim=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.trim'}));return OpenLayers.String.trim(this);};}
+if(!String.prototype.camelize){String.prototype.camelize=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.camelize'}));return OpenLayers.String.camelize(this);};}
+OpenLayers.Number={decimalSeparator:".",thousandsSeparator:",",limitSigDigs:function(num,sig){var fig=0;if(sig>0){fig=parseFloat(num.toPrecision(sig));}
+return fig;},format:function(num,dec,tsep,dsep){dec=(typeof dec!="undefined")?dec:0;tsep=(typeof tsep!="undefined")?tsep:OpenLayers.Number.thousandsSeparator;dsep=(typeof dsep!="undefined")?dsep:OpenLayers.Number.decimalSeparator;if(dec!=null){num=parseFloat(num.toFixed(dec));}
+var parts=num.toString().split(".");if(parts.length==1&&dec==null){dec=0;}
+var integer=parts[0];if(tsep){var thousands=/(-?[0-9]+)([0-9]{3})/;while(thousands.test(integer)){integer=integer.replace(thousands,"$1"+tsep+"$2");}}
+var str;if(dec==0){str=integer;}else{var rem=parts.length>1?parts[1]:"0";if(dec!=null){rem=rem+new Array(dec-rem.length+1).join("0");}
+str=integer+dsep+rem;}
+return str;}};if(!Number.prototype.limitSigDigs){Number.prototype.limitSigDigs=function(sig){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.Number.limitSigDigs'}));return OpenLayers.Number.limitSigDigs(this,sig);};}
+OpenLayers.Function={bind:function(func,object){var args=Array.prototype.slice.apply(arguments,[2]);return function(){var newArgs=args.concat(Array.prototype.slice.apply(arguments,[0]));return func.apply(object,newArgs);};},bindAsEventListener:function(func,object){return function(event){return func.call(object,event||window.event);};},False:function(){return false;},True:function(){return true;},Void:function(){}};if(!Function.prototype.bind){Function.prototype.bind=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.Function.bind'}));Array.prototype.unshift.apply(arguments,[this]);return OpenLayers.Function.bind.apply(null,arguments);};}
+if(!Function.prototype.bindAsEventListener){Function.prototype.bindAsEventListener=function(object){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.Function.bindAsEventListener'}));return OpenLayers.Function.bindAsEventListener(this,object);};}
+OpenLayers.Array={filter:function(array,callback,caller){var selected=[];if(Array.prototype.filter){selected=array.filter(callback,caller);}else{var len=array.length;if(typeof callback!="function"){throw new TypeError();}
+for(var i=0;i<len;i++){if(i in array){var val=array[i];if(callback.call(caller,val,i,array)){selected.push(val);}}}}
+return selected;}};OpenLayers.Class=function(){var len=arguments.length;var P=arguments[0];var F=arguments[len-1];var C=typeof F.initialize=="function"?F.initialize:function(){P.prototype.initialize.apply(this,arguments);};if(len>1){var newArgs=[C,P].concat(Array.prototype.slice.call(arguments).slice(1,len-1),F);OpenLayers.inherit.apply(null,newArgs);}else{C.prototype=F;}
+return C;};OpenLayers.Class.isPrototype=function(){};OpenLayers.Class.create=function(){return function(){if(arguments&&arguments[0]!=OpenLayers.Class.isPrototype){this.initialize.apply(this,arguments);}};};OpenLayers.Class.inherit=function(P){var C=function(){P.call(this);};var newArgs=[C].concat(Array.prototype.slice.call(arguments));OpenLayers.inherit.apply(null,newArgs);return C.prototype;};OpenLayers.inherit=function(C,P){var F=function(){};F.prototype=P.prototype;C.prototype=new F;var i,l,o;for(i=2,l=arguments.length;i<l;i++){o=arguments[i];if(typeof o==="function"){o=o.prototype;}
+OpenLayers.Util.extend(C.prototype,o);}};OpenLayers.Util=OpenLayers.Util||{};OpenLayers.Util.extend=function(destination,source){destination=destination||{};if(source){for(var property in source){var value=source[property];if(value!==undefined){destination[property]=value;}}
+var sourceIsEvt=typeof window.Event=="function"&&source instanceof window.Event;if(!sourceIsEvt&&source.hasOwnProperty&&source.hasOwnProperty("toString")){destination.toString=source.toString;}}
+return destination;};OpenLayers.Util=OpenLayers.Util||{};OpenLayers.Util.getElement=function(){var elements=[];for(var i=0,len=arguments.length;i<len;i++){var element=arguments[i];if(typeof element=='string'){element=document.getElementById(element);}
+if(arguments.length==1){return element;}
+elements.push(element);}
+return elements;};OpenLayers.Util.isElement=function(o){return!!(o&&o.nodeType===1);};OpenLayers.Util.isArray=function(a){return(Object.prototype.toString.call(a)==='[object Array]');};if(typeof window.$==="undefined"){window.$=OpenLayers.Util.getElement;}
+OpenLayers.Util.removeItem=function(array,item){for(var i=array.length-1;i>=0;i--){if(array[i]==item){array.splice(i,1);}}
+return array;};OpenLayers.Util.clearArray=function(array){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'array = []'}));array.length=0;};OpenLayers.Util.indexOf=function(array,obj){if(typeof array.indexOf=="function"){return array.indexOf(obj);}else{for(var i=0,len=array.length;i<len;i++){if(array[i]==obj){return i;}}
+return-1;}};OpenLayers.Util.modifyDOMElement=function(element,id,px,sz,position,border,overflow,opacity){if(id){element.id=id;}
+if(px){element.style.left=px.x+"px";element.style.top=px.y+"px";}
+if(sz){element.style.width=sz.w+"px";element.style.height=sz.h+"px";}
+if(position){element.style.position=position;}
+if(border){element.style.border=border;}
+if(overflow){element.style.overflow=overflow;}
+if(parseFloat(opacity)>=0.0&&parseFloat(opacity)<1.0){element.style.filter='alpha(opacity='+(opacity*100)+')';element.style.opacity=opacity;}else if(parseFloat(opacity)==1.0){element.style.filter='';element.style.opacity='';}};OpenLayers.Util.createDiv=function(id,px,sz,imgURL,position,border,overflow,opacity){var dom=document.createElement('div');if(imgURL){dom.style.backgroundImage='url('+imgURL+')';}
+if(!id){id=OpenLayers.Util.createUniqueID("OpenLayersDiv");}
+if(!position){position="absolute";}
+OpenLayers.Util.modifyDOMElement(dom,id,px,sz,position,border,overflow,opacity);return dom;};OpenLayers.Util.createImage=function(id,px,sz,imgURL,position,border,opacity,delayDisplay){var image=document.createElement("img");if(!id){id=OpenLayers.Util.createUniqueID("OpenLayersDiv");}
+if(!position){position="relative";}
+OpenLayers.Util.modifyDOMElement(image,id,px,sz,position,border,null,opacity);if(delayDisplay){image.style.display="none";OpenLayers.Event.observe(image,"load",OpenLayers.Function.bind(OpenLayers.Util.onImageLoad,image));OpenLayers.Event.observe(image,"error",OpenLayers.Function.bind(OpenLayers.Util.onImageLoadError,image));}
+image.style.alt=id;image.galleryImg="no";if(imgURL){image.src=imgURL;}
+return image;};OpenLayers.Util.setOpacity=function(element,opacity){OpenLayers.Util.modifyDOMElement(element,null,null,null,null,null,null,opacity);};OpenLayers.Util.onImageLoad=function(){if(!this.viewRequestID||(this.map&&this.viewRequestID==this.map.viewRequestID)){this.style.display="";}
+OpenLayers.Element.removeClass(this,"olImageLoadError");};OpenLayers.IMAGE_RELOAD_ATTEMPTS=0;OpenLayers.Util.onImageLoadError=function(){this._attempts=(this._attempts)?(this._attempts+1):1;if(this._attempts<=OpenLayers.IMAGE_RELOAD_ATTEMPTS){var urls=this.urls;if(urls&&OpenLayers.Util.isArray(urls)&&urls.length>1){var src=this.src.toString();var current_url,k;for(k=0;current_url=urls[k];k++){if(src.indexOf(current_url)!=-1){break;}}
+var guess=Math.floor(urls.length*Math.random());var new_url=urls[guess];k=0;while(new_url==current_url&&k++<4){guess=Math.floor(urls.length*Math.random());new_url=urls[guess];}
+this.src=src.replace(current_url,new_url);}else{this.src=this.src;}}else{OpenLayers.Element.addClass(this,"olImageLoadError");}
+this.style.display="";};OpenLayers.Util.alphaHackNeeded=null;OpenLayers.Util.alphaHack=function(){if(OpenLayers.Util.alphaHackNeeded==null){var arVersion=navigator.appVersion.split("MSIE");var version=parseFloat(arVersion[1]);var filter=false;try{filter=!!(document.body.filters);}catch(e){}
+OpenLayers.Util.alphaHackNeeded=(filter&&(version>=5.5)&&(version<7));}
+return OpenLayers.Util.alphaHackNeeded;};OpenLayers.Util.modifyAlphaImageDiv=function(div,id,px,sz,imgURL,position,border,sizing,opacity){OpenLayers.Util.modifyDOMElement(div,id,px,sz,position,null,null,opacity);var img=div.childNodes[0];if(imgURL){img.src=imgURL;}
+OpenLayers.Util.modifyDOMElement(img,div.id+"_innerImage",null,sz,"relative",border);if(OpenLayers.Util.alphaHack()){if(div.style.display!="none"){div.style.display="inline-block";}
+if(sizing==null){sizing="scale";}
+div.style.filter="progid:DXImageTransform.Microsoft"+".AlphaImageLoader(src='"+img.src+"', "+"sizingMethod='"+sizing+"')";if(parseFloat(div.style.opacity)>=0.0&&parseFloat(div.style.opacity)<1.0){div.style.filter+=" alpha(opacity="+div.style.opacity*100+")";}
+img.style.filter="alpha(opacity=0)";}};OpenLayers.Util.createAlphaImageDiv=function(id,px,sz,imgURL,position,border,sizing,opacity,delayDisplay){var div=OpenLayers.Util.createDiv();var img=OpenLayers.Util.createImage(null,null,null,null,null,null,null,false);div.appendChild(img);if(delayDisplay){img.style.display="none";OpenLayers.Event.observe(img,"load",OpenLayers.Function.bind(OpenLayers.Util.onImageLoad,div));OpenLayers.Event.observe(img,"error",OpenLayers.Function.bind(OpenLayers.Util.onImageLoadError,div));}
+OpenLayers.Util.modifyAlphaImageDiv(div,id,px,sz,imgURL,position,border,sizing,opacity);return div;};OpenLayers.Util.upperCaseObject=function(object){var uObject={};for(var key in object){uObject[key.toUpperCase()]=object[key];}
+return uObject;};OpenLayers.Util.applyDefaults=function(to,from){to=to||{};var fromIsEvt=typeof window.Event=="function"&&from instanceof window.Event;for(var key in from){if(to[key]===undefined||(!fromIsEvt&&from.hasOwnProperty&&from.hasOwnProperty(key)&&!to.hasOwnProperty(key))){to[key]=from[key];}}
+if(!fromIsEvt&&from&&from.hasOwnProperty&&from.hasOwnProperty('toString')&&!to.hasOwnProperty('toString')){to.toString=from.toString;}
+return to;};OpenLayers.Util.getParameterString=function(params){var paramsArray=[];for(var key in params){var value=params[key];if((value!=null)&&(typeof value!='function')){var encodedValue;if(typeof value=='object'&&value.constructor==Array){var encodedItemArray=[];var item;for(var itemIndex=0,len=value.length;itemIndex<len;itemIndex++){item=value[itemIndex];encodedItemArray.push(encodeURIComponent((item===null||item===undefined)?"":item));}
+encodedValue=encodedItemArray.join(",");}
+else{encodedValue=encodeURIComponent(value);}
+paramsArray.push(encodeURIComponent(key)+"="+encodedValue);}}
+return paramsArray.join("&");};OpenLayers.Util.urlAppend=function(url,paramStr){var newUrl=url;if(paramStr){var parts=(url+" ").split(/[?&]/);newUrl+=(parts.pop()===" "?paramStr:parts.length?"&"+paramStr:"?"+paramStr);}
+return newUrl;};OpenLayers.ImgPath='';OpenLayers.Util.getImagesLocation=function(){return OpenLayers.ImgPath||(OpenLayers._getScriptLocation()+"img/");};OpenLayers.Util.Try=function(){var returnValue=null;for(var i=0,len=arguments.length;i<len;i++){var lambda=arguments[i];try{returnValue=lambda();break;}catch(e){}}
+return returnValue;};OpenLayers.Util.getXmlNodeValue=function(node){var val=null;OpenLayers.Util.Try(function(){val=node.text;if(!val){val=node.textContent;}
+if(!val){val=node.firstChild.nodeValue;}},function(){val=node.textContent;});return val;};OpenLayers.Util.mouseLeft=function(evt,div){var target=(evt.relatedTarget)?evt.relatedTarget:evt.toElement;while(target!=div&&target!=null){target=target.parentNode;}
+return(target!=div);};OpenLayers.Util.DEFAULT_PRECISION=14;OpenLayers.Util.toFloat=function(number,precision){if(precision==null){precision=OpenLayers.Util.DEFAULT_PRECISION;}
+if(typeof number!=="number"){number=parseFloat(number);}
+return precision===0?number:parseFloat(number.toPrecision(precision));};OpenLayers.Util.rad=function(x){return x*Math.PI/180;};OpenLayers.Util.deg=function(x){return x*180/Math.PI;};OpenLayers.Util.VincentyConstants={a:6378137,b:6356752.3142,f:1/298.257223563};OpenLayers.Util.distVincenty=function(p1,p2){var ct=OpenLayers.Util.VincentyConstants;var a=ct.a,b=ct.b,f=ct.f;var L=OpenLayers.Util.rad(p2.lon-p1.lon);var U1=Math.atan((1-f)*Math.tan(OpenLayers.Util.rad(p1.lat)));var U2=Math.atan((1-f)*Math.tan(OpenLayers.Util.rad(p2.lat)));var sinU1=Math.sin(U1),cosU1=Math.cos(U1);var sinU2=Math.sin(U2),cosU2=Math.cos(U2);var lambda=L,lambdaP=2*Math.PI;var iterLimit=20;while(Math.abs(lambda-lambdaP)>1e-12&&--iterLimit>0){var sinLambda=Math.sin(lambda),cosLambda=Math.cos(lambda);var sinSigma=Math.sqrt((cosU2*sinLambda)*(cosU2*sinLambda)+
+(cosU1*sinU2-sinU1*cosU2*cosLambda)*(cosU1*sinU2-sinU1*cosU2*cosLambda));if(sinSigma==0){return 0;}
+var cosSigma=sinU1*sinU2+cosU1*cosU2*cosLambda;var sigma=Math.atan2(sinSigma,cosSigma);var alpha=Math.asin(cosU1*cosU2*sinLambda/sinSigma);var cosSqAlpha=Math.cos(alpha)*Math.cos(alpha);var cos2SigmaM=cosSigma-2*sinU1*sinU2/cosSqAlpha;var C=f/16*cosSqAlpha*(4+f*(4-3*cosSqAlpha));lambdaP=lambda;lambda=L+(1-C)*f*Math.sin(alpha)*(sigma+C*sinSigma*(cos2SigmaM+C*cosSigma*(-1+2*cos2SigmaM*cos2SigmaM)));}
+if(iterLimit==0){return NaN;}
+var uSq=cosSqAlpha*(a*a-b*b)/(b*b);var A=1+uSq/16384*(4096+uSq*(-768+uSq*(320-175*uSq)));var B=uSq/1024*(256+uSq*(-128+uSq*(74-47*uSq)));var deltaSigma=B*sinSigma*(cos2SigmaM+B/4*(cosSigma*(-1+2*cos2SigmaM*cos2SigmaM)-
+B/6*cos2SigmaM*(-3+4*sinSigma*sinSigma)*(-3+4*cos2SigmaM*cos2SigmaM)));var s=b*A*(sigma-deltaSigma);var d=s.toFixed(3)/1000;return d;};OpenLayers.Util.destinationVincenty=function(lonlat,brng,dist){var u=OpenLayers.Util;var ct=u.VincentyConstants;var a=ct.a,b=ct.b,f=ct.f;var lon1=lonlat.lon;var lat1=lonlat.lat;var s=dist;var alpha1=u.rad(brng);var sinAlpha1=Math.sin(alpha1);var cosAlpha1=Math.cos(alpha1);var tanU1=(1-f)*Math.tan(u.rad(lat1));var cosU1=1/Math.sqrt((1+tanU1*tanU1)),sinU1=tanU1*cosU1;var sigma1=Math.atan2(tanU1,cosAlpha1);var sinAlpha=cosU1*sinAlpha1;var cosSqAlpha=1-sinAlpha*sinAlpha;var uSq=cosSqAlpha*(a*a-b*b)/(b*b);var A=1+uSq/16384*(4096+uSq*(-768+uSq*(320-175*uSq)));var B=uSq/1024*(256+uSq*(-128+uSq*(74-47*uSq)));var sigma=s/(b*A),sigmaP=2*Math.PI;while(Math.abs(sigma-sigmaP)>1e-12){var cos2SigmaM=Math.cos(2*sigma1+sigma);var sinSigma=Math.sin(sigma);var cosSigma=Math.cos(sigma);var deltaSigma=B*sinSigma*(cos2SigmaM+B/4*(cosSigma*(-1+2*cos2SigmaM*cos2Sigm
 aM)-
+B/6*cos2SigmaM*(-3+4*sinSigma*sinSigma)*(-3+4*cos2SigmaM*cos2SigmaM)));sigmaP=sigma;sigma=s/(b*A)+deltaSigma;}
+var tmp=sinU1*sinSigma-cosU1*cosSigma*cosAlpha1;var lat2=Math.atan2(sinU1*cosSigma+cosU1*sinSigma*cosAlpha1,(1-f)*Math.sqrt(sinAlpha*sinAlpha+tmp*tmp));var lambda=Math.atan2(sinSigma*sinAlpha1,cosU1*cosSigma-sinU1*sinSigma*cosAlpha1);var C=f/16*cosSqAlpha*(4+f*(4-3*cosSqAlpha));var L=lambda-(1-C)*f*sinAlpha*(sigma+C*sinSigma*(cos2SigmaM+C*cosSigma*(-1+2*cos2SigmaM*cos2SigmaM)));var revAz=Math.atan2(sinAlpha,-tmp);return new OpenLayers.LonLat(lon1+u.deg(L),u.deg(lat2));};OpenLayers.Util.getParameters=function(url){url=(url===null||url===undefined)?window.location.href:url;var paramsString="";if(OpenLayers.String.contains(url,'?')){var start=url.indexOf('?')+1;var end=OpenLayers.String.contains(url,"#")?url.indexOf('#'):url.length;paramsString=url.substring(start,end);}
+var parameters={};var pairs=paramsString.split(/[&;]/);for(var i=0,len=pairs.length;i<len;++i){var keyValue=pairs[i].split('=');if(keyValue[0]){var key=keyValue[0];try{key=decodeURIComponent(key);}catch(err){key=unescape(key);}
+var value=(keyValue[1]||'').replace(/\+/g," ");try{value=decodeURIComponent(value);}catch(err){value=unescape(value);}
+value=value.split(",");if(value.length==1){value=value[0];}
+parameters[key]=value;}}
+return parameters;};OpenLayers.Util.getArgs=function(url){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.Util.getParameters'}));return OpenLayers.Util.getParameters(url);};OpenLayers.Util.lastSeqID=0;OpenLayers.Util.createUniqueID=function(prefix){if(prefix==null){prefix="id_";}
+OpenLayers.Util.lastSeqID+=1;return prefix+OpenLayers.Util.lastSeqID;};OpenLayers.INCHES_PER_UNIT={'inches':1.0,'ft':12.0,'mi':63360.0,'m':39.3701,'km':39370.1,'dd':4374754,'yd':36};OpenLayers.INCHES_PER_UNIT["in"]=OpenLayers.INCHES_PER_UNIT.inches;OpenLayers.INCHES_PER_UNIT["degrees"]=OpenLayers.INCHES_PER_UNIT.dd;OpenLayers.INCHES_PER_UNIT["nmi"]=1852*OpenLayers.INCHES_PER_UNIT.m;OpenLayers.METERS_PER_INCH=0.02540005080010160020;OpenLayers.Util.extend(OpenLayers.INCHES_PER_UNIT,{"Inch":OpenLayers.INCHES_PER_UNIT.inches,"Meter":1.0/OpenLayers.METERS_PER_INCH,"Foot":0.30480060960121920243/OpenLayers.METERS_PER_INCH,"IFoot":0.30480000000000000000/OpenLayers.METERS_PER_INCH,"ClarkeFoot":0.3047972651151/OpenLayers.METERS_PER_INCH,"SearsFoot":0.30479947153867624624/OpenLayers.METERS_PER_INCH,"GoldCoastFoot":0.30479971018150881758/OpenLayers.METERS_PER_INCH,"IInch":0.02540000000000000000/OpenLayers.METERS_PER_INCH,"MicroInch":0.00002540000000000000/OpenLayers.METERS_PER_INCH,"Mil
 ":0.00000002540000000000/OpenLayers.METERS_PER_INCH,"Centimeter":0.01000000000000000000/OpenLayers.METERS_PER_INCH,"Kilometer":1000.00000000000000000000/OpenLayers.METERS_PER_INCH,"Yard":0.91440182880365760731/OpenLayers.METERS_PER_INCH,"SearsYard":0.914398414616029/OpenLayers.METERS_PER_INCH,"IndianYard":0.91439853074444079983/OpenLayers.METERS_PER_INCH,"IndianYd37":0.91439523/OpenLayers.METERS_PER_INCH,"IndianYd62":0.9143988/OpenLayers.METERS_PER_INCH,"IndianYd75":0.9143985/OpenLayers.METERS_PER_INCH,"IndianFoot":0.30479951/OpenLayers.METERS_PER_INCH,"IndianFt37":0.30479841/OpenLayers.METERS_PER_INCH,"IndianFt62":0.3047996/OpenLayers.METERS_PER_INCH,"IndianFt75":0.3047995/OpenLayers.METERS_PER_INCH,"Mile":1609.34721869443738887477/OpenLayers.METERS_PER_INCH,"IYard":0.91440000000000000000/OpenLayers.METERS_PER_INCH,"IMile":1609.34400000000000000000/OpenLayers.METERS_PER_INCH,"NautM":1852.00000000000000000000/OpenLayers.METERS_PER_INCH,"Lat-66":110943.316488932731/OpenLayers
 .METERS_PER_INCH,"Lat-83":110946.25736872234125/OpenLayers.METERS_PER_INCH,"Decimeter":0.10000000000000000000/OpenLayers.METERS_PER_INCH,"Millimeter":0.00100000000000000000/OpenLayers.METERS_PER_INCH,"Dekameter":10.00000000000000000000/OpenLayers.METERS_PER_INCH,"Decameter":10.00000000000000000000/OpenLayers.METERS_PER_INCH,"Hectometer":100.00000000000000000000/OpenLayers.METERS_PER_INCH,"GermanMeter":1.0000135965/OpenLayers.METERS_PER_INCH,"CaGrid":0.999738/OpenLayers.METERS_PER_INCH,"ClarkeChain":20.1166194976/OpenLayers.METERS_PER_INCH,"GunterChain":20.11684023368047/OpenLayers.METERS_PER_INCH,"BenoitChain":20.116782494375872/OpenLayers.METERS_PER_INCH,"SearsChain":20.11676512155/OpenLayers.METERS_PER_INCH,"ClarkeLink":0.201166194976/OpenLayers.METERS_PER_INCH,"GunterLink":0.2011684023368047/OpenLayers.METERS_PER_INCH,"BenoitLink":0.20116782494375872/OpenLayers.METERS_PER_INCH,"SearsLink":0.2011676512155/OpenLayers.METERS_PER_INCH,"Rod":5.02921005842012/OpenLayers.METERS_
 PER_INCH,"IntnlChain":20.1168/OpenLayers.METERS_PER_INCH,"IntnlLink":0.201168/OpenLayers.METERS_PER_INCH,"Perch":5.02921005842012/OpenLayers.METERS_PER_INCH,"Pole":5.02921005842012/OpenLayers.METERS_PER_INCH,"Furlong":201.1684023368046/OpenLayers.METERS_PER_INCH,"Rood":3.778266898/OpenLayers.METERS_PER_INCH,"CapeFoot":0.3047972615/OpenLayers.METERS_PER_INCH,"Brealey":375.00000000000000000000/OpenLayers.METERS_PER_INCH,"ModAmFt":0.304812252984505969011938/OpenLayers.METERS_PER_INCH,"Fathom":1.8288/OpenLayers.METERS_PER_INCH,"NautM-UK":1853.184/OpenLayers.METERS_PER_INCH,"50kilometers":50000.0/OpenLayers.METERS_PER_INCH,"150kilometers":150000.0/OpenLayers.METERS_PER_INCH});OpenLayers.Util.extend(OpenLayers.INCHES_PER_UNIT,{"mm":OpenLayers.INCHES_PER_UNIT["Meter"]/1000.0,"cm":OpenLayers.INCHES_PER_UNIT["Meter"]/100.0,"dm":OpenLayers.INCHES_PER_UNIT["Meter"]*100.0,"km":OpenLayers.INCHES_PER_UNIT["Meter"]*1000.0,"kmi":OpenLayers.INCHES_PER_UNIT["nmi"],"fath":OpenLayers.INCHES_PER
 _UNIT["Fathom"],"ch":OpenLayers.INCHES_PER_UNIT["IntnlChain"],"link":OpenLayers.INCHES_PER_UNIT["IntnlLink"],"us-in":OpenLayers.INCHES_PER_UNIT["inches"],"us-ft":OpenLayers.INCHES_PER_UNIT["Foot"],"us-yd":OpenLayers.INCHES_PER_UNIT["Yard"],"us-ch":OpenLayers.INCHES_PER_UNIT["GunterChain"],"us-mi":OpenLayers.INCHES_PER_UNIT["Mile"],"ind-yd":OpenLayers.INCHES_PER_UNIT["IndianYd37"],"ind-ft":OpenLayers.INCHES_PER_UNIT["IndianFt37"],"ind-ch":20.11669506/OpenLayers.METERS_PER_INCH});OpenLayers.DOTS_PER_INCH=72;OpenLayers.Util.normalizeScale=function(scale){var normScale=(scale>1.0)?(1.0/scale):scale;return normScale;};OpenLayers.Util.getResolutionFromScale=function(scale,units){var resolution;if(scale){if(units==null){units="degrees";}
+var normScale=OpenLayers.Util.normalizeScale(scale);resolution=1/(normScale*OpenLayers.INCHES_PER_UNIT[units]*OpenLayers.DOTS_PER_INCH);}
+return resolution;};OpenLayers.Util.getScaleFromResolution=function(resolution,units){if(units==null){units="degrees";}
+var scale=resolution*OpenLayers.INCHES_PER_UNIT[units]*OpenLayers.DOTS_PER_INCH;return scale;};OpenLayers.Util.safeStopPropagation=function(evt){OpenLayers.Event.stop(evt,true);};OpenLayers.Util.pagePosition=function(forElement){var pos=[0,0];var viewportElement=OpenLayers.Util.getViewportElement();if(!forElement||forElement==window||forElement==viewportElement){return pos;}
+var BUGGY_GECKO_BOX_OBJECT=OpenLayers.IS_GECKO&&document.getBoxObjectFor&&OpenLayers.Element.getStyle(forElement,'position')=='absolute'&&(forElement.style.top==''||forElement.style.left=='');var parent=null;var box;if(forElement.getBoundingClientRect){box=forElement.getBoundingClientRect();var scrollTop=viewportElement.scrollTop;var scrollLeft=viewportElement.scrollLeft;pos[0]=box.left+scrollLeft;pos[1]=box.top+scrollTop;}else if(document.getBoxObjectFor&&!BUGGY_GECKO_BOX_OBJECT){box=document.getBoxObjectFor(forElement);var vpBox=document.getBoxObjectFor(viewportElement);pos[0]=box.screenX-vpBox.screenX;pos[1]=box.screenY-vpBox.screenY;}else{pos[0]=forElement.offsetLeft;pos[1]=forElement.offsetTop;parent=forElement.offsetParent;if(parent!=forElement){while(parent){pos[0]+=parent.offsetLeft;pos[1]+=parent.offsetTop;parent=parent.offsetParent;}}
+var browser=OpenLayers.BROWSER_NAME;if(browser=="opera"||(browser=="safari"&&OpenLayers.Element.getStyle(forElement,'position')=='absolute')){pos[1]-=document.body.offsetTop;}
+parent=forElement.offsetParent;while(parent&&parent!=document.body){pos[0]-=parent.scrollLeft;if(browser!="opera"||parent.tagName!='TR'){pos[1]-=parent.scrollTop;}
+parent=parent.offsetParent;}}
+return pos;};OpenLayers.Util.getViewportElement=function(){var viewportElement=arguments.callee.viewportElement;if(viewportElement==undefined){viewportElement=(OpenLayers.BROWSER_NAME=="msie"&&document.compatMode!='CSS1Compat')?document.body:document.documentElement;arguments.callee.viewportElement=viewportElement;}
+return viewportElement;};OpenLayers.Util.isEquivalentUrl=function(url1,url2,options){options=options||{};OpenLayers.Util.applyDefaults(options,{ignoreCase:true,ignorePort80:true,ignoreHash:true});var urlObj1=OpenLayers.Util.createUrlObject(url1,options);var urlObj2=OpenLayers.Util.createUrlObject(url2,options);for(var key in urlObj1){if(key!=="args"){if(urlObj1[key]!=urlObj2[key]){return false;}}}
+for(var key in urlObj1.args){if(urlObj1.args[key]!=urlObj2.args[key]){return false;}
+delete urlObj2.args[key];}
+for(var key in urlObj2.args){return false;}
+return true;};OpenLayers.Util.createUrlObject=function(url,options){options=options||{};if(!(/^\w+:\/\//).test(url)){var loc=window.location;var port=loc.port?":"+loc.port:"";var fullUrl=loc.protocol+"//"+loc.host.split(":").shift()+port;if(url.indexOf("/")===0){url=fullUrl+url;}else{var parts=loc.pathname.split("/");parts.pop();url=fullUrl+parts.join("/")+"/"+url;}}
+if(options.ignoreCase){url=url.toLowerCase();}
+var a=document.createElement('a');a.href=url;var urlObject={};urlObject.host=a.host.split(":").shift();urlObject.protocol=a.protocol;if(options.ignorePort80){urlObject.port=(a.port=="80"||a.port=="0")?"":a.port;}else{urlObject.port=(a.port==""||a.port=="0")?"80":a.port;}
+urlObject.hash=(options.ignoreHash||a.hash==="#")?"":a.hash;var queryString=a.search;if(!queryString){var qMark=url.indexOf("?");queryString=(qMark!=-1)?url.substr(qMark):"";}
+urlObject.args=OpenLayers.Util.getParameters(queryString);urlObject.pathname=(a.pathname.charAt(0)=="/")?a.pathname:"/"+a.pathname;return urlObject;};OpenLayers.Util.removeTail=function(url){var head=null;var qMark=url.indexOf("?");var hashMark=url.indexOf("#");if(qMark==-1){head=(hashMark!=-1)?url.substr(0,hashMark):url;}else{head=(hashMark!=-1)?url.substr(0,Math.min(qMark,hashMark)):url.substr(0,qMark);}
+return head;};OpenLayers.IS_GECKO=(function(){var ua=navigator.userAgent.toLowerCase();return ua.indexOf("webkit")==-1&&ua.indexOf("gecko")!=-1;})();OpenLayers.BROWSER_NAME=(function(){var name="";var ua=navigator.userAgent.toLowerCase();if(ua.indexOf("opera")!=-1){name="opera";}else if(ua.indexOf("msie")!=-1){name="msie";}else if(ua.indexOf("safari")!=-1){name="safari";}else if(ua.indexOf("mozilla")!=-1){if(ua.indexOf("firefox")!=-1){name="firefox";}else{name="mozilla";}}
+return name;})();OpenLayers.Util.getBrowserName=function(){return OpenLayers.BROWSER_NAME;};OpenLayers.Util.getRenderedDimensions=function(contentHTML,size,options){var w,h;var container=document.createElement("div");container.style.visibility="hidden";var containerElement=(options&&options.containerElement)?options.containerElement:document.body;if(size){if(size.w){w=size.w;container.style.width=w+"px";}else if(size.h){h=size.h;container.style.height=h+"px";}}
+if(options&&options.displayClass){container.className=options.displayClass;}
+var content=document.createElement("div");content.innerHTML=contentHTML;content.style.overflow="visible";if(content.childNodes){for(var i=0,l=content.childNodes.length;i<l;i++){if(!content.childNodes[i].style)continue;content.childNodes[i].style.overflow="visible";}}
+container.appendChild(content);containerElement.appendChild(container);var parentHasPositionAbsolute=false;var parent=container.parentNode;while(parent&&parent.tagName.toLowerCase()!="body"){var parentPosition=OpenLayers.Element.getStyle(parent,"position");if(parentPosition=="absolute"){parentHasPositionAbsolute=true;break;}else if(parentPosition&&parentPosition!="static"){break;}
+parent=parent.parentNode;}
+if(!parentHasPositionAbsolute){container.style.position="absolute";}
+if(!w){w=parseInt(content.scrollWidth);container.style.width=w+"px";}
+if(!h){h=parseInt(content.scrollHeight);}
+container.removeChild(content);containerElement.removeChild(container);return new OpenLayers.Size(w,h);};OpenLayers.Util.getScrollbarWidth=function(){var scrollbarWidth=OpenLayers.Util._scrollbarWidth;if(scrollbarWidth==null){var scr=null;var inn=null;var wNoScroll=0;var wScroll=0;scr=document.createElement('div');scr.style.position='absolute';scr.style.top='-1000px';scr.style.left='-1000px';scr.style.width='100px';scr.style.height='50px';scr.style.overflow='hidden';inn=document.createElement('div');inn.style.width='100%';inn.style.height='200px';scr.appendChild(inn);document.body.appendChild(scr);wNoScroll=inn.offsetWidth;scr.style.overflow='scroll';wScroll=inn.offsetWidth;document.body.removeChild(document.body.lastChild);OpenLayers.Util._scrollbarWidth=(wNoScroll-wScroll);scrollbarWidth=OpenLayers.Util._scrollbarWidth;}
+return scrollbarWidth;};OpenLayers.Util.getFormattedLonLat=function(coordinate,axis,dmsOption){if(!dmsOption){dmsOption='dms';}
+coordinate=(coordinate+540)%360-180;var abscoordinate=Math.abs(coordinate);var coordinatedegrees=Math.floor(abscoordinate);var coordinateminutes=(abscoordinate-coordinatedegrees)/(1/60);var tempcoordinateminutes=coordinateminutes;coordinateminutes=Math.floor(coordinateminutes);var coordinateseconds=(tempcoordinateminutes-coordinateminutes)/(1/60);coordinateseconds=Math.round(coordinateseconds*10);coordinateseconds/=10;if(coordinateseconds>=60){coordinateseconds-=60;coordinateminutes+=1;if(coordinateminutes>=60){coordinateminutes-=60;coordinatedegrees+=1;}}
+if(coordinatedegrees<10){coordinatedegrees="0"+coordinatedegrees;}
+var str=coordinatedegrees+"\u00B0";if(dmsOption.indexOf('dm')>=0){if(coordinateminutes<10){coordinateminutes="0"+coordinateminutes;}
+str+=coordinateminutes+"'";if(dmsOption.indexOf('dms')>=0){if(coordinateseconds<10){coordinateseconds="0"+coordinateseconds;}
+str+=coordinateseconds+'"';}}
+if(axis=="lon"){str+=coordinate<0?OpenLayers.i18n("W"):OpenLayers.i18n("E");}else{str+=coordinate<0?OpenLayers.i18n("S"):OpenLayers.i18n("N");}
+return str;};OpenLayers.Projection=OpenLayers.Class({proj:null,projCode:null,titleRegEx:/\+title=[^\+]*/,initialize:function(projCode,options){OpenLayers.Util.extend(this,options);this.projCode=projCode;if(window.Proj4js){this.proj=new Proj4js.Proj(projCode);}},getCode:function(){return this.proj?this.proj.srsCode:this.projCode;},getUnits:function(){return this.proj?this.proj.units:null;},toString:function(){return this.getCode();},equals:function(projection){var p=projection,equals=false;if(p){if(window.Proj4js&&this.proj.defData&&p.proj.defData){equals=this.proj.defData.replace(this.titleRegEx,"")==p.proj.defData.replace(this.titleRegEx,"");}else if(p.getCode){var source=this.getCode(),target=p.getCode();equals=source==target||!!OpenLayers.Projection.transforms[source]&&OpenLayers.Projection.transforms[source][target]===OpenLayers.Projection.nullTransform;}}
+return equals;},destroy:function(){delete this.proj;delete this.projCode;},CLASS_NAME:"OpenLayers.Projection"});OpenLayers.Projection.transforms={};OpenLayers.Projection.addTransform=function(from,to,method){if(!OpenLayers.Projection.transforms[from]){OpenLayers.Projection.transforms[from]={};}
+OpenLayers.Projection.transforms[from][to]=method;};OpenLayers.Projection.transform=function(point,source,dest){if(source.proj&&dest.proj){point=Proj4js.transform(source.proj,dest.proj,point);}else if(source&&dest&&OpenLayers.Projection.transforms[source.getCode()]&&OpenLayers.Projection.transforms[source.getCode()][dest.getCode()]){OpenLayers.Projection.transforms[source.getCode()][dest.getCode()](point);}
+return point;};OpenLayers.Projection.nullTransform=function(point){return point;};OpenLayers.Console={log:function(){},debug:function(){},info:function(){},warn:function(){},error:function(){},userError:function(error){alert(error);},assert:function(){},dir:function(){},dirxml:function(){},trace:function(){},group:function(){},groupEnd:function(){},time:function(){},timeEnd:function(){},profile:function(){},profileEnd:function(){},count:function(){},CLASS_NAME:"OpenLayers.Console"};(function(){var scripts=document.getElementsByTagName("script");for(var i=0,len=scripts.length;i<len;++i){if(scripts[i].src.indexOf("firebug.js")!=-1){if(console){OpenLayers.Util.extend(OpenLayers.Console,console);break;}}}})();OpenLayers.Lang={code:null,defaultCode:"en",getCode:function(){if(!OpenLayers.Lang.code){OpenLayers.Lang.setCode();}
+return OpenLayers.Lang.code;},setCode:function(code){var lang;if(!code){code=(OpenLayers.BROWSER_NAME=="msie")?navigator.userLanguage:navigator.language;}
+var parts=code.split('-');parts[0]=parts[0].toLowerCase();if(typeof OpenLayers.Lang[parts[0]]=="object"){lang=parts[0];}
+if(parts[1]){var testLang=parts[0]+'-'+parts[1].toUpperCase();if(typeof OpenLayers.Lang[testLang]=="object"){lang=testLang;}}
+if(!lang){OpenLayers.Console.warn('Failed to find OpenLayers.Lang.'+parts.join("-")+' dictionary, falling back to default language');lang=OpenLayers.Lang.defaultCode;}
+OpenLayers.Lang.code=lang;},translate:function(key,context){var dictionary=OpenLayers.Lang[OpenLayers.Lang.getCode()];var message=dictionary&&dictionary[key];if(!message){message=key;}
+if(context){message=OpenLayers.String.format(message,context);}
+return message;}};OpenLayers.i18n=OpenLayers.Lang.translate;OpenLayers.Bounds=OpenLayers.Class({left:null,bottom:null,right:null,top:null,centerLonLat:null,initialize:function(left,bottom,right,top){if(left!=null){this.left=OpenLayers.Util.toFloat(left);}
+if(bottom!=null){this.bottom=OpenLayers.Util.toFloat(bottom);}
+if(right!=null){this.right=OpenLayers.Util.toFloat(right);}
+if(top!=null){this.top=OpenLayers.Util.toFloat(top);}},clone:function(){return new OpenLayers.Bounds(this.left,this.bottom,this.right,this.top);},equals:function(bounds){var equals=false;if(bounds!=null){equals=((this.left==bounds.left)&&(this.right==bounds.right)&&(this.top==bounds.top)&&(this.bottom==bounds.bottom));}
+return equals;},toString:function(){return[this.left,this.bottom,this.right,this.top].join(",");},toArray:function(reverseAxisOrder){if(reverseAxisOrder===true){return[this.bottom,this.left,this.top,this.right];}else{return[this.left,this.bottom,this.right,this.top];}},toBBOX:function(decimal,reverseAxisOrder){if(decimal==null){decimal=6;}
+var mult=Math.pow(10,decimal);var xmin=Math.round(this.left*mult)/mult;var ymin=Math.round(this.bottom*mult)/mult;var xmax=Math.round(this.right*mult)/mult;var ymax=Math.round(this.top*mult)/mult;if(reverseAxisOrder===true){return ymin+","+xmin+","+ymax+","+xmax;}else{return xmin+","+ymin+","+xmax+","+ymax;}},toGeometry:function(){return new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing([new OpenLayers.Geometry.Point(this.left,this.bottom),new OpenLayers.Geometry.Point(this.right,this.bottom),new OpenLayers.Geometry.Point(this.right,this.top),new OpenLayers.Geometry.Point(this.left,this.top)])]);},getWidth:function(){return(this.right-this.left);},getHeight:function(){return(this.top-this.bottom);},getSize:function(){return new OpenLayers.Size(this.getWidth(),this.getHeight());},getCenterPixel:function(){return new OpenLayers.Pixel((this.left+this.right)/2,(this.bottom+this.top)/2);},getCenterLonLat:function(){if(!this.centerLonLat){this.centerLonLat=new Op
 enLayers.LonLat((this.left+this.right)/2,(this.bottom+this.top)/2);}
+return this.centerLonLat;},scale:function(ratio,origin){if(origin==null){origin=this.getCenterLonLat();}
+var origx,origy;if(origin.CLASS_NAME=="OpenLayers.LonLat"){origx=origin.lon;origy=origin.lat;}else{origx=origin.x;origy=origin.y;}
+var left=(this.left-origx)*ratio+origx;var bottom=(this.bottom-origy)*ratio+origy;var right=(this.right-origx)*ratio+origx;var top=(this.top-origy)*ratio+origy;return new OpenLayers.Bounds(left,bottom,right,top);},add:function(x,y){if((x==null)||(y==null)){var msg=OpenLayers.i18n("boundsAddError");OpenLayers.Console.error(msg);return null;}
+return new OpenLayers.Bounds(this.left+x,this.bottom+y,this.right+x,this.top+y);},extend:function(object){var bounds=null;if(object){switch(object.CLASS_NAME){case"OpenLayers.LonLat":bounds=new OpenLayers.Bounds(object.lon,object.lat,object.lon,object.lat);break;case"OpenLayers.Geometry.Point":bounds=new OpenLayers.Bounds(object.x,object.y,object.x,object.y);break;case"OpenLayers.Bounds":bounds=object;break;}
+if(bounds){this.centerLonLat=null;if((this.left==null)||(bounds.left<this.left)){this.left=bounds.left;}
+if((this.bottom==null)||(bounds.bottom<this.bottom)){this.bottom=bounds.bottom;}
+if((this.right==null)||(bounds.right>this.right)){this.right=bounds.right;}
+if((this.top==null)||(bounds.top>this.top)){this.top=bounds.top;}}}},containsLonLat:function(ll,inclusive){return this.contains(ll.lon,ll.lat,inclusive);},containsPixel:function(px,inclusive){return this.contains(px.x,px.y,inclusive);},contains:function(x,y,inclusive){if(inclusive==null){inclusive=true;}
+if(x==null||y==null){return false;}
+x=OpenLayers.Util.toFloat(x);y=OpenLayers.Util.toFloat(y);var contains=false;if(inclusive){contains=((x>=this.left)&&(x<=this.right)&&(y>=this.bottom)&&(y<=this.top));}else{contains=((x>this.left)&&(x<this.right)&&(y>this.bottom)&&(y<this.top));}
+return contains;},intersectsBounds:function(bounds,inclusive){if(inclusive==null){inclusive=true;}
+var intersects=false;var mightTouch=(this.left==bounds.right||this.right==bounds.left||this.top==bounds.bottom||this.bottom==bounds.top);if(inclusive||!mightTouch){var inBottom=(((bounds.bottom>=this.bottom)&&(bounds.bottom<=this.top))||((this.bottom>=bounds.bottom)&&(this.bottom<=bounds.top)));var inTop=(((bounds.top>=this.bottom)&&(bounds.top<=this.top))||((this.top>bounds.bottom)&&(this.top<bounds.top)));var inLeft=(((bounds.left>=this.left)&&(bounds.left<=this.right))||((this.left>=bounds.left)&&(this.left<=bounds.right)));var inRight=(((bounds.right>=this.left)&&(bounds.right<=this.right))||((this.right>=bounds.left)&&(this.right<=bounds.right)));intersects=((inBottom||inTop)&&(inLeft||inRight));}
+return intersects;},containsBounds:function(bounds,partial,inclusive){if(partial==null){partial=false;}
+if(inclusive==null){inclusive=true;}
+var bottomLeft=this.contains(bounds.left,bounds.bottom,inclusive);var bottomRight=this.contains(bounds.right,bounds.bottom,inclusive);var topLeft=this.contains(bounds.left,bounds.top,inclusive);var topRight=this.contains(bounds.right,bounds.top,inclusive);return(partial)?(bottomLeft||bottomRight||topLeft||topRight):(bottomLeft&&bottomRight&&topLeft&&topRight);},determineQuadrant:function(lonlat){var quadrant="";var center=this.getCenterLonLat();quadrant+=(lonlat.lat<center.lat)?"b":"t";quadrant+=(lonlat.lon<center.lon)?"l":"r";return quadrant;},transform:function(source,dest){this.centerLonLat=null;var ll=OpenLayers.Projection.transform({'x':this.left,'y':this.bottom},source,dest);var lr=OpenLayers.Projection.transform({'x':this.right,'y':this.bottom},source,dest);var ul=OpenLayers.Projection.transform({'x':this.left,'y':this.top},source,dest);var ur=OpenLayers.Projection.transform({'x':this.right,'y':this.top},source,dest);this.left=Math.min(ll.x,ul.x);this.bottom=Math.min(
 ll.y,lr.y);this.right=Math.max(lr.x,ur.x);this.top=Math.max(ul.y,ur.y);return this;},wrapDateLine:function(maxExtent,options){options=options||{};var leftTolerance=options.leftTolerance||0;var rightTolerance=options.rightTolerance||0;var newBounds=this.clone();if(maxExtent){while(newBounds.left<maxExtent.left&&(newBounds.right-rightTolerance)<=maxExtent.left){newBounds=newBounds.add(maxExtent.getWidth(),0);}
+while((newBounds.left+leftTolerance)>=maxExtent.right&&newBounds.right>maxExtent.right){newBounds=newBounds.add(-maxExtent.getWidth(),0);}}
+return newBounds;},CLASS_NAME:"OpenLayers.Bounds"});OpenLayers.Bounds.fromString=function(str,reverseAxisOrder){var bounds=str.split(",");return OpenLayers.Bounds.fromArray(bounds,reverseAxisOrder);};OpenLayers.Bounds.fromArray=function(bbox,reverseAxisOrder){return reverseAxisOrder===true?new OpenLayers.Bounds(parseFloat(bbox[1]),parseFloat(bbox[0]),parseFloat(bbox[3]),parseFloat(bbox[2])):new OpenLayers.Bounds(parseFloat(bbox[0]),parseFloat(bbox[1]),parseFloat(bbox[2]),parseFloat(bbox[3]));};OpenLayers.Bounds.fromSize=function(size){return new OpenLayers.Bounds(0,size.h,size.w,0);};OpenLayers.Bounds.oppositeQuadrant=function(quadrant){var opp="";opp+=(quadrant.charAt(0)=='t')?'b':'t';opp+=(quadrant.charAt(1)=='l')?'r':'l';return opp;};OpenLayers.Element={visible:function(element){return OpenLayers.Util.getElement(element).style.display!='none';},toggle:function(){for(var i=0,len=arguments.length;i<len;i++){var element=OpenLayers.Util.getElement(arguments[i]);var display=Op
 enLayers.Element.visible(element)?'hide':'show';OpenLayers.Element[display](element);}},hide:function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"element.style.display = 'none';"}));for(var i=0,len=arguments.length;i<len;i++){var element=OpenLayers.Util.getElement(arguments[i]);if(element){element.style.display='none';}}},show:function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"element.style.display = '';"}));for(var i=0,len=arguments.length;i<len;i++){var element=OpenLayers.Util.getElement(arguments[i]);if(element){element.style.display='';}}},remove:function(element){element=OpenLayers.Util.getElement(element);element.parentNode.removeChild(element);},getHeight:function(element){element=OpenLayers.Util.getElement(element);return element.offsetHeight;},getDimensions:function(element){element=OpenLayers.Util.getElement(element);if(OpenLayers.Element.getStyle(element,'display')!='none'){return{width:element.offsetWidt
 h,height:element.offsetHeight};}
+var els=element.style;var originalVisibility=els.visibility;var originalPosition=els.position;var originalDisplay=els.display;els.visibility='hidden';els.position='absolute';els.display='';var originalWidth=element.clientWidth;var originalHeight=element.clientHeight;els.display=originalDisplay;els.position=originalPosition;els.visibility=originalVisibility;return{width:originalWidth,height:originalHeight};},hasClass:function(element,name){var names=element.className;return(!!names&&new RegExp("(^|\\s)"+name+"(\\s|$)").test(names));},addClass:function(element,name){if(!OpenLayers.Element.hasClass(element,name)){element.className+=(element.className?" ":"")+name;}
+return element;},removeClass:function(element,name){var names=element.className;if(names){element.className=OpenLayers.String.trim(names.replace(new RegExp("(^|\\s+)"+name+"(\\s+|$)")," "));}
+return element;},toggleClass:function(element,name){if(OpenLayers.Element.hasClass(element,name)){OpenLayers.Element.removeClass(element,name);}else{OpenLayers.Element.addClass(element,name);}
+return element;},getStyle:function(element,style){element=OpenLayers.Util.getElement(element);var value=null;if(element&&element.style){value=element.style[OpenLayers.String.camelize(style)];if(!value){if(document.defaultView&&document.defaultView.getComputedStyle){var css=document.defaultView.getComputedStyle(element,null);value=css?css.getPropertyValue(style):null;}else if(element.currentStyle){value=element.currentStyle[OpenLayers.String.camelize(style)];}}
+var positions=['left','top','right','bottom'];if(window.opera&&(OpenLayers.Util.indexOf(positions,style)!=-1)&&(OpenLayers.Element.getStyle(element,'position')=='static')){value='auto';}}
+return value=='auto'?null:value;}};OpenLayers.LonLat=OpenLayers.Class({lon:0.0,lat:0.0,initialize:function(lon,lat){this.lon=OpenLayers.Util.toFloat(lon);this.lat=OpenLayers.Util.toFloat(lat);},toString:function(){return("lon="+this.lon+",lat="+this.lat);},toShortString:function(){return(this.lon+", "+this.lat);},clone:function(){return new OpenLayers.LonLat(this.lon,this.lat);},add:function(lon,lat){if((lon==null)||(lat==null)){var msg=OpenLayers.i18n("lonlatAddError");OpenLayers.Console.error(msg);return null;}
+return new OpenLayers.LonLat(this.lon+OpenLayers.Util.toFloat(lon),this.lat+OpenLayers.Util.toFloat(lat));},equals:function(ll){var equals=false;if(ll!=null){equals=((this.lon==ll.lon&&this.lat==ll.lat)||(isNaN(this.lon)&&isNaN(this.lat)&&isNaN(ll.lon)&&isNaN(ll.lat)));}
+return equals;},transform:function(source,dest){var point=OpenLayers.Projection.transform({'x':this.lon,'y':this.lat},source,dest);this.lon=point.x;this.lat=point.y;return this;},wrapDateLine:function(maxExtent){var newLonLat=this.clone();if(maxExtent){while(newLonLat.lon<maxExtent.left){newLonLat.lon+=maxExtent.getWidth();}
+while(newLonLat.lon>maxExtent.right){newLonLat.lon-=maxExtent.getWidth();}}
+return newLonLat;},CLASS_NAME:"OpenLayers.LonLat"});OpenLayers.LonLat.fromString=function(str){var pair=str.split(",");return new OpenLayers.LonLat(pair[0],pair[1]);};OpenLayers.LonLat.fromArray=function(arr){var gotArr=OpenLayers.Util.isArray(arr),lon=gotArr&&arr[0],lat=gotArr&&arr[1];return new OpenLayers.LonLat(lon,lat);};OpenLayers.Pixel=OpenLayers.Class({x:0.0,y:0.0,initialize:function(x,y){this.x=parseFloat(x);this.y=parseFloat(y);},toString:function(){return("x="+this.x+",y="+this.y);},clone:function(){return new OpenLayers.Pixel(this.x,this.y);},equals:function(px){var equals=false;if(px!=null){equals=((this.x==px.x&&this.y==px.y)||(isNaN(this.x)&&isNaN(this.y)&&isNaN(px.x)&&isNaN(px.y)));}
+return equals;},distanceTo:function(px){return Math.sqrt(Math.pow(this.x-px.x,2)+
+Math.pow(this.y-px.y,2));},add:function(x,y){if((x==null)||(y==null)){var msg=OpenLayers.i18n("pixelAddError");OpenLayers.Console.error(msg);return null;}
+return new OpenLayers.Pixel(this.x+x,this.y+y);},offset:function(px){var newPx=this.clone();if(px){newPx=this.add(px.x,px.y);}
+return newPx;},CLASS_NAME:"OpenLayers.Pixel"});OpenLayers.Size=OpenLayers.Class({w:0.0,h:0.0,initialize:function(w,h){this.w=parseFloat(w);this.h=parseFloat(h);},toString:function(){return("w="+this.w+",h="+this.h);},clone:function(){return new OpenLayers.Size(this.w,this.h);},equals:function(sz){var equals=false;if(sz!=null){equals=((this.w==sz.w&&this.h==sz.h)||(isNaN(this.w)&&isNaN(this.h)&&isNaN(sz.w)&&isNaN(sz.h)));}
+return equals;},CLASS_NAME:"OpenLayers.Size"});OpenLayers.Feature=OpenLayers.Class({layer:null,id:null,lonlat:null,data:null,marker:null,popupClass:null,popup:null,initialize:function(layer,lonlat,data){this.layer=layer;this.lonlat=lonlat;this.data=(data!=null)?data:{};this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){if((this.layer!=null)&&(this.layer.map!=null)){if(this.popup!=null){this.layer.map.removePopup(this.popup);}}
+if(this.layer!=null&&this.marker!=null){this.layer.removeMarker(this.marker);}
+this.layer=null;this.id=null;this.lonlat=null;this.data=null;if(this.marker!=null){this.destroyMarker(this.marker);this.marker=null;}
+if(this.popup!=null){this.destroyPopup(this.popup);this.popup=null;}},onScreen:function(){var onScreen=false;if((this.layer!=null)&&(this.layer.map!=null)){var screenBounds=this.layer.map.getExtent();onScreen=screenBounds.containsLonLat(this.lonlat);}
+return onScreen;},createMarker:function(){if(this.lonlat!=null){this.marker=new OpenLayers.Marker(this.lonlat,this.data.icon);}
+return this.marker;},destroyMarker:function(){this.marker.destroy();},createPopup:function(closeBox){if(this.lonlat!=null){if(!this.popup){var anchor=(this.marker)?this.marker.icon:null;var popupClass=this.popupClass?this.popupClass:OpenLayers.Popup.AnchoredBubble;this.popup=new popupClass(this.id+"_popup",this.lonlat,this.data.popupSize,this.data.popupContentHTML,anchor,closeBox);}
+if(this.data.overflow!=null){this.popup.contentDiv.style.overflow=this.data.overflow;}
+this.popup.feature=this;}
+return this.popup;},destroyPopup:function(){if(this.popup){this.popup.feature=null;this.popup.destroy();this.popup=null;}},CLASS_NAME:"OpenLayers.Feature"});OpenLayers.State={UNKNOWN:'Unknown',INSERT:'Insert',UPDATE:'Update',DELETE:'Delete'};OpenLayers.Feature.Vector=OpenLayers.Class(OpenLayers.Feature,{fid:null,geometry:null,attributes:null,bounds:null,state:null,style:null,url:null,renderIntent:"default",modified:null,initialize:function(geometry,attributes,style){OpenLayers.Feature.prototype.initialize.apply(this,[null,null,attributes]);this.lonlat=null;this.geometry=geometry?geometry:null;this.state=null;this.attributes={};if(attributes){this.attributes=OpenLayers.Util.extend(this.attributes,attributes);}
+this.style=style?style:null;},destroy:function(){if(this.layer){this.layer.removeFeatures(this);this.layer=null;}
+this.geometry=null;this.modified=null;OpenLayers.Feature.prototype.destroy.apply(this,arguments);},clone:function(){return new OpenLayers.Feature.Vector(this.geometry?this.geometry.clone():null,this.attributes,this.style);},onScreen:function(boundsOnly){var onScreen=false;if(this.layer&&this.layer.map){var screenBounds=this.layer.map.getExtent();if(boundsOnly){var featureBounds=this.geometry.getBounds();onScreen=screenBounds.intersectsBounds(featureBounds);}else{var screenPoly=screenBounds.toGeometry();onScreen=screenPoly.intersects(this.geometry);}}
+return onScreen;},getVisibility:function(){return!(this.style&&this.style.display=='none'||!this.layer||this.layer&&this.layer.styleMap&&this.layer.styleMap.createSymbolizer(this,this.renderIntent).display=='none'||this.layer&&!this.layer.getVisibility());},createMarker:function(){return null;},destroyMarker:function(){},createPopup:function(){return null;},atPoint:function(lonlat,toleranceLon,toleranceLat){var atPoint=false;if(this.geometry){atPoint=this.geometry.atPoint(lonlat,toleranceLon,toleranceLat);}
+return atPoint;},destroyPopup:function(){},move:function(location){if(!this.layer||!this.geometry.move){return undefined;}
+var pixel;if(location.CLASS_NAME=="OpenLayers.LonLat"){pixel=this.layer.getViewPortPxFromLonLat(location);}else{pixel=location;}
+var lastPixel=this.layer.getViewPortPxFromLonLat(this.geometry.getBounds().getCenterLonLat());var res=this.layer.map.getResolution();this.geometry.move(res*(pixel.x-lastPixel.x),res*(lastPixel.y-pixel.y));this.layer.drawFeature(this);return lastPixel;},toState:function(state){if(state==OpenLayers.State.UPDATE){switch(this.state){case OpenLayers.State.UNKNOWN:case OpenLayers.State.DELETE:this.state=state;break;case OpenLayers.State.UPDATE:case OpenLayers.State.INSERT:break;}}else if(state==OpenLayers.State.INSERT){switch(this.state){case OpenLayers.State.UNKNOWN:break;default:this.state=state;break;}}else if(state==OpenLayers.State.DELETE){switch(this.state){case OpenLayers.State.INSERT:break;case OpenLayers.State.DELETE:break;case OpenLayers.State.UNKNOWN:case OpenLayers.State.UPDATE:this.state=state;break;}}else if(state==OpenLayers.State.UNKNOWN){this.state=state;}},CLASS_NAME:"OpenLayers.Feature.Vector"});OpenLayers.Feature.Vector.style={'default':{fillColor:"#ee9900",fil
 lOpacity:0.4,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"#ee9900",strokeOpacity:1,strokeWidth:1,strokeLinecap:"round",strokeDashstyle:"solid",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:"inherit"},'select':{fillColor:"blue",fillOpacity:0.4,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"blue",strokeOpacity:1,strokeWidth:2,strokeLinecap:"round",strokeDashstyle:"solid",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:"pointer"},'temporary':{fillColor:"#66cccc",fillOpacity:0.2,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"#66cccc",strokeOpacity:1,strokeLinecap:"round",strokeWidth:2,strokeDashstyle:"solid",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvent
 s:"visiblePainted",cursor:"inherit"},'delete':{display:"none"}};OpenLayers.Style=OpenLayers.Class({id:null,name:null,title:null,description:null,layerName:null,isDefault:false,rules:null,context:null,defaultStyle:null,defaultsPerSymbolizer:false,propertyStyles:null,initialize:function(style,options){OpenLayers.Util.extend(this,options);this.rules=[];if(options&&options.rules){this.addRules(options.rules);}
+this.setDefaultStyle(style||OpenLayers.Feature.Vector.style["default"]);this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){for(var i=0,len=this.rules.length;i<len;i++){this.rules[i].destroy();this.rules[i]=null;}
+this.rules=null;this.defaultStyle=null;},createSymbolizer:function(feature){var style=this.defaultsPerSymbolizer?{}:this.createLiterals(OpenLayers.Util.extend({},this.defaultStyle),feature);var rules=this.rules;var rule,context;var elseRules=[];var appliedRules=false;for(var i=0,len=rules.length;i<len;i++){rule=rules[i];var applies=rule.evaluate(feature);if(applies){if(rule instanceof OpenLayers.Rule&&rule.elseFilter){elseRules.push(rule);}else{appliedRules=true;this.applySymbolizer(rule,style,feature);}}}
+if(appliedRules==false&&elseRules.length>0){appliedRules=true;for(var i=0,len=elseRules.length;i<len;i++){this.applySymbolizer(elseRules[i],style,feature);}}
+if(rules.length>0&&appliedRules==false){style.display="none";}
+if(style.label&&typeof style.label!=="string"){style.label=String(style.label);}
+return style;},applySymbolizer:function(rule,style,feature){var symbolizerPrefix=feature.geometry?this.getSymbolizerPrefix(feature.geometry):OpenLayers.Style.SYMBOLIZER_PREFIXES[0];var symbolizer=rule.symbolizer[symbolizerPrefix]||rule.symbolizer;if(this.defaultsPerSymbolizer===true){var defaults=this.defaultStyle;OpenLayers.Util.applyDefaults(symbolizer,{pointRadius:defaults.pointRadius});if(symbolizer.stroke===true||symbolizer.graphic===true){OpenLayers.Util.applyDefaults(symbolizer,{strokeWidth:defaults.strokeWidth,strokeColor:defaults.strokeColor,strokeOpacity:defaults.strokeOpacity,strokeDashstyle:defaults.strokeDashstyle,strokeLinecap:defaults.strokeLinecap});}
+if(symbolizer.fill===true||symbolizer.graphic===true){OpenLayers.Util.applyDefaults(symbolizer,{fillColor:defaults.fillColor,fillOpacity:defaults.fillOpacity});}
+if(symbolizer.graphic===true){OpenLayers.Util.applyDefaults(symbolizer,{pointRadius:this.defaultStyle.pointRadius,externalGraphic:this.defaultStyle.externalGraphic,graphicName:this.defaultStyle.graphicName,graphicOpacity:this.defaultStyle.graphicOpacity,graphicWidth:this.defaultStyle.graphicWidth,graphicHeight:this.defaultStyle.graphicHeight,graphicXOffset:this.defaultStyle.graphicXOffset,graphicYOffset:this.defaultStyle.graphicYOffset});}}
+return this.createLiterals(OpenLayers.Util.extend(style,symbolizer),feature);},createLiterals:function(style,feature){var context=OpenLayers.Util.extend({},feature.attributes||feature.data);OpenLayers.Util.extend(context,this.context);for(var i in this.propertyStyles){style[i]=OpenLayers.Style.createLiteral(style[i],context,feature,i);}
+return style;},findPropertyStyles:function(){var propertyStyles={};var style=this.defaultStyle;this.addPropertyStyles(propertyStyles,style);var rules=this.rules;var symbolizer,value;for(var i=0,len=rules.length;i<len;i++){symbolizer=rules[i].symbolizer;for(var key in symbolizer){value=symbolizer[key];if(typeof value=="object"){this.addPropertyStyles(propertyStyles,value);}else{this.addPropertyStyles(propertyStyles,symbolizer);break;}}}
+return propertyStyles;},addPropertyStyles:function(propertyStyles,symbolizer){var property;for(var key in symbolizer){property=symbolizer[key];if(typeof property=="string"&&property.match(/\$\{\w+\}/)){propertyStyles[key]=true;}}
+return propertyStyles;},addRules:function(rules){Array.prototype.push.apply(this.rules,rules);this.propertyStyles=this.findPropertyStyles();},setDefaultStyle:function(style){this.defaultStyle=style;this.propertyStyles=this.findPropertyStyles();},getSymbolizerPrefix:function(geometry){var prefixes=OpenLayers.Style.SYMBOLIZER_PREFIXES;for(var i=0,len=prefixes.length;i<len;i++){if(geometry.CLASS_NAME.indexOf(prefixes[i])!=-1){return prefixes[i];}}},clone:function(){var options=OpenLayers.Util.extend({},this);if(this.rules){options.rules=[];for(var i=0,len=this.rules.length;i<len;++i){options.rules.push(this.rules[i].clone());}}
+options.context=this.context&&OpenLayers.Util.extend({},this.context);var defaultStyle=OpenLayers.Util.extend({},this.defaultStyle);return new OpenLayers.Style(defaultStyle,options);},CLASS_NAME:"OpenLayers.Style"});OpenLayers.Style.createLiteral=function(value,context,feature,property){if(typeof value=="string"&&value.indexOf("${")!=-1){value=OpenLayers.String.format(value,context,[feature,property]);value=(isNaN(value)||!value)?value:parseFloat(value);}
+return value;};OpenLayers.Style.SYMBOLIZER_PREFIXES=['Point','Line','Polygon','Text','Raster'];OpenLayers.Renderer=OpenLayers.Class({container:null,root:null,extent:null,locked:false,size:null,resolution:null,map:null,initialize:function(containerID,options){this.container=OpenLayers.Util.getElement(containerID);OpenLayers.Util.extend(this,options);},destroy:function(){this.container=null;this.extent=null;this.size=null;this.resolution=null;this.map=null;},supported:function(){return false;},setExtent:function(extent,resolutionChanged){this.extent=extent.clone();if(resolutionChanged){this.resolution=null;}},setSize:function(size){this.size=size.clone();this.resolution=null;},getResolution:function(){this.resolution=this.resolution||this.map.getResolution();return this.resolution;},drawFeature:function(feature,style){if(style==null){style=feature.style;}
+if(feature.geometry){var bounds=feature.geometry.getBounds();if(bounds){if(!bounds.intersectsBounds(this.extent)){style={display:"none"};}
+var rendered=this.drawGeometry(feature.geometry,style,feature.id);if(style.display!="none"&&style.label&&rendered!==false){var location=feature.geometry.getCentroid();if(style.labelXOffset||style.labelYOffset){var xOffset=isNaN(style.labelXOffset)?0:style.labelXOffset;var yOffset=isNaN(style.labelYOffset)?0:style.labelYOffset;var res=this.getResolution();location.move(xOffset*res,yOffset*res);}
+this.drawText(feature.id,style,location);}else{this.removeText(feature.id);}
+return rendered;}}},drawGeometry:function(geometry,style,featureId){},drawText:function(featureId,style,location){},removeText:function(featureId){},clear:function(){},getFeatureIdFromEvent:function(evt){},eraseFeatures:function(features){if(!(OpenLayers.Util.isArray(features))){features=[features];}
+for(var i=0,len=features.length;i<len;++i){var feature=features[i];this.eraseGeometry(feature.geometry,feature.id);this.removeText(feature.id);}},eraseGeometry:function(geometry,featureId){},moveRoot:function(renderer){},getRenderLayerId:function(){return this.container.id;},applyDefaultSymbolizer:function(symbolizer){var result=OpenLayers.Util.extend({},OpenLayers.Renderer.defaultSymbolizer);if(symbolizer.stroke===false){delete result.strokeWidth;delete result.strokeColor;}
+if(symbolizer.fill===false){delete result.fillColor;}
+OpenLayers.Util.extend(result,symbolizer);return result;},CLASS_NAME:"OpenLayers.Renderer"});OpenLayers.Renderer.defaultSymbolizer={fillColor:"#000000",strokeColor:"#000000",strokeWidth:2,fillOpacity:1,strokeOpacity:1,pointRadius:0};OpenLayers.ElementsIndexer=OpenLayers.Class({maxZIndex:null,order:null,indices:null,compare:null,initialize:function(yOrdering){this.compare=yOrdering?OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER_Y_ORDER:OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER_DRAWING_ORDER;this.clear();},insert:function(newNode){if(this.exists(newNode)){this.remove(newNode);}
+var nodeId=newNode.id;this.determineZIndex(newNode);var leftIndex=-1;var rightIndex=this.order.length;var middle;while(rightIndex-leftIndex>1){middle=parseInt((leftIndex+rightIndex)/2);var placement=this.compare(this,newNode,OpenLayers.Util.getElement(this.order[middle]));if(placement>0){leftIndex=middle;}else{rightIndex=middle;}}
+this.order.splice(rightIndex,0,nodeId);this.indices[nodeId]=this.getZIndex(newNode);return this.getNextElement(rightIndex);},remove:function(node){var nodeId=node.id;var arrayIndex=OpenLayers.Util.indexOf(this.order,nodeId);if(arrayIndex>=0){this.order.splice(arrayIndex,1);delete this.indices[nodeId];if(this.order.length>0){var lastId=this.order[this.order.length-1];this.maxZIndex=this.indices[lastId];}else{this.maxZIndex=0;}}},clear:function(){this.order=[];this.indices={};this.maxZIndex=0;},exists:function(node){return(this.indices[node.id]!=null);},getZIndex:function(node){return node._style.graphicZIndex;},determineZIndex:function(node){var zIndex=node._style.graphicZIndex;if(zIndex==null){zIndex=this.maxZIndex;node._style.graphicZIndex=zIndex;}else if(zIndex>this.maxZIndex){this.maxZIndex=zIndex;}},getNextElement:function(index){var nextIndex=index+1;if(nextIndex<this.order.length){var nextElement=OpenLayers.Util.getElement(this.order[nextIndex]);if(nextElement==undefin
 ed){nextElement=this.getNextElement(nextIndex);}
+return nextElement;}else{return null;}},CLASS_NAME:"OpenLayers.ElementsIndexer"});OpenLayers.ElementsIndexer.IndexingMethods={Z_ORDER:function(indexer,newNode,nextNode){var newZIndex=indexer.getZIndex(newNode);var returnVal=0;if(nextNode){var nextZIndex=indexer.getZIndex(nextNode);returnVal=newZIndex-nextZIndex;}
+return returnVal;},Z_ORDER_DRAWING_ORDER:function(indexer,newNode,nextNode){var returnVal=OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER(indexer,newNode,nextNode);if(nextNode&&returnVal==0){returnVal=1;}
+return returnVal;},Z_ORDER_Y_ORDER:function(indexer,newNode,nextNode){var returnVal=OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER(indexer,newNode,nextNode);if(nextNode&&returnVal===0){var result=nextNode._boundsBottom-newNode._boundsBottom;returnVal=(result===0)?1:result;}
+return returnVal;}};OpenLayers.Renderer.Elements=OpenLayers.Class(OpenLayers.Renderer,{rendererRoot:null,root:null,vectorRoot:null,textRoot:null,xmlns:null,indexer:null,BACKGROUND_ID_SUFFIX:"_background",LABEL_ID_SUFFIX:"_label",initialize:function(containerID,options){OpenLayers.Renderer.prototype.initialize.apply(this,arguments);this.rendererRoot=this.createRenderRoot();this.root=this.createRoot("_root");this.vectorRoot=this.createRoot("_vroot");this.textRoot=this.createRoot("_troot");this.root.appendChild(this.vectorRoot);this.root.appendChild(this.textRoot);this.rendererRoot.appendChild(this.root);this.container.appendChild(this.rendererRoot);if(options&&(options.zIndexing||options.yOrdering)){this.indexer=new OpenLayers.ElementsIndexer(options.yOrdering);}},destroy:function(){this.clear();this.rendererRoot=null;this.root=null;this.xmlns=null;OpenLayers.Renderer.prototype.destroy.apply(this,arguments);},clear:function(){var child;var root=this.vectorRoot;if(root){while(c
 hild=root.firstChild){root.removeChild(child);}}
+root=this.textRoot;if(root){while(child=root.firstChild){root.removeChild(child);}}
+if(this.indexer){this.indexer.clear();}},getNodeType:function(geometry,style){},drawGeometry:function(geometry,style,featureId){var className=geometry.CLASS_NAME;var rendered=true;if((className=="OpenLayers.Geometry.Collection")||(className=="OpenLayers.Geometry.MultiPoint")||(className=="OpenLayers.Geometry.MultiLineString")||(className=="OpenLayers.Geometry.MultiPolygon")){for(var i=0,len=geometry.components.length;i<len;i++){rendered=this.drawGeometry(geometry.components[i],style,featureId)&&rendered;}
+return rendered;};rendered=false;var removeBackground=false;if(style.display!="none"){if(style.backgroundGraphic){this.redrawBackgroundNode(geometry.id,geometry,style,featureId);}else{removeBackground=true;}
+rendered=this.redrawNode(geometry.id,geometry,style,featureId);}
+if(rendered==false){var node=document.getElementById(geometry.id);if(node){if(node._style.backgroundGraphic){removeBackground=true;}
+node.parentNode.removeChild(node);}}
+if(removeBackground){var node=document.getElementById(geometry.id+this.BACKGROUND_ID_SUFFIX);if(node){node.parentNode.removeChild(node);}}
+return rendered;},redrawNode:function(id,geometry,style,featureId){style=this.applyDefaultSymbolizer(style);var node=this.nodeFactory(id,this.getNodeType(geometry,style));node._featureId=featureId;node._boundsBottom=geometry.getBounds().bottom;node._geometryClass=geometry.CLASS_NAME;node._style=style;var drawResult=this.drawGeometryNode(node,geometry,style);if(drawResult===false){return false;}
+node=drawResult.node;if(this.indexer){var insert=this.indexer.insert(node);if(insert){this.vectorRoot.insertBefore(node,insert);}else{this.vectorRoot.appendChild(node);}}else{if(node.parentNode!==this.vectorRoot){this.vectorRoot.appendChild(node);}}
+this.postDraw(node);return drawResult.complete;},redrawBackgroundNode:function(id,geometry,style,featureId){var backgroundStyle=OpenLayers.Util.extend({},style);backgroundStyle.externalGraphic=backgroundStyle.backgroundGraphic;backgroundStyle.graphicXOffset=backgroundStyle.backgroundXOffset;backgroundStyle.graphicYOffset=backgroundStyle.backgroundYOffset;backgroundStyle.graphicZIndex=backgroundStyle.backgroundGraphicZIndex;backgroundStyle.graphicWidth=backgroundStyle.backgroundWidth||backgroundStyle.graphicWidth;backgroundStyle.graphicHeight=backgroundStyle.backgroundHeight||backgroundStyle.graphicHeight;backgroundStyle.backgroundGraphic=null;backgroundStyle.backgroundXOffset=null;backgroundStyle.backgroundYOffset=null;backgroundStyle.backgroundGraphicZIndex=null;return this.redrawNode(id+this.BACKGROUND_ID_SUFFIX,geometry,backgroundStyle,null);},drawGeometryNode:function(node,geometry,style){style=style||node._style;var options={'isFilled':style.fill===undefined?true:style.
 fill,'isStroked':style.stroke===undefined?!!style.strokeWidth:style.stroke};var drawn;switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":if(style.graphic===false){options.isFilled=false;options.isStroked=false;}
+drawn=this.drawPoint(node,geometry);break;case"OpenLayers.Geometry.LineString":options.isFilled=false;drawn=this.drawLineString(node,geometry);break;case"OpenLayers.Geometry.LinearRing":drawn=this.drawLinearRing(node,geometry);break;case"OpenLayers.Geometry.Polygon":drawn=this.drawPolygon(node,geometry);break;case"OpenLayers.Geometry.Surface":drawn=this.drawSurface(node,geometry);break;case"OpenLayers.Geometry.Rectangle":drawn=this.drawRectangle(node,geometry);break;default:break;}
+node._options=options;if(drawn!=false){return{node:this.setStyle(node,style,options,geometry),complete:drawn};}else{return false;}},postDraw:function(node){},drawPoint:function(node,geometry){},drawLineString:function(node,geometry){},drawLinearRing:function(node,geometry){},drawPolygon:function(node,geometry){},drawRectangle:function(node,geometry){},drawCircle:function(node,geometry){},drawSurface:function(node,geometry){},removeText:function(featureId){var label=document.getElementById(featureId+this.LABEL_ID_SUFFIX);if(label){this.textRoot.removeChild(label);}},getFeatureIdFromEvent:function(evt){var target=evt.target;var useElement=target&&target.correspondingUseElement;var node=useElement?useElement:(target||evt.srcElement);var featureId=node._featureId;return featureId;},eraseGeometry:function(geometry,featureId){if((geometry.CLASS_NAME=="OpenLayers.Geometry.MultiPoint")||(geometry.CLASS_NAME=="OpenLayers.Geometry.MultiLineString")||(geometry.CLASS_NAME=="OpenLayers.G
 eometry.MultiPolygon")||(geometry.CLASS_NAME=="OpenLayers.Geometry.Collection")){for(var i=0,len=geometry.components.length;i<len;i++){this.eraseGeometry(geometry.components[i],featureId);}}else{var element=OpenLayers.Util.getElement(geometry.id);if(element&&element.parentNode){if(element.geometry){element.geometry.destroy();element.geometry=null;}
+element.parentNode.removeChild(element);if(this.indexer){this.indexer.remove(element);}
+if(element._style.backgroundGraphic){var backgroundId=geometry.id+this.BACKGROUND_ID_SUFFIX;var bElem=OpenLayers.Util.getElement(backgroundId);if(bElem&&bElem.parentNode){bElem.parentNode.removeChild(bElem);}}}}},nodeFactory:function(id,type){var node=OpenLayers.Util.getElement(id);if(node){if(!this.nodeTypeCompare(node,type)){node.parentNode.removeChild(node);node=this.nodeFactory(id,type);}}else{node=this.createNode(type,id);}
+return node;},nodeTypeCompare:function(node,type){},createNode:function(type,id){},moveRoot:function(renderer){var root=this.root;if(renderer.root.parentNode==this.rendererRoot){root=renderer.root;}
+root.parentNode.removeChild(root);renderer.rendererRoot.appendChild(root);},getRenderLayerId:function(){return this.root.parentNode.parentNode.id;},isComplexSymbol:function(graphicName){return(graphicName!="circle")&&!!graphicName;},CLASS_NAME:"OpenLayers.Renderer.Elements"});OpenLayers.Renderer.symbol={"star":[350,75,379,161,469,161,397,215,423,301,350,250,277,301,303,215,231,161,321,161,350,75],"cross":[4,0,6,0,6,4,10,4,10,6,6,6,6,10,4,10,4,6,0,6,0,4,4,4,4,0],"x":[0,0,25,0,50,35,75,0,100,0,65,50,100,100,75,100,50,65,25,100,0,100,35,50,0,0],"square":[0,0,0,1,1,1,1,0,0,0],"triangle":[0,10,10,10,5,0,0,10]};OpenLayers.Renderer.VML=OpenLayers.Class(OpenLayers.Renderer.Elements,{xmlns:"urn:schemas-microsoft-com:vml",symbolCache:{},offset:null,initialize:function(containerID){if(!this.supported()){return;}
+if(!document.namespaces.olv){document.namespaces.add("olv",this.xmlns);var style=document.createStyleSheet();var shapes=['shape','rect','oval','fill','stroke','imagedata','group','textbox'];for(var i=0,len=shapes.length;i<len;i++){style.addRule('olv\\:'+shapes[i],"behavior: url(#default#VML); "+"position: absolute; display: inline-block;");}}
+OpenLayers.Renderer.Elements.prototype.initialize.apply(this,arguments);},supported:function(){return!!(document.namespaces);},setExtent:function(extent,resolutionChanged){OpenLayers.Renderer.Elements.prototype.setExtent.apply(this,arguments);var resolution=this.getResolution();var left=(extent.left/resolution)|0;var top=(extent.top/resolution-this.size.h)|0;if(resolutionChanged||!this.offset){this.offset={x:left,y:top};left=0;top=0;}else{left=left-this.offset.x;top=top-this.offset.y;}
+var org=left+" "+top;this.root.coordorigin=org;var roots=[this.root,this.vectorRoot,this.textRoot];var root;for(var i=0,len=roots.length;i<len;++i){root=roots[i];var size=this.size.w+" "+this.size.h;root.coordsize=size;}
+this.root.style.flip="y";return true;},setSize:function(size){OpenLayers.Renderer.prototype.setSize.apply(this,arguments);var roots=[this.rendererRoot,this.root,this.vectorRoot,this.textRoot];var w=this.size.w+"px";var h=this.size.h+"px";var root;for(var i=0,len=roots.length;i<len;++i){root=roots[i];root.style.width=w;root.style.height=h;}},getNodeType:function(geometry,style){var nodeType=null;switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":if(style.externalGraphic){nodeType="olv:rect";}else if(this.isComplexSymbol(style.graphicName)){nodeType="olv:shape";}else{nodeType="olv:oval";}
+break;case"OpenLayers.Geometry.Rectangle":nodeType="olv:rect";break;case"OpenLayers.Geometry.LineString":case"OpenLayers.Geometry.LinearRing":case"OpenLayers.Geometry.Polygon":case"OpenLayers.Geometry.Curve":case"OpenLayers.Geometry.Surface":nodeType="olv:shape";break;default:break;}
+return nodeType;},setStyle:function(node,style,options,geometry){style=style||node._style;options=options||node._options;var fillColor=style.fillColor;if(node._geometryClass==="OpenLayers.Geometry.Point"){if(style.externalGraphic){options.isFilled=true;if(style.graphicTitle){node.title=style.graphicTitle;}
+var width=style.graphicWidth||style.graphicHeight;var height=style.graphicHeight||style.graphicWidth;width=width?width:style.pointRadius*2;height=height?height:style.pointRadius*2;var resolution=this.getResolution();var xOffset=(style.graphicXOffset!=undefined)?style.graphicXOffset:-(0.5*width);var yOffset=(style.graphicYOffset!=undefined)?style.graphicYOffset:-(0.5*height);node.style.left=(((geometry.x/resolution-this.offset.x)+xOffset)|0)+"px";node.style.top=(((geometry.y/resolution-this.offset.y)-(yOffset+height))|0)+"px";node.style.width=width+"px";node.style.height=height+"px";node.style.flip="y";fillColor="none";options.isStroked=false;}else if(this.isComplexSymbol(style.graphicName)){var cache=this.importSymbol(style.graphicName);node.path=cache.path;node.coordorigin=cache.left+","+cache.bottom;var size=cache.size;node.coordsize=size+","+size;this.drawCircle(node,geometry,style.pointRadius);node.style.flip="y";}else{this.drawCircle(node,geometry,style.pointRadius);}}
+if(options.isFilled){node.fillcolor=fillColor;}else{node.filled="false";}
+var fills=node.getElementsByTagName("fill");var fill=(fills.length==0)?null:fills[0];if(!options.isFilled){if(fill){node.removeChild(fill);}}else{if(!fill){fill=this.createNode('olv:fill',node.id+"_fill");}
+fill.opacity=style.fillOpacity;if(node._geometryClass==="OpenLayers.Geometry.Point"&&style.externalGraphic){if(style.graphicOpacity){fill.opacity=style.graphicOpacity;}
+fill.src=style.externalGraphic;fill.type="frame";if(!(style.graphicWidth&&style.graphicHeight)){fill.aspect="atmost";}}
+if(fill.parentNode!=node){node.appendChild(fill);}}
+var rotation=style.rotation;if((rotation!==undefined||node._rotation!==undefined)){node._rotation=rotation;if(style.externalGraphic){this.graphicRotate(node,xOffset,yOffset,style);fill.opacity=0;}else if(node._geometryClass==="OpenLayers.Geometry.Point"){node.style.rotation=rotation||0;}}
+var strokes=node.getElementsByTagName("stroke");var stroke=(strokes.length==0)?null:strokes[0];if(!options.isStroked){node.stroked=false;if(stroke){stroke.on=false;}}else{if(!stroke){stroke=this.createNode('olv:stroke',node.id+"_stroke");node.appendChild(stroke);}
+stroke.on=true;stroke.color=style.strokeColor;stroke.weight=style.strokeWidth+"px";stroke.opacity=style.strokeOpacity;stroke.endcap=style.strokeLinecap=='butt'?'flat':(style.strokeLinecap||'round');if(style.strokeDashstyle){stroke.dashstyle=this.dashStyle(style);}}
+if(style.cursor!="inherit"&&style.cursor!=null){node.style.cursor=style.cursor;}
+return node;},graphicRotate:function(node,xOffset,yOffset,style){var style=style||node._style;var rotation=style.rotation||0;var aspectRatio,size;if(!(style.graphicWidth&&style.graphicHeight)){var img=new Image();img.onreadystatechange=OpenLayers.Function.bind(function(){if(img.readyState=="complete"||img.readyState=="interactive"){aspectRatio=img.width/img.height;size=Math.max(style.pointRadius*2,style.graphicWidth||0,style.graphicHeight||0);xOffset=xOffset*aspectRatio;style.graphicWidth=size*aspectRatio;style.graphicHeight=size;this.graphicRotate(node,xOffset,yOffset,style);}},this);img.src=style.externalGraphic;return;}else{size=Math.max(style.graphicWidth,style.graphicHeight);aspectRatio=style.graphicWidth/style.graphicHeight;}
+var width=Math.round(style.graphicWidth||size*aspectRatio);var height=Math.round(style.graphicHeight||size);node.style.width=width+"px";node.style.height=height+"px";var image=document.getElementById(node.id+"_image");if(!image){image=this.createNode("olv:imagedata",node.id+"_image");node.appendChild(image);}
+image.style.width=width+"px";image.style.height=height+"px";image.src=style.externalGraphic;image.style.filter="progid:DXImageTransform.Microsoft.AlphaImageLoader("+"src='', sizingMethod='scale')";var rot=rotation*Math.PI/180;var sintheta=Math.sin(rot);var costheta=Math.cos(rot);var filter="progid:DXImageTransform.Microsoft.Matrix(M11="+costheta+",M12="+(-sintheta)+",M21="+sintheta+",M22="+costheta+",SizingMethod='auto expand')\n";var opacity=style.graphicOpacity||style.fillOpacity;if(opacity&&opacity!=1){filter+="progid:DXImageTransform.Microsoft.BasicImage(opacity="+
+opacity+")\n";}
+node.style.filter=filter;var centerPoint=new OpenLayers.Geometry.Point(-xOffset,-yOffset);var imgBox=new OpenLayers.Bounds(0,0,width,height).toGeometry();imgBox.rotate(style.rotation,centerPoint);var imgBounds=imgBox.getBounds();node.style.left=Math.round(parseInt(node.style.left)+imgBounds.left)+"px";node.style.top=Math.round(parseInt(node.style.top)-imgBounds.bottom)+"px";},postDraw:function(node){node.style.visibility="visible";var fillColor=node._style.fillColor;var strokeColor=node._style.strokeColor;if(fillColor=="none"&&node.fillcolor!=fillColor){node.fillcolor=fillColor;}
+if(strokeColor=="none"&&node.strokecolor!=strokeColor){node.strokecolor=strokeColor;}},setNodeDimension:function(node,geometry){var bbox=geometry.getBounds();if(bbox){var resolution=this.getResolution();var scaledBox=new OpenLayers.Bounds((bbox.left/resolution-this.offset.x)|0,(bbox.bottom/resolution-this.offset.y)|0,(bbox.right/resolution-this.offset.x)|0,(bbox.top/resolution-this.offset.y)|0);node.style.left=scaledBox.left+"px";node.style.top=scaledBox.top+"px";node.style.width=scaledBox.getWidth()+"px";node.style.height=scaledBox.getHeight()+"px";node.coordorigin=scaledBox.left+" "+scaledBox.top;node.coordsize=scaledBox.getWidth()+" "+scaledBox.getHeight();}},dashStyle:function(style){var dash=style.strokeDashstyle;switch(dash){case'solid':case'dot':case'dash':case'dashdot':case'longdash':case'longdashdot':return dash;default:var parts=dash.split(/[ ,]/);if(parts.length==2){if(1*parts[0]>=2*parts[1]){return"longdash";}
+return(parts[0]==1||parts[1]==1)?"dot":"dash";}else if(parts.length==4){return(1*parts[0]>=2*parts[1])?"longdashdot":"dashdot";}
+return"solid";}},createNode:function(type,id){var node=document.createElement(type);if(id){node.id=id;}
+node.unselectable='on';node.onselectstart=OpenLayers.Function.False;return node;},nodeTypeCompare:function(node,type){var subType=type;var splitIndex=subType.indexOf(":");if(splitIndex!=-1){subType=subType.substr(splitIndex+1);}
+var nodeName=node.nodeName;splitIndex=nodeName.indexOf(":");if(splitIndex!=-1){nodeName=nodeName.substr(splitIndex+1);}
+return(subType==nodeName);},createRenderRoot:function(){return this.nodeFactory(this.container.id+"_vmlRoot","div");},createRoot:function(suffix){return this.nodeFactory(this.container.id+suffix,"olv:group");},drawPoint:function(node,geometry){return this.drawCircle(node,geometry,1);},drawCircle:function(node,geometry,radius){if(!isNaN(geometry.x)&&!isNaN(geometry.y)){var resolution=this.getResolution();node.style.left=(((geometry.x/resolution-this.offset.x)|0)-radius)+"px";node.style.top=(((geometry.y/resolution-this.offset.y)|0)-radius)+"px";var diameter=radius*2;node.style.width=diameter+"px";node.style.height=diameter+"px";return node;}
+return false;},drawLineString:function(node,geometry){return this.drawLine(node,geometry,false);},drawLinearRing:function(node,geometry){return this.drawLine(node,geometry,true);},drawLine:function(node,geometry,closeLine){this.setNodeDimension(node,geometry);var resolution=this.getResolution();var numComponents=geometry.components.length;var parts=new Array(numComponents);var comp,x,y;for(var i=0;i<numComponents;i++){comp=geometry.components[i];x=(comp.x/resolution-this.offset.x)|0;y=(comp.y/resolution-this.offset.y)|0;parts[i]=" "+x+","+y+" l ";}
+var end=(closeLine)?" x e":" e";node.path="m"+parts.join("")+end;return node;},drawPolygon:function(node,geometry){this.setNodeDimension(node,geometry);var resolution=this.getResolution();var path=[];var j,jj,points,area,first,second,i,ii,comp,pathComp,x,y;for(j=0,jj=geometry.components.length;j<jj;j++){path.push("m");points=geometry.components[j].components;area=(j===0);first=null;second=null;for(i=0,ii=points.length;i<ii;i++){comp=points[i];x=(comp.x/resolution-this.offset.x)|0;y=(comp.y/resolution-this.offset.y)|0;pathComp=" "+x+","+y;path.push(pathComp);if(i==0){path.push(" l");}
+if(!area){if(!first){first=pathComp;}else if(first!=pathComp){if(!second){second=pathComp;}else if(second!=pathComp){area=true;}}}}
+path.push(area?" x ":" ");}
+path.push("e");node.path=path.join("");return node;},drawRectangle:function(node,geometry){var resolution=this.getResolution();node.style.left=((geometry.x/resolution-this.offset.x)|0)+"px";node.style.top=((geometry.y/resolution-this.offset.y)|0)+"px";node.style.width=((geometry.width/resolution)|0)+"px";node.style.height=((geometry.height/resolution)|0)+"px";return node;},drawText:function(featureId,style,location){var label=this.nodeFactory(featureId+this.LABEL_ID_SUFFIX,"olv:rect");var textbox=this.nodeFactory(featureId+this.LABEL_ID_SUFFIX+"_textbox","olv:textbox");var resolution=this.getResolution();label.style.left=((location.x/resolution-this.offset.x)|0)+"px";label.style.top=((location.y/resolution-this.offset.y)|0)+"px";label.style.flip="y";textbox.innerText=style.label;if(style.cursor!="inherit"&&style.cursor!=null){textbox.style.cursor=style.cursor;}
+if(style.fontColor){textbox.style.color=style.fontColor;}
+if(style.fontOpacity){textbox.style.filter='alpha(opacity='+(style.fontOpacity*100)+')';}
+if(style.fontFamily){textbox.style.fontFamily=style.fontFamily;}
+if(style.fontSize){textbox.style.fontSize=style.fontSize;}
+if(style.fontWeight){textbox.style.fontWeight=style.fontWeight;}
+if(style.fontStyle){textbox.style.fontStyle=style.fontStyle;}
+if(style.labelSelect===true){label._featureId=featureId;textbox._featureId=featureId;textbox._geometry=location;textbox._geometryClass=location.CLASS_NAME;}
+textbox.style.whiteSpace="nowrap";textbox.inset="1px,0px,0px,0px";if(!label.parentNode){label.appendChild(textbox);this.textRoot.appendChild(label);}
+var align=style.labelAlign||"cm";if(align.length==1){align+="m";}
+var xshift=textbox.clientWidth*(OpenLayers.Renderer.VML.LABEL_SHIFT[align.substr(0,1)]);var yshift=textbox.clientHeight*(OpenLayers.Renderer.VML.LABEL_SHIFT[align.substr(1,1)]);label.style.left=parseInt(label.style.left)-xshift-1+"px";label.style.top=parseInt(label.style.top)+yshift+"px";},drawSurface:function(node,geometry){this.setNodeDimension(node,geometry);var resolution=this.getResolution();var path=[];var comp,x,y;for(var i=0,len=geometry.components.length;i<len;i++){comp=geometry.components[i];x=(comp.x/resolution-this.offset.x)|0;y=(comp.y/resolution-this.offset.y)|0;if((i%3)==0&&(i/3)==0){path.push("m");}else if((i%3)==1){path.push(" c");}
+path.push(" "+x+","+y);}
+path.push(" x e");node.path=path.join("");return node;},moveRoot:function(renderer){var layer=this.map.getLayer(renderer.container.id);if(layer instanceof OpenLayers.Layer.Vector.RootContainer){layer=this.map.getLayer(this.container.id);}
+layer&&layer.renderer.clear();OpenLayers.Renderer.Elements.prototype.moveRoot.apply(this,arguments);layer&&layer.redraw();},importSymbol:function(graphicName){var id=this.container.id+"-"+graphicName;var cache=this.symbolCache[id];if(cache){return cache;}
+var symbol=OpenLayers.Renderer.symbol[graphicName];if(!symbol){throw new Error(graphicName+' is not a valid symbol name');}
+var symbolExtent=new OpenLayers.Bounds(Number.MAX_VALUE,Number.MAX_VALUE,0,0);var pathitems=["m"];for(var i=0;i<symbol.length;i=i+2){var x=symbol[i];var y=symbol[i+1];symbolExtent.left=Math.min(symbolExtent.left,x);symbolExtent.bottom=Math.min(symbolExtent.bottom,y);symbolExtent.right=Math.max(symbolExtent.right,x);symbolExtent.top=Math.max(symbolExtent.top,y);pathitems.push(x);pathitems.push(y);if(i==0){pathitems.push("l");}}
+pathitems.push("x e");var path=pathitems.join(" ");var diff=(symbolExtent.getWidth()-symbolExtent.getHeight())/2;if(diff>0){symbolExtent.bottom=symbolExtent.bottom-diff;symbolExtent.top=symbolExtent.top+diff;}else{symbolExtent.left=symbolExtent.left+diff;symbolExtent.right=symbolExtent.right-diff;}
+cache={path:path,size:symbolExtent.getWidth(),left:symbolExtent.left,bottom:symbolExtent.bottom};this.symbolCache[id]=cache;return cache;},CLASS_NAME:"OpenLayers.Renderer.VML"});OpenLayers.Renderer.VML.LABEL_SHIFT={"l":0,"c":.5,"r":1,"t":0,"m":.5,"b":1};OpenLayers.Tween=OpenLayers.Class({INTERVAL:10,easing:null,begin:null,finish:null,duration:null,callbacks:null,time:null,interval:null,playing:false,initialize:function(easing){this.easing=(easing)?easing:OpenLayers.Easing.Expo.easeOut;},start:function(begin,finish,duration,options){this.playing=true;this.begin=begin;this.finish=finish;this.duration=duration;this.callbacks=options.callbacks;this.time=0;if(this.interval){window.clearInterval(this.interval);this.interval=null;}
+if(this.callbacks&&this.callbacks.start){this.callbacks.start.call(this,this.begin);}
+this.interval=window.setInterval(OpenLayers.Function.bind(this.play,this),this.INTERVAL);},stop:function(){if(!this.playing){return;}
+if(this.callbacks&&this.callbacks.done){this.callbacks.done.call(this,this.finish);}
+window.clearInterval(this.interval);this.interval=null;this.playing=false;},play:function(){var value={};for(var i in this.begin){var b=this.begin[i];var f=this.finish[i];if(b==null||f==null||isNaN(b)||isNaN(f)){OpenLayers.Console.error('invalid value for Tween');}
+var c=f-b;value[i]=this.easing.apply(this,[this.time,b,c,this.duration]);}
+this.time++;if(this.callbacks&&this.callbacks.eachStep){this.callbacks.eachStep.call(this,value);}
+if(this.time>this.duration){this.stop();}},CLASS_NAME:"OpenLayers.Tween"});OpenLayers.Easing={CLASS_NAME:"OpenLayers.Easing"};OpenLayers.Easing.Linear={easeIn:function(t,b,c,d){return c*t/d+b;},easeOut:function(t,b,c,d){return c*t/d+b;},easeInOut:function(t,b,c,d){return c*t/d+b;},CLASS_NAME:"OpenLayers.Easing.Linear"};OpenLayers.Easing.Expo={easeIn:function(t,b,c,d){return(t==0)?b:c*Math.pow(2,10*(t/d-1))+b;},easeOut:function(t,b,c,d){return(t==d)?b+c:c*(-Math.pow(2,-10*t/d)+1)+b;},easeInOut:function(t,b,c,d){if(t==0)return b;if(t==d)return b+c;if((t/=d/2)<1)return c/2*Math.pow(2,10*(t-1))+b;return c/2*(-Math.pow(2,-10*--t)+2)+b;},CLASS_NAME:"OpenLayers.Easing.Expo"};OpenLayers.Easing.Quad={easeIn:function(t,b,c,d){return c*(t/=d)*t+b;},easeOut:function(t,b,c,d){return-c*(t/=d)*(t-2)+b;},easeInOut:function(t,b,c,d){if((t/=d/2)<1)return c/2*t*t+b;return-c/2*((--t)*(t-2)-1)+b;},CLASS_NAME:"OpenLayers.Easing.Quad"};OpenLayers.Format=OpenLayers.Class({options:null,externalProje
 ction:null,internalProjection:null,data:null,keepData:false,initialize:function(options){OpenLayers.Util.extend(this,options);this.options=options;},destroy:function(){},read:function(data){OpenLayers.Console.userError(OpenLayers.i18n("readNotImplemented"));},write:function(object){OpenLayers.Console.userError(OpenLayers.i18n("writeNotImplemented"));},CLASS_NAME:"OpenLayers.Format"});OpenLayers.Format.WKT=OpenLayers.Class(OpenLayers.Format,{initialize:function(options){this.regExes={'typeStr':/^\s*(\w+)\s*\(\s*(.*)\s*\)\s*$/,'spaces':/\s+/,'parenComma':/\)\s*,\s*\(/,'doubleParenComma':/\)\s*\)\s*,\s*\(\s*\(/,'trimParens':/^\s*\(?(.*?)\)?\s*$/};OpenLayers.Format.prototype.initialize.apply(this,[options]);},read:function(wkt){var features,type,str;wkt=wkt.replace(/[\n\r]/g," ");var matches=this.regExes.typeStr.exec(wkt);if(matches){type=matches[1].toLowerCase();str=matches[2];if(this.parse[type]){features=this.parse[type].apply(this,[str]);}
+if(this.internalProjection&&this.externalProjection){if(features&&features.CLASS_NAME=="OpenLayers.Feature.Vector"){features.geometry.transform(this.externalProjection,this.internalProjection);}else if(features&&type!="geometrycollection"&&typeof features=="object"){for(var i=0,len=features.length;i<len;i++){var component=features[i];component.geometry.transform(this.externalProjection,this.internalProjection);}}}}
+return features;},write:function(features){var collection,geometry,type,data,isCollection;if(features.constructor==Array){collection=features;isCollection=true;}else{collection=[features];isCollection=false;}
+var pieces=[];if(isCollection){pieces.push('GEOMETRYCOLLECTION(');}
+for(var i=0,len=collection.length;i<len;++i){if(isCollection&&i>0){pieces.push(',');}
+geometry=collection[i].geometry;pieces.push(this.extractGeometry(geometry));}
+if(isCollection){pieces.push(')');}
+return pieces.join('');},extractGeometry:function(geometry){var type=geometry.CLASS_NAME.split('.')[2].toLowerCase();if(!this.extract[type]){return null;}
+if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
+var wktType=type=='collection'?'GEOMETRYCOLLECTION':type.toUpperCase();var data=wktType+'('+this.extract[type].apply(this,[geometry])+')';return data;},extract:{'point':function(point){return point.x+' '+point.y;},'multipoint':function(multipoint){var array=[];for(var i=0,len=multipoint.components.length;i<len;++i){array.push('('+
+this.extract.point.apply(this,[multipoint.components[i]])+')');}
+return array.join(',');},'linestring':function(linestring){var array=[];for(var i=0,len=linestring.components.length;i<len;++i){array.push(this.extract.point.apply(this,[linestring.components[i]]));}
+return array.join(',');},'multilinestring':function(multilinestring){var array=[];for(var i=0,len=multilinestring.components.length;i<len;++i){array.push('('+
+this.extract.linestring.apply(this,[multilinestring.components[i]])+')');}
+return array.join(',');},'polygon':function(polygon){var array=[];for(var i=0,len=polygon.components.length;i<len;++i){array.push('('+
+this.extract.linestring.apply(this,[polygon.components[i]])+')');}
+return array.join(',');},'multipolygon':function(multipolygon){var array=[];for(var i=0,len=multipolygon.components.length;i<len;++i){array.push('('+
+this.extract.polygon.apply(this,[multipolygon.components[i]])+')');}
+return array.join(',');},'collection':function(collection){var array=[];for(var i=0,len=collection.components.length;i<len;++i){array.push(this.extractGeometry.apply(this,[collection.components[i]]));}
+return array.join(',');}},parse:{'point':function(str){var coords=OpenLayers.String.trim(str).split(this.regExes.spaces);return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(coords[0],coords[1]));},'multipoint':function(str){var point;var points=OpenLayers.String.trim(str).split(',');var components=[];for(var i=0,len=points.length;i<len;++i){point=points[i].replace(this.regExes.trimParens,'$1');components.push(this.parse.point.apply(this,[point]).geometry);}
+return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiPoint(components));},'linestring':function(str){var points=OpenLayers.String.trim(str).split(',');var components=[];for(var i=0,len=points.length;i<len;++i){components.push(this.parse.point.apply(this,[points[i]]).geometry);}
+return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString(components));},'multilinestring':function(str){var line;var lines=OpenLayers.String.trim(str).split(this.regExes.parenComma);var components=[];for(var i=0,len=lines.length;i<len;++i){line=lines[i].replace(this.regExes.trimParens,'$1');components.push(this.parse.linestring.apply(this,[line]).geometry);}
+return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiLineString(components));},'polygon':function(str){var ring,linestring,linearring;var rings=OpenLayers.String.trim(str).split(this.regExes.parenComma);var components=[];for(var i=0,len=rings.length;i<len;++i){ring=rings[i].replace(this.regExes.trimParens,'$1');linestring=this.parse.linestring.apply(this,[ring]).geometry;linearring=new OpenLayers.Geometry.LinearRing(linestring.components);components.push(linearring);}
+return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Polygon(components));},'multipolygon':function(str){var polygon;var polygons=OpenLayers.String.trim(str).split(this.regExes.doubleParenComma);var components=[];for(var i=0,len=polygons.length;i<len;++i){polygon=polygons[i].replace(this.regExes.trimParens,'$1');components.push(this.parse.polygon.apply(this,[polygon]).geometry);}
+return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiPolygon(components));},'geometrycollection':function(str){str=str.replace(/,\s*([A-Za-z])/g,'|$1');var wktArray=OpenLayers.String.trim(str).split('|');var components=[];for(var i=0,len=wktArray.length;i<len;++i){components.push(OpenLayers.Format.WKT.prototype.read.apply(this,[wktArray[i]]));}
+return components;}},CLASS_NAME:"OpenLayers.Format.WKT"});OpenLayers.Geometry=OpenLayers.Class({id:null,parent:null,bounds:null,initialize:function(){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){this.id=null;this.bounds=null;},clone:function(){return new OpenLayers.Geometry();},setBounds:function(bounds){if(bounds){this.bounds=bounds.clone();}},clearBounds:function(){this.bounds=null;if(this.parent){this.parent.clearBounds();}},extendBounds:function(newBounds){var bounds=this.getBounds();if(!bounds){this.setBounds(newBounds);}else{this.bounds.extend(newBounds);}},getBounds:function(){if(this.bounds==null){this.calculateBounds();}
+return this.bounds;},calculateBounds:function(){},distanceTo:function(geometry,options){},getVertices:function(nodes){},atPoint:function(lonlat,toleranceLon,toleranceLat){var atPoint=false;var bounds=this.getBounds();if((bounds!=null)&&(lonlat!=null)){var dX=(toleranceLon!=null)?toleranceLon:0;var dY=(toleranceLat!=null)?toleranceLat:0;var toleranceBounds=new OpenLayers.Bounds(this.bounds.left-dX,this.bounds.bottom-dY,this.bounds.right+dX,this.bounds.top+dY);atPoint=toleranceBounds.containsLonLat(lonlat);}
+return atPoint;},getLength:function(){return 0.0;},getArea:function(){return 0.0;},getCentroid:function(){return null;},toString:function(){return OpenLayers.Format.WKT.prototype.write(new OpenLayers.Feature.Vector(this));},CLASS_NAME:"OpenLayers.Geometry"});OpenLayers.Geometry.fromWKT=function(wkt){var format=arguments.callee.format;if(!format){format=new OpenLayers.Format.WKT();arguments.callee.format=format;}
+var geom;var result=format.read(wkt);if(result instanceof OpenLayers.Feature.Vector){geom=result.geometry;}else if(OpenLayers.Util.isArray(result)){var len=result.length;var components=new Array(len);for(var i=0;i<len;++i){components[i]=result[i].geometry;}
+geom=new OpenLayers.Geometry.Collection(components);}
+return geom;};OpenLayers.Geometry.segmentsIntersect=function(seg1,seg2,options){var point=options&&options.point;var tolerance=options&&options.tolerance;var intersection=false;var x11_21=seg1.x1-seg2.x1;var y11_21=seg1.y1-seg2.y1;var x12_11=seg1.x2-seg1.x1;var y12_11=seg1.y2-seg1.y1;var y22_21=seg2.y2-seg2.y1;var x22_21=seg2.x2-seg2.x1;var d=(y22_21*x12_11)-(x22_21*y12_11);var n1=(x22_21*y11_21)-(y22_21*x11_21);var n2=(x12_11*y11_21)-(y12_11*x11_21);if(d==0){if(n1==0&&n2==0){intersection=true;}}else{var along1=n1/d;var along2=n2/d;if(along1>=0&&along1<=1&&along2>=0&&along2<=1){if(!point){intersection=true;}else{var x=seg1.x1+(along1*x12_11);var y=seg1.y1+(along1*y12_11);intersection=new OpenLayers.Geometry.Point(x,y);}}}
+if(tolerance){var dist;if(intersection){if(point){var segs=[seg1,seg2];var seg,x,y;outer:for(var i=0;i<2;++i){seg=segs[i];for(var j=1;j<3;++j){x=seg["x"+j];y=seg["y"+j];dist=Math.sqrt(Math.pow(x-intersection.x,2)+
+Math.pow(y-intersection.y,2));if(dist<tolerance){intersection.x=x;intersection.y=y;break outer;}}}}}else{var segs=[seg1,seg2];var source,target,x,y,p,result;outer:for(var i=0;i<2;++i){source=segs[i];target=segs[(i+1)%2];for(var j=1;j<3;++j){p={x:source["x"+j],y:source["y"+j]};result=OpenLayers.Geometry.distanceToSegment(p,target);if(result.distance<tolerance){if(point){intersection=new OpenLayers.Geometry.Point(p.x,p.y);}else{intersection=true;}
+break outer;}}}}}
+return intersection;};OpenLayers.Geometry.distanceToSegment=function(point,segment){var x0=point.x;var y0=point.y;var x1=segment.x1;var y1=segment.y1;var x2=segment.x2;var y2=segment.y2;var dx=x2-x1;var dy=y2-y1;var along=((dx*(x0-x1))+(dy*(y0-y1)))/(Math.pow(dx,2)+Math.pow(dy,2));var x,y;if(along<=0.0){x=x1;y=y1;}else if(along>=1.0){x=x2;y=y2;}else{x=x1+along*dx;y=y1+along*dy;}
+return{distance:Math.sqrt(Math.pow(x-x0,2)+Math.pow(y-y0,2)),x:x,y:y};};OpenLayers.Geometry.Collection=OpenLayers.Class(OpenLayers.Geometry,{components:null,componentTypes:null,initialize:function(components){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.components=[];if(components!=null){this.addComponents(components);}},destroy:function(){this.components.length=0;this.components=null;OpenLayers.Geometry.prototype.destroy.apply(this,arguments);},clone:function(){var geometry=eval("new "+this.CLASS_NAME+"()");for(var i=0,len=this.components.length;i<len;i++){geometry.addComponent(this.components[i].clone());}
+OpenLayers.Util.applyDefaults(geometry,this);return geometry;},getComponentsString:function(){var strings=[];for(var i=0,len=this.components.length;i<len;i++){strings.push(this.components[i].toShortString());}
+return strings.join(",");},calculateBounds:function(){this.bounds=null;var bounds=new OpenLayers.Bounds();var components=this.components;if(components){for(var i=0,len=components.length;i<len;i++){bounds.extend(components[i].getBounds());}}
+if(bounds.left!=null&&bounds.bottom!=null&&bounds.right!=null&&bounds.top!=null){this.setBounds(bounds);}},addComponents:function(components){if(!(OpenLayers.Util.isArray(components))){components=[components];}
+for(var i=0,len=components.length;i<len;i++){this.addComponent(components[i]);}},addComponent:function(component,index){var added=false;if(component){if(this.componentTypes==null||(OpenLayers.Util.indexOf(this.componentTypes,component.CLASS_NAME)>-1)){if(index!=null&&(index<this.components.length)){var components1=this.components.slice(0,index);var components2=this.components.slice(index,this.components.length);components1.push(component);this.components=components1.concat(components2);}else{this.components.push(component);}
+component.parent=this;this.clearBounds();added=true;}}
+return added;},removeComponents:function(components){var removed=false;if(!(OpenLayers.Util.isArray(components))){components=[components];}
+for(var i=components.length-1;i>=0;--i){removed=this.removeComponent(components[i])||removed;}
+return removed;},removeComponent:function(component){OpenLayers.Util.removeItem(this.components,component);this.clearBounds();return true;},getLength:function(){var length=0.0;for(var i=0,len=this.components.length;i<len;i++){length+=this.components[i].getLength();}
+return length;},getArea:function(){var area=0.0;for(var i=0,len=this.components.length;i<len;i++){area+=this.components[i].getArea();}
+return area;},getGeodesicArea:function(projection){var area=0.0;for(var i=0,len=this.components.length;i<len;i++){area+=this.components[i].getGeodesicArea(projection);}
+return area;},getCentroid:function(weighted){if(!weighted){return this.components.length&&this.components[0].getCentroid();}
+var len=this.components.length;if(!len){return false;}
+var areas=[];var centroids=[];var areaSum=0;var minArea=Number.MAX_VALUE;var component;for(var i=0;i<len;++i){component=this.components[i];var area=component.getArea();var centroid=component.getCentroid(true);if(isNaN(area)||isNaN(centroid.x)||isNaN(centroid.y)){continue;}
+areas.push(area);areaSum+=area;minArea=(area<minArea&&area>0)?area:minArea;centroids.push(centroid);}
+len=areas.length;if(areaSum===0){for(var i=0;i<len;++i){areas[i]=1;}
+areaSum=areas.length;}else{for(var i=0;i<len;++i){areas[i]/=minArea;}
+areaSum/=minArea;}
+var xSum=0,ySum=0,centroid,area;for(var i=0;i<len;++i){centroid=centroids[i];area=areas[i];xSum+=centroid.x*area;ySum+=centroid.y*area;}
+return new OpenLayers.Geometry.Point(xSum/areaSum,ySum/areaSum);},getGeodesicLength:function(projection){var length=0.0;for(var i=0,len=this.components.length;i<len;i++){length+=this.components[i].getGeodesicLength(projection);}
+return length;},move:function(x,y){for(var i=0,len=this.components.length;i<len;i++){this.components[i].move(x,y);}},rotate:function(angle,origin){for(var i=0,len=this.components.length;i<len;++i){this.components[i].rotate(angle,origin);}},resize:function(scale,origin,ratio){for(var i=0;i<this.components.length;++i){this.components[i].resize(scale,origin,ratio);}
+return this;},distanceTo:function(geometry,options){var edge=!(options&&options.edge===false);var details=edge&&options&&options.details;var result,best,distance;var min=Number.POSITIVE_INFINITY;for(var i=0,len=this.components.length;i<len;++i){result=this.components[i].distanceTo(geometry,options);distance=details?result.distance:result;if(distance<min){min=distance;best=result;if(min==0){break;}}}
+return best;},equals:function(geometry){var equivalent=true;if(!geometry||!geometry.CLASS_NAME||(this.CLASS_NAME!=geometry.CLASS_NAME)){equivalent=false;}else if(!(OpenLayers.Util.isArray(geometry.components))||(geometry.components.length!=this.components.length)){equivalent=false;}else{for(var i=0,len=this.components.length;i<len;++i){if(!this.components[i].equals(geometry.components[i])){equivalent=false;break;}}}
+return equivalent;},transform:function(source,dest){if(source&&dest){for(var i=0,len=this.components.length;i<len;i++){var component=this.components[i];component.transform(source,dest);}
+this.bounds=null;}
+return this;},intersects:function(geometry){var intersect=false;for(var i=0,len=this.components.length;i<len;++i){intersect=geometry.intersects(this.components[i]);if(intersect){break;}}
+return intersect;},getVertices:function(nodes){var vertices=[];for(var i=0,len=this.components.length;i<len;++i){Array.prototype.push.apply(vertices,this.components[i].getVertices(nodes));}
+return vertices;},CLASS_NAME:"OpenLayers.Geometry.Collection"});OpenLayers.Geometry.Point=OpenLayers.Class(OpenLayers.Geometry,{x:null,y:null,initialize:function(x,y){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.x=parseFloat(x);this.y=parseFloat(y);},clone:function(obj){if(obj==null){obj=new OpenLayers.Geometry.Point(this.x,this.y);}
+OpenLayers.Util.applyDefaults(obj,this);return obj;},calculateBounds:function(){this.bounds=new OpenLayers.Bounds(this.x,this.y,this.x,this.y);},distanceTo:function(geometry,options){var edge=!(options&&options.edge===false);var details=edge&&options&&options.details;var distance,x0,y0,x1,y1,result;if(geometry instanceof OpenLayers.Geometry.Point){x0=this.x;y0=this.y;x1=geometry.x;y1=geometry.y;distance=Math.sqrt(Math.pow(x0-x1,2)+Math.pow(y0-y1,2));result=!details?distance:{x0:x0,y0:y0,x1:x1,y1:y1,distance:distance};}else{result=geometry.distanceTo(this,options);if(details){result={x0:result.x1,y0:result.y1,x1:result.x0,y1:result.y0,distance:result.distance};}}
+return result;},equals:function(geom){var equals=false;if(geom!=null){equals=((this.x==geom.x&&this.y==geom.y)||(isNaN(this.x)&&isNaN(this.y)&&isNaN(geom.x)&&isNaN(geom.y)));}
+return equals;},toShortString:function(){return(this.x+", "+this.y);},move:function(x,y){this.x=this.x+x;this.y=this.y+y;this.clearBounds();},rotate:function(angle,origin){angle*=Math.PI/180;var radius=this.distanceTo(origin);var theta=angle+Math.atan2(this.y-origin.y,this.x-origin.x);this.x=origin.x+(radius*Math.cos(theta));this.y=origin.y+(radius*Math.sin(theta));this.clearBounds();},getCentroid:function(){return new OpenLayers.Geometry.Point(this.x,this.y);},resize:function(scale,origin,ratio){ratio=(ratio==undefined)?1:ratio;this.x=origin.x+(scale*ratio*(this.x-origin.x));this.y=origin.y+(scale*(this.y-origin.y));this.clearBounds();return this;},intersects:function(geometry){var intersect=false;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){intersect=this.equals(geometry);}else{intersect=geometry.intersects(this);}
+return intersect;},transform:function(source,dest){if((source&&dest)){OpenLayers.Projection.transform(this,source,dest);this.bounds=null;}
+return this;},getVertices:function(nodes){return[this];},CLASS_NAME:"OpenLayers.Geometry.Point"});OpenLayers.Geometry.MultiPoint=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.Point"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},addPoint:function(point,index){this.addComponent(point,index);},removePoint:function(point){this.removeComponent(point);},CLASS_NAME:"OpenLayers.Geometry.MultiPoint"});OpenLayers.Geometry.Curve=OpenLayers.Class(OpenLayers.Geometry.MultiPoint,{componentTypes:["OpenLayers.Geometry.Point"],initialize:function(points){OpenLayers.Geometry.MultiPoint.prototype.initialize.apply(this,arguments);},getLength:function(){var length=0.0;if(this.components&&(this.components.length>1)){for(var i=1,len=this.components.length;i<len;i++){length+=this.components[i-1].distanceTo(this.components[i]);}}
+return length;},getGeodesicLength:function(projection){var geom=this;if(projection){var gg=new OpenLayers.Projection("EPSG:4326");if(!gg.equals(projection)){geom=this.clone().transform(projection,gg);}}
+var length=0.0;if(geom.components&&(geom.components.length>1)){var p1,p2;for(var i=1,len=geom.components.length;i<len;i++){p1=geom.components[i-1];p2=geom.components[i];length+=OpenLayers.Util.distVincenty({lon:p1.x,lat:p1.y},{lon:p2.x,lat:p2.y});}}
+return length*1000;},CLASS_NAME:"OpenLayers.Geometry.Curve"});OpenLayers.Geometry.LineString=OpenLayers.Class(OpenLayers.Geometry.Curve,{initialize:function(points){OpenLayers.Geometry.Curve.prototype.initialize.apply(this,arguments);},removeComponent:function(point){var removed=this.components&&(this.components.length>2);if(removed){OpenLayers.Geometry.Collection.prototype.removeComponent.apply(this,arguments);}
+return removed;},intersects:function(geometry){var intersect=false;var type=geometry.CLASS_NAME;if(type=="OpenLayers.Geometry.LineString"||type=="OpenLayers.Geometry.LinearRing"||type=="OpenLayers.Geometry.Point"){var segs1=this.getSortedSegments();var segs2;if(type=="OpenLayers.Geometry.Point"){segs2=[{x1:geometry.x,y1:geometry.y,x2:geometry.x,y2:geometry.y}];}else{segs2=geometry.getSortedSegments();}
+var seg1,seg1x1,seg1x2,seg1y1,seg1y2,seg2,seg2y1,seg2y2;outer:for(var i=0,len=segs1.length;i<len;++i){seg1=segs1[i];seg1x1=seg1.x1;seg1x2=seg1.x2;seg1y1=seg1.y1;seg1y2=seg1.y2;inner:for(var j=0,jlen=segs2.length;j<jlen;++j){seg2=segs2[j];if(seg2.x1>seg1x2){break;}
+if(seg2.x2<seg1x1){continue;}
+seg2y1=seg2.y1;seg2y2=seg2.y2;if(Math.min(seg2y1,seg2y2)>Math.max(seg1y1,seg1y2)){continue;}
+if(Math.max(seg2y1,seg2y2)<Math.min(seg1y1,seg1y2)){continue;}
+if(OpenLayers.Geometry.segmentsIntersect(seg1,seg2)){intersect=true;break outer;}}}}else{intersect=geometry.intersects(this);}
+return intersect;},getSortedSegments:function(){var numSeg=this.components.length-1;var segments=new Array(numSeg),point1,point2;for(var i=0;i<numSeg;++i){point1=this.components[i];point2=this.components[i+1];if(point1.x<point2.x){segments[i]={x1:point1.x,y1:point1.y,x2:point2.x,y2:point2.y};}else{segments[i]={x1:point2.x,y1:point2.y,x2:point1.x,y2:point1.y};}}
+function byX1(seg1,seg2){return seg1.x1-seg2.x1;}
+return segments.sort(byX1);},splitWithSegment:function(seg,options){var edge=!(options&&options.edge===false);var tolerance=options&&options.tolerance;var lines=[];var verts=this.getVertices();var points=[];var intersections=[];var split=false;var vert1,vert2,point;var node,vertex,target;var interOptions={point:true,tolerance:tolerance};var result=null;for(var i=0,stop=verts.length-2;i<=stop;++i){vert1=verts[i];points.push(vert1.clone());vert2=verts[i+1];target={x1:vert1.x,y1:vert1.y,x2:vert2.x,y2:vert2.y};point=OpenLayers.Geometry.segmentsIntersect(seg,target,interOptions);if(point instanceof OpenLayers.Geometry.Point){if((point.x===seg.x1&&point.y===seg.y1)||(point.x===seg.x2&&point.y===seg.y2)||point.equals(vert1)||point.equals(vert2)){vertex=true;}else{vertex=false;}
+if(vertex||edge){if(!point.equals(intersections[intersections.length-1])){intersections.push(point.clone());}
+if(i===0){if(point.equals(vert1)){continue;}}
+if(point.equals(vert2)){continue;}
+split=true;if(!point.equals(vert1)){points.push(point);}
+lines.push(new OpenLayers.Geometry.LineString(points));points=[point.clone()];}}}
+if(split){points.push(vert2.clone());lines.push(new OpenLayers.Geometry.LineString(points));}
+if(intersections.length>0){var xDir=seg.x1<seg.x2?1:-1;var yDir=seg.y1<seg.y2?1:-1;result={lines:lines,points:intersections.sort(function(p1,p2){return(xDir*p1.x-xDir*p2.x)||(yDir*p1.y-yDir*p2.y);})};}
+return result;},split:function(target,options){var results=null;var mutual=options&&options.mutual;var sourceSplit,targetSplit,sourceParts,targetParts;if(target instanceof OpenLayers.Geometry.LineString){var verts=this.getVertices();var vert1,vert2,seg,splits,lines,point;var points=[];sourceParts=[];for(var i=0,stop=verts.length-2;i<=stop;++i){vert1=verts[i];vert2=verts[i+1];seg={x1:vert1.x,y1:vert1.y,x2:vert2.x,y2:vert2.y};targetParts=targetParts||[target];if(mutual){points.push(vert1.clone());}
+for(var j=0;j<targetParts.length;++j){splits=targetParts[j].splitWithSegment(seg,options);if(splits){lines=splits.lines;if(lines.length>0){lines.unshift(j,1);Array.prototype.splice.apply(targetParts,lines);j+=lines.length-2;}
+if(mutual){for(var k=0,len=splits.points.length;k<len;++k){point=splits.points[k];if(!point.equals(vert1)){points.push(point);sourceParts.push(new OpenLayers.Geometry.LineString(points));if(point.equals(vert2)){points=[];}else{points=[point.clone()];}}}}}}}
+if(mutual&&sourceParts.length>0&&points.length>0){points.push(vert2.clone());sourceParts.push(new OpenLayers.Geometry.LineString(points));}}else{results=target.splitWith(this,options);}
+if(targetParts&&targetParts.length>1){targetSplit=true;}else{targetParts=[];}
+if(sourceParts&&sourceParts.length>1){sourceSplit=true;}else{sourceParts=[];}
+if(targetSplit||sourceSplit){if(mutual){results=[sourceParts,targetParts];}else{results=targetParts;}}
+return results;},splitWith:function(geometry,options){return geometry.split(this,options);},getVertices:function(nodes){var vertices;if(nodes===true){vertices=[this.components[0],this.components[this.components.length-1]];}else if(nodes===false){vertices=this.components.slice(1,this.components.length-1);}else{vertices=this.components.slice();}
+return vertices;},distanceTo:function(geometry,options){var edge=!(options&&options.edge===false);var details=edge&&options&&options.details;var result,best={};var min=Number.POSITIVE_INFINITY;if(geometry instanceof OpenLayers.Geometry.Point){var segs=this.getSortedSegments();var x=geometry.x;var y=geometry.y;var seg;for(var i=0,len=segs.length;i<len;++i){seg=segs[i];result=OpenLayers.Geometry.distanceToSegment(geometry,seg);if(result.distance<min){min=result.distance;best=result;if(min===0){break;}}else{if(seg.x2>x&&((y>seg.y1&&y<seg.y2)||(y<seg.y1&&y>seg.y2))){break;}}}
+if(details){best={distance:best.distance,x0:best.x,y0:best.y,x1:x,y1:y};}else{best=best.distance;}}else if(geometry instanceof OpenLayers.Geometry.LineString){var segs0=this.getSortedSegments();var segs1=geometry.getSortedSegments();var seg0,seg1,intersection,x0,y0;var len1=segs1.length;var interOptions={point:true};outer:for(var i=0,len=segs0.length;i<len;++i){seg0=segs0[i];x0=seg0.x1;y0=seg0.y1;for(var j=0;j<len1;++j){seg1=segs1[j];intersection=OpenLayers.Geometry.segmentsIntersect(seg0,seg1,interOptions);if(intersection){min=0;best={distance:0,x0:intersection.x,y0:intersection.y,x1:intersection.x,y1:intersection.y};break outer;}else{result=OpenLayers.Geometry.distanceToSegment({x:x0,y:y0},seg1);if(result.distance<min){min=result.distance;best={distance:min,x0:x0,y0:y0,x1:result.x,y1:result.y};}}}}
+if(!details){best=best.distance;}
+if(min!==0){if(seg0){result=geometry.distanceTo(new OpenLayers.Geometry.Point(seg0.x2,seg0.y2),options);var dist=details?result.distance:result;if(dist<min){if(details){best={distance:min,x0:result.x1,y0:result.y1,x1:result.x0,y1:result.y0};}else{best=dist;}}}}}else{best=geometry.distanceTo(this,options);if(details){best={distance:best.distance,x0:best.x1,y0:best.y1,x1:best.x0,y1:best.y0};}}
+return best;},simplify:function(tolerance){if(this&&this!==null){var points=this.getVertices();if(points.length<3){return this;}
+var compareNumbers=function(a,b){return(a-b);};var douglasPeuckerReduction=function(points,firstPoint,lastPoint,tolerance){var maxDistance=0;var indexFarthest=0;for(var index=firstPoint,distance;index<lastPoint;index++){distance=perpendicularDistance(points[firstPoint],points[lastPoint],points[index]);if(distance>maxDistance){maxDistance=distance;indexFarthest=index;}}
+if(maxDistance>tolerance&&indexFarthest!=firstPoint){pointIndexsToKeep.push(indexFarthest);douglasPeuckerReduction(points,firstPoint,indexFarthest,tolerance);douglasPeuckerReduction(points,indexFarthest,lastPoint,tolerance);}};var perpendicularDistance=function(point1,point2,point){var area=Math.abs(0.5*(point1.x*point2.y+point2.x*point.y+point.x*point1.y-point2.x*point1.y-point.x*point2.y-point1.x*point.y));var bottom=Math.sqrt(Math.pow(point1.x-point2.x,2)+Math.pow(point1.y-point2.y,2));var height=area/bottom*2;return height;};var firstPoint=0;var lastPoint=points.length-1;var pointIndexsToKeep=[];pointIndexsToKeep.push(firstPoint);pointIndexsToKeep.push(lastPoint);while(points[firstPoint].equals(points[lastPoint])){lastPoint--;pointIndexsToKeep.push(lastPoint);}
+douglasPeuckerReduction(points,firstPoint,lastPoint,tolerance);var returnPoints=[];pointIndexsToKeep.sort(compareNumbers);for(var index=0;index<pointIndexsToKeep.length;index++){returnPoints.push(points[pointIndexsToKeep[index]]);}
+return new OpenLayers.Geometry.LineString(returnPoints);}
+else{return this;}},CLASS_NAME:"OpenLayers.Geometry.LineString"});OpenLayers.Geometry.LinearRing=OpenLayers.Class(OpenLayers.Geometry.LineString,{componentTypes:["OpenLayers.Geometry.Point"],initialize:function(points){OpenLayers.Geometry.LineString.prototype.initialize.apply(this,arguments);},addComponent:function(point,index){var added=false;var lastPoint=this.components.pop();if(index!=null||!point.equals(lastPoint)){added=OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,arguments);}
+var firstPoint=this.components[0];OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,[firstPoint]);return added;},removeComponent:function(point){var removed=this.components&&(this.components.length>3);if(removed){this.components.pop();OpenLayers.Geometry.Collection.prototype.removeComponent.apply(this,arguments);var firstPoint=this.components[0];OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,[firstPoint]);}
+return removed;},move:function(x,y){for(var i=0,len=this.components.length;i<len-1;i++){this.components[i].move(x,y);}},rotate:function(angle,origin){for(var i=0,len=this.components.length;i<len-1;++i){this.components[i].rotate(angle,origin);}},resize:function(scale,origin,ratio){for(var i=0,len=this.components.length;i<len-1;++i){this.components[i].resize(scale,origin,ratio);}
+return this;},transform:function(source,dest){if(source&&dest){for(var i=0,len=this.components.length;i<len-1;i++){var component=this.components[i];component.transform(source,dest);}
+this.bounds=null;}
+return this;},getCentroid:function(){if(this.components&&(this.components.length>2)){var sumX=0.0;var sumY=0.0;for(var i=0;i<this.components.length-1;i++){var b=this.components[i];var c=this.components[i+1];sumX+=(b.x+c.x)*(b.x*c.y-c.x*b.y);sumY+=(b.y+c.y)*(b.x*c.y-c.x*b.y);}
+var area=-1*this.getArea();var x=sumX/(6*area);var y=sumY/(6*area);return new OpenLayers.Geometry.Point(x,y);}else{return null;}},getArea:function(){var area=0.0;if(this.components&&(this.components.length>2)){var sum=0.0;for(var i=0,len=this.components.length;i<len-1;i++){var b=this.components[i];var c=this.components[i+1];sum+=(b.x+c.x)*(c.y-b.y);}
+area=-sum/2.0;}
+return area;},getGeodesicArea:function(projection){var ring=this;if(projection){var gg=new OpenLayers.Projection("EPSG:4326");if(!gg.equals(projection)){ring=this.clone().transform(projection,gg);}}
+var area=0.0;var len=ring.components&&ring.components.length;if(len>2){var p1,p2;for(var i=0;i<len-1;i++){p1=ring.components[i];p2=ring.components[i+1];area+=OpenLayers.Util.rad(p2.x-p1.x)*(2+Math.sin(OpenLayers.Util.rad(p1.y))+
+Math.sin(OpenLayers.Util.rad(p2.y)));}
+area=area*6378137.0*6378137.0/2.0;}
+return area;},containsPoint:function(point){var approx=OpenLayers.Number.limitSigDigs;var digs=14;var px=approx(point.x,digs);var py=approx(point.y,digs);function getX(y,x1,y1,x2,y2){return(((x1-x2)*y)+((x2*y1)-(x1*y2)))/(y1-y2);}
+var numSeg=this.components.length-1;var start,end,x1,y1,x2,y2,cx,cy;var crosses=0;for(var i=0;i<numSeg;++i){start=this.components[i];x1=approx(start.x,digs);y1=approx(start.y,digs);end=this.components[i+1];x2=approx(end.x,digs);y2=approx(end.y,digs);if(y1==y2){if(py==y1){if(x1<=x2&&(px>=x1&&px<=x2)||x1>=x2&&(px<=x1&&px>=x2)){crosses=-1;break;}}
+continue;}
+cx=approx(getX(py,x1,y1,x2,y2),digs);if(cx==px){if(y1<y2&&(py>=y1&&py<=y2)||y1>y2&&(py<=y1&&py>=y2)){crosses=-1;break;}}
+if(cx<=px){continue;}
+if(x1!=x2&&(cx<Math.min(x1,x2)||cx>Math.max(x1,x2))){continue;}
+if(y1<y2&&(py>=y1&&py<y2)||y1>y2&&(py<y1&&py>=y2)){++crosses;}}
+var contained=(crosses==-1)?1:!!(crosses&1);return contained;},intersects:function(geometry){var intersect=false;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){intersect=this.containsPoint(geometry);}else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LineString"){intersect=geometry.intersects(this);}else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){intersect=OpenLayers.Geometry.LineString.prototype.intersects.apply(this,[geometry]);}else{for(var i=0,len=geometry.components.length;i<len;++i){intersect=geometry.components[i].intersects(this);if(intersect){break;}}}
+return intersect;},getVertices:function(nodes){return(nodes===true)?[]:this.components.slice(0,this.components.length-1);},CLASS_NAME:"OpenLayers.Geometry.LinearRing"});OpenLayers.Geometry.Polygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LinearRing"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},getArea:function(){var area=0.0;if(this.components&&(this.components.length>0)){area+=Math.abs(this.components[0].getArea());for(var i=1,len=this.components.length;i<len;i++){area-=Math.abs(this.components[i].getArea());}}
+return area;},getGeodesicArea:function(projection){var area=0.0;if(this.components&&(this.components.length>0)){area+=Math.abs(this.components[0].getGeodesicArea(projection));for(var i=1,len=this.components.length;i<len;i++){area-=Math.abs(this.components[i].getGeodesicArea(projection));}}
+return area;},containsPoint:function(point){var numRings=this.components.length;var contained=false;if(numRings>0){contained=this.components[0].containsPoint(point);if(contained!==1){if(contained&&numRings>1){var hole;for(var i=1;i<numRings;++i){hole=this.components[i].containsPoint(point);if(hole){if(hole===1){contained=1;}else{contained=false;}
+break;}}}}}
+return contained;},intersects:function(geometry){var intersect=false;var i,len;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){intersect=this.containsPoint(geometry);}else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LineString"||geometry.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){for(i=0,len=this.components.length;i<len;++i){intersect=geometry.intersects(this.components[i]);if(intersect){break;}}
+if(!intersect){for(i=0,len=geometry.components.length;i<len;++i){intersect=this.containsPoint(geometry.components[i]);if(intersect){break;}}}}else{for(i=0,len=geometry.components.length;i<len;++i){intersect=this.intersects(geometry.components[i]);if(intersect){break;}}}
+if(!intersect&&geometry.CLASS_NAME=="OpenLayers.Geometry.Polygon"){var ring=this.components[0];for(i=0,len=ring.components.length;i<len;++i){intersect=geometry.containsPoint(ring.components[i]);if(intersect){break;}}}
+return intersect;},distanceTo:function(geometry,options){var edge=!(options&&options.edge===false);var result;if(!edge&&this.intersects(geometry)){result=0;}else{result=OpenLayers.Geometry.Collection.prototype.distanceTo.apply(this,[geometry,options]);}
+return result;},CLASS_NAME:"OpenLayers.Geometry.Polygon"});OpenLayers.Geometry.Polygon.createRegularPolygon=function(origin,radius,sides,rotation){var angle=Math.PI*((1/sides)-(1/2));if(rotation){angle+=(rotation/180)*Math.PI;}
+var rotatedAngle,x,y;var points=[];for(var i=0;i<sides;++i){rotatedAngle=angle+(i*2*Math.PI/sides);x=origin.x+(radius*Math.cos(rotatedAngle));y=origin.y+(radius*Math.sin(rotatedAngle));points.push(new OpenLayers.Geometry.Point(x,y));}
+var ring=new OpenLayers.Geometry.LinearRing(points);return new OpenLayers.Geometry.Polygon([ring]);};OpenLayers.Event={observers:false,KEY_BACKSPACE:8,KEY_TAB:9,KEY_RETURN:13,KEY_ESC:27,KEY_LEFT:37,KEY_UP:38,KEY_RIGHT:39,KEY_DOWN:40,KEY_DELETE:46,element:function(event){return event.target||event.srcElement;},isSingleTouch:function(event){return event.touches&&event.touches.length==1;},isMultiTouch:function(event){return event.touches&&event.touches.length>1;},isLeftClick:function(event){return(((event.which)&&(event.which==1))||((event.button)&&(event.button==1)));},isRightClick:function(event){return(((event.which)&&(event.which==3))||((event.button)&&(event.button==2)));},stop:function(event,allowDefault){if(!allowDefault){if(event.preventDefault){event.preventDefault();}else{event.returnValue=false;}}
+if(event.stopPropagation){event.stopPropagation();}else{event.cancelBubble=true;}},findElement:function(event,tagName){var element=OpenLayers.Event.element(event);while(element.parentNode&&(!element.tagName||(element.tagName.toUpperCase()!=tagName.toUpperCase()))){element=element.parentNode;}
+return element;},observe:function(elementParam,name,observer,useCapture){var element=OpenLayers.Util.getElement(elementParam);useCapture=useCapture||false;if(name=='keypress'&&(navigator.appVersion.match(/Konqueror|Safari|KHTML/)||element.attachEvent)){name='keydown';}
+if(!this.observers){this.observers={};}
+if(!element._eventCacheID){var idPrefix="eventCacheID_";if(element.id){idPrefix=element.id+"_"+idPrefix;}
+element._eventCacheID=OpenLayers.Util.createUniqueID(idPrefix);}
+var cacheID=element._eventCacheID;if(!this.observers[cacheID]){this.observers[cacheID]=[];}
+this.observers[cacheID].push({'element':element,'name':name,'observer':observer,'useCapture':useCapture});if(element.addEventListener){element.addEventListener(name,observer,useCapture);}else if(element.attachEvent){element.attachEvent('on'+name,observer);}},stopObservingElement:function(elementParam){var element=OpenLayers.Util.getElement(elementParam);var cacheID=element._eventCacheID;this._removeElementObservers(OpenLayers.Event.observers[cacheID]);},_removeElementObservers:function(elementObservers){if(elementObservers){for(var i=elementObservers.length-1;i>=0;i--){var entry=elementObservers[i];var args=new Array(entry.element,entry.name,entry.observer,entry.useCapture);var removed=OpenLayers.Event.stopObserving.apply(this,args);}}},stopObserving:function(elementParam,name,observer,useCapture){useCapture=useCapture||false;var element=OpenLayers.Util.getElement(elementParam);var cacheID=element._eventCacheID;if(name=='keypress'){if(navigator.appVersion.match(/Konqueror|Sa
 fari|KHTML/)||element.detachEvent){name='keydown';}}
+var foundEntry=false;var elementObservers=OpenLayers.Event.observers[cacheID];if(elementObservers){var i=0;while(!foundEntry&&i<elementObservers.length){var cacheEntry=elementObservers[i];if((cacheEntry.name==name)&&(cacheEntry.observer==observer)&&(cacheEntry.useCapture==useCapture)){elementObservers.splice(i,1);if(elementObservers.length==0){delete OpenLayers.Event.observers[cacheID];}
+foundEntry=true;break;}
+i++;}}
+if(foundEntry){if(element.removeEventListener){element.removeEventListener(name,observer,useCapture);}else if(element&&element.detachEvent){element.detachEvent('on'+name,observer);}}
+return foundEntry;},unloadCache:function(){if(OpenLayers.Event&&OpenLayers.Event.observers){for(var cacheID in OpenLayers.Event.observers){var elementObservers=OpenLayers.Event.observers[cacheID];OpenLayers.Event._removeElementObservers.apply(this,[elementObservers]);}
+OpenLayers.Event.observers=false;}},CLASS_NAME:"OpenLayers.Event"};OpenLayers.Event.observe(window,'unload',OpenLayers.Event.unloadCache,false);if(window.Event){OpenLayers.Util.applyDefaults(window.Event,OpenLayers.Event);}else{var Event=OpenLayers.Event;}
+OpenLayers.Events=OpenLayers.Class({BROWSER_EVENTS:["mouseover","mouseout","mousedown","mouseup","mousemove","click","dblclick","rightclick","dblrightclick","resize","focus","blur","touchstart","touchmove","touchend"],listeners:null,object:null,element:null,eventTypes:null,eventHandler:null,fallThrough:null,includeXY:false,clearMouseListener:null,initialize:function(object,element,eventTypes,fallThrough,options){OpenLayers.Util.extend(this,options);this.object=object;this.fallThrough=fallThrough;this.listeners={};this.eventHandler=OpenLayers.Function.bindAsEventListener(this.handleBrowserEvent,this);this.clearMouseListener=OpenLayers.Function.bind(this.clearMouseCache,this);this.eventTypes=[];if(eventTypes!=null){for(var i=0,len=eventTypes.length;i<len;i++){this.addEventType(eventTypes[i]);}}
+if(element!=null){this.attachToElement(element);}},destroy:function(){if(this.element){OpenLayers.Event.stopObservingElement(this.element);if(this.element.hasScrollEvent){OpenLayers.Event.stopObserving(window,"scroll",this.clearMouseListener);}}
+this.element=null;this.listeners=null;this.object=null;this.eventTypes=null;this.fallThrough=null;this.eventHandler=null;},addEventType:function(eventName){if(!this.listeners[eventName]){this.eventTypes.push(eventName);this.listeners[eventName]=[];}},attachToElement:function(element){if(this.element){OpenLayers.Event.stopObservingElement(this.element);}
+this.element=element;for(var i=0,len=this.BROWSER_EVENTS.length;i<len;i++){var eventType=this.BROWSER_EVENTS[i];this.addEventType(eventType);OpenLayers.Event.observe(element,eventType,this.eventHandler);}
+OpenLayers.Event.observe(element,"dragstart",OpenLayers.Event.stop);},on:function(object){for(var type in object){if(type!="scope"){this.register(type,object.scope,object[type]);}}},register:function(type,obj,func){if((func!=null)&&(OpenLayers.Util.indexOf(this.eventTypes,type)!=-1)){if(obj==null){obj=this.object;}
+var listeners=this.listeners[type];listeners.push({obj:obj,func:func});}},registerPriority:function(type,obj,func){if(func!=null){if(obj==null){obj=this.object;}
+var listeners=this.listeners[type];if(listeners!=null){listeners.unshift({obj:obj,func:func});}}},un:function(object){for(var type in object){if(type!="scope"){this.unregister(type,object.scope,object[type]);}}},unregister:function(type,obj,func){if(obj==null){obj=this.object;}
+var listeners=this.listeners[type];if(listeners!=null){for(var i=0,len=listeners.length;i<len;i++){if(listeners[i].obj==obj&&listeners[i].func==func){listeners.splice(i,1);break;}}}},remove:function(type){if(this.listeners[type]!=null){this.listeners[type]=[];}},triggerEvent:function(type,evt){var listeners=this.listeners[type];if(!listeners||listeners.length==0){return undefined;}
+if(evt==null){evt={};}
+evt.object=this.object;evt.element=this.element;if(!evt.type){evt.type=type;}
+listeners=listeners.slice();var continueChain;for(var i=0,len=listeners.length;i<len;i++){var callback=listeners[i];continueChain=callback.func.apply(callback.obj,[evt]);if((continueChain!=undefined)&&(continueChain==false)){break;}}
+if(!this.fallThrough){OpenLayers.Event.stop(evt,true);}
+return continueChain;},handleBrowserEvent:function(evt){var type=evt.type,listeners=this.listeners[type];if(!listeners||listeners.length==0){return;}
+var touches=evt.touches;if(touches&&touches[0]){var x=0;var y=0;var num=touches.length;var touch;for(var i=0;i<num;++i){touch=touches[i];x+=touch.clientX;y+=touch.clientY;}
+evt.clientX=x/num;evt.clientY=y/num;}
+if(this.includeXY){evt.xy=this.getMousePosition(evt);}
+this.triggerEvent(type,evt);},clearMouseCache:function(){this.element.scrolls=null;this.element.lefttop=null;var body=document.body;if(body&&!((body.scrollTop!=0||body.scrollLeft!=0)&&navigator.userAgent.match(/iPhone/i))){this.element.offsets=null;}},getMousePosition:function(evt){if(!this.includeXY){this.clearMouseCache();}else if(!this.element.hasScrollEvent){OpenLayers.Event.observe(window,"scroll",this.clearMouseListener);this.element.hasScrollEvent=true;}
+if(!this.element.scrolls){var viewportElement=OpenLayers.Util.getViewportElement();this.element.scrolls=[viewportElement.scrollLeft,viewportElement.scrollTop];}
+if(!this.element.lefttop){this.element.lefttop=[(document.documentElement.clientLeft||0),(document.documentElement.clientTop||0)];}
+if(!this.element.offsets){this.element.offsets=OpenLayers.Util.pagePosition(this.element);}
+return new OpenLayers.Pixel((evt.clientX+this.element.scrolls[0])-this.element.offsets[0]
+-this.element.lefttop[0],(evt.clientY+this.element.scrolls[1])-this.element.offsets[1]
+-this.element.lefttop[1]);},CLASS_NAME:"OpenLayers.Events"});OpenLayers.Map=OpenLayers.Class({Z_INDEX_BASE:{BaseLayer:100,Overlay:325,Feature:725,Popup:750,Control:1000},EVENT_TYPES:["preaddlayer","addlayer","preremovelayer","removelayer","changelayer","movestart","move","moveend","zoomend","popupopen","popupclose","addmarker","removemarker","clearmarkers","mouseover","mouseout","mousemove","dragstart","drag","dragend","changebaselayer"],id:null,fractionalZoom:false,events:null,allOverlays:false,div:null,dragging:false,size:null,viewPortDiv:null,layerContainerOrigin:null,layerContainerDiv:null,layers:null,controls:null,popups:null,baseLayer:null,center:null,resolution:null,zoom:0,panRatio:1.5,viewRequestID:0,tileSize:null,projection:"EPSG:4326",units:'degrees',resolutions:null,maxResolution:1.40625,minResolution:null,maxScale:null,minScale:null,maxExtent:null,minExtent:null,restrictedExtent:null,numZoomLevels:16,theme:null,displayProjection:null,fallThrough:true,panTween:nul
 l,eventListeners:null,panMethod:OpenLayers.Easing.Expo.easeOut,panDuration:50,paddingForPopups:null,minPx:null,maxPx:null,initialize:function(div,options){if(arguments.length===1&&typeof div==="object"){options=div;div=options&&options.div;}
+this.tileSize=new OpenLayers.Size(OpenLayers.Map.TILE_WIDTH,OpenLayers.Map.TILE_HEIGHT);this.maxExtent=new OpenLayers.Bounds(-180,-90,180,90);this.paddingForPopups=new OpenLayers.Bounds(15,15,15,15);this.theme=OpenLayers._getScriptLocation()+'theme/default/style.css';OpenLayers.Util.extend(this,options);this.layers=[];this.id=OpenLayers.Util.createUniqueID("OpenLayers.Map_");this.div=OpenLayers.Util.getElement(div);if(!this.div){this.div=document.createElement("div");this.div.style.height="1px";this.div.style.width="1px";}
+OpenLayers.Element.addClass(this.div,'olMap');var id=this.id+"_OpenLayers_ViewPort";this.viewPortDiv=OpenLayers.Util.createDiv(id,null,null,null,"relative",null,"hidden");this.viewPortDiv.style.width="100%";this.viewPortDiv.style.height="100%";this.viewPortDiv.className="olMapViewport";this.div.appendChild(this.viewPortDiv);var eventsDiv=document.createElement("div");eventsDiv.id=this.id+"_events";eventsDiv.style.position="absolute";eventsDiv.style.width="100%";eventsDiv.style.height="100%";eventsDiv.style.zIndex=this.Z_INDEX_BASE.Control-1;this.viewPortDiv.appendChild(eventsDiv);this.eventsDiv=eventsDiv;this.events=new OpenLayers.Events(this,this.eventsDiv,this.EVENT_TYPES,this.fallThrough,{includeXY:true});id=this.id+"_OpenLayers_Container";this.layerContainerDiv=OpenLayers.Util.createDiv(id);this.layerContainerDiv.style.zIndex=this.Z_INDEX_BASE['Popup']-1;this.eventsDiv.appendChild(this.layerContainerDiv);this.updateSize();if(this.eventListeners instanceof Object){this.ev
 ents.on(this.eventListeners);}
+this.events.register("movestart",this,this.updateSize);if(OpenLayers.String.contains(navigator.appName,"Microsoft")){this.events.register("resize",this,this.updateSize);}else{this.updateSizeDestroy=OpenLayers.Function.bind(this.updateSize,this);OpenLayers.Event.observe(window,'resize',this.updateSizeDestroy);}
+if(this.theme){var addNode=true;var nodes=document.getElementsByTagName('link');for(var i=0,len=nodes.length;i<len;++i){if(OpenLayers.Util.isEquivalentUrl(nodes.item(i).href,this.theme)){addNode=false;break;}}
+if(addNode){var cssNode=document.createElement('link');cssNode.setAttribute('rel','stylesheet');cssNode.setAttribute('type','text/css');cssNode.setAttribute('href',this.theme);document.getElementsByTagName('head')[0].appendChild(cssNode);}}
+if(this.controls==null){if(OpenLayers.Control!=null){this.controls=[new OpenLayers.Control.Navigation(),new OpenLayers.Control.PanZoom(),new OpenLayers.Control.ArgParser(),new OpenLayers.Control.Attribution()];}else{this.controls=[];}}
+for(var i=0,len=this.controls.length;i<len;i++){this.addControlToMap(this.controls[i]);}
+this.popups=[];this.unloadDestroy=OpenLayers.Function.bind(this.destroy,this);OpenLayers.Event.observe(window,'unload',this.unloadDestroy);if(options&&options.layers){delete this.center;this.addLayers(options.layers);if(options.center){this.setCenter(options.center,options.zoom);}}},render:function(div){this.div=OpenLayers.Util.getElement(div);OpenLayers.Element.addClass(this.div,'olMap');this.viewPortDiv.parentNode.removeChild(this.viewPortDiv);this.div.appendChild(this.viewPortDiv);this.updateSize();},unloadDestroy:null,updateSizeDestroy:null,destroy:function(){if(!this.unloadDestroy){return false;}
+if(this.panTween){this.panTween.stop();this.panTween=null;}
+OpenLayers.Event.stopObserving(window,'unload',this.unloadDestroy);this.unloadDestroy=null;if(this.updateSizeDestroy){OpenLayers.Event.stopObserving(window,'resize',this.updateSizeDestroy);}else{this.events.unregister("resize",this,this.updateSize);}
+this.paddingForPopups=null;if(this.controls!=null){for(var i=this.controls.length-1;i>=0;--i){this.controls[i].destroy();}
+this.controls=null;}
+if(this.layers!=null){for(var i=this.layers.length-1;i>=0;--i){this.layers[i].destroy(false);}
+this.layers=null;}
+if(this.viewPortDiv){this.div.removeChild(this.viewPortDiv);}
+this.viewPortDiv=null;if(this.eventListeners){this.events.un(this.eventListeners);this.eventListeners=null;}
+this.events.destroy();this.events=null;},setOptions:function(options){var updatePxExtent=this.minPx&&options.restrictedExtent!=this.restrictedExtent;OpenLayers.Util.extend(this,options);updatePxExtent&&this.moveTo(this.getCachedCenter(),this.zoom,{forceZoomChange:true});},getTileSize:function(){return this.tileSize;},getBy:function(array,property,match){var test=(typeof match.test=="function");var found=OpenLayers.Array.filter(this[array],function(item){return item[property]==match||(test&&match.test(item[property]));});return found;},getLayersBy:function(property,match){return this.getBy("layers",property,match);},getLayersByName:function(match){return this.getLayersBy("name",match);},getLayersByClass:function(match){return this.getLayersBy("CLASS_NAME",match);},getControlsBy:function(property,match){return this.getBy("controls",property,match);},getControlsByClass:function(match){return this.getControlsBy("CLASS_NAME",match);},getLayer:function(id){var foundLayer=null;for(
 var i=0,len=this.layers.length;i<len;i++){var layer=this.layers[i];if(layer.id==id){foundLayer=layer;break;}}
+return foundLayer;},setLayerZIndex:function(layer,zIdx){layer.setZIndex(this.Z_INDEX_BASE[layer.isBaseLayer?'BaseLayer':'Overlay']
++zIdx*5);},resetLayersZIndex:function(){for(var i=0,len=this.layers.length;i<len;i++){var layer=this.layers[i];this.setLayerZIndex(layer,i);}},addLayer:function(layer){for(var i=0,len=this.layers.length;i<len;i++){if(this.layers[i]==layer){var msg=OpenLayers.i18n('layerAlreadyAdded',{'layerName':layer.name});OpenLayers.Console.warn(msg);return false;}}
+if(this.events.triggerEvent("preaddlayer",{layer:layer})===false){return;}
+if(this.allOverlays){layer.isBaseLayer=false;}
+layer.div.className="olLayerDiv";layer.div.style.overflow="";this.setLayerZIndex(layer,this.layers.length);if(layer.isFixed){this.viewPortDiv.appendChild(layer.div);}else{this.layerContainerDiv.appendChild(layer.div);}
+this.layers.push(layer);layer.setMap(this);if(layer.isBaseLayer||(this.allOverlays&&!this.baseLayer)){if(this.baseLayer==null){this.setBaseLayer(layer);}else{layer.setVisibility(false);}}else{layer.redraw();}
+this.events.triggerEvent("addlayer",{layer:layer});layer.events.triggerEvent("added",{map:this,layer:layer});layer.afterAdd();},addLayers:function(layers){for(var i=0,len=layers.length;i<len;i++){this.addLayer(layers[i]);}},removeLayer:function(layer,setNewBaseLayer){if(this.events.triggerEvent("preremovelayer",{layer:layer})===false){return;}
+if(setNewBaseLayer==null){setNewBaseLayer=true;}
+if(layer.isFixed){this.viewPortDiv.removeChild(layer.div);}else{this.layerContainerDiv.removeChild(layer.div);}
+OpenLayers.Util.removeItem(this.layers,layer);layer.removeMap(this);layer.map=null;if(this.baseLayer==layer){this.baseLayer=null;if(setNewBaseLayer){for(var i=0,len=this.layers.length;i<len;i++){var iLayer=this.layers[i];if(iLayer.isBaseLayer||this.allOverlays){this.setBaseLayer(iLayer);break;}}}}
+this.resetLayersZIndex();this.events.triggerEvent("removelayer",{layer:layer});layer.events.triggerEvent("removed",{map:this,layer:layer});},getNumLayers:function(){return this.layers.length;},getLayerIndex:function(layer){return OpenLayers.Util.indexOf(this.layers,layer);},setLayerIndex:function(layer,idx){var base=this.getLayerIndex(layer);if(idx<0){idx=0;}else if(idx>this.layers.length){idx=this.layers.length;}
+if(base!=idx){this.layers.splice(base,1);this.layers.splice(idx,0,layer);for(var i=0,len=this.layers.length;i<len;i++){this.setLayerZIndex(this.layers[i],i);}
+this.events.triggerEvent("changelayer",{layer:layer,property:"order"});if(this.allOverlays){if(idx===0){this.setBaseLayer(layer);}else if(this.baseLayer!==this.layers[0]){this.setBaseLayer(this.layers[0]);}}}},raiseLayer:function(layer,delta){var idx=this.getLayerIndex(layer)+delta;this.setLayerIndex(layer,idx);},setBaseLayer:function(newBaseLayer){if(newBaseLayer!=this.baseLayer){if(OpenLayers.Util.indexOf(this.layers,newBaseLayer)!=-1){var center=this.getCachedCenter();var newResolution=OpenLayers.Util.getResolutionFromScale(this.getScale(),newBaseLayer.units);if(this.baseLayer!=null&&!this.allOverlays){this.baseLayer.setVisibility(false);}
+this.baseLayer=newBaseLayer;this.viewRequestID++;if(!this.allOverlays||this.baseLayer.visibility){this.baseLayer.setVisibility(true);}
+if(center!=null){var newZoom=this.getZoomForResolution(newResolution||this.resolution,true);this.setCenter(center,newZoom,false,true);}
+this.events.triggerEvent("changebaselayer",{layer:this.baseLayer});}}},addControl:function(control,px){this.controls.push(control);this.addControlToMap(control,px);},addControls:function(controls,pixels){var pxs=(arguments.length===1)?[]:pixels;for(var i=0,len=controls.length;i<len;i++){var ctrl=controls[i];var px=(pxs[i])?pxs[i]:null;this.addControl(ctrl,px);}},addControlToMap:function(control,px){control.outsideViewport=(control.div!=null);if(this.displayProjection&&!control.displayProjection){control.displayProjection=this.displayProjection;}
+control.setMap(this);var div=control.draw(px);if(div){if(!control.outsideViewport){div.style.zIndex=this.Z_INDEX_BASE['Control']+
+this.controls.length;this.viewPortDiv.appendChild(div);}}
+if(control.autoActivate){control.activate();}},getControl:function(id){var returnControl=null;for(var i=0,len=this.controls.length;i<len;i++){var control=this.controls[i];if(control.id==id){returnControl=control;break;}}
+return returnControl;},removeControl:function(control){if((control)&&(control==this.getControl(control.id))){if(control.div&&(control.div.parentNode==this.viewPortDiv)){this.viewPortDiv.removeChild(control.div);}
+OpenLayers.Util.removeItem(this.controls,control);}},addPopup:function(popup,exclusive){if(exclusive){for(var i=this.popups.length-1;i>=0;--i){this.removePopup(this.popups[i]);}}
+popup.map=this;this.popups.push(popup);var popupDiv=popup.draw();if(popupDiv){popupDiv.style.zIndex=this.Z_INDEX_BASE['Popup']+
+this.popups.length;this.layerContainerDiv.appendChild(popupDiv);}},removePopup:function(popup){OpenLayers.Util.removeItem(this.popups,popup);if(popup.div){try{this.layerContainerDiv.removeChild(popup.div);}
+catch(e){}}
+popup.map=null;},getSize:function(){var size=null;if(this.size!=null){size=this.size.clone();}
+return size;},updateSize:function(){var newSize=this.getCurrentSize();if(newSize&&!isNaN(newSize.h)&&!isNaN(newSize.w)){this.events.clearMouseCache();var oldSize=this.getSize();if(oldSize==null){this.size=oldSize=newSize;}
+if(!newSize.equals(oldSize)){this.size=newSize;for(var i=0,len=this.layers.length;i<len;i++){this.layers[i].onMapResize();}
+var center=this.getCachedCenter();if(this.baseLayer!=null&&center!=null){var zoom=this.getZoom();this.zoom=null;this.setCenter(center,zoom);}}}},getCurrentSize:function(){var size=new OpenLayers.Size(this.div.clientWidth,this.div.clientHeight);if(size.w==0&&size.h==0||isNaN(size.w)&&isNaN(size.h)){size.w=this.div.offsetWidth;size.h=this.div.offsetHeight;}
+if(size.w==0&&size.h==0||isNaN(size.w)&&isNaN(size.h)){size.w=parseInt(this.div.style.width);size.h=parseInt(this.div.style.height);}
+return size;},calculateBounds:function(center,resolution){var extent=null;if(center==null){center=this.getCachedCenter();}
+if(resolution==null){resolution=this.getResolution();}
+if((center!=null)&&(resolution!=null)){var size=this.getSize();var w_deg=size.w*resolution;var h_deg=size.h*resolution;extent=new OpenLayers.Bounds(center.lon-w_deg/2,center.lat-h_deg/2,center.lon+w_deg/2,center.lat+h_deg/2);}
+return extent;},getCenter:function(){var center=null;var cachedCenter=this.getCachedCenter();if(cachedCenter){center=cachedCenter.clone();}
+return center;},getCachedCenter:function(){if(!this.center&&this.size){this.center=this.getLonLatFromViewPortPx(new OpenLayers.Pixel(this.size.w/2,this.size.h/2));}
+return this.center;},getZoom:function(){return this.zoom;},pan:function(dx,dy,options){options=OpenLayers.Util.applyDefaults(options,{animate:true,dragging:false});if(options.dragging){if(dx!=0||dy!=0){this.moveByPx(dx,dy);}}else{var centerPx=this.getViewPortPxFromLonLat(this.getCachedCenter());var newCenterPx=centerPx.add(dx,dy);if(this.dragging||!newCenterPx.equals(centerPx)){var newCenterLonLat=this.getLonLatFromViewPortPx(newCenterPx);if(options.animate){this.panTo(newCenterLonLat);}else{this.moveTo(newCenterLonLat);this.dragging=false;this.events.triggerEvent("moveend");}}}},panTo:function(lonlat){if(this.panMethod&&this.getExtent().scale(this.panRatio).containsLonLat(lonlat)){if(!this.panTween){this.panTween=new OpenLayers.Tween(this.panMethod);}
+var center=this.getCachedCenter();if(lonlat.equals(center)){return;}
+var from=this.getPixelFromLonLat(center);var to=this.getPixelFromLonLat(lonlat);var vector={x:to.x-from.x,y:to.y-from.y};var last={x:0,y:0};this.panTween.start({x:0,y:0},vector,this.panDuration,{callbacks:{eachStep:OpenLayers.Function.bind(function(px){var x=px.x-last.x,y=px.y-last.y;this.moveByPx(x,y);last.x=Math.round(px.x);last.y=Math.round(px.y);},this),done:OpenLayers.Function.bind(function(px){this.moveTo(lonlat);this.dragging=false;this.events.triggerEvent("moveend");},this)}});}else{this.setCenter(lonlat);}},setCenter:function(lonlat,zoom,dragging,forceZoomChange){this.panTween&&this.panTween.stop();this.moveTo(lonlat,zoom,{'dragging':dragging,'forceZoomChange':forceZoomChange});},moveByPx:function(dx,dy){var hw=this.size.w/2;var hh=this.size.h/2;var x=hw+dx;var y=hh+dy;var wrapDateLine=this.baseLayer.wrapDateLine;var xRestriction=0;var yRestriction=0;if(this.restrictedExtent){xRestriction=hw;yRestriction=hh;wrapDateLine=false;}
+dx=wrapDateLine||x<=this.maxPx.x-xRestriction&&x>=this.minPx.x+xRestriction?Math.round(dx):0;dy=y<=this.maxPx.y-yRestriction&&y>=this.minPx.y+yRestriction?Math.round(dy):0;var minX=this.minPx.x,maxX=this.maxPx.x;if(dx||dy){if(!this.dragging){this.dragging=true;this.events.triggerEvent("movestart");}
+this.center=null;if(dx){this.layerContainerDiv.style.left=parseInt(this.layerContainerDiv.style.left)-dx+"px";this.minPx.x-=dx;this.maxPx.x-=dx;if(wrapDateLine){if(this.maxPx.x>maxX){this.maxPx.x-=(maxX-minX);}
+if(this.minPx.x<minX){this.minPx.x+=(maxX-minX);}}}
+if(dy){this.layerContainerDiv.style.top=parseInt(this.layerContainerDiv.style.top)-dy+"px";this.minPx.y-=dy;this.maxPx.y-=dy;}
+var layer,i,len;for(i=0,len=this.layers.length;i<len;++i){layer=this.layers[i];if(layer.visibility&&(layer===this.baseLayer||layer.inRange)){layer.moveByPx(dx,dy);layer.events.triggerEvent("move");}}
+this.events.triggerEvent("move");}},moveTo:function(lonlat,zoom,options){if(!options){options={};}
+if(zoom!=null){zoom=parseFloat(zoom);if(!this.fractionalZoom){zoom=Math.round(zoom);}}
+var dragging=options.dragging||this.dragging;var forceZoomChange=options.forceZoomChange;if(!this.getCachedCenter()&&!this.isValidLonLat(lonlat)){lonlat=this.maxExtent.getCenterLonLat();this.center=lonlat.clone();}
+if(this.restrictedExtent!=null){if(lonlat==null){lonlat=this.center;}
+if(zoom==null){zoom=this.getZoom();}
+var resolution=this.getResolutionForZoom(zoom);var extent=this.calculateBounds(lonlat,resolution);if(!this.restrictedExtent.containsBounds(extent)){var maxCenter=this.restrictedExtent.getCenterLonLat();if(extent.getWidth()>this.restrictedExtent.getWidth()){lonlat=new OpenLayers.LonLat(maxCenter.lon,lonlat.lat);}else if(extent.left<this.restrictedExtent.left){lonlat=lonlat.add(this.restrictedExtent.left-
+extent.left,0);}else if(extent.right>this.restrictedExtent.right){lonlat=lonlat.add(this.restrictedExtent.right-
+extent.right,0);}
+if(extent.getHeight()>this.restrictedExtent.getHeight()){lonlat=new OpenLayers.LonLat(lonlat.lon,maxCenter.lat);}else if(extent.bottom<this.restrictedExtent.bottom){lonlat=lonlat.add(0,this.restrictedExtent.bottom-
+extent.bottom);}
+else if(extent.top>this.restrictedExtent.top){lonlat=lonlat.add(0,this.restrictedExtent.top-
+extent.top);}}}
+var zoomChanged=forceZoomChange||((this.isValidZoomLevel(zoom))&&(zoom!=this.getZoom()));var centerChanged=(this.isValidLonLat(lonlat))&&(!lonlat.equals(this.center));if(zoomChanged||centerChanged||dragging){dragging||this.events.triggerEvent("movestart");if(centerChanged){if(!zoomChanged&&this.center){this.centerLayerContainer(lonlat);}
+this.center=lonlat.clone();}
+var res=zoomChanged?this.getResolutionForZoom(zoom):this.getResolution();if(zoomChanged||this.layerContainerOrigin==null){this.layerContainerOrigin=this.getCachedCenter();this.layerContainerDiv.style.left="0px";this.layerContainerDiv.style.top="0px";var maxExtent=this.getMaxExtent({restricted:true});var maxExtentCenter=maxExtent.getCenterLonLat();var lonDelta=this.center.lon-maxExtentCenter.lon;var latDelta=maxExtentCenter.lat-this.center.lat;var extentWidth=Math.round(maxExtent.getWidth()/res);var extentHeight=Math.round(maxExtent.getHeight()/res);var left=(this.size.w-extentWidth)/2-lonDelta/res;var top=(this.size.h-extentHeight)/2-latDelta/res;this.minPx=new OpenLayers.Pixel(left,top);this.maxPx=new OpenLayers.Pixel(left+extentWidth,top+extentHeight);}
+if(zoomChanged){this.zoom=zoom;this.resolution=res;this.viewRequestID++;}
+var bounds=this.getExtent();if(this.baseLayer.visibility){this.baseLayer.moveTo(bounds,zoomChanged,options.dragging);options.dragging||this.baseLayer.events.triggerEvent("moveend",{zoomChanged:zoomChanged});}
+bounds=this.baseLayer.getExtent();for(var i=this.layers.length-1;i>=0;--i){var layer=this.layers[i];if(layer!==this.baseLayer&&!layer.isBaseLayer){var inRange=layer.calculateInRange();if(layer.inRange!=inRange){layer.inRange=inRange;if(!inRange){layer.display(false);}
+this.events.triggerEvent("changelayer",{layer:layer,property:"visibility"});}
+if(inRange&&layer.visibility){layer.moveTo(bounds,zoomChanged,options.dragging);options.dragging||layer.events.triggerEvent("moveend",{zoomChanged:zoomChanged});}}}
+this.events.triggerEvent("move");dragging||this.events.triggerEvent("moveend");if(zoomChanged){for(var i=0,len=this.popups.length;i<len;i++){this.popups[i].updatePosition();}
+this.events.triggerEvent("zoomend");}}},centerLayerContainer:function(lonlat){var originPx=this.getViewPortPxFromLonLat(this.layerContainerOrigin);var newPx=this.getViewPortPxFromLonLat(lonlat);if((originPx!=null)&&(newPx!=null)){var oldLeft=parseInt(this.layerContainerDiv.style.left);var oldTop=parseInt(this.layerContainerDiv.style.top);var newLeft=Math.round(originPx.x-newPx.x);var newTop=Math.round(originPx.y-newPx.y);this.layerContainerDiv.style.left=newLeft+"px";this.layerContainerDiv.style.top=newTop+"px";var dx=oldLeft-newLeft;var dy=oldTop-newTop;this.minPx.x-=dx;this.maxPx.x-=dx;this.minPx.y-=dy;this.maxPx.y-=dy;}},isValidZoomLevel:function(zoomLevel){return((zoomLevel!=null)&&(zoomLevel>=0)&&(zoomLevel<this.getNumZoomLevels()));},isValidLonLat:function(lonlat){var valid=false;if(lonlat!=null){var maxExtent=this.getMaxExtent();valid=maxExtent.containsLonLat(lonlat);}
+return valid;},getProjection:function(){var projection=this.getProjectionObject();return projection?projection.getCode():null;},getProjectionObject:function(){var projection=null;if(this.baseLayer!=null){projection=this.baseLayer.projection;}
+return projection;},getMaxResolution:function(){var maxResolution=null;if(this.baseLayer!=null){maxResolution=this.baseLayer.maxResolution;}
+return maxResolution;},getMaxExtent:function(options){var maxExtent=null;if(options&&options.restricted&&this.restrictedExtent){maxExtent=this.restrictedExtent;}else if(this.baseLayer!=null){maxExtent=this.baseLayer.maxExtent;}
+return maxExtent;},getNumZoomLevels:function(){var numZoomLevels=null;if(this.baseLayer!=null){numZoomLevels=this.baseLayer.numZoomLevels;}
+return numZoomLevels;},getExtent:function(){var extent=null;if(this.baseLayer!=null){extent=this.baseLayer.getExtent();}
+return extent;},getResolution:function(){var resolution=null;if(this.baseLayer!=null){resolution=this.baseLayer.getResolution();}else if(this.allOverlays===true&&this.layers.length>0){resolution=this.layers[0].getResolution();}
+return resolution;},getUnits:function(){var units=null;if(this.baseLayer!=null){units=this.baseLayer.units;}
+return units;},getScale:function(){var scale=null;if(this.baseLayer!=null){var res=this.getResolution();var units=this.baseLayer.units;scale=OpenLayers.Util.getScaleFromResolution(res,units);}
+return scale;},getZoomForExtent:function(bounds,closest){var zoom=null;if(this.baseLayer!=null){zoom=this.baseLayer.getZoomForExtent(bounds,closest);}
+return zoom;},getResolutionForZoom:function(zoom){var resolution=null;if(this.baseLayer){resolution=this.baseLayer.getResolutionForZoom(zoom);}
+return resolution;},getZoomForResolution:function(resolution,closest){var zoom=null;if(this.baseLayer!=null){zoom=this.baseLayer.getZoomForResolution(resolution,closest);}
+return zoom;},zoomTo:function(zoom){if(this.isValidZoomLevel(zoom)){this.setCenter(null,zoom);}},zoomIn:function(){this.zoomTo(this.getZoom()+1);},zoomOut:function(){this.zoomTo(this.getZoom()-1);},zoomToExtent:function(bounds,closest){var center=bounds.getCenterLonLat();if(this.baseLayer.wrapDateLine){var maxExtent=this.getMaxExtent();bounds=bounds.clone();while(bounds.right<bounds.left){bounds.right+=maxExtent.getWidth();}
+center=bounds.getCenterLonLat().wrapDateLine(maxExtent);}
+this.setCenter(center,this.getZoomForExtent(bounds,closest));},zoomToMaxExtent:function(options){var restricted=(options)?options.restricted:true;var maxExtent=this.getMaxExtent({'restricted':restricted});this.zoomToExtent(maxExtent);},zoomToScale:function(scale,closest){var res=OpenLayers.Util.getResolutionFromScale(scale,this.baseLayer.units);var size=this.getSize();var w_deg=size.w*res;var h_deg=size.h*res;var center=this.getCachedCenter();var extent=new OpenLayers.Bounds(center.lon-w_deg/2,center.lat-h_deg/2,center.lon+w_deg/2,center.lat+h_deg/2);this.zoomToExtent(extent,closest);},getLonLatFromViewPortPx:function(viewPortPx){var lonlat=null;if(this.baseLayer!=null){lonlat=this.baseLayer.getLonLatFromViewPortPx(viewPortPx);}
+return lonlat;},getViewPortPxFromLonLat:function(lonlat){var px=null;if(this.baseLayer!=null){px=this.baseLayer.getViewPortPxFromLonLat(lonlat);}
+return px;},getLonLatFromPixel:function(px){return this.getLonLatFromViewPortPx(px);},getPixelFromLonLat:function(lonlat){var px=this.getViewPortPxFromLonLat(lonlat);px.x=Math.round(px.x);px.y=Math.round(px.y);return px;},getGeodesicPixelSize:function(px){var lonlat=px?this.getLonLatFromPixel(px):(this.getCachedCenter()||new OpenLayers.LonLat(0,0));var res=this.getResolution();var left=lonlat.add(-res/2,0);var right=lonlat.add(res/2,0);var bottom=lonlat.add(0,-res/2);var top=lonlat.add(0,res/2);var dest=new OpenLayers.Projection("EPSG:4326");var source=this.getProjectionObject()||dest;if(!source.equals(dest)){left.transform(source,dest);right.transform(source,dest);bottom.transform(source,dest);top.transform(source,dest);}
+return new OpenLayers.Size(OpenLayers.Util.distVincenty(left,right),OpenLayers.Util.distVincenty(bottom,top));},getViewPortPxFromLayerPx:function(layerPx){var viewPortPx=null;if(layerPx!=null){var dX=parseInt(this.layerContainerDiv.style.left);var dY=parseInt(this.layerContainerDiv.style.top);viewPortPx=layerPx.add(dX,dY);}
+return viewPortPx;},getLayerPxFromViewPortPx:function(viewPortPx){var layerPx=null;if(viewPortPx!=null){var dX=-parseInt(this.layerContainerDiv.style.left);var dY=-parseInt(this.layerContainerDiv.style.top);layerPx=viewPortPx.add(dX,dY);if(isNaN(layerPx.x)||isNaN(layerPx.y)){layerPx=null;}}
+return layerPx;},getLonLatFromLayerPx:function(px){px=this.getViewPortPxFromLayerPx(px);return this.getLonLatFromViewPortPx(px);},getLayerPxFromLonLat:function(lonlat){var px=this.getPixelFromLonLat(lonlat);return this.getLayerPxFromViewPortPx(px);},CLASS_NAME:"OpenLayers.Map"});OpenLayers.Map.TILE_WIDTH=256;OpenLayers.Map.TILE_HEIGHT=256;OpenLayers.Layer=OpenLayers.Class({id:null,name:null,div:null,opacity:null,alwaysInRange:null,EVENT_TYPES:["loadstart","loadend","loadcancel","visibilitychanged","move","moveend","added","removed"],RESOLUTION_PROPERTIES:['scales','resolutions','maxScale','minScale','maxResolution','minResolution','numZoomLevels','maxZoomLevel'],events:null,map:null,isBaseLayer:false,alpha:false,displayInLayerSwitcher:true,visibility:true,attribution:null,inRange:false,imageSize:null,imageOffset:null,options:null,eventListeners:null,gutter:0,projection:null,units:null,scales:null,resolutions:null,maxExtent:null,minExtent:null,maxResolution:null,minResolution
 :null,numZoomLevels:null,minScale:null,maxScale:null,displayOutsideMaxExtent:false,wrapDateLine:false,transitionEffect:null,SUPPORTED_TRANSITIONS:['resize'],metadata:{},initialize:function(name,options){this.addOptions(options);this.name=name;if(this.id==null){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");this.div=OpenLayers.Util.createDiv(this.id);this.div.style.width="100%";this.div.style.height="100%";this.div.dir="ltr";this.events=new OpenLayers.Events(this,this.div,this.EVENT_TYPES);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}}
+if(this.wrapDateLine){this.displayOutsideMaxExtent=true;}},destroy:function(setNewBaseLayer){if(setNewBaseLayer==null){setNewBaseLayer=true;}
+if(this.map!=null){this.map.removeLayer(this,setNewBaseLayer);}
+this.projection=null;this.map=null;this.name=null;this.div=null;this.options=null;if(this.events){if(this.eventListeners){this.events.un(this.eventListeners);}
+this.events.destroy();}
+this.eventListeners=null;this.events=null;},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer(this.name,this.getOptions());}
+OpenLayers.Util.applyDefaults(obj,this);obj.map=null;return obj;},getOptions:function(){var options={};for(var o in this.options){options[o]=this[o];}
+return options;},setName:function(newName){if(newName!=this.name){this.name=newName;if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"name"});}}},addOptions:function(newOptions,reinitialize){if(this.options==null){this.options={};}
+OpenLayers.Util.extend(this.options,newOptions);OpenLayers.Util.extend(this,newOptions);if(typeof this.projection=="string"){this.projection=new OpenLayers.Projection(this.projection);}
+if(this.projection&&this.projection.getUnits()){this.units=this.projection.getUnits();}
+if(this.map){var resolution=this.map.getResolution();var properties=this.RESOLUTION_PROPERTIES.concat(["projection","units","minExtent","maxExtent"]);for(var o in newOptions){if(newOptions.hasOwnProperty(o)&&OpenLayers.Util.indexOf(properties,o)>=0){this.initResolutions();if(reinitialize&&this.map.baseLayer===this){this.map.setCenter(this.map.getCenter(),this.map.getZoomForResolution(resolution),false,true);this.map.events.triggerEvent("changebaselayer",{layer:this});}
+break;}}}},onMapResize:function(){},redraw:function(){var redrawn=false;if(this.map){this.inRange=this.calculateInRange();var extent=this.getExtent();if(extent&&this.inRange&&this.visibility){var zoomChanged=true;this.moveTo(extent,zoomChanged,false);this.events.triggerEvent("moveend",{"zoomChanged":zoomChanged});redrawn=true;}}
+return redrawn;},moveTo:function(bounds,zoomChanged,dragging){var display=this.visibility;if(!this.isBaseLayer){display=display&&this.inRange;}
+this.display(display);},moveByPx:function(dx,dy){},setMap:function(map){if(this.map==null){this.map=map;this.maxExtent=this.maxExtent||this.map.maxExtent;this.minExtent=this.minExtent||this.map.minExtent;this.projection=this.projection||this.map.projection;if(typeof this.projection=="string"){this.projection=new OpenLayers.Projection(this.projection);}
+this.units=this.projection.getUnits()||this.units||this.map.units;this.initResolutions();if(!this.isBaseLayer){this.inRange=this.calculateInRange();var show=((this.visibility)&&(this.inRange));this.div.style.display=show?"":"none";}
+this.setTileSize();}},afterAdd:function(){},removeMap:function(map){},getImageSize:function(bounds){return(this.imageSize||this.tileSize);},setTileSize:function(size){var tileSize=(size)?size:((this.tileSize)?this.tileSize:this.map.getTileSize());this.tileSize=tileSize;if(this.gutter){this.imageOffset=new OpenLayers.Pixel(-this.gutter,-this.gutter);this.imageSize=new OpenLayers.Size(tileSize.w+(2*this.gutter),tileSize.h+(2*this.gutter));}},getVisibility:function(){return this.visibility;},setVisibility:function(visibility){if(visibility!=this.visibility){this.visibility=visibility;this.display(visibility);this.redraw();if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"visibility"});}
+this.events.triggerEvent("visibilitychanged");}},display:function(display){if(display!=(this.div.style.display!="none")){this.div.style.display=(display&&this.calculateInRange())?"block":"none";}},calculateInRange:function(){var inRange=false;if(this.alwaysInRange){inRange=true;}else{if(this.map){var resolution=this.map.getResolution();inRange=((resolution>=this.minResolution)&&(resolution<=this.maxResolution));}}
+return inRange;},setIsBaseLayer:function(isBaseLayer){if(isBaseLayer!=this.isBaseLayer){this.isBaseLayer=isBaseLayer;if(this.map!=null){this.map.events.triggerEvent("changebaselayer",{layer:this});}}},initResolutions:function(){var i,len,p;var props={},alwaysInRange=true;for(i=0,len=this.RESOLUTION_PROPERTIES.length;i<len;i++){p=this.RESOLUTION_PROPERTIES[i];props[p]=this.options[p];if(alwaysInRange&&this.options[p]){alwaysInRange=false;}}
+if(this.alwaysInRange==null){this.alwaysInRange=alwaysInRange;}
+if(props.resolutions==null){props.resolutions=this.resolutionsFromScales(props.scales);}
+if(props.resolutions==null){props.resolutions=this.calculateResolutions(props);}
+if(props.resolutions==null){for(i=0,len=this.RESOLUTION_PROPERTIES.length;i<len;i++){p=this.RESOLUTION_PROPERTIES[i];props[p]=this.options[p]!=null?this.options[p]:this.map[p];}
+if(props.resolutions==null){props.resolutions=this.calculateResolutions(props);}}
+var maxResolution;if(this.options.maxResolution&&this.options.maxResolution!=="auto"){maxResolution=this.options.maxResolution;}
+if(this.options.minScale){maxResolution=OpenLayers.Util.getResolutionFromScale(this.options.minScale,this.units);}
+var minResolution;if(this.options.minResolution&&this.options.minResolution!=="auto"){minResolution=this.options.minResolution;}
+if(this.options.maxScale){minResolution=OpenLayers.Util.getResolutionFromScale(this.options.maxScale,this.units);}
+if(props.resolutions){props.resolutions.sort(function(a,b){return(b-a);});if(!maxResolution){maxResolution=props.resolutions[0];}
+if(!minResolution){var lastIdx=props.resolutions.length-1;minResolution=props.resolutions[lastIdx];}}
+this.resolutions=props.resolutions;if(this.resolutions){len=this.resolutions.length;this.scales=new Array(len);for(i=0;i<len;i++){this.scales[i]=OpenLayers.Util.getScaleFromResolution(this.resolutions[i],this.units);}
+this.numZoomLevels=len;}
+this.minResolution=minResolution;if(minResolution){this.maxScale=OpenLayers.Util.getScaleFromResolution(minResolution,this.units);}
+this.maxResolution=maxResolution;if(maxResolution){this.minScale=OpenLayers.Util.getScaleFromResolution(maxResolution,this.units);}},resolutionsFromScales:function(scales){if(scales==null){return;}
+var resolutions,i,len;len=scales.length;resolutions=new Array(len);for(i=0;i<len;i++){resolutions[i]=OpenLayers.Util.getResolutionFromScale(scales[i],this.units);}
+return resolutions;},calculateResolutions:function(props){var viewSize,wRes,hRes;var maxResolution=props.maxResolution;if(props.minScale!=null){maxResolution=OpenLayers.Util.getResolutionFromScale(props.minScale,this.units);}else if(maxResolution=="auto"&&this.maxExtent!=null){viewSize=this.map.getSize();wRes=this.maxExtent.getWidth()/viewSize.w;hRes=this.maxExtent.getHeight()/viewSize.h;maxResolution=Math.max(wRes,hRes);}
+var minResolution=props.minResolution;if(props.maxScale!=null){minResolution=OpenLayers.Util.getResolutionFromScale(props.maxScale,this.units);}else if(props.minResolution=="auto"&&this.minExtent!=null){viewSize=this.map.getSize();wRes=this.minExtent.getWidth()/viewSize.w;hRes=this.minExtent.getHeight()/viewSize.h;minResolution=Math.max(wRes,hRes);}
+var maxZoomLevel=props.maxZoomLevel;var numZoomLevels=props.numZoomLevels;if(typeof minResolution==="number"&&typeof maxResolution==="number"&&numZoomLevels===undefined){var ratio=maxResolution/minResolution;numZoomLevels=Math.floor(Math.log(ratio)/Math.log(2))+1;}else if(numZoomLevels===undefined&&maxZoomLevel!=null){numZoomLevels=maxZoomLevel+1;}
+if(typeof numZoomLevels!=="number"||numZoomLevels<=0||(typeof maxResolution!=="number"&&typeof minResolution!=="number")){return;}
+var resolutions=new Array(numZoomLevels);var base=2;if(typeof minResolution=="number"&&typeof maxResolution=="number"){base=Math.pow((maxResolution/minResolution),(1/(numZoomLevels-1)));}
+var i;if(typeof maxResolution==="number"){for(i=0;i<numZoomLevels;i++){resolutions[i]=maxResolution/Math.pow(base,i);}}else{for(i=0;i<numZoomLevels;i++){resolutions[numZoomLevels-1-i]=minResolution*Math.pow(base,i);}}
+return resolutions;},getResolution:function(){var zoom=this.map.getZoom();return this.getResolutionForZoom(zoom);},getExtent:function(){return this.map.calculateBounds();},getZoomForExtent:function(extent,closest){var viewSize=this.map.getSize();var idealResolution=Math.max(extent.getWidth()/viewSize.w,extent.getHeight()/viewSize.h);return this.getZoomForResolution(idealResolution,closest);},getDataExtent:function(){},getResolutionForZoom:function(zoom){zoom=Math.max(0,Math.min(zoom,this.resolutions.length-1));var resolution;if(this.map.fractionalZoom){var low=Math.floor(zoom);var high=Math.ceil(zoom);resolution=this.resolutions[low]-
+((zoom-low)*(this.resolutions[low]-this.resolutions[high]));}else{resolution=this.resolutions[Math.round(zoom)];}
+return resolution;},getZoomForResolution:function(resolution,closest){var zoom,i,len;if(this.map.fractionalZoom){var lowZoom=0;var highZoom=this.resolutions.length-1;var highRes=this.resolutions[lowZoom];var lowRes=this.resolutions[highZoom];var res;for(i=0,len=this.resolutions.length;i<len;++i){res=this.resolutions[i];if(res>=resolution){highRes=res;lowZoom=i;}
+if(res<=resolution){lowRes=res;highZoom=i;break;}}
+var dRes=highRes-lowRes;if(dRes>0){zoom=lowZoom+((highRes-resolution)/dRes);}else{zoom=lowZoom;}}else{var diff;var minDiff=Number.POSITIVE_INFINITY;for(i=0,len=this.resolutions.length;i<len;i++){if(closest){diff=Math.abs(this.resolutions[i]-resolution);if(diff>minDiff){break;}
+minDiff=diff;}else{if(this.resolutions[i]<resolution){break;}}}
+zoom=Math.max(0,i-1);}
+return zoom;},getLonLatFromViewPortPx:function(viewPortPx){var lonlat=null;var map=this.map;if(viewPortPx!=null&&map.minPx){var res=map.getResolution();var maxExtent=map.getMaxExtent({restricted:true});var lon=(viewPortPx.x-map.minPx.x)*res+maxExtent.left;var lat=(map.minPx.y-viewPortPx.y)*res+maxExtent.top;lonlat=new OpenLayers.LonLat(lon,lat);if(this.wrapDateLine){lonlat=lonlat.wrapDateLine(this.maxExtent);}}
+return lonlat;},getViewPortPxFromLonLat:function(lonlat){var px=null;if(lonlat!=null){var resolution=this.map.getResolution();var extent=this.map.getExtent();px=new OpenLayers.Pixel((1/resolution*(lonlat.lon-extent.left)),(1/resolution*(extent.top-lonlat.lat)));}
+return px;},setOpacity:function(opacity){if(opacity!=this.opacity){this.opacity=opacity;for(var i=0,len=this.div.childNodes.length;i<len;++i){var element=this.div.childNodes[i].firstChild;OpenLayers.Util.modifyDOMElement(element,null,null,null,null,null,null,opacity);}
+if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"opacity"});}}},getZIndex:function(){return this.div.style.zIndex;},setZIndex:function(zIndex){this.div.style.zIndex=zIndex;},adjustBounds:function(bounds){if(this.gutter){var mapGutter=this.gutter*this.map.getResolution();bounds=new OpenLayers.Bounds(bounds.left-mapGutter,bounds.bottom-mapGutter,bounds.right+mapGutter,bounds.top+mapGutter);}
+if(this.wrapDateLine){var wrappingOptions={'rightTolerance':this.getResolution(),'leftTolerance':this.getResolution()};bounds=bounds.wrapDateLine(this.maxExtent,wrappingOptions);}
+return bounds;},CLASS_NAME:"OpenLayers.Layer"});OpenLayers.Layer.HTTPRequest=OpenLayers.Class(OpenLayers.Layer,{URL_HASH_FACTOR:(Math.sqrt(5)-1)/2,url:null,params:null,reproject:false,initialize:function(name,url,params,options){OpenLayers.Layer.prototype.initialize.apply(this,[name,options]);this.url=url;this.params=OpenLayers.Util.extend({},params);},destroy:function(){this.url=null;this.params=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.HTTPRequest(this.name,this.url,this.params,this.getOptions());}
+obj=OpenLayers.Layer.prototype.clone.apply(this,[obj]);return obj;},setUrl:function(newUrl){this.url=newUrl;},mergeNewParams:function(newParams){this.params=OpenLayers.Util.extend(this.params,newParams);var ret=this.redraw();if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"params"});}
+return ret;},redraw:function(force){if(force){return this.mergeNewParams({"_olSalt":Math.random()});}else{return OpenLayers.Layer.prototype.redraw.apply(this,[]);}},selectUrl:function(paramString,urls){var product=1;for(var i=0,len=paramString.length;i<len;i++){product*=paramString.charCodeAt(i)*this.URL_HASH_FACTOR;product-=Math.floor(product);}
+return urls[Math.floor(product*urls.length)];},getFullRequestString:function(newParams,altUrl){var url=altUrl||this.url;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var paramsString=OpenLayers.Util.getParameterString(allParams);if(OpenLayers.Util.isArray(url)){url=this.selectUrl(paramsString,url);}
+var urlParams=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(url));for(var key in allParams){if(key.toUpperCase()in urlParams){delete allParams[key];}}
+paramsString=OpenLayers.Util.getParameterString(allParams);return OpenLayers.Util.urlAppend(url,paramsString);},CLASS_NAME:"OpenLayers.Layer.HTTPRequest"});OpenLayers.Layer.Grid=OpenLayers.Class(OpenLayers.Layer.HTTPRequest,{tileSize:null,tileOriginCorner:"bl",tileOrigin:null,tileOptions:null,grid:null,singleTile:false,ratio:1.5,buffer:0,numLoadingTiles:0,tileLoadingDelay:100,timerId:null,initialize:function(name,url,params,options){OpenLayers.Layer.HTTPRequest.prototype.initialize.apply(this,arguments);this.events.addEventType("tileloaded");this.grid=[];this._moveGriddedTiles=OpenLayers.Function.bind(this.moveGriddedTiles,this);},removeMap:function(map){if(this.timerId!=null){window.clearTimeout(this.timerId);this.timerId=null;}},destroy:function(){this.clearGrid();this.grid=null;this.tileSize=null;OpenLayers.Layer.HTTPRequest.prototype.destroy.apply(this,arguments);},clearGrid:function(){if(this.grid){for(var iRow=0,len=this.grid.length;iRow<len;iRow++){var row=this.grid[i
 Row];for(var iCol=0,clen=row.length;iCol<clen;iCol++){var tile=row[iCol];this.removeTileMonitoringHooks(tile);tile.destroy();}}
+this.grid=[];}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Grid(this.name,this.url,this.params,this.getOptions());}
+obj=OpenLayers.Layer.HTTPRequest.prototype.clone.apply(this,[obj]);if(this.tileSize!=null){obj.tileSize=this.tileSize.clone();}
+obj.grid=[];return obj;},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.HTTPRequest.prototype.moveTo.apply(this,arguments);bounds=bounds||this.map.getExtent();if(bounds!=null){var forceReTile=!this.grid.length||zoomChanged;var tilesBounds=this.getTilesBounds();if(this.singleTile){if(forceReTile||(!dragging&&!tilesBounds.containsBounds(bounds))){this.initSingleTile(bounds);}}else{if(forceReTile||!tilesBounds.containsBounds(bounds,true)){this.initGriddedTiles(bounds);}else{this.scheduleMoveGriddedTiles();}}}},moveByPx:function(dx,dy){if(!this.singleTile){this.scheduleMoveGriddedTiles();}},scheduleMoveGriddedTiles:function(){if(this.timerId!=null){window.clearTimeout(this.timerId);}
+this.timerId=window.setTimeout(this._moveGriddedTiles,this.tileLoadingDelay);},setTileSize:function(size){if(this.singleTile){size=this.map.getSize();size.h=parseInt(size.h*this.ratio);size.w=parseInt(size.w*this.ratio);}
+OpenLayers.Layer.HTTPRequest.prototype.setTileSize.apply(this,[size]);},getGridBounds:function(){var msg="The getGridBounds() function is deprecated. It will be "+"removed in 3.0. Please use getTilesBounds() instead.";OpenLayers.Console.warn(msg);return this.getTilesBounds();},getTilesBounds:function(){var bounds=null;if(this.grid.length){var bottom=this.grid.length-1;var bottomLeftTile=this.grid[bottom][0];var right=this.grid[0].length-1;var topRightTile=this.grid[0][right];bounds=new OpenLayers.Bounds(bottomLeftTile.bounds.left,bottomLeftTile.bounds.bottom,topRightTile.bounds.right,topRightTile.bounds.top);}
+return bounds;},initSingleTile:function(bounds){var center=bounds.getCenterLonLat();var tileWidth=bounds.getWidth()*this.ratio;var tileHeight=bounds.getHeight()*this.ratio;var tileBounds=new OpenLayers.Bounds(center.lon-(tileWidth/2),center.lat-(tileHeight/2),center.lon+(tileWidth/2),center.lat+(tileHeight/2));var ul=new OpenLayers.LonLat(tileBounds.left,tileBounds.top);var px=this.map.getLayerPxFromLonLat(ul);if(!this.grid.length){this.grid[0]=[];}
+var tile=this.grid[0][0];if(!tile){tile=this.addTile(tileBounds,px);this.addTileMonitoringHooks(tile);tile.draw();this.grid[0][0]=tile;}else{tile.moveTo(tileBounds,px);}
+this.removeExcessTiles(1,1);},calculateGridLayout:function(bounds,origin,resolution){var tilelon=resolution*this.tileSize.w;var tilelat=resolution*this.tileSize.h;var offsetlon=bounds.left-origin.lon;var tilecol=Math.floor(offsetlon/tilelon)-this.buffer;var tilecolremain=offsetlon/tilelon-tilecol;var tileoffsetx=-tilecolremain*this.tileSize.w;var tileoffsetlon=origin.lon+tilecol*tilelon;var offsetlat=bounds.top-(origin.lat+tilelat);var tilerow=Math.ceil(offsetlat/tilelat)+this.buffer;var tilerowremain=tilerow-offsetlat/tilelat;var tileoffsety=-tilerowremain*this.tileSize.h;var tileoffsetlat=origin.lat+tilerow*tilelat;return{tilelon:tilelon,tilelat:tilelat,tileoffsetlon:tileoffsetlon,tileoffsetlat:tileoffsetlat,tileoffsetx:tileoffsetx,tileoffsety:tileoffsety};},getTileOrigin:function(){var origin=this.tileOrigin;if(!origin){var extent=this.getMaxExtent();var edges=({"tl":["left","top"],"tr":["right","top"],"bl":["left","bottom"],"br":["right","bottom"]})[this.tileOriginCorner
 ];origin=new OpenLayers.LonLat(extent[edges[0]],extent[edges[1]]);}
+return origin;},initGriddedTiles:function(bounds){var viewSize=this.map.getSize();var minRows=Math.ceil(viewSize.h/this.tileSize.h)+
+Math.max(1,2*this.buffer);var minCols=Math.ceil(viewSize.w/this.tileSize.w)+
+Math.max(1,2*this.buffer);var origin=this.getTileOrigin();var resolution=this.map.getResolution();var tileLayout=this.calculateGridLayout(bounds,origin,resolution);var tileoffsetx=Math.round(tileLayout.tileoffsetx);var tileoffsety=Math.round(tileLayout.tileoffsety);var tileoffsetlon=tileLayout.tileoffsetlon;var tileoffsetlat=tileLayout.tileoffsetlat;var tilelon=tileLayout.tilelon;var tilelat=tileLayout.tilelat;this.origin=new OpenLayers.Pixel(tileoffsetx,tileoffsety);var startX=tileoffsetx;var startLon=tileoffsetlon;var rowidx=0;var layerContainerDivLeft=parseInt(this.map.layerContainerDiv.style.left);var layerContainerDivTop=parseInt(this.map.layerContainerDiv.style.top);do{var row=this.grid[rowidx++];if(!row){row=[];this.grid.push(row);}
+tileoffsetlon=startLon;tileoffsetx=startX;var colidx=0;do{var tileBounds=new OpenLayers.Bounds(tileoffsetlon,tileoffsetlat,tileoffsetlon+tilelon,tileoffsetlat+tilelat);var x=tileoffsetx;x-=layerContainerDivLeft;var y=tileoffsety;y-=layerContainerDivTop;var px=new OpenLayers.Pixel(x,y);var tile=row[colidx++];if(!tile){tile=this.addTile(tileBounds,px);this.addTileMonitoringHooks(tile);row.push(tile);}else{tile.moveTo(tileBounds,px,false);}
+tileoffsetlon+=tilelon;tileoffsetx+=this.tileSize.w;}while((tileoffsetlon<=bounds.right+tilelon*this.buffer)||colidx<minCols);tileoffsetlat-=tilelat;tileoffsety+=this.tileSize.h;}while((tileoffsetlat>=bounds.bottom-tilelat*this.buffer)||rowidx<minRows);this.removeExcessTiles(rowidx,colidx);this.spiralTileLoad();},getMaxExtent:function(){return this.maxExtent;},spiralTileLoad:function(){var tileQueue=[];var directions=["right","down","left","up"];var iRow=0;var iCell=-1;var direction=OpenLayers.Util.indexOf(directions,"right");var directionsTried=0;while(directionsTried<directions.length){var testRow=iRow;var testCell=iCell;switch(directions[direction]){case"right":testCell++;break;case"down":testRow++;break;case"left":testCell--;break;case"up":testRow--;break;}
+var tile=null;if((testRow<this.grid.length)&&(testRow>=0)&&(testCell<this.grid[0].length)&&(testCell>=0)){tile=this.grid[testRow][testCell];}
+if((tile!=null)&&(!tile.queued)){tileQueue.unshift(tile);tile.queued=true;directionsTried=0;iRow=testRow;iCell=testCell;}else{direction=(direction+1)%4;directionsTried++;}}
+for(var i=0,len=tileQueue.length;i<len;i++){var tile=tileQueue[i];tile.draw();tile.queued=false;}},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize,this.tileOptions);},addTileMonitoringHooks:function(tile){tile.onLoadStart=function(){if(this.numLoadingTiles==0){this.events.triggerEvent("loadstart");}
+this.numLoadingTiles++;};tile.events.register("loadstart",this,tile.onLoadStart);tile.onLoadEnd=function(){this.numLoadingTiles--;this.events.triggerEvent("tileloaded");if(this.numLoadingTiles==0){this.events.triggerEvent("loadend");}};tile.events.register("loadend",this,tile.onLoadEnd);tile.events.register("unload",this,tile.onLoadEnd);},removeTileMonitoringHooks:function(tile){tile.unload();tile.events.un({"loadstart":tile.onLoadStart,"loadend":tile.onLoadEnd,"unload":tile.onLoadEnd,scope:this});},moveGriddedTiles:function(){var shifted=true;var buffer=this.buffer||1;var tlLayer=this.grid[0][0].position;var offsetX=parseInt(this.map.layerContainerDiv.style.left);var offsetY=parseInt(this.map.layerContainerDiv.style.top);var tlViewPort=tlLayer.add(offsetX,offsetY);if(tlViewPort.x>-this.tileSize.w*(buffer-1)){this.shiftColumn(true);}else if(tlViewPort.x<-this.tileSize.w*buffer){this.shiftColumn(false);}else if(tlViewPort.y>-this.tileSize.h*(buffer-1)){this.shiftRow(true);}el
 se if(tlViewPort.y<-this.tileSize.h*buffer){this.shiftRow(false);}else{shifted=false;}
+if(shifted){this.timerId=window.setTimeout(this._moveGriddedTiles,0);}},shiftRow:function(prepend){var modelRowIndex=(prepend)?0:(this.grid.length-1);var grid=this.grid;var modelRow=grid[modelRowIndex];var resolution=this.map.getResolution();var deltaY=(prepend)?-this.tileSize.h:this.tileSize.h;var deltaLat=resolution*-deltaY;var row=(prepend)?grid.pop():grid.shift();for(var i=0,len=modelRow.length;i<len;i++){var modelTile=modelRow[i];var bounds=modelTile.bounds.clone();var position=modelTile.position.clone();bounds.bottom=bounds.bottom+deltaLat;bounds.top=bounds.top+deltaLat;position.y=position.y+deltaY;row[i].moveTo(bounds,position);}
+if(prepend){grid.unshift(row);}else{grid.push(row);}},shiftColumn:function(prepend){var deltaX=(prepend)?-this.tileSize.w:this.tileSize.w;var resolution=this.map.getResolution();var deltaLon=resolution*deltaX;for(var i=0,len=this.grid.length;i<len;i++){var row=this.grid[i];var modelTileIndex=(prepend)?0:(row.length-1);var modelTile=row[modelTileIndex];var bounds=modelTile.bounds.clone();var position=modelTile.position.clone();bounds.left=bounds.left+deltaLon;bounds.right=bounds.right+deltaLon;position.x=position.x+deltaX;var tile=prepend?this.grid[i].pop():this.grid[i].shift();tile.moveTo(bounds,position);if(prepend){row.unshift(tile);}else{row.push(tile);}}},removeExcessTiles:function(rows,columns){while(this.grid.length>rows){var row=this.grid.pop();for(var i=0,l=row.length;i<l;i++){var tile=row[i];this.removeTileMonitoringHooks(tile);tile.destroy();}}
+while(this.grid[0].length>columns){for(var i=0,l=this.grid.length;i<l;i++){var row=this.grid[i];var tile=row.pop();this.removeTileMonitoringHooks(tile);tile.destroy();}}},onMapResize:function(){if(this.singleTile){this.clearGrid();this.setTileSize();}},getTileBounds:function(viewPortPx){var maxExtent=this.maxExtent;var resolution=this.getResolution();var tileMapWidth=resolution*this.tileSize.w;var tileMapHeight=resolution*this.tileSize.h;var mapPoint=this.getLonLatFromViewPortPx(viewPortPx);var tileLeft=maxExtent.left+(tileMapWidth*Math.floor((mapPoint.lon-
+maxExtent.left)/tileMapWidth));var tileBottom=maxExtent.bottom+(tileMapHeight*Math.floor((mapPoint.lat-
+maxExtent.bottom)/tileMapHeight));return new OpenLayers.Bounds(tileLeft,tileBottom,tileLeft+tileMapWidth,tileBottom+tileMapHeight);},CLASS_NAME:"OpenLayers.Layer.Grid"});OpenLayers.Protocol=OpenLayers.Class({format:null,options:null,autoDestroy:true,defaultFilter:null,initialize:function(options){options=options||{};OpenLayers.Util.extend(this,options);this.options=options;},mergeWithDefaultFilter:function(filter){var merged;if(filter&&this.defaultFilter){merged=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.AND,filters:[this.defaultFilter,filter]});}else{merged=filter||this.defaultFilter||undefined;}
+return merged;},destroy:function(){this.options=null;this.format=null;},read:function(options){options=options||{};options.filter=this.mergeWithDefaultFilter(options.filter);},create:function(){},update:function(){},"delete":function(){},commit:function(){},abort:function(response){},createCallback:function(method,response,options){return OpenLayers.Function.bind(function(){method.apply(this,[response,options]);},this);},CLASS_NAME:"OpenLayers.Protocol"});OpenLayers.Protocol.Response=OpenLayers.Class({code:null,requestType:null,last:true,features:null,reqFeatures:null,priv:null,error:null,initialize:function(options){OpenLayers.Util.extend(this,options);},success:function(){return this.code>0;},CLASS_NAME:"OpenLayers.Protocol.Response"});OpenLayers.Protocol.Response.SUCCESS=1;OpenLayers.Protocol.Response.FAILURE=0;OpenLayers.Control=OpenLayers.Class({id:null,map:null,div:null,type:null,allowSelection:false,displayClass:"",title:"",autoActivate:false,active:null,handler:null,
 eventListeners:null,events:null,EVENT_TYPES:["activate","deactivate"],initialize:function(options){this.displayClass=this.CLASS_NAME.replace("OpenLayers.","ol").replace(/\./g,"");OpenLayers.Util.extend(this,options);this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}
+if(this.id==null){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");}},destroy:function(){if(this.events){if(this.eventListeners){this.events.un(this.eventListeners);}
+this.eventListeners=null;if(this.handler){this.handler.destroy();this.handler=null;}
+if(this.handlers){for(var key in this.handlers){if(this.handlers.hasOwnProperty(key)&&typeof this.handlers[key].destroy=="function"){this.handlers[key].destroy();}}
+this.handlers=null;}
+if(this.map){this.map.removeControl(this);this.map=null;}
+this.div=null;},setMap:function(map){this.map=map;if(this.handler){this.handler.setMap(map);}},draw:function(px){if(this.div==null){this.div=OpenLayers.Util.createDiv(this.id);this.div.className=this.displayClass;if(!this.allowSelection){this.div.className+=" olControlNoSelect";this.div.setAttribute("unselectable","on",0);this.div.onselectstart=OpenLayers.Function.False;}
+if(this.title!=""){this.div.title=this.title;}}
+if(px!=null){this.position=px.clone();}
+this.moveTo(this.position);return this.div;},moveTo:function(px){if((px!=null)&&(this.div!=null)){this.div.style.left=px.x+"px";this.div.style.top=px.y+"px";}},activate:function(){if(this.active){return false;}
+if(this.handler){this.handler.activate();}
+this.active=true;if(this.map){OpenLayers.Element.addClass(this.map.viewPortDiv,this.displayClass.replace(/ /g,"")+"Active");}
+this.events.triggerEvent("activate");return true;},deactivate:function(){if(this.active){if(this.handler){this.handler.deactivate();}
+this.active=false;if(this.map){OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass.replace(/ /g,"")+"Active");}
+this.events.triggerEvent("deactivate");return true;}
+return false;},CLASS_NAME:"OpenLayers.Control"});OpenLayers.Control.TYPE_BUTTON=1;OpenLayers.Control.TYPE_TOGGLE=2;OpenLayers.Control.TYPE_TOOL=3;OpenLayers.Control.Attribution=OpenLayers.Class(OpenLayers.Control,{separator:", ",destroy:function(){this.map.events.un({"removelayer":this.updateAttribution,"addlayer":this.updateAttribution,"changelayer":this.updateAttribution,"changebaselayer":this.updateAttribution,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.map.events.on({'changebaselayer':this.updateAttribution,'changelayer':this.updateAttribution,'addlayer':this.updateAttribution,'removelayer':this.updateAttribution,scope:this});this.updateAttribution();return this.div;},updateAttribution:function(){var attributions=[];if(this.map&&this.map.layers){for(var i=0,len=this.map.layers.length;i<len;i++){var layer=this.map.layers[i];if(layer.attribution&&layer.getVisibility()
 ){if(OpenLayers.Util.indexOf(attributions,layer.attribution)===-1){attributions.push(layer.attribution);}}}
+this.div.innerHTML=attributions.join(this.separator);}},CLASS_NAME:"OpenLayers.Control.Attribution"});OpenLayers.Format.JSON=OpenLayers.Class(OpenLayers.Format,{indent:"    ",space:" ",newline:"\n",level:0,pretty:false,nativeJSON:(function(){return!!(window.JSON&&typeof JSON.parse=="function"&&typeof JSON.stringify=="function");})(),read:function(json,filter){var object;if(this.nativeJSON){object=JSON.parse(json,filter);}else try{if(/^[\],:{}\s]*$/.test(json.replace(/\\["\\\/bfnrtu]/g,'@').replace(/"[^"\\\n\r]*"|true|false|null|-?\d+(?:\.\d*)?(?:[eE][+\-]?\d+)?/g,']').replace(/(?:^|:|,)(?:\s*\[)+/g,''))){object=eval('('+json+')');if(typeof filter==='function'){function walk(k,v){if(v&&typeof v==='object'){for(var i in v){if(v.hasOwnProperty(i)){v[i]=walk(i,v[i]);}}}
+return filter(k,v);}
+object=walk('',object);}}}catch(e){}
+if(this.keepData){this.data=object;}
+return object;},write:function(value,pretty){this.pretty=!!pretty;var json=null;var type=typeof value;if(this.serialize[type]){try{json=(!this.pretty&&this.nativeJSON)?JSON.stringify(value):this.serialize[type].apply(this,[value]);}catch(err){OpenLayers.Console.error("Trouble serializing: "+err);}}
+return json;},writeIndent:function(){var pieces=[];if(this.pretty){for(var i=0;i<this.level;++i){pieces.push(this.indent);}}
+return pieces.join('');},writeNewline:function(){return(this.pretty)?this.newline:'';},writeSpace:function(){return(this.pretty)?this.space:'';},serialize:{'object':function(object){if(object==null){return"null";}
+if(object.constructor==Date){return this.serialize.date.apply(this,[object]);}
+if(object.constructor==Array){return this.serialize.array.apply(this,[object]);}
+var pieces=['{'];this.level+=1;var key,keyJSON,valueJSON;var addComma=false;for(key in object){if(object.hasOwnProperty(key)){keyJSON=OpenLayers.Format.JSON.prototype.write.apply(this,[key,this.pretty]);valueJSON=OpenLayers.Format.JSON.prototype.write.apply(this,[object[key],this.pretty]);if(keyJSON!=null&&valueJSON!=null){if(addComma){pieces.push(',');}
+pieces.push(this.writeNewline(),this.writeIndent(),keyJSON,':',this.writeSpace(),valueJSON);addComma=true;}}}
+this.level-=1;pieces.push(this.writeNewline(),this.writeIndent(),'}');return pieces.join('');},'array':function(array){var json;var pieces=['['];this.level+=1;for(var i=0,len=array.length;i<len;++i){json=OpenLayers.Format.JSON.prototype.write.apply(this,[array[i],this.pretty]);if(json!=null){if(i>0){pieces.push(',');}
+pieces.push(this.writeNewline(),this.writeIndent(),json);}}
+this.level-=1;pieces.push(this.writeNewline(),this.writeIndent(),']');return pieces.join('');},'string':function(string){var m={'\b':'\\b','\t':'\\t','\n':'\\n','\f':'\\f','\r':'\\r','"':'\\"','\\':'\\\\'};if(/["\\\x00-\x1f]/.test(string)){return'"'+string.replace(/([\x00-\x1f\\"])/g,function(a,b){var c=m[b];if(c){return c;}
+c=b.charCodeAt();return'\\u00'+
+Math.floor(c/16).toString(16)+
+(c%16).toString(16);})+'"';}
+return'"'+string+'"';},'number':function(number){return isFinite(number)?String(number):"null";},'boolean':function(bool){return String(bool);},'date':function(date){function format(number){return(number<10)?'0'+number:number;}
+return'"'+date.getFullYear()+'-'+
+format(date.getMonth()+1)+'-'+
+format(date.getDate())+'T'+
+format(date.getHours())+':'+
+format(date.getMinutes())+':'+
+format(date.getSeconds())+'"';}},CLASS_NAME:"OpenLayers.Format.JSON"});OpenLayers.Format.XML=OpenLayers.Class(OpenLayers.Format,{namespaces:null,namespaceAlias:null,defaultPrefix:null,readers:{},writers:{},xmldom:null,initialize:function(options){if(window.ActiveXObject){this.xmldom=new ActiveXObject("Microsoft.XMLDOM");}
+OpenLayers.Format.prototype.initialize.apply(this,[options]);this.namespaces=OpenLayers.Util.extend({},this.namespaces);this.namespaceAlias={};for(var alias in this.namespaces){this.namespaceAlias[this.namespaces[alias]]=alias;}},destroy:function(){this.xmldom=null;OpenLayers.Format.prototype.destroy.apply(this,arguments);},setNamespace:function(alias,uri){this.namespaces[alias]=uri;this.namespaceAlias[uri]=alias;},read:function(text){var index=text.indexOf('<');if(index>0){text=text.substring(index);}
+var node=OpenLayers.Util.Try(OpenLayers.Function.bind((function(){var xmldom;if(window.ActiveXObject&&!this.xmldom){xmldom=new ActiveXObject("Microsoft.XMLDOM");}else{xmldom=this.xmldom;}
+xmldom.loadXML(text);return xmldom;}),this),function(){return new DOMParser().parseFromString(text,'text/xml');},function(){var req=new XMLHttpRequest();req.open("GET","data:"+"text/xml"+";charset=utf-8,"+encodeURIComponent(text),false);if(req.overrideMimeType){req.overrideMimeType("text/xml");}
+req.send(null);return req.responseXML;});if(this.keepData){this.data=node;}
+return node;},write:function(node){var data;if(this.xmldom){data=node.xml;}else{var serializer=new XMLSerializer();if(node.nodeType==1){var doc=document.implementation.createDocument("","",null);if(doc.importNode){node=doc.importNode(node,true);}
+doc.appendChild(node);data=serializer.serializeToString(doc);}else{data=serializer.serializeToString(node);}}
+return data;},createElementNS:function(uri,name){var element;if(this.xmldom){if(typeof uri=="string"){element=this.xmldom.createNode(1,name,uri);}else{element=this.xmldom.createNode(1,name,"");}}else{element=document.createElementNS(uri,name);}
+return element;},createTextNode:function(text){var node;if(typeof text!=="string"){text=String(text);}
+if(this.xmldom){node=this.xmldom.createTextNode(text);}else{node=document.createTextNode(text);}
+return node;},getElementsByTagNameNS:function(node,uri,name){var elements=[];if(node.getElementsByTagNameNS){elements=node.getElementsByTagNameNS(uri,name);}else{var allNodes=node.getElementsByTagName("*");var potentialNode,fullName;for(var i=0,len=allNodes.length;i<len;++i){potentialNode=allNodes[i];fullName=(potentialNode.prefix)?(potentialNode.prefix+":"+name):name;if((name=="*")||(fullName==potentialNode.nodeName)){if((uri=="*")||(uri==potentialNode.namespaceURI)){elements.push(potentialNode);}}}}
+return elements;},getAttributeNodeNS:function(node,uri,name){var attributeNode=null;if(node.getAttributeNodeNS){attributeNode=node.getAttributeNodeNS(uri,name);}else{var attributes=node.attributes;var potentialNode,fullName;for(var i=0,len=attributes.length;i<len;++i){potentialNode=attributes[i];if(potentialNode.namespaceURI==uri){fullName=(potentialNode.prefix)?(potentialNode.prefix+":"+name):name;if(fullName==potentialNode.nodeName){attributeNode=potentialNode;break;}}}}
+return attributeNode;},getAttributeNS:function(node,uri,name){var attributeValue="";if(node.getAttributeNS){attributeValue=node.getAttributeNS(uri,name)||"";}else{var attributeNode=this.getAttributeNodeNS(node,uri,name);if(attributeNode){attributeValue=attributeNode.nodeValue;}}
+return attributeValue;},getChildValue:function(node,def){var value=def||"";if(node){for(var child=node.firstChild;child;child=child.nextSibling){switch(child.nodeType){case 3:case 4:value+=child.nodeValue;}}}
+return value;},concatChildValues:function(node,def){var value="";var child=node.firstChild;var childValue;while(child){childValue=child.nodeValue;if(childValue){value+=childValue;}
+child=child.nextSibling;}
+if(value==""&&def!=undefined){value=def;}
+return value;},isSimpleContent:function(node){var simple=true;for(var child=node.firstChild;child;child=child.nextSibling){if(child.nodeType===1){simple=false;break;}}
+return simple;},contentType:function(node){var simple=false,complex=false;var type=OpenLayers.Format.XML.CONTENT_TYPE.EMPTY;for(var child=node.firstChild;child;child=child.nextSibling){switch(child.nodeType){case 1:complex=true;break;case 8:break;default:simple=true;}
+if(complex&&simple){break;}}
+if(complex&&simple){type=OpenLayers.Format.XML.CONTENT_TYPE.MIXED;}else if(complex){return OpenLayers.Format.XML.CONTENT_TYPE.COMPLEX;}else if(simple){return OpenLayers.Format.XML.CONTENT_TYPE.SIMPLE;}
+return type;},hasAttributeNS:function(node,uri,name){var found=false;if(node.hasAttributeNS){found=node.hasAttributeNS(uri,name);}else{found=!!this.getAttributeNodeNS(node,uri,name);}
+return found;},setAttributeNS:function(node,uri,name,value){if(node.setAttributeNS){node.setAttributeNS(uri,name,value);}else{if(this.xmldom){if(uri){var attribute=node.ownerDocument.createNode(2,name,uri);attribute.nodeValue=value;node.setAttributeNode(attribute);}else{node.setAttribute(name,value);}}else{throw"setAttributeNS not implemented";}}},createElementNSPlus:function(name,options){options=options||{};var uri=options.uri||this.namespaces[options.prefix];if(!uri){var loc=name.indexOf(":");uri=this.namespaces[name.substring(0,loc)];}
+if(!uri){uri=this.namespaces[this.defaultPrefix];}
+var node=this.createElementNS(uri,name);if(options.attributes){this.setAttributes(node,options.attributes);}
+var value=options.value;if(value!=null){node.appendChild(this.createTextNode(value));}
+return node;},setAttributes:function(node,obj){var value,uri;for(var name in obj){if(obj[name]!=null&&obj[name].toString){value=obj[name].toString();uri=this.namespaces[name.substring(0,name.indexOf(":"))]||null;this.setAttributeNS(node,uri,name,value);}}},readNode:function(node,obj){if(!obj){obj={};}
+var group=this.readers[node.namespaceURI?this.namespaceAlias[node.namespaceURI]:this.defaultPrefix];if(group){var local=node.localName||node.nodeName.split(":").pop();var reader=group[local]||group["*"];if(reader){reader.apply(this,[node,obj]);}}
+return obj;},readChildNodes:function(node,obj){if(!obj){obj={};}
+var children=node.childNodes;var child;for(var i=0,len=children.length;i<len;++i){child=children[i];if(child.nodeType==1){this.readNode(child,obj);}}
+return obj;},writeNode:function(name,obj,parent){var prefix,local;var split=name.indexOf(":");if(split>0){prefix=name.substring(0,split);local=name.substring(split+1);}else{if(parent){prefix=this.namespaceAlias[parent.namespaceURI];}else{prefix=this.defaultPrefix;}
+local=name;}
+var child=this.writers[prefix][local].apply(this,[obj]);if(parent){parent.appendChild(child);}
+return child;},getChildEl:function(node,name,uri){return node&&this.getThisOrNextEl(node.firstChild,name,uri);},getNextEl:function(node,name,uri){return node&&this.getThisOrNextEl(node.nextSibling,name,uri);},getThisOrNextEl:function(node,name,uri){outer:for(var sibling=node;sibling;sibling=sibling.nextSibling){switch(sibling.nodeType){case 1:if((!name||name===(sibling.localName||sibling.nodeName.split(":").pop()))&&(!uri||uri===sibling.namespaceURI)){break outer;}
+sibling=null;break outer;case 3:if(/^\s*$/.test(sibling.nodeValue)){break;}
+case 4:case 6:case 12:case 10:case 11:sibling=null;break outer;}}
+return sibling||null;},lookupNamespaceURI:function(node,prefix){var uri=null;if(node){if(node.lookupNamespaceURI){uri=node.lookupNamespaceURI(prefix);}else{outer:switch(node.nodeType){case 1:if(node.namespaceURI!==null&&node.prefix===prefix){uri=node.namespaceURI;break outer;}
+var len=node.attributes.length;if(len){var attr;for(var i=0;i<len;++i){attr=node.attributes[i];if(attr.prefix==="xmlns"&&attr.name==="xmlns:"+prefix){uri=attr.value||null;break outer;}else if(attr.name==="xmlns"&&prefix===null){uri=attr.value||null;break outer;}}}
+uri=this.lookupNamespaceURI(node.parentNode,prefix);break outer;case 2:uri=this.lookupNamespaceURI(node.ownerElement,prefix);break outer;case 9:uri=this.lookupNamespaceURI(node.documentElement,prefix);break outer;case 6:case 12:case 10:case 11:break outer;default:uri=this.lookupNamespaceURI(node.parentNode,prefix);break outer;}}}
+return uri;},getXMLDoc:function(){if(!OpenLayers.Format.XML.document&&!this.xmldom){if(document.implementation&&document.implementation.createDocument){OpenLayers.Format.XML.document=document.implementation.createDocument("","",null);}else if(!this.xmldom&&window.ActiveXObject){this.xmldom=new ActiveXObject("Microsoft.XMLDOM");}}
+return OpenLayers.Format.XML.document||this.xmldom;},CLASS_NAME:"OpenLayers.Format.XML"});OpenLayers.Format.XML.CONTENT_TYPE={EMPTY:0,SIMPLE:1,COMPLEX:2,MIXED:3};OpenLayers.Format.XML.lookupNamespaceURI=OpenLayers.Function.bind(OpenLayers.Format.XML.prototype.lookupNamespaceURI,OpenLayers.Format.XML.prototype);OpenLayers.Format.XML.document=null;OpenLayers.Handler=OpenLayers.Class({id:null,control:null,map:null,keyMask:null,active:false,evt:null,initialize:function(control,callbacks,options){OpenLayers.Util.extend(this,options);this.control=control;this.callbacks=callbacks;var map=this.map||control.map;if(map){this.setMap(map);}
+this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},setMap:function(map){this.map=map;},checkModifiers:function(evt){if(this.keyMask==null){return true;}
+var keyModifiers=(evt.shiftKey?OpenLayers.Handler.MOD_SHIFT:0)|(evt.ctrlKey?OpenLayers.Handler.MOD_CTRL:0)|(evt.altKey?OpenLayers.Handler.MOD_ALT:0);return(keyModifiers==this.keyMask);},activate:function(){if(this.active){return false;}
+var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0,len=events.length;i<len;i++){if(this[events[i]]){this.register(events[i],this[events[i]]);}}
+this.active=true;return true;},deactivate:function(){if(!this.active){return false;}
+var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0,len=events.length;i<len;i++){if(this[events[i]]){this.unregister(events[i],this[events[i]]);}}
+this.active=false;return true;},callback:function(name,args){if(name&&this.callbacks[name]){this.callbacks[name].apply(this.control,args);}},register:function(name,method){this.map.events.registerPriority(name,this,method);this.map.events.registerPriority(name,this,this.setEvent);},unregister:function(name,method){this.map.events.unregister(name,this,method);this.map.events.unregister(name,this,this.setEvent);},setEvent:function(evt){this.evt=evt;return true;},destroy:function(){this.deactivate();this.control=this.map=null;},CLASS_NAME:"OpenLayers.Handler"});OpenLayers.Handler.MOD_NONE=0;OpenLayers.Handler.MOD_SHIFT=1;OpenLayers.Handler.MOD_CTRL=2;OpenLayers.Handler.MOD_ALT=4;OpenLayers.Handler.Click=OpenLayers.Class(OpenLayers.Handler,{delay:300,single:true,'double':false,pixelTolerance:0,dblclickTolerance:13,stopSingle:false,stopDouble:false,timerId:null,touch:false,down:null,last:null,first:null,rightclickTimerId:null,initialize:function(control,callbacks,options){OpenLay
 ers.Handler.prototype.initialize.apply(this,arguments);},touchstart:function(evt){if(!this.touch){this.unregisterMouseListeners();this.touch=true;}
+this.down=this.getEventInfo(evt);this.last=this.getEventInfo(evt);return true;},touchmove:function(evt){this.last=this.getEventInfo(evt);return true;},touchend:function(evt){if(this.down){evt.xy=this.last.xy;evt.lastTouches=this.last.touches;this.handleSingle(evt);this.down=null;}
+return true;},unregisterMouseListeners:function(){this.map.events.un({mousedown:this.mousedown,mouseup:this.mouseup,click:this.click,dblclick:this.dblclick,scope:this});},mousedown:function(evt){this.down=this.getEventInfo(evt);this.last=this.getEventInfo(evt);return true;},mouseup:function(evt){var propagate=true;if(this.checkModifiers(evt)&&this.control.handleRightClicks&&OpenLayers.Event.isRightClick(evt)){propagate=this.rightclick(evt);}
+return propagate;},rightclick:function(evt){if(this.passesTolerance(evt)){if(this.rightclickTimerId!=null){this.clearTimer();this.callback('dblrightclick',[evt]);return!this.stopDouble;}else{var clickEvent=this['double']?OpenLayers.Util.extend({},evt):this.callback('rightclick',[evt]);var delayedRightCall=OpenLayers.Function.bind(this.delayedRightCall,this,clickEvent);this.rightclickTimerId=window.setTimeout(delayedRightCall,this.delay);}}
+return!this.stopSingle;},delayedRightCall:function(evt){this.rightclickTimerId=null;if(evt){this.callback('rightclick',[evt]);}},click:function(evt){if(!this.last){this.last=this.getEventInfo(evt);}
+this.handleSingle(evt);return!this.stopSingle;},dblclick:function(evt){this.handleDouble(evt);return!this.stopDouble;},handleDouble:function(evt){if(this["double"]&&this.passesDblclickTolerance(evt)){this.callback("dblclick",[evt]);}},handleSingle:function(evt){if(this.passesTolerance(evt)){if(this.timerId!=null){if(this.last.touches&&this.last.touches.length===1){if(this["double"]){OpenLayers.Event.stop(evt);}
+this.handleDouble(evt);}
+if(!this.last.touches||this.last.touches.length!==2){this.clearTimer();}}else{this.first=this.getEventInfo(evt);var clickEvent=this.single?OpenLayers.Util.extend({},evt):null;this.queuePotentialClick(clickEvent);}}},queuePotentialClick:function(evt){this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,evt),this.delay);},passesTolerance:function(evt){var passes=true;if(this.pixelTolerance!=null&&this.down&&this.down.xy){passes=this.pixelTolerance>=this.down.xy.distanceTo(evt.xy);if(passes&&this.touch&&this.down.touches.length===this.last.touches.length){for(var i=0,ii=this.down.touches.length;i<ii;++i){if(this.getTouchDistance(this.down.touches[i],this.last.touches[i])>this.pixelTolerance){passes=false;break;}}}}
+return passes;},getTouchDistance:function(from,to){return Math.sqrt(Math.pow(from.clientX-to.clientX,2)+
+Math.pow(from.clientY-to.clientY,2));},passesDblclickTolerance:function(evt){var passes=true;if(this.down&&this.first){passes=this.down.xy.distanceTo(this.first.xy)<=this.dblclickTolerance;}
+return passes;},clearTimer:function(){if(this.timerId!=null){window.clearTimeout(this.timerId);this.timerId=null;}
+if(this.rightclickTimerId!=null){window.clearTimeout(this.rightclickTimerId);this.rightclickTimerId=null;}},delayedCall:function(evt){this.timerId=null;if(evt){this.callback("click",[evt]);}},getEventInfo:function(evt){var touches;if(evt.touches){var len=evt.touches.length;touches=new Array(len);var touch;for(var i=0;i<len;i++){touch=evt.touches[i];touches[i]={clientX:touch.clientX,clientY:touch.clientY};}}
+return{xy:evt.xy,touches:touches};},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.clearTimer();this.down=null;this.first=null;this.last=null;this.touch=false;deactivated=true;}
+return deactivated;},CLASS_NAME:"OpenLayers.Handler.Click"});OpenLayers.Filter=OpenLayers.Class({initialize:function(options){OpenLayers.Util.extend(this,options);},destroy:function(){},evaluate:function(context){return true;},clone:function(){return null;},CLASS_NAME:"OpenLayers.Filter"});OpenLayers.Filter.Spatial=OpenLayers.Class(OpenLayers.Filter,{type:null,property:null,value:null,distance:null,distanceUnits:null,initialize:function(options){OpenLayers.Filter.prototype.initialize.apply(this,[options]);},evaluate:function(feature){var intersect=false;switch(this.type){case OpenLayers.Filter.Spatial.BBOX:case OpenLayers.Filter.Spatial.INTERSECTS:if(feature.geometry){var geom=this.value;if(this.value.CLASS_NAME=="OpenLayers.Bounds"){geom=this.value.toGeometry();}
+if(feature.geometry.intersects(geom)){intersect=true;}}
+break;default:OpenLayers.Console.error(OpenLayers.i18n("filterEvaluateNotImplemented"));break;}
+return intersect;},clone:function(){var options=OpenLayers.Util.applyDefaults({value:this.value&&this.value.clone&&this.value.clone()},this);return new OpenLayers.Filter.Spatial(options);},CLASS_NAME:"OpenLayers.Filter.Spatial"});OpenLayers.Filter.Spatial.BBOX="BBOX";OpenLayers.Filter.Spatial.INTERSECTS="INTERSECTS";OpenLayers.Filter.Spatial.DWITHIN="DWITHIN";OpenLayers.Filter.Spatial.WITHIN="WITHIN";OpenLayers.Filter.Spatial.CONTAINS="CONTAINS";OpenLayers.Handler.Drag=OpenLayers.Class(OpenLayers.Handler,{started:false,stopDown:true,dragging:false,touch:false,last:null,start:null,lastMoveEvt:null,oldOnselectstart:null,interval:0,timeoutId:null,documentDrag:false,documentEvents:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);if(this.documentDrag===true){var me=this;this._docMove=function(evt){me.mousemove({xy:{x:evt.clientX,y:evt.clientY},element:document});};this._docUp=function(evt){me.mouseup({xy:{x:evt.clie
 ntX,y:evt.clientY}});};}},dragstart:function(evt){var propagate=true;this.dragging=false;if(this.checkModifiers(evt)&&(OpenLayers.Event.isLeftClick(evt)||OpenLayers.Event.isSingleTouch(evt))){this.started=true;this.start=evt.xy;this.last=evt.xy;OpenLayers.Element.addClass(this.map.viewPortDiv,"olDragDown");this.down(evt);this.callback("down",[evt.xy]);OpenLayers.Event.stop(evt);if(!this.oldOnselectstart){this.oldOnselectstart=document.onselectstart?document.onselectstart:OpenLayers.Function.True;}
+document.onselectstart=OpenLayers.Function.False;propagate=!this.stopDown;}else{this.started=false;this.start=null;this.last=null;}
+return propagate;},dragmove:function(evt){this.lastMoveEvt=evt;if(this.started&&!this.timeoutId&&(evt.xy.x!=this.last.x||evt.xy.y!=this.last.y)){if(this.documentDrag===true&&this.documentEvents){if(evt.element===document){this.adjustXY(evt);this.setEvent(evt);}else{this.removeDocumentEvents();}}
+if(this.interval>0){this.timeoutId=setTimeout(OpenLayers.Function.bind(this.removeTimeout,this),this.interval);}
+this.dragging=true;this.move(evt);this.callback("move",[evt.xy]);if(!this.oldOnselectstart){this.oldOnselectstart=document.onselectstart;document.onselectstart=OpenLayers.Function.False;}
+this.last=evt.xy;}
+return true;},dragend:function(evt){if(this.started){if(this.documentDrag===true&&this.documentEvents){this.adjustXY(evt);this.removeDocumentEvents();}
+var dragged=(this.start!=this.last);this.started=false;this.dragging=false;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");this.up(evt);this.callback("up",[evt.xy]);if(dragged){this.callback("done",[evt.xy]);}
+document.onselectstart=this.oldOnselectstart;}
+return true;},down:function(evt){},move:function(evt){},up:function(evt){},out:function(evt){},mousedown:function(evt){return this.dragstart(evt);},touchstart:function(evt){if(!this.touch){this.touch=true;this.map.events.un({mousedown:this.mousedown,mouseup:this.mouseup,mousemove:this.mousemove,click:this.click,scope:this});}
+return this.dragstart(evt);},mousemove:function(evt){return this.dragmove(evt);},touchmove:function(evt){return this.dragmove(evt);},removeTimeout:function(){this.timeoutId=null;if(this.dragging){this.mousemove(this.lastMoveEvt);}},mouseup:function(evt){return this.dragend(evt);},touchend:function(evt){evt.xy=this.last;return this.dragend(evt);},mouseout:function(evt){if(this.started&&OpenLayers.Util.mouseLeft(evt,this.map.eventsDiv)){if(this.documentDrag===true){this.addDocumentEvents();}else{var dragged=(this.start!=this.last);this.started=false;this.dragging=false;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");this.out(evt);this.callback("out",[]);if(dragged){this.callback("done",[evt.xy]);}
+if(document.onselectstart){document.onselectstart=this.oldOnselectstart;}}}
+return true;},click:function(evt){return(this.start==this.last);},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragging=false;activated=true;}
+return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.touch=false;this.started=false;this.dragging=false;this.start=null;this.last=null;deactivated=true;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");}
+return deactivated;},adjustXY:function(evt){var pos=OpenLayers.Util.pagePosition(this.map.viewPortDiv);evt.xy.x-=pos[0];evt.xy.y-=pos[1];},addDocumentEvents:function(){OpenLayers.Element.addClass(document.body,"olDragDown");this.documentEvents=true;OpenLayers.Event.observe(document,"mousemove",this._docMove);OpenLayers.Event.observe(document,"mouseup",this._docUp);},removeDocumentEvents:function(){OpenLayers.Element.removeClass(document.body,"olDragDown");this.documentEvents=false;OpenLayers.Event.stopObserving(document,"mousemove",this._docMove);OpenLayers.Event.stopObserving(document,"mouseup",this._docUp);},CLASS_NAME:"OpenLayers.Handler.Drag"});OpenLayers.Handler.Box=OpenLayers.Class(OpenLayers.Handler,{dragHandler:null,boxDivClassName:'olHandlerBoxZoomBox',boxOffsets:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.dragHandler=new OpenLayers.Handler.Drag(this,{down:this.startBox,move:this.moveBox,out:
 this.removeBox,up:this.endBox},{keyMask:this.keyMask});},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);if(this.dragHandler){this.dragHandler.destroy();this.dragHandler=null;}},setMap:function(map){OpenLayers.Handler.prototype.setMap.apply(this,arguments);if(this.dragHandler){this.dragHandler.setMap(map);}},startBox:function(xy){this.callback("start",[]);this.zoomBox=OpenLayers.Util.createDiv('zoomBox',new OpenLayers.Pixel(-9999,-9999));this.zoomBox.className=this.boxDivClassName;this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.eventsDiv.appendChild(this.zoomBox);OpenLayers.Element.addClass(this.map.eventsDiv,"olDrawBox");},moveBox:function(xy){var startX=this.dragHandler.start.x;var startY=this.dragHandler.start.y;var deltaX=Math.abs(startX-xy.x);var deltaY=Math.abs(startY-xy.y);var offset=this.getBoxOffsets();this.zoomBox.style.width=(deltaX+offset.width+1)+"px";this.zoomBox.style.height=(deltaY+offset.height+1)+"px";this.z
 oomBox.style.left=(xy.x<startX?startX-deltaX-offset.left:startX-offset.left)+"px";this.zoomBox.style.top=(xy.y<startY?startY-deltaY-offset.top:startY-offset.top)+"px";},endBox:function(end){var result;if(Math.abs(this.dragHandler.start.x-end.x)>5||Math.abs(this.dragHandler.start.y-end.y)>5){var start=this.dragHandler.start;var top=Math.min(start.y,end.y);var bottom=Math.max(start.y,end.y);var left=Math.min(start.x,end.x);var right=Math.max(start.x,end.x);result=new OpenLayers.Bounds(left,bottom,right,top);}else{result=this.dragHandler.start.clone();}
+this.removeBox();this.callback("done",[result]);},removeBox:function(){this.map.eventsDiv.removeChild(this.zoomBox);this.zoomBox=null;this.boxOffsets=null;OpenLayers.Element.removeClass(this.map.eventsDiv,"olDrawBox");},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragHandler.activate();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){if(this.dragHandler.deactivate()){if(this.zoomBox){this.removeBox();}}
+return true;}else{return false;}},getBoxOffsets:function(){if(!this.boxOffsets){var testDiv=document.createElement("div");testDiv.style.position="absolute";testDiv.style.border="1px solid black";testDiv.style.width="3px";document.body.appendChild(testDiv);var w3cBoxModel=testDiv.clientWidth==3;document.body.removeChild(testDiv);var left=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-left-width"));var right=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-right-width"));var top=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-top-width"));var bottom=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-bottom-width"));this.boxOffsets={left:left,right:right,top:top,bottom:bottom,width:w3cBoxModel===false?left+right:0,height:w3cBoxModel===false?top+bottom:0};}
+return this.boxOffsets;},CLASS_NAME:"OpenLayers.Handler.Box"});OpenLayers.Control.ZoomBox=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,out:false,alwaysZoom:false,draw:function(){this.handler=new OpenLayers.Handler.Box(this,{done:this.zoomBox},{keyMask:this.keyMask});},zoomBox:function(position){if(position instanceof OpenLayers.Bounds){var bounds;if(!this.out){var minXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.left,position.bottom));var maxXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.right,position.top));bounds=new OpenLayers.Bounds(minXY.lon,minXY.lat,maxXY.lon,maxXY.lat);}else{var pixWidth=Math.abs(position.right-position.left);var pixHeight=Math.abs(position.top-position.bottom);var zoomFactor=Math.min((this.map.size.h/pixHeight),(this.map.size.w/pixWidth));var extent=this.map.getExtent();var center=this.map.getLonLatFromPixel(position.getCenterPixel());var xmin=center.lon-(extent.getWidth()/2)*zoomFactor;var xmax
 =center.lon+(extent.getWidth()/2)*zoomFactor;var ymin=center.lat-(extent.getHeight()/2)*zoomFactor;var ymax=center.lat+(extent.getHeight()/2)*zoomFactor;bounds=new OpenLayers.Bounds(xmin,ymin,xmax,ymax);}
+var lastZoom=this.map.getZoom();this.map.zoomToExtent(bounds);if(lastZoom==this.map.getZoom()&&this.alwaysZoom==true){this.map.zoomTo(lastZoom+(this.out?-1:1));}}else{if(!this.out){this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()+1);}else{this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()-1);}}},CLASS_NAME:"OpenLayers.Control.ZoomBox"});OpenLayers.Control.DragPan=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,panned:false,interval:1,documentDrag:false,kinetic:null,enableKinetic:false,kineticInterval:10,draw:function(){if(this.enableKinetic){var config={interval:this.kineticInterval};if(typeof this.enableKinetic==="object"){config=OpenLayers.Util.extend(config,this.enableKinetic);}
+this.kinetic=new OpenLayers.Kinetic(config);}
+this.handler=new OpenLayers.Handler.Drag(this,{"move":this.panMap,"done":this.panMapDone,"down":this.panMapStart},{interval:this.interval,documentDrag:this.documentDrag});},panMapStart:function(){if(this.kinetic){this.kinetic.begin();}},panMap:function(xy){if(this.kinetic){this.kinetic.update(xy);}
+this.panned=true;this.map.pan(this.handler.last.x-xy.x,this.handler.last.y-xy.y,{dragging:true,animate:false});},panMapDone:function(xy){if(this.panned){var res=null;if(this.kinetic){res=this.kinetic.end(xy);}
+this.map.pan(this.handler.last.x-xy.x,this.handler.last.y-xy.y,{dragging:!!res,animate:false});if(res){var self=this;this.kinetic.move(res,function(x,y,end){self.map.pan(x,y,{dragging:!end,animate:false});});}
+this.panned=false;}},CLASS_NAME:"OpenLayers.Control.DragPan"});OpenLayers.Handler.MouseWheel=OpenLayers.Class(OpenLayers.Handler,{wheelListener:null,mousePosition:null,interval:0,delta:0,cumulative:true,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.wheelListener=OpenLayers.Function.bindAsEventListener(this.onWheelEvent,this);},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);this.wheelListener=null;},onWheelEvent:function(e){if(!this.map||!this.checkModifiers(e)){return;}
+var overScrollableDiv=false;var overLayerDiv=false;var overMapDiv=false;var elem=OpenLayers.Event.element(e);while((elem!=null)&&!overMapDiv&&!overScrollableDiv){if(!overScrollableDiv){try{if(elem.currentStyle){overflow=elem.currentStyle["overflow"];}else{var style=document.defaultView.getComputedStyle(elem,null);var overflow=style.getPropertyValue("overflow");}
+overScrollableDiv=(overflow&&(overflow=="auto")||(overflow=="scroll"));}catch(err){}}
+if(!overLayerDiv){for(var i=0,len=this.map.layers.length;i<len;i++){if(elem==this.map.layers[i].div||elem==this.map.layers[i].pane){overLayerDiv=true;break;}}}
+overMapDiv=(elem==this.map.div);elem=elem.parentNode;}
+if(!overScrollableDiv&&overMapDiv){if(overLayerDiv){var delta=0;if(!e){e=window.event;}
+if(e.wheelDelta){delta=e.wheelDelta/120;if(window.opera&&window.opera.version()<9.2){delta=-delta;}}else if(e.detail){delta=-e.detail/3;}
+this.delta=this.delta+delta;if(this.interval){window.clearTimeout(this._timeoutId);this._timeoutId=window.setTimeout(OpenLayers.Function.bind(function(){this.wheelZoom(e);},this),this.interval);}else{this.wheelZoom(e);}}
+OpenLayers.Event.stop(e);}},wheelZoom:function(e){var delta=this.delta;this.delta=0;if(delta){if(this.mousePosition){e.xy=this.mousePosition;}
+if(!e.xy){e.xy=this.map.getPixelFromLonLat(this.map.getCenter());}
+if(delta<0){this.callback("down",[e,this.cumulative?delta:-1]);}else{this.callback("up",[e,this.cumulative?delta:1]);}}},mousemove:function(evt){this.mousePosition=evt.xy;},activate:function(evt){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){var wheelListener=this.wheelListener;OpenLayers.Event.observe(window,"DOMMouseScroll",wheelListener);OpenLayers.Event.observe(window,"mousewheel",wheelListener);OpenLayers.Event.observe(document,"mousewheel",wheelListener);return true;}else{return false;}},deactivate:function(evt){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){var wheelListener=this.wheelListener;OpenLayers.Event.stopObserving(window,"DOMMouseScroll",wheelListener);OpenLayers.Event.stopObserving(window,"mousewheel",wheelListener);OpenLayers.Event.stopObserving(document,"mousewheel",wheelListener);return true;}else{return false;}},CLASS_NAME:"OpenLayers.Handler.MouseWheel"});OpenLayers.Control.Navigation=OpenLayers.Class(OpenLayers.Con
 trol,{dragPan:null,dragPanOptions:null,pinchZoom:null,pinchZoomOptions:null,documentDrag:false,zoomBox:null,zoomBoxEnabled:true,zoomWheelEnabled:true,mouseWheelOptions:null,handleRightClicks:false,zoomBoxKeyMask:OpenLayers.Handler.MOD_SHIFT,autoActivate:true,initialize:function(options){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.deactivate();if(this.dragPan){this.dragPan.destroy();}
+this.dragPan=null;if(this.zoomBox){this.zoomBox.destroy();}
+this.zoomBox=null;if(this.pinchZoom){this.pinchZoom.destroy();}
+this.pinchZoom=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},activate:function(){this.dragPan.activate();if(this.zoomWheelEnabled){this.handlers.wheel.activate();}
+this.handlers.click.activate();if(this.zoomBoxEnabled){this.zoomBox.activate();}
+if(this.pinchZoom){this.pinchZoom.activate();}
+return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){if(this.pinchZoom){this.pinchZoom.deactivate();}
+this.zoomBox.deactivate();this.dragPan.deactivate();this.handlers.click.deactivate();this.handlers.wheel.deactivate();return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},draw:function(){if(this.handleRightClicks){this.map.viewPortDiv.oncontextmenu=OpenLayers.Function.False;}
+var clickCallbacks={'click':this.defaultClick,'dblclick':this.defaultDblClick,'dblrightclick':this.defaultDblRightClick};var clickOptions={'double':true,'stopDouble':true};this.handlers.click=new OpenLayers.Handler.Click(this,clickCallbacks,clickOptions);this.dragPan=new OpenLayers.Control.DragPan(OpenLayers.Util.extend({map:this.map,documentDrag:this.documentDrag},this.dragPanOptions));this.zoomBox=new OpenLayers.Control.ZoomBox({map:this.map,keyMask:this.zoomBoxKeyMask});this.dragPan.draw();this.zoomBox.draw();this.handlers.wheel=new OpenLayers.Handler.MouseWheel(this,{"up":this.wheelUp,"down":this.wheelDown},this.mouseWheelOptions);if(OpenLayers.Control.PinchZoom){this.pinchZoom=new OpenLayers.Control.PinchZoom(OpenLayers.Util.extend({map:this.map},this.pinchZoomOptions));}},defaultClick:function(evt){if(evt.lastTouches&&evt.lastTouches.length==2){this.map.zoomOut();}},defaultDblClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(
 newCenter,this.map.zoom+1);},defaultDblRightClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom-1);},wheelChange:function(evt,deltaZ){var currentZoom=this.map.getZoom();var newZoom=this.map.getZoom()+Math.round(deltaZ);newZoom=Math.max(newZoom,0);newZoom=Math.min(newZoom,this.map.getNumZoomLevels());if(newZoom===currentZoom){return;}
+var size=this.map.getSize();var deltaX=size.w/2-evt.xy.x;var deltaY=evt.xy.y-size.h/2;var newRes=this.map.baseLayer.getResolutionForZoom(newZoom);var zoomPoint=this.map.getLonLatFromPixel(evt.xy);var newCenter=new OpenLayers.LonLat(zoomPoint.lon+deltaX*newRes,zoomPoint.lat+deltaY*newRes);this.map.setCenter(newCenter,newZoom);},wheelUp:function(evt,delta){this.wheelChange(evt,delta||1);},wheelDown:function(evt,delta){this.wheelChange(evt,delta||-1);},disableZoomBox:function(){this.zoomBoxEnabled=false;this.zoomBox.deactivate();},enableZoomBox:function(){this.zoomBoxEnabled=true;if(this.active){this.zoomBox.activate();}},disableZoomWheel:function(){this.zoomWheelEnabled=false;this.handlers.wheel.deactivate();},enableZoomWheel:function(){this.zoomWheelEnabled=true;if(this.active){this.handlers.wheel.activate();}},CLASS_NAME:"OpenLayers.Control.Navigation"});OpenLayers.Handler.Feature=OpenLayers.Class(OpenLayers.Handler,{EVENTMAP:{'click':{'in':'click','out':'clickout'},'mousemo
 ve':{'in':'over','out':'out'},'dblclick':{'in':'dblclick','out':null},'mousedown':{'in':null,'out':null},'mouseup':{'in':null,'out':null},'touchstart':{'in':'click','out':'clickout'}},feature:null,lastFeature:null,down:null,up:null,touch:false,clickTolerance:4,geometryTypes:null,stopClick:true,stopDown:true,stopUp:false,initialize:function(control,layer,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,[control,callbacks,options]);this.layer=layer;},touchstart:function(evt){if(!this.touch){this.touch=true;this.map.events.un({mousedown:this.mousedown,mouseup:this.mouseup,mousemove:this.mousemove,click:this.click,dblclick:this.dblclick,scope:this});}
+return OpenLayers.Event.isMultiTouch(evt)?true:this.mousedown(evt);},touchmove:function(evt){OpenLayers.Event.stop(evt);},mousedown:function(evt){this.down=evt.xy;return this.handle(evt)?!this.stopDown:true;},mouseup:function(evt){this.up=evt.xy;return this.handle(evt)?!this.stopUp:true;},click:function(evt){return this.handle(evt)?!this.stopClick:true;},mousemove:function(evt){if(!this.callbacks['over']&&!this.callbacks['out']){return true;}
+this.handle(evt);return true;},dblclick:function(evt){return!this.handle(evt);},geometryTypeMatches:function(feature){return this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)>-1;},handle:function(evt){if(this.feature&&!this.feature.layer){this.feature=null;}
+var type=evt.type;var handled=false;var previouslyIn=!!(this.feature);var click=(type=="click"||type=="dblclick"||type=="touchstart");this.feature=this.layer.getFeatureFromEvent(evt);if(this.feature&&!this.feature.layer){this.feature=null;}
+if(this.lastFeature&&!this.lastFeature.layer){this.lastFeature=null;}
+if(this.feature){if(type==="touchstart"){OpenLayers.Event.stop(evt);}
+var inNew=(this.feature!=this.lastFeature);if(this.geometryTypeMatches(this.feature)){if(previouslyIn&&inNew){if(this.lastFeature){this.triggerCallback(type,'out',[this.lastFeature]);}
+this.triggerCallback(type,'in',[this.feature]);}else if(!previouslyIn||click){this.triggerCallback(type,'in',[this.feature]);}
+this.lastFeature=this.feature;handled=true;}else{if(this.lastFeature&&(previouslyIn&&inNew||click)){this.triggerCallback(type,'out',[this.lastFeature]);}
+this.feature=null;}}else{if(this.lastFeature&&(previouslyIn||click)){this.triggerCallback(type,'out',[this.lastFeature]);}}
+return handled;},triggerCallback:function(type,mode,args){var key=this.EVENTMAP[type][mode];if(key){if(type=='click'&&this.up&&this.down){var dpx=Math.sqrt(Math.pow(this.up.x-this.down.x,2)+
+Math.pow(this.up.y-this.down.y,2));if(dpx<=this.clickTolerance){this.callback(key,args);}}else{this.callback(key,args);}}},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.moveLayerToTop();this.map.events.on({"removelayer":this.handleMapEvents,"changelayer":this.handleMapEvents,scope:this});activated=true;}
+return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.moveLayerBack();this.feature=null;this.lastFeature=null;this.down=null;this.up=null;this.touch=false;this.map.events.un({"removelayer":this.handleMapEvents,"changelayer":this.handleMapEvents,scope:this});deactivated=true;}
+return deactivated;},handleMapEvents:function(evt){if(evt.type=="removelayer"||evt.property=="order"){this.moveLayerToTop();}},moveLayerToTop:function(){var index=Math.max(this.map.Z_INDEX_BASE['Feature']-1,this.layer.getZIndex())+1;this.layer.setZIndex(index);},moveLayerBack:function(){var index=this.layer.getZIndex()-1;if(index>=this.map.Z_INDEX_BASE['Feature']){this.layer.setZIndex(index);}else{this.map.setLayerZIndex(this.layer,this.map.getLayerIndex(this.layer));}},CLASS_NAME:"OpenLayers.Handler.Feature"});OpenLayers.StyleMap=OpenLayers.Class({styles:null,extendDefault:true,initialize:function(style,options){this.styles={"default":new OpenLayers.Style(OpenLayers.Feature.Vector.style["default"]),"select":new OpenLayers.Style(OpenLayers.Feature.Vector.style["select"]),"temporary":new OpenLayers.Style(OpenLayers.Feature.Vector.style["temporary"]),"delete":new OpenLayers.Style(OpenLayers.Feature.Vector.style["delete"])};if(style instanceof OpenLayers.Style){this.styles["def
 ault"]=style;this.styles["select"]=style;this.styles["temporary"]=style;this.styles["delete"]=style;}else if(typeof style=="object"){for(var key in style){if(style[key]instanceof OpenLayers.Style){this.styles[key]=style[key];}else if(typeof style[key]=="object"){this.styles[key]=new OpenLayers.Style(style[key]);}else{this.styles["default"]=new OpenLayers.Style(style);this.styles["select"]=new OpenLayers.Style(style);this.styles["temporary"]=new OpenLayers.Style(style);this.styles["delete"]=new OpenLayers.Style(style);break;}}}
+OpenLayers.Util.extend(this,options);},destroy:function(){for(var key in this.styles){this.styles[key].destroy();}
+this.styles=null;},createSymbolizer:function(feature,intent){if(!feature){feature=new OpenLayers.Feature.Vector();}
+if(!this.styles[intent]){intent="default";}
+feature.renderIntent=intent;var defaultSymbolizer={};if(this.extendDefault&&intent!="default"){defaultSymbolizer=this.styles["default"].createSymbolizer(feature);}
+return OpenLayers.Util.extend(defaultSymbolizer,this.styles[intent].createSymbolizer(feature));},addUniqueValueRules:function(renderIntent,property,symbolizers,context){var rules=[];for(var value in symbolizers){rules.push(new OpenLayers.Rule({symbolizer:symbolizers[value],context:context,filter:new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO,property:property,value:value})}));}
+this.styles[renderIntent].addRules(rules);},CLASS_NAME:"OpenLayers.StyleMap"});OpenLayers.Layer.Vector=OpenLayers.Class(OpenLayers.Layer,{EVENT_TYPES:["beforefeatureadded","beforefeaturesadded","featureadded","featuresadded","beforefeatureremoved","beforefeaturesremoved","featureremoved","featuresremoved","beforefeatureselected","featureselected","featureunselected","beforefeaturemodified","featuremodified","afterfeaturemodified","vertexmodified","vertexremoved","sketchstarted","sketchmodified","sketchcomplete","refresh"],isBaseLayer:false,isFixed:false,features:null,filter:null,selectedFeatures:null,unrenderedFeatures:null,reportError:true,style:null,styleMap:null,strategies:null,protocol:null,renderers:['SVG','VML','Canvas'],renderer:null,rendererOptions:null,geometryType:null,drawn:false,initialize:function(name,options){this.EVENT_TYPES=OpenLayers.Layer.Vector.prototype.EVENT_TYPES.concat(OpenLayers.Layer.prototype.EVENT_TYPES);OpenLayers.Layer.prototype.initialize.apply
 (this,arguments);if(!this.renderer||!this.renderer.supported()){this.assignRenderer();}
+if(!this.renderer||!this.renderer.supported()){this.renderer=null;this.displayError();}
+if(!this.styleMap){this.styleMap=new OpenLayers.StyleMap();}
+this.features=[];this.selectedFeatures=[];this.unrenderedFeatures={};if(this.strategies){for(var i=0,len=this.strategies.length;i<len;i++){this.strategies[i].setLayer(this);}}},destroy:function(){if(this.strategies){var strategy,i,len;for(i=0,len=this.strategies.length;i<len;i++){strategy=this.strategies[i];if(strategy.autoDestroy){strategy.destroy();}}
+this.strategies=null;}
+if(this.protocol){if(this.protocol.autoDestroy){this.protocol.destroy();}
+this.protocol=null;}
+this.destroyFeatures();this.features=null;this.selectedFeatures=null;this.unrenderedFeatures=null;if(this.renderer){this.renderer.destroy();}
+this.renderer=null;this.geometryType=null;this.drawn=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Vector(this.name,this.getOptions());}
+obj=OpenLayers.Layer.prototype.clone.apply(this,[obj]);var features=this.features;var len=features.length;var clonedFeatures=new Array(len);for(var i=0;i<len;++i){clonedFeatures[i]=features[i].clone();}
+obj.features=clonedFeatures;return obj;},refresh:function(obj){if(this.calculateInRange()&&this.visibility){this.events.triggerEvent("refresh",obj);}},assignRenderer:function(){for(var i=0,len=this.renderers.length;i<len;i++){var rendererClass=this.renderers[i];var renderer=(typeof rendererClass=="function")?rendererClass:OpenLayers.Renderer[rendererClass];if(renderer&&renderer.prototype.supported()){this.renderer=new renderer(this.div,this.rendererOptions);break;}}},displayError:function(){if(this.reportError){OpenLayers.Console.userError(OpenLayers.i18n("browserNotSupported",{'renderers':this.renderers.join("\n")}));}},setMap:function(map){OpenLayers.Layer.prototype.setMap.apply(this,arguments);if(!this.renderer){this.map.removeLayer(this);}else{this.renderer.map=this.map;this.renderer.setSize(this.map.getSize());}},afterAdd:function(){if(this.strategies){var strategy,i,len;for(i=0,len=this.strategies.length;i<len;i++){strategy=this.strategies[i];if(strategy.autoActivate){
 strategy.activate();}}}},removeMap:function(map){this.drawn=false;if(this.strategies){var strategy,i,len;for(i=0,len=this.strategies.length;i<len;i++){strategy=this.strategies[i];if(strategy.autoActivate){strategy.deactivate();}}}},onMapResize:function(){OpenLayers.Layer.prototype.onMapResize.apply(this,arguments);this.renderer.setSize(this.map.getSize());},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);var ng=(OpenLayers.Renderer.NG&&this.renderer instanceof OpenLayers.Renderer.NG);if(ng){dragging||this.renderer.updateDimensions(zoomChanged);}else{var coordSysUnchanged=true;if(!dragging){this.renderer.root.style.visibility="hidden";this.div.style.left=-parseInt(this.map.layerContainerDiv.style.left)+"px";this.div.style.top=-parseInt(this.map.layerContainerDiv.style.top)+"px";var extent=this.map.getExtent();coordSysUnchanged=this.renderer.setExtent(extent,zoomChanged);this.renderer.root.style.visibility="visible";if(OpenL
 ayers.IS_GECKO===true){this.div.scrollLeft=this.div.scrollLeft;}
+if(!zoomChanged&&coordSysUnchanged){for(var i in this.unrenderedFeatures){var feature=this.unrenderedFeatures[i];this.drawFeature(feature);}}}}
+if(!this.drawn||(!ng&&(zoomChanged||!coordSysUnchanged))){this.drawn=true;var feature;for(var i=0,len=this.features.length;i<len;i++){this.renderer.locked=(i!==(len-1));feature=this.features[i];this.drawFeature(feature);}}},redraw:function(){if(OpenLayers.Renderer.NG&&this.renderer instanceof OpenLayers.Renderer.NG){this.drawn=false;}
+return OpenLayers.Layer.prototype.redraw.apply(this,arguments);},display:function(display){OpenLayers.Layer.prototype.display.apply(this,arguments);var currentDisplay=this.div.style.display;if(currentDisplay!=this.renderer.root.style.display){this.renderer.root.style.display=currentDisplay;}},addFeatures:function(features,options){if(!(OpenLayers.Util.isArray(features))){features=[features];}
+var notify=!options||!options.silent;if(notify){var event={features:features};var ret=this.events.triggerEvent("beforefeaturesadded",event);if(ret===false){return;}
+features=event.features;}
+var featuresAdded=[];for(var i=0,len=features.length;i<len;i++){if(i!=(features.length-1)){this.renderer.locked=true;}else{this.renderer.locked=false;}
+var feature=features[i];if(this.geometryType&&!(feature.geometry instanceof this.geometryType)){var throwStr=OpenLayers.i18n('componentShouldBe',{'geomType':this.geometryType.prototype.CLASS_NAME});throw throwStr;}
+feature.layer=this;if(!feature.style&&this.style){feature.style=OpenLayers.Util.extend({},this.style);}
+if(notify){if(this.events.triggerEvent("beforefeatureadded",{feature:feature})===false){continue;}
+this.preFeatureInsert(feature);}
+featuresAdded.push(feature);this.features.push(feature);this.drawFeature(feature);if(notify){this.events.triggerEvent("featureadded",{feature:feature});this.onFeatureInsert(feature);}}
+if(notify){this.events.triggerEvent("featuresadded",{features:featuresAdded});}},removeFeatures:function(features,options){if(!features||features.length===0){return;}
+if(features===this.features){return this.removeAllFeatures(options);}
+if(!(OpenLayers.Util.isArray(features))){features=[features];}
+if(features===this.selectedFeatures){features=features.slice();}
+var notify=!options||!options.silent;if(notify){this.events.triggerEvent("beforefeaturesremoved",{features:features});}
+for(var i=features.length-1;i>=0;i--){if(i!=0&&features[i-1].geometry){this.renderer.locked=true;}else{this.renderer.locked=false;}
+var feature=features[i];delete this.unrenderedFeatures[feature.id];if(notify){this.events.triggerEvent("beforefeatureremoved",{feature:feature});}
+this.features=OpenLayers.Util.removeItem(this.features,feature);feature.layer=null;if(feature.geometry){this.renderer.eraseFeatures(feature);}
+if(OpenLayers.Util.indexOf(this.selectedFeatures,feature)!=-1){OpenLayers.Util.removeItem(this.selectedFeatures,feature);}
+if(notify){this.events.triggerEvent("featureremoved",{feature:feature});}}
+if(notify){this.events.triggerEvent("featuresremoved",{features:features});}},removeAllFeatures:function(options){var notify=!options||!options.silent;var features=this.features;if(notify){this.events.triggerEvent("beforefeaturesremoved",{features:features});}
+var feature;for(var i=features.length-1;i>=0;i--){feature=features[i];if(notify){this.events.triggerEvent("beforefeatureremoved",{feature:feature});}
+feature.layer=null;if(notify){this.events.triggerEvent("featureremoved",{feature:feature});}}
+this.renderer.clear();this.features=[];this.unrenderedFeatures={};this.selectedFeatures=[];if(notify){this.events.triggerEvent("featuresremoved",{features:features});}},destroyFeatures:function(features,options){var all=(features==undefined);if(all){features=this.features;}
+if(features){this.removeFeatures(features,options);for(var i=features.length-1;i>=0;i--){features[i].destroy();}}},drawFeature:function(feature,style){if(!this.drawn){return;}
+if(typeof style!="object"){if(!style&&feature.state===OpenLayers.State.DELETE){style="delete";}
+var renderIntent=style||feature.renderIntent;style=feature.style||this.style;if(!style){style=this.styleMap.createSymbolizer(feature,renderIntent);}}
+var drawn=this.renderer.drawFeature(feature,style);if(drawn===false||drawn===null){this.unrenderedFeatures[feature.id]=feature;}else{delete this.unrenderedFeatures[feature.id];}},eraseFeatures:function(features){this.renderer.eraseFeatures(features);},getFeatureFromEvent:function(evt){if(!this.renderer){OpenLayers.Console.error(OpenLayers.i18n("getFeatureError"));return null;}
+var feature=null;var featureId=this.renderer.getFeatureIdFromEvent(evt);if(featureId){if(typeof featureId==="string"){feature=this.getFeatureById(featureId);}else{feature=featureId;}}
+return feature;},getFeatureBy:function(property,value){var feature=null;for(var i=0,len=this.features.length;i<len;++i){if(this.features[i][property]==value){feature=this.features[i];break;}}
+return feature;},getFeatureById:function(featureId){return this.getFeatureBy('id',featureId);},getFeatureByFid:function(featureFid){return this.getFeatureBy('fid',featureFid);},getFeaturesByAttribute:function(attrName,attrValue){var i,feature,len=this.features.length,foundFeatures=[];for(i=0;i<len;i++){feature=this.features[i];if(feature&&feature.attributes){if(feature.attributes[attrName]===attrValue){foundFeatures.push(feature);}}}
+return foundFeatures;},onFeatureInsert:function(feature){},preFeatureInsert:function(feature){},getDataExtent:function(){var maxExtent=null;var features=this.features;if(features&&(features.length>0)){var geometry=null;for(var i=0,len=features.length;i<len;i++){geometry=features[i].geometry;if(geometry){if(maxExtent===null){maxExtent=new OpenLayers.Bounds();}
+maxExtent.extend(geometry.getBounds());}}}
+return maxExtent;},CLASS_NAME:"OpenLayers.Layer.Vector"});OpenLayers.Layer.Vector.RootContainer=OpenLayers.Class(OpenLayers.Layer.Vector,{displayInLayerSwitcher:false,layers:null,initialize:function(name,options){OpenLayers.Layer.Vector.prototype.initialize.apply(this,arguments);},display:function(){},getFeatureFromEvent:function(evt){var layers=this.layers;var feature;for(var i=0;i<layers.length;i++){feature=layers[i].getFeatureFromEvent(evt);if(feature){return feature;}}},setMap:function(map){OpenLayers.Layer.Vector.prototype.setMap.apply(this,arguments);this.collectRoots();map.events.register("changelayer",this,this.handleChangeLayer);},removeMap:function(map){map.events.unregister("changelayer",this,this.handleChangeLayer);this.resetRoots();OpenLayers.Layer.Vector.prototype.removeMap.apply(this,arguments);},collectRoots:function(){var layer;for(var i=0;i<this.map.layers.length;++i){layer=this.map.layers[i];if(OpenLayers.Util.indexOf(this.layers,layer)!=-1){layer.renderer
 .moveRoot(this.renderer);}}},resetRoots:function(){var layer;for(var i=0;i<this.layers.length;++i){layer=this.layers[i];if(this.renderer&&layer.renderer.getRenderLayerId()==this.id){this.renderer.moveRoot(layer.renderer);}}},handleChangeLayer:function(evt){var layer=evt.layer;if(evt.property=="order"&&OpenLayers.Util.indexOf(this.layers,layer)!=-1){this.resetRoots();this.collectRoots();}},CLASS_NAME:"OpenLayers.Layer.Vector.RootContainer"});OpenLayers.Filter.Logical=OpenLayers.Class(OpenLayers.Filter,{filters:null,type:null,initialize:function(options){this.filters=[];OpenLayers.Filter.prototype.initialize.apply(this,[options]);},destroy:function(){this.filters=null;OpenLayers.Filter.prototype.destroy.apply(this);},evaluate:function(context){var i,len;switch(this.type){case OpenLayers.Filter.Logical.AND:for(i=0,len=this.filters.length;i<len;i++){if(this.filters[i].evaluate(context)==false){return false;}}
+return true;case OpenLayers.Filter.Logical.OR:for(i=0,len=this.filters.length;i<len;i++){if(this.filters[i].evaluate(context)==true){return true;}}
+return false;case OpenLayers.Filter.Logical.NOT:return(!this.filters[0].evaluate(context));}
+return undefined;},clone:function(){var filters=[];for(var i=0,len=this.filters.length;i<len;++i){filters.push(this.filters[i].clone());}
+return new OpenLayers.Filter.Logical({type:this.type,filters:filters});},CLASS_NAME:"OpenLayers.Filter.Logical"});OpenLayers.Filter.Logical.AND="&&";OpenLayers.Filter.Logical.OR="||";OpenLayers.Filter.Logical.NOT="!";OpenLayers.Tile=OpenLayers.Class({EVENT_TYPES:["loadstart","loadend","reload","unload"],events:null,id:null,layer:null,url:null,bounds:null,size:null,position:null,isLoading:false,initialize:function(layer,position,bounds,url,size,options){this.layer=layer;this.position=position.clone();this.bounds=bounds.clone();this.url=url;if(size){this.size=size.clone();}
+this.id=OpenLayers.Util.createUniqueID("Tile_");this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);OpenLayers.Util.extend(this,options);},unload:function(){if(this.isLoading){this.isLoading=false;this.events.triggerEvent("unload");}},destroy:function(){this.layer=null;this.bounds=null;this.size=null;this.position=null;this.events.destroy();this.events=null;},clone:function(obj){if(obj==null){obj=new OpenLayers.Tile(this.layer,this.position,this.bounds,this.url,this.size);}
+OpenLayers.Util.applyDefaults(obj,this);return obj;},draw:function(){var maxExtent=this.layer.maxExtent;var withinMaxExtent=(maxExtent&&this.bounds.intersectsBounds(maxExtent,false));this.shouldDraw=(withinMaxExtent||this.layer.displayOutsideMaxExtent);this.clear();return this.shouldDraw;},moveTo:function(bounds,position,redraw){if(redraw==null){redraw=true;}
+this.bounds=bounds.clone();this.position=position.clone();if(redraw){this.draw();}},clear:function(){},getBoundsFromBaseLayer:function(position){var msg=OpenLayers.i18n('reprojectDeprecated',{'layerName':this.layer.name});OpenLayers.Console.warn(msg);var topLeft=this.layer.map.getLonLatFromLayerPx(position);var bottomRightPx=position.clone();bottomRightPx.x+=this.size.w;bottomRightPx.y+=this.size.h;var bottomRight=this.layer.map.getLonLatFromLayerPx(bottomRightPx);if(topLeft.lon>bottomRight.lon){if(topLeft.lon<0){topLeft.lon=-180-(topLeft.lon+180);}else{bottomRight.lon=180+bottomRight.lon+180;}}
+var bounds=new OpenLayers.Bounds(topLeft.lon,bottomRight.lat,bottomRight.lon,topLeft.lat);return bounds;},showTile:function(){if(this.shouldDraw){this.show();}},show:function(){},hide:function(){},CLASS_NAME:"OpenLayers.Tile"});OpenLayers.Tile.Image=OpenLayers.Class(OpenLayers.Tile,{url:null,imgDiv:null,frame:null,layerAlphaHack:null,isBackBuffer:false,isFirstDraw:true,backBufferTile:null,maxGetUrlLength:null,initialize:function(layer,position,bounds,url,size,options){OpenLayers.Tile.prototype.initialize.apply(this,arguments);if(this.maxGetUrlLength!=null){OpenLayers.Util.extend(this,OpenLayers.Tile.Image.IFrame);}
+this.url=url;this.frame=document.createElement('div');this.frame.style.overflow='hidden';this.frame.style.position='absolute';this.layerAlphaHack=this.layer.alpha&&OpenLayers.Util.alphaHack();},destroy:function(){if(this.imgDiv!=null){this.removeImgDiv();}
+this.imgDiv=null;if((this.frame!=null)&&(this.frame.parentNode==this.layer.div)){this.layer.div.removeChild(this.frame);}
+this.frame=null;if(this.backBufferTile){this.backBufferTile.destroy();this.backBufferTile=null;}
+this.layer.events.unregister("loadend",this,this.resetBackBuffer);OpenLayers.Tile.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Tile.Image(this.layer,this.position,this.bounds,this.url,this.size);}
+obj=OpenLayers.Tile.prototype.clone.apply(this,[obj]);obj.imgDiv=null;return obj;},draw:function(){if(this.layer!=this.layer.map.baseLayer&&this.layer.reproject){this.bounds=this.getBoundsFromBaseLayer(this.position);}
+var drawTile=OpenLayers.Tile.prototype.draw.apply(this,arguments);if((OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1)||this.layer.singleTile){if(drawTile){if(!this.backBufferTile){this.backBufferTile=this.clone();this.backBufferTile.hide();this.backBufferTile.isBackBuffer=true;this.events.register('loadend',this,this.resetBackBuffer);this.layer.events.register("loadend",this,this.resetBackBuffer);}
+this.startTransition();}else{if(this.backBufferTile){this.backBufferTile.clear();}}}else{if(drawTile&&this.isFirstDraw){this.events.register('loadend',this,this.showTile);this.isFirstDraw=false;}}
+if(!drawTile){return false;}
+if(this.isLoading){this.events.triggerEvent("reload");}else{this.isLoading=true;this.events.triggerEvent("loadstart");}
+return this.renderTile();},resetBackBuffer:function(){this.showTile();if(this.backBufferTile&&(this.isFirstDraw||!this.layer.numLoadingTiles)){this.isFirstDraw=false;var maxExtent=this.layer.maxExtent;var withinMaxExtent=(maxExtent&&this.bounds.intersectsBounds(maxExtent,false));if(withinMaxExtent){this.backBufferTile.position=this.position;this.backBufferTile.bounds=this.bounds;this.backBufferTile.size=this.size;this.backBufferTile.imageSize=this.layer.getImageSize(this.bounds)||this.size;this.backBufferTile.imageOffset=this.layer.imageOffset;this.backBufferTile.resolution=this.layer.getResolution();this.backBufferTile.renderTile();}
+this.backBufferTile.hide();}},renderTile:function(){if(this.layer.async){this.initImgDiv();this.layer.getURLasync(this.bounds,this,"url",this.positionImage);}else{this.url=this.layer.getURL(this.bounds);this.initImgDiv();this.positionImage();}
+return true;},positionImage:function(){if(this.layer===null){return;}
+OpenLayers.Util.modifyDOMElement(this.frame,null,this.position,this.size);var imageSize=this.layer.getImageSize(this.bounds);if(this.layerAlphaHack){OpenLayers.Util.modifyAlphaImageDiv(this.imgDiv,null,null,imageSize,this.url);}else{OpenLayers.Util.modifyDOMElement(this.imgDiv,null,null,imageSize);this.imgDiv.src=this.url;}},clear:function(){if(this.imgDiv){this.hide();if(OpenLayers.Tile.Image.useBlankTile){this.imgDiv.src=OpenLayers.Util.getImagesLocation()+"blank.gif";}}},initImgDiv:function(){if(this.imgDiv==null){var offset=this.layer.imageOffset;var size=this.layer.getImageSize(this.bounds);if(this.layerAlphaHack){this.imgDiv=OpenLayers.Util.createAlphaImageDiv(null,offset,size,null,"relative",null,null,null,true);}else{this.imgDiv=OpenLayers.Util.createImage(null,offset,size,null,"relative",null,null,true);}
+if(OpenLayers.Util.isArray(this.layer.url)){this.imgDiv.urls=this.layer.url.slice();}
+this.imgDiv.className='olTileImage';this.frame.style.zIndex=this.isBackBuffer?0:1;this.frame.appendChild(this.imgDiv);this.layer.div.appendChild(this.frame);if(this.layer.opacity!=null){OpenLayers.Util.modifyDOMElement(this.imgDiv,null,null,null,null,null,null,this.layer.opacity);}
+this.imgDiv.map=this.layer.map;var onload=function(){if(this.isLoading){this.isLoading=false;this.events.triggerEvent("loadend");}};if(this.layerAlphaHack){OpenLayers.Event.observe(this.imgDiv.childNodes[0],'load',OpenLayers.Function.bind(onload,this));}else{OpenLayers.Event.observe(this.imgDiv,'load',OpenLayers.Function.bind(onload,this));}
+var onerror=function(){if(this.imgDiv._attempts>OpenLayers.IMAGE_RELOAD_ATTEMPTS){onload.call(this);}};OpenLayers.Event.observe(this.imgDiv,"error",OpenLayers.Function.bind(onerror,this));}
+this.imgDiv.viewRequestID=this.layer.map.viewRequestID;},removeImgDiv:function(){OpenLayers.Event.stopObservingElement(this.imgDiv);if(this.imgDiv.parentNode==this.frame){this.frame.removeChild(this.imgDiv);this.imgDiv.map=null;}
+this.imgDiv.urls=null;var child=this.imgDiv.firstChild;if(child){OpenLayers.Event.stopObservingElement(child);this.imgDiv.removeChild(child);delete child;}else{this.imgDiv.src=OpenLayers.Util.getImagesLocation()+"blank.gif";}},checkImgURL:function(){if(this.layer){var loaded=this.layerAlphaHack?this.imgDiv.firstChild.src:this.imgDiv.src;if(!OpenLayers.Util.isEquivalentUrl(loaded,this.url)){this.hide();}}},startTransition:function(){if(!this.backBufferTile||!this.backBufferTile.imgDiv){return;}
+var ratio=1;if(this.backBufferTile.resolution){ratio=this.backBufferTile.resolution/this.layer.getResolution();}
+if(ratio!=1){if(this.layer.transitionEffect=='resize'){var upperLeft=new OpenLayers.LonLat(this.backBufferTile.bounds.left,this.backBufferTile.bounds.top);var size=new OpenLayers.Size(this.backBufferTile.size.w*ratio,this.backBufferTile.size.h*ratio);var px=this.layer.map.getLayerPxFromLonLat(upperLeft);OpenLayers.Util.modifyDOMElement(this.backBufferTile.frame,null,px,size);var imageSize=this.backBufferTile.imageSize;imageSize=new OpenLayers.Size(imageSize.w*ratio,imageSize.h*ratio);var imageOffset=this.backBufferTile.imageOffset;if(imageOffset){imageOffset=new OpenLayers.Pixel(imageOffset.x*ratio,imageOffset.y*ratio);}
+OpenLayers.Util.modifyDOMElement(this.backBufferTile.imgDiv,null,imageOffset,imageSize);this.backBufferTile.show();}}else{if(this.layer.singleTile){this.backBufferTile.show();}else{this.backBufferTile.hide();}}},show:function(){this.frame.style.display='';if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1){if(OpenLayers.IS_GECKO===true){this.frame.scrollLeft=this.frame.scrollLeft;}}},hide:function(){this.frame.style.display='none';},CLASS_NAME:"OpenLayers.Tile.Image"});OpenLayers.Tile.Image.useBlankTile=(OpenLayers.BROWSER_NAME=="safari"||OpenLayers.BROWSER_NAME=="opera");OpenLayers.Layer.XYZ=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,sphericalMercator:false,zoomOffset:0,serverResolutions:null,initialize:function(name,url,options){if(options&&options.sphericalMercator||this.sphericalMercator){options=OpenLayers.Util.extend({maxExtent:new OpenLayers.Bounds(-128*156543.03390625,-128*156543.03390625,128*156543.03390625,128
 *156543.03390625),maxResolution:156543.03390625,numZoomLevels:19,units:"m",projection:"EPSG:900913"},options);}
+url=url||this.url;name=name||this.name;var newArguments=[name,url,{},options];OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.XYZ(this.name,this.url,this.getOptions());}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){var xyz=this.getXYZ(bounds);var url=this.url;if(OpenLayers.Util.isArray(url)){var s=''+xyz.x+xyz.y+xyz.z;url=this.selectUrl(s,url);}
+return OpenLayers.String.format(url,xyz);},getXYZ:function(bounds){var res=this.map.getResolution();var x=Math.round((bounds.left-this.maxExtent.left)/(res*this.tileSize.w));var y=Math.round((this.maxExtent.top-bounds.top)/(res*this.tileSize.h));var z=this.serverResolutions!=null?OpenLayers.Util.indexOf(this.serverResolutions,res):this.map.getZoom()+this.zoomOffset;var limit=Math.pow(2,z);if(this.wrapDateLine)
+{x=((x%limit)+limit)%limit;}
+return{'x':x,'y':y,'z':z};},setMap:function(map){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.maxExtent.left,this.maxExtent.bottom);}},CLASS_NAME:"OpenLayers.Layer.XYZ"});OpenLayers.Layer.OSM=OpenLayers.Class(OpenLayers.Layer.XYZ,{name:"OpenStreetMap",attribution:"Data CC-By-SA by <a href='http://openstreetmap.org/'>OpenStreetMap</a>",sphericalMercator:true,url:'http://tile.openstreetmap.org/${z}/${x}/${y}.png',clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.OSM(this.name,this.url,this.getOptions());}
+obj=OpenLayers.Layer.XYZ.prototype.clone.apply(this,[obj]);return obj;},wrapDateLine:true,CLASS_NAME:"OpenLayers.Layer.OSM"});OpenLayers.Renderer.Canvas=OpenLayers.Class(OpenLayers.Renderer,{hitDetection:true,hitOverflow:0,canvas:null,features:null,pendingRedraw:false,initialize:function(containerID,options){OpenLayers.Renderer.prototype.initialize.apply(this,arguments);this.root=document.createElement("canvas");this.container.appendChild(this.root);this.canvas=this.root.getContext("2d");this.features={};if(this.hitDetection){this.hitCanvas=document.createElement("canvas");this.hitContext=this.hitCanvas.getContext("2d");}},eraseGeometry:function(geometry,featureId){this.eraseFeatures(this.features[featureId][0]);},supported:function(){var canvas=document.createElement("canvas");return!!canvas.getContext;},setSize:function(size){this.size=size.clone();var root=this.root;root.style.width=size.w+"px";root.style.height=size.h+"px";root.width=size.w;root.height=size.h;this.resolu
 tion=null;if(this.hitDetection){var hitCanvas=this.hitCanvas;hitCanvas.style.width=size.w+"px";hitCanvas.style.height=size.h+"px";hitCanvas.width=size.w;hitCanvas.height=size.h;}},drawFeature:function(feature,style){var rendered;if(feature.geometry){style=this.applyDefaultSymbolizer(style||feature.style);var bounds=feature.geometry.getBounds();rendered=(style.display!=="none")&&!!bounds&&bounds.intersectsBounds(this.extent);if(rendered){this.features[feature.id]=[feature,style];}
+else{delete(this.features[feature.id]);}
+this.pendingRedraw=true;}
+if(this.pendingRedraw&&!this.locked){this.redraw();this.pendingRedraw=false;}
+return rendered;},drawGeometry:function(geometry,style,featureId){var className=geometry.CLASS_NAME;if((className=="OpenLayers.Geometry.Collection")||(className=="OpenLayers.Geometry.MultiPoint")||(className=="OpenLayers.Geometry.MultiLineString")||(className=="OpenLayers.Geometry.MultiPolygon")){for(var i=0;i<geometry.components.length;i++){this.drawGeometry(geometry.components[i],style,featureId);}
+return;}
+switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":this.drawPoint(geometry,style,featureId);break;case"OpenLayers.Geometry.LineString":this.drawLineString(geometry,style,featureId);break;case"OpenLayers.Geometry.LinearRing":this.drawLinearRing(geometry,style,featureId);break;case"OpenLayers.Geometry.Polygon":this.drawPolygon(geometry,style,featureId);break;default:break;}},drawExternalGraphic:function(geometry,style,featureId){var img=new Image();if(style.graphicTitle){img.title=style.graphicTitle;}
+var width=style.graphicWidth||style.graphicHeight;var height=style.graphicHeight||style.graphicWidth;width=width?width:style.pointRadius*2;height=height?height:style.pointRadius*2;var xOffset=(style.graphicXOffset!=undefined)?style.graphicXOffset:-(0.5*width);var yOffset=(style.graphicYOffset!=undefined)?style.graphicYOffset:-(0.5*height);var opacity=style.graphicOpacity||style.fillOpacity;var onLoad=function(){if(!this.features[featureId]){return;}
+var pt=this.getLocalXY(geometry);var p0=pt[0];var p1=pt[1];if(!isNaN(p0)&&!isNaN(p1)){var x=(p0+xOffset)|0;var y=(p1+yOffset)|0;var canvas=this.canvas;canvas.globalAlpha=opacity;var factor=OpenLayers.Renderer.Canvas.drawImageScaleFactor||(OpenLayers.Renderer.Canvas.drawImageScaleFactor=/android 2.1/.test(navigator.userAgent.toLowerCase())?320/window.screen.width:1);canvas.drawImage(img,x*factor,y*factor,width*factor,height*factor);if(this.hitDetection){this.setHitContextStyle("fill",featureId);this.hitContext.fillRect(x,y,width,height);}}};img.onload=OpenLayers.Function.bind(onLoad,this);img.src=style.externalGraphic;},setCanvasStyle:function(type,style){if(type==="fill"){this.canvas.globalAlpha=style['fillOpacity'];this.canvas.fillStyle=style['fillColor'];}else if(type==="stroke"){this.canvas.globalAlpha=style['strokeOpacity'];this.canvas.strokeStyle=style['strokeColor'];this.canvas.lineWidth=style['strokeWidth'];}else{this.canvas.globalAlpha=0;this.canvas.lineWidth=1;}},fe
 atureIdToHex:function(featureId){var id=Number(featureId.split("_").pop())+1;if(id>=16777216){this.hitOverflow=id-16777215;id=id%16777216+1;}
+var hex="000000"+id.toString(16);var len=hex.length;hex="#"+hex.substring(len-6,len);return hex;},setHitContextStyle:function(type,featureId,symbolizer){var hex=this.featureIdToHex(featureId);if(type=="fill"){this.hitContext.globalAlpha=1.0;this.hitContext.fillStyle=hex;}else if(type=="stroke"){this.hitContext.globalAlpha=1.0;this.hitContext.strokeStyle=hex;this.hitContext.lineWidth=symbolizer.strokeWidth+2;}else{this.hitContext.globalAlpha=0;this.hitContext.lineWidth=1;}},drawPoint:function(geometry,style,featureId){if(style.graphic!==false){if(style.externalGraphic){this.drawExternalGraphic(geometry,style,featureId);}else{var pt=this.getLocalXY(geometry);var p0=pt[0];var p1=pt[1];if(!isNaN(p0)&&!isNaN(p1)){var twoPi=Math.PI*2;var radius=style.pointRadius;if(style.fill!==false){this.setCanvasStyle("fill",style);this.canvas.beginPath();this.canvas.arc(p0,p1,radius,0,twoPi,true);this.canvas.fill();if(this.hitDetection){this.setHitContextStyle("fill",featureId,style);this.hitC
 ontext.beginPath();this.hitContext.arc(p0,p1,radius,0,twoPi,true);this.hitContext.fill();}}
+if(style.stroke!==false){this.setCanvasStyle("stroke",style);this.canvas.beginPath();this.canvas.arc(p0,p1,radius,0,twoPi,true);this.canvas.stroke();if(this.hitDetection){this.setHitContextStyle("stroke",featureId,style);this.hitContext.beginPath();this.hitContext.arc(p0,p1,radius,0,twoPi,true);this.hitContext.stroke();}
+this.setCanvasStyle("reset");}}}}},drawLineString:function(geometry,style,featureId){style=OpenLayers.Util.applyDefaults({fill:false},style);this.drawLinearRing(geometry,style,featureId);},drawLinearRing:function(geometry,style,featureId){if(style.fill!==false){this.setCanvasStyle("fill",style);this.renderPath(this.canvas,geometry,style,featureId,"fill");if(this.hitDetection){this.setHitContextStyle("fill",featureId,style);this.renderPath(this.hitContext,geometry,style,featureId,"fill");}}
+if(style.stroke!==false){this.setCanvasStyle("stroke",style);this.renderPath(this.canvas,geometry,style,featureId,"stroke");if(this.hitDetection){this.setHitContextStyle("stroke",featureId,style);this.renderPath(this.hitContext,geometry,style,featureId,"stroke");}}
+this.setCanvasStyle("reset");},renderPath:function(context,geometry,style,featureId,type){var components=geometry.components;var len=components.length;context.beginPath();var start=this.getLocalXY(components[0]);var x=start[0];var y=start[1];if(!isNaN(x)&&!isNaN(y)){context.moveTo(start[0],start[1]);for(var i=1;i<len;++i){var pt=this.getLocalXY(components[i]);context.lineTo(pt[0],pt[1]);}
+if(type==="fill"){context.fill();}else{context.stroke();}}},drawPolygon:function(geometry,style,featureId){var components=geometry.components;var len=components.length;this.drawLinearRing(components[0],style,featureId);for(var i=1;i<len;++i){this.canvas.globalCompositeOperation="destination-out";if(this.hitDetection){this.hitContext.globalCompositeOperation="destination-out";}
+this.drawLinearRing(components[i],OpenLayers.Util.applyDefaults({stroke:false,fillOpacity:1.0},style),featureId);this.canvas.globalCompositeOperation="source-over";if(this.hitDetection){this.hitContext.globalCompositeOperation="source-over";}
+this.drawLinearRing(components[i],OpenLayers.Util.applyDefaults({fill:false},style),featureId);}},drawText:function(location,style){style=OpenLayers.Util.extend({fontColor:"#000000",labelAlign:"cm"},style);var pt=this.getLocalXY(location);this.setCanvasStyle("reset");this.canvas.fillStyle=style.fontColor;this.canvas.globalAlpha=style.fontOpacity||1.0;var fontStyle=[style.fontStyle?style.fontStyle:"normal","normal",style.fontWeight?style.fontWeight:"normal",style.fontSize?style.fontSize:"1em",style.fontFamily?style.fontFamily:"sans-serif"].join(" ");var labelRows=style.label.split('\n');var numRows=labelRows.length;if(this.canvas.fillText){this.canvas.font=fontStyle;this.canvas.textAlign=OpenLayers.Renderer.Canvas.LABEL_ALIGN[style.labelAlign[0]]||"center";this.canvas.textBaseline=OpenLayers.Renderer.Canvas.LABEL_ALIGN[style.labelAlign[1]]||"middle";var vfactor=OpenLayers.Renderer.Canvas.LABEL_FACTOR[style.labelAlign[1]];if(vfactor==null){vfactor=-.5;}
+var lineHeight=this.canvas.measureText('Mg').height||this.canvas.measureText('xx').width;pt[1]+=lineHeight*vfactor*(numRows-1);for(var i=0;i<numRows;i++){this.canvas.fillText(labelRows[i],pt[0],pt[1]+(lineHeight*i));}}else if(this.canvas.mozDrawText){this.canvas.mozTextStyle=fontStyle;var hfactor=OpenLayers.Renderer.Canvas.LABEL_FACTOR[style.labelAlign[0]];if(hfactor==null){hfactor=-.5;}
+var vfactor=OpenLayers.Renderer.Canvas.LABEL_FACTOR[style.labelAlign[1]];if(vfactor==null){vfactor=-.5;}
+var lineHeight=this.canvas.mozMeasureText('xx');pt[1]+=lineHeight*(1+(vfactor*numRows));for(var i=0;i<numRows;i++){var x=pt[0]+(hfactor*this.canvas.mozMeasureText(labelRows[i]));var y=pt[1]+(i*lineHeight);this.canvas.translate(x,y);this.canvas.mozDrawText(labelRows[i]);this.canvas.translate(-x,-y);}}
+this.setCanvasStyle("reset");},getLocalXY:function(point){var resolution=this.getResolution();var extent=this.extent;var x=(point.x/resolution+(-extent.left/resolution));var y=((extent.top/resolution)-point.y/resolution);return[x,y];},clear:function(){var height=this.root.height;var width=this.root.width;this.canvas.clearRect(0,0,width,height);this.features={};if(this.hitDetection){this.hitContext.clearRect(0,0,width,height);}},getFeatureIdFromEvent:function(evt){var feature=null;if(this.hitDetection){if(!this.map.dragging){var xy=evt.xy;var x=xy.x|0;var y=xy.y|0;var data=this.hitContext.getImageData(x,y,1,1).data;if(data[3]===255){var id=data[2]+(256*(data[1]+(256*data[0])));if(id){feature=this.features["OpenLayers.Feature.Vector_"+(id-1+this.hitOverflow)][0];}}}}
+return feature;},eraseFeatures:function(features){if(!(OpenLayers.Util.isArray(features))){features=[features];}
+for(var i=0;i<features.length;++i){delete this.features[features[i].id];}
+this.redraw();},redraw:function(){if(!this.locked){var height=this.root.height;var width=this.root.width;this.canvas.clearRect(0,0,width,height);if(this.hitDetection){this.hitContext.clearRect(0,0,width,height);}
+var labelMap=[];var feature,style;for(var id in this.features){if(!this.features.hasOwnProperty(id)){continue;}
+feature=this.features[id][0];style=this.features[id][1];this.drawGeometry(feature.geometry,style,feature.id);if(style.label){labelMap.push([feature,style]);}}
+var item;for(var i=0,len=labelMap.length;i<len;++i){item=labelMap[i];this.drawText(item[0].geometry.getCentroid(),item[1]);}}},CLASS_NAME:"OpenLayers.Renderer.Canvas"});OpenLayers.Renderer.Canvas.LABEL_ALIGN={"l":"left","r":"right","t":"top","b":"bottom"};OpenLayers.Renderer.Canvas.LABEL_FACTOR={"l":0,"r":-1,"t":0,"b":-1};OpenLayers.Renderer.Canvas.drawImageScaleFactor=null;OpenLayers.Renderer.SVG=OpenLayers.Class(OpenLayers.Renderer.Elements,{xmlns:"http://www.w3.org/2000/svg",xlinkns:"http://www.w3.org/1999/xlink",MAX_PIXEL:15000,translationParameters:null,symbolMetrics:null,initialize:function(containerID){if(!this.supported()){return;}
+OpenLayers.Renderer.Elements.prototype.initialize.apply(this,arguments);this.translationParameters={x:0,y:0};this.symbolMetrics={};},supported:function(){var svgFeature="http://www.w3.org/TR/SVG11/feature#";return(document.implementation&&(document.implementation.hasFeature("org.w3c.svg","1.0")||document.implementation.hasFeature(svgFeature+"SVG","1.1")||document.implementation.hasFeature(svgFeature+"BasicStructure","1.1")));},inValidRange:function(x,y,xyOnly){var left=x+(xyOnly?0:this.translationParameters.x);var top=y+(xyOnly?0:this.translationParameters.y);return(left>=-this.MAX_PIXEL&&left<=this.MAX_PIXEL&&top>=-this.MAX_PIXEL&&top<=this.MAX_PIXEL);},setExtent:function(extent,resolutionChanged){OpenLayers.Renderer.Elements.prototype.setExtent.apply(this,arguments);var resolution=this.getResolution();var left=-extent.left/resolution;var top=extent.top/resolution;if(resolutionChanged){this.left=left;this.top=top;var extentString="0 0 "+this.size.w+" "+this.size.h;this.rend
 ererRoot.setAttributeNS(null,"viewBox",extentString);this.translate(0,0);return true;}else{var inRange=this.translate(left-this.left,top-this.top);if(!inRange){this.setExtent(extent,true);}
+return inRange;}},translate:function(x,y){if(!this.inValidRange(x,y,true)){return false;}else{var transformString="";if(x||y){transformString="translate("+x+","+y+")";}
+this.root.setAttributeNS(null,"transform",transformString);this.translationParameters={x:x,y:y};return true;}},setSize:function(size){OpenLayers.Renderer.prototype.setSize.apply(this,arguments);this.rendererRoot.setAttributeNS(null,"width",this.size.w);this.rendererRoot.setAttributeNS(null,"height",this.size.h);},getNodeType:function(geometry,style){var nodeType=null;switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":if(style.externalGraphic){nodeType="image";}else if(this.isComplexSymbol(style.graphicName)){nodeType="svg";}else{nodeType="circle";}
+break;case"OpenLayers.Geometry.Rectangle":nodeType="rect";break;case"OpenLayers.Geometry.LineString":nodeType="polyline";break;case"OpenLayers.Geometry.LinearRing":nodeType="polygon";break;case"OpenLayers.Geometry.Polygon":case"OpenLayers.Geometry.Curve":case"OpenLayers.Geometry.Surface":nodeType="path";break;default:break;}
+return nodeType;},setStyle:function(node,style,options){style=style||node._style;options=options||node._options;var r=parseFloat(node.getAttributeNS(null,"r"));var widthFactor=1;var pos;if(node._geometryClass=="OpenLayers.Geometry.Point"&&r){node.style.visibility="";if(style.graphic===false){node.style.visibility="hidden";}else if(style.externalGraphic){pos=this.getPosition(node);if(style.graphicTitle){node.setAttributeNS(null,"title",style.graphicTitle);var label=this.nodeFactory(null,"title");label.textContent=style.graphicTitle;node.appendChild(label);}
+if(style.graphicWidth&&style.graphicHeight){node.setAttributeNS(null,"preserveAspectRatio","none");}
+var width=style.graphicWidth||style.graphicHeight;var height=style.graphicHeight||style.graphicWidth;width=width?width:style.pointRadius*2;height=height?height:style.pointRadius*2;var xOffset=(style.graphicXOffset!=undefined)?style.graphicXOffset:-(0.5*width);var yOffset=(style.graphicYOffset!=undefined)?style.graphicYOffset:-(0.5*height);var opacity=style.graphicOpacity||style.fillOpacity;node.setAttributeNS(null,"x",(pos.x+xOffset).toFixed());node.setAttributeNS(null,"y",(pos.y+yOffset).toFixed());node.setAttributeNS(null,"width",width);node.setAttributeNS(null,"height",height);node.setAttributeNS(this.xlinkns,"href",style.externalGraphic);node.setAttributeNS(null,"style","opacity: "+opacity);node.onclick=OpenLayers.Renderer.SVG.preventDefault;}else if(this.isComplexSymbol(style.graphicName)){var offset=style.pointRadius*3;var size=offset*2;var src=this.importSymbol(style.graphicName);pos=this.getPosition(node);widthFactor=this.symbolMetrics[src.id][0]*3/size;var parent=no
 de.parentNode;var nextSibling=node.nextSibling;if(parent){parent.removeChild(node);}
+node.firstChild&&node.removeChild(node.firstChild);node.appendChild(src.firstChild.cloneNode(true));node.setAttributeNS(null,"viewBox",src.getAttributeNS(null,"viewBox"));node.setAttributeNS(null,"width",size);node.setAttributeNS(null,"height",size);node.setAttributeNS(null,"x",pos.x-offset);node.setAttributeNS(null,"y",pos.y-offset);if(nextSibling){parent.insertBefore(node,nextSibling);}else if(parent){parent.appendChild(node);}}else{node.setAttributeNS(null,"r",style.pointRadius);}
+var rotation=style.rotation;if((rotation!==undefined||node._rotation!==undefined)&&pos){node._rotation=rotation;rotation|=0;if(node.nodeName!=="svg"){node.setAttributeNS(null,"transform","rotate("+rotation+" "+pos.x+" "+
+pos.y+")");}else{var metrics=this.symbolMetrics[src.id];node.firstChild.setAttributeNS(null,"transform","rotate("
++rotation+" "
++metrics[1]+" "
++metrics[2]+")");}}}
+if(options.isFilled){node.setAttributeNS(null,"fill",style.fillColor);node.setAttributeNS(null,"fill-opacity",style.fillOpacity);}else{node.setAttributeNS(null,"fill","none");}
+if(options.isStroked){node.setAttributeNS(null,"stroke",style.strokeColor);node.setAttributeNS(null,"stroke-opacity",style.strokeOpacity);node.setAttributeNS(null,"stroke-width",style.strokeWidth*widthFactor);node.setAttributeNS(null,"stroke-linecap",style.strokeLinecap||"round");node.setAttributeNS(null,"stroke-linejoin","round");style.strokeDashstyle&&node.setAttributeNS(null,"stroke-dasharray",this.dashStyle(style,widthFactor));}else{node.setAttributeNS(null,"stroke","none");}
+if(style.pointerEvents){node.setAttributeNS(null,"pointer-events",style.pointerEvents);}
+if(style.cursor!=null){node.setAttributeNS(null,"cursor",style.cursor);}
+return node;},dashStyle:function(style,widthFactor){var w=style.strokeWidth*widthFactor;var str=style.strokeDashstyle;switch(str){case'solid':return'none';case'dot':return[1,4*w].join();case'dash':return[4*w,4*w].join();case'dashdot':return[4*w,4*w,1,4*w].join();case'longdash':return[8*w,4*w].join();case'longdashdot':return[8*w,4*w,1,4*w].join();default:return OpenLayers.String.trim(str).replace(/\s+/g,",");}},createNode:function(type,id){var node=document.createElementNS(this.xmlns,type);if(id){node.setAttributeNS(null,"id",id);}
+return node;},nodeTypeCompare:function(node,type){return(type==node.nodeName);},createRenderRoot:function(){return this.nodeFactory(this.container.id+"_svgRoot","svg");},createRoot:function(suffix){return this.nodeFactory(this.container.id+suffix,"g");},createDefs:function(){var defs=this.nodeFactory(this.container.id+"_defs","defs");this.rendererRoot.appendChild(defs);return defs;},drawPoint:function(node,geometry){return this.drawCircle(node,geometry,1);},drawCircle:function(node,geometry,radius){var resolution=this.getResolution();var x=(geometry.x/resolution+this.left);var y=(this.top-geometry.y/resolution);if(this.inValidRange(x,y)){node.setAttributeNS(null,"cx",x);node.setAttributeNS(null,"cy",y);node.setAttributeNS(null,"r",radius);return node;}else{return false;}},drawLineString:function(node,geometry){var componentsResult=this.getComponentsString(geometry.components);if(componentsResult.path){node.setAttributeNS(null,"points",componentsResult.path);return(components
 Result.complete?node:null);}else{return false;}},drawLinearRing:function(node,geometry){var componentsResult=this.getComponentsString(geometry.components);if(componentsResult.path){node.setAttributeNS(null,"points",componentsResult.path);return(componentsResult.complete?node:null);}else{return false;}},drawPolygon:function(node,geometry){var d="";var draw=true;var complete=true;var linearRingResult,path;for(var j=0,len=geometry.components.length;j<len;j++){d+=" M";linearRingResult=this.getComponentsString(geometry.components[j].components," ");path=linearRingResult.path;if(path){d+=" "+path;complete=linearRingResult.complete&&complete;}else{draw=false;}}
+d+=" z";if(draw){node.setAttributeNS(null,"d",d);node.setAttributeNS(null,"fill-rule","evenodd");return complete?node:null;}else{return false;}},drawRectangle:function(node,geometry){var resolution=this.getResolution();var x=(geometry.x/resolution+this.left);var y=(this.top-geometry.y/resolution);if(this.inValidRange(x,y)){node.setAttributeNS(null,"x",x);node.setAttributeNS(null,"y",y);node.setAttributeNS(null,"width",geometry.width/resolution);node.setAttributeNS(null,"height",geometry.height/resolution);return node;}else{return false;}},drawSurface:function(node,geometry){var d=null;var draw=true;for(var i=0,len=geometry.components.length;i<len;i++){if((i%3)==0&&(i/3)==0){var component=this.getShortString(geometry.components[i]);if(!component){draw=false;}
+d="M "+component;}else if((i%3)==1){var component=this.getShortString(geometry.components[i]);if(!component){draw=false;}
+d+=" C "+component;}else{var component=this.getShortString(geometry.components[i]);if(!component){draw=false;}
+d+=" "+component;}}
+d+=" Z";if(draw){node.setAttributeNS(null,"d",d);return node;}else{return false;}},drawText:function(featureId,style,location){var resolution=this.getResolution();var x=(location.x/resolution+this.left);var y=(location.y/resolution-this.top);var label=this.nodeFactory(featureId+this.LABEL_ID_SUFFIX,"text");label.setAttributeNS(null,"x",x);label.setAttributeNS(null,"y",-y);if(style.fontColor){label.setAttributeNS(null,"fill",style.fontColor);}
+if(style.fontOpacity){label.setAttributeNS(null,"opacity",style.fontOpacity);}
+if(style.fontFamily){label.setAttributeNS(null,"font-family",style.fontFamily);}
+if(style.fontSize){label.setAttributeNS(null,"font-size",style.fontSize);}
+if(style.fontWeight){label.setAttributeNS(null,"font-weight",style.fontWeight);}
+if(style.fontStyle){label.setAttributeNS(null,"font-style",style.fontStyle);}
+if(style.labelSelect===true){label.setAttributeNS(null,"pointer-events","visible");label._featureId=featureId;}else{label.setAttributeNS(null,"pointer-events","none");}
+var align=style.labelAlign||"cm";label.setAttributeNS(null,"text-anchor",OpenLayers.Renderer.SVG.LABEL_ALIGN[align[0]]||"middle");if(OpenLayers.IS_GECKO===true){label.setAttributeNS(null,"dominant-baseline",OpenLayers.Renderer.SVG.LABEL_ALIGN[align[1]]||"central");}
+var labelRows=style.label.split('\n');var numRows=labelRows.length;while(label.childNodes.length>numRows){label.removeChild(label.lastChild);}
+for(var i=0;i<numRows;i++){var tspan=this.nodeFactory(featureId+this.LABEL_ID_SUFFIX+"_tspan_"+i,"tspan");if(style.labelSelect===true){tspan._featureId=featureId;tspan._geometry=location;tspan._geometryClass=location.CLASS_NAME;}
+if(OpenLayers.IS_GECKO===false){tspan.setAttributeNS(null,"baseline-shift",OpenLayers.Renderer.SVG.LABEL_VSHIFT[align[1]]||"-35%");}
+tspan.setAttribute("x",x);if(i==0){var vfactor=OpenLayers.Renderer.SVG.LABEL_VFACTOR[align[1]];if(vfactor==null){vfactor=-.5;}
+tspan.setAttribute("dy",(vfactor*(numRows-1))+"em");}else{tspan.setAttribute("dy","1em");}
+tspan.textContent=(labelRows[i]==='')?' ':labelRows[i];if(!tspan.parentNode){label.appendChild(tspan);}}
+if(!label.parentNode){this.textRoot.appendChild(label);}},getComponentsString:function(components,separator){var renderCmp=[];var complete=true;var len=components.length;var strings=[];var str,component;for(var i=0;i<len;i++){component=components[i];renderCmp.push(component);str=this.getShortString(component);if(str){strings.push(str);}else{if(i>0){if(this.getShortString(components[i-1])){strings.push(this.clipLine(components[i],components[i-1]));}}
+if(i<len-1){if(this.getShortString(components[i+1])){strings.push(this.clipLine(components[i],components[i+1]));}}
+complete=false;}}
+return{path:strings.join(separator||","),complete:complete};},clipLine:function(badComponent,goodComponent){if(goodComponent.equals(badComponent)){return"";}
+var resolution=this.getResolution();var maxX=this.MAX_PIXEL-this.translationParameters.x;var maxY=this.MAX_PIXEL-this.translationParameters.y;var x1=goodComponent.x/resolution+this.left;var y1=this.top-goodComponent.y/resolution;var x2=badComponent.x/resolution+this.left;var y2=this.top-badComponent.y/resolution;var k;if(x2<-maxX||x2>maxX){k=(y2-y1)/(x2-x1);x2=x2<0?-maxX:maxX;y2=y1+(x2-x1)*k;}
+if(y2<-maxY||y2>maxY){k=(x2-x1)/(y2-y1);y2=y2<0?-maxY:maxY;x2=x1+(y2-y1)*k;}
+return x2+","+y2;},getShortString:function(point){var resolution=this.getResolution();var x=(point.x/resolution+this.left);var y=(this.top-point.y/resolution);if(this.inValidRange(x,y)){return x+","+y;}else{return false;}},getPosition:function(node){return({x:parseFloat(node.getAttributeNS(null,"cx")),y:parseFloat(node.getAttributeNS(null,"cy"))});},importSymbol:function(graphicName){if(!this.defs){this.defs=this.createDefs();}
+var id=this.container.id+"-"+graphicName;var existing=document.getElementById(id)
+if(existing!=null){return existing;}
+var symbol=OpenLayers.Renderer.symbol[graphicName];if(!symbol){throw new Error(graphicName+' is not a valid symbol name');}
+var symbolNode=this.nodeFactory(id,"symbol");var node=this.nodeFactory(null,"polygon");symbolNode.appendChild(node);var symbolExtent=new OpenLayers.Bounds(Number.MAX_VALUE,Number.MAX_VALUE,0,0);var points=[];var x,y;for(var i=0;i<symbol.length;i=i+2){x=symbol[i];y=symbol[i+1];symbolExtent.left=Math.min(symbolExtent.left,x);symbolExtent.bottom=Math.min(symbolExtent.bottom,y);symbolExtent.right=Math.max(symbolExtent.right,x);symbolExtent.top=Math.max(symbolExtent.top,y);points.push(x,",",y);}
+node.setAttributeNS(null,"points",points.join(" "));var width=symbolExtent.getWidth();var height=symbolExtent.getHeight();var viewBox=[symbolExtent.left-width,symbolExtent.bottom-height,width*3,height*3];symbolNode.setAttributeNS(null,"viewBox",viewBox.join(" "));this.symbolMetrics[id]=[Math.max(width,height),symbolExtent.getCenterLonLat().lon,symbolExtent.getCenterLonLat().lat];this.defs.appendChild(symbolNode);return symbolNode;},getFeatureIdFromEvent:function(evt){var featureId=OpenLayers.Renderer.Elements.prototype.getFeatureIdFromEvent.apply(this,arguments);if(!featureId){var target=evt.target;featureId=target.parentNode&&target!=this.rendererRoot&&target.parentNode._featureId;}
+return featureId;},CLASS_NAME:"OpenLayers.Renderer.SVG"});OpenLayers.Renderer.SVG.LABEL_ALIGN={"l":"start","r":"end","b":"bottom","t":"hanging"};OpenLayers.Renderer.SVG.LABEL_VSHIFT={"t":"-70%","b":"0"};OpenLayers.Renderer.SVG.LABEL_VFACTOR={"t":0,"b":-1};OpenLayers.Renderer.SVG.preventDefault=function(e){e.preventDefault&&e.preventDefault();};OpenLayers.Filter.Comparison=OpenLayers.Class(OpenLayers.Filter,{type:null,property:null,value:null,matchCase:true,lowerBoundary:null,upperBoundary:null,initialize:function(options){OpenLayers.Filter.prototype.initialize.apply(this,[options]);if(this.type===OpenLayers.Filter.Comparison.LIKE&&options.matchCase===undefined){this.matchCase=null;}},evaluate:function(context){if(context instanceof OpenLayers.Feature.Vector){context=context.attributes;}
+var result=false;var got=context[this.property];var exp;switch(this.type){case OpenLayers.Filter.Comparison.EQUAL_TO:exp=this.value;if(!this.matchCase&&typeof got=="string"&&typeof exp=="string"){result=(got.toUpperCase()==exp.toUpperCase());}else{result=(got==exp);}
+break;case OpenLayers.Filter.Comparison.NOT_EQUAL_TO:exp=this.value;if(!this.matchCase&&typeof got=="string"&&typeof exp=="string"){result=(got.toUpperCase()!=exp.toUpperCase());}else{result=(got!=exp);}
+break;case OpenLayers.Filter.Comparison.LESS_THAN:result=got<this.value;break;case OpenLayers.Filter.Comparison.GREATER_THAN:result=got>this.value;break;case OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO:result=got<=this.value;break;case OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO:result=got>=this.value;break;case OpenLayers.Filter.Comparison.BETWEEN:result=(got>=this.lowerBoundary)&&(got<=this.upperBoundary);break;case OpenLayers.Filter.Comparison.LIKE:var regexp=new RegExp(this.value,"gi");result=regexp.test(got);break;}
+return result;},value2regex:function(wildCard,singleChar,escapeChar){if(wildCard=="."){var msg="'.' is an unsupported wildCard character for "+"OpenLayers.Filter.Comparison";OpenLayers.Console.error(msg);return null;}
+wildCard=wildCard?wildCard:"*";singleChar=singleChar?singleChar:".";escapeChar=escapeChar?escapeChar:"!";this.value=this.value.replace(new RegExp("\\"+escapeChar+"(.|$)","g"),"\\$1");this.value=this.value.replace(new RegExp("\\"+singleChar,"g"),".");this.value=this.value.replace(new RegExp("\\"+wildCard,"g"),".*");this.value=this.value.replace(new RegExp("\\\\.\\*","g"),"\\"+wildCard);this.value=this.value.replace(new RegExp("\\\\\\.","g"),"\\"+singleChar);return this.value;},regex2value:function(){var value=this.value;value=value.replace(/!/g,"!!");value=value.replace(/(\\)?\\\./g,function($0,$1){return $1?$0:"!.";});value=value.replace(/(\\)?\\\*/g,function($0,$1){return $1?$0:"!*";});value=value.replace(/\\\\/g,"\\");value=value.replace(/\.\*/g,"*");return value;},clone:function(){return OpenLayers.Util.extend(new OpenLayers.Filter.Comparison(),this);},CLASS_NAME:"OpenLayers.Filter.Comparison"});OpenLayers.Filter.Comparison.EQUAL_TO="==";OpenLayers.Filter.Comparison.NOT_E
 QUAL_TO="!=";OpenLayers.Filter.Comparison.LESS_THAN="<";OpenLayers.Filter.Comparison.GREATER_THAN=">";OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO="<=";OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO=">=";OpenLayers.Filter.Comparison.BETWEEN="..";OpenLayers.Filter.Comparison.LIKE="~";OpenLayers.Format.QueryStringFilter=(function(){var cmpToStr={};cmpToStr[OpenLayers.Filter.Comparison.EQUAL_TO]="eq";cmpToStr[OpenLayers.Filter.Comparison.NOT_EQUAL_TO]="ne";cmpToStr[OpenLayers.Filter.Comparison.LESS_THAN]="lt";cmpToStr[OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO]="lte";cmpToStr[OpenLayers.Filter.Comparison.GREATER_THAN]="gt";cmpToStr[OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO]="gte";cmpToStr[OpenLayers.Filter.Comparison.LIKE]="ilike";function regex2value(value){value=value.replace(/%/g,"\\%");value=value.replace(/\\\\\.(\*)?/g,function($0,$1){return $1?$0:"\\\\_";});value=value.replace(/\\\\\.\*/g,"\\\\%");value=value.replace(/(\\)?\.(\*)?/g,functi
 on($0,$1,$2){return $1||$2?$0:"_";});value=value.replace(/(\\)?\.\*/g,function($0,$1){return $1?$0:"%";});value=value.replace(/\\\./g,".");value=value.replace(/(\\)?\\\*/g,function($0,$1){return $1?$0:"*";});return value;}
+return OpenLayers.Class(OpenLayers.Format,{wildcarded:false,srsInBBOX:false,write:function(filter,params){params=params||{};var className=filter.CLASS_NAME;var filterType=className.substring(className.lastIndexOf(".")+1);switch(filterType){case"Spatial":switch(filter.type){case OpenLayers.Filter.Spatial.BBOX:params.bbox=filter.value.toArray();if(this.srsInBBOX&&filter.projection){params.bbox.push(filter.projection.getCode());}
+break;case OpenLayers.Filter.Spatial.DWITHIN:params.tolerance=filter.distance;case OpenLayers.Filter.Spatial.WITHIN:params.lon=filter.value.x;params.lat=filter.value.y;break;default:OpenLayers.Console.warn("Unknown spatial filter type "+filter.type);}
+break;case"Comparison":var op=cmpToStr[filter.type];if(op!==undefined){var value=filter.value;if(filter.type==OpenLayers.Filter.Comparison.LIKE){value=regex2value(value);if(this.wildcarded){value="%"+value+"%";}}
+params[filter.property+"__"+op]=value;params.queryable=params.queryable||[];params.queryable.push(filter.property);}else{OpenLayers.Console.warn("Unknown comparison filter type "+filter.type);}
+break;case"Logical":if(filter.type===OpenLayers.Filter.Logical.AND){for(var i=0,len=filter.filters.length;i<len;i++){params=this.write(filter.filters[i],params);}}else{OpenLayers.Console.warn("Unsupported logical filter type "+filter.type);}
+break;default:OpenLayers.Console.warn("Unknown filter type "+filterType);}
+return params;},CLASS_NAME:"OpenLayers.Format.QueryStringFilter"});})();OpenLayers.Control.MousePosition=OpenLayers.Class(OpenLayers.Control,{autoActivate:true,element:null,prefix:'',separator:', ',suffix:'',numDigits:5,granularity:10,emptyString:null,lastXy:null,displayProjection:null,destroy:function(){this.deactivate();OpenLayers.Control.prototype.destroy.apply(this,arguments);},activate:function(){if(OpenLayers.Control.prototype.activate.apply(this,arguments)){this.map.events.register('mousemove',this,this.redraw);this.map.events.register('mouseout',this,this.reset);this.redraw();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.map.events.unregister('mousemove',this,this.redraw);this.map.events.unregister('mouseout',this,this.reset);this.element.innerHTML="";return true;}else{return false;}},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.element){this.div.left=
 "";this.div.top="";this.element=this.div;}
+return this.div;},redraw:function(evt){var lonLat;if(evt==null){this.reset();return;}else{if(this.lastXy==null||Math.abs(evt.xy.x-this.lastXy.x)>this.granularity||Math.abs(evt.xy.y-this.lastXy.y)>this.granularity)
+{this.lastXy=evt.xy;return;}
+lonLat=this.map.getLonLatFromPixel(evt.xy);if(!lonLat){return;}
+if(this.displayProjection){lonLat.transform(this.map.getProjectionObject(),this.displayProjection);}
+this.lastXy=evt.xy;}
+var newHtml=this.formatOutput(lonLat);if(newHtml!=this.element.innerHTML){this.element.innerHTML=newHtml;}},reset:function(evt){if(this.emptyString!=null){this.element.innerHTML=this.emptyString;}},formatOutput:function(lonLat){var digits=parseInt(this.numDigits);var newHtml=this.prefix+
+lonLat.lon.toFixed(digits)+
+this.separator+
+lonLat.lat.toFixed(digits)+
+this.suffix;return newHtml;},CLASS_NAME:"OpenLayers.Control.MousePosition"});OpenLayers.Control.ZoomIn=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){this.map.zoomIn();},CLASS_NAME:"OpenLayers.Control.ZoomIn"});OpenLayers.Control.ZoomToMaxExtent=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){if(this.map){this.map.zoomToMaxExtent();}},CLASS_NAME:"OpenLayers.Control.ZoomToMaxExtent"});OpenLayers.Geometry.MultiLineString=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LineString"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},split:function(geometry,options){var results=null;var mutual=options&&options.mutual;var splits,sourceLine,sourceLines,sourceSplit,targetSplit;var sourceParts=[];var targetParts=[geometry];for(var i=0,len=this.components.length;i<len;++i){sourceLine=this.components[i];s
 ourceSplit=false;for(var j=0;j<targetParts.length;++j){splits=sourceLine.split(targetParts[j],options);if(splits){if(mutual){sourceLines=splits[0];for(var k=0,klen=sourceLines.length;k<klen;++k){if(k===0&&sourceParts.length){sourceParts[sourceParts.length-1].addComponent(sourceLines[k]);}else{sourceParts.push(new OpenLayers.Geometry.MultiLineString([sourceLines[k]]));}}
+sourceSplit=true;splits=splits[1];}
+if(splits.length){splits.unshift(j,1);Array.prototype.splice.apply(targetParts,splits);break;}}}
+if(!sourceSplit){if(sourceParts.length){sourceParts[sourceParts.length-1].addComponent(sourceLine.clone());}else{sourceParts=[new OpenLayers.Geometry.MultiLineString(sourceLine.clone())];}}}
+if(sourceParts&&sourceParts.length>1){sourceSplit=true;}else{sourceParts=[];}
+if(targetParts&&targetParts.length>1){targetSplit=true;}else{targetParts=[];}
+if(sourceSplit||targetSplit){if(mutual){results=[sourceParts,targetParts];}else{results=targetParts;}}
+return results;},splitWith:function(geometry,options){var results=null;var mutual=options&&options.mutual;var splits,targetLine,sourceLines,sourceSplit,targetSplit,sourceParts,targetParts;if(geometry instanceof OpenLayers.Geometry.LineString){targetParts=[];sourceParts=[geometry];for(var i=0,len=this.components.length;i<len;++i){targetSplit=false;targetLine=this.components[i];for(var j=0;j<sourceParts.length;++j){splits=sourceParts[j].split(targetLine,options);if(splits){if(mutual){sourceLines=splits[0];if(sourceLines.length){sourceLines.unshift(j,1);Array.prototype.splice.apply(sourceParts,sourceLines);j+=sourceLines.length-2;}
+splits=splits[1];if(splits.length===0){splits=[targetLine.clone()];}}
+for(var k=0,klen=splits.length;k<klen;++k){if(k===0&&targetParts.length){targetParts[targetParts.length-1].addComponent(splits[k]);}else{targetParts.push(new OpenLayers.Geometry.MultiLineString([splits[k]]));}}
+targetSplit=true;}}
+if(!targetSplit){if(targetParts.length){targetParts[targetParts.length-1].addComponent(targetLine.clone());}else{targetParts=[new OpenLayers.Geometry.MultiLineString([targetLine.clone()])];}}}}else{results=geometry.split(this);}
+return results;},CLASS_NAME:"OpenLayers.Geometry.MultiLineString"});OpenLayers.Request={DEFAULT_CONFIG:{method:"GET",url:window.location.href,async:true,user:undefined,password:undefined,params:null,proxy:OpenLayers.ProxyHost,headers:{},data:null,callback:function(){},success:null,failure:null,scope:null},URL_SPLIT_REGEX:/([^:]*:)\/\/([^:]*:?[^@]*@)?([^:\/\?]*):?([^\/\?]*)/,events:new OpenLayers.Events(this,null,["complete","success","failure"]),issue:function(config){var defaultConfig=OpenLayers.Util.extend(this.DEFAULT_CONFIG,{proxy:OpenLayers.ProxyHost});config=OpenLayers.Util.applyDefaults(config,defaultConfig);var request=new OpenLayers.Request.XMLHttpRequest();var url=OpenLayers.Util.urlAppend(config.url,OpenLayers.Util.getParameterString(config.params||{}));var sameOrigin=!(url.indexOf("http")==0);var urlParts=!sameOrigin&&url.match(this.URL_SPLIT_REGEX);if(urlParts){var location=window.location;sameOrigin=urlParts[1]==location.protocol&&urlParts[3]==location.hostname
 ;var uPort=urlParts[4],lPort=location.port;if(uPort!=80&&uPort!=""||lPort!="80"&&lPort!=""){sameOrigin=sameOrigin&&uPort==lPort;}}
+if(!sameOrigin){if(config.proxy){if(typeof config.proxy=="function"){url=config.proxy(url);}else{url=config.proxy+encodeURIComponent(url);}}else{OpenLayers.Console.warn(OpenLayers.i18n("proxyNeeded"),{url:url});}}
+request.open(config.method,url,config.async,config.user,config.password);for(var header in config.headers){request.setRequestHeader(header,config.headers[header]);}
+var events=this.events;var self=this;request.onreadystatechange=function(){if(request.readyState==OpenLayers.Request.XMLHttpRequest.DONE){var proceed=events.triggerEvent("complete",{request:request,config:config,requestUrl:url});if(proceed!==false){self.runCallbacks({request:request,config:config,requestUrl:url});}}};if(config.async===false){request.send(config.data);}else{window.setTimeout(function(){if(request.readyState!==0){request.send(config.data);}},0);}
+return request;},runCallbacks:function(options){var request=options.request;var config=options.config;var complete=(config.scope)?OpenLayers.Function.bind(config.callback,config.scope):config.callback;var success;if(config.success){success=(config.scope)?OpenLayers.Function.bind(config.success,config.scope):config.success;}
+var failure;if(config.failure){failure=(config.scope)?OpenLayers.Function.bind(config.failure,config.scope):config.failure;}
+if(OpenLayers.Util.createUrlObject(config.url).protocol=="file:"&&request.responseText){request.status=200;}
+complete(request);if(!request.status||(request.status>=200&&request.status<300)){this.events.triggerEvent("success",options);if(success){success(request);}}
+if(request.status&&(request.status<200||request.status>=300)){this.events.triggerEvent("failure",options);if(failure){failure(request);}}},GET:function(config){config=OpenLayers.Util.extend(config,{method:"GET"});return OpenLayers.Request.issue(config);},POST:function(config){config=OpenLayers.Util.extend(config,{method:"POST"});config.headers=config.headers?config.headers:{};if(!("CONTENT-TYPE"in OpenLayers.Util.upperCaseObject(config.headers))){config.headers["Content-Type"]="application/xml";}
+return OpenLayers.Request.issue(config);},PUT:function(config){config=OpenLayers.Util.extend(config,{method:"PUT"});config.headers=config.headers?config.headers:{};if(!("CONTENT-TYPE"in OpenLayers.Util.upperCaseObject(config.headers))){config.headers["Content-Type"]="application/xml";}
+return OpenLayers.Request.issue(config);},DELETE:function(config){config=OpenLayers.Util.extend(config,{method:"DELETE"});return OpenLayers.Request.issue(config);},HEAD:function(config){config=OpenLayers.Util.extend(config,{method:"HEAD"});return OpenLayers.Request.issue(config);},OPTIONS:function(config){config=OpenLayers.Util.extend(config,{method:"OPTIONS"});return OpenLayers.Request.issue(config);}};(function(){var oXMLHttpRequest=window.XMLHttpRequest;var bGecko=!!window.controllers,bIE=window.document.all&&!window.opera,bIE7=bIE&&window.navigator.userAgent.match(/MSIE 7.0/);function fXMLHttpRequest(){this._object=oXMLHttpRequest&&!bIE7?new oXMLHttpRequest:new window.ActiveXObject("Microsoft.XMLHTTP");this._listeners=[];};function cXMLHttpRequest(){return new fXMLHttpRequest;};cXMLHttpRequest.prototype=fXMLHttpRequest.prototype;if(bGecko&&oXMLHttpRequest.wrapped)
+cXMLHttpRequest.wrapped=oXMLHttpRequest.wrapped;cXMLHttpRequest.UNSENT=0;cXMLHttpRequest.OPENED=1;cXMLHttpRequest.HEADERS_RECEIVED=2;cXMLHttpRequest.LOADING=3;cXMLHttpRequest.DONE=4;cXMLHttpRequest.prototype.readyState=cXMLHttpRequest.UNSENT;cXMLHttpRequest.prototype.responseText='';cXMLHttpRequest.prototype.responseXML=null;cXMLHttpRequest.prototype.status=0;cXMLHttpRequest.prototype.statusText='';cXMLHttpRequest.prototype.priority="NORMAL";cXMLHttpRequest.prototype.onreadystatechange=null;cXMLHttpRequest.onreadystatechange=null;cXMLHttpRequest.onopen=null;cXMLHttpRequest.onsend=null;cXMLHttpRequest.onabort=null;cXMLHttpRequest.prototype.open=function(sMethod,sUrl,bAsync,sUser,sPassword){delete this._headers;if(arguments.length<3)
+bAsync=true;this._async=bAsync;var oRequest=this,nState=this.readyState,fOnUnload;if(bIE&&bAsync){fOnUnload=function(){if(nState!=cXMLHttpRequest.DONE){fCleanTransport(oRequest);oRequest.abort();}};window.attachEvent("onunload",fOnUnload);}
+if(cXMLHttpRequest.onopen)
+cXMLHttpRequest.onopen.apply(this,arguments);if(arguments.length>4)
+this._object.open(sMethod,sUrl,bAsync,sUser,sPassword);else
+if(arguments.length>3)
+this._object.open(sMethod,sUrl,bAsync,sUser);else
+this._object.open(sMethod,sUrl,bAsync);this.readyState=cXMLHttpRequest.OPENED;fReadyStateChange(this);this._object.onreadystatechange=function(){if(bGecko&&!bAsync)
+return;oRequest.readyState=oRequest._object.readyState;fSynchronizeValues(oRequest);if(oRequest._aborted){oRequest.readyState=cXMLHttpRequest.UNSENT;return;}
+if(oRequest.readyState==cXMLHttpRequest.DONE){delete oRequest._data;fCleanTransport(oRequest);if(bIE&&bAsync)
+window.detachEvent("onunload",fOnUnload);}
+if(nState!=oRequest.readyState)
+fReadyStateChange(oRequest);nState=oRequest.readyState;}};function fXMLHttpRequest_send(oRequest){oRequest._object.send(oRequest._data);if(bGecko&&!oRequest._async){oRequest.readyState=cXMLHttpRequest.OPENED;fSynchronizeValues(oRequest);while(oRequest.readyState<cXMLHttpRequest.DONE){oRequest.readyState++;fReadyStateChange(oRequest);if(oRequest._aborted)
+return;}}};cXMLHttpRequest.prototype.send=function(vData){if(cXMLHttpRequest.onsend)
+cXMLHttpRequest.onsend.apply(this,arguments);if(!arguments.length)
+vData=null;if(vData&&vData.nodeType){vData=window.XMLSerializer?new window.XMLSerializer().serializeToString(vData):vData.xml;if(!oRequest._headers["Content-Type"])
+oRequest._object.setRequestHeader("Content-Type","application/xml");}
+this._data=vData;fXMLHttpRequest_send(this);};cXMLHttpRequest.prototype.abort=function(){if(cXMLHttpRequest.onabort)
+cXMLHttpRequest.onabort.apply(this,arguments);if(this.readyState>cXMLHttpRequest.UNSENT)
+this._aborted=true;this._object.abort();fCleanTransport(this);this.readyState=cXMLHttpRequest.UNSENT;delete this._data;};cXMLHttpRequest.prototype.getAllResponseHeaders=function(){return this._object.getAllResponseHeaders();};cXMLHttpRequest.prototype.getResponseHeader=function(sName){return this._object.getResponseHeader(sName);};cXMLHttpRequest.prototype.setRequestHeader=function(sName,sValue){if(!this._headers)
+this._headers={};this._headers[sName]=sValue;return this._object.setRequestHeader(sName,sValue);};cXMLHttpRequest.prototype.addEventListener=function(sName,fHandler,bUseCapture){for(var nIndex=0,oListener;oListener=this._listeners[nIndex];nIndex++)
+if(oListener[0]==sName&&oListener[1]==fHandler&&oListener[2]==bUseCapture)
+return;this._listeners.push([sName,fHandler,bUseCapture]);};cXMLHttpRequest.prototype.removeEventListener=function(sName,fHandler,bUseCapture){for(var nIndex=0,oListener;oListener=this._listeners[nIndex];nIndex++)
+break;if(oListener)
+this._listeners.splice(nIndex,1);};cXMLHttpRequest.prototype.dispatchEvent=function(oEvent){var oEventPseudo={'type':oEvent.type,'target':this,'currentTarget':this,'eventPhase':2,'bubbles':oEvent.bubbles,'cancelable':oEvent.cancelable,'timeStamp':oEvent.timeStamp,'stopPropagation':function(){},'preventDefault':function(){},'initEvent':function(){}};if(oEventPseudo.type=="readystatechange"&&this.onreadystatechange)
+(this.onreadystatechange.handleEvent||this.onreadystatechange).apply(this,[oEventPseudo]);for(var nIndex=0,oListener;oListener=this._listeners[nIndex];nIndex++)
+if(oListener[0]==oEventPseudo.type&&!oListener[2])
+(oListener[1].handleEvent||oListener[1]).apply(this,[oEventPseudo]);};cXMLHttpRequest.prototype.toString=function(){return'['+"object"+' '+"XMLHttpRequest"+']';};cXMLHttpRequest.toString=function(){return'['+"XMLHttpRequest"+']';};function fReadyStateChange(oRequest){if(cXMLHttpRequest.onreadystatechange)
+cXMLHttpRequest.onreadystatechange.apply(oRequest);oRequest.dispatchEvent({'type':"readystatechange",'bubbles':false,'cancelable':false,'timeStamp':new Date+0});};function fGetDocument(oRequest){var oDocument=oRequest.responseXML,sResponse=oRequest.responseText;if(bIE&&sResponse&&oDocument&&!oDocument.documentElement&&oRequest.getResponseHeader("Content-Type").match(/[^\/]+\/[^\+]+\+xml/)){oDocument=new window.ActiveXObject("Microsoft.XMLDOM");oDocument.async=false;oDocument.validateOnParse=false;oDocument.loadXML(sResponse);}
+if(oDocument)
+if((bIE&&oDocument.parseError!=0)||!oDocument.documentElement||(oDocument.documentElement&&oDocument.documentElement.tagName=="parsererror"))
+return null;return oDocument;};function fSynchronizeValues(oRequest){try{oRequest.responseText=oRequest._object.responseText;}catch(e){}
+try{oRequest.responseXML=fGetDocument(oRequest._object);}catch(e){}
+try{oRequest.status=oRequest._object.status;}catch(e){}
+try{oRequest.statusText=oRequest._object.statusText;}catch(e){}};function fCleanTransport(oRequest){oRequest._object.onreadystatechange=new window.Function;};if(!window.Function.prototype.apply){window.Function.prototype.apply=function(oRequest,oArguments){if(!oArguments)
+oArguments=[];oRequest.__func=this;oRequest.__func(oArguments[0],oArguments[1],oArguments[2],oArguments[3],oArguments[4]);delete oRequest.__func;};};OpenLayers.Request.XMLHttpRequest=cXMLHttpRequest;})();OpenLayers.Protocol.HTTP=OpenLayers.Class(OpenLayers.Protocol,{url:null,headers:null,params:null,callback:null,scope:null,readWithPOST:false,wildcarded:false,srsInBBOX:false,initialize:function(options){options=options||{};this.params={};this.headers={};OpenLayers.Protocol.prototype.initialize.apply(this,arguments);if(!this.filterToParams&&OpenLayers.Format.QueryStringFilter){var format=new OpenLayers.Format.QueryStringFilter({wildcarded:this.wildcarded,srsInBBOX:this.srsInBBOX});this.filterToParams=function(filter,params){return format.write(filter,params);}}},destroy:function(){this.params=null;this.headers=null;OpenLayers.Protocol.prototype.destroy.apply(this);},read:function(options){OpenLayers.Protocol.prototype.read.apply(this,arguments);options=options||{};options.par
 ams=OpenLayers.Util.applyDefaults(options.params,this.options.params);options=OpenLayers.Util.applyDefaults(options,this.options);if(options.filter&&this.filterToParams){options.params=this.filterToParams(options.filter,options.params);}
+var readWithPOST=(options.readWithPOST!==undefined)?options.readWithPOST:this.readWithPOST;var resp=new OpenLayers.Protocol.Response({requestType:"read"});if(readWithPOST){resp.priv=OpenLayers.Request.POST({url:options.url,callback:this.createCallback(this.handleRead,resp,options),data:OpenLayers.Util.getParameterString(options.params),headers:{"Content-Type":"application/x-www-form-urlencoded"}});}else{resp.priv=OpenLayers.Request.GET({url:options.url,callback:this.createCallback(this.handleRead,resp,options),params:options.params,headers:options.headers});}
+return resp;},handleRead:function(resp,options){this.handleResponse(resp,options);},create:function(features,options){options=OpenLayers.Util.applyDefaults(options,this.options);var resp=new OpenLayers.Protocol.Response({reqFeatures:features,requestType:"create"});resp.priv=OpenLayers.Request.POST({url:options.url,callback:this.createCallback(this.handleCreate,resp,options),headers:options.headers,data:this.format.write(features)});return resp;},handleCreate:function(resp,options){this.handleResponse(resp,options);},update:function(feature,options){options=options||{};var url=options.url||feature.url||this.options.url+"/"+feature.fid;options=OpenLayers.Util.applyDefaults(options,this.options);var resp=new OpenLayers.Protocol.Response({reqFeatures:feature,requestType:"update"});resp.priv=OpenLayers.Request.PUT({url:url,callback:this.createCallback(this.handleUpdate,resp,options),headers:options.headers,data:this.format.write(feature)});return resp;},handleUpdate:function(resp
 ,options){this.handleResponse(resp,options);},"delete":function(feature,options){options=options||{};var url=options.url||feature.url||this.options.url+"/"+feature.fid;options=OpenLayers.Util.applyDefaults(options,this.options);var resp=new OpenLayers.Protocol.Response({reqFeatures:feature,requestType:"delete"});resp.priv=OpenLayers.Request.DELETE({url:url,callback:this.createCallback(this.handleDelete,resp,options),headers:options.headers});return resp;},handleDelete:function(resp,options){this.handleResponse(resp,options);},handleResponse:function(resp,options){var request=resp.priv;if(options.callback){if(request.status>=200&&request.status<300){if(resp.requestType!="delete"){resp.features=this.parseFeatures(request);}
+resp.code=OpenLayers.Protocol.Response.SUCCESS;}else{resp.code=OpenLayers.Protocol.Response.FAILURE;}
+options.callback.call(options.scope,resp);}},parseFeatures:function(request){var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
+if(!doc||doc.length<=0){return null;}
+return this.format.read(doc);},commit:function(features,options){options=OpenLayers.Util.applyDefaults(options,this.options);var resp=[],nResponses=0;var types={};types[OpenLayers.State.INSERT]=[];types[OpenLayers.State.UPDATE]=[];types[OpenLayers.State.DELETE]=[];var feature,list,requestFeatures=[];for(var i=0,len=features.length;i<len;++i){feature=features[i];list=types[feature.state];if(list){list.push(feature);requestFeatures.push(feature);}}
+var nRequests=(types[OpenLayers.State.INSERT].length>0?1:0)+
+types[OpenLayers.State.UPDATE].length+
+types[OpenLayers.State.DELETE].length;var success=true;var finalResponse=new OpenLayers.Protocol.Response({reqFeatures:requestFeatures});function insertCallback(response){var len=response.features?response.features.length:0;var fids=new Array(len);for(var i=0;i<len;++i){fids[i]=response.features[i].fid;}
+finalResponse.insertIds=fids;callback.apply(this,[response]);}
+function callback(response){this.callUserCallback(response,options);success=success&&response.success();nResponses++;if(nResponses>=nRequests){if(options.callback){finalResponse.code=success?OpenLayers.Protocol.Response.SUCCESS:OpenLayers.Protocol.Response.FAILURE;options.callback.apply(options.scope,[finalResponse]);}}}
+var queue=types[OpenLayers.State.INSERT];if(queue.length>0){resp.push(this.create(queue,OpenLayers.Util.applyDefaults({callback:insertCallback,scope:this},options.create)));}
+queue=types[OpenLayers.State.UPDATE];for(var i=queue.length-1;i>=0;--i){resp.push(this.update(queue[i],OpenLayers.Util.applyDefaults({callback:callback,scope:this},options.update)));}
+queue=types[OpenLayers.State.DELETE];for(var i=queue.length-1;i>=0;--i){resp.push(this["delete"](queue[i],OpenLayers.Util.applyDefaults({callback:callback,scope:this},options["delete"])));}
+return resp;},abort:function(response){if(response){response.priv.abort();}},callUserCallback:function(resp,options){var opt=options[resp.requestType];if(opt&&opt.callback){opt.callback.call(opt.scope,resp);}},CLASS_NAME:"OpenLayers.Protocol.HTTP"});OpenLayers.Geometry.MultiPolygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.Polygon"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Geometry.MultiPolygon"});OpenLayers.Format.GeoJSON=OpenLayers.Class(OpenLayers.Format.JSON,{ignoreExtraDims:false,read:function(json,type,filter){type=(type)?type:"FeatureCollection";var results=null;var obj=null;if(typeof json=="string"){obj=OpenLayers.Format.JSON.prototype.read.apply(this,[json,filter]);}else{obj=json;}
+if(!obj){OpenLayers.Console.error("Bad JSON: "+json);}else if(typeof(obj.type)!="string"){OpenLayers.Console.error("Bad GeoJSON - no type: "+json);}else if(this.isValidType(obj,type)){switch(type){case"Geometry":try{results=this.parseGeometry(obj);}catch(err){OpenLayers.Console.error(err);}
+break;case"Feature":try{results=this.parseFeature(obj);results.type="Feature";}catch(err){OpenLayers.Console.error(err);}
+break;case"FeatureCollection":results=[];switch(obj.type){case"Feature":try{results.push(this.parseFeature(obj));}catch(err){results=null;OpenLayers.Console.error(err);}
+break;case"FeatureCollection":for(var i=0,len=obj.features.length;i<len;++i){try{results.push(this.parseFeature(obj.features[i]));}catch(err){results=null;OpenLayers.Console.error(err);}}
+break;default:try{var geom=this.parseGeometry(obj);results.push(new OpenLayers.Feature.Vector(geom));}catch(err){results=null;OpenLayers.Console.error(err);}}
+break;}}
+return results;},isValidType:function(obj,type){var valid=false;switch(type){case"Geometry":if(OpenLayers.Util.indexOf(["Point","MultiPoint","LineString","MultiLineString","Polygon","MultiPolygon","Box","GeometryCollection"],obj.type)==-1){OpenLayers.Console.error("Unsupported geometry type: "+
+obj.type);}else{valid=true;}
+break;case"FeatureCollection":valid=true;break;default:if(obj.type==type){valid=true;}else{OpenLayers.Console.error("Cannot convert types from "+
+obj.type+" to "+type);}}
+return valid;},parseFeature:function(obj){var feature,geometry,attributes,bbox;attributes=(obj.properties)?obj.properties:{};bbox=(obj.geometry&&obj.geometry.bbox)||obj.bbox;try{geometry=this.parseGeometry(obj.geometry);}catch(err){throw err;}
+feature=new OpenLayers.Feature.Vector(geometry,attributes);if(bbox){feature.bounds=OpenLayers.Bounds.fromArray(bbox);}
+if(obj.id){feature.fid=obj.id;}
+return feature;},parseGeometry:function(obj){if(obj==null){return null;}
+var geometry,collection=false;if(obj.type=="GeometryCollection"){if(!(OpenLayers.Util.isArray(obj.geometries))){throw"GeometryCollection must have geometries array: "+obj;}
+var numGeom=obj.geometries.length;var components=new Array(numGeom);for(var i=0;i<numGeom;++i){components[i]=this.parseGeometry.apply(this,[obj.geometries[i]]);}
+geometry=new OpenLayers.Geometry.Collection(components);collection=true;}else{if(!(OpenLayers.Util.isArray(obj.coordinates))){throw"Geometry must have coordinates array: "+obj;}
+if(!this.parseCoords[obj.type.toLowerCase()]){throw"Unsupported geometry type: "+obj.type;}
+try{geometry=this.parseCoords[obj.type.toLowerCase()].apply(this,[obj.coordinates]);}catch(err){throw err;}}
+if(this.internalProjection&&this.externalProjection&&!collection){geometry.transform(this.externalProjection,this.internalProjection);}
+return geometry;},parseCoords:{"point":function(array){if(this.ignoreExtraDims==false&&array.length!=2){throw"Only 2D points are supported: "+array;}
+return new OpenLayers.Geometry.Point(array[0],array[1]);},"multipoint":function(array){var points=[];var p=null;for(var i=0,len=array.length;i<len;++i){try{p=this.parseCoords["point"].apply(this,[array[i]]);}catch(err){throw err;}
+points.push(p);}
+return new OpenLayers.Geometry.MultiPoint(points);},"linestring":function(array){var points=[];var p=null;for(var i=0,len=array.length;i<len;++i){try{p=this.parseCoords["point"].apply(this,[array[i]]);}catch(err){throw err;}
+points.push(p);}
+return new OpenLayers.Geometry.LineString(points);},"multilinestring":function(array){var lines=[];var l=null;for(var i=0,len=array.length;i<len;++i){try{l=this.parseCoords["linestring"].apply(this,[array[i]]);}catch(err){throw err;}
+lines.push(l);}
+return new OpenLayers.Geometry.MultiLineString(lines);},"polygon":function(array){var rings=[];var r,l;for(var i=0,len=array.length;i<len;++i){try{l=this.parseCoords["linestring"].apply(this,[array[i]]);}catch(err){throw err;}
+r=new OpenLayers.Geometry.LinearRing(l.components);rings.push(r);}
+return new OpenLayers.Geometry.Polygon(rings);},"multipolygon":function(array){var polys=[];var p=null;for(var i=0,len=array.length;i<len;++i){try{p=this.parseCoords["polygon"].apply(this,[array[i]]);}catch(err){throw err;}
+polys.push(p);}
+return new OpenLayers.Geometry.MultiPolygon(polys);},"box":function(array){if(array.length!=2){throw"GeoJSON box coordinates must have 2 elements";}
+return new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing([new OpenLayers.Geometry.Point(array[0][0],array[0][1]),new OpenLayers.Geometry.Point(array[1][0],array[0][1]),new OpenLayers.Geometry.Point(array[1][0],array[1][1]),new OpenLayers.Geometry.Point(array[0][0],array[1][1]),new OpenLayers.Geometry.Point(array[0][0],array[0][1])])]);}},write:function(obj,pretty){var geojson={"type":null};if(OpenLayers.Util.isArray(obj)){geojson.type="FeatureCollection";var numFeatures=obj.length;geojson.features=new Array(numFeatures);for(var i=0;i<numFeatures;++i){var element=obj[i];if(!element instanceof OpenLayers.Feature.Vector){var msg="FeatureCollection only supports collections "+"of features: "+element;throw msg;}
+geojson.features[i]=this.extract.feature.apply(this,[element]);}}else if(obj.CLASS_NAME.indexOf("OpenLayers.Geometry")==0){geojson=this.extract.geometry.apply(this,[obj]);}else if(obj instanceof OpenLayers.Feature.Vector){geojson=this.extract.feature.apply(this,[obj]);if(obj.layer&&obj.layer.projection){geojson.crs=this.createCRSObject(obj);}}
+return OpenLayers.Format.JSON.prototype.write.apply(this,[geojson,pretty]);},createCRSObject:function(object){var proj=object.layer.projection.toString();var crs={};if(proj.match(/epsg:/i)){var code=parseInt(proj.substring(proj.indexOf(":")+1));if(code==4326){crs={"type":"name","properties":{"name":"urn:ogc:def:crs:OGC:1.3:CRS84"}};}else{crs={"type":"name","properties":{"name":"EPSG:"+code}};}}
+return crs;},extract:{'feature':function(feature){var geom=this.extract.geometry.apply(this,[feature.geometry]);var json={"type":"Feature","properties":feature.attributes,"geometry":geom};if(feature.fid!=null){json.id=feature.fid;}
+return json;},'geometry':function(geometry){if(geometry==null){return null;}
+if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
+var geometryType=geometry.CLASS_NAME.split('.')[2];var data=this.extract[geometryType.toLowerCase()].apply(this,[geometry]);var json;if(geometryType=="Collection"){json={"type":"GeometryCollection","geometries":data};}else{json={"type":geometryType,"coordinates":data};}
+return json;},'point':function(point){return[point.x,point.y];},'multipoint':function(multipoint){var array=[];for(var i=0,len=multipoint.components.length;i<len;++i){array.push(this.extract.point.apply(this,[multipoint.components[i]]));}
+return array;},'linestring':function(linestring){var array=[];for(var i=0,len=linestring.components.length;i<len;++i){array.push(this.extract.point.apply(this,[linestring.components[i]]));}
+return array;},'multilinestring':function(multilinestring){var array=[];for(var i=0,len=multilinestring.components.length;i<len;++i){array.push(this.extract.linestring.apply(this,[multilinestring.components[i]]));}
+return array;},'polygon':function(polygon){var array=[];for(var i=0,len=polygon.components.length;i<len;++i){array.push(this.extract.linestring.apply(this,[polygon.components[i]]));}
+return array;},'multipolygon':function(multipolygon){var array=[];for(var i=0,len=multipolygon.components.length;i<len;++i){array.push(this.extract.polygon.apply(this,[multipolygon.components[i]]));}
+return array;},'collection':function(collection){var len=collection.components.length;var array=new Array(len);for(var i=0;i<len;++i){array[i]=this.extract.geometry.apply(this,[collection.components[i]]);}
+return array;}},CLASS_NAME:"OpenLayers.Format.GeoJSON"});OpenLayers.Control.ZoomOut=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){this.map.zoomOut();},CLASS_NAME:"OpenLayers.Control.ZoomOut"});OpenLayers.Lang.en={'unhandledRequest':"Unhandled request return ${statusText}",'Permalink':"Permalink",'Overlays':"Overlays",'Base Layer':"Base Layer",'readNotImplemented':"Read not implemented.",'writeNotImplemented':"Write not implemented.",'noFID':"Can't update a feature for which there is no FID.",'errorLoadingGML':"Error in loading GML file ${url}",'browserNotSupported':"Your browser does not support vector rendering. Currently supported renderers are:\n${renderers}",'componentShouldBe':"addFeatures : component should be an ${geomType}",'getFeatureError':"getFeatureFromEvent called on layer with no renderer. This usually means you "+"destroyed a layer, but not some handler which is associated with it.",'minZoomLevelError':"The minZoom
 Level property is only intended for use "+"with the FixedZoomLevels-descendent layers. That this "+"wfs layer checks for minZoomLevel is a relic of the"+"past. We cannot, however, remove it without possibly "+"breaking OL based applications that may depend on it."+" Therefore we are deprecating it -- the minZoomLevel "+"check below will be removed at 3.0. Please instead "+"use min/max resolution setting as described here: "+"http://trac.openlayers.org/wiki/SettingZoomLevels",'commitSuccess':"WFS Transaction: SUCCESS ${response}",'commitFailed':"WFS Transaction: FAILED ${response}",'googleWarning':"The Google Layer was unable to load correctly.<br><br>"+"To get rid of this message, select a new BaseLayer "+"in the layer switcher in the upper-right corner.<br><br>"+"Most likely, this is because the Google Maps library "+"script was either not included, or does not contain the "+"correct API key for your site.<br><br>"+"Developers: For help getting this working correctly, "+"<a
  href='http://trac.openlayers.org/wiki/Google' "+"target='_blank'>click here</a>",'getLayerWarning':"The ${layerType} Layer was unable to load correctly.<br><br>"+"To get rid of this message, select a new BaseLayer "+"in the layer switcher in the upper-right corner.<br><br>"+"Most likely, this is because the ${layerLib} library "+"script was not correctly included.<br><br>"+"Developers: For help getting this working correctly, "+"<a href='http://trac.openlayers.org/wiki/${layerLib}' "+"target='_blank'>click here</a>",'Scale = 1 : ${scaleDenom}':"Scale = 1 : ${scaleDenom}",'W':'W','E':'E','N':'N','S':'S','Graticule':'Graticule','layerAlreadyAdded':"You tried to add the layer: ${layerName} to the map, but it has already been added",'reprojectDeprecated':"You are using the 'reproject' option "+"on the ${layerName} layer. This option is deprecated: "+"its use was designed to support displaying data over commercial "+"basemaps, but that functionality should now be achieved by usi
 ng "+"Spherical Mercator support. More information is available from "+"http://trac.openlayers.org/wiki/SphericalMercator.",'methodDeprecated':"This method has been deprecated and will be removed in 3.0. "+"Please use ${newMethod} instead.",'boundsAddError':"You must pass both x and y values to the add function.",'lonlatAddError':"You must pass both lon and lat values to the add function.",'pixelAddError':"You must pass both x and y values to the add function.",'unsupportedGeometryType':"Unsupported geometry type: ${geomType}",'filterEvaluateNotImplemented':"evaluate is not implemented for this filter type.",'proxyNeeded':"You probably need to set OpenLayers.ProxyHost to access ${url}."+"See http://trac.osgeo.org/openlayers/wiki/FrequentlyAskedQuestions#ProxyHost",'end':''};OpenLayers.Control.ArgParser=OpenLayers.Class(OpenLayers.Control,{center:null,zoom:null,layers:null,displayProjection:null,getParameters:function(url){url=url||window.location.href;var parameters=OpenLaye
 rs.Util.getParameters(url);var index=url.indexOf('#');if(index>0){url='?'+url.substring(index+1,url.length);OpenLayers.Util.extend(parameters,OpenLayers.Util.getParameters(url));}
+return parameters;},setMap:function(map){OpenLayers.Control.prototype.setMap.apply(this,arguments);for(var i=0,len=this.map.controls.length;i<len;i++){var control=this.map.controls[i];if((control!=this)&&(control.CLASS_NAME=="OpenLayers.Control.ArgParser")){if(control.displayProjection!=this.displayProjection){this.displayProjection=control.displayProjection;}
+break;}}
+if(i==this.map.controls.length){var args=this.getParameters();if(args.layers){this.layers=args.layers;this.map.events.register('addlayer',this,this.configureLayers);this.configureLayers();}
+if(args.lat&&args.lon){this.center=new OpenLayers.LonLat(parseFloat(args.lon),parseFloat(args.lat));if(args.zoom){this.zoom=parseInt(args.zoom);}
+this.map.events.register('changebaselayer',this,this.setCenter);this.setCenter();}}},setCenter:function(){if(this.map.baseLayer){this.map.events.unregister('changebaselayer',this,this.setCenter);if(this.displayProjection){this.center.transform(this.displayProjection,this.map.getProjectionObject());}
+this.map.setCenter(this.center,this.zoom);}},configureLayers:function(){if(this.layers.length==this.map.layers.length){this.map.events.unregister('addlayer',this,this.configureLayers);for(var i=0,len=this.layers.length;i<len;i++){var layer=this.map.layers[i];var c=this.layers.charAt(i);if(c=="B"){this.map.setBaseLayer(layer);}else if((c=="T")||(c=="F")){layer.setVisibility(c=="T");}}}},CLASS_NAME:"OpenLayers.Control.ArgParser"});OpenLayers.Control.Permalink=OpenLayers.Class(OpenLayers.Control,{argParserClass:OpenLayers.Control.ArgParser,element:null,anchor:false,base:'',displayProjection:null,initialize:function(element,base,options){if(element!==null&&typeof element=='object'&&!OpenLayers.Util.isElement(element)){options=element;this.base=document.location.href;OpenLayers.Control.prototype.initialize.apply(this,[options]);if(this.element!=null){this.element=OpenLayers.Util.getElement(this.element);}}
+else{OpenLayers.Control.prototype.initialize.apply(this,[options]);this.element=OpenLayers.Util.getElement(element);this.base=base||document.location.href;}},destroy:function(){if(this.element.parentNode==this.div){this.div.removeChild(this.element);}
+this.element=null;this.map.events.unregister('moveend',this,this.updateLink);OpenLayers.Control.prototype.destroy.apply(this,arguments);},setMap:function(map){OpenLayers.Control.prototype.setMap.apply(this,arguments);for(var i=0,len=this.map.controls.length;i<len;i++){var control=this.map.controls[i];if(control.CLASS_NAME==this.argParserClass.CLASS_NAME){if(control.displayProjection!=this.displayProjection){this.displayProjection=control.displayProjection;}
+break;}}
+if(i==this.map.controls.length){this.map.addControl(new this.argParserClass({'displayProjection':this.displayProjection}));}},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.element&&!this.anchor){this.element=document.createElement("a");this.element.innerHTML=OpenLayers.i18n("Permalink");this.element.href="";this.div.appendChild(this.element);}
+this.map.events.on({'moveend':this.updateLink,'changelayer':this.updateLink,'changebaselayer':this.updateLink,scope:this});this.updateLink();return this.div;},updateLink:function(){var separator=this.anchor?'#':'?';var href=this.base;if(href.indexOf(separator)!=-1){href=href.substring(0,href.indexOf(separator));}
+href+=separator+OpenLayers.Util.getParameterString(this.createParams());if(this.anchor&&!this.element){window.location.href=href;}
+else{this.element.href=href;}},createParams:function(center,zoom,layers){center=center||this.map.getCenter();var params=OpenLayers.Util.getParameters(this.base);if(center){params.zoom=zoom||this.map.getZoom();var lat=center.lat;var lon=center.lon;if(this.displayProjection){var mapPosition=OpenLayers.Projection.transform({x:lon,y:lat},this.map.getProjectionObject(),this.displayProjection);lon=mapPosition.x;lat=mapPosition.y;}
+params.lat=Math.round(lat*100000)/100000;params.lon=Math.round(lon*100000)/100000;layers=layers||this.map.layers;params.layers='';for(var i=0,len=layers.length;i<len;i++){var layer=layers[i];if(layer.isBaseLayer){params.layers+=(layer==this.map.baseLayer)?"B":"0";}else{params.layers+=(layer.getVisibility())?"T":"F";}}}
+return params;},CLASS_NAME:"OpenLayers.Control.Permalink"});OpenLayers.Layer.TMS=OpenLayers.Class(OpenLayers.Layer.Grid,{serviceVersion:"1.0.0",layername:null,type:null,isBaseLayer:true,tileOrigin:null,serverResolutions:null,zoomOffset:0,initialize:function(name,url,options){var newArguments=[];newArguments.push(name,url,{},options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.TMS(this.name,this.url,this.getOptions());}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var res=this.map.getResolution();var x=Math.round((bounds.left-this.tileOrigin.lon)/(res*this.tileSize.w));var y=Math.round((bounds.bottom-this.tileOrigin.lat)/(res*this.tileSize.h));var z=this.serverResolutions!=null?OpenLayers.Util.indexOf(this.serverResolutions,res):this.map.getZoom()+this.zoomOffset;var path=this.serviceVersion+"/"+this.layername+"/"+z+"/"+x+"/"+y+"."+this.type;var url=this.url;if(OpenLayers.Util.isArray(url)){url=this.selectUrl(path,url);}
+return url+path;},setMap:function(map){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.map.maxExtent.left,this.map.maxExtent.bottom);}},CLASS_NAME:"OpenLayers.Layer.TMS"});OpenLayers.Control.SelectFeature=OpenLayers.Class(OpenLayers.Control,{EVENT_TYPES:["beforefeaturehighlighted","featurehighlighted","featureunhighlighted"],multipleKey:null,toggleKey:null,multiple:false,clickout:true,toggle:false,hover:false,highlightOnly:false,box:false,onBeforeSelect:function(){},onSelect:function(){},onUnselect:function(){},scope:null,geometryTypes:null,layer:null,layers:null,callbacks:null,selectStyle:null,renderIntent:"select",handlers:null,initialize:function(layers,options){this.EVENT_TYPES=OpenLayers.Control.SelectFeature.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);OpenLayers.Control.prototype.initialize.apply(this,[options]);if(this.scope===null){this.scope=this;}
+this.initLayer(layers);var callbacks={click:this.clickFeature,clickout:this.clickoutFeature};if(this.hover){callbacks.over=this.overFeature;callbacks.out=this.outFeature;}
+this.callbacks=OpenLayers.Util.extend(callbacks,this.callbacks);this.handlers={feature:new OpenLayers.Handler.Feature(this,this.layer,this.callbacks,{geometryTypes:this.geometryTypes})};if(this.box){this.handlers.box=new OpenLayers.Handler.Box(this,{done:this.selectBox},{boxDivClassName:"olHandlerBoxSelectFeature"});}},initLayer:function(layers){if(OpenLayers.Util.isArray(layers)){this.layers=layers;this.layer=new OpenLayers.Layer.Vector.RootContainer(this.id+"_container",{layers:layers});}else{this.layer=layers;}},destroy:function(){if(this.active&&this.layers){this.map.removeLayer(this.layer);}
+OpenLayers.Control.prototype.destroy.apply(this,arguments);if(this.layers){this.layer.destroy();}},activate:function(){if(!this.active){if(this.layers){this.map.addLayer(this.layer);}
+this.handlers.feature.activate();if(this.box&&this.handlers.box){this.handlers.box.activate();}}
+return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){if(this.active){this.handlers.feature.deactivate();if(this.handlers.box){this.handlers.box.deactivate();}
+if(this.layers){this.map.removeLayer(this.layer);}}
+return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},unselectAll:function(options){var layers=this.layers||[this.layer];var layer,feature;for(var l=0;l<layers.length;++l){layer=layers[l];for(var i=layer.selectedFeatures.length-1;i>=0;--i){feature=layer.selectedFeatures[i];if(!options||options.except!=feature){this.unselect(feature);}}}},clickFeature:function(feature){if(!this.hover){var selected=(OpenLayers.Util.indexOf(feature.layer.selectedFeatures,feature)>-1);if(selected){if(this.toggleSelect()){this.unselect(feature);}else if(!this.multipleSelect()){this.unselectAll({except:feature});}}else{if(!this.multipleSelect()){this.unselectAll({except:feature});}
+this.select(feature);}}},multipleSelect:function(){return this.multiple||(this.handlers.feature.evt&&this.handlers.feature.evt[this.multipleKey]);},toggleSelect:function(){return this.toggle||(this.handlers.feature.evt&&this.handlers.feature.evt[this.toggleKey]);},clickoutFeature:function(feature){if(!this.hover&&this.clickout){this.unselectAll();}},overFeature:function(feature){var layer=feature.layer;if(this.hover){if(this.highlightOnly){this.highlight(feature);}else if(OpenLayers.Util.indexOf(layer.selectedFeatures,feature)==-1){this.select(feature);}}},outFeature:function(feature){if(this.hover){if(this.highlightOnly){if(feature._lastHighlighter==this.id){if(feature._prevHighlighter&&feature._prevHighlighter!=this.id){delete feature._lastHighlighter;var control=this.map.getControl(feature._prevHighlighter);if(control){control.highlight(feature);}}else{this.unhighlight(feature);}}}else{this.unselect(feature);}}},highlight:function(feature){var layer=feature.layer;var cont
 =this.events.triggerEvent("beforefeaturehighlighted",{feature:feature});if(cont!==false){feature._prevHighlighter=feature._lastHighlighter;feature._lastHighlighter=this.id;var style=this.selectStyle||this.renderIntent;layer.drawFeature(feature,style);this.events.triggerEvent("featurehighlighted",{feature:feature});}},unhighlight:function(feature){var layer=feature.layer;if(feature._prevHighlighter==undefined){delete feature._lastHighlighter;}else if(feature._prevHighlighter==this.id){delete feature._prevHighlighter;}else{feature._lastHighlighter=feature._prevHighlighter;delete feature._prevHighlighter;}
+layer.drawFeature(feature,feature.style||feature.layer.style||"default");this.events.triggerEvent("featureunhighlighted",{feature:feature});},select:function(feature){var cont=this.onBeforeSelect.call(this.scope,feature);var layer=feature.layer;if(cont!==false){cont=layer.events.triggerEvent("beforefeatureselected",{feature:feature});if(cont!==false){layer.selectedFeatures.push(feature);this.highlight(feature);if(!this.handlers.feature.lastFeature){this.handlers.feature.lastFeature=layer.selectedFeatures[0];}
+layer.events.triggerEvent("featureselected",{feature:feature});this.onSelect.call(this.scope,feature);}}},unselect:function(feature){var layer=feature.layer;this.unhighlight(feature);OpenLayers.Util.removeItem(layer.selectedFeatures,feature);layer.events.triggerEvent("featureunselected",{feature:feature});this.onUnselect.call(this.scope,feature);},selectBox:function(position){if(position instanceof OpenLayers.Bounds){var minXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.left,position.bottom));var maxXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.right,position.top));var bounds=new OpenLayers.Bounds(minXY.lon,minXY.lat,maxXY.lon,maxXY.lat);if(!this.multipleSelect()){this.unselectAll();}
+var prevMultiple=this.multiple;this.multiple=true;var layers=this.layers||[this.layer];var layer;for(var l=0;l<layers.length;++l){layer=layers[l];for(var i=0,len=layer.features.length;i<len;++i){var feature=layer.features[i];if(!feature.getVisibility()){continue;}
+if(this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)>-1){if(bounds.toGeometry().intersects(feature.geometry)){if(OpenLayers.Util.indexOf(layer.selectedFeatures,feature)==-1){this.select(feature);}}}}}
+this.multiple=prevMultiple;}},setMap:function(map){this.handlers.feature.setMap(map);if(this.box){this.handlers.box.setMap(map);}
+OpenLayers.Control.prototype.setMap.apply(this,arguments);},setLayer:function(layers){var isActive=this.active;this.unselectAll();this.deactivate();if(this.layers){this.layer.destroy();this.layers=null;}
+this.initLayer(layers);this.handlers.feature.layer=this.layer;if(isActive){this.activate();}},CLASS_NAME:"OpenLayers.Control.SelectFeature"});OpenLayers.Layer.SphericalMercator={getExtent:function(){var extent=null;if(this.sphericalMercator){extent=this.map.calculateBounds();}else{extent=OpenLayers.Layer.FixedZoomLevels.prototype.getExtent.apply(this);}
+return extent;},getLonLatFromViewPortPx:function(viewPortPx){return OpenLayers.Layer.prototype.getLonLatFromViewPortPx.apply(this,arguments);},getViewPortPxFromLonLat:function(lonlat){return OpenLayers.Layer.prototype.getViewPortPxFromLonLat.apply(this,arguments);},initMercatorParameters:function(){this.RESOLUTIONS=[];var maxResolution=156543.03390625;for(var zoom=0;zoom<=this.MAX_ZOOM_LEVEL;++zoom){this.RESOLUTIONS[zoom]=maxResolution/Math.pow(2,zoom);}
+this.units="m";this.projection=this.projection||"EPSG:900913";},forwardMercator:function(lon,lat){var x=lon*20037508.34/180;var y=Math.log(Math.tan((90+lat)*Math.PI/360))/(Math.PI/180);y=y*20037508.34/180;return new OpenLayers.LonLat(x,y);},inverseMercator:function(x,y){var lon=(x/20037508.34)*180;var lat=(y/20037508.34)*180;lat=180/Math.PI*(2*Math.atan(Math.exp(lat*Math.PI/180))-Math.PI/2);return new OpenLayers.LonLat(lon,lat);},projectForward:function(point){var lonlat=OpenLayers.Layer.SphericalMercator.forwardMercator(point.x,point.y);point.x=lonlat.lon;point.y=lonlat.lat;return point;},projectInverse:function(point){var lonlat=OpenLayers.Layer.SphericalMercator.inverseMercator(point.x,point.y);point.x=lonlat.lon;point.y=lonlat.lat;return point;}};(function(){var codes=["EPSG:900913","EPSG:3857","EPSG:102113","EPSG:102100"];var add=OpenLayers.Projection.addTransform;var merc=OpenLayers.Layer.SphericalMercator;var same=OpenLayers.Projection.nullTransform;var i,len,code,oth
 er,j;for(i=0,len=codes.length;i<len;++i){code=codes[i];add("EPSG:4326",code,merc.projectForward);add(code,"EPSG:4326",merc.projectInverse);for(j=i+1;j<len;++j){other=codes[j];add(code,other,same);add(other,code,same);}}})();OpenLayers.Control.PanZoom=OpenLayers.Class(OpenLayers.Control,{slideFactor:50,slideRatio:null,buttons:null,position:null,initialize:function(options){this.position=new OpenLayers.Pixel(OpenLayers.Control.PanZoom.X,OpenLayers.Control.PanZoom.Y);OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.removeButtons();this.buttons=null;this.position=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(px){OpenLayers.Control.prototype.draw.apply(this,arguments);px=this.position;this.buttons=[];var sz=new OpenLayers.Size(18,18);var centered=new OpenLayers.Pixel(px.x+sz.w/2,px.y);this._addButton("panup","north-mini.png",centered,sz);px.y=centered.y+sz.h;this._addButton("panleft","west-mini.png",px,sz);t
 his._addButton("panright","east-mini.png",px.add(sz.w,0),sz);this._addButton("pandown","south-mini.png",centered.add(0,sz.h*2),sz);this._addButton("zoomin","zoom-plus-mini.png",centered.add(0,sz.h*3+5),sz);this._addButton("zoomworld","zoom-world-mini.png",centered.add(0,sz.h*4+5),sz);this._addButton("zoomout","zoom-minus-mini.png",centered.add(0,sz.h*5+5),sz);return this.div;},_addButton:function(id,img,xy,sz){var imgLocation=OpenLayers.Util.getImagesLocation()+img;var btn=OpenLayers.Util.createAlphaImageDiv(this.id+"_"+id,xy,sz,imgLocation,"absolute");btn.style.cursor="pointer";this.div.appendChild(btn);OpenLayers.Event.observe(btn,"mousedown",OpenLayers.Function.bindAsEventListener(this.buttonDown,btn));OpenLayers.Event.observe(btn,"dblclick",OpenLayers.Function.bindAsEventListener(this.doubleClick,btn));OpenLayers.Event.observe(btn,"click",OpenLayers.Function.bindAsEventListener(this.doubleClick,btn));btn.action=id;btn.map=this.map;if(!this.slideRatio){var slideFactorPixe
 ls=this.slideFactor;var getSlideFactor=function(){return slideFactorPixels;};}else{var slideRatio=this.slideRatio;var getSlideFactor=function(dim){return this.map.getSize()[dim]*slideRatio;};}
+btn.getSlideFactor=getSlideFactor;this.buttons.push(btn);return btn;},_removeButton:function(btn){OpenLayers.Event.stopObservingElement(btn);btn.map=null;btn.getSlideFactor=null;this.div.removeChild(btn);OpenLayers.Util.removeItem(this.buttons,btn);},removeButtons:function(){for(var i=this.buttons.length-1;i>=0;--i){this._removeButton(this.buttons[i]);}},doubleClick:function(evt){OpenLayers.Event.stop(evt);return false;},buttonDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
+switch(this.action){case"panup":this.map.pan(0,-this.getSlideFactor("h"));break;case"pandown":this.map.pan(0,this.getSlideFactor("h"));break;case"panleft":this.map.pan(-this.getSlideFactor("w"),0);break;case"panright":this.map.pan(this.getSlideFactor("w"),0);break;case"zoomin":this.map.zoomIn();break;case"zoomout":this.map.zoomOut();break;case"zoomworld":this.map.zoomToMaxExtent();break;}
+OpenLayers.Event.stop(evt);},CLASS_NAME:"OpenLayers.Control.PanZoom"});OpenLayers.Control.PanZoom.X=4;OpenLayers.Control.PanZoom.Y=4;OpenLayers.Handler.Keyboard=OpenLayers.Class(OpenLayers.Handler,{KEY_EVENTS:["keydown","keyup"],eventListener:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.eventListener=OpenLayers.Function.bindAsEventListener(this.handleKeyEvent,this);},destroy:function(){this.deactivate();this.eventListener=null;OpenLayers.Handler.prototype.destroy.apply(this,arguments);},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){for(var i=0,len=this.KEY_EVENTS.length;i<len;i++){OpenLayers.Event.observe(document,this.KEY_EVENTS[i],this.eventListener);}
+return true;}else{return false;}},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){for(var i=0,len=this.KEY_EVENTS.length;i<len;i++){OpenLayers.Event.stopObserving(document,this.KEY_EVENTS[i],this.eventListener);}
+deactivated=true;}
+return deactivated;},handleKeyEvent:function(evt){if(this.checkModifiers(evt)){this.callback(evt.type,[evt]);}},CLASS_NAME:"OpenLayers.Handler.Keyboard"});OpenLayers.Control.KeyboardDefaults=OpenLayers.Class(OpenLayers.Control,{autoActivate:true,slideFactor:75,draw:function(){this.handler=new OpenLayers.Handler.Keyboard(this,{"keydown":this.defaultKeyPress});},defaultKeyPress:function(evt){switch(evt.keyCode){case OpenLayers.Event.KEY_LEFT:this.map.pan(-this.slideFactor,0);break;case OpenLayers.Event.KEY_RIGHT:this.map.pan(this.slideFactor,0);break;case OpenLayers.Event.KEY_UP:this.map.pan(0,-this.slideFactor);break;case OpenLayers.Event.KEY_DOWN:this.map.pan(0,this.slideFactor);break;case 33:var size=this.map.getSize();this.map.pan(0,-0.75*size.h);break;case 34:var size=this.map.getSize();this.map.pan(0,0.75*size.h);break;case 35:var size=this.map.getSize();this.map.pan(0.75*size.w,0);break;case 36:var size=this.map.getSize();this.map.pan(-0.75*size.w,0);break;case 43:case
 61:case 187:case 107:this.map.zoomIn();break;case 45:case 109:case 189:case 95:this.map.zoomOut();break;}},CLASS_NAME:"OpenLayers.Control.KeyboardDefaults"});OpenLayers.Format.OSM=OpenLayers.Class(OpenLayers.Format.XML,{checkTags:false,interestingTagsExclude:null,areaTags:null,initialize:function(options){var layer_defaults={'interestingTagsExclude':['source','source_ref','source:ref','history','attribution','created_by'],'areaTags':['area','building','leisure','tourism','ruins','historic','landuse','military','natural','sport']};layer_defaults=OpenLayers.Util.extend(layer_defaults,options);var interesting={};for(var i=0;i<layer_defaults.interestingTagsExclude.length;i++){interesting[layer_defaults.interestingTagsExclude[i]]=true;}
+layer_defaults.interestingTagsExclude=interesting;var area={};for(var i=0;i<layer_defaults.areaTags.length;i++){area[layer_defaults.areaTags[i]]=true;}
+layer_defaults.areaTags=area;this.externalProjection=new OpenLayers.Projection("EPSG:4326");OpenLayers.Format.XML.prototype.initialize.apply(this,[layer_defaults]);},read:function(doc){if(typeof doc=="string"){doc=OpenLayers.Format.XML.prototype.read.apply(this,[doc]);}
+var nodes=this.getNodes(doc);var ways=this.getWays(doc);var feat_list=new Array(ways.length);for(var i=0;i<ways.length;i++){var point_list=new Array(ways[i].nodes.length);var poly=this.isWayArea(ways[i])?1:0;for(var j=0;j<ways[i].nodes.length;j++){var node=nodes[ways[i].nodes[j]];var point=new OpenLayers.Geometry.Point(node.lon,node.lat);point.osm_id=parseInt(ways[i].nodes[j]);point_list[j]=point;node.used=true;}
+var geometry=null;if(poly){geometry=new OpenLayers.Geometry.Polygon(new OpenLayers.Geometry.LinearRing(point_list));}else{geometry=new OpenLayers.Geometry.LineString(point_list);}
+if(this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}
+var feat=new OpenLayers.Feature.Vector(geometry,ways[i].tags);feat.osm_id=parseInt(ways[i].id);feat.fid="way."+feat.osm_id;feat_list[i]=feat;}
+for(var node_id in nodes){var node=nodes[node_id];if(!node.used||this.checkTags){var tags=null;if(this.checkTags){var result=this.getTags(node.node,true);if(node.used&&!result[1]){continue;}
+tags=result[0];}else{tags=this.getTags(node.node);}
+var feat=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(node['lon'],node['lat']),tags);if(this.internalProjection&&this.externalProjection){feat.geometry.transform(this.externalProjection,this.internalProjection);}
+feat.osm_id=parseInt(node_id);feat.fid="node."+feat.osm_id;feat_list.push(feat);}
+node.node=null;}
+return feat_list;},getNodes:function(doc){var node_list=doc.getElementsByTagName("node");var nodes={};for(var i=0;i<node_list.length;i++){var node=node_list[i];var id=node.getAttribute("id");nodes[id]={'lat':node.getAttribute("lat"),'lon':node.getAttribute("lon"),'node':node};}
+return nodes;},getWays:function(doc){var way_list=doc.getElementsByTagName("way");var return_ways=[];for(var i=0;i<way_list.length;i++){var way=way_list[i];var way_object={id:way.getAttribute("id")};way_object.tags=this.getTags(way);var node_list=way.getElementsByTagName("nd");way_object.nodes=new Array(node_list.length);for(var j=0;j<node_list.length;j++){way_object.nodes[j]=node_list[j].getAttribute("ref");}
+return_ways.push(way_object);}
+return return_ways;},getTags:function(dom_node,interesting_tags){var tag_list=dom_node.getElementsByTagName("tag");var tags={};var interesting=false;for(var j=0;j<tag_list.length;j++){var key=tag_list[j].getAttribute("k");tags[key]=tag_list[j].getAttribute("v");if(interesting_tags){if(!this.interestingTagsExclude[key]){interesting=true;}}}
+return interesting_tags?[tags,interesting]:tags;},isWayArea:function(way){var poly_shaped=false;var poly_tags=false;if(way.nodes[0]==way.nodes[way.nodes.length-1]){poly_shaped=true;}
+if(this.checkTags){for(var key in way.tags){if(this.areaTags[key]){poly_tags=true;break;}}}
+return poly_shaped&&(this.checkTags?poly_tags:true);},write:function(features){if(!(OpenLayers.Util.isArray(features))){features=[features];}
+this.osm_id=1;this.created_nodes={};var root_node=this.createElementNS(null,"osm");root_node.setAttribute("version","0.5");root_node.setAttribute("generator","OpenLayers "+OpenLayers.VERSION_NUMBER);for(var i=features.length-1;i>=0;i--){var nodes=this.createFeatureNodes(features[i]);for(var j=0;j<nodes.length;j++){root_node.appendChild(nodes[j]);}}
+return OpenLayers.Format.XML.prototype.write.apply(this,[root_node]);},createFeatureNodes:function(feature){var nodes=[];var className=feature.geometry.CLASS_NAME;var type=className.substring(className.lastIndexOf(".")+1);type=type.toLowerCase();var builder=this.createXML[type];if(builder){nodes=builder.apply(this,[feature]);}
+return nodes;},createXML:{'point':function(point){var id=null;var geometry=point.geometry?point.geometry:point;if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
+var already_exists=false;if(point.osm_id){id=point.osm_id;if(this.created_nodes[id]){already_exists=true;}}else{id=-this.osm_id;this.osm_id++;}
+if(already_exists){node=this.created_nodes[id];}else{var node=this.createElementNS(null,"node");}
+this.created_nodes[id]=node;node.setAttribute("id",id);node.setAttribute("lon",geometry.x);node.setAttribute("lat",geometry.y);if(point.attributes){this.serializeTags(point,node);}
+this.setState(point,node);return already_exists?[]:[node];},linestring:function(feature){var id;var nodes=[];var geometry=feature.geometry;if(feature.osm_id){id=feature.osm_id;}else{id=-this.osm_id;this.osm_id++;}
+var way=this.createElementNS(null,"way");way.setAttribute("id",id);for(var i=0;i<geometry.components.length;i++){var node=this.createXML['point'].apply(this,[geometry.components[i]]);if(node.length){node=node[0];var node_ref=node.getAttribute("id");nodes.push(node);}else{node_ref=geometry.components[i].osm_id;node=this.created_nodes[node_ref];}
+this.setState(feature,node);var nd_dom=this.createElementNS(null,"nd");nd_dom.setAttribute("ref",node_ref);way.appendChild(nd_dom);}
+this.serializeTags(feature,way);nodes.push(way);return nodes;},polygon:function(feature){var attrs=OpenLayers.Util.extend({'area':'yes'},feature.attributes);var feat=new OpenLayers.Feature.Vector(feature.geometry.components[0],attrs);feat.osm_id=feature.osm_id;return this.createXML['linestring'].apply(this,[feat]);}},serializeTags:function(feature,node){for(var key in feature.attributes){var tag=this.createElementNS(null,"tag");tag.setAttribute("k",key);tag.setAttribute("v",feature.attributes[key]);node.appendChild(tag);}},setState:function(feature,node){if(feature.state){var state=null;switch(feature.state){case OpenLayers.State.UPDATE:state="modify";case OpenLayers.State.DELETE:state="delete";}
+if(state){node.setAttribute("action",state);}}},CLASS_NAME:"OpenLayers.Format.OSM"});
\ No newline at end of file
Added: grass-web/trunk/user_map/lib/ext-all.js
--- grass-web/trunk/user_map/lib/ext-all.js	                        (rev 0)
+++ grass-web/trunk/user_map/lib/ext-all.js	2012-04-17 13:42:26 UTC (rev 51456)
@@ -0,0 +1,11 @@
+ * Ext JS Library 3.4.0
+ * Copyright(c) 2006-2011 Sencha Inc.
+ * licensing at sencha.com
+ * http://www.sencha.com/license
+(function(){var h=Ext.util,j=Ext.each,g=true,i=false;h.Observable=function(){var k=this,l=k.events;if(k.listeners){k.on(k.listeners);delete k.listeners}k.events=l||{}};h.Observable.prototype={filterOptRe:/^(?:scope|delay|buffer|single)$/,fireEvent:function(){var k=Array.prototype.slice.call(arguments,0),m=k[0].toLowerCase(),n=this,l=g,p=n.events[m],s,o,r;if(n.eventsSuspended===g){if(o=n.eventQueue){o.push(k)}}else{if(typeof p=="object"){if(p.bubble){if(p.fire.apply(p,k.slice(1))===i){return i}r=n.getBubbleTarget&&n.getBubbleTarget();if(r&&r.enableBubble){s=r.events[m];if(!s||typeof s!="object"||!s.bubble){r.enableBubble(m)}return r.fireEvent.apply(r,k)}}else{k.shift();l=p.fire.apply(p,k)}}}return l},addListener:function(k,m,l,r){var n=this,q,s,p;if(typeof k=="object"){r=k;for(q in r){s=r[q];if(!n.filterOptRe.test(q)){n.addListener(q,s.fn||s,s.scope||r.scope,s.fn?s:r)}}}else{k=k.toLowerCase();p=n.events[k]||g;if(typeof p=="boolean"){n.events[k]=p=new h.Event(n,k)}p.addListene
 r(m,l,typeof r=="object"?r:{})}},removeListener:function(k,m,l){var n=this.events[k.toLowerCase()];if(typeof n=="object"){n.removeListener(m,l)}},purgeListeners:function(){var m=this.events,k,l;for(l in m){k=m[l];if(typeof k=="object"){k.clearListeners()}}},addEvents:function(n){var m=this;m.events=m.events||{};if(typeof n=="string"){var k=arguments,l=k.length;while(l--){m.events[k[l]]=m.events[k[l]]||g}}else{Ext.applyIf(m.events,n)}},hasListener:function(k){var l=this.events[k.toLowerCase()];return typeof l=="object"&&l.listeners.length>0},suspendEvents:function(k){this.eventsSuspended=g;if(k&&!this.eventQueue){this.eventQueue=[]}},resumeEvents:function(){var k=this,l=k.eventQueue||[];k.eventsSuspended=i;delete k.eventQueue;j(l,function(m){k.fireEvent.apply(k,m)})}};var d=h.Observable.prototype;d.on=d.addListener;d.un=d.removeListener;h.Observable.releaseCapture=function(k){k.fireEvent=d.fireEvent};function e(l,m,k){return function(){if(m.target==arguments[0]){l.apply(k,Arr
 ay.prototype.slice.call(arguments,0))}}}function b(n,p,k,m){k.task=new h.DelayedTask();return function(){k.task.delay(p.buffer,n,m,Array.prototype.slice.call(arguments,0))}}function c(m,n,l,k){return function(){n.removeListener(l,k);return m.apply(k,arguments)}}function a(n,p,k,m){return function(){var l=new h.DelayedTask(),o=Array.prototype.slice.call(arguments,0);if(!k.tasks){k.tasks=[]}k.tasks.push(l);l.delay(p.delay||10,function(){k.tasks.remove(l);n.apply(m,o)},m)}}h.Event=function(l,k){this.name=k;this.obj=l;this.listeners=[]};h.Event.prototype={addListener:function(o,n,m){var p=this,k;n=n||p.obj;if(!p.isListening(o,n)){k=p.createListener(o,n,m);if(p.firing){p.listeners=p.listeners.slice(0)}p.listeners.push(k)}},createListener:function(p,n,q){q=q||{};n=n||this.obj;var k={fn:p,scope:n,options:q},m=p;if(q.target){m=e(m,q,n)}if(q.delay){m=a(m,q,k,n)}if(q.single){m=c(m,this,p,n)}if(q.buffer){m=b(m,q,k,n)}k.fireFn=m;return k},findListener:function(o,n){var p=this.listeners,
 m=p.length,k;n=n||this.obj;while(m--){k=p[m];if(k){if(k.fn==o&&k.scope==n){return m}}}return -1},isListening:function(l,k){return this.findListener(l,k)!=-1},removeListener:function(r,q){var p,m,n,s=this,o=i;if((p=s.findListener(r,q))!=-1){if(s.firing){s.listeners=s.listeners.slice(0)}m=s.listeners[p];if(m.task){m.task.cancel();delete m.task}n=m.tasks&&m.tasks.length;if(n){while(n--){m.tasks[n].cancel()}delete m.tasks}s.listeners.splice(p,1);o=g}return o},clearListeners:function(){var n=this,k=n.listeners,m=k.length;while(m--){n.removeListener(k[m].fn,k[m].scope)}},fire:function(){var q=this,p=q.listeners,k=p.length,o=0,m;if(k>0){q.firing=g;var n=Array.prototype.slice.call(arguments,0);for(;o<k;o++){m=p[o];if(m&&m.fireFn.apply(m.scope||q.obj||window,n)===i){return(q.firing=i)}}}q.firing=i;return g}}})();Ext.DomHelper=function(){var x=null,k=/^(?:br|frame|hr|img|input|link|meta|range|spacer|wbr|area|param|col)$/i,m=/^table|tbody|tr|td$/i,d=/tag|children|cn|html$/i,t=/td|tr|tb
 ody/i,o=/([a-z0-9-]+)\s*:\s*([^;\s]+(?:\s*[^;\s]+)*);?/gi,v=/end/i,r,n="afterbegin",p="afterend",c="beforebegin",q="beforeend",a="<table>",i="</table>",b=a+"<tbody>",j="</tbody>"+i,l=b+"<tr>",w="</tr>"+j;function h(B,D,C,E,A,y){var z=r.insertHtml(E,Ext.getDom(B),u(D));return C?Ext.get(z,true):z}function u(D){var z="",y,C,B,E;if(typeof D=="string"){z=D}else{if(Ext.isArray(D)){for(var A=0;A<D.length;A++){if(D[A]){z+=u(D[A])}}}else{z+="<"+(D.tag=D.tag||"div");for(y in D){C=D[y];if(!d.test(y)){if(typeof C=="object"){z+=" "+y+'="';for(B in C){z+=B+":"+C[B]+";"}z+='"'}else{z+=" "+({cls:"class",htmlFor:"for"}[y]||y)+'="'+C+'"'}}}if(k.test(D.tag)){z+="/>"}else{z+=">";if((E=D.children||D.cn)){z+=u(E)}else{if(D.html){z+=D.html}}z+="</"+D.tag+">"}}}return z}function g(F,C,B,D){x.innerHTML=[C,B,D].join("");var y=-1,A=x,z;while(++y<F){A=A.firstChild}if(z=A.nextSibling){var E=document.createDocumentFragment();while(A){z=A.nextSibling;E.appendChild(A);A=z}A=E}return A}function e(y,z,B,A){v
 ar C,D;x=x||document.createElement("div");if(y=="td"&&(z==n||z==q)||!t.test(y)&&(z==c||z==p)){return}D=z==c?B:z==p?B.nextSibling:z==n?B.firstChild:null;if(z==c||z==p){B=B.parentNode}if(y=="td"||(y=="tr"&&(z==q||z==n))){C=g(4,l,A,w)}else{if((y=="tbody"&&(z==q||z==n))||(y=="tr"&&(z==c||z==p))){C=g(3,b,A,j)}else{C=g(2,a,A,i)}}B.insertBefore(C,D);return C}function s(A){var D=document.createElement("div"),y=document.createDocumentFragment(),z=0,B,C;D.innerHTML=A;C=D.childNodes;B=C.length;for(;z<B;z++){y.appendChild(C[z].cloneNode(true))}return y}r={markup:function(y){return u(y)},applyStyles:function(y,z){if(z){var A;y=Ext.fly(y);if(typeof z=="function"){z=z.call()}if(typeof z=="string"){o.lastIndex=0;while((A=o.exec(z))){y.setStyle(A[1],A[2])}}else{if(typeof z=="object"){y.setStyle(z)}}}},insertHtml:function(D,y,E){var B={},A,F,C,G,H,z;D=D.toLowerCase();B[c]=["BeforeBegin","previousSibling"];B[p]=["AfterEnd","nextSibling"];if(y.insertAdjacentHTML){if(m.test(y.tagName)&&(z=e(y.ta
 gName.toLowerCase(),D,y,E))){return z}B[n]=["AfterBegin","firstChild"];B[q]=["BeforeEnd","lastChild"];if((A=B[D])){y.insertAdjacentHTML(A[0],E);return y[A[1]]}}else{F=y.ownerDocument.createRange();G="setStart"+(v.test(D)?"After":"Before");if(B[D]){F[G](y);if(!F.createContextualFragment){H=s(E)}else{H=F.createContextualFragment(E)}y.parentNode.insertBefore(H,D==c?y:y.nextSibling);return y[(D==c?"previous":"next")+"Sibling"]}else{C=(D==n?"first":"last")+"Child";if(y.firstChild){F[G](y[C]);if(!F.createContextualFragment){H=s(E)}else{H=F.createContextualFragment(E)}if(D==n){y.insertBefore(H,y.firstChild)}else{y.appendChild(H)}}else{y.innerHTML=E}return y[C]}}throw'Illegal insertion point -> "'+D+'"'},insertBefore:function(y,A,z){return h(y,A,z,c)},insertAfter:function(y,A,z){return h(y,A,z,p,"nextSibling")},insertFirst:function(y,A,z){return h(y,A,z,n,"firstChild")},append:function(y,A,z){return h(y,A,z,q,"",true)},overwrite:function(y,A,z){y=Ext.getDom(y);y.innerHTML=u(A);retur
 n z?Ext.get(y.firstChild):y.firstChild},createHtml:u};return r}();Ext.Template=function(h){var j=this,c=arguments,e=[],d;if(Ext.isArray(h)){h=h.join("")}else{if(c.length>1){for(var g=0,b=c.length;g<b;g++){d=c[g];if(typeof d=="object"){Ext.apply(j,d)}else{e.push(d)}}h=e.join("")}}j.html=h;if(j.compiled){j.compile()}};Ext.Template.prototype={re:/\{([\w\-]+)\}/g,applyTemplate:function(a){var b=this;return b.compiled?b.compiled(a):b.html.replace(b.re,function(c,d){return a[d]!==undefined?a[d]:""})},set:function(a,c){var b=this;b.html=a;b.compiled=null;return c?b.compile():b},compile:function(){var me=this,sep=Ext.isGecko?"+":",";function fn(m,name){name="values['"+name+"']";return"'"+sep+"("+name+" == undefined ? '' : "+name+")"+sep+"'"}eval("this.compiled = function(values){ return "+(Ext.isGecko?"'":"['")+me.html.replace(/\\/g,"\\\\").replace(/(\r\n|\n)/g,"\\n").replace(/'/g,"\\'").replace(this.re,fn)+(Ext.isGecko?"';};":"'].join('');};"));return me},insertFirst:function(b,a,c
 ){return this.doInsert("afterBegin",b,a,c)},insertBefore:function(b,a,c){return this.doInsert("beforeBegin",b,a,c)},insertAfter:function(b,a,c){return this.doInsert("afterEnd",b,a,c)},append:function(b,a,c){return this.doInsert("beforeEnd",b,a,c)},doInsert:function(c,e,b,a){e=Ext.getDom(e);var d=Ext.DomHelper.insertHtml(c,e,this.applyTemplate(b));return a?Ext.get(d,true):d},overwrite:function(b,a,c){b=Ext.getDom(b);b.innerHTML=this.applyTemplate(a);return c?Ext.get(b.firstChild,true):b.firstChild}};Ext.Template.prototype.apply=Ext.Template.prototype.applyTemplate;Ext.Template.from=function(b,a){b=Ext.getDom(b);return new Ext.Template(b.value||b.innerHTML,a||"")};Ext.DomQuery=function(){var cache={},simpleCache={},valueCache={},nonSpace=/\S/,trimRe=/^\s+|\s+$/g,tplRe=/\{(\d+)\}/g,modeRe=/^(\s?[\/>+~]\s?|\s|$)/,tagTokenRe=/^(#)?([\w\-\*]+)/,nthRe=/(\d*)n\+?(\d*)/,nthRe2=/\D/,isIE=window.ActiveXObject?true:false,key=30803;eval("var batch = 30803;");function child(parent,index){
 var i=0,n=parent.firstChild;while(n){if(n.nodeType==1){if(++i==index){return n}}n=n.nextSibling}return null}function next(n){while((n=n.nextSibling)&&n.nodeType!=1){}return n}function prev(n){while((n=n.previousSibling)&&n.nodeType!=1){}return n}function children(parent){var n=parent.firstChild,nodeIndex=-1,nextNode;while(n){nextNode=n.nextSibling;if(n.nodeType==3&&!nonSpace.test(n.nodeValue)){parent.removeChild(n)}else{n.nodeIndex=++nodeIndex}n=nextNode}return this}function byClassName(nodeSet,cls){if(!cls){return nodeSet}var result=[],ri=-1;for(var i=0,ci;ci=nodeSet[i];i++){if((" "+ci.className+" ").indexOf(cls)!=-1){result[++ri]=ci}}return result}function attrValue(n,attr){if(!n.tagName&&typeof n.length!="undefined"){n=n[0]}if(!n){return null}if(attr=="for"){return n.htmlFor}if(attr=="class"||attr=="className"){return n.className}return n.getAttribute(attr)||n[attr]}function getNodes(ns,mode,tagName){var result=[],ri=-1,cs;if(!ns){return result}tagName=tagName||"*";if(typ
 eof ns.getElementsByTagName!="undefined"){ns=[ns]}if(!mode){for(var i=0,ni;ni=ns[i];i++){cs=ni.getElementsByTagName(tagName);for(var j=0,ci;ci=cs[j];j++){result[++ri]=ci}}}else{if(mode=="/"||mode==">"){var utag=tagName.toUpperCase();for(var i=0,ni,cn;ni=ns[i];i++){cn=ni.childNodes;for(var j=0,cj;cj=cn[j];j++){if(cj.nodeName==utag||cj.nodeName==tagName||tagName=="*"){result[++ri]=cj}}}}else{if(mode=="+"){var utag=tagName.toUpperCase();for(var i=0,n;n=ns[i];i++){while((n=n.nextSibling)&&n.nodeType!=1){}if(n&&(n.nodeName==utag||n.nodeName==tagName||tagName=="*")){result[++ri]=n}}}else{if(mode=="~"){var utag=tagName.toUpperCase();for(var i=0,n;n=ns[i];i++){while((n=n.nextSibling)){if(n.nodeName==utag||n.nodeName==tagName||tagName=="*"){result[++ri]=n}}}}}}}return result}function concat(a,b){if(b.slice){return a.concat(b)}for(var i=0,l=b.length;i<l;i++){a[a.length]=b[i]}return a}function byTag(cs,tagName){if(cs.tagName||cs==document){cs=[cs]}if(!tagName){return cs}var result=[],r
 i=-1;tagName=tagName.toLowerCase();for(var i=0,ci;ci=cs[i];i++){if(ci.nodeType==1&&ci.tagName.toLowerCase()==tagName){result[++ri]=ci}}return result}function byId(cs,id){if(cs.tagName||cs==document){cs=[cs]}if(!id){return cs}var result=[],ri=-1;for(var i=0,ci;ci=cs[i];i++){if(ci&&ci.id==id){result[++ri]=ci;return result}}return result}function byAttribute(cs,attr,value,op,custom){var result=[],ri=-1,useGetStyle=custom=="{",fn=Ext.DomQuery.operators[op],a,xml,hasXml;for(var i=0,ci;ci=cs[i];i++){if(ci.nodeType!=1){continue}if(!hasXml){xml=Ext.DomQuery.isXml(ci);hasXml=true}if(!xml){if(useGetStyle){a=Ext.DomQuery.getStyle(ci,attr)}else{if(attr=="class"||attr=="className"){a=ci.className}else{if(attr=="for"){a=ci.htmlFor}else{if(attr=="href"){a=ci.getAttribute("href",2)}else{a=ci.getAttribute(attr)}}}}}else{a=ci.getAttribute(attr)}if((fn&&fn(a,value))||(!fn&&a)){result[++ri]=ci}}return result}function byPseudo(cs,name,value){return Ext.DomQuery.pseudos[name](cs,value)}function n
 odupIEXml(cs){var d=++key,r;cs[0].setAttribute("_nodup",d);r=[cs[0]];for(var i=1,len=cs.length;i<len;i++){var c=cs[i];if(!c.getAttribute("_nodup")!=d){c.setAttribute("_nodup",d);r[r.length]=c}}for(var i=0,len=cs.length;i<len;i++){cs[i].removeAttribute("_nodup")}return r}function nodup(cs){if(!cs){return[]}var len=cs.length,c,i,r=cs,cj,ri=-1;if(!len||typeof cs.nodeType!="undefined"||len==1){return cs}if(isIE&&typeof cs[0].selectSingleNode!="undefined"){return nodupIEXml(cs)}var d=++key;cs[0]._nodup=d;for(i=1;c=cs[i];i++){if(c._nodup!=d){c._nodup=d}else{r=[];for(var j=0;j<i;j++){r[++ri]=cs[j]}for(j=i+1;cj=cs[j];j++){if(cj._nodup!=d){cj._nodup=d;r[++ri]=cj}}return r}}return r}function quickDiffIEXml(c1,c2){var d=++key,r=[];for(var i=0,len=c1.length;i<len;i++){c1[i].setAttribute("_qdiff",d)}for(var i=0,len=c2.length;i<len;i++){if(c2[i].getAttribute("_qdiff")!=d){r[r.length]=c2[i]}}for(var i=0,len=c1.length;i<len;i++){c1[i].removeAttribute("_qdiff")}return r}function quickDiff(c1
 ,c2){var len1=c1.length,d=++key,r=[];if(!len1){return c2}if(isIE&&typeof c1[0].selectSingleNode!="undefined"){return quickDiffIEXml(c1,c2)}for(var i=0;i<len1;i++){c1[i]._qdiff=d}for(var i=0,len=c2.length;i<len;i++){if(c2[i]._qdiff!=d){r[r.length]=c2[i]}}return r}function quickId(ns,mode,root,id){if(ns==root){var d=root.ownerDocument||root;return d.getElementById(id)}ns=getNodes(ns,mode,"*");return byId(ns,id)}return{getStyle:function(el,name){return Ext.fly(el).getStyle(name)},compile:function(path,type){type=type||"select";var fn=["var f = function(root){\n var mode; ++batch; var n = root || document;\n"],mode,lastPath,matchers=Ext.DomQuery.matchers,matchersLn=matchers.length,modeMatch,lmode=path.match(modeRe);if(lmode&&lmode[1]){fn[fn.length]='mode="'+lmode[1].replace(trimRe,"")+'";';path=path.replace(lmode[1],"")}while(path.substr(0,1)=="/"){path=path.substr(1)}while(path&&lastPath!=path){lastPath=path;var tokenMatch=path.match(tagTokenRe);if(type=="select"){if(tokenMatch
 ){if(tokenMatch[1]=="#"){fn[fn.length]='n = quickId(n, mode, root, "'+tokenMatch[2]+'");'}else{fn[fn.length]='n = getNodes(n, mode, "'+tokenMatch[2]+'");'}path=path.replace(tokenMatch[0],"")}else{if(path.substr(0,1)!="@"){fn[fn.length]='n = getNodes(n, mode, "*");'}}}else{if(tokenMatch){if(tokenMatch[1]=="#"){fn[fn.length]='n = byId(n, "'+tokenMatch[2]+'");'}else{fn[fn.length]='n = byTag(n, "'+tokenMatch[2]+'");'}path=path.replace(tokenMatch[0],"")}}while(!(modeMatch=path.match(modeRe))){var matched=false;for(var j=0;j<matchersLn;j++){var t=matchers[j];var m=path.match(t.re);if(m){fn[fn.length]=t.select.replace(tplRe,function(x,i){return m[i]});path=path.replace(m[0],"");matched=true;break}}if(!matched){throw'Error parsing selector, parsing failed at "'+path+'"'}}if(modeMatch[1]){fn[fn.length]='mode="'+modeMatch[1].replace(trimRe,"")+'";';path=path.replace(modeMatch[1],"")}}fn[fn.length]="return nodup(n);\n}";eval(fn.join(""));return f},jsSelect:function(path,root,type){root
 =root||document;if(typeof root=="string"){root=document.getElementById(root)}var paths=path.split(","),results=[];for(var i=0,len=paths.length;i<len;i++){var subPath=paths[i].replace(trimRe,"");if(!cache[subPath]){cache[subPath]=Ext.DomQuery.compile(subPath);if(!cache[subPath]){throw subPath+" is not a valid selector"}}var result=cache[subPath](root);if(result&&result!=document){results=results.concat(result)}}if(paths.length>1){return nodup(results)}return results},isXml:function(el){var docEl=(el?el.ownerDocument||el:0).documentElement;return docEl?docEl.nodeName!=="HTML":false},select:document.querySelectorAll?function(path,root,type){root=root||document;if(!Ext.DomQuery.isXml(root)){try{var cs=root.querySelectorAll(path);return Ext.toArray(cs)}catch(ex){}}return Ext.DomQuery.jsSelect.call(this,path,root,type)}:function(path,root,type){return Ext.DomQuery.jsSelect.call(this,path,root,type)},selectNode:function(path,root){return Ext.DomQuery.select(path,root)[0]},selectVal
 ue:function(path,root,defaultValue){path=path.replace(trimRe,"");if(!valueCache[path]){valueCache[path]=Ext.DomQuery.compile(path,"select")}var n=valueCache[path](root),v;n=n[0]?n[0]:n;if(typeof n.normalize=="function"){n.normalize()}v=(n&&n.firstChild?n.firstChild.nodeValue:null);return((v===null||v===undefined||v==="")?defaultValue:v)},selectNumber:function(path,root,defaultValue){var v=Ext.DomQuery.selectValue(path,root,defaultValue||0);return parseFloat(v)},is:function(el,ss){if(typeof el=="string"){el=document.getElementById(el)}var isArray=Ext.isArray(el),result=Ext.DomQuery.filter(isArray?el:[el],ss);return isArray?(result.length==el.length):(result.length>0)},filter:function(els,ss,nonMatches){ss=ss.replace(trimRe,"");if(!simpleCache[ss]){simpleCache[ss]=Ext.DomQuery.compile(ss,"simple")}var result=simpleCache[ss](els);return nonMatches?quickDiff(result,els):result},matchers:[{re:/^\.([\w\-]+)/,select:'n = byClassName(n, " {1} ");'},{re:/^\:([\w\-]+)(?:\(((?:[^\s>\/]
 *|.*?))\))?/,select:'n = byPseudo(n, "{1}", "{2}");'},{re:/^(?:([\[\{])(?:@)?([\w\-]+)\s?(?:(=|.=)\s?(["']?)(.*?)\4)?[\]\}])/,select:'n = byAttribute(n, "{2}", "{5}", "{3}", "{1}");'},{re:/^#([\w\-]+)/,select:'n = byId(n, "{1}");'},{re:/^@([\w\-]+)/,select:'return {firstChild:{nodeValue:attrValue(n, "{1}")}};'}],operators:{"=":function(a,v){return a==v},"!=":function(a,v){return a!=v},"^=":function(a,v){return a&&a.substr(0,v.length)==v},"$=":function(a,v){return a&&a.substr(a.length-v.length)==v},"*=":function(a,v){return a&&a.indexOf(v)!==-1},"%=":function(a,v){return(a%v)==0},"|=":function(a,v){return a&&(a==v||a.substr(0,v.length+1)==v+"-")},"~=":function(a,v){return a&&(" "+a+" ").indexOf(" "+v+" ")!=-1}},pseudos:{"first-child":function(c){var r=[],ri=-1,n;for(var i=0,ci;ci=n=c[i];i++){while((n=n.previousSibling)&&n.nodeType!=1){}if(!n){r[++ri]=ci}}return r},"last-child":function(c){var r=[],ri=-1,n;for(var i=0,ci;ci=n=c[i];i++){while((n=n.nextSibling)&&n.nodeType!=1){}
 if(!n){r[++ri]=ci}}return r},"nth-child":function(c,a){var r=[],ri=-1,m=nthRe.exec(a=="even"&&"2n"||a=="odd"&&"2n+1"||!nthRe2.test(a)&&"n+"+a||a),f=(m[1]||1)-0,l=m[2]-0;for(var i=0,n;n=c[i];i++){var pn=n.parentNode;if(batch!=pn._batch){var j=0;for(var cn=pn.firstChild;cn;cn=cn.nextSibling){if(cn.nodeType==1){cn.nodeIndex=++j}}pn._batch=batch}if(f==1){if(l==0||n.nodeIndex==l){r[++ri]=n}}else{if((n.nodeIndex+l)%f==0){r[++ri]=n}}}return r},"only-child":function(c){var r=[],ri=-1;for(var i=0,ci;ci=c[i];i++){if(!prev(ci)&&!next(ci)){r[++ri]=ci}}return r},empty:function(c){var r=[],ri=-1;for(var i=0,ci;ci=c[i];i++){var cns=ci.childNodes,j=0,cn,empty=true;while(cn=cns[j]){++j;if(cn.nodeType==1||cn.nodeType==3){empty=false;break}}if(empty){r[++ri]=ci}}return r},contains:function(c,v){var r=[],ri=-1;for(var i=0,ci;ci=c[i];i++){if((ci.textContent||ci.innerText||"").indexOf(v)!=-1){r[++ri]=ci}}return r},nodeValue:function(c,v){var r=[],ri=-1;for(var i=0,ci;ci=c[i];i++){if(ci.firstChild
 &&ci.firstChild.nodeValue==v){r[++ri]=ci}}return r},checked:function(c){var r=[],ri=-1;for(var i=0,ci;ci=c[i];i++){if(ci.checked==true){r[++ri]=ci}}return r},not:function(c,ss){return Ext.DomQuery.filter(c,ss,true)},any:function(c,selectors){var ss=selectors.split("|"),r=[],ri=-1,s;for(var i=0,ci;ci=c[i];i++){for(var j=0;s=ss[j];j++){if(Ext.DomQuery.is(ci,s)){r[++ri]=ci;break}}}return r},odd:function(c){return this["nth-child"](c,"odd")},even:function(c){return this["nth-child"](c,"even")},nth:function(c,a){return c[a-1]||[]},first:function(c){return c[0]||[]},last:function(c){return c[c.length-1]||[]},has:function(c,ss){var s=Ext.DomQuery.select,r=[],ri=-1;for(var i=0,ci;ci=c[i];i++){if(s(ss,ci).length>0){r[++ri]=ci}}return r},next:function(c,ss){var is=Ext.DomQuery.is,r=[],ri=-1;for(var i=0,ci;ci=c[i];i++){var n=next(ci);if(n&&is(n,ss)){r[++ri]=ci}}return r},prev:function(c,ss){var is=Ext.DomQuery.is,r=[],ri=-1;for(var i=0,ci;ci=c[i];i++){var n=prev(ci);if(n&&is(n,ss)){r[+
 +ri]=ci}}return r}}}}();Ext.query=Ext.DomQuery.select;Ext.util.DelayedTask=function(d,c,a){var e=this,g,b=function(){clearInterval(g);g=null;d.apply(c,a||[])};e.delay=function(i,k,j,h){e.cancel();d=k||d;c=j||c;a=h||a;g=setInterval(b,i)};e.cancel=function(){if(g){clearInterval(g);g=null}}};(function(){var h=document;Ext.Element=function(l,m){var n=typeof l=="string"?h.getElementById(l):l,o;if(!n){return null}o=n.id;if(!m&&o&&Ext.elCache[o]){return Ext.elCache[o].el}this.dom=n;this.id=o||Ext.id(n)};var d=Ext.DomHelper,e=Ext.Element,a=Ext.elCache;e.prototype={set:function(q,m){var n=this.dom,l,p,m=(m!==false)&&!!n.setAttribute;for(l in q){if(q.hasOwnProperty(l)){p=q[l];if(l=="style"){d.applyStyles(n,p)}else{if(l=="cls"){n.className=p}else{if(m){n.setAttribute(l,p)}else{n[l]=p}}}}}return this},defaultUnit:"px",is:function(l){return Ext.DomQuery.is(this.dom,l)},focus:function(o,n){var l=this,n=n||l.dom;try{if(Number(o)){l.focus.defer(o,null,[null,n])}else{n.focus()}}catch(m){}ret
 urn l},blur:function(){try{this.dom.blur()}catch(l){}return this},getValue:function(l){var m=this.dom.value;return l?parseInt(m,10):m},addListener:function(l,o,n,m){Ext.EventManager.on(this.dom,l,o,n||this,m);return this},removeListener:function(l,n,m){Ext.EventManager.removeListener(this.dom,l,n,m||this);return this},removeAllListeners:function(){Ext.EventManager.removeAll(this.dom);return this},purgeAllListeners:function(){Ext.EventManager.purgeElement(this,true);return this},addUnits:function(l){if(l===""||l=="auto"||l===undefined){l=l||""}else{if(!isNaN(l)||!i.test(l)){l=l+(this.defaultUnit||"px")}}return l},load:function(m,n,l){Ext.Ajax.request(Ext.apply({params:n,url:m.url||m,callback:l,el:this.dom,indicatorText:m.indicatorText||""},Ext.isObject(m)?m:{}));return this},isBorderBox:function(){return Ext.isBorderBox||Ext.isForcedBorderBox||g[(this.dom.tagName||"").toLowerCase()]},remove:function(){var l=this,m=l.dom;if(m){delete l.dom;Ext.removeNode(m)}},hover:function(m,
 l,o,n){var p=this;p.on("mouseenter",m,o||p.dom,n);p.on("mouseleave",l,o||p.dom,n);return p},contains:function(l){return !l?false:Ext.lib.Dom.isAncestor(this.dom,l.dom?l.dom:l)},getAttributeNS:function(m,l){return this.getAttribute(l,m)},getAttribute:(function(){var p=document.createElement("table"),o=false,m="getAttribute" in p,l=/undefined|unknown/;if(m){try{p.getAttribute("ext:qtip")}catch(n){o=true}return function(q,s){var r=this.dom,t;if(r.getAttributeNS){t=r.getAttributeNS(s,q)||null}if(t==null){if(s){if(o&&r.tagName.toUpperCase()=="TABLE"){try{t=r.getAttribute(s+":"+q)}catch(u){t=""}}else{t=r.getAttribute(s+":"+q)}}else{t=r.getAttribute(q)||r[q]}}return t||""}}else{return function(q,s){var r=this.om,u,t;if(s){t=r[s+":"+q];u=l.test(typeof t)?undefined:t}else{u=r[q]}return u||""}}p=null})(),update:function(l){if(this.dom){this.dom.innerHTML=l}return this}};var k=e.prototype;e.addMethods=function(l){Ext.apply(k,l)};k.on=k.addListener;k.un=k.removeListener;k.autoBoxAdjust=
 true;var i=/\d+(px|em|%|en|ex|pt|in|cm|mm|pc)$/i,c;e.get=function(m){var l,p,o;if(!m){return null}if(typeof m=="string"){if(!(p=h.getElementById(m))){return null}if(a[m]&&a[m].el){l=a[m].el;l.dom=p}else{l=e.addToCache(new e(p))}return l}else{if(m.tagName){if(!(o=m.id)){o=Ext.id(m)}if(a[o]&&a[o].el){l=a[o].el;l.dom=m}else{l=e.addToCache(new e(m))}return l}else{if(m instanceof e){if(m!=c){if(Ext.isIE&&(m.id==undefined||m.id=="")){m.dom=m.dom}else{m.dom=h.getElementById(m.id)||m.dom}}return m}else{if(m.isComposite){return m}else{if(Ext.isArray(m)){return e.select(m)}else{if(m==h){if(!c){var n=function(){};n.prototype=e.prototype;c=new n();c.dom=h}return c}}}}}}return null};e.addToCache=function(l,m){m=m||l.id;a[m]={el:l,data:{},events:{}};return l};e.data=function(m,l,n){m=e.get(m);if(!m){return null}var o=a[m.id].data;if(arguments.length==2){return o[l]}else{return(o[l]=n)}};function j(){if(!Ext.enableGarbageCollector){clearInterval(e.collectorThreadId)}else{var l,n,q,p;for(l
 in a){p=a[l];if(p.skipGC){continue}n=p.el;q=n.dom;if(!q||!q.parentNode||(!q.offsetParent&&!h.getElementById(l))){if(Ext.enableListenerCollection){Ext.EventManager.removeAll(q)}delete a[l]}}if(Ext.isIE){var m={};for(l in a){m[l]=a[l]}a=Ext.elCache=m}}}e.collectorThreadId=setInterval(j,30000);var b=function(){};b.prototype=e.prototype;e.Flyweight=function(l){this.dom=l};e.Flyweight.prototype=new b();e.Flyweight.prototype.isFlyweight=true;e._flyweights={};e.fly=function(n,l){var m=null;l=l||"_global";if(n=Ext.getDom(n)){(e._flyweights[l]=e._flyweights[l]||new e.Flyweight()).dom=n;m=e._flyweights[l]}return m};Ext.get=e.get;Ext.fly=e.fly;var g=Ext.isStrict?{select:1}:{input:1,select:1,textarea:1};if(Ext.isIE||Ext.isGecko){g.button=1}})();Ext.Element.addMethods(function(){var d="parentNode",b="nextSibling",c="previousSibling",e=Ext.DomQuery,a=Ext.get;return{findParent:function(m,l,h){var j=this.dom,g=document.body,k=0,i;if(Ext.isGecko&&Object.prototype.toString.call(j)=="[object X
 ULElement]"){return null}l=l||50;if(isNaN(l)){i=Ext.getDom(l);l=Number.MAX_VALUE}while(j&&j.nodeType==1&&k<l&&j!=g&&j!=i){if(e.is(j,m)){return h?a(j):j}k++;j=j.parentNode}return null},findParentNode:function(j,i,g){var h=Ext.fly(this.dom.parentNode,"_internal");return h?h.findParent(j,i,g):null},up:function(h,g){return this.findParentNode(h,g,true)},select:function(g){return Ext.Element.select(g,this.dom)},query:function(g){return e.select(g,this.dom)},child:function(g,h){var i=e.selectNode(g,this.dom);return h?i:a(i)},down:function(g,h){var i=e.selectNode(" > "+g,this.dom);return h?i:a(i)},parent:function(g,h){return this.matchNode(d,d,g,h)},next:function(g,h){return this.matchNode(b,b,g,h)},prev:function(g,h){return this.matchNode(c,c,g,h)},first:function(g,h){return this.matchNode(b,"firstChild",g,h)},last:function(g,h){return this.matchNode(c,"lastChild",g,h)},matchNode:function(h,k,g,i){var j=this.dom[k];while(j){if(j.nodeType==1&&(!g||e.is(j,g))){return !i?a(j):j}j=j[h
 ]}return null}}}());Ext.Element.addMethods(function(){var c=Ext.getDom,a=Ext.get,b=Ext.DomHelper;return{appendChild:function(d){return a(d).appendTo(this)},appendTo:function(d){c(d).appendChild(this.dom);return this},insertBefore:function(d){(d=c(d)).parentNode.insertBefore(this.dom,d);return this},insertAfter:function(d){(d=c(d)).parentNode.insertBefore(this.dom,d.nextSibling);return this},insertFirst:function(e,d){e=e||{};if(e.nodeType||e.dom||typeof e=="string"){e=c(e);this.dom.insertBefore(e,this.dom.firstChild);return !d?a(e):e}else{return this.createChild(e,this.dom.firstChild,d)}},replace:function(d){d=a(d);this.insertBefore(d);d.remove();return this},replaceWith:function(d){var e=this;if(d.nodeType||d.dom||typeof d=="string"){d=c(d);e.dom.parentNode.insertBefore(d,e.dom)}else{d=b.insertBefore(e.dom,d)}delete Ext.elCache[e.id];Ext.removeNode(e.dom);e.id=Ext.id(e.dom=d);Ext.Element.addToCache(e.isFlyweight?new Ext.Element(e.dom):e);return e},createChild:function(e,d,g)
 {e=e||{tag:"div"};return d?b.insertBefore(d,e,g!==true):b[!this.dom.firstChild?"overwrite":"append"](this.dom,e,g!==true)},wrap:function(d,e){var g=b.insertBefore(this.dom,d||{tag:"div"},!e);g.dom?g.dom.appendChild(this.dom):g.appendChild(this.dom);return g},insertHtml:function(e,g,d){var h=b.insertHtml(e,this.dom,g);return d?Ext.get(h):h}}}());Ext.Element.addMethods(function(){var A=Ext.supports,h={},x=/(-[a-z])/gi,s=document.defaultView,D=/alpha\(opacity=(.*)\)/i,l=/^\s+|\s+$/g,B=Ext.Element,u=/\s+/,b=/\w/g,d="padding",c="margin",y="border",t="-left",q="-right",w="-top",o="-bottom",j="-width",r=Math,z="hidden",e="isClipped",k="overflow",n="overflow-x",m="overflow-y",C="originalClip",i={l:y+t+j,r:y+q+j,t:y+w+j,b:y+o+j},g={l:d+t,r:d+q,t:d+w,b:d+o},a={l:c+t,r:c+q,t:c+w,b:c+o},E=Ext.Element.data;function p(F,G){return G.charAt(1).toUpperCase()}function v(F){return h[F]||(h[F]=F=="float"?(A.cssFloat?"cssFloat":"styleFloat"):F.replace(x,p))}return{adjustWidth:function(F){var G=t
 his;var H=(typeof F=="number");if(H&&G.autoBoxAdjust&&!G.isBorderBox()){F-=(G.getBorderWidth("lr")+G.getPadding("lr"))}return(H&&F<0)?0:F},adjustHeight:function(F){var G=this;var H=(typeof F=="number");if(H&&G.autoBoxAdjust&&!G.isBorderBox()){F-=(G.getBorderWidth("tb")+G.getPadding("tb"))}return(H&&F<0)?0:F},addClass:function(J){var K=this,I,F,H,G=[];if(!Ext.isArray(J)){if(typeof J=="string"&&!this.hasClass(J)){K.dom.className+=" "+J}}else{for(I=0,F=J.length;I<F;I++){H=J[I];if(typeof H=="string"&&(" "+K.dom.className+" ").indexOf(" "+H+" ")==-1){G.push(H)}}if(G.length){K.dom.className+=" "+G.join(" ")}}return K},removeClass:function(K){var L=this,J,G,F,I,H;if(!Ext.isArray(K)){K=[K]}if(L.dom&&L.dom.className){H=L.dom.className.replace(l,"").split(u);for(J=0,F=K.length;J<F;J++){I=K[J];if(typeof I=="string"){I=I.replace(l,"");G=H.indexOf(I);if(G!=-1){H.splice(G,1)}}}L.dom.className=H.join(" ")}return L},radioClass:function(I){var J=this.dom.parentNode.childNodes,G,H,F;I=Ext.isA
 rray(I)?I:[I];for(H=0,F=J.length;H<F;H++){G=J[H];if(G&&G.nodeType==1){Ext.fly(G,"_internal").removeClass(I)}}return this.addClass(I)},toggleClass:function(F){return this.hasClass(F)?this.removeClass(F):this.addClass(F)},hasClass:function(F){return F&&(" "+this.dom.className+" ").indexOf(" "+F+" ")!=-1},replaceClass:function(G,F){return this.removeClass(G).addClass(F)},isStyle:function(F,G){return this.getStyle(F)==G},getStyle:function(){return s&&s.getComputedStyle?function(K){var I=this.dom,F,H,G,J;if(I==document){return null}K=v(K);G=(F=I.style[K])?F:(H=s.getComputedStyle(I,""))?H[K]:null;if(K=="marginRight"&&G!="0px"&&!A.correctRightMargin){J=I.style.display;I.style.display="inline-block";G=s.getComputedStyle(I,"").marginRight;I.style.display=J}if(K=="backgroundColor"&&G=="rgba(0, 0, 0, 0)"&&!A.correctTransparentColor){G="transparent"}return G}:function(J){var H=this.dom,F,G;if(H==document){return null}if(J=="opacity"){if(H.style.filter.match){if(F=H.style.filter.match(D)
 ){var I=parseFloat(F[1]);if(!isNaN(I)){return I?I/100:0}}}return 1}J=v(J);return H.style[J]||((G=H.currentStyle)?G[J]:null)}}(),getColor:function(F,G,K){var I=this.getStyle(F),H=(typeof K!="undefined")?K:"#",J;if(!I||(/transparent|inherit/.test(I))){return G}if(/^r/.test(I)){Ext.each(I.slice(4,I.length-1).split(","),function(L){J=parseInt(L,10);H+=(J<16?"0":"")+J.toString(16)})}else{I=I.replace("#","");H+=I.length==3?I.replace(/^(\w)(\w)(\w)$/,"$1$1$2$2$3$3"):I}return(H.length>5?H.toLowerCase():G)},setStyle:function(I,H){var F,G;if(typeof I!="object"){F={};F[I]=H;I=F}for(G in I){H=I[G];G=="opacity"?this.setOpacity(H):this.dom.style[v(G)]=H}return this},setOpacity:function(G,F){var J=this,H=J.dom.style;if(!F||!J.anim){if(Ext.isIE){var I=G<1?"alpha(opacity="+G*100+")":"",K=H.filter.replace(D,"").replace(l,"");H.zoom=1;H.filter=K+(K.length>0?" ":"")+I}else{H.opacity=G}}else{J.anim({opacity:{to:G}},J.preanim(arguments,1),null,0.35,"easeIn")}return J},clearOpacity:function(){var
 F=this.dom.style;if(Ext.isIE){if(!Ext.isEmpty(F.filter)){F.filter=F.filter.replace(D,"").replace(l,"")}}else{F.opacity=F["-moz-opacity"]=F["-khtml-opacity"]=""}return this},getHeight:function(H){var G=this,J=G.dom,I=Ext.isIE&&G.isStyle("display","none"),F=r.max(J.offsetHeight,I?0:J.clientHeight)||0;F=!H?F:F-G.getBorderWidth("tb")-G.getPadding("tb");return F<0?0:F},getWidth:function(G){var H=this,J=H.dom,I=Ext.isIE&&H.isStyle("display","none"),F=r.max(J.offsetWidth,I?0:J.clientWidth)||0;F=!G?F:F-H.getBorderWidth("lr")-H.getPadding("lr");return F<0?0:F},setWidth:function(G,F){var H=this;G=H.adjustWidth(G);!F||!H.anim?H.dom.style.width=H.addUnits(G):H.anim({width:{to:G}},H.preanim(arguments,1));return H},setHeight:function(F,G){var H=this;F=H.adjustHeight(F);!G||!H.anim?H.dom.style.height=H.addUnits(F):H.anim({height:{to:F}},H.preanim(arguments,1));return H},getBorderWidth:function(F){return this.addStyles(F,i)},getPadding:function(F){return this.addStyles(F,g)},clip:function()
 {var F=this,G=F.dom;if(!E(G,e)){E(G,e,true);E(G,C,{o:F.getStyle(k),x:F.getStyle(n),y:F.getStyle(m)});F.setStyle(k,z);F.setStyle(n,z);F.setStyle(m,z)}return F},unclip:function(){var F=this,H=F.dom;if(E(H,e)){E(H,e,false);var G=E(H,C);if(G.o){F.setStyle(k,G.o)}if(G.x){F.setStyle(n,G.x)}if(G.y){F.setStyle(m,G.y)}}return F},addStyles:function(M,L){var J=0,K=M.match(b),I,H,G,F=K.length;for(G=0;G<F;G++){I=K[G];H=I&&parseInt(this.getStyle(L[I]),10);if(H){J+=r.abs(H)}}return J},margins:a}}());(function(){var a=Ext.lib.Dom,b="left",g="right",d="top",i="bottom",h="position",c="static",e="relative",j="auto",k="z-index";Ext.Element.addMethods({getX:function(){return a.getX(this.dom)},getY:function(){return a.getY(this.dom)},getXY:function(){return a.getXY(this.dom)},getOffsetsTo:function(l){var n=this.getXY(),m=Ext.fly(l,"_internal").getXY();return[n[0]-m[0],n[1]-m[1]]},setX:function(l,m){return this.setXY([l,this.getY()],this.animTest(arguments,m,1))},setY:function(m,l){return this.set
 XY([this.getX(),m],this.animTest(arguments,l,1))},setLeft:function(l){this.setStyle(b,this.addUnits(l));return this},setTop:function(l){this.setStyle(d,this.addUnits(l));return this},setRight:function(l){this.setStyle(g,this.addUnits(l));return this},setBottom:function(l){this.setStyle(i,this.addUnits(l));return this},setXY:function(n,l){var m=this;if(!l||!m.anim){a.setXY(m.dom,n)}else{m.anim({points:{to:n}},m.preanim(arguments,1),"motion")}return m},setLocation:function(l,n,m){return this.setXY([l,n],this.animTest(arguments,m,2))},moveTo:function(l,n,m){return this.setXY([l,n],this.animTest(arguments,m,2))},getLeft:function(l){return !l?this.getX():parseInt(this.getStyle(b),10)||0},getRight:function(l){var m=this;return !l?m.getX()+m.getWidth():(m.getLeft(true)+m.getWidth())||0},getTop:function(l){return !l?this.getY():parseInt(this.getStyle(d),10)||0},getBottom:function(l){var m=this;return !l?m.getY()+m.getHeight():(m.getTop(true)+m.getHeight())||0},position:function(p,o,
 l,n){var m=this;if(!p&&m.isStyle(h,c)){m.setStyle(h,e)}else{if(p){m.setStyle(h,p)}}if(o){m.setStyle(k,o)}if(l||n){m.setXY([l||false,n||false])}},clearPositioning:function(l){l=l||"";this.setStyle({left:l,right:l,top:l,bottom:l,"z-index":"",position:c});return this},getPositioning:function(){var m=this.getStyle(b);var n=this.getStyle(d);return{position:this.getStyle(h),left:m,right:m?"":this.getStyle(g),top:n,bottom:n?"":this.getStyle(i),"z-index":this.getStyle(k)}},setPositioning:function(l){var n=this,m=n.dom.style;n.setStyle(l);if(l.right==j){m.right=""}if(l.bottom==j){m.bottom=""}return n},translatePoints:function(m,u){u=isNaN(m[1])?u:m[1];m=isNaN(m[0])?m:m[0];var q=this,r=q.isStyle(h,e),s=q.getXY(),n=parseInt(q.getStyle(b),10),p=parseInt(q.getStyle(d),10);n=!isNaN(n)?n:(r?0:q.dom.offsetLeft);p=!isNaN(p)?p:(r?0:q.dom.offsetTop);return{left:(m-s[0]+n),top:(u-s[1]+p)}},animTest:function(m,l,n){return !!l&&this.preanim?this.preanim(m,n):false}})})();Ext.Element.addMethods({i
 sScrollable:function(){var a=this.dom;return a.scrollHeight>a.clientHeight||a.scrollWidth>a.clientWidth},scrollTo:function(a,b){this.dom["scroll"+(/top/i.test(a)?"Top":"Left")]=b;return this},getScroll:function(){var i=this.dom,h=document,a=h.body,c=h.documentElement,b,g,e;if(i==h||i==a){if(Ext.isIE&&Ext.isStrict){b=c.scrollLeft;g=c.scrollTop}else{b=window.pageXOffset;g=window.pageYOffset}e={left:b||(a?a.scrollLeft:0),top:g||(a?a.scrollTop:0)}}else{e={left:i.scrollLeft,top:i.scrollTop}}return e}});Ext.Element.VISIBILITY=1;Ext.Element.DISPLAY=2;Ext.Element.OFFSETS=3;Ext.Element.ASCLASS=4;Ext.Element.visibilityCls="x-hide-nosize";Ext.Element.addMethods(function(){var e=Ext.Element,p="opacity",j="visibility",g="display",d="hidden",n="offsets",k="asclass",m="none",a="nosize",b="originalDisplay",c="visibilityMode",h="isVisible",i=e.data,l=function(r){var q=i(r,b);if(q===undefined){i(r,b,q="")}return q},o=function(r){var q=i(r,c);if(q===undefined){i(r,c,q=1)}return q};return{origi
 nalDisplay:"",visibilityMode:1,setVisibilityMode:function(q){i(this.dom,c,q);return this},animate:function(r,t,s,u,q){this.anim(r,{duration:t,callback:s,easing:u},q);return this},anim:function(t,u,r,w,s,q){r=r||"run";u=u||{};var v=this,x=Ext.lib.Anim[r](v.dom,t,(u.duration||w)||0.35,(u.easing||s)||"easeOut",function(){if(q){q.call(v)}if(u.callback){u.callback.call(u.scope||v,v,u)}},v);u.anim=x;return x},preanim:function(q,r){return !q[r]?false:(typeof q[r]=="object"?q[r]:{duration:q[r+1],callback:q[r+2],easing:q[r+3]})},isVisible:function(){var q=this,s=q.dom,r=i(s,h);if(typeof r=="boolean"){return r}r=!q.isStyle(j,d)&&!q.isStyle(g,m)&&!((o(s)==e.ASCLASS)&&q.hasClass(q.visibilityCls||e.visibilityCls));i(s,h,r);return r},setVisible:function(t,q){var w=this,r,y,x,v,u=w.dom,s=o(u);if(typeof q=="string"){switch(q){case g:s=e.DISPLAY;break;case j:s=e.VISIBILITY;break;case n:s=e.OFFSETS;break;case a:case k:s=e.ASCLASS;break}w.setVisibilityMode(s);q=false}if(!q||!w.anim){if(s==e.AS
 CLASS){w[t?"removeClass":"addClass"](w.visibilityCls||e.visibilityCls)}else{if(s==e.DISPLAY){return w.setDisplayed(t)}else{if(s==e.OFFSETS){if(!t){w.hideModeStyles={position:w.getStyle("position"),top:w.getStyle("top"),left:w.getStyle("left")};w.applyStyles({position:"absolute",top:"-10000px",left:"-10000px"})}else{w.applyStyles(w.hideModeStyles||{position:"",top:"",left:""});delete w.hideModeStyles}}else{w.fixDisplay();u.style.visibility=t?"visible":d}}}}else{if(t){w.setOpacity(0.01);w.setVisible(true)}w.anim({opacity:{to:(t?1:0)}},w.preanim(arguments,1),null,0.35,"easeIn",function(){t||w.setVisible(false).setOpacity(1)})}i(u,h,t);return w},hasMetrics:function(){var q=this.dom;return this.isVisible()||(o(q)==e.VISIBILITY)},toggle:function(q){var r=this;r.setVisible(!r.isVisible(),r.preanim(arguments,0));return r},setDisplayed:function(q){if(typeof q=="boolean"){q=q?l(this.dom):m}this.setStyle(g,q);return this},fixDisplay:function(){var q=this;if(q.isStyle(g,m)){q.setStyle(j
 ,d);q.setStyle(g,l(this.dom));if(q.isStyle(g,m)){q.setStyle(g,"block")}}},hide:function(q){if(typeof q=="string"){this.setVisible(false,q);return this}this.setVisible(false,this.preanim(arguments,0));return this},show:function(q){if(typeof q=="string"){this.setVisible(true,q);return this}this.setVisible(true,this.preanim(arguments,0));return this}}}());(function(){var y=null,A=undefined,k=true,t=false,j="setX",h="setY",a="setXY",n="left",l="bottom",s="top",m="right",q="height",g="width",i="points",w="hidden",z="absolute",u="visible",e="motion",o="position",r="easeOut",d=new Ext.Element.Flyweight(),v={},x=function(B){return B||{}},p=function(B){d.dom=B;d.id=Ext.id(B);return d},c=function(B){if(!v[B]){v[B]=[]}return v[B]},b=function(C,B){v[C]=B};Ext.enableFx=k;Ext.Fx={switchStatements:function(C,D,B){return D.apply(this,B[C])},slideIn:function(H,E){E=x(E);var J=this,G=J.dom,M=G.style,O,B,L,D,C,M,I,N,K,F;H=H||"t";J.queueFx(E,function(){O=p(G).getXY();p(G).fixDisplay();B=p(G).ge
 tFxRestore();L={x:O[0],y:O[1],0:O[0],1:O[1],width:G.offsetWidth,height:G.offsetHeight};L.right=L.x+L.width;L.bottom=L.y+L.height;p(G).setWidth(L.width).setHeight(L.height);D=p(G).fxWrap(B.pos,E,w);M.visibility=u;M.position=z;function P(){p(G).fxUnwrap(D,B.pos,E);M.width=B.width;M.height=B.height;p(G).afterFx(E)}N={to:[L.x,L.y]};K={to:L.width};F={to:L.height};function Q(U,R,V,S,X,Z,ac,ab,aa,W,T){var Y={};p(U).setWidth(V).setHeight(S);if(p(U)[X]){p(U)[X](Z)}R[ac]=R[ab]="0";if(aa){Y.width=aa}if(W){Y.height=W}if(T){Y.points=T}return Y}I=p(G).switchStatements(H.toLowerCase(),Q,{t:[D,M,L.width,0,y,y,n,l,y,F,y],l:[D,M,0,L.height,y,y,m,s,K,y,y],r:[D,M,L.width,L.height,j,L.right,n,s,y,y,N],b:[D,M,L.width,L.height,h,L.bottom,n,s,y,F,N],tl:[D,M,0,0,y,y,m,l,K,F,N],bl:[D,M,0,0,h,L.y+L.height,m,s,K,F,N],br:[D,M,0,0,a,[L.right,L.bottom],n,s,K,F,N],tr:[D,M,0,0,j,L.x+L.width,n,l,K,F,N]});M.visibility=u;p(D).show();arguments.callee.anim=p(D).fxanim(I,E,e,0.5,r,P)});return J},slideOut:function
 (F,D){D=x(D);var H=this,E=H.dom,K=E.style,L=H.getXY(),C,B,I,J,G={to:0};F=F||"t";H.queueFx(D,function(){B=p(E).getFxRestore();I={x:L[0],y:L[1],0:L[0],1:L[1],width:E.offsetWidth,height:E.offsetHeight};I.right=I.x+I.width;I.bottom=I.y+I.height;p(E).setWidth(I.width).setHeight(I.height);C=p(E).fxWrap(B.pos,D,u);K.visibility=u;K.position=z;p(C).setWidth(I.width).setHeight(I.height);function M(){D.useDisplay?p(E).setDisplayed(t):p(E).hide();p(E).fxUnwrap(C,B.pos,D);K.width=B.width;K.height=B.height;p(E).afterFx(D)}function N(O,W,U,X,S,V,R,T,Q){var P={};O[W]=O[U]="0";P[X]=S;if(V){P[V]=R}if(T){P[T]=Q}return P}J=p(E).switchStatements(F.toLowerCase(),N,{t:[K,n,l,q,G],l:[K,m,s,g,G],r:[K,n,s,g,G,i,{to:[I.right,I.y]}],b:[K,n,s,q,G,i,{to:[I.x,I.bottom]}],tl:[K,m,l,g,G,q,G],bl:[K,m,s,g,G,q,G,i,{to:[I.x,I.bottom]}],br:[K,n,s,g,G,q,G,i,{to:[I.x+I.width,I.bottom]}],tr:[K,n,l,g,G,q,G,i,{to:[I.right,I.y]}]});arguments.callee.anim=p(C).fxanim(J,D,e,0.5,r,M)});return H},puff:function(H){H=x(H);va
 r F=this,G=F.dom,C=G.style,D,B,E;F.queueFx(H,function(){D=p(G).getWidth();B=p(G).getHeight();p(G).clearOpacity();p(G).show();E=p(G).getFxRestore();function I(){H.useDisplay?p(G).setDisplayed(t):p(G).hide();p(G).clearOpacity();p(G).setPositioning(E.pos);C.width=E.width;C.height=E.height;C.fontSize="";p(G).afterFx(H)}arguments.callee.anim=p(G).fxanim({width:{to:p(G).adjustWidth(D*2)},height:{to:p(G).adjustHeight(B*2)},points:{by:[-D*0.5,-B*0.5]},opacity:{to:0},fontSize:{to:200,unit:"%"}},H,e,0.5,r,I)});return F},switchOff:function(F){F=x(F);var D=this,E=D.dom,B=E.style,C;D.queueFx(F,function(){p(E).clearOpacity();p(E).clip();C=p(E).getFxRestore();function G(){F.useDisplay?p(E).setDisplayed(t):p(E).hide();p(E).clearOpacity();p(E).setPositioning(C.pos);B.width=C.width;B.height=C.height;p(E).afterFx(F)}p(E).fxanim({opacity:{to:0.3}},y,y,0.1,y,function(){p(E).clearOpacity();(function(){p(E).fxanim({height:{to:1},points:{by:[0,p(E).getHeight()*0.5]}},F,e,0.3,"easeIn",G)}).defer(100
 )})});return D},highlight:function(D,H){H=x(H);var F=this,G=F.dom,B=H.attr||"backgroundColor",C={},E;F.queueFx(H,function(){p(G).clearOpacity();p(G).show();function I(){G.style[B]=E;p(G).afterFx(H)}E=G.style[B];C[B]={from:D||"ffff9c",to:H.endColor||p(G).getColor(B)||"ffffff"};arguments.callee.anim=p(G).fxanim(C,H,"color",1,"easeIn",I)});return F},frame:function(B,E,H){H=x(H);var D=this,G=D.dom,C,F;D.queueFx(H,function(){B=B||"#C3DAF9";if(B.length==6){B="#"+B}E=E||1;p(G).show();var L=p(G).getXY(),J={x:L[0],y:L[1],0:L[0],1:L[1],width:G.offsetWidth,height:G.offsetHeight},I=function(){C=p(document.body||document.documentElement).createChild({style:{position:z,"z-index":35000,border:"0px solid "+B}});return C.queueFx({},K)};arguments.callee.anim={isAnimated:true,stop:function(){E=0;C.stopFx()}};function K(){var M=Ext.isBorderBox?2:1;F=C.anim({top:{from:J.y,to:J.y-20},left:{from:J.x,to:J.x-20},borderWidth:{from:0,to:10},opacity:{from:1,to:0},height:{from:J.height,to:J.height+20*M}
 ,width:{from:J.width,to:J.width+20*M}},{duration:H.duration||1,callback:function(){C.remove();--E>0?I():p(G).afterFx(H)}});arguments.callee.anim={isAnimated:true,stop:function(){F.stop()}}}I()});return D},pause:function(D){var C=this.dom,B;this.queueFx({},function(){B=setTimeout(function(){p(C).afterFx({})},D*1000);arguments.callee.anim={isAnimated:true,stop:function(){clearTimeout(B);p(C).afterFx({})}}});return this},fadeIn:function(D){D=x(D);var B=this,C=B.dom,E=D.endOpacity||1;B.queueFx(D,function(){p(C).setOpacity(0);p(C).fixDisplay();C.style.visibility=u;arguments.callee.anim=p(C).fxanim({opacity:{to:E}},D,y,0.5,r,function(){if(E==1){p(C).clearOpacity()}p(C).afterFx(D)})});return B},fadeOut:function(E){E=x(E);var C=this,D=C.dom,B=D.style,F=E.endOpacity||0;C.queueFx(E,function(){arguments.callee.anim=p(D).fxanim({opacity:{to:F}},E,y,0.5,r,function(){if(F==0){Ext.Element.data(D,"visibilityMode")==Ext.Element.DISPLAY||E.useDisplay?B.display="none":B.visibility=w;p(D).clear
 Opacity()}p(D).afterFx(E)})});return C},scale:function(B,C,D){this.shift(Ext.apply({},D,{width:B,height:C}));return this},shift:function(D){D=x(D);var C=this.dom,B={};this.queueFx(D,function(){for(var E in D){if(D[E]!=A){B[E]={to:D[E]}}}B.width?B.width.to=p(C).adjustWidth(D.width):B;B.height?B.height.to=p(C).adjustWidth(D.height):B;if(B.x||B.y||B.xy){B.points=B.xy||{to:[B.x?B.x.to:p(C).getX(),B.y?B.y.to:p(C).getY()]}}arguments.callee.anim=p(C).fxanim(B,D,e,0.35,r,function(){p(C).afterFx(D)})});return this},ghost:function(E,C){C=x(C);var G=this,D=G.dom,J=D.style,H={opacity:{to:0},points:{}},K=H.points,B,I,F;E=E||"b";G.queueFx(C,function(){B=p(D).getFxRestore();I=p(D).getWidth();F=p(D).getHeight();function L(){C.useDisplay?p(D).setDisplayed(t):p(D).hide();p(D).clearOpacity();p(D).setPositioning(B.pos);J.width=B.width;J.height=B.height;p(D).afterFx(C)}K.by=p(D).switchStatements(E.toLowerCase(),function(N,M){return[N,M]},{t:[0,-F],l:[-I,0],r:[I,0],b:[0,F],tl:[-I,-F],bl:[-I,F],br
 :[I,F],tr:[I,-F]});arguments.callee.anim=p(D).fxanim(H,C,e,0.5,r,L)});return G},syncFx:function(){var B=this;B.fxDefaults=Ext.apply(B.fxDefaults||{},{block:t,concurrent:k,stopFx:t});return B},sequenceFx:function(){var B=this;B.fxDefaults=Ext.apply(B.fxDefaults||{},{block:t,concurrent:t,stopFx:t});return B},nextFx:function(){var B=c(this.dom.id)[0];if(B){B.call(this)}},hasActiveFx:function(){return c(this.dom.id)[0]},stopFx:function(B){var C=this,E=C.dom.id;if(C.hasActiveFx()){var D=c(E)[0];if(D&&D.anim){if(D.anim.isAnimated){b(E,[D]);D.anim.stop(B!==undefined?B:k)}else{b(E,[])}}}return C},beforeFx:function(B){if(this.hasActiveFx()&&!B.concurrent){if(B.stopFx){this.stopFx();return k}return t}return k},hasFxBlock:function(){var B=c(this.dom.id);return B&&B[0]&&B[0].block},queueFx:function(E,B){var C=p(this.dom);if(!C.hasFxBlock()){Ext.applyIf(E,C.fxDefaults);if(!E.concurrent){var D=C.beforeFx(E);B.block=E.block;c(C.dom.id).push(B);if(D){C.nextFx()}}else{B.call(C)}}return C},fx
 Wrap:function(H,F,D){var E=this.dom,C,B;if(!F.wrap||!(C=Ext.getDom(F.wrap))){if(F.fixPosition){B=p(E).getXY()}var G=document.createElement("div");G.style.visibility=D;C=E.parentNode.insertBefore(G,E);p(C).setPositioning(H);if(p(C).isStyle(o,"static")){p(C).position("relative")}p(E).clearPositioning("auto");p(C).clip();C.appendChild(E);if(B){p(C).setXY(B)}}return C},fxUnwrap:function(C,F,E){var D=this.dom;p(D).clearPositioning();p(D).setPositioning(F);if(!E.wrap){var B=p(C).dom.parentNode;B.insertBefore(D,C);p(C).remove()}},getFxRestore:function(){var B=this.dom.style;return{pos:this.getPositioning(),width:B.width,height:B.height}},afterFx:function(C){var B=this.dom,D=B.id;if(C.afterStyle){p(B).setStyle(C.afterStyle)}if(C.afterCls){p(B).addClass(C.afterCls)}if(C.remove==k){p(B).remove()}if(C.callback){C.callback.call(C.scope,p(B))}if(!C.concurrent){c(D).shift();p(B).nextFx()}},fxanim:function(E,F,C,G,D,B){C=C||"run";F=F||{};var H=Ext.lib.Anim[C](this.dom,E,(F.duration||G)||0.
 35,(F.easing||D)||r,B,this);F.anim=H;return H}};Ext.Fx.resize=Ext.Fx.scale;Ext.Element.addMethods(Ext.Fx)})();Ext.CompositeElementLite=function(b,a){this.elements=[];this.add(b,a);this.el=new Ext.Element.Flyweight()};Ext.CompositeElementLite.prototype={isComposite:true,getElement:function(a){var b=this.el;b.dom=a;b.id=a.id;return b},transformElement:function(a){return Ext.getDom(a)},getCount:function(){return this.elements.length},add:function(d,b){var e=this,g=e.elements;if(!d){return this}if(typeof d=="string"){d=Ext.Element.selectorFunction(d,b)}else{if(d.isComposite){d=d.elements}else{if(!Ext.isIterable(d)){d=[d]}}}for(var c=0,a=d.length;c<a;++c){g.push(e.transformElement(d[c]))}return e},invoke:function(g,b){var h=this,d=h.elements,a=d.length,j,c;for(c=0;c<a;c++){j=d[c];if(j){Ext.Element.prototype[g].apply(h.getElement(j),b)}}return h},item:function(b){var d=this,c=d.elements[b],a=null;if(c){a=d.getElement(c)}return a},addListener:function(b,j,h,g){var d=this.elements,a
 =d.length,c,k;for(c=0;c<a;c++){k=d[c];if(k){Ext.EventManager.on(k,b,j,h||k,g)}}return this},each:function(g,d){var h=this,c=h.elements,a=c.length,b,j;for(b=0;b<a;b++){j=c[b];if(j){j=this.getElement(j);if(g.call(d||j,j,h,b)===false){break}}}return h},fill:function(a){var b=this;b.elements=[];b.add(a);return b},filter:function(a){var b=[],d=this,c=Ext.isFunction(a)?a:function(e){return e.is(a)};d.each(function(h,e,g){if(c(h,g)!==false){b[b.length]=d.transformElement(h)}});d.elements=b;return d},indexOf:function(a){return this.elements.indexOf(this.transformElement(a))},replaceElement:function(e,c,a){var b=!isNaN(e)?e:this.indexOf(e),g;if(b>-1){c=Ext.getDom(c);if(a){g=this.elements[b];g.parentNode.insertBefore(c,g);Ext.removeNode(g)}this.elements.splice(b,1,c)}return this},clear:function(){this.elements=[]}};Ext.CompositeElementLite.prototype.on=Ext.CompositeElementLite.prototype.addListener;Ext.CompositeElementLite.importElementMethods=function(){var c,b=Ext.Element.prototype,
 a=Ext.CompositeElementLite.prototype;for(c in b){if(typeof b[c]=="function"){(function(d){a[d]=a[d]||function(){return this.invoke(d,arguments)}}).call(a,c)}}};Ext.CompositeElementLite.importElementMethods();if(Ext.DomQuery){Ext.Element.selectorFunction=Ext.DomQuery.select}Ext.Element.select=function(a,b){var c;if(typeof a=="string"){c=Ext.Element.selectorFunction(a,b)}else{if(a.length!==undefined){c=a}else{throw"Invalid selector"}}return new Ext.CompositeElementLite(c)};Ext.select=Ext.Element.select;(function(){var b="beforerequest",e="requestcomplete",d="requestexception",h=undefined,c="load",i="POST",a="GET",g=window;Ext.data.Connection=function(j){Ext.apply(this,j);this.addEvents(b,e,d);Ext.data.Connection.superclass.constructor.call(this)};Ext.extend(Ext.data.Connection,Ext.util.Observable,{timeout:30000,autoAbort:false,disableCaching:true,disableCachingParam:"_dc",request:function(n){var s=this;if(s.fireEvent(b,s,n)){if(n.el){if(!Ext.isEmpty(n.indicatorText)){s.indicat
 orText='<div class="loading-indicator">'+n.indicatorText+"</div>"}if(s.indicatorText){Ext.getDom(n.el).innerHTML=s.indicatorText}n.success=(Ext.isFunction(n.success)?n.success:function(){}).createInterceptor(function(o){Ext.getDom(n.el).innerHTML=o.responseText})}var l=n.params,k=n.url||s.url,j,q={success:s.handleResponse,failure:s.handleFailure,scope:s,argument:{options:n},timeout:Ext.num(n.timeout,s.timeout)},m,t;if(Ext.isFunction(l)){l=l.call(n.scope||g,n)}l=Ext.urlEncode(s.extraParams,Ext.isObject(l)?Ext.urlEncode(l):l);if(Ext.isFunction(k)){k=k.call(n.scope||g,n)}if((m=Ext.getDom(n.form))){k=k||m.action;if(n.isUpload||(/multipart\/form-data/i.test(m.getAttribute("enctype")))){return s.doFormUpload.call(s,n,l,k)}t=Ext.lib.Ajax.serializeForm(m);l=l?(l+"&"+t):t}j=n.method||s.method||((l||n.xmlData||n.jsonData)?i:a);if(j===a&&(s.disableCaching&&n.disableCaching!==false)||n.disableCaching===true){var r=n.disableCachingParam||s.disableCachingParam;k=Ext.urlAppend(k,r+"="+(new
  Date().getTime()))}n.headers=Ext.applyIf(n.headers||{},s.defaultHeaders||{});if(n.autoAbort===true||s.autoAbort){s.abort()}if((j==a||n.xmlData||n.jsonData)&&l){k=Ext.urlAppend(k,l);l=""}return(s.transId=Ext.lib.Ajax.request(j,k,q,l,n))}else{return n.callback?n.callback.apply(n.scope,[n,h,h]):null}},isLoading:function(j){return j?Ext.lib.Ajax.isCallInProgress(j):!!this.transId},abort:function(j){if(j||this.isLoading()){Ext.lib.Ajax.abort(j||this.transId)}},handleResponse:function(j){this.transId=false;var k=j.argument.options;j.argument=k?k.argument:null;this.fireEvent(e,this,j,k);if(k.success){k.success.call(k.scope,j,k)}if(k.callback){k.callback.call(k.scope,k,true,j)}},handleFailure:function(j,l){this.transId=false;var k=j.argument.options;j.argument=k?k.argument:null;this.fireEvent(d,this,j,k,l);if(k.failure){k.failure.call(k.scope,j,k)}if(k.callback){k.callback.call(k.scope,k,false,j)}},doFormUpload:function(q,j,k){var l=Ext.id(),v=document,r=v.createElement("iframe"),m
 =Ext.getDom(q.form),u=[],t,p="multipart/form-data",n={target:m.target,method:m.method,encoding:m.encoding,enctype:m.enctype,action:m.action};Ext.fly(r).set({id:l,name:l,cls:"x-hidden",src:Ext.SSL_SECURE_URL});v.body.appendChild(r);if(Ext.isIE){document.frames[l].name=l}Ext.fly(m).set({target:l,method:i,enctype:p,encoding:p,action:k||n.action});Ext.iterate(Ext.urlDecode(j,false),function(w,o){t=v.createElement("input");Ext.fly(t).set({type:"hidden",value:o,name:w});m.appendChild(t);u.push(t)});function s(){var x=this,w={responseText:"",responseXML:null,argument:q.argument},A,z;try{A=r.contentWindow.document||r.contentDocument||g.frames[l].document;if(A){if(A.body){if(/textarea/i.test((z=A.body.firstChild||{}).tagName)){w.responseText=z.value}else{w.responseText=A.body.innerHTML}}w.responseXML=A.XMLDocument||A}}catch(y){}Ext.EventManager.removeListener(r,c,s,x);x.fireEvent(e,x,w,q);function o(D,C,B){if(Ext.isFunction(D)){D.apply(C,B)}}o(q.success,q.scope,[w,q]);o(q.callback,q.
 scope,[q,true,w]);if(!x.debugUploads){setTimeout(function(){Ext.removeNode(r)},100)}}Ext.EventManager.on(r,c,s,this);m.submit();Ext.fly(m).set(n);Ext.each(u,function(o){Ext.removeNode(o)})}})})();Ext.Ajax=new Ext.data.Connection({autoAbort:false,serializeForm:function(a){return Ext.lib.Ajax.serializeForm(a)}});Ext.util.JSON=new (function(){var useHasOwn=!!{}.hasOwnProperty,isNative=function(){var useNative=null;return function(){if(useNative===null){useNative=Ext.USE_NATIVE_JSON&&window.JSON&&JSON.toString()=="[object JSON]"}return useNative}}(),pad=function(n){return n<10?"0"+n:n},doDecode=function(json){return json?eval("("+json+")"):""},doEncode=function(o){if(!Ext.isDefined(o)||o===null){return"null"}else{if(Ext.isArray(o)){return encodeArray(o)}else{if(Ext.isDate(o)){return Ext.util.JSON.encodeDate(o)}else{if(Ext.isString(o)){return encodeString(o)}else{if(typeof o=="number"){return isFinite(o)?String(o):"null"}else{if(Ext.isBoolean(o)){return String(o)}else{var a=["{"]
 ,b,i,v;for(i in o){if(!o.getElementsByTagName){if(!useHasOwn||o.hasOwnProperty(i)){v=o[i];switch(typeof v){case"undefined":case"function":case"unknown":break;default:if(b){a.push(",")}a.push(doEncode(i),":",v===null?"null":doEncode(v));b=true}}}}a.push("}");return a.join("")}}}}}}},m={"\b":"\\b","\t":"\\t","\n":"\\n","\f":"\\f","\r":"\\r",'"':'\\"',"\\":"\\\\"},encodeString=function(s){if(/["\\\x00-\x1f]/.test(s)){return'"'+s.replace(/([\x00-\x1f\\"])/g,function(a,b){var c=m[b];if(c){return c}c=b.charCodeAt();return"\\u00"+Math.floor(c/16).toString(16)+(c%16).toString(16)})+'"'}return'"'+s+'"'},encodeArray=function(o){var a=["["],b,i,l=o.length,v;for(i=0;i<l;i+=1){v=o[i];switch(typeof v){case"undefined":case"function":case"unknown":break;default:if(b){a.push(",")}a.push(v===null?"null":Ext.util.JSON.encode(v));b=true}}a.push("]");return a.join("")};this.encodeDate=function(o){return'"'+o.getFullYear()+"-"+pad(o.getMonth()+1)+"-"+pad(o.getDate())+"T"+pad(o.getHours())+":"+pad
 (o.getMinutes())+":"+pad(o.getSeconds())+'"'};this.encode=function(){var ec;return function(o){if(!ec){ec=isNative()?JSON.stringify:doEncode}return ec(o)}}();this.decode=function(){var dc;return function(json){if(!dc){dc=isNative()?JSON.parse:doDecode}return dc(json)}}()})();Ext.encode=Ext.util.JSON.encode;Ext.decode=Ext.util.JSON.decode;Ext.EventManager=function(){var z,p,j=false,l=Ext.isGecko||Ext.isWebKit||Ext.isSafari,o=Ext.lib.Event,q=Ext.lib.Dom,c=document,A=window,r="DOMContentLoaded",t="complete",g=/^(?:scope|delay|buffer|single|stopEvent|preventDefault|stopPropagation|normalized|args|delegate)$/,u=[];function n(E){var H=false,D=0,C=u.length,F=false,G;if(E){if(E.getElementById||E.navigator){for(;D<C;++D){G=u[D];if(G.el===E){H=G.id;break}}if(!H){H=Ext.id(E);u.push({id:H,el:E});F=true}}else{H=Ext.id(E)}if(!Ext.elCache[H]){Ext.Element.addToCache(new Ext.Element(E),H);if(F){Ext.elCache[H].skipGC=true}}}return H}function m(E,G,J,F,D,L){E=Ext.getDom(E);var C=n(E),K=Ext.elC
 ache[C].events,H;H=o.on(E,G,D);K[G]=K[G]||[];K[G].push([J,D,L,H,F]);if(E.addEventListener&&G=="mousewheel"){var I=["DOMMouseScroll",D,false];E.addEventListener.apply(E,I);Ext.EventManager.addListener(A,"unload",function(){E.removeEventListener.apply(E,I)})}if(E==c&&G=="mousedown"){Ext.EventManager.stoppedMouseDownEvent.addListener(D)}}function d(){if(window!=top){return false}try{c.documentElement.doScroll("left")}catch(C){return false}b();return true}function B(C){if(Ext.isIE&&d()){return true}if(c.readyState==t){b();return true}j||(p=setTimeout(arguments.callee,2));return false}var k;function i(C){k||(k=Ext.query("style, link[rel=stylesheet]"));if(k.length==c.styleSheets.length){b();return true}j||(p=setTimeout(arguments.callee,2));return false}function y(C){c.removeEventListener(r,arguments.callee,false);i()}function b(C){if(!j){j=true;if(p){clearTimeout(p)}if(l){c.removeEventListener(r,b,false)}if(Ext.isIE&&B.bindIE){c.detachEvent("onreadystatechange",B)}o.un(A,"load",ar
 guments.callee)}if(z&&!Ext.isReady){Ext.isReady=true;z.fire();z.listeners=[]}}function a(){z||(z=new Ext.util.Event());if(l){c.addEventListener(r,b,false)}if(Ext.isIE){if(!B()){B.bindIE=true;c.attachEvent("onreadystatechange",B)}}else{if(Ext.isOpera){(c.readyState==t&&i())||c.addEventListener(r,y,false)}else{if(Ext.isWebKit){B()}}}o.on(A,"load",b)}function x(C,D){return function(){var E=Ext.toArray(arguments);if(D.target==Ext.EventObject.setEvent(E[0]).target){C.apply(this,E)}}}function w(D,E,C){return function(F){C.delay(E.buffer,D,null,[new Ext.EventObjectImpl(F)])}}function s(G,F,C,E,D){return function(H){Ext.EventManager.removeListener(F,C,E,D);G(H)}}function e(D,E,C){return function(G){var F=new Ext.util.DelayedTask(D);if(!C.tasks){C.tasks=[]}C.tasks.push(F);F.delay(E.delay||10,D,null,[new Ext.EventObjectImpl(G)])}}function h(H,G,C,J,K){var D=(!C||typeof C=="boolean")?{}:C,E=Ext.getDom(H),F;J=J||D.fn;K=K||D.scope;if(!E){throw'Error listening for "'+G+'". Element "'+H+"\
 " doesn't exist."}function I(M){if(!Ext){return}M=Ext.EventObject.setEvent(M);var L;if(D.delegate){if(!(L=M.getTarget(D.delegate,E))){return}}else{L=M.target}if(D.stopEvent){M.stopEvent()}if(D.preventDefault){M.preventDefault()}if(D.stopPropagation){M.stopPropagation()}if(D.normalized===false){M=M.browserEvent}J.call(K||E,M,L,D)}if(D.target){I=x(I,D)}if(D.delay){I=e(I,D,J)}if(D.single){I=s(I,E,G,J,K)}if(D.buffer){F=new Ext.util.DelayedTask(I);I=w(I,D,F)}m(E,G,J,F,I,K);return I}var v={addListener:function(E,C,G,F,D){if(typeof C=="object"){var J=C,H,I;for(H in J){I=J[H];if(!g.test(H)){if(Ext.isFunction(I)){h(E,H,J,I,J.scope)}else{h(E,H,I)}}}}else{h(E,C,D,G,F)}},removeListener:function(E,I,M,N){E=Ext.getDom(E);var C=n(E),K=E&&(Ext.elCache[C].events)[I]||[],D,H,F,G,J,L;for(H=0,J=K.length;H<J;H++){if(Ext.isArray(L=K[H])&&L[0]==M&&(!N||L[2]==N)){if(L[4]){L[4].cancel()}G=M.tasks&&M.tasks.length;if(G){while(G--){M.tasks[G].cancel()}delete M.tasks}D=L[1];o.un(E,I,o.extAdapter?L[3]:D)
 ;if(D&&E.addEventListener&&I=="mousewheel"){E.removeEventListener("DOMMouseScroll",D,false)}if(D&&E==c&&I=="mousedown"){Ext.EventManager.stoppedMouseDownEvent.removeListener(D)}K.splice(H,1);if(K.length===0){delete Ext.elCache[C].events[I]}for(G in Ext.elCache[C].events){return false}Ext.elCache[C].events={};return false}}},removeAll:function(E){E=Ext.getDom(E);var D=n(E),J=Ext.elCache[D]||{},M=J.events||{},I,H,K,F,L,G,C;for(F in M){if(M.hasOwnProperty(F)){I=M[F];for(H=0,K=I.length;H<K;H++){L=I[H];if(L[4]){L[4].cancel()}if(L[0].tasks&&(G=L[0].tasks.length)){while(G--){L[0].tasks[G].cancel()}delete L.tasks}C=L[1];o.un(E,F,o.extAdapter?L[3]:C);if(E.addEventListener&&C&&F=="mousewheel"){E.removeEventListener("DOMMouseScroll",C,false)}if(C&&E==c&&F=="mousedown"){Ext.EventManager.stoppedMouseDownEvent.removeListener(C)}}}}if(Ext.elCache[D]){Ext.elCache[D].events={}}},getListeners:function(F,C){F=Ext.getDom(F);var H=n(F),D=Ext.elCache[H]||{},G=D.events||{},E=[];if(G&&G[C]){return
 G[C]}else{return null}},purgeElement:function(E,C,G){E=Ext.getDom(E);var D=n(E),J=Ext.elCache[D]||{},K=J.events||{},F,I,H;if(G){if(K&&K.hasOwnProperty(G)){I=K[G];for(F=0,H=I.length;F<H;F++){Ext.EventManager.removeListener(E,G,I[F][0])}}}else{Ext.EventManager.removeAll(E)}if(C&&E&&E.childNodes){for(F=0,H=E.childNodes.length;F<H;F++){Ext.EventManager.purgeElement(E.childNodes[F],C,G)}}},_unload:function(){var C;for(C in Ext.elCache){Ext.EventManager.removeAll(C)}delete Ext.elCache;delete Ext.Element._flyweights;var G,D,F,E=Ext.lib.Ajax;(typeof E.conn=="object")?D=E.conn:D={};for(F in D){G=D[F];if(G){E.abort({conn:G,tId:F})}}},onDocumentReady:function(E,D,C){if(Ext.isReady){z||(z=new Ext.util.Event());z.addListener(E,D,C);z.fire();z.listeners=[]}else{if(!z){a()}C=C||{};C.delay=C.delay||1;z.addListener(E,D,C)}},fireDocReady:b};v.on=v.addListener;v.un=v.removeListener;v.stoppedMouseDownEvent=new Ext.util.Event();return v}();Ext.onReady=Ext.EventManager.onDocumentReady;(function()
 {var a=function(){var c=document.body||document.getElementsByTagName("body")[0];if(!c){return false}var b=[" ",Ext.isIE?"ext-ie "+(Ext.isIE6?"ext-ie6":(Ext.isIE7?"ext-ie7":(Ext.isIE8?"ext-ie8":"ext-ie9"))):Ext.isGecko?"ext-gecko "+(Ext.isGecko2?"ext-gecko2":"ext-gecko3"):Ext.isOpera?"ext-opera":Ext.isWebKit?"ext-webkit":""];if(Ext.isSafari){b.push("ext-safari "+(Ext.isSafari2?"ext-safari2":(Ext.isSafari3?"ext-safari3":"ext-safari4")))}else{if(Ext.isChrome){b.push("ext-chrome")}}if(Ext.isMac){b.push("ext-mac")}if(Ext.isLinux){b.push("ext-linux")}if(Ext.isStrict||Ext.isBorderBox){var d=c.parentNode;if(d){if(!Ext.isStrict){Ext.fly(d,"_internal").addClass("x-quirks");if(Ext.isIE&&!Ext.isStrict){Ext.isIEQuirks=true}}Ext.fly(d,"_internal").addClass(((Ext.isStrict&&Ext.isIE)||(!Ext.enableForcedBoxModel&&!Ext.isIE))?" ext-strict":" ext-border-box")}}if(Ext.enableForcedBoxModel&&!Ext.isIE){Ext.isForcedBorderBox=true;b.push("ext-forced-border-box")}Ext.fly(c,"_internal").addClass(b);r
 eturn true};if(!a()){Ext.onReady(a)}})();(function(){var b=Ext.apply(Ext.supports,{correctRightMargin:true,correctTransparentColor:true,cssFloat:true});var a=function(){var g=document.createElement("div"),e=document,c,d;g.innerHTML='<div style="height:30px;width:50px;"><div style="height:20px;width:20px;"></div></div><div style="float:left;background-color:transparent;">';e.body.appendChild(g);d=g.lastChild;if((c=e.defaultView)){if(c.getComputedStyle(g.firstChild.firstChild,null).marginRight!="0px"){b.correctRightMargin=false}if(c.getComputedStyle(d,null).backgroundColor!="transparent"){b.correctTransparentColor=false}}b.cssFloat=!!d.style.cssFloat;e.body.removeChild(g)};if(Ext.isReady){a()}else{Ext.onReady(a)}})();Ext.EventObject=function(){var b=Ext.lib.Event,c=/(dbl)?click/,a={3:13,63234:37,63235:39,63232:38,63233:40,63276:33,63277:34,63272:46,63273:36,63275:35},d=Ext.isIE?{1:0,4:1,2:2}:{0:0,1:1,2:2};Ext.EventObjectImpl=function(g){if(g){this.setEvent(g.browserEvent||g)}}
 ;Ext.EventObjectImpl.prototype={setEvent:function(h){var g=this;if(h==g||(h&&h.browserEvent)){return h}g.browserEvent=h;if(h){g.button=h.button?d[h.button]:(h.which?h.which-1:-1);if(c.test(h.type)&&g.button==-1){g.button=0}g.type=h.type;g.shiftKey=h.shiftKey;g.ctrlKey=h.ctrlKey||h.metaKey||false;g.altKey=h.altKey;g.keyCode=h.keyCode;g.charCode=h.charCode;g.target=b.getTarget(h);g.xy=b.getXY(h)}else{g.button=-1;g.shiftKey=false;g.ctrlKey=false;g.altKey=false;g.keyCode=0;g.charCode=0;g.target=null;g.xy=[0,0]}return g},stopEvent:function(){var e=this;if(e.browserEvent){if(e.browserEvent.type=="mousedown"){Ext.EventManager.stoppedMouseDownEvent.fire(e)}b.stopEvent(e.browserEvent)}},preventDefault:function(){if(this.browserEvent){b.preventDefault(this.browserEvent)}},stopPropagation:function(){var e=this;if(e.browserEvent){if(e.browserEvent.type=="mousedown"){Ext.EventManager.stoppedMouseDownEvent.fire(e)}b.stopPropagation(e.browserEvent)}},getCharCode:function(){return this.char
 Code||this.keyCode},getKey:function(){return this.normalizeKey(this.keyCode||this.charCode)},normalizeKey:function(e){return Ext.isSafari?(a[e]||e):e},getPageX:function(){return this.xy[0]},getPageY:function(){return this.xy[1]},getXY:function(){return this.xy},getTarget:function(g,h,e){return g?Ext.fly(this.target).findParent(g,h,e):(e?Ext.get(this.target):this.target)},getRelatedTarget:function(){return this.browserEvent?b.getRelatedTarget(this.browserEvent):null},getWheelDelta:function(){var g=this.browserEvent;var h=0;if(g.wheelDelta){h=g.wheelDelta/120}else{if(g.detail){h=-g.detail/3}}return h},within:function(h,i,e){if(h){var g=this[i?"getRelatedTarget":"getTarget"]();return g&&((e?(g==Ext.getDom(h)):false)||Ext.fly(h).contains(g))}return false}};return new Ext.EventObjectImpl()}();Ext.Loader=Ext.apply({},{load:function(j,i,k,c){var k=k||this,g=document.getElementsByTagName("head")[0],b=document.createDocumentFragment(),a=j.length,h=0,e=this;var l=function(m){g.appendC
 hild(e.buildScriptTag(j[m],d))};var d=function(){h++;if(a==h&&typeof i=="function"){i.call(k)}else{if(c===true){l(h)}}};if(c===true){l.call(this,0)}else{Ext.each(j,function(n,m){b.appendChild(this.buildScriptTag(n,d))},this);g.appendChild(b)}},buildScriptTag:function(b,c){var a=document.createElement("script");a.type="text/javascript";a.src=b;if(a.readyState){a.onreadystatechange=function(){if(a.readyState=="loaded"||a.readyState=="complete"){a.onreadystatechange=null;c()}}}else{a.onload=c}return a}});Ext.ns("Ext.grid","Ext.list","Ext.dd","Ext.tree","Ext.form","Ext.menu","Ext.state","Ext.layout.boxOverflow","Ext.app","Ext.ux","Ext.chart","Ext.direct","Ext.slider");Ext.apply(Ext,function(){var c=Ext,a=0,b=null;return{emptyFn:function(){},BLANK_IMAGE_URL:Ext.isIE6||Ext.isIE7||Ext.isAir?"http://www.extjs.com/s.gif":"data:image/gif;base64,R0lGODlhAQABAID/AMDAwAAAACH5BAEAAAAALAAAAAABAAEAAAICRAEAOw==",extendX:function(d,e){return Ext.extend(d,e(d.prototype))},getDoc:function(){ret
 urn Ext.get(document)},num:function(e,d){e=Number(Ext.isEmpty(e)||Ext.isArray(e)||typeof e=="boolean"||(typeof e=="string"&&e.trim().length==0)?NaN:e);return isNaN(e)?d:e},value:function(g,d,e){return Ext.isEmpty(g,e)?d:g},escapeRe:function(d){return d.replace(/([-.*+?^${}()|[\]\/\\])/g,"\\$1")},sequence:function(h,d,g,e){h[d]=h[d].createSequence(g,e)},addBehaviors:function(i){if(!Ext.isReady){Ext.onReady(function(){Ext.addBehaviors(i)})}else{var e={},h,d,g;for(d in i){if((h=d.split("@"))[1]){g=h[0];if(!e[g]){e[g]=Ext.select(g)}e[g].on(h[1],i[d])}}e=null}},getScrollBarWidth:function(g){if(!Ext.isReady){return 0}if(g===true||b===null){var i=Ext.getBody().createChild('<div class="x-hide-offsets" style="width:100px;height:50px;overflow:hidden;"><div style="height:200px;"></div></div>'),h=i.child("div",true);var e=h.offsetWidth;i.setStyle("overflow",(Ext.isWebKit||Ext.isGecko)?"auto":"scroll");var d=h.offsetWidth;i.remove();b=e-d+2}return b},combine:function(){var g=arguments,e=
 g.length,j=[];for(var h=0;h<e;h++){var d=g[h];if(Ext.isArray(d)){j=j.concat(d)}else{if(d.length!==undefined&&!d.substr){j=j.concat(Array.prototype.slice.call(d,0))}else{j.push(d)}}}return j},copyTo:function(d,e,g){if(typeof g=="string"){g=g.split(/[,;\s]/)}Ext.each(g,function(h){if(e.hasOwnProperty(h)){d[h]=e[h]}},this);return d},destroy:function(){Ext.each(arguments,function(d){if(d){if(Ext.isArray(d)){this.destroy.apply(this,d)}else{if(typeof d.destroy=="function"){d.destroy()}else{if(d.dom){d.remove()}}}}},this)},destroyMembers:function(l,j,g,h){for(var k=1,e=arguments,d=e.length;k<d;k++){Ext.destroy(l[e[k]]);delete l[e[k]]}},clean:function(d){var e=[];Ext.each(d,function(g){if(!!g){e.push(g)}});return e},unique:function(d){var e=[],g={};Ext.each(d,function(h){if(!g[h]){e.push(h)}g[h]=true});return e},flatten:function(d){var g=[];function e(h){Ext.each(h,function(i){if(Ext.isArray(i)){e(i)}else{g.push(i)}});return g}return e(d)},min:function(d,e){var g=d[0];e=e||function(
 i,h){return i<h?-1:1};Ext.each(d,function(h){g=e(g,h)==-1?g:h});return g},max:function(d,e){var g=d[0];e=e||function(i,h){return i>h?1:-1};Ext.each(d,function(h){g=e(g,h)==1?g:h});return g},mean:function(d){return d.length>0?Ext.sum(d)/d.length:undefined},sum:function(d){var e=0;Ext.each(d,function(g){e+=g});return e},partition:function(d,e){var g=[[],[]];Ext.each(d,function(j,k,h){g[(e&&e(j,k,h))||(!e&&j)?0:1].push(j)});return g},invoke:function(d,e){var h=[],g=Array.prototype.slice.call(arguments,2);Ext.each(d,function(j,k){if(j&&typeof j[e]=="function"){h.push(j[e].apply(j,g))}else{h.push(undefined)}});return h},pluck:function(d,g){var e=[];Ext.each(d,function(h){e.push(h[g])});return e},zip:function(){var n=Ext.partition(arguments,function(i){return typeof i!="function"}),k=n[0],m=n[1][0],d=Ext.max(Ext.pluck(k,"length")),h=[];for(var l=0;l<d;l++){h[l]=[];if(m){h[l]=m.apply(m,Ext.pluck(k,l))}else{for(var g=0,e=k.length;g<e;g++){h[l].push(k[g][l])}}}return h},getCmp:functi
 on(d){return Ext.ComponentMgr.get(d)},useShims:c.isIE6||(c.isMac&&c.isGecko2),type:function(e){if(e===undefined||e===null){return false}if(e.htmlElement){return"element"}var d=typeof e;if(d=="object"&&e.nodeName){switch(e.nodeType){case 1:return"element";case 3:return(/\S/).test(e.nodeValue)?"textnode":"whitespace"}}if(d=="object"||d=="function"){switch(e.constructor){case Array:return"array";case RegExp:return"regexp";case Date:return"date"}if(typeof e.length=="number"&&typeof e.item=="function"){return"nodelist"}}return d},intercept:function(h,d,g,e){h[d]=h[d].createInterceptor(g,e)},callback:function(d,h,g,e){if(typeof d=="function"){if(e){d.defer(e,h,g||[])}else{d.apply(h,g||[])}}}}}());Ext.apply(Function.prototype,{createSequence:function(b,a){var c=this;return(typeof b!="function")?this:function(){var d=c.apply(this||window,arguments);b.apply(a||this||window,arguments);return d}}});Ext.applyIf(String,{escape:function(a){return a.replace(/('|\\)/g,"\\$1")},leftPad:funct
 ion(d,b,c){var a=String(d);if(!c){c=" "}while(a.length<b){a=c+a}return a}});String.prototype.toggle=function(b,a){return this==b?a:b};String.prototype.trim=function(){var a=/^\s+|\s+$/g;return function(){return this.replace(a,"")}}();Date.prototype.getElapsed=function(a){return Math.abs((a||new Date()).getTime()-this.getTime())};Ext.applyIf(Number.prototype,{constrain:function(b,a){return Math.min(Math.max(this,b),a)}});Ext.lib.Dom.getRegion=function(a){return Ext.lib.Region.getRegion(a)};Ext.lib.Region=function(d,g,a,c){var e=this;e.top=d;e[1]=d;e.right=g;e.bottom=a;e.left=c;e[0]=c};Ext.lib.Region.prototype={contains:function(b){var a=this;return(b.left>=a.left&&b.right<=a.right&&b.top>=a.top&&b.bottom<=a.bottom)},getArea:function(){var a=this;return((a.bottom-a.top)*(a.right-a.left))},intersect:function(h){var g=this,d=Math.max(g.top,h.top),e=Math.min(g.right,h.right),a=Math.min(g.bottom,h.bottom),c=Math.max(g.left,h.left);if(a>=d&&e>=c){return new Ext.lib.Region(d,e,a,c)}
 },union:function(h){var g=this,d=Math.min(g.top,h.top),e=Math.max(g.right,h.right),a=Math.max(g.bottom,h.bottom),c=Math.min(g.left,h.left);return new Ext.lib.Region(d,e,a,c)},constrainTo:function(b){var a=this;a.top=a.top.constrain(b.top,b.bottom);a.bottom=a.bottom.constrain(b.top,b.bottom);a.left=a.left.constrain(b.left,b.right);a.right=a.right.constrain(b.left,b.right);return a},adjust:function(d,c,a,g){var e=this;e.top+=d;e.left+=c;e.right+=g;e.bottom+=a;return e}};Ext.lib.Region.getRegion=function(e){var h=Ext.lib.Dom.getXY(e),d=h[1],g=h[0]+e.offsetWidth,a=h[1]+e.offsetHeight,c=h[0];return new Ext.lib.Region(d,g,a,c)};Ext.lib.Point=function(a,c){if(Ext.isArray(a)){c=a[1];a=a[0]}var b=this;b.x=b.right=b.left=b[0]=a;b.y=b.top=b.bottom=b[1]=c};Ext.lib.Point.prototype=new Ext.lib.Region();Ext.apply(Ext.DomHelper,function(){var e,a="afterbegin",h="afterend",i="beforebegin",d="beforeend",b=/tag|children|cn|html$/i;function g(m,p,n,q,l,j){m=Ext.getDom(m);var k;if(e.useDom){k=c(
 p,null);if(j){m.appendChild(k)}else{(l=="firstChild"?m:m.parentNode).insertBefore(k,m[l]||m)}}else{k=Ext.DomHelper.insertHtml(q,m,Ext.DomHelper.createHtml(p))}return n?Ext.get(k,true):k}function c(j,r){var k,u=document,p,s,m,t;if(Ext.isArray(j)){k=u.createDocumentFragment();for(var q=0,n=j.length;q<n;q++){c(j[q],k)}}else{if(typeof j=="string"){k=u.createTextNode(j)}else{k=u.createElement(j.tag||"div");p=!!k.setAttribute;for(var s in j){if(!b.test(s)){m=j[s];if(s=="cls"){k.className=m}else{if(p){k.setAttribute(s,m)}else{k[s]=m}}}}Ext.DomHelper.applyStyles(k,j.style);if((t=j.children||j.cn)){c(t,k)}else{if(j.html){k.innerHTML=j.html}}}}if(r){r.appendChild(k)}return k}e={createTemplate:function(k){var j=Ext.DomHelper.createHtml(k);return new Ext.Template(j)},useDom:false,insertBefore:function(j,l,k){return g(j,l,k,i)},insertAfter:function(j,l,k){return g(j,l,k,h,"nextSibling")},insertFirst:function(j,l,k){return g(j,l,k,a,"firstChild")},append:function(j,l,k){return g(j,l,k,d,"
 ",true)},createDom:c};return e}());Ext.apply(Ext.Template.prototype,{disableFormats:false,re:/\{([\w\-]+)(?:\:([\w\.]*)(?:\((.*?)?\))?)?\}/g,argsRe:/^\s*['"](.*)["']\s*$/,compileARe:/\\/g,compileBRe:/(\r\n|\n)/g,compileCRe:/'/g,applyTemplate:function(b){var g=this,a=g.disableFormats!==true,e=Ext.util.Format,c=g;if(g.compiled){return g.compiled(b)}function d(j,l,p,k){if(p&&a){if(p.substr(0,5)=="this."){return c.call(p.substr(5),b[l],b)}else{if(k){var o=g.argsRe;k=k.split(",");for(var n=0,h=k.length;n<h;n++){k[n]=k[n].replace(o,"$1")}k=[b[l]].concat(k)}else{k=[b[l]]}return e[p].apply(e,k)}}else{return b[l]!==undefined?b[l]:""}}return g.html.replace(g.re,d)},compile:function(){var me=this,fm=Ext.util.Format,useF=me.disableFormats!==true,sep=Ext.isGecko?"+":",",body;function fn(m,name,format,args){if(format&&useF){args=args?","+args:"";if(format.substr(0,5)!="this."){format="fm."+format+"("}else{format='this.call("'+format.substr(5)+'", ';args=", values"}}else{args="";format="(v
 alues['"+name+"'] == undefined ? '' : "}return"'"+sep+format+"values['"+name+"']"+args+")"+sep+"'"}if(Ext.isGecko){body="this.compiled = function(values){ return '"+me.html.replace(me.compileARe,"\\\\").replace(me.compileBRe,"\\n").replace(me.compileCRe,"\\'").replace(me.re,fn)+"';};"}else{body=["this.compiled = function(values){ return ['"];body.push(me.html.replace(me.compileARe,"\\\\").replace(me.compileBRe,"\\n").replace(me.compileCRe,"\\'").replace(me.re,fn));body.push("'].join('');};");body=body.join("")}eval(body);return me},call:function(c,b,a){return this[c](b,a)}});Ext.Template.prototype.apply=Ext.Template.prototype.applyTemplate;Ext.util.Functions={createInterceptor:function(c,b,a){var d=c;if(!Ext.isFunction(b)){return c}else{return function(){var g=this,e=arguments;b.target=g;b.method=c;return(b.apply(a||g||window,e)!==false)?c.apply(g||window,e):null}}},createDelegate:function(c,d,b,a){if(!Ext.isFunction(c)){return c}return function(){var g=b||arguments;if(a===t
 rue){g=Array.prototype.slice.call(arguments,0);g=g.concat(b)}else{if(Ext.isNumber(a)){g=Array.prototype.slice.call(arguments,0);var e=[a,0].concat(b);Array.prototype.splice.apply(g,e)}}return c.apply(d||window,g)}},defer:function(d,c,e,b,a){d=Ext.util.Functions.createDelegate(d,e,b,a);if(c>0){return setTimeout(d,c)}d();return 0},createSequence:function(c,b,a){if(!Ext.isFunction(b)){return c}else{return function(){var d=c.apply(this||window,arguments);b.apply(a||this||window,arguments);return d}}}};Ext.defer=Ext.util.Functions.defer;Ext.createInterceptor=Ext.util.Functions.createInterceptor;Ext.createSequence=Ext.util.Functions.createSequence;Ext.createDelegate=Ext.util.Functions.createDelegate;Ext.apply(Ext.util.Observable.prototype,function(){function a(j){var i=(this.methodEvents=this.methodEvents||{})[j],d,c,g,h=this;if(!i){this.methodEvents[j]=i={};i.originalFn=this[j];i.methodName=j;i.before=[];i.after=[];var b=function(l,k,e){if((c=l.apply(k||h,e))!==undefined){if(type
 of c=="object"){if(c.returnValue!==undefined){d=c.returnValue}else{d=c}g=!!c.cancel}else{if(c===false){g=true}else{d=c}}}};this[j]=function(){var l=Array.prototype.slice.call(arguments,0),k;d=c=undefined;g=false;for(var m=0,e=i.before.length;m<e;m++){k=i.before[m];b(k.fn,k.scope,l);if(g){return d}}if((c=i.originalFn.apply(h,l))!==undefined){d=c}for(var m=0,e=i.after.length;m<e;m++){k=i.after[m];b(k.fn,k.scope,l);if(g){return d}}return d}}return i}return{beforeMethod:function(d,c,b){a.call(this,d).before.push({fn:c,scope:b})},afterMethod:function(d,c,b){a.call(this,d).after.push({fn:c,scope:b})},removeMethodListener:function(j,g,d){var h=this.getMethodEvent(j);for(var c=0,b=h.before.length;c<b;c++){if(h.before[c].fn==g&&h.before[c].scope==d){h.before.splice(c,1);return}}for(var c=0,b=h.after.length;c<b;c++){if(h.after[c].fn==g&&h.after[c].scope==d){h.after.splice(c,1);return}}},relayEvents:function(j,e){var h=this;function g(i){return function(){return h.fireEvent.apply(h,[i]
 .concat(Array.prototype.slice.call(arguments,0)))}}for(var d=0,b=e.length;d<b;d++){var c=e[d];h.events[c]=h.events[c]||true;j.on(c,g(c),h)}},enableBubble:function(e){var g=this;if(!Ext.isEmpty(e)){e=Ext.isArray(e)?e:Array.prototype.slice.call(arguments,0);for(var d=0,b=e.length;d<b;d++){var c=e[d];c=c.toLowerCase();var h=g.events[c]||true;if(typeof h=="boolean"){h=new Ext.util.Event(g,c);g.events[c]=h}h.bubble=true}}}}}());Ext.util.Observable.capture=function(c,b,a){c.fireEvent=c.fireEvent.createInterceptor(b,a)};Ext.util.Observable.observeClass=function(b,a){if(b){if(!b.fireEvent){Ext.apply(b,new Ext.util.Observable());Ext.util.Observable.capture(b.prototype,b.fireEvent,b)}if(typeof a=="object"){b.on(a)}return b}};Ext.apply(Ext.EventManager,function(){var d,k,g,b,a=Ext.lib.Dom,j=/^(?:scope|delay|buffer|single|stopEvent|preventDefault|stopPropagation|normalized|args|delegate)$/,c=Ext.EventManager._unload,i=0,h=0,e=Ext.isWebKit?Ext.num(navigator.userAgent.match(/AppleWebKit\/
 (\d+)/)[1])>=525:!((Ext.isGecko&&!Ext.isWindows)||Ext.isOpera);return{_unload:function(){Ext.EventManager.un(window,"resize",this.fireWindowResize,this);c.call(Ext.EventManager)},doResizeEvent:function(){var m=a.getViewHeight(),l=a.getViewWidth();if(h!=m||i!=l){d.fire(i=l,h=m)}},onWindowResize:function(n,m,l){if(!d){d=new Ext.util.Event();k=new Ext.util.DelayedTask(this.doResizeEvent);Ext.EventManager.on(window,"resize",this.fireWindowResize,this)}d.addListener(n,m,l)},fireWindowResize:function(){if(d){k.delay(100)}},onTextResize:function(o,n,l){if(!g){g=new Ext.util.Event();var m=new Ext.Element(document.createElement("div"));m.dom.className="x-text-resize";m.dom.innerHTML="X";m.appendTo(document.body);b=m.dom.offsetHeight;setInterval(function(){if(m.dom.offsetHeight!=b){g.fire(b,b=m.dom.offsetHeight)}},this.textResizeInterval)}g.addListener(o,n,l)},removeResizeListener:function(m,l){if(d){d.removeListener(m,l)}},fireResize:function(){if(d){d.fire(a.getViewWidth(),a.getView
 Height())}},textResizeInterval:50,ieDeferSrc:false,getKeyEvent:function(){return e?"keydown":"keypress"},useKeydown:e}}());Ext.EventManager.on=Ext.EventManager.addListener;Ext.apply(Ext.EventObjectImpl.prototype,{BACKSPACE:8,TAB:9,NUM_CENTER:12,ENTER:13,RETURN:13,SHIFT:16,CTRL:17,CONTROL:17,ALT:18,PAUSE:19,CAPS_LOCK:20,ESC:27,SPACE:32,PAGE_UP:33,PAGEUP:33,PAGE_DOWN:34,PAGEDOWN:34,END:35,HOME:36,LEFT:37,UP:38,RIGHT:39,DOWN:40,PRINT_SCREEN:44,INSERT:45,DELETE:46,ZERO:48,ONE:49,TWO:50,THREE:51,FOUR:52,FIVE:53,SIX:54,SEVEN:55,EIGHT:56,NINE:57,A:65,B:66,C:67,D:68,E:69,F:70,G:71,H:72,I:73,J:74,K:75,L:76,M:77,N:78,O:79,P:80,Q:81,R:82,S:83,T:84,U:85,V:86,W:87,X:88,Y:89,Z:90,CONTEXT_MENU:93,NUM_ZERO:96,NUM_ONE:97,NUM_TWO:98,NUM_THREE:99,NUM_FOUR:100,NUM_FIVE:101,NUM_SIX:102,NUM_SEVEN:103,NUM_EIGHT:104,NUM_NINE:105,NUM_MULTIPLY:106,NUM_PLUS:107,NUM_MINUS:109,NUM_PERIOD:110,NUM_DIVISION:111,F1:112,F2:113,F3:114,F4:115,F5:116,F6:117,F7:118,F8:119,F9:120,F10:121,F11:122,F12:123,isNavKeyP
 ress:function(){var b=this,a=this.normalizeKey(b.keyCode);return(a>=33&&a<=40)||a==b.RETURN||a==b.TAB||a==b.ESC},isSpecialKey:function(){var a=this.normalizeKey(this.keyCode);return(this.type=="keypress"&&this.ctrlKey)||this.isNavKeyPress()||(a==this.BACKSPACE)||(a>=16&&a<=20)||(a>=44&&a<=46)},getPoint:function(){return new Ext.lib.Point(this.xy[0],this.xy[1])},hasModifier:function(){return((this.ctrlKey||this.altKey)||this.shiftKey)}});Ext.Element.addMethods({swallowEvent:function(a,b){var d=this;function c(g){g.stopPropagation();if(b){g.preventDefault()}}if(Ext.isArray(a)){Ext.each(a,function(g){d.on(g,c)});return d}d.on(a,c);return d},relayEvent:function(a,b){this.on(a,function(c){b.fireEvent(a,c)})},clean:function(b){var d=this,e=d.dom,g=e.firstChild,c=-1;if(Ext.Element.data(e,"isCleaned")&&b!==true){return d}while(g){var a=g.nextSibling;if(g.nodeType==3&&!(/\S/.test(g.nodeValue))){e.removeChild(g)}else{g.nodeIndex=++c}g=a}Ext.Element.data(e,"isCleaned",true);return d},l
 oad:function(){var a=this.getUpdater();a.update.apply(a,arguments);return this},getUpdater:function(){return this.updateManager||(this.updateManager=new Ext.Updater(this))},update:function(html,loadScripts,callback){if(!this.dom){return this}html=html||"";if(loadScripts!==true){this.dom.innerHTML=html;if(typeof callback=="function"){callback()}return this}var id=Ext.id(),dom=this.dom;html+='<span id="'+id+'"></span>';Ext.lib.Event.onAvailable(id,function(){var DOC=document,hd=DOC.getElementsByTagName("head")[0],re=/(?:<script([^>]*)?>)((\n|\r|.)*?)(?:<\/script>)/ig,srcRe=/\ssrc=([\'\"])(.*?)\1/i,typeRe=/\stype=([\'\"])(.*?)\1/i,match,attrs,srcMatch,typeMatch,el,s;while((match=re.exec(html))){attrs=match[1];srcMatch=attrs?attrs.match(srcRe):false;if(srcMatch&&srcMatch[2]){s=DOC.createElement("script");s.src=srcMatch[2];typeMatch=attrs.match(typeRe);if(typeMatch&&typeMatch[2]){s.type=typeMatch[2]}hd.appendChild(s)}else{if(match[2]&&match[2].length>0){if(window.execScript){wind
 ow.execScript(match[2])}else{window.eval(match[2])}}}}el=DOC.getElementById(id);if(el){Ext.removeNode(el)}if(typeof callback=="function"){callback()}});dom.innerHTML=html.replace(/(?:<script.*?>)((\n|\r|.)*?)(?:<\/script>)/ig,"");return this},removeAllListeners:function(){this.removeAnchor();Ext.EventManager.removeAll(this.dom);return this},createProxy:function(a,e,d){a=(typeof a=="object")?a:{tag:"div",cls:a};var c=this,b=e?Ext.DomHelper.append(e,a,true):Ext.DomHelper.insertBefore(c.dom,a,true);if(d&&c.setBox&&c.getBox){b.setBox(c.getBox())}return b}});Ext.Element.prototype.getUpdateManager=Ext.Element.prototype.getUpdater;Ext.Element.addMethods({getAnchorXY:function(e,l,q){e=(e||"tl").toLowerCase();q=q||{};var k=this,b=k.dom==document.body||k.dom==document,n=q.width||b?Ext.lib.Dom.getViewWidth():k.getWidth(),i=q.height||b?Ext.lib.Dom.getViewHeight():k.getHeight(),p,a=Math.round,c=k.getXY(),m=k.getScroll(),j=b?m.left:!l?c[0]:0,g=b?m.top:!l?c[1]:0,d={c:[a(n*0.5),a(i*0.5)],t:
 [a(n*0.5),0],l:[0,a(i*0.5)],r:[n,a(i*0.5)],b:[a(n*0.5),i],tl:[0,0],bl:[0,i],br:[n,i],tr:[n,0]};p=d[e];return[p[0]+j,p[1]+g]},anchorTo:function(b,h,c,a,k,l){var i=this,e=i.dom,j=!Ext.isEmpty(k),d=function(){Ext.fly(e).alignTo(b,h,c,a);Ext.callback(l,Ext.fly(e))},g=this.getAnchor();this.removeAnchor();Ext.apply(g,{fn:d,scroll:j});Ext.EventManager.onWindowResize(d,null);if(j){Ext.EventManager.on(window,"scroll",d,null,{buffer:!isNaN(k)?k:50})}d.call(i);return i},removeAnchor:function(){var b=this,a=this.getAnchor();if(a&&a.fn){Ext.EventManager.removeResizeListener(a.fn);if(a.scroll){Ext.EventManager.un(window,"scroll",a.fn)}delete a.fn}return b},getAnchor:function(){var b=Ext.Element.data,c=this.dom;if(!c){return}var a=b(c,"_anchor");if(!a){a=b(c,"_anchor",{})}return a},getAlignToXY:function(g,A,B){g=Ext.get(g);if(!g||!g.dom){throw"Element.alignToXY with an element that doesn't exist"}B=B||[0,0];A=(!A||A=="?"?"tl-bl?":(!(/-/).test(A)&&A!==""?"tl-"+A:A||"tl-bl")).toLowerCase();v
 ar K=this,H=K.dom,M,L,n,l,s,F,v,t=Ext.lib.Dom.getViewWidth()-10,G=Ext.lib.Dom.getViewHeight()-10,b,i,j,k,u,z,N=document,J=N.documentElement,q=N.body,E=(J.scrollLeft||q.scrollLeft||0)+5,D=(J.scrollTop||q.scrollTop||0)+5,I=false,e="",a="",C=A.match(/^([a-z]+)-([a-z]+)(\?)?$/);if(!C){throw"Element.alignTo with an invalid alignment "+A}e=C[1];a=C[2];I=!!C[3];M=K.getAnchorXY(e,true);L=g.getAnchorXY(a,false);n=L[0]-M[0]+B[0];l=L[1]-M[1]+B[1];if(I){s=K.getWidth();F=K.getHeight();v=g.getRegion();b=e.charAt(0);i=e.charAt(e.length-1);j=a.charAt(0);k=a.charAt(a.length-1);u=((b=="t"&&j=="b")||(b=="b"&&j=="t"));z=((i=="r"&&k=="l")||(i=="l"&&k=="r"));if(n+s>t+E){n=z?v.left-s:t+E-s}if(n<E){n=z?v.right:E}if(l+F>G+D){l=u?v.top-F:G+D-F}if(l<D){l=u?v.bottom:D}}return[n,l]},alignTo:function(c,a,e,b){var d=this;return d.setXY(d.getAlignToXY(c,a,e),d.preanim&&!!b?d.preanim(arguments,3):false)},adjustForConstraints:function(c,a,b){return this.getConstrainToXY(a||document,false,b,c)||c},getConstrai
 nToXY:function(b,a,c,e){var d={top:0,left:0,bottom:0,right:0};return function(i,A,l,n){i=Ext.get(i);l=l?Ext.applyIf(l,d):d;var z,D,v=0,u=0;if(i.dom==document.body||i.dom==document){z=Ext.lib.Dom.getViewWidth();D=Ext.lib.Dom.getViewHeight()}else{z=i.dom.clientWidth;D=i.dom.clientHeight;if(!A){var t=i.getXY();v=t[0];u=t[1]}}var r=i.getScroll();v+=l.left+r.left;u+=l.top+r.top;z-=l.right;D-=l.bottom;var B=v+z,g=u+D,j=n||(!A?this.getXY():[this.getLeft(true),this.getTop(true)]),p=j[0],o=j[1],k=this.getConstrainOffset(),q=this.dom.offsetWidth+k,C=this.dom.offsetHeight+k;var m=false;if((p+q)>B){p=B-q;m=true}if((o+C)>g){o=g-C;m=true}if(p<v){p=v;m=true}if(o<u){o=u;m=true}return m?[p,o]:false}}(),getConstrainOffset:function(){return 0},getCenterXY:function(){return this.getAlignToXY(document,"c-c")},center:function(a){return this.alignTo(a||document,"c-c")}});Ext.Element.addMethods({select:function(a,b){return Ext.Element.select(a,b,this.dom)}});Ext.apply(Ext.Element.prototype,function
 (){var c=Ext.getDom,a=Ext.get,b=Ext.DomHelper;return{insertSibling:function(i,g,h){var j=this,e,d=(g||"before").toLowerCase()=="after",k;if(Ext.isArray(i)){k=j;Ext.each(i,function(l){e=Ext.fly(k,"_internal").insertSibling(l,g,h);if(d){k=e}});return e}i=i||{};if(i.nodeType||i.dom){e=j.dom.parentNode.insertBefore(c(i),d?j.dom.nextSibling:j.dom);if(!h){e=a(e)}}else{if(d&&!j.dom.nextSibling){e=b.append(j.dom.parentNode,i,!h)}else{e=b[d?"insertAfter":"insertBefore"](j.dom,i,!h)}}return e}}}());Ext.Element.boxMarkup='<div class="{0}-tl"><div class="{0}-tr"><div class="{0}-tc"></div></div></div><div class="{0}-ml"><div class="{0}-mr"><div class="{0}-mc"></div></div></div><div class="{0}-bl"><div class="{0}-br"><div class="{0}-bc"></div></div></div>';Ext.Element.addMethods(function(){var a="_internal",b=/(\d+\.?\d+)px/;return{applyStyles:function(c){Ext.DomHelper.applyStyles(this.dom,c);return this},getStyles:function(){var c={};Ext.each(arguments,function(d){c[d]=this.getStyle(d)},
 this);return c},setOverflow:function(c){var d=this.dom;if(c=="auto"&&Ext.isMac&&Ext.isGecko2){d.style.overflow="hidden";(function(){d.style.overflow="auto"}).defer(1)}else{d.style.overflow=c}},boxWrap:function(c){c=c||"x-box";var d=Ext.get(this.insertHtml("beforeBegin","<div class='"+c+"'>"+String.format(Ext.Element.boxMarkup,c)+"</div>"));Ext.DomQuery.selectNode("."+c+"-mc",d.dom).appendChild(this.dom);return d},setSize:function(e,c,d){var g=this;if(typeof e=="object"){c=e.height;e=e.width}e=g.adjustWidth(e);c=g.adjustHeight(c);if(!d||!g.anim){g.dom.style.width=g.addUnits(e);g.dom.style.height=g.addUnits(c)}else{g.anim({width:{to:e},height:{to:c}},g.preanim(arguments,2))}return g},getComputedHeight:function(){var d=this,c=Math.max(d.dom.offsetHeight,d.dom.clientHeight);if(!c){c=parseFloat(d.getStyle("height"))||0;if(!d.isBorderBox()){c+=d.getFrameWidth("tb")}}return c},getComputedWidth:function(){var c=Math.max(this.dom.offsetWidth,this.dom.clientWidth);if(!c){c=parseFloat(
 this.getStyle("width"))||0;if(!this.isBorderBox()){c+=this.getFrameWidth("lr")}}return c},getFrameWidth:function(d,c){return c&&this.isBorderBox()?0:(this.getPadding(d)+this.getBorderWidth(d))},addClassOnOver:function(c){this.hover(function(){Ext.fly(this,a).addClass(c)},function(){Ext.fly(this,a).removeClass(c)});return this},addClassOnFocus:function(c){this.on("focus",function(){Ext.fly(this,a).addClass(c)},this.dom);this.on("blur",function(){Ext.fly(this,a).removeClass(c)},this.dom);return this},addClassOnClick:function(c){var d=this.dom;this.on("mousedown",function(){Ext.fly(d,a).addClass(c);var g=Ext.getDoc(),e=function(){Ext.fly(d,a).removeClass(c);g.removeListener("mouseup",e)};g.on("mouseup",e)});return this},getViewSize:function(){var g=document,h=this.dom,c=(h==g||h==g.body);if(c){var e=Ext.lib.Dom;return{width:e.getViewWidth(),height:e.getViewHeight()}}else{return{width:h.clientWidth,height:h.clientHeight}}},getStyleSize:function(){var j=this,c,i,l=document,m=this
 .dom,e=(m==l||m==l.body),g=m.style;if(e){var k=Ext.lib.Dom;return{width:k.getViewWidth(),height:k.getViewHeight()}}if(g.width&&g.width!="auto"){c=parseFloat(g.width);if(j.isBorderBox()){c-=j.getFrameWidth("lr")}}if(g.height&&g.height!="auto"){i=parseFloat(g.height);if(j.isBorderBox()){i-=j.getFrameWidth("tb")}}return{width:c||j.getWidth(true),height:i||j.getHeight(true)}},getSize:function(c){return{width:this.getWidth(c),height:this.getHeight(c)}},repaint:function(){var c=this.dom;this.addClass("x-repaint");setTimeout(function(){Ext.fly(c).removeClass("x-repaint")},1);return this},unselectable:function(){this.dom.unselectable="on";return this.swallowEvent("selectstart",true).applyStyles("-moz-user-select:none;-khtml-user-select:none;").addClass("x-unselectable")},getMargins:function(d){var e=this,c,g={t:"top",l:"left",r:"right",b:"bottom"},h={};if(!d){for(c in e.margins){h[g[c]]=parseFloat(e.getStyle(e.margins[c]))||0}return h}else{return e.addStyles.call(e,d,e.margins)}}}}(
 ));Ext.Element.addMethods({setBox:function(e,g,b){var d=this,a=e.width,c=e.height;if((g&&!d.autoBoxAdjust)&&!d.isBorderBox()){a-=(d.getBorderWidth("lr")+d.getPadding("lr"));c-=(d.getBorderWidth("tb")+d.getPadding("tb"))}d.setBounds(e.x,e.y,a,c,d.animTest.call(d,arguments,b,2));return d},getBox:function(j,p){var m=this,v,e,o,d=m.getBorderWidth,q=m.getPadding,g,a,u,n;if(!p){v=m.getXY()}else{e=parseInt(m.getStyle("left"),10)||0;o=parseInt(m.getStyle("top"),10)||0;v=[e,o]}var c=m.dom,s=c.offsetWidth,i=c.offsetHeight,k;if(!j){k={x:v[0],y:v[1],0:v[0],1:v[1],width:s,height:i}}else{g=d.call(m,"l")+q.call(m,"l");a=d.call(m,"r")+q.call(m,"r");u=d.call(m,"t")+q.call(m,"t");n=d.call(m,"b")+q.call(m,"b");k={x:v[0]+g,y:v[1]+u,0:v[0]+g,1:v[1]+u,width:s-(g+a),height:i-(u+n)}}k.right=k.x+k.width;k.bottom=k.y+k.height;return k},move:function(j,b,c){var g=this,m=g.getXY(),k=m[0],i=m[1],d=[k-b,i],l=[k+b,i],h=[k,i-b],a=[k,i+b],e={l:d,left:d,r:l,right:l,t:h,top:h,up:h,b:a,bottom:a,down:a};j=j.toL
 owerCase();g.moveTo(e[j][0],e[j][1],g.animTest.call(g,arguments,c,2))},setLeftTop:function(d,c){var b=this,a=b.dom.style;a.left=b.addUnits(d);a.top=b.addUnits(c);return b},getRegion:function(){return Ext.lib.Dom.getRegion(this.dom)},setBounds:function(b,g,d,a,c){var e=this;if(!c||!e.anim){e.setSize(d,a);e.setLocation(b,g)}else{e.anim({points:{to:[b,g]},width:{to:e.adjustWidth(d)},height:{to:e.adjustHeight(a)}},e.preanim(arguments,4),"motion")}return e},setRegion:function(b,a){return this.setBounds(b.left,b.top,b.right-b.left,b.bottom-b.top,this.animTest.call(this,arguments,a,1))}});Ext.Element.addMethods({scrollTo:function(b,d,a){var e=/top/i.test(b),c=this,g=c.dom,h;if(!a||!c.anim){h="scroll"+(e?"Top":"Left");g[h]=d}else{h="scroll"+(e?"Left":"Top");c.anim({scroll:{to:e?[g[h],d]:[d,g[h]]}},c.preanim(arguments,2),"scroll")}return c},scrollIntoView:function(e,i){var p=Ext.getDom(e)||Ext.getBody().dom,h=this.dom,g=this.getOffsetsTo(p),k=g[0]+p.scrollLeft,u=g[1]+p.scrollTop,q=u+
 h.offsetHeight,d=k+h.offsetWidth,a=p.clientHeight,m=parseInt(p.scrollTop,10),s=parseInt(p.scrollLeft,10),j=m+a,n=s+p.clientWidth;if(h.offsetHeight>a||u<m){p.scrollTop=u}else{if(q>j){p.scrollTop=q-a}}p.scrollTop=p.scrollTop;if(i!==false){if(h.offsetWidth>p.clientWidth||k<s){p.scrollLeft=k}else{if(d>n){p.scrollLeft=d-p.clientWidth}}p.scrollLeft=p.scrollLeft}return this},scrollChildIntoView:function(b,a){Ext.fly(b,"_scrollChildIntoView").scrollIntoView(this,a)},scroll:function(m,b,d){if(!this.isScrollable()){return false}var e=this.dom,g=e.scrollLeft,p=e.scrollTop,n=e.scrollWidth,k=e.scrollHeight,i=e.clientWidth,a=e.clientHeight,c=false,o,j={l:Math.min(g+b,n-i),r:o=Math.max(g-b,0),t:Math.max(p-b,0),b:Math.min(p+b,k-a)};j.d=j.b;j.u=j.t;m=m.substr(0,1);if((o=j[m])>-1){c=true;this.scrollTo(m=="l"||m=="r"?"left":"top",o,this.preanim(arguments,2))}return c}});Ext.Element.addMethods(function(){var d="visibility",b="display",a="hidden",h="none",c="x-masked",g="x-masked-relative",e=Ext
 .Element.data;return{isVisible:function(i){var j=!this.isStyle(d,a)&&!this.isStyle(b,h),k=this.dom.parentNode;if(i!==true||!j){return j}while(k&&!(/^body/i.test(k.tagName))){if(!Ext.fly(k,"_isVisible").isVisible()){return false}k=k.parentNode}return true},isDisplayed:function(){return !this.isStyle(b,h)},enableDisplayMode:function(i){this.setVisibilityMode(Ext.Element.DISPLAY);if(!Ext.isEmpty(i)){e(this.dom,"originalDisplay",i)}return this},mask:function(j,n){var p=this,l=p.dom,o=Ext.DomHelper,m="ext-el-mask-msg",i,q;if(!/^body/i.test(l.tagName)&&p.getStyle("position")=="static"){p.addClass(g)}if(i=e(l,"maskMsg")){i.remove()}if(i=e(l,"mask")){i.remove()}q=o.append(l,{cls:"ext-el-mask"},true);e(l,"mask",q);p.addClass(c);q.setDisplayed(true);if(typeof j=="string"){var k=o.append(l,{cls:m,cn:{tag:"div"}},true);e(l,"maskMsg",k);k.dom.className=n?m+" "+n:m;k.dom.firstChild.innerHTML=j;k.setDisplayed(true);k.center(p)}if(Ext.isIE&&!(Ext.isIE7&&Ext.isStrict)&&p.getStyle("height")==
 "auto"){q.setSize(undefined,p.getHeight())}return q},unmask:function(){var k=this,l=k.dom,i=e(l,"mask"),j=e(l,"maskMsg");if(i){if(j){j.remove();e(l,"maskMsg",undefined)}i.remove();e(l,"mask",undefined);k.removeClass([c,g])}},isMasked:function(){var i=e(this.dom,"mask");return i&&i.isVisible()},createShim:function(){var i=document.createElement("iframe"),j;i.frameBorder="0";i.className="ext-shim";i.src=Ext.SSL_SECURE_URL;j=Ext.get(this.dom.parentNode.insertBefore(i,this.dom));j.autoBoxAdjust=false;return j}}}());Ext.Element.addMethods({addKeyListener:function(b,d,c){var a;if(typeof b!="object"||Ext.isArray(b)){a={key:b,fn:d,scope:c}}else{a={key:b.key,shift:b.shift,ctrl:b.ctrl,alt:b.alt,fn:d,scope:c}}return new Ext.KeyMap(this,a)},addKeyMap:function(a){return new Ext.KeyMap(this,a)}});Ext.CompositeElementLite.importElementMethods();Ext.apply(Ext.CompositeElementLite.prototype,{addElements:function(c,a){if(!c){return this}if(typeof c=="string"){c=Ext.Element.selectorFunction(c,
 a)}var b=this.elements;Ext.each(c,function(d){b.push(Ext.get(d))});return this},first:function(){return this.item(0)},last:function(){return this.item(this.getCount()-1)},contains:function(a){return this.indexOf(a)!=-1},removeElement:function(d,e){var c=this,a=this.elements,b;Ext.each(d,function(g){if((b=(a[g]||a[g=c.indexOf(g)]))){if(e){if(b.dom){b.remove()}else{Ext.removeNode(b)}}a.splice(g,1)}});return this}});Ext.CompositeElement=Ext.extend(Ext.CompositeElementLite,{constructor:function(b,a){this.elements=[];this.add(b,a)},getElement:function(a){return a},transformElement:function(a){return Ext.get(a)}});Ext.Element.select=function(a,d,b){var c;if(typeof a=="string"){c=Ext.Element.selectorFunction(a,b)}else{if(a.length!==undefined){c=a}else{throw"Invalid selector"}}return(d===true)?new Ext.CompositeElement(c):new Ext.CompositeElementLite(c)};Ext.select=Ext.Element.select;Ext.UpdateManager=Ext.Updater=Ext.extend(Ext.util.Observable,function(){var b="beforeupdate",d="updat
 e",c="failure";function a(h){var i=this;i.transaction=null;if(h.argument.form&&h.argument.reset){try{h.argument.form.reset()}catch(j){}}if(i.loadScripts){i.renderer.render(i.el,h,i,g.createDelegate(i,[h]))}else{i.renderer.render(i.el,h,i);g.call(i,h)}}function g(h,i,j){this.fireEvent(i||d,this.el,h);if(Ext.isFunction(h.argument.callback)){h.argument.callback.call(h.argument.scope,this.el,Ext.isEmpty(j)?true:false,h,h.argument.options)}}function e(h){g.call(this,h,c,!!(this.transaction=null))}return{constructor:function(i,h){var j=this;i=Ext.get(i);if(!h&&i.updateManager){return i.updateManager}j.el=i;j.defaultUrl=null;j.addEvents(b,d,c);Ext.apply(j,Ext.Updater.defaults);j.transaction=null;j.refreshDelegate=j.refresh.createDelegate(j);j.updateDelegate=j.update.createDelegate(j);j.formUpdateDelegate=(j.formUpdate||function(){}).createDelegate(j);j.renderer=j.renderer||j.getDefaultRenderer();Ext.Updater.superclass.constructor.call(j)},setRenderer:function(h){this.renderer=h},ge
 tRenderer:function(){return this.renderer},getDefaultRenderer:function(){return new Ext.Updater.BasicRenderer()},setDefaultUrl:function(h){this.defaultUrl=h},getEl:function(){return this.el},update:function(i,n,p,l){var k=this,h,j;if(k.fireEvent(b,k.el,i,n)!==false){if(Ext.isObject(i)){h=i;i=h.url;n=n||h.params;p=p||h.callback;l=l||h.discardUrl;j=h.scope;if(!Ext.isEmpty(h.nocache)){k.disableCaching=h.nocache}if(!Ext.isEmpty(h.text)){k.indicatorText='<div class="loading-indicator">'+h.text+"</div>"}if(!Ext.isEmpty(h.scripts)){k.loadScripts=h.scripts}if(!Ext.isEmpty(h.timeout)){k.timeout=h.timeout}}k.showLoading();if(!l){k.defaultUrl=i}if(Ext.isFunction(i)){i=i.call(k)}var m=Ext.apply({},{url:i,params:(Ext.isFunction(n)&&j)?n.createDelegate(j):n,success:a,failure:e,scope:k,callback:undefined,timeout:(k.timeout*1000),disableCaching:k.disableCaching,argument:{options:h,url:i,form:null,callback:p,scope:j||window,params:n}},h);k.transaction=Ext.Ajax.request(m)}},formUpdate:functio
 n(k,h,j,l){var i=this;if(i.fireEvent(b,i.el,k,h)!==false){if(Ext.isFunction(h)){h=h.call(i)}k=Ext.getDom(k);i.transaction=Ext.Ajax.request({form:k,url:h,success:a,failure:e,scope:i,timeout:(i.timeout*1000),argument:{url:h,form:k,callback:l,reset:j}});i.showLoading.defer(1,i)}},startAutoRefresh:function(i,j,l,m,h){var k=this;if(h){k.update(j||k.defaultUrl,l,m,true)}if(k.autoRefreshProcId){clearInterval(k.autoRefreshProcId)}k.autoRefreshProcId=setInterval(k.update.createDelegate(k,[j||k.defaultUrl,l,m,true]),i*1000)},stopAutoRefresh:function(){if(this.autoRefreshProcId){clearInterval(this.autoRefreshProcId);delete this.autoRefreshProcId}},isAutoRefreshing:function(){return !!this.autoRefreshProcId},showLoading:function(){if(this.showLoadIndicator){this.el.dom.innerHTML=this.indicatorText}},abort:function(){if(this.transaction){Ext.Ajax.abort(this.transaction)}},isUpdating:function(){return this.transaction?Ext.Ajax.isLoading(this.transaction):false},refresh:function(h){if(this
 .defaultUrl){this.update(this.defaultUrl,null,h,true)}}}}());Ext.Updater.defaults={timeout:30,disableCaching:false,showLoadIndicator:true,indicatorText:'<div class="loading-indicator">Loading...</div>',loadScripts:false,sslBlankUrl:Ext.SSL_SECURE_URL};Ext.Updater.updateElement=function(d,c,e,b){var a=Ext.get(d).getUpdater();Ext.apply(a,b);a.update(c,e,b?b.callback:null)};Ext.Updater.BasicRenderer=function(){};Ext.Updater.BasicRenderer.prototype={render:function(c,a,b,d){c.update(a.responseText,b.loadScripts,d)}};(function(){Date.useStrict=false;function b(d){var c=Array.prototype.slice.call(arguments,1);return d.replace(/\{(\d+)\}/g,function(e,g){return c[g]})}Date.formatCodeToRegex=function(d,c){var e=Date.parseCodes[d];if(e){e=typeof e=="function"?e():e;Date.parseCodes[d]=e}return e?Ext.applyIf({c:e.c?b(e.c,c||"{0}"):e.c},e):{g:0,c:null,s:Ext.escapeRe(d)}};var a=Date.formatCodeToRegex;Ext.apply(Date,{parseFunctions:{"M$":function(d,c){var e=new RegExp("\\/Date\\(([-+])?(\\
 d+)(?:[+-]\\d{4})?\\)\\/");var g=(d||"").match(e);return g?new Date(((g[1]||"")+g[2])*1):null}},parseRegexes:[],formatFunctions:{"M$":function(){return"\\/Date("+this.getTime()+")\\/"}},y2kYear:50,MILLI:"ms",SECOND:"s",MINUTE:"mi",HOUR:"h",DAY:"d",MONTH:"mo",YEAR:"y",defaults:{},dayNames:["Sunday","Monday","Tuesday","Wednesday","Thursday","Friday","Saturday"],monthNames:["January","February","March","April","May","June","July","August","September","October","November","December"],monthNumbers:{Jan:0,Feb:1,Mar:2,Apr:3,May:4,Jun:5,Jul:6,Aug:7,Sep:8,Oct:9,Nov:10,Dec:11},getShortMonthName:function(c){return Date.monthNames[c].substring(0,3)},getShortDayName:function(c){return Date.dayNames[c].substring(0,3)},getMonthNumber:function(c){return Date.monthNumbers[c.substring(0,1).toUpperCase()+c.substring(1,3).toLowerCase()]},formatContainsHourInfo:(function(){var d=/(\\.)/g,c=/([gGhHisucUOPZ]|M\$)/;return function(e){return c.test(e.replace(d,""))}})(),formatCodes:{d:"String.leftPa
 d(this.getDate(), 2, '0')",D:"Date.getShortDayName(this.getDay())",j:"this.getDate()",l:"Date.dayNames[this.getDay()]",N:"(this.getDay() ? this.getDay() : 7)",S:"this.getSuffix()",w:"this.getDay()",z:"this.getDayOfYear()",W:"String.leftPad(this.getWeekOfYear(), 2, '0')",F:"Date.monthNames[this.getMonth()]",m:"String.leftPad(this.getMonth() + 1, 2, '0')",M:"Date.getShortMonthName(this.getMonth())",n:"(this.getMonth() + 1)",t:"this.getDaysInMonth()",L:"(this.isLeapYear() ? 1 : 0)",o:"(this.getFullYear() + (this.getWeekOfYear() == 1 && this.getMonth() > 0 ? +1 : (this.getWeekOfYear() >= 52 && this.getMonth() < 11 ? -1 : 0)))",Y:"String.leftPad(this.getFullYear(), 4, '0')",y:"('' + this.getFullYear()).substring(2, 4)",a:"(this.getHours() < 12 ? 'am' : 'pm')",A:"(this.getHours() < 12 ? 'AM' : 'PM')",g:"((this.getHours() % 12) ? this.getHours() % 12 : 12)",G:"this.getHours()",h:"String.leftPad((this.getHours() % 12) ? this.getHours() % 12 : 12, 2, '0')",H:"String.leftPad(this.getH
 ours(), 2, '0')",i:"String.leftPad(this.getMinutes(), 2, '0')",s:"String.leftPad(this.getSeconds(), 2, '0')",u:"String.leftPad(this.getMilliseconds(), 3, '0')",O:"this.getGMTOffset()",P:"this.getGMTOffset(true)",T:"this.getTimezone()",Z:"(this.getTimezoneOffset() * -60)",c:function(){for(var k="Y-m-dTH:i:sP",h=[],g=0,d=k.length;g<d;++g){var j=k.charAt(g);h.push(j=="T"?"'T'":Date.getFormatCode(j))}return h.join(" + ")},U:"Math.round(this.getTime() / 1000)"},isValid:function(o,c,n,k,g,j,e){k=k||0;g=g||0;j=j||0;e=e||0;var l=new Date(o<100?100:o,c-1,n,k,g,j,e).add(Date.YEAR,o<100?o-100:0);return o==l.getFullYear()&&c==l.getMonth()+1&&n==l.getDate()&&k==l.getHours()&&g==l.getMinutes()&&j==l.getSeconds()&&e==l.getMilliseconds()},parseDate:function(d,g,c){var e=Date.parseFunctions;if(e[g]==null){Date.createParser(g)}return e[g](d,Ext.isDefined(c)?c:Date.useStrict)},getFormatCode:function(d){var c=Date.formatCodes[d];if(c){c=typeof c=="function"?c():c;Date.formatCodes[d]=c}return c|
 |("'"+String.escape(d)+"'")},createFormat:function(h){var g=[],c=false,e="";for(var d=0;d<h.length;++d){e=h.charAt(d);if(!c&&e=="\\"){c=true}else{if(c){c=false;g.push("'"+String.escape(e)+"'")}else{g.push(Date.getFormatCode(e))}}}Date.formatFunctions[h]=new Function("return "+g.join("+"))},createParser:function(){var c=["var dt, y, m, d, h, i, s, ms, o, z, zz, u, v,","def = Date.defaults,","results = String(input).match(Date.parseRegexes[{0}]);","if(results){","{1}","if(u != null){","v = new Date(u * 1000);","}else{","dt = (new Date()).clearTime();","y = Ext.num(y, Ext.num(def.y, dt.getFullYear()));","m = Ext.num(m, Ext.num(def.m - 1, dt.getMonth()));","d = Ext.num(d, Ext.num(def.d, dt.getDate()));","h  = Ext.num(h, Ext.num(def.h, dt.getHours()));","i  = Ext.num(i, Ext.num(def.i, dt.getMinutes()));","s  = Ext.num(s, Ext.num(def.s, dt.getSeconds()));","ms = Ext.num(ms, Ext.num(def.ms, dt.getMilliseconds()));","if(z >= 0 && y >= 0){","v = new Date(y < 100 ? 100 : y, 0, 1, h, i
 , s, ms).add(Date.YEAR, y < 100 ? y - 100 : 0);","v = !strict? v : (strict === true && (z <= 364 || (v.isLeapYear() && z <= 365))? v.add(Date.DAY, z) : null);","}else if(strict === true && !Date.isValid(y, m + 1, d, h, i, s, ms)){","v = null;","}else{","v = new Date(y < 100 ? 100 : y, m, d, h, i, s, ms).add(Date.YEAR, y < 100 ? y - 100 : 0);","}","}","}","if(v){","if(zz != null){","v = v.add(Date.SECOND, -v.getTimezoneOffset() * 60 - zz);","}else if(o){","v = v.add(Date.MINUTE, -v.getTimezoneOffset() + (sn == '+'? -1 : 1) * (hr * 60 + mn));","}","}","return v;"].join("\n");return function(m){var e=Date.parseRegexes.length,o=1,g=[],l=[],k=false,d="",j=0,h,n;for(;j<m.length;++j){d=m.charAt(j);if(!k&&d=="\\"){k=true}else{if(k){k=false;l.push(String.escape(d))}else{h=a(d,o);o+=h.g;l.push(h.s);if(h.g&&h.c){if(h.calcLast){n=h.c}else{g.push(h.c)}}}}}if(n){g.push(n)}Date.parseRegexes[e]=new RegExp("^"+l.join("")+"$","i");Date.parseFunctions[m]=new Function("input","strict",b(c,e,g.j
 oin("")))}}(),parseCodes:{d:{g:1,c:"d = parseInt(results[{0}], 10);\n",s:"(\\d{2})"},j:{g:1,c:"d = parseInt(results[{0}], 10);\n",s:"(\\d{1,2})"},D:function(){for(var c=[],d=0;d<7;c.push(Date.getShortDayName(d)),++d){}return{g:0,c:null,s:"(?:"+c.join("|")+")"}},l:function(){return{g:0,c:null,s:"(?:"+Date.dayNames.join("|")+")"}},N:{g:0,c:null,s:"[1-7]"},S:{g:0,c:null,s:"(?:st|nd|rd|th)"},w:{g:0,c:null,s:"[0-6]"},z:{g:1,c:"z = parseInt(results[{0}], 10);\n",s:"(\\d{1,3})"},W:{g:0,c:null,s:"(?:\\d{2})"},F:function(){return{g:1,c:"m = parseInt(Date.getMonthNumber(results[{0}]), 10);\n",s:"("+Date.monthNames.join("|")+")"}},M:function(){for(var c=[],d=0;d<12;c.push(Date.getShortMonthName(d)),++d){}return Ext.applyIf({s:"("+c.join("|")+")"},a("F"))},m:{g:1,c:"m = parseInt(results[{0}], 10) - 1;\n",s:"(\\d{2})"},n:{g:1,c:"m = parseInt(results[{0}], 10) - 1;\n",s:"(\\d{1,2})"},t:{g:0,c:null,s:"(?:\\d{2})"},L:{g:0,c:null,s:"(?:1|0)"},o:function(){return a("Y")},Y:{g:1,c:"y = parseIn
 t(results[{0}], 10);\n",s:"(\\d{4})"},y:{g:1,c:"var ty = parseInt(results[{0}], 10);\ny = ty > Date.y2kYear ? 1900 + ty : 2000 + ty;\n",s:"(\\d{1,2})"},a:function(){return a("A")},A:{calcLast:true,g:1,c:"if (/(am)/i.test(results[{0}])) {\nif (!h || h == 12) { h = 0; }\n} else { if (!h || h < 12) { h = (h || 0) + 12; }}",s:"(AM|PM|am|pm)"},g:function(){return a("G")},G:{g:1,c:"h = parseInt(results[{0}], 10);\n",s:"(\\d{1,2})"},h:function(){return a("H")},H:{g:1,c:"h = parseInt(results[{0}], 10);\n",s:"(\\d{2})"},i:{g:1,c:"i = parseInt(results[{0}], 10);\n",s:"(\\d{2})"},s:{g:1,c:"s = parseInt(results[{0}], 10);\n",s:"(\\d{2})"},u:{g:1,c:"ms = results[{0}]; ms = parseInt(ms, 10)/Math.pow(10, ms.length - 3);\n",s:"(\\d+)"},O:{g:1,c:["o = results[{0}];","var sn = o.substring(0,1),","hr = o.substring(1,3)*1 + Math.floor(o.substring(3,5) / 60),","mn = o.substring(3,5) % 60;","o = ((-12 <= (hr*60 + mn)/60) && ((hr*60 + mn)/60 <= 14))? (sn + String.leftPad(hr, 2, '0') + String.leftP
 ad(mn, 2, '0')) : null;\n"].join("\n"),s:"([+-]\\d{4})"},P:{g:1,c:["o = results[{0}];","var sn = o.substring(0,1),","hr = o.substring(1,3)*1 + Math.floor(o.substring(4,6) / 60),","mn = o.substring(4,6) % 60;","o = ((-12 <= (hr*60 + mn)/60) && ((hr*60 + mn)/60 <= 14))? (sn + String.leftPad(hr, 2, '0') + String.leftPad(mn, 2, '0')) : null;\n"].join("\n"),s:"([+-]\\d{2}:\\d{2})"},T:{g:0,c:null,s:"[A-Z]{1,4}"},Z:{g:1,c:"zz = results[{0}] * 1;\nzz = (-43200 <= zz && zz <= 50400)? zz : null;\n",s:"([+-]?\\d{1,5})"},c:function(){var e=[],c=[a("Y",1),a("m",2),a("d",3),a("h",4),a("i",5),a("s",6),{c:"ms = results[7] || '0'; ms = parseInt(ms, 10)/Math.pow(10, ms.length - 3);\n"},{c:["if(results[8]) {","if(results[8] == 'Z'){","zz = 0;","}else if (results[8].indexOf(':') > -1){",a("P",8).c,"}else{",a("O",8).c,"}","}"].join("\n")}];for(var g=0,d=c.length;g<d;++g){e.push(c[g].c)}return{g:1,c:e.join(""),s:[c[0].s,"(?:","-",c[1].s,"(?:","-",c[2].s,"(?:","(?:T| )?",c[3].s,":",c[4].s,"(?::",c
 [5].s,")?","(?:(?:\\.|,)(\\d+))?","(Z|(?:[-+]\\d{2}(?::)?\\d{2}))?",")?",")?",")?"].join("")}},U:{g:1,c:"u = parseInt(results[{0}], 10);\n",s:"(-?\\d+)"}}})}());Ext.apply(Date.prototype,{dateFormat:function(a){if(Date.formatFunctions[a]==null){Date.createFormat(a)}return Date.formatFunctions[a].call(this)},getTimezone:function(){return this.toString().replace(/^.* (?:\((.*)\)|([A-Z]{1,4})(?:[\-+][0-9]{4})?(?: -?\d+)?)$/,"$1$2").replace(/[^A-Z]/g,"")},getGMTOffset:function(a){return(this.getTimezoneOffset()>0?"-":"+")+String.leftPad(Math.floor(Math.abs(this.getTimezoneOffset())/60),2,"0")+(a?":":"")+String.leftPad(Math.abs(this.getTimezoneOffset()%60),2,"0")},getDayOfYear:function(){var b=0,e=this.clone(),a=this.getMonth(),c;for(c=0,e.setDate(1),e.setMonth(0);c<a;e.setMonth(++c)){b+=e.getDaysInMonth()}return b+this.getDate()-1},getWeekOfYear:function(){var a=86400000,b=7*a;return function(){var d=Date.UTC(this.getFullYear(),this.getMonth(),this.getDate()+3)/a,c=Math.floor(d/7
 ),e=new Date(c*b).getUTCFullYear();return c-Math.floor(Date.UTC(e,0,7)/b)+1}}(),isLeapYear:function(){var a=this.getFullYear();return !!((a&3)==0&&(a%100||(a%400==0&&a)))},getFirstDayOfMonth:function(){var a=(this.getDay()-(this.getDate()-1))%7;return(a<0)?(a+7):a},getLastDayOfMonth:function(){return this.getLastDateOfMonth().getDay()},getFirstDateOfMonth:function(){return new Date(this.getFullYear(),this.getMonth(),1)},getLastDateOfMonth:function(){return new Date(this.getFullYear(),this.getMonth(),this.getDaysInMonth())},getDaysInMonth:function(){var a=[31,28,31,30,31,30,31,31,30,31,30,31];return function(){var b=this.getMonth();return b==1&&this.isLeapYear()?29:a[b]}}(),getSuffix:function(){switch(this.getDate()){case 1:case 21:case 31:return"st";case 2:case 22:return"nd";case 3:case 23:return"rd";default:return"th"}},clone:function(){return new Date(this.getTime())},isDST:function(){return new Date(this.getFullYear(),0,1).getTimezoneOffset()!=this.getTimezoneOffset()},cl
 earTime:function(g){if(g){return this.clone().clearTime()}var b=this.getDate();this.setHours(0);this.setMinutes(0);this.setSeconds(0);this.setMilliseconds(0);if(this.getDate()!=b){for(var a=1,e=this.add(Date.HOUR,a);e.getDate()!=b;a++,e=this.add(Date.HOUR,a)){}this.setDate(b);this.setHours(e.getHours())}return this},add:function(b,c){var e=this.clone();if(!b||c===0){return e}switch(b.toLowerCase()){case Date.MILLI:e.setMilliseconds(this.getMilliseconds()+c);break;case Date.SECOND:e.setSeconds(this.getSeconds()+c);break;case Date.MINUTE:e.setMinutes(this.getMinutes()+c);break;case Date.HOUR:e.setHours(this.getHours()+c);break;case Date.DAY:e.setDate(this.getDate()+c);break;case Date.MONTH:var a=this.getDate();if(a>28){a=Math.min(a,this.getFirstDateOfMonth().add("mo",c).getLastDateOfMonth().getDate())}e.setDate(a);e.setMonth(this.getMonth()+c);break;case Date.YEAR:e.setFullYear(this.getFullYear()+c);break}return e},between:function(c,a){var b=this.getTime();return c.getTime()<
 =b&&b<=a.getTime()}});Date.prototype.format=Date.prototype.dateFormat;if(Ext.isSafari&&(navigator.userAgent.match(/WebKit\/(\d+)/)[1]||NaN)<420){Ext.apply(Date.prototype,{_xMonth:Date.prototype.setMonth,_xDate:Date.prototype.setDate,setMonth:function(a){if(a<=-1){var d=Math.ceil(-a),c=Math.ceil(d/12),b=(d%12)?12-d%12:0;this.setFullYear(this.getFullYear()-c);return this._xMonth(b)}else{return this._xMonth(a)}},setDate:function(a){return this.setTime(this.getTime()-(this.getDate()-a)*86400000)}})}Ext.util.MixedCollection=function(b,a){this.items=[];this.map={};this.keys=[];this.length=0;this.addEvents("clear","add","replace","remove","sort");this.allowFunctions=b===true;if(a){this.getKey=a}Ext.util.MixedCollection.superclass.constructor.call(this)};Ext.extend(Ext.util.MixedCollection,Ext.util.Observable,{allowFunctions:false,add:function(b,c){if(arguments.length==1){c=arguments[0];b=this.getKey(c)}if(typeof b!="undefined"&&b!==null){var a=this.map[b];if(typeof a!="undefined"){
 return this.replace(b,c)}this.map[b]=c}this.length++;this.items.push(c);this.keys.push(b);this.fireEvent("add",this.length-1,c,b);return c},getKey:function(a){return a.id},replace:function(c,d){if(arguments.length==1){d=arguments[0];c=this.getKey(d)}var a=this.map[c];if(typeof c=="undefined"||c===null||typeof a=="undefined"){return this.add(c,d)}var b=this.indexOfKey(c);this.items[b]=d;this.map[c]=d;this.fireEvent("replace",c,a,d);return d},addAll:function(e){if(arguments.length>1||Ext.isArray(e)){var b=arguments.length>1?arguments:e;for(var d=0,a=b.length;d<a;d++){this.add(b[d])}}else{for(var c in e){if(this.allowFunctions||typeof e[c]!="function"){this.add(c,e[c])}}}},each:function(e,d){var b=[].concat(this.items);for(var c=0,a=b.length;c<a;c++){if(e.call(d||b[c],b[c],c,a)===false){break}}},eachKey:function(d,c){for(var b=0,a=this.keys.length;b<a;b++){d.call(c||window,this.keys[b],this.items[b],b,a)}},find:function(d,c){for(var b=0,a=this.items.length;b<a;b++){if(d.call(c|
 |window,this.items[b],this.keys[b])){return this.items[b]}}return null},insert:function(a,b,c){if(arguments.length==2){c=arguments[1];b=this.getKey(c)}if(this.containsKey(b)){this.suspendEvents();this.removeKey(b);this.resumeEvents()}if(a>=this.length){return this.add(b,c)}this.length++;this.items.splice(a,0,c);if(typeof b!="undefined"&&b!==null){this.map[b]=c}this.keys.splice(a,0,b);this.fireEvent("add",a,c,b);return c},remove:function(a){return this.removeAt(this.indexOf(a))},removeAt:function(a){if(a<this.length&&a>=0){this.length--;var c=this.items[a];this.items.splice(a,1);var b=this.keys[a];if(typeof b!="undefined"){delete this.map[b]}this.keys.splice(a,1);this.fireEvent("remove",c,b);return c}return false},removeKey:function(a){return this.removeAt(this.indexOfKey(a))},getCount:function(){return this.length},indexOf:function(a){return this.items.indexOf(a)},indexOfKey:function(a){return this.keys.indexOf(a)},item:function(b){var a=this.map[b],c=a!==undefined?a:(typeof
  b=="number")?this.items[b]:undefined;return typeof c!="function"||this.allowFunctions?c:null},itemAt:function(a){return this.items[a]},key:function(a){return this.map[a]},contains:function(a){return this.indexOf(a)!=-1},containsKey:function(a){return typeof this.map[a]!="undefined"},clear:function(){this.length=0;this.items=[];this.keys=[];this.map={};this.fireEvent("clear")},first:function(){return this.items[0]},last:function(){return this.items[this.length-1]},_sort:function(k,a,j){var d,e,b=String(a).toUpperCase()=="DESC"?-1:1,h=[],l=this.keys,g=this.items;j=j||function(i,c){return i-c};for(d=0,e=g.length;d<e;d++){h[h.length]={key:l[d],value:g[d],index:d}}h.sort(function(i,c){var m=j(i[k],c[k])*b;if(m===0){m=(i.index<c.index?-1:1)}return m});for(d=0,e=h.length;d<e;d++){g[d]=h[d].value;l[d]=h[d].key}this.fireEvent("sort",this)},sort:function(a,b){this._sort("value",a,b)},reorder:function(d){this.suspendEvents();var b=this.items,c=0,g=b.length,a=[],e=[],h;for(h in d){a[d[
 h]]=b[h]}for(c=0;c<g;c++){if(d[c]==undefined){e.push(b[c])}}for(c=0;c<g;c++){if(a[c]==undefined){a[c]=e.shift()}}this.clear();this.addAll(a);this.resumeEvents();this.fireEvent("sort",this)},keySort:function(a,b){this._sort("key",a,b||function(d,c){var g=String(d).toUpperCase(),e=String(c).toUpperCase();return g>e?1:(g<e?-1:0)})},getRange:function(e,a){var b=this.items;if(b.length<1){return[]}e=e||0;a=Math.min(typeof a=="undefined"?this.length-1:a,this.length-1);var c,d=[];if(e<=a){for(c=e;c<=a;c++){d[d.length]=b[c]}}else{for(c=e;c>=a;c--){d[d.length]=b[c]}}return d},filter:function(c,b,d,a){if(Ext.isEmpty(b,false)){return this.clone()}b=this.createValueMatcher(b,d,a);return this.filterBy(function(e){return e&&b.test(e[c])})},filterBy:function(g,e){var h=new Ext.util.MixedCollection();h.getKey=this.getKey;var b=this.keys,d=this.items;for(var c=0,a=d.length;c<a;c++){if(g.call(e||this,d[c],b[c])){h.add(b[c],d[c])}}return h},findIndex:function(c,b,e,d,a){if(Ext.isEmpty(b,false))
 {return -1}b=this.createValueMatcher(b,d,a);return this.findIndexBy(function(g){return g&&b.test(g[c])},null,e)},findIndexBy:function(g,e,h){var b=this.keys,d=this.items;for(var c=(h||0),a=d.length;c<a;c++){if(g.call(e||this,d[c],b[c])){return c}}return -1},createValueMatcher:function(c,e,a,b){if(!c.exec){var d=Ext.escapeRe;c=String(c);if(e===true){c=d(c)}else{c="^"+d(c);if(b===true){c+="$"}}c=new RegExp(c,a?"":"i")}return c},clone:function(){var e=new Ext.util.MixedCollection();var b=this.keys,d=this.items;for(var c=0,a=d.length;c<a;c++){e.add(b[c],d[c])}e.getKey=this.getKey;return e}});Ext.util.MixedCollection.prototype.get=Ext.util.MixedCollection.prototype.item;Ext.AbstractManager=Ext.extend(Object,{typeName:"type",constructor:function(a){Ext.apply(this,a||{});this.all=new Ext.util.MixedCollection();this.types={}},get:function(a){return this.all.get(a)},register:function(a){this.all.add(a)},unregister:function(a){this.all.remove(a)},registerType:function(b,a){this.types[
 b]=a;a[this.typeName]=b},isRegistered:function(a){return this.types[a]!==undefined},create:function(a,d){var b=a[this.typeName]||a.type||d,c=this.types[b];if(c==undefined){throw new Error(String.format("The '{0}' type has not been registered with this manager",b))}return new c(a)},onAvailable:function(d,c,b){var a=this.all;a.on("add",function(e,g){if(g.id==d){c.call(b||g,g);a.un("add",c,b)}})}});Ext.util.Format=function(){var trimRe=/^\s+|\s+$/g,stripTagsRE=/<\/?[^>]+>/gi,stripScriptsRe=/(?:<script.*?>)((\n|\r|.)*?)(?:<\/script>)/ig,nl2brRe=/\r?\n/g;return{ellipsis:function(value,len,word){if(value&&value.length>len){if(word){var vs=value.substr(0,len-2),index=Math.max(vs.lastIndexOf(" "),vs.lastIndexOf("."),vs.lastIndexOf("!"),vs.lastIndexOf("?"));if(index==-1||index<(len-15)){return value.substr(0,len-3)+"..."}else{return vs.substr(0,index)+"..."}}else{return value.substr(0,len-3)+"..."}}return value},undef:function(value){return value!==undefined?value:""},defaultValue:fu
 nction(value,defaultValue){return value!==undefined&&value!==""?value:defaultValue},htmlEncode:function(value){return !value?value:String(value).replace(/&/g,"&amp;").replace(/>/g,"&gt;").replace(/</g,"&lt;").replace(/"/g,"&quot;")},htmlDecode:function(value){return !value?value:String(value).replace(/&gt;/g,">").replace(/&lt;/g,"<").replace(/&quot;/g,'"').replace(/&amp;/g,"&")},trim:function(value){return String(value).replace(trimRe,"")},substr:function(value,start,length){return String(value).substr(start,length)},lowercase:function(value){return String(value).toLowerCase()},uppercase:function(value){return String(value).toUpperCase()},capitalize:function(value){return !value?value:value.charAt(0).toUpperCase()+value.substr(1).toLowerCase()},call:function(value,fn){if(arguments.length>2){var args=Array.prototype.slice.call(arguments,2);args.unshift(value);return eval(fn).apply(window,args)}else{return eval(fn).call(window,value)}},usMoney:function(v){v=(Math.round((v-0)*1
 00))/100;v=(v==Math.floor(v))?v+".00":((v*10==Math.floor(v*10))?v+"0":v);v=String(v);var ps=v.split("."),whole=ps[0],sub=ps[1]?"."+ps[1]:".00",r=/(\d+)(\d{3})/;while(r.test(whole)){whole=whole.replace(r,"$1,$2")}v=whole+sub;if(v.charAt(0)=="-"){return"-$"+v.substr(1)}return"$"+v},date:function(v,format){if(!v){return""}if(!Ext.isDate(v)){v=new Date(Date.parse(v))}return v.dateFormat(format||"m/d/Y")},dateRenderer:function(format){return function(v){return Ext.util.Format.date(v,format)}},stripTags:function(v){return !v?v:String(v).replace(stripTagsRE,"")},stripScripts:function(v){return !v?v:String(v).replace(stripScriptsRe,"")},fileSize:function(size){if(size<1024){return size+" bytes"}else{if(size<1048576){return(Math.round(((size*10)/1024))/10)+" KB"}else{return(Math.round(((size*10)/1048576))/10)+" MB"}}},math:function(){var fns={};return function(v,a){if(!fns[a]){fns[a]=new Function("v","return v "+a+";")}return fns[a](v)}}(),round:function(value,precision){var result=N
 umber(value);if(typeof precision=="number"){precision=Math.pow(10,precision);result=Math.round(value*precision)/precision}return result},number:function(v,format){if(!format){return v}v=Ext.num(v,NaN);if(isNaN(v)){return""}var comma=",",dec=".",i18n=false,neg=v<0;v=Math.abs(v);if(format.substr(format.length-2)=="/i"){format=format.substr(0,format.length-2);i18n=true;comma=".";dec=","}var hasComma=format.indexOf(comma)!=-1,psplit=(i18n?format.replace(/[^\d\,]/g,""):format.replace(/[^\d\.]/g,"")).split(dec);if(1<psplit.length){v=v.toFixed(psplit[1].length)}else{if(2<psplit.length){throw ("NumberFormatException: invalid format, formats should have no more than 1 period: "+format)}else{v=v.toFixed(0)}}var fnum=v.toString();psplit=fnum.split(".");if(hasComma){var cnum=psplit[0],parr=[],j=cnum.length,m=Math.floor(j/3),n=cnum.length%3||3,i;for(i=0;i<j;i+=n){if(i!=0){n=3}parr[parr.length]=cnum.substr(i,n);m-=1}fnum=parr.join(comma);if(psplit[1]){fnum+=dec+psplit[1]}}else{if(psplit[1
 ]){fnum=psplit[0]+dec+psplit[1]}}return(neg?"-":"")+format.replace(/[\d,?\.?]+/,fnum)},numberRenderer:function(format){return function(v){return Ext.util.Format.number(v,format)}},plural:function(v,s,p){return v+" "+(v==1?s:(p?p:s+"s"))},nl2br:function(v){return Ext.isEmpty(v)?"":v.replace(nl2brRe,"<br/>")}}}();Ext.XTemplate=function(){Ext.XTemplate.superclass.constructor.apply(this,arguments);var y=this,j=y.html,q=/<tpl\b[^>]*>((?:(?=([^<]+))\2|<(?!tpl\b[^>]*>))*?)<\/tpl>/,d=/^<tpl\b[^>]*?for="(.*?)"/,v=/^<tpl\b[^>]*?if="(.*?)"/,x=/^<tpl\b[^>]*?exec="(.*?)"/,r,p=0,k=[],o="values",w="parent",l="xindex",n="xcount",e="return ",c="with(values){ ";j=["<tpl>",j,"</tpl>"].join("");while((r=j.match(q))){var b=r[0].match(d),a=r[0].match(v),A=r[0].match(x),g=null,h=null,t=null,z=b&&b[1]?b[1]:"";if(a){g=a&&a[1]?a[1]:null;if(g){h=new Function(o,w,l,n,c+e+(Ext.util.Format.htmlDecode(g))+"; }")}}if(A){g=A&&A[1]?A[1]:null;if(g){t=new Function(o,w,l,n,c+(Ext.util.Format.htmlDecode(g))+"; }
 ")}}if(z){switch(z){case".":z=new Function(o,w,c+e+o+"; }");break;case"..":z=new Function(o,w,c+e+w+"; }");break;default:z=new Function(o,w,c+e+z+"; }")}}k.push({id:p,target:z,exec:t,test:h,body:r[1]||""});j=j.replace(r[0],"{xtpl"+p+"}");++p}for(var u=k.length-1;u>=0;--u){y.compileTpl(k[u])}y.master=k[k.length-1];y.tpls=k};Ext.extend(Ext.XTemplate,Ext.Template,{re:/\{([\w\-\.\#]+)(?:\:([\w\.]*)(?:\((.*?)?\))?)?(\s?[\+\-\*\\]\s?[\d\.\+\-\*\\\(\)]+)?\}/g,codeRe:/\{\[((?:\\\]|.|\n)*?)\]\}/g,applySubTemplate:function(a,k,j,d,c){var h=this,g,m=h.tpls[a],l,b=[];if((m.test&&!m.test.call(h,k,j,d,c))||(m.exec&&m.exec.call(h,k,j,d,c))){return""}l=m.target?m.target.call(h,k,j):k;g=l.length;j=m.target?k:j;if(m.target&&Ext.isArray(l)){for(var e=0,g=l.length;e<g;e++){b[b.length]=m.compiled.call(h,l[e],j,e+1,g)}return b.join("")}return m.compiled.call(h,l,j,d,c)},compileTpl:function(tpl){var fm=Ext.util.Format,useF=this.disableFormats!==true,sep=Ext.isGecko?"+":",",body;function fn(m,name,
 format,args,math){if(name.substr(0,4)=="xtpl"){return"'"+sep+"this.applySubTemplate("+name.substr(4)+", values, parent, xindex, xcount)"+sep+"'"}var v;if(name==="."){v="values"}else{if(name==="#"){v="xindex"}else{if(name.indexOf(".")!=-1){v=name}else{v="values['"+name+"']"}}}if(math){v="("+v+math+")"}if(format&&useF){args=args?","+args:"";if(format.substr(0,5)!="this."){format="fm."+format+"("}else{format='this.call("'+format.substr(5)+'", ';args=", values"}}else{args="";format="("+v+" === undefined ? '' : "}return"'"+sep+format+v+args+")"+sep+"'"}function codeFn(m,code){return"'"+sep+"("+code.replace(/\\'/g,"'")+")"+sep+"'"}if(Ext.isGecko){body="tpl.compiled = function(values, parent, xindex, xcount){ return '"+tpl.body.replace(/(\r\n|\n)/g,"\\n").replace(/'/g,"\\'").replace(this.re,fn).replace(this.codeRe,codeFn)+"';};"}else{body=["tpl.compiled = function(values, parent, xindex, xcount){ return ['"];body.push(tpl.body.replace(/(\r\n|\n)/g,"\\n").replace(/'/g,"\\'").replace
 (this.re,fn).replace(this.codeRe,codeFn));body.push("'].join('');};");body=body.join("")}eval(body);return this},applyTemplate:function(a){return this.master.compiled.call(this,a,{},1,1)},compile:function(){return this}});Ext.XTemplate.prototype.apply=Ext.XTemplate.prototype.applyTemplate;Ext.XTemplate.from=function(a){a=Ext.getDom(a);return new Ext.XTemplate(a.value||a.innerHTML)};Ext.util.CSS=function(){var d=null;var c=document;var b=/(-[a-z])/gi;var a=function(e,g){return g.charAt(1).toUpperCase()};return{createStyleSheet:function(i,l){var h;var g=c.getElementsByTagName("head")[0];var k=c.createElement("style");k.setAttribute("type","text/css");if(l){k.setAttribute("id",l)}if(Ext.isIE){g.appendChild(k);h=k.styleSheet;h.cssText=i}else{try{k.appendChild(c.createTextNode(i))}catch(j){k.cssText=i}g.appendChild(k);h=k.styleSheet?k.styleSheet:(k.sheet||c.styleSheets[c.styleSheets.length-1])}this.cacheStyleSheet(h);return h},removeStyleSheet:function(g){var e=c.getElementById(g
 );if(e){e.parentNode.removeChild(e)}},swapStyleSheet:function(h,e){this.removeStyleSheet(h);var g=c.createElement("link");g.setAttribute("rel","stylesheet");g.setAttribute("type","text/css");g.setAttribute("id",h);g.setAttribute("href",e);c.getElementsByTagName("head")[0].appendChild(g)},refreshCache:function(){return this.getRules(true)},cacheStyleSheet:function(h){if(!d){d={}}try{var k=h.cssRules||h.rules;for(var g=k.length-1;g>=0;--g){d[k[g].selectorText.toLowerCase()]=k[g]}}catch(i){}},getRules:function(h){if(d===null||h){d={};var k=c.styleSheets;for(var j=0,g=k.length;j<g;j++){try{this.cacheStyleSheet(k[j])}catch(l){}}}return d},getRule:function(e,h){var g=this.getRules(h);if(!Ext.isArray(e)){return g[e.toLowerCase()]}for(var j=0;j<e.length;j++){if(g[e[j]]){return g[e[j].toLowerCase()]}}return null},updateRule:function(e,j,h){if(!Ext.isArray(e)){var k=this.getRule(e);if(k){k.style[j.replace(b,a)]=h;return true}}else{for(var g=0;g<e.length;g++){if(this.updateRule(e[g],j,
 h)){return true}}}return false}}}();Ext.util.ClickRepeater=Ext.extend(Ext.util.Observable,{constructor:function(b,a){this.el=Ext.get(b);this.el.unselectable();Ext.apply(this,a);this.addEvents("mousedown","click","mouseup");if(!this.disabled){this.disabled=true;this.enable()}if(this.handler){this.on("click",this.handler,this.scope||this)}Ext.util.ClickRepeater.superclass.constructor.call(this)},interval:20,delay:250,preventDefault:true,stopDefault:false,timer:0,enable:function(){if(this.disabled){this.el.on("mousedown",this.handleMouseDown,this);if(Ext.isIE){this.el.on("dblclick",this.handleDblClick,this)}if(this.preventDefault||this.stopDefault){this.el.on("click",this.eventOptions,this)}}this.disabled=false},disable:function(a){if(a||!this.disabled){clearTimeout(this.timer);if(this.pressClass){this.el.removeClass(this.pressClass)}Ext.getDoc().un("mouseup",this.handleMouseUp,this);this.el.removeAllListeners()}this.disabled=true},setDisabled:function(a){this[a?"disable":"enab
 le"]()},eventOptions:function(a){if(this.preventDefault){a.preventDefault()}if(this.stopDefault){a.stopEvent()}},destroy:function(){this.disable(true);Ext.destroy(this.el);this.purgeListeners()},handleDblClick:function(a){clearTimeout(this.timer);this.el.blur();this.fireEvent("mousedown",this,a);this.fireEvent("click",this,a)},handleMouseDown:function(a){clearTimeout(this.timer);this.el.blur();if(this.pressClass){this.el.addClass(this.pressClass)}this.mousedownTime=new Date();Ext.getDoc().on("mouseup",this.handleMouseUp,this);this.el.on("mouseout",this.handleMouseOut,this);this.fireEvent("mousedown",this,a);this.fireEvent("click",this,a);if(this.accelerate){this.delay=400}this.timer=this.click.defer(this.delay||this.interval,this,[a])},click:function(a){this.fireEvent("click",this,a);this.timer=this.click.defer(this.accelerate?this.easeOutExpo(this.mousedownTime.getElapsed(),400,-390,12000):this.interval,this,[a])},easeOutExpo:function(e,a,h,g){return(e==g)?a+h:h*(-Math.pow(
 2,-10*e/g)+1)+a},handleMouseOut:function(){clearTimeout(this.timer);if(this.pressClass){this.el.removeClass(this.pressClass)}this.el.on("mouseover",this.handleMouseReturn,this)},handleMouseReturn:function(){this.el.un("mouseover",this.handleMouseReturn,this);if(this.pressClass){this.el.addClass(this.pressClass)}this.click()},handleMouseUp:function(a){clearTimeout(this.timer);this.el.un("mouseover",this.handleMouseReturn,this);this.el.un("mouseout",this.handleMouseOut,this);Ext.getDoc().un("mouseup",this.handleMouseUp,this);this.el.removeClass(this.pressClass);this.fireEvent("mouseup",this,a)}});Ext.KeyNav=function(b,a){this.el=Ext.get(b);Ext.apply(this,a);if(!this.disabled){this.disabled=true;this.enable()}};Ext.KeyNav.prototype={disabled:false,defaultEventAction:"stopEvent",forceKeyDown:false,relay:function(c){var a=c.getKey(),b=this.keyToHandler[a];if(b&&this[b]){if(this.doRelay(c,this[b],b)!==true){c[this.defaultEventAction]()}}},doRelay:function(c,b,a){return b.call(this
 .scope||this,c,a)},enter:false,left:false,right:false,up:false,down:false,tab:false,esc:false,pageUp:false,pageDown:false,del:false,home:false,end:false,space:false,keyToHandler:{37:"left",39:"right",38:"up",40:"down",33:"pageUp",34:"pageDown",46:"del",36:"home",35:"end",13:"enter",27:"esc",9:"tab",32:"space"},stopKeyUp:function(b){var a=b.getKey();if(a>=37&&a<=40){b.stopEvent()}},destroy:function(){this.disable()},enable:function(){if(this.disabled){if(Ext.isSafari2){this.el.on("keyup",this.stopKeyUp,this)}this.el.on(this.isKeydown()?"keydown":"keypress",this.relay,this);this.disabled=false}},disable:function(){if(!this.disabled){if(Ext.isSafari2){this.el.un("keyup",this.stopKeyUp,this)}this.el.un(this.isKeydown()?"keydown":"keypress",this.relay,this);this.disabled=true}},setDisabled:function(a){this[a?"disable":"enable"]()},isKeydown:function(){return this.forceKeyDown||Ext.EventManager.useKeydown}};Ext.KeyMap=function(c,b,a){this.el=Ext.get(c);this.eventName=a||"keydown";
 this.bindings=[];if(b){this.addBinding(b)}this.enable()};Ext.KeyMap.prototype={stopEvent:false,addBinding:function(b){if(Ext.isArray(b)){Ext.each(b,function(j){this.addBinding(j)},this);return}var k=b.key,g=b.fn||b.handler,l=b.scope;if(b.stopEvent){this.stopEvent=b.stopEvent}if(typeof k=="string"){var h=[];var e=k.toUpperCase();for(var c=0,d=e.length;c<d;c++){h.push(e.charCodeAt(c))}k=h}var a=Ext.isArray(k);var i=function(o){if(this.checkModifiers(b,o)){var m=o.getKey();if(a){for(var n=0,j=k.length;n<j;n++){if(k[n]==m){if(this.stopEvent){o.stopEvent()}g.call(l||window,m,o);return}}}else{if(m==k){if(this.stopEvent){o.stopEvent()}g.call(l||window,m,o)}}}};this.bindings.push(i)},checkModifiers:function(b,h){var j,d,g=["shift","ctrl","alt"];for(var c=0,a=g.length;c<a;++c){d=g[c];j=b[d];if(!(j===undefined||(j===h[d+"Key"]))){return false}}return true},on:function(b,d,c){var h,a,e,g;if(typeof b=="object"&&!Ext.isArray(b)){h=b.key;a=b.shift;e=b.ctrl;g=b.alt}else{h=b}this.addBinding
 ({key:h,shift:a,ctrl:e,alt:g,fn:d,scope:c})},handleKeyDown:function(g){if(this.enabled){var c=this.bindings;for(var d=0,a=c.length;d<a;d++){c[d].call(this,g)}}},isEnabled:function(){return this.enabled},enable:function(){if(!this.enabled){this.el.on(this.eventName,this.handleKeyDown,this);this.enabled=true}},disable:function(){if(this.enabled){this.el.removeListener(this.eventName,this.handleKeyDown,this);this.enabled=false}},setDisabled:function(a){this[a?"disable":"enable"]()}};Ext.util.TextMetrics=function(){var a;return{measure:function(b,c,d){if(!a){a=Ext.util.TextMetrics.Instance(b,d)}a.bind(b);a.setFixedWidth(d||"auto");return a.getSize(c)},createInstance:function(b,c){return Ext.util.TextMetrics.Instance(b,c)}}}();Ext.util.TextMetrics.Instance=function(b,d){var c=new Ext.Element(document.createElement("div"));document.body.appendChild(c.dom);c.position("absolute");c.setLeftTop(-1000,-1000);c.hide();if(d){c.setWidth(d)}var a={getSize:function(g){c.update(g);var e=c.ge
 tSize();c.update("");return e},bind:function(e){c.setStyle(Ext.fly(e).getStyles("font-size","font-style","font-weight","font-family","line-height","text-transform","letter-spacing"))},setFixedWidth:function(e){c.setWidth(e)},getWidth:function(e){c.dom.style.width="auto";return this.getSize(e).width},getHeight:function(e){return this.getSize(e).height}};a.bind(b);return a};Ext.Element.addMethods({getTextWidth:function(c,b,a){return(Ext.util.TextMetrics.measure(this.dom,Ext.value(c,this.dom.innerHTML,true)).width).constrain(b||0,a||1000000)}});Ext.util.Cookies={set:function(c,e){var a=arguments;var i=arguments.length;var b=(i>2)?a[2]:null;var h=(i>3)?a[3]:"/";var d=(i>4)?a[4]:null;var g=(i>5)?a[5]:false;document.cookie=c+"="+escape(e)+((b===null)?"":("; expires="+b.toGMTString()))+((h===null)?"":("; path="+h))+((d===null)?"":("; domain="+d))+((g===true)?"; secure":"")},get:function(d){var b=d+"=";var g=b.length;var a=document.cookie.length;var e=0;var c=0;while(e<a){c=e+g;if(d
 ocument.cookie.substring(e,c)==b){return Ext.util.Cookies.getCookieVal(c)}e=document.cookie.indexOf(" ",e)+1;if(e===0){break}}return null},clear:function(a){if(Ext.util.Cookies.get(a)){document.cookie=a+"=; expires=Thu, 01-Jan-70 00:00:01 GMT"}},getCookieVal:function(b){var a=document.cookie.indexOf(";",b);if(a==-1){a=document.cookie.length}return unescape(document.cookie.substring(b,a))}};Ext.handleError=function(a){throw a};Ext.Error=function(a){this.message=(this.lang[a])?this.lang[a]:a};Ext.Error.prototype=new Error();Ext.apply(Ext.Error.prototype,{lang:{},name:"Ext.Error",getName:function(){return this.name},getMessage:function(){return this.message},toJson:function(){return Ext.encode(this)}});Ext.ComponentMgr=function(){var c=new Ext.util.MixedCollection();var b={};var a={};return{register:function(d){c.add(d)},unregister:function(d){c.remove(d)},get:function(d){return c.get(d)},onAvailable:function(g,e,d){c.on("add",function(h,i){if(i.id==g){e.call(d||i,i);c.un("add"
 ,e,d)}})},all:c,types:b,ptypes:a,isRegistered:function(d){return b[d]!==undefined},isPluginRegistered:function(d){return a[d]!==undefined},registerType:function(e,d){b[e]=d;d.xtype=e},create:function(d,e){return d.render?d:new b[d.xtype||e](d)},registerPlugin:function(e,d){a[e]=d;d.ptype=e},createPlugin:function(e,g){var d=a[e.ptype||g];if(d.init){return d}else{return new d(e)}}}}();Ext.reg=Ext.ComponentMgr.registerType;Ext.preg=Ext.ComponentMgr.registerPlugin;Ext.create=Ext.ComponentMgr.create;Ext.Component=function(b){b=b||{};if(b.initialConfig){if(b.isAction){this.baseAction=b}b=b.initialConfig}else{if(b.tagName||b.dom||Ext.isString(b)){b={applyTo:b,id:b.id||b}}}this.initialConfig=b;Ext.apply(this,b);this.addEvents("added","disable","enable","beforeshow","show","beforehide","hide","removed","beforerender","render","afterrender","beforedestroy","destroy","beforestaterestore","staterestore","beforestatesave","statesave");this.getId();Ext.ComponentMgr.register(this);Ext.Comp
 onent.superclass.constructor.call(this);if(this.baseAction){this.baseAction.addComponent(this)}this.initComponent();if(this.plugins){if(Ext.isArray(this.plugins)){for(var c=0,a=this.plugins.length;c<a;c++){this.plugins[c]=this.initPlugin(this.plugins[c])}}else{this.plugins=this.initPlugin(this.plugins)}}if(this.stateful!==false){this.initState()}if(this.applyTo){this.applyToMarkup(this.applyTo);delete this.applyTo}else{if(this.renderTo){this.render(this.renderTo);delete this.renderTo}}};Ext.Component.AUTO_ID=1000;Ext.extend(Ext.Component,Ext.util.Observable,{disabled:false,hidden:false,autoEl:"div",disabledClass:"x-item-disabled",allowDomMove:true,autoShow:false,hideMode:"display",hideParent:false,rendered:false,tplWriteMode:"overwrite",bubbleEvents:[],ctype:"Ext.Component",actionMode:"el",getActionEl:function(){return this[this.actionMode]},initPlugin:function(a){if(a.ptype&&!Ext.isFunction(a.init)){a=Ext.ComponentMgr.createPlugin(a)}else{if(Ext.isString(a)){a=Ext.Component
 Mgr.createPlugin({ptype:a})}}a.init(this);return a},initComponent:function(){if(this.listeners){this.on(this.listeners);delete this.listeners}this.enableBubble(this.bubbleEvents)},render:function(b,a){if(!this.rendered&&this.fireEvent("beforerender",this)!==false){if(!b&&this.el){this.el=Ext.get(this.el);b=this.el.dom.parentNode;this.allowDomMove=false}this.container=Ext.get(b);if(this.ctCls){this.container.addClass(this.ctCls)}this.rendered=true;if(a!==undefined){if(Ext.isNumber(a)){a=this.container.dom.childNodes[a]}else{a=Ext.getDom(a)}}this.onRender(this.container,a||null);if(this.autoShow){this.el.removeClass(["x-hidden","x-hide-"+this.hideMode])}if(this.cls){this.el.addClass(this.cls);delete this.cls}if(this.style){this.el.applyStyles(this.style);delete this.style}if(this.overCls){this.el.addClassOnOver(this.overCls)}this.fireEvent("render",this);var c=this.getContentTarget();if(this.html){c.update(Ext.DomHelper.markup(this.html));delete this.html}if(this.contentEl){va
 r d=Ext.getDom(this.contentEl);Ext.fly(d).removeClass(["x-hidden","x-hide-display"]);c.appendChild(d)}if(this.tpl){if(!this.tpl.compile){this.tpl=new Ext.XTemplate(this.tpl)}if(this.data){this.tpl[this.tplWriteMode](c,this.data);delete this.data}}this.afterRender(this.container);if(this.hidden){this.doHide()}if(this.disabled){this.disable(true)}if(this.stateful!==false){this.initStateEvents()}this.fireEvent("afterrender",this)}return this},update:function(b,d,a){var c=this.getContentTarget();if(this.tpl&&typeof b!=="string"){this.tpl[this.tplWriteMode](c,b||{})}else{var e=Ext.isObject(b)?Ext.DomHelper.markup(b):b;c.update(e,d,a)}},onAdded:function(a,b){this.ownerCt=a;this.initRef();this.fireEvent("added",this,a,b)},onRemoved:function(){this.removeRef();this.fireEvent("removed",this,this.ownerCt);delete this.ownerCt},initRef:function(){if(this.ref&&!this.refOwner){var d=this.ref.split("/"),c=d.length,b=0,a=this;while(a&&b<c){a=a.ownerCt;++b}if(a){a[this.refName=d[--b]]=this;t
 his.refOwner=a}}},removeRef:function(){if(this.refOwner&&this.refName){delete this.refOwner[this.refName];delete this.refOwner}},initState:function(){if(Ext.state.Manager){var b=this.getStateId();if(b){var a=Ext.state.Manager.get(b);if(a){if(this.fireEvent("beforestaterestore",this,a)!==false){this.applyState(Ext.apply({},a));this.fireEvent("staterestore",this,a)}}}}},getStateId:function(){return this.stateId||((/^(ext-comp-|ext-gen)/).test(String(this.id))?null:this.id)},initStateEvents:function(){if(this.stateEvents){for(var a=0,b;b=this.stateEvents[a];a++){this.on(b,this.saveState,this,{delay:100})}}},applyState:function(a){if(a){Ext.apply(this,a)}},getState:function(){return null},saveState:function(){if(Ext.state.Manager&&this.stateful!==false){var b=this.getStateId();if(b){var a=this.getState();if(this.fireEvent("beforestatesave",this,a)!==false){Ext.state.Manager.set(b,a);this.fireEvent("statesave",this,a)}}}},applyToMarkup:function(a){this.allowDomMove=false;this.el=
 Ext.get(a);this.render(this.el.dom.parentNode)},addClass:function(a){if(this.el){this.el.addClass(a)}else{this.cls=this.cls?this.cls+" "+a:a}return this},removeClass:function(a){if(this.el){this.el.removeClass(a)}else{if(this.cls){this.cls=this.cls.split(" ").remove(a).join(" ")}}return this},onRender:function(b,a){if(!this.el&&this.autoEl){if(Ext.isString(this.autoEl)){this.el=document.createElement(this.autoEl)}else{var c=document.createElement("div");Ext.DomHelper.overwrite(c,this.autoEl);this.el=c.firstChild}if(!this.el.id){this.el.id=this.getId()}}if(this.el){this.el=Ext.get(this.el);if(this.allowDomMove!==false){b.dom.insertBefore(this.el.dom,a);if(c){Ext.removeNode(c);c=null}}}},getAutoCreate:function(){var a=Ext.isObject(this.autoCreate)?this.autoCreate:Ext.apply({},this.defaultAutoCreate);if(this.id&&!a.id){a.id=this.id}return a},afterRender:Ext.emptyFn,destroy:function(){if(!this.isDestroyed){if(this.fireEvent("beforedestroy",this)!==false){this.destroying=true;thi
 s.beforeDestroy();if(this.ownerCt&&this.ownerCt.remove){this.ownerCt.remove(this,false)}if(this.rendered){this.el.remove();if(this.actionMode=="container"||this.removeMode=="container"){this.container.remove()}}if(this.focusTask&&this.focusTask.cancel){this.focusTask.cancel()}this.onDestroy();Ext.ComponentMgr.unregister(this);this.fireEvent("destroy",this);this.purgeListeners();this.destroying=false;this.isDestroyed=true}}},deleteMembers:function(){var b=arguments;for(var c=0,a=b.length;c<a;++c){delete this[b[c]]}},beforeDestroy:Ext.emptyFn,onDestroy:Ext.emptyFn,getEl:function(){return this.el},getContentTarget:function(){return this.el},getId:function(){return this.id||(this.id="ext-comp-"+(++Ext.Component.AUTO_ID))},getItemId:function(){return this.itemId||this.getId()},focus:function(b,a){if(a){this.focusTask=new Ext.util.DelayedTask(this.focus,this,[b,false]);this.focusTask.delay(Ext.isNumber(a)?a:10);return this}if(this.rendered&&!this.isDestroyed){this.el.focus();if(b=
 ==true){this.el.dom.select()}}return this},blur:function(){if(this.rendered){this.el.blur()}return this},disable:function(a){if(this.rendered){this.onDisable()}this.disabled=true;if(a!==true){this.fireEvent("disable",this)}return this},onDisable:function(){this.getActionEl().addClass(this.disabledClass);this.el.dom.disabled=true},enable:function(){if(this.rendered){this.onEnable()}this.disabled=false;this.fireEvent("enable",this);return this},onEnable:function(){this.getActionEl().removeClass(this.disabledClass);this.el.dom.disabled=false},setDisabled:function(a){return this[a?"disable":"enable"]()},show:function(){if(this.fireEvent("beforeshow",this)!==false){this.hidden=false;if(this.autoRender){this.render(Ext.isBoolean(this.autoRender)?Ext.getBody():this.autoRender)}if(this.rendered){this.onShow()}this.fireEvent("show",this)}return this},onShow:function(){this.getVisibilityEl().removeClass("x-hide-"+this.hideMode)},hide:function(){if(this.fireEvent("beforehide",this)!==f
 alse){this.doHide();this.fireEvent("hide",this)}return this},doHide:function(){this.hidden=true;if(this.rendered){this.onHide()}},onHide:function(){this.getVisibilityEl().addClass("x-hide-"+this.hideMode)},getVisibilityEl:function(){return this.hideParent?this.container:this.getActionEl()},setVisible:function(a){return this[a?"show":"hide"]()},isVisible:function(){return this.rendered&&this.getVisibilityEl().isVisible()},cloneConfig:function(b){b=b||{};var c=b.id||Ext.id();var a=Ext.applyIf(b,this.initialConfig);a.id=c;return new this.constructor(a)},getXType:function(){return this.constructor.xtype},isXType:function(b,a){if(Ext.isFunction(b)){b=b.xtype}else{if(Ext.isObject(b)){b=b.constructor.xtype}}return !a?("/"+this.getXTypes()+"/").indexOf("/"+b+"/")!=-1:this.constructor.xtype==b},getXTypes:function(){var a=this.constructor;if(!a.xtypes){var d=[],b=this;while(b&&b.constructor.xtype){d.unshift(b.constructor.xtype);b=b.constructor.superclass}a.xtypeChain=d;a.xtypes=d.join
 ("/")}return a.xtypes},findParentBy:function(a){for(var b=this.ownerCt;(b!=null)&&!a(b,this);b=b.ownerCt){}return b||null},findParentByType:function(b,a){return this.findParentBy(function(d){return d.isXType(b,a)})},bubble:function(c,b,a){var d=this;while(d){if(c.apply(b||d,a||[d])===false){break}d=d.ownerCt}return this},getPositionEl:function(){return this.positionEl||this.el},purgeListeners:function(){Ext.Component.superclass.purgeListeners.call(this);if(this.mons){this.on("beforedestroy",this.clearMons,this,{single:true})}},clearMons:function(){Ext.each(this.mons,function(a){a.item.un(a.ename,a.fn,a.scope)},this);this.mons=[]},createMons:function(){if(!this.mons){this.mons=[];this.on("beforedestroy",this.clearMons,this,{single:true})}},mon:function(g,b,d,c,a){this.createMons();if(Ext.isObject(b)){var j=/^(?:scope|delay|buffer|single|stopEvent|preventDefault|stopPropagation|normalized|args|delegate)$/;var i=b;for(var h in i){if(j.test(h)){continue}if(Ext.isFunction(i[h])){
 this.mons.push({item:g,ename:h,fn:i[h],scope:i.scope});g.on(h,i[h],i.scope,i)}else{this.mons.push({item:g,ename:h,fn:i[h],scope:i.scope});g.on(h,i[h])}}return}this.mons.push({item:g,ename:b,fn:d,scope:c});g.on(b,d,c,a)},mun:function(h,c,g,e){var j,d;this.createMons();for(var b=0,a=this.mons.length;b<a;++b){d=this.mons[b];if(h===d.item&&c==d.ename&&g===d.fn&&e===d.scope){this.mons.splice(b,1);h.un(c,g,e);j=true;break}}return j},nextSibling:function(){if(this.ownerCt){var a=this.ownerCt.items.indexOf(this);if(a!=-1&&a+1<this.ownerCt.items.getCount()){return this.ownerCt.items.itemAt(a+1)}}return null},previousSibling:function(){if(this.ownerCt){var a=this.ownerCt.items.indexOf(this);if(a>0){return this.ownerCt.items.itemAt(a-1)}}return null},getBubbleTarget:function(){return this.ownerCt}});Ext.reg("component",Ext.Component);Ext.Action=Ext.extend(Object,{constructor:function(a){this.initialConfig=a;this.itemId=a.itemId=(a.itemId||a.id||Ext.id());this.items=[]},isAction:true,se
 tText:function(a){this.initialConfig.text=a;this.callEach("setText",[a])},getText:function(){return this.initialConfig.text},setIconClass:function(a){this.initialConfig.iconCls=a;this.callEach("setIconClass",[a])},getIconClass:function(){return this.initialConfig.iconCls},setDisabled:function(a){this.initialConfig.disabled=a;this.callEach("setDisabled",[a])},enable:function(){this.setDisabled(false)},disable:function(){this.setDisabled(true)},isDisabled:function(){return this.initialConfig.disabled},setHidden:function(a){this.initialConfig.hidden=a;this.callEach("setVisible",[!a])},show:function(){this.setHidden(false)},hide:function(){this.setHidden(true)},isHidden:function(){return this.initialConfig.hidden},setHandler:function(b,a){this.initialConfig.handler=b;this.initialConfig.scope=a;this.callEach("setHandler",[b,a])},each:function(b,a){Ext.each(this.items,b,a)},callEach:function(e,b){var d=this.items;for(var c=0,a=d.length;c<a;c++){d[c][e].apply(d[c],b)}},addComponent
 :function(a){this.items.push(a);a.on("destroy",this.removeComponent,this)},removeComponent:function(a){this.items.remove(a)},execute:function(){this.initialConfig.handler.apply(this.initialConfig.scope||window,arguments)}});(function(){Ext.Layer=function(d,c){d=d||{};var e=Ext.DomHelper,h=d.parentEl,g=h?Ext.getDom(h):document.body;if(c){this.dom=Ext.getDom(c)}if(!this.dom){var i=d.dh||{tag:"div",cls:"x-layer"};this.dom=e.append(g,i)}if(d.cls){this.addClass(d.cls)}this.constrain=d.constrain!==false;this.setVisibilityMode(Ext.Element.VISIBILITY);if(d.id){this.id=this.dom.id=d.id}else{this.id=Ext.id(this.dom)}this.zindex=d.zindex||this.getZIndex();this.position("absolute",this.zindex);if(d.shadow){this.shadowOffset=d.shadowOffset||4;this.shadow=new Ext.Shadow({offset:this.shadowOffset,mode:d.shadow})}else{this.shadowOffset=0}this.useShim=d.shim!==false&&Ext.useShims;this.useDisplay=d.useDisplay;this.hide()};var a=Ext.Element.prototype;var b=[];Ext.extend(Ext.Layer,Ext.Element,{
 getZIndex:function(){return this.zindex||parseInt((this.getShim()||this).getStyle("z-index"),10)||11000},getShim:function(){if(!this.useShim){return null}if(this.shim){return this.shim}var d=b.shift();if(!d){d=this.createShim();d.enableDisplayMode("block");d.dom.style.display="none";d.dom.style.visibility="visible"}var c=this.dom.parentNode;if(d.dom.parentNode!=c){c.insertBefore(d.dom,this.dom)}d.setStyle("z-index",this.getZIndex()-2);this.shim=d;return d},hideShim:function(){if(this.shim){this.shim.setDisplayed(false);b.push(this.shim);delete this.shim}},disableShadow:function(){if(this.shadow){this.shadowDisabled=true;this.shadow.hide();this.lastShadowOffset=this.shadowOffset;this.shadowOffset=0}},enableShadow:function(c){if(this.shadow){this.shadowDisabled=false;if(Ext.isDefined(this.lastShadowOffset)){this.shadowOffset=this.lastShadowOffset;delete this.lastShadowOffset}if(c){this.sync(true)}}},sync:function(d){var n=this.shadow;if(!this.updating&&this.isVisible()&&(n||th
 is.useShim)){var i=this.getShim(),m=this.getWidth(),j=this.getHeight(),e=this.getLeft(true),o=this.getTop(true);if(n&&!this.shadowDisabled){if(d&&!n.isVisible()){n.show(this)}else{n.realign(e,o,m,j)}if(i){if(d){i.show()}var k=n.el.getXY(),g=i.dom.style,c=n.el.getSize();g.left=(k[0])+"px";g.top=(k[1])+"px";g.width=(c.width)+"px";g.height=(c.height)+"px"}}else{if(i){if(d){i.show()}i.setSize(m,j);i.setLeftTop(e,o)}}}},destroy:function(){this.hideShim();if(this.shadow){this.shadow.hide()}this.removeAllListeners();Ext.removeNode(this.dom);delete this.dom},remove:function(){this.destroy()},beginUpdate:function(){this.updating=true},endUpdate:function(){this.updating=false;this.sync(true)},hideUnders:function(c){if(this.shadow){this.shadow.hide()}this.hideShim()},constrainXY:function(){if(this.constrain){var j=Ext.lib.Dom.getViewWidth(),d=Ext.lib.Dom.getViewHeight();var o=Ext.getDoc().getScroll();var n=this.getXY();var k=n[0],i=n[1];var c=this.shadowOffset;var l=this.dom.offsetWidt
 h+c,e=this.dom.offsetHeight+c;var g=false;if((k+l)>j+o.left){k=j-l-c;g=true}if((i+e)>d+o.top){i=d-e-c;g=true}if(k<o.left){k=o.left;g=true}if(i<o.top){i=o.top;g=true}if(g){if(this.avoidY){var m=this.avoidY;if(i<=m&&(i+e)>=m){i=m-e-5}}n=[k,i];this.storeXY(n);a.setXY.call(this,n);this.sync()}}return this},getConstrainOffset:function(){return this.shadowOffset},isVisible:function(){return this.visible},showAction:function(){this.visible=true;if(this.useDisplay===true){this.setDisplayed("")}else{if(this.lastXY){a.setXY.call(this,this.lastXY)}else{if(this.lastLT){a.setLeftTop.call(this,this.lastLT[0],this.lastLT[1])}}}},hideAction:function(){this.visible=false;if(this.useDisplay===true){this.setDisplayed(false)}else{this.setLeftTop(-10000,-10000)}},setVisible:function(i,h,k,l,j){if(i){this.showAction()}if(h&&i){var g=function(){this.sync(true);if(l){l()}}.createDelegate(this);a.setVisible.call(this,true,true,k,g,j)}else{if(!i){this.hideUnders(true)}var g=l;if(h){g=function(){this.
 hideAction();if(l){l()}}.createDelegate(this)}a.setVisible.call(this,i,h,k,g,j);if(i){this.sync(true)}else{if(!h){this.hideAction()}}}return this},storeXY:function(c){delete this.lastLT;this.lastXY=c},storeLeftTop:function(d,c){delete this.lastXY;this.lastLT=[d,c]},beforeFx:function(){this.beforeAction();return Ext.Layer.superclass.beforeFx.apply(this,arguments)},afterFx:function(){Ext.Layer.superclass.afterFx.apply(this,arguments);this.sync(this.isVisible())},beforeAction:function(){if(!this.updating&&this.shadow){this.shadow.hide()}},setLeft:function(c){this.storeLeftTop(c,this.getTop(true));a.setLeft.apply(this,arguments);this.sync();return this},setTop:function(c){this.storeLeftTop(this.getLeft(true),c);a.setTop.apply(this,arguments);this.sync();return this},setLeftTop:function(d,c){this.storeLeftTop(d,c);a.setLeftTop.apply(this,arguments);this.sync();return this},setXY:function(j,h,k,l,i){this.fixDisplay();this.beforeAction();this.storeXY(j);var g=this.createCB(l);a.set
 XY.call(this,j,h,k,g,i);if(!h){g()}return this},createCB:function(e){var d=this;return function(){d.constrainXY();d.sync(true);if(e){e()}}},setX:function(g,h,j,k,i){this.setXY([g,this.getY()],h,j,k,i);return this},setY:function(k,g,i,j,h){this.setXY([this.getX(),k],g,i,j,h);return this},setSize:function(j,k,i,m,n,l){this.beforeAction();var g=this.createCB(n);a.setSize.call(this,j,k,i,m,g,l);if(!i){g()}return this},setWidth:function(i,h,k,l,j){this.beforeAction();var g=this.createCB(l);a.setWidth.call(this,i,h,k,g,j);if(!h){g()}return this},setHeight:function(j,i,l,m,k){this.beforeAction();var g=this.createCB(m);a.setHeight.call(this,j,i,l,g,k);if(!i){g()}return this},setBounds:function(o,m,p,i,n,k,l,j){this.beforeAction();var g=this.createCB(l);if(!n){this.storeXY([o,m]);a.setXY.call(this,[o,m]);a.setSize.call(this,p,i,n,k,g,j);g()}else{a.setBounds.call(this,o,m,p,i,n,k,g,j)}return this},setZIndex:function(c){this.zindex=c;this.setStyle("z-index",c+2);if(this.shadow){this.sh
 adow.setZIndex(c+1)}if(this.shim){this.shim.setStyle("z-index",c)}return this}})})();Ext.Shadow=function(d){Ext.apply(this,d);if(typeof this.mode!="string"){this.mode=this.defaultMode}var e=this.offset,c={h:0},b=Math.floor(this.offset/2);switch(this.mode.toLowerCase()){case"drop":c.w=0;c.l=c.t=e;c.t-=1;if(Ext.isIE){c.l-=this.offset+b;c.t-=this.offset+b;c.w-=b;c.h-=b;c.t+=1}break;case"sides":c.w=(e*2);c.l=-e;c.t=e-1;if(Ext.isIE){c.l-=(this.offset-b);c.t-=this.offset+b;c.l+=1;c.w-=(this.offset-b)*2;c.w-=b+1;c.h-=1}break;case"frame":c.w=c.h=(e*2);c.l=c.t=-e;c.t+=1;c.h-=2;if(Ext.isIE){c.l-=(this.offset-b);c.t-=(this.offset-b);c.l+=1;c.w-=(this.offset+b+1);c.h-=(this.offset+b);c.h+=1}break}this.adjusts=c};Ext.Shadow.prototype={offset:4,defaultMode:"drop",show:function(a){a=Ext.get(a);if(!this.el){this.el=Ext.Shadow.Pool.pull();if(this.el.dom.nextSibling!=a.dom){this.el.insertBefore(a)}}this.el.setStyle("z-index",this.zIndex||parseInt(a.getStyle("z-index"),10)-1);if(Ext.isIE){this
 .el.dom.style.filter="progid:DXImageTransform.Microsoft.alpha(opacity=50) progid:DXImageTransform.Microsoft.Blur(pixelradius="+(this.offset)+")"}this.realign(a.getLeft(true),a.getTop(true),a.getWidth(),a.getHeight());this.el.dom.style.display="block"},isVisible:function(){return this.el?true:false},realign:function(b,r,q,g){if(!this.el){return}var n=this.adjusts,k=this.el.dom,u=k.style,i=0,p=(q+n.w),e=(g+n.h),j=p+"px",o=e+"px",m,c;u.left=(b+n.l)+"px";u.top=(r+n.t)+"px";if(u.width!=j||u.height!=o){u.width=j;u.height=o;if(!Ext.isIE){m=k.childNodes;c=Math.max(0,(p-12))+"px";m[0].childNodes[1].style.width=c;m[1].childNodes[1].style.width=c;m[2].childNodes[1].style.width=c;m[1].style.height=Math.max(0,(e-12))+"px"}}},hide:function(){if(this.el){this.el.dom.style.display="none";Ext.Shadow.Pool.push(this.el);delete this.el}},setZIndex:function(a){this.zIndex=a;if(this.el){this.el.setStyle("z-index",a)}}};Ext.Shadow.Pool=function(){var b=[],a=Ext.isIE?'<div class="x-ie-shadow"></div
 >':'<div class="x-shadow"><div class="xst"><div class="xstl"></div><div class="xstc"></div><div class="xstr"></div></div><div class="xsc"><div class="xsml"></div><div class="xsmc"></div><div class="xsmr"></div></div><div class="xsb"><div class="xsbl"></div><div class="xsbc"></div><div class="xsbr"></div></div></div>';return{pull:function(){var c=b.shift();if(!c){c=Ext.get(Ext.DomHelper.insertHtml("beforeBegin",document.body.firstChild,a));c.autoBoxAdjust=false}return c},push:function(c){b.push(c)}}}();Ext.BoxComponent=Ext.extend(Ext.Component,{initComponent:function(){Ext.BoxComponent.superclass.initComponent.call(this);this.addEvents("resize","move")},boxReady:false,deferHeight:false,setSize:function(b,d){if(typeof b=="object"){d=b.height;b=b.width}if(Ext.isDefined(b)&&Ext.isDefined(this.boxMinWidth)&&(b<this.boxMinWidth)){b=this.boxMinWidth}if(Ext.isDefined(d)&&Ext.isDefined(this.boxMinHeight)&&(d<this.boxMinHeight)){d=this.boxMinHeight}if(Ext.isDefined(b)&&Ext.isDefined(t
 his.boxMaxWidth)&&(b>this.boxMaxWidth)){b=this.boxMaxWidth}if(Ext.isDefined(d)&&Ext.isDefined(this.boxMaxHeight)&&(d>this.boxMaxHeight)){d=this.boxMaxHeight}if(!this.boxReady){this.width=b;this.height=d;return this}if(this.cacheSizes!==false&&this.lastSize&&this.lastSize.width==b&&this.lastSize.height==d){return this}this.lastSize={width:b,height:d};var c=this.adjustSize(b,d),g=c.width,a=c.height,e;if(g!==undefined||a!==undefined){e=this.getResizeEl();if(!this.deferHeight&&g!==undefined&&a!==undefined){e.setSize(g,a)}else{if(!this.deferHeight&&a!==undefined){e.setHeight(a)}else{if(g!==undefined){e.setWidth(g)}}}this.onResize(g,a,b,d);this.fireEvent("resize",this,g,a,b,d)}return this},setWidth:function(a){return this.setSize(a)},setHeight:function(a){return this.setSize(undefined,a)},getSize:function(){return this.getResizeEl().getSize()},getWidth:function(){return this.getResizeEl().getWidth()},getHeight:function(){return this.getResizeEl().getHeight()},getOuterSize:function
 (){var a=this.getResizeEl();return{width:a.getWidth()+a.getMargins("lr"),height:a.getHeight()+a.getMargins("tb")}},getPosition:function(a){var b=this.getPositionEl();if(a===true){return[b.getLeft(true),b.getTop(true)]}return this.xy||b.getXY()},getBox:function(a){var c=this.getPosition(a);var b=this.getSize();b.x=c[0];b.y=c[1];return b},updateBox:function(a){this.setSize(a.width,a.height);this.setPagePosition(a.x,a.y);return this},getResizeEl:function(){return this.resizeEl||this.el},setAutoScroll:function(a){if(this.rendered){this.getContentTarget().setOverflow(a?"auto":"")}this.autoScroll=a;return this},setPosition:function(a,g){if(a&&typeof a[1]=="number"){g=a[1];a=a[0]}this.x=a;this.y=g;if(!this.boxReady){return this}var b=this.adjustPosition(a,g);var e=b.x,d=b.y;var c=this.getPositionEl();if(e!==undefined||d!==undefined){if(e!==undefined&&d!==undefined){c.setLeftTop(e,d)}else{if(e!==undefined){c.setLeft(e)}else{if(d!==undefined){c.setTop(d)}}}this.onPosition(e,d);this.f
 ireEvent("move",this,e,d)}return this},setPagePosition:function(a,c){if(a&&typeof a[1]=="number"){c=a[1];a=a[0]}this.pageX=a;this.pageY=c;if(!this.boxReady){return}if(a===undefined||c===undefined){return}var b=this.getPositionEl().translatePoints(a,c);this.setPosition(b.left,b.top);return this},afterRender:function(){Ext.BoxComponent.superclass.afterRender.call(this);if(this.resizeEl){this.resizeEl=Ext.get(this.resizeEl)}if(this.positionEl){this.positionEl=Ext.get(this.positionEl)}this.boxReady=true;Ext.isDefined(this.autoScroll)&&this.setAutoScroll(this.autoScroll);this.setSize(this.width,this.height);if(this.x||this.y){this.setPosition(this.x,this.y)}else{if(this.pageX||this.pageY){this.setPagePosition(this.pageX,this.pageY)}}},syncSize:function(){delete this.lastSize;this.setSize(this.autoWidth?undefined:this.getResizeEl().getWidth(),this.autoHeight?undefined:this.getResizeEl().getHeight());return this},onResize:function(d,b,a,c){},onPosition:function(a,b){},adjustSize:fu
 nction(a,b){if(this.autoWidth){a="auto"}if(this.autoHeight){b="auto"}return{width:a,height:b}},adjustPosition:function(a,b){return{x:a,y:b}}});Ext.reg("box",Ext.BoxComponent);Ext.Spacer=Ext.extend(Ext.BoxComponent,{autoEl:"div"});Ext.reg("spacer",Ext.Spacer);Ext.SplitBar=function(c,e,b,d,a){this.el=Ext.get(c,true);this.el.dom.unselectable="on";this.resizingEl=Ext.get(e,true);this.orientation=b||Ext.SplitBar.HORIZONTAL;this.minSize=0;this.maxSize=2000;this.animate=false;this.useShim=false;this.shim=null;if(!a){this.proxy=Ext.SplitBar.createProxy(this.orientation)}else{this.proxy=Ext.get(a).dom}this.dd=new Ext.dd.DDProxy(this.el.dom.id,"XSplitBars",{dragElId:this.proxy.id});this.dd.b4StartDrag=this.onStartProxyDrag.createDelegate(this);this.dd.endDrag=this.onEndProxyDrag.createDelegate(this);this.dragSpecs={};this.adapter=new Ext.SplitBar.BasicLayoutAdapter();this.adapter.init(this);if(this.orientation==Ext.SplitBar.HORIZONTAL){this.placement=d||(this.el.getX()>this.resizingEl
 .getX()?Ext.SplitBar.LEFT:Ext.SplitBar.RIGHT);this.el.addClass("x-splitbar-h")}else{this.placement=d||(this.el.getY()>this.resizingEl.getY()?Ext.SplitBar.TOP:Ext.SplitBar.BOTTOM);this.el.addClass("x-splitbar-v")}this.addEvents("resize","moved","beforeresize","beforeapply");Ext.SplitBar.superclass.constructor.call(this)};Ext.extend(Ext.SplitBar,Ext.util.Observable,{onStartProxyDrag:function(a,e){this.fireEvent("beforeresize",this);this.overlay=Ext.DomHelper.append(document.body,{cls:"x-drag-overlay",html:"&#160;"},true);this.overlay.unselectable();this.overlay.setSize(Ext.lib.Dom.getViewWidth(true),Ext.lib.Dom.getViewHeight(true));this.overlay.show();Ext.get(this.proxy).setDisplayed("block");var c=this.adapter.getElementSize(this);this.activeMinSize=this.getMinimumSize();this.activeMaxSize=this.getMaximumSize();var d=c-this.activeMinSize;var b=Math.max(this.activeMaxSize-c,0);if(this.orientation==Ext.SplitBar.HORIZONTAL){this.dd.resetConstraints();this.dd.setXConstraint(this.
 placement==Ext.SplitBar.LEFT?d:b,this.placement==Ext.SplitBar.LEFT?b:d,this.tickSize);this.dd.setYConstraint(0,0)}else{this.dd.resetConstraints();this.dd.setXConstraint(0,0);this.dd.setYConstraint(this.placement==Ext.SplitBar.TOP?d:b,this.placement==Ext.SplitBar.TOP?b:d,this.tickSize)}this.dragSpecs.startSize=c;this.dragSpecs.startPoint=[a,e];Ext.dd.DDProxy.prototype.b4StartDrag.call(this.dd,a,e)},onEndProxyDrag:function(c){Ext.get(this.proxy).setDisplayed(false);var b=Ext.lib.Event.getXY(c);if(this.overlay){Ext.destroy(this.overlay);delete this.overlay}var a;if(this.orientation==Ext.SplitBar.HORIZONTAL){a=this.dragSpecs.startSize+(this.placement==Ext.SplitBar.LEFT?b[0]-this.dragSpecs.startPoint[0]:this.dragSpecs.startPoint[0]-b[0])}else{a=this.dragSpecs.startSize+(this.placement==Ext.SplitBar.TOP?b[1]-this.dragSpecs.startPoint[1]:this.dragSpecs.startPoint[1]-b[1])}a=Math.min(Math.max(a,this.activeMinSize),this.activeMaxSize);if(a!=this.dragSpecs.startSize){if(this.fireEvent
 ("beforeapply",this,a)!==false){this.adapter.setElementSize(this,a);this.fireEvent("moved",this,a);this.fireEvent("resize",this,a)}}},getAdapter:function(){return this.adapter},setAdapter:function(a){this.adapter=a;this.adapter.init(this)},getMinimumSize:function(){return this.minSize},setMinimumSize:function(a){this.minSize=a},getMaximumSize:function(){return this.maxSize},setMaximumSize:function(a){this.maxSize=a},setCurrentSize:function(b){var a=this.animate;this.animate=false;this.adapter.setElementSize(this,b);this.animate=a},destroy:function(a){Ext.destroy(this.shim,Ext.get(this.proxy));this.dd.unreg();if(a){this.el.remove()}this.purgeListeners()}});Ext.SplitBar.createProxy=function(b){var c=new Ext.Element(document.createElement("div"));document.body.appendChild(c.dom);c.unselectable();var a="x-splitbar-proxy";c.addClass(a+" "+(b==Ext.SplitBar.HORIZONTAL?a+"-h":a+"-v"));return c.dom};Ext.SplitBar.BasicLayoutAdapter=function(){};Ext.SplitBar.BasicLayoutAdapter.prototyp
 e={init:function(a){},getElementSize:function(a){if(a.orientation==Ext.SplitBar.HORIZONTAL){return a.resizingEl.getWidth()}else{return a.resizingEl.getHeight()}},setElementSize:function(b,a,c){if(b.orientation==Ext.SplitBar.HORIZONTAL){if(!b.animate){b.resizingEl.setWidth(a);if(c){c(b,a)}}else{b.resizingEl.setWidth(a,true,0.1,c,"easeOut")}}else{if(!b.animate){b.resizingEl.setHeight(a);if(c){c(b,a)}}else{b.resizingEl.setHeight(a,true,0.1,c,"easeOut")}}}};Ext.SplitBar.AbsoluteLayoutAdapter=function(a){this.basic=new Ext.SplitBar.BasicLayoutAdapter();this.container=Ext.get(a)};Ext.SplitBar.AbsoluteLayoutAdapter.prototype={init:function(a){this.basic.init(a)},getElementSize:function(a){return this.basic.getElementSize(a)},setElementSize:function(b,a,c){this.basic.setElementSize(b,a,this.moveSplitter.createDelegate(this,[b]))},moveSplitter:function(a){var b=Ext.SplitBar;switch(a.placement){case b.LEFT:a.el.setX(a.resizingEl.getRight());break;case b.RIGHT:a.el.setStyle("right",(th
 is.container.getWidth()-a.resizingEl.getLeft())+"px");break;case b.TOP:a.el.setY(a.resizingEl.getBottom());break;case b.BOTTOM:a.el.setY(a.resizingEl.getTop()-a.el.getHeight());break}}};Ext.SplitBar.VERTICAL=1;Ext.SplitBar.HORIZONTAL=2;Ext.SplitBar.LEFT=1;Ext.SplitBar.RIGHT=2;Ext.SplitBar.TOP=3;Ext.SplitBar.BOTTOM=4;Ext.Container=Ext.extend(Ext.BoxComponent,{bufferResize:50,autoDestroy:true,forceLayout:false,defaultType:"panel",resizeEvent:"resize",bubbleEvents:["add","remove"],initComponent:function(){Ext.Container.superclass.initComponent.call(this);this.addEvents("afterlayout","beforeadd","beforeremove","add","remove");var a=this.items;if(a){delete this.items;this.add(a)}},initItems:function(){if(!this.items){this.items=new Ext.util.MixedCollection(false,this.getComponentId);this.getLayout()}},setLayout:function(a){if(this.layout&&this.layout!=a){this.layout.setContainer(null)}this.layout=a;this.initItems();a.setContainer(this)},afterRender:function(){Ext.Container.superc
 lass.afterRender.call(this);if(!this.layout){this.layout="auto"}if(Ext.isObject(this.layout)&&!this.layout.layout){this.layoutConfig=this.layout;this.layout=this.layoutConfig.type}if(Ext.isString(this.layout)){this.layout=new Ext.Container.LAYOUTS[this.layout.toLowerCase()](this.layoutConfig)}this.setLayout(this.layout);if(this.activeItem!==undefined&&this.layout.setActiveItem){var a=this.activeItem;delete this.activeItem;this.layout.setActiveItem(a)}if(!this.ownerCt){this.doLayout(false,true)}if(this.monitorResize===true){Ext.EventManager.onWindowResize(this.doLayout,this,[false])}},getLayoutTarget:function(){return this.el},getComponentId:function(a){return a.getItemId()},add:function(b){this.initItems();var e=arguments.length>1;if(e||Ext.isArray(b)){var a=[];Ext.each(e?arguments:b,function(h){a.push(this.add(h))},this);return a}var g=this.lookupComponent(this.applyDefaults(b));var d=this.items.length;if(this.fireEvent("beforeadd",this,g,d)!==false&&this.onBeforeAdd(g)!==f
 alse){this.items.add(g);g.onAdded(this,d);this.onAdd(g);this.fireEvent("add",this,g,d)}return g},onAdd:function(a){},onAdded:function(a,b){this.ownerCt=a;this.initRef();this.cascade(function(d){d.initRef()});this.fireEvent("added",this,a,b)},insert:function(e,b){var d=arguments,h=d.length,a=[],g,j;this.initItems();if(h>2){for(g=h-1;g>=1;--g){a.push(this.insert(e,d[g]))}return a}j=this.lookupComponent(this.applyDefaults(b));e=Math.min(e,this.items.length);if(this.fireEvent("beforeadd",this,j,e)!==false&&this.onBeforeAdd(j)!==false){if(j.ownerCt==this){this.items.remove(j)}this.items.insert(e,j);j.onAdded(this,e);this.onAdd(j);this.fireEvent("add",this,j,e)}return j},applyDefaults:function(b){var a=this.defaults;if(a){if(Ext.isFunction(a)){a=a.call(this,b)}if(Ext.isString(b)){b=Ext.ComponentMgr.get(b);Ext.apply(b,a)}else{if(!b.events){Ext.applyIf(b.isAction?b.initialConfig:b,a)}else{Ext.apply(b,a)}}}return b},onBeforeAdd:function(a){if(a.ownerCt){a.ownerCt.remove(a,false)}if(t
 his.hideBorders===true){a.border=(a.border===true)}},remove:function(a,b){this.initItems();var d=this.getComponent(a);if(d&&this.fireEvent("beforeremove",this,d)!==false){this.doRemove(d,b);this.fireEvent("remove",this,d)}return d},onRemove:function(a){},doRemove:function(e,d){var b=this.layout,a=b&&this.rendered;if(a){b.onRemove(e)}this.items.remove(e);e.onRemoved();this.onRemove(e);if(d===true||(d!==false&&this.autoDestroy)){e.destroy()}if(a){b.afterRemove(e)}},removeAll:function(c){this.initItems();var e,g=[],b=[];this.items.each(function(h){g.push(h)});for(var d=0,a=g.length;d<a;++d){e=g[d];this.remove(e,c);if(e.ownerCt!==this){b.push(e)}}return b},getComponent:function(a){if(Ext.isObject(a)){a=a.getItemId()}return this.items.get(a)},lookupComponent:function(a){if(Ext.isString(a)){return Ext.ComponentMgr.get(a)}else{if(!a.events){return this.createComponent(a)}}return a},createComponent:function(a,d){if(a.render){return a}var b=Ext.create(Ext.apply({ownerCt:this},a),d||t
 his.defaultType);delete b.initialConfig.ownerCt;delete b.ownerCt;return b},canLayout:function(){var a=this.getVisibilityEl();return a&&a.dom&&!a.isStyle("display","none")},doLayout:function(g,e){var k=this.rendered,j=e||this.forceLayout;if(this.collapsed||!this.canLayout()){this.deferLayout=this.deferLayout||!g;if(!j){return}g=g&&!this.deferLayout}else{delete this.deferLayout}if(k&&this.layout){this.layout.layout()}if(g!==true&&this.items){var d=this.items.items;for(var b=0,a=d.length;b<a;b++){var h=d[b];if(h.doLayout){h.doLayout(false,j)}}}if(k){this.onLayout(g,j)}this.hasLayout=true;delete this.forceLayout},onLayout:Ext.emptyFn,shouldBufferLayout:function(){var a=this.hasLayout;if(this.ownerCt){return a?!this.hasLayoutPending():false}return a},hasLayoutPending:function(){var a=false;this.ownerCt.bubble(function(b){if(b.layoutPending){a=true;return false}});return a},onShow:function(){Ext.Container.superclass.onShow.call(this);if(Ext.isDefined(this.deferLayout)){delete this
 .deferLayout;this.doLayout(true)}},getLayout:function(){if(!this.layout){var a=new Ext.layout.AutoLayout(this.layoutConfig);this.setLayout(a)}return this.layout},beforeDestroy:function(){var a;if(this.items){while(a=this.items.first()){this.doRemove(a,true)}}if(this.monitorResize){Ext.EventManager.removeResizeListener(this.doLayout,this)}Ext.destroy(this.layout);Ext.Container.superclass.beforeDestroy.call(this)},cascade:function(g,e,b){if(g.apply(e||this,b||[this])!==false){if(this.items){var d=this.items.items;for(var c=0,a=d.length;c<a;c++){if(d[c].cascade){d[c].cascade(g,e,b)}else{g.apply(e||d[c],b||[d[c]])}}}}return this},findById:function(c){var a=null,b=this;this.cascade(function(d){if(b!=d&&d.id===c){a=d;return false}});return a},findByType:function(b,a){return this.findBy(function(d){return d.isXType(b,a)})},find:function(b,a){return this.findBy(function(d){return d[b]===a})},findBy:function(d,c){var a=[],b=this;this.cascade(function(e){if(b!=e&&d.call(c||e,e,b)===tr
 ue){a.push(e)}});return a},get:function(a){return this.getComponent(a)}});Ext.Container.LAYOUTS={};Ext.reg("container",Ext.Container);Ext.layout.ContainerLayout=Ext.extend(Object,{monitorResize:false,activeItem:null,constructor:function(a){this.id=Ext.id(null,"ext-layout-");Ext.apply(this,a)},type:"container",IEMeasureHack:function(k,g){var a=k.dom.childNodes,b=a.length,n,m=[],l,h,j;for(h=0;h<b;h++){n=a[h];l=Ext.get(n);if(l){m[h]=l.getStyle("display");l.setStyle({display:"none"})}}j=k?k.getViewSize(g):{};for(h=0;h<b;h++){n=a[h];l=Ext.get(n);if(l){l.setStyle({display:m[h]})}}return j},getLayoutTargetSize:Ext.EmptyFn,layout:function(){var a=this.container,b=a.getLayoutTarget();if(!(this.hasLayout||Ext.isEmpty(this.targetCls))){b.addClass(this.targetCls)}this.onLayout(a,b);a.fireEvent("afterlayout",a,this)},onLayout:function(a,b){this.renderAll(a,b)},isValidParent:function(b,a){return a&&b.getPositionEl().dom.parentNode==(a.dom||a)},renderAll:function(e,g){var b=e.items.items,d
 ,h,a=b.length;for(d=0;d<a;d++){h=b[d];if(h&&(!h.rendered||!this.isValidParent(h,g))){this.renderItem(h,d,g)}}},renderItem:function(d,a,b){if(d){if(!d.rendered){d.render(b,a);this.configureItem(d)}else{if(!this.isValidParent(d,b)){if(Ext.isNumber(a)){a=b.dom.childNodes[a]}b.dom.insertBefore(d.getPositionEl().dom,a||null);d.container=b;this.configureItem(d)}}}},getRenderedItems:function(g){var e=g.getLayoutTarget(),h=g.items.items,a=h.length,d,j,b=[];for(d=0;d<a;d++){if((j=h[d]).rendered&&this.isValidParent(j,e)&&j.shouldLayout!==false){b.push(j)}}return b},configureItem:function(b){if(this.extraCls){var a=b.getPositionEl?b.getPositionEl():b;a.addClass(this.extraCls)}if(b.doLayout&&this.forceLayout){b.doLayout()}if(this.renderHidden&&b!=this.activeItem){b.hide()}},onRemove:function(b){if(this.activeItem==b){delete this.activeItem}if(b.rendered&&this.extraCls){var a=b.getPositionEl?b.getPositionEl():b;a.removeClass(this.extraCls)}},afterRemove:function(a){if(a.removeRestore){a.
 removeMode="container";delete a.removeRestore}},onResize:function(){var c=this.container,a;if(c.collapsed){return}if(a=c.bufferResize&&c.shouldBufferLayout()){if(!this.resizeTask){this.resizeTask=new Ext.util.DelayedTask(this.runLayout,this);this.resizeBuffer=Ext.isNumber(a)?a:50}c.layoutPending=true;this.resizeTask.delay(this.resizeBuffer)}else{this.runLayout()}},runLayout:function(){var a=this.container;this.layout();a.onLayout();delete a.layoutPending},setContainer:function(b){if(this.monitorResize&&b!=this.container){var a=this.container;if(a){a.un(a.resizeEvent,this.onResize,this)}if(b){b.on(b.resizeEvent,this.onResize,this)}}this.container=b},parseMargins:function(b){if(Ext.isNumber(b)){b=b.toString()}var c=b.split(" "),a=c.length;if(a==1){c[1]=c[2]=c[3]=c[0]}else{if(a==2){c[2]=c[0];c[3]=c[1]}else{if(a==3){c[3]=c[1]}}}return{top:parseInt(c[0],10)||0,right:parseInt(c[1],10)||0,bottom:parseInt(c[2],10)||0,left:parseInt(c[3],10)||0}},fieldTpl:(function(){var a=new Ext.Tem
 plate('<div class="x-form-item {itemCls}" tabIndex="-1">','<label for="{id}" style="{labelStyle}" class="x-form-item-label">{label}{labelSeparator}</label>','<div class="x-form-element" id="x-form-el-{id}" style="{elementStyle}">','</div><div class="{clearCls}"></div>',"</div>");a.disableFormats=true;return a.compile()})(),destroy:function(){if(this.resizeTask&&this.resizeTask.cancel){this.resizeTask.cancel()}if(this.container){this.container.un(this.container.resizeEvent,this.onResize,this)}if(!Ext.isEmpty(this.targetCls)){var a=this.container.getLayoutTarget();if(a){a.removeClass(this.targetCls)}}}});Ext.layout.AutoLayout=Ext.extend(Ext.layout.ContainerLayout,{type:"auto",monitorResize:true,onLayout:function(d,g){Ext.layout.AutoLayout.superclass.onLayout.call(this,d,g);var e=this.getRenderedItems(d),a=e.length,b,h;for(b=0;b<a;b++){h=e[b];if(h.doLayout){h.doLayout(true)}}}});Ext.Container.LAYOUTS.auto=Ext.layout.AutoLayout;Ext.layout.FitLayout=Ext.extend(Ext.layout.Containe
 rLayout,{monitorResize:true,type:"fit",getLayoutTargetSize:function(){var a=this.container.getLayoutTarget();if(!a){return{}}return a.getStyleSize()},onLayout:function(a,b){Ext.layout.FitLayout.superclass.onLayout.call(this,a,b);if(!a.collapsed){this.setItemSize(this.activeItem||a.items.itemAt(0),this.getLayoutTargetSize())}},setItemSize:function(b,a){if(b&&a.height>0){b.setSize(a)}}});Ext.Container.LAYOUTS.fit=Ext.layout.FitLayout;Ext.layout.CardLayout=Ext.extend(Ext.layout.FitLayout,{deferredRender:false,layoutOnCardChange:false,renderHidden:true,type:"card",setActiveItem:function(d){var a=this.activeItem,b=this.container;d=b.getComponent(d);if(d&&a!=d){if(a){a.hide();if(a.hidden!==true){return false}a.fireEvent("deactivate",a)}var c=d.doLayout&&(this.layoutOnCardChange||!d.rendered);this.activeItem=d;delete d.deferLayout;d.show();this.layout();if(c){d.doLayout()}d.fireEvent("activate",d)}},renderAll:function(a,b){if(this.deferredRender){this.renderItem(this.activeItem,und
 efined,b)}else{Ext.layout.CardLayout.superclass.renderAll.call(this,a,b)}}});Ext.Container.LAYOUTS.card=Ext.layout.CardLayout;Ext.layout.AnchorLayout=Ext.extend(Ext.layout.ContainerLayout,{monitorResize:true,type:"anchor",defaultAnchor:"100%",parseAnchorRE:/^(r|right|b|bottom)$/i,getLayoutTargetSize:function(){var b=this.container.getLayoutTarget(),a={};if(b){a=b.getViewSize();if(Ext.isIE&&Ext.isStrict&&a.width==0){a=b.getStyleSize()}a.width-=b.getPadding("lr");a.height-=b.getPadding("tb")}return a},onLayout:function(m,w){Ext.layout.AnchorLayout.superclass.onLayout.call(this,m,w);var p=this.getLayoutTargetSize(),k=p.width,o=p.height,q=w.getStyle("overflow"),n=this.getRenderedItems(m),t=n.length,g=[],j,a,v,l,h,c,e,d,u=0,s,b;if(k<20&&o<20){return}if(m.anchorSize){if(typeof m.anchorSize=="number"){a=m.anchorSize}else{a=m.anchorSize.width;v=m.anchorSize.height}}else{a=m.initialConfig.width;v=m.initialConfig.height}for(s=0;s<t;s++){l=n[s];b=l.getPositionEl();if(!l.anchor&&l.items
 &&!Ext.isNumber(l.width)&&!(Ext.isIE6&&Ext.isStrict)){l.anchor=this.defaultAnchor}if(l.anchor){h=l.anchorSpec;if(!h){d=l.anchor.split(" ");l.anchorSpec=h={right:this.parseAnchor(d[0],l.initialConfig.width,a),bottom:this.parseAnchor(d[1],l.initialConfig.height,v)}}c=h.right?this.adjustWidthAnchor(h.right(k)-b.getMargins("lr"),l):undefined;e=h.bottom?this.adjustHeightAnchor(h.bottom(o)-b.getMargins("tb"),l):undefined;if(c||e){g.push({component:l,width:c||undefined,height:e||undefined})}}}for(s=0,t=g.length;s<t;s++){j=g[s];j.component.setSize(j.width,j.height)}if(q&&q!="hidden"&&!this.adjustmentPass){var r=this.getLayoutTargetSize();if(r.width!=p.width||r.height!=p.height){this.adjustmentPass=true;this.onLayout(m,w)}}delete this.adjustmentPass},parseAnchor:function(c,h,b){if(c&&c!="none"){var e;if(this.parseAnchorRE.test(c)){var g=b-h;return function(a){if(a!==e){e=a;return a-g}}}else{if(c.indexOf("%")!=-1){var d=parseFloat(c.replace("%",""))*0.01;return function(a){if(a!==e){e
 =a;return Math.floor(a*d)}}}else{c=parseInt(c,10);if(!isNaN(c)){return function(a){if(a!==e){e=a;return a+c}}}}}}return false},adjustWidthAnchor:function(b,a){return b},adjustHeightAnchor:function(b,a){return b}});Ext.Container.LAYOUTS.anchor=Ext.layout.AnchorLayout;Ext.layout.ColumnLayout=Ext.extend(Ext.layout.ContainerLayout,{monitorResize:true,type:"column",extraCls:"x-column",scrollOffset:0,targetCls:"x-column-layout-ct",isValidParent:function(b,a){return this.innerCt&&b.getPositionEl().dom.parentNode==this.innerCt.dom},getLayoutTargetSize:function(){var b=this.container.getLayoutTarget(),a;if(b){a=b.getViewSize();if(Ext.isIE&&Ext.isStrict&&a.width==0){a=b.getStyleSize()}a.width-=b.getPadding("lr");a.height-=b.getPadding("tb")}return a},renderAll:function(a,b){if(!this.innerCt){this.innerCt=b.createChild({cls:"x-column-inner"});this.innerCt.createChild({cls:"x-clear"})}Ext.layout.ColumnLayout.superclass.renderAll.call(this,a,this.innerCt)},onLayout:function(e,k){var g=e.
 items.items,j=g.length,n,b,a,o=[];this.renderAll(e,k);var r=this.getLayoutTargetSize();if(r.width<1&&r.height<1){return}var p=r.width-this.scrollOffset,d=r.height,q=p;this.innerCt.setWidth(p);for(b=0;b<j;b++){n=g[b];a=n.getPositionEl().getMargins("lr");o[b]=a;if(!n.columnWidth){q-=(n.getWidth()+a)}}q=q<0?0:q;for(b=0;b<j;b++){n=g[b];a=o[b];if(n.columnWidth){n.setSize(Math.floor(n.columnWidth*q)-a)}}if(Ext.isIE){if(b=k.getStyle("overflow")&&b!="hidden"&&!this.adjustmentPass){var l=this.getLayoutTargetSize();if(l.width!=r.width){this.adjustmentPass=true;this.onLayout(e,k)}}}delete this.adjustmentPass}});Ext.Container.LAYOUTS.column=Ext.layout.ColumnLayout;Ext.layout.BorderLayout=Ext.extend(Ext.layout.ContainerLayout,{monitorResize:true,rendered:false,type:"border",targetCls:"x-border-layout-ct",getLayoutTargetSize:function(){var a=this.container.getLayoutTarget();return a?a.getViewSize():{}},onLayout:function(g,I){var j,B,F,o,x=g.items.items,C=x.length;if(!this.rendered){j=[];f
 or(B=0;B<C;B++){F=x[B];o=F.region;if(F.collapsed){j.push(F)}F.collapsed=false;if(!F.rendered){F.render(I,B);F.getPositionEl().addClass("x-border-panel")}this[o]=o!="center"&&F.split?new Ext.layout.BorderLayout.SplitRegion(this,F.initialConfig,o):new Ext.layout.BorderLayout.Region(this,F.initialConfig,o);this[o].render(I,F)}this.rendered=true}var v=this.getLayoutTargetSize();if(v.width<20||v.height<20){if(j){this.restoreCollapsed=j}return}else{if(this.restoreCollapsed){j=this.restoreCollapsed;delete this.restoreCollapsed}}var t=v.width,D=v.height,r=t,A=D,p=0,q=0,y=this.north,u=this.south,l=this.west,E=this.east,F=this.center,H,z,d,G;if(!F&&Ext.layout.BorderLayout.WARN!==false){throw"No center region defined in BorderLayout "+g.id}if(y&&y.isVisible()){H=y.getSize();z=y.getMargins();H.width=t-(z.left+z.right);H.x=z.left;H.y=z.top;p=H.height+H.y+z.bottom;A-=p;y.applyLayout(H)}if(u&&u.isVisible()){H=u.getSize();z=u.getMargins();H.width=t-(z.left+z.right);H.x=z.left;G=(H.height+z.
 top+z.bottom);H.y=D-G+z.top;A-=G;u.applyLayout(H)}if(l&&l.isVisible()){H=l.getSize();z=l.getMargins();H.height=A-(z.top+z.bottom);H.x=z.left;H.y=p+z.top;d=(H.width+z.left+z.right);q+=d;r-=d;l.applyLayout(H)}if(E&&E.isVisible()){H=E.getSize();z=E.getMargins();H.height=A-(z.top+z.bottom);d=(H.width+z.left+z.right);H.x=t-d+z.left;H.y=p+z.top;r-=d;E.applyLayout(H)}if(F){z=F.getMargins();var k={x:q+z.left,y:p+z.top,width:r-(z.left+z.right),height:A-(z.top+z.bottom)};F.applyLayout(k)}if(j){for(B=0,C=j.length;B<C;B++){j[B].collapse(false)}}if(Ext.isIE&&Ext.isStrict){I.repaint()}if(B=I.getStyle("overflow")&&B!="hidden"&&!this.adjustmentPass){var a=this.getLayoutTargetSize();if(a.width!=v.width||a.height!=v.height){this.adjustmentPass=true;this.onLayout(g,I)}}delete this.adjustmentPass},destroy:function(){var b=["north","south","east","west"],a,c;for(a=0;a<b.length;a++){c=this[b[a]];if(c){if(c.destroy){c.destroy()}else{if(c.split){c.split.destroy(true)}}}}Ext.layout.BorderLayout.supe
 rclass.destroy.call(this)}});Ext.layout.BorderLayout.Region=function(b,a,c){Ext.apply(this,a);this.layout=b;this.position=c;this.state={};if(typeof this.margins=="string"){this.margins=this.layout.parseMargins(this.margins)}this.margins=Ext.applyIf(this.margins||{},this.defaultMargins);if(this.collapsible){if(typeof this.cmargins=="string"){this.cmargins=this.layout.parseMargins(this.cmargins)}if(this.collapseMode=="mini"&&!this.cmargins){this.cmargins={left:0,top:0,right:0,bottom:0}}else{this.cmargins=Ext.applyIf(this.cmargins||{},c=="north"||c=="south"?this.defaultNSCMargins:this.defaultEWCMargins)}}};Ext.layout.BorderLayout.Region.prototype={collapsible:false,split:false,floatable:true,minWidth:50,minHeight:50,defaultMargins:{left:0,top:0,right:0,bottom:0},defaultNSCMargins:{left:5,top:5,right:5,bottom:5},defaultEWCMargins:{left:5,top:0,right:5,bottom:0},floatingZIndex:100,isCollapsed:false,render:function(b,c){this.panel=c;c.el.enableDisplayMode();this.targetEl=b;this.el
 =c.el;var a=c.getState,d=this.position;c.getState=function(){return Ext.apply(a.call(c)||{},this.state)}.createDelegate(this);if(d!="center"){c.allowQueuedExpand=false;c.on({beforecollapse:this.beforeCollapse,collapse:this.onCollapse,beforeexpand:this.beforeExpand,expand:this.onExpand,hide:this.onHide,show:this.onShow,scope:this});if(this.collapsible||this.floatable){c.collapseEl="el";c.slideAnchor=this.getSlideAnchor()}if(c.tools&&c.tools.toggle){c.tools.toggle.addClass("x-tool-collapse-"+d);c.tools.toggle.addClassOnOver("x-tool-collapse-"+d+"-over")}}},getCollapsedEl:function(){if(!this.collapsedEl){if(!this.toolTemplate){var b=new Ext.Template('<div class="x-tool x-tool-{id}">&#160;</div>');b.disableFormats=true;b.compile();Ext.layout.BorderLayout.Region.prototype.toolTemplate=b}this.collapsedEl=this.targetEl.createChild({cls:"x-layout-collapsed x-layout-collapsed-"+this.position,id:this.panel.id+"-xcollapsed"});this.collapsedEl.enableDisplayMode("block");if(this.collapse
 Mode=="mini"){this.collapsedEl.addClass("x-layout-cmini-"+this.position);this.miniCollapsedEl=this.collapsedEl.createChild({cls:"x-layout-mini x-layout-mini-"+this.position,html:"&#160;"});this.miniCollapsedEl.addClassOnOver("x-layout-mini-over");this.collapsedEl.addClassOnOver("x-layout-collapsed-over");this.collapsedEl.on("click",this.onExpandClick,this,{stopEvent:true})}else{if(this.collapsible!==false&&!this.hideCollapseTool){var a=this.expandToolEl=this.toolTemplate.append(this.collapsedEl.dom,{id:"expand-"+this.position},true);a.addClassOnOver("x-tool-expand-"+this.position+"-over");a.on("click",this.onExpandClick,this,{stopEvent:true})}if(this.floatable!==false||this.titleCollapse){this.collapsedEl.addClassOnOver("x-layout-collapsed-over");this.collapsedEl.on("click",this[this.floatable?"collapseClick":"onExpandClick"],this)}}}return this.collapsedEl},onExpandClick:function(a){if(this.isSlid){this.panel.expand(false)}else{this.panel.expand()}},onCollapseClick:function
 (a){this.panel.collapse()},beforeCollapse:function(c,a){this.lastAnim=a;if(this.splitEl){this.splitEl.hide()}this.getCollapsedEl().show();var b=this.panel.getEl();this.originalZIndex=b.getStyle("z-index");b.setStyle("z-index",100);this.isCollapsed=true;this.layout.layout()},onCollapse:function(a){this.panel.el.setStyle("z-index",1);if(this.lastAnim===false||this.panel.animCollapse===false){this.getCollapsedEl().dom.style.visibility="visible"}else{this.getCollapsedEl().slideIn(this.panel.slideAnchor,{duration:0.2})}this.state.collapsed=true;this.panel.saveState()},beforeExpand:function(a){if(this.isSlid){this.afterSlideIn()}var b=this.getCollapsedEl();this.el.show();if(this.position=="east"||this.position=="west"){this.panel.setSize(undefined,b.getHeight())}else{this.panel.setSize(b.getWidth(),undefined)}b.hide();b.dom.style.visibility="hidden";this.panel.el.setStyle("z-index",this.floatingZIndex)},onExpand:function(){this.isCollapsed=false;if(this.splitEl){this.splitEl.show(
 )}this.layout.layout();this.panel.el.setStyle("z-index",this.originalZIndex);this.state.collapsed=false;this.panel.saveState()},collapseClick:function(a){if(this.isSlid){a.stopPropagation();this.slideIn()}else{a.stopPropagation();this.slideOut()}},onHide:function(){if(this.isCollapsed){this.getCollapsedEl().hide()}else{if(this.splitEl){this.splitEl.hide()}}},onShow:function(){if(this.isCollapsed){this.getCollapsedEl().show()}else{if(this.splitEl){this.splitEl.show()}}},isVisible:function(){return !this.panel.hidden},getMargins:function(){return this.isCollapsed&&this.cmargins?this.cmargins:this.margins},getSize:function(){return this.isCollapsed?this.getCollapsedEl().getSize():this.panel.getSize()},setPanel:function(a){this.panel=a},getMinWidth:function(){return this.minWidth},getMinHeight:function(){return this.minHeight},applyLayoutCollapsed:function(a){var b=this.getCollapsedEl();b.setLeftTop(a.x,a.y);b.setSize(a.width,a.height)},applyLayout:function(a){if(this.isCollapse
 d){this.applyLayoutCollapsed(a)}else{this.panel.setPosition(a.x,a.y);this.panel.setSize(a.width,a.height)}},beforeSlide:function(){this.panel.beforeEffect()},afterSlide:function(){this.panel.afterEffect()},initAutoHide:function(){if(this.autoHide!==false){if(!this.autoHideHd){this.autoHideSlideTask=new Ext.util.DelayedTask(this.slideIn,this);this.autoHideHd={mouseout:function(a){if(!a.within(this.el,true)){this.autoHideSlideTask.delay(500)}},mouseover:function(a){this.autoHideSlideTask.cancel()},scope:this}}this.el.on(this.autoHideHd);this.collapsedEl.on(this.autoHideHd)}},clearAutoHide:function(){if(this.autoHide!==false){this.el.un("mouseout",this.autoHideHd.mouseout);this.el.un("mouseover",this.autoHideHd.mouseover);this.collapsedEl.un("mouseout",this.autoHideHd.mouseout);this.collapsedEl.un("mouseover",this.autoHideHd.mouseover)}},clearMonitor:function(){Ext.getDoc().un("click",this.slideInIf,this)},slideOut:function(){if(this.isSlid||this.el.hasActiveFx()){return}this.i
 sSlid=true;var b=this.panel.tools,c,a;if(b&&b.toggle){b.toggle.hide()}this.el.show();a=this.panel.collapsed;this.panel.collapsed=false;if(this.position=="east"||this.position=="west"){c=this.panel.deferHeight;this.panel.deferHeight=false;this.panel.setSize(undefined,this.collapsedEl.getHeight());this.panel.deferHeight=c}else{this.panel.setSize(this.collapsedEl.getWidth(),undefined)}this.panel.collapsed=a;this.restoreLT=[this.el.dom.style.left,this.el.dom.style.top];this.el.alignTo(this.collapsedEl,this.getCollapseAnchor());this.el.setStyle("z-index",this.floatingZIndex+2);this.panel.el.replaceClass("x-panel-collapsed","x-panel-floating");if(this.animFloat!==false){this.beforeSlide();this.el.slideIn(this.getSlideAnchor(),{callback:function(){this.afterSlide();this.initAutoHide();Ext.getDoc().on("click",this.slideInIf,this)},scope:this,block:true})}else{this.initAutoHide();Ext.getDoc().on("click",this.slideInIf,this)}},afterSlideIn:function(){this.clearAutoHide();this.isSlid=f
 alse;this.clearMonitor();this.el.setStyle("z-index","");this.panel.el.replaceClass("x-panel-floating","x-panel-collapsed");this.el.dom.style.left=this.restoreLT[0];this.el.dom.style.top=this.restoreLT[1];var a=this.panel.tools;if(a&&a.toggle){a.toggle.show()}},slideIn:function(a){if(!this.isSlid||this.el.hasActiveFx()){Ext.callback(a);return}this.isSlid=false;if(this.animFloat!==false){this.beforeSlide();this.el.slideOut(this.getSlideAnchor(),{callback:function(){this.el.hide();this.afterSlide();this.afterSlideIn();Ext.callback(a)},scope:this,block:true})}else{this.el.hide();this.afterSlideIn()}},slideInIf:function(a){if(!a.within(this.el)){this.slideIn()}},anchors:{west:"left",east:"right",north:"top",south:"bottom"},sanchors:{west:"l",east:"r",north:"t",south:"b"},canchors:{west:"tl-tr",east:"tr-tl",north:"tl-bl",south:"bl-tl"},getAnchor:function(){return this.anchors[this.position]},getCollapseAnchor:function(){return this.canchors[this.position]},getSlideAnchor:function(
 ){return this.sanchors[this.position]},getAlignAdj:function(){var a=this.cmargins;switch(this.position){case"west":return[0,0];break;case"east":return[0,0];break;case"north":return[0,0];break;case"south":return[0,0];break}},getExpandAdj:function(){var b=this.collapsedEl,a=this.cmargins;switch(this.position){case"west":return[-(a.right+b.getWidth()+a.left),0];break;case"east":return[a.right+b.getWidth()+a.left,0];break;case"north":return[0,-(a.top+a.bottom+b.getHeight())];break;case"south":return[0,a.top+a.bottom+b.getHeight()];break}},destroy:function(){if(this.autoHideSlideTask&&this.autoHideSlideTask.cancel){this.autoHideSlideTask.cancel()}Ext.destroyMembers(this,"miniCollapsedEl","collapsedEl","expandToolEl")}};Ext.layout.BorderLayout.SplitRegion=function(b,a,c){Ext.layout.BorderLayout.SplitRegion.superclass.constructor.call(this,b,a,c);this.applyLayout=this.applyFns[c]};Ext.extend(Ext.layout.BorderLayout.SplitRegion,Ext.layout.BorderLayout.Region,{splitTip:"Drag to resiz
 e.",collapsibleSplitTip:"Drag to resize. Double click to hide.",useSplitTips:false,splitSettings:{north:{orientation:Ext.SplitBar.VERTICAL,placement:Ext.SplitBar.TOP,maxFn:"getVMaxSize",minProp:"minHeight",maxProp:"maxHeight"},south:{orientation:Ext.SplitBar.VERTICAL,placement:Ext.SplitBar.BOTTOM,maxFn:"getVMaxSize",minProp:"minHeight",maxProp:"maxHeight"},east:{orientation:Ext.SplitBar.HORIZONTAL,placement:Ext.SplitBar.RIGHT,maxFn:"getHMaxSize",minProp:"minWidth",maxProp:"maxWidth"},west:{orientation:Ext.SplitBar.HORIZONTAL,placement:Ext.SplitBar.LEFT,maxFn:"getHMaxSize",minProp:"minWidth",maxProp:"maxWidth"}},applyFns:{west:function(c){if(this.isCollapsed){return this.applyLayoutCollapsed(c)}var d=this.splitEl.dom,b=d.style;this.panel.setPosition(c.x,c.y);var a=d.offsetWidth;b.left=(c.x+c.width-a)+"px";b.top=(c.y)+"px";b.height=Math.max(0,c.height)+"px";this.panel.setSize(c.width-a,c.height)},east:function(c){if(this.isCollapsed){return this.applyLayoutCollapsed(c)}var d=t
 his.splitEl.dom,b=d.style;var a=d.offsetWidth;this.panel.setPosition(c.x+a,c.y);b.left=(c.x)+"px";b.top=(c.y)+"px";b.height=Math.max(0,c.height)+"px";this.panel.setSize(c.width-a,c.height)},north:function(c){if(this.isCollapsed){return this.applyLayoutCollapsed(c)}var d=this.splitEl.dom,b=d.style;var a=d.offsetHeight;this.panel.setPosition(c.x,c.y);b.left=(c.x)+"px";b.top=(c.y+c.height-a)+"px";b.width=Math.max(0,c.width)+"px";this.panel.setSize(c.width,c.height-a)},south:function(c){if(this.isCollapsed){return this.applyLayoutCollapsed(c)}var d=this.splitEl.dom,b=d.style;var a=d.offsetHeight;this.panel.setPosition(c.x,c.y+a);b.left=(c.x)+"px";b.top=(c.y)+"px";b.width=Math.max(0,c.width)+"px";this.panel.setSize(c.width,c.height-a)}},render:function(a,c){Ext.layout.BorderLayout.SplitRegion.superclass.render.call(this,a,c);var d=this.position;this.splitEl=a.createChild({cls:"x-layout-split x-layout-split-"+d,html:"&#160;",id:this.panel.id+"-xsplit"});if(this.collapseMode=="mini
 "){this.miniSplitEl=this.splitEl.createChild({cls:"x-layout-mini x-layout-mini-"+d,html:"&#160;"});this.miniSplitEl.addClassOnOver("x-layout-mini-over");this.miniSplitEl.on("click",this.onCollapseClick,this,{stopEvent:true})}var b=this.splitSettings[d];this.split=new Ext.SplitBar(this.splitEl.dom,c.el,b.orientation);this.split.tickSize=this.tickSize;this.split.placement=b.placement;this.split.getMaximumSize=this[b.maxFn].createDelegate(this);this.split.minSize=this.minSize||this[b.minProp];this.split.on("beforeapply",this.onSplitMove,this);this.split.useShim=this.useShim===true;this.maxSize=this.maxSize||this[b.maxProp];if(c.hidden){this.splitEl.hide()}if(this.useSplitTips){this.splitEl.dom.title=this.collapsible?this.collapsibleSplitTip:this.splitTip}if(this.collapsible){this.splitEl.on("dblclick",this.onCollapseClick,this)}},getSize:function(){if(this.isCollapsed){return this.collapsedEl.getSize()}var a=this.panel.getSize();if(this.position=="north"||this.position=="south"
 ){a.height+=this.splitEl.dom.offsetHeight}else{a.width+=this.splitEl.dom.offsetWidth}return a},getHMaxSize:function(){var b=this.maxSize||10000;var a=this.layout.center;return Math.min(b,(this.el.getWidth()+a.el.getWidth())-a.getMinWidth())},getVMaxSize:function(){var b=this.maxSize||10000;var a=this.layout.center;return Math.min(b,(this.el.getHeight()+a.el.getHeight())-a.getMinHeight())},onSplitMove:function(b,a){var c=this.panel.getSize();this.lastSplitSize=a;if(this.position=="north"||this.position=="south"){this.panel.setSize(c.width,a);this.state.height=a}else{this.panel.setSize(a,c.height);this.state.width=a}this.layout.layout();this.panel.saveState();return false},getSplitBar:function(){return this.split},destroy:function(){Ext.destroy(this.miniSplitEl,this.split,this.splitEl);Ext.layout.BorderLayout.SplitRegion.superclass.destroy.call(this)}});Ext.Container.LAYOUTS.border=Ext.layout.BorderLayout;Ext.layout.FormLayout=Ext.extend(Ext.layout.AnchorLayout,{labelSeparator
 :":",trackLabels:true,type:"form",onRemove:function(d){Ext.layout.FormLayout.superclass.onRemove.call(this,d);if(this.trackLabels){d.un("show",this.onFieldShow,this);d.un("hide",this.onFieldHide,this)}var b=d.getPositionEl(),a=d.getItemCt&&d.getItemCt();if(d.rendered&&a){if(b&&b.dom){b.insertAfter(a)}Ext.destroy(a);Ext.destroyMembers(d,"label","itemCt");if(d.customItemCt){Ext.destroyMembers(d,"getItemCt","customItemCt")}}},setContainer:function(a){Ext.layout.FormLayout.superclass.setContainer.call(this,a);if(a.labelAlign){a.addClass("x-form-label-"+a.labelAlign)}if(a.hideLabels){Ext.apply(this,{labelStyle:"display:none",elementStyle:"padding-left:0;",labelAdjust:0})}else{this.labelSeparator=Ext.isDefined(a.labelSeparator)?a.labelSeparator:this.labelSeparator;a.labelWidth=a.labelWidth||100;if(Ext.isNumber(a.labelWidth)){var b=Ext.isNumber(a.labelPad)?a.labelPad:5;Ext.apply(this,{labelAdjust:a.labelWidth+b,labelStyle:"width:"+a.labelWidth+"px;",elementStyle:"padding-left:"+(a.
 labelWidth+b)+"px"})}if(a.labelAlign=="top"){Ext.apply(this,{labelStyle:"width:auto;",labelAdjust:0,elementStyle:"padding-left:0;"})}}},isHide:function(a){return a.hideLabel||this.container.hideLabels},onFieldShow:function(a){a.getItemCt().removeClass("x-hide-"+a.hideMode);if(a.isComposite){a.doLayout()}},onFieldHide:function(a){a.getItemCt().addClass("x-hide-"+a.hideMode)},getLabelStyle:function(e){var b="",c=[this.labelStyle,e];for(var d=0,a=c.length;d<a;++d){if(c[d]){b+=c[d];if(b.substr(-1,1)!=";"){b+=";"}}}return b},renderItem:function(e,a,d){if(e&&(e.isFormField||e.fieldLabel)&&e.inputType!="hidden"){var b=this.getTemplateArgs(e);if(Ext.isNumber(a)){a=d.dom.childNodes[a]||null}if(a){e.itemCt=this.fieldTpl.insertBefore(a,b,true)}else{e.itemCt=this.fieldTpl.append(d,b,true)}if(!e.getItemCt){Ext.apply(e,{getItemCt:function(){return e.itemCt},customItemCt:true})}e.label=e.getItemCt().child("label.x-form-item-label");if(!e.rendered){e.render("x-form-el-"+e.id)}else{if(!this.
 isValidParent(e,d)){Ext.fly("x-form-el-"+e.id).appendChild(e.getPositionEl())}}if(this.trackLabels){if(e.hidden){this.onFieldHide(e)}e.on({scope:this,show:this.onFieldShow,hide:this.onFieldHide})}this.configureItem(e)}else{Ext.layout.FormLayout.superclass.renderItem.apply(this,arguments)}},getTemplateArgs:function(c){var a=!c.fieldLabel||c.hideLabel,b=(c.itemCls||this.container.itemCls||"")+(c.hideLabel?" x-hide-label":"");if(Ext.isIE9&&Ext.isIEQuirks&&c instanceof Ext.form.TextField){b+=" x-input-wrapper"}return{id:c.id,label:c.fieldLabel,itemCls:b,clearCls:c.clearCls||"x-form-clear-left",labelStyle:this.getLabelStyle(c.labelStyle),elementStyle:this.elementStyle||"",labelSeparator:a?"":(Ext.isDefined(c.labelSeparator)?c.labelSeparator:this.labelSeparator)}},adjustWidthAnchor:function(a,d){if(d.label&&!this.isHide(d)&&(this.container.labelAlign!="top")){var b=Ext.isIE6||(Ext.isIE&&!Ext.isStrict);return a-this.labelAdjust+(b?-3:0)}return a},adjustHeightAnchor:function(a,b){if
 (b.label&&!this.isHide(b)&&(this.container.labelAlign=="top")){return a-b.label.getHeight()}return a},isValidParent:function(b,a){return a&&this.container.getEl().contains(b.getPositionEl())}});Ext.Container.LAYOUTS.form=Ext.layout.FormLayout;Ext.layout.AccordionLayout=Ext.extend(Ext.layout.FitLayout,{fill:true,autoWidth:true,titleCollapse:true,hideCollapseTool:false,collapseFirst:false,animate:false,sequence:false,activeOnTop:false,type:"accordion",renderItem:function(a){if(this.animate===false){a.animCollapse=false}a.collapsible=true;if(this.autoWidth){a.autoWidth=true}if(this.titleCollapse){a.titleCollapse=true}if(this.hideCollapseTool){a.hideCollapseTool=true}if(this.collapseFirst!==undefined){a.collapseFirst=this.collapseFirst}if(!this.activeItem&&!a.collapsed){this.setActiveItem(a,true)}else{if(this.activeItem&&this.activeItem!=a){a.collapsed=true}}Ext.layout.AccordionLayout.superclass.renderItem.apply(this,arguments);a.header.addClass("x-accordion-hd");a.on("beforeexp
 and",this.beforeExpand,this)},onRemove:function(a){Ext.layout.AccordionLayout.superclass.onRemove.call(this,a);if(a.rendered){a.header.removeClass("x-accordion-hd")}a.un("beforeexpand",this.beforeExpand,this)},beforeExpand:function(c,b){var a=this.activeItem;if(a){if(this.sequence){delete this.activeItem;if(!a.collapsed){a.collapse({callback:function(){c.expand(b||true)},scope:this});return false}}else{a.collapse(this.animate)}}this.setActive(c);if(this.activeOnTop){c.el.dom.parentNode.insertBefore(c.el.dom,c.el.dom.parentNode.firstChild)}this.layout()},setItemSize:function(g,e){if(this.fill&&g){var d=0,c,b=this.getRenderedItems(this.container),a=b.length,h;for(c=0;c<a;c++){if((h=b[c])!=g&&!h.hidden){d+=h.header.getHeight()}}e.height-=d;g.setSize(e)}},setActiveItem:function(a){this.setActive(a,true)},setActive:function(c,b){var a=this.activeItem;c=this.container.getComponent(c);if(a!=c){if(c.rendered&&c.collapsed&&b){c.expand()}else{if(a){a.fireEvent("deactivate",a)}this.act
 iveItem=c;c.fireEvent("activate",c)}}}});Ext.Container.LAYOUTS.accordion=Ext.layout.AccordionLayout;Ext.layout.Accordion=Ext.layout.AccordionLayout;Ext.layout.TableLayout=Ext.extend(Ext.layout.ContainerLayout,{monitorResize:false,type:"table",targetCls:"x-table-layout-ct",tableAttrs:null,setContainer:function(a){Ext.layout.TableLayout.superclass.setContainer.call(this,a);this.currentRow=0;this.currentColumn=0;this.cells=[]},onLayout:function(d,g){var e=d.items.items,a=e.length,h,b;if(!this.table){g.addClass("x-table-layout-ct");this.table=g.createChild(Ext.apply({tag:"table",cls:"x-table-layout",cellspacing:0,cn:{tag:"tbody"}},this.tableAttrs),null,true)}this.renderAll(d,g)},getRow:function(a){var b=this.table.tBodies[0].childNodes[a];if(!b){b=document.createElement("tr");this.table.tBodies[0].appendChild(b)}return b},getNextCell:function(j){var a=this.getNextNonSpan(this.currentColumn,this.currentRow);var g=this.currentColumn=a[0],e=this.currentRow=a[1];for(var i=e;i<e+(j.r
 owspan||1);i++){if(!this.cells[i]){this.cells[i]=[]}for(var d=g;d<g+(j.colspan||1);d++){this.cells[i][d]=true}}var h=document.createElement("td");if(j.cellId){h.id=j.cellId}var b="x-table-layout-cell";if(j.cellCls){b+=" "+j.cellCls}h.className=b;if(j.colspan){h.colSpan=j.colspan}if(j.rowspan){h.rowSpan=j.rowspan}this.getRow(e).appendChild(h);return h},getNextNonSpan:function(a,c){var b=this.columns;while((b&&a>=b)||(this.cells[c]&&this.cells[c][a])){if(b&&a>=b){c++;a=0}else{a++}}return[a,c]},renderItem:function(e,a,d){if(!this.table){this.table=d.createChild(Ext.apply({tag:"table",cls:"x-table-layout",cellspacing:0,cn:{tag:"tbody"}},this.tableAttrs),null,true)}if(e&&!e.rendered){e.render(this.getNextCell(e));this.configureItem(e)}else{if(e&&!this.isValidParent(e,d)){var b=this.getNextCell(e);b.insertBefore(e.getPositionEl().dom,null);e.container=Ext.get(b);this.configureItem(e)}}},isValidParent:function(b,a){return b.getPositionEl().up("table",5).dom.parentNode===(a.dom||a)}
 ,destroy:function(){delete this.table;Ext.layout.TableLayout.superclass.destroy.call(this)}});Ext.Container.LAYOUTS.table=Ext.layout.TableLayout;Ext.layout.AbsoluteLayout=Ext.extend(Ext.layout.AnchorLayout,{extraCls:"x-abs-layout-item",type:"absolute",onLayout:function(a,b){b.position();this.paddingLeft=b.getPadding("l");this.paddingTop=b.getPadding("t");Ext.layout.AbsoluteLayout.superclass.onLayout.call(this,a,b)},adjustWidthAnchor:function(b,a){return b?b-a.getPosition(true)[0]+this.paddingLeft:b},adjustHeightAnchor:function(b,a){return b?b-a.getPosition(true)[1]+this.paddingTop:b}});Ext.Container.LAYOUTS.absolute=Ext.layout.AbsoluteLayout;Ext.layout.BoxLayout=Ext.extend(Ext.layout.ContainerLayout,{defaultMargins:{left:0,top:0,right:0,bottom:0},padding:"0",pack:"start",monitorResize:true,type:"box",scrollOffset:0,extraCls:"x-box-item",targetCls:"x-box-layout-ct",innerCls:"x-box-inner",constructor:function(a){Ext.layout.BoxLayout.superclass.constructor.call(this,a);if(Ext.i
 sString(this.defaultMargins)){this.defaultMargins=this.parseMargins(this.defaultMargins)}var d=this.overflowHandler;if(typeof d=="string"){d={type:d}}var c="none";if(d&&d.type!=undefined){c=d.type}var b=Ext.layout.boxOverflow[c];if(b[this.type]){b=b[this.type]}this.overflowHandler=new b(this,d)},onLayout:function(b,h){Ext.layout.BoxLayout.superclass.onLayout.call(this,b,h);var d=this.getLayoutTargetSize(),i=this.getVisibleItems(b),c=this.calculateChildBoxes(i,d),g=c.boxes,j=c.meta;if(d.width>0){var k=this.overflowHandler,a=j.tooNarrow?"handleOverflow":"clearOverflow";var e=k[a](c,d);if(e){if(e.targetSize){d=e.targetSize}if(e.recalculate){i=this.getVisibleItems(b);c=this.calculateChildBoxes(i,d);g=c.boxes}}}this.layoutTargetLastSize=d;this.childBoxCache=c;this.updateInnerCtSize(d,c);this.updateChildBoxes(g);this.handleTargetOverflow(d,b,h)},updateChildBoxes:function(c){for(var b=0,e=c.length;b<e;b++){var d=c[b],a=d.component;if(d.dirtySize){a.setSize(d.width,d.height)}if(isNa
 N(d.left)||isNaN(d.top)){continue}a.setPosition(d.left,d.top)}},updateInnerCtSize:function(c,h){var i=this.align,g=this.padding,e=c.width,a=c.height;if(this.type=="hbox"){var b=e,d=h.meta.maxHeight+g.top+g.bottom;if(i=="stretch"){d=a}else{if(i=="middle"){d=Math.max(a,d)}}}else{var d=a,b=h.meta.maxWidth+g.left+g.right;if(i=="stretch"){b=e}else{if(i=="center"){b=Math.max(e,b)}}}this.innerCt.setSize(b||undefined,d||undefined)},handleTargetOverflow:function(d,a,c){var e=c.getStyle("overflow");if(e&&e!="hidden"&&!this.adjustmentPass){var b=this.getLayoutTargetSize();if(b.width!=d.width||b.height!=d.height){this.adjustmentPass=true;this.onLayout(a,c)}}delete this.adjustmentPass},isValidParent:function(b,a){return this.innerCt&&b.getPositionEl().dom.parentNode==this.innerCt.dom},getVisibleItems:function(g){var g=g||this.container,e=g.getLayoutTarget(),h=g.items.items,a=h.length,d,j,b=[];for(d=0;d<a;d++){if((j=h[d]).rendered&&this.isValidParent(j,e)&&j.hidden!==true&&j.collapsed!==t
 rue&&j.shouldLayout!==false){b.push(j)}}return b},renderAll:function(a,b){if(!this.innerCt){this.innerCt=b.createChild({cls:this.innerCls});this.padding=this.parseMargins(this.padding)}Ext.layout.BoxLayout.superclass.renderAll.call(this,a,this.innerCt)},getLayoutTargetSize:function(){var b=this.container.getLayoutTarget(),a;if(b){a=b.getViewSize();if(Ext.isIE&&Ext.isStrict&&a.width==0){a=b.getStyleSize()}a.width-=b.getPadding("lr");a.height-=b.getPadding("tb")}return a},renderItem:function(a){if(Ext.isString(a.margins)){a.margins=this.parseMargins(a.margins)}else{if(!a.margins){a.margins=this.defaultMargins}}Ext.layout.BoxLayout.superclass.renderItem.apply(this,arguments)},destroy:function(){Ext.destroy(this.overflowHandler);Ext.layout.BoxLayout.superclass.destroy.apply(this,arguments)}});Ext.layout.boxOverflow.None=Ext.extend(Object,{constructor:function(b,a){this.layout=b;Ext.apply(this,a||{})},handleOverflow:Ext.emptyFn,clearOverflow:Ext.emptyFn});Ext.layout.boxOverflow.n
 one=Ext.layout.boxOverflow.None;Ext.layout.boxOverflow.Menu=Ext.extend(Ext.layout.boxOverflow.None,{afterCls:"x-strip-right",noItemsMenuText:'<div class="x-toolbar-no-items">(None)</div>',constructor:function(a){Ext.layout.boxOverflow.Menu.superclass.constructor.apply(this,arguments);this.menuItems=[]},createInnerElements:function(){if(!this.afterCt){this.afterCt=this.layout.innerCt.insertSibling({cls:this.afterCls},"before")}},clearOverflow:function(a,g){var e=g.width+(this.afterCt?this.afterCt.getWidth():0),b=this.menuItems;this.hideTrigger();for(var c=0,d=b.length;c<d;c++){b.pop().component.show()}return{targetSize:{height:g.height,width:e}}},showTrigger:function(){this.createMenu();this.menuTrigger.show()},hideTrigger:function(){if(this.menuTrigger!=undefined){this.menuTrigger.hide()}},beforeMenuShow:function(h){var b=this.menuItems,a=b.length,g,e;var c=function(j,i){return j.isXType("buttongroup")&&!(i instanceof Ext.Toolbar.Separator)};this.clearMenu();h.removeAll();fo
 r(var d=0;d<a;d++){g=b[d].component;if(e&&(c(g,e)||c(e,g))){h.add("-")}this.addComponentToMenu(h,g);e=g}if(h.items.length<1){h.add(this.noItemsMenuText)}},createMenuConfig:function(c,a){var b=Ext.apply({},c.initialConfig),d=c.toggleGroup;Ext.copyTo(b,c,["iconCls","icon","itemId","disabled","handler","scope","menu"]);Ext.apply(b,{text:c.overflowText||c.text,hideOnClick:a});if(d||c.enableToggle){Ext.apply(b,{group:d,checked:c.pressed,listeners:{checkchange:function(g,e){c.toggle(e)}}})}delete b.ownerCt;delete b.xtype;delete b.id;return b},addComponentToMenu:function(b,a){if(a instanceof Ext.Toolbar.Separator){b.add("-")}else{if(Ext.isFunction(a.isXType)){if(a.isXType("splitbutton")){b.add(this.createMenuConfig(a,true))}else{if(a.isXType("button")){b.add(this.createMenuConfig(a,!a.menu))}else{if(a.isXType("buttongroup")){a.items.each(function(c){this.addComponentToMenu(b,c)},this)}}}}}},clearMenu:function(){var a=this.moreMenu;if(a&&a.items){a.items.each(function(b){delete b.me
 nu})}},createMenu:function(){if(!this.menuTrigger){this.createInnerElements();this.menu=new Ext.menu.Menu({ownerCt:this.layout.container,listeners:{scope:this,beforeshow:this.beforeMenuShow}});this.menuTrigger=new Ext.Button({iconCls:"x-toolbar-more-icon",cls:"x-toolbar-more",menu:this.menu,renderTo:this.afterCt})}},destroy:function(){Ext.destroy(this.menu,this.menuTrigger)}});Ext.layout.boxOverflow.menu=Ext.layout.boxOverflow.Menu;Ext.layout.boxOverflow.HorizontalMenu=Ext.extend(Ext.layout.boxOverflow.Menu,{constructor:function(){Ext.layout.boxOverflow.HorizontalMenu.superclass.constructor.apply(this,arguments);var c=this,b=c.layout,a=b.calculateChildBoxes;b.calculateChildBoxes=function(d,i){var l=a.apply(b,arguments),k=l.meta,e=c.menuItems;var j=0;for(var g=0,h=e.length;g<h;g++){j+=e[g].width}k.minimumWidth+=j;k.tooNarrow=k.minimumWidth>i.width;return l}},handleOverflow:function(d,h){this.showTrigger();var k=h.width-this.afterCt.getWidth(),l=d.boxes,e=0,r=false;for(var o=0
 ,c=l.length;o<c;o++){e+=l[o].width}var a=k-e,g=0;for(var o=0,c=this.menuItems.length;o<c;o++){var n=this.menuItems[o],m=n.component,b=n.width;if(b<a){m.show();a-=b;g++;r=true}else{break}}if(r){this.menuItems=this.menuItems.slice(g)}else{for(var j=l.length-1;j>=0;j--){var q=l[j].component,p=l[j].left+l[j].width;if(p>=k){this.menuItems.unshift({component:q,width:l[j].width});q.hide()}else{break}}}if(this.menuItems.length==0){this.hideTrigger()}return{targetSize:{height:h.height,width:k},recalculate:r}}});Ext.layout.boxOverflow.menu.hbox=Ext.layout.boxOverflow.HorizontalMenu;Ext.layout.boxOverflow.Scroller=Ext.extend(Ext.layout.boxOverflow.None,{animateScroll:true,scrollIncrement:100,wheelIncrement:3,scrollRepeatInterval:400,scrollDuration:0.4,beforeCls:"x-strip-left",afterCls:"x-strip-right",scrollerCls:"x-strip-scroller",beforeScrollerCls:"x-strip-scroller-left",afterScrollerCls:"x-strip-scroller-right",createWheelListener:function(){this.layout.innerCt.on({scope:this,mousewh
 eel:function(a){a.stopEvent();this.scrollBy(a.getWheelDelta()*this.wheelIncrement*-1,false)}})},handleOverflow:function(a,b){this.createInnerElements();this.showScrollers()},clearOverflow:function(){this.hideScrollers()},showScrollers:function(){this.createScrollers();this.beforeScroller.show();this.afterScroller.show();this.updateScrollButtons()},hideScrollers:function(){if(this.beforeScroller!=undefined){this.beforeScroller.hide();this.afterScroller.hide()}},createScrollers:function(){if(!this.beforeScroller&&!this.afterScroller){var a=this.beforeCt.createChild({cls:String.format("{0} {1} ",this.scrollerCls,this.beforeScrollerCls)});var b=this.afterCt.createChild({cls:String.format("{0} {1}",this.scrollerCls,this.afterScrollerCls)});a.addClassOnOver(this.beforeScrollerCls+"-hover");b.addClassOnOver(this.afterScrollerCls+"-hover");a.setVisibilityMode(Ext.Element.DISPLAY);b.setVisibilityMode(Ext.Element.DISPLAY);this.beforeRepeater=new Ext.util.ClickRepeater(a,{interval:this
 .scrollRepeatInterval,handler:this.scrollLeft,scope:this});this.afterRepeater=new Ext.util.ClickRepeater(b,{interval:this.scrollRepeatInterval,handler:this.scrollRight,scope:this});this.beforeScroller=a;this.afterScroller=b}},destroy:function(){Ext.destroy(this.beforeScroller,this.afterScroller,this.beforeRepeater,this.afterRepeater,this.beforeCt,this.afterCt)},scrollBy:function(b,a){this.scrollTo(this.getScrollPosition()+b,a)},getItem:function(a){if(Ext.isString(a)){a=Ext.getCmp(a)}else{if(Ext.isNumber(a)){a=this.items[a]}}return a},getScrollAnim:function(){return{duration:this.scrollDuration,callback:this.updateScrollButtons,scope:this}},updateScrollButtons:function(){if(this.beforeScroller==undefined||this.afterScroller==undefined){return}var d=this.atExtremeBefore()?"addClass":"removeClass",c=this.atExtremeAfter()?"addClass":"removeClass",a=this.beforeScrollerCls+"-disabled",b=this.afterScrollerCls+"-disabled";this.beforeScroller[d](a);this.afterScroller[c](b);this.scrol
 ling=false},atExtremeBefore:function(){return this.getScrollPosition()===0},scrollLeft:function(a){this.scrollBy(-this.scrollIncrement,a)},scrollRight:function(a){this.scrollBy(this.scrollIncrement,a)},scrollToItem:function(d,b){d=this.getItem(d);if(d!=undefined){var a=this.getItemVisibility(d);if(!a.fullyVisible){var c=d.getBox(true,true),e=c.x;if(a.hiddenRight){e-=(this.layout.innerCt.getWidth()-c.width)}this.scrollTo(e,b)}}},getItemVisibility:function(e){var d=this.getItem(e).getBox(true,true),a=d.x,c=d.x+d.width,g=this.getScrollPosition(),b=this.layout.innerCt.getWidth()+g;return{hiddenLeft:a<g,hiddenRight:c>b,fullyVisible:a>g&&c<b}}});Ext.layout.boxOverflow.scroller=Ext.layout.boxOverflow.Scroller;Ext.layout.boxOverflow.VerticalScroller=Ext.extend(Ext.layout.boxOverflow.Scroller,{scrollIncrement:75,wheelIncrement:2,handleOverflow:function(a,b){Ext.layout.boxOverflow.VerticalScroller.superclass.handleOverflow.apply(this,arguments);return{targetSize:{height:b.height-(this
 .beforeCt.getHeight()+this.afterCt.getHeight()),width:b.width}}},createInnerElements:function(){var a=this.layout.innerCt;if(!this.beforeCt){this.beforeCt=a.insertSibling({cls:this.beforeCls},"before");this.afterCt=a.insertSibling({cls:this.afterCls},"after");this.createWheelListener()}},scrollTo:function(a,b){var d=this.getScrollPosition(),c=a.constrain(0,this.getMaxScrollBottom());if(c!=d&&!this.scrolling){if(b==undefined){b=this.animateScroll}this.layout.innerCt.scrollTo("top",c,b?this.getScrollAnim():false);if(b){this.scrolling=true}else{this.scrolling=false;this.updateScrollButtons()}}},getScrollPosition:function(){return parseInt(this.layout.innerCt.dom.scrollTop,10)||0},getMaxScrollBottom:function(){return this.layout.innerCt.dom.scrollHeight-this.layout.innerCt.getHeight()},atExtremeAfter:function(){return this.getScrollPosition()>=this.getMaxScrollBottom()}});Ext.layout.boxOverflow.scroller.vbox=Ext.layout.boxOverflow.VerticalScroller;Ext.layout.boxOverflow.Horizont
 alScroller=Ext.extend(Ext.layout.boxOverflow.Scroller,{handleOverflow:function(a,b){Ext.layout.boxOverflow.HorizontalScroller.superclass.handleOverflow.apply(this,arguments);return{targetSize:{height:b.height,width:b.width-(this.beforeCt.getWidth()+this.afterCt.getWidth())}}},createInnerElements:function(){var a=this.layout.innerCt;if(!this.beforeCt){this.afterCt=a.insertSibling({cls:this.afterCls},"before");this.beforeCt=a.insertSibling({cls:this.beforeCls},"before");this.createWheelListener()}},scrollTo:function(a,b){var d=this.getScrollPosition(),c=a.constrain(0,this.getMaxScrollRight());if(c!=d&&!this.scrolling){if(b==undefined){b=this.animateScroll}this.layout.innerCt.scrollTo("left",c,b?this.getScrollAnim():false);if(b){this.scrolling=true}else{this.scrolling=false;this.updateScrollButtons()}}},getScrollPosition:function(){return parseInt(this.layout.innerCt.dom.scrollLeft,10)||0},getMaxScrollRight:function(){return this.layout.innerCt.dom.scrollWidth-this.layout.inner
 Ct.getWidth()},atExtremeAfter:function(){return this.getScrollPosition()>=this.getMaxScrollRight()}});Ext.layout.boxOverflow.scroller.hbox=Ext.layout.boxOverflow.HorizontalScroller;Ext.layout.HBoxLayout=Ext.extend(Ext.layout.BoxLayout,{align:"top",type:"hbox",calculateChildBoxes:function(r,b){var F=r.length,R=this.padding,D=R.top,U=R.left,y=D+R.bottom,O=U+R.right,a=b.width-this.scrollOffset,e=b.height,o=Math.max(0,e-y),P=this.pack=="start",W=this.pack=="center",A=this.pack=="end",L=0,Q=0,T=0,l=0,X=0,H=[],k,J,M,V,w,j,S,I,c,x,q,N;for(S=0;S<F;S++){k=r[S];M=k.height;J=k.width;j=!k.hasLayout&&typeof k.doLayout=="function";if(typeof J!="number"){if(k.flex&&!J){T+=k.flex}else{if(!J&&j){k.doLayout()}V=k.getSize();J=V.width;M=V.height}}w=k.margins;x=w.left+w.right;L+=x+(J||0);l+=x+(k.flex?k.minWidth||0:J);X+=x+(k.minWidth||J||0);if(typeof M!="number"){if(j){k.doLayout()}M=k.getHeight()}Q=Math.max(Q,M+w.top+w.bottom);H.push({component:k,height:M||undefined,width:J||undefined})}var K=l
 -a,p=X>a;var n=Math.max(0,a-L-O);if(p){for(S=0;S<F;S++){H[S].width=r[S].minWidth||r[S].width||H[S].width}}else{if(K>0){var C=[];for(var E=0,v=F;E<v;E++){var B=r[E],t=B.minWidth||0;if(B.flex){H[E].width=t}else{C.push({minWidth:t,available:H[E].width-t,index:E})}}C.sort(function(Y,i){return Y.available>i.available?1:-1});for(var S=0,v=C.length;S<v;S++){var G=C[S].index;if(G==undefined){continue}var B=r[G],m=H[G],u=m.width,t=B.minWidth,d=Math.max(t,u-Math.ceil(K/(v-S))),g=u-d;H[G].width=d;K-=g}}else{var h=n,s=T;for(S=0;S<F;S++){k=r[S];I=H[S];w=k.margins;q=w.top+w.bottom;if(P&&k.flex&&!k.width){c=Math.ceil((k.flex/s)*h);h-=c;s-=k.flex;I.width=c;I.dirtySize=true}}}}if(W){U+=n/2}else{if(A){U+=n}}for(S=0;S<F;S++){k=r[S];I=H[S];w=k.margins;U+=w.left;q=w.top+w.bottom;I.left=U;I.top=D+w.top;switch(this.align){case"stretch":N=o-q;I.height=N.constrain(k.minHeight||0,k.maxHeight||1000000);I.dirtySize=true;break;case"stretchmax":N=Q-q;I.height=N.constrain(k.minHeight||0,k.maxHeight||10000
 00);I.dirtySize=true;break;case"middle":var z=o-I.height-q;if(z>0){I.top=D+q+(z/2)}}U+=I.width+w.right}return{boxes:H,meta:{maxHeight:Q,nonFlexWidth:L,desiredWidth:l,minimumWidth:X,shortfall:l-a,tooNarrow:p}}}});Ext.Container.LAYOUTS.hbox=Ext.layout.HBoxLayout;Ext.layout.VBoxLayout=Ext.extend(Ext.layout.BoxLayout,{align:"left",type:"vbox",calculateChildBoxes:function(o,b){var E=o.length,R=this.padding,C=R.top,V=R.left,x=C+R.bottom,O=V+R.right,a=b.width-this.scrollOffset,c=b.height,K=Math.max(0,a-O),P=this.pack=="start",X=this.pack=="center",z=this.pack=="end",k=0,u=0,U=0,L=0,m=0,G=[],h,I,N,W,t,g,T,H,S,w,n,d,r;for(T=0;T<E;T++){h=o[T];N=h.height;I=h.width;g=!h.hasLayout&&typeof h.doLayout=="function";if(typeof N!="number"){if(h.flex&&!N){U+=h.flex}else{if(!N&&g){h.doLayout()}W=h.getSize();I=W.width;N=W.height}}t=h.margins;n=t.top+t.bottom;k+=n+(N||0);L+=n+(h.flex?h.minHeight||0:N);m+=n+(h.minHeight||N||0);if(typeof I!="number"){if(g){h.doLayout()}I=h.getWidth()}u=Math.max(u,I+
 t.left+t.right);G.push({component:h,height:N||undefined,width:I||undefined})}var M=L-c,l=m>c;var q=Math.max(0,(c-k-x));if(l){for(T=0,r=E;T<r;T++){G[T].height=o[T].minHeight||o[T].height||G[T].height}}else{if(M>0){var J=[];for(var D=0,r=E;D<r;D++){var A=o[D],s=A.minHeight||0;if(A.flex){G[D].height=s}else{J.push({minHeight:s,available:G[D].height-s,index:D})}}J.sort(function(Y,i){return Y.available>i.available?1:-1});for(var T=0,r=J.length;T<r;T++){var F=J[T].index;if(F==undefined){continue}var A=o[F],j=G[F],v=j.height,s=A.minHeight,B=Math.max(s,v-Math.ceil(M/(r-T))),e=v-B;G[F].height=B;M-=e}}else{var Q=q,p=U;for(T=0;T<E;T++){h=o[T];H=G[T];t=h.margins;w=t.left+t.right;if(P&&h.flex&&!h.height){S=Math.ceil((h.flex/p)*Q);Q-=S;p-=h.flex;H.height=S;H.dirtySize=true}}}}if(X){C+=q/2}else{if(z){C+=q}}for(T=0;T<E;T++){h=o[T];H=G[T];t=h.margins;C+=t.top;w=t.left+t.right;H.left=V+t.left;H.top=C;switch(this.align){case"stretch":d=K-w;H.width=d.constrain(h.minWidth||0,h.maxWidth||1000000);
 H.dirtySize=true;break;case"stretchmax":d=u-w;H.width=d.constrain(h.minWidth||0,h.maxWidth||1000000);H.dirtySize=true;break;case"center":var y=K-H.width-w;if(y>0){H.left=V+w+(y/2)}}C+=H.height+t.bottom}return{boxes:G,meta:{maxWidth:u,nonFlexHeight:k,desiredHeight:L,minimumHeight:m,shortfall:L-c,tooNarrow:l}}}});Ext.Container.LAYOUTS.vbox=Ext.layout.VBoxLayout;Ext.layout.ToolbarLayout=Ext.extend(Ext.layout.ContainerLayout,{monitorResize:true,type:"toolbar",triggerWidth:18,noItemsMenuText:'<div class="x-toolbar-no-items">(None)</div>',lastOverflow:false,tableHTML:['<table cellspacing="0" class="x-toolbar-ct">',"<tbody>","<tr>",'<td class="x-toolbar-left" align="{0}">','<table cellspacing="0">',"<tbody>",'<tr class="x-toolbar-left-row"></tr>',"</tbody>","</table>","</td>",'<td class="x-toolbar-right" align="right">','<table cellspacing="0" class="x-toolbar-right-ct">',"<tbody>","<tr>","<td>",'<table cellspacing="0">',"<tbody>",'<tr class="x-toolbar-right-row"></tr>',"</tbody>",
 "</table>","</td>","<td>",'<table cellspacing="0">',"<tbody>",'<tr class="x-toolbar-extras-row"></tr>',"</tbody>","</table>","</td>","</tr>","</tbody>","</table>","</td>","</tr>","</tbody>","</table>"].join(""),onLayout:function(e,j){if(!this.leftTr){var h=e.buttonAlign=="center"?"center":"left";j.addClass("x-toolbar-layout-ct");j.insertHtml("beforeEnd",String.format(this.tableHTML,h));this.leftTr=j.child("tr.x-toolbar-left-row",true);this.rightTr=j.child("tr.x-toolbar-right-row",true);this.extrasTr=j.child("tr.x-toolbar-extras-row",true);if(this.hiddenItem==undefined){this.hiddenItems=[]}}var k=e.buttonAlign=="right"?this.rightTr:this.leftTr,l=e.items.items,d=0;for(var b=0,g=l.length,m;b<g;b++,d++){m=l[b];if(m.isFill){k=this.rightTr;d=-1}else{if(!m.rendered){m.render(this.insertCell(m,k,d));this.configureItem(m)}else{if(!m.xtbHidden&&!this.isValidParent(m,k.childNodes[d])){var a=this.insertCell(m,k,d);a.appendChild(m.getPositionEl().dom);m.container=Ext.get(a)}}}}this.clean
 up(this.leftTr);this.cleanup(this.rightTr);this.cleanup(this.extrasTr);this.fitToSize(j)},cleanup:function(b){var e=b.childNodes,a,d;for(a=e.length-1;a>=0&&(d=e[a]);a--){if(!d.firstChild){b.removeChild(d)}}},insertCell:function(e,b,a){var d=document.createElement("td");d.className="x-toolbar-cell";b.insertBefore(d,b.childNodes[a]||null);return d},hideItem:function(a){this.hiddenItems.push(a);a.xtbHidden=true;a.xtbWidth=a.getPositionEl().dom.parentNode.offsetWidth;a.hide()},unhideItem:function(a){a.show();a.xtbHidden=false;this.hiddenItems.remove(a)},getItemWidth:function(a){return a.hidden?(a.xtbWidth||0):a.getPositionEl().dom.parentNode.offsetWidth},fitToSize:function(k){if(this.container.enableOverflow===false){return}var b=k.dom.clientWidth,j=k.dom.firstChild.offsetWidth,m=b-this.triggerWidth,a=this.lastWidth||0,c=this.hiddenItems,e=c.length!=0,n=b>=a;this.lastWidth=b;if(j>b||(e&&n)){var l=this.container.items.items,h=l.length,d=0,o;for(var g=0;g<h;g++){o=l[g];if(!o.isFil
 l){d+=this.getItemWidth(o);if(d>m){if(!(o.hidden||o.xtbHidden)){this.hideItem(o)}}else{if(o.xtbHidden){this.unhideItem(o)}}}}}e=c.length!=0;if(e){this.initMore();if(!this.lastOverflow){this.container.fireEvent("overflowchange",this.container,true);this.lastOverflow=true}}else{if(this.more){this.clearMenu();this.more.destroy();delete this.more;if(this.lastOverflow){this.container.fireEvent("overflowchange",this.container,false);this.lastOverflow=false}}}},createMenuConfig:function(c,a){var b=Ext.apply({},c.initialConfig),d=c.toggleGroup;Ext.copyTo(b,c,["iconCls","icon","itemId","disabled","handler","scope","menu"]);Ext.apply(b,{text:c.overflowText||c.text,hideOnClick:a});if(d||c.enableToggle){Ext.apply(b,{group:d,checked:c.pressed,listeners:{checkchange:function(g,e){c.toggle(e)}}})}delete b.ownerCt;delete b.xtype;delete b.id;return b},addComponentToMenu:function(b,a){if(a instanceof Ext.Toolbar.Separator){b.add("-")}else{if(Ext.isFunction(a.isXType)){if(a.isXType("splitbutto
 n")){b.add(this.createMenuConfig(a,true))}else{if(a.isXType("button")){b.add(this.createMenuConfig(a,!a.menu))}else{if(a.isXType("buttongroup")){a.items.each(function(c){this.addComponentToMenu(b,c)},this)}}}}}},clearMenu:function(){var a=this.moreMenu;if(a&&a.items){a.items.each(function(b){delete b.menu})}},beforeMoreShow:function(h){var b=this.container.items.items,a=b.length,g,e;var c=function(j,i){return j.isXType("buttongroup")&&!(i instanceof Ext.Toolbar.Separator)};this.clearMenu();h.removeAll();for(var d=0;d<a;d++){g=b[d];if(g.xtbHidden){if(e&&(c(g,e)||c(e,g))){h.add("-")}this.addComponentToMenu(h,g);e=g}}if(h.items.length<1){h.add(this.noItemsMenuText)}},initMore:function(){if(!this.more){this.moreMenu=new Ext.menu.Menu({ownerCt:this.container,listeners:{beforeshow:this.beforeMoreShow,scope:this}});this.more=new Ext.Button({iconCls:"x-toolbar-more-icon",cls:"x-toolbar-more",menu:this.moreMenu,ownerCt:this.container});var a=this.insertCell(this.more,this.extrasTr,10
 0);this.more.render(a)}},destroy:function(){Ext.destroy(this.more,this.moreMenu);delete this.leftTr;delete this.rightTr;delete this.extrasTr;Ext.layout.ToolbarLayout.superclass.destroy.call(this)}});Ext.Container.LAYOUTS.toolbar=Ext.layout.ToolbarLayout;Ext.layout.MenuLayout=Ext.extend(Ext.layout.ContainerLayout,{monitorResize:true,type:"menu",setContainer:function(a){this.monitorResize=!a.floating;a.on("autosize",this.doAutoSize,this);Ext.layout.MenuLayout.superclass.setContainer.call(this,a)},renderItem:function(g,b,e){if(!this.itemTpl){this.itemTpl=Ext.layout.MenuLayout.prototype.itemTpl=new Ext.XTemplate('<li id="{itemId}" class="{itemCls}">','<tpl if="needsIcon">','<img alt="{altText}" src="{icon}" class="{iconCls}"/>',"</tpl>","</li>")}if(g&&!g.rendered){if(Ext.isNumber(b)){b=e.dom.childNodes[b]}var d=this.getItemArgs(g);g.render(g.positionEl=b?this.itemTpl.insertBefore(b,d,true):this.itemTpl.append(e,d,true));g.positionEl.menuItemId=g.getItemId();if(!d.isMenuItem&&d.n
 eedsIcon){g.positionEl.addClass("x-menu-list-item-indent")}this.configureItem(g)}else{if(g&&!this.isValidParent(g,e)){if(Ext.isNumber(b)){b=e.dom.childNodes[b]}e.dom.insertBefore(g.getActionEl().dom,b||null)}}},getItemArgs:function(d){var a=d instanceof Ext.menu.Item,b=!(a||d instanceof Ext.menu.Separator);return{isMenuItem:a,needsIcon:b&&(d.icon||d.iconCls),icon:d.icon||Ext.BLANK_IMAGE_URL,iconCls:"x-menu-item-icon "+(d.iconCls||""),itemId:"x-menu-el-"+d.id,itemCls:"x-menu-list-item ",altText:d.altText||""}},isValidParent:function(b,a){return b.el.up("li.x-menu-list-item",5).dom.parentNode===(a.dom||a)},onLayout:function(a,b){Ext.layout.MenuLayout.superclass.onLayout.call(this,a,b);this.doAutoSize()},doAutoSize:function(){var c=this.container,a=c.width;if(c.floating){if(a){c.setWidth(a)}else{if(Ext.isIE){c.setWidth(Ext.isStrict&&(Ext.isIE7||Ext.isIE8||Ext.isIE9)?"auto":c.minWidth);var d=c.getEl(),b=d.dom.offsetWidth;c.setWidth(c.getLayoutTarget().getWidth()+d.getFrameWidth(
 "lr"))}}}}});Ext.Container.LAYOUTS.menu=Ext.layout.MenuLayout;Ext.Viewport=Ext.extend(Ext.Container,{initComponent:function(){Ext.Viewport.superclass.initComponent.call(this);document.getElementsByTagName("html")[0].className+=" x-viewport";this.el=Ext.getBody();this.el.setHeight=Ext.emptyFn;this.el.setWidth=Ext.emptyFn;this.el.setSize=Ext.emptyFn;this.el.dom.scroll="no";this.allowDomMove=false;this.autoWidth=true;this.autoHeight=true;Ext.EventManager.onWindowResize(this.fireResize,this);this.renderTo=this.el},fireResize:function(a,b){this.fireEvent("resize",this,a,b,a,b)}});Ext.reg("viewport",Ext.Viewport);Ext.Panel=Ext.extend(Ext.Container,{baseCls:"x-panel",collapsedCls:"x-panel-collapsed",maskDisabled:true,animCollapse:Ext.enableFx,headerAsText:true,buttonAlign:"right",collapsed:false,collapseFirst:true,minButtonWidth:75,elements:"body",preventBodyReset:false,padding:undefined,resizeEvent:"bodyresize",toolTarget:"header",collapseEl:"bwrap",slideAnchor:"t",disabledClass:"
 ",deferHeight:true,expandDefaults:{duration:0.25},collapseDefaults:{duration:0.25},initComponent:function(){Ext.Panel.superclass.initComponent.call(this);this.addEvents("bodyresize","titlechange","iconchange","collapse","expand","beforecollapse","beforeexpand","beforeclose","close","activate","deactivate");if(this.unstyled){this.baseCls="x-plain"}this.toolbars=[];if(this.tbar){this.elements+=",tbar";this.topToolbar=this.createToolbar(this.tbar);this.tbar=null}if(this.bbar){this.elements+=",bbar";this.bottomToolbar=this.createToolbar(this.bbar);this.bbar=null}if(this.header===true){this.elements+=",header";this.header=null}else{if(this.headerCfg||(this.title&&this.header!==false)){this.elements+=",header"}}if(this.footerCfg||this.footer===true){this.elements+=",footer";this.footer=null}if(this.buttons){this.fbar=this.buttons;this.buttons=null}if(this.fbar){this.createFbar(this.fbar)}if(this.autoLoad){this.on("render",this.doAutoLoad,this,{delay:10})}},createFbar:function(b){v
 ar a=this.minButtonWidth;this.elements+=",footer";this.fbar=this.createToolbar(b,{buttonAlign:this.buttonAlign,toolbarCls:"x-panel-fbar",enableOverflow:false,defaults:function(d){return{minWidth:d.minWidth||a}}});this.fbar.items.each(function(d){d.minWidth=d.minWidth||this.minButtonWidth},this);this.buttons=this.fbar.items.items},createToolbar:function(b,c){var a;if(Ext.isArray(b)){b={items:b}}a=b.events?Ext.apply(b,c):this.createComponent(Ext.apply({},b,c),"toolbar");this.toolbars.push(a);return a},createElement:function(a,c){if(this[a]){c.appendChild(this[a].dom);return}if(a==="bwrap"||this.elements.indexOf(a)!=-1){if(this[a+"Cfg"]){this[a]=Ext.fly(c).createChild(this[a+"Cfg"])}else{var b=document.createElement("div");b.className=this[a+"Cls"];this[a]=Ext.get(c.appendChild(b))}if(this[a+"CssClass"]){this[a].addClass(this[a+"CssClass"])}if(this[a+"Style"]){this[a].applyStyles(this[a+"Style"])}}},onRender:function(g,e){Ext.Panel.superclass.onRender.call(this,g,e);this.create
 Classes();var a=this.el,h=a.dom,k,i;if(this.collapsible&&!this.hideCollapseTool){this.tools=this.tools?this.tools.slice(0):[];this.tools[this.collapseFirst?"unshift":"push"]({id:"toggle",handler:this.toggleCollapse,scope:this})}if(this.tools){i=this.tools;this.elements+=(this.header!==false)?",header":""}this.tools={};a.addClass(this.baseCls);if(h.firstChild){this.header=a.down("."+this.headerCls);this.bwrap=a.down("."+this.bwrapCls);var j=this.bwrap?this.bwrap:a;this.tbar=j.down("."+this.tbarCls);this.body=j.down("."+this.bodyCls);this.bbar=j.down("."+this.bbarCls);this.footer=j.down("."+this.footerCls);this.fromMarkup=true}if(this.preventBodyReset===true){a.addClass("x-panel-reset")}if(this.cls){a.addClass(this.cls)}if(this.buttons){this.elements+=",footer"}if(this.frame){a.insertHtml("afterBegin",String.format(Ext.Element.boxMarkup,this.baseCls));this.createElement("header",h.firstChild.firstChild.firstChild);this.createElement("bwrap",h);k=this.bwrap.dom;var c=h.childNod
 es[1],b=h.childNodes[2];k.appendChild(c);k.appendChild(b);var l=k.firstChild.firstChild.firstChild;this.createElement("tbar",l);this.createElement("body",l);this.createElement("bbar",l);this.createElement("footer",k.lastChild.firstChild.firstChild);if(!this.footer){this.bwrap.dom.lastChild.className+=" x-panel-nofooter"}this.ft=Ext.get(this.bwrap.dom.lastChild);this.mc=Ext.get(l)}else{this.createElement("header",h);this.createElement("bwrap",h);k=this.bwrap.dom;this.createElement("tbar",k);this.createElement("body",k);this.createElement("bbar",k);this.createElement("footer",k);if(!this.header){this.body.addClass(this.bodyCls+"-noheader");if(this.tbar){this.tbar.addClass(this.tbarCls+"-noheader")}}}if(Ext.isDefined(this.padding)){this.body.setStyle("padding",this.body.addUnits(this.padding))}if(this.border===false){this.el.addClass(this.baseCls+"-noborder");this.body.addClass(this.bodyCls+"-noborder");if(this.header){this.header.addClass(this.headerCls+"-noborder")}if(this.fo
 oter){this.footer.addClass(this.footerCls+"-noborder")}if(this.tbar){this.tbar.addClass(this.tbarCls+"-noborder")}if(this.bbar){this.bbar.addClass(this.bbarCls+"-noborder")}}if(this.bodyBorder===false){this.body.addClass(this.bodyCls+"-noborder")}this.bwrap.enableDisplayMode("block");if(this.header){this.header.unselectable();if(this.headerAsText){this.header.dom.innerHTML='<span class="'+this.headerTextCls+'">'+this.header.dom.innerHTML+"</span>";if(this.iconCls){this.setIconClass(this.iconCls)}}}if(this.floating){this.makeFloating(this.floating)}if(this.collapsible&&this.titleCollapse&&this.header){this.mon(this.header,"click",this.toggleCollapse,this);this.header.setStyle("cursor","pointer")}if(i){this.addTool.apply(this,i)}if(this.fbar){this.footer.addClass("x-panel-btns");this.fbar.ownerCt=this;this.fbar.render(this.footer);this.footer.createChild({cls:"x-clear"})}if(this.tbar&&this.topToolbar){this.topToolbar.ownerCt=this;this.topToolbar.render(this.tbar)}if(this.bbar&
 &this.bottomToolbar){this.bottomToolbar.ownerCt=this;this.bottomToolbar.render(this.bbar)}},setIconClass:function(b){var a=this.iconCls;this.iconCls=b;if(this.rendered&&this.header){if(this.frame){this.header.addClass("x-panel-icon");this.header.replaceClass(a,this.iconCls)}else{var e=this.header,c=e.child("img.x-panel-inline-icon");if(c){Ext.fly(c).replaceClass(a,this.iconCls)}else{var d=e.child("span."+this.headerTextCls);if(d){Ext.DomHelper.insertBefore(d.dom,{tag:"img",alt:"",src:Ext.BLANK_IMAGE_URL,cls:"x-panel-inline-icon "+this.iconCls})}}}}this.fireEvent("iconchange",this,b,a)},makeFloating:function(a){this.floating=true;this.el=new Ext.Layer(Ext.apply({},a,{shadow:Ext.isDefined(this.shadow)?this.shadow:"sides",shadowOffset:this.shadowOffset,constrain:false,shim:this.shim===false?false:undefined}),this.el)},getTopToolbar:function(){return this.topToolbar},getBottomToolbar:function(){return this.bottomToolbar},getFooterToolbar:function(){return this.fbar},addButton:fu
 nction(a,c,b){if(!this.fbar){this.createFbar([])}if(c){if(Ext.isString(a)){a={text:a}}a=Ext.apply({handler:c,scope:b},a)}return this.fbar.add(a)},addTool:function(){if(!this.rendered){if(!this.tools){this.tools=[]}Ext.each(arguments,function(a){this.tools.push(a)},this);return}if(!this[this.toolTarget]){return}if(!this.toolTemplate){var h=new Ext.Template('<div class="x-tool x-tool-{id}">&#160;</div>');h.disableFormats=true;h.compile();Ext.Panel.prototype.toolTemplate=h}for(var g=0,d=arguments,c=d.length;g<c;g++){var b=d[g];if(!this.tools[b.id]){var j="x-tool-"+b.id+"-over";var e=this.toolTemplate.insertFirst(this[this.toolTarget],b,true);this.tools[b.id]=e;e.enableDisplayMode("block");this.mon(e,"click",this.createToolHandler(e,b,j,this));if(b.on){this.mon(e,b.on)}if(b.hidden){e.hide()}if(b.qtip){if(Ext.isObject(b.qtip)){Ext.QuickTips.register(Ext.apply({target:e.id},b.qtip))}else{e.dom.qtip=b.qtip}}e.addClassOnOver(j)}}},onLayout:function(b,a){Ext.Panel.superclass.onLayout
 .apply(this,arguments);if(this.hasLayout&&this.toolbars.length>0){Ext.each(this.toolbars,function(c){c.doLayout(undefined,a)});this.syncHeight()}},syncHeight:function(){var b=this.toolbarHeight,c=this.body,a=this.lastSize.height,d;if(this.autoHeight||!Ext.isDefined(a)||a=="auto"){return}if(b!=this.getToolbarHeight()){b=Math.max(0,a-this.getFrameHeight());c.setHeight(b);d=c.getSize();this.toolbarHeight=this.getToolbarHeight();this.onBodyResize(d.width,d.height)}},onShow:function(){if(this.floating){return this.el.show()}Ext.Panel.superclass.onShow.call(this)},onHide:function(){if(this.floating){return this.el.hide()}Ext.Panel.superclass.onHide.call(this)},createToolHandler:function(c,a,d,b){return function(g){c.removeClass(d);if(a.stopEvent!==false){g.stopEvent()}if(a.handler){a.handler.call(a.scope||c,g,c,b,a)}}},afterRender:function(){if(this.floating&&!this.hidden){this.el.show()}if(this.title){this.setTitle(this.title)}Ext.Panel.superclass.afterRender.call(this);if(this.c
 ollapsed){this.collapsed=false;this.collapse(false)}this.initEvents()},getKeyMap:function(){if(!this.keyMap){this.keyMap=new Ext.KeyMap(this.el,this.keys)}return this.keyMap},initEvents:function(){if(this.keys){this.getKeyMap()}if(this.draggable){this.initDraggable()}if(this.toolbars.length>0){Ext.each(this.toolbars,function(a){a.doLayout();a.on({scope:this,afterlayout:this.syncHeight,remove:this.syncHeight})},this);this.syncHeight()}},initDraggable:function(){this.dd=new Ext.Panel.DD(this,Ext.isBoolean(this.draggable)?null:this.draggable)},beforeEffect:function(a){if(this.floating){this.el.beforeAction()}if(a!==false){this.el.addClass("x-panel-animated")}},afterEffect:function(a){this.syncShadow();this.el.removeClass("x-panel-animated")},createEffect:function(c,b,d){var e={scope:d,block:true};if(c===true){e.callback=b;return e}else{if(!c.callback){e.callback=b}else{e.callback=function(){b.call(d);Ext.callback(c.callback,c.scope)}}}return Ext.applyIf(e,c)},collapse:function(
 b){if(this.collapsed||this.el.hasFxBlock()||this.fireEvent("beforecollapse",this,b)===false){return}var a=b===true||(b!==false&&this.animCollapse);this.beforeEffect(a);this.onCollapse(a,b);return this},onCollapse:function(a,b){if(a){this[this.collapseEl].slideOut(this.slideAnchor,Ext.apply(this.createEffect(b||true,this.afterCollapse,this),this.collapseDefaults))}else{this[this.collapseEl].hide(this.hideMode);this.afterCollapse(false)}},afterCollapse:function(a){this.collapsed=true;this.el.addClass(this.collapsedCls);if(a!==false){this[this.collapseEl].hide(this.hideMode)}this.afterEffect(a);this.cascade(function(b){if(b.lastSize){b.lastSize={width:undefined,height:undefined}}});this.fireEvent("collapse",this)},expand:function(b){if(!this.collapsed||this.el.hasFxBlock()||this.fireEvent("beforeexpand",this,b)===false){return}var a=b===true||(b!==false&&this.animCollapse);this.el.removeClass(this.collapsedCls);this.beforeEffect(a);this.onExpand(a,b);return this},onExpand:funct
 ion(a,b){if(a){this[this.collapseEl].slideIn(this.slideAnchor,Ext.apply(this.createEffect(b||true,this.afterExpand,this),this.expandDefaults))}else{this[this.collapseEl].show(this.hideMode);this.afterExpand(false)}},afterExpand:function(a){this.collapsed=false;if(a!==false){this[this.collapseEl].show(this.hideMode)}this.afterEffect(a);if(this.deferLayout){delete this.deferLayout;this.doLayout(true)}this.fireEvent("expand",this)},toggleCollapse:function(a){this[this.collapsed?"expand":"collapse"](a);return this},onDisable:function(){if(this.rendered&&this.maskDisabled){this.el.mask()}Ext.Panel.superclass.onDisable.call(this)},onEnable:function(){if(this.rendered&&this.maskDisabled){this.el.unmask()}Ext.Panel.superclass.onEnable.call(this)},onResize:function(g,d,c,e){var a=g,b=d;if(Ext.isDefined(a)||Ext.isDefined(b)){if(!this.collapsed){if(Ext.isNumber(a)){this.body.setWidth(a=this.adjustBodyWidth(a-this.getFrameWidth()))}else{if(a=="auto"){a=this.body.setWidth("auto").dom.off
 setWidth}else{a=this.body.dom.offsetWidth}}if(this.tbar){this.tbar.setWidth(a);if(this.topToolbar){this.topToolbar.setSize(a)}}if(this.bbar){this.bbar.setWidth(a);if(this.bottomToolbar){this.bottomToolbar.setSize(a);if(Ext.isIE){this.bbar.setStyle("position","static");this.bbar.setStyle("position","")}}}if(this.footer){this.footer.setWidth(a);if(this.fbar){this.fbar.setSize(Ext.isIE?(a-this.footer.getFrameWidth("lr")):"auto")}}if(Ext.isNumber(b)){b=Math.max(0,b-this.getFrameHeight());this.body.setHeight(b)}else{if(b=="auto"){this.body.setHeight(b)}}if(this.disabled&&this.el._mask){this.el._mask.setSize(this.el.dom.clientWidth,this.el.getHeight())}}else{this.queuedBodySize={width:a,height:b};if(!this.queuedExpand&&this.allowQueuedExpand!==false){this.queuedExpand=true;this.on("expand",function(){delete this.queuedExpand;this.onResize(this.queuedBodySize.width,this.queuedBodySize.height)},this,{single:true})}}this.onBodyResize(a,b)}this.syncShadow();Ext.Panel.superclass.onResi
 ze.call(this,g,d,c,e)},onBodyResize:function(a,b){this.fireEvent("bodyresize",this,a,b)},getToolbarHeight:function(){var a=0;if(this.rendered){Ext.each(this.toolbars,function(b){a+=b.getHeight()},this)}return a},adjustBodyHeight:function(a){return a},adjustBodyWidth:function(a){return a},onPosition:function(){this.syncShadow()},getFrameWidth:function(){var b=this.el.getFrameWidth("lr")+this.bwrap.getFrameWidth("lr");if(this.frame){var a=this.bwrap.dom.firstChild;b+=(Ext.fly(a).getFrameWidth("l")+Ext.fly(a.firstChild).getFrameWidth("r"));b+=this.mc.getFrameWidth("lr")}return b},getFrameHeight:function(){var a=this.el.getFrameWidth("tb")+this.bwrap.getFrameWidth("tb");a+=(this.tbar?this.tbar.getHeight():0)+(this.bbar?this.bbar.getHeight():0);if(this.frame){a+=this.el.dom.firstChild.offsetHeight+this.ft.dom.offsetHeight+this.mc.getFrameWidth("tb")}else{a+=(this.header?this.header.getHeight():0)+(this.footer?this.footer.getHeight():0)}return a},getInnerWidth:function(){return th
 is.getSize().width-this.getFrameWidth()},getInnerHeight:function(){return this.body.getHeight()},syncShadow:function(){if(this.floating){this.el.sync(true)}},getLayoutTarget:function(){return this.body},getContentTarget:function(){return this.body},setTitle:function(b,a){this.title=b;if(this.header&&this.headerAsText){this.header.child("span").update(b)}if(a){this.setIconClass(a)}this.fireEvent("titlechange",this,b);return this},getUpdater:function(){return this.body.getUpdater()},load:function(){var a=this.body.getUpdater();a.update.apply(a,arguments);return this},beforeDestroy:function(){Ext.Panel.superclass.beforeDestroy.call(this);if(this.header){this.header.removeAllListeners()}if(this.tools){for(var a in this.tools){Ext.destroy(this.tools[a])}}if(this.toolbars.length>0){Ext.each(this.toolbars,function(b){b.un("afterlayout",this.syncHeight,this);b.un("remove",this.syncHeight,this)},this)}if(Ext.isArray(this.buttons)){while(this.buttons.length){Ext.destroy(this.buttons[0
 ])}}if(this.rendered){Ext.destroy(this.ft,this.header,this.footer,this.tbar,this.bbar,this.body,this.mc,this.bwrap,this.dd);if(this.fbar){Ext.destroy(this.fbar,this.fbar.el)}}Ext.destroy(this.toolbars)},createClasses:function(){this.headerCls=this.baseCls+"-header";this.headerTextCls=this.baseCls+"-header-text";this.bwrapCls=this.baseCls+"-bwrap";this.tbarCls=this.baseCls+"-tbar";this.bodyCls=this.baseCls+"-body";this.bbarCls=this.baseCls+"-bbar";this.footerCls=this.baseCls+"-footer"},createGhost:function(a,e,b){var d=document.createElement("div");d.className="x-panel-ghost "+(a?a:"");if(this.header){d.appendChild(this.el.dom.firstChild.cloneNode(true))}Ext.fly(d.appendChild(document.createElement("ul"))).setHeight(this.bwrap.getHeight());d.style.width=this.el.dom.offsetWidth+"px";if(!b){this.container.dom.appendChild(d)}else{Ext.getDom(b).appendChild(d)}if(e!==false&&this.el.useShim!==false){var c=new Ext.Layer({shadow:false,useDisplay:true,constrain:false},d);c.show();retu
 rn c}else{return new Ext.Element(d)}},doAutoLoad:function(){var a=this.body.getUpdater();if(this.renderer){a.setRenderer(this.renderer)}a.update(Ext.isObject(this.autoLoad)?this.autoLoad:{url:this.autoLoad})},getTool:function(a){return this.tools[a]}});Ext.reg("panel",Ext.Panel);Ext.Editor=function(b,a){if(b.field){this.field=Ext.create(b.field,"textfield");a=Ext.apply({},b);delete a.field}else{this.field=b}Ext.Editor.superclass.constructor.call(this,a)};Ext.extend(Ext.Editor,Ext.Component,{allowBlur:true,value:"",alignment:"c-c?",offsets:[0,0],shadow:"frame",constrain:false,swallowKeys:true,completeOnEnter:true,cancelOnEsc:true,updateEl:false,initComponent:function(){Ext.Editor.superclass.initComponent.call(this);this.addEvents("beforestartedit","startedit","beforecomplete","complete","canceledit","specialkey")},onRender:function(b,a){this.el=new Ext.Layer({shadow:this.shadow,cls:"x-editor",parentEl:b,shim:this.shim,shadowOffset:this.shadowOffset||4,id:this.id,constrain:thi
 s.constrain});if(this.zIndex){this.el.setZIndex(this.zIndex)}this.el.setStyle("overflow",Ext.isGecko?"auto":"hidden");if(this.field.msgTarget!="title"){this.field.msgTarget="qtip"}this.field.inEditor=true;this.mon(this.field,{scope:this,blur:this.onBlur,specialkey:this.onSpecialKey});if(this.field.grow){this.mon(this.field,"autosize",this.el.sync,this.el,{delay:1})}this.field.render(this.el).show();this.field.getEl().dom.name="";if(this.swallowKeys){this.field.el.swallowEvent(["keypress","keydown"])}},onSpecialKey:function(g,d){var b=d.getKey(),a=this.completeOnEnter&&b==d.ENTER,c=this.cancelOnEsc&&b==d.ESC;if(a||c){d.stopEvent();if(a){this.completeEdit()}else{this.cancelEdit()}if(g.triggerBlur){g.triggerBlur()}}this.fireEvent("specialkey",g,d)},startEdit:function(b,c){if(this.editing){this.completeEdit()}this.boundEl=Ext.get(b);var a=c!==undefined?c:this.boundEl.dom.innerHTML;if(!this.rendered){this.render(this.parentEl||document.body)}if(this.fireEvent("beforestartedit",th
 is,this.boundEl,a)!==false){this.startValue=a;this.field.reset();this.field.setValue(a);this.realign(true);this.editing=true;this.show()}},doAutoSize:function(){if(this.autoSize){var b=this.boundEl.getSize(),a=this.field.getSize();switch(this.autoSize){case"width":this.setSize(b.width,a.height);break;case"height":this.setSize(a.width,b.height);break;case"none":this.setSize(a.width,a.height);break;default:this.setSize(b.width,b.height)}}},setSize:function(a,b){delete this.field.lastSize;this.field.setSize(a,b);if(this.el){if(Ext.isGecko2||Ext.isOpera||(Ext.isIE7&&Ext.isStrict)){this.el.setSize(a,b)}this.el.sync()}},realign:function(a){if(a===true){this.doAutoSize()}this.el.alignTo(this.boundEl,this.alignment,this.offsets)},completeEdit:function(a){if(!this.editing){return}if(this.field.assertValue){this.field.assertValue()}var b=this.getValue();if(!this.field.isValid()){if(this.revertInvalid!==false){this.cancelEdit(a)}return}if(String(b)===String(this.startValue)&&this.ignor
 eNoChange){this.hideEdit(a);return}if(this.fireEvent("beforecomplete",this,b,this.startValue)!==false){b=this.getValue();if(this.updateEl&&this.boundEl){this.boundEl.update(b)}this.hideEdit(a);this.fireEvent("complete",this,b,this.startValue)}},onShow:function(){this.el.show();if(this.hideEl!==false){this.boundEl.hide()}this.field.show().focus(false,true);this.fireEvent("startedit",this.boundEl,this.startValue)},cancelEdit:function(a){if(this.editing){var b=this.getValue();this.setValue(this.startValue);this.hideEdit(a);this.fireEvent("canceledit",this,b,this.startValue)}},hideEdit:function(a){if(a!==true){this.editing=false;this.hide()}},onBlur:function(){if(this.allowBlur===true&&this.editing&&this.selectSameEditor!==true){this.completeEdit()}},onHide:function(){if(this.editing){this.completeEdit();return}this.field.blur();if(this.field.collapse){this.field.collapse()}this.el.hide();if(this.hideEl!==false){this.boundEl.show()}},setValue:function(a){this.field.setValue(a)},
 getValue:function(){return this.field.getValue()},beforeDestroy:function(){Ext.destroyMembers(this,"field");delete this.parentEl;delete this.boundEl}});Ext.reg("editor",Ext.Editor);Ext.ColorPalette=Ext.extend(Ext.Component,{itemCls:"x-color-palette",value:null,clickEvent:"click",ctype:"Ext.ColorPalette",allowReselect:false,colors:["000000","993300","333300","003300","003366","000080","333399","333333","800000","FF6600","808000","008000","008080","0000FF","666699","808080","FF0000","FF9900","99CC00","339966","33CCCC","3366FF","800080","969696","FF00FF","FFCC00","FFFF00","00FF00","00FFFF","00CCFF","993366","C0C0C0","FF99CC","FFCC99","FFFF99","CCFFCC","CCFFFF","99CCFF","CC99FF","FFFFFF"],initComponent:function(){Ext.ColorPalette.superclass.initComponent.call(this);this.addEvents("select");if(this.handler){this.on("select",this.handler,this.scope,true)}},onRender:function(b,a){this.autoEl={tag:"div",cls:this.itemCls};Ext.ColorPalette.superclass.onRender.call(this,b,a);var c=this
 .tpl||new Ext.XTemplate('<tpl for="."><a href="#" class="color-{.}" hidefocus="on"><em><span style="background:#{.}" unselectable="on">&#160;</span></em></a></tpl>');c.overwrite(this.el,this.colors);this.mon(this.el,this.clickEvent,this.handleClick,this,{delegate:"a"});if(this.clickEvent!="click"){this.mon(this.el,"click",Ext.emptyFn,this,{delegate:"a",preventDefault:true})}},afterRender:function(){Ext.ColorPalette.superclass.afterRender.call(this);if(this.value){var a=this.value;this.value=null;this.select(a,true)}},handleClick:function(b,a){b.preventDefault();if(!this.disabled){var d=a.className.match(/(?:^|\s)color-(.{6})(?:\s|$)/)[1];this.select(d.toUpperCase())}},select:function(b,a){b=b.replace("#","");if(b!=this.value||this.allowReselect){var c=this.el;if(this.value){c.child("a.color-"+this.value).removeClass("x-color-palette-sel")}c.child("a.color-"+b).addClass("x-color-palette-sel");this.value=b;if(a!==true){this.fireEvent("select",this,b)}}}});Ext.reg("colorpalette
 ",Ext.ColorPalette);Ext.DatePicker=Ext.extend(Ext.BoxComponent,{todayText:"Today",okText:"&#160;OK&#160;",cancelText:"Cancel",todayTip:"{0} (Spacebar)",minText:"This date is before the minimum date",maxText:"This date is after the maximum date",format:"m/d/y",disabledDaysText:"Disabled",disabledDatesText:"Disabled",monthNames:Date.monthNames,dayNames:Date.dayNames,nextText:"Next Month (Control+Right)",prevText:"Previous Month (Control+Left)",monthYearText:"Choose a month (Control+Up/Down to move years)",startDay:0,showToday:true,focusOnSelect:true,initHour:12,initComponent:function(){Ext.DatePicker.superclass.initComponent.call(this);this.value=this.value?this.value.clearTime(true):new Date().clearTime();this.addEvents("select");if(this.handler){this.on("select",this.handler,this.scope||this)}this.initDisabledDays()},initDisabledDays:function(){if(!this.disabledDatesRE&&this.disabledDates){var b=this.disabledDates,a=b.length-1,c="(?:";Ext.each(b,function(g,e){c+=Ext.isDate(g
 )?"^"+Ext.escapeRe(g.dateFormat(this.format))+"$":b[e];if(e!=a){c+="|"}},this);this.disabledDatesRE=new RegExp(c+")")}},setDisabledDates:function(a){if(Ext.isArray(a)){this.disabledDates=a;this.disabledDatesRE=null}else{this.disabledDatesRE=a}this.initDisabledDays();this.update(this.value,true)},setDisabledDays:function(a){this.disabledDays=a;this.update(this.value,true)},setMinDate:function(a){this.minDate=a;this.update(this.value,true)},setMaxDate:function(a){this.maxDate=a;this.update(this.value,true)},setValue:function(a){this.value=a.clearTime(true);this.update(this.value)},getValue:function(){return this.value},focus:function(){this.update(this.activeDate)},onEnable:function(a){Ext.DatePicker.superclass.onEnable.call(this);this.doDisabled(false);this.update(a?this.value:this.activeDate);if(Ext.isIE){this.el.repaint()}},onDisable:function(){Ext.DatePicker.superclass.onDisable.call(this);this.doDisabled(true);if(Ext.isIE&&!Ext.isIE8){Ext.each([].concat(this.textNodes,thi
 s.el.query("th span")),function(a){Ext.fly(a).repaint()})}},doDisabled:function(a){this.keyNav.setDisabled(a);this.prevRepeater.setDisabled(a);this.nextRepeater.setDisabled(a);if(this.showToday){this.todayKeyListener.setDisabled(a);this.todayBtn.setDisabled(a)}},onRender:function(e,b){var a=['<table cellspacing="0">','<tr><td class="x-date-left"><a href="#" title="',this.prevText,'">&#160;</a></td><td class="x-date-middle" align="center"></td><td class="x-date-right"><a href="#" title="',this.nextText,'">&#160;</a></td></tr>','<tr><td colspan="3"><table class="x-date-inner" cellspacing="0"><thead><tr>'],c=this.dayNames,h;for(h=0;h<7;h++){var k=this.startDay+h;if(k>6){k=k-7}a.push("<th><span>",c[k].substr(0,1),"</span></th>")}a[a.length]="</tr></thead><tbody><tr>";for(h=0;h<42;h++){if(h%7===0&&h!==0){a[a.length]="</tr><tr>"}a[a.length]='<td><a href="#" hidefocus="on" class="x-date-date" tabIndex="1"><em><span></span></em></a></td>'}a.push("</tr></tbody></table></td></tr>",thi
 s.showToday?'<tr><td colspan="3" class="x-date-bottom" align="center"></td></tr>':"",'</table><div class="x-date-mp"></div>');var j=document.createElement("div");j.className="x-date-picker";j.innerHTML=a.join("");e.dom.insertBefore(j,b);this.el=Ext.get(j);this.eventEl=Ext.get(j.firstChild);this.prevRepeater=new Ext.util.ClickRepeater(this.el.child("td.x-date-left a"),{handler:this.showPrevMonth,scope:this,preventDefault:true,stopDefault:true});this.nextRepeater=new Ext.util.ClickRepeater(this.el.child("td.x-date-right a"),{handler:this.showNextMonth,scope:this,preventDefault:true,stopDefault:true});this.monthPicker=this.el.down("div.x-date-mp");this.monthPicker.enableDisplayMode("block");this.keyNav=new Ext.KeyNav(this.eventEl,{left:function(d){if(d.ctrlKey){this.showPrevMonth()}else{this.update(this.activeDate.add("d",-1))}},right:function(d){if(d.ctrlKey){this.showNextMonth()}else{this.update(this.activeDate.add("d",1))}},up:function(d){if(d.ctrlKey){this.showNextYear()}el
 se{this.update(this.activeDate.add("d",-7))}},down:function(d){if(d.ctrlKey){this.showPrevYear()}else{this.update(this.activeDate.add("d",7))}},pageUp:function(d){this.showNextMonth()},pageDown:function(d){this.showPrevMonth()},enter:function(d){d.stopPropagation();return true},scope:this});this.el.unselectable();this.cells=this.el.select("table.x-date-inner tbody td");this.textNodes=this.el.query("table.x-date-inner tbody span");this.mbtn=new Ext.Button({text:"&#160;",tooltip:this.monthYearText,renderTo:this.el.child("td.x-date-middle",true)});this.mbtn.el.child("em").addClass("x-btn-arrow");if(this.showToday){this.todayKeyListener=this.eventEl.addKeyListener(Ext.EventObject.SPACE,this.selectToday,this);var g=(new Date()).dateFormat(this.format);this.todayBtn=new Ext.Button({renderTo:this.el.child("td.x-date-bottom",true),text:String.format(this.todayText,g),tooltip:String.format(this.todayTip,g),handler:this.selectToday,scope:this})}this.mon(this.eventEl,"mousewheel",this.
 handleMouseWheel,this);this.mon(this.eventEl,"click",this.handleDateClick,this,{delegate:"a.x-date-date"});this.mon(this.mbtn,"click",this.showMonthPicker,this);this.onEnable(true)},createMonthPicker:function(){if(!this.monthPicker.dom.firstChild){var a=['<table border="0" cellspacing="0">'];for(var b=0;b<6;b++){a.push('<tr><td class="x-date-mp-month"><a href="#">',Date.getShortMonthName(b),"</a></td>",'<td class="x-date-mp-month x-date-mp-sep"><a href="#">',Date.getShortMonthName(b+6),"</a></td>",b===0?'<td class="x-date-mp-ybtn" align="center"><a class="x-date-mp-prev"></a></td><td class="x-date-mp-ybtn" align="center"><a class="x-date-mp-next"></a></td></tr>':'<td class="x-date-mp-year"><a href="#"></a></td><td class="x-date-mp-year"><a href="#"></a></td></tr>')}a.push('<tr class="x-date-mp-btns"><td colspan="4"><button type="button" class="x-date-mp-ok">',this.okText,'</button><button type="button" class="x-date-mp-cancel">',this.cancelText,"</button></td></tr>","</table
 >");this.monthPicker.update(a.join(""));this.mon(this.monthPicker,"click",this.onMonthClick,this);this.mon(this.monthPicker,"dblclick",this.onMonthDblClick,this);this.mpMonths=this.monthPicker.select("td.x-date-mp-month");this.mpYears=this.monthPicker.select("td.x-date-mp-year");this.mpMonths.each(function(c,d,e){e+=1;if((e%2)===0){c.dom.xmonth=5+Math.round(e*0.5)}else{c.dom.xmonth=Math.round((e-1)*0.5)}})}},showMonthPicker:function(){if(!this.disabled){this.createMonthPicker();var a=this.el.getSize();this.monthPicker.setSize(a);this.monthPicker.child("table").setSize(a);this.mpSelMonth=(this.activeDate||this.value).getMonth();this.updateMPMonth(this.mpSelMonth);this.mpSelYear=(this.activeDate||this.value).getFullYear();this.updateMPYear(this.mpSelYear);this.monthPicker.slideIn("t",{duration:0.2})}},updateMPYear:function(e){this.mpyear=e;var c=this.mpYears.elements;for(var b=1;b<=10;b++){var d=c[b-1],a;if((b%2)===0){a=e+Math.round(b*0.5);d.firstChild.innerHTML=a;d.xyear=a}el
 se{a=e-(5-Math.round(b*0.5));d.firstChild.innerHTML=a;d.xyear=a}this.mpYears.item(b-1)[a==this.mpSelYear?"addClass":"removeClass"]("x-date-mp-sel")}},updateMPMonth:function(a){this.mpMonths.each(function(b,c,d){b[b.dom.xmonth==a?"addClass":"removeClass"]("x-date-mp-sel")})},selectMPMonth:function(a){},onMonthClick:function(g,b){g.stopEvent();var c=new Ext.Element(b),a;if(c.is("button.x-date-mp-cancel")){this.hideMonthPicker()}else{if(c.is("button.x-date-mp-ok")){var h=new Date(this.mpSelYear,this.mpSelMonth,(this.activeDate||this.value).getDate());if(h.getMonth()!=this.mpSelMonth){h=new Date(this.mpSelYear,this.mpSelMonth,1).getLastDateOfMonth()}this.update(h);this.hideMonthPicker()}else{if((a=c.up("td.x-date-mp-month",2))){this.mpMonths.removeClass("x-date-mp-sel");a.addClass("x-date-mp-sel");this.mpSelMonth=a.dom.xmonth}else{if((a=c.up("td.x-date-mp-year",2))){this.mpYears.removeClass("x-date-mp-sel");a.addClass("x-date-mp-sel");this.mpSelYear=a.dom.xyear}else{if(c.is("a.x
 -date-mp-prev")){this.updateMPYear(this.mpyear-10)}else{if(c.is("a.x-date-mp-next")){this.updateMPYear(this.mpyear+10)}}}}}}},onMonthDblClick:function(d,b){d.stopEvent();var c=new Ext.Element(b),a;if((a=c.up("td.x-date-mp-month",2))){this.update(new Date(this.mpSelYear,a.dom.xmonth,(this.activeDate||this.value).getDate()));this.hideMonthPicker()}else{if((a=c.up("td.x-date-mp-year",2))){this.update(new Date(a.dom.xyear,this.mpSelMonth,(this.activeDate||this.value).getDate()));this.hideMonthPicker()}}},hideMonthPicker:function(a){if(this.monthPicker){if(a===true){this.monthPicker.hide()}else{this.monthPicker.slideOut("t",{duration:0.2})}}},showPrevMonth:function(a){this.update(this.activeDate.add("mo",-1))},showNextMonth:function(a){this.update(this.activeDate.add("mo",1))},showPrevYear:function(){this.update(this.activeDate.add("y",-1))},showNextYear:function(){this.update(this.activeDate.add("y",1))},handleMouseWheel:function(a){a.stopEvent();if(!this.disabled){var b=a.getWh
 eelDelta();if(b>0){this.showPrevMonth()}else{if(b<0){this.showNextMonth()}}}},handleDateClick:function(b,a){b.stopEvent();if(!this.disabled&&a.dateValue&&!Ext.fly(a.parentNode).hasClass("x-date-disabled")){this.cancelFocus=this.focusOnSelect===false;this.setValue(new Date(a.dateValue));delete this.cancelFocus;this.fireEvent("select",this,this.value)}},selectToday:function(){if(this.todayBtn&&!this.todayBtn.disabled){this.setValue(new Date().clearTime());this.fireEvent("select",this,this.value)}},update:function(G,A){if(this.rendered){var a=this.activeDate,p=this.isVisible();this.activeDate=G;if(!A&&a&&this.el){var o=G.getTime();if(a.getMonth()==G.getMonth()&&a.getFullYear()==G.getFullYear()){this.cells.removeClass("x-date-selected");this.cells.each(function(d){if(d.dom.firstChild.dateValue==o){d.addClass("x-date-selected");if(p&&!this.cancelFocus){Ext.fly(d.dom.firstChild).focus(50)}return false}},this);return}}var k=G.getDaysInMonth(),q=G.getFirstDateOfMonth(),g=q.getDay()-
 this.startDay;if(g<0){g+=7}k+=g;var B=G.add("mo",-1),h=B.getDaysInMonth()-g,e=this.cells.elements,r=this.textNodes,D=(new Date(B.getFullYear(),B.getMonth(),h,this.initHour)),C=new Date().clearTime().getTime(),v=G.clearTime(true).getTime(),u=this.minDate?this.minDate.clearTime(true):Number.NEGATIVE_INFINITY,y=this.maxDate?this.maxDate.clearTime(true):Number.POSITIVE_INFINITY,F=this.disabledDatesRE,s=this.disabledDatesText,I=this.disabledDays?this.disabledDays.join(""):false,E=this.disabledDaysText,z=this.format;if(this.showToday){var m=new Date().clearTime(),c=(m<u||m>y||(F&&z&&F.test(m.dateFormat(z)))||(I&&I.indexOf(m.getDay())!=-1));if(!this.disabled){this.todayBtn.setDisabled(c);this.todayKeyListener[c?"disable":"enable"]()}}var l=function(J,d){d.title="";var i=D.clearTime(true).getTime();d.firstChild.dateValue=i;if(i==C){d.className+=" x-date-today";d.title=J.todayText}if(i==v){d.className+=" x-date-selected";if(p){Ext.fly(d.firstChild).focus(50)}}if(i<u){d.className=" x-
 date-disabled";d.title=J.minText;return}if(i>y){d.className=" x-date-disabled";d.title=J.maxText;return}if(I){if(I.indexOf(D.getDay())!=-1){d.title=E;d.className=" x-date-disabled"}}if(F&&z){var w=D.dateFormat(z);if(F.test(w)){d.title=s.replace("%0",w);d.className=" x-date-disabled"}}};var x=0;for(;x<g;x++){r[x].innerHTML=(++h);D.setDate(D.getDate()+1);e[x].className="x-date-prevday";l(this,e[x])}for(;x<k;x++){var b=x-g+1;r[x].innerHTML=(b);D.setDate(D.getDate()+1);e[x].className="x-date-active";l(this,e[x])}var H=0;for(;x<42;x++){r[x].innerHTML=(++H);D.setDate(D.getDate()+1);e[x].className="x-date-nextday";l(this,e[x])}this.mbtn.setText(this.monthNames[G.getMonth()]+" "+G.getFullYear());if(!this.internalRender){var j=this.el.dom.firstChild,n=j.offsetWidth;this.el.setWidth(n+this.el.getBorderWidth("lr"));Ext.fly(j).setWidth(n);this.internalRender=true;if(Ext.isOpera&&!this.secondPass){j.rows[0].cells[1].style.width=(n-(j.rows[0].cells[0].offsetWidth+j.rows[0].cells[2].offset
 Width))+"px";this.secondPass=true;this.update.defer(10,this,[G])}}}},beforeDestroy:function(){if(this.rendered){Ext.destroy(this.keyNav,this.monthPicker,this.eventEl,this.mbtn,this.nextRepeater,this.prevRepeater,this.cells.el,this.todayBtn);delete this.textNodes;delete this.cells.elements}}});Ext.reg("datepicker",Ext.DatePicker);Ext.LoadMask=function(c,b){this.el=Ext.get(c);Ext.apply(this,b);if(this.store){this.store.on({scope:this,beforeload:this.onBeforeLoad,load:this.onLoad,exception:this.onLoad});this.removeMask=Ext.value(this.removeMask,false)}else{var a=this.el.getUpdater();a.showLoadIndicator=false;a.on({scope:this,beforeupdate:this.onBeforeLoad,update:this.onLoad,failure:this.onLoad});this.removeMask=Ext.value(this.removeMask,true)}};Ext.LoadMask.prototype={msg:"Loading...",msgCls:"x-mask-loading",disabled:false,disable:function(){this.disabled=true},enable:function(){this.disabled=false},onLoad:function(){this.el.unmask(this.removeMask)},onBeforeLoad:function(){if(!
 this.disabled){this.el.mask(this.msg,this.msgCls)}},show:function(){this.onBeforeLoad()},hide:function(){this.onLoad()},destroy:function(){if(this.store){this.store.un("beforeload",this.onBeforeLoad,this);this.store.un("load",this.onLoad,this);this.store.un("exception",this.onLoad,this)}else{var a=this.el.getUpdater();a.un("beforeupdate",this.onBeforeLoad,this);a.un("update",this.onLoad,this);a.un("failure",this.onLoad,this)}}};Ext.slider.Thumb=Ext.extend(Object,{dragging:false,constructor:function(a){Ext.apply(this,a||{},{cls:"x-slider-thumb",constrain:false});Ext.slider.Thumb.superclass.constructor.call(this,a);if(this.slider.vertical){Ext.apply(this,Ext.slider.Thumb.Vertical)}},render:function(){this.el=this.slider.innerEl.insertFirst({cls:this.cls});this.initEvents()},enable:function(){this.disabled=false;this.el.removeClass(this.slider.disabledClass)},disable:function(){this.disabled=true;this.el.addClass(this.slider.disabledClass)},initEvents:function(){var a=this.el;a
 .addClassOnOver("x-slider-thumb-over");this.tracker=new Ext.dd.DragTracker({onBeforeStart:this.onBeforeDragStart.createDelegate(this),onStart:this.onDragStart.createDelegate(this),onDrag:this.onDrag.createDelegate(this),onEnd:this.onDragEnd.createDelegate(this),tolerance:3,autoStart:300});this.tracker.initEl(a)},onBeforeDragStart:function(a){if(this.disabled){return false}else{this.slider.promoteThumb(this);return true}},onDragStart:function(a){this.el.addClass("x-slider-thumb-drag");this.dragging=true;this.dragStartValue=this.value;this.slider.fireEvent("dragstart",this.slider,a,this)},onDrag:function(g){var c=this.slider,b=this.index,d=this.getNewValue();if(this.constrain){var a=c.thumbs[b+1],h=c.thumbs[b-1];if(h!=undefined&&d<=h.value){d=h.value}if(a!=undefined&&d>=a.value){d=a.value}}c.setValue(b,d,false);c.fireEvent("drag",c,g,this)},getNewValue:function(){var a=this.slider,b=a.innerEl.translatePoints(this.tracker.getXY());return Ext.util.Format.round(a.reverseValue(b.l
 eft),a.decimalPrecision)},onDragEnd:function(c){var a=this.slider,b=this.value;this.el.removeClass("x-slider-thumb-drag");this.dragging=false;a.fireEvent("dragend",a,c);if(this.dragStartValue!=b){a.fireEvent("changecomplete",a,b,this)}},destroy:function(){Ext.destroyMembers(this,"tracker","el")}});Ext.slider.MultiSlider=Ext.extend(Ext.BoxComponent,{vertical:false,minValue:0,maxValue:100,decimalPrecision:0,keyIncrement:1,increment:0,clickRange:[5,15],clickToChange:true,animate:true,constrainThumbs:true,topThumbZIndex:10000,initComponent:function(){if(!Ext.isDefined(this.value)){this.value=this.minValue}this.thumbs=[];Ext.slider.MultiSlider.superclass.initComponent.call(this);this.keyIncrement=Math.max(this.increment,this.keyIncrement);this.addEvents("beforechange","change","changecomplete","dragstart","drag","dragend");if(this.values==undefined||Ext.isEmpty(this.values)){this.values=[0]}var a=this.values;for(var b=0;b<a.length;b++){this.addThumb(a[b])}if(this.vertical){Ext.ap
 ply(this,Ext.slider.Vertical)}},addThumb:function(b){var a=new Ext.slider.Thumb({value:b,slider:this,index:this.thumbs.length,constrain:this.constrainThumbs});this.thumbs.push(a);if(this.rendered){a.render()}},promoteThumb:function(d){var a=this.thumbs,g,b;for(var e=0,c=a.length;e<c;e++){b=a[e];if(b==d){g=this.topThumbZIndex}else{g=""}b.el.setStyle("zIndex",g)}},onRender:function(){this.autoEl={cls:"x-slider "+(this.vertical?"x-slider-vert":"x-slider-horz"),cn:{cls:"x-slider-end",cn:{cls:"x-slider-inner",cn:[{tag:"a",cls:"x-slider-focus",href:"#",tabIndex:"-1",hidefocus:"on"}]}}};Ext.slider.MultiSlider.superclass.onRender.apply(this,arguments);this.endEl=this.el.first();this.innerEl=this.endEl.first();this.focusEl=this.innerEl.child(".x-slider-focus");for(var b=0;b<this.thumbs.length;b++){this.thumbs[b].render()}var a=this.innerEl.child(".x-slider-thumb");this.halfThumb=(this.vertical?a.getHeight():a.getWidth())/2;this.initEvents()},initEvents:function(){this.mon(this.el,{sc
 ope:this,mousedown:this.onMouseDown,keydown:this.onKeyDown});this.focusEl.swallowEvent("click",true)},onMouseDown:function(d){if(this.disabled){return}var c=false;for(var b=0;b<this.thumbs.length;b++){c=c||d.target==this.thumbs[b].el.dom}if(this.clickToChange&&!c){var a=this.innerEl.translatePoints(d.getXY());this.onClickChange(a)}this.focus()},onClickChange:function(c){if(c.top>this.clickRange[0]&&c.top<this.clickRange[1]){var a=this.getNearest(c,"left"),b=a.index;this.setValue(b,Ext.util.Format.round(this.reverseValue(c.left),this.decimalPrecision),undefined,true)}},getNearest:function(k,b){var m=b=="top"?this.innerEl.getHeight()-k[b]:k[b],g=this.reverseValue(m),j=(this.maxValue-this.minValue)+5,e=0,c=null;for(var d=0;d<this.thumbs.length;d++){var a=this.thumbs[d],l=a.value,h=Math.abs(l-g);if(Math.abs(h<=j)){c=a;e=d;j=h}}return c},onKeyDown:function(b){if(this.disabled||this.thumbs.length!==1){b.preventDefault();return}var a=b.getKey(),c;switch(a){case b.UP:case b.RIGHT:b.
 stopEvent();c=b.ctrlKey?this.maxValue:this.getValue(0)+this.keyIncrement;this.setValue(0,c,undefined,true);break;case b.DOWN:case b.LEFT:b.stopEvent();c=b.ctrlKey?this.minValue:this.getValue(0)-this.keyIncrement;this.setValue(0,c,undefined,true);break;default:b.preventDefault()}},doSnap:function(b){if(!(this.increment&&b)){return b}var d=b,c=this.increment,a=b%c;if(a!=0){d-=a;if(a*2>=c){d+=c}else{if(a*2<-c){d-=c}}}return d.constrain(this.minValue,this.maxValue)},afterRender:function(){Ext.slider.MultiSlider.superclass.afterRender.apply(this,arguments);for(var c=0;c<this.thumbs.length;c++){var b=this.thumbs[c];if(b.value!==undefined){var a=this.normalizeValue(b.value);if(a!==b.value){this.setValue(c,a,false)}else{this.moveThumb(c,this.translateValue(a),false)}}}},getRatio:function(){var a=this.innerEl.getWidth(),b=this.maxValue-this.minValue;return b==0?a:(a/b)},normalizeValue:function(a){a=this.doSnap(a);a=Ext.util.Format.round(a,this.decimalPrecision);a=a.constrain(this.min
 Value,this.maxValue);return a},setMinValue:function(e){this.minValue=e;var d=0,b=this.thumbs,a=b.length,c;for(;d<a;++d){c=b[d];c.value=c.value<e?e:c.value}this.syncThumb()},setMaxValue:function(e){this.maxValue=e;var d=0,b=this.thumbs,a=b.length,c;for(;d<a;++d){c=b[d];c.value=c.value>e?e:c.value}this.syncThumb()},setValue:function(d,c,b,g){var a=this.thumbs[d],e=a.el;c=this.normalizeValue(c);if(c!==a.value&&this.fireEvent("beforechange",this,c,a.value,a)!==false){a.value=c;if(this.rendered){this.moveThumb(d,this.translateValue(c),b!==false);this.fireEvent("change",this,c,a);if(g){this.fireEvent("changecomplete",this,c,a)}}}},translateValue:function(a){var b=this.getRatio();return(a*b)-(this.minValue*b)-this.halfThumb},reverseValue:function(b){var a=this.getRatio();return(b+(this.minValue*a))/a},moveThumb:function(d,c,b){var a=this.thumbs[d].el;if(!b||this.animate===false){a.setLeft(c)}else{a.shift({left:c,stopFx:true,duration:0.35})}},focus:function(){this.focusEl.focus(10)}
 ,onResize:function(c,e){var b=this.thumbs,a=b.length,d=0;for(;d<a;++d){b[d].el.stopFx()}if(Ext.isNumber(c)){this.innerEl.setWidth(c-(this.el.getPadding("l")+this.endEl.getPadding("r")))}this.syncThumb();Ext.slider.MultiSlider.superclass.onResize.apply(this,arguments)},onDisable:function(){Ext.slider.MultiSlider.superclass.onDisable.call(this);for(var b=0;b<this.thumbs.length;b++){var a=this.thumbs[b],c=a.el;a.disable();if(Ext.isIE){var d=c.getXY();c.hide();this.innerEl.addClass(this.disabledClass).dom.disabled=true;if(!this.thumbHolder){this.thumbHolder=this.endEl.createChild({cls:"x-slider-thumb "+this.disabledClass})}this.thumbHolder.show().setXY(d)}}},onEnable:function(){Ext.slider.MultiSlider.superclass.onEnable.call(this);for(var b=0;b<this.thumbs.length;b++){var a=this.thumbs[b],c=a.el;a.enable();if(Ext.isIE){this.innerEl.removeClass(this.disabledClass).dom.disabled=false;if(this.thumbHolder){this.thumbHolder.hide()}c.show();this.syncThumb()}}},syncThumb:function(){if(
 this.rendered){for(var a=0;a<this.thumbs.length;a++){this.moveThumb(a,this.translateValue(this.thumbs[a].value))}}},getValue:function(a){return this.thumbs[a].value},getValues:function(){var a=[];for(var b=0;b<this.thumbs.length;b++){a.push(this.thumbs[b].value)}return a},beforeDestroy:function(){var b=this.thumbs;for(var c=0,a=b.length;c<a;++c){b[c].destroy();b[c]=null}Ext.destroyMembers(this,"endEl","innerEl","focusEl","thumbHolder");Ext.slider.MultiSlider.superclass.beforeDestroy.call(this)}});Ext.reg("multislider",Ext.slider.MultiSlider);Ext.slider.SingleSlider=Ext.extend(Ext.slider.MultiSlider,{constructor:function(a){a=a||{};Ext.applyIf(a,{values:[a.value||0]});Ext.slider.SingleSlider.superclass.constructor.call(this,a)},getValue:function(){return Ext.slider.SingleSlider.superclass.getValue.call(this,0)},setValue:function(d,b){var c=Ext.toArray(arguments),a=c.length;if(a==1||(a<=3&&typeof arguments[1]!="number")){c.unshift(0)}return Ext.slider.SingleSlider.superclass.s
 etValue.apply(this,c)},syncThumb:function(){return Ext.slider.SingleSlider.superclass.syncThumb.apply(this,[0].concat(arguments))},getNearest:function(){return this.thumbs[0]}});Ext.Slider=Ext.slider.SingleSlider;Ext.reg("slider",Ext.slider.SingleSlider);Ext.slider.Vertical={onResize:function(a,b){this.innerEl.setHeight(b-(this.el.getPadding("t")+this.endEl.getPadding("b")));this.syncThumb()},getRatio:function(){var b=this.innerEl.getHeight(),a=this.maxValue-this.minValue;return b/a},moveThumb:function(d,c,b){var a=this.thumbs[d],e=a.el;if(!b||this.animate===false){e.setBottom(c)}else{e.shift({bottom:c,stopFx:true,duration:0.35})}},onClickChange:function(c){if(c.left>this.clickRange[0]&&c.left<this.clickRange[1]){var a=this.getNearest(c,"top"),b=a.index,d=this.minValue+this.reverseValue(this.innerEl.getHeight()-c.top);this.setValue(b,Ext.util.Format.round(d,this.decimalPrecision),undefined,true)}}};Ext.slider.Thumb.Vertical={getNewValue:function(){var b=this.slider,c=b.inner
 El,d=c.translatePoints(this.tracker.getXY()),a=c.getHeight()-d.top;return b.minValue+Ext.util.Format.round(a/b.getRatio(),b.decimalPrecision)}};Ext.ProgressBar=Ext.extend(Ext.BoxComponent,{baseCls:"x-progress",animate:false,waitTimer:null,initComponent:function(){Ext.ProgressBar.superclass.initComponent.call(this);this.addEvents("update")},onRender:function(d,a){var c=new Ext.Template('<div class="{cls}-wrap">','<div class="{cls}-inner">','<div class="{cls}-bar">','<div class="{cls}-text">',"<div>&#160;</div>","</div>","</div>",'<div class="{cls}-text {cls}-text-back">',"<div>&#160;</div>","</div>","</div>","</div>");this.el=a?c.insertBefore(a,{cls:this.baseCls},true):c.append(d,{cls:this.baseCls},true);if(this.id){this.el.dom.id=this.id}var b=this.el.dom.firstChild;this.progressBar=Ext.get(b.firstChild);if(this.textEl){this.textEl=Ext.get(this.textEl);delete this.textTopEl}else{this.textTopEl=Ext.get(this.progressBar.dom.firstChild);var e=Ext.get(b.childNodes[1]);this.textT
 opEl.setStyle("z-index",99).addClass("x-hidden");this.textEl=new Ext.CompositeElement([this.textTopEl.dom.firstChild,e.dom.firstChild]);this.textEl.setWidth(b.offsetWidth)}this.progressBar.setHeight(b.offsetHeight)},afterRender:function(){Ext.ProgressBar.superclass.afterRender.call(this);if(this.value){this.updateProgress(this.value,this.text)}else{this.updateText(this.text)}},updateProgress:function(c,d,b){this.value=c||0;if(d){this.updateText(d)}if(this.rendered&&!this.isDestroyed){var a=Math.floor(c*this.el.dom.firstChild.offsetWidth);this.progressBar.setWidth(a,b===true||(b!==false&&this.animate));if(this.textTopEl){this.textTopEl.removeClass("x-hidden").setWidth(a)}}this.fireEvent("update",this,c,d);return this},wait:function(b){if(!this.waitTimer){var a=this;b=b||{};this.updateText(b.text);this.waitTimer=Ext.TaskMgr.start({run:function(c){var d=b.increment||10;c-=1;this.updateProgress(((((c+d)%d)+1)*(100/d))*0.01,null,b.animate)},interval:b.interval||1000,duration:b.du
 ration,onStop:function(){if(b.fn){b.fn.apply(b.scope||this)}this.reset()},scope:a})}return this},isWaiting:function(){return this.waitTimer!==null},updateText:function(a){this.text=a||"&#160;";if(this.rendered){this.textEl.update(this.text)}return this},syncProgressBar:function(){if(this.value){this.updateProgress(this.value,this.text)}return this},setSize:function(a,c){Ext.ProgressBar.superclass.setSize.call(this,a,c);if(this.textTopEl){var b=this.el.dom.firstChild;this.textEl.setSize(b.offsetWidth,b.offsetHeight)}this.syncProgressBar();return this},reset:function(a){this.updateProgress(0);if(this.textTopEl){this.textTopEl.addClass("x-hidden")}this.clearTimer();if(a===true){this.hide()}return this},clearTimer:function(){if(this.waitTimer){this.waitTimer.onStop=null;Ext.TaskMgr.stop(this.waitTimer);this.waitTimer=null}},onDestroy:function(){this.clearTimer();if(this.rendered){if(this.textEl.isComposite){this.textEl.clear()}Ext.destroyMembers(this,"textEl","progressBar","text
 TopEl")}Ext.ProgressBar.superclass.onDestroy.call(this)}});Ext.reg("progress",Ext.ProgressBar);(function(){var a=Ext.EventManager;var b=Ext.lib.Dom;Ext.dd.DragDrop=function(e,c,d){if(e){this.init(e,c,d)}};Ext.dd.DragDrop.prototype={id:null,config:null,dragElId:null,handleElId:null,invalidHandleTypes:null,invalidHandleIds:null,invalidHandleClasses:null,startPageX:0,startPageY:0,groups:null,locked:false,lock:function(){this.locked=true},moveOnly:false,unlock:function(){this.locked=false},isTarget:true,padding:null,_domRef:null,__ygDragDrop:true,constrainX:false,constrainY:false,minX:0,maxX:0,minY:0,maxY:0,maintainOffset:false,xTicks:null,yTicks:null,primaryButtonOnly:true,available:false,hasOuterHandles:false,b4StartDrag:function(c,d){},startDrag:function(c,d){},b4Drag:function(c){},onDrag:function(c){},onDragEnter:function(c,d){},b4DragOver:function(c){},onDragOver:function(c,d){},b4DragOut:function(c){},onDragOut:function(c,d){},b4DragDrop:function(c){},onDragDrop:function(c
 ,d){},onInvalidDrop:function(c){},b4EndDrag:function(c){},endDrag:function(c){},b4MouseDown:function(c){},onMouseDown:function(c){},onMouseUp:function(c){},onAvailable:function(){},defaultPadding:{left:0,right:0,top:0,bottom:0},constrainTo:function(j,h,o){if(Ext.isNumber(h)){h={left:h,right:h,top:h,bottom:h}}h=h||this.defaultPadding;var l=Ext.get(this.getEl()).getBox(),d=Ext.get(j),n=d.getScroll(),k,e=d.dom;if(e==document.body){k={x:n.left,y:n.top,width:Ext.lib.Dom.getViewWidth(),height:Ext.lib.Dom.getViewHeight()}}else{var m=d.getXY();k={x:m[0],y:m[1],width:e.clientWidth,height:e.clientHeight}}var i=l.y-k.y,g=l.x-k.x;this.resetConstraints();this.setXConstraint(g-(h.left||0),k.width-g-l.width-(h.right||0),this.xTickSize);this.setYConstraint(i-(h.top||0),k.height-i-l.height-(h.bottom||0),this.yTickSize)},getEl:function(){if(!this._domRef){this._domRef=Ext.getDom(this.id)}return this._domRef},getDragEl:function(){return Ext.getDom(this.dragElId)},init:function(e,c,d){this.init
 Target(e,c,d);a.on(this.id,"mousedown",this.handleMouseDown,this)},initTarget:function(e,c,d){this.config=d||{};this.DDM=Ext.dd.DDM;this.groups={};if(typeof e!=="string"){e=Ext.id(e)}this.id=e;this.addToGroup((c)?c:"default");this.handleElId=e;this.setDragElId(e);this.invalidHandleTypes={A:"A"};this.invalidHandleIds={};this.invalidHandleClasses=[];this.applyConfig();this.handleOnAvailable()},applyConfig:function(){this.padding=this.config.padding||[0,0,0,0];this.isTarget=(this.config.isTarget!==false);this.maintainOffset=(this.config.maintainOffset);this.primaryButtonOnly=(this.config.primaryButtonOnly!==false)},handleOnAvailable:function(){this.available=true;this.resetConstraints();this.onAvailable()},setPadding:function(e,c,g,d){if(!c&&0!==c){this.padding=[e,e,e,e]}else{if(!g&&0!==g){this.padding=[e,c,e,c]}else{this.padding=[e,c,g,d]}}},setInitPosition:function(g,e){var h=this.getEl();if(!this.DDM.verifyEl(h)){return}var d=g||0;var c=e||0;var i=b.getXY(h);this.initPageX=i
 [0]-d;this.initPageY=i[1]-c;this.lastPageX=i[0];this.lastPageY=i[1];this.setStartPosition(i)},setStartPosition:function(d){var c=d||b.getXY(this.getEl());this.deltaSetXY=null;this.startPageX=c[0];this.startPageY=c[1]},addToGroup:function(c){this.groups[c]=true;this.DDM.regDragDrop(this,c)},removeFromGroup:function(c){if(this.groups[c]){delete this.groups[c]}this.DDM.removeDDFromGroup(this,c)},setDragElId:function(c){this.dragElId=c},setHandleElId:function(c){if(typeof c!=="string"){c=Ext.id(c)}this.handleElId=c;this.DDM.regHandle(this.id,c)},setOuterHandleElId:function(c){if(typeof c!=="string"){c=Ext.id(c)}a.on(c,"mousedown",this.handleMouseDown,this);this.setHandleElId(c);this.hasOuterHandles=true},unreg:function(){a.un(this.id,"mousedown",this.handleMouseDown);this._domRef=null;this.DDM._remove(this)},destroy:function(){this.unreg()},isLocked:function(){return(this.DDM.isLocked()||this.locked)},handleMouseDown:function(g,d){if(this.primaryButtonOnly&&g.button!=0){return}i
 f(this.isLocked()){return}this.DDM.refreshCache(this.groups);var c=new Ext.lib.Point(Ext.lib.Event.getPageX(g),Ext.lib.Event.getPageY(g));if(!this.hasOuterHandles&&!this.DDM.isOverTarget(c,this)){}else{if(this.clickValidator(g)){this.setStartPosition();this.b4MouseDown(g);this.onMouseDown(g);this.DDM.handleMouseDown(g,this);this.DDM.stopEvent(g)}else{}}},clickValidator:function(d){var c=d.getTarget();return(this.isValidHandleChild(c)&&(this.id==this.handleElId||this.DDM.handleWasClicked(c,this.id)))},addInvalidHandleType:function(c){var d=c.toUpperCase();this.invalidHandleTypes[d]=d},addInvalidHandleId:function(c){if(typeof c!=="string"){c=Ext.id(c)}this.invalidHandleIds[c]=c},addInvalidHandleClass:function(c){this.invalidHandleClasses.push(c)},removeInvalidHandleType:function(c){var d=c.toUpperCase();delete this.invalidHandleTypes[d]},removeInvalidHandleId:function(c){if(typeof c!=="string"){c=Ext.id(c)}delete this.invalidHandleIds[c]},removeInvalidHandleClass:function(d){f
 or(var e=0,c=this.invalidHandleClasses.length;e<c;++e){if(this.invalidHandleClasses[e]==d){delete this.invalidHandleClasses[e]}}},isValidHandleChild:function(h){var g=true;var k;try{k=h.nodeName.toUpperCase()}catch(j){k=h.nodeName}g=g&&!this.invalidHandleTypes[k];g=g&&!this.invalidHandleIds[h.id];for(var d=0,c=this.invalidHandleClasses.length;g&&d<c;++d){g=!Ext.fly(h).hasClass(this.invalidHandleClasses[d])}return g},setXTicks:function(g,c){this.xTicks=[];this.xTickSize=c;var e={};for(var d=this.initPageX;d>=this.minX;d=d-c){if(!e[d]){this.xTicks[this.xTicks.length]=d;e[d]=true}}for(d=this.initPageX;d<=this.maxX;d=d+c){if(!e[d]){this.xTicks[this.xTicks.length]=d;e[d]=true}}this.xTicks.sort(this.DDM.numericSort)},setYTicks:function(g,c){this.yTicks=[];this.yTickSize=c;var e={};for(var d=this.initPageY;d>=this.minY;d=d-c){if(!e[d]){this.yTicks[this.yTicks.length]=d;e[d]=true}}for(d=this.initPageY;d<=this.maxY;d=d+c){if(!e[d]){this.yTicks[this.yTicks.length]=d;e[d]=true}}this.yT
 icks.sort(this.DDM.numericSort)},setXConstraint:function(e,d,c){this.leftConstraint=e;this.rightConstraint=d;this.minX=this.initPageX-e;this.maxX=this.initPageX+d;if(c){this.setXTicks(this.initPageX,c)}this.constrainX=true},clearConstraints:function(){this.constrainX=false;this.constrainY=false;this.clearTicks()},clearTicks:function(){this.xTicks=null;this.yTicks=null;this.xTickSize=0;this.yTickSize=0},setYConstraint:function(c,e,d){this.topConstraint=c;this.bottomConstraint=e;this.minY=this.initPageY-c;this.maxY=this.initPageY+e;if(d){this.setYTicks(this.initPageY,d)}this.constrainY=true},resetConstraints:function(){if(this.initPageX||this.initPageX===0){var d=(this.maintainOffset)?this.lastPageX-this.initPageX:0;var c=(this.maintainOffset)?this.lastPageY-this.initPageY:0;this.setInitPosition(d,c)}else{this.setInitPosition()}if(this.constrainX){this.setXConstraint(this.leftConstraint,this.rightConstraint,this.xTickSize)}if(this.constrainY){this.setYConstraint(this.topConstr
 aint,this.bottomConstraint,this.yTickSize)}},getTick:function(k,g){if(!g){return k}else{if(g[0]>=k){return g[0]}else{for(var d=0,c=g.length;d<c;++d){var e=d+1;if(g[e]&&g[e]>=k){var j=k-g[d];var h=g[e]-k;return(h>j)?g[d]:g[e]}}return g[g.length-1]}}},toString:function(){return("DragDrop "+this.id)}}})();if(!Ext.dd.DragDropMgr){Ext.dd.DragDropMgr=function(){var a=Ext.EventManager;return{ids:{},handleIds:{},dragCurrent:null,dragOvers:{},deltaX:0,deltaY:0,preventDefault:true,stopPropagation:true,initialized:false,locked:false,init:function(){this.initialized=true},POINT:0,INTERSECT:1,mode:0,_execOnAll:function(d,c){for(var e in this.ids){for(var b in this.ids[e]){var g=this.ids[e][b];if(!this.isTypeOfDD(g)){continue}g[d].apply(g,c)}}},_onLoad:function(){this.init();a.on(document,"mouseup",this.handleMouseUp,this,true);a.on(document,"mousemove",this.handleMouseMove,this,true);a.on(window,"unload",this._onUnload,this,true);a.on(window,"resize",this._onResize,this,true)},_onResize:
 function(b){this._execOnAll("resetConstraints",[])},lock:function(){this.locked=true},unlock:function(){this.locked=false},isLocked:function(){return this.locked},locationCache:{},useCache:true,clickPixelThresh:3,clickTimeThresh:350,dragThreshMet:false,clickTimeout:null,startX:0,startY:0,regDragDrop:function(c,b){if(!this.initialized){this.init()}if(!this.ids[b]){this.ids[b]={}}this.ids[b][c.id]=c},removeDDFromGroup:function(d,b){if(!this.ids[b]){this.ids[b]={}}var c=this.ids[b];if(c&&c[d.id]){delete c[d.id]}},_remove:function(c){for(var b in c.groups){if(b&&this.ids[b]&&this.ids[b][c.id]){delete this.ids[b][c.id]}}delete this.handleIds[c.id]},regHandle:function(c,b){if(!this.handleIds[c]){this.handleIds[c]={}}this.handleIds[c][b]=b},isDragDrop:function(b){return(this.getDDById(b))?true:false},getRelated:function(h,c){var g=[];for(var e in h.groups){for(var d in this.ids[e]){var b=this.ids[e][d];if(!this.isTypeOfDD(b)){continue}if(!c||b.isTarget){g[g.length]=b}}}return g},is
 LegalTarget:function(g,e){var c=this.getRelated(g,true);for(var d=0,b=c.length;d<b;++d){if(c[d].id==e.id){return true}}return false},isTypeOfDD:function(b){return(b&&b.__ygDragDrop)},isHandle:function(c,b){return(this.handleIds[c]&&this.handleIds[c][b])},getDDById:function(c){for(var b in this.ids){if(this.ids[b][c]){return this.ids[b][c]}}return null},handleMouseDown:function(d,c){if(Ext.QuickTips){Ext.QuickTips.ddDisable()}if(this.dragCurrent){this.handleMouseUp(d)}this.currentTarget=d.getTarget();this.dragCurrent=c;var b=c.getEl();this.startX=d.getPageX();this.startY=d.getPageY();this.deltaX=this.startX-b.offsetLeft;this.deltaY=this.startY-b.offsetTop;this.dragThreshMet=false;this.clickTimeout=setTimeout(function(){var e=Ext.dd.DDM;e.startDrag(e.startX,e.startY)},this.clickTimeThresh)},startDrag:function(b,c){clearTimeout(this.clickTimeout);if(this.dragCurrent){this.dragCurrent.b4StartDrag(b,c);this.dragCurrent.startDrag(b,c)}this.dragThreshMet=true},handleMouseUp:functio
 n(b){if(Ext.QuickTips){Ext.QuickTips.ddEnable()}if(!this.dragCurrent){return}clearTimeout(this.clickTimeout);if(this.dragThreshMet){this.fireEvents(b,true)}else{}this.stopDrag(b);this.stopEvent(b)},stopEvent:function(b){if(this.stopPropagation){b.stopPropagation()}if(this.preventDefault){b.preventDefault()}},stopDrag:function(b){if(this.dragCurrent){if(this.dragThreshMet){this.dragCurrent.b4EndDrag(b);this.dragCurrent.endDrag(b)}this.dragCurrent.onMouseUp(b)}this.dragCurrent=null;this.dragOvers={}},handleMouseMove:function(d){if(!this.dragCurrent){return true}if(Ext.isIE&&(d.button!==0&&d.button!==1&&d.button!==2)){this.stopEvent(d);return this.handleMouseUp(d)}if(!this.dragThreshMet){var c=Math.abs(this.startX-d.getPageX());var b=Math.abs(this.startY-d.getPageY());if(c>this.clickPixelThresh||b>this.clickPixelThresh){this.startDrag(this.startX,this.startY)}}if(this.dragThreshMet){this.dragCurrent.b4Drag(d);this.dragCurrent.onDrag(d);if(!this.dragCurrent.moveOnly){this.fireEv
 ents(d,false)}}this.stopEvent(d);return true},fireEvents:function(n,o){var q=this.dragCurrent;if(!q||q.isLocked()){return}var r=n.getPoint();var b=[];var g=[];var l=[];var j=[];var d=[];for(var h in this.dragOvers){var c=this.dragOvers[h];if(!this.isTypeOfDD(c)){continue}if(!this.isOverTarget(r,c,this.mode)){g.push(c)}b[h]=true;delete this.dragOvers[h]}for(var p in q.groups){if("string"!=typeof p){continue}for(h in this.ids[p]){var k=this.ids[p][h];if(!this.isTypeOfDD(k)){continue}if(k.isTarget&&!k.isLocked()&&((k!=q)||(q.ignoreSelf===false))){if(this.isOverTarget(r,k,this.mode)){if(o){j.push(k)}else{if(!b[k.id]){d.push(k)}else{l.push(k)}this.dragOvers[k.id]=k}}}}}if(this.mode){if(g.length){q.b4DragOut(n,g);q.onDragOut(n,g)}if(d.length){q.onDragEnter(n,d)}if(l.length){q.b4DragOver(n,l);q.onDragOver(n,l)}if(j.length){q.b4DragDrop(n,j);q.onDragDrop(n,j)}}else{var m=0;for(h=0,m=g.length;h<m;++h){q.b4DragOut(n,g[h].id);q.onDragOut(n,g[h].id)}for(h=0,m=d.length;h<m;++h){q.onDragE
 nter(n,d[h].id)}for(h=0,m=l.length;h<m;++h){q.b4DragOver(n,l[h].id);q.onDragOver(n,l[h].id)}for(h=0,m=j.length;h<m;++h){q.b4DragDrop(n,j[h].id);q.onDragDrop(n,j[h].id)}}if(o&&!j.length){q.onInvalidDrop(n)}},getBestMatch:function(d){var g=null;var c=d.length;if(c==1){g=d[0]}else{for(var e=0;e<c;++e){var b=d[e];if(b.cursorIsOver){g=b;break}else{if(!g||g.overlap.getArea()<b.overlap.getArea()){g=b}}}}return g},refreshCache:function(c){for(var b in c){if("string"!=typeof b){continue}for(var d in this.ids[b]){var e=this.ids[b][d];if(this.isTypeOfDD(e)){var g=this.getLocation(e);if(g){this.locationCache[e.id]=g}else{delete this.locationCache[e.id]}}}}},verifyEl:function(c){if(c){var b;if(Ext.isIE){try{b=c.offsetParent}catch(d){}}else{b=c.offsetParent}if(b){return true}}return false},getLocation:function(j){if(!this.isTypeOfDD(j)){return null}var h=j.getEl(),o,g,d,q,p,s,c,n,i,m;try{o=Ext.lib.Dom.getXY(h)}catch(k){}if(!o){return null}g=o[0];d=g+h.offsetWidth;q=o[1];p=q+h.offsetHeight
 ;s=q-j.padding[0];c=d+j.padding[1];n=p+j.padding[2];i=g-j.padding[3];m=new Ext.lib.Region(s,c,n,i);h=Ext.get(h.parentNode);while(h&&m){if(h.isScrollable()){m=m.intersect(h.getRegion())}h=h.parent()}return m},isOverTarget:function(k,b,d){var g=this.locationCache[b.id];if(!g||!this.useCache){g=this.getLocation(b);this.locationCache[b.id]=g}if(!g){return false}b.cursorIsOver=g.contains(k);var j=this.dragCurrent;if(!j||!j.getTargetCoord||(!d&&!j.constrainX&&!j.constrainY)){return b.cursorIsOver}b.overlap=null;var h=j.getTargetCoord(k.x,k.y);var c=j.getDragEl();var e=new Ext.lib.Region(h.y,h.x+c.offsetWidth,h.y+c.offsetHeight,h.x);var i=e.intersect(g);if(i){b.overlap=i;return(d)?true:b.cursorIsOver}else{return false}},_onUnload:function(c,b){a.removeListener(document,"mouseup",this.handleMouseUp,this);a.removeListener(document,"mousemove",this.handleMouseMove,this);a.removeListener(window,"resize",this._onResize,this);Ext.dd.DragDropMgr.unregAll()},unregAll:function(){if(this.dra
 gCurrent){this.stopDrag();this.dragCurrent=null}this._execOnAll("unreg",[]);for(var b in this.elementCache){delete this.elementCache[b]}this.elementCache={};this.ids={}},elementCache:{},getElWrapper:function(c){var b=this.elementCache[c];if(!b||!b.el){b=this.elementCache[c]=new this.ElementWrapper(Ext.getDom(c))}return b},getElement:function(b){return Ext.getDom(b)},getCss:function(c){var b=Ext.getDom(c);return(b)?b.style:null},ElementWrapper:function(b){this.el=b||null;this.id=this.el&&b.id;this.css=this.el&&b.style},getPosX:function(b){return Ext.lib.Dom.getX(b)},getPosY:function(b){return Ext.lib.Dom.getY(b)},swapNode:function(d,b){if(d.swapNode){d.swapNode(b)}else{var e=b.parentNode;var c=b.nextSibling;if(c==d){e.insertBefore(d,b)}else{if(b==d.nextSibling){e.insertBefore(b,d)}else{d.parentNode.replaceChild(b,d);e.insertBefore(d,c)}}}},getScroll:function(){var d,b,e=document.documentElement,c=document.body;if(e&&(e.scrollTop||e.scrollLeft)){d=e.scrollTop;b=e.scrollLeft}el
 se{if(c){d=c.scrollTop;b=c.scrollLeft}else{}}return{top:d,left:b}},getStyle:function(c,b){return Ext.fly(c).getStyle(b)},getScrollTop:function(){return this.getScroll().top},getScrollLeft:function(){return this.getScroll().left},moveToEl:function(b,d){var c=Ext.lib.Dom.getXY(d);Ext.lib.Dom.setXY(b,c)},numericSort:function(d,c){return(d-c)},_timeoutCount:0,_addListeners:function(){var b=Ext.dd.DDM;if(Ext.lib.Event&&document){b._onLoad()}else{if(b._timeoutCount>2000){}else{setTimeout(b._addListeners,10);if(document&&document.body){b._timeoutCount+=1}}}},handleWasClicked:function(b,d){if(this.isHandle(d,b.id)){return true}else{var c=b.parentNode;while(c){if(this.isHandle(d,c.id)){return true}else{c=c.parentNode}}}return false}}}();Ext.dd.DDM=Ext.dd.DragDropMgr;Ext.dd.DDM._addListeners()}Ext.dd.DD=function(c,a,b){if(c){this.init(c,a,b)}};Ext.extend(Ext.dd.DD,Ext.dd.DragDrop,{scroll:true,autoOffset:function(c,b){var a=c-this.startPageX;var d=b-this.startPageY;this.setDelta(a,d)},
 setDelta:function(b,a){this.deltaX=b;this.deltaY=a},setDragElPos:function(c,b){var a=this.getDragEl();this.alignElWithMouse(a,c,b)},alignElWithMouse:function(c,h,g){var e=this.getTargetCoord(h,g);var b=c.dom?c:Ext.fly(c,"_dd");if(!this.deltaSetXY){var i=[e.x,e.y];b.setXY(i);var d=b.getLeft(true);var a=b.getTop(true);this.deltaSetXY=[d-e.x,a-e.y]}else{b.setLeftTop(e.x+this.deltaSetXY[0],e.y+this.deltaSetXY[1])}this.cachePosition(e.x,e.y);this.autoScroll(e.x,e.y,c.offsetHeight,c.offsetWidth);return e},cachePosition:function(b,a){if(b){this.lastPageX=b;this.lastPageY=a}else{var c=Ext.lib.Dom.getXY(this.getEl());this.lastPageX=c[0];this.lastPageY=c[1]}},autoScroll:function(l,k,e,m){if(this.scroll){var n=Ext.lib.Dom.getViewHeight();var b=Ext.lib.Dom.getViewWidth();var p=this.DDM.getScrollTop();var d=this.DDM.getScrollLeft();var j=e+k;var o=m+l;var i=(n+p-k-this.deltaY);var g=(b+d-l-this.deltaX);var c=40;var a=(document.all)?80:30;if(j>n&&i<c){window.scrollTo(d,p+a)}if(k<p&&p>0&&k
 -p<c){window.scrollTo(d,p-a)}if(o>b&&g<c){window.scrollTo(d+a,p)}if(l<d&&d>0&&l-d<c){window.scrollTo(d-a,p)}}},getTargetCoord:function(c,b){var a=c-this.deltaX;var d=b-this.deltaY;if(this.constrainX){if(a<this.minX){a=this.minX}if(a>this.maxX){a=this.maxX}}if(this.constrainY){if(d<this.minY){d=this.minY}if(d>this.maxY){d=this.maxY}}a=this.getTick(a,this.xTicks);d=this.getTick(d,this.yTicks);return{x:a,y:d}},applyConfig:function(){Ext.dd.DD.superclass.applyConfig.call(this);this.scroll=(this.config.scroll!==false)},b4MouseDown:function(a){this.autoOffset(a.getPageX(),a.getPageY())},b4Drag:function(a){this.setDragElPos(a.getPageX(),a.getPageY())},toString:function(){return("DD "+this.id)}});Ext.dd.DDProxy=function(c,a,b){if(c){this.init(c,a,b);this.initFrame()}};Ext.dd.DDProxy.dragElId="ygddfdiv";Ext.extend(Ext.dd.DDProxy,Ext.dd.DD,{resizeFrame:true,centerFrame:false,createFrame:function(){var b=this;var a=document.body;if(!a||!a.firstChild){setTimeout(function(){b.createFrame
 ()},50);return}var d=this.getDragEl();if(!d){d=document.createElement("div");d.id=this.dragElId;var c=d.style;c.position="absolute";c.visibility="hidden";c.cursor="move";c.border="2px solid #aaa";c.zIndex=999;a.insertBefore(d,a.firstChild)}},initFrame:function(){this.createFrame()},applyConfig:function(){Ext.dd.DDProxy.superclass.applyConfig.call(this);this.resizeFrame=(this.config.resizeFrame!==false);this.centerFrame=(this.config.centerFrame);this.setDragElId(this.config.dragElId||Ext.dd.DDProxy.dragElId)},showFrame:function(e,d){var c=this.getEl();var a=this.getDragEl();var b=a.style;this._resizeProxy();if(this.centerFrame){this.setDelta(Math.round(parseInt(b.width,10)/2),Math.round(parseInt(b.height,10)/2))}this.setDragElPos(e,d);Ext.fly(a).show()},_resizeProxy:function(){if(this.resizeFrame){var a=this.getEl();Ext.fly(this.getDragEl()).setSize(a.offsetWidth,a.offsetHeight)}},b4MouseDown:function(b){var a=b.getPageX();var c=b.getPageY();this.autoOffset(a,c);this.setDragE
 lPos(a,c)},b4StartDrag:function(a,b){this.showFrame(a,b)},b4EndDrag:function(a){Ext.fly(this.getDragEl()).hide()},endDrag:function(c){var b=this.getEl();var a=this.getDragEl();a.style.visibility="";this.beforeMove();b.style.visibility="hidden";Ext.dd.DDM.moveToEl(b,a);a.style.visibility="hidden";b.style.visibility="";this.afterDrag()},beforeMove:function(){},afterDrag:function(){},toString:function(){return("DDProxy "+this.id)}});Ext.dd.DDTarget=function(c,a,b){if(c){this.initTarget(c,a,b)}};Ext.extend(Ext.dd.DDTarget,Ext.dd.DragDrop,{getDragEl:Ext.emptyFn,isValidHandleChild:Ext.emptyFn,startDrag:Ext.emptyFn,endDrag:Ext.emptyFn,onDrag:Ext.emptyFn,onDragDrop:Ext.emptyFn,onDragEnter:Ext.emptyFn,onDragOut:Ext.emptyFn,onDragOver:Ext.emptyFn,onInvalidDrop:Ext.emptyFn,onMouseDown:Ext.emptyFn,onMouseUp:Ext.emptyFn,setXConstraint:Ext.emptyFn,setYConstraint:Ext.emptyFn,resetConstraints:Ext.emptyFn,clearConstraints:Ext.emptyFn,clearTicks:Ext.emptyFn,setInitPosition:Ext.emptyFn,setDrag
 ElId:Ext.emptyFn,setHandleElId:Ext.emptyFn,setOuterHandleElId:Ext.emptyFn,addInvalidHandleClass:Ext.emptyFn,addInvalidHandleId:Ext.emptyFn,addInvalidHandleType:Ext.emptyFn,removeInvalidHandleClass:Ext.emptyFn,removeInvalidHandleId:Ext.emptyFn,removeInvalidHandleType:Ext.emptyFn,toString:function(){return("DDTarget "+this.id)}});Ext.dd.DragTracker=Ext.extend(Ext.util.Observable,{active:false,tolerance:5,autoStart:false,constructor:function(a){Ext.apply(this,a);this.addEvents("mousedown","mouseup","mousemove","dragstart","dragend","drag");this.dragRegion=new Ext.lib.Region(0,0,0,0);if(this.el){this.initEl(this.el)}Ext.dd.DragTracker.superclass.constructor.call(this,a)},initEl:function(a){this.el=Ext.get(a);a.on("mousedown",this.onMouseDown,this,this.delegate?{delegate:this.delegate}:undefined)},destroy:function(){this.el.un("mousedown",this.onMouseDown,this);delete this.el},onMouseDown:function(b,a){if(this.fireEvent("mousedown",this,b)!==false&&this.onBeforeStart(b)!==false){
 this.startXY=this.lastXY=b.getXY();this.dragTarget=this.delegate?a:this.el.dom;if(this.preventDefault!==false){b.preventDefault()}Ext.getDoc().on({scope:this,mouseup:this.onMouseUp,mousemove:this.onMouseMove,selectstart:this.stopSelect});if(this.autoStart){this.timer=this.triggerStart.defer(this.autoStart===true?1000:this.autoStart,this,[b])}}},onMouseMove:function(d,c){if(this.active&&Ext.isIE&&!d.browserEvent.button){d.preventDefault();this.onMouseUp(d);return}d.preventDefault();var b=d.getXY(),a=this.startXY;this.lastXY=b;if(!this.active){if(Math.abs(a[0]-b[0])>this.tolerance||Math.abs(a[1]-b[1])>this.tolerance){this.triggerStart(d)}else{return}}this.fireEvent("mousemove",this,d);this.onDrag(d);this.fireEvent("drag",this,d)},onMouseUp:function(c){var b=Ext.getDoc(),a=this.active;b.un("mousemove",this.onMouseMove,this);b.un("mouseup",this.onMouseUp,this);b.un("selectstart",this.stopSelect,this);c.preventDefault();this.clearStart();this.active=false;delete this.elRegion;thi
 s.fireEvent("mouseup",this,c);if(a){this.onEnd(c);this.fireEvent("dragend",this,c)}},triggerStart:function(a){this.clearStart();this.active=true;this.onStart(a);this.fireEvent("dragstart",this,a)},clearStart:function(){if(this.timer){clearTimeout(this.timer);delete this.timer}},stopSelect:function(a){a.stopEvent();return false},onBeforeStart:function(a){},onStart:function(a){},onDrag:function(a){},onEnd:function(a){},getDragTarget:function(){return this.dragTarget},getDragCt:function(){return this.el},getXY:function(a){return a?this.constrainModes[a].call(this,this.lastXY):this.lastXY},getOffset:function(c){var b=this.getXY(c),a=this.startXY;return[a[0]-b[0],a[1]-b[1]]},constrainModes:{point:function(b){if(!this.elRegion){this.elRegion=this.getDragCt().getRegion()}var a=this.dragRegion;a.left=b[0];a.top=b[1];a.right=b[0];a.bottom=b[1];a.constrainTo(this.elRegion);return[a.left,a.top]}}});Ext.dd.ScrollManager=function(){var c=Ext.dd.DragDropMgr;var e={};var b=null;var i={};va
 r h=function(l){b=null;a()};var j=function(){if(c.dragCurrent){c.refreshCache(c.dragCurrent.groups)}};var d=function(){if(c.dragCurrent){var l=Ext.dd.ScrollManager;var m=i.el.ddScrollConfig?i.el.ddScrollConfig.increment:l.increment;if(!l.animate){if(i.el.scroll(i.dir,m)){j()}}else{i.el.scroll(i.dir,m,true,l.animDuration,j)}}};var a=function(){if(i.id){clearInterval(i.id)}i.id=0;i.el=null;i.dir=""};var g=function(m,l){a();i.el=m;i.dir=l;var o=m.ddScrollConfig?m.ddScrollConfig.ddGroup:undefined,n=(m.ddScrollConfig&&m.ddScrollConfig.frequency)?m.ddScrollConfig.frequency:Ext.dd.ScrollManager.frequency;if(o===undefined||c.dragCurrent.ddGroup==o){i.id=setInterval(d,n)}};var k=function(o,q){if(q||!c.dragCurrent){return}var s=Ext.dd.ScrollManager;if(!b||b!=c.dragCurrent){b=c.dragCurrent;s.refreshCache()}var t=Ext.lib.Event.getXY(o);var u=new Ext.lib.Point(t[0],t[1]);for(var m in e){var n=e[m],l=n._region;var p=n.ddScrollConfig?n.ddScrollConfig:s;if(l&&l.contains(u)&&n.isScrollable()
 ){if(l.bottom-u.y<=p.vthresh){if(i.el!=n){g(n,"down")}return}else{if(l.right-u.x<=p.hthresh){if(i.el!=n){g(n,"left")}return}else{if(u.y-l.top<=p.vthresh){if(i.el!=n){g(n,"up")}return}else{if(u.x-l.left<=p.hthresh){if(i.el!=n){g(n,"right")}return}}}}}}a()};c.fireEvents=c.fireEvents.createSequence(k,c);c.stopDrag=c.stopDrag.createSequence(h,c);return{register:function(n){if(Ext.isArray(n)){for(var m=0,l=n.length;m<l;m++){this.register(n[m])}}else{n=Ext.get(n);e[n.id]=n}},unregister:function(n){if(Ext.isArray(n)){for(var m=0,l=n.length;m<l;m++){this.unregister(n[m])}}else{n=Ext.get(n);delete e[n.id]}},vthresh:25,hthresh:25,increment:100,frequency:500,animate:true,animDuration:0.4,ddGroup:undefined,refreshCache:function(){for(var l in e){if(typeof e[l]=="object"){e[l]._region=e[l].getRegion()}}}}}();Ext.dd.Registry=function(){var d={};var b={};var a=0;var c=function(g,e){if(typeof g=="string"){return g}var h=g.id;if(!h&&e!==false){h="extdd-"+(++a);g.id=h}return h};return{registe
 r:function(j,k){k=k||{};if(typeof j=="string"){j=document.getElementById(j)}k.ddel=j;d[c(j)]=k;if(k.isHandle!==false){b[k.ddel.id]=k}if(k.handles){var h=k.handles;for(var g=0,e=h.length;g<e;g++){b[c(h[g])]=k}}},unregister:function(j){var l=c(j,false);var k=d[l];if(k){delete d[l];if(k.handles){var h=k.handles;for(var g=0,e=h.length;g<e;g++){delete b[c(h[g],false)]}}}},getHandle:function(e){if(typeof e!="string"){e=e.id}return b[e]},getHandleFromEvent:function(h){var g=Ext.lib.Event.getTarget(h);return g?b[g.id]:null},getTarget:function(e){if(typeof e!="string"){e=e.id}return d[e]},getTargetFromEvent:function(h){var g=Ext.lib.Event.getTarget(h);return g?d[g.id]||b[g.id]:null}}}();Ext.dd.StatusProxy=function(a){Ext.apply(this,a);this.id=this.id||Ext.id();this.el=new Ext.Layer({dh:{id:this.id,tag:"div",cls:"x-dd-drag-proxy "+this.dropNotAllowed,children:[{tag:"div",cls:"x-dd-drop-icon"},{tag:"div",cls:"x-dd-drag-ghost"}]},shadow:!a||a.shadow!==false});this.ghost=Ext.get(this.el.
 dom.childNodes[1]);this.dropStatus=this.dropNotAllowed};Ext.dd.StatusProxy.prototype={dropAllowed:"x-dd-drop-ok",dropNotAllowed:"x-dd-drop-nodrop",setStatus:function(a){a=a||this.dropNotAllowed;if(this.dropStatus!=a){this.el.replaceClass(this.dropStatus,a);this.dropStatus=a}},reset:function(a){this.el.dom.className="x-dd-drag-proxy "+this.dropNotAllowed;this.dropStatus=this.dropNotAllowed;if(a){this.ghost.update("")}},update:function(a){if(typeof a=="string"){this.ghost.update(a)}else{this.ghost.update("");a.style.margin="0";this.ghost.dom.appendChild(a)}var b=this.ghost.dom.firstChild;if(b){Ext.fly(b).setStyle("float","none")}},getEl:function(){return this.el},getGhost:function(){return this.ghost},hide:function(a){this.el.hide();if(a){this.reset(true)}},stop:function(){if(this.anim&&this.anim.isAnimated&&this.anim.isAnimated()){this.anim.stop()}},show:function(){this.el.show()},sync:function(){this.el.sync()},repair:function(b,c,a){this.callback=c;this.scope=a;if(b&&this.a
 nimRepair!==false){this.el.addClass("x-dd-drag-repair");this.el.hideUnders(true);this.anim=this.el.shift({duration:this.repairDuration||0.5,easing:"easeOut",xy:b,stopFx:true,callback:this.afterRepair,scope:this})}else{this.afterRepair()}},afterRepair:function(){this.hide(true);if(typeof this.callback=="function"){this.callback.call(this.scope||this)}this.callback=null;this.scope=null},destroy:function(){Ext.destroy(this.ghost,this.el)}};Ext.dd.DragSource=function(b,a){this.el=Ext.get(b);if(!this.dragData){this.dragData={}}Ext.apply(this,a);if(!this.proxy){this.proxy=new Ext.dd.StatusProxy()}Ext.dd.DragSource.superclass.constructor.call(this,this.el.dom,this.ddGroup||this.group,{dragElId:this.proxy.id,resizeFrame:false,isTarget:false,scroll:this.scroll===true});this.dragging=false};Ext.extend(Ext.dd.DragSource,Ext.dd.DDProxy,{dropAllowed:"x-dd-drop-ok",dropNotAllowed:"x-dd-drop-nodrop",getDragData:function(a){return this.dragData},onDragEnter:function(c,d){var b=Ext.dd.DragDr
 opMgr.getDDById(d);this.cachedTarget=b;if(this.beforeDragEnter(b,c,d)!==false){if(b.isNotifyTarget){var a=b.notifyEnter(this,c,this.dragData);this.proxy.setStatus(a)}else{this.proxy.setStatus(this.dropAllowed)}if(this.afterDragEnter){this.afterDragEnter(b,c,d)}}},beforeDragEnter:function(b,a,c){return true},alignElWithMouse:function(){Ext.dd.DragSource.superclass.alignElWithMouse.apply(this,arguments);this.proxy.sync()},onDragOver:function(c,d){var b=this.cachedTarget||Ext.dd.DragDropMgr.getDDById(d);if(this.beforeDragOver(b,c,d)!==false){if(b.isNotifyTarget){var a=b.notifyOver(this,c,this.dragData);this.proxy.setStatus(a)}if(this.afterDragOver){this.afterDragOver(b,c,d)}}},beforeDragOver:function(b,a,c){return true},onDragOut:function(b,c){var a=this.cachedTarget||Ext.dd.DragDropMgr.getDDById(c);if(this.beforeDragOut(a,b,c)!==false){if(a.isNotifyTarget){a.notifyOut(this,b,this.dragData)}this.proxy.reset();if(this.afterDragOut){this.afterDragOut(a,b,c)}}this.cachedTarget=nul
 l},beforeDragOut:function(b,a,c){return true},onDragDrop:function(b,c){var a=this.cachedTarget||Ext.dd.DragDropMgr.getDDById(c);if(this.beforeDragDrop(a,b,c)!==false){if(a.isNotifyTarget){if(a.notifyDrop(this,b,this.dragData)){this.onValidDrop(a,b,c)}else{this.onInvalidDrop(a,b,c)}}else{this.onValidDrop(a,b,c)}if(this.afterDragDrop){this.afterDragDrop(a,b,c)}}delete this.cachedTarget},beforeDragDrop:function(b,a,c){return true},onValidDrop:function(b,a,c){this.hideProxy();if(this.afterValidDrop){this.afterValidDrop(b,a,c)}},getRepairXY:function(b,a){return this.el.getXY()},onInvalidDrop:function(b,a,c){this.beforeInvalidDrop(b,a,c);if(this.cachedTarget){if(this.cachedTarget.isNotifyTarget){this.cachedTarget.notifyOut(this,a,this.dragData)}this.cacheTarget=null}this.proxy.repair(this.getRepairXY(a,this.dragData),this.afterRepair,this);if(this.afterInvalidDrop){this.afterInvalidDrop(a,c)}},afterRepair:function(){if(Ext.enableFx){this.el.highlight(this.hlColor||"c3daf9")}this.d
 ragging=false},beforeInvalidDrop:function(b,a,c){return true},handleMouseDown:function(b){if(this.dragging){return}var a=this.getDragData(b);if(a&&this.onBeforeDrag(a,b)!==false){this.dragData=a;this.proxy.stop();Ext.dd.DragSource.superclass.handleMouseDown.apply(this,arguments)}},onBeforeDrag:function(a,b){return true},onStartDrag:Ext.emptyFn,startDrag:function(a,b){this.proxy.reset();this.dragging=true;this.proxy.update("");this.onInitDrag(a,b);this.proxy.show()},onInitDrag:function(a,c){var b=this.el.dom.cloneNode(true);b.id=Ext.id();this.proxy.update(b);this.onStartDrag(a,c);return true},getProxy:function(){return this.proxy},hideProxy:function(){this.proxy.hide();this.proxy.reset(true);this.dragging=false},triggerCacheRefresh:function(){Ext.dd.DDM.refreshCache(this.groups)},b4EndDrag:function(a){},endDrag:function(a){this.onEndDrag(this.dragData,a)},onEndDrag:function(a,b){},autoOffset:function(a,b){this.setDelta(-12,-20)},destroy:function(){Ext.dd.DragSource.superclass
 .destroy.call(this);Ext.destroy(this.proxy)}});Ext.dd.DropTarget=Ext.extend(Ext.dd.DDTarget,{constructor:function(b,a){this.el=Ext.get(b);Ext.apply(this,a);if(this.containerScroll){Ext.dd.ScrollManager.register(this.el)}Ext.dd.DropTarget.superclass.constructor.call(this,this.el.dom,this.ddGroup||this.group,{isTarget:true})},dropAllowed:"x-dd-drop-ok",dropNotAllowed:"x-dd-drop-nodrop",isTarget:true,isNotifyTarget:true,notifyEnter:function(a,c,b){if(this.overClass){this.el.addClass(this.overClass)}return this.dropAllowed},notifyOver:function(a,c,b){return this.dropAllowed},notifyOut:function(a,c,b){if(this.overClass){this.el.removeClass(this.overClass)}},notifyDrop:function(a,c,b){return false},destroy:function(){Ext.dd.DropTarget.superclass.destroy.call(this);if(this.containerScroll){Ext.dd.ScrollManager.unregister(this.el)}}});Ext.dd.DragZone=Ext.extend(Ext.dd.DragSource,{constructor:function(b,a){Ext.dd.DragZone.superclass.constructor.call(this,b,a);if(this.containerScroll)
 {Ext.dd.ScrollManager.register(this.el)}},getDragData:function(a){return Ext.dd.Registry.getHandleFromEvent(a)},onInitDrag:function(a,b){this.proxy.update(this.dragData.ddel.cloneNode(true));this.onStartDrag(a,b);return true},afterRepair:function(){if(Ext.enableFx){Ext.Element.fly(this.dragData.ddel).highlight(this.hlColor||"c3daf9")}this.dragging=false},getRepairXY:function(a){return Ext.Element.fly(this.dragData.ddel).getXY()},destroy:function(){Ext.dd.DragZone.superclass.destroy.call(this);if(this.containerScroll){Ext.dd.ScrollManager.unregister(this.el)}}});Ext.dd.DropZone=function(b,a){Ext.dd.DropZone.superclass.constructor.call(this,b,a)};Ext.extend(Ext.dd.DropZone,Ext.dd.DropTarget,{getTargetFromEvent:function(a){return Ext.dd.Registry.getTargetFromEvent(a)},onNodeEnter:function(d,a,c,b){},onNodeOver:function(d,a,c,b){return this.dropAllowed},onNodeOut:function(d,a,c,b){},onNodeDrop:function(d,a,c,b){return false},onContainerOver:function(a,c,b){return this.dropNotAll
 owed},onContainerDrop:function(a,c,b){return false},notifyEnter:function(a,c,b){return this.dropNotAllowed},notifyOver:function(a,c,b){var d=this.getTargetFromEvent(c);if(!d){if(this.lastOverNode){this.onNodeOut(this.lastOverNode,a,c,b);this.lastOverNode=null}return this.onContainerOver(a,c,b)}if(this.lastOverNode!=d){if(this.lastOverNode){this.onNodeOut(this.lastOverNode,a,c,b)}this.onNodeEnter(d,a,c,b);this.lastOverNode=d}return this.onNodeOver(d,a,c,b)},notifyOut:function(a,c,b){if(this.lastOverNode){this.onNodeOut(this.lastOverNode,a,c,b);this.lastOverNode=null}},notifyDrop:function(a,c,b){if(this.lastOverNode){this.onNodeOut(this.lastOverNode,a,c,b);this.lastOverNode=null}var d=this.getTargetFromEvent(c);return d?this.onNodeDrop(d,a,c,b):this.onContainerDrop(a,c,b)},triggerCacheRefresh:function(){Ext.dd.DDM.refreshCache(this.groups)}});Ext.Element.addMethods({initDD:function(c,b,d){var a=new Ext.dd.DD(Ext.id(this.dom),c,b);return Ext.apply(a,d)},initDDProxy:function(c,b
 ,d){var a=new Ext.dd.DDProxy(Ext.id(this.dom),c,b);return Ext.apply(a,d)},initDDTarget:function(c,b,d){var a=new Ext.dd.DDTarget(Ext.id(this.dom),c,b);return Ext.apply(a,d)}});Ext.data.Api=(function(){var a={};return{actions:{create:"create",read:"read",update:"update",destroy:"destroy"},restActions:{create:"POST",read:"GET",update:"PUT",destroy:"DELETE"},isAction:function(b){return(Ext.data.Api.actions[b])?true:false},getVerb:function(b){if(a[b]){return a[b]}for(var c in this.actions){if(this.actions[c]===b){a[b]=c;break}}return(a[b]!==undefined)?a[b]:null},isValid:function(b){var e=[];var d=this.actions;for(var c in b){if(!(c in d)){e.push(c)}}return(!e.length)?true:e},hasUniqueUrl:function(c,g){var b=(c.api[g])?c.api[g].url:null;var e=true;for(var d in c.api){if((e=(d===g)?true:(c.api[d].url!=b)?true:false)===false){break}}return e},prepare:function(b){if(!b.api){b.api={}}for(var d in this.actions){var c=this.actions[d];b.api[c]=b.api[c]||b.url||b.directFn;if(typeof(b.api
 [c])=="string"){b.api[c]={url:b.api[c],method:(b.restful===true)?Ext.data.Api.restActions[c]:undefined}}}},restify:function(b){b.restful=true;for(var c in this.restActions){b.api[this.actions[c]].method||(b.api[this.actions[c]].method=this.restActions[c])}b.onWrite=b.onWrite.createInterceptor(function(i,j,g,e){var d=j.reader;var h=new Ext.data.Response({action:i,raw:g});switch(g.status){case 200:return true;break;case 201:if(Ext.isEmpty(h.raw.responseText)){h.success=true}else{return true}break;case 204:h.success=true;h.data=null;break;default:return true;break}if(h.success===true){this.fireEvent("write",this,i,h.data,h,e,j.request.arg)}else{this.fireEvent("exception",this,"remote",i,j,h,e)}j.request.callback.call(j.request.scope,h.data,h,h.success);return false},b)}}})();Ext.data.Response=function(b,a){Ext.apply(this,b,{raw:a})};Ext.data.Response.prototype={message:null,success:false,status:null,root:null,raw:null,getMessage:function(){return this.message},getSuccess:functi
 on(){return this.success},getStatus:function(){return this.status},getRoot:function(){return this.root},getRawResponse:function(){return this.raw}};Ext.data.Api.Error=Ext.extend(Ext.Error,{constructor:function(b,a){this.arg=a;Ext.Error.call(this,b)},name:"Ext.data.Api"});Ext.apply(Ext.data.Api.Error.prototype,{lang:{"action-url-undefined":"No fallback url defined for this action.  When defining a DataProxy api, please be sure to define an url for each CRUD action in Ext.data.Api.actions or define a default url in addition to your api-configuration.",invalid:"received an invalid API-configuration.  Please ensure your proxy API-configuration contains only the actions defined in Ext.data.Api.actions","invalid-url":"Invalid url.  Please review your proxy configuration.",execute:'Attempted to execute an unknown action.  Valid API actions are defined in Ext.data.Api.actions"'}});Ext.data.SortTypes={none:function(a){return a},stripTagsRE:/<\/?[^>]+>/gi,asText:function(a){return Str
 ing(a).replace(this.stripTagsRE,"")},asUCText:function(a){return String(a).toUpperCase().replace(this.stripTagsRE,"")},asUCString:function(a){return String(a).toUpperCase()},asDate:function(a){if(!a){return 0}if(Ext.isDate(a)){return a.getTime()}return Date.parse(String(a))},asFloat:function(a){var b=parseFloat(String(a).replace(/,/g,""));return isNaN(b)?0:b},asInt:function(a){var b=parseInt(String(a).replace(/,/g,""),10);return isNaN(b)?0:b}};Ext.data.Record=function(a,b){this.id=(b||b===0)?b:Ext.data.Record.id(this);this.data=a||{}};Ext.data.Record.create=function(e){var c=Ext.extend(Ext.data.Record,{});var d=c.prototype;d.fields=new Ext.util.MixedCollection(false,function(g){return g.name});for(var b=0,a=e.length;b<a;b++){d.fields.add(new Ext.data.Field(e[b]))}c.getField=function(g){return d.fields.get(g)};return c};Ext.data.Record.PREFIX="ext-record";Ext.data.Record.AUTO_ID=1;Ext.data.Record.EDIT="edit";Ext.data.Record.REJECT="reject";Ext.data.Record.COMMIT="commit";Ext.
 data.Record.id=function(a){a.phantom=true;return[Ext.data.Record.PREFIX,"-",Ext.data.Record.AUTO_ID++].join("")};Ext.data.Record.prototype={dirty:false,editing:false,error:null,modified:null,phantom:false,join:function(a){this.store=a},set:function(a,c){var b=Ext.isPrimitive(c)?String:Ext.encode;if(b(this.data[a])==b(c)){return}this.dirty=true;if(!this.modified){this.modified={}}if(this.modified[a]===undefined){this.modified[a]=this.data[a]}this.data[a]=c;if(!this.editing){this.afterEdit()}},afterEdit:function(){if(this.store!=undefined&&typeof this.store.afterEdit=="function"){this.store.afterEdit(this)}},afterReject:function(){if(this.store){this.store.afterReject(this)}},afterCommit:function(){if(this.store){this.store.afterCommit(this)}},get:function(a){return this.data[a]},beginEdit:function(){this.editing=true;this.modified=this.modified||{}},cancelEdit:function(){this.editing=false;delete this.modified},endEdit:function(){this.editing=false;if(this.dirty){this.afterEd
 it()}},reject:function(b){var a=this.modified;for(var c in a){if(typeof a[c]!="function"){this.data[c]=a[c]}}this.dirty=false;delete this.modified;this.editing=false;if(b!==true){this.afterReject()}},commit:function(a){this.dirty=false;delete this.modified;this.editing=false;if(a!==true){this.afterCommit()}},getChanges:function(){var a=this.modified,b={};for(var c in a){if(a.hasOwnProperty(c)){b[c]=this.data[c]}}return b},hasError:function(){return this.error!==null},clearError:function(){this.error=null},copy:function(a){return new this.constructor(Ext.apply({},this.data),a||this.id)},isModified:function(a){return !!(this.modified&&this.modified.hasOwnProperty(a))},isValid:function(){return this.fields.find(function(a){return(a.allowBlank===false&&Ext.isEmpty(this.data[a.name]))?true:false},this)?false:true},markDirty:function(){this.dirty=true;if(!this.modified){this.modified={}}this.fields.each(function(a){this.modified[a.name]=this.data[a.name]},this)}};Ext.StoreMgr=Ext.
 apply(new Ext.util.MixedCollection(),{register:function(){for(var a=0,b;(b=arguments[a]);a++){this.add(b)}},unregister:function(){for(var a=0,b;(b=arguments[a]);a++){this.remove(this.lookup(b))}},lookup:function(e){if(Ext.isArray(e)){var b=["field1"],d=!Ext.isArray(e[0]);if(!d){for(var c=2,a=e[0].length;c<=a;++c){b.push("field"+c)}}return new Ext.data.ArrayStore({fields:b,data:e,expandData:d,autoDestroy:true,autoCreated:true})}return Ext.isObject(e)?(e.events?e:Ext.create(e,"store")):this.get(e)},getKey:function(a){return a.storeId}});Ext.data.Store=Ext.extend(Ext.util.Observable,{writer:undefined,remoteSort:false,autoDestroy:false,pruneModifiedRecords:false,lastOptions:null,autoSave:true,batch:true,restful:false,paramNames:undefined,defaultParamNames:{start:"start",limit:"limit",sort:"sort",dir:"dir"},isDestroyed:false,hasMultiSort:false,batchKey:"_ext_batch_",constructor:function(a){this.data=new Ext.util.MixedCollection(false);this.data.getKey=function(b){return b.id};thi
 s.removed=[];if(a&&a.data){this.inlineData=a.data;delete a.data}Ext.apply(this,a);this.baseParams=Ext.isObject(this.baseParams)?this.baseParams:{};this.paramNames=Ext.applyIf(this.paramNames||{},this.defaultParamNames);if((this.url||this.api)&&!this.proxy){this.proxy=new Ext.data.HttpProxy({url:this.url,api:this.api})}if(this.restful===true&&this.proxy){this.batch=false;Ext.data.Api.restify(this.proxy)}if(this.reader){if(!this.recordType){this.recordType=this.reader.recordType}if(this.reader.onMetaChange){this.reader.onMetaChange=this.reader.onMetaChange.createSequence(this.onMetaChange,this)}if(this.writer){if(this.writer instanceof (Ext.data.DataWriter)===false){this.writer=this.buildWriter(this.writer)}this.writer.meta=this.reader.meta;this.pruneModifiedRecords=true}}if(this.recordType){this.fields=this.recordType.prototype.fields}this.modified=[];this.addEvents("datachanged","metachange","add","remove","update","clear","exception","beforeload","load","loadexception","bef
 orewrite","write","beforesave","save");if(this.proxy){this.relayEvents(this.proxy,["loadexception","exception"])}if(this.writer){this.on({scope:this,add:this.createRecords,remove:this.destroyRecord,update:this.updateRecord,clear:this.onClear})}this.sortToggle={};if(this.sortField){this.setDefaultSort(this.sortField,this.sortDir)}else{if(this.sortInfo){this.setDefaultSort(this.sortInfo.field,this.sortInfo.direction)}}Ext.data.Store.superclass.constructor.call(this);if(this.id){this.storeId=this.id;delete this.id}if(this.storeId){Ext.StoreMgr.register(this)}if(this.inlineData){this.loadData(this.inlineData);delete this.inlineData}else{if(this.autoLoad){this.load.defer(10,this,[typeof this.autoLoad=="object"?this.autoLoad:undefined])}}this.batchCounter=0;this.batches={}},buildWriter:function(b){var a=undefined,c=(b.format||"json").toLowerCase();switch(c){case"json":a=Ext.data.JsonWriter;break;case"xml":a=Ext.data.XmlWriter;break;default:a=Ext.data.JsonWriter}return new a(b)},de
 stroy:function(){if(!this.isDestroyed){if(this.storeId){Ext.StoreMgr.unregister(this)}this.clearData();this.data=null;Ext.destroy(this.proxy);this.reader=this.writer=null;this.purgeListeners();this.isDestroyed=true}},add:function(c){var e,a,b,d;c=[].concat(c);if(c.length<1){return}for(e=0,a=c.length;e<a;e++){b=c[e];b.join(this);if(b.dirty||b.phantom){this.modified.push(b)}}d=this.data.length;this.data.addAll(c);if(this.snapshot){this.snapshot.addAll(c)}this.fireEvent("add",this,c,d)},addSorted:function(a){var b=this.findInsertIndex(a);this.insert(b,a)},doUpdate:function(a){var b=a.id;this.getById(b).join(null);this.data.replace(b,a);if(this.snapshot){this.snapshot.replace(b,a)}a.join(this);this.fireEvent("update",this,a,Ext.data.Record.COMMIT)},remove:function(a){if(Ext.isArray(a)){Ext.each(a,function(c){this.remove(c)},this);return}var b=this.data.indexOf(a);if(b>-1){a.join(null);this.data.removeAt(b)}if(this.pruneModifiedRecords){this.modified.remove(a)}if(this.snapshot){t
 his.snapshot.remove(a)}if(b>-1){this.fireEvent("remove",this,a,b)}},removeAt:function(a){this.remove(this.getAt(a))},removeAll:function(b){var a=[];this.each(function(c){a.push(c)});this.clearData();if(this.snapshot){this.snapshot.clear()}if(this.pruneModifiedRecords){this.modified=[]}if(b!==true){this.fireEvent("clear",this,a)}},onClear:function(b,a){Ext.each(a,function(d,c){this.destroyRecord(this,d,c)},this)},insert:function(d,c){var e,a,b;c=[].concat(c);for(e=0,a=c.length;e<a;e++){b=c[e];this.data.insert(d+e,b);b.join(this);if(b.dirty||b.phantom){this.modified.push(b)}}if(this.snapshot){this.snapshot.addAll(c)}this.fireEvent("add",this,c,d)},indexOf:function(a){return this.data.indexOf(a)},indexOfId:function(a){return this.data.indexOfKey(a)},getById:function(a){return(this.snapshot||this.data).key(a)},getAt:function(a){return this.data.itemAt(a)},getRange:function(b,a){return this.data.getRange(b,a)},storeOptions:function(a){a=Ext.apply({},a);delete a.callback;delete a.
 scope;this.lastOptions=a},clearData:function(){this.data.each(function(a){a.join(null)});this.data.clear()},load:function(b){b=Ext.apply({},b);this.storeOptions(b);if(this.sortInfo&&this.remoteSort){var a=this.paramNames;b.params=Ext.apply({},b.params);b.params[a.sort]=this.sortInfo.field;b.params[a.dir]=this.sortInfo.direction}try{return this.execute("read",null,b)}catch(c){this.handleException(c);return false}},updateRecord:function(b,a,c){if(c==Ext.data.Record.EDIT&&this.autoSave===true&&(!a.phantom||(a.phantom&&a.isValid()))){this.save()}},createRecords:function(c,b,e){var d=this.modified,h=b.length,a,g;for(g=0;g<h;g++){a=b[g];if(a.phantom&&a.isValid()){a.markDirty();if(d.indexOf(a)==-1){d.push(a)}}}if(this.autoSave===true){this.save()}},destroyRecord:function(b,a,c){if(this.modified.indexOf(a)!=-1){this.modified.remove(a)}if(!a.phantom){this.removed.push(a);a.lastIndex=c;if(this.autoSave===true){this.save()}}},execute:function(e,a,c,b){if(!Ext.data.Api.isAction(e)){thro
 w new Ext.data.Api.Error("execute",e)}c=Ext.applyIf(c||{},{params:{}});if(b!==undefined){this.addToBatch(b)}var d=true;if(e==="read"){d=this.fireEvent("beforeload",this,c);Ext.applyIf(c.params,this.baseParams)}else{if(this.writer.listful===true&&this.restful!==true){a=(Ext.isArray(a))?a:[a]}else{if(Ext.isArray(a)&&a.length==1){a=a.shift()}}if((d=this.fireEvent("beforewrite",this,e,a,c))!==false){this.writer.apply(c.params,this.baseParams,e,a)}}if(d!==false){if(this.writer&&this.proxy.url&&!this.proxy.restful&&!Ext.data.Api.hasUniqueUrl(this.proxy,e)){c.params.xaction=e}this.proxy.request(Ext.data.Api.actions[e],a,c.params,this.reader,this.createCallback(e,a,b),this,c)}return d},save:function(){if(!this.writer){throw new Ext.data.Store.Error("writer-undefined")}var h=[],j,k,e,c={},d;if(this.removed.length){h.push(["destroy",this.removed])}var b=[].concat(this.getModifiedRecords());if(b.length){var g=[];for(d=b.length-1;d>=0;d--){if(b[d].phantom===true){var a=b.splice(d,1).shi
 ft();if(a.isValid()){g.push(a)}}else{if(!b[d].isValid()){b.splice(d,1)}}}if(g.length){h.push(["create",g])}if(b.length){h.push(["update",b])}}j=h.length;if(j){e=++this.batchCounter;for(d=0;d<j;++d){k=h[d];c[k[0]]=k[1]}if(this.fireEvent("beforesave",this,c)!==false){for(d=0;d<j;++d){k=h[d];this.doTransaction(k[0],k[1],e)}return e}}return -1},doTransaction:function(e,b,c){function g(h){try{this.execute(e,h,undefined,c)}catch(i){this.handleException(i)}}if(this.batch===false){for(var d=0,a=b.length;d<a;d++){g.call(this,b[d])}}else{g.call(this,b)}},addToBatch:function(c){var a=this.batches,d=this.batchKey+c,e=a[d];if(!e){a[d]=e={id:c,count:0,data:{}}}++e.count},removeFromBatch:function(d,h,g){var c=this.batches,e=this.batchKey+d,i=c[e],a;if(i){a=i.data[h]||[];i.data[h]=a.concat(g);if(i.count===1){g=i.data;delete c[e];this.fireEvent("save",this,d,g)}else{--i.count}}},createCallback:function(c,a,b){var d=Ext.data.Api.actions;return(c=="read")?this.loadRecords:function(g,e,h){this[
 "on"+Ext.util.Format.capitalize(c)+"Records"](h,a,[].concat(g));if(h===true){this.fireEvent("write",this,c,g,e,a)}this.removeFromBatch(b,c,g)}},clearModified:function(a){if(Ext.isArray(a)){for(var b=a.length-1;b>=0;b--){this.modified.splice(this.modified.indexOf(a[b]),1)}}else{this.modified.splice(this.modified.indexOf(a),1)}},reMap:function(b){if(Ext.isArray(b)){for(var d=0,a=b.length;d<a;d++){this.reMap(b[d])}}else{delete this.data.map[b._phid];this.data.map[b.id]=b;var c=this.data.keys.indexOf(b._phid);this.data.keys.splice(c,1,b.id);delete b._phid}},onCreateRecords:function(d,a,b){if(d===true){try{this.reader.realize(a,b)}catch(c){this.handleException(c);if(Ext.isArray(a)){this.onCreateRecords(d,a,b)}}}},onUpdateRecords:function(d,a,b){if(d===true){try{this.reader.update(a,b)}catch(c){this.handleException(c);if(Ext.isArray(a)){this.onUpdateRecords(d,a,b)}}}},onDestroyRecords:function(e,b,d){b=(b instanceof Ext.data.Record)?[b]:[].concat(b);for(var c=0,a=b.length;c<a;c++)
 {this.removed.splice(this.removed.indexOf(b[c]),1)}if(e===false){for(c=b.length-1;c>=0;c--){this.insert(b[c].lastIndex,b[c])}}},handleException:function(a){Ext.handleError(a)},reload:function(a){this.load(Ext.applyIf(a||{},this.lastOptions))},loadRecords:function(b,l,h){var e,g;if(this.isDestroyed===true){return}if(!b||h===false){if(h!==false){this.fireEvent("load",this,[],l)}if(l.callback){l.callback.call(l.scope||this,[],l,false,b)}return}var a=b.records,j=b.totalRecords||a.length;if(!l||l.add!==true){if(this.pruneModifiedRecords){this.modified=[]}for(e=0,g=a.length;e<g;e++){a[e].join(this)}if(this.snapshot){this.data=this.snapshot;delete this.snapshot}this.clearData();this.data.addAll(a);this.totalLength=j;this.applySort();this.fireEvent("datachanged",this)}else{var k=[],d,c=0;for(e=0,g=a.length;e<g;++e){d=a[e];if(this.indexOfId(d.id)>-1){this.doUpdate(d)}else{k.push(d);++c}}this.totalLength=Math.max(j,this.data.length+c);this.add(k)}this.fireEvent("load",this,a,l);if(l.c
 allback){l.callback.call(l.scope||this,a,l,true)}},loadData:function(c,a){var b=this.reader.readRecords(c);this.loadRecords(b,{add:a},true)},getCount:function(){return this.data.length||0},getTotalCount:function(){return this.totalLength||0},getSortState:function(){return this.sortInfo},applySort:function(){if((this.sortInfo||this.multiSortInfo)&&!this.remoteSort){this.sortData()}},sortData:function(){var a=this.hasMultiSort?this.multiSortInfo:this.sortInfo,k=a.direction||"ASC",h=a.sorters,c=[];if(!this.hasMultiSort){h=[{direction:k,field:a.field}]}for(var d=0,b=h.length;d<b;d++){c.push(this.createSortFunction(h[d].field,h[d].direction))}if(c.length==0){return}var g=k.toUpperCase()=="DESC"?-1:1;var e=function(n,m){var l=c[0].call(this,n,m);if(c.length>1){for(var p=1,o=c.length;p<o;p++){l=l||c[p].call(this,n,m)}}return g*l};this.data.sort(k,e);if(this.snapshot&&this.snapshot!=this.data){this.snapshot.sort(k,e)}},createSortFunction:function(c,b){b=b||"ASC";var a=b.toUpperCase(
 )=="DESC"?-1:1;var d=this.fields.get(c).sortType;return function(g,e){var i=d(g.data[c]),h=d(e.data[c]);return a*(i>h?1:(i<h?-1:0))}},setDefaultSort:function(b,a){a=a?a.toUpperCase():"ASC";this.sortInfo={field:b,direction:a};this.sortToggle[b]=a},sort:function(b,a){if(Ext.isArray(arguments[0])){return this.multiSort.call(this,b,a)}else{return this.singleSort(b,a)}},singleSort:function(g,c){var e=this.fields.get(g);if(!e){return false}var b=e.name,a=this.sortInfo||null,d=this.sortToggle?this.sortToggle[b]:null;if(!c){if(a&&a.field==b){c=(this.sortToggle[b]||"ASC").toggle("ASC","DESC")}else{c=e.sortDir}}this.sortToggle[b]=c;this.sortInfo={field:b,direction:c};this.hasMultiSort=false;if(this.remoteSort){if(!this.load(this.lastOptions)){if(d){this.sortToggle[b]=d}if(a){this.sortInfo=a}}}else{this.applySort();this.fireEvent("datachanged",this)}return true},multiSort:function(b,a){this.hasMultiSort=true;a=a||"ASC";if(this.multiSortInfo&&a==this.multiSortInfo.direction){a=a.toggle(
 "ASC","DESC")}this.multiSortInfo={sorters:b,direction:a};if(this.remoteSort){this.singleSort(b[0].field,b[0].direction)}else{this.applySort();this.fireEvent("datachanged",this)}},each:function(b,a){this.data.each(b,a)},getModifiedRecords:function(){return this.modified},sum:function(e,g,a){var c=this.data.items,b=0;g=g||0;a=(a||a===0)?a:c.length-1;for(var d=g;d<=a;d++){b+=(c[d].data[e]||0)}return b},createFilterFn:function(d,c,e,a,b){if(Ext.isEmpty(c,false)){return false}c=this.data.createValueMatcher(c,e,a,b);return function(g){return c.test(g.data[d])}},createMultipleFilterFn:function(a){return function(b){var k=true;for(var d=0,c=a.length;d<c;d++){var h=a[d],g=h.fn,e=h.scope;k=k&&g.call(e,b)}return k}},filter:function(n,m,h,k,e){var l;if(Ext.isObject(n)){n=[n]}if(Ext.isArray(n)){var b=[];for(var g=0,d=n.length;g<d;g++){var a=n[g],c=a.fn,o=a.scope||this;if(!Ext.isFunction(c)){c=this.createFilterFn(a.property,a.value,a.anyMatch,a.caseSensitive,a.exactMatch)}b.push({fn:c,sco
 pe:o})}l=this.createMultipleFilterFn(b)}else{l=this.createFilterFn(n,m,h,k,e)}return l?this.filterBy(l):this.clearFilter()},filterBy:function(b,a){this.snapshot=this.snapshot||this.data;this.data=this.queryBy(b,a||this);this.fireEvent("datachanged",this)},clearFilter:function(a){if(this.isFiltered()){this.data=this.snapshot;delete this.snapshot;if(a!==true){this.fireEvent("datachanged",this)}}},isFiltered:function(){return !!this.snapshot&&this.snapshot!=this.data},query:function(d,c,e,a){var b=this.createFilterFn(d,c,e,a);return b?this.queryBy(b):this.data.clone()},queryBy:function(b,a){var c=this.snapshot||this.data;return c.filterBy(b,a||this)},find:function(d,c,g,e,a){var b=this.createFilterFn(d,c,e,a);return b?this.data.findIndexBy(b,null,g):-1},findExact:function(b,a,c){return this.data.findIndexBy(function(d){return d.get(b)===a},this,c)},findBy:function(b,a,c){return this.data.findIndexBy(b,a,c)},collect:function(j,k,b){var h=(b===true&&this.snapshot)?this.snapshot.i
 tems:this.data.items;var m,n,a=[],c={};for(var e=0,g=h.length;e<g;e++){m=h[e].data[j];n=String(m);if((k||!Ext.isEmpty(m))&&!c[n]){c[n]=true;a[a.length]=m}}return a},afterEdit:function(a){if(this.modified.indexOf(a)==-1){this.modified.push(a)}this.fireEvent("update",this,a,Ext.data.Record.EDIT)},afterReject:function(a){this.modified.remove(a);this.fireEvent("update",this,a,Ext.data.Record.REJECT)},afterCommit:function(a){this.modified.remove(a);this.fireEvent("update",this,a,Ext.data.Record.COMMIT)},commitChanges:function(){var a=this.modified.slice(0),c=a.length,b;for(b=0;b<c;b++){a[b].commit()}this.modified=[];this.removed=[]},rejectChanges:function(){var a=this.modified.slice(0),e=this.removed.slice(0).reverse(),c=a.length,d=e.length,b;for(b=0;b<c;b++){a[b].reject()}for(b=0;b<d;b++){this.insert(e[b].lastIndex||0,e[b]);e[b].reject()}this.modified=[];this.removed=[]},onMetaChange:function(a){this.recordType=this.reader.recordType;this.fields=this.recordType.prototype.fields;
 delete this.snapshot;if(this.reader.meta.sortInfo){this.sortInfo=this.reader.meta.sortInfo}else{if(this.sortInfo&&!this.fields.get(this.sortInfo.field)){delete this.sortInfo}}if(this.writer){this.writer.meta=this.reader.meta}this.modified=[];this.fireEvent("metachange",this,this.reader.meta)},findInsertIndex:function(a){this.suspendEvents();var c=this.data.clone();this.data.add(a);this.applySort();var b=this.data.indexOf(a);this.data=c;this.resumeEvents();return b},setBaseParam:function(a,b){this.baseParams=this.baseParams||{};this.baseParams[a]=b}});Ext.reg("store",Ext.data.Store);Ext.data.Store.Error=Ext.extend(Ext.Error,{name:"Ext.data.Store"});Ext.apply(Ext.data.Store.Error.prototype,{lang:{"writer-undefined":"Attempted to execute a write-action without a DataWriter installed."}});Ext.data.Field=Ext.extend(Object,{constructor:function(b){if(Ext.isString(b)){b={name:b}}Ext.apply(this,b);var d=Ext.data.Types,a=this.sortType,c;if(this.type){if(Ext.isString(this.type)){this.
 type=Ext.data.Types[this.type.toUpperCase()]||d.AUTO}}else{this.type=d.AUTO}if(Ext.isString(a)){this.sortType=Ext.data.SortTypes[a]}else{if(Ext.isEmpty(a)){this.sortType=this.type.sortType}}if(!this.convert){this.convert=this.type.convert}},dateFormat:null,useNull:false,defaultValue:"",mapping:null,sortType:null,sortDir:"ASC",allowBlank:true});Ext.data.DataReader=function(a,b){this.meta=a;this.recordType=Ext.isArray(b)?Ext.data.Record.create(b):b;if(this.recordType){this.buildExtractors()}};Ext.data.DataReader.prototype={getTotal:Ext.emptyFn,getRoot:Ext.emptyFn,getMessage:Ext.emptyFn,getSuccess:Ext.emptyFn,getId:Ext.emptyFn,buildExtractors:Ext.emptyFn,extractValues:Ext.emptyFn,realize:function(a,c){if(Ext.isArray(a)){for(var b=a.length-1;b>=0;b--){if(Ext.isArray(c)){this.realize(a.splice(b,1).shift(),c.splice(b,1).shift())}else{this.realize(a.splice(b,1).shift(),c)}}}else{if(Ext.isArray(c)&&c.length==1){c=c.shift()}if(!this.isData(c)){throw new Ext.data.DataReader.Error("rea
 lize",a)}a.phantom=false;a._phid=a.id;a.id=this.getId(c);a.data=c;a.commit();a.store.reMap(a)}},update:function(a,c){if(Ext.isArray(a)){for(var b=a.length-1;b>=0;b--){if(Ext.isArray(c)){this.update(a.splice(b,1).shift(),c.splice(b,1).shift())}else{this.update(a.splice(b,1).shift(),c)}}}else{if(Ext.isArray(c)&&c.length==1){c=c.shift()}if(this.isData(c)){a.data=Ext.apply(a.data,c)}a.commit()}},extractData:function(k,a){var j=(this instanceof Ext.data.JsonReader)?"json":"node";var c=[];if(this.isData(k)&&!(this instanceof Ext.data.XmlReader)){k=[k]}var h=this.recordType.prototype.fields,o=h.items,m=h.length,c=[];if(a===true){var l=this.recordType;for(var e=0;e<k.length;e++){var b=k[e];var g=new l(this.extractValues(b,o,m),this.getId(b));g[j]=b;c.push(g)}}else{for(var e=0;e<k.length;e++){var d=this.extractValues(k[e],o,m);d[this.meta.idProperty]=this.getId(k[e]);c.push(d)}}return c},isData:function(a){return(a&&Ext.isObject(a)&&!Ext.isEmpty(this.getId(a)))?true:false},onMetaChan
 ge:function(a){delete this.ef;this.meta=a;this.recordType=Ext.data.Record.create(a.fields);this.buildExtractors()}};Ext.data.DataReader.Error=Ext.extend(Ext.Error,{constructor:function(b,a){this.arg=a;Ext.Error.call(this,b)},name:"Ext.data.DataReader"});Ext.apply(Ext.data.DataReader.Error.prototype,{lang:{update:"#update received invalid data from server.  Please see docs for DataReader#update and review your DataReader configuration.",realize:"#realize was called with invalid remote-data.  Please see the docs for DataReader#realize and review your DataReader configuration.","invalid-response":"#readResponse received an invalid response from the server."}});Ext.data.DataWriter=function(a){Ext.apply(this,a)};Ext.data.DataWriter.prototype={writeAllFields:false,listful:false,apply:function(e,g,d,a){var c=[],b=d+"Record";if(Ext.isArray(a)){Ext.each(a,function(h){c.push(this[b](h))},this)}else{if(a instanceof Ext.data.Record){c=this[b](a)}}this.render(e,g,c)},render:Ext.emptyFn,u
 pdateRecord:Ext.emptyFn,createRecord:Ext.emptyFn,destroyRecord:Ext.emptyFn,toHash:function(g,c){var e=g.fields.map,d={},b=(this.writeAllFields===false&&g.phantom===false)?g.getChanges():g.data,a;Ext.iterate(b,function(i,h){if((a=e[i])){d[a.mapping?a.mapping:a.name]=h}});if(g.phantom){if(g.fields.containsKey(this.meta.idProperty)&&Ext.isEmpty(g.data[this.meta.idProperty])){delete d[this.meta.idProperty]}}else{d[this.meta.idProperty]=g.id}return d},toArray:function(b){var a=[];Ext.iterate(b,function(d,c){a.push({name:d,value:c})},this);return a}};Ext.data.DataProxy=function(a){a=a||{};this.api=a.api;this.url=a.url;this.restful=a.restful;this.listeners=a.listeners;this.prettyUrls=a.prettyUrls;this.addEvents("exception","beforeload","load","loadexception","beforewrite","write");Ext.data.DataProxy.superclass.constructor.call(this);try{Ext.data.Api.prepare(this)}catch(b){if(b instanceof Ext.data.Api.Error){b.toConsole()}}Ext.data.DataProxy.relayEvents(this,["beforewrite","write","
 exception"])};Ext.extend(Ext.data.DataProxy,Ext.util.Observable,{restful:false,setApi:function(){if(arguments.length==1){var a=Ext.data.Api.isValid(arguments[0]);if(a===true){this.api=arguments[0]}else{throw new Ext.data.Api.Error("invalid",a)}}else{if(arguments.length==2){if(!Ext.data.Api.isAction(arguments[0])){throw new Ext.data.Api.Error("invalid",arguments[0])}this.api[arguments[0]]=arguments[1]}}Ext.data.Api.prepare(this)},isApiAction:function(a){return(this.api[a])?true:false},request:function(e,b,g,a,h,d,c){if(!this.api[e]&&!this.load){throw new Ext.data.DataProxy.Error("action-undefined",e)}g=g||{};if((e===Ext.data.Api.actions.read)?this.fireEvent("beforeload",this,g):this.fireEvent("beforewrite",this,e,b,g)!==false){this.doRequest.apply(this,arguments)}else{h.call(d||this,null,c,false)}},load:null,doRequest:function(e,b,g,a,h,d,c){this.load(g,a,h,d,c)},onRead:Ext.emptyFn,onWrite:Ext.emptyFn,buildUrl:function(d,b){b=b||null;var c=(this.conn&&this.conn.url)?this.conn
 .url:(this.api[d])?this.api[d].url:this.url;if(!c){throw new Ext.data.Api.Error("invalid-url",d)}var e=null;var a=c.match(/(.*)(\.json|\.xml|\.html)$/);if(a){e=a[2];c=a[1]}if((this.restful===true||this.prettyUrls===true)&&b instanceof Ext.data.Record&&!b.phantom){c+="/"+b.id}return(e===null)?c:c+e},destroy:function(){this.purgeListeners()}});Ext.apply(Ext.data.DataProxy,Ext.util.Observable.prototype);Ext.util.Observable.call(Ext.data.DataProxy);Ext.data.DataProxy.Error=Ext.extend(Ext.Error,{constructor:function(b,a){this.arg=a;Ext.Error.call(this,b)},name:"Ext.data.DataProxy"});Ext.apply(Ext.data.DataProxy.Error.prototype,{lang:{"action-undefined":"DataProxy attempted to execute an API-action but found an undefined url / function.  Please review your Proxy url/api-configuration.","api-invalid":"Recieved an invalid API-configuration.  Please ensure your proxy API-configuration contains only the actions from Ext.data.Api.actions."}});Ext.data.Request=function(a){Ext.apply(this
 ,a)};Ext.data.Request.prototype={action:undefined,rs:undefined,params:undefined,callback:Ext.emptyFn,scope:undefined,reader:undefined};Ext.data.Response=function(a){Ext.apply(this,a)};Ext.data.Response.prototype={action:undefined,success:undefined,message:undefined,data:undefined,raw:undefined,records:undefined};Ext.data.ScriptTagProxy=function(a){Ext.apply(this,a);Ext.data.ScriptTagProxy.superclass.constructor.call(this,a);this.head=document.getElementsByTagName("head")[0]};Ext.data.ScriptTagProxy.TRANS_ID=1000;Ext.extend(Ext.data.ScriptTagProxy,Ext.data.DataProxy,{timeout:30000,callbackParam:"callback",nocache:true,doRequest:function(e,g,d,h,j,k,l){var c=Ext.urlEncode(Ext.apply(d,this.extraParams));var b=this.buildUrl(e,g);if(!b){throw new Ext.data.Api.Error("invalid-url",b)}b=Ext.urlAppend(b,c);if(this.nocache){b=Ext.urlAppend(b,"_dc="+(new Date().getTime()))}var a=++Ext.data.ScriptTagProxy.TRANS_ID;var m={id:a,action:e,cb:"stcCallback"+a,scriptId:"stcScript"+a,params:d,a
 rg:l,url:b,callback:j,scope:k,reader:h};window[m.cb]=this.createCallback(e,g,m);b+=String.format("&{0}={1}",this.callbackParam,m.cb);if(this.autoAbort!==false){this.abort()}m.timeoutId=this.handleFailure.defer(this.timeout,this,[m]);var i=document.createElement("script");i.setAttribute("src",b);i.setAttribute("type","text/javascript");i.setAttribute("id",m.scriptId);this.head.appendChild(i);this.trans=m},createCallback:function(d,b,c){var a=this;return function(e){a.trans=false;a.destroyTrans(c,true);if(d===Ext.data.Api.actions.read){a.onRead.call(a,d,c,e)}else{a.onWrite.call(a,d,c,e,b)}}},onRead:function(d,c,b){var a;try{a=c.reader.readRecords(b)}catch(g){this.fireEvent("loadexception",this,c,b,g);this.fireEvent("exception",this,"response",d,c,b,g);c.callback.call(c.scope||window,null,c.arg,false);return}if(a.success===false){this.fireEvent("loadexception",this,c,b);this.fireEvent("exception",this,"remote",d,c,b,null)}else{this.fireEvent("load",this,b,c.arg)}c.callback.call
 (c.scope||window,a,c.arg,a.success)},onWrite:function(h,g,c,b){var a=g.reader;try{var d=a.readResponse(h,c)}catch(i){this.fireEvent("exception",this,"response",h,g,d,i);g.callback.call(g.scope||window,null,d,false);return}if(!d.success===true){this.fireEvent("exception",this,"remote",h,g,d,b);g.callback.call(g.scope||window,null,d,false);return}this.fireEvent("write",this,h,d.data,d,b,g.arg);g.callback.call(g.scope||window,d.data,d,true)},isLoading:function(){return this.trans?true:false},abort:function(){if(this.isLoading()){this.destroyTrans(this.trans)}},destroyTrans:function(b,a){this.head.removeChild(document.getElementById(b.scriptId));clearTimeout(b.timeoutId);if(a){window[b.cb]=undefined;try{delete window[b.cb]}catch(c){}}else{window[b.cb]=function(){window[b.cb]=undefined;try{delete window[b.cb]}catch(d){}}}},handleFailure:function(a){this.trans=false;this.destroyTrans(a,false);if(a.action===Ext.data.Api.actions.read){this.fireEvent("loadexception",this,null,a.arg)}
 this.fireEvent("exception",this,"response",a.action,{response:null,options:a.arg});a.callback.call(a.scope||window,null,a.arg,false)},destroy:function(){this.abort();Ext.data.ScriptTagProxy.superclass.destroy.call(this)}});Ext.data.HttpProxy=function(a){Ext.data.HttpProxy.superclass.constructor.call(this,a);this.conn=a;this.conn.url=null;this.useAjax=!a||!a.events;var c=Ext.data.Api.actions;this.activeRequest={};for(var b in c){this.activeRequest[c[b]]=undefined}};Ext.extend(Ext.data.HttpProxy,Ext.data.DataProxy,{getConnection:function(){return this.useAjax?Ext.Ajax:this.conn},setUrl:function(a,b){this.conn.url=a;if(b===true){this.url=a;this.api=null;Ext.data.Api.prepare(this)}},doRequest:function(g,d,i,c,b,e,a){var h={method:(this.api[g])?this.api[g]["method"]:undefined,request:{callback:b,scope:e,arg:a},reader:c,callback:this.createCallback(g,d),scope:this};if(i.jsonData){h.jsonData=i.jsonData}else{if(i.xmlData){h.xmlData=i.xmlData}else{h.params=i||{}}}this.conn.url=this.b
 uildUrl(g,d);if(this.useAjax){Ext.applyIf(h,this.conn);if(this.activeRequest[g]){}this.activeRequest[g]=Ext.Ajax.request(h)}else{this.conn.request(h)}this.conn.url=null},createCallback:function(b,a){return function(e,d,c){this.activeRequest[b]=undefined;if(!d){if(b===Ext.data.Api.actions.read){this.fireEvent("loadexception",this,e,c)}this.fireEvent("exception",this,"response",b,e,c);e.request.callback.call(e.request.scope,null,e.request.arg,false);return}if(b===Ext.data.Api.actions.read){this.onRead(b,e,c)}else{this.onWrite(b,e,c,a)}}},onRead:function(d,h,b){var a;try{a=h.reader.read(b)}catch(g){this.fireEvent("loadexception",this,h,b,g);this.fireEvent("exception",this,"response",d,h,b,g);h.request.callback.call(h.request.scope,null,h.request.arg,false);return}if(a.success===false){this.fireEvent("loadexception",this,h,b);var c=h.reader.readResponse(d,b);this.fireEvent("exception",this,"remote",d,h,c,null)}else{this.fireEvent("load",this,h,h.request.arg)}h.request.callback.c
 all(h.request.scope,a,h.request.arg,a.success)},onWrite:function(g,i,c,b){var a=i.reader;var d;try{d=a.readResponse(g,c)}catch(h){this.fireEvent("exception",this,"response",g,i,c,h);i.request.callback.call(i.request.scope,null,i.request.arg,false);return}if(d.success===true){this.fireEvent("write",this,g,d.data,d,b,i.request.arg)}else{this.fireEvent("exception",this,"remote",g,i,d,b)}i.request.callback.call(i.request.scope,d.data,d,d.success)},destroy:function(){if(!this.useAjax){this.conn.abort()}else{if(this.activeRequest){var b=Ext.data.Api.actions;for(var a in b){if(this.activeRequest[b[a]]){Ext.Ajax.abort(this.activeRequest[b[a]])}}}}Ext.data.HttpProxy.superclass.destroy.call(this)}});Ext.data.MemoryProxy=function(b){var a={};a[Ext.data.Api.actions.read]=true;Ext.data.MemoryProxy.superclass.constructor.call(this,{api:a});this.data=b};Ext.extend(Ext.data.MemoryProxy,Ext.data.DataProxy,{doRequest:function(b,c,a,d,h,i,j){a=a||{};var k;try{k=d.readRecords(this.data)}catch(g
 ){this.fireEvent("loadexception",this,null,j,g);this.fireEvent("exception",this,"response",b,j,null,g);h.call(i,null,j,false);return}h.call(i,k,j,true)}});Ext.data.Types=new function(){var a=Ext.data.SortTypes;Ext.apply(this,{stripRe:/[\$,%]/g,AUTO:{convert:function(b){return b},sortType:a.none,type:"auto"},STRING:{convert:function(b){return(b===undefined||b===null)?"":String(b)},sortType:a.asUCString,type:"string"},INT:{convert:function(b){return b!==undefined&&b!==null&&b!==""?parseInt(String(b).replace(Ext.data.Types.stripRe,""),10):(this.useNull?null:0)},sortType:a.none,type:"int"},FLOAT:{convert:function(b){return b!==undefined&&b!==null&&b!==""?parseFloat(String(b).replace(Ext.data.Types.stripRe,""),10):(this.useNull?null:0)},sortType:a.none,type:"float"},BOOL:{convert:function(b){return b===true||b==="true"||b==1},sortType:a.none,type:"bool"},DATE:{convert:function(c){var d=this.dateFormat;if(!c){return null}if(Ext.isDate(c)){return c}if(d){if(d=="timestamp"){return n
 ew Date(c*1000)}if(d=="time"){return new Date(parseInt(c,10))}return Date.parseDate(c,d)}var b=Date.parse(c);return b?new Date(b):null},sortType:a.asDate,type:"date"}});Ext.apply(this,{BOOLEAN:this.BOOL,INTEGER:this.INT,NUMBER:this.FLOAT})};Ext.data.JsonWriter=Ext.extend(Ext.data.DataWriter,{encode:true,encodeDelete:false,constructor:function(a){Ext.data.JsonWriter.superclass.constructor.call(this,a)},render:function(c,d,b){if(this.encode===true){Ext.apply(c,d);c[this.meta.root]=Ext.encode(b)}else{var a=Ext.apply({},d);a[this.meta.root]=b;c.jsonData=a}},createRecord:function(a){return this.toHash(a)},updateRecord:function(a){return this.toHash(a)},destroyRecord:function(b){if(this.encodeDelete){var a={};a[this.meta.idProperty]=b.id;return a}else{return b.id}}});Ext.data.JsonReader=function(a,b){a=a||{};Ext.applyIf(a,{idProperty:"id",successProperty:"success",totalProperty:"total"});Ext.data.JsonReader.superclass.constructor.call(this,a,b||a.fields)};Ext.extend(Ext.data.JsonR
 eader,Ext.data.DataReader,{read:function(a){var b=a.responseText;var c=Ext.decode(b);if(!c){throw {message:"JsonReader.read: Json object not found"}}return this.readRecords(c)},readResponse:function(e,b){var h=(b.responseText!==undefined)?Ext.decode(b.responseText):b;if(!h){throw new Ext.data.JsonReader.Error("response")}var a=this.getRoot(h),g=this.getSuccess(h);if(g&&e===Ext.data.Api.actions.create){var d=Ext.isDefined(a);if(d&&Ext.isEmpty(a)){throw new Ext.data.JsonReader.Error("root-empty",this.meta.root)}else{if(!d){throw new Ext.data.JsonReader.Error("root-undefined-response",this.meta.root)}}}var c=new Ext.data.Response({action:e,success:g,data:(a)?this.extractData(a,false):[],message:this.getMessage(h),raw:h});if(Ext.isEmpty(c.success)){throw new Ext.data.JsonReader.Error("successProperty-response",this.meta.successProperty)}return c},readRecords:function(a){this.jsonData=a;if(a.metaData){this.onMetaChange(a.metaData)}var m=this.meta,h=this.recordType,b=h.prototype.f
 ields,l=b.items,i=b.length,j;var g=this.getRoot(a),e=g.length,d=e,k=true;if(m.totalProperty){j=parseInt(this.getTotal(a),10);if(!isNaN(j)){d=j}}if(m.successProperty){j=this.getSuccess(a);if(j===false||j==="false"){k=false}}return{success:k,records:this.extractData(g,true),totalRecords:d}},buildExtractors:function(){if(this.ef){return}var l=this.meta,h=this.recordType,e=h.prototype.fields,k=e.items,j=e.length;if(l.totalProperty){this.getTotal=this.createAccessor(l.totalProperty)}if(l.successProperty){this.getSuccess=this.createAccessor(l.successProperty)}if(l.messageProperty){this.getMessage=this.createAccessor(l.messageProperty)}this.getRoot=l.root?this.createAccessor(l.root):function(g){return g};if(l.id||l.idProperty){var d=this.createAccessor(l.id||l.idProperty);this.getId=function(i){var g=d(i);return(g===undefined||g==="")?null:g}}else{this.getId=function(){return null}}var c=[];for(var b=0;b<j;b++){e=k[b];var a=(e.mapping!==undefined&&e.mapping!==null)?e.mapping:e.name
 ;c.push(this.createAccessor(a))}this.ef=c},simpleAccess:function(b,a){return b[a]},createAccessor:function(){var a=/[\[\.]/;return function(c){if(Ext.isEmpty(c)){return Ext.emptyFn}if(Ext.isFunction(c)){return c}var b=String(c).search(a);if(b>=0){return new Function("obj","return obj"+(b>0?".":"")+c)}return function(d){return d[c]}}}(),extractValues:function(h,d,a){var g,c={};for(var e=0;e<a;e++){g=d[e];var b=this.ef[e](h);c[g.name]=g.convert((b!==undefined)?b:g.defaultValue,h)}return c}});Ext.data.JsonReader.Error=Ext.extend(Ext.Error,{constructor:function(b,a){this.arg=a;Ext.Error.call(this,b)},name:"Ext.data.JsonReader"});Ext.apply(Ext.data.JsonReader.Error.prototype,{lang:{response:"An error occurred while json-decoding your server response","successProperty-response":'Could not locate your "successProperty" in your server response.  Please review your JsonReader config to ensure the config-property "successProperty" matches the property in your server-response.  See the
  JsonReader docs.',"root-undefined-config":'Your JsonReader was configured without a "root" property.  Please review your JsonReader config and make sure to define the root property.  See the JsonReader docs.',"idProperty-undefined":'Your JsonReader was configured without an "idProperty"  Please review your JsonReader configuration and ensure the "idProperty" is set (e.g.: "id").  See the JsonReader docs.',"root-empty":'Data was expected to be returned by the server in the "root" property of the response.  Please review your JsonReader configuration to ensure the "root" property matches that returned in the server-response.  See JsonReader docs.'}});Ext.data.ArrayReader=Ext.extend(Ext.data.JsonReader,{readRecords:function(r){this.arrayData=r;var l=this.meta,d=l?Ext.num(l.idIndex,l.id):null,b=this.recordType,q=b.prototype.fields,z=[],e=true,g;var u=this.getRoot(r);for(var y=0,A=u.length;y<A;y++){var t=u[y],a={},p=((d||d===0)&&t[d]!==undefined&&t[d]!==""?t[d]:null);for(var x=0
 ,m=q.length;x<m;x++){var B=q.items[x],w=B.mapping!==undefined&&B.mapping!==null?B.mapping:x;g=t[w]!==undefined?t[w]:B.defaultValue;g=B.convert(g,t);a[B.name]=g}var c=new b(a,p);c.json=t;z[z.length]=c}var h=z.length;if(l.totalProperty){g=parseInt(this.getTotal(r),10);if(!isNaN(g)){h=g}}if(l.successProperty){g=this.getSuccess(r);if(g===false||g==="false"){e=false}}return{success:e,records:z,totalRecords:h}}});Ext.data.ArrayStore=Ext.extend(Ext.data.Store,{constructor:function(a){Ext.data.ArrayStore.superclass.constructor.call(this,Ext.apply(a,{reader:new Ext.data.ArrayReader(a)}))},loadData:function(e,b){if(this.expandData===true){var d=[];for(var c=0,a=e.length;c<a;c++){d[d.length]=[e[c]]}e=d}Ext.data.ArrayStore.superclass.loadData.call(this,e,b)}});Ext.reg("arraystore",Ext.data.ArrayStore);Ext.data.SimpleStore=Ext.data.ArrayStore;Ext.reg("simplestore",Ext.data.SimpleStore);Ext.data.JsonStore=Ext.extend(Ext.data.Store,{constructor:function(a){Ext.data.JsonStore.superclass.con
 structor.call(this,Ext.apply(a,{reader:new Ext.data.JsonReader(a)}))}});Ext.reg("jsonstore",Ext.data.JsonStore);Ext.data.XmlWriter=function(a){Ext.data.XmlWriter.superclass.constructor.apply(this,arguments);this.tpl=(typeof(this.tpl)==="string")?new Ext.XTemplate(this.tpl).compile():this.tpl.compile()};Ext.extend(Ext.data.XmlWriter,Ext.data.DataWriter,{documentRoot:"xrequest",forceDocumentRoot:false,root:"records",xmlVersion:"1.0",xmlEncoding:"ISO-8859-15",tpl:'<tpl for="."><\u003fxml version="{version}" encoding="{encoding}"\u003f><tpl if="documentRoot"><{documentRoot}><tpl for="baseParams"><tpl for="."><{name}>{value}</{name}></tpl></tpl></tpl><tpl if="records.length&gt;1"><{root}></tpl><tpl for="records"><{parent.record}><tpl for="."><{name}>{value}</{name}></tpl></{parent.record}></tpl><tpl if="records.length&gt;1"></{root}></tpl><tpl if="documentRoot"></{documentRoot}></tpl></tpl>',render:function(b,c,a){c=this.toArray(c);b.xmlData=this.tpl.applyTemplate({version:this.x
 mlVersion,encoding:this.xmlEncoding,documentRoot:(c.length>0||this.forceDocumentRoot===true)?this.documentRoot:false,record:this.meta.record,root:this.root,baseParams:c,records:(Ext.isArray(a[0]))?a:[a]})},createRecord:function(a){return this.toArray(this.toHash(a))},updateRecord:function(a){return this.toArray(this.toHash(a))},destroyRecord:function(b){var a={};a[this.meta.idProperty]=b.id;return this.toArray(a)}});Ext.data.XmlReader=function(a,b){a=a||{};Ext.applyIf(a,{idProperty:a.idProperty||a.idPath||a.id,successProperty:a.successProperty||a.success});Ext.data.XmlReader.superclass.constructor.call(this,a,b||a.fields)};Ext.extend(Ext.data.XmlReader,Ext.data.DataReader,{read:function(a){var b=a.responseXML;if(!b){throw {message:"XmlReader.read: XML Document not available"}}return this.readRecords(b)},readRecords:function(d){this.xmlData=d;var a=d.documentElement||d,c=Ext.DomQuery,g=0,e=true;if(this.meta.totalProperty){g=this.getTotal(a,0)}if(this.meta.successProperty){e=t
 his.getSuccess(a)}var b=this.extractData(c.select(this.meta.record,a),true);return{success:e,records:b,totalRecords:g||b.length}},readResponse:function(g,b){var e=Ext.DomQuery,h=b.responseXML,a=h.documentElement||h;var c=new Ext.data.Response({action:g,success:this.getSuccess(a),message:this.getMessage(a),data:this.extractData(e.select(this.meta.record,a)||e.select(this.meta.root,a),false),raw:h});if(Ext.isEmpty(c.success)){throw new Ext.data.DataReader.Error("successProperty-response",this.meta.successProperty)}if(g===Ext.data.Api.actions.create){var d=Ext.isDefined(c.data);if(d&&Ext.isEmpty(c.data)){throw new Ext.data.JsonReader.Error("root-empty",this.meta.root)}else{if(!d){throw new Ext.data.JsonReader.Error("root-undefined-response",this.meta.root)}}}return c},getSuccess:function(){return true},buildExtractors:function(){if(this.ef){return}var l=this.meta,h=this.recordType,e=h.prototype.fields,k=e.items,j=e.length;if(l.totalProperty){this.getTotal=this.createAccessor(l.
 totalProperty)}if(l.successProperty){this.getSuccess=this.createAccessor(l.successProperty)}if(l.messageProperty){this.getMessage=this.createAccessor(l.messageProperty)}this.getRoot=function(g){return(!Ext.isEmpty(g[this.meta.record]))?g[this.meta.record]:g[this.meta.root]};if(l.idPath||l.idProperty){var d=this.createAccessor(l.idPath||l.idProperty);this.getId=function(g){var i=d(g)||g.id;return(i===undefined||i==="")?null:i}}else{this.getId=function(){return null}}var c=[];for(var b=0;b<j;b++){e=k[b];var a=(e.mapping!==undefined&&e.mapping!==null)?e.mapping:e.name;c.push(this.createAccessor(a))}this.ef=c},createAccessor:function(){var a=Ext.DomQuery;return function(b){if(Ext.isFunction(b)){return b}switch(b){case this.meta.totalProperty:return function(c,d){return a.selectNumber(b,c,d)};break;case this.meta.successProperty:return function(d,e){var c=a.selectValue(b,d,true);var g=c!==false&&c!=="false";return g};break;default:return function(c,d){return a.selectValue(b,c,d)}
 ;break}}}(),extractValues:function(h,d,a){var g,c={};for(var e=0;e<a;e++){g=d[e];var b=this.ef[e](h);c[g.name]=g.convert((b!==undefined)?b:g.defaultValue,h)}return c}});Ext.data.XmlStore=Ext.extend(Ext.data.Store,{constructor:function(a){Ext.data.XmlStore.superclass.constructor.call(this,Ext.apply(a,{reader:new Ext.data.XmlReader(a)}))}});Ext.reg("xmlstore",Ext.data.XmlStore);Ext.data.GroupingStore=Ext.extend(Ext.data.Store,{constructor:function(d){d=d||{};this.hasMultiSort=true;this.multiSortInfo=this.multiSortInfo||{sorters:[]};var e=this.multiSortInfo.sorters,c=d.groupField||this.groupField,b=d.sortInfo||this.sortInfo,a=d.groupDir||this.groupDir;if(c){e.push({field:c,direction:a})}if(b){e.push(b)}Ext.data.GroupingStore.superclass.constructor.call(this,d);this.addEvents("groupchange");this.applyGroupField()},remoteGroup:false,groupOnSort:false,groupDir:"ASC",clearGrouping:function(){this.groupField=false;if(this.remoteGroup){if(this.baseParams){delete this.baseParams.group
 By;delete this.baseParams.groupDir}var a=this.lastOptions;if(a&&a.params){delete a.params.groupBy;delete a.params.groupDir}this.reload()}else{this.sort();this.fireEvent("datachanged",this)}},groupBy:function(e,a,d){d=d?(String(d).toUpperCase()=="DESC"?"DESC":"ASC"):this.groupDir;if(this.groupField==e&&this.groupDir==d&&!a){return}var c=this.multiSortInfo.sorters;if(c.length>0&&c[0].field==this.groupField){c.shift()}this.groupField=e;this.groupDir=d;this.applyGroupField();var b=function(){this.fireEvent("groupchange",this,this.getGroupState())};if(this.groupOnSort){this.sort(e,d);b.call(this);return}if(this.remoteGroup){this.on("load",b,this,{single:true});this.reload()}else{this.sort(c);b.call(this)}},sort:function(h,c){if(this.remoteSort){return Ext.data.GroupingStore.superclass.sort.call(this,h,c)}var g=[];if(Ext.isArray(arguments[0])){g=arguments[0]}else{if(h==undefined){g=this.sortInfo?[this.sortInfo]:[]}else{var e=this.fields.get(h);if(!e){return false}var b=e.name,a=th
 is.sortInfo||null,d=this.sortToggle?this.sortToggle[b]:null;if(!c){if(a&&a.field==b){c=(this.sortToggle[b]||"ASC").toggle("ASC","DESC")}else{c=e.sortDir}}this.sortToggle[b]=c;this.sortInfo={field:b,direction:c};g=[this.sortInfo]}}if(this.groupField){g.unshift({direction:this.groupDir,field:this.groupField})}return this.multiSort.call(this,g,c)},applyGroupField:function(){if(this.remoteGroup){if(!this.baseParams){this.baseParams={}}Ext.apply(this.baseParams,{groupBy:this.groupField,groupDir:this.groupDir});var a=this.lastOptions;if(a&&a.params){a.params.groupDir=this.groupDir;delete a.params.groupBy}}},applyGrouping:function(a){if(this.groupField!==false){this.groupBy(this.groupField,true,this.groupDir);return true}else{if(a===true){this.fireEvent("datachanged",this)}return false}},getGroupState:function(){return this.groupOnSort&&this.groupField!==false?(this.sortInfo?this.sortInfo.field:undefined):this.groupField}});Ext.reg("groupingstore",Ext.data.GroupingStore);Ext.data.D
 irectProxy=function(a){Ext.apply(this,a);if(typeof this.paramOrder=="string"){this.paramOrder=this.paramOrder.split(/[\s,|]/)}Ext.data.DirectProxy.superclass.constructor.call(this,a)};Ext.extend(Ext.data.DirectProxy,Ext.data.DataProxy,{paramOrder:undefined,paramsAsHash:true,directFn:undefined,doRequest:function(b,c,a,e,k,l,n){var j=[],h=this.api[b]||this.directFn;switch(b){case Ext.data.Api.actions.create:j.push(a.jsonData);break;case Ext.data.Api.actions.read:if(h.directCfg.method.len>0){if(this.paramOrder){for(var d=0,g=this.paramOrder.length;d<g;d++){j.push(a[this.paramOrder[d]])}}else{if(this.paramsAsHash){j.push(a)}}}break;case Ext.data.Api.actions.update:j.push(a.jsonData);break;case Ext.data.Api.actions.destroy:j.push(a.jsonData);break}var m={params:a||{},request:{callback:k,scope:l,arg:n},reader:e};j.push(this.createCallback(b,c,m),this);h.apply(window,j)},createCallback:function(d,a,b){var c=this;return function(e,g){if(!g.status){if(d===Ext.data.Api.actions.read){c
 .fireEvent("loadexception",c,b,g,null)}c.fireEvent("exception",c,"remote",d,b,g,null);b.request.callback.call(b.request.scope,null,b.request.arg,false);return}if(d===Ext.data.Api.actions.read){c.onRead(d,b,e,g)}else{c.onWrite(d,b,e,g,a)}}},onRead:function(g,e,a,d){var b;try{b=e.reader.readRecords(a)}catch(c){this.fireEvent("loadexception",this,e,d,c);this.fireEvent("exception",this,"response",g,e,d,c);e.request.callback.call(e.request.scope,null,e.request.arg,false);return}this.fireEvent("load",this,d,e.request.arg);e.request.callback.call(e.request.scope,b,e.request.arg,true)},onWrite:function(g,d,a,c,b){var e=d.reader.extractData(d.reader.getRoot(a),false);var h=d.reader.getSuccess(a);h=(h!==false);if(h){this.fireEvent("write",this,g,e,c,b,d.request.arg)}else{this.fireEvent("exception",this,"remote",g,d,a,b)}d.request.callback.call(d.request.scope,e,c,h)}});Ext.data.DirectStore=Ext.extend(Ext.data.Store,{constructor:function(a){var b=Ext.apply({},{batchTransactions:false},
 a);Ext.data.DirectStore.superclass.constructor.call(this,Ext.apply(b,{proxy:Ext.isDefined(b.proxy)?b.proxy:new Ext.data.DirectProxy(Ext.copyTo({},b,"paramOrder,paramsAsHash,directFn,api")),reader:(!Ext.isDefined(b.reader)&&b.fields)?new Ext.data.JsonReader(Ext.copyTo({},b,"totalProperty,root,idProperty"),b.fields):b.reader}))}});Ext.reg("directstore",Ext.data.DirectStore);Ext.Direct=Ext.extend(Ext.util.Observable,{exceptions:{TRANSPORT:"xhr",PARSE:"parse",LOGIN:"login",SERVER:"exception"},constructor:function(){this.addEvents("event","exception");this.transactions={};this.providers={}},addProvider:function(e){var c=arguments;if(c.length>1){for(var d=0,b=c.length;d<b;d++){this.addProvider(c[d])}return}if(!e.events){e=new Ext.Direct.PROVIDERS[e.type](e)}e.id=e.id||Ext.id();this.providers[e.id]=e;e.on("data",this.onProviderData,this);e.on("exception",this.onProviderException,this);if(!e.isConnected()){e.connect()}return e},getProvider:function(a){return this.providers[a]},remov
 eProvider:function(b){var a=b.id?b:this.providers[b];a.un("data",this.onProviderData,this);a.un("exception",this.onProviderException,this);delete this.providers[a.id];return a},addTransaction:function(a){this.transactions[a.tid]=a;return a},removeTransaction:function(a){delete this.transactions[a.tid||a];return a},getTransaction:function(a){return this.transactions[a.tid||a]},onProviderData:function(d,c){if(Ext.isArray(c)){for(var b=0,a=c.length;b<a;b++){this.onProviderData(d,c[b])}return}if(c.name&&c.name!="event"&&c.name!="exception"){this.fireEvent(c.name,c)}else{if(c.type=="exception"){this.fireEvent("exception",c)}}this.fireEvent("event",c,d)},createEvent:function(a,b){return new Ext.Direct.eventTypes[a.type](Ext.apply(a,b))}});Ext.Direct=new Ext.Direct();Ext.Direct.TID=1;Ext.Direct.PROVIDERS={};Ext.Direct.Transaction=function(a){Ext.apply(this,a);this.tid=++Ext.Direct.TID;this.retryCount=0};Ext.Direct.Transaction.prototype={send:function(){this.provider.queueTransactio
 n(this)},retry:function(){this.retryCount++;this.send()},getProvider:function(){return this.provider}};Ext.Direct.Event=function(a){Ext.apply(this,a)};Ext.Direct.Event.prototype={status:true,getData:function(){return this.data}};Ext.Direct.RemotingEvent=Ext.extend(Ext.Direct.Event,{type:"rpc",getTransaction:function(){return this.transaction||Ext.Direct.getTransaction(this.tid)}});Ext.Direct.ExceptionEvent=Ext.extend(Ext.Direct.RemotingEvent,{status:false,type:"exception"});Ext.Direct.eventTypes={rpc:Ext.Direct.RemotingEvent,event:Ext.Direct.Event,exception:Ext.Direct.ExceptionEvent};Ext.direct.Provider=Ext.extend(Ext.util.Observable,{priority:1,constructor:function(a){Ext.apply(this,a);this.addEvents("connect","disconnect","data","exception");Ext.direct.Provider.superclass.constructor.call(this,a)},isConnected:function(){return false},connect:Ext.emptyFn,disconnect:Ext.emptyFn});Ext.direct.JsonProvider=Ext.extend(Ext.direct.Provider,{parseResponse:function(a){if(!Ext.isEmpt
 y(a.responseText)){if(typeof a.responseText=="object"){return a.responseText}return Ext.decode(a.responseText)}return null},getEvents:function(j){var g=null;try{g=this.parseResponse(j)}catch(h){var d=new Ext.Direct.ExceptionEvent({data:h,xhr:j,code:Ext.Direct.exceptions.PARSE,message:"Error parsing json response: \n\n "+g});return[d]}var c=[];if(Ext.isArray(g)){for(var b=0,a=g.length;b<a;b++){c.push(Ext.Direct.createEvent(g[b]))}}else{c.push(Ext.Direct.createEvent(g))}return c}});Ext.direct.PollingProvider=Ext.extend(Ext.direct.JsonProvider,{priority:3,interval:3000,constructor:function(a){Ext.direct.PollingProvider.superclass.constructor.call(this,a);this.addEvents("beforepoll","poll")},isConnected:function(){return !!this.pollTask},connect:function(){if(this.url&&!this.pollTask){this.pollTask=Ext.TaskMgr.start({run:function(){if(this.fireEvent("beforepoll",this)!==false){if(typeof this.url=="function"){this.url(this.baseParams)}else{Ext.Ajax.request({url:this.url,callback:
 this.onData,scope:this,params:this.baseParams})}}},interval:this.interval,scope:this});this.fireEvent("connect",this)}else{if(!this.url){throw"Error initializing PollingProvider, no url configured."}}},disconnect:function(){if(this.pollTask){Ext.TaskMgr.stop(this.pollTask);delete this.pollTask;this.fireEvent("disconnect",this)}},onData:function(d,j,h){if(j){var c=this.getEvents(h);for(var b=0,a=c.length;b<a;b++){var g=c[b];this.fireEvent("data",this,g)}}else{var g=new Ext.Direct.ExceptionEvent({data:g,code:Ext.Direct.exceptions.TRANSPORT,message:"Unable to connect to the server.",xhr:h});this.fireEvent("data",this,g)}}});Ext.Direct.PROVIDERS.polling=Ext.direct.PollingProvider;Ext.direct.RemotingProvider=Ext.extend(Ext.direct.JsonProvider,{enableBuffer:10,maxRetries:1,timeout:undefined,constructor:function(a){Ext.direct.RemotingProvider.superclass.constructor.call(this,a);this.addEvents("beforecall","call");this.namespace=(Ext.isString(this.namespace))?Ext.ns(this.namespace):
 this.namespace||window;this.transactions={};this.callBuffer=[]},initAPI:function(){var h=this.actions;for(var j in h){var d=this.namespace[j]||(this.namespace[j]={}),e=h[j];for(var g=0,b=e.length;g<b;g++){var a=e[g];d[a.name]=this.createMethod(j,a)}}},isConnected:function(){return !!this.connected},connect:function(){if(this.url){this.initAPI();this.connected=true;this.fireEvent("connect",this)}else{if(!this.url){throw"Error initializing RemotingProvider, no url configured."}}},disconnect:function(){if(this.connected){this.connected=false;this.fireEvent("disconnect",this)}},onData:function(a,h,j){if(h){var k=this.getEvents(j);for(var b=0,c=k.length;b<c;b++){var d=k[b],l=this.getTransaction(d);this.fireEvent("data",this,d);if(l){this.doCallback(l,d,true);Ext.Direct.removeTransaction(l)}}}else{var g=[].concat(a.ts);for(var b=0,c=g.length;b<c;b++){var l=this.getTransaction(g[b]);if(l&&l.retryCount<this.maxRetries){l.retry()}else{var d=new Ext.Direct.ExceptionEvent({data:d,trans
 action:l,code:Ext.Direct.exceptions.TRANSPORT,message:"Unable to connect to the server.",xhr:j});this.fireEvent("data",this,d);if(l){this.doCallback(l,d,false);Ext.Direct.removeTransaction(l)}}}}},getCallData:function(a){return{action:a.action,method:a.method,data:a.data,type:"rpc",tid:a.tid}},doSend:function(d){var g={url:this.url,callback:this.onData,scope:this,ts:d,timeout:this.timeout},b;if(Ext.isArray(d)){b=[];for(var c=0,a=d.length;c<a;c++){b.push(this.getCallData(d[c]))}}else{b=this.getCallData(d)}if(this.enableUrlEncode){var e={};e[Ext.isString(this.enableUrlEncode)?this.enableUrlEncode:"data"]=Ext.encode(b);g.params=e}else{g.jsonData=b}Ext.Ajax.request(g)},combineAndSend:function(){var a=this.callBuffer.length;if(a>0){this.doSend(a==1?this.callBuffer[0]:this.callBuffer);this.callBuffer=[]}},queueTransaction:function(a){if(a.form){this.processForm(a);return}this.callBuffer.push(a);if(this.enableBuffer){if(!this.callTask){this.callTask=new Ext.util.DelayedTask(this.co
 mbineAndSend,this)}this.callTask.delay(Ext.isNumber(this.enableBuffer)?this.enableBuffer:10)}else{this.combineAndSend()}},doCall:function(i,a,b){var h=null,e=b[a.len],g=b[a.len+1];if(a.len!==0){h=b.slice(0,a.len)}var d=new Ext.Direct.Transaction({provider:this,args:b,action:i,method:a.name,data:h,cb:g&&Ext.isFunction(e)?e.createDelegate(g):e});if(this.fireEvent("beforecall",this,d,a)!==false){Ext.Direct.addTransaction(d);this.queueTransaction(d);this.fireEvent("call",this,d,a)}},doForm:function(j,b,g,i,e){var d=new Ext.Direct.Transaction({provider:this,action:j,method:b.name,args:[g,i,e],cb:e&&Ext.isFunction(i)?i.createDelegate(e):i,isForm:true});if(this.fireEvent("beforecall",this,d,b)!==false){Ext.Direct.addTransaction(d);var a=String(g.getAttribute("enctype")).toLowerCase()=="multipart/form-data",h={extTID:d.tid,extAction:j,extMethod:b.name,extType:"rpc",extUpload:String(a)};Ext.apply(d,{form:Ext.getDom(g),isUpload:a,params:i&&Ext.isObject(i.params)?Ext.apply(h,i.params):
 h});this.fireEvent("call",this,d,b);this.processForm(d)}},processForm:function(a){Ext.Ajax.request({url:this.url,params:a.params,callback:this.onData,scope:this,form:a.form,isUpload:a.isUpload,ts:a})},createMethod:function(d,a){var b;if(!a.formHandler){b=function(){this.doCall(d,a,Array.prototype.slice.call(arguments,0))}.createDelegate(this)}else{b=function(e,g,c){this.doForm(d,a,e,g,c)}.createDelegate(this)}b.directCfg={action:d,method:a};return b},getTransaction:function(a){return a&&a.tid?Ext.Direct.getTransaction(a.tid):null},doCallback:function(c,g){var d=g.status?"success":"failure";if(c&&c.cb){var b=c.cb,a=Ext.isDefined(g.result)?g.result:g.data;if(Ext.isFunction(b)){b(a,g)}else{Ext.callback(b[d],b.scope,[a,g]);Ext.callback(b.callback,b.scope,[a,g])}}}});Ext.Direct.PROVIDERS.remoting=Ext.direct.RemotingProvider;Ext.Resizable=Ext.extend(Ext.util.Observable,{constructor:function(d,e){this.el=Ext.get(d);if(e&&e.wrap){e.resizeChild=this.el;this.el=this.el.wrap(typeof e.w
 rap=="object"?e.wrap:{cls:"xresizable-wrap"});this.el.id=this.el.dom.id=e.resizeChild.id+"-rzwrap";this.el.setStyle("overflow","hidden");this.el.setPositioning(e.resizeChild.getPositioning());e.resizeChild.clearPositioning();if(!e.width||!e.height){var g=e.resizeChild.getSize();this.el.setSize(g.width,g.height)}if(e.pinned&&!e.adjustments){e.adjustments="auto"}}this.proxy=this.el.createProxy({tag:"div",cls:"x-resizable-proxy",id:this.el.id+"-rzproxy"},Ext.getBody());this.proxy.unselectable();this.proxy.enableDisplayMode("block");Ext.apply(this,e);if(this.pinned){this.disableTrackOver=true;this.el.addClass("x-resizable-pinned")}var k=this.el.getStyle("position");if(k!="absolute"&&k!="fixed"){this.el.setStyle("position","relative")}if(!this.handles){this.handles="s,e,se";if(this.multiDirectional){this.handles+=",n,w"}}if(this.handles=="all"){this.handles="n s e w ne nw se sw"}var o=this.handles.split(/\s*?[,;]\s*?| /);var c=Ext.Resizable.positions;for(var j=0,l=o.length;j<l;j+
 +){if(o[j]&&c[o[j]]){var n=c[o[j]];this[n]=new Ext.Resizable.Handle(this,n,this.disableTrackOver,this.transparent,this.handleCls)}}this.corner=this.southeast;if(this.handles.indexOf("n")!=-1||this.handles.indexOf("w")!=-1){this.updateBox=true}this.activeHandle=null;if(this.resizeChild){if(typeof this.resizeChild=="boolean"){this.resizeChild=Ext.get(this.el.dom.firstChild,true)}else{this.resizeChild=Ext.get(this.resizeChild,true)}}if(this.adjustments=="auto"){var b=this.resizeChild;var m=this.west,h=this.east,a=this.north,o=this.south;if(b&&(m||a)){b.position("relative");b.setLeft(m?m.el.getWidth():0);b.setTop(a?a.el.getHeight():0)}this.adjustments=[(h?-h.el.getWidth():0)+(m?-m.el.getWidth():0),(a?-a.el.getHeight():0)+(o?-o.el.getHeight():0)-1]}if(this.draggable){this.dd=this.dynamic?this.el.initDD(null):this.el.initDDProxy(null,{dragElId:this.proxy.id});this.dd.setHandleElId(this.resizeChild?this.resizeChild.id:this.el.id);if(this.constrainTo){this.dd.constrainTo(this.constr
 ainTo)}}this.addEvents("beforeresize","resize");if(this.width!==null&&this.height!==null){this.resizeTo(this.width,this.height)}else{this.updateChildSize()}if(Ext.isIE){this.el.dom.style.zoom=1}Ext.Resizable.superclass.constructor.call(this)},adjustments:[0,0],animate:false,disableTrackOver:false,draggable:false,duration:0.35,dynamic:false,easing:"easeOutStrong",enabled:true,handles:false,multiDirectional:false,height:null,width:null,heightIncrement:0,widthIncrement:0,minHeight:5,minWidth:5,maxHeight:10000,maxWidth:10000,minX:0,minY:0,pinned:false,preserveRatio:false,resizeChild:false,transparent:false,resizeTo:function(b,a){this.el.setSize(b,a);this.updateChildSize();this.fireEvent("resize",this,b,a,null)},startSizing:function(c,b){this.fireEvent("beforeresize",this,c);if(this.enabled){if(!this.overlay){this.overlay=this.el.createProxy({tag:"div",cls:"x-resizable-overlay",html:"&#160;"},Ext.getBody());this.overlay.unselectable();this.overlay.enableDisplayMode("block");this.
 overlay.on({scope:this,mousemove:this.onMouseMove,mouseup:this.onMouseUp})}this.overlay.setStyle("cursor",b.el.getStyle("cursor"));this.resizing=true;this.startBox=this.el.getBox();this.startPoint=c.getXY();this.offsets=[(this.startBox.x+this.startBox.width)-this.startPoint[0],(this.startBox.y+this.startBox.height)-this.startPoint[1]];this.overlay.setSize(Ext.lib.Dom.getViewWidth(true),Ext.lib.Dom.getViewHeight(true));this.overlay.show();if(this.constrainTo){var a=Ext.get(this.constrainTo);this.resizeRegion=a.getRegion().adjust(a.getFrameWidth("t"),a.getFrameWidth("l"),-a.getFrameWidth("b"),-a.getFrameWidth("r"))}this.proxy.setStyle("visibility","hidden");this.proxy.show();this.proxy.setBox(this.startBox);if(!this.dynamic){this.proxy.setStyle("visibility","visible")}}},onMouseDown:function(a,b){if(this.enabled){b.stopEvent();this.activeHandle=a;this.startSizing(b,a)}},onMouseUp:function(b){this.activeHandle=null;var a=this.resizeElement();this.resizing=false;this.handleOut()
 ;this.overlay.hide();this.proxy.hide();this.fireEvent("resize",this,a.width,a.height,b)},updateChildSize:function(){if(this.resizeChild){var d=this.el;var e=this.resizeChild;var c=this.adjustments;if(d.dom.offsetWidth){var a=d.getSize(true);e.setSize(a.width+c[0],a.height+c[1])}if(Ext.isIE){setTimeout(function(){if(d.dom.offsetWidth){var g=d.getSize(true);e.setSize(g.width+c[0],g.height+c[1])}},10)}}},snap:function(c,e,b){if(!e||!c){return c}var d=c;var a=c%e;if(a>0){if(a>(e/2)){d=c+(e-a)}else{d=c-a}}return Math.max(b,d)},resizeElement:function(){var a=this.proxy.getBox();if(this.updateBox){this.el.setBox(a,false,this.animate,this.duration,null,this.easing)}else{this.el.setSize(a.width,a.height,this.animate,this.duration,null,this.easing)}this.updateChildSize();if(!this.dynamic){this.proxy.hide()}if(this.draggable&&this.constrainTo){this.dd.resetConstraints();this.dd.constrainTo(this.constrainTo)}return a},constrain:function(b,c,a,d){if(b-c<a){c=b-a}else{if(b-c>d){c=b-d}}ret
 urn c},onMouseMove:function(z){if(this.enabled&&this.activeHandle){try{if(this.resizeRegion&&!this.resizeRegion.contains(z.getPoint())){return}var t=this.curSize||this.startBox,l=this.startBox.x,k=this.startBox.y,c=l,b=k,m=t.width,u=t.height,d=m,o=u,n=this.minWidth,A=this.minHeight,s=this.maxWidth,D=this.maxHeight,i=this.widthIncrement,a=this.heightIncrement,B=z.getXY(),r=-(this.startPoint[0]-Math.max(this.minX,B[0])),p=-(this.startPoint[1]-Math.max(this.minY,B[1])),j=this.activeHandle.position,E,g;switch(j){case"east":m+=r;m=Math.min(Math.max(n,m),s);break;case"south":u+=p;u=Math.min(Math.max(A,u),D);break;case"southeast":m+=r;u+=p;m=Math.min(Math.max(n,m),s);u=Math.min(Math.max(A,u),D);break;case"north":p=this.constrain(u,p,A,D);k+=p;u-=p;break;case"west":r=this.constrain(m,r,n,s);l+=r;m-=r;break;case"northeast":m+=r;m=Math.min(Math.max(n,m),s);p=this.constrain(u,p,A,D);k+=p;u-=p;break;case"northwest":r=this.constrain(m,r,n,s);p=this.constrain(u,p,A,D);k+=p;u-=p;l+=r;m-=r;
 break;case"southwest":r=this.constrain(m,r,n,s);u+=p;u=Math.min(Math.max(A,u),D);l+=r;m-=r;break}var q=this.snap(m,i,n);var C=this.snap(u,a,A);if(q!=m||C!=u){switch(j){case"northeast":k-=C-u;break;case"north":k-=C-u;break;case"southwest":l-=q-m;break;case"west":l-=q-m;break;case"northwest":l-=q-m;k-=C-u;break}m=q;u=C}if(this.preserveRatio){switch(j){case"southeast":case"east":u=o*(m/d);u=Math.min(Math.max(A,u),D);m=d*(u/o);break;case"south":m=d*(u/o);m=Math.min(Math.max(n,m),s);u=o*(m/d);break;case"northeast":m=d*(u/o);m=Math.min(Math.max(n,m),s);u=o*(m/d);break;case"north":E=m;m=d*(u/o);m=Math.min(Math.max(n,m),s);u=o*(m/d);l+=(E-m)/2;break;case"southwest":u=o*(m/d);u=Math.min(Math.max(A,u),D);E=m;m=d*(u/o);l+=E-m;break;case"west":g=u;u=o*(m/d);u=Math.min(Math.max(A,u),D);k+=(g-u)/2;E=m;m=d*(u/o);l+=E-m;break;case"northwest":E=m;g=u;u=o*(m/d);u=Math.min(Math.max(A,u),D);m=d*(u/o);k+=g-u;l+=E-m;break}}this.proxy.setBounds(l,k,m,u);if(this.dynamic){this.resizeElement()}}catch
 (v){}}},handleOver:function(){if(this.enabled){this.el.addClass("x-resizable-over")}},handleOut:function(){if(!this.resizing){this.el.removeClass("x-resizable-over")}},getEl:function(){return this.el},getResizeChild:function(){return this.resizeChild},destroy:function(b){Ext.destroy(this.dd,this.overlay,this.proxy);this.overlay=null;this.proxy=null;var c=Ext.Resizable.positions;for(var a in c){if(typeof c[a]!="function"&&this[c[a]]){this[c[a]].destroy()}}if(b){this.el.update("");Ext.destroy(this.el);this.el=null}this.purgeListeners()},syncHandleHeight:function(){var a=this.el.getHeight(true);if(this.west){this.west.el.setHeight(a)}if(this.east){this.east.el.setHeight(a)}}});Ext.Resizable.positions={n:"north",s:"south",e:"east",w:"west",se:"southeast",sw:"southwest",nw:"northwest",ne:"northeast"};Ext.Resizable.Handle=Ext.extend(Object,{constructor:function(d,g,c,e,a){if(!this.tpl){var b=Ext.DomHelper.createTemplate({tag:"div",cls:"x-resizable-handle x-resizable-handle-{0}"});
 b.compile();Ext.Resizable.Handle.prototype.tpl=b}this.position=g;this.rz=d;this.el=this.tpl.append(d.el.dom,[this.position],true);this.el.unselectable();if(e){this.el.setOpacity(0)}if(!Ext.isEmpty(a)){this.el.addClass(a)}this.el.on("mousedown",this.onMouseDown,this);if(!c){this.el.on({scope:this,mouseover:this.onMouseOver,mouseout:this.onMouseOut})}},afterResize:function(a){},onMouseDown:function(a){this.rz.onMouseDown(this,a)},onMouseOver:function(a){this.rz.handleOver(this,a)},onMouseOut:function(a){this.rz.handleOut(this,a)},destroy:function(){Ext.destroy(this.el);this.el=null}});Ext.Window=Ext.extend(Ext.Panel,{baseCls:"x-window",resizable:true,draggable:true,closable:true,closeAction:"close",constrain:false,constrainHeader:false,plain:false,minimizable:false,maximizable:false,minHeight:100,minWidth:200,expandOnShow:true,showAnimDuration:0.25,hideAnimDuration:0.25,collapsible:false,initHidden:undefined,hidden:true,elements:"header,body",frame:true,floating:true,initCompo
 nent:function(){this.initTools();Ext.Window.superclass.initComponent.call(this);this.addEvents("resize","maximize","minimize","restore");if(Ext.isDefined(this.initHidden)){this.hidden=this.initHidden}if(this.hidden===false){this.hidden=true;this.show()}},getState:function(){return Ext.apply(Ext.Window.superclass.getState.call(this)||{},this.getBox(true))},onRender:function(b,a){Ext.Window.superclass.onRender.call(this,b,a);if(this.plain){this.el.addClass("x-window-plain")}this.focusEl=this.el.createChild({tag:"a",href:"#",cls:"x-dlg-focus",tabIndex:"-1",html:"&#160;"});this.focusEl.swallowEvent("click",true);this.proxy=this.el.createProxy("x-window-proxy");this.proxy.enableDisplayMode("block");if(this.modal){this.mask=this.container.createChild({cls:"ext-el-mask"},this.el.dom);this.mask.enableDisplayMode("block");this.mask.hide();this.mon(this.mask,"click",this.focus,this)}if(this.maximizable){this.mon(this.header,"dblclick",this.toggleMaximize,this)}},initEvents:function(){
 Ext.Window.superclass.initEvents.call(this);if(this.animateTarget){this.setAnimateTarget(this.animateTarget)}if(this.resizable){this.resizer=new Ext.Resizable(this.el,{minWidth:this.minWidth,minHeight:this.minHeight,handles:this.resizeHandles||"all",pinned:true,resizeElement:this.resizerAction,handleCls:"x-window-handle"});this.resizer.window=this;this.mon(this.resizer,"beforeresize",this.beforeResize,this)}if(this.draggable){this.header.addClass("x-window-draggable")}this.mon(this.el,"mousedown",this.toFront,this);this.manager=this.manager||Ext.WindowMgr;this.manager.register(this);if(this.maximized){this.maximized=false;this.maximize()}if(this.closable){var a=this.getKeyMap();a.on(27,this.onEsc,this);a.disable()}},initDraggable:function(){this.dd=new Ext.Window.DD(this)},onEsc:function(a,b){if(this.activeGhost){this.unghost()}b.stopEvent();this[this.closeAction]()},beforeDestroy:function(){if(this.rendered){this.hide();this.clearAnchor();Ext.destroy(this.focusEl,this.resiz
 er,this.dd,this.proxy,this.mask)}Ext.Window.superclass.beforeDestroy.call(this)},onDestroy:function(){if(this.manager){this.manager.unregister(this)}Ext.Window.superclass.onDestroy.call(this)},initTools:function(){if(this.minimizable){this.addTool({id:"minimize",handler:this.minimize.createDelegate(this,[])})}if(this.maximizable){this.addTool({id:"maximize",handler:this.maximize.createDelegate(this,[])});this.addTool({id:"restore",handler:this.restore.createDelegate(this,[]),hidden:true})}if(this.closable){this.addTool({id:"close",handler:this[this.closeAction].createDelegate(this,[])})}},resizerAction:function(){var a=this.proxy.getBox();this.proxy.hide();this.window.handleResize(a);return a},beforeResize:function(){this.resizer.minHeight=Math.max(this.minHeight,this.getFrameHeight()+40);this.resizer.minWidth=Math.max(this.minWidth,this.getFrameWidth()+40);this.resizeBox=this.el.getBox()},updateHandles:function(){if(Ext.isIE&&this.resizer){this.resizer.syncHandleHeight();th
 is.el.repaint()}},handleResize:function(b){var a=this.resizeBox;if(a.x!=b.x||a.y!=b.y){this.updateBox(b)}else{this.setSize(b);if(Ext.isIE6&&Ext.isStrict){this.doLayout()}}this.focus();this.updateHandles();this.saveState()},focus:function(){var e=this.focusEl,a=this.defaultButton,c=typeof a,d,b;if(Ext.isDefined(a)){if(Ext.isNumber(a)&&this.fbar){e=this.fbar.items.get(a)}else{if(Ext.isString(a)){e=Ext.getCmp(a)}else{e=a}}d=e.getEl();b=Ext.getDom(this.container);if(d&&b){if(b!=document.body&&!Ext.lib.Region.getRegion(b).contains(Ext.lib.Region.getRegion(d.dom))){return}}}e=e||this.focusEl;e.focus.defer(10,e)},setAnimateTarget:function(a){a=Ext.get(a);this.animateTarget=a},beforeShow:function(){delete this.el.lastXY;delete this.el.lastLT;if(this.x===undefined||this.y===undefined){var a=this.el.getAlignToXY(this.container,"c-c");var b=this.el.translatePoints(a[0],a[1]);this.x=this.x===undefined?b.left:this.x;this.y=this.y===undefined?b.top:this.y}this.el.setLeftTop(this.x,this.y)
 ;if(this.expandOnShow){this.expand(false)}if(this.modal){Ext.getBody().addClass("x-body-masked");this.mask.setSize(Ext.lib.Dom.getViewWidth(true),Ext.lib.Dom.getViewHeight(true));this.mask.show()}},show:function(c,a,b){if(!this.rendered){this.render(Ext.getBody())}if(this.hidden===false){this.toFront();return this}if(this.fireEvent("beforeshow",this)===false){return this}if(a){this.on("show",a,b,{single:true})}this.hidden=false;if(Ext.isDefined(c)){this.setAnimateTarget(c)}this.beforeShow();if(this.animateTarget){this.animShow()}else{this.afterShow()}return this},afterShow:function(b){if(this.isDestroyed){return false}this.proxy.hide();this.el.setStyle("display","block");this.el.show();if(this.maximized){this.fitContainer()}if(Ext.isMac&&Ext.isGecko2){this.cascade(this.setAutoScroll)}if(this.monitorResize||this.modal||this.constrain||this.constrainHeader){Ext.EventManager.onWindowResize(this.onWindowResize,this)}this.doConstrain();this.doLayout();if(this.keyMap){this.keyMap.
 enable()}this.toFront();this.updateHandles();if(b&&(Ext.isIE||Ext.isWebKit)){var a=this.getSize();this.onResize(a.width,a.height)}this.onShow();this.fireEvent("show",this)},animShow:function(){this.proxy.show();this.proxy.setBox(this.animateTarget.getBox());this.proxy.setOpacity(0);var a=this.getBox();this.el.setStyle("display","none");this.proxy.shift(Ext.apply(a,{callback:this.afterShow.createDelegate(this,[true],false),scope:this,easing:"easeNone",duration:this.showAnimDuration,opacity:0.5}))},hide:function(c,a,b){if(this.hidden||this.fireEvent("beforehide",this)===false){return this}if(a){this.on("hide",a,b,{single:true})}this.hidden=true;if(c!==undefined){this.setAnimateTarget(c)}if(this.modal){this.mask.hide();Ext.getBody().removeClass("x-body-masked")}if(this.animateTarget){this.animHide()}else{this.el.hide();this.afterHide()}return this},afterHide:function(){this.proxy.hide();if(this.monitorResize||this.modal||this.constrain||this.constrainHeader){Ext.EventManager.re
 moveResizeListener(this.onWindowResize,this)}if(this.keyMap){this.keyMap.disable()}this.onHide();this.fireEvent("hide",this)},animHide:function(){this.proxy.setOpacity(0.5);this.proxy.show();var a=this.getBox(false);this.proxy.setBox(a);this.el.hide();this.proxy.shift(Ext.apply(this.animateTarget.getBox(),{callback:this.afterHide,scope:this,duration:this.hideAnimDuration,easing:"easeNone",opacity:0}))},onShow:Ext.emptyFn,onHide:Ext.emptyFn,onWindowResize:function(){if(this.maximized){this.fitContainer()}if(this.modal){this.mask.setSize("100%","100%");var a=this.mask.dom.offsetHeight;this.mask.setSize(Ext.lib.Dom.getViewWidth(true),Ext.lib.Dom.getViewHeight(true))}this.doConstrain()},doConstrain:function(){if(this.constrain||this.constrainHeader){var b;if(this.constrain){b={right:this.el.shadowOffset,left:this.el.shadowOffset,bottom:this.el.shadowOffset}}else{var a=this.getSize();b={right:-(a.width-100),bottom:-(a.height-25+this.el.getConstrainOffset())}}var c=this.el.getCons
 trainToXY(this.container,true,b);if(c){this.setPosition(c[0],c[1])}}},ghost:function(a){var c=this.createGhost(a);var b=this.getBox(true);c.setLeftTop(b.x,b.y);c.setWidth(b.width);this.el.hide();this.activeGhost=c;return c},unghost:function(b,a){if(!this.activeGhost){return}if(b!==false){this.el.show();this.focus.defer(10,this);if(Ext.isMac&&Ext.isGecko2){this.cascade(this.setAutoScroll)}}if(a!==false){this.setPosition(this.activeGhost.getLeft(true),this.activeGhost.getTop(true))}this.activeGhost.hide();this.activeGhost.remove();delete this.activeGhost},minimize:function(){this.fireEvent("minimize",this);return this},close:function(){if(this.fireEvent("beforeclose",this)!==false){if(this.hidden){this.doClose()}else{this.hide(null,this.doClose,this)}}},doClose:function(){this.fireEvent("close",this);this.destroy()},maximize:function(){if(!this.maximized){this.expand(false);this.restoreSize=this.getSize();this.restorePos=this.getPosition(true);if(this.maximizable){this.tools.m
 aximize.hide();this.tools.restore.show()}this.maximized=true;this.el.disableShadow();if(this.dd){this.dd.lock()}if(this.collapsible){this.tools.toggle.hide()}this.el.addClass("x-window-maximized");this.container.addClass("x-window-maximized-ct");this.setPosition(0,0);this.fitContainer();this.fireEvent("maximize",this)}return this},restore:function(){if(this.maximized){var a=this.tools;this.el.removeClass("x-window-maximized");if(a.restore){a.restore.hide()}if(a.maximize){a.maximize.show()}this.setPosition(this.restorePos[0],this.restorePos[1]);this.setSize(this.restoreSize.width,this.restoreSize.height);delete this.restorePos;delete this.restoreSize;this.maximized=false;this.el.enableShadow(true);if(this.dd){this.dd.unlock()}if(this.collapsible&&a.toggle){a.toggle.show()}this.container.removeClass("x-window-maximized-ct");this.doConstrain();this.fireEvent("restore",this)}return this},toggleMaximize:function(){return this[this.maximized?"restore":"maximize"]()},fitContainer:f
 unction(){var a=this.container.getViewSize(false);this.setSize(a.width,a.height)},setZIndex:function(a){if(this.modal){this.mask.setStyle("z-index",a)}this.el.setZIndex(++a);a+=5;if(this.resizer){this.resizer.proxy.setStyle("z-index",++a)}this.lastZIndex=a},alignTo:function(b,a,c){var d=this.el.getAlignToXY(b,a,c);this.setPagePosition(d[0],d[1]);return this},anchorTo:function(c,e,d,b){this.clearAnchor();this.anchorTarget={el:c,alignment:e,offsets:d};Ext.EventManager.onWindowResize(this.doAnchor,this);var a=typeof b;if(a!="undefined"){Ext.EventManager.on(window,"scroll",this.doAnchor,this,{buffer:a=="number"?b:50})}return this.doAnchor()},doAnchor:function(){var a=this.anchorTarget;this.alignTo(a.el,a.alignment,a.offsets);return this},clearAnchor:function(){if(this.anchorTarget){Ext.EventManager.removeResizeListener(this.doAnchor,this);Ext.EventManager.un(window,"scroll",this.doAnchor,this);delete this.anchorTarget}return this},toFront:function(a){if(this.manager.bringToFront
 (this)){if(!a||!a.getTarget().focus){this.focus()}}return this},setActive:function(a){if(a){if(!this.maximized){this.el.enableShadow(true)}this.fireEvent("activate",this)}else{this.el.disableShadow();this.fireEvent("deactivate",this)}},toBack:function(){this.manager.sendToBack(this);return this},center:function(){var a=this.el.getAlignToXY(this.container,"c-c");this.setPagePosition(a[0],a[1]);return this}});Ext.reg("window",Ext.Window);Ext.Window.DD=Ext.extend(Ext.dd.DD,{constructor:function(a){this.win=a;Ext.Window.DD.superclass.constructor.call(this,a.el.id,"WindowDD-"+a.id);this.setHandleElId(a.header.id);this.scroll=false},moveOnly:true,headerOffsets:[100,25],startDrag:function(){var a=this.win;this.proxy=a.ghost(a.initialConfig.cls);if(a.constrain!==false){var c=a.el.shadowOffset;this.constrainTo(a.container,{right:c,left:c,bottom:c})}else{if(a.constrainHeader!==false){var b=this.proxy.getSize();this.constrainTo(a.container,{right:-(b.width-this.headerOffsets[0]),bottom
 :-(b.height-this.headerOffsets[1])})}}},b4Drag:Ext.emptyFn,onDrag:function(a){this.alignElWithMouse(this.proxy,a.getPageX(),a.getPageY())},endDrag:function(a){this.win.unghost();this.win.saveState()}});Ext.WindowGroup=function(){var g={};var d=[];var e=null;var c=function(j,i){return(!j._lastAccess||j._lastAccess<i._lastAccess)?-1:1};var h=function(){var l=d,j=l.length;if(j>0){l.sort(c);var k=l[0].manager.zseed;for(var m=0;m<j;m++){var n=l[m];if(n&&!n.hidden){n.setZIndex(k+(m*10))}}}a()};var b=function(i){if(i!=e){if(e){e.setActive(false)}e=i;if(i){i.setActive(true)}}};var a=function(){for(var j=d.length-1;j>=0;--j){if(!d[j].hidden){b(d[j]);return}}b(null)};return{zseed:9000,register:function(i){if(i.manager){i.manager.unregister(i)}i.manager=this;g[i.id]=i;d.push(i);i.on("hide",a)},unregister:function(i){delete i.manager;delete g[i.id];i.un("hide",a);d.remove(i)},get:function(i){return typeof i=="object"?i:g[i]},bringToFront:function(i){i=this.get(i);if(i!=e){i._lastAccess=
 new Date().getTime();h();return true}return false},sendToBack:function(i){i=this.get(i);i._lastAccess=-(new Date().getTime());h();return i},hideAll:function(){for(var i in g){if(g[i]&&typeof g[i]!="function"&&g[i].isVisible()){g[i].hide()}}},getActive:function(){return e},getBy:function(l,k){var m=[];for(var j=d.length-1;j>=0;--j){var n=d[j];if(l.call(k||n,n)!==false){m.push(n)}}return m},each:function(j,i){for(var k in g){if(g[k]&&typeof g[k]!="function"){if(j.call(i||g[k],g[k])===false){return}}}}}};Ext.WindowMgr=new Ext.WindowGroup();Ext.MessageBox=function(){var u,b,q,t,h,l,s,a,n,p,j,g,r,v,o,i="",d="",m=["ok","yes","no","cancel"];var c=function(x){r[x].blur();if(u.isVisible()){u.hide();w();Ext.callback(b.fn,b.scope||window,[x,v.dom.value,b],1)}};var w=function(){if(b&&b.cls){u.el.removeClass(b.cls)}n.reset()};var e=function(z,x,y){if(b&&b.closable!==false){u.hide();w()}if(y){y.stopEvent()}};var k=function(x){var z=0,y;if(!x){Ext.each(m,function(A){r[A].hide()});return z}
 u.footer.dom.style.display="";Ext.iterate(r,function(A,B){y=x[A];if(y){B.show();B.setText(Ext.isString(y)?y:Ext.MessageBox.buttonText[A]);z+=B.getEl().getWidth()+15}else{B.hide()}});return z};return{getDialog:function(x){if(!u){var z=[];r={};Ext.each(m,function(A){z.push(r[A]=new Ext.Button({text:this.buttonText[A],handler:c.createCallback(A),hideMode:"offsets"}))},this);u=new Ext.Window({autoCreate:true,title:x,resizable:false,constrain:true,constrainHeader:true,minimizable:false,maximizable:false,stateful:false,modal:true,shim:true,buttonAlign:"center",width:400,height:100,minHeight:80,plain:true,footer:true,closable:true,close:function(){if(b&&b.buttons&&b.buttons.no&&!b.buttons.cancel){c("no")}else{c("cancel")}},fbar:new Ext.Toolbar({items:z,enableOverflow:false})});u.render(document.body);u.getEl().addClass("x-window-dlg");q=u.mask;h=u.body.createChild({html:'<div class="ext-mb-icon"></div><div class="ext-mb-content"><span class="ext-mb-text"></span><br /><div class="ex
 t-mb-fix-cursor"><input type="text" class="ext-mb-input" /><textarea class="ext-mb-textarea"></textarea></div></div>'});j=Ext.get(h.dom.firstChild);var y=h.dom.childNodes[1];l=Ext.get(y.firstChild);s=Ext.get(y.childNodes[2].firstChild);s.enableDisplayMode();s.addKeyListener([10,13],function(){if(u.isVisible()&&b&&b.buttons){if(b.buttons.ok){c("ok")}else{if(b.buttons.yes){c("yes")}}}});a=Ext.get(y.childNodes[2].childNodes[1]);a.enableDisplayMode();n=new Ext.ProgressBar({renderTo:h});h.createChild({cls:"x-clear"})}return u},updateText:function(A){if(!u.isVisible()&&!b.width){u.setSize(this.maxWidth,100)}l.update(A?A+" ":"&#160;");var y=d!=""?(j.getWidth()+j.getMargins("lr")):0,C=l.getWidth()+l.getMargins("lr"),z=u.getFrameWidth("lr"),B=u.body.getFrameWidth("lr"),x;x=Math.max(Math.min(b.width||y+C+z+B,b.maxWidth||this.maxWidth),Math.max(b.minWidth||this.minWidth,o||0));if(b.prompt===true){v.setWidth(x-y-z-B)}if(b.progress===true||b.wait===true){n.setSize(x-y-z-B)}if(Ext.isIE&&x
 ==o){x+=4}l.update(A||"&#160;");u.setSize(x,"auto").center();return this},updateProgress:function(y,x,z){n.updateProgress(y,x);if(z){this.updateText(z)}return this},isVisible:function(){return u&&u.isVisible()},hide:function(){var x=u?u.activeGhost:null;if(this.isVisible()||x){u.hide();w();if(x){u.unghost(false,false)}}return this},show:function(A){if(this.isVisible()){this.hide()}b=A;var B=this.getDialog(b.title||"&#160;");B.setTitle(b.title||"&#160;");var x=(b.closable!==false&&b.progress!==true&&b.wait!==true);B.tools.close.setDisplayed(x);v=s;b.prompt=b.prompt||(b.multiline?true:false);if(b.prompt){if(b.multiline){s.hide();a.show();a.setHeight(Ext.isNumber(b.multiline)?b.multiline:this.defaultTextHeight);v=a}else{s.show();a.hide()}}else{s.hide();a.hide()}v.dom.value=b.value||"";if(b.prompt){B.focusEl=v}else{var z=b.buttons;var y=null;if(z&&z.ok){y=r.ok}else{if(z&&z.yes){y=r.yes}}if(y){B.focusEl=y}}if(Ext.isDefined(b.iconCls)){B.setIconClass(b.iconCls)}this.setIcon(Ext.is
 Defined(b.icon)?b.icon:i);o=k(b.buttons);n.setVisible(b.progress===true||b.wait===true);this.updateProgress(0,b.progressText);this.updateText(b.msg);if(b.cls){B.el.addClass(b.cls)}B.proxyDrag=b.proxyDrag===true;B.modal=b.modal!==false;B.mask=b.modal!==false?q:false;if(!B.isVisible()){document.body.appendChild(u.el.dom);B.setAnimateTarget(b.animEl);B.on("show",function(){if(x===true){B.keyMap.enable()}else{B.keyMap.disable()}},this,{single:true});B.show(b.animEl)}if(b.wait===true){n.wait(b.waitConfig)}return this},setIcon:function(x){if(!u){i=x;return}i=undefined;if(x&&x!=""){j.removeClass("x-hidden");j.replaceClass(d,x);h.addClass("x-dlg-icon");d=x}else{j.replaceClass(d,"x-hidden");h.removeClass("x-dlg-icon");d=""}return this},progress:function(z,y,x){this.show({title:z,msg:y,buttons:false,progress:true,closable:false,minWidth:this.minProgressWidth,progressText:x});return this},wait:function(z,y,x){this.show({title:y,msg:z,buttons:false,closable:false,wait:true,modal:true,mi
 nWidth:this.minProgressWidth,waitConfig:x});return this},alert:function(A,z,y,x){this.show({title:A,msg:z,buttons:this.OK,fn:y,scope:x,minWidth:this.minWidth});return this},confirm:function(A,z,y,x){this.show({title:A,msg:z,buttons:this.YESNO,fn:y,scope:x,icon:this.QUESTION,minWidth:this.minWidth});return this},prompt:function(C,B,z,y,x,A){this.show({title:C,msg:B,buttons:this.OKCANCEL,fn:z,minWidth:this.minPromptWidth,scope:y,prompt:true,multiline:x,value:A});return this},OK:{ok:true},CANCEL:{cancel:true},OKCANCEL:{ok:true,cancel:true},YESNO:{yes:true,no:true},YESNOCANCEL:{yes:true,no:true,cancel:true},INFO:"ext-mb-info",WARNING:"ext-mb-warning",QUESTION:"ext-mb-question",ERROR:"ext-mb-error",defaultTextHeight:75,maxWidth:600,minWidth:100,minProgressWidth:250,minPromptWidth:250,buttonText:{ok:"OK",cancel:"Cancel",yes:"Yes",no:"No"}}}();Ext.Msg=Ext.MessageBox;Ext.dd.PanelProxy=Ext.extend(Object,{constructor:function(a,b){this.panel=a;this.id=this.panel.id+"-ddproxy";Ext.appl
 y(this,b)},insertProxy:true,setStatus:Ext.emptyFn,reset:Ext.emptyFn,update:Ext.emptyFn,stop:Ext.emptyFn,sync:Ext.emptyFn,getEl:function(){return this.ghost},getGhost:function(){return this.ghost},getProxy:function(){return this.proxy},hide:function(){if(this.ghost){if(this.proxy){this.proxy.remove();delete this.proxy}this.panel.el.dom.style.display="";this.ghost.remove();delete this.ghost}},show:function(){if(!this.ghost){this.ghost=this.panel.createGhost(this.panel.initialConfig.cls,undefined,Ext.getBody());this.ghost.setXY(this.panel.el.getXY());if(this.insertProxy){this.proxy=this.panel.el.insertSibling({cls:"x-panel-dd-spacer"});this.proxy.setSize(this.panel.getSize())}this.panel.el.dom.style.display="none"}},repair:function(b,c,a){this.hide();if(typeof c=="function"){c.call(a||this)}},moveProxy:function(a,b){if(this.proxy){a.insertBefore(this.proxy.dom,b)}}});Ext.Panel.DD=Ext.extend(Ext.dd.DragSource,{constructor:function(b,a){this.panel=b;this.dragData={panel:b};this.p
 roxy=new Ext.dd.PanelProxy(b,a);Ext.Panel.DD.superclass.constructor.call(this,b.el,a);var d=b.header,c=b.body;if(d){this.setHandleElId(d.id);c=b.header}c.setStyle("cursor","move");this.scroll=false},showFrame:Ext.emptyFn,startDrag:Ext.emptyFn,b4StartDrag:function(a,b){this.proxy.show()},b4MouseDown:function(b){var a=b.getPageX(),c=b.getPageY();this.autoOffset(a,c)},onInitDrag:function(a,b){this.onStartDrag(a,b);return true},createFrame:Ext.emptyFn,getDragEl:function(a){return this.proxy.ghost.dom},endDrag:function(a){this.proxy.hide();this.panel.saveState()},autoOffset:function(a,b){a-=this.startPageX;b-=this.startPageY;this.setDelta(a,b)}});Ext.state.Provider=Ext.extend(Ext.util.Observable,{constructor:function(){this.addEvents("statechange");this.state={};Ext.state.Provider.superclass.constructor.call(this)},get:function(b,a){return typeof this.state[b]=="undefined"?a:this.state[b]},clear:function(a){delete this.state[a];this.fireEvent("statechange",this,a,null)},set:funct
 ion(a,b){this.state[a]=b;this.fireEvent("statechange",this,a,b)},decodeValue:function(b){var e=/^(a|n|d|b|s|o|e)\:(.*)$/,h=e.exec(unescape(b)),d,c,a,g;if(!h||!h[1]){return}c=h[1];a=h[2];switch(c){case"e":return null;case"n":return parseFloat(a);case"d":return new Date(Date.parse(a));case"b":return(a=="1");case"a":d=[];if(a!=""){Ext.each(a.split("^"),function(i){d.push(this.decodeValue(i))},this)}return d;case"o":d={};if(a!=""){Ext.each(a.split("^"),function(i){g=i.split("=");d[g[0]]=this.decodeValue(g[1])},this)}return d;default:return a}},encodeValue:function(c){var b,g="",e=0,a,d;if(c==null){return"e:1"}else{if(typeof c=="number"){b="n:"+c}else{if(typeof c=="boolean"){b="b:"+(c?"1":"0")}else{if(Ext.isDate(c)){b="d:"+c.toGMTString()}else{if(Ext.isArray(c)){for(a=c.length;e<a;e++){g+=this.encodeValue(c[e]);if(e!=a-1){g+="^"}}b="a:"+g}else{if(typeof c=="object"){for(d in c){if(typeof c[d]!="function"&&c[d]!==undefined){g+=d+"="+this.encodeValue(c[d])+"^"}}b="o:"+g.substring(0
 ,g.length-1)}else{b="s:"+c}}}}}}return escape(b)}});Ext.state.Manager=function(){var a=new Ext.state.Provider();return{setProvider:function(b){a=b},get:function(c,b){return a.get(c,b)},set:function(b,c){a.set(b,c)},clear:function(b){a.clear(b)},getProvider:function(){return a}}}();Ext.state.CookieProvider=Ext.extend(Ext.state.Provider,{constructor:function(a){Ext.state.CookieProvider.superclass.constructor.call(this);this.path="/";this.expires=new Date(new Date().getTime()+(1000*60*60*24*7));this.domain=null;this.secure=false;Ext.apply(this,a);this.state=this.readCookies()},set:function(a,b){if(typeof b=="undefined"||b===null){this.clear(a);return}this.setCookie(a,b);Ext.state.CookieProvider.superclass.set.call(this,a,b)},clear:function(a){this.clearCookie(a);Ext.state.CookieProvider.superclass.clear.call(this,a)},readCookies:function(){var d={},h=document.cookie+";",b=/\s?(.*?)=(.*?);/g,g,a,e;while((g=b.exec(h))!=null){a=g[1];e=g[2];if(a&&a.substring(0,3)=="ys-"){d[a.substr
 (3)]=this.decodeValue(e)}}return d},setCookie:function(a,b){document.cookie="ys-"+a+"="+this.encodeValue(b)+((this.expires==null)?"":("; expires="+this.expires.toGMTString()))+((this.path==null)?"":("; path="+this.path))+((this.domain==null)?"":("; domain="+this.domain))+((this.secure==true)?"; secure":"")},clearCookie:function(a){document.cookie="ys-"+a+"=null; expires=Thu, 01-Jan-70 00:00:01 GMT"+((this.path==null)?"":("; path="+this.path))+((this.domain==null)?"":("; domain="+this.domain))+((this.secure==true)?"; secure":"")}});Ext.DataView=Ext.extend(Ext.BoxComponent,{selectedClass:"x-view-selected",emptyText:"",deferEmptyText:true,trackOver:false,blockRefresh:false,last:false,initComponent:function(){Ext.DataView.superclass.initComponent.call(this);if(Ext.isString(this.tpl)||Ext.isArray(this.tpl)){this.tpl=new Ext.XTemplate(this.tpl)}this.addEvents("beforeclick","click","mouseenter","mouseleave","containerclick","dblclick","contextmenu","containercontextmenu","selection
 change","beforeselect");this.store=Ext.StoreMgr.lookup(this.store);this.all=new Ext.CompositeElementLite();this.selected=new Ext.CompositeElementLite()},afterRender:function(){Ext.DataView.superclass.afterRender.call(this);this.mon(this.getTemplateTarget(),{click:this.onClick,dblclick:this.onDblClick,contextmenu:this.onContextMenu,scope:this});if(this.overClass||this.trackOver){this.mon(this.getTemplateTarget(),{mouseover:this.onMouseOver,mouseout:this.onMouseOut,scope:this})}if(this.store){this.bindStore(this.store,true)}},refresh:function(){this.clearSelections(false,true);var b=this.getTemplateTarget(),a=this.store.getRange();b.update("");if(a.length<1){if(!this.deferEmptyText||this.hasSkippedEmptyText){b.update(this.emptyText)}this.all.clear()}else{this.tpl.overwrite(b,this.collectData(a,0));this.all.fill(Ext.query(this.itemSelector,b.dom));this.updateIndexes(0)}this.hasSkippedEmptyText=true},getTemplateTarget:function(){return this.el},prepareData:function(a){return a},
 collectData:function(b,e){var d=[],c=0,a=b.length;for(;c<a;c++){d[d.length]=this.prepareData(b[c].data,e+c,b[c])}return d},bufferRender:function(a,b){var c=document.createElement("div");this.tpl.overwrite(c,this.collectData(a,b));return Ext.query(this.itemSelector,c)},onUpdate:function(g,a){var b=this.store.indexOf(a);if(b>-1){var e=this.isSelected(b),c=this.all.elements[b],d=this.bufferRender([a],b)[0];this.all.replaceElement(b,d,true);if(e){this.selected.replaceElement(c,d);this.all.item(b).addClass(this.selectedClass)}this.updateIndexes(b,b)}},onAdd:function(g,d,e){if(this.all.getCount()===0){this.refresh();return}var c=this.bufferRender(d,e),h,b=this.all.elements;if(e<this.all.getCount()){h=this.all.item(e).insertSibling(c,"before",true);b.splice.apply(b,[e,0].concat(c))}else{h=this.all.last().insertSibling(c,"after",true);b.push.apply(b,c)}this.updateIndexes(e)},onRemove:function(c,a,b){this.deselect(b);this.all.removeElement(b,true);this.updateIndexes(b);if(this.store.
 getCount()===0){this.refresh()}},refreshNode:function(a){this.onUpdate(this.store,this.store.getAt(a))},updateIndexes:function(d,c){var b=this.all.elements;d=d||0;c=c||((c===0)?0:(b.length-1));for(var a=d;a<=c;a++){b[a].viewIndex=a}},getStore:function(){return this.store},bindStore:function(a,b){if(!b&&this.store){if(a!==this.store&&this.store.autoDestroy){this.store.destroy()}else{this.store.un("beforeload",this.onBeforeLoad,this);this.store.un("datachanged",this.onDataChanged,this);this.store.un("add",this.onAdd,this);this.store.un("remove",this.onRemove,this);this.store.un("update",this.onUpdate,this);this.store.un("clear",this.refresh,this)}if(!a){this.store=null}}if(a){a=Ext.StoreMgr.lookup(a);a.on({scope:this,beforeload:this.onBeforeLoad,datachanged:this.onDataChanged,add:this.onAdd,remove:this.onRemove,update:this.onUpdate,clear:this.refresh})}this.store=a;if(a){this.refresh()}},onDataChanged:function(){if(this.blockRefresh!==true){this.refresh.apply(this,arguments)}}
 ,findItemFromChild:function(a){return Ext.fly(a).findParent(this.itemSelector,this.getTemplateTarget())},onClick:function(c){var b=c.getTarget(this.itemSelector,this.getTemplateTarget()),a;if(b){a=this.indexOf(b);if(this.onItemClick(b,a,c)!==false){this.fireEvent("click",this,a,b,c)}}else{if(this.fireEvent("containerclick",this,c)!==false){this.onContainerClick(c)}}},onContainerClick:function(a){this.clearSelections()},onContextMenu:function(b){var a=b.getTarget(this.itemSelector,this.getTemplateTarget());if(a){this.fireEvent("contextmenu",this,this.indexOf(a),a,b)}else{this.fireEvent("containercontextmenu",this,b)}},onDblClick:function(b){var a=b.getTarget(this.itemSelector,this.getTemplateTarget());if(a){this.fireEvent("dblclick",this,this.indexOf(a),a,b)}},onMouseOver:function(b){var a=b.getTarget(this.itemSelector,this.getTemplateTarget());if(a&&a!==this.lastItem){this.lastItem=a;Ext.fly(a).addClass(this.overClass);this.fireEvent("mouseenter",this,this.indexOf(a),a,b)}},
 onMouseOut:function(a){if(this.lastItem){if(!a.within(this.lastItem,true,true)){Ext.fly(this.lastItem).removeClass(this.overClass);this.fireEvent("mouseleave",this,this.indexOf(this.lastItem),this.lastItem,a);delete this.lastItem}}},onItemClick:function(b,a,c){if(this.fireEvent("beforeclick",this,a,b,c)===false){return false}if(this.multiSelect){this.doMultiSelection(b,a,c);c.preventDefault()}else{if(this.singleSelect){this.doSingleSelection(b,a,c);c.preventDefault()}}return true},doSingleSelection:function(b,a,c){if(c.ctrlKey&&this.isSelected(a)){this.deselect(a)}else{this.select(a,false)}},doMultiSelection:function(c,a,d){if(d.shiftKey&&this.last!==false){var b=this.last;this.selectRange(b,a,d.ctrlKey);this.last=b}else{if((d.ctrlKey||this.simpleSelect)&&this.isSelected(a)){this.deselect(a)}else{this.select(a,d.ctrlKey||d.shiftKey||this.simpleSelect)}}},getSelectionCount:function(){return this.selected.getCount()},getSelectedNodes:function(){return this.selected.elements},g
 etSelectedIndexes:function(){var b=[],d=this.selected.elements,c=0,a=d.length;for(;c<a;c++){b.push(d[c].viewIndex)}return b},getSelectedRecords:function(){return this.getRecords(this.selected.elements)},getRecords:function(c){var b=[],d=0,a=c.length;for(;d<a;d++){b[b.length]=this.store.getAt(c[d].viewIndex)}return b},getRecord:function(a){return this.store.getAt(a.viewIndex)},clearSelections:function(a,b){if((this.multiSelect||this.singleSelect)&&this.selected.getCount()>0){if(!b){this.selected.removeClass(this.selectedClass)}this.selected.clear();this.last=false;if(!a){this.fireEvent("selectionchange",this,this.selected.elements)}}},isSelected:function(a){return this.selected.contains(this.getNode(a))},deselect:function(a){if(this.isSelected(a)){a=this.getNode(a);this.selected.removeElement(a);if(this.last==a.viewIndex){this.last=false}Ext.fly(a).removeClass(this.selectedClass);this.fireEvent("selectionchange",this,this.selected.elements)}},select:function(d,g,b){if(Ext.isA
 rray(d)){if(!g){this.clearSelections(true)}for(var c=0,a=d.length;c<a;c++){this.select(d[c],true,true)}if(!b){this.fireEvent("selectionchange",this,this.selected.elements)}}else{var e=this.getNode(d);if(!g){this.clearSelections(true)}if(e&&!this.isSelected(e)){if(this.fireEvent("beforeselect",this,e,this.selected.elements)!==false){Ext.fly(e).addClass(this.selectedClass);this.selected.add(e);this.last=e.viewIndex;if(!b){this.fireEvent("selectionchange",this,this.selected.elements)}}}}},selectRange:function(c,a,b){if(!b){this.clearSelections(true)}this.select(this.getNodes(c,a),true)},getNode:function(b){if(Ext.isString(b)){return document.getElementById(b)}else{if(Ext.isNumber(b)){return this.all.elements[b]}else{if(b instanceof Ext.data.Record){var a=this.store.indexOf(b);return this.all.elements[a]}}}return b},getNodes:function(e,a){var d=this.all.elements,b=[],c;e=e||0;a=!Ext.isDefined(a)?Math.max(d.length-1,0):a;if(e<=a){for(c=e;c<=a&&d[c];c++){b.push(d[c])}}else{for(c=e
 ;c>=a&&d[c];c--){b.push(d[c])}}return b},indexOf:function(a){a=this.getNode(a);if(Ext.isNumber(a.viewIndex)){return a.viewIndex}return this.all.indexOf(a)},onBeforeLoad:function(){if(this.loadingText){this.clearSelections(false,true);this.getTemplateTarget().update('<div class="loading-indicator">'+this.loadingText+"</div>");this.all.clear()}},onDestroy:function(){this.all.clear();this.selected.clear();Ext.DataView.superclass.onDestroy.call(this);this.bindStore(null)}});Ext.DataView.prototype.setStore=Ext.DataView.prototype.bindStore;Ext.reg("dataview",Ext.DataView);Ext.list.ListView=Ext.extend(Ext.DataView,{itemSelector:"dl",selectedClass:"x-list-selected",overClass:"x-list-over",scrollOffset:undefined,columnResize:true,columnSort:true,maxColumnWidth:Ext.isIE?99:100,initComponent:function(){if(this.columnResize){this.colResizer=new Ext.list.ColumnResizer(this.colResizer);this.colResizer.init(this)}if(this.columnSort){this.colSorter=new Ext.list.Sorter(this.columnSort);this.
 colSorter.init(this)}if(!this.internalTpl){this.internalTpl=new Ext.XTemplate('<div class="x-list-header"><div class="x-list-header-inner">','<tpl for="columns">','<div style="width:{[values.width*100]}%;text-align:{align};"><em unselectable="on" id="',this.id,'-xlhd-{#}">',"{header}","</em></div>","</tpl>",'<div class="x-clear"></div>',"</div></div>",'<div class="x-list-body"><div class="x-list-body-inner">',"</div></div>")}if(!this.tpl){this.tpl=new Ext.XTemplate('<tpl for="rows">',"<dl>",'<tpl for="parent.columns">','<dt style="width:{[values.width*100]}%;text-align:{align};">','<em unselectable="on"<tpl if="cls"> class="{cls}</tpl>">',"{[values.tpl.apply(parent)]}","</em></dt>","</tpl>",'<div class="x-clear"></div>',"</dl>","</tpl>")}var l=this.columns,h=0,k=0,m=l.length,b=[];for(var g=0;g<m;g++){var n=l[g];if(!n.isColumn){n.xtype=n.xtype?(/^lv/.test(n.xtype)?n.xtype:"lv"+n.xtype):"lvcolumn";n=Ext.create(n)}if(n.width){h+=n.width*100;if(h>this.maxColumnWidth){n.width-=(h
 -this.maxColumnWidth)/100}k++}b.push(n)}l=this.columns=b;if(k<m){var d=m-k;if(h<this.maxColumnWidth){var a=((this.maxColumnWidth-h)/d)/100;for(var e=0;e<m;e++){var n=l[e];if(!n.width){n.width=a}}}}Ext.list.ListView.superclass.initComponent.call(this)},onRender:function(){this.autoEl={cls:"x-list-wrap"};Ext.list.ListView.superclass.onRender.apply(this,arguments);this.internalTpl.overwrite(this.el,{columns:this.columns});this.innerBody=Ext.get(this.el.dom.childNodes[1].firstChild);this.innerHd=Ext.get(this.el.dom.firstChild.firstChild);if(this.hideHeaders){this.el.dom.firstChild.style.display="none"}},getTemplateTarget:function(){return this.innerBody},collectData:function(){var a=Ext.list.ListView.superclass.collectData.apply(this,arguments);return{columns:this.columns,rows:a}},verifyInternalSize:function(){if(this.lastSize){this.onResize(this.lastSize.width,this.lastSize.height)}},onResize:function(c,e){var b=this.innerBody.dom,g=this.innerHd.dom,d=c-Ext.num(this.scrollOffse
 t,Ext.getScrollBarWidth())+"px",a;if(!b){return}a=b.parentNode;if(Ext.isNumber(c)){if(this.reserveScrollOffset||((a.offsetWidth-a.clientWidth)>10)){b.style.width=d;g.style.width=d}else{b.style.width=c+"px";g.style.width=c+"px";setTimeout(function(){if((a.offsetWidth-a.clientWidth)>10){b.style.width=d;g.style.width=d}},10)}}if(Ext.isNumber(e)){a.style.height=Math.max(0,e-g.parentNode.offsetHeight)+"px"}},updateIndexes:function(){Ext.list.ListView.superclass.updateIndexes.apply(this,arguments);this.verifyInternalSize()},findHeaderIndex:function(g){g=g.dom||g;var a=g.parentNode,d=a.parentNode.childNodes,b=0,e;for(;e=d[b];b++){if(e==a){return b}}return -1},setHdWidths:function(){var d=this.innerHd.dom.getElementsByTagName("div"),c=0,b=this.columns,a=b.length;for(;c<a;c++){d[c].style.width=(b[c].width*100)+"%"}}});Ext.reg("listview",Ext.list.ListView);Ext.ListView=Ext.list.ListView;Ext.list.Column=Ext.extend(Object,{isColumn:true,align:"left",header:"",width:null,cls:"",construct
 or:function(a){if(!a.tpl){a.tpl=new Ext.XTemplate("{"+a.dataIndex+"}")}else{if(Ext.isString(a.tpl)){a.tpl=new Ext.XTemplate(a.tpl)}}Ext.apply(this,a)}});Ext.reg("lvcolumn",Ext.list.Column);Ext.list.NumberColumn=Ext.extend(Ext.list.Column,{format:"0,000.00",constructor:function(a){a.tpl=a.tpl||new Ext.XTemplate("{"+a.dataIndex+':number("'+(a.format||this.format)+'")}');Ext.list.NumberColumn.superclass.constructor.call(this,a)}});Ext.reg("lvnumbercolumn",Ext.list.NumberColumn);Ext.list.DateColumn=Ext.extend(Ext.list.Column,{format:"m/d/Y",constructor:function(a){a.tpl=a.tpl||new Ext.XTemplate("{"+a.dataIndex+':date("'+(a.format||this.format)+'")}');Ext.list.DateColumn.superclass.constructor.call(this,a)}});Ext.reg("lvdatecolumn",Ext.list.DateColumn);Ext.list.BooleanColumn=Ext.extend(Ext.list.Column,{trueText:"true",falseText:"false",undefinedText:"&#160;",constructor:function(e){e.tpl=e.tpl||new Ext.XTemplate("{"+e.dataIndex+":this.format}");var b=this.trueText,d=this.falseTex
 t,a=this.undefinedText;e.tpl.format=function(c){if(c===undefined){return a}if(!c||c==="false"){return d}return b};Ext.list.DateColumn.superclass.constructor.call(this,e)}});Ext.reg("lvbooleancolumn",Ext.list.BooleanColumn);Ext.list.ColumnResizer=Ext.extend(Ext.util.Observable,{minPct:0.05,constructor:function(a){Ext.apply(this,a);Ext.list.ColumnResizer.superclass.constructor.call(this)},init:function(a){this.view=a;a.on("render",this.initEvents,this)},initEvents:function(a){a.mon(a.innerHd,"mousemove",this.handleHdMove,this);this.tracker=new Ext.dd.DragTracker({onBeforeStart:this.onBeforeStart.createDelegate(this),onStart:this.onStart.createDelegate(this),onDrag:this.onDrag.createDelegate(this),onEnd:this.onEnd.createDelegate(this),tolerance:3,autoStart:300});this.tracker.initEl(a.innerHd);a.on("beforedestroy",this.tracker.destroy,this.tracker)},handleHdMove:function(i,d){var c=5,b=i.getPageX(),j=i.getTarget("em",3,true);if(j){var h=j.getRegion(),g=j.dom.style,a=j.dom.parent
 Node;if(b-h.left<=c&&a!=a.parentNode.firstChild){this.activeHd=Ext.get(a.previousSibling.firstChild);g.cursor=Ext.isWebKit?"e-resize":"col-resize"}else{if(h.right-b<=c&&a!=a.parentNode.lastChild.previousSibling){this.activeHd=j;g.cursor=Ext.isWebKit?"w-resize":"col-resize"}else{delete this.activeHd;g.cursor=""}}}},onBeforeStart:function(a){this.dragHd=this.activeHd;return !!this.dragHd},onStart:function(g){var d=this,b=d.view,c=d.dragHd,a=d.tracker.getXY()[0];d.proxy=b.el.createChild({cls:"x-list-resizer"});d.dragX=c.getX();d.headerIndex=b.findHeaderIndex(c);d.headersDisabled=b.disableHeaders;b.disableHeaders=true;d.proxy.setHeight(b.el.getHeight());d.proxy.setX(d.dragX);d.proxy.setWidth(a-d.dragX);this.setBoundaries()},setBoundaries:function(j){var k=this.view,h=this.headerIndex,c=k.innerHd.getWidth(),j=k.innerHd.getX(),b=Math.ceil(c*this.minPct),l=c-b,e=k.columns.length,d=k.innerHd.select("em",true),g=b+j,a=l+j,i;if(e==2){this.minX=g;this.maxX=a}else{i=d.item(h+2);this.min
 X=d.item(h).getX()+b;this.maxX=i?i.getX()-b:a;if(h==0){this.minX=g}else{if(h==e-2){this.maxX=a}}}},onDrag:function(c){var b=this,a=b.tracker.getXY()[0].constrain(b.minX,b.maxX);b.proxy.setWidth(a-this.dragX)},onEnd:function(i){var g=this.proxy.getWidth(),h=this.headerIndex,l=this.view,c=l.columns,b=l.innerHd.getWidth(),k=Math.ceil(g*l.maxColumnWidth/b)/100,d=this.headersDisabled,m=c[h],j=c[h+1],a=m.width+j.width;this.proxy.remove();m.width=k;j.width=a-k;delete this.dragHd;l.setHdWidths();l.refresh();setTimeout(function(){l.disableHeaders=d},100)}});Ext.ListView.ColumnResizer=Ext.list.ColumnResizer;Ext.list.Sorter=Ext.extend(Ext.util.Observable,{sortClasses:["sort-asc","sort-desc"],constructor:function(a){Ext.apply(this,a);Ext.list.Sorter.superclass.constructor.call(this)},init:function(a){this.view=a;a.on("render",this.initEvents,this)},initEvents:function(a){a.mon(a.innerHd,"click",this.onHdClick,this);a.innerHd.setStyle("cursor","pointer");a.mon(a.store,"datachanged",this.
 updateSortState,this);this.updateSortState.defer(10,this,[a.store])},updateSortState:function(c){var g=c.getSortState();if(!g){return}this.sortState=g;var e=this.view.columns,h=-1;for(var d=0,a=e.length;d<a;d++){if(e[d].dataIndex==g.field){h=d;break}}if(h!=-1){var b=g.direction;this.updateSortIcon(h,b)}},updateSortIcon:function(b,a){var d=this.sortClasses;var c=this.view.innerHd.select("em").removeClass(d);c.item(b).addClass(d[a=="DESC"?1:0])},onHdClick:function(c){var b=c.getTarget("em",3);if(b&&!this.view.disableHeaders){var a=this.view.findHeaderIndex(b);this.view.store.sort(this.view.columns[a].dataIndex)}}});Ext.ListView.Sorter=Ext.list.Sorter;Ext.TabPanel=Ext.extend(Ext.Panel,{deferredRender:true,tabWidth:120,minTabWidth:30,resizeTabs:false,enableTabScroll:false,scrollIncrement:0,scrollRepeatInterval:400,scrollDuration:0.35,animScroll:true,tabPosition:"top",baseCls:"x-tab-panel",autoTabs:false,autoTabSelector:"div.x-tab",activeTab:undefined,tabMargin:2,plain:false,whee
 lIncrement:20,idDelimiter:"__",itemCls:"x-tab-item",elements:"body",headerAsText:false,frame:false,hideBorders:true,initComponent:function(){this.frame=false;Ext.TabPanel.superclass.initComponent.call(this);this.addEvents("beforetabchange","tabchange","contextmenu");this.setLayout(new Ext.layout.CardLayout(Ext.apply({layoutOnCardChange:this.layoutOnTabChange,deferredRender:this.deferredRender},this.layoutConfig)));if(this.tabPosition=="top"){this.elements+=",header";this.stripTarget="header"}else{this.elements+=",footer";this.stripTarget="footer"}if(!this.stack){this.stack=Ext.TabPanel.AccessStack()}this.initItems()},onRender:function(c,a){Ext.TabPanel.superclass.onRender.call(this,c,a);if(this.plain){var g=this.tabPosition=="top"?"header":"footer";this[g].addClass("x-tab-panel-"+g+"-plain")}var b=this[this.stripTarget];this.stripWrap=b.createChild({cls:"x-tab-strip-wrap",cn:{tag:"ul",cls:"x-tab-strip x-tab-strip-"+this.tabPosition}});var e=(this.tabPosition=="bottom"?this.s
 tripWrap:null);b.createChild({cls:"x-tab-strip-spacer"},e);this.strip=new Ext.Element(this.stripWrap.dom.firstChild);this.edge=this.strip.createChild({tag:"li",cls:"x-tab-edge",cn:[{tag:"span",cls:"x-tab-strip-text",cn:"&#160;"}]});this.strip.createChild({cls:"x-clear"});this.body.addClass("x-tab-panel-body-"+this.tabPosition);if(!this.itemTpl){var d=new Ext.Template('<li class="{cls}" id="{id}"><a class="x-tab-strip-close"></a>','<a class="x-tab-right" href="#"><em class="x-tab-left">','<span class="x-tab-strip-inner"><span class="x-tab-strip-text {iconCls}">{text}</span></span>',"</em></a></li>");d.disableFormats=true;d.compile();Ext.TabPanel.prototype.itemTpl=d}this.items.each(this.initTab,this)},afterRender:function(){Ext.TabPanel.superclass.afterRender.call(this);if(this.autoTabs){this.readTabs(false)}if(this.activeTab!==undefined){var a=Ext.isObject(this.activeTab)?this.activeTab:this.items.get(this.activeTab);delete this.activeTab;this.setActiveTab(a)}},initEvents:fun
 ction(){Ext.TabPanel.superclass.initEvents.call(this);this.mon(this.strip,{scope:this,mousedown:this.onStripMouseDown,contextmenu:this.onStripContextMenu});if(this.enableTabScroll){this.mon(this.strip,"mousewheel",this.onWheel,this)}},findTargets:function(c){var b=null,a=c.getTarget("li:not(.x-tab-edge)",this.strip);if(a){b=this.getComponent(a.id.split(this.idDelimiter)[1]);if(b.disabled){return{close:null,item:null,el:null}}}return{close:c.getTarget(".x-tab-strip-close",this.strip),item:b,el:a}},onStripMouseDown:function(b){if(b.button!==0){return}b.preventDefault();var a=this.findTargets(b);if(a.close){if(a.item.fireEvent("beforeclose",a.item)!==false){a.item.fireEvent("close",a.item);this.remove(a.item)}return}if(a.item&&a.item!=this.activeTab){this.setActiveTab(a.item)}},onStripContextMenu:function(b){b.preventDefault();var a=this.findTargets(b);if(a.item){this.fireEvent("contextmenu",this,a.item,b)}},readTabs:function(d){if(d===true){this.items.each(function(h){this.rem
 ove(h)},this)}var c=this.el.query(this.autoTabSelector);for(var b=0,a=c.length;b<a;b++){var e=c[b],g=e.getAttribute("title");e.removeAttribute("title");this.add({title:g,contentEl:e})}},initTab:function(d,b){var e=this.strip.dom.childNodes[b],g=this.getTemplateArgs(d),c=e?this.itemTpl.insertBefore(e,g):this.itemTpl.append(this.strip,g),a="x-tab-strip-over",h=Ext.get(c);h.hover(function(){if(!d.disabled){h.addClass(a)}},function(){h.removeClass(a)});if(d.tabTip){h.child("span.x-tab-strip-text",true).qtip=d.tabTip}d.tabEl=c;h.select("a").on("click",function(i){if(!i.getPageX()){this.onStripMouseDown(i)}},this,{preventDefault:true});d.on({scope:this,disable:this.onItemDisabled,enable:this.onItemEnabled,titlechange:this.onItemTitleChanged,iconchange:this.onItemIconChanged,beforeshow:this.onBeforeShowItem})},getTemplateArgs:function(b){var a=b.closable?"x-tab-strip-closable":"";if(b.disabled){a+=" x-item-disabled"}if(b.iconCls){a+=" x-tab-with-icon"}if(b.tabCls){a+=" "+b.tabCls}r
 eturn{id:this.id+this.idDelimiter+b.getItemId(),text:b.title,cls:a,iconCls:b.iconCls||""}},onAdd:function(b){Ext.TabPanel.superclass.onAdd.call(this,b);if(this.rendered){var a=this.items;this.initTab(b,a.indexOf(b));this.delegateUpdates()}},onBeforeAdd:function(b){var a=b.events?(this.items.containsKey(b.getItemId())?b:null):this.items.get(b);if(a){this.setActiveTab(b);return false}Ext.TabPanel.superclass.onBeforeAdd.apply(this,arguments);var c=b.elements;b.elements=c?c.replace(",header",""):c;b.border=(b.border===true)},onRemove:function(d){var b=Ext.get(d.tabEl);if(b){b.select("a").removeAllListeners();Ext.destroy(b)}Ext.TabPanel.superclass.onRemove.call(this,d);this.stack.remove(d);delete d.tabEl;d.un("disable",this.onItemDisabled,this);d.un("enable",this.onItemEnabled,this);d.un("titlechange",this.onItemTitleChanged,this);d.un("iconchange",this.onItemIconChanged,this);d.un("beforeshow",this.onBeforeShowItem,this);if(d==this.activeTab){var a=this.stack.next();if(a){this.s
 etActiveTab(a)}else{if(this.items.getCount()>0){this.setActiveTab(0)}else{this.setActiveTab(null)}}}if(!this.destroying){this.delegateUpdates()}},onBeforeShowItem:function(a){if(a!=this.activeTab){this.setActiveTab(a);return false}},onItemDisabled:function(b){var a=this.getTabEl(b);if(a){Ext.fly(a).addClass("x-item-disabled")}this.stack.remove(b)},onItemEnabled:function(b){var a=this.getTabEl(b);if(a){Ext.fly(a).removeClass("x-item-disabled")}},onItemTitleChanged:function(b){var a=this.getTabEl(b);if(a){Ext.fly(a).child("span.x-tab-strip-text",true).innerHTML=b.title}},onItemIconChanged:function(d,a,c){var b=this.getTabEl(d);if(b){b=Ext.get(b);b.child("span.x-tab-strip-text").replaceClass(c,a);b[Ext.isEmpty(a)?"removeClass":"addClass"]("x-tab-with-icon")}},getTabEl:function(a){var b=this.getComponent(a);return b?b.tabEl:null},onResize:function(){Ext.TabPanel.superclass.onResize.apply(this,arguments);this.delegateUpdates()},beginUpdate:function(){this.suspendUpdates=true},end
 Update:function(){this.suspendUpdates=false;this.delegateUpdates()},hideTabStripItem:function(b){b=this.getComponent(b);var a=this.getTabEl(b);if(a){a.style.display="none";this.delegateUpdates()}this.stack.remove(b)},unhideTabStripItem:function(b){b=this.getComponent(b);var a=this.getTabEl(b);if(a){a.style.display="";this.delegateUpdates()}},delegateUpdates:function(){var a=this.rendered;if(this.suspendUpdates){return}if(this.resizeTabs&&a){this.autoSizeTabs()}if(this.enableTabScroll&&a){this.autoScrollTabs()}},autoSizeTabs:function(){var h=this.items.length,b=this.tabPosition!="bottom"?"header":"footer",c=this[b].dom.offsetWidth,a=this[b].dom.clientWidth;if(!this.resizeTabs||h<1||!a){return}var k=Math.max(Math.min(Math.floor((a-4)/h)-this.tabMargin,this.tabWidth),this.minTabWidth);this.lastTabWidth=k;var m=this.strip.query("li:not(.x-tab-edge)");for(var e=0,j=m.length;e<j;e++){var l=m[e],n=Ext.fly(l).child(".x-tab-strip-inner",true),g=l.offsetWidth,d=n.offsetWidth;n.style.w
 idth=(k-(g-d))+"px"}},adjustBodyWidth:function(a){if(this.header){this.header.setWidth(a)}if(this.footer){this.footer.setWidth(a)}return a},setActiveTab:function(c){c=this.getComponent(c);if(this.fireEvent("beforetabchange",this,c,this.activeTab)===false){return}if(!this.rendered){this.activeTab=c;return}if(this.activeTab!=c){if(this.activeTab){var a=this.getTabEl(this.activeTab);if(a){Ext.fly(a).removeClass("x-tab-strip-active")}}this.activeTab=c;if(c){var b=this.getTabEl(c);Ext.fly(b).addClass("x-tab-strip-active");this.stack.add(c);this.layout.setActiveItem(c);this.delegateUpdates();if(this.scrolling){this.scrollToTab(c,this.animScroll)}}this.fireEvent("tabchange",this,c)}},getActiveTab:function(){return this.activeTab||null},getItem:function(a){return this.getComponent(a)},autoScrollTabs:function(){this.pos=this.tabPosition=="bottom"?this.footer:this.header;var h=this.items.length,d=this.pos.dom.offsetWidth,c=this.pos.dom.clientWidth,g=this.stripWrap,e=g.dom,b=e.offsetWi
 dth,i=this.getScrollPos(),a=this.edge.getOffsetsTo(this.stripWrap)[0]+i;if(!this.enableTabScroll||b<20){return}if(h==0||a<=c){e.scrollLeft=0;g.setWidth(c);if(this.scrolling){this.scrolling=false;this.pos.removeClass("x-tab-scrolling");this.scrollLeft.hide();this.scrollRight.hide();if(Ext.isAir||Ext.isWebKit){e.style.marginLeft="";e.style.marginRight=""}}}else{if(!this.scrolling){this.pos.addClass("x-tab-scrolling");if(Ext.isAir||Ext.isWebKit){e.style.marginLeft="18px";e.style.marginRight="18px"}}c-=g.getMargins("lr");g.setWidth(c>20?c:20);if(!this.scrolling){if(!this.scrollLeft){this.createScrollers()}else{this.scrollLeft.show();this.scrollRight.show()}}this.scrolling=true;if(i>(a-c)){e.scrollLeft=a-c}else{this.scrollToTab(this.activeTab,false)}this.updateScrollButtons()}},createScrollers:function(){this.pos.addClass("x-tab-scrolling-"+this.tabPosition);var c=this.stripWrap.dom.offsetHeight;var a=this.pos.insertFirst({cls:"x-tab-scroller-left"});a.setHeight(c);a.addClassOnOv
 er("x-tab-scroller-left-over");this.leftRepeater=new Ext.util.ClickRepeater(a,{interval:this.scrollRepeatInterval,handler:this.onScrollLeft,scope:this});this.scrollLeft=a;var b=this.pos.insertFirst({cls:"x-tab-scroller-right"});b.setHeight(c);b.addClassOnOver("x-tab-scroller-right-over");this.rightRepeater=new Ext.util.ClickRepeater(b,{interval:this.scrollRepeatInterval,handler:this.onScrollRight,scope:this});this.scrollRight=b},getScrollWidth:function(){return this.edge.getOffsetsTo(this.stripWrap)[0]+this.getScrollPos()},getScrollPos:function(){return parseInt(this.stripWrap.dom.scrollLeft,10)||0},getScrollArea:function(){return parseInt(this.stripWrap.dom.clientWidth,10)||0},getScrollAnim:function(){return{duration:this.scrollDuration,callback:this.updateScrollButtons,scope:this}},getScrollIncrement:function(){return this.scrollIncrement||(this.resizeTabs?this.lastTabWidth+2:100)},scrollToTab:function(e,a){if(!e){return}var c=this.getTabEl(e),h=this.getScrollPos(),d=this.
 getScrollArea(),g=Ext.fly(c).getOffsetsTo(this.stripWrap)[0]+h,b=g+c.offsetWidth;if(g<h){this.scrollTo(g,a)}else{if(b>(h+d)){this.scrollTo(b-d,a)}}},scrollTo:function(b,a){this.stripWrap.scrollTo("left",b,a?this.getScrollAnim():false);if(!a){this.updateScrollButtons()}},onWheel:function(g){var h=g.getWheelDelta()*this.wheelIncrement*-1;g.stopEvent();var i=this.getScrollPos(),c=i+h,a=this.getScrollWidth()-this.getScrollArea();var b=Math.max(0,Math.min(a,c));if(b!=i){this.scrollTo(b,false)}},onScrollRight:function(){var a=this.getScrollWidth()-this.getScrollArea(),c=this.getScrollPos(),b=Math.min(a,c+this.getScrollIncrement());if(b!=c){this.scrollTo(b,this.animScroll)}},onScrollLeft:function(){var b=this.getScrollPos(),a=Math.max(0,b-this.getScrollIncrement());if(a!=b){this.scrollTo(a,this.animScroll)}},updateScrollButtons:function(){var a=this.getScrollPos();this.scrollLeft[a===0?"addClass":"removeClass"]("x-tab-scroller-left-disabled");this.scrollRight[a>=(this.getScrollWidt
 h()-this.getScrollArea())?"addClass":"removeClass"]("x-tab-scroller-right-disabled")},beforeDestroy:function(){Ext.destroy(this.leftRepeater,this.rightRepeater);this.deleteMembers("strip","edge","scrollLeft","scrollRight","stripWrap");this.activeTab=null;Ext.TabPanel.superclass.beforeDestroy.apply(this)}});Ext.reg("tabpanel",Ext.TabPanel);Ext.TabPanel.prototype.activate=Ext.TabPanel.prototype.setActiveTab;Ext.TabPanel.AccessStack=function(){var a=[];return{add:function(b){a.push(b);if(a.length>10){a.shift()}},remove:function(e){var d=[];for(var c=0,b=a.length;c<b;c++){if(a[c]!=e){d.push(a[c])}}a=d},next:function(){return a.pop()}}};Ext.Button=Ext.extend(Ext.BoxComponent,{hidden:false,disabled:false,pressed:false,enableToggle:false,menuAlign:"tl-bl?",type:"button",menuClassTarget:"tr:nth(2)",clickEvent:"click",handleMouseEvents:true,tooltipType:"qtip",buttonSelector:"button:first-child",scale:"small",iconAlign:"left",arrowAlign:"right",initComponent:function(){if(this.menu){i
 f(Ext.isArray(this.menu)){this.menu={items:this.menu}}if(Ext.isObject(this.menu)){this.menu.ownerCt=this}this.menu=Ext.menu.MenuMgr.get(this.menu);this.menu.ownerCt=undefined}Ext.Button.superclass.initComponent.call(this);this.addEvents("click","toggle","mouseover","mouseout","menushow","menuhide","menutriggerover","menutriggerout");if(Ext.isString(this.toggleGroup)){this.enableToggle=true}},getTemplateArgs:function(){return[this.type,"x-btn-"+this.scale+" x-btn-icon-"+this.scale+"-"+this.iconAlign,this.getMenuClass(),this.cls,this.id]},setButtonClass:function(){if(this.useSetClass){if(!Ext.isEmpty(this.oldCls)){this.el.removeClass([this.oldCls,"x-btn-pressed"])}this.oldCls=(this.iconCls||this.icon)?(this.text?"x-btn-text-icon":"x-btn-icon"):"x-btn-noicon";this.el.addClass([this.oldCls,this.pressed?"x-btn-pressed":null])}},getMenuClass:function(){return this.menu?(this.arrowAlign!="bottom"?"x-btn-arrow":"x-btn-arrow-bottom"):""},onRender:function(c,a){if(!this.template){if(!
 Ext.Button.buttonTemplate){Ext.Button.buttonTemplate=new Ext.Template('<table id="{4}" cellspacing="0" class="x-btn {3}"><tbody class="{1}">','<tr><td class="x-btn-tl"><i>&#160;</i></td><td class="x-btn-tc"></td><td class="x-btn-tr"><i>&#160;</i></td></tr>','<tr><td class="x-btn-ml"><i>&#160;</i></td><td class="x-btn-mc"><em class="{2}" unselectable="on"><button type="{0}"></button></em></td><td class="x-btn-mr"><i>&#160;</i></td></tr>','<tr><td class="x-btn-bl"><i>&#160;</i></td><td class="x-btn-bc"></td><td class="x-btn-br"><i>&#160;</i></td></tr>',"</tbody></table>");Ext.Button.buttonTemplate.compile()}this.template=Ext.Button.buttonTemplate}var b,d=this.getTemplateArgs();if(a){b=this.template.insertBefore(a,d,true)}else{b=this.template.append(c,d,true)}this.btnEl=b.child(this.buttonSelector);this.mon(this.btnEl,{scope:this,focus:this.onFocus,blur:this.onBlur});this.initButtonEl(b,this.btnEl);Ext.ButtonToggleMgr.register(this)},initButtonEl:function(b,c){this.el=b;this.se
 tIcon(this.icon);this.setText(this.text);this.setIconClass(this.iconCls);if(Ext.isDefined(this.tabIndex)){c.dom.tabIndex=this.tabIndex}if(this.tooltip){this.setTooltip(this.tooltip,true)}if(this.handleMouseEvents){this.mon(b,{scope:this,mouseover:this.onMouseOver,mousedown:this.onMouseDown})}if(this.menu){this.mon(this.menu,{scope:this,show:this.onMenuShow,hide:this.onMenuHide})}if(this.repeat){var a=new Ext.util.ClickRepeater(b,Ext.isObject(this.repeat)?this.repeat:{});this.mon(a,"click",this.onRepeatClick,this)}else{this.mon(b,this.clickEvent,this.onClick,this)}},afterRender:function(){Ext.Button.superclass.afterRender.call(this);this.useSetClass=true;this.setButtonClass();this.doc=Ext.getDoc();this.doAutoWidth()},setIconClass:function(a){this.iconCls=a;if(this.el){this.btnEl.dom.className="";this.btnEl.addClass(["x-btn-text",a||""]);this.setButtonClass()}return this},setTooltip:function(b,a){if(this.rendered){if(!a){this.clearTip()}if(Ext.isObject(b)){Ext.QuickTips.regist
 er(Ext.apply({target:this.btnEl.id},b));this.tooltip=b}else{this.btnEl.dom[this.tooltipType]=b}}else{this.tooltip=b}return this},clearTip:function(){if(Ext.isObject(this.tooltip)){Ext.QuickTips.unregister(this.btnEl)}},beforeDestroy:function(){if(this.rendered){this.clearTip()}if(this.menu&&this.destroyMenu!==false){Ext.destroy(this.btnEl,this.menu)}Ext.destroy(this.repeater)},onDestroy:function(){if(this.rendered){this.doc.un("mouseover",this.monitorMouseOver,this);this.doc.un("mouseup",this.onMouseUp,this);delete this.doc;delete this.btnEl;Ext.ButtonToggleMgr.unregister(this)}Ext.Button.superclass.onDestroy.call(this)},doAutoWidth:function(){if(this.autoWidth!==false&&this.el&&this.text&&this.width===undefined){this.el.setWidth("auto");if(Ext.isIE7&&Ext.isStrict){var a=this.btnEl;if(a&&a.getWidth()>20){a.clip();a.setWidth(Ext.util.TextMetrics.measure(a,this.text).width+a.getFrameWidth("lr"))}}if(this.minWidth){if(this.el.getWidth()<this.minWidth){this.el.setWidth(this.minW
 idth)}}}},setHandler:function(b,a){this.handler=b;this.scope=a;return this},setText:function(a){this.text=a;if(this.el){this.btnEl.update(a||"&#160;");this.setButtonClass()}this.doAutoWidth();return this},setIcon:function(a){this.icon=a;if(this.el){this.btnEl.setStyle("background-image",a?"url("+a+")":"");this.setButtonClass()}return this},getText:function(){return this.text},toggle:function(b,a){b=b===undefined?!this.pressed:!!b;if(b!=this.pressed){if(this.rendered){this.el[b?"addClass":"removeClass"]("x-btn-pressed")}this.pressed=b;if(!a){this.fireEvent("toggle",this,b);if(this.toggleHandler){this.toggleHandler.call(this.scope||this,this,b)}}}return this},onDisable:function(){this.onDisableChange(true)},onEnable:function(){this.onDisableChange(false)},onDisableChange:function(a){if(this.el){if(!Ext.isIE6||!this.text){this.el[a?"addClass":"removeClass"](this.disabledClass)}this.el.dom.disabled=a}this.disabled=a},showMenu:function(){if(this.rendered&&this.menu){if(this.toolt
 ip){Ext.QuickTips.getQuickTip().cancelShow(this.btnEl)}if(this.menu.isVisible()){this.menu.hide()}this.menu.ownerCt=this;this.menu.show(this.el,this.menuAlign)}return this},hideMenu:function(){if(this.hasVisibleMenu()){this.menu.hide()}return this},hasVisibleMenu:function(){return this.menu&&this.menu.ownerCt==this&&this.menu.isVisible()},onRepeatClick:function(a,b){this.onClick(b)},onClick:function(a){if(a){a.preventDefault()}if(a.button!==0){return}if(!this.disabled){this.doToggle();if(this.menu&&!this.hasVisibleMenu()&&!this.ignoreNextClick){this.showMenu()}this.fireEvent("click",this,a);if(this.handler){this.handler.call(this.scope||this,this,a)}}},doToggle:function(){if(this.enableToggle&&(this.allowDepress!==false||!this.pressed)){this.toggle()}},isMenuTriggerOver:function(b,a){return this.menu&&!a},isMenuTriggerOut:function(b,a){return this.menu&&!a},onMouseOver:function(b){if(!this.disabled){var a=b.within(this.el,true);if(!a){this.el.addClass("x-btn-over");if(!this.
 monitoringMouseOver){this.doc.on("mouseover",this.monitorMouseOver,this);this.monitoringMouseOver=true}this.fireEvent("mouseover",this,b)}if(this.isMenuTriggerOver(b,a)){this.fireEvent("menutriggerover",this,this.menu,b)}}},monitorMouseOver:function(a){if(a.target!=this.el.dom&&!a.within(this.el)){if(this.monitoringMouseOver){this.doc.un("mouseover",this.monitorMouseOver,this);this.monitoringMouseOver=false}this.onMouseOut(a)}},onMouseOut:function(b){var a=b.within(this.el)&&b.target!=this.el.dom;this.el.removeClass("x-btn-over");this.fireEvent("mouseout",this,b);if(this.isMenuTriggerOut(b,a)){this.fireEvent("menutriggerout",this,this.menu,b)}},focus:function(){this.btnEl.focus()},blur:function(){this.btnEl.blur()},onFocus:function(a){if(!this.disabled){this.el.addClass("x-btn-focus")}},onBlur:function(a){this.el.removeClass("x-btn-focus")},getClickEl:function(b,a){return this.el},onMouseDown:function(a){if(!this.disabled&&a.button===0){this.getClickEl(a).addClass("x-btn-cli
 ck");this.doc.on("mouseup",this.onMouseUp,this)}},onMouseUp:function(a){if(a.button===0){this.getClickEl(a,true).removeClass("x-btn-click");this.doc.un("mouseup",this.onMouseUp,this)}},onMenuShow:function(a){if(this.menu.ownerCt==this){this.menu.ownerCt=this;this.ignoreNextClick=0;this.el.addClass("x-btn-menu-active");this.fireEvent("menushow",this,this.menu)}},onMenuHide:function(a){if(this.menu.ownerCt==this){this.el.removeClass("x-btn-menu-active");this.ignoreNextClick=this.restoreClick.defer(250,this);this.fireEvent("menuhide",this,this.menu);delete this.menu.ownerCt}},restoreClick:function(){this.ignoreNextClick=0}});Ext.reg("button",Ext.Button);Ext.ButtonToggleMgr=function(){var a={};function b(e,j){if(j){var h=a[e.toggleGroup];for(var d=0,c=h.length;d<c;d++){if(h[d]!=e){h[d].toggle(false)}}}}return{register:function(c){if(!c.toggleGroup){return}var d=a[c.toggleGroup];if(!d){d=a[c.toggleGroup]=[]}d.push(c);c.on("toggle",b)},unregister:function(c){if(!c.toggleGroup){ret
 urn}var d=a[c.toggleGroup];if(d){d.remove(c);c.un("toggle",b)}},getPressed:function(h){var e=a[h];if(e){for(var d=0,c=e.length;d<c;d++){if(e[d].pressed===true){return e[d]}}}return null}}}();Ext.SplitButton=Ext.extend(Ext.Button,{arrowSelector:"em",split:true,initComponent:function(){Ext.SplitButton.superclass.initComponent.call(this);this.addEvents("arrowclick")},onRender:function(){Ext.SplitButton.superclass.onRender.apply(this,arguments);if(this.arrowTooltip){this.el.child(this.arrowSelector).dom[this.tooltipType]=this.arrowTooltip}},setArrowHandler:function(b,a){this.arrowHandler=b;this.scope=a},getMenuClass:function(){return"x-btn-split"+(this.arrowAlign=="bottom"?"-bottom":"")},isClickOnArrow:function(c){if(this.arrowAlign!="bottom"){var b=this.el.child("em.x-btn-split");var a=b.getRegion().right-b.getPadding("r");return c.getPageX()>a}else{return c.getPageY()>this.btnEl.getRegion().bottom}},onClick:function(b,a){b.preventDefault();if(!this.disabled){if(this.isClickOnA
 rrow(b)){if(this.menu&&!this.menu.isVisible()&&!this.ignoreNextClick){this.showMenu()}this.fireEvent("arrowclick",this,b);if(this.arrowHandler){this.arrowHandler.call(this.scope||this,this,b)}}else{this.doToggle();this.fireEvent("click",this,b);if(this.handler){this.handler.call(this.scope||this,this,b)}}}},isMenuTriggerOver:function(a){return this.menu&&a.target.tagName==this.arrowSelector},isMenuTriggerOut:function(b,a){return this.menu&&b.target.tagName!=this.arrowSelector}});Ext.reg("splitbutton",Ext.SplitButton);Ext.CycleButton=Ext.extend(Ext.SplitButton,{getItemText:function(a){if(a&&this.showText===true){var b="";if(this.prependText){b+=this.prependText}b+=a.text;return b}return undefined},setActiveItem:function(c,a){if(!Ext.isObject(c)){c=this.menu.getComponent(c)}if(c){if(!this.rendered){this.text=this.getItemText(c);this.iconCls=c.iconCls}else{var b=this.getItemText(c);if(b){this.setText(b)}this.setIconClass(c.iconCls)}this.activeItem=c;if(!c.checked){c.setChecked(
 true,a)}if(this.forceIcon){this.setIconClass(this.forceIcon)}if(!a){this.fireEvent("change",this,c)}}},getActiveItem:function(){return this.activeItem},initComponent:function(){this.addEvents("change");if(this.changeHandler){this.on("change",this.changeHandler,this.scope||this);delete this.changeHandler}this.itemCount=this.items.length;this.menu={cls:"x-cycle-menu",items:[]};var a=0;Ext.each(this.items,function(c,b){Ext.apply(c,{group:c.group||this.id,itemIndex:b,checkHandler:this.checkHandler,scope:this,checked:c.checked||false});this.menu.items.push(c);if(c.checked){a=b}},this);Ext.CycleButton.superclass.initComponent.call(this);this.on("click",this.toggleSelected,this);this.setActiveItem(a,true)},checkHandler:function(a,b){if(b){this.setActiveItem(a)}},toggleSelected:function(){var a=this.menu;a.render();if(!a.hasLayout){a.doLayout()}var d,b;for(var c=1;c<this.itemCount;c++){d=(this.activeItem.itemIndex+c)%this.itemCount;b=a.items.itemAt(d);if(!b.disabled){b.setChecked(tr
 ue);break}}}});Ext.reg("cycle",Ext.CycleButton);Ext.Toolbar=function(a){if(Ext.isArray(a)){a={items:a,layout:"toolbar"}}else{a=Ext.apply({layout:"toolbar"},a);if(a.buttons){a.items=a.buttons}}Ext.Toolbar.superclass.constructor.call(this,a)};(function(){var a=Ext.Toolbar;Ext.extend(a,Ext.Container,{defaultType:"button",enableOverflow:false,trackMenus:true,internalDefaults:{removeMode:"container",hideParent:true},toolbarCls:"x-toolbar",initComponent:function(){a.superclass.initComponent.call(this);this.addEvents("overflowchange")},onRender:function(c,b){if(!this.el){if(!this.autoCreate){this.autoCreate={cls:this.toolbarCls+" x-small-editor"}}this.el=c.createChild(Ext.apply({id:this.id},this.autoCreate),b);Ext.Toolbar.superclass.onRender.apply(this,arguments)}},lookupComponent:function(b){if(Ext.isString(b)){if(b=="-"){b=new a.Separator()}else{if(b==" "){b=new a.Spacer()}else{if(b=="->"){b=new a.Fill()}else{b=new a.TextItem(b)}}}this.applyDefaults(b)}else{if(b.isFormField||b.re
 nder){b=this.createComponent(b)}else{if(b.tag){b=new a.Item({autoEl:b})}else{if(b.tagName){b=new a.Item({el:b})}else{if(Ext.isObject(b)){b=b.xtype?this.createComponent(b):this.constructButton(b)}}}}}return b},applyDefaults:function(e){if(!Ext.isString(e)){e=Ext.Toolbar.superclass.applyDefaults.call(this,e);var b=this.internalDefaults;if(e.events){Ext.applyIf(e.initialConfig,b);Ext.apply(e,b)}else{Ext.applyIf(e,b)}}return e},addSeparator:function(){return this.add(new a.Separator())},addSpacer:function(){return this.add(new a.Spacer())},addFill:function(){this.add(new a.Fill())},addElement:function(b){return this.addItem(new a.Item({el:b}))},addItem:function(b){return this.add.apply(this,arguments)},addButton:function(c){if(Ext.isArray(c)){var e=[];for(var d=0,b=c.length;d<b;d++){e.push(this.addButton(c[d]))}return e}return this.add(this.constructButton(c))},addText:function(b){return this.addItem(new a.TextItem(b))},addDom:function(b){return this.add(new a.Item({autoEl:b}))}
 ,addField:function(b){return this.add(b)},insertButton:function(c,g){if(Ext.isArray(g)){var e=[];for(var d=0,b=g.length;d<b;d++){e.push(this.insertButton(c+d,g[d]))}return e}return Ext.Toolbar.superclass.insert.call(this,c,g)},trackMenu:function(c,b){if(this.trackMenus&&c.menu){var d=b?"mun":"mon";this[d](c,"menutriggerover",this.onButtonTriggerOver,this);this[d](c,"menushow",this.onButtonMenuShow,this);this[d](c,"menuhide",this.onButtonMenuHide,this)}},constructButton:function(d){var c=d.events?d:this.createComponent(d,d.split?"splitbutton":this.defaultType);return c},onAdd:function(b){Ext.Toolbar.superclass.onAdd.call(this);this.trackMenu(b);if(this.disabled){b.disable()}},onRemove:function(b){Ext.Toolbar.superclass.onRemove.call(this);if(b==this.activeMenuBtn){delete this.activeMenuBtn}this.trackMenu(b,true)},onDisable:function(){this.items.each(function(b){if(b.disable){b.disable()}})},onEnable:function(){this.items.each(function(b){if(b.enable){b.enable()}})},onButtonTr
 iggerOver:function(b){if(this.activeMenuBtn&&this.activeMenuBtn!=b){this.activeMenuBtn.hideMenu();b.showMenu();this.activeMenuBtn=b}},onButtonMenuShow:function(b){this.activeMenuBtn=b},onButtonMenuHide:function(b){delete this.activeMenuBtn}});Ext.reg("toolbar",Ext.Toolbar);a.Item=Ext.extend(Ext.BoxComponent,{hideParent:true,enable:Ext.emptyFn,disable:Ext.emptyFn,focus:Ext.emptyFn});Ext.reg("tbitem",a.Item);a.Separator=Ext.extend(a.Item,{onRender:function(c,b){this.el=c.createChild({tag:"span",cls:"xtb-sep"},b)}});Ext.reg("tbseparator",a.Separator);a.Spacer=Ext.extend(a.Item,{onRender:function(c,b){this.el=c.createChild({tag:"div",cls:"xtb-spacer",style:this.width?"width:"+this.width+"px":""},b)}});Ext.reg("tbspacer",a.Spacer);a.Fill=Ext.extend(a.Item,{render:Ext.emptyFn,isFill:true});Ext.reg("tbfill",a.Fill);a.TextItem=Ext.extend(a.Item,{constructor:function(b){a.TextItem.superclass.constructor.call(this,Ext.isString(b)?{text:b}:b)},onRender:function(c,b){this.autoEl={cls:"x
 tb-text",html:this.text||""};a.TextItem.superclass.onRender.call(this,c,b)},setText:function(b){if(this.rendered){this.el.update(b)}else{this.text=b}}});Ext.reg("tbtext",a.TextItem);a.Button=Ext.extend(Ext.Button,{});a.SplitButton=Ext.extend(Ext.SplitButton,{});Ext.reg("tbbutton",a.Button);Ext.reg("tbsplit",a.SplitButton)})();Ext.ButtonGroup=Ext.extend(Ext.Panel,{baseCls:"x-btn-group",layout:"table",defaultType:"button",frame:true,internalDefaults:{removeMode:"container",hideParent:true},initComponent:function(){this.layoutConfig=this.layoutConfig||{};Ext.applyIf(this.layoutConfig,{columns:this.columns});if(!this.title){this.addClass("x-btn-group-notitle")}this.on("afterlayout",this.onAfterLayout,this);Ext.ButtonGroup.superclass.initComponent.call(this)},applyDefaults:function(b){b=Ext.ButtonGroup.superclass.applyDefaults.call(this,b);var a=this.internalDefaults;if(b.events){Ext.applyIf(b.initialConfig,a);Ext.apply(b,a)}else{Ext.applyIf(b,a)}return b},onAfterLayout:function(
 ){var a=this.body.getFrameWidth("lr")+this.body.dom.firstChild.offsetWidth;this.body.setWidth(a);this.el.setWidth(a+this.getFrameWidth())}});Ext.reg("buttongroup",Ext.ButtonGroup);(function(){var a=Ext.Toolbar;Ext.PagingToolbar=Ext.extend(Ext.Toolbar,{pageSize:20,displayMsg:"Displaying {0} - {1} of {2}",emptyMsg:"No data to display",beforePageText:"Page",afterPageText:"of {0}",firstText:"First Page",prevText:"Previous Page",nextText:"Next Page",lastText:"Last Page",refreshText:"Refresh",initComponent:function(){var c=[this.first=new a.Button({tooltip:this.firstText,overflowText:this.firstText,iconCls:"x-tbar-page-first",disabled:true,handler:this.moveFirst,scope:this}),this.prev=new a.Button({tooltip:this.prevText,overflowText:this.prevText,iconCls:"x-tbar-page-prev",disabled:true,handler:this.movePrevious,scope:this}),"-",this.beforePageText,this.inputItem=new Ext.form.NumberField({cls:"x-tbar-page-number",allowDecimals:false,allowNegative:false,enableKeyEvents:true,selectO
 nFocus:true,submitValue:false,listeners:{scope:this,keydown:this.onPagingKeyDown,blur:this.onPagingBlur}}),this.afterTextItem=new a.TextItem({text:String.format(this.afterPageText,1)}),"-",this.next=new a.Button({tooltip:this.nextText,overflowText:this.nextText,iconCls:"x-tbar-page-next",disabled:true,handler:this.moveNext,scope:this}),this.last=new a.Button({tooltip:this.lastText,overflowText:this.lastText,iconCls:"x-tbar-page-last",disabled:true,handler:this.moveLast,scope:this}),"-",this.refresh=new a.Button({tooltip:this.refreshText,overflowText:this.refreshText,iconCls:"x-tbar-loading",handler:this.doRefresh,scope:this})];var b=this.items||this.buttons||[];if(this.prependButtons){this.items=b.concat(c)}else{this.items=c.concat(b)}delete this.buttons;if(this.displayInfo){this.items.push("->");this.items.push(this.displayItem=new a.TextItem({}))}Ext.PagingToolbar.superclass.initComponent.call(this);this.addEvents("change","beforechange");this.on("afterlayout",this.onFirst
 Layout,this,{single:true});this.cursor=0;this.bindStore(this.store,true)},onFirstLayout:function(){if(this.dsLoaded){this.onLoad.apply(this,this.dsLoaded)}},updateInfo:function(){if(this.displayItem){var b=this.store.getCount();var c=b==0?this.emptyMsg:String.format(this.displayMsg,this.cursor+1,this.cursor+b,this.store.getTotalCount());this.displayItem.setText(c)}},onLoad:function(b,e,j){if(!this.rendered){this.dsLoaded=[b,e,j];return}var g=this.getParams();this.cursor=(j.params&&j.params[g.start])?j.params[g.start]:0;var i=this.getPageData(),c=i.activePage,h=i.pages;this.afterTextItem.setText(String.format(this.afterPageText,i.pages));this.inputItem.setValue(c);this.first.setDisabled(c==1);this.prev.setDisabled(c==1);this.next.setDisabled(c==h);this.last.setDisabled(c==h);this.refresh.enable();this.updateInfo();this.fireEvent("change",this,i)},getPageData:function(){var b=this.store.getTotalCount();return{total:b,activePage:Math.ceil((this.cursor+this.pageSize)/this.pageSi
 ze),pages:b<this.pageSize?1:Math.ceil(b/this.pageSize)}},changePage:function(b){this.doLoad(((b-1)*this.pageSize).constrain(0,this.store.getTotalCount()))},onLoadError:function(){if(!this.rendered){return}this.refresh.enable()},readPage:function(e){var b=this.inputItem.getValue(),c;if(!b||isNaN(c=parseInt(b,10))){this.inputItem.setValue(e.activePage);return false}return c},onPagingFocus:function(){this.inputItem.select()},onPagingBlur:function(b){this.inputItem.setValue(this.getPageData().activePage)},onPagingKeyDown:function(i,h){var c=h.getKey(),j=this.getPageData(),g;if(c==h.RETURN){h.stopEvent();g=this.readPage(j);if(g!==false){g=Math.min(Math.max(1,g),j.pages)-1;this.doLoad(g*this.pageSize)}}else{if(c==h.HOME||c==h.END){h.stopEvent();g=c==h.HOME?1:j.pages;i.setValue(g)}else{if(c==h.UP||c==h.PAGEUP||c==h.DOWN||c==h.PAGEDOWN){h.stopEvent();if((g=this.readPage(j))){var b=h.shiftKey?10:1;if(c==h.DOWN||c==h.PAGEDOWN){b*=-1}g+=b;if(g>=1&g<=j.pages){i.setValue(g)}}}}}},getPara
 ms:function(){return this.paramNames||this.store.paramNames},beforeLoad:function(){if(this.rendered&&this.refresh){this.refresh.disable()}},doLoad:function(d){var c={},b=this.getParams();c[b.start]=d;c[b.limit]=this.pageSize;if(this.fireEvent("beforechange",this,c)!==false){this.store.load({params:c})}},moveFirst:function(){this.doLoad(0)},movePrevious:function(){this.doLoad(Math.max(0,this.cursor-this.pageSize))},moveNext:function(){this.doLoad(this.cursor+this.pageSize)},moveLast:function(){var c=this.store.getTotalCount(),b=c%this.pageSize;this.doLoad(b?(c-b):c-this.pageSize)},doRefresh:function(){this.doLoad(this.cursor)},bindStore:function(c,d){var b;if(!d&&this.store){if(c!==this.store&&this.store.autoDestroy){this.store.destroy()}else{this.store.un("beforeload",this.beforeLoad,this);this.store.un("load",this.onLoad,this);this.store.un("exception",this.onLoadError,this)}if(!c){this.store=null}}if(c){c=Ext.StoreMgr.lookup(c);c.on({scope:this,beforeload:this.beforeLoad,l
 oad:this.onLoad,exception:this.onLoadError});b=true}this.store=c;if(b){this.onLoad(c,null,{})}},unbind:function(b){this.bindStore(null)},bind:function(b){this.bindStore(b)},onDestroy:function(){this.bindStore(null);Ext.PagingToolbar.superclass.onDestroy.call(this)}})})();Ext.reg("paging",Ext.PagingToolbar);Ext.History=(function(){var e,c;var k=false;var d;function g(){var l=location.href,m=l.indexOf("#"),n=m>=0?l.substr(m+1):null;if(Ext.isGecko){n=decodeURIComponent(n)}return n}function a(){c.value=d}function h(l){d=l;Ext.History.fireEvent("change",l)}function i(m){var l=['<html><body><div id="state">',Ext.util.Format.htmlEncode(m),"</div></body></html>"].join("");try{var o=e.contentWindow.document;o.open();o.write(l);o.close();return true}catch(n){return false}}function b(){if(!e.contentWindow||!e.contentWindow.document){setTimeout(b,10);return}var o=e.contentWindow.document;var m=o.getElementById("state");var l=m?m.innerText:null;var n=g();setInterval(function(){o=e.conten
 tWindow.document;m=o.getElementById("state");var q=m?m.innerText:null;var p=g();if(q!==l){l=q;h(l);location.hash=l;n=l;a()}else{if(p!==n){n=p;i(p)}}},50);k=true;Ext.History.fireEvent("ready",Ext.History)}function j(){d=c.value?c.value:g();if(Ext.isIE){b()}else{var l=g();setInterval(function(){var m=g();if(m!==l){l=m;h(l);a()}},50);k=true;Ext.History.fireEvent("ready",Ext.History)}}return{fieldId:"x-history-field",iframeId:"x-history-frame",events:{},init:function(m,l){if(k){Ext.callback(m,l,[this]);return}if(!Ext.isReady){Ext.onReady(function(){Ext.History.init(m,l)});return}c=Ext.getDom(Ext.History.fieldId);if(Ext.isIE){e=Ext.getDom(Ext.History.iframeId)}this.addEvents("ready","change");if(m){this.on("ready",m,l,{single:true})}j()},add:function(l,m){if(m!==false){if(this.getToken()==l){return true}}if(Ext.isIE){return i(l)}else{location.hash=l;return true}},back:function(){history.go(-1)},forward:function(){history.go(1)},getToken:function(){return k?d:g()}}})();Ext.apply(E
 xt.History,new Ext.util.Observable());Ext.Tip=Ext.extend(Ext.Panel,{minWidth:40,maxWidth:300,shadow:"sides",defaultAlign:"tl-bl?",autoRender:true,quickShowInterval:250,frame:true,hidden:true,baseCls:"x-tip",floating:{shadow:true,shim:true,useDisplay:true,constrain:false},autoHeight:true,closeAction:"hide",initComponent:function(){Ext.Tip.superclass.initComponent.call(this);if(this.closable&&!this.title){this.elements+=",header"}},afterRender:function(){Ext.Tip.superclass.afterRender.call(this);if(this.closable){this.addTool({id:"close",handler:this[this.closeAction],scope:this})}},showAt:function(a){Ext.Tip.superclass.show.call(this);if(this.measureWidth!==false&&(!this.initialConfig||typeof this.initialConfig.width!="number")){this.doAutoWidth()}if(this.constrainPosition){a=this.el.adjustForConstraints(a)}this.setPagePosition(a[0],a[1])},doAutoWidth:function(a){a=a||0;var b=this.body.getTextWidth();if(this.title){b=Math.max(b,this.header.child("span").getTextWidth(this.titl
 e))}b+=this.getFrameWidth()+(this.closable?20:0)+this.body.getPadding("lr")+a;this.setWidth(b.constrain(this.minWidth,this.maxWidth));if(Ext.isIE7&&!this.repainted){this.el.repaint();this.repainted=true}},showBy:function(a,b){if(!this.rendered){this.render(Ext.getBody())}this.showAt(this.el.getAlignToXY(a,b||this.defaultAlign))},initDraggable:function(){this.dd=new Ext.Tip.DD(this,typeof this.draggable=="boolean"?null:this.draggable);this.header.addClass("x-tip-draggable")}});Ext.reg("tip",Ext.Tip);Ext.Tip.DD=function(b,a){Ext.apply(this,a);this.tip=b;Ext.Tip.DD.superclass.constructor.call(this,b.el.id,"WindowDD-"+b.id);this.setHandleElId(b.header.id);this.scroll=false};Ext.extend(Ext.Tip.DD,Ext.dd.DD,{moveOnly:true,scroll:false,headerOffsets:[100,25],startDrag:function(){this.tip.el.disableShadow()},endDrag:function(a){this.tip.el.enableShadow(true)}});Ext.ToolTip=Ext.extend(Ext.Tip,{showDelay:500,hideDelay:200,dismissDelay:5000,trackMouse:false,anchorToTarget:true,anchorOf
 fset:0,targetCounter:0,constrainPosition:false,initComponent:function(){Ext.ToolTip.superclass.initComponent.call(this);this.lastActive=new Date();this.initTarget(this.target);this.origAnchor=this.anchor},onRender:function(b,a){Ext.ToolTip.superclass.onRender.call(this,b,a);this.anchorCls="x-tip-anchor-"+this.getAnchorPosition();this.anchorEl=this.el.createChild({cls:"x-tip-anchor "+this.anchorCls})},afterRender:function(){Ext.ToolTip.superclass.afterRender.call(this);this.anchorEl.setStyle("z-index",this.el.getZIndex()+1).setVisibilityMode(Ext.Element.DISPLAY)},initTarget:function(c){var a;if((a=Ext.get(c))){if(this.target){var b=Ext.get(this.target);this.mun(b,"mouseover",this.onTargetOver,this);this.mun(b,"mouseout",this.onTargetOut,this);this.mun(b,"mousemove",this.onMouseMove,this)}this.mon(a,{mouseover:this.onTargetOver,mouseout:this.onTargetOut,mousemove:this.onMouseMove,scope:this});this.target=a}if(this.anchor){this.anchorTarget=this.target}},onMouseMove:function(b)
 {var a=this.delegate?b.getTarget(this.delegate):this.triggerElement=true;if(a){this.targetXY=b.getXY();if(a===this.triggerElement){if(!this.hidden&&this.trackMouse){this.setPagePosition(this.getTargetXY())}}else{this.hide();this.lastActive=new Date(0);this.onTargetOver(b)}}else{if(!this.closable&&this.isVisible()){this.hide()}}},getTargetXY:function(){if(this.delegate){this.anchorTarget=this.triggerElement}if(this.anchor){this.targetCounter++;var c=this.getOffsets(),l=(this.anchorToTarget&&!this.trackMouse)?this.el.getAlignToXY(this.anchorTarget,this.getAnchorAlign()):this.targetXY,a=Ext.lib.Dom.getViewWidth()-5,h=Ext.lib.Dom.getViewHeight()-5,i=document.documentElement,e=document.body,k=(i.scrollLeft||e.scrollLeft||0)+5,j=(i.scrollTop||e.scrollTop||0)+5,b=[l[0]+c[0],l[1]+c[1]],g=this.getSize();this.anchorEl.removeClass(this.anchorCls);if(this.targetCounter<2){if(b[0]<k){if(this.anchorToTarget){this.defaultAlign="l-r";if(this.mouseOffset){this.mouseOffset[0]*=-1}}this.anchor
 ="left";return this.getTargetXY()}if(b[0]+g.width>a){if(this.anchorToTarget){this.defaultAlign="r-l";if(this.mouseOffset){this.mouseOffset[0]*=-1}}this.anchor="right";return this.getTargetXY()}if(b[1]<j){if(this.anchorToTarget){this.defaultAlign="t-b";if(this.mouseOffset){this.mouseOffset[1]*=-1}}this.anchor="top";return this.getTargetXY()}if(b[1]+g.height>h){if(this.anchorToTarget){this.defaultAlign="b-t";if(this.mouseOffset){this.mouseOffset[1]*=-1}}this.anchor="bottom";return this.getTargetXY()}}this.anchorCls="x-tip-anchor-"+this.getAnchorPosition();this.anchorEl.addClass(this.anchorCls);this.targetCounter=0;return b}else{var d=this.getMouseOffset();return[this.targetXY[0]+d[0],this.targetXY[1]+d[1]]}},getMouseOffset:function(){var a=this.anchor?[0,0]:[15,18];if(this.mouseOffset){a[0]+=this.mouseOffset[0];a[1]+=this.mouseOffset[1]}return a},getAnchorPosition:function(){if(this.anchor){this.tipAnchor=this.anchor.charAt(0)}else{var a=this.defaultAlign.match(/^([a-z]+)-([a-
 z]+)(\?)?$/);if(!a){throw"AnchorTip.defaultAlign is invalid"}this.tipAnchor=a[1].charAt(0)}switch(this.tipAnchor){case"t":return"top";case"b":return"bottom";case"r":return"right"}return"left"},getAnchorAlign:function(){switch(this.anchor){case"top":return"tl-bl";case"left":return"tl-tr";case"right":return"tr-tl";default:return"bl-tl"}},getOffsets:function(){var b,a=this.getAnchorPosition().charAt(0);if(this.anchorToTarget&&!this.trackMouse){switch(a){case"t":b=[0,9];break;case"b":b=[0,-13];break;case"r":b=[-13,0];break;default:b=[9,0];break}}else{switch(a){case"t":b=[-15-this.anchorOffset,30];break;case"b":b=[-19-this.anchorOffset,-13-this.el.dom.offsetHeight];break;case"r":b=[-15-this.el.dom.offsetWidth,-13-this.anchorOffset];break;default:b=[25,-13-this.anchorOffset];break}}var c=this.getMouseOffset();b[0]+=c[0];b[1]+=c[1];return b},onTargetOver:function(b){if(this.disabled||b.within(this.target.dom,true)){return}var a=b.getTarget(this.delegate);if(a){this.triggerElement=a
 ;this.clearTimer("hide");this.targetXY=b.getXY();this.delayShow()}},delayShow:function(){if(this.hidden&&!this.showTimer){if(this.lastActive.getElapsed()<this.quickShowInterval){this.show()}else{this.showTimer=this.show.defer(this.showDelay,this)}}else{if(!this.hidden&&this.autoHide!==false){this.show()}}},onTargetOut:function(a){if(this.disabled||a.within(this.target.dom,true)){return}this.clearTimer("show");if(this.autoHide!==false){this.delayHide()}},delayHide:function(){if(!this.hidden&&!this.hideTimer){this.hideTimer=this.hide.defer(this.hideDelay,this)}},hide:function(){this.clearTimer("dismiss");this.lastActive=new Date();if(this.anchorEl){this.anchorEl.hide()}Ext.ToolTip.superclass.hide.call(this);delete this.triggerElement},show:function(){if(this.anchor){this.showAt([-1000,-1000]);this.origConstrainPosition=this.constrainPosition;this.constrainPosition=false;this.anchor=this.origAnchor}this.showAt(this.getTargetXY());if(this.anchor){this.anchorEl.show();this.syncAn
 chor();this.constrainPosition=this.origConstrainPosition}else{this.anchorEl.hide()}},showAt:function(a){this.lastActive=new Date();this.clearTimers();Ext.ToolTip.superclass.showAt.call(this,a);if(this.dismissDelay&&this.autoHide!==false){this.dismissTimer=this.hide.defer(this.dismissDelay,this)}if(this.anchor&&!this.anchorEl.isVisible()){this.syncAnchor();this.anchorEl.show()}else{this.anchorEl.hide()}},syncAnchor:function(){var a,b,c;switch(this.tipAnchor.charAt(0)){case"t":a="b";b="tl";c=[20+this.anchorOffset,2];break;case"r":a="l";b="tr";c=[-2,11+this.anchorOffset];break;case"b":a="t";b="bl";c=[20+this.anchorOffset,-2];break;default:a="r";b="tl";c=[2,11+this.anchorOffset];break}this.anchorEl.alignTo(this.el,a+"-"+b,c)},setPagePosition:function(a,b){Ext.ToolTip.superclass.setPagePosition.call(this,a,b);if(this.anchor){this.syncAnchor()}},clearTimer:function(a){a=a+"Timer";clearTimeout(this[a]);delete this[a]},clearTimers:function(){this.clearTimer("show");this.clearTimer("
 dismiss");this.clearTimer("hide")},onShow:function(){Ext.ToolTip.superclass.onShow.call(this);Ext.getDoc().on("mousedown",this.onDocMouseDown,this)},onHide:function(){Ext.ToolTip.superclass.onHide.call(this);Ext.getDoc().un("mousedown",this.onDocMouseDown,this)},onDocMouseDown:function(a){if(this.autoHide!==true&&!this.closable&&!a.within(this.el.dom)){this.disable();this.doEnable.defer(100,this)}},doEnable:function(){if(!this.isDestroyed){this.enable()}},onDisable:function(){this.clearTimers();this.hide()},adjustPosition:function(a,d){if(this.constrainPosition){var c=this.targetXY[1],b=this.getSize().height;if(d<=c&&(d+b)>=c){d=c-b-5}}return{x:a,y:d}},beforeDestroy:function(){this.clearTimers();Ext.destroy(this.anchorEl);delete this.anchorEl;delete this.target;delete this.anchorTarget;delete this.triggerElement;Ext.ToolTip.superclass.beforeDestroy.call(this)},onDestroy:function(){Ext.getDoc().un("mousedown",this.onDocMouseDown,this);Ext.ToolTip.superclass.onDestroy.call(thi
 s)}});Ext.reg("tooltip",Ext.ToolTip);Ext.QuickTip=Ext.extend(Ext.ToolTip,{interceptTitles:false,tagConfig:{namespace:"ext",attribute:"qtip",width:"qwidth",target:"target",title:"qtitle",hide:"hide",cls:"qclass",align:"qalign",anchor:"anchor"},initComponent:function(){this.target=this.target||Ext.getDoc();this.targets=this.targets||{};Ext.QuickTip.superclass.initComponent.call(this)},register:function(e){var h=Ext.isArray(e)?e:arguments;for(var g=0,a=h.length;g<a;g++){var l=h[g];var k=l.target;if(k){if(Ext.isArray(k)){for(var d=0,b=k.length;d<b;d++){this.targets[Ext.id(k[d])]=l}}else{this.targets[Ext.id(k)]=l}}}},unregister:function(a){delete this.targets[Ext.id(a)]},cancelShow:function(b){var a=this.activeTarget;b=Ext.get(b).dom;if(this.isVisible()){if(a&&a.el==b){this.hide()}}else{if(a&&a.el==b){this.clearTimer("show")}}},getTipCfg:function(d){var b=d.getTarget(),c,a;if(this.interceptTitles&&b.title&&Ext.isString(b.title)){c=b.title;b.qtip=c;b.removeAttribute("title");d.pre
 ventDefault()}else{a=this.tagConfig;c=b.qtip||Ext.fly(b).getAttribute(a.attribute,a.namespace)}return c},onTargetOver:function(i){if(this.disabled){return}this.targetXY=i.getXY();var c=i.getTarget();if(!c||c.nodeType!==1||c==document||c==document.body){return}if(this.activeTarget&&((c==this.activeTarget.el)||Ext.fly(this.activeTarget.el).contains(c))){this.clearTimer("hide");this.show();return}if(c&&this.targets[c.id]){this.activeTarget=this.targets[c.id];this.activeTarget.el=c;this.anchor=this.activeTarget.anchor;if(this.anchor){this.anchorTarget=c}this.delayShow();return}var g,h=Ext.fly(c),b=this.tagConfig,d=b.namespace;if(g=this.getTipCfg(i)){var a=h.getAttribute(b.hide,d);this.activeTarget={el:c,text:g,width:h.getAttribute(b.width,d),autoHide:a!="user"&&a!=="false",title:h.getAttribute(b.title,d),cls:h.getAttribute(b.cls,d),align:h.getAttribute(b.align,d)};this.anchor=h.getAttribute(b.anchor,d);if(this.anchor){this.anchorTarget=c}this.delayShow()}},onTargetOut:function(a
 ){if(this.activeTarget&&a.within(this.activeTarget.el)&&!this.getTipCfg(a)){return}this.clearTimer("show");if(this.autoHide!==false){this.delayHide()}},showAt:function(b){var a=this.activeTarget;if(a){if(!this.rendered){this.render(Ext.getBody());this.activeTarget=a}if(a.width){this.setWidth(a.width);this.body.setWidth(this.adjustBodyWidth(a.width-this.getFrameWidth()));this.measureWidth=false}else{this.measureWidth=true}this.setTitle(a.title||"");this.body.update(a.text);this.autoHide=a.autoHide;this.dismissDelay=a.dismissDelay||this.dismissDelay;if(this.lastCls){this.el.removeClass(this.lastCls);delete this.lastCls}if(a.cls){this.el.addClass(a.cls);this.lastCls=a.cls}if(this.anchor){this.constrainPosition=false}else{if(a.align){b=this.el.getAlignToXY(a.el,a.align);this.constrainPosition=false}else{this.constrainPosition=true}}}Ext.QuickTip.superclass.showAt.call(this,b)},hide:function(){delete this.activeTarget;Ext.QuickTip.superclass.hide.call(this)}});Ext.reg("quicktip",
 Ext.QuickTip);Ext.QuickTips=function(){var b,a=false;return{init:function(c){if(!b){if(!Ext.isReady){Ext.onReady(function(){Ext.QuickTips.init(c)});return}b=new Ext.QuickTip({elements:"header,body",disabled:a});if(c!==false){b.render(Ext.getBody())}}},ddDisable:function(){if(b&&!a){b.disable()}},ddEnable:function(){if(b&&!a){b.enable()}},enable:function(){if(b){b.enable()}a=false},disable:function(){if(b){b.disable()}a=true},isEnabled:function(){return b!==undefined&&!b.disabled},getQuickTip:function(){return b},register:function(){b.register.apply(b,arguments)},unregister:function(){b.unregister.apply(b,arguments)},tips:function(){b.register.apply(b,arguments)}}}();Ext.slider.Tip=Ext.extend(Ext.Tip,{minWidth:10,offsets:[0,-10],init:function(a){a.on({scope:this,dragstart:this.onSlide,drag:this.onSlide,dragend:this.hide,destroy:this.destroy})},onSlide:function(b,c,a){this.show();this.body.update(this.getText(a));this.doAutoWidth();this.el.alignTo(a.el,"b-t?",this.offsets)},ge
 tText:function(a){return String(a.value)}});Ext.ux.SliderTip=Ext.slider.Tip;Ext.tree.TreePanel=Ext.extend(Ext.Panel,{rootVisible:true,animate:Ext.enableFx,lines:true,enableDD:false,hlDrop:Ext.enableFx,pathSeparator:"/",bubbleEvents:[],initComponent:function(){Ext.tree.TreePanel.superclass.initComponent.call(this);if(!this.eventModel){this.eventModel=new Ext.tree.TreeEventModel(this)}var a=this.loader;if(!a){a=new Ext.tree.TreeLoader({dataUrl:this.dataUrl,requestMethod:this.requestMethod})}else{if(Ext.isObject(a)&&!a.load){a=new Ext.tree.TreeLoader(a)}}this.loader=a;this.nodeHash={};if(this.root){var b=this.root;delete this.root;this.setRootNode(b)}this.addEvents("append","remove","movenode","insert","beforeappend","beforeremove","beforemovenode","beforeinsert","beforeload","load","textchange","beforeexpandnode","beforecollapsenode","expandnode","disabledchange","collapsenode","beforeclick","click","containerclick","checkchange","beforedblclick","dblclick","containerdblclick"
 ,"contextmenu","containercontextmenu","beforechildrenrendered","startdrag","enddrag","dragdrop","beforenodedrop","nodedrop","nodedragover");if(this.singleExpand){this.on("beforeexpandnode",this.restrictExpand,this)}},proxyNodeEvent:function(c,b,a,h,g,e,d){if(c=="collapse"||c=="expand"||c=="beforecollapse"||c=="beforeexpand"||c=="move"||c=="beforemove"){c=c+"node"}return this.fireEvent(c,b,a,h,g,e,d)},getRootNode:function(){return this.root},setRootNode:function(b){this.destroyRoot();if(!b.render){b=this.loader.createNode(b)}this.root=b;b.ownerTree=this;b.isRoot=true;this.registerNode(b);if(!this.rootVisible){var a=b.attributes.uiProvider;b.ui=a?new a(b):new Ext.tree.RootTreeNodeUI(b)}if(this.innerCt){this.clearInnerCt();this.renderRoot()}return b},clearInnerCt:function(){this.innerCt.update("")},renderRoot:function(){this.root.render();if(!this.rootVisible){this.root.renderChildren()}},getNodeById:function(a){return this.nodeHash[a]},registerNode:function(a){this.nodeHash[a.
 id]=a},unregisterNode:function(a){delete this.nodeHash[a.id]},toString:function(){return"[Tree"+(this.id?" "+this.id:"")+"]"},restrictExpand:function(a){var b=a.parentNode;if(b){if(b.expandedChild&&b.expandedChild.parentNode==b){b.expandedChild.collapse()}b.expandedChild=a}},getChecked:function(b,c){c=c||this.root;var d=[];var e=function(){if(this.attributes.checked){d.push(!b?this:(b=="id"?this.id:this.attributes[b]))}};c.cascade(e);return d},getLoader:function(){return this.loader},expandAll:function(){this.root.expand(true)},collapseAll:function(){this.root.collapse(true)},getSelectionModel:function(){if(!this.selModel){this.selModel=new Ext.tree.DefaultSelectionModel()}return this.selModel},expandPath:function(g,a,h){if(Ext.isEmpty(g)){if(h){h(false,undefined)}return}a=a||"id";var d=g.split(this.pathSeparator);var c=this.root;if(c.attributes[a]!=d[1]){if(h){h(false,null)}return}var b=1;var e=function(){if(++b==d.length){if(h){h(true,c)}return}var i=c.findChild(a,d[b]);if
 (!i){if(h){h(false,c)}return}c=i;i.expand(false,false,e)};c.expand(false,false,e)},selectPath:function(e,a,g){if(Ext.isEmpty(e)){if(g){g(false,undefined)}return}a=a||"id";var c=e.split(this.pathSeparator),b=c.pop();if(c.length>1){var d=function(i,h){if(i&&h){var j=h.findChild(a,b);if(j){j.select();if(g){g(true,j)}}else{if(g){g(false,j)}}}else{if(g){g(false,j)}}};this.expandPath(c.join(this.pathSeparator),a,d)}else{this.root.select();if(g){g(true,this.root)}}},getTreeEl:function(){return this.body},onRender:function(b,a){Ext.tree.TreePanel.superclass.onRender.call(this,b,a);this.el.addClass("x-tree");this.innerCt=this.body.createChild({tag:"ul",cls:"x-tree-root-ct "+(this.useArrows?"x-tree-arrows":this.lines?"x-tree-lines":"x-tree-no-lines")})},initEvents:function(){Ext.tree.TreePanel.superclass.initEvents.call(this);if(this.containerScroll){Ext.dd.ScrollManager.register(this.body)}if((this.enableDD||this.enableDrop)&&!this.dropZone){this.dropZone=new Ext.tree.TreeDropZone(th
 is,this.dropConfig||{ddGroup:this.ddGroup||"TreeDD",appendOnly:this.ddAppendOnly===true})}if((this.enableDD||this.enableDrag)&&!this.dragZone){this.dragZone=new Ext.tree.TreeDragZone(this,this.dragConfig||{ddGroup:this.ddGroup||"TreeDD",scroll:this.ddScroll})}this.getSelectionModel().init(this)},afterRender:function(){Ext.tree.TreePanel.superclass.afterRender.call(this);this.renderRoot()},beforeDestroy:function(){if(this.rendered){Ext.dd.ScrollManager.unregister(this.body);Ext.destroy(this.dropZone,this.dragZone)}this.destroyRoot();Ext.destroy(this.loader);this.nodeHash=this.root=this.loader=null;Ext.tree.TreePanel.superclass.beforeDestroy.call(this)},destroyRoot:function(){if(this.root&&this.root.destroy){this.root.destroy(true)}}});Ext.tree.TreePanel.nodeTypes={};Ext.reg("treepanel",Ext.tree.TreePanel);Ext.tree.TreeEventModel=function(a){this.tree=a;this.tree.on("render",this.initEvents,this)};Ext.tree.TreeEventModel.prototype={initEvents:function(){var a=this.tree;if(a.tr
 ackMouseOver!==false){a.mon(a.innerCt,{scope:this,mouseover:this.delegateOver,mouseout:this.delegateOut})}a.mon(a.getTreeEl(),{scope:this,click:this.delegateClick,dblclick:this.delegateDblClick,contextmenu:this.delegateContextMenu})},getNode:function(b){var a;if(a=b.getTarget(".x-tree-node-el",10)){var c=Ext.fly(a,"_treeEvents").getAttribute("tree-node-id","ext");if(c){return this.tree.getNodeById(c)}}return null},getNodeTarget:function(b){var a=b.getTarget(".x-tree-node-icon",1);if(!a){a=b.getTarget(".x-tree-node-el",6)}return a},delegateOut:function(b,a){if(!this.beforeEvent(b)){return}if(b.getTarget(".x-tree-ec-icon",1)){var c=this.getNode(b);this.onIconOut(b,c);if(c==this.lastEcOver){delete this.lastEcOver}}if((a=this.getNodeTarget(b))&&!b.within(a,true)){this.onNodeOut(b,this.getNode(b))}},delegateOver:function(b,a){if(!this.beforeEvent(b)){return}if(Ext.isGecko&&!this.trackingDoc){Ext.getBody().on("mouseover",this.trackExit,this);this.trackingDoc=true}if(this.lastEcOve
 r){this.onIconOut(b,this.lastEcOver);delete this.lastEcOver}if(b.getTarget(".x-tree-ec-icon",1)){this.lastEcOver=this.getNode(b);this.onIconOver(b,this.lastEcOver)}if(a=this.getNodeTarget(b)){this.onNodeOver(b,this.getNode(b))}},trackExit:function(a){if(this.lastOverNode){if(this.lastOverNode.ui&&!a.within(this.lastOverNode.ui.getEl())){this.onNodeOut(a,this.lastOverNode)}delete this.lastOverNode;Ext.getBody().un("mouseover",this.trackExit,this);this.trackingDoc=false}},delegateClick:function(b,a){if(this.beforeEvent(b)){if(b.getTarget("input[type=checkbox]",1)){this.onCheckboxClick(b,this.getNode(b))}else{if(b.getTarget(".x-tree-ec-icon",1)){this.onIconClick(b,this.getNode(b))}else{if(this.getNodeTarget(b)){this.onNodeClick(b,this.getNode(b))}}}}else{this.checkContainerEvent(b,"click")}},delegateDblClick:function(b,a){if(this.beforeEvent(b)){if(this.getNodeTarget(b)){this.onNodeDblClick(b,this.getNode(b))}}else{this.checkContainerEvent(b,"dblclick")}},delegateContextMenu:fu
 nction(b,a){if(this.beforeEvent(b)){if(this.getNodeTarget(b)){this.onNodeContextMenu(b,this.getNode(b))}}else{this.checkContainerEvent(b,"contextmenu")}},checkContainerEvent:function(b,a){if(this.disabled){b.stopEvent();return false}this.onContainerEvent(b,a)},onContainerEvent:function(b,a){this.tree.fireEvent("container"+a,this.tree,b)},onNodeClick:function(b,a){a.ui.onClick(b)},onNodeOver:function(b,a){this.lastOverNode=a;a.ui.onOver(b)},onNodeOut:function(b,a){a.ui.onOut(b)},onIconOver:function(b,a){a.ui.addClass("x-tree-ec-over")},onIconOut:function(b,a){a.ui.removeClass("x-tree-ec-over")},onIconClick:function(b,a){a.ui.ecClick(b)},onCheckboxClick:function(b,a){a.ui.onCheckChange(b)},onNodeDblClick:function(b,a){a.ui.onDblClick(b)},onNodeContextMenu:function(b,a){a.ui.onContextMenu(b)},beforeEvent:function(b){var a=this.getNode(b);if(this.disabled||!a||!a.ui){b.stopEvent();return false}return true},disable:function(){this.disabled=true},enable:function(){this.disabled=fa
 lse}};Ext.tree.DefaultSelectionModel=Ext.extend(Ext.util.Observable,{constructor:function(a){this.selNode=null;this.addEvents("selectionchange","beforeselect");Ext.apply(this,a);Ext.tree.DefaultSelectionModel.superclass.constructor.call(this)},init:function(a){this.tree=a;a.mon(a.getTreeEl(),"keydown",this.onKeyDown,this);a.on("click",this.onNodeClick,this)},onNodeClick:function(a,b){this.select(a)},select:function(c,a){if(!Ext.fly(c.ui.wrap).isVisible()&&a){return a.call(this,c)}var b=this.selNode;if(c==b){c.ui.onSelectedChange(true)}else{if(this.fireEvent("beforeselect",this,c,b)!==false){if(b&&b.ui){b.ui.onSelectedChange(false)}this.selNode=c;c.ui.onSelectedChange(true);this.fireEvent("selectionchange",this,c,b)}}return c},unselect:function(b,a){if(this.selNode==b){this.clearSelections(a)}},clearSelections:function(a){var b=this.selNode;if(b){b.ui.onSelectedChange(false);this.selNode=null;if(a!==true){this.fireEvent("selectionchange",this,null)}}return b},getSelectedNode:
 function(){return this.selNode},isSelected:function(a){return this.selNode==a},selectPrevious:function(a){if(!(a=a||this.selNode||this.lastSelNode)){return null}var c=a.previousSibling;if(c){if(!c.isExpanded()||c.childNodes.length<1){return this.select(c,this.selectPrevious)}else{var b=c.lastChild;while(b&&b.isExpanded()&&Ext.fly(b.ui.wrap).isVisible()&&b.childNodes.length>0){b=b.lastChild}return this.select(b,this.selectPrevious)}}else{if(a.parentNode&&(this.tree.rootVisible||!a.parentNode.isRoot)){return this.select(a.parentNode,this.selectPrevious)}}return null},selectNext:function(b){if(!(b=b||this.selNode||this.lastSelNode)){return null}if(b.firstChild&&b.isExpanded()&&Ext.fly(b.ui.wrap).isVisible()){return this.select(b.firstChild,this.selectNext)}else{if(b.nextSibling){return this.select(b.nextSibling,this.selectNext)}else{if(b.parentNode){var a=null;b.parentNode.bubble(function(){if(this.nextSibling){a=this.getOwnerTree().selModel.select(this.nextSibling,this.selectN
 ext);return false}});return a}}}return null},onKeyDown:function(c){var b=this.selNode||this.lastSelNode;var d=this;if(!b){return}var a=c.getKey();switch(a){case c.DOWN:c.stopEvent();this.selectNext();break;case c.UP:c.stopEvent();this.selectPrevious();break;case c.RIGHT:c.preventDefault();if(b.hasChildNodes()){if(!b.isExpanded()){b.expand()}else{if(b.firstChild){this.select(b.firstChild,c)}}}break;case c.LEFT:c.preventDefault();if(b.hasChildNodes()&&b.isExpanded()){b.collapse()}else{if(b.parentNode&&(this.tree.rootVisible||b.parentNode!=this.tree.getRootNode())){this.select(b.parentNode,c)}}break}}});Ext.tree.MultiSelectionModel=Ext.extend(Ext.util.Observable,{constructor:function(a){this.selNodes=[];this.selMap={};this.addEvents("selectionchange");Ext.apply(this,a);Ext.tree.MultiSelectionModel.superclass.constructor.call(this)},init:function(a){this.tree=a;a.mon(a.getTreeEl(),"keydown",this.onKeyDown,this);a.on("click",this.onNodeClick,this)},onNodeClick:function(a,b){if(b.
 ctrlKey&&this.isSelected(a)){this.unselect(a)}else{this.select(a,b,b.ctrlKey)}},select:function(a,c,b){if(b!==true){this.clearSelections(true)}if(this.isSelected(a)){this.lastSelNode=a;return a}this.selNodes.push(a);this.selMap[a.id]=a;this.lastSelNode=a;a.ui.onSelectedChange(true);this.fireEvent("selectionchange",this,this.selNodes);return a},unselect:function(b){if(this.selMap[b.id]){b.ui.onSelectedChange(false);var c=this.selNodes;var a=c.indexOf(b);if(a!=-1){this.selNodes.splice(a,1)}delete this.selMap[b.id];this.fireEvent("selectionchange",this,this.selNodes)}},clearSelections:function(b){var d=this.selNodes;if(d.length>0){for(var c=0,a=d.length;c<a;c++){d[c].ui.onSelectedChange(false)}this.selNodes=[];this.selMap={};if(b!==true){this.fireEvent("selectionchange",this,this.selNodes)}}},isSelected:function(a){return this.selMap[a.id]?true:false},getSelectedNodes:function(){return this.selNodes.concat([])},onKeyDown:Ext.tree.DefaultSelectionModel.prototype.onKeyDown,select
 Next:Ext.tree.DefaultSelectionModel.prototype.selectNext,selectPrevious:Ext.tree.DefaultSelectionModel.prototype.selectPrevious});Ext.data.Tree=Ext.extend(Ext.util.Observable,{constructor:function(a){this.nodeHash={};this.root=null;if(a){this.setRootNode(a)}this.addEvents("append","remove","move","insert","beforeappend","beforeremove","beforemove","beforeinsert");Ext.data.Tree.superclass.constructor.call(this)},pathSeparator:"/",proxyNodeEvent:function(){return this.fireEvent.apply(this,arguments)},getRootNode:function(){return this.root},setRootNode:function(a){this.root=a;a.ownerTree=this;a.isRoot=true;this.registerNode(a);return a},getNodeById:function(a){return this.nodeHash[a]},registerNode:function(a){this.nodeHash[a.id]=a},unregisterNode:function(a){delete this.nodeHash[a.id]},toString:function(){return"[Tree"+(this.id?" "+this.id:"")+"]"}});Ext.data.Node=Ext.extend(Ext.util.Observable,{constructor:function(a){this.attributes=a||{};this.leaf=this.attributes.leaf;this.
 id=this.attributes.id;if(!this.id){this.id=Ext.id(null,"xnode-");this.attributes.id=this.id}this.childNodes=[];this.parentNode=null;this.firstChild=null;this.lastChild=null;this.previousSibling=null;this.nextSibling=null;this.addEvents({append:true,remove:true,move:true,insert:true,beforeappend:true,beforeremove:true,beforemove:true,beforeinsert:true});this.listeners=this.attributes.listeners;Ext.data.Node.superclass.constructor.call(this)},fireEvent:function(b){if(Ext.data.Node.superclass.fireEvent.apply(this,arguments)===false){return false}var a=this.getOwnerTree();if(a){if(a.proxyNodeEvent.apply(a,arguments)===false){return false}}return true},isLeaf:function(){return this.leaf===true},setFirstChild:function(a){this.firstChild=a},setLastChild:function(a){this.lastChild=a},isLast:function(){return(!this.parentNode?true:this.parentNode.lastChild==this)},isFirst:function(){return(!this.parentNode?true:this.parentNode.firstChild==this)},hasChildNodes:function(){return !this.
 isLeaf()&&this.childNodes.length>0},isExpandable:function(){return this.attributes.expandable||this.hasChildNodes()},appendChild:function(e){var g=false;if(Ext.isArray(e)){g=e}else{if(arguments.length>1){g=arguments}}if(g){for(var d=0,a=g.length;d<a;d++){this.appendChild(g[d])}}else{if(this.fireEvent("beforeappend",this.ownerTree,this,e)===false){return false}var b=this.childNodes.length;var c=e.parentNode;if(c){if(e.fireEvent("beforemove",e.getOwnerTree(),e,c,this,b)===false){return false}c.removeChild(e)}b=this.childNodes.length;if(b===0){this.setFirstChild(e)}this.childNodes.push(e);e.parentNode=this;var h=this.childNodes[b-1];if(h){e.previousSibling=h;h.nextSibling=e}else{e.previousSibling=null}e.nextSibling=null;this.setLastChild(e);e.setOwnerTree(this.getOwnerTree());this.fireEvent("append",this.ownerTree,this,e,b);if(c){e.fireEvent("move",this.ownerTree,e,c,this,b)}return e}},removeChild:function(c,b){var a=this.childNodes.indexOf(c);if(a==-1){return false}if(this.fir
 eEvent("beforeremove",this.ownerTree,this,c)===false){return false}this.childNodes.splice(a,1);if(c.previousSibling){c.previousSibling.nextSibling=c.nextSibling}if(c.nextSibling){c.nextSibling.previousSibling=c.previousSibling}if(this.firstChild==c){this.setFirstChild(c.nextSibling)}if(this.lastChild==c){this.setLastChild(c.previousSibling)}this.fireEvent("remove",this.ownerTree,this,c);if(b){c.destroy(true)}else{c.clear()}return c},clear:function(a){this.setOwnerTree(null,a);this.parentNode=this.previousSibling=this.nextSibling=null;if(a){this.firstChild=this.lastChild=null}},destroy:function(a){if(a===true){this.purgeListeners();this.clear(true);Ext.each(this.childNodes,function(b){b.destroy(true)});this.childNodes=null}else{this.remove(true)}},insertBefore:function(d,a){if(!a){return this.appendChild(d)}if(d==a){return false}if(this.fireEvent("beforeinsert",this.ownerTree,this,d,a)===false){return false}var b=this.childNodes.indexOf(a);var c=d.parentNode;var e=b;if(c==thi
 s&&this.childNodes.indexOf(d)<b){e--}if(c){if(d.fireEvent("beforemove",d.getOwnerTree(),d,c,this,b,a)===false){return false}c.removeChild(d)}if(e===0){this.setFirstChild(d)}this.childNodes.splice(e,0,d);d.parentNode=this;var g=this.childNodes[e-1];if(g){d.previousSibling=g;g.nextSibling=d}else{d.previousSibling=null}d.nextSibling=a;a.previousSibling=d;d.setOwnerTree(this.getOwnerTree());this.fireEvent("insert",this.ownerTree,this,d,a);if(c){d.fireEvent("move",this.ownerTree,d,c,this,e,a)}return d},remove:function(a){if(this.parentNode){this.parentNode.removeChild(this,a)}return this},removeAll:function(a){var c=this.childNodes,b;while((b=c[0])){this.removeChild(b,a)}return this},item:function(a){return this.childNodes[a]},replaceChild:function(a,c){var b=c?c.nextSibling:null;this.removeChild(c);this.insertBefore(a,b);return c},indexOf:function(a){return this.childNodes.indexOf(a)},getOwnerTree:function(){if(!this.ownerTree){var a=this;while(a){if(a.ownerTree){this.ownerTree=
 a.ownerTree;break}a=a.parentNode}}return this.ownerTree},getDepth:function(){var b=0;var a=this;while(a.parentNode){++b;a=a.parentNode}return b},setOwnerTree:function(a,b){if(a!=this.ownerTree){if(this.ownerTree){this.ownerTree.unregisterNode(this)}this.ownerTree=a;if(b!==true){Ext.each(this.childNodes,function(c){c.setOwnerTree(a)})}if(a){a.registerNode(this)}}},setId:function(b){if(b!==this.id){var a=this.ownerTree;if(a){a.unregisterNode(this)}this.id=this.attributes.id=b;if(a){a.registerNode(this)}this.onIdChange(b)}},onIdChange:Ext.emptyFn,getPath:function(c){c=c||"id";var e=this.parentNode;var a=[this.attributes[c]];while(e){a.unshift(e.attributes[c]);e=e.parentNode}var d=this.getOwnerTree().pathSeparator;return d+a.join(d)},bubble:function(c,b,a){var d=this;while(d){if(c.apply(b||d,a||[d])===false){break}d=d.parentNode}},cascade:function(g,e,b){if(g.apply(e||this,b||[this])!==false){var d=this.childNodes;for(var c=0,a=d.length;c<a;c++){d[c].cascade(g,e,b)}}},eachChild:
 function(g,e,b){var d=this.childNodes;for(var c=0,a=d.length;c<a;c++){if(g.apply(e||d[c],b||[d[c]])===false){break}}},findChild:function(b,c,a){return this.findChildBy(function(){return this.attributes[b]==c},null,a)},findChildBy:function(h,g,b){var e=this.childNodes,a=e.length,d=0,j,c;for(;d<a;d++){j=e[d];if(h.call(g||j,j)===true){return j}else{if(b){c=j.findChildBy(h,g,b);if(c!=null){return c}}}}return null},sort:function(e,d){var c=this.childNodes;var a=c.length;if(a>0){var g=d?function(){e.apply(d,arguments)}:e;c.sort(g);for(var b=0;b<a;b++){var h=c[b];h.previousSibling=c[b-1];h.nextSibling=c[b+1];if(b===0){this.setFirstChild(h)}if(b==a-1){this.setLastChild(h)}}}},contains:function(a){return a.isAncestor(this)},isAncestor:function(a){var b=this.parentNode;while(b){if(b==a){return true}b=b.parentNode}return false},toString:function(){return"[Node"+(this.id?" "+this.id:"")+"]"}});Ext.tree.TreeNode=Ext.extend(Ext.data.Node,{constructor:function(a){a=a||{};if(Ext.isString(a)
 ){a={text:a}}this.childrenRendered=false;this.rendered=false;Ext.tree.TreeNode.superclass.constructor.call(this,a);this.expanded=a.expanded===true;this.isTarget=a.isTarget!==false;this.draggable=a.draggable!==false&&a.allowDrag!==false;this.allowChildren=a.allowChildren!==false&&a.allowDrop!==false;this.text=a.text;this.disabled=a.disabled===true;this.hidden=a.hidden===true;this.addEvents("textchange","beforeexpand","beforecollapse","expand","disabledchange","collapse","beforeclick","click","checkchange","beforedblclick","dblclick","contextmenu","beforechildrenrendered");var b=this.attributes.uiProvider||this.defaultUI||Ext.tree.TreeNodeUI;this.ui=new b(this)},preventHScroll:true,isExpanded:function(){return this.expanded},getUI:function(){return this.ui},getLoader:function(){var a;return this.loader||((a=this.getOwnerTree())&&a.loader?a.loader:(this.loader=new Ext.tree.TreeLoader()))},setFirstChild:function(a){var b=this.firstChild;Ext.tree.TreeNode.superclass.setFirstChild
 .call(this,a);if(this.childrenRendered&&b&&a!=b){b.renderIndent(true,true)}if(this.rendered){this.renderIndent(true,true)}},setLastChild:function(b){var a=this.lastChild;Ext.tree.TreeNode.superclass.setLastChild.call(this,b);if(this.childrenRendered&&a&&b!=a){a.renderIndent(true,true)}if(this.rendered){this.renderIndent(true,true)}},appendChild:function(b){if(!b.render&&!Ext.isArray(b)){b=this.getLoader().createNode(b)}var a=Ext.tree.TreeNode.superclass.appendChild.call(this,b);if(a&&this.childrenRendered){a.render()}this.ui.updateExpandIcon();return a},removeChild:function(b,a){this.ownerTree.getSelectionModel().unselect(b);Ext.tree.TreeNode.superclass.removeChild.apply(this,arguments);if(!a){var c=b.ui.rendered;if(c){b.ui.remove()}if(c&&this.childNodes.length<1){this.collapse(false,false)}else{this.ui.updateExpandIcon()}if(!this.firstChild&&!this.isHiddenRoot()){this.childrenRendered=false}}return b},insertBefore:function(c,a){if(!c.render){c=this.getLoader().createNode(c)
 }var b=Ext.tree.TreeNode.superclass.insertBefore.call(this,c,a);if(b&&a&&this.childrenRendered){c.render()}this.ui.updateExpandIcon();return b},setText:function(b){var a=this.text;this.text=this.attributes.text=b;if(this.rendered){this.ui.onTextChange(this,b,a)}this.fireEvent("textchange",this,b,a)},setIconCls:function(b){var a=this.attributes.iconCls;this.attributes.iconCls=b;if(this.rendered){this.ui.onIconClsChange(this,b,a)}},setTooltip:function(a,b){this.attributes.qtip=a;this.attributes.qtipTitle=b;if(this.rendered){this.ui.onTipChange(this,a,b)}},setIcon:function(a){this.attributes.icon=a;if(this.rendered){this.ui.onIconChange(this,a)}},setHref:function(a,b){this.attributes.href=a;this.attributes.hrefTarget=b;if(this.rendered){this.ui.onHrefChange(this,a,b)}},setCls:function(b){var a=this.attributes.cls;this.attributes.cls=b;if(this.rendered){this.ui.onClsChange(this,b,a)}},select:function(){var a=this.getOwnerTree();if(a){a.getSelectionModel().select(this)}},unselect
 :function(a){var b=this.getOwnerTree();if(b){b.getSelectionModel().unselect(this,a)}},isSelected:function(){var a=this.getOwnerTree();return a?a.getSelectionModel().isSelected(this):false},expand:function(a,c,d,b){if(!this.expanded){if(this.fireEvent("beforeexpand",this,a,c)===false){return}if(!this.childrenRendered){this.renderChildren()}this.expanded=true;if(!this.isHiddenRoot()&&(this.getOwnerTree().animate&&c!==false)||c){this.ui.animExpand(function(){this.fireEvent("expand",this);this.runCallback(d,b||this,[this]);if(a===true){this.expandChildNodes(true,true)}}.createDelegate(this));return}else{this.ui.expand();this.fireEvent("expand",this);this.runCallback(d,b||this,[this])}}else{this.runCallback(d,b||this,[this])}if(a===true){this.expandChildNodes(true)}},runCallback:function(a,c,b){if(Ext.isFunction(a)){a.apply(c,b)}},isHiddenRoot:function(){return this.isRoot&&!this.getOwnerTree().rootVisible},collapse:function(b,g,h,e){if(this.expanded&&!this.isHiddenRoot()){if(thi
 s.fireEvent("beforecollapse",this,b,g)===false){return}this.expanded=false;if((this.getOwnerTree().animate&&g!==false)||g){this.ui.animCollapse(function(){this.fireEvent("collapse",this);this.runCallback(h,e||this,[this]);if(b===true){this.collapseChildNodes(true)}}.createDelegate(this));return}else{this.ui.collapse();this.fireEvent("collapse",this);this.runCallback(h,e||this,[this])}}else{if(!this.expanded){this.runCallback(h,e||this,[this])}}if(b===true){var d=this.childNodes;for(var c=0,a=d.length;c<a;c++){d[c].collapse(true,false)}}},delayedExpand:function(a){if(!this.expandProcId){this.expandProcId=this.expand.defer(a,this)}},cancelExpand:function(){if(this.expandProcId){clearTimeout(this.expandProcId)}this.expandProcId=false},toggle:function(){if(this.expanded){this.collapse()}else{this.expand()}},ensureVisible:function(c,b){var a=this.getOwnerTree();a.expandPath(this.parentNode?this.parentNode.getPath():this.getPath(),false,function(){var d=a.getNodeById(this.id);a.ge
 tTreeEl().scrollChildIntoView(d.ui.anchor);this.runCallback(c,b||this,[this])}.createDelegate(this))},expandChildNodes:function(b,e){var d=this.childNodes,c,a=d.length;for(c=0;c<a;c++){d[c].expand(b,e)}},collapseChildNodes:function(b){var d=this.childNodes;for(var c=0,a=d.length;c<a;c++){d[c].collapse(b)}},disable:function(){this.disabled=true;this.unselect();if(this.rendered&&this.ui.onDisableChange){this.ui.onDisableChange(this,true)}this.fireEvent("disabledchange",this,true)},enable:function(){this.disabled=false;if(this.rendered&&this.ui.onDisableChange){this.ui.onDisableChange(this,false)}this.fireEvent("disabledchange",this,false)},renderChildren:function(b){if(b!==false){this.fireEvent("beforechildrenrendered",this)}var d=this.childNodes;for(var c=0,a=d.length;c<a;c++){d[c].render(true)}this.childrenRendered=true},sort:function(e,d){Ext.tree.TreeNode.superclass.sort.apply(this,arguments);if(this.childrenRendered){var c=this.childNodes;for(var b=0,a=c.length;b<a;b++){c
 [b].render(true)}}},render:function(a){this.ui.render(a);if(!this.rendered){this.getOwnerTree().registerNode(this);this.rendered=true;if(this.expanded){this.expanded=false;this.expand(false,false)}}},renderIndent:function(b,e){if(e){this.ui.childIndent=null}this.ui.renderIndent();if(b===true&&this.childrenRendered){var d=this.childNodes;for(var c=0,a=d.length;c<a;c++){d[c].renderIndent(true,e)}}},beginUpdate:function(){this.childrenRendered=false},endUpdate:function(){if(this.expanded&&this.rendered){this.renderChildren()}},destroy:function(a){if(a===true){this.unselect(true)}Ext.tree.TreeNode.superclass.destroy.call(this,a);Ext.destroy(this.ui,this.loader);this.ui=this.loader=null},onIdChange:function(a){this.ui.onIdChange(a)}});Ext.tree.TreePanel.nodeTypes.node=Ext.tree.TreeNode;Ext.tree.AsyncTreeNode=function(a){this.loaded=a&&a.loaded===true;this.loading=false;Ext.tree.AsyncTreeNode.superclass.constructor.apply(this,arguments);this.addEvents("beforeload","load")};Ext.ext
 end(Ext.tree.AsyncTreeNode,Ext.tree.TreeNode,{expand:function(b,e,h,c){if(this.loading){var g;var d=function(){if(!this.loading){clearInterval(g);this.expand(b,e,h,c)}}.createDelegate(this);g=setInterval(d,200);return}if(!this.loaded){if(this.fireEvent("beforeload",this)===false){return}this.loading=true;this.ui.beforeLoad(this);var a=this.loader||this.attributes.loader||this.getOwnerTree().getLoader();if(a){a.load(this,this.loadComplete.createDelegate(this,[b,e,h,c]),this);return}}Ext.tree.AsyncTreeNode.superclass.expand.call(this,b,e,h,c)},isLoading:function(){return this.loading},loadComplete:function(a,c,d,b){this.loading=false;this.loaded=true;this.ui.afterLoad(this);this.fireEvent("load",this);this.expand(a,c,d,b)},isLoaded:function(){return this.loaded},hasChildNodes:function(){if(!this.isLeaf()&&!this.loaded){return true}else{return Ext.tree.AsyncTreeNode.superclass.hasChildNodes.call(this)}},reload:function(b,a){this.collapse(false,false);while(this.firstChild){this
 .removeChild(this.firstChild).destroy()}this.childrenRendered=false;this.loaded=false;if(this.isHiddenRoot()){this.expanded=false}this.expand(false,false,b,a)}});Ext.tree.TreePanel.nodeTypes.async=Ext.tree.AsyncTreeNode;Ext.tree.TreeNodeUI=Ext.extend(Object,{constructor:function(a){Ext.apply(this,{node:a,rendered:false,animating:false,wasLeaf:true,ecc:"x-tree-ec-icon x-tree-elbow",emptyIcon:Ext.BLANK_IMAGE_URL})},removeChild:function(a){if(this.rendered){this.ctNode.removeChild(a.ui.getEl())}},beforeLoad:function(){this.addClass("x-tree-node-loading")},afterLoad:function(){this.removeClass("x-tree-node-loading")},onTextChange:function(b,c,a){if(this.rendered){this.textNode.innerHTML=c}},onIconClsChange:function(c,a,b){if(this.rendered){Ext.fly(this.iconNode).replaceClass(b,a)}},onIconChange:function(b,a){if(this.rendered){var c=Ext.isEmpty(a);this.iconNode.src=c?this.emptyIcon:a;Ext.fly(this.iconNode)[c?"removeClass":"addClass"]("x-tree-node-inline-icon")}},onTipChange:funct
 ion(b,c,d){if(this.rendered){var a=Ext.isDefined(d);if(this.textNode.setAttributeNS){this.textNode.setAttributeNS("ext","qtip",c);if(a){this.textNode.setAttributeNS("ext","qtitle",d)}}else{this.textNode.setAttribute("ext:qtip",c);if(a){this.textNode.setAttribute("ext:qtitle",d)}}}},onHrefChange:function(b,a,c){if(this.rendered){this.anchor.href=this.getHref(a);if(Ext.isDefined(c)){this.anchor.target=c}}},onClsChange:function(c,a,b){if(this.rendered){Ext.fly(this.elNode).replaceClass(b,a)}},onDisableChange:function(a,b){this.disabled=b;if(this.checkbox){this.checkbox.disabled=b}this[b?"addClass":"removeClass"]("x-tree-node-disabled")},onSelectedChange:function(a){if(a){this.focus();this.addClass("x-tree-selected")}else{this.removeClass("x-tree-selected")}},onMove:function(a,h,e,g,d,b){this.childIndent=null;if(this.rendered){var i=g.ui.getContainer();if(!i){this.holder=document.createElement("div");this.holder.appendChild(this.wrap);return}var c=b?b.ui.getEl():null;if(c){i.ins
 ertBefore(this.wrap,c)}else{i.appendChild(this.wrap)}this.node.renderIndent(true,e!=g)}},addClass:function(a){if(this.elNode){Ext.fly(this.elNode).addClass(a)}},removeClass:function(a){if(this.elNode){Ext.fly(this.elNode).removeClass(a)}},remove:function(){if(this.rendered){this.holder=document.createElement("div");this.holder.appendChild(this.wrap)}},fireEvent:function(){return this.node.fireEvent.apply(this.node,arguments)},initEvents:function(){this.node.on("move",this.onMove,this);if(this.node.disabled){this.onDisableChange(this.node,true)}if(this.node.hidden){this.hide()}var b=this.node.getOwnerTree();var a=b.enableDD||b.enableDrag||b.enableDrop;if(a&&(!this.node.isRoot||b.rootVisible)){Ext.dd.Registry.register(this.elNode,{node:this.node,handles:this.getDDHandles(),isHandle:false})}},getDDHandles:function(){return[this.iconNode,this.textNode,this.elNode]},hide:function(){this.node.hidden=true;if(this.wrap){this.wrap.style.display="none"}},show:function(){this.node.hidd
 en=false;if(this.wrap){this.wrap.style.display=""}},onContextMenu:function(a){if(this.node.hasListener("contextmenu")||this.node.getOwnerTree().hasListener("contextmenu")){a.preventDefault();this.focus();this.fireEvent("contextmenu",this.node,a)}},onClick:function(c){if(this.dropping){c.stopEvent();return}if(this.fireEvent("beforeclick",this.node,c)!==false){var b=c.getTarget("a");if(!this.disabled&&this.node.attributes.href&&b){this.fireEvent("click",this.node,c);return}else{if(b&&c.ctrlKey){c.stopEvent()}}c.preventDefault();if(this.disabled){return}if(this.node.attributes.singleClickExpand&&!this.animating&&this.node.isExpandable()){this.node.toggle()}this.fireEvent("click",this.node,c)}else{c.stopEvent()}},onDblClick:function(a){a.preventDefault();if(this.disabled){return}if(this.fireEvent("beforedblclick",this.node,a)!==false){if(this.checkbox){this.toggleCheck()}if(!this.animating&&this.node.isExpandable()){this.node.toggle()}this.fireEvent("dblclick",this.node,a)}},onO
 ver:function(a){this.addClass("x-tree-node-over")},onOut:function(a){this.removeClass("x-tree-node-over")},onCheckChange:function(){var a=this.checkbox.checked;this.checkbox.defaultChecked=a;this.node.attributes.checked=a;this.fireEvent("checkchange",this.node,a)},ecClick:function(a){if(!this.animating&&this.node.isExpandable()){this.node.toggle()}},startDrop:function(){this.dropping=true},endDrop:function(){setTimeout(function(){this.dropping=false}.createDelegate(this),50)},expand:function(){this.updateExpandIcon();this.ctNode.style.display=""},focus:function(){if(!this.node.preventHScroll){try{this.anchor.focus()}catch(c){}}else{try{var b=this.node.getOwnerTree().getTreeEl().dom;var a=b.scrollLeft;this.anchor.focus();b.scrollLeft=a}catch(c){}}},toggleCheck:function(b){var a=this.checkbox;if(a){a.checked=(b===undefined?!a.checked:b);this.onCheckChange()}},blur:function(){try{this.anchor.blur()}catch(a){}},animExpand:function(b){var a=Ext.get(this.ctNode);a.stopFx();if(!thi
 s.node.isExpandable()){this.updateExpandIcon();this.ctNode.style.display="";Ext.callback(b);return}this.animating=true;this.updateExpandIcon();a.slideIn("t",{callback:function(){this.animating=false;Ext.callback(b)},scope:this,duration:this.node.ownerTree.duration||0.25})},highlight:function(){var a=this.node.getOwnerTree();Ext.fly(this.wrap).highlight(a.hlColor||"C3DAF9",{endColor:a.hlBaseColor})},collapse:function(){this.updateExpandIcon();this.ctNode.style.display="none"},animCollapse:function(b){var a=Ext.get(this.ctNode);a.enableDisplayMode("block");a.stopFx();this.animating=true;this.updateExpandIcon();a.slideOut("t",{callback:function(){this.animating=false;Ext.callback(b)},scope:this,duration:this.node.ownerTree.duration||0.25})},getContainer:function(){return this.ctNode},getEl:function(){return this.wrap},appendDDGhost:function(a){a.appendChild(this.elNode.cloneNode(true))},getDDRepairXY:function(){return Ext.lib.Dom.getXY(this.iconNode)},onRender:function(){this.r
 ender()},render:function(c){var e=this.node,b=e.attributes;var d=e.parentNode?e.parentNode.ui.getContainer():e.ownerTree.innerCt.dom;if(!this.rendered){this.rendered=true;this.renderElements(e,b,d,c);if(b.qtip){this.onTipChange(e,b.qtip,b.qtipTitle)}else{if(b.qtipCfg){b.qtipCfg.target=Ext.id(this.textNode);Ext.QuickTips.register(b.qtipCfg)}}this.initEvents();if(!this.node.expanded){this.updateExpandIcon(true)}}else{if(c===true){d.appendChild(this.wrap)}}},renderElements:function(e,k,j,l){this.indentMarkup=e.parentNode?e.parentNode.ui.getChildIndent():"";var g=Ext.isBoolean(k.checked),b,c=this.getHref(k.href),d=['<li class="x-tree-node"><div ext:tree-node-id="',e.id,'" class="x-tree-node-el x-tree-node-leaf x-unselectable ',k.cls,'" unselectable="on">','<span class="x-tree-node-indent">',this.indentMarkup,"</span>",'<img alt="" src="',this.emptyIcon,'" class="x-tree-ec-icon x-tree-elbow" />','<img alt="" src="',k.icon||this.emptyIcon,'" class="x-tree-node-icon',(k.icon?" x-tr
 ee-node-inline-icon":""),(k.iconCls?" "+k.iconCls:""),'" unselectable="on" />',g?('<input class="x-tree-node-cb" type="checkbox" '+(k.checked?'checked="checked" />':"/>")):"",'<a hidefocus="on" class="x-tree-node-anchor" href="',c,'" tabIndex="1" ',k.hrefTarget?' target="'+k.hrefTarget+'"':"",'><span unselectable="on">',e.text,"</span></a></div>",'<ul class="x-tree-node-ct" style="display:none;"></ul>',"</li>"].join("");if(l!==true&&e.nextSibling&&(b=e.nextSibling.ui.getEl())){this.wrap=Ext.DomHelper.insertHtml("beforeBegin",b,d)}else{this.wrap=Ext.DomHelper.insertHtml("beforeEnd",j,d)}this.elNode=this.wrap.childNodes[0];this.ctNode=this.wrap.childNodes[1];var i=this.elNode.childNodes;this.indentNode=i[0];this.ecNode=i[1];this.iconNode=i[2];var h=3;if(g){this.checkbox=i[3];this.checkbox.defaultChecked=this.checkbox.checked;h++}this.anchor=i[h];this.textNode=i[h].firstChild},getHref:function(a){return Ext.isEmpty(a)?(Ext.isGecko?"":"#"):a},getAnchor:function(){return this.anc
 hor},getTextEl:function(){return this.textNode},getIconEl:function(){return this.iconNode},isChecked:function(){return this.checkbox?this.checkbox.checked:false},updateExpandIcon:function(){if(this.rendered){var g=this.node,d,c,a=g.isLast()?"x-tree-elbow-end":"x-tree-elbow",e=g.hasChildNodes();if(e||g.attributes.expandable){if(g.expanded){a+="-minus";d="x-tree-node-collapsed";c="x-tree-node-expanded"}else{a+="-plus";d="x-tree-node-expanded";c="x-tree-node-collapsed"}if(this.wasLeaf){this.removeClass("x-tree-node-leaf");this.wasLeaf=false}if(this.c1!=d||this.c2!=c){Ext.fly(this.elNode).replaceClass(d,c);this.c1=d;this.c2=c}}else{if(!this.wasLeaf){Ext.fly(this.elNode).replaceClass("x-tree-node-expanded","x-tree-node-collapsed");delete this.c1;delete this.c2;this.wasLeaf=true}}var b="x-tree-ec-icon "+a;if(this.ecc!=b){this.ecNode.className=b;this.ecc=b}}},onIdChange:function(a){if(this.rendered){this.elNode.setAttribute("ext:tree-node-id",a)}},getChildIndent:function(){if(!this
 .childIndent){var a=[],b=this.node;while(b){if(!b.isRoot||(b.isRoot&&b.ownerTree.rootVisible)){if(!b.isLast()){a.unshift('<img alt="" src="'+this.emptyIcon+'" class="x-tree-elbow-line" />')}else{a.unshift('<img alt="" src="'+this.emptyIcon+'" class="x-tree-icon" />')}}b=b.parentNode}this.childIndent=a.join("")}return this.childIndent},renderIndent:function(){if(this.rendered){var a="",b=this.node.parentNode;if(b){a=b.ui.getChildIndent()}if(this.indentMarkup!=a){this.indentNode.innerHTML=a;this.indentMarkup=a}this.updateExpandIcon()}},destroy:function(){if(this.elNode){Ext.dd.Registry.unregister(this.elNode.id)}Ext.each(["textnode","anchor","checkbox","indentNode","ecNode","iconNode","elNode","ctNode","wrap","holder"],function(a){if(this[a]){Ext.fly(this[a]).remove();delete this[a]}},this);delete this.node}});Ext.tree.RootTreeNodeUI=Ext.extend(Ext.tree.TreeNodeUI,{render:function(){if(!this.rendered){var a=this.node.ownerTree.innerCt.dom;this.node.expanded=true;a.innerHTML='<
 div class="x-tree-root-node"></div>';this.wrap=this.ctNode=a.firstChild}},collapse:Ext.emptyFn,expand:Ext.emptyFn});Ext.tree.TreeLoader=function(a){this.baseParams={};Ext.apply(this,a);this.addEvents("beforeload","load","loadexception");Ext.tree.TreeLoader.superclass.constructor.call(this);if(Ext.isString(this.paramOrder)){this.paramOrder=this.paramOrder.split(/[\s,|]/)}};Ext.extend(Ext.tree.TreeLoader,Ext.util.Observable,{uiProviders:{},clearOnLoad:true,paramOrder:undefined,paramsAsHash:false,nodeParameter:"node",directFn:undefined,load:function(b,c,a){if(this.clearOnLoad){while(b.firstChild){b.removeChild(b.firstChild)}}if(this.doPreload(b)){this.runCallback(c,a||b,[b])}else{if(this.directFn||this.dataUrl||this.url){this.requestData(b,c,a||b)}}},doPreload:function(d){if(d.attributes.children){if(d.childNodes.length<1){var c=d.attributes.children;d.beginUpdate();for(var b=0,a=c.length;b<a;b++){var e=d.appendChild(this.createNode(c[b]));if(this.preloadChildren){this.doPreloa
 d(e)}}d.endUpdate()}return true}return false},getParams:function(g){var e=Ext.apply({},this.baseParams),h=this.nodeParameter,b=this.paramOrder;h&&(e[h]=g.id);if(this.directFn){var c=[g.id];if(b){if(h&&b.indexOf(h)>-1){c=[]}for(var d=0,a=b.length;d<a;d++){c.push(e[b[d]])}}else{if(this.paramsAsHash){c=[e]}}return c}else{return e}},requestData:function(c,d,b){if(this.fireEvent("beforeload",this,c,d)!==false){if(this.directFn){var a=this.getParams(c);a.push(this.processDirectResponse.createDelegate(this,[{callback:d,node:c,scope:b}],true));this.directFn.apply(window,a)}else{this.transId=Ext.Ajax.request({method:this.requestMethod,url:this.dataUrl||this.url,success:this.handleResponse,failure:this.handleFailure,scope:this,argument:{callback:d,node:c,scope:b},params:this.getParams(c)})}}else{this.runCallback(d,b||c,[])}},processDirectResponse:function(a,b,c){if(b.status){this.handleResponse({responseData:Ext.isArray(a)?a:null,responseText:a,argument:c})}else{this.handleFailure({ar
 gument:c})}},runCallback:function(a,c,b){if(Ext.isFunction(a)){a.apply(c,b)}},isLoading:function(){return !!this.transId},abort:function(){if(this.isLoading()){Ext.Ajax.abort(this.transId)}},createNode:function(attr){if(this.baseAttrs){Ext.applyIf(attr,this.baseAttrs)}if(this.applyLoader!==false&&!attr.loader){attr.loader=this}if(Ext.isString(attr.uiProvider)){attr.uiProvider=this.uiProviders[attr.uiProvider]||eval(attr.uiProvider)}if(attr.nodeType){return new Ext.tree.TreePanel.nodeTypes[attr.nodeType](attr)}else{return attr.leaf?new Ext.tree.TreeNode(attr):new Ext.tree.AsyncTreeNode(attr)}},processResponse:function(d,c,k,l){var m=d.responseText;try{var a=d.responseData||Ext.decode(m);c.beginUpdate();for(var g=0,h=a.length;g<h;g++){var b=this.createNode(a[g]);if(b){c.appendChild(b)}}c.endUpdate();this.runCallback(k,l||c,[c])}catch(j){this.handleFailure(d)}},handleResponse:function(c){this.transId=false;var b=c.argument;this.processResponse(c,b.node,b.callback,b.scope);this.
 fireEvent("load",this,b.node,c)},handleFailure:function(c){this.transId=false;var b=c.argument;this.fireEvent("loadexception",this,b.node,c);this.runCallback(b.callback,b.scope||b.node,[b.node])},destroy:function(){this.abort();this.purgeListeners()}});Ext.tree.TreeFilter=function(a,b){this.tree=a;this.filtered={};Ext.apply(this,b)};Ext.tree.TreeFilter.prototype={clearBlank:false,reverse:false,autoClear:false,remove:false,filter:function(d,a,b){a=a||"text";var c;if(typeof d=="string"){var e=d.length;if(e==0&&this.clearBlank){this.clear();return}d=d.toLowerCase();c=function(g){return g.attributes[a].substr(0,e).toLowerCase()==d}}else{if(d.exec){c=function(g){return d.test(g.attributes[a])}}else{throw"Illegal filter type, must be string or regex"}}this.filterBy(c,null,b)},filterBy:function(d,c,b){b=b||this.tree.root;if(this.autoClear){this.clear()}var a=this.filtered,i=this.reverse;var e=function(k){if(k==b){return true}if(a[k.id]){return false}var j=d.call(c||k,k);if(!j||i){a
 [k.id]=k;k.ui.hide();return false}return true};b.cascade(e);if(this.remove){for(var h in a){if(typeof h!="function"){var g=a[h];if(g&&g.parentNode){g.parentNode.removeChild(g)}}}}},clear:function(){var b=this.tree;var a=this.filtered;for(var d in a){if(typeof d!="function"){var c=a[d];if(c){c.ui.show()}}}this.filtered={}}};Ext.tree.TreeSorter=Ext.extend(Object,{constructor:function(a,c){Ext.apply(this,c);a.on({scope:this,beforechildrenrendered:this.doSort,append:this.updateSort,insert:this.updateSort,textchange:this.updateSortParent});var e=this.dir&&this.dir.toLowerCase()=="desc",i=this.property||"text",d=this.sortType,h=this.folderSort,b=this.caseSensitive===true,g=this.leafAttr||"leaf";if(Ext.isString(d)){d=Ext.data.SortTypes[d]}this.sortFn=function(o,m){var k=o.attributes,j=m.attributes;if(h){if(k[g]&&!j[g]){return 1}if(!k[g]&&j[g]){return -1}}var n=k[i],l=j[i],q=d?d(n):(b?n:n.toUpperCase()),p=d?d(l):(b?l:l.toUpperCase());if(q<p){return e?1:-1}else{if(q>p){return e?-1:1}
 }return 0}},doSort:function(a){a.sort(this.sortFn)},updateSort:function(a,b){if(b.childrenRendered){this.doSort.defer(1,this,[b])}},updateSortParent:function(a){var b=a.parentNode;if(b&&b.childrenRendered){this.doSort.defer(1,this,[b])}}});if(Ext.dd.DropZone){Ext.tree.TreeDropZone=function(a,b){this.allowParentInsert=b.allowParentInsert||false;this.allowContainerDrop=b.allowContainerDrop||false;this.appendOnly=b.appendOnly||false;Ext.tree.TreeDropZone.superclass.constructor.call(this,a.getTreeEl(),b);this.tree=a;this.dragOverData={};this.lastInsertClass="x-tree-no-status"};Ext.extend(Ext.tree.TreeDropZone,Ext.dd.DropZone,{ddGroup:"TreeDD",expandDelay:1000,expandNode:function(a){if(a.hasChildNodes()&&!a.isExpanded()){a.expand(false,null,this.triggerCacheRefresh.createDelegate(this))}},queueExpand:function(a){this.expandProcId=this.expandNode.defer(this.expandDelay,this,[a])},cancelExpand:function(){if(this.expandProcId){clearTimeout(this.expandProcId);this.expandProcId=false}
 },isValidDropPoint:function(a,k,i,d,c){if(!a||!c){return false}var g=a.node;var h=c.node;if(!(g&&g.isTarget&&k)){return false}if(k=="append"&&g.allowChildren===false){return false}if((k=="above"||k=="below")&&(g.parentNode&&g.parentNode.allowChildren===false)){return false}if(h&&(g==h||h.contains(g))){return false}var b=this.dragOverData;b.tree=this.tree;b.target=g;b.data=c;b.point=k;b.source=i;b.rawEvent=d;b.dropNode=h;b.cancel=false;var j=this.tree.fireEvent("nodedragover",b);return b.cancel===false&&j!==false},getDropPoint:function(h,g,l){var m=g.node;if(m.isRoot){return m.allowChildren!==false?"append":false}var c=g.ddel;var o=Ext.lib.Dom.getY(c),j=o+c.offsetHeight;var i=Ext.lib.Event.getPageY(h);var k=m.allowChildren===false||m.isLeaf();if(this.appendOnly||m.parentNode.allowChildren===false){return k?false:"append"}var d=false;if(!this.allowParentInsert){d=m.hasChildNodes()&&m.isExpanded()}var a=(j-o)/(k?2:3);if(i>=o&&i<(o+a)){return"above"}else{if(!d&&(k||i>=j-a&&i<=j)
 ){return"below"}else{return"append"}}},onNodeEnter:function(d,a,c,b){this.cancelExpand()},onContainerOver:function(a,c,b){if(this.allowContainerDrop&&this.isValidDropPoint({ddel:this.tree.getRootNode().ui.elNode,node:this.tree.getRootNode()},"append",a,c,b)){return this.dropAllowed}return this.dropNotAllowed},onNodeOver:function(b,i,h,g){var k=this.getDropPoint(h,b,i);var c=b.node;if(!this.expandProcId&&k=="append"&&c.hasChildNodes()&&!b.node.isExpanded()){this.queueExpand(c)}else{if(k!="append"){this.cancelExpand()}}var d=this.dropNotAllowed;if(this.isValidDropPoint(b,k,i,h,g)){if(k){var a=b.ddel;var j;if(k=="above"){d=b.node.isFirst()?"x-tree-drop-ok-above":"x-tree-drop-ok-between";j="x-tree-drag-insert-above"}else{if(k=="below"){d=b.node.isLast()?"x-tree-drop-ok-below":"x-tree-drop-ok-between";j="x-tree-drag-insert-below"}else{d="x-tree-drop-ok-append";j="x-tree-drag-append"}}if(this.lastInsertClass!=j){Ext.fly(a).replaceClass(this.lastInsertClass,j);this.lastInsertClass=
 j}}}return d},onNodeOut:function(d,a,c,b){this.cancelExpand();this.removeDropIndicators(d)},onNodeDrop:function(i,b,h,d){var a=this.getDropPoint(h,i,b);var g=i.node;g.ui.startDrop();if(!this.isValidDropPoint(i,a,b,h,d)){g.ui.endDrop();return false}var c=d.node||(b.getTreeNode?b.getTreeNode(d,g,a,h):null);return this.processDrop(g,d,a,b,h,c)},onContainerDrop:function(a,g,c){if(this.allowContainerDrop&&this.isValidDropPoint({ddel:this.tree.getRootNode().ui.elNode,node:this.tree.getRootNode()},"append",a,g,c)){var d=this.tree.getRootNode();d.ui.startDrop();var b=c.node||(a.getTreeNode?a.getTreeNode(c,d,"append",g):null);return this.processDrop(d,c,"append",a,g,b)}return false},processDrop:function(j,h,b,a,i,d){var g={tree:this.tree,target:j,data:h,point:b,source:a,rawEvent:i,dropNode:d,cancel:!d,dropStatus:false};var c=this.tree.fireEvent("beforenodedrop",g);if(c===false||g.cancel===true||!g.dropNode){j.ui.endDrop();return g.dropStatus}j=g.target;if(b=="append"&&!j.isExpanded()
 ){j.expand(false,null,function(){this.completeDrop(g)}.createDelegate(this))}else{this.completeDrop(g)}return true},completeDrop:function(h){var d=h.dropNode,e=h.point,c=h.target;if(!Ext.isArray(d)){d=[d]}var g;for(var b=0,a=d.length;b<a;b++){g=d[b];if(e=="above"){c.parentNode.insertBefore(g,c)}else{if(e=="below"){c.parentNode.insertBefore(g,c.nextSibling)}else{c.appendChild(g)}}}g.ui.focus();if(Ext.enableFx&&this.tree.hlDrop){g.ui.highlight()}c.ui.endDrop();this.tree.fireEvent("nodedrop",h)},afterNodeMoved:function(a,c,g,d,b){if(Ext.enableFx&&this.tree.hlDrop){b.ui.focus();b.ui.highlight()}this.tree.fireEvent("nodedrop",this.tree,d,c,a,g)},getTree:function(){return this.tree},removeDropIndicators:function(b){if(b&&b.ddel){var a=b.ddel;Ext.fly(a).removeClass(["x-tree-drag-insert-above","x-tree-drag-insert-below","x-tree-drag-append"]);this.lastInsertClass="_noclass"}},beforeDragDrop:function(b,a,c){this.cancelExpand();return true},afterRepair:function(a){if(a&&Ext.enableFx){
 a.node.ui.highlight()}this.hideProxy()}})}if(Ext.dd.DragZone){Ext.tree.TreeDragZone=function(a,b){Ext.tree.TreeDragZone.superclass.constructor.call(this,a.innerCt,b);this.tree=a};Ext.extend(Ext.tree.TreeDragZone,Ext.dd.DragZone,{ddGroup:"TreeDD",onBeforeDrag:function(a,b){var c=a.node;return c&&c.draggable&&!c.disabled},onInitDrag:function(b){var a=this.dragData;this.tree.getSelectionModel().select(a.node);this.tree.eventModel.disable();this.proxy.update("");a.node.ui.appendDDGhost(this.proxy.ghost.dom);this.tree.fireEvent("startdrag",this.tree,a.node,b)},getRepairXY:function(b,a){return a.node.ui.getDDRepairXY()},onEndDrag:function(a,b){this.tree.eventModel.enable.defer(100,this.tree.eventModel);this.tree.fireEvent("enddrag",this.tree,a.node,b)},onValidDrop:function(a,b,c){this.tree.fireEvent("dragdrop",this.tree,this.dragData.node,a,b);this.hideProxy()},beforeInvalidDrop:function(a,c){var b=this.tree.getSelectionModel();b.clearSelections();b.select(this.dragData.node)},aft
 erRepair:function(){if(Ext.enableFx&&this.tree.hlDrop){Ext.Element.fly(this.dragData.ddel).highlight(this.hlColor||"c3daf9")}this.dragging=false}})}Ext.tree.TreeEditor=function(a,c,b){c=c||{};var d=c.events?c:new Ext.form.TextField(c);Ext.tree.TreeEditor.superclass.constructor.call(this,d,b);this.tree=a;if(!a.rendered){a.on("render",this.initEditor,this)}else{this.initEditor(a)}};Ext.extend(Ext.tree.TreeEditor,Ext.Editor,{alignment:"l-l",autoSize:false,hideEl:false,cls:"x-small-editor x-tree-editor",shim:false,shadow:"frame",maxWidth:250,editDelay:350,initEditor:function(a){a.on({scope:this,beforeclick:this.beforeNodeClick,dblclick:this.onNodeDblClick});this.on({scope:this,complete:this.updateNode,beforestartedit:this.fitToTree,specialkey:this.onSpecialKey});this.on("startedit",this.bindScroll,this,{delay:10})},fitToTree:function(b,c){var e=this.tree.getTreeEl().dom,d=c.dom;if(e.scrollLeft>d.offsetLeft){e.scrollLeft=d.offsetLeft}var a=Math.min(this.maxWidth,(e.clientWidth>20
 ?e.clientWidth:e.offsetWidth)-Math.max(0,d.offsetLeft-e.scrollLeft)-5);this.setSize(a,"")},triggerEdit:function(a,c){this.completeEdit();if(a.attributes.editable!==false){this.editNode=a;if(this.tree.autoScroll){Ext.fly(a.ui.getEl()).scrollIntoView(this.tree.body)}var b=a.text||"";if(!Ext.isGecko&&Ext.isEmpty(a.text)){a.setText("&#160;")}this.autoEditTimer=this.startEdit.defer(this.editDelay,this,[a.ui.textNode,b]);return false}},bindScroll:function(){this.tree.getTreeEl().on("scroll",this.cancelEdit,this)},beforeNodeClick:function(a,b){clearTimeout(this.autoEditTimer);if(this.tree.getSelectionModel().isSelected(a)){b.stopEvent();return this.triggerEdit(a)}},onNodeDblClick:function(a,b){clearTimeout(this.autoEditTimer)},updateNode:function(a,b){this.tree.getTreeEl().un("scroll",this.cancelEdit,this);this.editNode.setText(b)},onHide:function(){Ext.tree.TreeEditor.superclass.onHide.call(this);if(this.editNode){this.editNode.ui.focus.defer(50,this.editNode.ui)}},onSpecialKey:fu
 nction(c,b){var a=b.getKey();if(a==b.ESC){b.stopEvent();this.cancelEdit()}else{if(a==b.ENTER&&!b.hasModifier()){b.stopEvent();this.completeEdit()}}},onDestroy:function(){clearTimeout(this.autoEditTimer);Ext.tree.TreeEditor.superclass.onDestroy.call(this);var a=this.tree;a.un("beforeclick",this.beforeNodeClick,this);a.un("dblclick",this.onNodeDblClick,this)}});
+/* SWFObject v2.2 <http://code.google.com/p/swfobject/>
+    is released under the MIT License <http://www.opensource.org/licenses/mit-license.php>
+var swfobject=function(){var E="undefined",s="object",T="Shockwave Flash",X="ShockwaveFlash.ShockwaveFlash",r="application/x-shockwave-flash",S="SWFObjectExprInst",y="onreadystatechange",P=window,k=document,u=navigator,U=false,V=[i],p=[],O=[],J=[],m,R,F,C,K=false,a=false,o,H,n=true,N=function(){var ab=typeof k.getElementById!=E&&typeof k.getElementsByTagName!=E&&typeof k.createElement!=E,ai=u.userAgent.toLowerCase(),Z=u.platform.toLowerCase(),af=Z?(/win/).test(Z):/win/.test(ai),ad=Z?(/mac/).test(Z):/mac/.test(ai),ag=/webkit/.test(ai)?parseFloat(ai.replace(/^.*webkit\/(\d+(\.\d+)?).*$/,"$1")):false,Y=!+"\v1",ah=[0,0,0],ac=null;if(typeof u.plugins!=E&&typeof u.plugins[T]==s){ac=u.plugins[T].description;if(ac&&!(typeof u.mimeTypes!=E&&u.mimeTypes[r]&&!u.mimeTypes[r].enabledPlugin)){U=true;Y=false;ac=ac.replace(/^.*\s+(\S+\s+\S+$)/,"$1");ah[0]=parseInt(ac.replace(/^(.*)\..*$/,"$1"),10);ah[1]=parseInt(ac.replace(/^.*\.(.*)\s.*$/,"$1"),10);ah[2]=/[a-zA-Z]/.test(ac)?parseInt(ac.rep
 lace(/^.*[a-zA-Z]+(.*)$/,"$1"),10):0}}else{if(typeof P.ActiveXObject!=E){try{var ae=new ActiveXObject(X);if(ae){ac=ae.GetVariable("$version");if(ac){Y=true;ac=ac.split(" ")[1].split(",");ah=[parseInt(ac[0],10),parseInt(ac[1],10),parseInt(ac[2],10)]}}}catch(aa){}}}return{w3:ab,pv:ah,wk:ag,ie:Y,win:af,mac:ad}}(),l=function(){if(!N.w3){return}if((typeof k.readyState!=E&&k.readyState=="complete")||(typeof k.readyState==E&&(k.getElementsByTagName("body")[0]||k.body))){g()}if(!K){if(typeof k.addEventListener!=E){k.addEventListener("DOMContentLoaded",g,false)}if(N.ie&&N.win){k.attachEvent(y,function(){if(k.readyState=="complete"){k.detachEvent(y,arguments.callee);g()}});if(P==top){(function(){if(K){return}try{k.documentElement.doScroll("left")}catch(Y){setTimeout(arguments.callee,0);return}g()})()}}if(N.wk){(function(){if(K){return}if(!(/loaded|complete/).test(k.readyState)){setTimeout(arguments.callee,0);return}g()})()}t(g)}}();function g(){if(K){return}try{var aa=k.getElementsByT
 agName("body")[0].appendChild(D("span"));aa.parentNode.removeChild(aa)}catch(ab){return}K=true;var Y=V.length;for(var Z=0;Z<Y;Z++){V[Z]()}}function L(Y){if(K){Y()}else{V[V.length]=Y}}function t(Z){if(typeof P.addEventListener!=E){P.addEventListener("load",Z,false)}else{if(typeof k.addEventListener!=E){k.addEventListener("load",Z,false)}else{if(typeof P.attachEvent!=E){j(P,"onload",Z)}else{if(typeof P.onload=="function"){var Y=P.onload;P.onload=function(){Y();Z()}}else{P.onload=Z}}}}}function i(){if(U){W()}else{I()}}function W(){var Y=k.getElementsByTagName("body")[0];var ab=D(s);ab.setAttribute("type",r);var aa=Y.appendChild(ab);if(aa){var Z=0;(function(){if(typeof aa.GetVariable!=E){var ac=aa.GetVariable("$version");if(ac){ac=ac.split(" ")[1].split(",");N.pv=[parseInt(ac[0],10),parseInt(ac[1],10),parseInt(ac[2],10)]}}else{if(Z<10){Z++;setTimeout(arguments.callee,10);return}}Y.removeChild(ab);aa=null;I()})()}else{I()}}function I(){var ah=p.length;if(ah>0){for(var ag=0;ag<ah;
 ag++){var Z=p[ag].id;var ac=p[ag].callbackFn;var ab={success:false,id:Z};if(N.pv[0]>0){var af=c(Z);if(af){if(G(p[ag].swfVersion)&&!(N.wk&&N.wk<312)){x(Z,true);if(ac){ab.success=true;ab.ref=A(Z);ac(ab)}}else{if(p[ag].expressInstall&&B()){var aj={};aj.data=p[ag].expressInstall;aj.width=af.getAttribute("width")||"0";aj.height=af.getAttribute("height")||"0";if(af.getAttribute("class")){aj.styleclass=af.getAttribute("class")}if(af.getAttribute("align")){aj.align=af.getAttribute("align")}var ai={};var Y=af.getElementsByTagName("param");var ad=Y.length;for(var ae=0;ae<ad;ae++){if(Y[ae].getAttribute("name").toLowerCase()!="movie"){ai[Y[ae].getAttribute("name")]=Y[ae].getAttribute("value")}}Q(aj,ai,Z,ac)}else{q(af);if(ac){ac(ab)}}}}}else{x(Z,true);if(ac){var aa=A(Z);if(aa&&typeof aa.SetVariable!=E){ab.success=true;ab.ref=aa}ac(ab)}}}}}function A(ab){var Y=null;var Z=c(ab);if(Z&&Z.nodeName=="OBJECT"){if(typeof Z.SetVariable!=E){Y=Z}else{var aa=Z.getElementsByTagName(s)[0];if(aa){Y=aa}
 }}return Y}function B(){return !a&&G("6.0.65")&&(N.win||N.mac)&&!(N.wk&&N.wk<312)}function Q(ab,ac,Y,aa){a=true;F=aa||null;C={success:false,id:Y};var af=c(Y);if(af){if(af.nodeName=="OBJECT"){m=h(af);R=null}else{m=af;R=Y}ab.id=S;if(typeof ab.width==E||(!(/%$/).test(ab.width)&&parseInt(ab.width,10)<310)){ab.width="310"}if(typeof ab.height==E||(!(/%$/).test(ab.height)&&parseInt(ab.height,10)<137)){ab.height="137"}k.title=k.title.slice(0,47)+" - Flash Player Installation";var ae=N.ie&&N.win?"ActiveX":"PlugIn",ad="MMredirectURL="+P.location.toString().replace(/&/g,"%26")+"&MMplayerType="+ae+"&MMdoctitle="+k.title;if(typeof ac.flashvars!=E){ac.flashvars+="&"+ad}else{ac.flashvars=ad}if(N.ie&&N.win&&af.readyState!=4){var Z=D("div");Y+="SWFObjectNew";Z.setAttribute("id",Y);af.parentNode.insertBefore(Z,af);af.style.display="none";(function(){if(af.readyState==4){af.parentNode.removeChild(af)}else{setTimeout(arguments.callee,10)}})()}v(ab,ac,Y)}}function q(Z){if(N.ie&&N.win&&Z.readySta
 te!=4){var Y=D("div");Z.parentNode.insertBefore(Y,Z);Y.parentNode.replaceChild(h(Z),Y);Z.style.display="none";(function(){if(Z.readyState==4){Z.parentNode.removeChild(Z)}else{setTimeout(arguments.callee,10)}})()}else{Z.parentNode.replaceChild(h(Z),Z)}}function h(ad){var ab=D("div");if(N.win&&N.ie){ab.innerHTML=ad.innerHTML}else{var Z=ad.getElementsByTagName(s)[0];if(Z){var ae=Z.childNodes;if(ae){var Y=ae.length;for(var aa=0;aa<Y;aa++){if(!(ae[aa].nodeType==1&&ae[aa].nodeName=="PARAM")&&!(ae[aa].nodeType==8)){ab.appendChild(ae[aa].cloneNode(true))}}}}}return ab}function v(aj,ah,Z){var Y,ab=c(Z);if(N.wk&&N.wk<312){return Y}if(ab){if(typeof aj.id==E){aj.id=Z}if(N.ie&&N.win){var ai="";for(var af in aj){if(aj[af]!=Object.prototype[af]){if(af.toLowerCase()=="data"){ah.movie=aj[af]}else{if(af.toLowerCase()=="styleclass"){ai+=' class="'+aj[af]+'"'}else{if(af.toLowerCase()!="classid"){ai+=" "+af+'="'+aj[af]+'"'}}}}}var ag="";for(var ae in ah){if(ah[ae]!=Object.prototype[ae]){ag+='<pa
 ram name="'+ae+'" value="'+ah[ae]+'" />'}}ab.outerHTML='<object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000"'+ai+">"+ag+"</object>";O[O.length]=aj.id;Y=c(aj.id)}else{var aa=D(s);aa.setAttribute("type",r);for(var ad in aj){if(aj[ad]!=Object.prototype[ad]){if(ad.toLowerCase()=="styleclass"){aa.setAttribute("class",aj[ad])}else{if(ad.toLowerCase()!="classid"){aa.setAttribute(ad,aj[ad])}}}}for(var ac in ah){if(ah[ac]!=Object.prototype[ac]&&ac.toLowerCase()!="movie"){e(aa,ac,ah[ac])}}ab.parentNode.replaceChild(aa,ab);Y=aa}}return Y}function e(aa,Y,Z){var ab=D("param");ab.setAttribute("name",Y);ab.setAttribute("value",Z);aa.appendChild(ab)}function z(Z){var Y=c(Z);if(Y&&Y.nodeName=="OBJECT"){if(N.ie&&N.win){Y.style.display="none";(function(){if(Y.readyState==4){b(Z)}else{setTimeout(arguments.callee,10)}})()}else{Y.parentNode.removeChild(Y)}}}function b(aa){var Z=c(aa);if(Z){for(var Y in Z){if(typeof Z[Y]=="function"){Z[Y]=null}}Z.parentNode.removeChild(Z)}}function c(aa){v
 ar Y=null;try{Y=k.getElementById(aa)}catch(Z){}return Y}function D(Y){return k.createElement(Y)}function j(aa,Y,Z){aa.attachEvent(Y,Z);J[J.length]=[aa,Y,Z]}function G(aa){var Z=N.pv,Y=aa.split(".");Y[0]=parseInt(Y[0],10);Y[1]=parseInt(Y[1],10)||0;Y[2]=parseInt(Y[2],10)||0;return(Z[0]>Y[0]||(Z[0]==Y[0]&&Z[1]>Y[1])||(Z[0]==Y[0]&&Z[1]==Y[1]&&Z[2]>=Y[2]))?true:false}function w(ad,Z,ae,ac){if(N.ie&&N.mac){return}var ab=k.getElementsByTagName("head")[0];if(!ab){return}var Y=(ae&&typeof ae=="string")?ae:"screen";if(ac){o=null;H=null}if(!o||H!=Y){var aa=D("style");aa.setAttribute("type","text/css");aa.setAttribute("media",Y);o=ab.appendChild(aa);if(N.ie&&N.win&&typeof k.styleSheets!=E&&k.styleSheets.length>0){o=k.styleSheets[k.styleSheets.length-1]}H=Y}if(N.ie&&N.win){if(o&&typeof o.addRule==s){o.addRule(ad,Z)}}else{if(o&&typeof k.createTextNode!=E){o.appendChild(k.createTextNode(ad+" {"+Z+"}"))}}}function x(aa,Y){if(!n){return}var Z=Y?"visible":"hidden";if(K&&c(aa)){c(aa).style.vis
 ibility=Z}else{w("#"+aa,"visibility:"+Z)}}function M(Z){var aa=/[\\\"<>\.;]/;var Y=aa.exec(Z)!=null;return Y&&typeof encodeURIComponent!=E?encodeURIComponent(Z):Z}var d=function(){if(N.ie&&N.win){window.attachEvent("onunload",function(){var ad=J.length;for(var ac=0;ac<ad;ac++){J[ac][0].detachEvent(J[ac][1],J[ac][2])}var aa=O.length;for(var ab=0;ab<aa;ab++){z(O[ab])}for(var Z in N){N[Z]=null}N=null;for(var Y in swfobject){swfobject[Y]=null}swfobject=null;window.detachEvent("onunload",arguments.callee)})}}();return{registerObject:function(ac,Y,ab,aa){if(N.w3&&ac&&Y){var Z={};Z.id=ac;Z.swfVersion=Y;Z.expressInstall=ab;Z.callbackFn=aa;p[p.length]=Z;x(ac,false)}else{if(aa){aa({success:false,id:ac})}}},getObjectById:function(Y){if(N.w3){return A(Y)}},embedSWF:function(ac,ai,af,ah,Z,ab,aa,ae,ag,ad){var Y={success:false,id:ai};if(N.w3&&!(N.wk&&N.wk<312)&&ac&&ai&&af&&ah&&Z){x(ai,false);L(function(){af+="";ah+="";var ak={};if(ag&&typeof ag===s){for(var am in ag){ak[am]=ag[am]}}ak.data
 =ac;ak.width=af;ak.height=ah;var an={};if(ae&&typeof ae===s){for(var al in ae){an[al]=ae[al]}}if(aa&&typeof aa===s){for(var aj in aa){if(typeof an.flashvars!=E){an.flashvars+="&"+aj+"="+aa[aj]}else{an.flashvars=aj+"="+aa[aj]}}}if(G(Z)){var ao=v(ak,an,ai);if(ak.id==ai){x(ai,true)}Y.success=true;Y.ref=ao}else{if(ab&&B()){ak.data=ab;Q(ak,an,ai,ad);return}else{x(ai,true)}}if(ad){ad(Y)}})}else{if(ad){ad(Y)}}},switchOffAutoHideShow:function(){n=false},ua:N,getFlashPlayerVersion:function(){return{major:N.pv[0],minor:N.pv[1],release:N.pv[2]}},hasFlashPlayerVersion:G,createSWF:function(aa,Z,Y){if(N.w3){return v(aa,Z,Y)}else{return undefined}},showExpressInstall:function(aa,ab,Y,Z){if(N.w3&&B()){Q(aa,ab,Y,Z)}},removeSWF:function(Y){if(N.w3){z(Y)}},createCSS:function(ab,aa,Z,Y){if(N.w3){w(ab,aa,Z,Y)}},addDomLoadEvent:L,addLoadEvent:t,getQueryParamValue:function(ab){var aa=k.location.search||k.location.hash;if(aa){if(/\?/.test(aa)){aa=aa.split("?")[1]}if(ab==null){return M(aa)}var Z=aa.
 split("&");for(var Y=0;Y<Z.length;Y++){if(Z[Y].substring(0,Z[Y].indexOf("="))==ab){return M(Z[Y].substring((Z[Y].indexOf("=")+1)))}}}return""},expressInstallCallback:function(){if(a){var Y=c(S);if(Y&&m){Y.parentNode.replaceChild(m,Y);if(R){x(R,true);if(N.ie&&N.win){m.style.display="block"}}if(F){F(C)}}a=false}}}}();Ext.FlashComponent=Ext.extend(Ext.BoxComponent,{flashVersion:"9.0.115",backgroundColor:"#ffffff",wmode:"opaque",flashVars:undefined,flashParams:undefined,url:undefined,swfId:undefined,swfWidth:"100%",swfHeight:"100%",expressInstall:false,initComponent:function(){Ext.FlashComponent.superclass.initComponent.call(this);this.addEvents("initialize")},onRender:function(){Ext.FlashComponent.superclass.onRender.apply(this,arguments);var b=Ext.apply({allowScriptAccess:"always",bgcolor:this.backgroundColor,wmode:this.wmode},this.flashParams),a=Ext.apply({allowedDomain:document.location.hostname,YUISwfId:this.getId(),YUIBridgeCallback:"Ext.FlashEventProxy.onEvent"},this.flas
 hVars);new swfobject.embedSWF(this.url,this.id,this.swfWidth,this.swfHeight,this.flashVersion,this.expressInstall?Ext.FlashComponent.EXPRESS_INSTALL_URL:undefined,a,b);this.swf=Ext.getDom(this.id);this.el=Ext.get(this.swf)},getSwfId:function(){return this.swfId||(this.swfId="extswf"+(++Ext.Component.AUTO_ID))},getId:function(){return this.id||(this.id="extflashcmp"+(++Ext.Component.AUTO_ID))},onFlashEvent:function(a){switch(a.type){case"swfReady":this.initSwf();return;case"log":return}a.component=this;this.fireEvent(a.type.toLowerCase().replace(/event$/,""),a)},initSwf:function(){this.onSwfReady(!!this.isInitialized);this.isInitialized=true;this.fireEvent("initialize",this)},beforeDestroy:function(){if(this.rendered){swfobject.removeSWF(this.swf.id)}Ext.FlashComponent.superclass.beforeDestroy.call(this)},onSwfReady:Ext.emptyFn});Ext.FlashComponent.EXPRESS_INSTALL_URL="http://swfobject.googlecode.com/svn/trunk/swfobject/expressInstall.swf";Ext.reg("flash",Ext.FlashComponent);
 Ext.FlashEventProxy={onEvent:function(c,b){var a=Ext.getCmp(c);if(a){a.onFlashEvent(b)}else{arguments.callee.defer(10,this,[c,b])}}};Ext.chart.Chart=Ext.extend(Ext.FlashComponent,{refreshBuffer:100,chartStyle:{padding:10,animationEnabled:true,font:{name:"Tahoma",color:4473924,size:11},dataTip:{padding:5,border:{color:10075112,size:1},background:{color:14346230,alpha:0.9},font:{name:"Tahoma",color:1393291,size:10,bold:true}}},extraStyle:null,seriesStyles:null,disableCaching:Ext.isIE||Ext.isOpera,disableCacheParam:"_dc",initComponent:function(){Ext.chart.Chart.superclass.initComponent.call(this);if(!this.url){this.url=Ext.chart.Chart.CHART_URL}if(this.disableCaching){this.url=Ext.urlAppend(this.url,String.format("{0}={1}",this.disableCacheParam,new Date().getTime()))}this.addEvents("itemmouseover","itemmouseout","itemclick","itemdoubleclick","itemdragstart","itemdrag","itemdragend","beforerefresh","refresh");this.store=Ext.StoreMgr.lookup(this.store)},setStyle:function(a,b){th
 is.swf.setStyle(a,Ext.encode(b))},setStyles:function(a){this.swf.setStyles(Ext.encode(a))},setSeriesStyles:function(b){this.seriesStyles=b;var a=[];Ext.each(b,function(c){a.push(Ext.encode(c))});this.swf.setSeriesStyles(a)},setCategoryNames:function(a){this.swf.setCategoryNames(a)},setLegendRenderer:function(c,b){var a=this;b=b||a;a.removeFnProxy(a.legendFnName);a.legendFnName=a.createFnProxy(function(d){return c.call(b,d)});a.swf.setLegendLabelFunction(a.legendFnName)},setTipRenderer:function(c,b){var a=this;b=b||a;a.removeFnProxy(a.tipFnName);a.tipFnName=a.createFnProxy(function(h,e,g){var d=a.store.getAt(e);return c.call(b,a,d,e,g)});a.swf.setDataTipFunction(a.tipFnName)},setSeries:function(a){this.series=a;this.refresh()},bindStore:function(a,b){if(!b&&this.store){if(a!==this.store&&this.store.autoDestroy){this.store.destroy()}else{this.store.un("datachanged",this.refresh,this);this.store.un("add",this.delayRefresh,this);this.store.un("remove",this.delayRefresh,this);thi
 s.store.un("update",this.delayRefresh,this);this.store.un("clear",this.refresh,this)}}if(a){a=Ext.StoreMgr.lookup(a);a.on({scope:this,datachanged:this.refresh,add:this.delayRefresh,remove:this.delayRefresh,update:this.delayRefresh,clear:this.refresh})}this.store=a;if(a&&!b){this.refresh()}},onSwfReady:function(b){Ext.chart.Chart.superclass.onSwfReady.call(this,b);var a;this.swf.setType(this.type);if(this.chartStyle){this.setStyles(Ext.apply({},this.extraStyle,this.chartStyle))}if(this.categoryNames){this.setCategoryNames(this.categoryNames)}if(this.tipRenderer){a=this.getFunctionRef(this.tipRenderer);this.setTipRenderer(a.fn,a.scope)}if(this.legendRenderer){a=this.getFunctionRef(this.legendRenderer);this.setLegendRenderer(a.fn,a.scope)}if(!b){this.bindStore(this.store,true)}this.refresh.defer(10,this)},delayRefresh:function(){if(!this.refreshTask){this.refreshTask=new Ext.util.DelayedTask(this.refresh,this)}this.refreshTask.delay(this.refreshBuffer)},refresh:function(){if(th
 is.fireEvent("beforerefresh",this)!==false){var m=false;var k=[],c=this.store.data.items;for(var g=0,l=c.length;g<l;g++){k[g]=c[g].data}var e=[];var d=0;var n=null;var h=0;if(this.series){d=this.series.length;for(h=0;h<d;h++){n=this.series[h];var b={};for(var a in n){if(a=="style"&&n.style!==null){b.style=Ext.encode(n.style);m=true}else{b[a]=n[a]}}e.push(b)}}if(d>0){for(h=0;h<d;h++){n=e[h];if(!n.type){n.type=this.type}n.dataProvider=k}}else{e.push({type:this.type,dataProvider:k})}this.swf.setDataProvider(e);if(this.seriesStyles){this.setSeriesStyles(this.seriesStyles)}this.fireEvent("refresh",this)}},createFnProxy:function(a){var b="extFnProxy"+(++Ext.chart.Chart.PROXY_FN_ID);Ext.chart.Chart.proxyFunction[b]=a;return"Ext.chart.Chart.proxyFunction."+b},removeFnProxy:function(a){if(!Ext.isEmpty(a)){a=a.replace("Ext.chart.Chart.proxyFunction.","");delete Ext.chart.Chart.proxyFunction[a]}},getFunctionRef:function(a){if(Ext.isFunction(a)){return{fn:a,scope:this}}else{return{fn:a.
 fn,scope:a.scope||this}}},onDestroy:function(){if(this.refreshTask&&this.refreshTask.cancel){this.refreshTask.cancel()}Ext.chart.Chart.superclass.onDestroy.call(this);this.bindStore(null);this.removeFnProxy(this.tipFnName);this.removeFnProxy(this.legendFnName)}});Ext.reg("chart",Ext.chart.Chart);Ext.chart.Chart.PROXY_FN_ID=0;Ext.chart.Chart.proxyFunction={};Ext.chart.Chart.CHART_URL="http://yui.yahooapis.com/2.8.2/build/charts/assets/charts.swf";Ext.chart.PieChart=Ext.extend(Ext.chart.Chart,{type:"pie",onSwfReady:function(a){Ext.chart.PieChart.superclass.onSwfReady.call(this,a);this.setDataField(this.dataField);this.setCategoryField(this.categoryField)},setDataField:function(a){this.dataField=a;this.swf.setDataField(a)},setCategoryField:function(a){this.categoryField=a;this.swf.setCategoryField(a)}});Ext.reg("piechart",Ext.chart.PieChart);Ext.chart.CartesianChart=Ext.extend(Ext.chart.Chart,{onSwfReady:function(a){Ext.chart.CartesianChart.superclass.onSwfReady.call(this,a);th
 is.labelFn=[];if(this.xField){this.setXField(this.xField)}if(this.yField){this.setYField(this.yField)}if(this.xAxis){this.setXAxis(this.xAxis)}if(this.xAxes){this.setXAxes(this.xAxes)}if(this.yAxis){this.setYAxis(this.yAxis)}if(this.yAxes){this.setYAxes(this.yAxes)}if(Ext.isDefined(this.constrainViewport)){this.swf.setConstrainViewport(this.constrainViewport)}},setXField:function(a){this.xField=a;this.swf.setHorizontalField(a)},setYField:function(a){this.yField=a;this.swf.setVerticalField(a)},setXAxis:function(a){this.xAxis=this.createAxis("xAxis",a);this.swf.setHorizontalAxis(this.xAxis)},setXAxes:function(c){var b;for(var a=0;a<c.length;a++){b=this.createAxis("xAxis"+a,c[a]);this.swf.setHorizontalAxis(b)}},setYAxis:function(a){this.yAxis=this.createAxis("yAxis",a);this.swf.setVerticalAxis(this.yAxis)},setYAxes:function(c){var b;for(var a=0;a<c.length;a++){b=this.createAxis("yAxis"+a,c[a]);this.swf.setVerticalAxis(b)}},createAxis:function(b,d){var e=Ext.apply({},d),c,a;if(t
 his[b]){a=this[b].labelFunction;this.removeFnProxy(a);this.labelFn.remove(a)}if(e.labelRenderer){c=this.getFunctionRef(e.labelRenderer);e.labelFunction=this.createFnProxy(function(g){return c.fn.call(c.scope,g)});delete e.labelRenderer;this.labelFn.push(e.labelFunction)}if(b.indexOf("xAxis")>-1&&e.position=="left"){e.position="bottom"}return e},onDestroy:function(){Ext.chart.CartesianChart.superclass.onDestroy.call(this);Ext.each(this.labelFn,function(a){this.removeFnProxy(a)},this)}});Ext.reg("cartesianchart",Ext.chart.CartesianChart);Ext.chart.LineChart=Ext.extend(Ext.chart.CartesianChart,{type:"line"});Ext.reg("linechart",Ext.chart.LineChart);Ext.chart.ColumnChart=Ext.extend(Ext.chart.CartesianChart,{type:"column"});Ext.reg("columnchart",Ext.chart.ColumnChart);Ext.chart.StackedColumnChart=Ext.extend(Ext.chart.CartesianChart,{type:"stackcolumn"});Ext.reg("stackedcolumnchart",Ext.chart.StackedColumnChart);Ext.chart.BarChart=Ext.extend(Ext.chart.CartesianChart,{type:"bar"});
 Ext.reg("barchart",Ext.chart.BarChart);Ext.chart.StackedBarChart=Ext.extend(Ext.chart.CartesianChart,{type:"stackbar"});Ext.reg("stackedbarchart",Ext.chart.StackedBarChart);Ext.chart.Axis=function(a){Ext.apply(this,a)};Ext.chart.Axis.prototype={type:null,orientation:"horizontal",reverse:false,labelFunction:null,hideOverlappingLabels:true,labelSpacing:2};Ext.chart.NumericAxis=Ext.extend(Ext.chart.Axis,{type:"numeric",minimum:NaN,maximum:NaN,majorUnit:NaN,minorUnit:NaN,snapToUnits:true,alwaysShowZero:true,scale:"linear",roundMajorUnit:true,calculateByLabelSize:true,position:"left",adjustMaximumByMajorUnit:true,adjustMinimumByMajorUnit:true});Ext.chart.TimeAxis=Ext.extend(Ext.chart.Axis,{type:"time",minimum:null,maximum:null,majorUnit:NaN,majorTimeUnit:null,minorUnit:NaN,minorTimeUnit:null,snapToUnits:true,stackingEnabled:false,calculateByLabelSize:true});Ext.chart.CategoryAxis=Ext.extend(Ext.chart.Axis,{type:"category",categoryNames:null,calculateCategoryCount:false});Ext.char
 t.Series=function(a){Ext.apply(this,a)};Ext.chart.Series.prototype={type:null,displayName:null};Ext.chart.CartesianSeries=Ext.extend(Ext.chart.Series,{xField:null,yField:null,showInLegend:true,axis:"primary"});Ext.chart.ColumnSeries=Ext.extend(Ext.chart.CartesianSeries,{type:"column"});Ext.chart.LineSeries=Ext.extend(Ext.chart.CartesianSeries,{type:"line"});Ext.chart.BarSeries=Ext.extend(Ext.chart.CartesianSeries,{type:"bar"});Ext.chart.PieSeries=Ext.extend(Ext.chart.Series,{type:"pie",dataField:null,categoryField:null});Ext.menu.Menu=Ext.extend(Ext.Container,{minWidth:120,shadow:"sides",subMenuAlign:"tl-tr?",defaultAlign:"tl-bl?",allowOtherMenus:false,ignoreParentClicks:false,enableScrolling:true,maxHeight:null,scrollIncrement:24,showSeparator:true,defaultOffsets:[0,0],plain:false,floating:true,zIndex:15000,hidden:true,layout:"menu",hideMode:"offsets",scrollerHeight:8,autoLayout:true,defaultType:"menuitem",bufferResize:false,initComponent:function(){if(Ext.isArray(this.init
 ialConfig)){Ext.apply(this,{items:this.initialConfig})}this.addEvents("click","mouseover","mouseout","itemclick");Ext.menu.MenuMgr.register(this);if(this.floating){Ext.EventManager.onWindowResize(this.hide,this)}else{if(this.initialConfig.hidden!==false){this.hidden=false}this.internalDefaults={hideOnClick:false}}Ext.menu.Menu.superclass.initComponent.call(this);if(this.autoLayout){var a=this.doLayout.createDelegate(this,[]);this.on({add:a,remove:a})}},getLayoutTarget:function(){return this.ul},onRender:function(b,a){if(!b){b=Ext.getBody()}var c={id:this.getId(),cls:"x-menu "+((this.floating)?"x-menu-floating x-layer ":"")+(this.cls||"")+(this.plain?" x-menu-plain":"")+(this.showSeparator?"":" x-menu-nosep"),style:this.style,cn:[{tag:"a",cls:"x-menu-focus",href:"#",onclick:"return false;",tabIndex:"-1"},{tag:"ul",cls:"x-menu-list"}]};if(this.floating){this.el=new Ext.Layer({shadow:this.shadow,dh:c,constrain:false,parentEl:b,zindex:this.zIndex})}else{this.el=b.createChild(c)}
 Ext.menu.Menu.superclass.onRender.call(this,b,a);if(!this.keyNav){this.keyNav=new Ext.menu.MenuNav(this)}this.focusEl=this.el.child("a.x-menu-focus");this.ul=this.el.child("ul.x-menu-list");this.mon(this.ul,{scope:this,click:this.onClick,mouseover:this.onMouseOver,mouseout:this.onMouseOut});if(this.enableScrolling){this.mon(this.el,{scope:this,delegate:".x-menu-scroller",click:this.onScroll,mouseover:this.deactivateActive})}},findTargetItem:function(b){var a=b.getTarget(".x-menu-list-item",this.ul,true);if(a&&a.menuItemId){return this.items.get(a.menuItemId)}},onClick:function(b){var a=this.findTargetItem(b);if(a){if(a.isFormField){this.setActiveItem(a)}else{if(a instanceof Ext.menu.BaseItem){if(a.menu&&this.ignoreParentClicks){a.expandMenu();b.preventDefault()}else{if(a.onClick){a.onClick(b);this.fireEvent("click",this,a,b)}}}}}},setActiveItem:function(a,b){if(a!=this.activeItem){this.deactivateActive();if((this.activeItem=a).isFormField){a.focus()}else{a.activate(b)}}else{
 if(b){a.expandMenu()}}},deactivateActive:function(){var b=this.activeItem;if(b){if(b.isFormField){if(b.collapse){b.collapse()}}else{b.deactivate()}delete this.activeItem}},tryActivate:function(g,e){var b=this.items;for(var c=g,a=b.length;c>=0&&c<a;c+=e){var d=b.get(c);if(d.isVisible()&&!d.disabled&&(d.canActivate||d.isFormField)){this.setActiveItem(d,false);return d}}return false},onMouseOver:function(b){var a=this.findTargetItem(b);if(a){if(a.canActivate&&!a.disabled){this.setActiveItem(a,true)}}this.over=true;this.fireEvent("mouseover",this,b,a)},onMouseOut:function(b){var a=this.findTargetItem(b);if(a){if(a==this.activeItem&&a.shouldDeactivate&&a.shouldDeactivate(b)){this.activeItem.deactivate();delete this.activeItem}}this.over=false;this.fireEvent("mouseout",this,b,a)},onScroll:function(d,b){if(d){d.stopEvent()}var a=this.ul.dom,c=Ext.fly(b).is(".x-menu-scroller-top");a.scrollTop+=this.scrollIncrement*(c?-1:1);if(c?a.scrollTop<=0:a.scrollTop+this.activeMax>=a.scrollHeig
 ht){this.onScrollerOut(null,b)}},onScrollerIn:function(d,b){var a=this.ul.dom,c=Ext.fly(b).is(".x-menu-scroller-top");if(c?a.scrollTop>0:a.scrollTop+this.activeMax<a.scrollHeight){Ext.fly(b).addClass(["x-menu-item-active","x-menu-scroller-active"])}},onScrollerOut:function(b,a){Ext.fly(a).removeClass(["x-menu-item-active","x-menu-scroller-active"])},show:function(b,c,a){if(this.floating){this.parentMenu=a;if(!this.el){this.render();this.doLayout(false,true)}this.showAt(this.el.getAlignToXY(b,c||this.defaultAlign,this.defaultOffsets),a)}else{Ext.menu.Menu.superclass.show.call(this)}},showAt:function(b,a){if(this.fireEvent("beforeshow",this)!==false){this.parentMenu=a;if(!this.el){this.render()}if(this.enableScrolling){this.el.setXY(b);b[1]=this.constrainScroll(b[1]);b=[this.el.adjustForConstraints(b)[0],b[1]]}else{b=this.el.adjustForConstraints(b)}this.el.setXY(b);this.el.show();Ext.menu.Menu.superclass.onShow.call(this);if(Ext.isIE){this.fireEvent("autosize",this);if(!Ext.is
 IE8){this.el.repaint()}}this.hidden=false;this.focus();this.fireEvent("show",this)}},constrainScroll:function(i){var b,d=this.ul.setHeight("auto").getHeight(),a=i,h,e,g,c;if(this.floating){e=Ext.fly(this.el.dom.parentNode);g=e.getScroll().top;c=e.getViewSize().height;h=i-g;b=this.maxHeight?this.maxHeight:c-h;if(d>c){b=c;a=i-h}else{if(b<d){a=i-(d-b);b=d}}}else{b=this.getHeight()}if(this.maxHeight){b=Math.min(this.maxHeight,b)}if(d>b&&b>0){this.activeMax=b-this.scrollerHeight*2-this.el.getFrameWidth("tb")-Ext.num(this.el.shadowOffset,0);this.ul.setHeight(this.activeMax);this.createScrollers();this.el.select(".x-menu-scroller").setDisplayed("")}else{this.ul.setHeight(d);this.el.select(".x-menu-scroller").setDisplayed("none")}this.ul.dom.scrollTop=0;return a},createScrollers:function(){if(!this.scroller){this.scroller={pos:0,top:this.el.insertFirst({tag:"div",cls:"x-menu-scroller x-menu-scroller-top",html:"&#160;"}),bottom:this.el.createChild({tag:"div",cls:"x-menu-scroller x-me
 nu-scroller-bottom",html:"&#160;"})};this.scroller.top.hover(this.onScrollerIn,this.onScrollerOut,this);this.scroller.topRepeater=new Ext.util.ClickRepeater(this.scroller.top,{listeners:{click:this.onScroll.createDelegate(this,[null,this.scroller.top],false)}});this.scroller.bottom.hover(this.onScrollerIn,this.onScrollerOut,this);this.scroller.bottomRepeater=new Ext.util.ClickRepeater(this.scroller.bottom,{listeners:{click:this.onScroll.createDelegate(this,[null,this.scroller.bottom],false)}})}},onLayout:function(){if(this.isVisible()){if(this.enableScrolling){this.constrainScroll(this.el.getTop())}if(this.floating){this.el.sync()}}},focus:function(){if(!this.hidden){this.doFocus.defer(50,this)}},doFocus:function(){if(!this.hidden){this.focusEl.focus()}},hide:function(a){if(!this.isDestroyed){this.deepHide=a;Ext.menu.Menu.superclass.hide.call(this);delete this.deepHide}},onHide:function(){Ext.menu.Menu.superclass.onHide.call(this);this.deactivateActive();if(this.el&&this.flo
 ating){this.el.hide()}var a=this.parentMenu;if(this.deepHide===true&&a){if(a.floating){a.hide(true)}else{a.deactivateActive()}}},lookupComponent:function(a){if(Ext.isString(a)){a=(a=="separator"||a=="-")?new Ext.menu.Separator():new Ext.menu.TextItem(a);this.applyDefaults(a)}else{if(Ext.isObject(a)){a=this.getMenuItem(a)}else{if(a.tagName||a.el){a=new Ext.BoxComponent({el:a})}}}return a},applyDefaults:function(b){if(!Ext.isString(b)){b=Ext.menu.Menu.superclass.applyDefaults.call(this,b);var a=this.internalDefaults;if(a){if(b.events){Ext.applyIf(b.initialConfig,a);Ext.apply(b,a)}else{Ext.applyIf(b,a)}}}return b},getMenuItem:function(a){a.ownerCt=this;if(!a.isXType){if(!a.xtype&&Ext.isBoolean(a.checked)){return new Ext.menu.CheckItem(a)}return Ext.create(a,this.defaultType)}return a},addSeparator:function(){return this.add(new Ext.menu.Separator())},addElement:function(a){return this.add(new Ext.menu.BaseItem({el:a}))},addItem:function(a){return this.add(a)},addMenuItem:functi
 on(a){return this.add(this.getMenuItem(a))},addText:function(a){return this.add(new Ext.menu.TextItem(a))},onDestroy:function(){Ext.EventManager.removeResizeListener(this.hide,this);var a=this.parentMenu;if(a&&a.activeChild==this){delete a.activeChild}delete this.parentMenu;Ext.menu.Menu.superclass.onDestroy.call(this);Ext.menu.MenuMgr.unregister(this);if(this.keyNav){this.keyNav.disable()}var b=this.scroller;if(b){Ext.destroy(b.topRepeater,b.bottomRepeater,b.top,b.bottom)}Ext.destroy(this.el,this.focusEl,this.ul)}});Ext.reg("menu",Ext.menu.Menu);Ext.menu.MenuNav=Ext.extend(Ext.KeyNav,function(){function a(d,c){if(!c.tryActivate(c.items.indexOf(c.activeItem)-1,-1)){c.tryActivate(c.items.length-1,-1)}}function b(d,c){if(!c.tryActivate(c.items.indexOf(c.activeItem)+1,1)){c.tryActivate(0,1)}}return{constructor:function(c){Ext.menu.MenuNav.superclass.constructor.call(this,c.el);this.scope=this.menu=c},doRelay:function(g,d){var c=g.getKey();if(this.menu.activeItem&&this.menu.acti
 veItem.isFormField&&c!=g.TAB){return false}if(!this.menu.activeItem&&g.isNavKeyPress()&&c!=g.SPACE&&c!=g.RETURN){this.menu.tryActivate(0,1);return false}return d.call(this.scope||this,g,this.menu)},tab:function(d,c){d.stopEvent();if(d.shiftKey){a(d,c)}else{b(d,c)}},up:a,down:b,right:function(d,c){if(c.activeItem){c.activeItem.expandMenu(true)}},left:function(d,c){c.hide();if(c.parentMenu&&c.parentMenu.activeItem){c.parentMenu.activeItem.activate()}},enter:function(d,c){if(c.activeItem){d.stopPropagation();c.activeItem.onClick(d);c.fireEvent("click",this,c.activeItem);return true}}}}());Ext.menu.MenuMgr=function(){var h,e,b,d={},a=false,l=new Date();function n(){h={};e=new Ext.util.MixedCollection();b=Ext.getDoc().addKeyListener(27,j);b.disable()}function j(){if(e&&e.length>0){var o=e.clone();o.each(function(p){p.hide()});return true}return false}function g(o){e.remove(o);if(e.length<1){b.disable();Ext.getDoc().un("mousedown",m);a=false}}function k(o){var p=e.last();l=new Dat
 e();e.add(o);if(!a){b.enable();Ext.getDoc().on("mousedown",m);a=true}if(o.parentMenu){o.getEl().setZIndex(parseInt(o.parentMenu.getEl().getStyle("z-index"),10)+3);o.parentMenu.activeChild=o}else{if(p&&!p.isDestroyed&&p.isVisible()){o.getEl().setZIndex(parseInt(p.getEl().getStyle("z-index"),10)+3)}}}function c(o){if(o.activeChild){o.activeChild.hide()}if(o.autoHideTimer){clearTimeout(o.autoHideTimer);delete o.autoHideTimer}}function i(o){var p=o.parentMenu;if(!p&&!o.allowOtherMenus){j()}else{if(p&&p.activeChild){p.activeChild.hide()}}}function m(o){if(l.getElapsed()>50&&e.length>0&&!o.getTarget(".x-menu")){j()}}return{hideAll:function(){return j()},register:function(o){if(!h){n()}h[o.id]=o;o.on({beforehide:c,hide:g,beforeshow:i,show:k})},get:function(o){if(typeof o=="string"){if(!h){return null}return h[o]}else{if(o.events){return o}else{if(typeof o.length=="number"){return new Ext.menu.Menu({items:o})}else{return Ext.create(o,"menu")}}}},unregister:function(o){delete h[o.id]
 ;o.un("beforehide",c);o.un("hide",g);o.un("beforeshow",i);o.un("show",k)},registerCheckable:function(o){var p=o.group;if(p){if(!d[p]){d[p]=[]}d[p].push(o)}},unregisterCheckable:function(o){var p=o.group;if(p){d[p].remove(o)}},onCheckChange:function(q,r){if(q.group&&r){var t=d[q.group],p=0,o=t.length,s;for(;p<o;p++){s=t[p];if(s!=q){s.setChecked(false)}}}},getCheckedItem:function(q){var r=d[q];if(r){for(var p=0,o=r.length;p<o;p++){if(r[p].checked){return r[p]}}}return null},setCheckedItem:function(q,s){var r=d[q];if(r){for(var p=0,o=r.length;p<o;p++){if(r[p].id==s){r[p].setChecked(true)}}}return null}}}();Ext.menu.BaseItem=Ext.extend(Ext.Component,{canActivate:false,activeClass:"x-menu-item-active",hideOnClick:true,clickHideDelay:1,ctype:"Ext.menu.BaseItem",actionMode:"container",initComponent:function(){Ext.menu.BaseItem.superclass.initComponent.call(this);this.addEvents("click","activate","deactivate");if(this.handler){this.on("click",this.handler,this.scope)}},onRender:func
 tion(b,a){Ext.menu.BaseItem.superclass.onRender.apply(this,arguments);if(this.ownerCt&&this.ownerCt instanceof Ext.menu.Menu){this.parentMenu=this.ownerCt}else{this.container.addClass("x-menu-list-item");this.mon(this.el,{scope:this,click:this.onClick,mouseenter:this.activate,mouseleave:this.deactivate})}},setHandler:function(b,a){if(this.handler){this.un("click",this.handler,this.scope)}this.on("click",this.handler=b,this.scope=a)},onClick:function(a){if(!this.disabled&&this.fireEvent("click",this,a)!==false&&(this.parentMenu&&this.parentMenu.fireEvent("itemclick",this,a)!==false)){this.handleClick(a)}else{a.stopEvent()}},activate:function(){if(this.disabled){return false}var a=this.container;a.addClass(this.activeClass);this.region=a.getRegion().adjust(2,2,-2,-2);this.fireEvent("activate",this);return true},deactivate:function(){this.container.removeClass(this.activeClass);this.fireEvent("deactivate",this)},shouldDeactivate:function(a){return !this.region||!this.region.con
 tains(a.getPoint())},handleClick:function(b){var a=this.parentMenu;if(this.hideOnClick){if(a.floating){this.clickHideDelayTimer=a.hide.defer(this.clickHideDelay,a,[true])}else{a.deactivateActive()}}},beforeDestroy:function(){clearTimeout(this.clickHideDelayTimer);Ext.menu.BaseItem.superclass.beforeDestroy.call(this)},expandMenu:Ext.emptyFn,hideMenu:Ext.emptyFn});Ext.reg("menubaseitem",Ext.menu.BaseItem);Ext.menu.TextItem=Ext.extend(Ext.menu.BaseItem,{hideOnClick:false,itemCls:"x-menu-text",constructor:function(a){if(typeof a=="string"){a={text:a}}Ext.menu.TextItem.superclass.constructor.call(this,a)},onRender:function(){var a=document.createElement("span");a.className=this.itemCls;a.innerHTML=this.text;this.el=a;Ext.menu.TextItem.superclass.onRender.apply(this,arguments)}});Ext.reg("menutextitem",Ext.menu.TextItem);Ext.menu.Separator=Ext.extend(Ext.menu.BaseItem,{itemCls:"x-menu-sep",hideOnClick:false,activeClass:"",onRender:function(a){var b=document.createElement("span");b
 .className=this.itemCls;b.innerHTML="&#160;";this.el=b;a.addClass("x-menu-sep-li");Ext.menu.Separator.superclass.onRender.apply(this,arguments)}});Ext.reg("menuseparator",Ext.menu.Separator);Ext.menu.Item=Ext.extend(Ext.menu.BaseItem,{itemCls:"x-menu-item",canActivate:true,showDelay:200,altText:"",hideDelay:200,ctype:"Ext.menu.Item",initComponent:function(){Ext.menu.Item.superclass.initComponent.call(this);if(this.menu){if(Ext.isArray(this.menu)){this.menu={items:this.menu}}if(Ext.isObject(this.menu)){this.menu.ownerCt=this}this.menu=Ext.menu.MenuMgr.get(this.menu);this.menu.ownerCt=undefined}},onRender:function(d,b){if(!this.itemTpl){this.itemTpl=Ext.menu.Item.prototype.itemTpl=new Ext.XTemplate('<a id="{id}" class="{cls}" hidefocus="true" unselectable="on" href="{href}"','<tpl if="hrefTarget">',' target="{hrefTarget}"',"</tpl>",">",'<img alt="{altText}" src="{icon}" class="x-menu-item-icon {iconCls}"/>','<span class="x-menu-item-text">{text}</span>',"</a>")}var c=this.getT
 emplateArgs();this.el=b?this.itemTpl.insertBefore(b,c,true):this.itemTpl.append(d,c,true);this.iconEl=this.el.child("img.x-menu-item-icon");this.textEl=this.el.child(".x-menu-item-text");if(!this.href){this.mon(this.el,"click",Ext.emptyFn,null,{preventDefault:true})}Ext.menu.Item.superclass.onRender.call(this,d,b)},getTemplateArgs:function(){return{id:this.id,cls:this.itemCls+(this.menu?" x-menu-item-arrow":"")+(this.cls?" "+this.cls:""),href:this.href||"#",hrefTarget:this.hrefTarget,icon:this.icon||Ext.BLANK_IMAGE_URL,iconCls:this.iconCls||"",text:this.itemText||this.text||"&#160;",altText:this.altText||""}},setText:function(a){this.text=a||"&#160;";if(this.rendered){this.textEl.update(this.text);this.parentMenu.layout.doAutoSize()}},setIconClass:function(a){var b=this.iconCls;this.iconCls=a;if(this.rendered){this.iconEl.replaceClass(b,this.iconCls)}},beforeDestroy:function(){clearTimeout(this.showTimer);clearTimeout(this.hideTimer);if(this.menu){delete this.menu.ownerCt;th
 is.menu.destroy()}Ext.menu.Item.superclass.beforeDestroy.call(this)},handleClick:function(a){if(!this.href){a.stopEvent()}Ext.menu.Item.superclass.handleClick.apply(this,arguments)},activate:function(a){if(Ext.menu.Item.superclass.activate.apply(this,arguments)){this.focus();if(a){this.expandMenu()}}return true},shouldDeactivate:function(a){if(Ext.menu.Item.superclass.shouldDeactivate.call(this,a)){if(this.menu&&this.menu.isVisible()){return !this.menu.getEl().getRegion().contains(a.getPoint())}return true}return false},deactivate:function(){Ext.menu.Item.superclass.deactivate.apply(this,arguments);this.hideMenu()},expandMenu:function(a){if(!this.disabled&&this.menu){clearTimeout(this.hideTimer);delete this.hideTimer;if(!this.menu.isVisible()&&!this.showTimer){this.showTimer=this.deferExpand.defer(this.showDelay,this,[a])}else{if(this.menu.isVisible()&&a){this.menu.tryActivate(0,1)}}}},deferExpand:function(a){delete this.showTimer;this.menu.show(this.container,this.parentMen
 u.subMenuAlign||"tl-tr?",this.parentMenu);if(a){this.menu.tryActivate(0,1)}},hideMenu:function(){clearTimeout(this.showTimer);delete this.showTimer;if(!this.hideTimer&&this.menu&&this.menu.isVisible()){this.hideTimer=this.deferHide.defer(this.hideDelay,this)}},deferHide:function(){delete this.hideTimer;if(this.menu.over){this.parentMenu.setActiveItem(this,false)}else{this.menu.hide()}}});Ext.reg("menuitem",Ext.menu.Item);Ext.menu.CheckItem=Ext.extend(Ext.menu.Item,{itemCls:"x-menu-item x-menu-check-item",groupClass:"x-menu-group-item",checked:false,ctype:"Ext.menu.CheckItem",initComponent:function(){Ext.menu.CheckItem.superclass.initComponent.call(this);this.addEvents("beforecheckchange","checkchange");if(this.checkHandler){this.on("checkchange",this.checkHandler,this.scope)}Ext.menu.MenuMgr.registerCheckable(this)},onRender:function(a){Ext.menu.CheckItem.superclass.onRender.apply(this,arguments);if(this.group){this.el.addClass(this.groupClass)}if(this.checked){this.checked=
 false;this.setChecked(true,true)}},destroy:function(){Ext.menu.MenuMgr.unregisterCheckable(this);Ext.menu.CheckItem.superclass.destroy.apply(this,arguments)},setChecked:function(b,a){var c=a===true;if(this.checked!=b&&(c||this.fireEvent("beforecheckchange",this,b)!==false)){Ext.menu.MenuMgr.onCheckChange(this,b);if(this.container){this.container[b?"addClass":"removeClass"]("x-menu-item-checked")}this.checked=b;if(!c){this.fireEvent("checkchange",this,b)}}},handleClick:function(a){if(!this.disabled&&!(this.checked&&this.group)){this.setChecked(!this.checked)}Ext.menu.CheckItem.superclass.handleClick.apply(this,arguments)}});Ext.reg("menucheckitem",Ext.menu.CheckItem);Ext.menu.DateMenu=Ext.extend(Ext.menu.Menu,{enableScrolling:false,hideOnClick:true,pickerId:null,cls:"x-date-menu",initComponent:function(){this.on("beforeshow",this.onBeforeShow,this);if(this.strict=(Ext.isIE7&&Ext.isStrict)){this.on("show",this.onShow,this,{single:true,delay:20})}Ext.apply(this,{plain:true,show
 Separator:false,items:this.picker=new Ext.DatePicker(Ext.applyIf({internalRender:this.strict||!Ext.isIE,ctCls:"x-menu-date-item",id:this.pickerId},this.initialConfig))});this.picker.purgeListeners();Ext.menu.DateMenu.superclass.initComponent.call(this);this.relayEvents(this.picker,["select"]);this.on("show",this.picker.focus,this.picker);this.on("select",this.menuHide,this);if(this.handler){this.on("select",this.handler,this.scope||this)}},menuHide:function(){if(this.hideOnClick){this.hide(true)}},onBeforeShow:function(){if(this.picker){this.picker.hideMonthPicker(true)}},onShow:function(){var a=this.picker.getEl();a.setWidth(a.getWidth())}});Ext.reg("datemenu",Ext.menu.DateMenu);Ext.menu.ColorMenu=Ext.extend(Ext.menu.Menu,{enableScrolling:false,hideOnClick:true,cls:"x-color-menu",paletteId:null,initComponent:function(){Ext.apply(this,{plain:true,showSeparator:false,items:this.palette=new Ext.ColorPalette(Ext.applyIf({id:this.paletteId},this.initialConfig))});this.palette.pu
 rgeListeners();Ext.menu.ColorMenu.superclass.initComponent.call(this);this.relayEvents(this.palette,["select"]);this.on("select",this.menuHide,this);if(this.handler){this.on("select",this.handler,this.scope||this)}},menuHide:function(){if(this.hideOnClick){this.hide(true)}}});Ext.reg("colormenu",Ext.menu.ColorMenu);Ext.form.Field=Ext.extend(Ext.BoxComponent,{invalidClass:"x-form-invalid",invalidText:"The value in this field is invalid",focusClass:"x-form-focus",validationEvent:"keyup",validateOnBlur:true,validationDelay:250,defaultAutoCreate:{tag:"input",type:"text",size:"20",autocomplete:"off"},fieldClass:"x-form-field",msgTarget:"qtip",msgFx:"normal",readOnly:false,disabled:false,submitValue:true,isFormField:true,msgDisplay:"",hasFocus:false,initComponent:function(){Ext.form.Field.superclass.initComponent.call(this);this.addEvents("focus","blur","specialkey","change","invalid","valid")},getName:function(){return this.rendered&&this.el.dom.name?this.el.dom.name:this.name||t
 his.id||""},onRender:function(c,a){if(!this.el){var b=this.getAutoCreate();if(!b.name){b.name=this.name||this.id}if(this.inputType){b.type=this.inputType}this.autoEl=b}Ext.form.Field.superclass.onRender.call(this,c,a);if(this.submitValue===false){this.el.dom.removeAttribute("name")}var d=this.el.dom.type;if(d){if(d=="password"){d="text"}this.el.addClass("x-form-"+d)}if(this.readOnly){this.setReadOnly(true)}if(this.tabIndex!==undefined){this.el.dom.setAttribute("tabIndex",this.tabIndex)}this.el.addClass([this.fieldClass,this.cls])},getItemCt:function(){return this.itemCt},initValue:function(){if(this.value!==undefined){this.setValue(this.value)}else{if(!Ext.isEmpty(this.el.dom.value)&&this.el.dom.value!=this.emptyText){this.setValue(this.el.dom.value)}}this.originalValue=this.getValue()},isDirty:function(){if(this.disabled||!this.rendered){return false}return String(this.getValue())!==String(this.originalValue)},setReadOnly:function(a){if(this.rendered){this.el.dom.readOnly=a
 }this.readOnly=a},afterRender:function(){Ext.form.Field.superclass.afterRender.call(this);this.initEvents();this.initValue()},fireKey:function(a){if(a.isSpecialKey()){this.fireEvent("specialkey",this,a)}},reset:function(){this.setValue(this.originalValue);this.clearInvalid()},initEvents:function(){this.mon(this.el,Ext.EventManager.getKeyEvent(),this.fireKey,this);this.mon(this.el,"focus",this.onFocus,this);this.mon(this.el,"blur",this.onBlur,this,this.inEditor?{buffer:10}:null)},preFocus:Ext.emptyFn,onFocus:function(){this.preFocus();if(this.focusClass){this.el.addClass(this.focusClass)}if(!this.hasFocus){this.hasFocus=true;this.startValue=this.getValue();this.fireEvent("focus",this)}},beforeBlur:Ext.emptyFn,onBlur:function(){this.beforeBlur();if(this.focusClass){this.el.removeClass(this.focusClass)}this.hasFocus=false;if(this.validationEvent!==false&&(this.validateOnBlur||this.validationEvent=="blur")){this.validate()}var a=this.getValue();if(String(a)!==String(this.startVa
 lue)){this.fireEvent("change",this,a,this.startValue)}this.fireEvent("blur",this);this.postBlur()},postBlur:Ext.emptyFn,isValid:function(a){if(this.disabled){return true}var c=this.preventMark;this.preventMark=a===true;var b=this.validateValue(this.processValue(this.getRawValue()),a);this.preventMark=c;return b},validate:function(){if(this.disabled||this.validateValue(this.processValue(this.getRawValue()))){this.clearInvalid();return true}return false},processValue:function(a){return a},validateValue:function(b){var a=this.getErrors(b)[0];if(a==undefined){return true}else{this.markInvalid(a);return false}},getErrors:function(){return[]},getActiveError:function(){return this.activeError||""},markInvalid:function(c){if(this.rendered&&!this.preventMark){c=c||this.invalidText;var a=this.getMessageHandler();if(a){a.mark(this,c)}else{if(this.msgTarget){this.el.addClass(this.invalidClass);var b=Ext.getDom(this.msgTarget);if(b){b.innerHTML=c;b.style.display=this.msgDisplay}}}}this.s
 etActiveError(c)},clearInvalid:function(){if(this.rendered&&!this.preventMark){this.el.removeClass(this.invalidClass);var a=this.getMessageHandler();if(a){a.clear(this)}else{if(this.msgTarget){this.el.removeClass(this.invalidClass);var b=Ext.getDom(this.msgTarget);if(b){b.innerHTML="";b.style.display="none"}}}}this.unsetActiveError()},setActiveError:function(b,a){this.activeError=b;if(a!==true){this.fireEvent("invalid",this,b)}},unsetActiveError:function(a){delete this.activeError;if(a!==true){this.fireEvent("valid",this)}},getMessageHandler:function(){return Ext.form.MessageTargets[this.msgTarget]},getErrorCt:function(){return this.el.findParent(".x-form-element",5,true)||this.el.findParent(".x-form-field-wrap",5,true)},alignErrorEl:function(){this.errorEl.setWidth(this.getErrorCt().getWidth(true)-20)},alignErrorIcon:function(){this.errorIcon.alignTo(this.el,"tl-tr",[2,0])},getRawValue:function(){var a=this.rendered?this.el.getValue():Ext.value(this.value,"");if(a===this.em
 ptyText){a=""}return a},getValue:function(){if(!this.rendered){return this.value}var a=this.el.getValue();if(a===this.emptyText||a===undefined){a=""}return a},setRawValue:function(a){return this.rendered?(this.el.dom.value=(Ext.isEmpty(a)?"":a)):""},setValue:function(a){this.value=a;if(this.rendered){this.el.dom.value=(Ext.isEmpty(a)?"":a);this.validate()}return this},append:function(a){this.setValue([this.getValue(),a].join(""))}});Ext.form.MessageTargets={qtip:{mark:function(a,b){a.el.addClass(a.invalidClass);a.el.dom.qtip=b;a.el.dom.qclass="x-form-invalid-tip";if(Ext.QuickTips){Ext.QuickTips.enable()}},clear:function(a){a.el.removeClass(a.invalidClass);a.el.dom.qtip=""}},title:{mark:function(a,b){a.el.addClass(a.invalidClass);a.el.dom.title=b},clear:function(a){a.el.dom.title=""}},under:{mark:function(b,c){b.el.addClass(b.invalidClass);if(!b.errorEl){var a=b.getErrorCt();if(!a){b.el.dom.title=c;return}b.errorEl=a.createChild({cls:"x-form-invalid-msg"});b.on("resize",b.ali
 gnErrorEl,b);b.on("destroy",function(){Ext.destroy(this.errorEl)},b)}b.alignErrorEl();b.errorEl.update(c);Ext.form.Field.msgFx[b.msgFx].show(b.errorEl,b)},clear:function(a){a.el.removeClass(a.invalidClass);if(a.errorEl){Ext.form.Field.msgFx[a.msgFx].hide(a.errorEl,a)}else{a.el.dom.title=""}}},side:{mark:function(b,c){b.el.addClass(b.invalidClass);if(!b.errorIcon){var a=b.getErrorCt();if(!a){b.el.dom.title=c;return}b.errorIcon=a.createChild({cls:"x-form-invalid-icon"});if(b.ownerCt){b.ownerCt.on("afterlayout",b.alignErrorIcon,b);b.ownerCt.on("expand",b.alignErrorIcon,b)}b.on("resize",b.alignErrorIcon,b);b.on("destroy",function(){Ext.destroy(this.errorIcon)},b)}b.alignErrorIcon();b.errorIcon.dom.qtip=c;b.errorIcon.dom.qclass="x-form-invalid-tip";b.errorIcon.show()},clear:function(a){a.el.removeClass(a.invalidClass);if(a.errorIcon){a.errorIcon.dom.qtip="";a.errorIcon.hide()}else{a.el.dom.title=""}}}};Ext.form.Field.msgFx={normal:{show:function(a,b){a.setDisplayed("block")},hide
 :function(a,b){a.setDisplayed(false).update("")}},slide:{show:function(a,b){a.slideIn("t",{stopFx:true})},hide:function(a,b){a.slideOut("t",{stopFx:true,useDisplay:true})}},slideRight:{show:function(a,b){a.fixDisplay();a.alignTo(b.el,"tl-tr");a.slideIn("l",{stopFx:true})},hide:function(a,b){a.slideOut("l",{stopFx:true,useDisplay:true})}}};Ext.reg("field",Ext.form.Field);Ext.form.TextField=Ext.extend(Ext.form.Field,{grow:false,growMin:30,growMax:800,vtype:null,maskRe:null,disableKeyFilter:false,allowBlank:true,minLength:0,maxLength:Number.MAX_VALUE,minLengthText:"The minimum length for this field is {0}",maxLengthText:"The maximum length for this field is {0}",selectOnFocus:false,blankText:"This field is required",validator:null,regex:null,regexText:"",emptyText:null,emptyClass:"x-form-empty-field",initComponent:function(){Ext.form.TextField.superclass.initComponent.call(this);this.addEvents("autosize","keydown","keyup","keypress")},initEvents:function(){Ext.form.TextField.su
 perclass.initEvents.call(this);if(this.validationEvent=="keyup"){this.validationTask=new Ext.util.DelayedTask(this.validate,this);this.mon(this.el,"keyup",this.filterValidation,this)}else{if(this.validationEvent!==false&&this.validationEvent!="blur"){this.mon(this.el,this.validationEvent,this.validate,this,{buffer:this.validationDelay})}}if(this.selectOnFocus||this.emptyText){this.mon(this.el,"mousedown",this.onMouseDown,this);if(this.emptyText){this.applyEmptyText()}}if(this.maskRe||(this.vtype&&this.disableKeyFilter!==true&&(this.maskRe=Ext.form.VTypes[this.vtype+"Mask"]))){this.mon(this.el,"keypress",this.filterKeys,this)}if(this.grow){this.mon(this.el,"keyup",this.onKeyUpBuffered,this,{buffer:50});this.mon(this.el,"click",this.autoSize,this)}if(this.enableKeyEvents){this.mon(this.el,{scope:this,keyup:this.onKeyUp,keydown:this.onKeyDown,keypress:this.onKeyPress})}},onMouseDown:function(a){if(!this.hasFocus){this.mon(this.el,"mouseup",Ext.emptyFn,this,{single:true,preventD
 efault:true})}},processValue:function(a){if(this.stripCharsRe){var b=a.replace(this.stripCharsRe,"");if(b!==a){this.setRawValue(b);return b}}return a},filterValidation:function(a){if(!a.isNavKeyPress()){this.validationTask.delay(this.validationDelay)}},onDisable:function(){Ext.form.TextField.superclass.onDisable.call(this);if(Ext.isIE){this.el.dom.unselectable="on"}},onEnable:function(){Ext.form.TextField.superclass.onEnable.call(this);if(Ext.isIE){this.el.dom.unselectable=""}},onKeyUpBuffered:function(a){if(this.doAutoSize(a)){this.autoSize()}},doAutoSize:function(a){return !a.isNavKeyPress()},onKeyUp:function(a){this.fireEvent("keyup",this,a)},onKeyDown:function(a){this.fireEvent("keydown",this,a)},onKeyPress:function(a){this.fireEvent("keypress",this,a)},reset:function(){Ext.form.TextField.superclass.reset.call(this);this.applyEmptyText()},applyEmptyText:function(){if(this.rendered&&this.emptyText&&this.getRawValue().length<1&&!this.hasFocus){this.setRawValue(this.emptyTe
 xt);this.el.addClass(this.emptyClass)}},preFocus:function(){var a=this.el,b;if(this.emptyText){if(a.dom.value==this.emptyText){this.setRawValue("");b=true}a.removeClass(this.emptyClass)}if(this.selectOnFocus||b){a.dom.select()}},postBlur:function(){this.applyEmptyText()},filterKeys:function(b){if(b.ctrlKey){return}var a=b.getKey();if(Ext.isGecko&&(b.isNavKeyPress()||a==b.BACKSPACE||(a==b.DELETE&&b.button==-1))){return}var c=String.fromCharCode(b.getCharCode());if(!Ext.isGecko&&b.isSpecialKey()&&!c){return}if(!this.maskRe.test(c)){b.stopEvent()}},setValue:function(a){if(this.emptyText&&this.el&&!Ext.isEmpty(a)){this.el.removeClass(this.emptyClass)}Ext.form.TextField.superclass.setValue.apply(this,arguments);this.applyEmptyText();this.autoSize();return this},getErrors:function(a){var d=Ext.form.TextField.superclass.getErrors.apply(this,arguments);a=Ext.isDefined(a)?a:this.processValue(this.getRawValue());if(Ext.isFunction(this.validator)){var c=this.validator(a);if(c!==true){d
 .push(c)}}if(a.length<1||a===this.emptyText){if(this.allowBlank){return d}else{d.push(this.blankText)}}if(!this.allowBlank&&(a.length<1||a===this.emptyText)){d.push(this.blankText)}if(a.length<this.minLength){d.push(String.format(this.minLengthText,this.minLength))}if(a.length>this.maxLength){d.push(String.format(this.maxLengthText,this.maxLength))}if(this.vtype){var b=Ext.form.VTypes;if(!b[this.vtype](a,this)){d.push(this.vtypeText||b[this.vtype+"Text"])}}if(this.regex&&!this.regex.test(a)){d.push(this.regexText)}return d},selectText:function(h,a){var c=this.getRawValue();var e=false;if(c.length>0){h=h===undefined?0:h;a=a===undefined?c.length:a;var g=this.el.dom;if(g.setSelectionRange){g.setSelectionRange(h,a)}else{if(g.createTextRange){var b=g.createTextRange();b.moveStart("character",h);b.moveEnd("character",a-c.length);b.select()}}e=Ext.isGecko||Ext.isOpera}else{e=true}if(e){this.focus()}},autoSize:function(){if(!this.grow||!this.rendered){return}if(!this.metrics){this.m
 etrics=Ext.util.TextMetrics.createInstance(this.el)}var c=this.el;var b=c.dom.value;var e=document.createElement("div");e.appendChild(document.createTextNode(b));b=e.innerHTML;Ext.removeNode(e);e=null;b+="&#160;";var a=Math.min(this.growMax,Math.max(this.metrics.getWidth(b)+10,this.growMin));this.el.setWidth(a);this.fireEvent("autosize",this,a)},onDestroy:function(){if(this.validationTask){this.validationTask.cancel();this.validationTask=null}Ext.form.TextField.superclass.onDestroy.call(this)}});Ext.reg("textfield",Ext.form.TextField);Ext.form.TriggerField=Ext.extend(Ext.form.TextField,{defaultAutoCreate:{tag:"input",type:"text",size:"16",autocomplete:"off"},hideTrigger:false,editable:true,readOnly:false,wrapFocusClass:"x-trigger-wrap-focus",autoSize:Ext.emptyFn,monitorTab:true,deferHeight:true,mimicing:false,actionMode:"wrap",defaultTriggerWidth:17,onResize:function(a,c){Ext.form.TriggerField.superclass.onResize.call(this,a,c);var b=this.getTriggerWidth();if(Ext.isNumber(a)
 ){this.el.setWidth(a-b)}this.wrap.setWidth(this.el.getWidth()+b)},getTriggerWidth:function(){var a=this.trigger.getWidth();if(!this.hideTrigger&&!this.readOnly&&a===0){a=this.defaultTriggerWidth}return a},alignErrorIcon:function(){if(this.wrap){this.errorIcon.alignTo(this.wrap,"tl-tr",[2,0])}},onRender:function(b,a){this.doc=Ext.isIE?Ext.getBody():Ext.getDoc();Ext.form.TriggerField.superclass.onRender.call(this,b,a);this.wrap=this.el.wrap({cls:"x-form-field-wrap x-form-field-trigger-wrap"});this.trigger=this.wrap.createChild(this.triggerConfig||{tag:"img",src:Ext.BLANK_IMAGE_URL,alt:"",cls:"x-form-trigger "+this.triggerClass});this.initTrigger();if(!this.width){this.wrap.setWidth(this.el.getWidth()+this.trigger.getWidth())}this.resizeEl=this.positionEl=this.wrap},getWidth:function(){return(this.el.getWidth()+this.trigger.getWidth())},updateEditState:function(){if(this.rendered){if(this.readOnly){this.el.dom.readOnly=true;this.el.addClass("x-trigger-noedit");this.mun(this.el,
 "click",this.onTriggerClick,this);this.trigger.setDisplayed(false)}else{if(!this.editable){this.el.dom.readOnly=true;this.el.addClass("x-trigger-noedit");this.mon(this.el,"click",this.onTriggerClick,this)}else{this.el.dom.readOnly=false;this.el.removeClass("x-trigger-noedit");this.mun(this.el,"click",this.onTriggerClick,this)}this.trigger.setDisplayed(!this.hideTrigger)}this.onResize(this.width||this.wrap.getWidth())}},setHideTrigger:function(a){if(a!=this.hideTrigger){this.hideTrigger=a;this.updateEditState()}},setEditable:function(a){if(a!=this.editable){this.editable=a;this.updateEditState()}},setReadOnly:function(a){if(a!=this.readOnly){this.readOnly=a;this.updateEditState()}},afterRender:function(){Ext.form.TriggerField.superclass.afterRender.call(this);this.updateEditState()},initTrigger:function(){this.mon(this.trigger,"click",this.onTriggerClick,this,{preventDefault:true});this.trigger.addClassOnOver("x-form-trigger-over");this.trigger.addClassOnClick("x-form-trigger
 -click")},onDestroy:function(){Ext.destroy(this.trigger,this.wrap);if(this.mimicing){this.doc.un("mousedown",this.mimicBlur,this)}delete this.doc;Ext.form.TriggerField.superclass.onDestroy.call(this)},onFocus:function(){Ext.form.TriggerField.superclass.onFocus.call(this);if(!this.mimicing){this.wrap.addClass(this.wrapFocusClass);this.mimicing=true;this.doc.on("mousedown",this.mimicBlur,this,{delay:10});if(this.monitorTab){this.on("specialkey",this.checkTab,this)}}},checkTab:function(a,b){if(b.getKey()==b.TAB){this.triggerBlur()}},onBlur:Ext.emptyFn,mimicBlur:function(a){if(!this.isDestroyed&&!this.wrap.contains(a.target)&&this.validateBlur(a)){this.triggerBlur()}},triggerBlur:function(){this.mimicing=false;this.doc.un("mousedown",this.mimicBlur,this);if(this.monitorTab&&this.el){this.un("specialkey",this.checkTab,this)}Ext.form.TriggerField.superclass.onBlur.call(this);if(this.wrap){this.wrap.removeClass(this.wrapFocusClass)}},beforeBlur:Ext.emptyFn,validateBlur:function(a){
 return true},onTriggerClick:Ext.emptyFn});Ext.form.TwinTriggerField=Ext.extend(Ext.form.TriggerField,{initComponent:function(){Ext.form.TwinTriggerField.superclass.initComponent.call(this);this.triggerConfig={tag:"span",cls:"x-form-twin-triggers",cn:[{tag:"img",src:Ext.BLANK_IMAGE_URL,alt:"",cls:"x-form-trigger "+this.trigger1Class},{tag:"img",src:Ext.BLANK_IMAGE_URL,alt:"",cls:"x-form-trigger "+this.trigger2Class}]}},getTrigger:function(a){return this.triggers[a]},afterRender:function(){Ext.form.TwinTriggerField.superclass.afterRender.call(this);var c=this.triggers,b=0,a=c.length;for(;b<a;++b){if(this["hideTrigger"+(b+1)]){c[b].hide()}}},initTrigger:function(){var a=this.trigger.select(".x-form-trigger",true),b=this;a.each(function(d,g,c){var e="Trigger"+(c+1);d.hide=function(){var h=b.wrap.getWidth();this.dom.style.display="none";b.el.setWidth(h-b.trigger.getWidth());b["hidden"+e]=true};d.show=function(){var h=b.wrap.getWidth();this.dom.style.display="";b.el.setWidth(h-b.t
 rigger.getWidth());b["hidden"+e]=false};this.mon(d,"click",this["on"+e+"Click"],this,{preventDefault:true});d.addClassOnOver("x-form-trigger-over");d.addClassOnClick("x-form-trigger-click")},this);this.triggers=a.elements},getTriggerWidth:function(){var a=0;Ext.each(this.triggers,function(d,c){var e="Trigger"+(c+1),b=d.getWidth();if(b===0&&!this["hidden"+e]){a+=this.defaultTriggerWidth}else{a+=b}},this);return a},onDestroy:function(){Ext.destroy(this.triggers);Ext.form.TwinTriggerField.superclass.onDestroy.call(this)},onTrigger1Click:Ext.emptyFn,onTrigger2Click:Ext.emptyFn});Ext.reg("trigger",Ext.form.TriggerField);Ext.form.TextArea=Ext.extend(Ext.form.TextField,{growMin:60,growMax:1000,growAppend:"&#160;\n&#160;",enterIsSpecial:false,preventScrollbars:false,onRender:function(b,a){if(!this.el){this.defaultAutoCreate={tag:"textarea",style:"width:100px;height:60px;",autocomplete:"off"}}Ext.form.TextArea.superclass.onRender.call(this,b,a);if(this.grow){this.textSizeEl=Ext.DomHe
 lper.append(document.body,{tag:"pre",cls:"x-form-grow-sizer"});if(this.preventScrollbars){this.el.setStyle("overflow","hidden")}this.el.setHeight(this.growMin)}},onDestroy:function(){Ext.removeNode(this.textSizeEl);Ext.form.TextArea.superclass.onDestroy.call(this)},fireKey:function(a){if(a.isSpecialKey()&&(this.enterIsSpecial||(a.getKey()!=a.ENTER||a.hasModifier()))){this.fireEvent("specialkey",this,a)}},doAutoSize:function(a){return !a.isNavKeyPress()||a.getKey()==a.ENTER},filterValidation:function(a){if(!a.isNavKeyPress()||(!this.enterIsSpecial&&a.keyCode==a.ENTER)){this.validationTask.delay(this.validationDelay)}},autoSize:function(){if(!this.grow||!this.textSizeEl){return}var c=this.el,a=Ext.util.Format.htmlEncode(c.dom.value),d=this.textSizeEl,b;Ext.fly(d).setWidth(this.el.getWidth());if(a.length<1){a="&#160;&#160;"}else{a+=this.growAppend;if(Ext.isIE){a=a.replace(/\n/g,"&#160;<br />")}}d.innerHTML=a;b=Math.min(this.growMax,Math.max(d.offsetHeight,this.growMin));if(b!=t
 his.lastHeight){this.lastHeight=b;this.el.setHeight(b);this.fireEvent("autosize",this,b)}}});Ext.reg("textarea",Ext.form.TextArea);Ext.form.NumberField=Ext.extend(Ext.form.TextField,{fieldClass:"x-form-field x-form-num-field",allowDecimals:true,decimalSeparator:".",decimalPrecision:2,allowNegative:true,minValue:Number.NEGATIVE_INFINITY,maxValue:Number.MAX_VALUE,minText:"The minimum value for this field is {0}",maxText:"The maximum value for this field is {0}",nanText:"{0} is not a valid number",baseChars:"0123456789",autoStripChars:false,initEvents:function(){var a=this.baseChars+"";if(this.allowDecimals){a+=this.decimalSeparator}if(this.allowNegative){a+="-"}a=Ext.escapeRe(a);this.maskRe=new RegExp("["+a+"]");if(this.autoStripChars){this.stripCharsRe=new RegExp("[^"+a+"]","gi")}Ext.form.NumberField.superclass.initEvents.call(this)},getErrors:function(b){var c=Ext.form.NumberField.superclass.getErrors.apply(this,arguments);b=Ext.isDefined(b)?b:this.processValue(this.getRawVa
 lue());if(b.length<1){return c}b=String(b).replace(this.decimalSeparator,".");if(isNaN(b)){c.push(String.format(this.nanText,b))}var a=this.parseValue(b);if(a<this.minValue){c.push(String.format(this.minText,this.minValue))}if(a>this.maxValue){c.push(String.format(this.maxText,this.maxValue))}return c},getValue:function(){return this.fixPrecision(this.parseValue(Ext.form.NumberField.superclass.getValue.call(this)))},setValue:function(a){a=Ext.isNumber(a)?a:parseFloat(String(a).replace(this.decimalSeparator,"."));a=this.fixPrecision(a);a=isNaN(a)?"":String(a).replace(".",this.decimalSeparator);return Ext.form.NumberField.superclass.setValue.call(this,a)},setMinValue:function(a){this.minValue=Ext.num(a,Number.NEGATIVE_INFINITY)},setMaxValue:function(a){this.maxValue=Ext.num(a,Number.MAX_VALUE)},parseValue:function(a){a=parseFloat(String(a).replace(this.decimalSeparator,"."));return isNaN(a)?"":a},fixPrecision:function(b){var a=isNaN(b);if(!this.allowDecimals||this.decimalPreci
 sion==-1||a||!b){return a?"":b}return parseFloat(parseFloat(b).toFixed(this.decimalPrecision))},beforeBlur:function(){var a=this.parseValue(this.getRawValue());if(!Ext.isEmpty(a)){this.setValue(a)}}});Ext.reg("numberfield",Ext.form.NumberField);Ext.form.DateField=Ext.extend(Ext.form.TriggerField,{format:"m/d/Y",altFormats:"m/d/Y|n/j/Y|n/j/y|m/j/y|n/d/y|m/j/Y|n/d/Y|m-d-y|m-d-Y|m/d|m-d|md|mdy|mdY|d|Y-m-d|n-j|n/j",disabledDaysText:"Disabled",disabledDatesText:"Disabled",minText:"The date in this field must be equal to or after {0}",maxText:"The date in this field must be equal to or before {0}",invalidText:"{0} is not a valid date - it must be in the format {1}",triggerClass:"x-form-date-trigger",showToday:true,startDay:0,defaultAutoCreate:{tag:"input",type:"text",size:"10",autocomplete:"off"},initTime:"12",initTimeFormat:"H",safeParse:function(b,c){if(Date.formatContainsHourInfo(c)){return Date.parseDate(b,c)}else{var a=Date.parseDate(b+" "+this.initTime,c+" "+this.initTimeFor
 mat);if(a){return a.clearTime()}}},initComponent:function(){Ext.form.DateField.superclass.initComponent.call(this);this.addEvents("select");if(Ext.isString(this.minValue)){this.minValue=this.parseDate(this.minValue)}if(Ext.isString(this.maxValue)){this.maxValue=this.parseDate(this.maxValue)}this.disabledDatesRE=null;this.initDisabledDays()},initEvents:function(){Ext.form.DateField.superclass.initEvents.call(this);this.keyNav=new Ext.KeyNav(this.el,{down:function(a){this.onTriggerClick()},scope:this,forceKeyDown:true})},initDisabledDays:function(){if(this.disabledDates){var b=this.disabledDates,a=b.length-1,c="(?:";Ext.each(b,function(g,e){c+=Ext.isDate(g)?"^"+Ext.escapeRe(g.dateFormat(this.format))+"$":b[e];if(e!=a){c+="|"}},this);this.disabledDatesRE=new RegExp(c+")")}},setDisabledDates:function(a){this.disabledDates=a;this.initDisabledDays();if(this.menu){this.menu.picker.setDisabledDates(this.disabledDatesRE)}},setDisabledDays:function(a){this.disabledDays=a;if(this.menu)
 {this.menu.picker.setDisabledDays(a)}},setMinValue:function(a){this.minValue=(Ext.isString(a)?this.parseDate(a):a);if(this.menu){this.menu.picker.setMinDate(this.minValue)}},setMaxValue:function(a){this.maxValue=(Ext.isString(a)?this.parseDate(a):a);if(this.menu){this.menu.picker.setMaxDate(this.maxValue)}},getErrors:function(e){var h=Ext.form.DateField.superclass.getErrors.apply(this,arguments);e=this.formatDate(e||this.processValue(this.getRawValue()));if(e.length<1){return h}var c=e;e=this.parseDate(e);if(!e){h.push(String.format(this.invalidText,c,this.format));return h}var g=e.getTime();if(this.minValue&&g<this.minValue.clearTime().getTime()){h.push(String.format(this.minText,this.formatDate(this.minValue)))}if(this.maxValue&&g>this.maxValue.clearTime().getTime()){h.push(String.format(this.maxText,this.formatDate(this.maxValue)))}if(this.disabledDays){var a=e.getDay();for(var b=0;b<this.disabledDays.length;b++){if(a===this.disabledDays[b]){h.push(this.disabledDaysText);
 break}}}var d=this.formatDate(e);if(this.disabledDatesRE&&this.disabledDatesRE.test(d)){h.push(String.format(this.disabledDatesText,d))}return h},validateBlur:function(){return !this.menu||!this.menu.isVisible()},getValue:function(){return this.parseDate(Ext.form.DateField.superclass.getValue.call(this))||""},setValue:function(a){return Ext.form.DateField.superclass.setValue.call(this,this.formatDate(this.parseDate(a)))},parseDate:function(g){if(!g||Ext.isDate(g)){return g}var b=this.safeParse(g,this.format),c=this.altFormats,e=this.altFormatsArray;if(!b&&c){e=e||c.split("|");for(var d=0,a=e.length;d<a&&!b;d++){b=this.safeParse(g,e[d])}}return b},onDestroy:function(){Ext.destroy(this.menu,this.keyNav);Ext.form.DateField.superclass.onDestroy.call(this)},formatDate:function(a){return Ext.isDate(a)?a.dateFormat(this.format):a},onTriggerClick:function(){if(this.disabled){return}if(this.menu==null){this.menu=new Ext.menu.DateMenu({hideOnClick:false,focusOnSelect:false})}this.onFo
 cus();Ext.apply(this.menu.picker,{minDate:this.minValue,maxDate:this.maxValue,disabledDatesRE:this.disabledDatesRE,disabledDatesText:this.disabledDatesText,disabledDays:this.disabledDays,disabledDaysText:this.disabledDaysText,format:this.format,showToday:this.showToday,startDay:this.startDay,minText:String.format(this.minText,this.formatDate(this.minValue)),maxText:String.format(this.maxText,this.formatDate(this.maxValue))});this.menu.picker.setValue(this.getValue()||new Date());this.menu.show(this.el,"tl-bl?");this.menuEvents("on")},menuEvents:function(a){this.menu[a]("select",this.onSelect,this);this.menu[a]("hide",this.onMenuHide,this);this.menu[a]("show",this.onFocus,this)},onSelect:function(a,b){this.setValue(b);this.fireEvent("select",this,b);this.menu.hide()},onMenuHide:function(){this.focus(false,60);this.menuEvents("un")},beforeBlur:function(){var a=this.parseDate(this.getRawValue());if(a){this.setValue(a)}}});Ext.reg("datefield",Ext.form.DateField);Ext.form.Display
 Field=Ext.extend(Ext.form.Field,{validationEvent:false,validateOnBlur:false,defaultAutoCreate:{tag:"div"},fieldClass:"x-form-display-field",htmlEncode:false,initEvents:Ext.emptyFn,isValid:function(){return true},validate:function(){return true},getRawValue:function(){var a=this.rendered?this.el.dom.innerHTML:Ext.value(this.value,"");if(a===this.emptyText){a=""}if(this.htmlEncode){a=Ext.util.Format.htmlDecode(a)}return a},getValue:function(){return this.getRawValue()},getName:function(){return this.name},setRawValue:function(a){if(this.htmlEncode){a=Ext.util.Format.htmlEncode(a)}return this.rendered?(this.el.dom.innerHTML=(Ext.isEmpty(a)?"":a)):(this.value=a)},setValue:function(a){this.setRawValue(a);return this}});Ext.reg("displayfield",Ext.form.DisplayField);Ext.form.ComboBox=Ext.extend(Ext.form.TriggerField,{defaultAutoCreate:{tag:"input",type:"text",size:"24",autocomplete:"off"},listClass:"",selectedClass:"x-combo-selected",listEmptyText:"",triggerClass:"x-form-arrow-trig
 ger",shadow:"sides",listAlign:"tl-bl?",maxHeight:300,minHeight:90,triggerAction:"query",minChars:4,autoSelect:true,typeAhead:false,queryDelay:500,pageSize:0,selectOnFocus:false,queryParam:"query",loadingText:"Loading...",resizable:false,handleHeight:8,allQuery:"",mode:"remote",minListWidth:70,forceSelection:false,typeAheadDelay:250,lazyInit:true,clearFilterOnReset:true,submitValue:undefined,initComponent:function(){Ext.form.ComboBox.superclass.initComponent.call(this);this.addEvents("expand","collapse","beforeselect","select","beforequery");if(this.transform){var c=Ext.getDom(this.transform);if(!this.hiddenName){this.hiddenName=c.name}if(!this.store){this.mode="local";var j=[],e=c.options;for(var b=0,a=e.length;b<a;b++){var h=e[b],g=(h.hasAttribute?h.hasAttribute("value"):h.getAttributeNode("value").specified)?h.value:h.text;if(h.selected&&Ext.isEmpty(this.value,true)){this.value=g}j.push([g,h.text])}this.store=new Ext.data.ArrayStore({idIndex:0,fields:["value","text"],data:
 j,autoDestroy:true});this.valueField="value";this.displayField="text"}c.name=Ext.id();if(!this.lazyRender){this.target=true;this.el=Ext.DomHelper.insertBefore(c,this.autoCreate||this.defaultAutoCreate);this.render(this.el.parentNode,c)}Ext.removeNode(c)}else{if(this.store){this.store=Ext.StoreMgr.lookup(this.store);if(this.store.autoCreated){this.displayField=this.valueField="field1";if(!this.store.expandData){this.displayField="field2"}this.mode="local"}}}this.selectedIndex=-1;if(this.mode=="local"){if(!Ext.isDefined(this.initialConfig.queryDelay)){this.queryDelay=10}if(!Ext.isDefined(this.initialConfig.minChars)){this.minChars=0}}},onRender:function(b,a){if(this.hiddenName&&!Ext.isDefined(this.submitValue)){this.submitValue=false}Ext.form.ComboBox.superclass.onRender.call(this,b,a);if(this.hiddenName){this.hiddenField=this.el.insertSibling({tag:"input",type:"hidden",name:this.hiddenName,id:(this.hiddenId||Ext.id())},"before",true)}if(Ext.isGecko){this.el.dom.setAttribute("
 autocomplete","off")}if(!this.lazyInit){this.initList()}else{this.on("focus",this.initList,this,{single:true})}},initValue:function(){Ext.form.ComboBox.superclass.initValue.call(this);if(this.hiddenField){this.hiddenField.value=Ext.value(Ext.isDefined(this.hiddenValue)?this.hiddenValue:this.value,"")}},getParentZIndex:function(){var a;if(this.ownerCt){this.findParentBy(function(b){a=parseInt(b.getPositionEl().getStyle("z-index"),10);return !!a})}return a},getZIndex:function(b){b=b||Ext.getDom(this.getListParent()||Ext.getBody());var a=parseInt(Ext.fly(b).getStyle("z-index"),10);if(!a){a=this.getParentZIndex()}return(a||12000)+5},initList:function(){if(!this.list){var a="x-combo-list",c=Ext.getDom(this.getListParent()||Ext.getBody());this.list=new Ext.Layer({parentEl:c,shadow:this.shadow,cls:[a,this.listClass].join(" "),constrain:false,zindex:this.getZIndex(c)});var b=this.listWidth||Math.max(this.wrap.getWidth(),this.minListWidth);this.list.setSize(b,0);this.list.swallowEven
 t("mousewheel");this.assetHeight=0;if(this.syncFont!==false){this.list.setStyle("font-size",this.el.getStyle("font-size"))}if(this.title){this.header=this.list.createChild({cls:a+"-hd",html:this.title});this.assetHeight+=this.header.getHeight()}this.innerList=this.list.createChild({cls:a+"-inner"});this.mon(this.innerList,"mouseover",this.onViewOver,this);this.mon(this.innerList,"mousemove",this.onViewMove,this);this.innerList.setWidth(b-this.list.getFrameWidth("lr"));if(this.pageSize){this.footer=this.list.createChild({cls:a+"-ft"});this.pageTb=new Ext.PagingToolbar({store:this.store,pageSize:this.pageSize,renderTo:this.footer});this.assetHeight+=this.footer.getHeight()}if(!this.tpl){this.tpl='<tpl for="."><div class="'+a+'-item">{'+this.displayField+"}</div></tpl>"}this.view=new Ext.DataView({applyTo:this.innerList,tpl:this.tpl,singleSelect:true,selectedClass:this.selectedClass,itemSelector:this.itemSelector||"."+a+"-item",emptyText:this.listEmptyText,deferEmptyText:false}
 );this.mon(this.view,{containerclick:this.onViewClick,click:this.onViewClick,scope:this});this.bindStore(this.store,true);if(this.resizable){this.resizer=new Ext.Resizable(this.list,{pinned:true,handles:"se"});this.mon(this.resizer,"resize",function(g,d,e){this.maxHeight=e-this.handleHeight-this.list.getFrameWidth("tb")-this.assetHeight;this.listWidth=d;this.innerList.setWidth(d-this.list.getFrameWidth("lr"));this.restrictHeight()},this);this[this.pageSize?"footer":"innerList"].setStyle("margin-bottom",this.handleHeight+"px")}}},getListParent:function(){return document.body},getStore:function(){return this.store},bindStore:function(a,b){if(this.store&&!b){if(this.store!==a&&this.store.autoDestroy){this.store.destroy()}else{this.store.un("beforeload",this.onBeforeLoad,this);this.store.un("load",this.onLoad,this);this.store.un("exception",this.collapse,this)}if(!a){this.store=null;if(this.view){this.view.bindStore(null)}if(this.pageTb){this.pageTb.bindStore(null)}}}if(a){if(!b
 ){this.lastQuery=null;if(this.pageTb){this.pageTb.bindStore(a)}}this.store=Ext.StoreMgr.lookup(a);this.store.on({scope:this,beforeload:this.onBeforeLoad,load:this.onLoad,exception:this.collapse});if(this.view){this.view.bindStore(a)}}},reset:function(){if(this.clearFilterOnReset&&this.mode=="local"){this.store.clearFilter()}Ext.form.ComboBox.superclass.reset.call(this)},initEvents:function(){Ext.form.ComboBox.superclass.initEvents.call(this);this.keyNav=new Ext.KeyNav(this.el,{up:function(a){this.inKeyMode=true;this.selectPrev()},down:function(a){if(!this.isExpanded()){this.onTriggerClick()}else{this.inKeyMode=true;this.selectNext()}},enter:function(a){this.onViewClick()},esc:function(a){this.collapse()},tab:function(a){if(this.forceSelection===true){this.collapse()}else{this.onViewClick(false)}return true},scope:this,doRelay:function(c,b,a){if(a=="down"||this.scope.isExpanded()){var d=Ext.KeyNav.prototype.doRelay.apply(this,arguments);if(!Ext.isIE&&Ext.EventManager.useKeydo
 wn){this.scope.fireKey(c)}return d}return true},forceKeyDown:true,defaultEventAction:"stopEvent"});this.queryDelay=Math.max(this.queryDelay||10,this.mode=="local"?10:250);this.dqTask=new Ext.util.DelayedTask(this.initQuery,this);if(this.typeAhead){this.taTask=new Ext.util.DelayedTask(this.onTypeAhead,this)}if(!this.enableKeyEvents){this.mon(this.el,"keyup",this.onKeyUp,this)}},onDestroy:function(){if(this.dqTask){this.dqTask.cancel();this.dqTask=null}this.bindStore(null);Ext.destroy(this.resizer,this.view,this.pageTb,this.list);Ext.destroyMembers(this,"hiddenField");Ext.form.ComboBox.superclass.onDestroy.call(this)},fireKey:function(a){if(!this.isExpanded()){Ext.form.ComboBox.superclass.fireKey.call(this,a)}},onResize:function(a,b){Ext.form.ComboBox.superclass.onResize.apply(this,arguments);if(!isNaN(a)&&this.isVisible()&&this.list){this.doResize(a)}else{this.bufferSize=a}},doResize:function(a){if(!Ext.isDefined(this.listWidth)){var b=Math.max(a,this.minListWidth);this.list.
 setWidth(b);this.innerList.setWidth(b-this.list.getFrameWidth("lr"))}},onEnable:function(){Ext.form.ComboBox.superclass.onEnable.apply(this,arguments);if(this.hiddenField){this.hiddenField.disabled=false}},onDisable:function(){Ext.form.ComboBox.superclass.onDisable.apply(this,arguments);if(this.hiddenField){this.hiddenField.disabled=true}},onBeforeLoad:function(){if(!this.hasFocus){return}this.innerList.update(this.loadingText?'<div class="loading-indicator">'+this.loadingText+"</div>":"");this.restrictHeight();this.selectedIndex=-1},onLoad:function(){if(!this.hasFocus){return}if(this.store.getCount()>0||this.listEmptyText){this.expand();this.restrictHeight();if(this.lastQuery==this.allQuery){if(this.editable){this.el.dom.select()}if(this.autoSelect!==false&&!this.selectByValue(this.value,true)){this.select(0,true)}}else{if(this.autoSelect!==false){this.selectNext()}if(this.typeAhead&&this.lastKey!=Ext.EventObject.BACKSPACE&&this.lastKey!=Ext.EventObject.DELETE){this.taTask.
 delay(this.typeAheadDelay)}}}else{this.collapse()}},onTypeAhead:function(){if(this.store.getCount()>0){var b=this.store.getAt(0);var c=b.data[this.displayField];var a=c.length;var d=this.getRawValue().length;if(d!=a){this.setRawValue(c);this.selectText(d,c.length)}}},assertValue:function(){var b=this.getRawValue(),a;if(this.valueField&&Ext.isDefined(this.value)){a=this.findRecord(this.valueField,this.value)}if(!a||a.get(this.displayField)!=b){a=this.findRecord(this.displayField,b)}if(!a&&this.forceSelection){if(b.length>0&&b!=this.emptyText){this.el.dom.value=Ext.value(this.lastSelectionText,"");this.applyEmptyText()}else{this.clearValue()}}else{if(a&&this.valueField){if(this.value==b){return}b=a.get(this.valueField||this.displayField)}this.setValue(b)}},onSelect:function(a,b){if(this.fireEvent("beforeselect",this,a,b)!==false){this.setValue(a.data[this.valueField||this.displayField]);this.collapse();this.fireEvent("select",this,a,b)}},getName:function(){var a=this.hiddenFie
 ld;return a&&a.name?a.name:this.hiddenName||Ext.form.ComboBox.superclass.getName.call(this)},getValue:function(){if(this.valueField){return Ext.isDefined(this.value)?this.value:""}else{return Ext.form.ComboBox.superclass.getValue.call(this)}},clearValue:function(){if(this.hiddenField){this.hiddenField.value=""}this.setRawValue("");this.lastSelectionText="";this.applyEmptyText();this.value=""},setValue:function(a){var c=a;if(this.valueField){var b=this.findRecord(this.valueField,a);if(b){c=b.data[this.displayField]}else{if(Ext.isDefined(this.valueNotFoundText)){c=this.valueNotFoundText}}}this.lastSelectionText=c;if(this.hiddenField){this.hiddenField.value=Ext.value(a,"")}Ext.form.ComboBox.superclass.setValue.call(this,c);this.value=a;return this},findRecord:function(c,b){var a;if(this.store.getCount()>0){this.store.each(function(d){if(d.data[c]==b){a=d;return false}})}return a},onViewMove:function(b,a){this.inKeyMode=false},onViewOver:function(d,b){if(this.inKeyMode){return}v
 ar c=this.view.findItemFromChild(b);if(c){var a=this.view.indexOf(c);this.select(a,false)}},onViewClick:function(b){var a=this.view.getSelectedIndexes()[0],c=this.store,d=c.getAt(a);if(d){this.onSelect(d,a)}else{this.collapse()}if(b!==false){this.el.focus()}},restrictHeight:function(){this.innerList.dom.style.height="";var b=this.innerList.dom,e=this.list.getFrameWidth("tb")+(this.resizable?this.handleHeight:0)+this.assetHeight,c=Math.max(b.clientHeight,b.offsetHeight,b.scrollHeight),a=this.getPosition()[1]-Ext.getBody().getScroll().top,g=Ext.lib.Dom.getViewHeight()-a-this.getSize().height,d=Math.max(a,g,this.minHeight||0)-this.list.shadowOffset-e-5;c=Math.min(c,d,this.maxHeight);this.innerList.setHeight(c);this.list.beginUpdate();this.list.setHeight(c+e);this.list.alignTo.apply(this.list,[this.el].concat(this.listAlign));this.list.endUpdate()},isExpanded:function(){return this.list&&this.list.isVisible()},selectByValue:function(a,c){if(!Ext.isEmpty(a,true)){var b=this.findR
 ecord(this.valueField||this.displayField,a);if(b){this.select(this.store.indexOf(b),c);return true}}return false},select:function(a,c){this.selectedIndex=a;this.view.select(a);if(c!==false){var b=this.view.getNode(a);if(b){this.innerList.scrollChildIntoView(b,false)}}},selectNext:function(){var a=this.store.getCount();if(a>0){if(this.selectedIndex==-1){this.select(0)}else{if(this.selectedIndex<a-1){this.select(this.selectedIndex+1)}}}},selectPrev:function(){var a=this.store.getCount();if(a>0){if(this.selectedIndex==-1){this.select(0)}else{if(this.selectedIndex!==0){this.select(this.selectedIndex-1)}}}},onKeyUp:function(b){var a=b.getKey();if(this.editable!==false&&this.readOnly!==true&&(a==b.BACKSPACE||!b.isSpecialKey())){this.lastKey=a;this.dqTask.delay(this.queryDelay)}Ext.form.ComboBox.superclass.onKeyUp.call(this,b)},validateBlur:function(){return !this.list||!this.list.isVisible()},initQuery:function(){this.doQuery(this.getRawValue())},beforeBlur:function(){this.assertV
 alue()},postBlur:function(){Ext.form.ComboBox.superclass.postBlur.call(this);this.collapse();this.inKeyMode=false},doQuery:function(c,b){c=Ext.isEmpty(c)?"":c;var a={query:c,forceAll:b,combo:this,cancel:false};if(this.fireEvent("beforequery",a)===false||a.cancel){return false}c=a.query;b=a.forceAll;if(b===true||(c.length>=this.minChars)){if(this.lastQuery!==c){this.lastQuery=c;if(this.mode=="local"){this.selectedIndex=-1;if(b){this.store.clearFilter()}else{this.store.filter(this.displayField,c)}this.onLoad()}else{this.store.baseParams[this.queryParam]=c;this.store.load({params:this.getParams(c)});this.expand()}}else{this.selectedIndex=-1;this.onLoad()}}},getParams:function(a){var b={},c=this.store.paramNames;if(this.pageSize){b[c.start]=0;b[c.limit]=this.pageSize}return b},collapse:function(){if(!this.isExpanded()){return}this.list.hide();Ext.getDoc().un("mousewheel",this.collapseIf,this);Ext.getDoc().un("mousedown",this.collapseIf,this);this.fireEvent("collapse",this)},coll
 apseIf:function(a){if(!this.isDestroyed&&!a.within(this.wrap)&&!a.within(this.list)){this.collapse()}},expand:function(){if(this.isExpanded()||!this.hasFocus){return}if(this.title||this.pageSize){this.assetHeight=0;if(this.title){this.assetHeight+=this.header.getHeight()}if(this.pageSize){this.assetHeight+=this.footer.getHeight()}}if(this.bufferSize){this.doResize(this.bufferSize);delete this.bufferSize}this.list.alignTo.apply(this.list,[this.el].concat(this.listAlign));this.list.setZIndex(this.getZIndex());this.list.show();if(Ext.isGecko2){this.innerList.setOverflow("auto")}this.mon(Ext.getDoc(),{scope:this,mousewheel:this.collapseIf,mousedown:this.collapseIf});this.fireEvent("expand",this)},onTriggerClick:function(){if(this.readOnly||this.disabled){return}if(this.isExpanded()){this.collapse();this.el.focus()}else{this.onFocus({});if(this.triggerAction=="all"){this.doQuery(this.allQuery,true)}else{this.doQuery(this.getRawValue())}this.el.focus()}}});Ext.reg("combo",Ext.form
 .ComboBox);Ext.form.Checkbox=Ext.extend(Ext.form.Field,{focusClass:undefined,fieldClass:"x-form-field",checked:false,boxLabel:"&#160;",defaultAutoCreate:{tag:"input",type:"checkbox",autocomplete:"off"},actionMode:"wrap",initComponent:function(){Ext.form.Checkbox.superclass.initComponent.call(this);this.addEvents("check")},onResize:function(){Ext.form.Checkbox.superclass.onResize.apply(this,arguments);if(!this.boxLabel&&!this.fieldLabel){this.el.alignTo(this.wrap,"c-c")}},initEvents:function(){Ext.form.Checkbox.superclass.initEvents.call(this);this.mon(this.el,{scope:this,click:this.onClick,change:this.onClick})},markInvalid:Ext.emptyFn,clearInvalid:Ext.emptyFn,onRender:function(b,a){Ext.form.Checkbox.superclass.onRender.call(this,b,a);if(this.inputValue!==undefined){this.el.dom.value=this.inputValue}this.wrap=this.el.wrap({cls:"x-form-check-wrap"});if(this.boxLabel){this.wrap.createChild({tag:"label",htmlFor:this.el.id,cls:"x-form-cb-label",html:this.boxLabel})}if(this.check
 ed){this.setValue(true)}else{this.checked=this.el.dom.checked}if(Ext.isIE&&!Ext.isStrict){this.wrap.repaint()}this.resizeEl=this.positionEl=this.wrap},onDestroy:function(){Ext.destroy(this.wrap);Ext.form.Checkbox.superclass.onDestroy.call(this)},initValue:function(){this.originalValue=this.getValue()},getValue:function(){if(this.rendered){return this.el.dom.checked}return this.checked},onClick:function(){if(this.el.dom.checked!=this.checked){this.setValue(this.el.dom.checked)}},setValue:function(a){var c=this.checked,b=this.inputValue;if(a===false){this.checked=false}else{this.checked=(a===true||a==="true"||a=="1"||(b?a==b:String(a).toLowerCase()=="on"))}if(this.rendered){this.el.dom.checked=this.checked;this.el.dom.defaultChecked=this.checked}if(c!=this.checked){this.fireEvent("check",this,this.checked);if(this.handler){this.handler.call(this.scope||this,this,this.checked)}}return this}});Ext.reg("checkbox",Ext.form.Checkbox);Ext.form.CheckboxGroup=Ext.extend(Ext.form.Field
 ,{columns:"auto",vertical:false,allowBlank:true,blankText:"You must select at least one item in this group",defaultType:"checkbox",groupCls:"x-form-check-group",initComponent:function(){this.addEvents("change");this.on("change",this.validate,this);Ext.form.CheckboxGroup.superclass.initComponent.call(this)},onRender:function(j,g){if(!this.el){var p={autoEl:{id:this.id},cls:this.groupCls,layout:"column",renderTo:j,bufferResize:false};var a={xtype:"container",defaultType:this.defaultType,layout:"form",defaults:{hideLabel:true,anchor:"100%"}};if(this.items[0].items){Ext.apply(p,{layoutConfig:{columns:this.items.length},defaults:this.defaults,items:this.items});for(var e=0,m=this.items.length;e<m;e++){Ext.applyIf(this.items[e],a)}}else{var d,n=[];if(typeof this.columns=="string"){this.columns=this.items.length}if(!Ext.isArray(this.columns)){var k=[];for(var e=0;e<this.columns;e++){k.push((100/this.columns)*0.01)}this.columns=k}d=this.columns.length;for(var e=0;e<d;e++){var b=Ext.
 apply({items:[]},a);b[this.columns[e]<=1?"columnWidth":"width"]=this.columns[e];if(this.defaults){b.defaults=Ext.apply(b.defaults||{},this.defaults)}n.push(b)}if(this.vertical){var r=Math.ceil(this.items.length/d),o=0;for(var e=0,m=this.items.length;e<m;e++){if(e>0&&e%r==0){o++}if(this.items[e].fieldLabel){this.items[e].hideLabel=false}n[o].items.push(this.items[e])}}else{for(var e=0,m=this.items.length;e<m;e++){var q=e%d;if(this.items[e].fieldLabel){this.items[e].hideLabel=false}n[q].items.push(this.items[e])}}Ext.apply(p,{layoutConfig:{columns:d},items:n})}this.panel=new Ext.Container(p);this.panel.ownerCt=this;this.el=this.panel.getEl();if(this.forId&&this.itemCls){var c=this.el.up(this.itemCls).child("label",true);if(c){c.setAttribute("htmlFor",this.forId)}}var h=this.panel.findBy(function(i){return i.isFormField},this);this.items=new Ext.util.MixedCollection();this.items.addAll(h)}Ext.form.CheckboxGroup.superclass.onRender.call(this,j,g)},initValue:function(){if(this.va
 lue){this.setValue.apply(this,this.buffered?this.value:[this.value]);delete this.buffered;delete this.value}},afterRender:function(){Ext.form.CheckboxGroup.superclass.afterRender.call(this);this.eachItem(function(a){a.on("check",this.fireChecked,this);a.inGroup=true})},doLayout:function(){if(this.rendered){this.panel.forceLayout=this.ownerCt.forceLayout;this.panel.doLayout()}},fireChecked:function(){var a=[];this.eachItem(function(b){if(b.checked){a.push(b)}});this.fireEvent("change",this,a)},getErrors:function(){var b=Ext.form.CheckboxGroup.superclass.getErrors.apply(this,arguments);if(!this.allowBlank){var a=true;this.eachItem(function(c){if(c.checked){return(a=false)}});if(a){b.push(this.blankText)}}return b},isDirty:function(){if(this.disabled||!this.rendered){return false}var a=false;this.eachItem(function(b){if(b.isDirty()){a=true;return false}});return a},setReadOnly:function(a){if(this.rendered){this.eachItem(function(b){b.setReadOnly(a)})}this.readOnly=a},onDisable:
 function(){this.eachItem(function(a){a.disable()})},onEnable:function(){this.eachItem(function(a){a.enable()})},onResize:function(a,b){this.panel.setSize(a,b);this.panel.doLayout()},reset:function(){if(this.originalValue){this.eachItem(function(a){if(a.setValue){a.setValue(false);a.originalValue=a.getValue()}});this.resetOriginal=true;this.setValue(this.originalValue);delete this.resetOriginal}else{this.eachItem(function(a){if(a.reset){a.reset()}})}(function(){this.clearInvalid()}).defer(50,this)},setValue:function(){if(this.rendered){this.onSetValue.apply(this,arguments)}else{this.buffered=true;this.value=arguments}return this},onSetValue:function(d,c){if(arguments.length==1){if(Ext.isArray(d)){Ext.each(d,function(h,e){if(Ext.isObject(h)&&h.setValue){h.setValue(true);if(this.resetOriginal===true){h.originalValue=h.getValue()}}else{var g=this.items.itemAt(e);if(g){g.setValue(h)}}},this)}else{if(Ext.isObject(d)){for(var a in d){var b=this.getBox(a);if(b){b.setValue(d[a])}}}el
 se{this.setValueForItem(d)}}}else{var b=this.getBox(d);if(b){b.setValue(c)}}},beforeDestroy:function(){Ext.destroy(this.panel);if(!this.rendered){Ext.destroy(this.items)}Ext.form.CheckboxGroup.superclass.beforeDestroy.call(this)},setValueForItem:function(a){a=String(a).split(",");this.eachItem(function(b){if(a.indexOf(b.inputValue)>-1){b.setValue(true)}})},getBox:function(b){var a=null;this.eachItem(function(c){if(b==c||c.dataIndex==b||c.id==b||c.getName()==b){a=c;return false}});return a},getValue:function(){var a=[];this.eachItem(function(b){if(b.checked){a.push(b)}});return a},eachItem:function(b,a){if(this.items&&this.items.each){this.items.each(b,a||this)}},getRawValue:Ext.emptyFn,setRawValue:Ext.emptyFn});Ext.reg("checkboxgroup",Ext.form.CheckboxGroup);Ext.form.CompositeField=Ext.extend(Ext.form.Field,{defaultMargins:"0 5 0 0",skipLastItemMargin:true,isComposite:true,combineErrors:true,labelConnector:", ",initComponent:function(){var g=[],b=this.items,e;for(var d=0,c=b
 .length;d<c;d++){e=b[d];if(!Ext.isEmpty(e.ref)){e.ref="../"+e.ref}g.push(e.fieldLabel);Ext.applyIf(e,this.defaults);if(!(d==c-1&&this.skipLastItemMargin)){Ext.applyIf(e,{margins:this.defaultMargins})}}this.fieldLabel=this.fieldLabel||this.buildLabel(g);this.fieldErrors=new Ext.util.MixedCollection(true,function(h){return h.field});this.fieldErrors.on({scope:this,add:this.updateInvalidMark,remove:this.updateInvalidMark,replace:this.updateInvalidMark});Ext.form.CompositeField.superclass.initComponent.apply(this,arguments);this.innerCt=new Ext.Container({layout:"hbox",items:this.items,cls:"x-form-composite",defaultMargins:"0 3 0 0",ownerCt:this});this.innerCt.ownerCt=undefined;var a=this.innerCt.findBy(function(h){return h.isFormField},this);this.items=new Ext.util.MixedCollection();this.items.addAll(a)},onRender:function(c,a){if(!this.el){var d=this.innerCt;d.render(c);this.el=d.getEl();if(this.combineErrors){this.eachItem(function(e){Ext.apply(e,{markInvalid:this.onFieldMarkI
 nvalid.createDelegate(this,[e],0),clearInvalid:this.onFieldClearInvalid.createDelegate(this,[e],0)})})}var b=this.el.parent().parent().child("label",true);if(b){b.setAttribute("for",this.items.items[0].id)}}Ext.form.CompositeField.superclass.onRender.apply(this,arguments)},onFieldMarkInvalid:function(d,c){var b=d.getName(),a={field:b,errorName:d.fieldLabel||b,error:c};this.fieldErrors.replace(b,a);if(!d.preventMark){d.el.addClass(d.invalidClass)}},onFieldClearInvalid:function(a){this.fieldErrors.removeKey(a.getName());a.el.removeClass(a.invalidClass)},updateInvalidMark:function(){var a=Ext.isIE6&&Ext.isStrict;if(this.fieldErrors.length==0){this.clearInvalid();if(a){this.clearInvalid.defer(50,this)}}else{var b=this.buildCombinedErrorMessage(this.fieldErrors.items);this.sortErrors();this.markInvalid(b);if(a){this.markInvalid(b)}}},validateValue:function(c,a){var b=true;this.eachItem(function(d){if(!d.isValid(a)){b=false}});return b},buildCombinedErrorMessage:function(e){var d=
 [],b;for(var c=0,a=e.length;c<a;c++){b=e[c];d.push(String.format("{0}: {1}",b.errorName,b.error))}return d.join("<br />")},sortErrors:function(){var a=this.items;this.fieldErrors.sort("ASC",function(g,d){var c=function(b){return function(i){return i.getName()==b}};var h=a.findIndexBy(c(g.field)),e=a.findIndexBy(c(d.field));return h<e?-1:1})},reset:function(){this.eachItem(function(a){a.reset()});(function(){this.clearInvalid()}).defer(50,this)},clearInvalidChildren:function(){this.eachItem(function(a){a.clearInvalid()})},buildLabel:function(a){return Ext.clean(a).join(this.labelConnector)},isDirty:function(){if(this.disabled||!this.rendered){return false}var a=false;this.eachItem(function(b){if(b.isDirty()){a=true;return false}});return a},eachItem:function(b,a){if(this.items&&this.items.each){this.items.each(b,a||this)}},onResize:function(e,c,a,d){var b=this.innerCt;if(this.rendered&&b.rendered){b.setSize(e,c)}Ext.form.CompositeField.superclass.onResize.apply(this,arguments
 )},doLayout:function(c,b){if(this.rendered){var a=this.innerCt;a.forceLayout=this.ownerCt.forceLayout;a.doLayout(c,b)}},beforeDestroy:function(){Ext.destroy(this.innerCt);Ext.form.CompositeField.superclass.beforeDestroy.call(this)},setReadOnly:function(a){if(a==undefined){a=true}a=!!a;if(this.rendered){this.eachItem(function(b){b.setReadOnly(a)})}this.readOnly=a},onShow:function(){Ext.form.CompositeField.superclass.onShow.call(this);this.doLayout()},onDisable:function(){this.eachItem(function(a){a.disable()})},onEnable:function(){this.eachItem(function(a){a.enable()})}});Ext.reg("compositefield",Ext.form.CompositeField);Ext.form.Radio=Ext.extend(Ext.form.Checkbox,{inputType:"radio",markInvalid:Ext.emptyFn,clearInvalid:Ext.emptyFn,getGroupValue:function(){var a=this.el.up("form")||Ext.getBody();var b=a.child('input[name="'+this.el.dom.name+'"]:checked',true);return b?b.value:null},setValue:function(b){var a,d,c;if(typeof b=="boolean"){Ext.form.Radio.superclass.setValue.call(t
 his,b)}else{if(this.rendered){a=this.getCheckEl();c=a.child('input[name="'+this.el.dom.name+'"][value="'+b+'"]',true);if(c){Ext.getCmp(c.id).setValue(true)}}}if(this.rendered&&this.checked){a=a||this.getCheckEl();d=this.getCheckEl().select('input[name="'+this.el.dom.name+'"]');d.each(function(e){if(e.dom.id!=this.id){Ext.getCmp(e.dom.id).setValue(false)}},this)}return this},getCheckEl:function(){if(this.inGroup){return this.el.up(".x-form-radio-group")}return this.el.up("form")||Ext.getBody()}});Ext.reg("radio",Ext.form.Radio);Ext.form.RadioGroup=Ext.extend(Ext.form.CheckboxGroup,{allowBlank:true,blankText:"You must select one item in this group",defaultType:"radio",groupCls:"x-form-radio-group",getValue:function(){var a=null;this.eachItem(function(b){if(b.checked){a=b;return false}});return a},onSetValue:function(c,b){if(arguments.length>1){var a=this.getBox(c);if(a){a.setValue(b);if(a.checked){this.eachItem(function(d){if(d!==a){d.setValue(false)}})}}}else{this.setValueFor
 Item(c)}},setValueForItem:function(a){a=String(a).split(",")[0];this.eachItem(function(b){b.setValue(a==b.inputValue)})},fireChecked:function(){if(!this.checkTask){this.checkTask=new Ext.util.DelayedTask(this.bufferChecked,this)}this.checkTask.delay(10)},bufferChecked:function(){var a=null;this.eachItem(function(b){if(b.checked){a=b;return false}});this.fireEvent("change",this,a)},onDestroy:function(){if(this.checkTask){this.checkTask.cancel();this.checkTask=null}Ext.form.RadioGroup.superclass.onDestroy.call(this)}});Ext.reg("radiogroup",Ext.form.RadioGroup);Ext.form.Hidden=Ext.extend(Ext.form.Field,{inputType:"hidden",shouldLayout:false,onRender:function(){Ext.form.Hidden.superclass.onRender.apply(this,arguments)},initEvents:function(){this.originalValue=this.getValue()},setSize:Ext.emptyFn,setWidth:Ext.emptyFn,setHeight:Ext.emptyFn,setPosition:Ext.emptyFn,setPagePosition:Ext.emptyFn,markInvalid:Ext.emptyFn,clearInvalid:Ext.emptyFn});Ext.reg("hidden",Ext.form.Hidden);Ext.fo
 rm.BasicForm=Ext.extend(Ext.util.Observable,{constructor:function(b,a){Ext.apply(this,a);if(Ext.isString(this.paramOrder)){this.paramOrder=this.paramOrder.split(/[\s,|]/)}this.items=new Ext.util.MixedCollection(false,function(c){return c.getItemId()});this.addEvents("beforeaction","actionfailed","actioncomplete");if(b){this.initEl(b)}Ext.form.BasicForm.superclass.constructor.call(this)},timeout:30,paramOrder:undefined,paramsAsHash:false,waitTitle:"Please Wait...",activeAction:null,trackResetOnLoad:false,initEl:function(a){this.el=Ext.get(a);this.id=this.el.id||Ext.id();if(!this.standardSubmit){this.el.on("submit",this.onSubmit,this)}this.el.addClass("x-form")},getEl:function(){return this.el},onSubmit:function(a){a.stopEvent()},destroy:function(a){if(a!==true){this.items.each(function(b){Ext.destroy(b)});Ext.destroy(this.el)}this.items.clear();this.purgeListeners()},isValid:function(){var a=true;this.items.each(function(b){if(!b.validate()){a=false}});return a},isDirty:funct
 ion(){var a=false;this.items.each(function(b){if(b.isDirty()){a=true;return false}});return a},doAction:function(b,a){if(Ext.isString(b)){b=new Ext.form.Action.ACTION_TYPES[b](this,a)}if(this.fireEvent("beforeaction",this,b)!==false){this.beforeAction(b);b.run.defer(100,b)}return this},submit:function(b){b=b||{};if(this.standardSubmit){var a=b.clientValidation===false||this.isValid();if(a){var c=this.el.dom;if(this.url&&Ext.isEmpty(c.action)){c.action=this.url}c.submit()}return a}var d=String.format("{0}submit",this.api?"direct":"");this.doAction(d,b);return this},load:function(a){var b=String.format("{0}load",this.api?"direct":"");this.doAction(b,a);return this},updateRecord:function(b){b.beginEdit();var a=b.fields,d,c;a.each(function(e){d=this.findField(e.name);if(d){c=d.getValue();if(Ext.type(c)!==false&&c.getGroupValue){c=c.getGroupValue()}else{if(d.eachItem){c=[];d.eachItem(function(g){c.push(g.getValue())})}}b.set(e.name,c)}},this);b.endEdit();return this},loadRecord:f
 unction(a){this.setValues(a.data);return this},beforeAction:function(a){this.items.each(function(c){if(c.isFormField&&c.syncValue){c.syncValue()}});var b=a.options;if(b.waitMsg){if(this.waitMsgTarget===true){this.el.mask(b.waitMsg,"x-mask-loading")}else{if(this.waitMsgTarget){this.waitMsgTarget=Ext.get(this.waitMsgTarget);this.waitMsgTarget.mask(b.waitMsg,"x-mask-loading")}else{Ext.MessageBox.wait(b.waitMsg,b.waitTitle||this.waitTitle)}}}},afterAction:function(a,c){this.activeAction=null;var b=a.options;if(b.waitMsg){if(this.waitMsgTarget===true){this.el.unmask()}else{if(this.waitMsgTarget){this.waitMsgTarget.unmask()}else{Ext.MessageBox.updateProgress(1);Ext.MessageBox.hide()}}}if(c){if(b.reset){this.reset()}Ext.callback(b.success,b.scope,[this,a]);this.fireEvent("actioncomplete",this,a)}else{Ext.callback(b.failure,b.scope,[this,a]);this.fireEvent("actionfailed",this,a)}},findField:function(c){var b=this.items.get(c);if(!Ext.isObject(b)){var a=function(d){if(d.isFormField){
 if(d.dataIndex==c||d.id==c||d.getName()==c){b=d;return false}else{if(d.isComposite){return d.items.each(a)}else{if(d instanceof Ext.form.CheckboxGroup&&d.rendered){return d.eachItem(a)}}}}};this.items.each(a)}return b||null},markInvalid:function(h){if(Ext.isArray(h)){for(var c=0,a=h.length;c<a;c++){var b=h[c];var d=this.findField(b.id);if(d){d.markInvalid(b.msg)}}}else{var e,g;for(g in h){if(!Ext.isFunction(h[g])&&(e=this.findField(g))){e.markInvalid(h[g])}}}return this},setValues:function(c){if(Ext.isArray(c)){for(var d=0,a=c.length;d<a;d++){var b=c[d];var e=this.findField(b.id);if(e){e.setValue(b.value);if(this.trackResetOnLoad){e.originalValue=e.getValue()}}}}else{var g,h;for(h in c){if(!Ext.isFunction(c[h])&&(g=this.findField(h))){g.setValue(c[h]);if(this.trackResetOnLoad){g.originalValue=g.getValue()}}}}return this},getValues:function(b){var a=Ext.lib.Ajax.serializeForm(this.el.dom);if(b===true){return a}return Ext.urlDecode(a)},getFieldValues:function(a){var d={},e,b,c
 ;this.items.each(function(g){if(!g.disabled&&(a!==true||g.isDirty())){e=g.getName();b=d[e];c=g.getValue();if(Ext.isDefined(b)){if(Ext.isArray(b)){d[e].push(c)}else{d[e]=[b,c]}}else{d[e]=c}}});return d},clearInvalid:function(){this.items.each(function(a){a.clearInvalid()});return this},reset:function(){this.items.each(function(a){a.reset()});return this},add:function(){this.items.addAll(Array.prototype.slice.call(arguments,0));return this},remove:function(a){this.items.remove(a);return this},cleanDestroyed:function(){this.items.filterBy(function(a){return !!a.isDestroyed}).each(this.remove,this)},render:function(){this.items.each(function(a){if(a.isFormField&&!a.rendered&&document.getElementById(a.id)){a.applyToMarkup(a.id)}});return this},applyToFields:function(a){this.items.each(function(b){Ext.apply(b,a)});return this},applyIfToFields:function(a){this.items.each(function(b){Ext.applyIf(b,a)});return this},callFieldMethod:function(b,a){a=a||[];this.items.each(function(c){if
 (Ext.isFunction(c[b])){c[b].apply(c,a)}});return this}});Ext.BasicForm=Ext.form.BasicForm;Ext.FormPanel=Ext.extend(Ext.Panel,{minButtonWidth:75,labelAlign:"left",monitorValid:false,monitorPoll:200,layout:"form",initComponent:function(){this.form=this.createForm();Ext.FormPanel.superclass.initComponent.call(this);this.bodyCfg={tag:"form",cls:this.baseCls+"-body",method:this.method||"POST",id:this.formId||Ext.id()};if(this.fileUpload){this.bodyCfg.enctype="multipart/form-data"}this.initItems();this.addEvents("clientvalidation");this.relayEvents(this.form,["beforeaction","actionfailed","actioncomplete"])},createForm:function(){var a=Ext.applyIf({listeners:{}},this.initialConfig);return new Ext.form.BasicForm(null,a)},initFields:function(){var c=this.form;var a=this;var b=function(d){if(a.isField(d)){c.add(d)}else{if(d.findBy&&d!=a){a.applySettings(d);if(d.items&&d.items.each){d.items.each(b,this)}}}};this.items.each(b,this)},applySettings:function(b){var a=b.ownerCt;Ext.applyIf
 (b,{labelAlign:a.labelAlign,labelWidth:a.labelWidth,itemCls:a.itemCls})},getLayoutTarget:function(){return this.form.el},getForm:function(){return this.form},onRender:function(b,a){this.initFields();Ext.FormPanel.superclass.onRender.call(this,b,a);this.form.initEl(this.body)},beforeDestroy:function(){this.stopMonitoring();this.form.destroy(true);Ext.FormPanel.superclass.beforeDestroy.call(this)},isField:function(a){return !!a.setValue&&!!a.getValue&&!!a.markInvalid&&!!a.clearInvalid},initEvents:function(){Ext.FormPanel.superclass.initEvents.call(this);this.on({scope:this,add:this.onAddEvent,remove:this.onRemoveEvent});if(this.monitorValid){this.startMonitoring()}},onAdd:function(a){Ext.FormPanel.superclass.onAdd.call(this,a);this.processAdd(a)},onAddEvent:function(a,b){if(a!==this){this.processAdd(b)}},processAdd:function(a){if(this.isField(a)){this.form.add(a)}else{if(a.findBy){this.applySettings(a);this.form.add.apply(this.form,a.findBy(this.isField))}}},onRemove:function(
 a){Ext.FormPanel.superclass.onRemove.call(this,a);this.processRemove(a)},onRemoveEvent:function(a,b){if(a!==this){this.processRemove(b)}},processRemove:function(a){if(!this.destroying){if(this.isField(a)){this.form.remove(a)}else{if(a.findBy){Ext.each(a.findBy(this.isField),this.form.remove,this.form);this.form.cleanDestroyed()}}}},startMonitoring:function(){if(!this.validTask){this.validTask=new Ext.util.TaskRunner();this.validTask.start({run:this.bindHandler,interval:this.monitorPoll||200,scope:this})}},stopMonitoring:function(){if(this.validTask){this.validTask.stopAll();this.validTask=null}},load:function(){this.form.load.apply(this.form,arguments)},onDisable:function(){Ext.FormPanel.superclass.onDisable.call(this);if(this.form){this.form.items.each(function(){this.disable()})}},onEnable:function(){Ext.FormPanel.superclass.onEnable.call(this);if(this.form){this.form.items.each(function(){this.enable()})}},bindHandler:function(){var e=true;this.form.items.each(function(g)
 {if(!g.isValid(true)){e=false;return false}});if(this.fbar){var b=this.fbar.items.items;for(var d=0,a=b.length;d<a;d++){var c=b[d];if(c.formBind===true&&c.disabled===e){c.setDisabled(!e)}}}this.fireEvent("clientvalidation",this,e)}});Ext.reg("form",Ext.FormPanel);Ext.form.FormPanel=Ext.FormPanel;Ext.form.FieldSet=Ext.extend(Ext.Panel,{baseCls:"x-fieldset",layout:"form",animCollapse:false,onRender:function(b,a){if(!this.el){this.el=document.createElement("fieldset");this.el.id=this.id;if(this.title||this.header||this.checkboxToggle){this.el.appendChild(document.createElement("legend")).className=this.baseCls+"-header"}}Ext.form.FieldSet.superclass.onRender.call(this,b,a);if(this.checkboxToggle){var c=typeof this.checkboxToggle=="object"?this.checkboxToggle:{tag:"input",type:"checkbox",name:this.checkboxName||this.id+"-checkbox"};this.checkbox=this.header.insertFirst(c);this.checkbox.dom.checked=!this.collapsed;this.mon(this.checkbox,"click",this.onCheckClick,this)}},onCollaps
 e:function(a,b){if(this.checkbox){this.checkbox.dom.checked=false}Ext.form.FieldSet.superclass.onCollapse.call(this,a,b)},onExpand:function(a,b){if(this.checkbox){this.checkbox.dom.checked=true}Ext.form.FieldSet.superclass.onExpand.call(this,a,b)},onCheckClick:function(){this[this.checkbox.dom.checked?"expand":"collapse"]()}});Ext.reg("fieldset",Ext.form.FieldSet);Ext.form.HtmlEditor=Ext.extend(Ext.form.Field,{enableFormat:true,enableFontSize:true,enableColors:true,enableAlignments:true,enableLists:true,enableSourceEdit:true,enableLinks:true,enableFont:true,createLinkText:"Please enter the URL for the link:",defaultLinkValue:"http://",fontFamilies:["Arial","Courier New","Tahoma","Times New Roman","Verdana"],defaultFont:"tahoma",defaultValue:(Ext.isOpera||Ext.isIE6)?"&#160;":"&#8203;",actionMode:"wrap",validationEvent:false,deferHeight:true,initialized:false,activated:false,sourceEditMode:false,onFocus:Ext.emptyFn,iframePad:3,hideMode:"offsets",defaultAutoCreate:{tag:"textare
 a",style:"width:500px;height:300px;",autocomplete:"off"},initComponent:function(){this.addEvents("initialize","activate","beforesync","beforepush","sync","push","editmodechange");Ext.form.HtmlEditor.superclass.initComponent.call(this)},createFontOptions:function(){var d=[],b=this.fontFamilies,c,g;for(var e=0,a=b.length;e<a;e++){c=b[e];g=c.toLowerCase();d.push('<option value="',g,'" style="font-family:',c,';"',(this.defaultFont==g?' selected="true">':">"),c,"</option>")}return d.join("")},createToolbar:function(e){var c=[];var a=Ext.QuickTips&&Ext.QuickTips.isEnabled();function d(j,h,i){return{itemId:j,cls:"x-btn-icon",iconCls:"x-edit-"+j,enableToggle:h!==false,scope:e,handler:i||e.relayBtnCmd,clickEvent:"mousedown",tooltip:a?e.buttonTips[j]||undefined:undefined,overflowText:e.buttonTips[j].title||undefined,tabIndex:-1}}if(this.enableFont&&!Ext.isSafari2){var g=new Ext.Toolbar.Item({autoEl:{tag:"select",cls:"x-font-select",html:this.createFontOptions()}});c.push(g,"-")}if(thi
 s.enableFormat){c.push(d("bold"),d("italic"),d("underline"))}if(this.enableFontSize){c.push("-",d("increasefontsize",false,this.adjustFont),d("decreasefontsize",false,this.adjustFont))}if(this.enableColors){c.push("-",{itemId:"forecolor",cls:"x-btn-icon",iconCls:"x-edit-forecolor",clickEvent:"mousedown",tooltip:a?e.buttonTips.forecolor||undefined:undefined,tabIndex:-1,menu:new Ext.menu.ColorMenu({allowReselect:true,focus:Ext.emptyFn,value:"000000",plain:true,listeners:{scope:this,select:function(i,h){this.execCmd("forecolor",Ext.isWebKit||Ext.isIE?"#"+h:h);this.deferFocus()}},clickEvent:"mousedown"})},{itemId:"backcolor",cls:"x-btn-icon",iconCls:"x-edit-backcolor",clickEvent:"mousedown",tooltip:a?e.buttonTips.backcolor||undefined:undefined,tabIndex:-1,menu:new Ext.menu.ColorMenu({focus:Ext.emptyFn,value:"FFFFFF",plain:true,allowReselect:true,listeners:{scope:this,select:function(i,h){if(Ext.isGecko){this.execCmd("useCSS",false);this.execCmd("hilitecolor",h);this.execCmd("use
 CSS",true);this.deferFocus()}else{this.execCmd(Ext.isOpera?"hilitecolor":"backcolor",Ext.isWebKit||Ext.isIE?"#"+h:h);this.deferFocus()}}},clickEvent:"mousedown"})})}if(this.enableAlignments){c.push("-",d("justifyleft"),d("justifycenter"),d("justifyright"))}if(!Ext.isSafari2){if(this.enableLinks){c.push("-",d("createlink",false,this.createLink))}if(this.enableLists){c.push("-",d("insertorderedlist"),d("insertunorderedlist"))}if(this.enableSourceEdit){c.push("-",d("sourceedit",true,function(h){this.toggleSourceEdit(!this.sourceEditMode)}))}}var b=new Ext.Toolbar({renderTo:this.wrap.dom.firstChild,items:c});if(g){this.fontSelect=g.el;this.mon(this.fontSelect,"change",function(){var h=this.fontSelect.dom.value;this.relayCmd("fontname",h);this.deferFocus()},this)}this.mon(b.el,"click",function(h){h.preventDefault()});this.tb=b;this.tb.doLayout()},onDisable:function(){this.wrap.mask();Ext.form.HtmlEditor.superclass.onDisable.call(this)},onEnable:function(){this.wrap.unmask();Ext.f
 orm.HtmlEditor.superclass.onEnable.call(this)},setReadOnly:function(b){Ext.form.HtmlEditor.superclass.setReadOnly.call(this,b);if(this.initialized){if(Ext.isIE){this.getEditorBody().contentEditable=!b}else{this.setDesignMode(!b)}var a=this.getEditorBody();if(a){a.style.cursor=this.readOnly?"default":"text"}this.disableItems(b)}},getDocMarkup:function(){var a=Ext.fly(this.iframe).getHeight()-this.iframePad*2;return String.format('<html><head><style type="text/css">body{border: 0; margin: 0; padding: {0}px; height: {1}px; cursor: text}</style></head><body></body></html>',this.iframePad,a)},getEditorBody:function(){var a=this.getDoc();return a.body||a.documentElement},getDoc:function(){return Ext.isIE?this.getWin().document:(this.iframe.contentDocument||this.getWin().document)},getWin:function(){return Ext.isIE?this.iframe.contentWindow:window.frames[this.iframe.name]},onRender:function(b,a){Ext.form.HtmlEditor.superclass.onRender.call(this,b,a);this.el.dom.style.border="0 none
 ";this.el.dom.setAttribute("tabIndex",-1);this.el.addClass("x-hidden");if(Ext.isIE){this.el.applyStyles("margin-top:-1px;margin-bottom:-1px;")}this.wrap=this.el.wrap({cls:"x-html-editor-wrap",cn:{cls:"x-html-editor-tb"}});this.createToolbar(this);this.disableItems(true);this.tb.doLayout();this.createIFrame();if(!this.width){var c=this.el.getSize();this.setSize(c.width,this.height||c.height)}this.resizeEl=this.positionEl=this.wrap},createIFrame:function(){var a=document.createElement("iframe");a.name=Ext.id();a.frameBorder="0";a.style.overflow="auto";a.src=Ext.SSL_SECURE_URL;this.wrap.dom.appendChild(a);this.iframe=a;this.monitorTask=Ext.TaskMgr.start({run:this.checkDesignMode,scope:this,interval:100})},initFrame:function(){Ext.TaskMgr.stop(this.monitorTask);var b=this.getDoc();this.win=this.getWin();b.open();b.write(this.getDocMarkup());b.close();var a={run:function(){var c=this.getDoc();if(c.body||c.readyState=="complete"){Ext.TaskMgr.stop(a);this.setDesignMode(true);this.i
 nitEditor.defer(10,this)}},interval:10,duration:10000,scope:this};Ext.TaskMgr.start(a)},checkDesignMode:function(){if(this.wrap&&this.wrap.dom.offsetWidth){var a=this.getDoc();if(!a){return}if(!a.editorInitialized||this.getDesignMode()!="on"){this.initFrame()}}},setDesignMode:function(b){var a=this.getDoc();if(a){if(this.readOnly){b=false}a.designMode=(/on|true/i).test(String(b).toLowerCase())?"on":"off"}},getDesignMode:function(){var a=this.getDoc();if(!a){return""}return String(a.designMode).toLowerCase()},disableItems:function(a){if(this.fontSelect){this.fontSelect.dom.disabled=a}this.tb.items.each(function(b){if(b.getItemId()!="sourceedit"){b.setDisabled(a)}})},onResize:function(b,c){Ext.form.HtmlEditor.superclass.onResize.apply(this,arguments);if(this.el&&this.iframe){if(Ext.isNumber(b)){var e=b-this.wrap.getFrameWidth("lr");this.el.setWidth(e);this.tb.setWidth(e);this.iframe.style.width=Math.max(e,0)+"px"}if(Ext.isNumber(c)){var a=c-this.wrap.getFrameWidth("tb")-this.t
 b.el.getHeight();this.el.setHeight(a);this.iframe.style.height=Math.max(a,0)+"px";var d=this.getEditorBody();if(d){d.style.height=Math.max((a-(this.iframePad*2)),0)+"px"}}}},toggleSourceEdit:function(b){var d,a;if(b===undefined){b=!this.sourceEditMode}this.sourceEditMode=b===true;var c=this.tb.getComponent("sourceedit");if(c.pressed!==this.sourceEditMode){c.toggle(this.sourceEditMode);if(!c.xtbHidden){return}}if(this.sourceEditMode){this.previousSize=this.getSize();d=Ext.get(this.iframe).getHeight();this.disableItems(true);this.syncValue();this.iframe.className="x-hidden";this.el.removeClass("x-hidden");this.el.dom.removeAttribute("tabIndex");this.el.focus();this.el.dom.style.height=d+"px"}else{a=parseInt(this.el.dom.style.height,10);if(this.initialized){this.disableItems(this.readOnly)}this.pushValue();this.iframe.className="";this.el.addClass("x-hidden");this.el.dom.setAttribute("tabIndex",-1);this.deferFocus();this.setSize(this.previousSize);delete this.previousSize;this.
 iframe.style.height=a+"px"}this.fireEvent("editmodechange",this,this.sourceEditMode)},createLink:function(){var a=prompt(this.createLinkText,this.defaultLinkValue);if(a&&a!="http://"){this.relayCmd("createlink",a)}},initEvents:function(){this.originalValue=this.getValue()},markInvalid:Ext.emptyFn,clearInvalid:Ext.emptyFn,setValue:function(a){Ext.form.HtmlEditor.superclass.setValue.call(this,a);this.pushValue();return this},cleanHtml:function(a){a=String(a);if(Ext.isWebKit){a=a.replace(/\sclass="(?:Apple-style-span|khtml-block-placeholder)"/gi,"")}if(a.charCodeAt(0)==this.defaultValue.replace(/\D/g,"")){a=a.substring(1)}return a},syncValue:function(){if(this.initialized){var d=this.getEditorBody();var c=d.innerHTML;if(Ext.isWebKit){var b=d.getAttribute("style");var a=b.match(/text-align:(.*?);/i);if(a&&a[1]){c='<div style="'+a[0]+'">'+c+"</div>"}}c=this.cleanHtml(c);if(this.fireEvent("beforesync",this,c)!==false){this.el.dom.value=c;this.fireEvent("sync",this,c)}}},getValue:f
 unction(){this[this.sourceEditMode?"pushValue":"syncValue"]();return Ext.form.HtmlEditor.superclass.getValue.call(this)},pushValue:function(){if(this.initialized){var a=this.el.dom.value;if(!this.activated&&a.length<1){a=this.defaultValue}if(this.fireEvent("beforepush",this,a)!==false){this.getEditorBody().innerHTML=a;if(Ext.isGecko){this.setDesignMode(false);this.setDesignMode(true)}this.fireEvent("push",this,a)}}},deferFocus:function(){this.focus.defer(10,this)},focus:function(){if(this.win&&!this.sourceEditMode){this.win.focus()}else{this.el.focus()}},initEditor:function(){try{var c=this.getEditorBody(),a=this.el.getStyles("font-size","font-family","background-image","background-repeat","background-color","color"),g,b;a["background-attachment"]="fixed";c.bgProperties="fixed";Ext.DomHelper.applyStyles(c,a);g=this.getDoc();if(g){try{Ext.EventManager.removeAll(g)}catch(d){}}b=this.onEditorEvent.createDelegate(this);Ext.EventManager.on(g,{mousedown:b,dblclick:b,click:b,keyup:
 b,buffer:100});if(Ext.isGecko){Ext.EventManager.on(g,"keypress",this.applyCommand,this)}if(Ext.isIE||Ext.isWebKit||Ext.isOpera){Ext.EventManager.on(g,"keydown",this.fixKeys,this)}g.editorInitialized=true;this.initialized=true;this.pushValue();this.setReadOnly(this.readOnly);this.fireEvent("initialize",this)}catch(d){}},beforeDestroy:function(){if(this.monitorTask){Ext.TaskMgr.stop(this.monitorTask)}if(this.rendered){Ext.destroy(this.tb);var b=this.getDoc();if(b){try{Ext.EventManager.removeAll(b);for(var c in b){delete b[c]}}catch(a){}}if(this.wrap){this.wrap.dom.innerHTML="";this.wrap.remove()}}Ext.form.HtmlEditor.superclass.beforeDestroy.call(this)},onFirstFocus:function(){this.activated=true;this.disableItems(this.readOnly);if(Ext.isGecko){this.win.focus();var a=this.win.getSelection();if(!a.focusNode||a.focusNode.nodeType!=3){var b=a.getRangeAt(0);b.selectNodeContents(this.getEditorBody());b.collapse(true);this.deferFocus()}try{this.execCmd("useCSS",true);this.execCmd("st
 yleWithCSS",false)}catch(c){}}this.fireEvent("activate",this)},adjustFont:function(b){var d=b.getItemId()=="increasefontsize"?1:-1,c=this.getDoc(),a=parseInt(c.queryCommandValue("FontSize")||2,10);if((Ext.isSafari&&!Ext.isSafari2)||Ext.isChrome||Ext.isAir){if(a<=10){a=1+d}else{if(a<=13){a=2+d}else{if(a<=16){a=3+d}else{if(a<=18){a=4+d}else{if(a<=24){a=5+d}else{a=6+d}}}}}a=a.constrain(1,6)}else{if(Ext.isSafari){d*=2}a=Math.max(1,a+d)+(Ext.isSafari?"px":0)}this.execCmd("FontSize",a)},onEditorEvent:function(a){this.updateToolbar()},updateToolbar:function(){if(this.readOnly){return}if(!this.activated){this.onFirstFocus();return}var b=this.tb.items.map,c=this.getDoc();if(this.enableFont&&!Ext.isSafari2){var a=(c.queryCommandValue("FontName")||this.defaultFont).toLowerCase();if(a!=this.fontSelect.dom.value){this.fontSelect.dom.value=a}}if(this.enableFormat){b.bold.toggle(c.queryCommandState("bold"));b.italic.toggle(c.queryCommandState("italic"));b.underline.toggle(c.queryCommandSta
 te("underline"))}if(this.enableAlignments){b.justifyleft.toggle(c.queryCommandState("justifyleft"));b.justifycenter.toggle(c.queryCommandState("justifycenter"));b.justifyright.toggle(c.queryCommandState("justifyright"))}if(!Ext.isSafari2&&this.enableLists){b.insertorderedlist.toggle(c.queryCommandState("insertorderedlist"));b.insertunorderedlist.toggle(c.queryCommandState("insertunorderedlist"))}Ext.menu.MenuMgr.hideAll();this.syncValue()},relayBtnCmd:function(a){this.relayCmd(a.getItemId())},relayCmd:function(b,a){(function(){this.focus();this.execCmd(b,a);this.updateToolbar()}).defer(10,this)},execCmd:function(b,a){var c=this.getDoc();c.execCommand(b,false,a===undefined?null:a);this.syncValue()},applyCommand:function(b){if(b.ctrlKey){var d=b.getCharCode(),a;if(d>0){d=String.fromCharCode(d);switch(d){case"b":a="bold";break;case"i":a="italic";break;case"u":a="underline";break}if(a){this.win.focus();this.execCmd(a);this.deferFocus();b.preventDefault()}}}},insertAtCursor:funct
 ion(c){if(!this.activated){return}if(Ext.isIE){this.win.focus();var b=this.getDoc(),a=b.selection.createRange();if(a){a.pasteHTML(c);this.syncValue();this.deferFocus()}}else{this.win.focus();this.execCmd("InsertHTML",c);this.deferFocus()}},fixKeys:function(){if(Ext.isIE){return function(g){var a=g.getKey(),d=this.getDoc(),b;if(a==g.TAB){g.stopEvent();b=d.selection.createRange();if(b){b.collapse(true);b.pasteHTML("&nbsp;&nbsp;&nbsp;&nbsp;");this.deferFocus()}}else{if(a==g.ENTER){b=d.selection.createRange();if(b){var c=b.parentElement();if(!c||c.tagName.toLowerCase()!="li"){g.stopEvent();b.pasteHTML("<br />");b.collapse(false);b.select()}}}}}}else{if(Ext.isOpera){return function(b){var a=b.getKey();if(a==b.TAB){b.stopEvent();this.win.focus();this.execCmd("InsertHTML","&nbsp;&nbsp;&nbsp;&nbsp;");this.deferFocus()}}}else{if(Ext.isWebKit){return function(b){var a=b.getKey();if(a==b.TAB){b.stopEvent();this.execCmd("InsertText","\t");this.deferFocus()}else{if(a==b.ENTER){b.stopEven
 t();this.execCmd("InsertHtml","<br /><br />");this.deferFocus()}}}}}}}(),getToolbar:function(){return this.tb},buttonTips:{bold:{title:"Bold (Ctrl+B)",text:"Make the selected text bold.",cls:"x-html-editor-tip"},italic:{title:"Italic (Ctrl+I)",text:"Make the selected text italic.",cls:"x-html-editor-tip"},underline:{title:"Underline (Ctrl+U)",text:"Underline the selected text.",cls:"x-html-editor-tip"},increasefontsize:{title:"Grow Text",text:"Increase the font size.",cls:"x-html-editor-tip"},decreasefontsize:{title:"Shrink Text",text:"Decrease the font size.",cls:"x-html-editor-tip"},backcolor:{title:"Text Highlight Color",text:"Change the background color of the selected text.",cls:"x-html-editor-tip"},forecolor:{title:"Font Color",text:"Change the color of the selected text.",cls:"x-html-editor-tip"},justifyleft:{title:"Align Text Left",text:"Align text to the left.",cls:"x-html-editor-tip"},justifycenter:{title:"Center Text",text:"Center text in the editor.",cls:"x-html-
 editor-tip"},justifyright:{title:"Align Text Right",text:"Align text to the right.",cls:"x-html-editor-tip"},insertunorderedlist:{title:"Bullet List",text:"Start a bulleted list.",cls:"x-html-editor-tip"},insertorderedlist:{title:"Numbered List",text:"Start a numbered list.",cls:"x-html-editor-tip"},createlink:{title:"Hyperlink",text:"Make the selected text a hyperlink.",cls:"x-html-editor-tip"},sourceedit:{title:"Source Edit",text:"Switch to source editing mode.",cls:"x-html-editor-tip"}}});Ext.reg("htmleditor",Ext.form.HtmlEditor);Ext.form.TimeField=Ext.extend(Ext.form.ComboBox,{minValue:undefined,maxValue:undefined,minText:"The time in this field must be equal to or after {0}",maxText:"The time in this field must be equal to or before {0}",invalidText:"{0} is not a valid time",format:"g:i A",altFormats:"g:ia|g:iA|g:i a|g:i A|h:i|g:i|H:i|ga|ha|gA|h a|g a|g A|gi|hi|gia|hia|g|H|gi a|hi a|giA|hiA|gi A|hi A",increment:15,mode:"local",triggerAction:"all",typeAhead:false,initDat
 e:"1/1/2008",initDateFormat:"j/n/Y",initComponent:function(){if(Ext.isDefined(this.minValue)){this.setMinValue(this.minValue,true)}if(Ext.isDefined(this.maxValue)){this.setMaxValue(this.maxValue,true)}if(!this.store){this.generateStore(true)}Ext.form.TimeField.superclass.initComponent.call(this)},setMinValue:function(b,a){this.setLimit(b,true,a);return this},setMaxValue:function(b,a){this.setLimit(b,false,a);return this},generateStore:function(b){var c=this.minValue||new Date(this.initDate).clearTime(),a=this.maxValue||new Date(this.initDate).clearTime().add("mi",(24*60)-1),d=[];while(c<=a){d.push(c.dateFormat(this.format));c=c.add("mi",this.increment)}this.bindStore(d,b)},setLimit:function(b,g,a){var e;if(Ext.isString(b)){e=this.parseDate(b)}else{if(Ext.isDate(b)){e=b}}if(e){var c=new Date(this.initDate).clearTime();c.setHours(e.getHours(),e.getMinutes(),e.getSeconds(),e.getMilliseconds());this[g?"minValue":"maxValue"]=c;if(!a){this.generateStore()}}},getValue:function(){va
 r a=Ext.form.TimeField.superclass.getValue.call(this);return this.formatDate(this.parseDate(a))||""},setValue:function(a){return Ext.form.TimeField.superclass.setValue.call(this,this.formatDate(this.parseDate(a)))},validateValue:Ext.form.DateField.prototype.validateValue,formatDate:Ext.form.DateField.prototype.formatDate,parseDate:function(h){if(!h||Ext.isDate(h)){return h}var j=this.initDate+" ",g=this.initDateFormat+" ",b=Date.parseDate(j+h,g+this.format),c=this.altFormats;if(!b&&c){if(!this.altFormatsArray){this.altFormatsArray=c.split("|")}for(var e=0,d=this.altFormatsArray,a=d.length;e<a&&!b;e++){b=Date.parseDate(j+h,g+d[e])}}return b}});Ext.reg("timefield",Ext.form.TimeField);Ext.form.SliderField=Ext.extend(Ext.form.Field,{useTips:true,tipText:null,actionMode:"wrap",initComponent:function(){var b=Ext.copyTo({id:this.id+"-slider"},this.initialConfig,["vertical","minValue","maxValue","decimalPrecision","keyIncrement","increment","clickToChange","animate"]);if(this.useTip
 s){var a=this.tipText?{getText:this.tipText}:{};b.plugins=[new Ext.slider.Tip(a)]}this.slider=new Ext.Slider(b);Ext.form.SliderField.superclass.initComponent.call(this)},onRender:function(b,a){this.autoCreate={id:this.id,name:this.name,type:"hidden",tag:"input"};Ext.form.SliderField.superclass.onRender.call(this,b,a);this.wrap=this.el.wrap({cls:"x-form-field-wrap"});this.resizeEl=this.positionEl=this.wrap;this.slider.render(this.wrap)},onResize:function(b,c,d,a){Ext.form.SliderField.superclass.onResize.call(this,b,c,d,a);this.slider.setSize(b,c)},initEvents:function(){Ext.form.SliderField.superclass.initEvents.call(this);this.slider.on("change",this.onChange,this)},onChange:function(b,a){this.setValue(a,undefined,true)},onEnable:function(){Ext.form.SliderField.superclass.onEnable.call(this);this.slider.enable()},onDisable:function(){Ext.form.SliderField.superclass.onDisable.call(this);this.slider.disable()},beforeDestroy:function(){Ext.destroy(this.slider);Ext.form.SliderFie
 ld.superclass.beforeDestroy.call(this)},alignErrorIcon:function(){this.errorIcon.alignTo(this.slider.el,"tl-tr",[2,0])},setMinValue:function(a){this.slider.setMinValue(a);return this},setMaxValue:function(a){this.slider.setMaxValue(a);return this},setValue:function(c,b,a){if(!a){this.slider.setValue(c,b)}return Ext.form.SliderField.superclass.setValue.call(this,this.slider.getValue())},getValue:function(){return this.slider.getValue()}});Ext.reg("sliderfield",Ext.form.SliderField);Ext.form.Label=Ext.extend(Ext.BoxComponent,{onRender:function(b,a){if(!this.el){this.el=document.createElement("label");this.el.id=this.getId();this.el.innerHTML=this.text?Ext.util.Format.htmlEncode(this.text):(this.html||"");if(this.forId){this.el.setAttribute("for",this.forId)}}Ext.form.Label.superclass.onRender.call(this,b,a)},setText:function(a,b){var c=b===false;this[!c?"text":"html"]=a;delete this[c?"text":"html"];if(this.rendered){this.el.dom.innerHTML=b!==false?Ext.util.Format.htmlEncode(a)
 :a}return this}});Ext.reg("label",Ext.form.Label);Ext.form.Action=function(b,a){this.form=b;this.options=a||{}};Ext.form.Action.CLIENT_INVALID="client";Ext.form.Action.SERVER_INVALID="server";Ext.form.Action.CONNECT_FAILURE="connect";Ext.form.Action.LOAD_FAILURE="load";Ext.form.Action.prototype={type:"default",run:function(a){},success:function(a){},handleResponse:function(a){},failure:function(a){this.response=a;this.failureType=Ext.form.Action.CONNECT_FAILURE;this.form.afterAction(this,false)},processResponse:function(a){this.response=a;if(!a.responseText&&!a.responseXML){return true}this.result=this.handleResponse(a);return this.result},decodeResponse:function(a){try{return Ext.decode(a.responseText)}catch(b){return false}},getUrl:function(c){var a=this.options.url||this.form.url||this.form.el.dom.action;if(c){var b=this.getParams();if(b){a=Ext.urlAppend(a,b)}}return a},getMethod:function(){return(this.options.method||this.form.method||this.form.el.dom.method||"POST").toU
 pperCase()},getParams:function(){var a=this.form.baseParams;var b=this.options.params;if(b){if(typeof b=="object"){b=Ext.urlEncode(Ext.applyIf(b,a))}else{if(typeof b=="string"&&a){b+="&"+Ext.urlEncode(a)}}}else{if(a){b=Ext.urlEncode(a)}}return b},createCallback:function(a){var a=a||{};return{success:this.success,failure:this.failure,scope:this,timeout:(a.timeout*1000)||(this.form.timeout*1000),upload:this.form.fileUpload?this.success:undefined}}};Ext.form.Action.Submit=function(b,a){Ext.form.Action.Submit.superclass.constructor.call(this,b,a)};Ext.extend(Ext.form.Action.Submit,Ext.form.Action,{type:"submit",run:function(){var e=this.options,g=this.getMethod(),d=g=="GET";if(e.clientValidation===false||this.form.isValid()){if(e.submitEmptyText===false){var a=this.form.items,c=[],b=function(h){if(h.el.getValue()==h.emptyText){c.push(h);h.el.dom.value=""}if(h.isComposite&&h.rendered){h.items.each(b)}};a.each(b)}Ext.Ajax.request(Ext.apply(this.createCallback(e),{form:this.form.el
 .dom,url:this.getUrl(d),method:g,headers:e.headers,params:!d?this.getParams():null,isUpload:this.form.fileUpload}));if(e.submitEmptyText===false){Ext.each(c,function(h){if(h.applyEmptyText){h.applyEmptyText()}})}}else{if(e.clientValidation!==false){this.failureType=Ext.form.Action.CLIENT_INVALID;this.form.afterAction(this,false)}}},success:function(b){var a=this.processResponse(b);if(a===true||a.success){this.form.afterAction(this,true);return}if(a.errors){this.form.markInvalid(a.errors)}this.failureType=Ext.form.Action.SERVER_INVALID;this.form.afterAction(this,false)},handleResponse:function(c){if(this.form.errorReader){var b=this.form.errorReader.read(c);var g=[];if(b.records){for(var d=0,a=b.records.length;d<a;d++){var e=b.records[d];g[d]=e.data}}if(g.length<1){g=null}return{success:b.success,errors:g}}return this.decodeResponse(c)}});Ext.form.Action.Load=function(b,a){Ext.form.Action.Load.superclass.constructor.call(this,b,a);this.reader=this.form.reader};Ext.extend(Ext.
 form.Action.Load,Ext.form.Action,{type:"load",run:function(){Ext.Ajax.request(Ext.apply(this.createCallback(this.options),{method:this.getMethod(),url:this.getUrl(false),headers:this.options.headers,params:this.getParams()}))},success:function(b){var a=this.processResponse(b);if(a===true||!a.success||!a.data){this.failureType=Ext.form.Action.LOAD_FAILURE;this.form.afterAction(this,false);return}this.form.clearInvalid();this.form.setValues(a.data);this.form.afterAction(this,true)},handleResponse:function(b){if(this.form.reader){var a=this.form.reader.read(b);var c=a.records&&a.records[0]?a.records[0].data:null;return{success:a.success,data:c}}return this.decodeResponse(b)}});Ext.form.Action.DirectLoad=Ext.extend(Ext.form.Action.Load,{constructor:function(b,a){Ext.form.Action.DirectLoad.superclass.constructor.call(this,b,a)},type:"directload",run:function(){var a=this.getParams();a.push(this.success,this);this.form.api.load.apply(window,a)},getParams:function(){var c=[],h={};v
 ar e=this.form.baseParams;var g=this.options.params;Ext.apply(h,g,e);var b=this.form.paramOrder;if(b){for(var d=0,a=b.length;d<a;d++){c.push(h[b[d]])}}else{if(this.form.paramsAsHash){c.push(h)}}return c},processResponse:function(a){this.result=a;return a},success:function(a,b){if(b.type==Ext.Direct.exceptions.SERVER){a={}}Ext.form.Action.DirectLoad.superclass.success.call(this,a)}});Ext.form.Action.DirectSubmit=Ext.extend(Ext.form.Action.Submit,{constructor:function(b,a){Ext.form.Action.DirectSubmit.superclass.constructor.call(this,b,a)},type:"directsubmit",run:function(){var a=this.options;if(a.clientValidation===false||this.form.isValid()){this.success.params=this.getParams();this.form.api.submit(this.form.el.dom,this.success,this)}else{if(a.clientValidation!==false){this.failureType=Ext.form.Action.CLIENT_INVALID;this.form.afterAction(this,false)}}},getParams:function(){var c={};var a=this.form.baseParams;var b=this.options.params;Ext.apply(c,b,a);return c},processRespons
 e:function(a){this.result=a;return a},success:function(a,b){if(b.type==Ext.Direct.exceptions.SERVER){a={}}Ext.form.Action.DirectSubmit.superclass.success.call(this,a)}});Ext.form.Action.ACTION_TYPES={load:Ext.form.Action.Load,submit:Ext.form.Action.Submit,directload:Ext.form.Action.DirectLoad,directsubmit:Ext.form.Action.DirectSubmit};Ext.form.VTypes=function(){var c=/^[a-zA-Z_]+$/,d=/^[a-zA-Z0-9_]+$/,b=/^(\w+)([\-+.\'][\w]+)*@(\w[\-\w]*\.){1,5}([A-Za-z]){2,6}$/,a=/(((^https?)|(^ftp)):\/\/([\-\w]+\.)+\w{2,3}(\/[%\-\w]+(\.\w{2,})?)*(([\w\-\.\?\\\/+@&#;`~=%!]*)(\.\w{2,})?)*\/?)/i;return{email:function(e){return b.test(e)},emailText:'This field should be an e-mail address in the format "user at example.com"',emailMask:/[a-z0-9_\.\-\+\'@]/i,url:function(e){return a.test(e)},urlText:'This field should be a URL in the format "http://www.example.com"',alpha:function(e){return c.test(e)},alphaText:"This field should only contain letters and _",alphaMask:/[a-z_]/i,alphanum:function(e){r
 eturn d.test(e)},alphanumText:"This field should only contain letters, numbers and _",alphanumMask:/[a-z0-9_]/i}}();Ext.grid.GridPanel=Ext.extend(Ext.Panel,{autoExpandColumn:false,autoExpandMax:1000,autoExpandMin:50,columnLines:false,ddText:"{0} selected row{1}",deferRowRender:true,enableColumnHide:true,enableColumnMove:true,enableDragDrop:false,enableHdMenu:true,loadMask:false,minColumnWidth:25,stripeRows:false,trackMouseOver:true,stateEvents:["columnmove","columnresize","sortchange","groupchange"],view:null,bubbleEvents:[],rendered:false,viewReady:false,initComponent:function(){Ext.grid.GridPanel.superclass.initComponent.call(this);if(this.columnLines){this.cls=(this.cls||"")+" x-grid-with-col-lines"}this.autoScroll=false;this.autoWidth=false;if(Ext.isArray(this.columns)){this.colModel=new Ext.grid.ColumnModel(this.columns);delete this.columns}if(this.ds){this.store=this.ds;delete this.ds}if(this.cm){this.colModel=this.cm;delete this.cm}if(this.sm){this.selModel=this.sm;de
 lete this.sm}this.store=Ext.StoreMgr.lookup(this.store);this.addEvents("click","dblclick","contextmenu","mousedown","mouseup","mouseover","mouseout","keypress","keydown","cellmousedown","rowmousedown","headermousedown","groupmousedown","rowbodymousedown","containermousedown","cellclick","celldblclick","rowclick","rowdblclick","headerclick","headerdblclick","groupclick","groupdblclick","containerclick","containerdblclick","rowbodyclick","rowbodydblclick","rowcontextmenu","cellcontextmenu","headercontextmenu","groupcontextmenu","containercontextmenu","rowbodycontextmenu","bodyscroll","columnresize","columnmove","sortchange","groupchange","reconfigure","viewready")},onRender:function(d,a){Ext.grid.GridPanel.superclass.onRender.apply(this,arguments);var e=this.getGridEl();this.el.addClass("x-grid-panel");this.mon(e,{scope:this,mousedown:this.onMouseDown,click:this.onClick,dblclick:this.onDblClick,contextmenu:this.onContextMenu});this.relayEvents(e,["mousedown","mouseup","mouseov
 er","mouseout","keypress","keydown"]);var b=this.getView();b.init(this);b.render();this.getSelectionModel().init(this)},initEvents:function(){Ext.grid.GridPanel.superclass.initEvents.call(this);if(this.loadMask){this.loadMask=new Ext.LoadMask(this.bwrap,Ext.apply({store:this.store},this.loadMask))}},initStateEvents:function(){Ext.grid.GridPanel.superclass.initStateEvents.call(this);this.mon(this.colModel,"hiddenchange",this.saveState,this,{delay:100})},applyState:function(a){var k=this.colModel,g=a.columns,j=this.store,m,h,l;if(g){for(var d=0,e=g.length;d<e;d++){m=g[d];h=k.getColumnById(m.id);if(h){l=k.getIndexById(m.id);k.setState(l,{hidden:m.hidden,width:m.width,sortable:m.sortable});if(l!=d){k.moveColumn(l,d)}}}}if(j){m=a.sort;if(m){j[j.remoteSort?"setDefaultSort":"sort"](m.field,m.direction)}m=a.group;if(j.groupBy){if(m){j.groupBy(m)}else{j.clearGrouping()}}}var b=Ext.apply({},a);delete b.columns;delete b.sort;Ext.grid.GridPanel.superclass.applyState.call(this,b)},getSta
 te:function(){var g={columns:[]},b=this.store,e,a;for(var d=0,h;(h=this.colModel.config[d]);d++){g.columns[d]={id:h.id,width:h.width};if(h.hidden){g.columns[d].hidden=true}if(h.sortable){g.columns[d].sortable=true}}if(b){e=b.getSortState();if(e){g.sort=e}if(b.getGroupState){a=b.getGroupState();if(a){g.group=a}}}return g},afterRender:function(){Ext.grid.GridPanel.superclass.afterRender.call(this);var a=this.view;this.on("bodyresize",a.layout,a);a.layout(true);if(this.deferRowRender){if(!this.deferRowRenderTask){this.deferRowRenderTask=new Ext.util.DelayedTask(a.afterRender,this.view)}this.deferRowRenderTask.delay(10)}else{a.afterRender()}this.viewReady=true},reconfigure:function(a,b){var c=this.rendered;if(c){if(this.loadMask){this.loadMask.destroy();this.loadMask=new Ext.LoadMask(this.bwrap,Ext.apply({},{store:a},this.initialConfig.loadMask))}}if(this.view){this.view.initData(a,b)}this.store=a;this.colModel=b;if(c){this.view.refresh(true)}this.fireEvent("reconfigure",this,a,
 b)},onDestroy:function(){if(this.deferRowRenderTask&&this.deferRowRenderTask.cancel){this.deferRowRenderTask.cancel()}if(this.rendered){Ext.destroy(this.view,this.loadMask)}else{if(this.store&&this.store.autoDestroy){this.store.destroy()}}Ext.destroy(this.colModel,this.selModel);this.store=this.selModel=this.colModel=this.view=this.loadMask=null;Ext.grid.GridPanel.superclass.onDestroy.call(this)},processEvent:function(a,b){this.view.processEvent(a,b)},onClick:function(a){this.processEvent("click",a)},onMouseDown:function(a){this.processEvent("mousedown",a)},onContextMenu:function(b,a){this.processEvent("contextmenu",b)},onDblClick:function(a){this.processEvent("dblclick",a)},walkCells:function(k,c,b,e,j){var i=this.colModel,g=i.getColumnCount(),a=this.store,h=a.getCount(),d=true;if(b<0){if(c<0){k--;d=false}while(k>=0){if(!d){c=g-1}d=false;while(c>=0){if(e.call(j||this,k,c,i)===true){return[k,c]}c--}k--}}else{if(c>=g){k++;d=false}while(k<h){if(!d){c=0}d=false;while(c<g){if(e.
 call(j||this,k,c,i)===true){return[k,c]}c++}k++}}return null},getGridEl:function(){return this.body},stopEditing:Ext.emptyFn,getSelectionModel:function(){if(!this.selModel){this.selModel=new Ext.grid.RowSelectionModel(this.disableSelection?{selectRow:Ext.emptyFn}:null)}return this.selModel},getStore:function(){return this.store},getColumnModel:function(){return this.colModel},getView:function(){if(!this.view){this.view=new Ext.grid.GridView(this.viewConfig)}return this.view},getDragDropText:function(){var a=this.selModel.getCount();return String.format(this.ddText,a,a==1?"":"s")}});Ext.reg("grid",Ext.grid.GridPanel);Ext.grid.PivotGrid=Ext.extend(Ext.grid.GridPanel,{aggregator:"sum",renderer:undefined,initComponent:function(){Ext.grid.PivotGrid.superclass.initComponent.apply(this,arguments);this.initAxes();this.enableColumnResize=false;this.viewConfig=Ext.apply(this.viewConfig||{},{forceFit:true});this.colModel=new Ext.grid.ColumnModel({})},getAggregator:function(){if(typeof
 this.aggregator=="string"){return Ext.grid.PivotAggregatorMgr.types[this.aggregator]}else{return this.aggregator}},setAggregator:function(a){this.aggregator=a},setMeasure:function(a){this.measure=a},setLeftAxis:function(b,a){this.leftAxis=b;if(a){this.view.refresh()}},setTopAxis:function(b,a){this.topAxis=b;if(a){this.view.refresh()}},initAxes:function(){var a=Ext.grid.PivotAxis;if(!(this.leftAxis instanceof a)){this.setLeftAxis(new a({orientation:"vertical",dimensions:this.leftAxis||[],store:this.store}))}if(!(this.topAxis instanceof a)){this.setTopAxis(new a({orientation:"horizontal",dimensions:this.topAxis||[],store:this.store}))}},extractData:function(){var c=this.store.data.items,s=c.length,q=[],h,g,e,d;if(s==0){return[]}var l=this.leftAxis.getTuples(),o=l.length,m=this.topAxis.getTuples(),a=m.length,b=this.getAggregator();for(g=0;g<s;g++){h=c[g];for(e=0;e<o;e++){q[e]=q[e]||[];if(l[e].matcher(h)===true){for(d=0;d<a;d++){q[e][d]=q[e][d]||[];if(m[d].matcher(h)){q[e][d].pu
 sh(h)}}}}}var n=q.length,p,r;for(g=0;g<n;g++){r=q[g];p=r.length;for(e=0;e<p;e++){q[g][e]=b(q[g][e],this.measure)}}return q},getView:function(){if(!this.view){this.view=new Ext.grid.PivotGridView(this.viewConfig)}return this.view}});Ext.reg("pivotgrid",Ext.grid.PivotGrid);Ext.grid.PivotAggregatorMgr=new Ext.AbstractManager();Ext.grid.PivotAggregatorMgr.registerType("sum",function(a,c){var e=a.length,d=0,b;for(b=0;b<e;b++){d+=a[b].get(c)}return d});Ext.grid.PivotAggregatorMgr.registerType("avg",function(a,c){var e=a.length,d=0,b;for(b=0;b<e;b++){d+=a[b].get(c)}return(d/e)||"n/a"});Ext.grid.PivotAggregatorMgr.registerType("min",function(a,c){var e=[],d=a.length,b;for(b=0;b<d;b++){e.push(a[b].get(c))}return Math.min.apply(this,e)||"n/a"});Ext.grid.PivotAggregatorMgr.registerType("max",function(a,c){var e=[],d=a.length,b;for(b=0;b<d;b++){e.push(a[b].get(c))}return Math.max.apply(this,e)||"n/a"});Ext.grid.PivotAggregatorMgr.registerType("count",function(a,b){return a.length});Ext.
 grid.GridView=Ext.extend(Ext.util.Observable,{deferEmptyText:true,scrollOffset:undefined,autoFill:false,forceFit:false,sortClasses:["sort-asc","sort-desc"],sortAscText:"Sort Ascending",sortDescText:"Sort Descending",columnsText:"Columns",selectedRowClass:"x-grid3-row-selected",borderWidth:2,tdClass:"x-grid3-cell",hdCls:"x-grid3-hd",markDirty:true,cellSelectorDepth:4,rowSelectorDepth:10,rowBodySelectorDepth:10,cellSelector:"td.x-grid3-cell",rowSelector:"div.x-grid3-row",rowBodySelector:"div.x-grid3-row-body",firstRowCls:"x-grid3-row-first",lastRowCls:"x-grid3-row-last",rowClsRe:/(?:^|\s+)x-grid3-row-(first|last|alt)(?:\s+|$)/g,headerMenuOpenCls:"x-grid3-hd-menu-open",rowOverCls:"x-grid3-row-over",constructor:function(a){Ext.apply(this,a);this.addEvents("beforerowremoved","beforerowsinserted","beforerefresh","rowremoved","rowsinserted","rowupdated","refresh");Ext.grid.GridView.superclass.constructor.call(this)},masterTpl:new Ext.Template('<div class="x-grid3" hidefocus="true">
 ','<div class="x-grid3-viewport">','<div class="x-grid3-header">','<div class="x-grid3-header-inner">','<div class="x-grid3-header-offset" style="{ostyle}">{header}</div>',"</div>",'<div class="x-clear"></div>',"</div>",'<div class="x-grid3-scroller">','<div class="x-grid3-body" style="{bstyle}">{body}</div>','<a href="#" class="x-grid3-focus" tabIndex="-1"></a>',"</div>","</div>",'<div class="x-grid3-resize-marker">&#160;</div>','<div class="x-grid3-resize-proxy">&#160;</div>',"</div>"),headerTpl:new Ext.Template('<table border="0" cellspacing="0" cellpadding="0" style="{tstyle}">',"<thead>",'<tr class="x-grid3-hd-row">{cells}</tr>',"</thead>","</table>"),bodyTpl:new Ext.Template("{rows}"),cellTpl:new Ext.Template('<td class="x-grid3-col x-grid3-cell x-grid3-td-{id} {css}" style="{style}" tabIndex="0" {cellAttr}>','<div class="x-grid3-cell-inner x-grid3-col-{id}" unselectable="on" {attr}>{value}</div>',"</td>"),initTemplates:function(){var c=this.templates||{},d,b,g=new Ext
 .Template('<td class="x-grid3-hd x-grid3-cell x-grid3-td-{id} {css}" style="{style}">','<div {tooltip} {attr} class="x-grid3-hd-inner x-grid3-hd-{id}" unselectable="on" style="{istyle}">',this.grid.enableHdMenu?'<a class="x-grid3-hd-btn" href="#"></a>':"","{value}",'<img alt="" class="x-grid3-sort-icon" src="',Ext.BLANK_IMAGE_URL,'" />',"</div>","</td>"),a=['<tr class="x-grid3-row-body-tr" style="{bodyStyle}">','<td colspan="{cols}" class="x-grid3-body-cell" tabIndex="0" hidefocus="on">','<div class="x-grid3-row-body">{body}</div>',"</td>","</tr>"].join(""),e=['<table class="x-grid3-row-table" border="0" cellspacing="0" cellpadding="0" style="{tstyle}">',"<tbody>","<tr>{cells}</tr>",this.enableRowBody?a:"","</tbody>","</table>"].join("");Ext.applyIf(c,{hcell:g,cell:this.cellTpl,body:this.bodyTpl,header:this.headerTpl,master:this.masterTpl,row:new Ext.Template('<div class="x-grid3-row {alt}" style="{tstyle}">'+e+"</div>"),rowInner:new Ext.Template(e)});for(b in c){d=c[b];if(d
 &&Ext.isFunction(d.compile)&&!d.compiled){d.disableFormats=true;d.compile()}}this.templates=c;this.colRe=new RegExp("x-grid3-td-([^\\s]+)","")},fly:function(a){if(!this._flyweight){this._flyweight=new Ext.Element.Flyweight(document.body)}this._flyweight.dom=a;return this._flyweight},getEditorParent:function(){return this.scroller.dom},initElements:function(){var b=Ext.Element,d=Ext.get(this.grid.getGridEl().dom.firstChild),e=new b(d.child("div.x-grid3-viewport")),c=new b(e.child("div.x-grid3-header")),a=new b(e.child("div.x-grid3-scroller"));if(this.grid.hideHeaders){c.setDisplayed(false)}if(this.forceFit){a.setStyle("overflow-x","hidden")}Ext.apply(this,{el:d,mainWrap:e,scroller:a,mainHd:c,innerHd:c.child("div.x-grid3-header-inner").dom,mainBody:new b(b.fly(a).child("div.x-grid3-body")),focusEl:new b(b.fly(a).child("a")),resizeMarker:new b(d.child("div.x-grid3-resize-marker")),resizeProxy:new b(d.child("div.x-grid3-resize-proxy"))});this.focusEl.swallowEvent("click",true)},
 getRows:function(){return this.hasRows()?this.mainBody.dom.childNodes:[]},findCell:function(a){if(!a){return false}return this.fly(a).findParent(this.cellSelector,this.cellSelectorDepth)},findCellIndex:function(d,c){var b=this.findCell(d),a;if(b){a=this.fly(b).hasClass(c);if(!c||a){return this.getCellIndex(b)}}return false},getCellIndex:function(b){if(b){var a=b.className.match(this.colRe);if(a&&a[1]){return this.cm.getIndexById(a[1])}}return false},findHeaderCell:function(b){var a=this.findCell(b);return a&&this.fly(a).hasClass(this.hdCls)?a:null},findHeaderIndex:function(a){return this.findCellIndex(a,this.hdCls)},findRow:function(a){if(!a){return false}return this.fly(a).findParent(this.rowSelector,this.rowSelectorDepth)},findRowIndex:function(a){var b=this.findRow(a);return b?b.rowIndex:false},findRowBody:function(a){if(!a){return false}return this.fly(a).findParent(this.rowBodySelector,this.rowBodySelectorDepth)},getRow:function(a){return this.getRows()[a]},getCell:func
 tion(b,a){return Ext.fly(this.getRow(b)).query(this.cellSelector)[a]},getHeaderCell:function(a){return this.mainHd.dom.getElementsByTagName("td")[a]},addRowClass:function(b,a){var c=this.getRow(b);if(c){this.fly(c).addClass(a)}},removeRowClass:function(c,a){var b=this.getRow(c);if(b){this.fly(b).removeClass(a)}},removeRow:function(a){Ext.removeNode(this.getRow(a));this.syncFocusEl(a)},removeRows:function(c,a){var b=this.mainBody.dom,d;for(d=c;d<=a;d++){Ext.removeNode(b.childNodes[c])}this.syncFocusEl(c)},getScrollState:function(){var a=this.scroller.dom;return{left:a.scrollLeft,top:a.scrollTop}},restoreScroll:function(a){var b=this.scroller.dom;b.scrollLeft=a.left;b.scrollTop=a.top},scrollToTop:function(){var a=this.scroller.dom;a.scrollTop=0;a.scrollLeft=0},syncScroll:function(){this.syncHeaderScroll();var a=this.scroller.dom;this.grid.fireEvent("bodyscroll",a.scrollLeft,a.scrollTop)},syncHeaderScroll:function(){var a=this.innerHd,b=this.scroller.dom.scrollLeft;a.scrollLeft
 =b;a.scrollLeft=b},updateSortIcon:function(d,c){var a=this.sortClasses,b=a[c=="DESC"?1:0],e=this.mainHd.select("td").removeClass(a);e.item(d).addClass(b)},updateAllColumnWidths:function(){var e=this.getTotalWidth(),k=this.cm.getColumnCount(),m=this.getRows(),g=m.length,b=[],l,a,h,d,c;for(d=0;d<k;d++){b[d]=this.getColumnWidth(d);this.getHeaderCell(d).style.width=b[d]}this.updateHeaderWidth();for(d=0;d<g;d++){l=m[d];l.style.width=e;a=l.firstChild;if(a){a.style.width=e;h=a.rows[0];for(c=0;c<k;c++){h.childNodes[c].style.width=b[c]}}}this.onAllColumnWidthsUpdated(b,e)},updateColumnWidth:function(d,b){var c=this.getColumnWidth(d),j=this.getTotalWidth(),h=this.getHeaderCell(d),a=this.getRows(),e=a.length,l,g,k;this.updateHeaderWidth();h.style.width=c;for(g=0;g<e;g++){l=a[g];k=l.firstChild;l.style.width=j;if(k){k.style.width=j;k.rows[0].childNodes[d].style.width=c}}this.onColumnWidthUpdated(d,c,j)},updateColumnHidden:function(b,j){var h=this.getTotalWidth(),k=j?"none":"",g=this.getH
 eaderCell(b),a=this.getRows(),d=a.length,l,c,e;this.updateHeaderWidth();g.style.display=k;for(e=0;e<d;e++){l=a[e];l.style.width=h;c=l.firstChild;if(c){c.style.width=h;c.rows[0].childNodes[b].style.display=k}}this.onColumnHiddenUpdated(b,j,h);delete this.lastViewWidth;this.layout()},doRender:function(d,v,m,a,r,t){var h=this.templates,c=h.cell,y=h.row,o=r-1,b="width:"+this.getTotalWidth()+";",k=[],l=[],n={tstyle:b},q={},w=v.length,x,g,e,u,s,p;for(s=0;s<w;s++){e=v[s];l=[];p=s+a;for(u=0;u<r;u++){g=d[u];q.id=g.id;q.css=u===0?"x-grid3-cell-first ":(u==o?"x-grid3-cell-last ":"");q.attr=q.cellAttr="";q.style=g.style;q.value=g.renderer.call(g.scope,e.data[g.name],q,e,p,u,m);if(Ext.isEmpty(q.value)){q.value="&#160;"}if(this.markDirty&&e.dirty&&typeof e.modified[g.name]!="undefined"){q.css+=" x-grid3-dirty-cell"}l[l.length]=c.apply(q)}x=[];if(t&&((p+1)%2===0)){x[0]="x-grid3-row-alt"}if(e.dirty){x[1]=" x-grid3-dirty-row"}n.cols=r;if(this.getRowClass){x[2]=this.getRowClass(e,p,n,m)}n.alt
 =x.join(" ");n.cells=l.join("");k[k.length]=y.apply(n)}return k.join("")},processRows:function(a,g){if(!this.ds||this.ds.getCount()<1){return}var d=this.getRows(),c=d.length,e,b;g=g||!this.grid.stripeRows;a=a||0;for(b=0;b<c;b++){e=d[b];if(e){e.rowIndex=b;if(!g){e.className=e.className.replace(this.rowClsRe," ");if((b+1)%2===0){e.className+=" x-grid3-row-alt"}}}}if(a===0){Ext.fly(d[0]).addClass(this.firstRowCls)}Ext.fly(d[c-1]).addClass(this.lastRowCls)},afterRender:function(){if(!this.ds||!this.cm){return}this.mainBody.dom.innerHTML=this.renderBody()||"&#160;";this.processRows(0,true);if(this.deferEmptyText!==true){this.applyEmptyText()}this.grid.fireEvent("viewready",this.grid)},afterRenderUI:function(){var a=this.grid;this.initElements();Ext.fly(this.innerHd).on("click",this.handleHdDown,this);this.mainHd.on({scope:this,mouseover:this.handleHdOver,mouseout:this.handleHdOut,mousemove:this.handleHdMove});this.scroller.on("scroll",this.syncScroll,this);if(a.enableColumnResize
 !==false){this.splitZone=new Ext.grid.GridView.SplitDragZone(a,this.mainHd.dom)}if(a.enableColumnMove){this.columnDrag=new Ext.grid.GridView.ColumnDragZone(a,this.innerHd);this.columnDrop=new Ext.grid.HeaderDropZone(a,this.mainHd.dom)}if(a.enableHdMenu!==false){this.hmenu=new Ext.menu.Menu({id:a.id+"-hctx"});this.hmenu.add({itemId:"asc",text:this.sortAscText,cls:"xg-hmenu-sort-asc"},{itemId:"desc",text:this.sortDescText,cls:"xg-hmenu-sort-desc"});if(a.enableColumnHide!==false){this.colMenu=new Ext.menu.Menu({id:a.id+"-hcols-menu"});this.colMenu.on({scope:this,beforeshow:this.beforeColMenuShow,itemclick:this.handleHdMenuClick});this.hmenu.add("-",{itemId:"columns",hideOnClick:false,text:this.columnsText,menu:this.colMenu,iconCls:"x-cols-icon"})}this.hmenu.on("itemclick",this.handleHdMenuClick,this)}if(a.trackMouseOver){this.mainBody.on({scope:this,mouseover:this.onRowOver,mouseout:this.onRowOut})}if(a.enableDragDrop||a.enableDrag){this.dragZone=new Ext.grid.GridDragZone(a,{dd
 Group:a.ddGroup||"GridDD"})}this.updateHeaderSortState()},renderUI:function(){var a=this.templates;return a.master.apply({body:a.body.apply({rows:"&#160;"}),header:this.renderHeaders(),ostyle:"width:"+this.getOffsetWidth()+";",bstyle:"width:"+this.getTotalWidth()+";"})},processEvent:function(b,h){var i=h.getTarget(),a=this.grid,d=this.findHeaderIndex(i),k,j,c,g;a.fireEvent(b,h);if(d!==false){a.fireEvent("header"+b,a,d,h)}else{k=this.findRowIndex(i);if(k!==false){j=this.findCellIndex(i);if(j!==false){c=a.colModel.getColumnAt(j);if(a.fireEvent("cell"+b,a,k,j,h)!==false){if(!c||(c.processEvent&&(c.processEvent(b,h,a,k,j)!==false))){a.fireEvent("row"+b,a,k,h)}}}else{if(a.fireEvent("row"+b,a,k,h)!==false){(g=this.findRowBody(i))&&a.fireEvent("rowbody"+b,a,k,h)}}}else{a.fireEvent("container"+b,a,h)}}},layout:function(j){if(!this.mainBody){return}var a=this.grid,d=a.getGridEl(),c=d.getSize(true),i=c.width,b=c.height,h=this.scroller,g,e,k;if(i<20||b<20){return}if(a.autoHeight){g=h.d
 om.style;g.overflow="visible";if(Ext.isWebKit){g.position="static"}}else{this.el.setSize(i,b);e=this.mainHd.getHeight();k=b-e;h.setSize(i,k);if(this.innerHd){this.innerHd.style.width=(i)+"px"}}if(this.forceFit||(j===true&&this.autoFill)){if(this.lastViewWidth!=i){this.fitColumns(false,false);this.lastViewWidth=i}}else{this.autoExpand();this.syncHeaderScroll()}this.onLayout(i,k)},onLayout:function(a,b){},onColumnWidthUpdated:function(c,a,b){},onAllColumnWidthsUpdated:function(a,b){},onColumnHiddenUpdated:function(b,c,a){},updateColumnText:function(a,b){},afterMove:function(a){},init:function(a){this.grid=a;this.initTemplates();this.initData(a.store,a.colModel);this.initUI(a)},getColumnId:function(a){return this.cm.getColumnId(a)},getOffsetWidth:function(){return(this.cm.getTotalWidth()+this.getScrollOffset())+"px"},getScrollOffset:function(){return Ext.num(this.scrollOffset,Ext.getScrollBarWidth())},renderHeaders:function(){var e=this.cm,g=this.templates,a=g.hcell,d={},h=e.ge
 tColumnCount(),j=h-1,k=[],c,b;for(c=0;c<h;c++){if(c==0){b="x-grid3-cell-first "}else{b=c==j?"x-grid3-cell-last ":""}d={id:e.getColumnId(c),value:e.getColumnHeader(c)||"",style:this.getColumnStyle(c,true),css:b,tooltip:this.getColumnTooltip(c)};if(e.config[c].align=="right"){d.istyle="padding-right: 16px;"}else{delete d.istyle}k[c]=a.apply(d)}return g.header.apply({cells:k.join(""),tstyle:String.format("width: {0};",this.getTotalWidth())})},getColumnTooltip:function(a){var b=this.cm.getColumnTooltip(a);if(b){if(Ext.QuickTips.isEnabled()){return'ext:qtip="'+b+'"'}else{return'title="'+b+'"'}}return""},beforeUpdate:function(){this.grid.stopEditing(true)},updateHeaders:function(){this.innerHd.firstChild.innerHTML=this.renderHeaders();this.updateHeaderWidth(false)},updateHeaderWidth:function(c){var b=this.innerHd.firstChild,a=this.getTotalWidth();b.style.width=this.getOffsetWidth();b.firstChild.style.width=a;if(c!==false){this.mainBody.dom.style.width=a}},focusRow:function(a){this
 .focusCell(a,0,false)},focusCell:function(d,b,c){this.syncFocusEl(this.ensureVisible(d,b,c));var a=this.focusEl;if(Ext.isGecko){a.focus()}else{a.focus.defer(1,a)}},resolveCell:function(h,d,g){if(!Ext.isNumber(h)){h=h.rowIndex}if(!this.ds){return null}if(h<0||h>=this.ds.getCount()){return null}d=(d!==undefined?d:0);var c=this.getRow(h),b=this.cm,e=b.getColumnCount(),a;if(!(g===false&&d===0)){while(d<e&&b.isHidden(d)){d++}a=this.getCell(h,d)}return{row:c,cell:a}},getResolvedXY:function(b){if(!b){return null}var a=b.cell,c=b.row;if(a){return Ext.fly(a).getXY()}else{return[this.el.getX(),Ext.fly(c).getY()]}},syncFocusEl:function(d,a,c){var b=d;if(!Ext.isArray(b)){d=Math.min(d,Math.max(0,this.getRows().length-1));if(isNaN(d)){return}b=this.getResolvedXY(this.resolveCell(d,a,c))}this.focusEl.setXY(b||this.scroller.getXY())},ensureVisible:function(t,g,e){var r=this.resolveCell(t,g,e);if(!r||!r.row){return null}var k=r.row,h=r.cell,n=this.scroller.dom,d=k,s=0,o=this.el.dom;while(d&&
 d!=o){s+=d.offsetTop;d=d.offsetParent}s-=this.mainHd.dom.offsetHeight;o=parseInt(n.scrollTop,10);var q=s+k.offsetHeight,a=n.clientHeight,m=o+a;if(s<o){n.scrollTop=s}else{if(q>m){n.scrollTop=q-a}}if(e!==false){var l=parseInt(h.offsetLeft,10),j=l+h.offsetWidth,i=parseInt(n.scrollLeft,10),b=i+n.clientWidth;if(l<i){n.scrollLeft=l}else{if(j>b){n.scrollLeft=j-n.clientWidth}}}return this.getResolvedXY(r)},insertRows:function(a,i,e,h){var d=a.getCount()-1;if(!h&&i===0&&e>=d){this.fireEvent("beforerowsinserted",this,i,e);this.refresh();this.fireEvent("rowsinserted",this,i,e)}else{if(!h){this.fireEvent("beforerowsinserted",this,i,e)}var b=this.renderRows(i,e),g=this.getRow(i);if(g){if(i===0){Ext.fly(this.getRow(0)).removeClass(this.firstRowCls)}Ext.DomHelper.insertHtml("beforeBegin",g,b)}else{var c=this.getRow(d-1);if(c){Ext.fly(c).removeClass(this.lastRowCls)}Ext.DomHelper.insertHtml("beforeEnd",this.mainBody.dom,b)}if(!h){this.processRows(i);this.fireEvent("rowsinserted",this,i,e)}e
 lse{if(i===0||i>=d){Ext.fly(this.getRow(i)).addClass(i===0?this.firstRowCls:this.lastRowCls)}}}this.syncFocusEl(i)},deleteRows:function(a,c,b){if(a.getRowCount()<1){this.refresh()}else{this.fireEvent("beforerowsdeleted",this,c,b);this.removeRows(c,b);this.processRows(c);this.fireEvent("rowsdeleted",this,c,b)}},getColumnStyle:function(b,d){var a=this.cm,g=a.config,c=d?"":g[b].css||"",e=g[b].align;c+=String.format("width: {0};",this.getColumnWidth(b));if(a.isHidden(b)){c+="display: none; "}if(e){c+=String.format("text-align: {0};",e)}return c},getColumnWidth:function(b){var c=this.cm.getColumnWidth(b),a=this.borderWidth;if(Ext.isNumber(c)){if(Ext.isBorderBox||(Ext.isWebKit&&!Ext.isSafari2)){return c+"px"}else{return Math.max(c-a,0)+"px"}}else{return c}},getTotalWidth:function(){return this.cm.getTotalWidth()+"px"},fitColumns:function(g,j,h){var a=this.grid,l=this.cm,s=l.getTotalWidth(false),q=this.getGridInnerWidth(),r=q-s,c=[],o=0,n=0,u,d,p;if(q<20||r===0){return false}var e=
 l.getColumnCount(true),m=l.getColumnCount(false),b=e-(Ext.isNumber(h)?1:0);if(b===0){b=1;h=undefined}for(p=0;p<m;p++){if(!l.isFixed(p)&&p!==h){u=l.getColumnWidth(p);c.push(p,u);if(!l.isHidden(p)){o=p;n+=u}}}d=(q-l.getTotalWidth())/n;while(c.length){u=c.pop();p=c.pop();l.setColumnWidth(p,Math.max(a.minColumnWidth,Math.floor(u+u*d)),true)}s=l.getTotalWidth(false);if(s>q){var t=(b==e)?o:h,k=Math.max(1,l.getColumnWidth(t)-(s-q));l.setColumnWidth(t,k,true)}if(g!==true){this.updateAllColumnWidths()}return true},autoExpand:function(k){var a=this.grid,i=this.cm,e=this.getGridInnerWidth(),c=i.getTotalWidth(false),g=a.autoExpandColumn;if(!this.userResized&&g){if(e!=c){var j=i.getIndexById(g),b=i.getColumnWidth(j),h=e-c+b,d=Math.min(Math.max(h,a.autoExpandMin),a.autoExpandMax);if(b!=d){i.setColumnWidth(j,d,true);if(k!==true){this.updateColumnWidth(j,d)}}}}},getGridInnerWidth:function(){return this.grid.getGridEl().getWidth(true)-this.getScrollOffset()},getColumnData:function(){var e=[]
 ,c=this.cm,g=c.getColumnCount(),a=this.ds.fields,d,b;for(d=0;d<g;d++){b=c.getDataIndex(d);e[d]={name:Ext.isDefined(b)?b:(a.get(d)?a.get(d).name:undefined),renderer:c.getRenderer(d),scope:c.getRendererScope(d),id:c.getColumnId(d),style:this.getColumnStyle(d)}}return e},renderRows:function(i,c){var a=this.grid,g=a.store,j=a.stripeRows,e=a.colModel,h=e.getColumnCount(),d=g.getCount(),b;if(d<1){return""}i=i||0;c=Ext.isDefined(c)?c:d-1;b=g.getRange(i,c);return this.doRender(this.getColumnData(),b,g,i,h,j)},renderBody:function(){var a=this.renderRows()||"&#160;";return this.templates.body.apply({rows:a})},refreshRow:function(g){var l=this.ds,m=this.cm.getColumnCount(),c=this.getColumnData(),n=m-1,p=["x-grid3-row"],e={tstyle:String.format("width: {0};",this.getTotalWidth())},a=[],k=this.templates.cell,j,q,b,o,h,d;if(Ext.isNumber(g)){j=g;g=l.getAt(j)}else{j=l.indexOf(g)}if(!g||j<0){return}for(d=0;d<m;d++){b=c[d];if(d==0){h="x-grid3-cell-first"}else{h=(d==n)?"x-grid3-cell-last ":""}o
 ={id:b.id,style:b.style,css:h,attr:"",cellAttr:""};o.value=b.renderer.call(b.scope,g.data[b.name],o,g,j,d,l);if(Ext.isEmpty(o.value)){o.value="&#160;"}if(this.markDirty&&g.dirty&&typeof g.modified[b.name]!="undefined"){o.css+=" x-grid3-dirty-cell"}a[d]=k.apply(o)}q=this.getRow(j);q.className="";if(this.grid.stripeRows&&((j+1)%2===0)){p.push("x-grid3-row-alt")}if(this.getRowClass){e.cols=m;p.push(this.getRowClass(g,j,e,l))}this.fly(q).addClass(p).setStyle(e.tstyle);e.cells=a.join("");q.innerHTML=this.templates.rowInner.apply(e);this.fireEvent("rowupdated",this,j,g)},refresh:function(b){this.fireEvent("beforerefresh",this);this.grid.stopEditing(true);var a=this.renderBody();this.mainBody.update(a).setWidth(this.getTotalWidth());if(b===true){this.updateHeaders();this.updateHeaderSortState()}this.processRows(0,true);this.layout();this.applyEmptyText();this.fireEvent("refresh",this)},applyEmptyText:function(){if(this.emptyText&&!this.hasRows()){this.mainBody.update('<div class="x
 -grid-empty">'+this.emptyText+"</div>")}},updateHeaderSortState:function(){var b=this.ds.getSortState();if(!b){return}if(!this.sortState||(this.sortState.field!=b.field||this.sortState.direction!=b.direction)){this.grid.fireEvent("sortchange",this.grid,b)}this.sortState=b;var c=this.cm.findColumnIndex(b.field);if(c!=-1){var a=b.direction;this.updateSortIcon(c,a)}},clearHeaderSortState:function(){if(!this.sortState){return}this.grid.fireEvent("sortchange",this.grid,null);this.mainHd.select("td").removeClass(this.sortClasses);delete this.sortState},destroy:function(){var j=this,a=j.grid,d=a.getGridEl(),i=j.dragZone,g=j.splitZone,h=j.columnDrag,e=j.columnDrop,k=j.scrollToTopTask,c,b;if(k&&k.cancel){k.cancel()}Ext.destroyMembers(j,"colMenu","hmenu");j.initData(null,null);j.purgeListeners();Ext.fly(j.innerHd).un("click",j.handleHdDown,j);if(a.enableColumnMove){c=h.dragData;b=h.proxy;Ext.destroy(h.el,b.ghost,b.el,e.el,e.proxyTop,e.proxyBottom,c.ddel,c.header);if(b.anim){Ext.destro
 y(b.anim)}delete b.ghost;delete c.ddel;delete c.header;h.destroy();delete Ext.dd.DDM.locationCache[h.id];delete h._domRef;delete e.proxyTop;delete e.proxyBottom;e.destroy();delete Ext.dd.DDM.locationCache["gridHeader"+d.id];delete e._domRef;delete Ext.dd.DDM.ids[e.ddGroup]}if(g){g.destroy();delete g._domRef;delete Ext.dd.DDM.ids["gridSplitters"+d.id]}Ext.fly(j.innerHd).removeAllListeners();Ext.removeNode(j.innerHd);delete j.innerHd;Ext.destroy(j.el,j.mainWrap,j.mainHd,j.scroller,j.mainBody,j.focusEl,j.resizeMarker,j.resizeProxy,j.activeHdBtn,j._flyweight,i,g);delete a.container;if(i){i.destroy()}Ext.dd.DDM.currentTarget=null;delete Ext.dd.DDM.locationCache[d.id];Ext.EventManager.removeResizeListener(j.onWindowResize,j)},onDenyColumnHide:function(){},render:function(){if(this.autoFill){var a=this.grid.ownerCt;if(a&&a.getLayout()){a.on("afterlayout",function(){this.fitColumns(true,true);this.updateHeaders();this.updateHeaderSortState()},this,{single:true})}}else{if(this.forceF
 it){this.fitColumns(true,false)}else{if(this.grid.autoExpandColumn){this.autoExpand(true)}}}this.grid.getGridEl().dom.innerHTML=this.renderUI();this.afterRenderUI()},initData:function(a,e){var b=this;if(b.ds){var d=b.ds;d.un("add",b.onAdd,b);d.un("load",b.onLoad,b);d.un("clear",b.onClear,b);d.un("remove",b.onRemove,b);d.un("update",b.onUpdate,b);d.un("datachanged",b.onDataChange,b);if(d!==a&&d.autoDestroy){d.destroy()}}if(a){a.on({scope:b,load:b.onLoad,add:b.onAdd,remove:b.onRemove,update:b.onUpdate,clear:b.onClear,datachanged:b.onDataChange})}if(b.cm){var c=b.cm;c.un("configchange",b.onColConfigChange,b);c.un("widthchange",b.onColWidthChange,b);c.un("headerchange",b.onHeaderChange,b);c.un("hiddenchange",b.onHiddenChange,b);c.un("columnmoved",b.onColumnMove,b)}if(e){delete b.lastViewWidth;e.on({scope:b,configchange:b.onColConfigChange,widthchange:b.onColWidthChange,headerchange:b.onHeaderChange,hiddenchange:b.onHiddenChange,columnmoved:b.onColumnMove})}b.ds=a;b.cm=e},onDataC
 hange:function(){this.refresh(true);this.updateHeaderSortState();this.syncFocusEl(0)},onClear:function(){this.refresh();this.syncFocusEl(0)},onUpdate:function(b,a){this.refreshRow(a)},onAdd:function(b,a,c){this.insertRows(b,c,c+(a.length-1))},onRemove:function(b,a,c,d){if(d!==true){this.fireEvent("beforerowremoved",this,c,a)}this.removeRow(c);if(d!==true){this.processRows(c);this.applyEmptyText();this.fireEvent("rowremoved",this,c,a)}},onLoad:function(){if(Ext.isGecko){if(!this.scrollToTopTask){this.scrollToTopTask=new Ext.util.DelayedTask(this.scrollToTop,this)}this.scrollToTopTask.delay(1)}else{this.scrollToTop()}},onColWidthChange:function(a,b,c){this.updateColumnWidth(b,c)},onHeaderChange:function(a,b,c){this.updateHeaders()},onHiddenChange:function(a,b,c){this.updateColumnHidden(b,c)},onColumnMove:function(a,c,b){this.indexMap=null;this.refresh(true);this.restoreScroll(this.getScrollState());this.afterMove(b);this.grid.fireEvent("columnmove",c,b)},onColConfigChange:func
 tion(){delete this.lastViewWidth;this.indexMap=null;this.refresh(true)},initUI:function(a){a.on("headerclick",this.onHeaderClick,this)},initEvents:Ext.emptyFn,onHeaderClick:function(b,a){if(this.headersDisabled||!this.cm.isSortable(a)){return}b.stopEditing(true);b.store.sort(this.cm.getDataIndex(a))},onRowOver:function(b,a){var c=this.findRowIndex(a);if(c!==false){this.addRowClass(c,this.rowOverCls)}},onRowOut:function(b,a){var c=this.findRowIndex(a);if(c!==false&&!b.within(this.getRow(c),true)){this.removeRowClass(c,this.rowOverCls)}},onRowSelect:function(a){this.addRowClass(a,this.selectedRowClass)},onRowDeselect:function(a){this.removeRowClass(a,this.selectedRowClass)},onCellSelect:function(c,b){var a=this.getCell(c,b);if(a){this.fly(a).addClass("x-grid3-cell-selected")}},onCellDeselect:function(c,b){var a=this.getCell(c,b);if(a){this.fly(a).removeClass("x-grid3-cell-selected")}},handleWheel:function(a){a.stopPropagation()},onColumnSplitterMoved:function(a,b){this.userRes
 ized=true;this.grid.colModel.setColumnWidth(a,b,true);if(this.forceFit){this.fitColumns(true,false,a);this.updateAllColumnWidths()}else{this.updateColumnWidth(a,b);this.syncHeaderScroll()}this.grid.fireEvent("columnresize",a,b)},beforeColMenuShow:function(){var b=this.cm,d=b.getColumnCount(),a=this.colMenu,c;a.removeAll();for(c=0;c<d;c++){if(b.config[c].hideable!==false){a.add(new Ext.menu.CheckItem({text:b.getColumnHeader(c),itemId:"col-"+b.getColumnId(c),checked:!b.isHidden(c),disabled:b.config[c].hideable===false,hideOnClick:false}))}}},handleHdMenuClick:function(c){var a=this.ds,b=this.cm.getDataIndex(this.hdCtxIndex);switch(c.getItemId()){case"asc":a.sort(b,"ASC");break;case"desc":a.sort(b,"DESC");break;default:this.handleHdMenuClickDefault(c)}return true},handleHdMenuClickDefault:function(c){var b=this.cm,d=c.getItemId(),a=b.getIndexById(d.substr(4));if(a!=-1){if(c.checked&&b.getColumnsBy(this.isHideableColumn,this).length<=1){this.onDenyColumnHide();return}b.setHidden
 (a,c.checked)}},handleHdDown:function(i,j){if(Ext.fly(j).hasClass("x-grid3-hd-btn")){i.stopEvent();var k=this.cm,g=this.findHeaderCell(j),h=this.getCellIndex(g),d=k.isSortable(h),c=this.hmenu,b=c.items,a=this.headerMenuOpenCls;this.hdCtxIndex=h;Ext.fly(g).addClass(a);b.get("asc").setDisabled(!d);b.get("desc").setDisabled(!d);c.on("hide",function(){Ext.fly(g).removeClass(a)},this,{single:true});c.show(j,"tl-bl?")}},handleHdMove:function(k){var i=this.findHeaderCell(this.activeHdRef);if(i&&!this.headersDisabled){var l=this.splitHandleWidth||5,j=this.activeHdRegion,p=i.style,m=this.cm,o="",g=k.getPageX();if(this.grid.enableColumnResize!==false){var a=this.activeHdIndex,b=this.getPreviousVisible(a),n=m.isResizable(a),c=b&&m.isResizable(b),d=g-j.left<=l,h=j.right-g<=(!this.activeHdBtn?l:2);if(d&&c){o=Ext.isAir?"move":Ext.isWebKit?"e-resize":"col-resize"}else{if(h&&n){o=Ext.isAir?"move":Ext.isWebKit?"w-resize":"col-resize"}}}p.cursor=o}},getPreviousVisible:function(a){while(a>0){i
 f(!this.cm.isHidden(a-1)){return a}a--}return undefined},handleHdOver:function(c,b){var d=this.findHeaderCell(b);if(d&&!this.headersDisabled){var a=this.fly(d);this.activeHdRef=b;this.activeHdIndex=this.getCellIndex(d);this.activeHdRegion=a.getRegion();if(!this.isMenuDisabled(this.activeHdIndex,a)){a.addClass("x-grid3-hd-over");this.activeHdBtn=a.child(".x-grid3-hd-btn");if(this.activeHdBtn){this.activeHdBtn.dom.style.height=(d.firstChild.offsetHeight-1)+"px"}}}},handleHdOut:function(b,a){var c=this.findHeaderCell(a);if(c&&(!Ext.isIE||!b.within(c,true))){this.activeHdRef=null;this.fly(c).removeClass("x-grid3-hd-over");c.style.cursor=""}},isMenuDisabled:function(a,b){return this.cm.isMenuDisabled(a)},hasRows:function(){var a=this.mainBody.dom.firstChild;return a&&a.nodeType==1&&a.className!="x-grid-empty"},isHideableColumn:function(a){return !a.hidden},bind:function(a,b){this.initData(a,b)}});Ext.grid.GridView.SplitDragZone=Ext.extend(Ext.dd.DDProxy,{constructor:function(a,b)
 {this.grid=a;this.view=a.getView();this.marker=this.view.resizeMarker;this.proxy=this.view.resizeProxy;Ext.grid.GridView.SplitDragZone.superclass.constructor.call(this,b,"gridSplitters"+this.grid.getGridEl().id,{dragElId:Ext.id(this.proxy.dom),resizeFrame:false});this.scroll=false;this.hw=this.view.splitHandleWidth||5},b4StartDrag:function(a,e){this.dragHeadersDisabled=this.view.headersDisabled;this.view.headersDisabled=true;var d=this.view.mainWrap.getHeight();this.marker.setHeight(d);this.marker.show();this.marker.alignTo(this.view.getHeaderCell(this.cellIndex),"tl-tl",[-2,0]);this.proxy.setHeight(d);var b=this.cm.getColumnWidth(this.cellIndex),c=Math.max(b-this.grid.minColumnWidth,0);this.resetConstraints();this.setXConstraint(c,1000);this.setYConstraint(0,0);this.minX=a-c;this.maxX=a+1000;this.startPos=a;Ext.dd.DDProxy.prototype.b4StartDrag.call(this,a,e)},allowHeaderDrag:function(a){return true},handleMouseDown:function(a){var h=this.view.findHeaderCell(a.getTarget());i
 f(h&&this.allowHeaderDrag(a)){var k=this.view.fly(h).getXY(),c=k[0],i=a.getXY(),b=i[0],g=h.offsetWidth,d=false;if((b-c)<=this.hw){d=-1}else{if((c+g)-b<=this.hw){d=0}}if(d!==false){this.cm=this.grid.colModel;var j=this.view.getCellIndex(h);if(d==-1){if(j+d<0){return}while(this.cm.isHidden(j+d)){--d;if(j+d<0){return}}}this.cellIndex=j+d;this.split=h.dom;if(this.cm.isResizable(this.cellIndex)&&!this.cm.isFixed(this.cellIndex)){Ext.grid.GridView.SplitDragZone.superclass.handleMouseDown.apply(this,arguments)}}else{if(this.view.columnDrag){this.view.columnDrag.callHandleMouseDown(a)}}}},endDrag:function(g){this.marker.hide();var a=this.view,c=Math.max(this.minX,g.getPageX()),d=c-this.startPos,b=this.dragHeadersDisabled;a.onColumnSplitterMoved(this.cellIndex,this.cm.getColumnWidth(this.cellIndex)+d);setTimeout(function(){a.headersDisabled=b},50)},autoOffset:function(){this.setDelta(0,0)}});Ext.grid.PivotGridView=Ext.extend(Ext.grid.GridView,{colHeaderCellCls:"grid-hd-group-cell",ti
 tle:"",getColumnHeaders:function(){return this.grid.topAxis.buildHeaders()},getRowHeaders:function(){return this.grid.leftAxis.buildHeaders()},renderRows:function(a,t){var b=this.grid,o=b.extractData(),p=o.length,g=this.templates,s=b.renderer,h=typeof s=="function",w=this.getCellCls,n=typeof w=="function",d=g.cell,x=g.row,k=[],q={},c="width:"+this.getGridInnerWidth()+"px;",l,r,e,v,m;a=a||0;t=Ext.isDefined(t)?t:p-1;for(v=0;v<p;v++){m=o[v];r=m.length;l=[];for(var u=0;u<r;u++){q.id=v+"-"+u;q.css=u===0?"x-grid3-cell-first ":(u==(r-1)?"x-grid3-cell-last ":"");q.attr=q.cellAttr="";q.value=m[u];if(Ext.isEmpty(q.value)){q.value="&#160;"}if(h){q.value=s(q.value)}if(n){q.css+=w(q.value)+" "}l[l.length]=d.apply(q)}k[k.length]=x.apply({tstyle:c,cols:r,cells:l.join(""),alt:""})}return k.join("")},masterTpl:new Ext.Template('<div class="x-grid3 x-pivotgrid" hidefocus="true">','<div class="x-grid3-viewport">','<div class="x-grid3-header">','<div class="x-grid3-header-title"><span>{title}</
 span></div>','<div class="x-grid3-header-inner">','<div class="x-grid3-header-offset" style="{ostyle}"></div>',"</div>",'<div class="x-clear"></div>',"</div>",'<div class="x-grid3-scroller">','<div class="x-grid3-row-headers"></div>','<div class="x-grid3-body" style="{bstyle}">{body}</div>','<a href="#" class="x-grid3-focus" tabIndex="-1"></a>',"</div>","</div>",'<div class="x-grid3-resize-marker">&#160;</div>','<div class="x-grid3-resize-proxy">&#160;</div>',"</div>"),initTemplates:function(){Ext.grid.PivotGridView.superclass.initTemplates.apply(this,arguments);var a=this.templates||{};if(!a.gcell){a.gcell=new Ext.XTemplate('<td class="x-grid3-hd x-grid3-gcell x-grid3-td-{id} ux-grid-hd-group-row-{row} '+this.colHeaderCellCls+'" style="{style}">','<div {tooltip} class="x-grid3-hd-inner x-grid3-hd-{id}" unselectable="on" style="{istyle}">',this.grid.enableHdMenu?'<a class="x-grid3-hd-btn" href="#"></a>':"","{value}","</div>","</td>")}this.templates=a;this.hrowRe=new RegExp("
 ux-grid-hd-group-row-(\\d+)","")},initElements:function(){Ext.grid.PivotGridView.superclass.initElements.apply(this,arguments);this.rowHeadersEl=new Ext.Element(this.scroller.child("div.x-grid3-row-headers"));this.headerTitleEl=new Ext.Element(this.mainHd.child("div.x-grid3-header-title"))},getGridInnerWidth:function(){var a=Ext.grid.PivotGridView.superclass.getGridInnerWidth.apply(this,arguments);return a-this.getTotalRowHeaderWidth()},getTotalRowHeaderWidth:function(){var d=this.getRowHeaders(),c=d.length,b=0,a;for(a=0;a<c;a++){b+=d[a].width}return b},getTotalColumnHeaderHeight:function(){return this.getColumnHeaders().length*21},getCellIndex:function(b){if(b){var a=b.className.match(this.colRe),c;if(a&&(c=a[1])){return parseInt(c.split("-")[1],10)}}return false},renderUI:function(){var b=this.templates,a=this.getGridInnerWidth();return b.master.apply({body:b.body.apply({rows:"&#160;"}),ostyle:"width:"+a+"px",bstyle:"width:"+a+"px"})},onLayout:function(b,a){Ext.grid.PivotG
 ridView.superclass.onLayout.apply(this,arguments);var b=this.getGridInnerWidth();this.resizeColumnHeaders(b);this.resizeAllRows(b)},refresh:function(b){this.fireEvent("beforerefresh",this);this.grid.stopEditing(true);var a=this.renderBody();this.mainBody.update(a).setWidth(this.getGridInnerWidth());if(b===true){this.updateHeaders();this.updateHeaderSortState()}this.processRows(0,true);this.layout();this.applyEmptyText();this.fireEvent("refresh",this)},renderHeaders:Ext.emptyFn,fitColumns:Ext.emptyFn,resizeColumnHeaders:function(b){var a=this.grid.topAxis;if(a.rendered){a.el.setWidth(b)}},resizeRowHeaders:function(){var a=this.getTotalRowHeaderWidth(),b=String.format("margin-left: {0}px;",a);this.rowHeadersEl.setWidth(a);this.mainBody.applyStyles(b);Ext.fly(this.innerHd).applyStyles(b);this.headerTitleEl.setWidth(a);this.headerTitleEl.setHeight(this.getTotalColumnHeaderHeight())},resizeAllRows:function(b){var d=this.getRows(),c=d.length,a;for(a=0;a<c;a++){Ext.fly(d[a]).setWid
 th(b);Ext.fly(d[a]).child("table").setWidth(b)}},updateHeaders:function(){this.renderGroupRowHeaders();this.renderGroupColumnHeaders()},renderGroupRowHeaders:function(){var a=this.grid.leftAxis;this.resizeRowHeaders();a.rendered=false;a.render(this.rowHeadersEl);this.setTitle(this.title)},setTitle:function(a){this.headerTitleEl.child("span").dom.innerHTML=a},renderGroupColumnHeaders:function(){var a=this.grid.topAxis;a.rendered=false;a.render(this.innerHd.firstChild)},isMenuDisabled:function(a,b){return true}});Ext.grid.PivotAxis=Ext.extend(Ext.Component,{orientation:"horizontal",defaultHeaderWidth:80,paddingWidth:7,setDimensions:function(a){this.dimensions=a},onRender:function(b,a){var c=this.orientation=="horizontal"?this.renderHorizontalRows():this.renderVerticalRows();this.el=Ext.DomHelper.overwrite(b.dom,{tag:"table",cn:c},true)},renderHorizontalRows:function(){var k=this.buildHeaders(),a=k.length,g=[],c,h,e,d,b;for(d=0;d<a;d++){c=[];h=k[d].items;e=h.length;for(b=0;b<e;
 b++){c.push({tag:"td",html:h[b].header,colspan:h[b].span})}g[d]={tag:"tr",cn:c}}return g},renderVerticalRows:function(){var b=this.buildHeaders(),k=b.length,a=[],m=[],h,c,l,g,e,d;for(e=0;e<k;e++){c=b[e];g=c.width||80;h=c.items.length;for(d=0;d<h;d++){l=c.items[d];a[l.start]=a[l.start]||[];a[l.start].push({tag:"td",html:l.header,rowspan:l.span,width:Ext.isBorderBox?g:g-this.paddingWidth})}}h=a.length;for(e=0;e<h;e++){m[e]={tag:"tr",cn:a[e]}}return m},getTuples:function(){var b=new Ext.data.Store({});b.data=this.store.data.clone();b.fields=this.store.fields;var l=[],a=this.dimensions,c=a.length,j;for(j=0;j<c;j++){l.push({field:a[j].dataIndex,direction:a[j].direction||"ASC"})}b.sort(l);var e=b.data.items,n=[],k=[],o,h,d,g,m;c=e.length;for(j=0;j<c;j++){d=this.getRecordInfo(e[j]);g=d.data;h="";for(m in g){h+=g[m]+"---"}if(n.indexOf(h)==-1){n.push(h);k.push(d)}}b.destroy();return k},getRecordInfo:function(a){var e=this.dimensions,d=e.length,h={},j,c,b;for(b=0;b<d;b++){j=e[b];c=j.d
 ataIndex;h[c]=a.get(c)}var g=function(i){return function(k){for(var l in i){if(k.get(l)!=i[l]){return false}}return true}};return{data:h,matcher:g(h)}},buildHeaders:function(){var l=this.getTuples(),m=l.length,a=this.dimensions,e,r=a.length,c=[],o,s,n,q,p,b,k,h,g,d;for(g=0;g<r;g++){e=a[g];s=[];p=0;b=0;for(d=0;d<m;d++){o=l[d];k=d==(m-1);n=o.data[e.dataIndex];h=q!=undefined&&q!=n;if(g>0&&d>0){h=h||o.data[a[g-1].dataIndex]!=l[d-1].data[a[g-1].dataIndex]}if(h){s.push({header:q,span:p,start:b});b+=p;p=0}if(k){s.push({header:n,span:p+1,start:b});b+=p;p=0}q=n;p++}c.push({items:s,width:e.width||this.defaultHeaderWidth});q=undefined}return c}});Ext.grid.HeaderDragZone=Ext.extend(Ext.dd.DragZone,{maxDragWidth:120,constructor:function(a,c,b){this.grid=a;this.view=a.getView();this.ddGroup="gridHeader"+this.grid.getGridEl().id;Ext.grid.HeaderDragZone.superclass.constructor.call(this,c);if(b){this.setHandleElId(Ext.id(c));this.setOuterHandleElId(Ext.id(b))}this.scroll=false},getDragData:f
 unction(c){var a=Ext.lib.Event.getTarget(c),b=this.view.findHeaderCell(a);if(b){return{ddel:b.firstChild,header:b}}return false},onInitDrag:function(a){this.dragHeadersDisabled=this.view.headersDisabled;this.view.headersDisabled=true;var b=this.dragData.ddel.cloneNode(true);b.id=Ext.id();b.style.width=Math.min(this.dragData.header.offsetWidth,this.maxDragWidth)+"px";this.proxy.update(b);return true},afterValidDrop:function(){this.completeDrop()},afterInvalidDrop:function(){this.completeDrop()},completeDrop:function(){var a=this.view,b=this.dragHeadersDisabled;setTimeout(function(){a.headersDisabled=b},50)}});Ext.grid.HeaderDropZone=Ext.extend(Ext.dd.DropZone,{proxyOffsets:[-4,-9],fly:Ext.Element.fly,constructor:function(a,c,b){this.grid=a;this.view=a.getView();this.proxyTop=Ext.DomHelper.append(document.body,{cls:"col-move-top",html:"&#160;"},true);this.proxyBottom=Ext.DomHelper.append(document.body,{cls:"col-move-bottom",html:"&#160;"},true);this.proxyTop.hide=this.proxyBot
 tom.hide=function(){this.setLeftTop(-100,-100);this.setStyle("visibility","hidden")};this.ddGroup="gridHeader"+this.grid.getGridEl().id;Ext.grid.HeaderDropZone.superclass.constructor.call(this,a.getGridEl().dom)},getTargetFromEvent:function(c){var a=Ext.lib.Event.getTarget(c),b=this.view.findCellIndex(a);if(b!==false){return this.view.getHeaderCell(b)}},nextVisible:function(c){var b=this.view,a=this.grid.colModel;c=c.nextSibling;while(c){if(!a.isHidden(b.getCellIndex(c))){return c}c=c.nextSibling}return null},prevVisible:function(c){var b=this.view,a=this.grid.colModel;c=c.prevSibling;while(c){if(!a.isHidden(b.getCellIndex(c))){return c}c=c.prevSibling}return null},positionIndicator:function(d,k,j){var a=Ext.lib.Event.getPageX(j),g=Ext.lib.Dom.getRegion(k.firstChild),c,i,b=g.top+this.proxyOffsets[1];if((g.right-a)<=(g.right-g.left)/2){c=g.right+this.view.borderWidth;i="after"}else{c=g.left;i="before"}if(this.grid.colModel.isFixed(this.view.getCellIndex(k))){return false}c+=t
 his.proxyOffsets[0];this.proxyTop.setLeftTop(c,b);this.proxyTop.show();if(!this.bottomOffset){this.bottomOffset=this.view.mainHd.getHeight()}this.proxyBottom.setLeftTop(c,b+this.proxyTop.dom.offsetHeight+this.bottomOffset);this.proxyBottom.show();return i},onNodeEnter:function(d,a,c,b){if(b.header!=d){this.positionIndicator(b.header,d,c)}},onNodeOver:function(g,b,d,c){var a=false;if(c.header!=g){a=this.positionIndicator(c.header,g,d)}if(!a){this.proxyTop.hide();this.proxyBottom.hide()}return a?this.dropAllowed:this.dropNotAllowed},onNodeOut:function(d,a,c,b){this.proxyTop.hide();this.proxyBottom.hide()},onNodeDrop:function(b,m,g,c){var d=c.header;if(d!=b){var k=this.grid.colModel,j=Ext.lib.Event.getPageX(g),a=Ext.lib.Dom.getRegion(b.firstChild),o=(a.right-j)<=((a.right-a.left)/2)?"after":"before",i=this.view.getCellIndex(d),l=this.view.getCellIndex(b);if(o=="after"){l++}if(i<l){l--}k.moveColumn(i,l);return true}return false}});Ext.grid.GridView.ColumnDragZone=Ext.extend(Ext.
 grid.HeaderDragZone,{constructor:function(a,b){Ext.grid.GridView.ColumnDragZone.superclass.constructor.call(this,a,b,null);this.proxy.el.addClass("x-grid3-col-dd")},handleMouseDown:function(a){},callHandleMouseDown:function(a){Ext.grid.GridView.ColumnDragZone.superclass.handleMouseDown.call(this,a)}});Ext.grid.SplitDragZone=Ext.extend(Ext.dd.DDProxy,{fly:Ext.Element.fly,constructor:function(a,c,b){this.grid=a;this.view=a.getView();this.proxy=this.view.resizeProxy;Ext.grid.SplitDragZone.superclass.constructor.call(this,c,"gridSplitters"+this.grid.getGridEl().id,{dragElId:Ext.id(this.proxy.dom),resizeFrame:false});this.setHandleElId(Ext.id(c));this.setOuterHandleElId(Ext.id(b));this.scroll=false},b4StartDrag:function(a,d){this.view.headersDisabled=true;this.proxy.setHeight(this.view.mainWrap.getHeight());var b=this.cm.getColumnWidth(this.cellIndex);var c=Math.max(b-this.grid.minColumnWidth,0);this.resetConstraints();this.setXConstraint(c,1000);this.setYConstraint(0,0);this.min
 X=a-c;this.maxX=a+1000;this.startPos=a;Ext.dd.DDProxy.prototype.b4StartDrag.call(this,a,d)},handleMouseDown:function(c){var b=Ext.EventObject.setEvent(c);var a=this.fly(b.getTarget());if(a.hasClass("x-grid-split")){this.cellIndex=this.view.getCellIndex(a.dom);this.split=a.dom;this.cm=this.grid.colModel;if(this.cm.isResizable(this.cellIndex)&&!this.cm.isFixed(this.cellIndex)){Ext.grid.SplitDragZone.superclass.handleMouseDown.apply(this,arguments)}}},endDrag:function(c){this.view.headersDisabled=false;var a=Math.max(this.minX,Ext.lib.Event.getPageX(c));var b=a-this.startPos;this.view.onColumnSplitterMoved(this.cellIndex,this.cm.getColumnWidth(this.cellIndex)+b)},autoOffset:function(){this.setDelta(0,0)}});Ext.grid.GridDragZone=function(b,a){this.view=b.getView();Ext.grid.GridDragZone.superclass.constructor.call(this,this.view.mainBody.dom,a);this.scroll=false;this.grid=b;this.ddel=document.createElement("div");this.ddel.className="x-grid-dd-wrap"};Ext.extend(Ext.grid.GridDragZ
 one,Ext.dd.DragZone,{ddGroup:"GridDD",getDragData:function(b){var a=Ext.lib.Event.getTarget(b);var d=this.view.findRowIndex(a);if(d!==false){var c=this.grid.selModel;if(!c.isSelected(d)||b.hasModifier()){c.handleMouseDown(this.grid,d,b)}return{grid:this.grid,ddel:this.ddel,rowIndex:d,selections:c.getSelections()}}return false},onInitDrag:function(b){var a=this.dragData;this.ddel.innerHTML=this.grid.getDragDropText();this.proxy.update(this.ddel)},afterRepair:function(){this.dragging=false},getRepairXY:function(b,a){return false},onEndDrag:function(a,b){},onValidDrop:function(a,b,c){this.hideProxy()},beforeInvalidDrop:function(a,b){}});Ext.grid.ColumnModel=Ext.extend(Ext.util.Observable,{defaultWidth:100,defaultSortable:false,constructor:function(a){if(a.columns){Ext.apply(this,a);this.setConfig(a.columns,true)}else{this.setConfig(a,true)}this.addEvents("widthchange","headerchange","hiddenchange","columnmoved","configchange");Ext.grid.ColumnModel.superclass.constructor.call(th
 is)},getColumnId:function(a){return this.config[a].id},getColumnAt:function(a){return this.config[a]},setConfig:function(d,b){var e,h,a;if(!b){delete this.totalWidth;for(e=0,a=this.config.length;e<a;e++){h=this.config[e];if(h.setEditor){h.setEditor(null)}}}this.defaults=Ext.apply({width:this.defaultWidth,sortable:this.defaultSortable},this.defaults);this.config=d;this.lookup={};for(e=0,a=d.length;e<a;e++){h=Ext.applyIf(d[e],this.defaults);if(Ext.isEmpty(h.id)){h.id=e}if(!h.isColumn){var g=Ext.grid.Column.types[h.xtype||"gridcolumn"];h=new g(h);d[e]=h}this.lookup[h.id]=h}if(!b){this.fireEvent("configchange",this)}},getColumnById:function(a){return this.lookup[a]},getIndexById:function(c){for(var b=0,a=this.config.length;b<a;b++){if(this.config[b].id==c){return b}}return -1},moveColumn:function(e,b){var a=this.config,d=a[e];a.splice(e,1);a.splice(b,0,d);this.dataMap=null;this.fireEvent("columnmoved",this,e,b)},getColumnCount:function(b){var d=this.config.length,e=0,a;if(b===tr
 ue){for(a=0;a<d;a++){if(!this.isHidden(a)){e++}}return e}return d},getColumnsBy:function(g,e){var b=this.config,h=b.length,a=[],d,j;for(d=0;d<h;d++){j=b[d];if(g.call(e||this,j,d)===true){a[a.length]=j}}return a},isSortable:function(a){return !!this.config[a].sortable},isMenuDisabled:function(a){return !!this.config[a].menuDisabled},getRenderer:function(a){return this.config[a].renderer||Ext.grid.ColumnModel.defaultRenderer},getRendererScope:function(a){return this.config[a].scope},setRenderer:function(a,b){this.config[a].renderer=b},getColumnWidth:function(a){var b=this.config[a].width;if(typeof b!="number"){b=this.defaultWidth}return b},setColumnWidth:function(b,c,a){this.config[b].width=c;this.totalWidth=null;if(!a){this.fireEvent("widthchange",this,b,c)}},getTotalWidth:function(b){if(!this.totalWidth){this.totalWidth=0;for(var c=0,a=this.config.length;c<a;c++){if(b||!this.isHidden(c)){this.totalWidth+=this.getColumnWidth(c)}}}return this.totalWidth},getColumnHeader:functi
 on(a){return this.config[a].header},setColumnHeader:function(a,b){this.config[a].header=b;this.fireEvent("headerchange",this,a,b)},getColumnTooltip:function(a){return this.config[a].tooltip},setColumnTooltip:function(a,b){this.config[a].tooltip=b},getDataIndex:function(a){return this.config[a].dataIndex},setDataIndex:function(a,b){this.config[a].dataIndex=b},findColumnIndex:function(d){var e=this.config;for(var b=0,a=e.length;b<a;b++){if(e[b].dataIndex==d){return b}}return -1},isCellEditable:function(b,e){var d=this.config[b],a=d.editable;return !!(a||(!Ext.isDefined(a)&&d.editor))},getCellEditor:function(a,b){return this.config[a].getCellEditor(b)},setEditable:function(a,b){this.config[a].editable=b},isHidden:function(a){return !!this.config[a].hidden},isFixed:function(a){return !!this.config[a].fixed},isResizable:function(a){return a>=0&&this.config[a].resizable!==false&&this.config[a].fixed!==true},setHidden:function(a,b){var d=this.config[a];if(d.hidden!==b){d.hidden=b;t
 his.totalWidth=null;this.fireEvent("hiddenchange",this,a,b)}},setEditor:function(a,b){this.config[a].setEditor(b)},destroy:function(){var b=this.config.length,a=0;for(;a<b;a++){this.config[a].destroy()}delete this.config;delete this.lookup;this.purgeListeners()},setState:function(a,b){b=Ext.applyIf(b,this.defaults);Ext.apply(this.config[a],b)}});Ext.grid.ColumnModel.defaultRenderer=function(a){if(typeof a=="string"&&a.length<1){return"&#160;"}return a};Ext.grid.AbstractSelectionModel=Ext.extend(Ext.util.Observable,{constructor:function(){this.locked=false;Ext.grid.AbstractSelectionModel.superclass.constructor.call(this)},init:function(a){this.grid=a;if(this.lockOnInit){delete this.lockOnInit;this.locked=false;this.lock()}this.initEvents()},lock:function(){if(!this.locked){this.locked=true;var a=this.grid;if(a){a.getView().on({scope:this,beforerefresh:this.sortUnLock,refresh:this.sortLock})}else{this.lockOnInit=true}}},sortLock:function(){this.locked=true},sortUnLock:function
 (){this.locked=false},unlock:function(){if(this.locked){this.locked=false;var a=this.grid,b;if(a){b=a.getView();b.un("beforerefresh",this.sortUnLock,this);b.un("refresh",this.sortLock,this)}else{delete this.lockOnInit}}},isLocked:function(){return this.locked},destroy:function(){this.unlock();this.purgeListeners()}});Ext.grid.RowSelectionModel=Ext.extend(Ext.grid.AbstractSelectionModel,{singleSelect:false,constructor:function(a){Ext.apply(this,a);this.selections=new Ext.util.MixedCollection(false,function(b){return b.id});this.last=false;this.lastActive=false;this.addEvents("selectionchange","beforerowselect","rowselect","rowdeselect");Ext.grid.RowSelectionModel.superclass.constructor.call(this)},initEvents:function(){if(!this.grid.enableDragDrop&&!this.grid.enableDrag){this.grid.on("rowmousedown",this.handleMouseDown,this)}this.rowNav=new Ext.KeyNav(this.grid.getGridEl(),{up:this.onKeyPress,down:this.onKeyPress,scope:this});this.grid.getView().on({scope:this,refresh:this.on
 Refresh,rowupdated:this.onRowUpdated,rowremoved:this.onRemove})},onKeyPress:function(g,b){var a=b=="up",h=a?"selectPrevious":"selectNext",d=a?-1:1,c;if(!g.shiftKey||this.singleSelect){this[h](false)}else{if(this.last!==false&&this.lastActive!==false){c=this.last;this.selectRange(this.last,this.lastActive+d);this.grid.getView().focusRow(this.lastActive);if(c!==false){this.last=c}}else{this.selectFirstRow()}}},onRefresh:function(){var g=this.grid.store,d=this.getSelections(),c=0,a=d.length,b,e;this.silent=true;this.clearSelections(true);for(;c<a;c++){e=d[c];if((b=g.indexOfId(e.id))!=-1){this.selectRow(b,true)}}if(d.length!=this.selections.getCount()){this.fireEvent("selectionchange",this)}this.silent=false},onRemove:function(a,b,c){if(this.selections.remove(c)!==false){this.fireEvent("selectionchange",this)}},onRowUpdated:function(a,b,c){if(this.isSelected(c)){a.onRowSelect(b)}},selectRecords:function(b,e){if(!e){this.clearSelections()}var d=this.grid.store,c=0,a=b.length;for(
 ;c<a;c++){this.selectRow(d.indexOf(b[c]),true)}},getCount:function(){return this.selections.length},selectFirstRow:function(){this.selectRow(0)},selectLastRow:function(a){this.selectRow(this.grid.store.getCount()-1,a)},selectNext:function(a){if(this.hasNext()){this.selectRow(this.last+1,a);this.grid.getView().focusRow(this.last);return true}return false},selectPrevious:function(a){if(this.hasPrevious()){this.selectRow(this.last-1,a);this.grid.getView().focusRow(this.last);return true}return false},hasNext:function(){return this.last!==false&&(this.last+1)<this.grid.store.getCount()},hasPrevious:function(){return !!this.last},getSelections:function(){return[].concat(this.selections.items)},getSelected:function(){return this.selections.itemAt(0)},each:function(e,d){var c=this.getSelections(),b=0,a=c.length;for(;b<a;b++){if(e.call(d||this,c[b],b)===false){return false}}return true},clearSelections:function(a){if(this.isLocked()){return}if(a!==true){var c=this.grid.store,b=this.
 selections;b.each(function(d){this.deselectRow(c.indexOfId(d.id))},this);b.clear()}else{this.selections.clear()}this.last=false},selectAll:function(){if(this.isLocked()){return}this.selections.clear();for(var b=0,a=this.grid.store.getCount();b<a;b++){this.selectRow(b,true)}},hasSelection:function(){return this.selections.length>0},isSelected:function(a){var b=Ext.isNumber(a)?this.grid.store.getAt(a):a;return(b&&this.selections.key(b.id)?true:false)},isIdSelected:function(a){return(this.selections.key(a)?true:false)},handleMouseDown:function(d,i,h){if(h.button!==0||this.isLocked()){return}var a=this.grid.getView();if(h.shiftKey&&!this.singleSelect&&this.last!==false){var c=this.last;this.selectRange(c,i,h.ctrlKey);this.last=c;a.focusRow(i)}else{var b=this.isSelected(i);if(h.ctrlKey&&b){this.deselectRow(i)}else{if(!b||this.getCount()>1){this.selectRow(i,h.ctrlKey||h.shiftKey);a.focusRow(i)}}}},selectRows:function(c,d){if(!d){this.clearSelections()}for(var b=0,a=c.length;b<a;b+
 +){this.selectRow(c[b],true)}},selectRange:function(b,a,d){var c;if(this.isLocked()){return}if(!d){this.clearSelections()}if(b<=a){for(c=b;c<=a;c++){this.selectRow(c,true)}}else{for(c=b;c>=a;c--){this.selectRow(c,true)}}},deselectRange:function(c,b,a){if(this.isLocked()){return}for(var d=c;d<=b;d++){this.deselectRow(d,a)}},selectRow:function(b,d,a){if(this.isLocked()||(b<0||b>=this.grid.store.getCount())||(d&&this.isSelected(b))){return}var c=this.grid.store.getAt(b);if(c&&this.fireEvent("beforerowselect",this,b,d,c)!==false){if(!d||this.singleSelect){this.clearSelections()}this.selections.add(c);this.last=this.lastActive=b;if(!a){this.grid.getView().onRowSelect(b)}if(!this.silent){this.fireEvent("rowselect",this,b,c);this.fireEvent("selectionchange",this)}}},deselectRow:function(b,a){if(this.isLocked()){return}if(this.last==b){this.last=false}if(this.lastActive==b){this.lastActive=false}var c=this.grid.store.getAt(b);if(c){this.selections.remove(c);if(!a){this.grid.getView(
 ).onRowDeselect(b)}this.fireEvent("rowdeselect",this,b,c);this.fireEvent("selectionchange",this)}},acceptsNav:function(c,b,a){return !a.isHidden(b)&&a.isCellEditable(b,c)},onEditorKey:function(n,l){var d=l.getKey(),h,i=this.grid,p=i.lastEdit,j=i.activeEditor,b=l.shiftKey,o,p,a,m;if(d==l.TAB){l.stopEvent();j.completeEdit();if(b){h=i.walkCells(j.row,j.col-1,-1,this.acceptsNav,this)}else{h=i.walkCells(j.row,j.col+1,1,this.acceptsNav,this)}}else{if(d==l.ENTER){if(this.moveEditorOnEnter!==false){if(b){h=i.walkCells(p.row-1,p.col,-1,this.acceptsNav,this)}else{h=i.walkCells(p.row+1,p.col,1,this.acceptsNav,this)}}}}if(h){a=h[0];m=h[1];this.onEditorSelect(a,p.row);if(i.isEditor&&i.editing){o=i.activeEditor;if(o&&o.field.triggerBlur){o.field.triggerBlur()}}i.startEditing(a,m)}},onEditorSelect:function(b,a){if(a!=b){this.selectRow(b)}},destroy:function(){Ext.destroy(this.rowNav);this.rowNav=null;Ext.grid.RowSelectionModel.superclass.destroy.call(this)}});Ext.grid.Column=Ext.extend(Ext.
 util.Observable,{isColumn:true,constructor:function(b){Ext.apply(this,b);if(Ext.isString(this.renderer)){this.renderer=Ext.util.Format[this.renderer]}else{if(Ext.isObject(this.renderer)){this.scope=this.renderer.scope;this.renderer=this.renderer.fn}}if(!this.scope){this.scope=this}var a=this.editor;delete this.editor;this.setEditor(a);this.addEvents("click","contextmenu","dblclick","mousedown");Ext.grid.Column.superclass.constructor.call(this)},processEvent:function(b,d,c,g,a){return this.fireEvent(b,this,c,g,d)},destroy:function(){if(this.setEditor){this.setEditor(null)}this.purgeListeners()},renderer:function(a){return a},getEditor:function(a){return this.editable!==false?this.editor:null},setEditor:function(b){var a=this.editor;if(a){if(a.gridEditor){a.gridEditor.destroy();delete a.gridEditor}else{a.destroy()}}this.editor=null;if(b){if(!b.isXType){b=Ext.create(b,"textfield")}this.editor=b}},getCellEditor:function(b){var a=this.getEditor(b);if(a){if(!a.startEdit){if(!a.gri
 dEditor){a.gridEditor=new Ext.grid.GridEditor(a)}a=a.gridEditor}}return a}});Ext.grid.BooleanColumn=Ext.extend(Ext.grid.Column,{trueText:"true",falseText:"false",undefinedText:"&#160;",constructor:function(a){Ext.grid.BooleanColumn.superclass.constructor.call(this,a);var c=this.trueText,d=this.falseText,b=this.undefinedText;this.renderer=function(e){if(e===undefined){return b}if(!e||e==="false"){return d}return c}}});Ext.grid.NumberColumn=Ext.extend(Ext.grid.Column,{format:"0,000.00",constructor:function(a){Ext.grid.NumberColumn.superclass.constructor.call(this,a);this.renderer=Ext.util.Format.numberRenderer(this.format)}});Ext.grid.DateColumn=Ext.extend(Ext.grid.Column,{format:"m/d/Y",constructor:function(a){Ext.grid.DateColumn.superclass.constructor.call(this,a);this.renderer=Ext.util.Format.dateRenderer(this.format)}});Ext.grid.TemplateColumn=Ext.extend(Ext.grid.Column,{constructor:function(a){Ext.grid.TemplateColumn.superclass.constructor.call(this,a);var b=(!Ext.isPrimi
 tive(this.tpl)&&this.tpl.compile)?this.tpl:new Ext.XTemplate(this.tpl);this.renderer=function(d,e,c){return b.apply(c.data)};this.tpl=b}});Ext.grid.ActionColumn=Ext.extend(Ext.grid.Column,{header:"&#160;",actionIdRe:/x-action-col-(\d+)/,altText:"",constructor:function(b){var g=this,c=b.items||(g.items=[g]),a=c.length,d,e;Ext.grid.ActionColumn.superclass.constructor.call(g,b);g.renderer=function(h,i){h=Ext.isFunction(b.renderer)?b.renderer.apply(this,arguments)||"":"";i.css+=" x-action-col-cell";for(d=0;d<a;d++){e=c[d];h+='<img alt="'+(e.altText||g.altText)+'" src="'+(e.icon||Ext.BLANK_IMAGE_URL)+'" class="x-action-col-icon x-action-col-'+String(d)+" "+(e.iconCls||"")+" "+(Ext.isFunction(e.getClass)?e.getClass.apply(e.scope||this.scope||this,arguments):"")+'"'+((e.tooltip)?' ext:qtip="'+e.tooltip+'"':"")+" />"}return h}},destroy:function(){delete this.items;delete this.renderer;return Ext.grid.ActionColumn.superclass.destroy.apply(this,arguments)},processEvent:function(c,i,d,
 j,b){var a=i.getTarget().className.match(this.actionIdRe),h,g;if(a&&(h=this.items[parseInt(a[1],10)])){if(c=="click"){(g=h.handler||this.handler)&&g.call(h.scope||this.scope||this,d,j,b,h,i)}else{if((c=="mousedown")&&(h.stopSelection!==false)){return false}}}return Ext.grid.ActionColumn.superclass.processEvent.apply(this,arguments)}});Ext.grid.Column.types={gridcolumn:Ext.grid.Column,booleancolumn:Ext.grid.BooleanColumn,numbercolumn:Ext.grid.NumberColumn,datecolumn:Ext.grid.DateColumn,templatecolumn:Ext.grid.TemplateColumn,actioncolumn:Ext.grid.ActionColumn};Ext.grid.RowNumberer=Ext.extend(Object,{header:"",width:23,sortable:false,constructor:function(a){Ext.apply(this,a);if(this.rowspan){this.renderer=this.renderer.createDelegate(this)}},fixed:true,hideable:false,menuDisabled:true,dataIndex:"",id:"numberer",rowspan:undefined,renderer:function(b,c,a,d){if(this.rowspan){c.cellAttr='rowspan="'+this.rowspan+'"'}return d+1}});Ext.grid.CheckboxSelectionModel=Ext.extend(Ext.grid.R
 owSelectionModel,{header:'<div class="x-grid3-hd-checker">&#160;</div>',width:20,sortable:false,menuDisabled:true,fixed:true,hideable:false,dataIndex:"",id:"checker",isColumn:true,constructor:function(){Ext.grid.CheckboxSelectionModel.superclass.constructor.apply(this,arguments);if(this.checkOnly){this.handleMouseDown=Ext.emptyFn}},initEvents:function(){Ext.grid.CheckboxSelectionModel.superclass.initEvents.call(this);this.grid.on("render",function(){Ext.fly(this.grid.getView().innerHd).on("mousedown",this.onHdMouseDown,this)},this)},processEvent:function(b,d,c,g,a){if(b=="mousedown"){this.onMouseDown(d,d.getTarget());return false}else{return Ext.grid.Column.prototype.processEvent.apply(this,arguments)}},onMouseDown:function(c,b){if(c.button===0&&b.className=="x-grid3-row-checker"){c.stopEvent();var d=c.getTarget(".x-grid3-row");if(d){var a=d.rowIndex;if(this.isSelected(a)){this.deselectRow(a)}else{this.selectRow(a,true);this.grid.getView().focusRow(a)}}}},onHdMouseDown:funct
 ion(c,a){if(a.className=="x-grid3-hd-checker"){c.stopEvent();var b=Ext.fly(a.parentNode);var d=b.hasClass("x-grid3-hd-checker-on");if(d){b.removeClass("x-grid3-hd-checker-on");this.clearSelections()}else{b.addClass("x-grid3-hd-checker-on");this.selectAll()}}},renderer:function(b,c,a){return'<div class="x-grid3-row-checker">&#160;</div>'},onEditorSelect:function(b,a){if(a!=b&&!this.checkOnly){this.selectRow(b)}}});Ext.grid.CellSelectionModel=Ext.extend(Ext.grid.AbstractSelectionModel,{constructor:function(a){Ext.apply(this,a);this.selection=null;this.addEvents("beforecellselect","cellselect","selectionchange");Ext.grid.CellSelectionModel.superclass.constructor.call(this)},initEvents:function(){this.grid.on("cellmousedown",this.handleMouseDown,this);this.grid.on(Ext.EventManager.getKeyEvent(),this.handleKeyDown,this);this.grid.getView().on({scope:this,refresh:this.onViewChange,rowupdated:this.onRowUpdated,beforerowremoved:this.clearSelections,beforerowsinserted:this.clearSelec
 tions});if(this.grid.isEditor){this.grid.on("beforeedit",this.beforeEdit,this)}},beforeEdit:function(a){this.select(a.row,a.column,false,true,a.record)},onRowUpdated:function(a,b,c){if(this.selection&&this.selection.record==c){a.onCellSelect(b,this.selection.cell[1])}},onViewChange:function(){this.clearSelections(true)},getSelectedCell:function(){return this.selection?this.selection.cell:null},clearSelections:function(b){var a=this.selection;if(a){if(b!==true){this.grid.view.onCellDeselect(a.cell[0],a.cell[1])}this.selection=null;this.fireEvent("selectionchange",this,null)}},hasSelection:function(){return this.selection?true:false},handleMouseDown:function(b,d,a,c){if(c.button!==0||this.isLocked()){return}this.select(d,a)},select:function(g,c,b,e,d){if(this.fireEvent("beforecellselect",this,g,c)!==false){this.clearSelections();d=d||this.grid.store.getAt(g);this.selection={record:d,cell:[g,c]};if(!b){var a=this.grid.getView();a.onCellSelect(g,c);if(e!==true){a.focusCell(g,c)}
 }this.fireEvent("cellselect",this,g,c);this.fireEvent("selectionchange",this,this.selection)}},isSelectable:function(c,b,a){return !a.isHidden(b)},onEditorKey:function(b,a){if(a.getKey()==a.TAB){this.handleKeyDown(a)}},handleKeyDown:function(j){if(!j.isNavKeyPress()){return}var d=j.getKey(),i=this.grid,p=this.selection,b=this,m=function(g,c,e){return i.walkCells(g,c,e,i.isEditor&&i.editing?b.acceptsNav:b.isSelectable,b)},o,h,a,l,n;switch(d){case j.ESC:case j.PAGE_UP:case j.PAGE_DOWN:break;default:j.stopEvent();break}if(!p){o=m(0,0,1);if(o){this.select(o[0],o[1])}return}o=p.cell;a=o[0];l=o[1];switch(d){case j.TAB:if(j.shiftKey){h=m(a,l-1,-1)}else{h=m(a,l+1,1)}break;case j.DOWN:h=m(a+1,l,1);break;case j.UP:h=m(a-1,l,-1);break;case j.RIGHT:h=m(a,l+1,1);break;case j.LEFT:h=m(a,l-1,-1);break;case j.ENTER:if(i.isEditor&&!i.editing){i.startEditing(a,l);return}break}if(h){a=h[0];l=h[1];this.select(a,l);if(i.isEditor&&i.editing){n=i.activeEditor;if(n&&n.field.triggerBlur){n.field.tri
 ggerBlur()}i.startEditing(a,l)}}},acceptsNav:function(c,b,a){return !a.isHidden(b)&&a.isCellEditable(b,c)}});Ext.grid.EditorGridPanel=Ext.extend(Ext.grid.GridPanel,{clicksToEdit:2,forceValidation:false,isEditor:true,detectEdit:false,autoEncode:false,trackMouseOver:false,initComponent:function(){Ext.grid.EditorGridPanel.superclass.initComponent.call(this);if(!this.selModel){this.selModel=new Ext.grid.CellSelectionModel()}this.activeEditor=null;this.addEvents("beforeedit","afteredit","validateedit")},initEvents:function(){Ext.grid.EditorGridPanel.superclass.initEvents.call(this);this.getGridEl().on("mousewheel",this.stopEditing.createDelegate(this,[true]),this);this.on("columnresize",this.stopEditing,this,[true]);if(this.clicksToEdit==1){this.on("cellclick",this.onCellDblClick,this)}else{var a=this.getView();if(this.clicksToEdit=="auto"&&a.mainBody){a.mainBody.on("mousedown",this.onAutoEditClick,this)}this.on("celldblclick",this.onCellDblClick,this)}},onResize:function(){Ext.g
 rid.EditorGridPanel.superclass.onResize.apply(this,arguments);var a=this.activeEditor;if(this.editing&&a){a.realign(true)}},onCellDblClick:function(b,c,a){this.startEditing(c,a)},onAutoEditClick:function(c,b){if(c.button!==0){return}var g=this.view.findRowIndex(b),a=this.view.findCellIndex(b);if(g!==false&&a!==false){this.stopEditing();if(this.selModel.getSelectedCell){var d=this.selModel.getSelectedCell();if(d&&d[0]===g&&d[1]===a){this.startEditing(g,a)}}else{if(this.selModel.isSelected(g)){this.startEditing(g,a)}}}},onEditComplete:function(b,d,a){this.editing=false;this.lastActiveEditor=this.activeEditor;this.activeEditor=null;var c=b.record,h=this.colModel.getDataIndex(b.col);d=this.postEditValue(d,a,c,h);if(this.forceValidation===true||String(d)!==String(a)){var g={grid:this,record:c,field:h,originalValue:a,value:d,row:b.row,column:b.col,cancel:false};if(this.fireEvent("validateedit",g)!==false&&!g.cancel&&String(d)!==String(a)){c.set(h,g.value);delete g.cancel;this.fire
 Event("afteredit",g)}}this.view.focusCell(b.row,b.col)},startEditing:function(i,c){this.stopEditing();if(this.colModel.isCellEditable(c,i)){this.view.ensureVisible(i,c,true);var d=this.store.getAt(i),h=this.colModel.getDataIndex(c),g={grid:this,record:d,field:h,value:d.data[h],row:i,column:c,cancel:false};if(this.fireEvent("beforeedit",g)!==false&&!g.cancel){this.editing=true;var b=this.colModel.getCellEditor(c,i);if(!b){return}if(!b.rendered){b.parentEl=this.view.getEditorParent(b);b.on({scope:this,render:{fn:function(e){e.field.focus(false,true)},single:true,scope:this},specialkey:function(k,j){this.getSelectionModel().onEditorKey(k,j)},complete:this.onEditComplete,canceledit:this.stopEditing.createDelegate(this,[true])})}Ext.apply(b,{row:i,col:c,record:d});this.lastEdit={row:i,col:c};this.activeEditor=b;b.selectSameEditor=(this.activeEditor==this.lastActiveEditor);var a=this.preEditValue(d,h);b.startEdit(this.view.getCell(i,c).firstChild,Ext.isDefined(a)?a:"");(function()
 {delete b.selectSameEditor}).defer(50)}}},preEditValue:function(a,c){var b=a.data[c];return this.autoEncode&&Ext.isString(b)?Ext.util.Format.htmlDecode(b):b},postEditValue:function(c,a,b,d){return this.autoEncode&&Ext.isString(c)?Ext.util.Format.htmlEncode(c):c},stopEditing:function(b){if(this.editing){var a=this.lastActiveEditor=this.activeEditor;if(a){a[b===true?"cancelEdit":"completeEdit"]();this.view.focusCell(a.row,a.col)}this.activeEditor=null}this.editing=false}});Ext.reg("editorgrid",Ext.grid.EditorGridPanel);Ext.grid.GridEditor=function(b,a){Ext.grid.GridEditor.superclass.constructor.call(this,b,a);b.monitorTab=false};Ext.extend(Ext.grid.GridEditor,Ext.Editor,{alignment:"tl-tl",autoSize:"width",hideEl:false,cls:"x-small-editor x-grid-editor",shim:false,shadow:false});Ext.grid.PropertyRecord=Ext.data.Record.create([{name:"name",type:"string"},"value"]);Ext.grid.PropertyStore=Ext.extend(Ext.util.Observable,{constructor:function(a,b){this.grid=a;this.store=new Ext.data
 .Store({recordType:Ext.grid.PropertyRecord});this.store.on("update",this.onUpdate,this);if(b){this.setSource(b)}Ext.grid.PropertyStore.superclass.constructor.call(this)},setSource:function(c){this.source=c;this.store.removeAll();var b=[];for(var a in c){if(this.isEditableValue(c[a])){b.push(new Ext.grid.PropertyRecord({name:a,value:c[a]},a))}}this.store.loadRecords({records:b},{},true)},onUpdate:function(e,a,d){if(d==Ext.data.Record.EDIT){var b=a.data.value;var c=a.modified.value;if(this.grid.fireEvent("beforepropertychange",this.source,a.id,b,c)!==false){this.source[a.id]=b;a.commit();this.grid.fireEvent("propertychange",this.source,a.id,b,c)}else{a.reject()}}},getProperty:function(a){return this.store.getAt(a)},isEditableValue:function(a){return Ext.isPrimitive(a)||Ext.isDate(a)},setValue:function(d,c,a){var b=this.getRec(d);if(b){b.set("value",c);this.source[d]=c}else{if(a){this.source[d]=c;b=new Ext.grid.PropertyRecord({name:d,value:c},d);this.store.add(b)}}},remove:func
 tion(b){var a=this.getRec(b);if(a){this.store.remove(a);delete this.source[b]}},getRec:function(a){return this.store.getById(a)},getSource:function(){return this.source}});Ext.grid.PropertyColumnModel=Ext.extend(Ext.grid.ColumnModel,{nameText:"Name",valueText:"Value",dateFormat:"m/j/Y",trueText:"true",falseText:"false",constructor:function(c,b){var d=Ext.grid,e=Ext.form;this.grid=c;d.PropertyColumnModel.superclass.constructor.call(this,[{header:this.nameText,width:50,sortable:true,dataIndex:"name",id:"name",menuDisabled:true},{header:this.valueText,width:50,resizable:false,dataIndex:"value",id:"value",menuDisabled:true}]);this.store=b;var a=new e.Field({autoCreate:{tag:"select",children:[{tag:"option",value:"true",html:this.trueText},{tag:"option",value:"false",html:this.falseText}]},getValue:function(){return this.el.dom.value=="true"}});this.editors={date:new d.GridEditor(new e.DateField({selectOnFocus:true})),string:new d.GridEditor(new e.TextField({selectOnFocus:true})),
 number:new d.GridEditor(new e.NumberField({selectOnFocus:true,style:"text-align:left;"})),"boolean":new d.GridEditor(a,{autoSize:"both"})};this.renderCellDelegate=this.renderCell.createDelegate(this);this.renderPropDelegate=this.renderProp.createDelegate(this)},renderDate:function(a){return a.dateFormat(this.dateFormat)},renderBool:function(a){return this[a?"trueText":"falseText"]},isCellEditable:function(a,b){return a==1},getRenderer:function(a){return a==1?this.renderCellDelegate:this.renderPropDelegate},renderProp:function(a){return this.getPropertyName(a)},renderCell:function(d,b,c){var a=this.grid.customRenderers[c.get("name")];if(a){return a.apply(this,arguments)}var e=d;if(Ext.isDate(d)){e=this.renderDate(d)}else{if(typeof d=="boolean"){e=this.renderBool(d)}}return Ext.util.Format.htmlEncode(e)},getPropertyName:function(b){var a=this.grid.propertyNames;return a&&a[b]?a[b]:b},getCellEditor:function(a,e){var b=this.store.getProperty(e),d=b.data.name,c=b.data.value;if(th
 is.grid.customEditors[d]){return this.grid.customEditors[d]}if(Ext.isDate(c)){return this.editors.date}else{if(typeof c=="number"){return this.editors.number}else{if(typeof c=="boolean"){return this.editors["boolean"]}else{return this.editors.string}}}},destroy:function(){Ext.grid.PropertyColumnModel.superclass.destroy.call(this);this.destroyEditors(this.editors);this.destroyEditors(this.grid.customEditors)},destroyEditors:function(b){for(var a in b){Ext.destroy(b[a])}}});Ext.grid.PropertyGrid=Ext.extend(Ext.grid.EditorGridPanel,{enableColumnMove:false,stripeRows:false,trackMouseOver:false,clicksToEdit:1,enableHdMenu:false,viewConfig:{forceFit:true},initComponent:function(){this.customRenderers=this.customRenderers||{};this.customEditors=this.customEditors||{};this.lastEditRow=null;var b=new Ext.grid.PropertyStore(this);this.propStore=b;var a=new Ext.grid.PropertyColumnModel(this,b);b.store.sort("name","ASC");this.addEvents("beforepropertychange","propertychange");this.cm=a;
 this.ds=b.store;Ext.grid.PropertyGrid.superclass.initComponent.call(this);this.mon(this.selModel,"beforecellselect",function(e,d,c){if(c===0){this.startEditing.defer(200,this,[d,1]);return false}},this)},onRender:function(){Ext.grid.PropertyGrid.superclass.onRender.apply(this,arguments);this.getGridEl().addClass("x-props-grid")},afterRender:function(){Ext.grid.PropertyGrid.superclass.afterRender.apply(this,arguments);if(this.source){this.setSource(this.source)}},setSource:function(a){this.propStore.setSource(a)},getSource:function(){return this.propStore.getSource()},setProperty:function(c,b,a){this.propStore.setValue(c,b,a)},removeProperty:function(a){this.propStore.remove(a)}});Ext.reg("propertygrid",Ext.grid.PropertyGrid);Ext.grid.GroupingView=Ext.extend(Ext.grid.GridView,{groupByText:"Group By This Field",showGroupsText:"Show in Groups",hideGroupedColumn:false,showGroupName:true,startCollapsed:false,enableGrouping:true,enableGroupingMenu:true,enableNoGroups:true,emptyGro
 upText:"(None)",ignoreAdd:false,groupTextTpl:"{text}",groupMode:"value",cancelEditOnToggle:true,initTemplates:function(){Ext.grid.GroupingView.superclass.initTemplates.call(this);this.state={};var a=this.grid.getSelectionModel();a.on(a.selectRow?"beforerowselect":"beforecellselect",this.onBeforeRowSelect,this);if(!this.startGroup){this.startGroup=new Ext.XTemplate('<div id="{groupId}" class="x-grid-group {cls}">','<div id="{groupId}-hd" class="x-grid-group-hd" style="{style}"><div class="x-grid-group-title">',this.groupTextTpl,"</div></div>",'<div id="{groupId}-bd" class="x-grid-group-body">')}this.startGroup.compile();if(!this.endGroup){this.endGroup="</div></div>"}},findGroup:function(a){return Ext.fly(a).up(".x-grid-group",this.mainBody.dom)},getGroups:function(){return this.hasRows()?this.mainBody.dom.childNodes:[]},onAdd:function(d,a,b){if(this.canGroup()&&!this.ignoreAdd){var c=this.getScrollState();this.fireEvent("beforerowsinserted",d,b,b+(a.length-1));this.refresh()
 ;this.restoreScroll(c);this.fireEvent("rowsinserted",d,b,b+(a.length-1))}else{if(!this.canGroup()){Ext.grid.GroupingView.superclass.onAdd.apply(this,arguments)}}},onRemove:function(e,a,b,d){Ext.grid.GroupingView.superclass.onRemove.apply(this,arguments);var c=document.getElementById(a._groupId);if(c&&c.childNodes[1].childNodes.length<1){Ext.removeNode(c)}this.applyEmptyText()},refreshRow:function(a){if(this.ds.getCount()==1){this.refresh()}else{this.isUpdating=true;Ext.grid.GroupingView.superclass.refreshRow.apply(this,arguments);this.isUpdating=false}},beforeMenuShow:function(){var c,a=this.hmenu.items,b=this.cm.config[this.hdCtxIndex].groupable===false;if((c=a.get("groupBy"))){c.setDisabled(b)}if((c=a.get("showGroups"))){c.setDisabled(b);c.setChecked(this.canGroup(),true)}},renderUI:function(){var a=Ext.grid.GroupingView.superclass.renderUI.call(this);if(this.enableGroupingMenu&&this.hmenu){this.hmenu.add("-",{itemId:"groupBy",text:this.groupByText,handler:this.onGroupByCl
 ick,scope:this,iconCls:"x-group-by-icon"});if(this.enableNoGroups){this.hmenu.add({itemId:"showGroups",text:this.showGroupsText,checked:true,checkHandler:this.onShowGroupsClick,scope:this})}this.hmenu.on("beforeshow",this.beforeMenuShow,this)}return a},processEvent:function(b,i){Ext.grid.GroupingView.superclass.processEvent.call(this,b,i);var h=i.getTarget(".x-grid-group-hd",this.mainBody);if(h){var g=this.getGroupField(),d=this.getPrefix(g),a=h.id.substring(d.length),c=new RegExp("gp-"+Ext.escapeRe(g)+"--hd");a=a.substr(0,a.length-3);if(a||c.test(h.id)){this.grid.fireEvent("group"+b,this.grid,g,a,i)}if(b=="mousedown"&&i.button==0){this.toggleGroup(h.parentNode)}}},onGroupByClick:function(){var a=this.grid;this.enableGrouping=true;a.store.groupBy(this.cm.getDataIndex(this.hdCtxIndex));a.fireEvent("groupchange",a,a.store.getGroupState());this.beforeMenuShow();this.refresh()},onShowGroupsClick:function(a,b){this.enableGrouping=b;if(b){this.onGroupByClick()}else{this.grid.store
 .clearGrouping();this.grid.fireEvent("groupchange",this,null)}},toggleRowIndex:function(c,a){if(!this.canGroup()){return}var b=this.getRow(c);if(b){this.toggleGroup(this.findGroup(b),a)}},toggleGroup:function(c,b){var a=Ext.get(c),d=Ext.util.Format.htmlEncode(a.id);b=Ext.isDefined(b)?b:a.hasClass("x-grid-group-collapsed");if(this.state[d]!==b){if(this.cancelEditOnToggle!==false){this.grid.stopEditing(true)}this.state[d]=b;a[b?"removeClass":"addClass"]("x-grid-group-collapsed")}},toggleAllGroups:function(c){var b=this.getGroups();for(var d=0,a=b.length;d<a;d++){this.toggleGroup(b[d],c)}},expandAllGroups:function(){this.toggleAllGroups(true)},collapseAllGroups:function(){this.toggleAllGroups(false)},getGroup:function(a,e,i,j,b,h){var c=this.cm.config[b],d=i?i.call(c.scope,a,{},e,j,b,h):String(a);if(d===""||d==="&#160;"){d=c.emptyGroupText||this.emptyGroupText}return d},getGroupField:function(){return this.grid.store.getGroupState()},afterRender:function(){if(!this.ds||!this.cm
 ){return}Ext.grid.GroupingView.superclass.afterRender.call(this);if(this.grid.deferRowRender){this.updateGroupWidths()}},afterRenderUI:function(){Ext.grid.GroupingView.superclass.afterRenderUI.call(this);if(this.enableGroupingMenu&&this.hmenu){this.hmenu.add("-",{itemId:"groupBy",text:this.groupByText,handler:this.onGroupByClick,scope:this,iconCls:"x-group-by-icon"});if(this.enableNoGroups){this.hmenu.add({itemId:"showGroups",text:this.showGroupsText,checked:true,checkHandler:this.onShowGroupsClick,scope:this})}this.hmenu.on("beforeshow",this.beforeMenuShow,this)}},renderRows:function(){var a=this.getGroupField();var e=!!a;if(this.hideGroupedColumn){var b=this.cm.findColumnIndex(a),d=Ext.isDefined(this.lastGroupField);if(!e&&d){this.mainBody.update("");this.cm.setHidden(this.cm.findColumnIndex(this.lastGroupField),false);delete this.lastGroupField}else{if(e&&!d){this.lastGroupField=a;this.cm.setHidden(b,true)}else{if(e&&d&&a!==this.lastGroupField){this.mainBody.update("");va
 r c=this.cm.findColumnIndex(this.lastGroupField);this.cm.setHidden(c,false);this.lastGroupField=a;this.cm.setHidden(b,true)}}}}return Ext.grid.GroupingView.superclass.renderRows.apply(this,arguments)},doRender:function(c,h,q,a,p,s){if(h.length<1){return""}if(!this.canGroup()||this.isUpdating){return Ext.grid.GroupingView.superclass.doRender.apply(this,arguments)}var z=this.getGroupField(),o=this.cm.findColumnIndex(z),w,j="width:"+this.getTotalWidth()+";",e=this.cm.config[o],b=e.groupRenderer||e.renderer,t=this.showGroupName?(e.groupName||e.header)+": ":"",y=[],l,u,v,n;for(u=0,v=h.length;u<v;u++){var k=a+u,m=h[u],d=m.data[z];w=this.getGroup(d,m,b,k,o,q);if(!l||l.group!=w){n=this.constructId(d,z,o);this.state[n]=!(Ext.isDefined(this.state[n])?!this.state[n]:this.startCollapsed);l={group:w,gvalue:d,text:t+w,groupId:n,startRow:k,rs:[m],cls:this.state[n]?"":"x-grid-group-collapsed",style:j};y.push(l)}else{l.rs.push(m)}m._groupId=n}var x=[];for(u=0,v=y.length;u<v;u++){w=y[u];this.
 doGroupStart(x,w,c,q,p);x[x.length]=Ext.grid.GroupingView.superclass.doRender.call(this,c,w.rs,q,w.startRow,p,s);this.doGroupEnd(x,w,c,q,p)}return x.join("")},getGroupId:function(a){var b=this.getGroupField();return this.constructId(a,b,this.cm.findColumnIndex(b))},constructId:function(c,e,a){var b=this.cm.config[a],d=b.groupRenderer||b.renderer,g=(this.groupMode=="value")?c:this.getGroup(c,{data:{}},d,0,a,this.ds);return this.getPrefix(e)+Ext.util.Format.htmlEncode(g)},canGroup:function(){return this.enableGrouping&&!!this.getGroupField()},getPrefix:function(a){return this.grid.getGridEl().id+"-gp-"+a+"-"},doGroupStart:function(a,d,b,e,c){a[a.length]=this.startGroup.apply(d)},doGroupEnd:function(a,d,b,e,c){a[a.length]=this.endGroup},getRows:function(){if(!this.canGroup()){return Ext.grid.GroupingView.superclass.getRows.call(this)}var k=[],c=this.getGroups(),h,e=0,a=c.length,d,b;for(;e<a;++e){h=c[e].childNodes[1];if(h){h=h.childNodes;for(d=0,b=h.length;d<b;++d){k[k.length]=h
 [d]}}}return k},updateGroupWidths:function(){if(!this.canGroup()||!this.hasRows()){return}var c=Math.max(this.cm.getTotalWidth(),this.el.dom.offsetWidth-this.getScrollOffset())+"px";var b=this.getGroups();for(var d=0,a=b.length;d<a;d++){b[d].firstChild.style.width=c}},onColumnWidthUpdated:function(c,a,b){Ext.grid.GroupingView.superclass.onColumnWidthUpdated.call(this,c,a,b);this.updateGroupWidths()},onAllColumnWidthsUpdated:function(a,b){Ext.grid.GroupingView.superclass.onAllColumnWidthsUpdated.call(this,a,b);this.updateGroupWidths()},onColumnHiddenUpdated:function(b,c,a){Ext.grid.GroupingView.superclass.onColumnHiddenUpdated.call(this,b,c,a);this.updateGroupWidths()},onLayout:function(){this.updateGroupWidths()},onBeforeRowSelect:function(b,a){this.toggleRowIndex(a,true)}});Ext.grid.GroupingView.GROUP_ID=1000;
\ No newline at end of file
Added: grass-web/trunk/user_map/lib/ext-base.js
--- grass-web/trunk/user_map/lib/ext-base.js	                        (rev 0)
+++ grass-web/trunk/user_map/lib/ext-base.js	2012-04-17 13:42:26 UTC (rev 51456)
@@ -0,0 +1,7 @@
+ * Ext JS Library 3.4.0
+ * Copyright(c) 2006-2011 Sencha Inc.
+ * licensing at sencha.com
+ * http://www.sencha.com/license
+window.undefined=window.undefined;Ext={version:"3.4.0",versionDetail:{major:3,minor:4,patch:0}};Ext.apply=function(d,e,b){if(b){Ext.apply(d,b)}if(d&&e&&typeof e=="object"){for(var a in e){d[a]=e[a]}}return d};(function(){var g=0,u=Object.prototype.toString,v=navigator.userAgent.toLowerCase(),A=function(e){return e.test(v)},i=document,n=i.documentMode,l=i.compatMode=="CSS1Compat",C=A(/opera/),h=A(/\bchrome\b/),w=A(/webkit/),z=!h&&A(/safari/),f=z&&A(/applewebkit\/4/),b=z&&A(/version\/3/),D=z&&A(/version\/4/),t=!C&&A(/msie/),r=t&&(A(/msie 7/)||n==7),q=t&&(A(/msie 8/)&&n!=7),p=t&&A(/msie 9/),s=t&&!r&&!q&&!p,o=!w&&A(/gecko/),d=o&&A(/rv:1\.8/),a=o&&A(/rv:1\.9/),x=t&&!l,B=A(/windows|win32/),k=A(/macintosh|mac os x/),j=A(/adobeair/),m=A(/linux/),c=/^https/i.test(window.location.protocol);if(s){try{i.execCommand("BackgroundImageCache",false,true)}catch(y){}}Ext.apply(Ext,{SSL_SECURE_URL:c&&t?'javascript:""':"about:blank",isStrict:l,isSecure:c,isReady:false,enableForcedBoxModel:false,
 enableGarbageCollector:true,enableListenerCollection:false,enableNestedListenerRemoval:false,USE_NATIVE_JSON:false,applyIf:function(E,F){if(E){for(var e in F){if(!Ext.isDefined(E[e])){E[e]=F[e]}}}return E},id:function(e,E){e=Ext.getDom(e,true)||{};if(!e.id){e.id=(E||"ext-gen")+(++g)}return e.id},extend:function(){var E=function(G){for(var F in G){this[F]=G[F]}};var e=Object.prototype.constructor;return function(L,I,K){if(typeof I=="object"){K=I;I=L;L=K.constructor!=e?K.constructor:function(){I.apply(this,arguments)}}var H=function(){},J,G=I.prototype;H.prototype=G;J=L.prototype=new H();J.constructor=L;L.superclass=G;if(G.constructor==e){G.constructor=I}L.override=function(F){Ext.override(L,F)};J.superclass=J.supr=(function(){return G});J.override=E;Ext.override(L,K);L.extend=function(F){return Ext.extend(L,F)};return L}}(),override:function(e,F){if(F){var E=e.prototype;Ext.apply(E,F);if(Ext.isIE&&F.hasOwnProperty("toString")){E.toString=F.toString}}},namespace:function(){var
  G=arguments.length,H=0,E,F,e,J,I,K;for(;H<G;++H){e=arguments[H];J=arguments[H].split(".");K=window[J[0]];if(K===undefined){K=window[J[0]]={}}I=J.slice(1);E=I.length;for(F=0;F<E;++F){K=K[I[F]]=K[I[F]]||{}}}return K},urlEncode:function(I,H){var F,E=[],G=encodeURIComponent;Ext.iterate(I,function(e,J){F=Ext.isEmpty(J);Ext.each(F?e:J,function(K){E.push("&",G(e),"=",(!Ext.isEmpty(K)&&(K!=e||!F))?(Ext.isDate(K)?Ext.encode(K).replace(/"/g,""):G(K)):"")})});if(!H){E.shift();H=""}return H+E.join("")},urlDecode:function(F,E){if(Ext.isEmpty(F)){return{}}var I={},H=F.split("&"),J=decodeURIComponent,e,G;Ext.each(H,function(K){K=K.split("=");e=J(K[0]);G=J(K[1]);I[e]=E||!I[e]?G:[].concat(I[e]).concat(G)});return I},urlAppend:function(e,E){if(!Ext.isEmpty(E)){return e+(e.indexOf("?")===-1?"?":"&")+E}return e},toArray:function(){return t?function(F,I,G,H){H=[];for(var E=0,e=F.length;E<e;E++){H.push(F[E])}return H.slice(I||0,G||H.length)}:function(e,F,E){return Array.prototype.slice.call(e,F|
 |0,E||e.length)}}(),isIterable:function(e){if(Ext.isArray(e)||e.callee){return true}if(/NodeList|HTMLCollection/.test(u.call(e))){return true}return((typeof e.nextNode!="undefined"||e.item)&&Ext.isNumber(e.length))},each:function(H,G,F){if(Ext.isEmpty(H,true)){return}if(!Ext.isIterable(H)||Ext.isPrimitive(H)){H=[H]}for(var E=0,e=H.length;E<e;E++){if(G.call(F||H[E],H[E],E,H)===false){return E}}},iterate:function(F,E,e){if(Ext.isEmpty(F)){return}if(Ext.isIterable(F)){Ext.each(F,E,e);return}else{if(typeof F=="object"){for(var G in F){if(F.hasOwnProperty(G)){if(E.call(e||F,G,F[G],F)===false){return}}}}}},getDom:function(F,E){if(!F||!i){return null}if(F.dom){return F.dom}else{if(typeof F=="string"){var G=i.getElementById(F);if(G&&t&&E){if(F==G.getAttribute("id")){return G}else{return null}}return G}else{return F}}},getBody:function(){return Ext.get(i.body||i.documentElement)},getHead:function(){var e;return function(){if(e==undefined){e=Ext.get(i.getElementsByTagName("head")[0])}
 return e}}(),removeNode:t&&!q?function(){var e;return function(E){if(E&&E.tagName!="BODY"){(Ext.enableNestedListenerRemoval)?Ext.EventManager.purgeElement(E,true):Ext.EventManager.removeAll(E);e=e||i.createElement("div");e.appendChild(E);e.innerHTML="";delete Ext.elCache[E.id]}}}():function(e){if(e&&e.parentNode&&e.tagName!="BODY"){(Ext.enableNestedListenerRemoval)?Ext.EventManager.purgeElement(e,true):Ext.EventManager.removeAll(e);e.parentNode.removeChild(e);delete Ext.elCache[e.id]}},isEmpty:function(E,e){return E===null||E===undefined||((Ext.isArray(E)&&!E.length))||(!e?E==="":false)},isArray:function(e){return u.apply(e)==="[object Array]"},isDate:function(e){return u.apply(e)==="[object Date]"},isObject:function(e){return !!e&&Object.prototype.toString.call(e)==="[object Object]"},isPrimitive:function(e){return Ext.isString(e)||Ext.isNumber(e)||Ext.isBoolean(e)},isFunction:function(e){return u.apply(e)==="[object Function]"},isNumber:function(e){return typeof e==="numbe
 r"&&isFinite(e)},isString:function(e){return typeof e==="string"},isBoolean:function(e){return typeof e==="boolean"},isElement:function(e){return e?!!e.tagName:false},isDefined:function(e){return typeof e!=="undefined"},isOpera:C,isWebKit:w,isChrome:h,isSafari:z,isSafari3:b,isSafari4:D,isSafari2:f,isIE:t,isIE6:s,isIE7:r,isIE8:q,isIE9:p,isGecko:o,isGecko2:d,isGecko3:a,isBorderBox:x,isLinux:m,isWindows:B,isMac:k,isAir:j});Ext.ns=Ext.namespace})();Ext.ns("Ext.util","Ext.lib","Ext.data","Ext.supports");Ext.elCache={};Ext.apply(Function.prototype,{createInterceptor:function(b,a){var c=this;return !Ext.isFunction(b)?this:function(){var e=this,d=arguments;b.target=e;b.method=c;return(b.apply(a||e||window,d)!==false)?c.apply(e||window,d):null}},createCallback:function(){var a=arguments,b=this;return function(){return b.apply(window,a)}},createDelegate:function(c,b,a){var d=this;return function(){var f=b||arguments;if(a===true){f=Array.prototype.slice.call(arguments,0);f=f.concat(b)}
 else{if(Ext.isNumber(a)){f=Array.prototype.slice.call(arguments,0);var e=[a,0].concat(b);Array.prototype.splice.apply(f,e)}}return d.apply(c||window,f)}},defer:function(c,e,b,a){var d=this.createDelegate(e,b,a);if(c>0){return setTimeout(d,c)}d();return 0}});Ext.applyIf(String,{format:function(b){var a=Ext.toArray(arguments,1);return b.replace(/\{(\d+)\}/g,function(c,d){return a[d]})}});Ext.applyIf(Array.prototype,{indexOf:function(b,c){var a=this.length;c=c||0;c+=(c<0)?a:0;for(;c<a;++c){if(this[c]===b){return c}}return -1},remove:function(b){var a=this.indexOf(b);if(a!=-1){this.splice(a,1)}return this}});Ext.util.TaskRunner=function(e){e=e||10;var f=[],a=[],b=0,g=false,d=function(){g=false;clearInterval(b);b=0},h=function(){if(!g){g=true;b=setInterval(i,e)}},c=function(j){a.push(j);if(j.onStop){j.onStop.apply(j.scope||j)}},i=function(){var l=a.length,n=new Date().getTime();if(l>0){for(var p=0;p<l;p++){f.remove(a[p])}a=[];if(f.length<1){d();return}}for(var p=0,o,k,m,j=f.lengt
 h;p<j;++p){o=f[p];k=n-o.taskRunTime;if(o.interval<=k){m=o.run.apply(o.scope||o,o.args||[++o.taskRunCount]);o.taskRunTime=n;if(m===false||o.taskRunCount===o.repeat){c(o);return}}if(o.duration&&o.duration<=(n-o.taskStartTime)){c(o)}}};this.start=function(j){f.push(j);j.taskStartTime=new Date().getTime();j.taskRunTime=0;j.taskRunCount=0;h();return j};this.stop=function(j){c(j);return j};this.stopAll=function(){d();for(var k=0,j=f.length;k<j;k++){if(f[k].onStop){f[k].onStop()}}f=[];a=[]}};Ext.TaskMgr=new Ext.util.TaskRunner();(function(){var b;function c(d){if(!b){b=new Ext.Element.Flyweight()}b.dom=d;return b}(function(){var g=document,e=g.compatMode=="CSS1Compat",f=Math.max,d=Math.round,h=parseInt;Ext.lib.Dom={isAncestor:function(j,k){var i=false;j=Ext.getDom(j);k=Ext.getDom(k);if(j&&k){if(j.contains){return j.contains(k)}else{if(j.compareDocumentPosition){return !!(j.compareDocumentPosition(k)&16)}else{while(k=k.parentNode){i=k==j||i}}}}return i},getViewWidth:function(i){retu
 rn i?this.getDocumentWidth():this.getViewportWidth()},getViewHeight:function(i){return i?this.getDocumentHeight():this.getViewportHeight()},getDocumentHeight:function(){return f(!e?g.body.scrollHeight:g.documentElement.scrollHeight,this.getViewportHeight())},getDocumentWidth:function(){return f(!e?g.body.scrollWidth:g.documentElement.scrollWidth,this.getViewportWidth())},getViewportHeight:function(){return Ext.isIE?(Ext.isStrict?g.documentElement.clientHeight:g.body.clientHeight):self.innerHeight},getViewportWidth:function(){return !Ext.isStrict&&!Ext.isOpera?g.body.clientWidth:Ext.isIE?g.documentElement.clientWidth:self.innerWidth},getY:function(i){return this.getXY(i)[1]},getX:function(i){return this.getXY(i)[0]},getXY:function(k){var j,q,s,v,l,m,u=0,r=0,t,i,n=(g.body||g.documentElement),o=[0,0];k=Ext.getDom(k);if(k!=n){if(k.getBoundingClientRect){s=k.getBoundingClientRect();t=c(document).getScroll();o=[d(s.left+t.left),d(s.top+t.top)]}else{j=k;i=c(k).isStyle("position","a
 bsolute");while(j){q=c(j);u+=j.offsetLeft;r+=j.offsetTop;i=i||q.isStyle("position","absolute");if(Ext.isGecko){r+=v=h(q.getStyle("borderTopWidth"),10)||0;u+=l=h(q.getStyle("borderLeftWidth"),10)||0;if(j!=k&&!q.isStyle("overflow","visible")){u+=l;r+=v}}j=j.offsetParent}if(Ext.isSafari&&i){u-=n.offsetLeft;r-=n.offsetTop}if(Ext.isGecko&&!i){m=c(n);u+=h(m.getStyle("borderLeftWidth"),10)||0;r+=h(m.getStyle("borderTopWidth"),10)||0}j=k.parentNode;while(j&&j!=n){if(!Ext.isOpera||(j.tagName!="TR"&&!c(j).isStyle("display","inline"))){u-=j.scrollLeft;r-=j.scrollTop}j=j.parentNode}o=[u,r]}}return o},setXY:function(j,k){(j=Ext.fly(j,"_setXY")).position();var l=j.translatePoints(k),i=j.dom.style,m;for(m in l){if(!isNaN(l[m])){i[m]=l[m]+"px"}}},setX:function(j,i){this.setXY(j,[i,false])},setY:function(i,j){this.setXY(i,[false,j])}}})();Ext.lib.Event=function(){var v=false,f={},z=0,o=[],d,A=false,k=window,E=document,l=200,r=20,p=0,i=1,s=2,w=3,t="scrollLeft",q="scrollTop",g="unload",y="mous
 eover",D="mouseout",e=function(){var F;if(k.addEventListener){F=function(J,H,I,G){if(H=="mouseenter"){I=I.createInterceptor(n);J.addEventListener(y,I,(G))}else{if(H=="mouseleave"){I=I.createInterceptor(n);J.addEventListener(D,I,(G))}else{J.addEventListener(H,I,(G))}}return I}}else{if(k.attachEvent){F=function(J,H,I,G){J.attachEvent("on"+H,I);return I}}else{F=function(){}}}return F}(),h=function(){var F;if(k.removeEventListener){F=function(J,H,I,G){if(H=="mouseenter"){H=y}else{if(H=="mouseleave"){H=D}}J.removeEventListener(H,I,(G))}}else{if(k.detachEvent){F=function(I,G,H){I.detachEvent("on"+G,H)}}else{F=function(){}}}return F}();function n(F){return !u(F.currentTarget,x.getRelatedTarget(F))}function u(F,G){if(F&&F.firstChild){while(G){if(G===F){return true}G=G.parentNode;if(G&&(G.nodeType!=1)){G=null}}}return false}function B(){var G=false,L=[],J,I,F,H,K=!v||(z>0);if(!A){A=true;for(I=0;I<o.length;++I){F=o[I];if(F&&(J=E.getElementById(F.id))){if(!F.checkReady||v||J.nextSiblin
 g||(E&&E.body)){H=F.override;J=H?(H===true?F.obj:H):J;F.fn.call(J,F.obj);o.remove(F);--I}else{L.push(F)}}}z=(L.length===0)?0:z-1;if(K){m()}else{clearInterval(d);d=null}G=!(A=false)}return G}function m(){if(!d){var F=function(){B()};d=setInterval(F,r)}}function C(){var F=E.documentElement,G=E.body;if(F&&(F[q]||F[t])){return[F[t],F[q]]}else{if(G){return[G[t],G[q]]}else{return[0,0]}}}function j(F,G){F=F.browserEvent||F;var H=F["page"+G];if(!H&&H!==0){H=F["client"+G]||0;if(Ext.isIE){H+=C()[G=="X"?0:1]}}return H}var x={extAdapter:true,onAvailable:function(H,F,I,G){o.push({id:H,fn:F,obj:I,override:G,checkReady:false});z=l;m()},addListener:function(H,F,G){H=Ext.getDom(H);if(H&&G){if(F==g){if(f[H.id]===undefined){f[H.id]=[]}f[H.id].push([F,G]);return G}return e(H,F,G,false)}return false},removeListener:function(L,H,K){L=Ext.getDom(L);var J,G,F,I;if(L&&K){if(H==g){if((I=f[L.id])!==undefined){for(J=0,G=I.length;J<G;J++){if((F=I[J])&&F[p]==H&&F[i]==K){f[L.id].splice(J,1)}}}return}h(L,H
 ,K,false)}},getTarget:function(F){F=F.browserEvent||F;return this.resolveTextNode(F.target||F.srcElement)},resolveTextNode:Ext.isGecko?function(G){if(!G){return}var F=HTMLElement.prototype.toString.call(G);if(F=="[xpconnect wrapped native prototype]"||F=="[object XULElement]"){return}return G.nodeType==3?G.parentNode:G}:function(F){return F&&F.nodeType==3?F.parentNode:F},getRelatedTarget:function(F){F=F.browserEvent||F;return this.resolveTextNode(F.relatedTarget||(/(mouseout|mouseleave)/.test(F.type)?F.toElement:/(mouseover|mouseenter)/.test(F.type)?F.fromElement:null))},getPageX:function(F){return j(F,"X")},getPageY:function(F){return j(F,"Y")},getXY:function(F){return[this.getPageX(F),this.getPageY(F)]},stopEvent:function(F){this.stopPropagation(F);this.preventDefault(F)},stopPropagation:function(F){F=F.browserEvent||F;if(F.stopPropagation){F.stopPropagation()}else{F.cancelBubble=true}},preventDefault:function(F){F=F.browserEvent||F;if(F.preventDefault){F.preventDefault()}
 else{if(F.keyCode){F.keyCode=0}F.returnValue=false}},getEvent:function(F){F=F||k.event;if(!F){var G=this.getEvent.caller;while(G){F=G.arguments[0];if(F&&Event==F.constructor){break}G=G.caller}}return F},getCharCode:function(F){F=F.browserEvent||F;return F.charCode||F.keyCode||0},getListeners:function(G,F){Ext.EventManager.getListeners(G,F)},purgeElement:function(G,H,F){Ext.EventManager.purgeElement(G,H,F)},_load:function(F){v=true;if(Ext.isIE&&F!==true){h(k,"load",arguments.callee)}},_unload:function(J){var G=Ext.lib.Event,H,M,K,F,I,N;for(F in f){K=f[F];for(H=0,I=K.length;H<I;H++){M=K[H];if(M){try{N=M[w]?(M[w]===true?M[s]:M[w]):k;M[i].call(N,G.getEvent(J),M[s])}catch(L){}}}}Ext.EventManager._unload();h(k,g,G._unload)}};x.on=x.addListener;x.un=x.removeListener;if(E&&E.body){x._load(true)}else{e(k,"load",x._load)}e(k,g,x._unload);B();return x}();Ext.lib.Ajax=function(){var g=["Msxml2.XMLHTTP.6.0","Msxml2.XMLHTTP.3.0","Msxml2.XMLHTTP"],d="Content-Type";function h(v){var t=v.con
 n,w,u={};function s(x,y){for(w in y){if(y.hasOwnProperty(w)){x.setRequestHeader(w,y[w])}}}Ext.apply(u,k.headers,k.defaultHeaders);s(t,u);delete k.headers}function e(v,u,t,s){return{tId:v,status:t?-1:0,statusText:t?"transaction aborted":"communication failure",isAbort:t,isTimeout:s,argument:u}}function j(s,t){(k.headers=k.headers||{})[s]=t}function p(u,y){var C={},x,w=u.conn,A,B,v=w.status==1223;try{x=u.conn.getAllResponseHeaders();Ext.each(x.replace(/\r\n/g,"\n").split("\n"),function(s){A=s.indexOf(":");if(A>=0){B=s.substr(0,A).toLowerCase();if(s.charAt(A+1)==" "){++A}C[B]=s.substr(A+1)}})}catch(z){}return{tId:u.tId,status:v?204:w.status,statusText:v?"No Content":w.statusText,getResponseHeader:function(s){return C[s.toLowerCase()]},getAllResponseHeaders:function(){return x},responseText:w.responseText,responseXML:w.responseXML,argument:y}}function o(s){if(s.tId){k.conn[s.tId]=null}s.conn=null;s=null}function f(x,y,t,s){if(!y){o(x);return}var v,u;try{if(x.conn.status!==undefi
 ned&&x.conn.status!=0){v=x.conn.status}else{v=13030}}catch(w){v=13030}if((v>=200&&v<300)||(Ext.isIE&&v==1223)){u=p(x,y.argument);if(y.success){if(!y.scope){y.success(u)}else{y.success.apply(y.scope,[u])}}}else{switch(v){case 12002:case 12029:case 12030:case 12031:case 12152:case 13030:u=e(x.tId,y.argument,(t?t:false),s);if(y.failure){if(!y.scope){y.failure(u)}else{y.failure.apply(y.scope,[u])}}break;default:u=p(x,y.argument);if(y.failure){if(!y.scope){y.failure(u)}else{y.failure.apply(y.scope,[u])}}}}o(x);u=null}function m(u,x,s,w,t,v){if(s&&s.readyState==4){clearInterval(t[w]);t[w]=null;if(v){clearTimeout(k.timeout[w]);k.timeout[w]=null}f(u,x)}}function r(s,t){k.abort(s,t,true)}function n(u,x){x=x||{};var s=u.conn,w=u.tId,t=k.poll,v=x.timeout||null;if(v){k.conn[w]=s;k.timeout[w]=setTimeout(r.createCallback(u,x),v)}t[w]=setInterval(m.createCallback(u,x,s,w,t,v),k.pollInterval)}function i(w,t,v,s){var u=l()||null;if(u){u.conn.open(w,t,true);if(k.useDefaultXhrHeader){j("X-Requ
 ested-With",k.defaultXhrHeader)}if(s&&k.useDefaultHeader&&(!k.headers||!k.headers[d])){j(d,k.defaultPostHeader)}if(k.defaultHeaders||k.headers){h(u)}n(u,v);u.conn.send(s||null)}return u}function l(){var t;try{if(t=q(k.transactionId)){k.transactionId++}}catch(s){}finally{return t}}function q(v){var s;try{s=new XMLHttpRequest()}catch(u){for(var t=Ext.isIE6?1:0;t<g.length;++t){try{s=new ActiveXObject(g[t]);break}catch(u){}}}finally{return{conn:s,tId:v}}}var k={request:function(s,u,v,w,A){if(A){var x=this,t=A.xmlData,y=A.jsonData,z;Ext.applyIf(x,A);if(t||y){z=x.headers;if(!z||!z[d]){j(d,t?"text/xml":"application/json")}w=t||(!Ext.isPrimitive(y)?Ext.encode(y):y)}}return i(s||A.method||"POST",u,v,w)},serializeForm:function(y){var x=y.elements||(document.forms[y]||Ext.getDom(y)).elements,s=false,w=encodeURIComponent,t,z="",v,u;Ext.each(x,function(A){t=A.name;v=A.type;if(!A.disabled&&t){if(/select-(one|multiple)/i.test(v)){Ext.each(A.options,function(B){if(B.selected){u=B.hasAttribu
 te?B.hasAttribute("value"):B.getAttributeNode("value").specified;z+=String.format("{0}={1}&",w(t),w(u?B.value:B.text))}})}else{if(!(/file|undefined|reset|button/i.test(v))){if(!(/radio|checkbox/i.test(v)&&!A.checked)&&!(v=="submit"&&s)){z+=w(t)+"="+w(A.value)+"&";s=/submit/i.test(v)}}}}});return z.substr(0,z.length-1)},useDefaultHeader:true,defaultPostHeader:"application/x-www-form-urlencoded; charset=UTF-8",useDefaultXhrHeader:true,defaultXhrHeader:"XMLHttpRequest",poll:{},timeout:{},conn:{},pollInterval:50,transactionId:0,abort:function(v,x,s){var u=this,w=v.tId,t=false;if(u.isCallInProgress(v)){v.conn.abort();clearInterval(u.poll[w]);u.poll[w]=null;clearTimeout(k.timeout[w]);u.timeout[w]=null;f(v,x,(t=true),s)}return t},isCallInProgress:function(s){return s.conn&&!{0:true,4:true}[s.conn.readyState]}};return k}();(function(){var g=Ext.lib,i=/width|height|opacity|padding/i,f=/^((width|height)|(top|left))$/,d=/width|height|top$|bottom$|left$|right$/i,h=/\d+(em|%|en|ex|pt|in|
 cm|mm|pc)$/i,j=function(k){return typeof k!=="undefined"},e=function(){return new Date()};g.Anim={motion:function(n,l,o,p,k,m){return this.run(n,l,o,p,k,m,Ext.lib.Motion)},run:function(o,l,q,r,k,n,m){m=m||Ext.lib.AnimBase;if(typeof r=="string"){r=Ext.lib.Easing[r]}var p=new m(o,l,q,r);p.animateX(function(){if(Ext.isFunction(k)){k.call(n)}});return p}};g.AnimBase=function(l,k,m,n){if(l){this.init(l,k,m,n)}};g.AnimBase.prototype={doMethod:function(k,n,l){var m=this;return m.method(m.curFrame,n,l-n,m.totalFrames)},setAttr:function(k,m,l){if(i.test(k)&&m<0){m=0}Ext.fly(this.el,"_anim").setStyle(k,m+l)},getAttr:function(k){var m=Ext.fly(this.el),n=m.getStyle(k),l=f.exec(k)||[];if(n!=="auto"&&!h.test(n)){return parseFloat(n)}return(!!(l[2])||(m.getStyle("position")=="absolute"&&!!(l[3])))?m.dom["offset"+l[0].charAt(0).toUpperCase()+l[0].substr(1)]:0},getDefaultUnit:function(k){return d.test(k)?"px":""},animateX:function(n,k){var l=this,m=function(){l.onComplete.removeListener(m);i
 f(Ext.isFunction(n)){n.call(k||l,l)}};l.onComplete.addListener(m,l);l.animate()},setRunAttr:function(p){var r=this,s=this.attributes[p],t=s.to,q=s.by,u=s.from,v=s.unit,l=(this.runAttrs[p]={}),m;if(!j(t)&&!j(q)){return false}var k=j(u)?u:r.getAttr(p);if(j(t)){m=t}else{if(j(q)){if(Ext.isArray(k)){m=[];for(var n=0,o=k.length;n<o;n++){m[n]=k[n]+q[n]}}else{m=k+q}}}Ext.apply(l,{start:k,end:m,unit:j(v)?v:r.getDefaultUnit(p)})},init:function(l,p,o,k){var r=this,n=0,s=g.AnimMgr;Ext.apply(r,{isAnimated:false,startTime:null,el:Ext.getDom(l),attributes:p||{},duration:o||1,method:k||g.Easing.easeNone,useSec:true,curFrame:0,totalFrames:s.fps,runAttrs:{},animate:function(){var u=this,v=u.duration;if(u.isAnimated){return false}u.curFrame=0;u.totalFrames=u.useSec?Math.ceil(s.fps*v):v;s.registerElement(u)},stop:function(u){var v=this;if(u){v.curFrame=v.totalFrames;v._onTween.fire()}s.stop(v)}});var t=function(){var v=this,u;v.onStart.fire();v.runAttrs={};for(u in this.attributes){this.setRunA
 ttr(u)}v.isAnimated=true;v.startTime=e();n=0};var q=function(){var v=this;v.onTween.fire({duration:e()-v.startTime,curFrame:v.curFrame});var w=v.runAttrs;for(var u in w){this.setAttr(u,v.doMethod(u,w[u].start,w[u].end),w[u].unit)}++n};var m=function(){var u=this,w=(e()-u.startTime)/1000,v={duration:w,frames:n,fps:n/w};u.isAnimated=false;n=0;u.onComplete.fire(v)};r.onStart=new Ext.util.Event(r);r.onTween=new Ext.util.Event(r);r.onComplete=new Ext.util.Event(r);(r._onStart=new Ext.util.Event(r)).addListener(t);(r._onTween=new Ext.util.Event(r)).addListener(q);(r._onComplete=new Ext.util.Event(r)).addListener(m)}};Ext.lib.AnimMgr=new function(){var o=this,m=null,l=[],k=0;Ext.apply(o,{fps:1000,delay:1,registerElement:function(q){l.push(q);++k;q._onStart.fire();o.start()},unRegister:function(r,q){r._onComplete.fire();q=q||p(r);if(q!=-1){l.splice(q,1)}if(--k<=0){o.stop()}},start:function(){if(m===null){m=setInterval(o.run,o.delay)}},stop:function(s){if(!s){clearInterval(m);for(var
  r=0,q=l.length;r<q;++r){if(l[0].isAnimated){o.unRegister(l[0],0)}}l=[];m=null;k=0}else{o.unRegister(s)}},run:function(){var t,s,q,r;for(s=0,q=l.length;s<q;s++){r=l[s];if(r&&r.isAnimated){t=r.totalFrames;if(r.curFrame<t||t===null){++r.curFrame;if(r.useSec){n(r)}r._onTween.fire()}else{o.stop(r)}}}}});var p=function(s){var r,q;for(r=0,q=l.length;r<q;r++){if(l[r]===s){return r}}return -1};var n=function(r){var v=r.totalFrames,u=r.curFrame,t=r.duration,s=(u*t*1000/v),q=(e()-r.startTime),w=0;if(q<t*1000){w=Math.round((q/s-1)*u)}else{w=v-(u+1)}if(w>0&&isFinite(w)){if(r.curFrame+w>=v){w=v-(u+1)}r.curFrame+=w}}};g.Bezier=new function(){this.getPosition=function(p,o){var r=p.length,m=[],q=1-o,l,k;for(l=0;l<r;++l){m[l]=[p[l][0],p[l][1]]}for(k=1;k<r;++k){for(l=0;l<r-k;++l){m[l][0]=q*m[l][0]+o*m[parseInt(l+1,10)][0];m[l][1]=q*m[l][1]+o*m[parseInt(l+1,10)][1]}}return[m[0][0],m[0][1]]}};g.Easing={easeNone:function(l,k,n,m){return n*l/m+k},easeIn:function(l,k,n,m){return n*(l/=m)*l+k},ease
 Out:function(l,k,n,m){return -n*(l/=m)*(l-2)+k}};(function(){g.Motion=function(o,n,p,q){if(o){g.Motion.superclass.constructor.call(this,o,n,p,q)}};Ext.extend(g.Motion,Ext.lib.AnimBase);var m=g.Motion.superclass,l=/^points$/i;Ext.apply(g.Motion.prototype,{setAttr:function(n,r,q){var p=this,o=m.setAttr;if(l.test(n)){q=q||"px";o.call(p,"left",r[0],q);o.call(p,"top",r[1],q)}else{o.call(p,n,r,q)}},getAttr:function(n){var p=this,o=m.getAttr;return l.test(n)?[o.call(p,"left"),o.call(p,"top")]:o.call(p,n)},doMethod:function(n,q,o){var p=this;return l.test(n)?g.Bezier.getPosition(p.runAttrs[n],p.method(p.curFrame,0,100,p.totalFrames)/100):m.doMethod.call(p,n,q,o)},setRunAttr:function(u){if(l.test(u)){var w=this,p=this.el,z=this.attributes.points,s=z.control||[],x=z.from,y=z.to,v=z.by,A=g.Dom,o,r,q,t,n;if(s.length>0&&!Ext.isArray(s[0])){s=[s]}else{}Ext.fly(p,"_anim").position();A.setXY(p,j(x)?x:A.getXY(p));o=w.getAttr("points");if(j(y)){q=k.call(w,y,o);for(r=0,t=s.length;r<t;++r){s[r]
 =k.call(w,s[r],o)}}else{if(j(v)){q=[o[0]+v[0],o[1]+v[1]];for(r=0,t=s.length;r<t;++r){s[r]=[o[0]+s[r][0],o[1]+s[r][1]]}}}n=this.runAttrs[u]=[o];if(s.length>0){n=n.concat(s)}n[n.length]=q}else{m.setRunAttr.call(this,u)}}});var k=function(n,p){var o=g.Dom.getXY(this.el);return[n[0]-o[0]+p[0],n[1]-o[1]+p[1]]}})()})();(function(){var d=Math.abs,i=Math.PI,h=Math.asin,g=Math.pow,e=Math.sin,f=Ext.lib;Ext.apply(f.Easing,{easeBoth:function(k,j,m,l){return((k/=l/2)<1)?m/2*k*k+j:-m/2*((--k)*(k-2)-1)+j},easeInStrong:function(k,j,m,l){return m*(k/=l)*k*k*k+j},easeOutStrong:function(k,j,m,l){return -m*((k=k/l-1)*k*k*k-1)+j},easeBothStrong:function(k,j,m,l){return((k/=l/2)<1)?m/2*k*k*k*k+j:-m/2*((k-=2)*k*k*k-2)+j},elasticIn:function(l,j,q,o,k,n){if(l==0||(l/=o)==1){return l==0?j:j+q}n=n||(o*0.3);var m;if(k>=d(q)){m=n/(2*i)*h(q/k)}else{k=q;m=n/4}return -(k*g(2,10*(l-=1))*e((l*o-m)*(2*i)/n))+j},elasticOut:function(l,j,q,o,k,n){if(l==0||(l/=o)==1){return l==0?j:j+q}n=n||(o*0.3);var m;if(k>=d(q
 )){m=n/(2*i)*h(q/k)}else{k=q;m=n/4}return k*g(2,-10*l)*e((l*o-m)*(2*i)/n)+q+j},elasticBoth:function(l,j,q,o,k,n){if(l==0||(l/=o/2)==2){return l==0?j:j+q}n=n||(o*(0.3*1.5));var m;if(k>=d(q)){m=n/(2*i)*h(q/k)}else{k=q;m=n/4}return l<1?-0.5*(k*g(2,10*(l-=1))*e((l*o-m)*(2*i)/n))+j:k*g(2,-10*(l-=1))*e((l*o-m)*(2*i)/n)*0.5+q+j},backIn:function(k,j,n,m,l){l=l||1.70158;return n*(k/=m)*k*((l+1)*k-l)+j},backOut:function(k,j,n,m,l){if(!l){l=1.70158}return n*((k=k/m-1)*k*((l+1)*k+l)+1)+j},backBoth:function(k,j,n,m,l){l=l||1.70158;return((k/=m/2)<1)?n/2*(k*k*(((l*=(1.525))+1)*k-l))+j:n/2*((k-=2)*k*(((l*=(1.525))+1)*k+l)+2)+j},bounceIn:function(k,j,m,l){return m-f.Easing.bounceOut(l-k,0,m,l)+j},bounceOut:function(k,j,m,l){if((k/=l)<(1/2.75)){return m*(7.5625*k*k)+j}else{if(k<(2/2.75)){return m*(7.5625*(k-=(1.5/2.75))*k+0.75)+j}else{if(k<(2.5/2.75)){return m*(7.5625*(k-=(2.25/2.75))*k+0.9375)+j}}}return m*(7.5625*(k-=(2.625/2.75))*k+0.984375)+j},bounceBoth:function(k,j,m,l){return(k<l/2)?f
 .Easing.bounceIn(k*2,0,m,l)*0.5+j:f.Easing.bounceOut(k*2-l,0,m,l)*0.5+m*0.5+j}})})();(function(){var h=Ext.lib;h.Anim.color=function(p,n,q,r,m,o){return h.Anim.run(p,n,q,r,m,o,h.ColorAnim)};h.ColorAnim=function(n,m,o,p){h.ColorAnim.superclass.constructor.call(this,n,m,o,p)};Ext.extend(h.ColorAnim,h.AnimBase);var j=h.ColorAnim.superclass,i=/color$/i,f=/^transparent|rgba\(0, 0, 0, 0\)$/,l=/^rgb\(([0-9]+)\s*,\s*([0-9]+)\s*,\s*([0-9]+)\)$/i,d=/^#?([0-9A-F]{2})([0-9A-F]{2})([0-9A-F]{2})$/i,e=/^#?([0-9A-F]{1})([0-9A-F]{1})([0-9A-F]{1})$/i,g=function(m){return typeof m!=="undefined"};function k(n){var p=parseInt,o,m=null,q;if(n.length==3){return n}Ext.each([d,l,e],function(s,r){o=(r%2==0)?16:10;q=s.exec(n);if(q&&q.length==4){m=[p(q[1],o),p(q[2],o),p(q[3],o)];return false}});return m}Ext.apply(h.ColorAnim.prototype,{getAttr:function(m){var o=this,n=o.el,p;if(i.test(m)){while(n&&f.test(p=Ext.fly(n).getStyle(m))){n=n.parentNode;p="fff"}}else{p=j.getAttr.call(o,m)}return p},doMethod:fu
 nction(s,m,o){var t=this,n,q=Math.floor,p,r,u;if(i.test(s)){n=[];o=o||[];for(p=0,r=m.length;p<r;p++){u=m[p];n[p]=j.doMethod.call(t,s,u,o[p])}n="rgb("+q(n[0])+","+q(n[1])+","+q(n[2])+")"}else{n=j.doMethod.call(t,s,m,o)}return n},setRunAttr:function(r){var t=this,u=t.attributes[r],v=u.to,s=u.by,n;j.setRunAttr.call(t,r);n=t.runAttrs[r];if(i.test(r)){var m=k(n.start),o=k(n.end);if(!g(v)&&g(s)){o=k(s);for(var p=0,q=m.length;p<q;p++){o[p]=m[p]+o[p]}}n.start=m;n.end=o}}})})();(function(){var d=Ext.lib;d.Anim.scroll=function(j,h,k,l,g,i){return d.Anim.run(j,h,k,l,g,i,d.Scroll)};d.Scroll=function(h,g,i,j){if(h){d.Scroll.superclass.constructor.call(this,h,g,i,j)}};Ext.extend(d.Scroll,d.ColorAnim);var f=d.Scroll.superclass,e="scroll";Ext.apply(d.Scroll.prototype,{doMethod:function(g,m,h){var k,j=this,l=j.curFrame,i=j.totalFrames;if(g==e){k=[j.method(l,m[0],h[0]-m[0],i),j.method(l,m[1],h[1]-m[1],i)]}else{k=f.doMethod.call(j,g,m,h)}return k},getAttr:function(g){var h=this;if(g==e){return
 [h.el.scrollLeft,h.el.scrollTop]}else{return f.getAttr.call(h,g)}},setAttr:function(g,j,i){var h=this;if(g==e){h.el.scrollLeft=j[0];h.el.scrollTop=j[1]}else{f.setAttr.call(h,g,j,i)}}})})();if(Ext.isIE){function a(){var d=Function.prototype;delete d.createSequence;delete d.defer;delete d.createDelegate;delete d.createCallback;delete d.createInterceptor;window.detachEvent("onunload",a)}window.attachEvent("onunload",a)}})();
Added: grass-web/trunk/user_map/lib/grass_theme/convert_color_ranges.sh
--- grass-web/trunk/user_map/lib/grass_theme/convert_color_ranges.sh	                        (rev 0)
+++ grass-web/trunk/user_map/lib/grass_theme/convert_color_ranges.sh	2012-04-17 13:42:26 UTC (rev 51456)
@@ -0,0 +1,62 @@
+#!/bin/bash
+prefix="images/"
+folders=( "box" "button" "form" "grid" "layout" "menu" "panel" "progress" "qtip" "shared" "sizer" "slider" "tabs" "toolbar" "window" )
+for i in `ls -1 ${prefix}window/icon-*`; do
+    mv $i ${i}_old
+done
+mv ${prefix}shared/calendar.gif ${prefix}shared/calendar.gif_old
+mv ${prefix}shared/large_loading.gif ${prefix}shared/large_loading.gif_old
+mv ${prefix}shared/warning.gif ${prefix}shared/warning.gif_old
+for i in `ls -1 ${prefix}grid/drop-*`; do
+    mv $i ${i}_old
+done
+for i in `ls -1 ${prefix}grid/hmenu-*`; do
+    mv $i ${i}_old
+done
+mv ${prefix}form/exclamation.gif ${prefix}form/exclamation.gif_old
+for f in "${folders[@]}"; do
+    for l in `ls -1 ${prefix}${f}/`; do
+#         name=`echo $l | cut -d'.' -f'-1'`
+        name=`echo ${l%.*}`;
+        ext=`echo ${l#*.}`;
+        echo "$name $ext";
+        old=`echo $ext | cut -d'_' -f2`;
+        if [ "$old" != "old" ]; then
+            if [ "$ext" != "psd" ]; then
+                # convert RGB -> HIS (HSB), http://www.imagemagick.org/script/convert.php
+                convert -colorspace HSB ${prefix}${f}/$l ${prefix}${f}/${name}_HSB.${ext};
+                # change Hue from Blue to Green, http://www.imagemagick.org/script/command-line-options.php#modulate
+                convert -modulate 100,100,50 ${prefix}${f}/${name}_HSB.${ext} ${prefix}${f}/${name}_HSB_green.${ext} ;
+                # convert HSB -> RGB
+                convert -colorspace RGB ${prefix}${f}/${name}_HSB_green.${ext} ${prefix}${f}/$l;
+                rm -f ${prefix}${f}/${name}_HSB.${ext} ${prefix}${f}/${name}_HSB_green.${ext}
+            fi
+        fi
+    done
+done
+for i in `ls -1 ${prefix}window/*_old`; do
+    pref=`echo $i | cut -d'_' -f1`
+    mv $i $pref
+done
+mv ${prefix}shared/calendar.gif_old ${prefix}shared/calendar.gif
+mv ${prefix}shared/large_loading.gif_old ${prefix}shared/large_loading.gif
+mv ${prefix}shared/warning.gif_old ${prefix}shared/warning.gif
+for i in `ls -1 ${prefix}grid/*_old`; do
+    mv $i $pref
+done
+mv ${prefix}form/exclamation.gif_old ${prefix}form/exclamation.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/convert_color_ranges.sh
___________________________________________________________________
Added: svn:executable
Added: grass-web/trunk/user_map/lib/grass_theme/ext-all.css
--- grass-web/trunk/user_map/lib/grass_theme/ext-all.css	                        (rev 0)
+++ grass-web/trunk/user_map/lib/grass_theme/ext-all.css	2012-04-17 13:42:26 UTC (rev 51456)
@@ -0,0 +1,6993 @@
+html,body,div,dl,dt,dd,ul,ol,li,h1,h2,h3,h4,h5,h6,pre,form,fieldset,input,p,blockquote,th,td{margin:0;padding:0;}img,body,html{border:0;}address,caption,cite,code,dfn,em,strong,th,var{font-style:normal;font-weight:normal;}ol,ul {list-style:none;}caption,th {text-align:left;}h1,h2,h3,h4,h5,h6{font-size:100%;}q:before,q:after{content:'';}
+.ext-forced-border-box, .ext-forced-border-box * {
+    -moz-box-sizing: border-box;
+    -ms-box-sizing: border-box;
+    -webkit-box-sizing: border-box;
+.ext-el-mask {
+    z-index: 100;
+    position: absolute;
+    top:0;
+    left:0;
+    -moz-opacity: 0.5;
+    opacity: .50;
+    filter: alpha(opacity=50);
+    width: 100%;
+    height: 100%;
+    zoom: 1;
+.ext-el-mask-msg {
+    z-index: 20001;
+    top: 0;
+    left: 0;
+    border:1px solid;
+    background:repeat-x 0 -16px;
+    padding:2px;
+.ext-el-mask-msg div {
+    padding:5px 10px 5px 10px;
+    border:1px solid;
+    cursor:wait;
+.ext-shim {
+    position:absolute;
+    visibility:hidden;
+    left:0;
+    top:0;
+    overflow:hidden;
+.ext-ie .ext-shim {
+    filter: alpha(opacity=0);
+.ext-ie6 .ext-shim {
+    margin-left: 5px;
+    margin-top: 3px;
+.x-mask-loading div {
+    padding:5px 10px 5px 25px;
+    background:no-repeat 5px 5px;
+    line-height:16px;
+/* class for hiding elements without using display:none */
+.x-hidden, .x-hide-offsets {
+    position:absolute !important;
+    left:-10000px;
+    top:-10000px;
+.x-hide-display {
+    display:none !important;
+.x-hide-nosize,
+.x-hide-nosize *    /* Emulate display:none for children */
+   height:0px!important;
+   width:0px!important;
+   visibility:hidden!important;
+   border:none!important;
+   zoom:1;
+.x-hide-visibility {
+    visibility:hidden !important;
+.x-masked {
+    overflow: hidden !important;
+.x-masked-relative {
+    position: relative !important;
+.x-masked select, .x-masked object, .x-masked embed {
+    visibility: hidden;
+.x-layer {
+.x-unselectable, .x-unselectable * {
+    -moz-user-select: none;
+    -khtml-user-select: none;
+    -webkit-user-select:ignore;
+.x-repaint {
+    zoom: 1;
+    background-color: transparent;
+    -moz-outline: none;
+    outline: none;
+.x-item-disabled {
+    cursor: default;
+    opacity: .6;
+    -moz-opacity: .6;
+    filter: alpha(opacity=60);
+.x-item-disabled * {
+    cursor: default !important;
+.x-form-radio-group .x-item-disabled {
+    filter: none;
+.x-splitbar-proxy {
+    z-index: 20001;
+    zoom: 1;
+    line-height: 1px;
+    font-size: 1px;
+    overflow: hidden;
+.x-splitbar-h, .x-splitbar-proxy-h {
+    cursor: e-resize;
+    cursor: col-resize;
+.x-splitbar-v, .x-splitbar-proxy-v {
+    cursor: s-resize;
+    cursor: row-resize;
+.x-color-palette {
+    width: 150px;
+    height: 92px;
+    cursor: pointer;
+.x-color-palette a {
+    border: 1px solid;
+    float: left;
+    padding: 2px;
+    text-decoration: none;
+    -moz-outline: 0 none;
+    outline: 0 none;
+    cursor: pointer;
+.x-color-palette a:hover, .x-color-palette a.x-color-palette-sel {
+.x-color-palette em {
+    display: block;
+.x-color-palette em span {
+    cursor: pointer;
+    display: block;
+    height: 10px;
+    line-height: 10px;
+    width: 10px;
+.x-ie-shadow {
+    display: none;
+    overflow: hidden;
+    left:0;
+    top:0;
+    zoom:1;
+.x-shadow {
+    display: none;
+    overflow: hidden;
+    left:0;
+    top:0;
+.x-shadow * {
+    overflow: hidden;
+.x-shadow * {
+    padding: 0;
+    border: 0;
+    margin: 0;
+    clear: none;
+    zoom: 1;
+/* top  bottom */
+.x-shadow .xstc, .x-shadow .xsbc {
+    height: 6px;
+    float: left;
+/* corners */
+.x-shadow .xstl, .x-shadow .xstr, .x-shadow .xsbl, .x-shadow .xsbr {
+    width: 6px;
+    height: 6px;
+    float: left;
+/* sides */
+.x-shadow .xsc {
+    width: 100%;
+.x-shadow .xsml, .x-shadow .xsmr {
+    width: 6px;
+    float: left;
+    height: 100%;
+.x-shadow .xsmc {
+    float: left;
+    height: 100%;
+.x-shadow .xst, .x-shadow .xsb {
+    height: 6px;
+    overflow: hidden;
+    width: 100%;
+.x-shadow .xsml {
+    background: transparent repeat-y 0 0;
+.x-shadow .xsmr {
+    background: transparent repeat-y -6px 0;
+.x-shadow .xstl {
+    background: transparent no-repeat 0 0;
+.x-shadow .xstc {
+    background: transparent repeat-x 0 -30px;
+.x-shadow .xstr {
+    background: transparent repeat-x 0 -18px;
+.x-shadow .xsbl {
+    background: transparent no-repeat 0 -12px;
+.x-shadow .xsbc {
+    background: transparent repeat-x 0 -36px;
+.x-shadow .xsbr {
+    background: transparent repeat-x 0 -6px;
+.loading-indicator {
+    background: no-repeat left;
+    padding-left: 20px;
+    line-height: 16px;
+    margin: 3px;
+.x-text-resize {
+    left: -1000px;
+    top: -1000px;
+    zoom: 1;
+.x-drag-overlay {
+    width: 100%;
+    height: 100%;
+    display: none;
+    left: 0;
+    top: 0;
+    background-image:url(images/s.gif);
+    z-index: 20000;
+.x-clear {
+    clear:both;
+    height:0;
+    overflow:hidden;
+    line-height:0;
+    font-size:0;
+.x-spotlight {
+    z-index: 8999;
+    top:0;
+    left:0;
+    opacity: .50;
+    width:0;
+    height:0;
+    zoom: 1;
+#x-history-frame {
+    top:-1px;
+    left:0;
+	width:1px;
+    height:1px;
+#x-history-field {
+    top:0;
+    left:-1px;
+	width:1px;
+    height:1px;
+.x-resizable-handle {
+    z-index:100;
+    /* ie needs these */
+    font-size:1px;
+    line-height:6px;
+    overflow:hidden;
+	filter:alpha(opacity=0);
+	opacity:0;
+	zoom:1;
+.x-resizable-handle-east{
+    width:6px;
+    cursor:e-resize;
+    right:0;
+    top:0;
+    height:100%;
+.ext-ie .x-resizable-handle-east {
+    margin-right:-1px; /*IE rounding error*/
+.x-resizable-handle-south{
+    width:100%;
+    cursor:s-resize;
+    left:0;
+    bottom:0;
+    height:6px;
+.ext-ie .x-resizable-handle-south {
+    margin-bottom:-1px; /*IE rounding error*/
+.x-resizable-handle-west{
+    width:6px;
+    cursor:w-resize;
+    left:0;
+    top:0;
+    height:100%;
+.x-resizable-handle-north{
+    width:100%;
+    cursor:n-resize;
+    left:0;
+    top:0;
+    height:6px;
+.x-resizable-handle-southeast{
+    width:6px;
+    cursor:se-resize;
+    right:0;
+    bottom:0;
+    height:6px;
+    z-index:101;
+.x-resizable-handle-northwest{
+    width:6px;
+    cursor:nw-resize;
+    left:0;
+    top:0;
+    height:6px;
+    z-index:101;
+.x-resizable-handle-northeast{
+    width:6px;
+    cursor:ne-resize;
+    right:0;
+    top:0;
+    height:6px;
+    z-index:101;
+.x-resizable-handle-southwest{
+    width:6px;
+    cursor:sw-resize;
+    left:0;
+    bottom:0;
+    height:6px;
+    z-index:101;
+.x-resizable-over .x-resizable-handle, .x-resizable-pinned .x-resizable-handle{
+    filter:alpha(opacity=100);
+	opacity:1;
+.x-resizable-over .x-resizable-handle-east, .x-resizable-pinned .x-resizable-handle-east,
+.x-resizable-over .x-resizable-handle-west, .x-resizable-pinned .x-resizable-handle-west
+	background-position: left;
+.x-resizable-over .x-resizable-handle-south, .x-resizable-pinned .x-resizable-handle-south,
+.x-resizable-over .x-resizable-handle-north, .x-resizable-pinned .x-resizable-handle-north
+    background-position: top;
+.x-resizable-over .x-resizable-handle-southeast, .x-resizable-pinned .x-resizable-handle-southeast{
+    background-position: top left;
+.x-resizable-over .x-resizable-handle-northwest, .x-resizable-pinned .x-resizable-handle-northwest{
+    background-position:bottom right;
+.x-resizable-over .x-resizable-handle-northeast, .x-resizable-pinned .x-resizable-handle-northeast{
+    background-position: bottom left;
+.x-resizable-over .x-resizable-handle-southwest, .x-resizable-pinned .x-resizable-handle-southwest{
+    background-position: top right;
+.x-resizable-proxy{
+    border: 1px dashed;
+    overflow:hidden;
+    display:none;
+	left:0;
+    top:0;
+    z-index:50000;
+.x-resizable-overlay{
+    width:100%;
+	height:100%;
+	display:none;
+	left:0;
+	top:0;
+	z-index:200000;
+	-moz-opacity: 0;
+    opacity:0;
+.x-tab-panel {
+    overflow:hidden;
+.x-tab-panel-header, .x-tab-panel-footer {
+    overflow:hidden;
+    zoom:1;
+.x-tab-panel-header {
+	padding-bottom: 2px;
+.x-tab-panel-footer {
+	padding-top: 2px;
+.x-tab-strip-wrap {
+	width:100%;
+    overflow:hidden;
+    position:relative;
+    zoom:1;
+ul.x-tab-strip {
+	display:block;
+    width:5000px;
+    zoom:1;
+ul.x-tab-strip-top{
+	padding-top: 1px;
+	background: repeat-x bottom;
+	border-bottom: 1px solid;
+ul.x-tab-strip-bottom{
+	padding-bottom: 1px;
+	background: repeat-x top;
+	border-top: 1px solid;
+	border-bottom: 0 none;
+.x-tab-panel-header-plain .x-tab-strip-top {
+    background:transparent !important;
+    padding-top:0 !important;
+.x-tab-panel-header-plain {
+    border-width:0 !important;
+    padding-bottom:0 !important;
+.x-tab-panel-header-plain .x-tab-strip-spacer,
+.x-tab-panel-footer-plain .x-tab-strip-spacer {
+    border:1px solid;
+    height:2px;
+    font-size:1px;
+    line-height:1px;
+.x-tab-panel-header-plain .x-tab-strip-spacer {
+    border-top: 0 none;
+.x-tab-panel-footer-plain .x-tab-strip-bottom {
+.x-tab-panel-footer-plain {
+.ext-border-box .x-tab-panel-header-plain .x-tab-strip-spacer,
+.ext-border-box .x-tab-panel-footer-plain .x-tab-strip-spacer {
+    height:3px;
+ul.x-tab-strip li {
+    float:left;
+    margin-left:2px;
+ul.x-tab-strip li.x-tab-edge {
+    float:left;
+    margin:0 !important;
+    padding:0 !important;
+    border:0 none !important;
+    font-size:1px !important;
+    line-height:1px !important;
+    overflow:hidden;
+    zoom:1;
+    width:1px;
+.x-tab-strip a, .x-tab-strip span, .x-tab-strip em {
+	display:block;
+.x-tab-strip a {
+	text-decoration:none !important;
+	outline: none;
+	cursor:pointer;
+.x-tab-strip-inner {
+    overflow:hidden;
+	text-overflow: ellipsis;
+.x-tab-strip span.x-tab-strip-text {
+	white-space: nowrap;
+	cursor:pointer;
+    padding:4px 0;
+.x-tab-strip-top .x-tab-with-icon .x-tab-right {
+    padding-left:6px;
+.x-tab-strip .x-tab-with-icon span.x-tab-strip-text {
+	padding-left:20px;
+    background-position: 0 3px;
+    background-repeat: no-repeat;
+.x-tab-strip-active, .x-tab-strip-active a.x-tab-right {
+    cursor:default;
+.x-tab-strip-active span.x-tab-strip-text {
+	cursor:default;
+.x-tab-strip-disabled .x-tabs-text {
+	cursor:default;
+.x-tab-panel-body {
+    overflow:hidden;
+.x-tab-panel-bwrap {
+    overflow:hidden;
+.ext-ie .x-tab-strip .x-tab-right {
+.x-tab-strip-top .x-tab-strip-active .x-tab-right {
+ * Horrible hack for IE8 in quirks mode
+.ext-ie8 .x-tab-strip li {
+    position: relative;
+.ext-border-box .ext-ie8 .x-tab-strip-top .x-tab-right {
+    top: 1px;
+.ext-ie8 .x-tab-strip-top {
+    padding-top: 1;
+.ext-border-box .ext-ie8 .x-tab-strip-top {
+    padding-top: 0;
+.ext-ie8 .x-tab-strip .x-tab-strip-closable a.x-tab-strip-close {
+    top:3px;
+.ext-border-box .ext-ie8 .x-tab-strip .x-tab-strip-closable a.x-tab-strip-close {
+    top:4px;
+.ext-ie8 .x-tab-strip-bottom .x-tab-right{
+    top:0;
+.x-tab-strip-top .x-tab-strip-active .x-tab-right span.x-tab-strip-text {
+    padding-bottom:5px;
+.x-tab-strip-bottom .x-tab-strip-active .x-tab-right {
+    margin-top:-1px;
+.x-tab-strip-bottom .x-tab-strip-active .x-tab-right span.x-tab-strip-text {
+    padding-top:5px;
+.x-tab-strip-top .x-tab-right {
+	background: transparent no-repeat 0 -51px;
+    padding-left:10px;
+.x-tab-strip-top .x-tab-left {
+	background: transparent no-repeat right -351px;
+    padding-right:10px;
+.x-tab-strip-top .x-tab-strip-inner {
+	background: transparent repeat-x 0 -201px;
+.x-tab-strip-top .x-tab-strip-over .x-tab-right {
+	 background-position:0 -101px;
+.x-tab-strip-top .x-tab-strip-over .x-tab-left {
+	 background-position:right -401px;
+.x-tab-strip-top .x-tab-strip-over .x-tab-strip-inner {
+	 background-position:0 -251px;
+	background-position: 0 0;
+.x-tab-strip-top .x-tab-strip-active .x-tab-left {
+	background-position: right -301px;
+.x-tab-strip-top .x-tab-strip-active .x-tab-strip-inner {
+	background-position: 0 -151px;
+.x-tab-strip-bottom .x-tab-right {
+	background: no-repeat bottom right;
+.x-tab-strip-bottom .x-tab-left {
+	background: no-repeat bottom left;
+.x-tab-strip-bottom .x-tab-strip-active .x-tab-left {
+    margin-right: 3px;
+    padding:0 10px;
+    padding:0;
+.x-tab-strip .x-tab-strip-close {
+    display:none;
+.x-tab-strip-closable {
+.x-tab-strip-closable .x-tab-left {
+    padding-right:19px;
+.x-tab-strip .x-tab-strip-closable a.x-tab-strip-close {
+    opacity:.6;
+    -moz-opacity:.6;
+    background-repeat:no-repeat;
+    display:block;
+	width:11px;
+    height:11px;
+    top:3px;
+    right:3px;
+    cursor:pointer;
+    z-index:2;
+.x-tab-strip .x-tab-strip-active a.x-tab-strip-close {
+    opacity:.8;
+    -moz-opacity:.8;
+.x-tab-strip .x-tab-strip-closable a.x-tab-strip-close:hover{
+    opacity:1;
+    -moz-opacity:1;
+.x-tab-panel-body-top {
+.x-tab-panel-body-bottom {
+.x-tab-scroller-left {
+    background: transparent no-repeat -18px 0;
+    width:18px;
+    left:0;
+    top:0;
+    z-index:10;
+    cursor:pointer;
+.x-tab-scroller-left-over {
+.x-tab-scroller-left-disabled {
+    background-position: -18px 0;
+    opacity:.5;
+    -moz-opacity:.5;
+    filter:alpha(opacity=50);
+    cursor:default;
+.x-tab-scroller-right {
+    width:18px;
+    right:0;
+    top:0;
+    z-index:10;
+    cursor:pointer;
+.x-tab-scroller-right-over {
+.x-tab-scroller-right-disabled {
+    opacity:.5;
+    -moz-opacity:.5;
+    cursor:default;
+.x-tab-scrolling-bottom .x-tab-scroller-left, .x-tab-scrolling-bottom .x-tab-scroller-right{
+    margin-top: 1px;
+.x-tab-scrolling .x-tab-strip-wrap {
+    margin-left:18px;
+    margin-right:18px;
+.x-tab-scrolling {
+.x-tab-panel-bbar .x-toolbar {
+    border:1px solid;
+    border-top:0 none;
+    overflow:hidden;
+    padding:2px;
+.x-tab-panel-tbar .x-toolbar {
+    border:1px solid;
+    overflow:hidden;
+    padding:2px;
+}/* all fields */
+.x-form-field{
+    margin: 0 0 0 0;
+.ext-webkit *:focus{
+    outline: none !important;
+/* ---- text fields ---- */
+.x-form-text, textarea.x-form-field{
+    padding:1px 3px;
+    background:repeat-x 0 0;
+    border:1px solid;
+textarea.x-form-field {
+    padding:2px 3px;
+.x-form-text, .ext-ie .x-form-file {
+    height:22px;
+    line-height:18px;
+    vertical-align:middle;
+.ext-ie6 .x-form-text, .ext-ie7 .x-form-text {
+    margin:-1px 0; /* ie bogus margin bug */
+    height:22px; /* ie quirks */
+    line-height:18px;
+.x-quirks .ext-ie9 .x-form-text {
+    height: 22px;
+    padding-top: 3px;
+    padding-bottom: 0px;
+/* Ugly hacks for the bogus 1px margin bug in IE9 quirks */
+.x-quirks .ext-ie9 .x-input-wrapper .x-form-text,
+.x-quirks .ext-ie9 .x-form-field-trigger-wrap .x-form-text {
+    margin-top: -1px;
+    margin-bottom: -1px;
+.x-quirks .ext-ie9 .x-input-wrapper .x-form-element {
+.ext-ie6 .x-form-field-wrap .x-form-file-btn, .ext-ie7 .x-form-field-wrap .x-form-file-btn {
+    top: -1px; /* because of all these margin hacks, these buttons are off by one pixel in IE6,7 */
+.ext-ie6 textarea.x-form-field, .ext-ie7 textarea.x-form-field {
+.ext-strict .x-form-text {
+    height:18px;
+.ext-safari.ext-mac textarea.x-form-field {
+    margin-bottom:-2px; /* another bogus margin bug, safari/mac only */
+.ext-strict .ext-ie8 .x-form-text, .ext-strict .ext-ie8 textarea.x-form-field {
+    margin-bottom: 1px;
+.ext-gecko .x-form-text , .ext-ie8 .x-form-text {
+    padding-top:2px; /* FF won't center the text vertically */
+    padding-bottom:0;
+.ext-ie6 .x-form-composite .x-form-text.x-box-item, .ext-ie7 .x-form-composite .x-form-text.x-box-item {
+    margin: 0 !important; /* clear ie bogus margin bug fix */
+textarea {
+    resize: none;  /* Disable browser resizable textarea */
+/* select boxes */
+.x-form-select-one {
+    height:20px;
+    line-height:18px;
+/* multi select boxes */
+/* --- TODO --- */
+/* 2.0.2 style */
+.x-form-check-wrap {
+    line-height:18px;
+    height: auto;
+.ext-ie .x-form-check-wrap input {
+    width:15px;
+    height:15px;
+.x-form-check-wrap input{
+    vertical-align: bottom;
+.x-editor .x-form-check-wrap {
+    padding:3px;
+.x-editor .x-form-checkbox {
+    height:13px;
+.x-form-check-group-label {
+    margin-bottom: 5px;
+    padding-left: 3px !important;
+    float: none !important;
+/* wrapped fields and triggers */
+.x-form-field-wrap .x-form-trigger{
+    width:17px;
+    height:21px;
+    border:0;
+    background:transparent no-repeat 0 0;
+    cursor:pointer;
+    top:0;
+.x-form-field-wrap .x-form-date-trigger, .x-form-field-wrap .x-form-clear-trigger, .x-form-field-wrap .x-form-search-trigger{
+    cursor:pointer;
+.x-form-field-wrap .x-form-twin-triggers .x-form-trigger{
+    position:static;
+    top:auto;
+    vertical-align:top;
+.x-form-field-wrap {
+    left:0;top:0;
+    text-align: left;
+    zoom:1;
+.ext-strict .ext-ie8 .x-toolbar-cell .x-form-field-trigger-wrap .x-form-trigger {
+    right: 0; /* IE8 Strict mode trigger bug */
+.x-form-field-wrap .x-form-trigger-over{
+    background-position:-17px 0;
+.x-form-field-wrap .x-form-trigger-click{
+    background-position:-34px 0;
+.x-trigger-wrap-focus .x-form-trigger{
+    background-position:-51px 0;
+.x-trigger-wrap-focus .x-form-trigger-over{
+    background-position:-68px 0;
+.x-trigger-wrap-focus .x-form-trigger-click{
+    background-position:-85px 0;
+.x-item-disabled .x-form-trigger-over{
+    background-position:0 0 !important;
+.x-item-disabled .x-form-trigger-click{
+.x-trigger-noedit{
+    cursor:pointer;
+/* field focus style */
+.x-form-focus, textarea.x-form-focus{
+/* invalid fields */
+.x-form-invalid, textarea.x-form-invalid{
+    background:repeat-x bottom;
+.x-form-inner-invalid, textarea.x-form-inner-invalid{
+/* editors */
+.x-editor {
+    padding:0;
+    margin:0;
+.x-form-grow-sizer {
+    left: -10000px;
+    padding: 8px 3px;
+    top: -10000px;
+    white-space: pre-wrap;
+    white-space: -moz-pre-wrap;
+    white-space: -pre-wrap;
+    white-space: -o-pre-wrap;
+    word-wrap: break-word;
+    zoom:1;
+.x-form-grow-sizer p {
+/* Form Items CSS */
+.x-form-item {
+    display:block;
+    margin-bottom:4px;
+    zoom:1;
+.x-form-item label.x-form-item-label {
+    display:block;
+    float:left;
+    width:100px;
+    padding:3px;
+    padding-left:0;
+    clear:left;
+    z-index:2;
+.x-form-element {
+    padding-left:105px;
+.x-form-invalid-msg {
+    padding:2px;
+    padding-left:18px;
+    background: transparent no-repeat 0 2px;
+    line-height:16px;
+    width:200px;
+.x-form-label-left label.x-form-item-label {
+   text-align:left;
+.x-form-label-right label.x-form-item-label {
+   text-align:right;
+.x-form-label-top .x-form-item label.x-form-item-label {
+    width:auto;
+    float:none;
+    clear:none;
+    display:inline;
+    position:static;
+.x-form-label-top .x-form-element {
+    padding-left:0;
+    padding-top:4px;
+.x-form-label-top .x-form-item {
+    padding-bottom:4px;
+/* Editor small font for grid, toolbar and tree */
+.x-small-editor .x-form-text {
+    height:20px;
+    line-height:16px;
+.ext-ie6 .x-small-editor .x-form-text, .ext-ie7 .x-small-editor .x-form-text {
+    margin-top:-1px !important; /* ie bogus margin bug */
+    margin-bottom:-1px !important;
+    height:20px !important; /* ie quirks */
+    line-height:16px !important;
+.ext-strict .x-small-editor .x-form-text {
+    height:16px !important;
+    height:20px;
+    line-height:16px;
+.ext-border-box .x-small-editor .x-form-text {
+    height:20px;
+.x-small-editor .x-form-select-one {
+    height:20px;
+    line-height:16px;
+.x-small-editor .x-form-num-field {
+    text-align:right;
+.x-small-editor .x-form-field-wrap .x-form-trigger{
+    height:19px;
+.ext-webkit .x-small-editor .x-form-text{padding-top:3px;font-size:100%;}
+.ext-strict .ext-webkit .x-small-editor .x-form-text{
+    height:14px !important;
+.x-form-clear {
+    clear:both;
+    height:0;
+    overflow:hidden;
+    line-height:0;
+    font-size:0;
+.x-form-clear-left {
+    clear:left;
+    height:0;
+    overflow:hidden;
+    line-height:0;
+    font-size:0;
+.ext-ie6 .x-form-check-wrap input, .ext-border-box .x-form-check-wrap input{
+   margin-top: 3px;
+.x-form-cb-label {
+    margin-left:4px;
+    top: 2px;
+.ext-ie .x-form-cb-label{
+    top: 1px;
+.ext-ie6 .x-form-cb-label, .ext-border-box .x-form-cb-label{
+    top: 3px;
+.x-form-display-field{
+    padding-top: 2px;
+.ext-gecko .x-form-display-field, .ext-strict .ext-ie7 .x-form-display-field{
+    padding-top: 1px;
+.ext-ie .x-form-display-field{
+    padding-top: 3px;
+.ext-strict .ext-ie8 .x-form-display-field{
+    padding-top: 0;
+.x-form-column {
+    float:left;
+    padding:0;
+    margin:0;
+    width:48%;
+    overflow:hidden;
+    zoom:1;
+/* buttons */
+.x-form .x-form-btns-ct .x-btn{
+    float:right;
+    clear:none;
+.x-form .x-form-btns-ct .x-form-btns td {
+    border:0;
+    padding:0;
+.x-form .x-form-btns-ct .x-form-btns-right table{
+    float:right;
+    clear:none;
+.x-form .x-form-btns-ct .x-form-btns-left table{
+    float:left;
+    clear:none;
+.x-form .x-form-btns-ct .x-form-btns-center{
+    text-align:center; /*ie*/
+.x-form .x-form-btns-ct .x-form-btns-center table{
+    margin:0 auto; /*everyone else*/
+.x-form .x-form-btns-ct table td.x-form-btn-td{
+    padding:3px;
+.x-form .x-form-btns-ct .x-btn-focus .x-btn-left{
+    background-position:0 -147px;
+.x-form .x-form-btns-ct .x-btn-focus .x-btn-right{
+    background-position:0 -168px;
+.x-form .x-form-btns-ct .x-btn-focus .x-btn-center{
+    background-position:0 -189px;
+.x-form .x-form-btns-ct .x-btn-click .x-btn-center{
+    background-position:0 -126px;
+.x-form .x-form-btns-ct .x-btn-click  .x-btn-right{
+    background-position:0 -84px;
+.x-form .x-form-btns-ct .x-btn-click .x-btn-left{
+    background-position:0 -63px;
+.x-form-invalid-icon {
+    width:16px;
+    height:18px;
+    left:0;
+    top:0;
+    display:block;
+    background:transparent no-repeat 0 2px;
+/* fieldsets */
+.x-fieldset {
+    border:1px solid;
+    padding:10px;
+    margin-bottom:10px;
+    display:block; /* preserve margins in IE */
+/* make top of checkbox/tools visible in webkit */
+.ext-webkit .x-fieldset-header {
+    padding-top: 1px;
+.ext-ie .x-fieldset legend {
+.ext-strict .ext-ie9 .x-fieldset legend.x-fieldset-header {
+    padding-top: 1px;
+.ext-ie .x-fieldset {
+    padding-top: 0;
+    padding-bottom:10px;
+.x-fieldset legend .x-tool-toggle {
+    margin-right:3px;
+    margin-left:0;
+    float:left !important;
+.x-fieldset legend input {
+    margin-right:3px;
+    height:13px;
+    width:13px;
+fieldset.x-panel-collapsed {
+    border-width: 1px 1px 0 1px !important;
+    border-left-color: transparent;
+    border-right-color: transparent;
+.ext-ie6 fieldset.x-panel-collapsed{
+    border-width: 1px 0 0 0 !important;
+    margin-left: 1px;
+    margin-right: 1px;
+fieldset.x-panel-collapsed .x-fieldset-bwrap {
+    left:-1000px;
+    top:-1000px;
+.ext-ie .x-fieldset-bwrap {
+    zoom:1;
+.x-fieldset-noborder {
+    border:0px none transparent;
+.x-fieldset-noborder legend {
+    margin-left:-3px;
+/* IE legend positioning bug */
+.ext-ie .x-fieldset-noborder legend {
+    margin-bottom:23px;
+.ext-ie .x-fieldset-noborder legend span {
+    left:16px;
+.ext-gecko .x-window-body .x-form-item {
+    outline: none;
+    overflow: auto;
+.ext-mac.ext-gecko .x-window-body .x-form-item {
+    overflow:hidden;
+.ext-gecko .x-form-item {
+    outline: none;
+.x-hide-label label.x-form-item-label {
+     display:none;
+.x-hide-label .x-form-element {
+     padding-left: 0 !important;
+.x-form-label-top .x-hide-label label.x-form-item-label{
+    display: none;
+.x-fieldset {
+    overflow:hidden;
+.x-fieldset-bwrap {
+    overflow:hidden;
+    zoom:1;
+.x-fieldset-body {
+    overflow:hidden;
+.x-btn{
+	cursor:pointer;
+.x-btn button{
+    border:0 none;
+    background-color:transparent;
+    padding-left:3px;
+    padding-right:3px;
+    cursor:pointer;
+    margin:0;
+    overflow:visible;
+    width:auto;
+    -moz-outline:0 none;
+    outline:0 none;
+* html .ext-ie .x-btn button {
+    width:1px;
+.ext-gecko .x-btn button, .ext-webkit .x-btn button {
+    padding-left:0;
+    padding-right:0;
+.ext-gecko .x-btn button::-moz-focus-inner {
+    padding:0;
+.ext-ie .x-btn button {
+    padding-top:2px;
+.x-btn td {
+.x-btn-text {
+    cursor:pointer;
+    padding:0;
+/* icon placement and sizing styles */
+/* Only text */
+.x-btn-noicon .x-btn-small .x-btn-text{
+	height: 16px;
+.x-btn-noicon .x-btn-medium .x-btn-text{
+    height: 24px;
+.x-btn-noicon .x-btn-large .x-btn-text{
+    height: 32px;
+/* Only icons */
+.x-btn-icon .x-btn-text{
+    background-position: center;
+.x-btn-icon .x-btn-small .x-btn-text{
+	height: 16px;
+	width: 16px;
+.x-btn-icon .x-btn-medium .x-btn-text{
+    height: 24px;
+	width: 24px;
+.x-btn-icon .x-btn-large .x-btn-text{
+    height: 32px;
+	width: 32px;
+/* Icons and text */
+/* left */
+.x-btn-text-icon .x-btn-icon-small-left .x-btn-text{
+    background-position: 0 center;
+    height:16px;
+.x-btn-text-icon .x-btn-icon-medium-left .x-btn-text{
+    padding-left:26px;
+    height:24px;
+.x-btn-text-icon .x-btn-icon-large-left .x-btn-text{
+    padding-left:34px;
+    height:32px;
+/* top */
+.x-btn-text-icon .x-btn-icon-small-top .x-btn-text{
+    background-position: center 0;
+    padding-top:18px;
+.x-btn-text-icon .x-btn-icon-medium-top .x-btn-text{
+    padding-top:26px;
+.x-btn-text-icon .x-btn-icon-large-top .x-btn-text{
+    padding-top:34px;
+/* right */
+.x-btn-text-icon .x-btn-icon-small-right .x-btn-text{
+    background-position: right center;
+    padding-right:18px;
+    height:16px;
+.x-btn-text-icon .x-btn-icon-medium-right .x-btn-text{
+    padding-right:26px;
+    height:24px;
+.x-btn-text-icon .x-btn-icon-large-right .x-btn-text{
+    padding-right:34px;
+    height:32px;
+/* bottom */
+.x-btn-text-icon .x-btn-icon-small-bottom .x-btn-text{
+    background-position: center bottom;
+    padding-bottom:18px;
+.x-btn-text-icon .x-btn-icon-medium-bottom .x-btn-text{
+    padding-bottom:26px;
+.x-btn-text-icon .x-btn-icon-large-bottom .x-btn-text{
+    padding-bottom:34px;
+/* background positioning */
+.x-btn-tr i, .x-btn-tl i, .x-btn-mr i, .x-btn-ml i, .x-btn-br i, .x-btn-bl i{
+	font-size:1px;
+    line-height:1px;
+    width:3px;
+    display:block;
+    overflow:hidden;
+.x-btn-tr i, .x-btn-tl i, .x-btn-br i, .x-btn-bl i{
+	height:3px;
+.x-btn-tl{
+	width:3px;
+	height:3px;
+	background:no-repeat 0 0;
+.x-btn-tr{
+	width:3px;
+	height:3px;
+	background:no-repeat -3px 0;
+.x-btn-tc{
+	height:3px;
+	background:repeat-x 0 -6px;
+.x-btn-ml{
+	width:3px;
+	background:no-repeat 0 -24px;
+.x-btn-mr{
+	width:3px;
+	background:no-repeat -3px -24px;
+.x-btn-mc{
+	background:repeat-x 0 -1096px;
+    vertical-align: middle;
+	padding:0 5px;
+	cursor:pointer;
+	white-space:nowrap;
+/* Fixes an issue with the button height */
+.ext-strict .ext-ie6 .x-btn-mc, .ext-strict .ext-ie7 .x-btn-mc {
+    height: 100%;
+.x-btn-bl{
+	width:3px;
+	height:3px;
+	background:no-repeat 0 -3px;
+.x-btn-br{
+	width:3px;
+	height:3px;
+	background:no-repeat -3px -3px;
+.x-btn-bc{
+	height:3px;
+	background:repeat-x 0 -15px;
+.x-btn-over .x-btn-tl{
+	background-position: -6px 0;
+.x-btn-over .x-btn-tr{
+	background-position: -9px 0;
+.x-btn-over .x-btn-tc{
+	background-position: 0 -9px;
+.x-btn-over .x-btn-ml{
+	background-position: -6px -24px;
+.x-btn-over .x-btn-mr{
+	background-position: -9px -24px;
+.x-btn-over .x-btn-mc{
+	background-position: 0 -2168px;
+.x-btn-over .x-btn-bl{
+	background-position: -6px -3px;
+.x-btn-over .x-btn-br{
+	background-position: -9px -3px;
+.x-btn-over .x-btn-bc{
+	background-position: 0 -18px;
+.x-btn-click .x-btn-tl, .x-btn-menu-active .x-btn-tl, .x-btn-pressed .x-btn-tl{
+	background-position: -12px 0;
+.x-btn-click .x-btn-tr, .x-btn-menu-active .x-btn-tr, .x-btn-pressed .x-btn-tr{
+	background-position: -15px 0;
+.x-btn-click .x-btn-tc, .x-btn-menu-active .x-btn-tc, .x-btn-pressed .x-btn-tc{
+	background-position: 0 -12px;
+.x-btn-click .x-btn-ml, .x-btn-menu-active .x-btn-ml, .x-btn-pressed .x-btn-ml{
+	background-position: -12px -24px;
+.x-btn-click .x-btn-mr, .x-btn-menu-active .x-btn-mr, .x-btn-pressed .x-btn-mr{
+	background-position: -15px -24px;
+.x-btn-click .x-btn-mc, .x-btn-menu-active .x-btn-mc, .x-btn-pressed .x-btn-mc{
+	background-position: 0 -3240px;
+.x-btn-click .x-btn-bl, .x-btn-menu-active .x-btn-bl, .x-btn-pressed .x-btn-bl{
+	background-position: -12px -3px;
+.x-btn-click .x-btn-br, .x-btn-menu-active .x-btn-br, .x-btn-pressed .x-btn-br{
+	background-position: -15px -3px;
+.x-btn-click .x-btn-bc, .x-btn-menu-active .x-btn-bc, .x-btn-pressed .x-btn-bc{
+	background-position: 0 -21px;
+.x-btn-disabled *{
+	cursor:default !important;
+/* With a menu arrow */
+/* right */
+.x-btn-mc em.x-btn-arrow {
+    display:block;
+    background:transparent no-repeat right center;
+.x-btn-mc em.x-btn-split {
+    display:block;
+	padding-right:14px;
+/* bottom */
+.x-btn-mc em.x-btn-arrow-bottom {
+    display:block;
+    background:transparent no-repeat center bottom;
+	padding-bottom:14px;
+.x-btn-mc em.x-btn-split-bottom {
+    display:block;
+/* height adjustment class */
+.x-btn-as-arrow .x-btn-mc em {
+    display:block;
+/* groups */
+.x-btn-group {
+    padding:1px;
+.x-btn-group-header {
+    padding:2px;
+.x-btn-group-tc {
+	background: transparent repeat-x 0 0;
+	overflow:hidden;
+.x-btn-group-tl {
+	padding-left:3px;
+    zoom:1;
+.x-btn-group-tr {
+	background: transparent no-repeat right 0;
+	zoom:1;
+.x-btn-group-bc {
+	background: transparent repeat-x 0 bottom;
+    zoom:1;
+.x-btn-group-bc .x-panel-footer {
+    zoom:1;
+.x-btn-group-bl {
+	background: transparent no-repeat 0 bottom;
+	padding-left:3px;
+    zoom:1;
+.x-btn-group-br {
+	background: transparent no-repeat right bottom;
+    zoom:1;
+.x-btn-group-mc {
+    border:0 none;
+    padding:1px 0 0 0;
+    margin:0;
+.x-btn-group-mc .x-btn-group-body {
+    border: 0 none;
+.x-btn-group-ml {
+	padding-left:3px;
+    zoom:1;
+.x-btn-group-mr {
+	background: transparent repeat-y right 0;
+    zoom:1;
+.x-btn-group-bc .x-btn-group-footer {
+    padding-bottom:6px;
+.x-panel-nofooter .x-btn-group-bc {
+	height:3px;
+    font-size:0;
+    line-height:0;
+.x-btn-group-bwrap {
+    overflow:hidden;
+    zoom:1;
+.x-btn-group-body {
+    overflow:hidden;
+    zoom:1;
+.x-btn-group-notitle .x-btn-group-tc {
+	overflow:hidden;
+    height:2px;
+}.x-toolbar{
+    border-style:solid;
+    border-width:0 0 1px 0;
+    display: block;
+	padding:2px;
+    background:repeat-x top left;
+    left:0;
+    top:0;
+    zoom:1;
+    overflow:hidden;
+.x-toolbar-left {
+    width: 100%;
+.x-toolbar .x-item-disabled .x-btn-icon {
+    opacity: .35;
+    -moz-opacity: .35;
+    filter: alpha(opacity=35);
+.x-toolbar td {
+.x-toolbar td,.x-toolbar span,.x-toolbar input,.x-toolbar div,.x-toolbar select,.x-toolbar label{
+.x-toolbar .x-item-disabled {
+	cursor:default;
+	opacity:.6;
+	-moz-opacity:.6;
+	filter:alpha(opacity=60);
+.x-toolbar .x-item-disabled * {
+	cursor:default;
+.x-toolbar .x-toolbar-cell {
+.x-toolbar .x-btn-tl, .x-toolbar .x-btn-tr, .x-toolbar .x-btn-tc, .x-toolbar .x-btn-ml, .x-toolbar .x-btn-mr,
+.x-toolbar .x-btn-mc, .x-toolbar .x-btn-bl, .x-toolbar .x-btn-br, .x-toolbar .x-btn-bc
+	background-position: 500px 500px;
+/* These rules are duplicated from button.css to give priority of x-toolbar rules above */
+.x-toolbar .x-btn-over .x-btn-tl{
+.x-toolbar .x-btn-over .x-btn-tr{
+.x-toolbar .x-btn-over .x-btn-tc{
+.x-toolbar .x-btn-over .x-btn-ml{
+.x-toolbar .x-btn-over .x-btn-mr{
+.x-toolbar .x-btn-over .x-btn-mc{
+.x-toolbar .x-btn-over .x-btn-bl{
+.x-toolbar .x-btn-over .x-btn-br{
+.x-toolbar .x-btn-over .x-btn-bc{
+.x-toolbar .x-btn-click .x-btn-tl, .x-toolbar .x-btn-menu-active .x-btn-tl, .x-toolbar .x-btn-pressed .x-btn-tl{
+.x-toolbar .x-btn-click .x-btn-tr, .x-toolbar .x-btn-menu-active .x-btn-tr, .x-toolbar .x-btn-pressed .x-btn-tr{
+.x-toolbar .x-btn-click .x-btn-tc, .x-toolbar .x-btn-menu-active .x-btn-tc, .x-toolbar .x-btn-pressed .x-btn-tc{
+.x-toolbar .x-btn-click .x-btn-ml, .x-toolbar .x-btn-menu-active .x-btn-ml, .x-toolbar .x-btn-pressed .x-btn-ml{
+.x-toolbar .x-btn-click .x-btn-mr, .x-toolbar .x-btn-menu-active .x-btn-mr, .x-toolbar .x-btn-pressed .x-btn-mr{
+.x-toolbar .x-btn-click .x-btn-mc, .x-toolbar .x-btn-menu-active .x-btn-mc, .x-toolbar .x-btn-pressed .x-btn-mc{
+.x-toolbar .x-btn-click .x-btn-bl, .x-toolbar .x-btn-menu-active .x-btn-bl, .x-toolbar .x-btn-pressed .x-btn-bl{
+.x-toolbar .x-btn-click .x-btn-br, .x-toolbar .x-btn-menu-active .x-btn-br, .x-toolbar .x-btn-pressed .x-btn-br{
+.x-toolbar .x-btn-click .x-btn-bc, .x-toolbar .x-btn-menu-active .x-btn-bc, .x-toolbar .x-btn-pressed .x-btn-bc{
+.x-toolbar div.xtb-text{
+    padding:2px 2px 0;
+    line-height:16px;
+    display:block;
+.x-toolbar .xtb-sep {
+	display: block;
+	font-size: 1px;
+	height: 16px;
+	width:4px;
+	overflow: hidden;
+	cursor:default;
+	margin: 0 2px 0;
+	border:0;
+.x-toolbar .xtb-spacer {
+    width:2px;
+/* Paging Toolbar */
+.x-tbar-page-number{
+	width:30px;
+	height:14px;
+.ext-ie .x-tbar-page-number{
+    margin-top: 2px;
+.x-paging-info {
+    top:5px;
+    right: 8px;
+/* floating */
+.x-toolbar-ct {
+    width:100%;
+.x-toolbar-right td {
+    text-align: center;
+.x-panel-tbar, .x-panel-bbar, .x-window-tbar, .x-window-bbar, .x-tab-panel-tbar, .x-tab-panel-bbar, .x-plain-tbar, .x-plain-bbar {
+    overflow:hidden;
+    zoom:1;
+.x-toolbar-more .x-btn-small .x-btn-text{
+	height: 16px;
+	width: 12px;
+.x-toolbar-more em.x-btn-arrow {
+    display:inline;
+	padding-right:0;
+.x-toolbar-more .x-btn-mc em.x-btn-arrow {
+    background-image: none;
+div.x-toolbar-no-items {
+    color:gray !important;
+    padding:5px 10px !important;
+/* fix ie toolbar form items */
+.ext-border-box .x-toolbar-cell .x-form-text {
+.ext-border-box .x-toolbar-cell .x-form-field-wrap .x-form-text {
+.ext-ie .x-toolbar-cell .x-form-field-wrap {
+    height:21px;
+.ext-ie .x-toolbar-cell .x-form-text {
+    top:-1px;
+.ext-strict .ext-ie8 .x-toolbar-cell .x-form-field-trigger-wrap .x-form-text, .ext-strict .ext-ie .x-toolbar-cell .x-form-text {
+    top: 0px;
+.x-toolbar-right td .x-form-field-trigger-wrap{
+    text-align: left;
+.x-toolbar-cell .x-form-checkbox, .x-toolbar-cell .x-form-radio{
+    margin-top: 5px;
+.x-toolbar-cell .x-form-cb-label{
+    top: 1px;
+.ext-ie .x-toolbar-cell .x-form-checkbox, .ext-ie .x-toolbar-cell .x-form-radio{
+    margin-top: 4px;
+.ext-ie .x-toolbar-cell .x-form-cb-label{
+    top: 0;
+/* Grid3 styles */
+.x-grid3 {
+	overflow:hidden;
+.x-grid-panel .x-panel-body {
+    overflow:hidden !important;
+.x-grid-panel .x-panel-mc .x-panel-body {
+    border:1px solid;
+.x-grid3 table {
+    table-layout:fixed;
+.x-grid3-viewport{
+	overflow:hidden;
+.x-grid3-hd-row td, .x-grid3-row td, .x-grid3-summary-row td{
+    outline: none;
+	-moz-user-focus: normal;
+.x-grid3-row td, .x-grid3-summary-row td {
+    line-height:13px;
+    vertical-align: top;
+	padding-left:1px;
+    padding-right:1px;
+    -khtml-user-select:none;
+.x-grid3-cell{
+.x-grid3-hd-row td {
+    line-height:15px;
+    border-left:1px solid;
+    border-right:1px solid;
+.x-grid3-hd-row .x-grid3-marker-hd {
+    padding:3px;
+.x-grid3-row .x-grid3-marker {
+    padding:3px;
+.x-grid3-cell-inner, .x-grid3-hd-inner{
+	overflow:hidden;
+	-o-text-overflow: ellipsis;
+    padding:3px 3px 3px 5px;
+/* ActionColumn, reduce padding to accommodate 16x16 icons in normal row height */
+.x-action-col-cell .x-grid3-cell-inner {
+    padding-top: 1px;
+.x-action-col-icon {
+    cursor: pointer;
+.x-grid3-hd-inner {
+	cursor:inherit;
+	padding:4px 3px 4px 5px;
+.x-grid3-row-body {
+    white-space:normal;
+.x-grid3-body-cell {
+    outline:0 none;
+/* IE Quirks to clip */
+.ext-ie .x-grid3-cell-inner, .ext-ie .x-grid3-hd-inner{
+	width:100%;
+/* reverse above in strict mode */
+.ext-strict .x-grid3-cell-inner, .ext-strict .x-grid3-hd-inner{
+	width:auto;
+.x-grid-row-loading {
+    background: no-repeat center center;
+.x-grid-page {
+    overflow:hidden;
+.x-grid3-row {
+	cursor: default;
+    width:100%;
+.x-grid3-row-over {
+	border:1px solid;
+    background: repeat-x left top;
+.x-grid3-resize-proxy {
+	width:1px;
+    left:0;
+	cursor: e-resize;
+	top:0;
+	height:100px;
+	overflow:hidden;
+	border:0 none;
+	z-index:7;
+.x-grid3-resize-marker {
+	width:1px;
+	left:0;
+	top:0;
+	height:100px;
+	overflow:hidden;
+	border:0 none;
+	z-index:7;
+.x-grid3-focus {
+	left:0;
+	top:0;
+	width:1px;
+	height:1px;
+    line-height:1px;
+    font-size:1px;
+    outline:0 none;
+    -moz-user-select: text;
+    -khtml-user-select: text;
+/* header styles */
+.x-grid3-header{
+	background: repeat-x 0 bottom;
+	cursor:default;
+    zoom:1;
+.x-grid3-header-pop {
+    float:right;
+    clear:none;
+.x-grid3-header-pop-inner {
+    width:14px;
+    height:19px;
+    background: transparent no-repeat center center;
+.ext-ie .x-grid3-header-pop-inner {
+    width:15px;
+.ext-strict .x-grid3-header-pop-inner {
+    width:14px;
+.x-grid3-header-inner {
+    overflow:hidden;
+    zoom:1;
+    float:left;
+.x-grid3-header-offset {
+    padding-left:1px;
+    text-align: left;
+td.x-grid3-hd-over, td.sort-desc, td.sort-asc, td.x-grid3-hd-menu-open {
+td.x-grid3-hd-over .x-grid3-hd-inner, td.sort-desc .x-grid3-hd-inner, td.sort-asc .x-grid3-hd-inner, td.x-grid3-hd-menu-open .x-grid3-hd-inner {
+    background: repeat-x left bottom;
+.x-grid3-sort-icon{
+	display: none;
+	height: 4px;
+	width: 13px;
+	margin-left:3px;
+.sort-asc .x-grid3-sort-icon, .sort-desc .x-grid3-sort-icon {
+	display: inline;
+/* Header position fixes for IE strict mode */
+.ext-strict .ext-ie .x-grid3-header-inner, .ext-strict .ext-ie6 .x-grid3-hd {
+.ext-strict .ext-ie6 .x-grid3-hd-inner{
+    position:static;
+/* Body Styles */
+.x-grid3-body {
+	zoom:1;
+.x-grid3-scroller {
+	overflow:auto;
+    zoom:1;
+.x-grid3-cell-text, .x-grid3-hd-text {
+	display: block;
+	padding: 3px 5px 3px 5px;
+.x-grid3-split {
+	cursor: e-resize;
+	display: block;
+	font-size: 1px;
+	height: 16px;
+	overflow: hidden;
+	top: 2px;
+	width: 6px;
+	z-index: 3;
+/* Column Reorder DD */
+.x-dd-drag-proxy .x-grid3-hd-inner{
+	width:120px;
+	padding:3px;
+	border:1px solid;
+	overflow:hidden;
+.col-move-top, .col-move-bottom{
+	width:9px;
+	height:9px;
+	top:0;
+	line-height:1px;
+	font-size:1px;
+	overflow:hidden;
+	z-index:20000;
+    background:transparent no-repeat left top;
+/* Selection Styles */
+.x-grid3-row-selected {
+	border:1px dotted;
+.x-grid3-locked td.x-grid3-row-marker, .x-grid3-locked .x-grid3-row-selected td.x-grid3-row-marker{
+    background: repeat-x 0 bottom !important;
+    vertical-align:middle !important;
+    padding:0;
+    border-top:1px solid;
+    border-bottom:none !important;
+    border-right:1px solid !important;
+.x-grid3-locked td.x-grid3-row-marker div, .x-grid3-locked .x-grid3-row-selected td.x-grid3-row-marker div{
+    padding:0 4px;
+/* dirty cells */
+.x-grid3-dirty-cell {
+/* Grid Toolbars */
+.x-grid3-topbar, .x-grid3-bottombar{
+    overflow:hidden;
+	display:none;
+	zoom:1;
+.x-grid3-topbar .x-toolbar{
+	border-right:0 none;
+.x-grid3-bottombar .x-toolbar{
+	border-bottom:0 none;
+/* Props Grid Styles */
+.x-props-grid .x-grid3-cell{
+	padding:1px;
+.x-props-grid .x-grid3-td-name .x-grid3-cell-inner{
+	background:transparent repeat-y -16px !important;
+    padding-left:12px;
+.x-props-grid .x-grid3-body .x-grid3-td-name{
+    padding:1px;
+    padding-right:0;
+    border:0 none;
+/* dd */
+.x-grid3-col-dd {
+    border:0 none;
+    padding:0;
+.x-dd-drag-ghost .x-grid3-dd-wrap {
+    padding:1px 3px 3px 1px;
+.x-grid3-hd {
+    -moz-user-select:none;
+.x-grid3-hd-btn {
+    display:none;
+    width:14px;
+    background:no-repeat left center;
+    right:0;
+    top:0;
+    z-index:2;
+	cursor:pointer;
+.x-grid3-hd-over .x-grid3-hd-btn, .x-grid3-hd-menu-open .x-grid3-hd-btn {
+    display:block;
+a.x-grid3-hd-btn:hover {
+    background-position:-14px center;
+/* Expanders */
+.x-grid3-body .x-grid3-td-expander {
+    background:transparent repeat-y right;
+.x-grid3-body .x-grid3-td-expander .x-grid3-cell-inner {
+    height:100%;
+.x-grid3-row-expander {
+    width:100%;
+    height:18px;
+    background-position:4px 2px;
+.x-grid3-row-collapsed .x-grid3-row-expander {
+.x-grid3-row-expanded .x-grid3-row-expander {
+    background-position:-21px 2px;
+.x-grid3-row-collapsed .x-grid3-row-body {
+.x-grid3-row-expanded .x-grid3-row-body {
+    display:block !important;
+/* Checkers */
+.x-grid3-body .x-grid3-td-checker {
+.x-grid3-body .x-grid3-td-checker .x-grid3-cell-inner, .x-grid3-header .x-grid3-td-checker .x-grid3-hd-inner {
+    height:100%;
+.x-grid3-row-checker, .x-grid3-hd-checker {
+    width:100%;
+    height:18px;
+    background-position:2px 2px;
+.x-grid3-row .x-grid3-row-checker {
+.x-grid3-row-selected .x-grid3-row-checker, .x-grid3-hd-checker-on .x-grid3-hd-checker,.x-grid3-row-checked .x-grid3-row-checker {
+    background-position:-23px 2px;
+.x-grid3-hd-checker {
+    background-position:2px 1px;
+.ext-border-box .x-grid3-hd-checker {
+    background-position:2px 3px;
+.x-grid3-hd-checker-on .x-grid3-hd-checker {
+    background-position:-23px 1px;
+.ext-border-box .x-grid3-hd-checker-on .x-grid3-hd-checker {
+    background-position:-23px 3px;
+/* Numberer */
+.x-grid3-body .x-grid3-td-numberer {
+.x-grid3-body .x-grid3-td-numberer .x-grid3-cell-inner {
+    padding:3px 5px 0 0 !important;
+    text-align:right;
+/* Row Icon */
+.x-grid3-body .x-grid3-td-row-icon {
+.x-grid3-body .x-grid3-td-row-icon .x-grid3-cell-inner {
+    background-position:center center;
+    width:16px;
+    height:16px;
+    margin-left:2px;
+    margin-top:3px;
+/* All specials */
+.x-grid3-body .x-grid3-row-selected .x-grid3-td-numberer,
+.x-grid3-body .x-grid3-row-selected .x-grid3-td-checker,
+.x-grid3-body .x-grid3-row-selected .x-grid3-td-expander {
+.x-grid3-body .x-grid3-check-col-td .x-grid3-cell-inner {
+    padding: 1px 0 0 0 !important;
+.x-grid3-check-col {
+    width:100%;
+    height:16px;
+.x-grid3-check-col-on {
+    width:100%;
+    height:16px;
+/* Grouping classes */
+.x-grid-group, .x-grid-group-body, .x-grid-group-hd {
+    zoom:1;
+.x-grid-group-hd {
+    border-bottom: 2px solid;
+    cursor:pointer;
+    padding-top:6px;
+.x-grid-group-hd div.x-grid-group-title {
+    background:transparent no-repeat 3px 3px;
+    padding:4px 4px 4px 17px;
+.x-grid-group-collapsed .x-grid-group-body {
+    display:none;
+.ext-ie6 .x-grid3 .x-editor .x-form-text, .ext-ie7 .x-grid3 .x-editor .x-form-text {
+    top:-1px;
+.ext-ie .x-props-grid .x-editor .x-form-text {
+    position:static;
+    top:0;
+.x-grid-empty {
+    padding:10px;
+/* fix floating toolbar issue */
+.ext-ie7 .x-grid-panel .x-panel-bbar {
+/* Reset position to static when Grid Panel has been framed */
+/* to resolve 'snapping' from top to bottom behavior. */
+/* @forumThread 86656 */
+.ext-ie7 .x-grid-panel .x-panel-mc .x-panel-bbar {
+    position: static;
+.ext-ie6 .x-grid3-header {
+/* Fix WebKit bug in Grids */
+.ext-webkit .x-grid-panel .x-panel-bwrap{
+    -webkit-user-select:none;
+.ext-webkit .x-tbar-page-number{
+/* end*/
+/* column lines */
+.x-grid-with-col-lines .x-grid3-row td.x-grid3-cell {
+    padding-right:0;
+.x-pivotgrid .x-grid3-header-offset table {
+    width: 100%;
+    border-collapse: collapse;
+.x-pivotgrid .x-grid3-header-offset table td {
+    padding: 4px 3px 4px 5px;
+    overflow: hidden;
+    font-size: 11px;
+    line-height: 13px;
+    font-family: tahoma;
+.x-pivotgrid .x-grid3-row-headers {
+    display: block;
+    float: left;
+.x-pivotgrid .x-grid3-row-headers table {
+    height: 100%;
+    width: 100%;
+.x-pivotgrid .x-grid3-row-headers table td {
+    height: 18px;
+    padding: 2px 7px 0 0;
+    text-align: right;
+    font-size: 11px;
+.ext-gecko .x-pivotgrid .x-grid3-row-headers table td {
+    height: 21px;
+.x-grid3-header-title {
+    top: 0%;
+    left: 0%;
+    font-size: 11px;
+    padding: auto 1px;
+    display: table-cell;
+.x-grid3-header-title span {
+    top: 50%;
+    left: 0%;
+    width: 100%;
+    margin-top: -6px;
+}.x-dd-drag-proxy{
+	left:0;
+    top:0;
+	z-index:15000;
+.x-dd-drag-ghost{
+	-moz-opacity: 0.85;
+    opacity:.85;
+    filter: alpha(opacity=85);
+	padding:3px;
+.x-dd-drag-repair .x-dd-drag-ghost{
+	-moz-opacity: 0.4;
+    opacity:.4;
+    filter: alpha(opacity=40);
+	border:0 none;
+	padding:0;
+.x-dd-drag-repair .x-dd-drop-icon{
+.x-dd-drop-icon{
+	top:3px;
+	left:3px;
+	display:block;
+	width:16px;
+	height:16px;
+	z-index:1;
+.x-view-selector {
+    left:0;
+    top:0;
+    width:0;
+	opacity: .5;
+    -moz-opacity: .5;
+    zoom:1;
+}.ext-strict .ext-ie .x-tree .x-panel-bwrap{
+    overflow:hidden;
+.x-tree-icon, .x-tree-ec-icon, .x-tree-elbow-line, .x-tree-elbow, .x-tree-elbow-end, .x-tree-elbow-plus, .x-tree-elbow-minus, .x-tree-elbow-end-plus, .x-tree-elbow-end-minus{
+	border: 0 none;
+	height: 18px;
+	margin: 0;
+	padding: 0;
+	width: 16px;
+.x-tree-node-collapsed .x-tree-node-icon, .x-tree-node-expanded .x-tree-node-icon, .x-tree-node-leaf .x-tree-node-icon{
+	border: 0 none;
+	height: 18px;
+	margin: 0;
+	padding: 0;
+	width: 16px;
+	background-position:center;
+.ext-ie .x-tree-node-indent img, .ext-ie .x-tree-node-icon, .ext-ie .x-tree-ec-icon {
+    vertical-align: middle !important;
+.ext-strict .ext-ie8 .x-tree-node-indent img, .ext-strict .ext-ie8 .x-tree-node-icon, .ext-strict .ext-ie8 .x-tree-ec-icon {
+    vertical-align: top !important;
+/* checkboxes */
+input.x-tree-node-cb {
+    margin-left:1px;
+    height: 19px;
+.ext-ie input.x-tree-node-cb {
+    margin-left:0;
+    margin-top: 1px;
+    width: 16px;
+    height: 16px;
+.ext-strict .ext-ie8 input.x-tree-node-cb{
+    margin: 1px 1px;
+    height: 14px;
+.ext-strict .ext-ie8 input.x-tree-node-cb + a{
+.ext-opera input.x-tree-node-cb {
+    height: 14px;
+.x-tree-noicon .x-tree-node-icon{
+	width:0; height:0;
+/* No line styles */
+.x-tree-no-lines .x-tree-elbow{
+.x-tree-no-lines .x-tree-elbow-end{
+.x-tree-no-lines .x-tree-elbow-line{
+/* Arrows */
+.x-tree-arrows .x-tree-elbow{
+.x-tree-arrows .x-tree-elbow-plus{
+.x-tree-arrows .x-tree-elbow-minus{
+    background:transparent no-repeat -16px 0;
+.x-tree-arrows .x-tree-elbow-end{
+.x-tree-arrows .x-tree-elbow-end-plus{
+.x-tree-arrows .x-tree-elbow-end-minus{
+.x-tree-arrows .x-tree-elbow-line{
+.x-tree-arrows .x-tree-ec-over .x-tree-elbow-plus{
+    background-position:-32px 0;
+.x-tree-arrows .x-tree-ec-over .x-tree-elbow-minus{
+    background-position:-48px 0;
+.x-tree-arrows .x-tree-ec-over .x-tree-elbow-end-plus{
+.x-tree-arrows .x-tree-ec-over .x-tree-elbow-end-minus{
+.x-tree-elbow-plus, .x-tree-elbow-minus, .x-tree-elbow-end-plus, .x-tree-elbow-end-minus{
+	cursor:pointer;
+.ext-ie ul.x-tree-node-ct{
+    font-size:0;
+    line-height:0;
+    zoom:1;
+.x-tree-node{
+.x-tree-node-el {
+    line-height:18px;
+    cursor:pointer;
+.x-tree-node a, .x-dd-drag-ghost a{
+	text-decoration:none;
+    -kthml-user-focus:normal;
+    -moz-user-focus:normal;
+    outline:0 none;
+.x-tree-node a span, .x-dd-drag-ghost a span{
+	padding:1px 3px 1px 2px;
+.x-tree-node .x-tree-node-disabled .x-tree-node-icon{
+   opacity:.5;
+.x-tree-node .x-tree-node-inline-icon{
+.x-tree-node a:hover, .x-dd-drag-ghost a:hover{
+.x-tree-node div.x-tree-drag-insert-below{
+ 	 border-bottom:1px dotted;
+.x-tree-node div.x-tree-drag-insert-above{
+	 border-top:1px dotted;
+.x-tree-dd-underline .x-tree-node div.x-tree-drag-insert-below{
+.x-tree-dd-underline .x-tree-node div.x-tree-drag-insert-above{
+.x-tree-dd-underline .x-tree-node div.x-tree-drag-insert-below a{
+ 	 border-bottom:2px solid;
+.x-tree-dd-underline .x-tree-node div.x-tree-drag-insert-above a{
+	 border-top:2px solid;
+.x-tree-node .x-tree-drag-append a span{
+.x-dd-drag-ghost .x-tree-node-indent, .x-dd-drag-ghost .x-tree-ec-icon{
+/* Fix for ie rootVisible:false issue */
+.x-tree-root-ct {
+    zoom:1;
+.x-date-picker {
+.x-date-picker a {
+    outline:0 none;
+.x-date-inner, .x-date-inner td, .x-date-inner th{
+    border-collapse:separate;
+.x-date-middle,.x-date-left,.x-date-right {
+	background: repeat-x 0 -83px;
+	overflow:hidden;
+.x-date-middle .x-btn-tc,.x-date-middle .x-btn-tl,.x-date-middle .x-btn-tr,
+.x-date-middle .x-btn-mc,.x-date-middle .x-btn-ml,.x-date-middle .x-btn-mr,
+.x-date-middle .x-btn-bc,.x-date-middle .x-btn-bl,.x-date-middle .x-btn-br{
+.x-date-middle .x-btn-mc em.x-btn-arrow {
+    background:transparent no-repeat right 0;
+.x-date-right, .x-date-left {
+    width:18px;
+.x-date-right{
+    text-align:right;
+.x-date-middle {
+    padding-top:2px;
+    padding-bottom:2px;
+    width:130px; /* FF3 */
+.x-date-right a, .x-date-left a{
+    display:block;
+    width:16px;
+	height:16px;
+	cursor:pointer;
+    -moz-opacity: 0.6;
+    opacity:.6;
+.x-date-right a:hover, .x-date-left a:hover{
+    -moz-opacity: 1;
+    opacity:1;
+    filter: alpha(opacity=100);
+.x-item-disabled .x-date-right a:hover, .x-item-disabled .x-date-left a:hover{
+    opacity:.6;
+.x-date-right a {
+    margin-right:2px;
+.x-date-left a{
+    margin-left:2px;
+table.x-date-inner {
+    width: 100%;
+.ext-webkit table.x-date-inner{
+    /* Fix for webkit browsers */
+    width: 175px;
+.x-date-inner th {
+    width:25px;
+.x-date-inner th {
+    text-align:right !important;
+	cursor:default;
+    padding:0;
+.x-date-inner th span {
+    display:block;
+    padding:2px;
+    padding-right:7px;
+.x-date-inner td {
+	text-align:right;
+    padding:0;
+.x-date-inner a {
+    padding:2px 5px;
+    display:block;
+    text-align:right;
+    zoom:1;
+.x-date-inner .x-date-active{
+	cursor:pointer;
+	color:black;
+.x-date-inner .x-date-selected a{
+	border:1px solid;
+    padding:1px 4px;
+.x-date-inner .x-date-today a{
+    padding:1px 4px;
+.x-date-inner .x-date-prevday a,.x-date-inner .x-date-nextday a {
+.x-date-bottom {
+    padding:4px;
+.x-date-inner a:hover, .x-date-inner .x-date-disabled a:hover{
+.x-item-disabled .x-date-inner a:hover{
+    background: none;
+.x-date-inner .x-date-disabled a {
+	cursor:default;
+.x-date-menu .x-menu-item {
+	padding:1px 24px 1px 4px;
+.x-date-menu .x-menu-item .x-menu-item-icon {
+    width:10px;
+    height:10px;
+    margin-right:5px;
+    background-position:center -4px !important;
+.x-date-mp {
+	left:0;
+	top:0;
+	display:none;
+.x-date-mp td {
+    padding:2px;
+	font:normal 11px arial, helvetica,tahoma,sans-serif;
+td.x-date-mp-month,td.x-date-mp-year,td.x-date-mp-ybtn {
+    border: 0 none;
+	width:25%;
+.x-date-mp-ok {
+	margin-right:3px;
+.x-date-mp-btns button {
+	border:1px solid;
+	padding:1px 3px 1px;
+	cursor:pointer;
+.x-date-mp-btns {
+.x-date-mp-btns td {
+td.x-date-mp-month a,td.x-date-mp-year a {
+	display:block;
+	padding:2px 4px;
+td.x-date-mp-month a:hover,td.x-date-mp-year a:hover {
+	cursor:pointer;
+td.x-date-mp-sel a {
+	padding:1px 3px;
+	border:1px solid;
+.x-date-mp-ybtn a {
+    overflow:hidden;
+    width:15px;
+    height:15px;
+    cursor:pointer;
+    background:transparent no-repeat;
+    display:block;
+    margin:0 auto;
+.x-date-mp-ybtn a.x-date-mp-next {
+    background-position:0 -120px;
+.x-date-mp-ybtn a.x-date-mp-next:hover {
+    background-position:-15px -120px;
+.x-date-mp-ybtn a.x-date-mp-prev {
+    background-position:0 -105px;
+.x-date-mp-ybtn a.x-date-mp-prev:hover {
+    background-position:-15px -105px;
+.x-date-mp-ybtn {
+td.x-date-mp-sep {
+}.x-tip{
+	top: 0;
+    left:0;
+	z-index: 20002;
+    border:0 none;
+.x-tip .x-tip-close{
+	height: 15px;
+	float:right;
+	width: 15px;
+    margin:0 0 2px 2px;
+    cursor:pointer;
+    display:none;
+.x-tip .x-tip-tc {
+	background: transparent no-repeat 0 -62px;
+	padding-top:3px;
+    overflow:hidden;
+    zoom:1;
+.x-tip .x-tip-tl {
+	padding-left:6px;
+    overflow:hidden;
+    zoom:1;
+.x-tip .x-tip-tr {
+	padding-right:6px;
+    overflow:hidden;
+    zoom:1;
+.x-tip .x-tip-bc {
+	background: transparent no-repeat 0 -121px;
+	height:3px;
+    overflow:hidden;
+.x-tip .x-tip-bl {
+	background: transparent no-repeat 0 -59px;
+	padding-left:6px;
+    zoom:1;
+.x-tip .x-tip-br {
+	background: transparent no-repeat right -59px;
+    zoom:1;
+.x-tip .x-tip-mc {
+    border:0 none;
+.x-tip .x-tip-ml {
+	background: no-repeat 0 -124px;
+	padding-left:6px;
+    zoom:1;
+.x-tip .x-tip-mr {
+	background: transparent no-repeat right -124px;
+    zoom:1;
+.ext-ie .x-tip .x-tip-header,.ext-ie .x-tip .x-tip-tc {
+    font-size:0;
+    line-height:0;
+.ext-border-box .x-tip .x-tip-header, .ext-border-box .x-tip .x-tip-tc{
+    line-height: 1px;
+.x-tip .x-tip-header-text {
+    padding:0;
+    margin:0 0 2px 0;
+.x-tip .x-tip-body {
+    line-height:14px;
+    padding:0;
+.x-tip .x-tip-body .loading-indicator {
+    margin:0;
+.x-tip-draggable .x-tip-header,.x-tip-draggable .x-tip-header-text {
+    cursor:move;
+.x-form-invalid-tip .x-tip-tc {
+	background: repeat-x 0 -12px;
+    padding-top:6px;
+.x-form-invalid-tip .x-tip-bc {
+	background: repeat-x 0 -18px;
+    height:6px;
+.x-form-invalid-tip .x-tip-bl {
+	background: no-repeat 0 -6px;
+.x-form-invalid-tip .x-tip-br {
+	background: no-repeat right -6px;
+.x-form-invalid-tip .x-tip-body {
+    padding:2px;
+    padding-left:24px;
+    background:transparent no-repeat 2px 2px;
+.x-tip-anchor {
+    width: 9px;
+    height: 10px;
+    overflow:hidden;
+    zoom:1;
+.x-tip-anchor-bottom {
+.x-tip-anchor-right {
+    width: 10px;
+.x-tip-anchor-left {
+    background-position: -28px 0;
+    width: 10px;
+}.x-menu {
+	z-index: 15000;
+	zoom: 1;
+	background: repeat-y;
+.x-menu-floating{
+.x-menu a {
+    text-decoration: none !important;
+.ext-ie .x-menu {
+    zoom:1;
+    overflow:hidden;
+.x-menu-list{
+    padding: 2px;
+	border:0 none;
+    overflow:hidden;
+    overflow-y: hidden;
+.ext-strict .ext-ie .x-menu-list{
+.x-menu li{
+	line-height:100%;
+.x-menu li.x-menu-sep-li{
+	font-size:1px;
+	line-height:1px;
+.x-menu-list-item{
+	display:block;
+	padding:1px;
+.x-menu-item{
+.x-menu-item-arrow{
+	background:transparent no-repeat right;
+.x-menu-sep {
+	display:block;
+	font-size:1px;
+	line-height:1px;
+	margin: 2px 3px;
+	border-bottom:1px solid;
+    overflow:hidden;
+.x-menu-focus {
+	left:-1px;
+	top:-1px;
+	width:1px;
+	height:1px;
+    line-height:1px;
+    font-size:1px;
+    outline:0 none;
+    overflow:hidden;
+    display:block;
+a.x-menu-item {
+    cursor: pointer;
+    display: block;
+    outline-color: -moz-use-text-color;
+    outline-style: none;
+    outline-width: 0;
+    padding: 3px 21px 3px 27px;
+.x-menu-item-active {
+    background-repeat: repeat-x;
+    background-position: left bottom;
+    border-width: 1px 0;
+    margin:0 1px;
+	padding: 0;
+.x-menu-item-active a.x-menu-item {
+    border-width:0 1px;
+    margin:0 -1px;
+.x-menu-item-icon {
+	border: 0 none;
+	height: 16px;
+	padding: 0;
+	width: 16px;
+    left: 3px;
+    top: 3px;
+    margin: 0;
+.ext-ie .x-menu-item-icon {
+    left: -24px;
+.ext-strict .x-menu-item-icon {
+    left: 3px;
+.ext-ie6 .x-menu-item-icon {
+    left: -24px;
+.x-menu-check-item .x-menu-item-icon{
+	background: transparent no-repeat center;
+.x-menu-group-item .x-menu-item-icon{
+.x-menu-item-checked .x-menu-group-item .x-menu-item-icon{
+.x-date-menu .x-menu-list{
+    padding: 0;
+.x-menu-date-item{
+	padding:0;
+.x-menu .x-color-palette, .x-menu .x-date-picker{
+    margin-left: 26px;
+	margin-right:4px;
+.x-menu .x-date-picker{
+    border:1px solid;
+    margin-top:2px;
+    margin-bottom:2px;
+.x-menu-plain .x-color-palette, .x-menu-plain .x-date-picker{
+	 margin: 0;
+	 border: 0 none;
+.x-date-menu {
+ * fixes separator visibility problem in IE 6
+.ext-strict .ext-ie6 .x-menu-sep-li {
+    padding: 3px 4px;
+.ext-strict .ext-ie6 .x-menu-sep {
+    margin: 0;
+    height: 1px;
+ * Fixes an issue with "fat" separators in webkit
+.ext-webkit .x-menu-sep{
+    height: 1px;
+ * Ugly mess to remove the white border under the picker
+.ext-ie .x-date-menu{
+    height: 199px;
+.ext-strict .ext-ie .x-date-menu, .ext-border-box .ext-ie8 .x-date-menu{
+    height: 197px;
+.ext-strict .ext-ie7 .x-date-menu{
+    height: 195px;
+.ext-strict .ext-ie8 .x-date-menu{
+    height: auto;
+.x-cycle-menu .x-menu-item-checked {
+    border:1px dotted !important;
+	padding:0;
+.x-menu .x-menu-scroller {
+    width: 100%;
+	height:8px;
+    line-height: 8px;
+	cursor:pointer;
+    margin: 0;
+    padding: 0;
+.x-menu .x-menu-scroller-active{
+    height: 6px;
+    line-height: 6px;
+.x-menu-list-item-indent{
+    padding-left: 27px;
+ Creates rounded, raised boxes like on the Ext website - the markup isn't pretty:
+  <div class="x-box-blue">
+        <div class="x-box-tl"><div class="x-box-tr"><div class="x-box-tc"></div></div></div>
+        <div class="x-box-ml"><div class="x-box-mr"><div class="x-box-mc">
+            <h3>YOUR TITLE HERE (optional)</h3>
+            <div>YOUR CONTENT HERE</div>
+        </div></div></div>
+        <div class="x-box-bl"><div class="x-box-br"><div class="x-box-bc"></div></div></div>
+    </div>
+.x-box-tl {
+    zoom:1;
+.x-box-tc {
+	height: 8px;
+	overflow: hidden;
+.x-box-tr {
+	background: transparent no-repeat right -8px;
+.x-box-ml {
+	background: transparent repeat-y 0;
+	padding-left: 4px;
+	overflow: hidden;
+    zoom:1;
+.x-box-mc {
+	background: repeat-x 0 -16px;
+	padding: 4px 10px;
+.x-box-mc h3 {
+	margin: 0 0 4px 0;
+    zoom:1;
+.x-box-mr {
+	background: transparent repeat-y right;
+	padding-right: 4px;
+	overflow: hidden;
+.x-box-bl {
+	background: transparent no-repeat 0 -16px;
+    zoom:1;
+.x-box-bc {
+	background: transparent repeat-x 0 -8px;
+	height: 8px;
+	overflow: hidden;
+.x-box-br {
+	background: transparent no-repeat right -24px;
+.x-box-tl, .x-box-bl {
+	padding-left: 8px;
+	overflow: hidden;
+.x-box-tr, .x-box-br {
+	padding-right: 8px;
+	overflow: hidden;
+}.x-combo-list {
+    border:1px solid;
+    zoom:1;
+    overflow:hidden;
+.x-combo-list-inner {
+    overflow:auto;
+    position:relative; /* for calculating scroll offsets */
+    zoom:1;
+    overflow-x:hidden;
+.x-combo-list-hd {
+    padding:3px;
+.x-resizable-pinned .x-combo-list-inner {
+.x-combo-list-item {
+    padding:2px;
+    border:1px solid;
+    overflow:hidden;
+.x-combo-list .x-combo-selected{
+    cursor:pointer;
+.x-combo-list .x-toolbar {
+}.x-panel {
+    border-style: solid;
+    border-width:0;
+.x-panel-header {
+    overflow:hidden;
+    zoom:1;
+    padding:5px 3px 4px 5px;
+    border:1px solid;
+    line-height: 15px;
+    background: transparent repeat-x 0 -1px;
+.x-panel-body {
+    border:1px solid;
+    overflow:hidden;
+    position: relative; /* added for item scroll positioning */
+.x-panel-bbar .x-toolbar, .x-panel-tbar .x-toolbar {
+    border:1px solid;
+    overflow:hidden;
+    padding:2px;
+.x-panel-tbar-noheader .x-toolbar, .x-panel-mc .x-panel-tbar .x-toolbar {
+.x-panel-body-noheader, .x-panel-mc .x-panel-body {
+.x-panel-header {
+    overflow:hidden;
+    zoom:1;
+.x-panel-tl .x-panel-header {
+    padding:5px 0 4px 0;
+    border:0 none;
+.x-panel-tl .x-panel-icon, .x-window-tl .x-panel-icon {
+    padding-left:20px !important;
+    background-position:0 4px;
+    zoom:1;
+.x-panel-inline-icon {
+    width:16px;
+	height:16px;
+    background-position:0 0;
+	margin-right:4px;
+	margin-top:-1px;
+.x-panel-tc {
+	overflow:hidden;
+/* fix ie7 strict mode bug */
+.ext-strict .ext-ie7 .x-panel-tc {
+    overflow: visible;
+.x-panel-tl {
+	padding-left:6px;
+    zoom:1;
+.x-panel-tr {
+	zoom:1;
+.x-panel-bc {
+    zoom:1;
+.x-panel-bc .x-panel-footer {
+    zoom:1;
+.x-panel-bl {
+	padding-left:6px;
+    zoom:1;
+.x-panel-br {
+    zoom:1;
+.x-panel-mc {
+    border:0 none;
+    padding:0;
+    margin:0;
+    padding-top:6px;
+.x-panel-mc .x-panel-body {
+    border: 0 none;
+.x-panel-ml {
+	background: repeat-y 0 0;
+	padding-left:6px;
+    zoom:1;
+.x-panel-mr {
+    zoom:1;
+.x-panel-nofooter .x-panel-bc, .x-panel-nofooter .x-window-bc {
+	height:6px;
+    font-size:0;
+    line-height:0;
+.x-panel-bwrap {
+    overflow:hidden;
+    zoom:1;
+    left:0;
+    top:0;
+.x-panel-body {
+    overflow:hidden;
+    zoom:1;
+.x-panel-collapsed .x-resizable-handle{
+    display:none;
+.ext-gecko .x-panel-animated div {
+/* Plain */
+.x-plain-body {
+    overflow:hidden;
+.x-plain-bbar .x-toolbar {
+    overflow:hidden;
+    padding:2px;
+.x-plain-tbar .x-toolbar {
+    overflow:hidden;
+    padding:2px;
+.x-plain-bwrap {
+    overflow:hidden;
+    zoom:1;
+.x-plain {
+    overflow:hidden;
+/* Tools */
+.x-tool {
+    overflow:hidden;
+    width:15px;
+    height:15px;
+    float:right;
+    cursor:pointer;
+    margin-left:2px;
+/* expand / collapse tools */
+.x-tool-toggle {
+    background-position:0 -60px;
+.x-tool-toggle-over {
+    background-position:-15px -60px;
+.x-panel-collapsed .x-tool-toggle {
+    background-position:0 -75px;
+.x-panel-collapsed .x-tool-toggle-over {
+    background-position:-15px -75px;
+.x-tool-close {
+    background-position:0 -0;
+.x-tool-close-over {
+    background-position:-15px 0;
+.x-tool-minimize {
+    background-position:0 -15px;
+.x-tool-minimize-over {
+    background-position:-15px -15px;
+.x-tool-maximize {
+    background-position:0 -30px;
+.x-tool-maximize-over {
+    background-position:-15px -30px;
+.x-tool-restore {
+    background-position:0 -45px;
+.x-tool-restore-over {
+    background-position:-15px -45px;
+.x-tool-gear {
+    background-position:0 -90px;
+.x-tool-gear-over {
+    background-position:-15px -90px;
+.x-tool-prev {
+.x-tool-prev-over {
+.x-tool-next {
+.x-tool-next-over {
+.x-tool-pin {
+    background-position:0 -135px;
+.x-tool-pin-over {
+    background-position:-15px -135px;
+.x-tool-unpin {
+    background-position:0 -150px;
+.x-tool-unpin-over {
+    background-position:-15px -150px;
+.x-tool-right {
+    background-position:0 -165px;
+.x-tool-right-over {
+    background-position:-15px -165px;
+.x-tool-left {
+    background-position:0 -180px;
+.x-tool-left-over {
+    background-position:-15px -180px;
+.x-tool-down {
+    background-position:0 -195px;
+.x-tool-down-over {
+    background-position:-15px -195px;
+.x-tool-up {
+    background-position:0 -210px;
+.x-tool-up-over {
+    background-position:-15px -210px;
+.x-tool-refresh {
+    background-position:0 -225px;
+.x-tool-refresh-over {
+    background-position:-15px -225px;
+.x-tool-plus {
+    background-position:0 -240px;
+.x-tool-plus-over {
+    background-position:-15px -240px;
+.x-tool-minus {
+    background-position:0 -255px;
+.x-tool-minus-over {
+    background-position:-15px -255px;
+.x-tool-search {
+    background-position:0 -270px;
+.x-tool-search-over {
+    background-position:-15px -270px;
+.x-tool-save {
+    background-position:0 -285px;
+.x-tool-save-over {
+    background-position:-15px -285px;
+.x-tool-help {
+    background-position:0 -300px;
+.x-tool-help-over {
+    background-position:-15px -300px;
+.x-tool-print {
+    background-position:0 -315px;
+.x-tool-print-over {
+    background-position:-15px -315px;
+.x-tool-expand {
+    background-position:0 -330px;
+.x-tool-expand-over {
+    background-position:-15px -330px;
+.x-tool-collapse {
+    background-position:0 -345px;
+.x-tool-collapse-over {
+    background-position:-15px -345px;
+.x-tool-resize {
+    background-position:0 -360px;
+.x-tool-resize-over {
+    background-position:-15px -360px;
+.x-tool-move {
+    background-position:0 -375px;
+.x-tool-move-over {
+    background-position:-15px -375px;
+/* Ghosting */
+.x-panel-ghost {
+    z-index:12000;
+    overflow:hidden;
+    left:0;top:0;
+    opacity:.65;
+    -moz-opacity:.65;
+    filter:alpha(opacity=65);
+.x-panel-ghost ul {
+    margin:0;
+    padding:0;
+    overflow:hidden;
+    font-size:0;
+    line-height:0;
+    border:1px solid;
+    display:block;
+.x-panel-ghost * {
+    cursor:move !important;
+.x-panel-dd-spacer {
+    border:2px dashed;
+/* Buttons */
+.x-panel-btns {
+    padding:5px;
+    overflow:hidden;
+.x-panel-btns td.x-toolbar-cell{
+	padding:3px;
+.x-panel-btns .x-btn-focus .x-btn-left{
+.x-panel-btns .x-btn-focus .x-btn-right{
+.x-panel-btns .x-btn-focus .x-btn-center{
+.x-panel-btns .x-btn-over .x-btn-left{
+.x-panel-btns .x-btn-over .x-btn-right{
+.x-panel-btns .x-btn-over .x-btn-center{
+.x-panel-btns .x-btn-click .x-btn-center{
+.x-panel-btns .x-btn-click  .x-btn-right{
+.x-panel-btns .x-btn-click .x-btn-left{
+.x-panel-fbar td,.x-panel-fbar span,.x-panel-fbar input,.x-panel-fbar div,.x-panel-fbar select,.x-panel-fbar label{
+ * W3C Suggested Default style sheet for HTML 4
+ * http://www.w3.org/TR/CSS21/sample.html
+ * Resets for Ext.Panel @cfg normal: true
+.x-panel-reset .x-panel-body html,
+.x-panel-reset .x-panel-body address,
+.x-panel-reset .x-panel-body blockquote,
+.x-panel-reset .x-panel-body body,
+.x-panel-reset .x-panel-body dd,
+.x-panel-reset .x-panel-body div,
+.x-panel-reset .x-panel-body dl,
+.x-panel-reset .x-panel-body dt,
+.x-panel-reset .x-panel-body fieldset,
+.x-panel-reset .x-panel-body form,
+.x-panel-reset .x-panel-body frame, frameset,
+.x-panel-reset .x-panel-body h1,
+.x-panel-reset .x-panel-body h2,
+.x-panel-reset .x-panel-body h3,
+.x-panel-reset .x-panel-body h4,
+.x-panel-reset .x-panel-body h5,
+.x-panel-reset .x-panel-body h6,
+.x-panel-reset .x-panel-body noframes,
+.x-panel-reset .x-panel-body ol,
+.x-panel-reset .x-panel-body p,
+.x-panel-reset .x-panel-body ul,
+.x-panel-reset .x-panel-body center,
+.x-panel-reset .x-panel-body dir,
+.x-panel-reset .x-panel-body hr,
+.x-panel-reset .x-panel-body menu,
+.x-panel-reset .x-panel-body pre 			  { display: block }
+.x-panel-reset .x-panel-body li              { display: list-item }
+.x-panel-reset .x-panel-body head            { display: none }
+.x-panel-reset .x-panel-body table           { display: table }
+.x-panel-reset .x-panel-body tr              { display: table-row }
+.x-panel-reset .x-panel-body thead           { display: table-header-group }
+.x-panel-reset .x-panel-body tbody           { display: table-row-group }
+.x-panel-reset .x-panel-body tfoot           { display: table-footer-group }
+.x-panel-reset .x-panel-body col             { display: table-column }
+.x-panel-reset .x-panel-body colgroup        { display: table-column-group }
+.x-panel-reset .x-panel-body td,
+.x-panel-reset .x-panel-body th 	          { display: table-cell }
+.x-panel-reset .x-panel-body caption         { display: table-caption }
+.x-panel-reset .x-panel-body th              { font-weight: bolder; text-align: center }
+.x-panel-reset .x-panel-body caption         { text-align: center }
+.x-panel-reset .x-panel-body body            { margin: 8px }
+.x-panel-reset .x-panel-body h1              { font-size: 2em; margin: .67em 0 }
+.x-panel-reset .x-panel-body h2              { font-size: 1.5em; margin: .75em 0 }
+.x-panel-reset .x-panel-body h3              { font-size: 1.17em; margin: .83em 0 }
+.x-panel-reset .x-panel-body menu            { margin: 1.12em 0 }
+.x-panel-reset .x-panel-body h5              { font-size: .83em; margin: 1.5em 0 }
+.x-panel-reset .x-panel-body h6              { font-size: .75em; margin: 1.67em 0 }
+.x-panel-reset .x-panel-body b,
+.x-panel-reset .x-panel-body strong          { font-weight: bolder }
+.x-panel-reset .x-panel-body blockquote      { margin-left: 40px; margin-right: 40px }
+.x-panel-reset .x-panel-body i,
+.x-panel-reset .x-panel-body cite,
+.x-panel-reset .x-panel-body em,
+.x-panel-reset .x-panel-body var,
+.x-panel-reset .x-panel-body address    	  { font-style: italic }
+.x-panel-reset .x-panel-body pre,
+.x-panel-reset .x-panel-body tt,
+.x-panel-reset .x-panel-body code,
+.x-panel-reset .x-panel-body kbd,
+.x-panel-reset .x-panel-body samp       	  { font-family: monospace }
+.x-panel-reset .x-panel-body pre             { white-space: pre }
+.x-panel-reset .x-panel-body button,
+.x-panel-reset .x-panel-body textarea,
+.x-panel-reset .x-panel-body input,
+.x-panel-reset .x-panel-body select   		  { display: inline-block }
+.x-panel-reset .x-panel-body big             { font-size: 1.17em }
+.x-panel-reset .x-panel-body small,
+.x-panel-reset .x-panel-body sub,
+.x-panel-reset .x-panel-body sup 			  { font-size: .83em }
+.x-panel-reset .x-panel-body sub             { vertical-align: sub }
+.x-panel-reset .x-panel-body sup             { vertical-align: super }
+.x-panel-reset .x-panel-body table           { border-spacing: 2px; }
+.x-panel-reset .x-panel-body thead,
+.x-panel-reset .x-panel-body tbody,
+.x-panel-reset .x-panel-body tfoot           { vertical-align: middle }
+.x-panel-reset .x-panel-body th          	  { vertical-align: inherit }
+.x-panel-reset .x-panel-body s,
+.x-panel-reset .x-panel-body strike,
+.x-panel-reset .x-panel-body del  			  { text-decoration: line-through }
+.x-panel-reset .x-panel-body hr              { border: 1px inset }
+.x-panel-reset .x-panel-body dd        	  { margin-left: 40px }
+.x-panel-reset .x-panel-body ul, .x-panel-reset .x-panel-body menu, .x-panel-reset .x-panel-body dir { list-style-type: disc;}
+.x-panel-reset .x-panel-body ol              { list-style-type: decimal }
+.x-panel-reset .x-panel-body ol ul,
+.x-panel-reset .x-panel-body ul ol,
+.x-panel-reset .x-panel-body ul ul,
+.x-panel-reset .x-panel-body ol ol    		  { margin-top: 0; margin-bottom: 0 }
+.x-panel-reset .x-panel-body u,
+.x-panel-reset .x-panel-body ins          	  { text-decoration: underline }
+.x-panel-reset .x-panel-body br:before       { content: "\A" }
+.x-panel-reset .x-panel-body :before, .x-panel-reset .x-panel-body :after { white-space: pre-line }
+.x-panel-reset .x-panel-body center          { text-align: center }
+.x-panel-reset .x-panel-body :link, .x-panel-reset .x-panel-body :visited { text-decoration: underline }
+.x-panel-reset .x-panel-body :focus          { outline: invert dotted thin }
+/* Begin bidirectionality settings (do not change) */
+.x-panel-reset .x-panel-body BDO[DIR="ltr"]  { direction: ltr; unicode-bidi: bidi-override }
+.x-panel-reset .x-panel-body BDO[DIR="rtl"]  { direction: rtl; unicode-bidi: bidi-override }
+.x-window {
+    zoom:1;
+.x-window .x-window-handle {
+    opacity:0;
+    -moz-opacity:0;
+    filter:alpha(opacity=0);
+.x-window-proxy {
+    border:1px solid;
+    z-index:12000;
+    overflow:hidden;
+    position:absolute;
+    left:0;top:0;
+    display:none;
+    opacity:.5;
+    -moz-opacity:.5;
+.x-window-header {
+    overflow:hidden;
+    zoom:1;
+.x-window-bwrap {
+    z-index:1;
+    zoom:1;
+    left:0;top:0;
+.x-window-tl .x-window-header {
+.x-window-header-text {
+    cursor:pointer;
+.x-window-tc {
+	overflow:hidden;
+    zoom:1;
+.x-window-tl {
+	background: transparent no-repeat 0 0;
+	padding-left:6px;
+    zoom:1;
+    z-index:1;
+.x-window-tr {
+.x-window-bc {
+    zoom:1;
+.x-window-bc .x-window-footer {
+    zoom:1;
+    font-size:0;
+    line-height:0;
+.x-window-bl {
+	padding-left:6px;
+    zoom:1;
+.x-window-br {
+    zoom:1;
+.x-window-mc {
+    border:1px solid;
+    padding:0;
+    margin:0;
+.x-window-ml {
+	background: transparent repeat-y 0 0;
+	padding-left:6px;
+    zoom:1;
+.x-window-mr {
+    zoom:1;
+.x-window-body {
+    overflow:hidden;
+.x-window-bwrap {
+    overflow:hidden;
+.x-window-maximized .x-window-bl, .x-window-maximized .x-window-br,
+    .x-window-maximized .x-window-ml, .x-window-maximized .x-window-mr,
+    .x-window-maximized .x-window-tl, .x-window-maximized .x-window-tr {
+    padding:0;
+.x-window-maximized .x-window-footer {
+    padding-bottom:0;
+.x-window-maximized .x-window-tc {
+    padding-left:3px;
+.x-window-maximized .x-window-mc {
+    border-left:0 none;
+.x-window-tbar .x-toolbar, .x-window-bbar .x-toolbar {
+    border-right: 0 none;
+.x-window-bbar .x-toolbar {
+.x-window-draggable, .x-window-draggable .x-window-header-text {
+    cursor:move;
+.x-window-maximized .x-window-draggable, .x-window-maximized .x-window-draggable .x-window-header-text {
+    cursor:default;
+.x-window-body {
+.x-panel-ghost .x-window-tl {
+.x-panel-collapsed .x-window-tl {
+.x-window-maximized-ct {
+    overflow:hidden;
+.x-window-maximized .x-window-handle {
+    display:none;
+.x-window-sizing-ghost ul {
+    border:0 none !important;
+.x-dlg-focus{
+	outline:0 none;
+	width:0;
+	height:0;
+	overflow:hidden;
+	top:0;
+	left:0;
+.ext-webkit .x-dlg-focus{
+    width: 1px;
+    height: 1px;
+.x-dlg-mask{
+    z-index:10000;
+    display:none;
+    top:0;
+    left:0;
+    -moz-opacity: 0.5;
+    opacity:.50;
+    filter: alpha(opacity=50);
+body.ext-ie6.x-body-masked select {
+	visibility:hidden;
+body.ext-ie6.x-body-masked .x-window select {
+	visibility:visible;
+.x-window-plain .x-window-mc {
+    border: 1px solid;
+.x-window-plain .x-window-body {
+    background:transparent !important;
+}.x-html-editor-wrap {
+    border:1px solid;
+.x-html-editor-tb .x-btn-text {
+.x-html-editor-tb .x-edit-bold, .x-menu-item img.x-edit-bold {
+    background-image:url(images/editor/tb-sprite.gif);
+.x-html-editor-tb .x-edit-italic, .x-menu-item img.x-edit-italic {
+    background-position:-16px 0;
+.x-html-editor-tb .x-edit-underline, .x-menu-item img.x-edit-underline {
+.x-html-editor-tb .x-edit-forecolor, .x-menu-item img.x-edit-forecolor {
+    background-position:-160px 0;
+.x-html-editor-tb .x-edit-backcolor, .x-menu-item img.x-edit-backcolor {
+    background-position:-176px 0;
+.x-html-editor-tb .x-edit-justifyleft, .x-menu-item img.x-edit-justifyleft {
+    background-position:-112px 0;
+.x-html-editor-tb .x-edit-justifycenter, .x-menu-item img.x-edit-justifycenter {
+    background-position:-128px 0;
+.x-html-editor-tb .x-edit-justifyright, .x-menu-item img.x-edit-justifyright {
+    background-position:-144px 0;
+.x-html-editor-tb .x-edit-insertorderedlist, .x-menu-item img.x-edit-insertorderedlist {
+    background-position:-80px 0;
+.x-html-editor-tb .x-edit-insertunorderedlist, .x-menu-item img.x-edit-insertunorderedlist {
+    background-position:-96px 0;
+.x-html-editor-tb .x-edit-increasefontsize, .x-menu-item img.x-edit-increasefontsize {
+.x-html-editor-tb .x-edit-decreasefontsize, .x-menu-item img.x-edit-decreasefontsize {
+    background-position:-64px 0;
+.x-html-editor-tb .x-edit-sourceedit, .x-menu-item img.x-edit-sourceedit {
+    background-position:-192px 0;
+.x-html-editor-tb .x-edit-createlink, .x-menu-item img.x-edit-createlink {
+    background-position:-208px 0;
+.x-html-editor-tip .x-tip-bd .x-tip-bd-inner {
+    padding:5px;
+    padding-bottom:1px;
+.x-html-editor-tb .x-toolbar {
+    position:static !important;
+}.x-panel-noborder .x-panel-body-noborder {
+    border-width:0;
+.x-panel-noborder .x-panel-header-noborder {
+    border-width:0 0 1px;
+.x-panel-noborder .x-panel-tbar-noborder .x-toolbar {
+.x-panel-noborder .x-panel-bbar-noborder .x-toolbar {
+    border-width:1px 0 0 0;
+.x-window-noborder .x-window-mc {
+    border-width:0;
+.x-window-plain .x-window-body-noborder {
+    border-width:0;
+.x-tab-panel-noborder .x-tab-panel-body-noborder {
+	border-width:0;
+.x-tab-panel-noborder .x-tab-panel-header-noborder {
+    border-width: 0 0 1px 0;
+.x-tab-panel-noborder .x-tab-panel-footer-noborder {
+    border-width: 1px 0 0 0;
+.x-tab-panel-bbar-noborder .x-toolbar {
+.x-tab-panel-tbar-noborder .x-toolbar {
+}.x-border-layout-ct {
+.x-border-panel {
+    left:0;
+    top:0;
+.x-tool-collapse-south {
+.x-tool-collapse-south-over {
+.x-tool-collapse-north {
+.x-tool-collapse-north-over {
+.x-tool-collapse-west {
+.x-tool-collapse-west-over {
+.x-tool-collapse-east {
+.x-tool-collapse-east-over {
+.x-tool-expand-south {
+.x-tool-expand-south-over {
+.x-tool-expand-north {
+.x-tool-expand-north-over {
+.x-tool-expand-west {
+.x-tool-expand-west-over {
+.x-tool-expand-east {
+.x-tool-expand-east-over {
+.x-tool-expand-north, .x-tool-expand-south {
+    float:right;
+    margin:3px;
+.x-tool-expand-east, .x-tool-expand-west {
+    float:none;
+    margin:3px 2px;
+.x-accordion-hd .x-tool-toggle {
+.x-accordion-hd .x-tool-toggle-over {
+.x-panel-collapsed .x-accordion-hd .x-tool-toggle {
+.x-panel-collapsed .x-accordion-hd .x-tool-toggle-over {
+.x-accordion-hd {
+	padding-top:4px;
+	padding-bottom:3px;
+    background: transparent repeat-x 0 -9px;
+.x-layout-collapsed{
+    left:-10000px;
+    top:-10000px;
+    width:20px;
+    height:20px;
+    overflow:hidden;
+	border:1px solid;
+	z-index:20;
+.ext-border-box .x-layout-collapsed{
+    width:22px;
+    height:22px;
+.x-layout-collapsed-over{
+    cursor:pointer;
+.x-layout-collapsed-west .x-layout-collapsed-tools, .x-layout-collapsed-east .x-layout-collapsed-tools{
+    top:0;
+    left:0;
+    width:20px;
+    height:20px;
+.x-layout-split{
+    height:5px;
+    width:5px;
+    line-height:1px;
+    font-size:1px;
+    z-index:3;
+/* IE6 strict won't drag w/out a color */
+.ext-strict .ext-ie6 .x-layout-split{
+    background-color: #fff !important;
+    filter: alpha(opacity=1);
+.x-layout-split-h{
+    background-image:url(images/s.gif);
+    background-position: left;
+.x-layout-split-v{
+    background-position: top;
+.x-column-layout-ct {
+    overflow:hidden;
+    zoom:1;
+.x-column {
+    float:left;
+    padding:0;
+    margin:0;
+    overflow:hidden;
+    zoom:1;
+.x-column-inner {
+    overflow:hidden;
+    zoom:1;
+/* mini mode */
+.x-layout-mini {
+    top:0;
+    left:0;
+    display:block;
+    width:5px;
+    height:35px;
+    cursor:pointer;
+    opacity:.5;
+    -moz-opacity:.5;
+    filter:alpha(opacity=50);
+.x-layout-mini-over, .x-layout-collapsed-over .x-layout-mini{
+    opacity:1;
+    -moz-opacity:1;
+    filter:none;
+.x-layout-split-west .x-layout-mini {
+    top:48%;
+.x-layout-split-east .x-layout-mini {
+    top:48%;
+.x-layout-split-north .x-layout-mini {
+    left:48%;
+    height:5px;
+    width:35px;
+.x-layout-split-south .x-layout-mini {
+    left:48%;
+    height:5px;
+    width:35px;
+.x-layout-cmini-west .x-layout-mini {
+    top:48%;
+.x-layout-cmini-east .x-layout-mini {
+    top:48%;
+.x-layout-cmini-north .x-layout-mini {
+    left:48%;
+    height:5px;
+    width:35px;
+.x-layout-cmini-south .x-layout-mini {
+    left:48%;
+    height:5px;
+    width:35px;
+.x-layout-cmini-west, .x-layout-cmini-east {
+    border:0 none;
+    width:5px !important;
+    padding:0;
+.x-layout-cmini-north, .x-layout-cmini-south {
+    border:0 none;
+    height:5px !important;
+    padding:0;
+.x-viewport, .x-viewport body {
+    margin: 0;
+    padding: 0;
+    border: 0 none;
+    overflow: hidden;
+    height: 100%;
+.x-abs-layout-item {
+    left:0;
+    top:0;
+.ext-ie input.x-abs-layout-item, .ext-ie textarea.x-abs-layout-item {
+    margin:0;
+.x-box-layout-ct {
+    overflow:hidden;
+    zoom:1;
+.x-box-inner {
+    overflow:hidden;
+    zoom:1;
+    left:0;
+    top:0;
+.x-box-item {
+    left:0;
+    top:0;
+}.x-progress-wrap {
+    border:1px solid;
+    overflow:hidden;
+.x-progress-inner {
+    height:18px;
+    background:repeat-x;
+.x-progress-bar {
+    height:18px;
+    float:left;
+    width:0;
+    background: repeat-x left center;
+.x-progress-text {
+    padding:1px 5px;
+    overflow:hidden;
+    left:0;
+.x-progress-text-back {
+    line-height:16px;
+.ext-ie .x-progress-text-back {
+    line-height:15px;
+.ext-strict .ext-ie7 .x-progress-text-back{
+    width: 100%;
+.x-list-header{
+	cursor:default;
+    zoom:1;
+    height:22px;
+.x-list-header-inner div {
+    display:block;
+    float:left;
+    overflow:hidden;
+	text-overflow: ellipsis;
+    white-space: nowrap;
+.x-list-header-inner div em {
+    display:block;
+    padding:4px 4px;
+    overflow:hidden;
+    -moz-user-select: none;
+    -khtml-user-select: none;
+    line-height:14px;
+.x-list-body {
+    overflow:auto;
+    overflow-y:auto;
+    zoom:1;
+    float: left;
+    width: 100%;
+.x-list-body dl {
+    zoom:1;
+.x-list-body dt {
+    display:block;
+    float:left;
+    overflow:hidden;
+    cursor:pointer;
+    zoom:1;
+.x-list-body dt em {
+    display:block;
+    padding:3px 4px;
+    overflow:hidden;
+.x-list-resizer {
+    left:0;
+    top:0;
+.x-list-header-inner em.sort-asc {
+    background: transparent no-repeat center 0;
+    border-width: 0 1px 1px;
+.x-list-header-inner em.sort-desc {
+    background: transparent no-repeat center -23px;
+/* Shared styles */
+.x-slider {
+    zoom:1;
+.x-slider-inner {
+    left:0;
+    top:0;
+    overflow:visible;
+    zoom:1;
+.x-slider-focus {
+	left:0;
+	top:0;
+	width:1px;
+	height:1px;
+    line-height:1px;
+    font-size:1px;
+    outline:0 none;
+    -webkit-user-select:ignore;
+	display:block;
+	overflow:hidden;
+/* Horizontal styles */
+.x-slider-horz {
+    padding-left:7px;
+    background:transparent no-repeat 0 -22px;
+.x-slider-horz .x-slider-end {
+    zoom:1;
+    background:transparent no-repeat right -44px;
+.x-slider-horz .x-slider-inner {
+    background:transparent repeat-x 0 0;
+    height:22px;
+.x-slider-horz .x-slider-thumb {
+    width:14px;
+    height:15px;
+    left:0;
+    top:3px;
+    background:transparent no-repeat 0 0;
+.x-slider-horz .x-slider-thumb-over {
+    background-position: -14px -15px;
+.x-slider-horz .x-slider-thumb-drag {
+    background-position: -28px -30px;
+/* Vertical styles */
+.x-slider-vert {
+    padding-top:7px;
+    background:transparent no-repeat -44px 0;
+    width:22px;
+.x-slider-vert .x-slider-end {
+    padding-bottom:7px;
+    zoom:1;
+    background:transparent no-repeat -22px bottom;
+.x-slider-vert .x-slider-inner {
+    background:transparent repeat-y 0 0;
+.x-slider-vert .x-slider-thumb {
+    width:15px;
+    height:14px;
+    left:3px;
+    bottom:0;
+.x-slider-vert .x-slider-thumb-over {
+    background-position: -15px -14px;
+.x-slider-vert .x-slider-thumb-drag {
+    background-position: -30px -28px;
+}.x-window-dlg .x-window-body {
+    padding:5px 10px;
+.x-window-dlg .x-window-mc {
+.x-window-dlg .ext-mb-input {
+    margin-top:4px;
+    width:95%;
+.x-window-dlg .ext-mb-textarea {
+    margin-top:4px;
+.x-window-dlg .x-progress-wrap {
+    margin-top:4px;
+.ext-ie .x-window-dlg .x-progress-wrap {
+    margin-top:6px;
+.x-window-dlg .x-msg-box-wait {
+    background:transparent no-repeat left;
+    display:block;
+    width:300px;
+    padding-left:18px;
+    line-height:18px;
+.x-window-dlg .ext-mb-icon {
+    float:left;
+    width:47px;
+    height:32px;
+.x-window-dlg .x-dlg-icon .ext-mb-content{
+    zoom: 1;
+    margin-left: 47px;
+.x-window-dlg .ext-mb-info, .x-window-dlg .ext-mb-warning, .x-window-dlg .ext-mb-question, .x-window-dlg .ext-mb-error {
+    background:transparent no-repeat top left;
+.ext-gecko2 .ext-mb-fix-cursor {
+    overflow:auto;
+}.ext-el-mask {
+    background-color: #ccc;
+.ext-el-mask-msg {
+    border-color:#6593cf;
+    background-color:#c3daf9;
+    background-image:url(images/box/tb-blue.gif);
+.ext-el-mask-msg div {
+    background-color: #eee;
+    border-color:#a3bad9;
+    color:#222;
+    font:normal 11px tahoma, arial, helvetica, sans-serif;
+.x-mask-loading div {
+    background-color:#fbfbfb;
+    background-image:url(images/grid/loading.gif);
+.x-item-disabled {
+    color: gray;
+.x-item-disabled * {
+    color: gray !important;
+.x-splitbar-proxy {
+    background-color: #aaa;
+.x-color-palette a {
+    border-color:#fff;
+.x-color-palette a:hover, .x-color-palette a.x-color-palette-sel {
+    border-color:#8bb8f3;
+    background-color: #deecfd;
+.x-color-palette em:hover, .x-color-palette span:hover{
+.x-color-palette em {
+    border-color:#aca899;
+.x-ie-shadow {
+    background-color:#777;
+.x-shadow .xsmc {
+    background-image: url(images/shadow-c.png);
+.x-shadow .xsml, .x-shadow .xsmr {
+    background-image: url(images/shadow-lr.png);
+.x-shadow .xstl, .x-shadow .xstc,  .x-shadow .xstr, .x-shadow .xsbl, .x-shadow .xsbc, .x-shadow .xsbr{
+    background-image: url(images/shadow.png);
+.loading-indicator {
+    font-size: 11px;
+    background-image: url(images/grid/loading.gif);
+.x-spotlight {
+.x-tab-panel-header, .x-tab-panel-footer {
+	border-color:#8db2e3;
+    overflow:hidden;
+    zoom:1;
+ul.x-tab-strip-top{
+    background-color:#cedff5;
+	background-image: url(images/tabs/tab-strip-bg.gif);
+	border-bottom-color:#8db2e3;
+ul.x-tab-strip-bottom{
+	background-image: url(images/tabs/tab-strip-btm-bg.gif);
+	border-top-color:#8db2e3;
+.x-tab-panel-header-plain .x-tab-strip-spacer,
+.x-tab-panel-footer-plain .x-tab-strip-spacer {
+.x-tab-strip span.x-tab-strip-text {
+	font:normal 11px tahoma,arial,helvetica;
+	color:#416aa3;
+.x-tab-strip-over span.x-tab-strip-text {
+	color:#15428b;
+.x-tab-strip-active span.x-tab-strip-text {
+	color:#15428b;
+    font-weight:bold;
+.x-tab-strip-disabled .x-tabs-text {
+	color:#aaaaaa;
+.x-tab-strip-top .x-tab-right, .x-tab-strip-top .x-tab-left, .x-tab-strip-top .x-tab-strip-inner{
+	background-image: url(images/tabs/tabs-sprite.gif);
+.x-tab-strip-bottom .x-tab-right {
+	background-image: url(images/tabs/tab-btm-inactive-right-bg.gif);
+.x-tab-strip-bottom .x-tab-left {
+	background-image: url(images/tabs/tab-btm-inactive-left-bg.gif);
+.x-tab-strip-bottom .x-tab-strip-over .x-tab-right {
+	background-image: url(images/tabs/tab-btm-over-right-bg.gif);
+.x-tab-strip-bottom .x-tab-strip-over .x-tab-left {
+	background-image: url(images/tabs/tab-btm-over-left-bg.gif);
+.x-tab-strip-bottom .x-tab-strip-active .x-tab-right {
+	background-image: url(images/tabs/tab-btm-right-bg.gif);
+.x-tab-strip-bottom .x-tab-strip-active .x-tab-left {
+	background-image: url(images/tabs/tab-btm-left-bg.gif);
+.x-tab-strip .x-tab-strip-closable a.x-tab-strip-close {
+	background-image:url(images/tabs/tab-close.gif);
+.x-tab-strip .x-tab-strip-closable a.x-tab-strip-close:hover{
+.x-tab-panel-body {
+    background-color:#fff;
+.x-tab-panel-body-top {
+    border-top: 0 none;
+.x-tab-panel-body-bottom {
+    border-bottom: 0 none;
+.x-tab-scroller-left {
+    background-image:url(images/tabs/scroll-left.gif);
+.x-tab-scroller-left-over {
+    background-position: 0 0;
+.x-tab-scroller-left-disabled {
+    background-position: -18px 0;
+    opacity:.5;
+    -moz-opacity:.5;
+    cursor:default;
+.x-tab-scroller-right {
+    background-image:url(images/tabs/scroll-right.gif);
+.x-tab-panel-bbar .x-toolbar, .x-tab-panel-tbar .x-toolbar {
+    border-color:99e8a1;
+}.x-form-field {
+    font:normal 12px tahoma, arial, helvetica, sans-serif;
+.x-form-text, textarea.x-form-field {
+    background-image:url(images/form/text-bg.gif);
+    border-color:#b5b8c8;
+.x-form-select-one {
+.x-form-check-group-label {
+    border-bottom: 1px solid 99e8a1;
+    color: #15428b;
+.x-editor .x-form-check-wrap {
+.x-form-field-wrap .x-form-trigger {
+    background-image:url(images/form/trigger.gif);
+    border-bottom-color:#b5b8c8;
+.x-form-field-wrap .x-form-date-trigger {
+    background-image: url(images/form/date-trigger.gif);
+.x-form-field-wrap .x-form-clear-trigger {
+    background-image: url(images/form/clear-trigger.gif);
+.x-form-field-wrap .x-form-search-trigger {
+    background-image: url(images/form/search-trigger.gif);
+.x-trigger-wrap-focus .x-form-trigger {
+    border-bottom-color:#7eadd9;
+.x-item-disabled .x-form-trigger-over {
+.x-item-disabled .x-form-trigger-click {
+.x-form-focus, textarea.x-form-focus {
+	border-color:#7eadd9;
+.x-form-invalid, textarea.x-form-invalid {
+	background-image:url(images/grid/invalid_line.gif);
+	border-color:#c30;
+.x-form-invalid.x-form-composite {
+    border: none;
+.x-form-invalid.x-form-composite .x-form-invalid {
+.x-form-inner-invalid, textarea.x-form-inner-invalid {
+.x-form-grow-sizer {
+.x-form-item {
+.x-form-invalid-msg {
+    color:#c0272b;
+    background-image:url(images/shared/warning.gif);
+.x-form-empty-field {
+    color:gray;
+.x-small-editor .x-form-field {
+    font:normal 11px arial, tahoma, helvetica, sans-serif;
+.ext-webkit .x-small-editor .x-form-field {
+.x-form-invalid-icon {
+    background-image:url(images/form/exclamation.gif);
+.x-fieldset {
+.x-fieldset legend {
+    font:bold 11px tahoma, arial, helvetica, sans-serif;
+    color:#15428b;
+.x-btn{
+	font:normal 11px tahoma, verdana, helvetica;
+.x-btn button{
+    font:normal 11px arial,tahoma,verdana,helvetica;
+    color:#333;
+.x-btn em {
+    font-style:normal;
+    font-weight:normal;
+.x-btn-tl, .x-btn-tr, .x-btn-tc, .x-btn-ml, .x-btn-mr, .x-btn-mc, .x-btn-bl, .x-btn-br, .x-btn-bc{
+	background-image:url(images/button/btn.gif);
+.x-btn-click .x-btn-text, .x-btn-menu-active .x-btn-text, .x-btn-pressed .x-btn-text{
+    color:#000;
+.x-btn-disabled *{
+    background-image:url(images/button/arrow.gif);
+    background-image:url(images/button/s-arrow.gif);
+.x-btn-over .x-btn-mc em.x-btn-split, .x-btn-click .x-btn-mc em.x-btn-split, .x-btn-menu-active .x-btn-mc em.x-btn-split, .x-btn-pressed .x-btn-mc em.x-btn-split {
+    background-image:url(images/button/s-arrow-o.gif);
+    background-image:url(images/button/s-arrow-b-noline.gif);
+    background-image:url(images/button/s-arrow-b.gif);
+.x-btn-over .x-btn-mc em.x-btn-split-bottom, .x-btn-click .x-btn-mc em.x-btn-split-bottom, .x-btn-menu-active .x-btn-mc em.x-btn-split-bottom, .x-btn-pressed .x-btn-mc em.x-btn-split-bottom {
+    background-image:url(images/button/s-arrow-bo.gif);
+    color: #3e6aaa;
+.x-btn-group-tc {
+	background-image: url(images/button/group-tb.gif);
+.x-btn-group-tl {
+	background-image: url(images/button/group-cs.gif);
+.x-btn-group-tr {
+.x-btn-group-bc {
+.x-btn-group-bl {
+.x-btn-group-br {
+.x-btn-group-ml {
+	background-image: url(images/button/group-lr.gif);
+.x-btn-group-mr {
+}.x-toolbar{
+	border-color:#a9bfd3;
+    background-color:#d0def0;
+    background-image:url(images/toolbar/bg.gif);
+    font:normal 11px arial,tahoma, helvetica, sans-serif;
+	color:gray;
+	color:gray;
+.x-toolbar .x-btn-mc em.x-btn-split {
+    background-image:url(images/button/s-arrow-noline.gif);
+.x-toolbar .x-btn-over .x-btn-mc em.x-btn-split, .x-toolbar .x-btn-click .x-btn-mc em.x-btn-split,
+.x-toolbar .x-btn-menu-active .x-btn-mc em.x-btn-split, .x-toolbar .x-btn-pressed .x-btn-mc em.x-btn-split
+.x-toolbar .x-btn-mc em.x-btn-split-bottom {
+.x-toolbar .x-btn-over .x-btn-mc em.x-btn-split-bottom, .x-toolbar .x-btn-click .x-btn-mc em.x-btn-split-bottom,
+.x-toolbar .x-btn-menu-active .x-btn-mc em.x-btn-split-bottom, .x-toolbar .x-btn-pressed .x-btn-mc em.x-btn-split-bottom
+	background-image: url(images/grid/grid-blue-split.gif);
+.x-tbar-page-first{
+	background-image: url(images/grid/page-first.gif) !important;
+.x-tbar-loading{
+	background-image: url(images/grid/refresh.gif) !important;
+.x-tbar-page-last{
+	background-image: url(images/grid/page-last.gif) !important;
+.x-tbar-page-next{
+	background-image: url(images/grid/page-next.gif) !important;
+.x-tbar-page-prev{
+	background-image: url(images/grid/page-prev.gif) !important;
+.x-item-disabled .x-tbar-loading{
+	background-image: url(images/grid/refresh-disabled.gif) !important;
+.x-item-disabled .x-tbar-page-first{
+	background-image: url(images/grid/page-first-disabled.gif) !important;
+.x-item-disabled .x-tbar-page-last{
+	background-image: url(images/grid/page-last-disabled.gif) !important;
+.x-item-disabled .x-tbar-page-next{
+	background-image: url(images/grid/page-next-disabled.gif) !important;
+.x-item-disabled .x-tbar-page-prev{
+	background-image: url(images/grid/page-prev-disabled.gif) !important;
+.x-paging-info {
+    color:#444;
+.x-toolbar-more-icon {
+    background-image: url(images/toolbar/more.gif) !important;
+}.x-resizable-handle {
+.x-resizable-over .x-resizable-handle-east, .x-resizable-pinned .x-resizable-handle-east,
+.x-resizable-over .x-resizable-handle-west, .x-resizable-pinned .x-resizable-handle-west
+    background-image:url(images/sizer/e-handle.gif);
+.x-resizable-over .x-resizable-handle-south, .x-resizable-pinned .x-resizable-handle-south,
+.x-resizable-over .x-resizable-handle-north, .x-resizable-pinned .x-resizable-handle-north
+    background-image:url(images/sizer/s-handle.gif);
+.x-resizable-over .x-resizable-handle-north, .x-resizable-pinned .x-resizable-handle-north{
+.x-resizable-over .x-resizable-handle-southeast, .x-resizable-pinned .x-resizable-handle-southeast{
+    background-image:url(images/sizer/se-handle.gif);
+.x-resizable-over .x-resizable-handle-northwest, .x-resizable-pinned .x-resizable-handle-northwest{
+    background-image:url(images/sizer/nw-handle.gif);
+.x-resizable-over .x-resizable-handle-northeast, .x-resizable-pinned .x-resizable-handle-northeast{
+    background-image:url(images/sizer/ne-handle.gif);
+.x-resizable-over .x-resizable-handle-southwest, .x-resizable-pinned .x-resizable-handle-southwest{
+    background-image:url(images/sizer/sw-handle.gif);
+.x-resizable-proxy{
+    border-color:#3b5a82;
+.x-resizable-overlay{
+.x-grid3 {
+.x-grid3-row td, .x-grid3-summary-row td{
+	font:normal 11px/13px arial, tahoma, helvetica, sans-serif;
+	font:normal 11px/15px arial, tahoma, helvetica, sans-serif;
+    border-left-color:#eee;
+    border-right-color:#d0d0d0;
+    background-color: #fff;
+    background-image:url(images/shared/loading-balls.gif);
+.x-grid3-row {
+    border-color:#ededed;
+    border-top-color:#fff;
+.x-grid3-row-alt{
+	background-color:#fafafa;
+	border-color:#ddd;
+    background-color:#efefef;
+    background-image:url(images/grid/row-over.gif);
+.x-grid3-header{
+    background-color:#f9f9f9;
+	background-image:url(images/grid/grid3-hrow.gif);
+    border-left-color:#d0d0d0;
+    background-image:url(images/grid/hd-pop.gif);
+    border-left-color:#aaccf6;
+    border-right-color:#aaccf6;
+    background-color:#ebf3fd;
+    background-image:url(images/grid/grid3-hrow-over.gif);
+.sort-asc .x-grid3-sort-icon {
+	background-image: url(images/grid/sort_asc.gif);
+.sort-desc .x-grid3-sort-icon {
+	background-image: url(images/grid/sort_desc.gif);
+	color:#000;
+.x-grid3-split {
+	background-image: url(images/grid/grid-split.gif);
+.x-grid3-hd-text {
+	color:#15428b;
+	border-color:#aaccf6;
+.col-move-top{
+	background-image:url(images/grid/col-move-top.gif);
+.col-move-bottom{
+	background-image:url(images/grid/col-move-bottom.gif);
+td.grid-hd-group-cell {
+    background: url(images/grid/grid3-hrow.gif) repeat-x bottom;
+	background-color: acf6b1 !important;
+	border-color:#a3bae9;
+.x-grid3-cell-selected{
+	background-color: #b8cfee !important;
+	color:#000;
+.x-grid3-cell-selected span{
+	color:#000 !important;
+.x-grid3-cell-selected .x-grid3-cell-text{
+	color:#000;
+    background-color:#ebeadb !important;
+    background-image:url(images/grid/grid-hrow.gif) !important;
+    color:#000;
+    border-right-color:#6fa0df !important;
+    color:#15428b !important;
+    background-image:url(images/grid/dirty.gif);
+	border-top-color:#a9bfd3;
+	background-image:url(images/grid/grid3-special-col-bg.gif) !important;
+    background-color:#fff !important;
+    border-right-color:#eee;
+.xg-hmenu-sort-asc .x-menu-item-icon{
+	background-image: url(images/grid/hmenu-asc.gif);
+.xg-hmenu-sort-desc .x-menu-item-icon{
+	background-image: url(images/grid/hmenu-desc.gif);
+.xg-hmenu-lock .x-menu-item-icon{
+	background-image: url(images/grid/hmenu-lock.gif);
+.xg-hmenu-unlock .x-menu-item-icon{
+	background-image: url(images/grid/hmenu-unlock.gif);
+.x-grid3-hd-btn {
+    background-image:url(images/grid/grid3-hd-btn.gif);
+    background-image:url(images/grid/grid3-special-col-bg.gif);
+    background-image:url(images/grid/row-expand-sprite.gif);
+    background-image: url(images/grid/grid3-special-col-bg.gif);
+    background-image:url(images/grid/row-check-sprite.gif);
+	color:#444;
+	background-image:url(images/grid/grid3-special-col-sel-bg.gif);
+	background-image:url(images/menu/unchecked.gif);
+	background-image:url(images/menu/checked.gif);
+    zoom:1;
+.x-grid-group-hd {
+    border-bottom-color:99e8a1;
+    background-image:url(images/grid/group-collapse.gif);
+    color:#3764a0;
+.x-grid-group-collapsed .x-grid-group-hd div.x-grid-group-title {
+    background-image:url(images/grid/group-expand.gif);
+.x-group-by-icon {
+    background-image:url(images/grid/group-by.gif);
+.x-cols-icon {
+    background-image:url(images/grid/columns.gif);
+.x-show-groups-icon {
+.x-grid-empty {
+    color:gray;
+    border-right-color:#ededed;
+.x-grid-with-col-lines .x-grid3-row-selected {
+	border-top-color:#a3bae9;
+}.x-pivotgrid .x-grid3-header-offset table td {
+    background: url(images/grid/grid3-hrow.gif) repeat-x 50% 100%;
+    border-left: 1px solid;
+    border-right: 1px solid;
+    border-left-color: #EEE;
+    border-right-color: #D0D0D0;
+    background-color: #f9f9f9;
+    background: #EEE url(images/grid/grid3-rowheader.gif) repeat-x left top;
+    border-bottom: 1px solid;
+    border-bottom-color: #D0D0D0;
+    height: 18px;
+.x-dd-drag-ghost{
+	color:#000;
+	font: normal 11px arial, helvetica, sans-serif;
+    border-color: #ddd #bbb #bbb #ddd;
+.x-dd-drop-nodrop .x-dd-drop-icon{
+  background-image: url(images/dd/drop-no.gif);
+.x-dd-drop-ok .x-dd-drop-icon{
+  background-image: url(images/dd/drop-yes.gif);
+.x-dd-drop-ok-add .x-dd-drop-icon{
+  background-image: url(images/dd/drop-add.gif);
+.x-view-selector {
+    border-color:#3399bb;
+}.x-tree-node-expanded .x-tree-node-icon{
+	background-image:url(images/tree/folder-open.gif);
+.x-tree-node-leaf .x-tree-node-icon{
+	background-image:url(images/tree/leaf.gif);
+.x-tree-node-collapsed .x-tree-node-icon{
+	background-image:url(images/tree/folder.gif);
+.x-tree-node-loading .x-tree-node-icon{
+	background-image:url(images/tree/loading.gif) !important;
+.x-tree-node .x-tree-node-inline-icon {
+    background-image: none;
+.x-tree-node-loading a span{
+	 font-style: italic;
+	 color:#444444;
+.x-tree-lines .x-tree-elbow{
+	background-image:url(images/tree/elbow.gif);
+.x-tree-lines .x-tree-elbow-plus{
+	background-image:url(images/tree/elbow-plus.gif);
+.x-tree-lines .x-tree-elbow-minus{
+	background-image:url(images/tree/elbow-minus.gif);
+.x-tree-lines .x-tree-elbow-end{
+	background-image:url(images/tree/elbow-end.gif);
+.x-tree-lines .x-tree-elbow-end-plus{
+	background-image:url(images/tree/elbow-end-plus.gif);
+.x-tree-lines .x-tree-elbow-end-minus{
+	background-image:url(images/tree/elbow-end-minus.gif);
+.x-tree-lines .x-tree-elbow-line{
+	background-image:url(images/tree/elbow-line.gif);
+.x-tree-no-lines .x-tree-elbow-plus{
+	background-image:url(images/tree/elbow-plus-nl.gif);
+.x-tree-no-lines .x-tree-elbow-minus{
+	background-image:url(images/tree/elbow-minus-nl.gif);
+.x-tree-no-lines .x-tree-elbow-end-plus{
+	background-image:url(images/tree/elbow-end-plus-nl.gif);
+.x-tree-no-lines .x-tree-elbow-end-minus{
+	background-image:url(images/tree/elbow-end-minus-nl.gif);
+    background-image:url(images/tree/arrows.gif);
+.x-tree-node{
+	color:#000;
+	font: normal 11px arial, tahoma, helvetica, sans-serif;
+	color:#000;
+	color:#000;
+.x-tree-node .x-tree-node-disabled a span{
+	color:gray !important;
+ 	 border-bottom-color:#36c;
+	 border-top-color:#36c;
+	 background-color:#ddd;
+	 border-color:gray;
+.x-tree-node .x-tree-node-over {
+.x-tree-node .x-tree-selected {
+	background-color: #d9e8fb;
+.x-tree-drop-ok-append .x-dd-drop-icon{
+  background-image: url(images/tree/drop-add.gif);
+.x-tree-drop-ok-above .x-dd-drop-icon{
+  background-image: url(images/tree/drop-over.gif);
+.x-tree-drop-ok-below .x-dd-drop-icon{
+  background-image: url(images/tree/drop-under.gif);
+.x-tree-drop-ok-between .x-dd-drop-icon{
+  background-image: url(images/tree/drop-between.gif);
+}.x-date-picker {
+    border-color: #1b376c;
+	background-image: url(images/shared/hd-sprite.gif);
+	color:#fff;
+	font:bold 11px "sans serif", tahoma, verdana, helvetica;
+.x-date-middle .x-btn .x-btn-text {
+    color:#fff;
+    background-image:url(images/toolbar/btn-arrow-light.gif);
+.x-date-right a {
+    background-image: url(images/shared/right-btn.gif);
+.x-date-left a{
+	background-image: url(images/shared/left-btn.gif);
+.x-date-inner th {
+    background-color:#dfecfb;
+    background-image:url(images/shared/glass-bg.gif);
+	border-bottom-color:#a3bad9;
+    font:normal 10px arial, helvetica,tahoma,sans-serif;
+	color:#233d6d;
+.x-date-inner td {
+.x-date-inner a {
+    color:#000;
+	color:#000;
+	border-color:darkred;
+.x-date-inner .x-date-selected span{
+    font-weight:bold;
+	color:#aaa;
+.x-date-bottom {
+    border-top-color:#a3bad9;
+    color:#000;
+    background-color:#ddecfe;
+	background-color:#eee;
+	color:#bbb;
+.x-date-mmenu{
+    background-color:#eee !important;
+.x-date-mmenu .x-menu-item {
+	font-size:10px;
+	color:#000;
+.x-date-mp {
+.x-date-mp td {
+	background-color:#083772;
+	color:#fff;
+	border-color: #3366cc #000055 #000055 #3366cc;
+.x-date-mp-btns {
+    background-color: #dfecfb;
+	background-image: url(images/shared/glass-bg.gif);
+	border-top-color: #c5d2df;
+	color:#15428b;
+	color:#15428b;
+	background-color: #ddecfe;
+    background-image:url(images/panel/tool-sprites.gif);
+td.x-date-mp-sep {
+   border-right-color:#c5d2df;
+}.x-tip .x-tip-close{
+	background-image: url(images/qtip/close.gif);
+.x-tip .x-tip-tc, .x-tip .x-tip-tl, .x-tip .x-tip-tr, .x-tip .x-tip-bc, .x-tip .x-tip-bl, .x-tip .x-tip-br, .x-tip .x-tip-ml, .x-tip .x-tip-mr {
+	background-image: url(images/qtip/tip-sprite.gif);
+.x-tip .x-tip-mc {
+    font: normal 11px tahoma,arial,helvetica,sans-serif;
+.x-tip .x-tip-ml {
+    font: bold 11px tahoma,arial,helvetica,sans-serif;
+    color:#444;
+    color:#444;
+.x-form-invalid-tip .x-tip-tc, .x-form-invalid-tip .x-tip-tl, .x-form-invalid-tip .x-tip-tr, .x-form-invalid-tip .x-tip-bc,
+.x-form-invalid-tip .x-tip-bl, .x-form-invalid-tip .x-tip-br, .x-form-invalid-tip .x-tip-ml, .x-form-invalid-tip .x-tip-mr
+	background-image: url(images/form/error-tip-corners.gif);
+.x-tip-anchor {
+    background-image:url(images/qtip/tip-anchor-sprite.gif);
+}.x-menu {
+    background-color:#f0f0f0;
+	background-image:url(images/menu/menu.gif);
+.x-menu-floating{
+    border-color:#718bb7;
+.x-menu-nosep {
+	background-image:none;
+.x-menu-list-item{
+	font:normal 11px arial,tahoma,sans-serif;
+	background-image:url(images/menu/menu-parent.gif);
+.x-menu-sep {
+    background-color:#e0e0e0;
+	border-bottom-color:#fff;
+a.x-menu-item {
+	color:#222;
+    background-image: url(images/menu/item-over.gif);
+	background-color: #dbecf4;
+.x-menu-item-checked .x-menu-item-icon{
+    background-image:url(images/menu/group-checked.gif);
+.x-menu-plain {
+	background-color:#f0f0f0 !important;
+.x-date-menu, .x-color-menu{
+    border-color:#a3bae9 !important;
+    background-color:#def8f6;
+.x-menu-scroller-top {
+    background-image:url(images/layout/mini-top.gif);
+.x-menu-scroller-bottom {
+    background-image:url(images/layout/mini-bottom.gif);
+.x-box-tl {
+	background-image: url(images/box/corners.gif);
+.x-box-tc {
+	background-image: url(images/box/tb.gif);
+.x-box-tr {
+.x-box-ml {
+	background-image: url(images/box/l.gif);
+.x-box-mc {
+	font-family: "Myriad Pro","Myriad Web","Tahoma","Helvetica","Arial",sans-serif;
+	color: #393939;
+	font-size: 12px;
+.x-box-mc h3 {
+	font-size: 14px;
+	font-weight: bold;
+.x-box-mr {
+	background-image: url(images/box/r.gif);
+.x-box-bl {
+.x-box-bc {
+.x-box-br {
+.x-box-blue .x-box-bl, .x-box-blue .x-box-br, .x-box-blue .x-box-tl, .x-box-blue .x-box-tr {
+	background-image: url(images/box/corners-blue.gif);
+.x-box-blue .x-box-bc, .x-box-blue .x-box-mc, .x-box-blue .x-box-tc {
+	background-image: url(images/box/tb-blue.gif);
+.x-box-blue .x-box-mc {
+	background-color: #c3daf9;
+.x-box-blue .x-box-mc h3 {
+	color: #17385b;
+.x-box-blue .x-box-ml {
+	background-image: url(images/box/l-blue.gif);
+.x-box-blue .x-box-mr {
+	background-image: url(images/box/r-blue.gif);
+}.x-combo-list {
+    border-color:#98c0f4;
+.x-combo-list-hd {
+    color:#15428b;
+    background-image: url(images/layout/panel-title-light-bg.gif);
+    border-bottom-color:#98c0f4;
+    background-color:acf6b1;
+    border-top-color:#98c0f4;
+.x-combo-list-small {
+}.x-panel {
+    border-color: 99e8a1;
+.x-panel-header {
+    color:#15428b;
+	font-weight:bold;
+    font-size: 11px;
+    font-family: tahoma,arial,verdana,sans-serif;
+    background-image: url(images/panel/white-top-bottom.gif);
+.x-panel-body {
+    border-top-color:99e8a1;
+    color:#15428b;
+	font:bold 11px tahoma,arial,verdana,sans-serif;
+.x-panel-tc {
+	background-image: url(images/panel/top-bottom.gif);
+.x-panel-tl, .x-panel-tr, .x-panel-bl,  .x-panel-br{
+	background-image: url(images/panel/corners-sprite.gif);
+.x-panel-bc {
+.x-panel-mc {
+.x-panel-ml {
+    background-image:url(images/panel/left-right.gif);
+.x-panel-mr {
+	background-image: url(images/panel/left-right.gif);
+.x-tool {
+.x-panel-ghost {
+    background-color:#cbddf3;
+.x-window-proxy {
+    background-color:#c7dffc;
+    color:#15428b;
+.x-window-tc {
+	background-image: url(images/window/top-bottom.png);
+.x-window-tl {
+	background-image: url(images/window/left-corners.png);
+.x-window-tr {
+	background-image: url(images/window/right-corners.png);
+.x-window-bc {
+.x-window-bl {
+.x-window-br {
+.x-window-mc {
+.x-window-ml {
+	background-image: url(images/window/left-right.png);
+.x-window-mr {
+    border-bottom-color:#84a0c4;
+.x-dlg-mask{
+   background-color:#ccc;
+    background-color: #ccd9e8;
+    border-color: #a3bae9 acf6b1 acf6b1 #a3bae9;
+    border-color: acf6b1 #a3bae9 #a3bae9 acf6b1;
+body.x-body-masked .x-window-plain .x-window-mc {
+}.x-panel-noborder .x-panel-header-noborder {
+.x-accordion-hd {
+	color:#222;
+    background-image: url(images/panel/light-hd.gif);
+    background-color:#d2e0f2;
+    background-color:#d9e8fb;
+    background-image:url(images/layout/mini-left.gif);
+    background-image:url(images/layout/mini-right.gif);
+    background-color:#e0e8f3;
+    background-image:url(images/qtip/bg.gif);
+.x-progress-bar {
+    background-color:#9cbfee;
+    background-image:url(images/progress/progress-bg.gif);
+    border-top-color:#d1e4fd;
+    border-bottom-color:#7fa9e4;
+    border-right-color:#7fa9e4;
+.x-progress-text {
+    font-size:11px;
+    font-weight:bold;
+    color:#fff;
+    color:#396095;
+}.x-list-header{
+    border-left-color:#ddd;
+.x-list-over {
+.x-list-selected {
+.x-list-resizer {
+    border-left-color:#555;
+    border-right-color:#555;
+.x-list-header-inner em.sort-asc, .x-list-header-inner em.sort-desc {
+    background-image:url(images/grid/sort-hd.gif);
+}.x-slider-horz, .x-slider-horz .x-slider-end, .x-slider-horz .x-slider-inner {
+    background-image:url(images/slider/slider-bg.png);
+    background-image:url(images/slider/slider-thumb.png);
+.x-slider-vert, .x-slider-vert .x-slider-end, .x-slider-vert .x-slider-inner {
+    background-image:url(images/slider/slider-v-bg.png);
+    background-image:url(images/slider/slider-v-thumb.png);
+}.x-window-dlg .ext-mb-text,
+.x-window-dlg .x-window-header-text {
+    font-size:12px;
+    font:normal 12px tahoma,arial,helvetica,sans-serif;
+.x-window-dlg .ext-mb-info {
+    background-image:url(images/window/icon-info.gif);
+.x-window-dlg .ext-mb-warning {
+    background-image:url(images/window/icon-warning.gif);
+.x-window-dlg .ext-mb-question {
+    background-image:url(images/window/icon-question.gif);
+.x-window-dlg .ext-mb-error {
+    background-image:url(images/window/icon-error.gif);
\ No newline at end of file
Added: grass-web/trunk/user_map/lib/grass_theme/images/box/corners-blue.gif
(Binary files differ)
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/box/corners-blue.gif
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: grass-web/trunk/user_map/lib/grass_theme/images/box/corners.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/box/corners.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/box/l-blue.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/box/l-blue.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/box/l.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/box/l.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/box/r-blue.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/box/r-blue.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/box/r.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/box/r.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/box/tb-blue.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/box/tb-blue.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/box/tb.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/box/tb.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/button/arrow.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/button/arrow.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/button/btn.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/button/btn.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/button/group-cs.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/button/group-cs.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/button/group-lr.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/button/group-lr.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/button/group-tb.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/button/group-tb.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/button/s-arrow-b-noline.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/button/s-arrow-b-noline.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/button/s-arrow-b.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/button/s-arrow-b.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/button/s-arrow-bo.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/button/s-arrow-bo.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/button/s-arrow-noline.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/button/s-arrow-noline.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/button/s-arrow-o.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/button/s-arrow-o.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/button/s-arrow.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/button/s-arrow.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/dd/drop-add.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/dd/drop-add.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/dd/drop-no.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/dd/drop-no.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/dd/drop-yes.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/dd/drop-yes.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/editor/tb-sprite.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/editor/tb-sprite.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/form/checkbox.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/form/checkbox.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/form/clear-trigger.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/form/clear-trigger.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/form/clear-trigger.psd
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/form/clear-trigger.psd
Added: grass-web/trunk/user_map/lib/grass_theme/images/form/date-trigger.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/form/date-trigger.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/form/date-trigger.psd
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/form/date-trigger.psd
Added: grass-web/trunk/user_map/lib/grass_theme/images/form/error-tip-corners.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/form/error-tip-corners.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/form/exclamation.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/form/exclamation.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/form/radio.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/form/radio.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/form/search-trigger.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/form/search-trigger.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/form/search-trigger.psd
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/form/search-trigger.psd
Added: grass-web/trunk/user_map/lib/grass_theme/images/form/text-bg.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/form/text-bg.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/form/trigger-square.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/form/trigger-square.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/form/trigger-square.psd
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/form/trigger-square.psd
Added: grass-web/trunk/user_map/lib/grass_theme/images/form/trigger-tpl.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/form/trigger-tpl.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/form/trigger.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/form/trigger.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/form/trigger.psd
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/form/trigger.psd
Added: grass-web/trunk/user_map/lib/grass_theme/images/gradient-bg.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/gradient-bg.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/arrow-left-white.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/arrow-left-white.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/arrow-right-white.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/arrow-right-white.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/col-move-bottom.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/col-move-bottom.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/col-move-top.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/col-move-top.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/columns.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/columns.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/dirty.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/dirty.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/done.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/done.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/drop-no.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/drop-no.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/drop-yes.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/drop-yes.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/footer-bg.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/footer-bg.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/grid-blue-hd.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/grid-blue-hd.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/grid-blue-split.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/grid-blue-split.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/grid-hrow.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/grid-hrow.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/grid-loading.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/grid-loading.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/grid-split.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/grid-split.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/grid-vista-hd.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/grid-vista-hd.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/grid3-hd-btn.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/grid3-hd-btn.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/grid3-hrow-over.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/grid3-hrow-over.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/grid3-hrow.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/grid3-hrow.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/grid3-rowheader.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/grid3-rowheader.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/grid3-special-col-bg.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/grid3-special-col-bg.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/grid3-special-col-sel-bg.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/grid3-special-col-sel-bg.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/group-by.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/group-by.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/group-collapse.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/group-collapse.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/group-expand-sprite.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/group-expand-sprite.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/group-expand.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/group-expand.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/hd-pop.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/hd-pop.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/hmenu-asc.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/hmenu-asc.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/hmenu-desc.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/hmenu-desc.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/hmenu-lock.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/hmenu-lock.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/hmenu-lock.png
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/hmenu-lock.png
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/hmenu-unlock.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/hmenu-unlock.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/hmenu-unlock.png
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/hmenu-unlock.png
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/invalid_line.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/invalid_line.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/loading.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/loading.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/mso-hd.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/mso-hd.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/nowait.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/nowait.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/page-first-disabled.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/page-first-disabled.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/page-first.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/page-first.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/page-last-disabled.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/page-last-disabled.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/page-last.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/page-last.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/page-next-disabled.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/page-next-disabled.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/page-next.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/page-next.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/page-prev-disabled.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/page-prev-disabled.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/page-prev.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/page-prev.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/pick-button.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/pick-button.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/refresh-disabled.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/refresh-disabled.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/refresh.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/refresh.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/row-check-sprite.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/row-check-sprite.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/row-expand-sprite.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/row-expand-sprite.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/row-over.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/row-over.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/row-sel.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/row-sel.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/sort-hd.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/sort-hd.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/sort_asc.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/sort_asc.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/sort_desc.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/sort_desc.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/grid/wait.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/grid/wait.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/layout/collapse.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/layout/collapse.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/layout/expand.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/layout/expand.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/layout/gradient-bg.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/layout/gradient-bg.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/layout/mini-bottom.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/layout/mini-bottom.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/layout/mini-left.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/layout/mini-left.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/layout/mini-right.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/layout/mini-right.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/layout/mini-top.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/layout/mini-top.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/layout/ns-collapse.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/layout/ns-collapse.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/layout/ns-expand.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/layout/ns-expand.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/layout/panel-close.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/layout/panel-close.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/layout/panel-title-bg.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/layout/panel-title-bg.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/layout/panel-title-light-bg.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/layout/panel-title-light-bg.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/layout/stick.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/layout/stick.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/layout/stuck.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/layout/stuck.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/layout/tab-close-on.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/layout/tab-close-on.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/layout/tab-close.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/layout/tab-close.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/menu/checked.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/menu/checked.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/menu/group-checked.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/menu/group-checked.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/menu/item-over.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/menu/item-over.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/menu/menu-parent.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/menu/menu-parent.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/menu/menu.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/menu/menu.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/menu/unchecked.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/menu/unchecked.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/panel/corners-sprite.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/panel/corners-sprite.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/panel/left-right.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/panel/left-right.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/panel/light-hd.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/panel/light-hd.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/panel/tool-sprite-tpl.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/panel/tool-sprite-tpl.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/panel/tool-sprites.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/panel/tool-sprites.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/panel/tools-sprites-trans.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/panel/tools-sprites-trans.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/panel/top-bottom.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/panel/top-bottom.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/panel/top-bottom.png
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/panel/top-bottom.png
Added: grass-web/trunk/user_map/lib/grass_theme/images/panel/white-corners-sprite.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/panel/white-corners-sprite.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/panel/white-left-right.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/panel/white-left-right.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/panel/white-top-bottom.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/panel/white-top-bottom.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/progress/progress-bg.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/progress/progress-bg.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/qtip/bg.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/qtip/bg.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/qtip/close.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/qtip/close.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/qtip/tip-anchor-sprite.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/qtip/tip-anchor-sprite.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/qtip/tip-sprite.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/qtip/tip-sprite.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/s.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/s.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/shadow-c.png
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/shadow-c.png
Added: grass-web/trunk/user_map/lib/grass_theme/images/shadow-lr.png
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/shadow-lr.png
Added: grass-web/trunk/user_map/lib/grass_theme/images/shadow.png
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/shadow.png
Added: grass-web/trunk/user_map/lib/grass_theme/images/shared/blue-loading.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/shared/blue-loading.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/shared/calendar.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/shared/calendar.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/shared/glass-bg.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/shared/glass-bg.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/shared/hd-sprite.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/shared/hd-sprite.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/shared/large-loading.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/shared/large-loading.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/shared/left-btn.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/shared/left-btn.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/shared/loading-balls.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/shared/loading-balls.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/shared/right-btn.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/shared/right-btn.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/shared/warning.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/shared/warning.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/sizer/e-handle-dark.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/sizer/e-handle-dark.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/sizer/e-handle.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/sizer/e-handle.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/sizer/ne-handle-dark.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/sizer/ne-handle-dark.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/sizer/ne-handle.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/sizer/ne-handle.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/sizer/nw-handle-dark.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/sizer/nw-handle-dark.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/sizer/nw-handle.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/sizer/nw-handle.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/sizer/s-handle-dark.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/sizer/s-handle-dark.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/sizer/s-handle.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/sizer/s-handle.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/sizer/se-handle-dark.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/sizer/se-handle-dark.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/sizer/se-handle.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/sizer/se-handle.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/sizer/square.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/sizer/square.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/sizer/sw-handle-dark.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/sizer/sw-handle-dark.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/sizer/sw-handle.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/sizer/sw-handle.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/slider/slider-bg.png
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/slider/slider-bg.png
Added: grass-web/trunk/user_map/lib/grass_theme/images/slider/slider-thumb.png
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/slider/slider-thumb.png
Added: grass-web/trunk/user_map/lib/grass_theme/images/slider/slider-v-bg.png
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/slider/slider-v-bg.png
Added: grass-web/trunk/user_map/lib/grass_theme/images/slider/slider-v-thumb.png
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/slider/slider-v-thumb.png
Added: grass-web/trunk/user_map/lib/grass_theme/images/tabs/scroll-left.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tabs/scroll-left.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tabs/scroll-right.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tabs/scroll-right.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tabs/scroller-bg.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tabs/scroller-bg.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tabs/tab-btm-inactive-left-bg.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tabs/tab-btm-inactive-left-bg.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tabs/tab-btm-inactive-right-bg.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tabs/tab-btm-inactive-right-bg.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tabs/tab-btm-left-bg.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tabs/tab-btm-left-bg.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tabs/tab-btm-over-left-bg.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tabs/tab-btm-over-left-bg.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tabs/tab-btm-over-right-bg.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tabs/tab-btm-over-right-bg.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tabs/tab-btm-right-bg.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tabs/tab-btm-right-bg.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tabs/tab-close.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tabs/tab-close.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tabs/tab-strip-bg.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tabs/tab-strip-bg.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tabs/tab-strip-bg.png
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tabs/tab-strip-bg.png
Added: grass-web/trunk/user_map/lib/grass_theme/images/tabs/tab-strip-btm-bg.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tabs/tab-strip-btm-bg.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tabs/tabs-sprite.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tabs/tabs-sprite.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/toolbar/bg.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/toolbar/bg.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/toolbar/btn-arrow-light.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/toolbar/btn-arrow-light.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/toolbar/btn-arrow.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/toolbar/btn-arrow.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/toolbar/btn-over-bg.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/toolbar/btn-over-bg.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/toolbar/gray-bg.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/toolbar/gray-bg.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/toolbar/more.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/toolbar/more.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/toolbar/tb-bg.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/toolbar/tb-bg.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/toolbar/tb-btn-sprite.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/toolbar/tb-btn-sprite.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/toolbar/tb-xl-btn-sprite.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/toolbar/tb-xl-btn-sprite.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/toolbar/tb-xl-sep.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/toolbar/tb-xl-sep.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tree/arrows.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tree/arrows.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tree/drop-add.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tree/drop-add.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tree/drop-between.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tree/drop-between.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tree/drop-no.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tree/drop-no.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tree/drop-over.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tree/drop-over.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tree/drop-under.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tree/drop-under.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tree/drop-yes.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tree/drop-yes.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow-end-minus-nl.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow-end-minus-nl.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow-end-minus.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow-end-minus.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow-end-plus-nl.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow-end-plus-nl.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow-end-plus.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow-end-plus.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow-end.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow-end.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow-line.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow-line.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow-minus-nl.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow-minus-nl.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow-minus.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow-minus.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow-plus-nl.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow-plus-nl.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow-plus.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow-plus.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tree/elbow.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tree/folder-open.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tree/folder-open.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tree/folder.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tree/folder.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tree/leaf.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tree/leaf.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tree/loading.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tree/loading.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/tree/s.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/tree/s.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/window/icon-error.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/window/icon-error.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/window/icon-info.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/window/icon-info.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/window/icon-question.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/window/icon-question.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/window/icon-warning.gif
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/window/icon-warning.gif
Added: grass-web/trunk/user_map/lib/grass_theme/images/window/left-corners.png
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/window/left-corners.png
Added: grass-web/trunk/user_map/lib/grass_theme/images/window/left-corners.psd
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/window/left-corners.psd
Added: grass-web/trunk/user_map/lib/grass_theme/images/window/left-right.png
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/window/left-right.png
Added: grass-web/trunk/user_map/lib/grass_theme/images/window/left-right.psd
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/window/left-right.psd
Added: grass-web/trunk/user_map/lib/grass_theme/images/window/right-corners.png
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/window/right-corners.png
Added: grass-web/trunk/user_map/lib/grass_theme/images/window/right-corners.psd
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/window/right-corners.psd
Added: grass-web/trunk/user_map/lib/grass_theme/images/window/top-bottom.png
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/window/top-bottom.png
Added: grass-web/trunk/user_map/lib/grass_theme/images/window/top-bottom.psd
Property changes on: grass-web/trunk/user_map/lib/grass_theme/images/window/top-bottom.psd
Added: grass-web/trunk/user_map/lib/img/blank.gif
Property changes on: grass-web/trunk/user_map/lib/img/blank.gif
Added: grass-web/trunk/user_map/lib/img/cloud-popup-relative.png
Property changes on: grass-web/trunk/user_map/lib/img/cloud-popup-relative.png
Added: svn:executable
Added: grass-web/trunk/user_map/lib/img/drag-rectangle-off.png
Property changes on: grass-web/trunk/user_map/lib/img/drag-rectangle-off.png
Added: grass-web/trunk/user_map/lib/img/drag-rectangle-on.png
Property changes on: grass-web/trunk/user_map/lib/img/drag-rectangle-on.png
Added: grass-web/trunk/user_map/lib/img/east-mini.png
Property changes on: grass-web/trunk/user_map/lib/img/east-mini.png
Added: grass-web/trunk/user_map/lib/img/layer-switcher-maximize.png
Property changes on: grass-web/trunk/user_map/lib/img/layer-switcher-maximize.png
Added: grass-web/trunk/user_map/lib/img/layer-switcher-minimize.png
Property changes on: grass-web/trunk/user_map/lib/img/layer-switcher-minimize.png
Added: grass-web/trunk/user_map/lib/img/marker-blue.png
Property changes on: grass-web/trunk/user_map/lib/img/marker-blue.png
Added: grass-web/trunk/user_map/lib/img/marker-gold.png
Property changes on: grass-web/trunk/user_map/lib/img/marker-gold.png
Added: grass-web/trunk/user_map/lib/img/marker-green.png
Property changes on: grass-web/trunk/user_map/lib/img/marker-green.png
Added: grass-web/trunk/user_map/lib/img/marker.png
Property changes on: grass-web/trunk/user_map/lib/img/marker.png
Added: grass-web/trunk/user_map/lib/img/measuring-stick-off.png
Property changes on: grass-web/trunk/user_map/lib/img/measuring-stick-off.png
Added: grass-web/trunk/user_map/lib/img/measuring-stick-on.png
Property changes on: grass-web/trunk/user_map/lib/img/measuring-stick-on.png
Added: grass-web/trunk/user_map/lib/img/north-mini.png
Property changes on: grass-web/trunk/user_map/lib/img/north-mini.png
Added: grass-web/trunk/user_map/lib/img/panning-hand-off.png
Property changes on: grass-web/trunk/user_map/lib/img/panning-hand-off.png
Added: grass-web/trunk/user_map/lib/img/panning-hand-on.png
Property changes on: grass-web/trunk/user_map/lib/img/panning-hand-on.png
Added: grass-web/trunk/user_map/lib/img/slider.png
Property changes on: grass-web/trunk/user_map/lib/img/slider.png
Added: grass-web/trunk/user_map/lib/img/south-mini.png
Property changes on: grass-web/trunk/user_map/lib/img/south-mini.png
Added: grass-web/trunk/user_map/lib/img/west-mini.png
Property changes on: grass-web/trunk/user_map/lib/img/west-mini.png
Added: grass-web/trunk/user_map/lib/img/zoom-minus-mini.png
Property changes on: grass-web/trunk/user_map/lib/img/zoom-minus-mini.png
Added: grass-web/trunk/user_map/lib/img/zoom-plus-mini.png
Property changes on: grass-web/trunk/user_map/lib/img/zoom-plus-mini.png
Added: grass-web/trunk/user_map/lib/img/zoom-world-mini.png
Property changes on: grass-web/trunk/user_map/lib/img/zoom-world-mini.png
Added: grass-web/trunk/user_map/lib/img/zoombar.png
Property changes on: grass-web/trunk/user_map/lib/img/zoombar.png
Added: grass-web/trunk/user_map/lib/theme/default/framedCloud.css
Added: grass-web/trunk/user_map/lib/theme/default/google.css
--- grass-web/trunk/user_map/lib/theme/default/google.css	                        (rev 0)
+++ grass-web/trunk/user_map/lib/theme/default/google.css	2012-04-17 13:42:26 UTC (rev 51456)
@@ -0,0 +1,17 @@
+.olLayerGoogleCopyright {
+    right: 3px;
+    bottom: 2px;
+    left: auto;
+.olLayerGoogleV3.olLayerGoogleCopyright {
+    bottom: 0px;
+    right: 0px !important;
+.olLayerGooglePoweredBy {
+    left: 2px;
+    bottom: 2px;
+.olLayerGoogleV3.olLayerGooglePoweredBy {
+    bottom: 0px !important;
Added: grass-web/trunk/user_map/lib/theme/default/google.tidy.css
--- grass-web/trunk/user_map/lib/theme/default/google.tidy.css	                        (rev 0)
+++ grass-web/trunk/user_map/lib/theme/default/google.tidy.css	2012-04-17 13:42:26 UTC (rev 51456)
@@ -0,0 +1 @@
+.olLayerGoogleCopyright{right:3px;bottom:2px;left:auto;}.olLayerGoogleV3.olLayerGoogleCopyright{bottom:0;right:0!important;}.olLayerGooglePoweredBy{left:2px;bottom:2px;}.olLayerGoogleV3.olLayerGooglePoweredBy{bottom:0!important;}
Added: grass-web/trunk/user_map/lib/theme/default/ie6-style.css
--- grass-web/trunk/user_map/lib/theme/default/ie6-style.css	                        (rev 0)
+++ grass-web/trunk/user_map/lib/theme/default/ie6-style.css	2012-04-17 13:42:26 UTC (rev 51456)
@@ -0,0 +1,10 @@
+.olControlZoomPanel div {
+    background-image: url(img/zoom-panel-NOALPHA.png);
+.olControlPanPanel div {
+    background-image: url(img/pan-panel-NOALPHA.png);
+.olControlEditingToolbar {
+    width: 200px;
Added: grass-web/trunk/user_map/lib/theme/default/ie6-style.tidy.css
--- grass-web/trunk/user_map/lib/theme/default/ie6-style.tidy.css	                        (rev 0)
+++ grass-web/trunk/user_map/lib/theme/default/ie6-style.tidy.css	2012-04-17 13:42:26 UTC (rev 51456)
@@ -0,0 +1 @@
+.olControlZoomPanel div{background-image:url(img/zoom-panel-NOALPHA.png);}.olControlPanPanel div{background-image:url(img/pan-panel-NOALPHA.png);}.olControlEditingToolbar{width:200px;}
Added: grass-web/trunk/user_map/lib/theme/default/img/add_point_off.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/add_point_off.png
Added: grass-web/trunk/user_map/lib/theme/default/img/add_point_on.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/add_point_on.png
Added: grass-web/trunk/user_map/lib/theme/default/img/blank.gif
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/blank.gif
Added: grass-web/trunk/user_map/lib/theme/default/img/close.gif
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/close.gif
Added: grass-web/trunk/user_map/lib/theme/default/img/drag-rectangle-off.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/drag-rectangle-off.png
Added: grass-web/trunk/user_map/lib/theme/default/img/drag-rectangle-on.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/drag-rectangle-on.png
Added: grass-web/trunk/user_map/lib/theme/default/img/draw_line_off.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/draw_line_off.png
Added: grass-web/trunk/user_map/lib/theme/default/img/draw_line_on.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/draw_line_on.png
Added: grass-web/trunk/user_map/lib/theme/default/img/draw_point_off.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/draw_point_off.png
Added: grass-web/trunk/user_map/lib/theme/default/img/draw_point_on.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/draw_point_on.png
Added: grass-web/trunk/user_map/lib/theme/default/img/draw_polygon_off.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/draw_polygon_off.png
Added: grass-web/trunk/user_map/lib/theme/default/img/draw_polygon_on.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/draw_polygon_on.png
Added: grass-web/trunk/user_map/lib/theme/default/img/editing_tool_bar.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/editing_tool_bar.png
Added: grass-web/trunk/user_map/lib/theme/default/img/move_feature_off.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/move_feature_off.png
Added: grass-web/trunk/user_map/lib/theme/default/img/move_feature_on.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/move_feature_on.png
Added: grass-web/trunk/user_map/lib/theme/default/img/navigation_history.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/navigation_history.png
Added: grass-web/trunk/user_map/lib/theme/default/img/overview_replacement.gif
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/overview_replacement.gif
Added: grass-web/trunk/user_map/lib/theme/default/img/pan-panel-NOALPHA.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/pan-panel-NOALPHA.png
Added: grass-web/trunk/user_map/lib/theme/default/img/pan-panel.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/pan-panel.png
Added: grass-web/trunk/user_map/lib/theme/default/img/pan_off.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/pan_off.png
Added: grass-web/trunk/user_map/lib/theme/default/img/pan_on.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/pan_on.png
Added: grass-web/trunk/user_map/lib/theme/default/img/panning-hand-off.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/panning-hand-off.png
Added: grass-web/trunk/user_map/lib/theme/default/img/panning-hand-on.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/panning-hand-on.png
Added: grass-web/trunk/user_map/lib/theme/default/img/remove_point_off.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/remove_point_off.png
Added: grass-web/trunk/user_map/lib/theme/default/img/remove_point_on.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/remove_point_on.png
Added: grass-web/trunk/user_map/lib/theme/default/img/ruler.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/ruler.png
Added: grass-web/trunk/user_map/lib/theme/default/img/save_features_off.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/save_features_off.png
Added: grass-web/trunk/user_map/lib/theme/default/img/save_features_on.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/save_features_on.png
Added: grass-web/trunk/user_map/lib/theme/default/img/view_next_off.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/view_next_off.png
Added: grass-web/trunk/user_map/lib/theme/default/img/view_next_on.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/view_next_on.png
Added: grass-web/trunk/user_map/lib/theme/default/img/view_previous_off.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/view_previous_off.png
Added: grass-web/trunk/user_map/lib/theme/default/img/view_previous_on.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/view_previous_on.png
Added: grass-web/trunk/user_map/lib/theme/default/img/zoom-panel-NOALPHA.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/zoom-panel-NOALPHA.png
Added: grass-web/trunk/user_map/lib/theme/default/img/zoom-panel.png
Property changes on: grass-web/trunk/user_map/lib/theme/default/img/zoom-panel.png
Added: grass-web/trunk/user_map/lib/theme/default/style.css
--- grass-web/trunk/user_map/lib/theme/default/style.css	                        (rev 0)
+++ grass-web/trunk/user_map/lib/theme/default/style.css	2012-04-17 13:42:26 UTC (rev 51456)
@@ -0,0 +1,433 @@
+div.olMap {
+    z-index: 0;
+    padding: 0 !important;
+    margin: 0 !important;
+    cursor: default;
+div.olMapViewport {
+    text-align: left;
+div.olLayerDiv {
+   -moz-user-select: none;
+   -khtml-user-select: none;
+    left: 2px;
+    bottom: 2px;
+    right: auto !important;
+    left: 2px;
+    bottom: 15px;
+    bottom: 15px !important;
+.olControlAttribution {
+    font-size: smaller;
+    right: 3px;
+    bottom: 4.5em;
+    position: absolute;
+    display: block;
+.olControlScale {
+    right: 3px;
+    bottom: 3em;
+    display: block;
+.olControlScaleLine {
+   display: block;
+   left: 10px;
+   bottom: 15px;
+   font-size: xx-small;
+.olControlScaleLineBottom {
+   border: solid 2px black;
+   border-bottom: none;
+   margin-top:-2px;
+   text-align: center;
+.olControlScaleLineTop {
+   border-top: none;
+.olControlPermalink {
+    right: 3px;
+    bottom: 1.5em;
+    display: block;
+div.olControlMousePosition {
+    bottom: 0em;
+    right: 3px;
+    display: block;
+    font-family: Arial;
+.olControlOverviewMapContainer {
+    bottom: 0;
+    right: 0;
+.olControlOverviewMapElement {
+    padding: 10px 18px 10px 10px;
+    background-color: #00008B;
+    -moz-border-radius: 1em 0 0 0;
+.olControlOverviewMapMinimizeButton {
+    right: 0;
+    bottom: 80px;
+    cursor: pointer;
+.olControlOverviewMapMaximizeButton {
+    right: 0;
+    bottom: 80px;
+    cursor: pointer;
+.olControlOverviewMapExtentRectangle {
+    overflow: hidden;
+    background-image: url("img/blank.gif");
+    cursor: move;
+    border: 2px dotted red;
+.olControlOverviewMapRectReplacement {
+    overflow: hidden;
+    cursor: move;
+    background-image: url("img/overview_replacement.gif");
+    background-repeat: no-repeat;
+    background-position: center;
+.olLayerGeoRSSDescription {
+    float:left;
+    width:100%;
+    overflow:auto;
+    font-size:1.0em;
+.olLayerGeoRSSClose {
+    float:right;
+    color:gray;
+    font-size:1.2em;
+    margin-right:6px;
+    font-family:sans-serif;
+.olLayerGeoRSSTitle {
+    float:left;font-size:1.2em;
+.olPopupContent {
+    padding:5px;
+    overflow: auto;
+.olControlNavigationHistory {
+   background-image: url("img/navigation_history.png");
+   width:  24px;
+   height: 24px;
+.olControlNavigationHistoryPreviousItemActive {
+  background-position: 0 0;
+.olControlNavigationHistoryPreviousItemInactive {
+   background-position: 0 -24px;
+.olControlNavigationHistoryNextItemActive {
+   background-position: -24px 0;
+.olControlNavigationHistoryNextItemInactive {
+   background-position: -24px -24px;
+div.olControlSaveFeaturesItemActive {
+    background-image: url(img/save_features_on.png);
+    background-position: 0 1px;
+div.olControlSaveFeaturesItemInactive {
+    background-image: url(img/save_features_off.png);
+.olHandlerBoxZoomBox {
+    border: 2px solid red;
+    background-color: white;
+    opacity: 0.50;
+    font-size: 1px;
+    filter: alpha(opacity=50);
+.olHandlerBoxSelectFeature {
+    border: 2px solid blue;
+    opacity: 0.50;
+    font-size: 1px;
+.olControlPanPanel {
+    top: 10px;
+    left: 5px;
+    background-image: url(img/pan-panel.png);
+    height: 18px;
+    width: 18px;
+    cursor: pointer;
+.olControlPanPanel .olControlPanNorthItemInactive {
+    top: 0;
+    left: 9px;
+.olControlPanPanel .olControlPanSouthItemInactive {
+    top: 36px;
+    left: 9px;
+    background-position: 18px 0;
+.olControlPanPanel .olControlPanWestItemInactive {
+    top: 18px;
+    left: 0;
+    background-position: 0 18px;
+.olControlPanPanel .olControlPanEastItemInactive {
+    top: 18px;
+    left: 18px;
+    background-position: 18px 18px;
+.olControlZoomPanel {
+    top: 71px;
+    left: 14px;
+    background-image: url(img/zoom-panel.png);
+    height: 18px;
+    width: 18px;
+    cursor: pointer;
+.olControlZoomPanel .olControlZoomInItemInactive {
+    top: 0;
+    left: 0;
+.olControlZoomPanel .olControlZoomToMaxExtentItemInactive {
+    top: 18px;
+    left: 0;
+    background-position: 0 -18px;
+.olControlZoomPanel .olControlZoomOutItemInactive {
+    top: 36px;
+    left: 0;
+ * When a potential text is bigger than the image it move the image
+ * with some headers (closes #3154)
+.olControlPanZoomBar div {
+    font-size: 1px;
+.olPopupCloseBox {
+  background: url("img/close.gif") no-repeat;
+  cursor: pointer;
+.olFramedCloudPopupContent {
+    padding: 5px;
+    overflow: auto;
+.olControlNoSelect {
+.olImageLoadError {
+    background-color: pink;
+    opacity: 0.5;
+    filter: alpha(opacity=50); /* IE */
+ * Cursor styles
+.olCursorWait {
+    cursor: wait;
+.olDragDown {
+    cursor: move;
+.olDrawBox {
+    cursor: crosshair;
+.olControlDragFeatureOver {
+    cursor: move;
+.olControlDragFeatureActive.olControlDragFeatureOver.olDragDown {
+    cursor: -moz-grabbing;
+ * Layer switcher
+.olControlLayerSwitcher {
+    top: 25px;
+    right: 0;
+    width: 20em;
+    font-family: sans-serif;
+    margin-top: 3px;
+    margin-left: 3px;
+    margin-bottom: 3px;
+    color: white;
+    background-color: transparent;
+.olControlLayerSwitcher .layersDiv {
+    padding-top: 5px;
+    padding-left: 10px;
+    padding-bottom: 5px;
+    padding-right: 75px;
+    background-color: darkblue;
+    width: 100%;
+    height: 100%;
+.olControlLayerSwitcher .layersDiv .baseLbl,
+.olControlLayerSwitcher .layersDiv .dataLbl {
+    margin-top: 3px;
+    margin-left: 3px;
+.olControlLayerSwitcher .layersDiv .baseLayersDiv,
+.olControlLayerSwitcher .layersDiv .dataLayersDiv {
+.olControlLayerSwitcher .maximizeDiv,
+.olControlLayerSwitcher .minimizeDiv {
+    top: 5px;
+    right: 0;
+    cursor: pointer;
+.olBingAttribution {
+    color: #DDD;
+.olBingAttribution.road {
+    color: #333;
+.olGoogleAttribution.hybrid, .olGoogleAttribution.satellite {
+    color: #EEE;
+.olGoogleAttribution {
+    color: #333;
+span.olGoogleAttribution a {
+    color: #77C;
+span.olGoogleAttribution.hybrid a, span.olGoogleAttribution.satellite a {
+    color: #EEE;
+ * Editing and navigation icons.
+ * (using the editing_tool_bar.png sprint image)
+.olControlNavToolbar ,
+    margin: 5px 5px 0 0;
+.olControlNavToolbar div,
+.olControlEditingToolbar div {
+    background-image: url("img/editing_tool_bar.png");
+    margin: 0 0 5px 5px;
+    width: 24px;
+    height: 22px;
+    cursor: pointer
+/* positions */
+    right: 0;
+    top: 0;
+.olControlNavToolbar {
+    top: 295px;
+    left: 9px;
+/* layouts */
+    float: right;
+/* individual controls */
+.olControlNavToolbar .olControlNavigationItemInactive,
+.olControlEditingToolbar .olControlNavigationItemInactive {
+    background-position: -103px -1px;
+.olControlNavToolbar .olControlNavigationItemActive ,
+.olControlEditingToolbar .olControlNavigationItemActive  {
+    background-position: -103px -24px;
+.olControlNavToolbar .olControlZoomBoxItemInactive {
+    background-position: -128px -1px;
+.olControlNavToolbar .olControlZoomBoxItemActive  {
+    background-position: -128px -24px;
+.olControlEditingToolbar .olControlDrawFeaturePointItemInactive {
+    background-position: -77px -1px;
+.olControlEditingToolbar .olControlDrawFeaturePointItemActive {
+    background-position: -77px -24px;
+.olControlEditingToolbar .olControlDrawFeaturePathItemInactive {
+    background-position: -51px -1px;
+.olControlEditingToolbar .olControlDrawFeaturePathItemActive {
+    background-position: -51px -24px;
+.olControlEditingToolbar .olControlDrawFeaturePolygonItemInactive{
+    background-position: -26px -1px;
+.olControlEditingToolbar .olControlDrawFeaturePolygonItemActive {
+    background-position: -26px -24px;
Added: grass-web/trunk/user_map/lib/theme/default/style.tidy.css
--- grass-web/trunk/user_map/lib/theme/default/style.tidy.css	                        (rev 0)
+++ grass-web/trunk/user_map/lib/theme/default/style.tidy.css	2012-04-17 13:42:26 UTC (rev 51456)
@@ -0,0 +1 @@
+div.olMap{z-index:0;cursor:default;margin:0!important;padding:0!important;}div.olMapViewport{text-align:left;}.olLayerGoogleCopyright{left:2px;bottom:2px;}.olLayerGoogleV3.olLayerGoogleCopyright{right:auto!important;}.olLayerGooglePoweredBy{left:2px;bottom:15px;}.olLayerGoogleV3.olLayerGooglePoweredBy{bottom:15px!important;}.olControlAttribution{font-size:smaller;right:3px;bottom:4.5em;position:absolute;display:block;}.olControlScale{right:3px;bottom:3em;display:block;position:absolute;font-size:smaller;}.olControlScaleLine{display:block;position:absolute;left:10px;bottom:15px;font-size:xx-small;}.olControlScaleLineBottom{border:solid 2px #000;border-bottom:none;margin-top:-2px;text-align:center;}.olControlScaleLineTop{border:solid 2px #000;border-top:none;text-align:center;}.olControlPermalink{right:3px;bottom:1.5em;display:block;position:absolute;font-size:smaller;}div.olControlMousePosition{bottom:0;right:3px;display:block;position:absolute;font-family:Arial;font-size:sma
 ller;}.olControlOverviewMapContainer{position:absolute;bottom:0;right:0;}.olControlOverviewMapElement{background-color:#00008B;-moz-border-radius:1em 0 0;padding:10px 18px 10px 10px;}.olControlOverviewMapExtentRectangle{overflow:hidden;background-image:url(img/blank.gif);cursor:move;border:2px dotted red;}.olControlOverviewMapRectReplacement{overflow:hidden;cursor:move;background-image:url(img/overview_replacement.gif);background-repeat:no-repeat;background-position:center;}.olLayerGeoRSSDescription{float:left;width:100%;overflow:auto;font-size:1em;}.olLayerGeoRSSClose{float:right;color:gray;font-size:1.2em;margin-right:6px;font-family:sans-serif;}.olLayerGeoRSSTitle{float:left;font-size:1.2em;}.olControlNavigationHistory{background-image:url(img/navigation_history.png);background-repeat:no-repeat;width:24px;height:24px;}.olControlNavigationHistoryPreviousItemActive{background-position:0 0;}.olControlNavigationHistoryPreviousItemInactive{background-position:0 -24px;}.olContr
 olNavigationHistoryNextItemActive{background-position:-24px 0;}.olControlNavigationHistoryNextItemInactive{background-position:-24px -24px;}div.olControlSaveFeaturesItemActive{background-image:url(img/save_features_on.png);background-repeat:no-repeat;background-position:0 1px;}div.olControlSaveFeaturesItemInactive{background-image:url(img/save_features_off.png);background-repeat:no-repeat;background-position:0 1px;}.olHandlerBoxZoomBox{border:2px solid red;position:absolute;background-color:#FFF;opacity:.5;font-size:1px;filter:alpha(opacity=50);}.olHandlerBoxSelectFeature{border:2px solid blue;position:absolute;background-color:#FFF;opacity:.5;font-size:1px;filter:alpha(opacity=50);}.olControlPanPanel{top:10px;left:5px;}.olControlPanPanel div{background-image:url(img/pan-panel.png);height:18px;width:18px;cursor:pointer;position:absolute;}.olControlPanPanel .olControlPanNorthItemInactive{top:0;left:9px;background-position:0 0;}.olControlPanPanel .olControlPanSouthItemInactive
 {top:36px;left:9px;background-position:18px 0;}.olControlPanPanel .olControlPanWestItemInactive{position:absolute;top:18px;left:0;background-position:0 18px;}.olControlPanPanel .olControlPanEastItemInactive{top:18px;left:18px;background-position:18px 18px;}.olControlZoomPanel{top:71px;left:14px;}.olControlZoomPanel div{background-image:url(img/zoom-panel.png);position:absolute;height:18px;width:18px;cursor:pointer;}.olControlZoomPanel .olControlZoomInItemInactive{top:0;left:0;background-position:0 0;}.olControlZoomPanel .olControlZoomToMaxExtentItemInactive{top:18px;left:0;background-position:0 -18px;}.olControlZoomPanel .olControlZoomOutItemInactive{top:36px;left:0;background-position:0 18px;}.olControlPanZoomBar div{font-size:1px;}.olPopupCloseBox{background:url(img/close.gif) no-repeat;cursor:pointer;}.olImageLoadError{background-color:#FFC0CB;opacity:.5;filter:alpha(opacity=50);}.olCursorWait{cursor:wait;}.olDrawBox{cursor:crosshair;}.olControlDragFeatureActive.olControl
 DragFeatureOver.olDragDown{cursor:0;}.olControlLayerSwitcher{position:absolute;top:25px;right:0;width:20em;font-family:sans-serif;font-weight:700;margin-top:3px;margin-left:3px;margin-bottom:3px;font-size:smaller;color:#FFF;background-color:transparent;}.olControlLayerSwitcher .layersDiv{background-color:#00008B;width:100%;height:100%;padding:5px 75px 5px 10px;}.olControlLayerSwitcher .layersDiv .baseLbl,.olControlLayerSwitcher .layersDiv .dataLbl{margin-top:3px;margin-left:3px;margin-bottom:3px;}.olControlLayerSwitcher .layersDiv .baseLayersDiv,.olControlLayerSwitcher .layersDiv .dataLayersDiv{padding-left:10px;}.olControlLayerSwitcher .maximizeDiv,.olControlLayerSwitcher .minimizeDiv{top:5px;right:0;cursor:pointer;}.olBingAttribution{color:#DDD;}span.olGoogleAttribution a{color:#77C;}.olControlNavToolbar,.olControlEditingToolbar{margin:5px 5px 0 0;}.olControlNavToolbar div,.olControlEditingToolbar div{background-image:url(img/editing_tool_bar.png);background-repeat:no-repe
 at;width:24px;height:22px;cursor:pointer;margin:0 0 5px 5px;}.olControlEditingToolbar{right:0;top:0;}.olControlNavToolbar{top:295px;left:9px;}.olControlEditingToolbar div{float:right;}.olControlNavToolbar .olControlNavigationItemInactive,.olControlEditingToolbar .olControlNavigationItemInactive{background-position:-103px -1px;}.olControlNavToolbar .olControlNavigationItemActive,.olControlEditingToolbar .olControlNavigationItemActive{background-position:-103px -24px;}.olControlNavToolbar .olControlZoomBoxItemInactive{background-position:-128px -1px;}.olControlNavToolbar .olControlZoomBoxItemActive{background-position:-128px -24px;}.olControlEditingToolbar .olControlDrawFeaturePointItemInactive{background-position:-77px -1px;}.olControlEditingToolbar .olControlDrawFeaturePointItemActive{background-position:-77px -24px;}.olControlEditingToolbar .olControlDrawFeaturePathItemInactive{background-position:-51px -1px;}.olControlEditingToolbar .olControlDrawFeaturePathItemActive{back
 ground-position:-51px -24px;}.olControlEditingToolbar .olControlDrawFeaturePolygonItemInactive{background-position:-26px -1px;}.olControlEditingToolbar .olControlDrawFeaturePolygonItemActive{background-position:-26px -24px;}div.olLayerDiv,.olControlNoSelect{-khtml-user-select:none;-moz-user-select:none;}.olControlOverviewMapMinimizeButton,.olControlOverviewMapMaximizeButton{bottom:80px;cursor:pointer;right:0;}.olPopupContent,.olFramedCloudPopupContent{overflow:auto;padding:5px;}.olDragDown,.olControlDragFeatureOver{cursor:move;}.olBingAttribution.road,.olGoogleAttribution{color:#333;}.olGoogleAttribution.hybrid,.olGoogleAttribution.satellite,span.olGoogleAttribution.hybrid a,span.olGoogleAttribution.satellite a{color:#EEE;}
\ No newline at end of file
Added: grass-web/trunk/user_map/n_users.php
--- grass-web/trunk/user_map/n_users.php	                        (rev 0)
+++ grass-web/trunk/user_map/n_users.php	2012-04-17 13:42:26 UTC (rev 51456)
@@ -0,0 +1,14 @@
+<?php
+# required for connection
+require_once 'connection.php';
+# load spatialite library
+$grassuserdb->loadExtension('libspatialite.so');
+# return the number of users
+$rs = $grassuserdb->query('SELECT count(id) FROM users;');
+$val = $rs->fetchArray();
+# close connection
+$grassuserdb->close();
+echo "$val[0] number of GRASS GIS users";
Added: grass-web/trunk/user_map/read_spatialite.php
--- grass-web/trunk/user_map/read_spatialite.php	                        (rev 0)
+++ grass-web/trunk/user_map/read_spatialite.php	2012-04-17 13:42:26 UTC (rev 51456)
@@ -0,0 +1,36 @@
+<?php
+# select all the data
+$rs = $grassuserdb->query('SELECT id, name, company, x, y FROM users;');
+# start to create geojson
+$geojson = array(
+                'type'      => 'FeatureCollection',
+                'features'  => array()
+# for each row create a feature into geojson
+while ($row = $rs->fetchArray()) {
+    $lon = floatval(trim($row[3]));
+    $lat = floatval(trim($row[4]));
+    $latlon = array($lon,$lat);
+    $feature = array(
+        "type" => "Feature",
+        "id" => floatval(trim($row[0])),
+        "properties" => array(
+            "name" => trim($row[1]),
+            "company" => trim($row[2])
+        "geometry" => array("type" => "Point", "coordinates" => $latlon)
+    array_push($geojson['features'], $feature);
+# close connection
+# return geojson file
+header('Content-type: application/json',true);
+echo json_encode($geojson);
Added: grass-web/trunk/user_map/user_grass.sqlite
(Binary files differ)
Property changes on: grass-web/trunk/user_map/user_grass.sqlite
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: grass-web/trunk/user_map/user_map.js
--- grass-web/trunk/user_map/user_map.js	                        (rev 0)
+++ grass-web/trunk/user_map/user_map.js	2012-04-17 13:42:26 UTC (rev 51456)
@@ -0,0 +1,355 @@
+var tbarItems;
+Ext.onReady(function() {
+    OpenLayers.ProxyHost = "/cgi-bin/proxy.cgi?url=";
+    Ext.QuickTips.init();
+	//ADD STYLESHEET
+	var filecss=document.createElement("link")
+	filecss.setAttribute("rel", "stylesheet")
+	filecss.setAttribute("type", "text/css")
+	filecss.setAttribute("href", "user_map/lib/grass_theme/ext-all.css")
+	document.getElementsByTagName("head")[0].appendChild(filecss)
+// 	Ext.BLANK_IMAGE_URL = '../mfbase/ext/resources/images/default/s.gif';
+	var map, mapPanel, users, store, popup, options;
+    OpenLayers.ImgPath = "http://js.mapbox.com/theme/dark/";
+	//FUNCTION TO ADD NEW USER
+	OpenLayers.Control.Click = OpenLayers.Class(OpenLayers.Control, {
+	    defaultHandlerOptions: {
+		'single': true,
+		'double': false,
+		'pixelTolerance': 0,
+		'stopSingle': false,
+		'stopDouble': false
+	    initialize: function(options) {
+		this.handlerOptions = OpenLayers.Util.extend(
+		    {}, this.defaultHandlerOptions
+		OpenLayers.Control.prototype.initialize.apply(
+		    this, arguments
+		this.handler = new OpenLayers.Handler.Click(
+		    this, {
+			'click': this.trigger
+		    }, this.handlerOptions
+	    trigger: function(e) {
+		var lonlatMerc = map.getLonLatFromViewPortPx(e.xy);
+		var lonlat = lonlatMerc.transform(map.projection,map.displayProjection);
+		var formm = new Ext.FormPanel({
+		labelWidth:100,
+		frame:true,
+		width:300,
+		height: 98,
+		closable: true,
+		items: [{
+			xtype:'textfield',
+			fieldLabel: 'Your name',
+			name: 'uname',
+			allowBlank:false
+			fieldLabel: 'Institute/Company',
+			name: 'iname',
+			autoScroll: true
+            xtype: 'hidden',
+// 			xtype: 'numberfield',
+			fieldLabel: 'Longitudine',
+			name: 'long',
+			allowBlank: false,
+			maxValue: 180,
+			minValue: -180,
+			value: lonlat.lon
+			xtype: 'hidden',
+			fieldLabel: 'Latitudine',
+			name: 'lat',
+			maxValue: 90,
+			minValue: -90,
+			value: lonlat.lat
+		buttons: [{
+			text:'Send',
+			handler:function(){
+				formm.getForm().submit({
+					method:'POST',
+					waitTitle:'Waiting.....',
+					waitMsg:'data are loading...',
+					url:'./user_map/insert.php',
+					success:function(){
+						Ext.Msg.alert('', 'Data loaded!', winfo.close());
+                        store.load();
+					failure:function(form, action){
+						if(action.failureType == 'server'){
+							obj = Ext.util.JSON.decode(action.response.responseText);
+							Ext.Msg.alert('Something wrong!', obj.errors.reason);
+						} else {
+							Ext.Msg.alert('Warning!', 'Data don\'t upload, try again');
+							formm.getForm().reset();
+			text: 'Reset',
+			handler: function(){
+		var winfo = new Ext.Window({
+			items: formm,
+			frame:true,
+			title:'Insert new user',
+			width:314,
+			height: 130,
+			closable: true
+		winfo.show();
+		//Ext.Msg.alert('Status', "You clicked near " + lonlat.lat + " N, " + lonlat.lon + " E");
+	Ext.onReady(function(){
+		Ext.state.Manager.setProvider(new Ext.state.CookieProvider());
+		//START OPENLAYERS
+		//OpenLayers.ProxyHost = "/cgi-bin/proxy.cgi?url=";
+		options = {theme: null};
+		map = new OpenLayers.Map ("map", {
+			controls:[
+			new OpenLayers.Control.Navigation(),
+			new OpenLayers.Control.PanZoom(),
+			/*new OpenLayers.Control.MousePosition(),
+			new OpenLayers.Control.Attribution(),
+			new OpenLayers.Control.Permalink()*/],
+			numZoomLevels: 19,
+			minZoomLevel: 1,
+			units: 'm',
+			projection: new OpenLayers.Projection("EPSG:900913"),
+			displayProjection: new OpenLayers.Projection("EPSG:4326")//,
+//             maxExtent: new OpenLayers.Bounds(-180, -90, 180, 90).transform(map.projection,map.displayProjection)
+		},{div: $('map')});
+		//FUNCTION TO CHECK THE ZOOM UNDER 1
+		map.events.register('zoomend', this, function (event) {
+		    var x = map.getZoom();
+		    if( x < 2){
+                map.zoomTo(2);
+		//BASE LAYER
+		var mapnik = new OpenLayers.Layer.OSM("Mapnik");
+		map.addLayer(mapnik);
+		map.setBaseLayer(mapnik);
+		//USERS LAYER
+        var users_style = new OpenLayers.Style(OpenLayers.Util.applyDefaults({
+            graphicOpacity: 1,
+            pointRadius: "${scaledSize}",
+            externalGraphic: "user_map/image/grass.png"
+        }, OpenLayers.Feature.Vector.style["default"]), {
+            context: {
+                scaledSize: function() {
+                    //return feature.layer.map.getResolution() * feature.attributes.size;
+                    if ( x == 1 ){
+                        return x*3;
+                    } else if ( x < 3 ){
+                        return x*2;
+                    } else if ( x < 7 ){
+                        return x*1.5;
+                    } else {
+                        return x;
+        var users_styleMap = new OpenLayers.StyleMap({"default": users_style});
+        users = new OpenLayers.Layer.Vector("GRASS users",{projection: map.displayProjection, styleMap: users_styleMap});
+		map.addLayer(users);
+        store = new GeoExt.data.FeatureStore({
+            layer: users,
+            proxy: new GeoExt.data.ProtocolProxy({
+                protocol: new OpenLayers.Protocol.HTTP({
+                    url: "./user_map/read_spatialite.php",
+                    projection: map.displayProjection,
+                    format: new OpenLayers.Format.GeoJSON({
+                        internalProjection: map.projection,
+                        externalProjection: map.displayProjection
+            fields: [
+                {name: 'name', type: 'string'},
+                {name: 'company', type: 'string'}
+            autoLoad: true
+        // define "createPopup" function
+        function createPopupUsers(feature) {
+            popup = new GeoExt.Popup({
+                title: 'GRASS GIS User',
+                feature: feature,
+                autoScroll: true,
+                width:300,
+                map: map,
+                html: 'User: <b>'+feature.attributes.name+'</b><br>Company<b>: '+feature.attributes.company+'</b>',
+                collapsible: true
+            // unselect feature when the popup
+            // is closed
+            popup.on({
+                close: function() {
+                    if(OpenLayers.Util.indexOf(users.selectedFeatures, this.feature) > -1) {
+                        selectControl.unselect(this.feature);
+            popup.show();
+        // create popup on "featureselected"
+        users.events.on({
+            featureselected: function(e) {
+                if(popup) {
+                    popup.close();
+                createPopupUsers(e.feature);
+        selectControl = new OpenLayers.Control.SelectFeature(users)
+        map.addControl(selectControl);
+		//TOOLBAR
+		var adduser=new OpenLayers.Control.Click();
+		tbarItems = [];
+		tbarItems.push(new GeoExt.Action({
+		    map: map,
+            enableToggle: true,
+		    control: new OpenLayers.Control.Navigation(),
+		    tooltip: "Navigate",
+		    toggleGroup: "map",
+		    iconCls: "pan",
+		    pressed: true
+		tbarItems.push(" ");
+		    map: map,
+		    control: new OpenLayers.Control.ZoomToMaxExtent(),
+		    tooltip: "Zoom to max extent",
+		    iconCls: "zoommax",
+		    pressed: false
+		    map: map,
+		    control: new OpenLayers.Control.ZoomBox(),
+		    tooltip: "Zoom in",
+		    iconCls: "zoomin",
+		    pressed: false
+		tbarItems.push("-");
+        tbarItems.push(new Ext.Button({
+            map: map,
+            handler: function(toggled){
+                if (toggled) {
+                    selectControl.activate();
+                } else {
+                    selectControl.deactivate();
+            tooltip: "Query user",
+            iconCls: "infobox",
+            pressed: false
+		    map: map,
+		    control: adduser,
+		    tooltip: "Add new user",
+		    iconCls: "addbox",
+		    pressed: false
+        // THIS DOESN'T WORK, WE WOULD SHOW HOW MANY USERS THERE ARE
+//         tbarItems.push(" ");
+//         tbarItems.push("-");
+//         tbarItems.push(new OpenLayers.Control.Attribution());
+//         tbarItems.push({xtype: 'tbspacer', width: 100});
+//         Ext.Ajax.request({
+//             url: "./user_map/n_users.php",
+//             success: function(result) {
+//                 tbarItems.push(result.responseText);
+//             failure: function(result) {
+//                 tbarItems.push("");
+		//MAIN WINDOW
+		mapPanel = new Ext.Viewport({
+		    title: "GRASS GIS user",
+		    height: 450,
+		    width: 510,
+		    layout: "border",
+            maximizable: true,
+		    tbar: tbarItems,
+		    items: [{
+                renderTo: "mappanel",
+                region: "center",
+                xtype: "gx_mappanel",
+                tbar: tbarItems,
+                map: map
