[GRASS-SVN] r51464 - grass/trunk/lib/temporal/SQL
svn_grass at osgeo.org
Tue Apr 17 16:50:46 EDT 2012
Author: huhabla
Date: 2012-04-17 13:50:45 -0700 (Tue, 17 Apr 2012)
New Revision: 51464
grass/trunk/lib/temporal/SQL/map_tables_template.sql
grass/trunk/lib/temporal/SQL/vector_metadata_table.sql
Index creation for start and end time columns. Using boolean type in vector metadata.
Modified: grass/trunk/lib/temporal/SQL/map_tables_template.sql
--- grass/trunk/lib/temporal/SQL/map_tables_template.sql 2012-04-17 20:15:12 UTC (rev 51463)
+++ grass/trunk/lib/temporal/SQL/map_tables_template.sql 2012-04-17 20:50:45 UTC (rev 51464)
@@ -38,6 +38,8 @@
FOREIGN KEY (id) REFERENCES GRASS_MAP_base (id) ON DELETE CASCADE
+CREATE INDEX GRASS_MAP_relative_time_index ON GRASS_MAP_relative_time (start_time, end_time);
CREATE TABLE GRASS_MAP_absolute_time (
id VARCHAR NOT NULL, -- The id (PFK) is the unique identifier for all tables, it is based on name and mapset (name at mapset) and is used as primary foreign key
start_time TIMESTAMP, -- Start of the valid time, can be NULL if no time information is available
@@ -47,6 +49,8 @@
+CREATE INDEX GRASS_MAP_absolute_time_index ON GRASS_MAP_absolute_time (start_time, end_time);
-- The spatial extent of a raster map
CREATE TABLE GRASS_MAP_spatial_extent (
Modified: grass/trunk/lib/temporal/SQL/vector_metadata_table.sql
--- grass/trunk/lib/temporal/SQL/vector_metadata_table.sql 2012-04-17 20:15:12 UTC (rev 51463)
+++ grass/trunk/lib/temporal/SQL/vector_metadata_table.sql 2012-04-17 20:50:45 UTC (rev 51464)
@@ -12,7 +12,7 @@
CREATE TABLE vector_metadata (
stvds_register VARCHAR, -- The name of the table storing all space-time vector datasets in which this map is registered
- is_3d INTEGER, -- This is 1 if the vector map is 3d and 0 otherwise
+ is_3d BOOLEAN, -- This is 1 if the vector map is 3d and 0 otherwise
points INTEGER, -- The number of points
lines INTEGER, -- The number of lines
boundaries INTEGER, -- The number of boundaries
