[GRASS-SVN] r51466 - grass/trunk/lib/gis
Tue Apr 17 17:34:57 EDT 2012
Author: martinl
Date: 2012-04-17 14:34:57 -0700 (Tue, 17 Apr 2012)
New Revision: 51466
   grass/trunk/lib/gis/error.c
   grass/trunk/lib/gis/parser.c
   grass/trunk/lib/gis/verbose.c
libgis: new verbosity level
        GRASS_VERBOSE=-1 also discards error and warning messages
        doxygen documentation for verbose.c updated
Modified: grass/trunk/lib/gis/error.c
--- grass/trunk/lib/gis/error.c	2012-04-17 21:03:14 UTC (rev 51465)
+++ grass/trunk/lib/gis/error.c	2012-04-17 21:34:57 UTC (rev 51466)
@@ -43,8 +43,8 @@
 /* static int (*error)() = 0; */
 static int (*ext_error) (const char *, int);	/* Roger Bivand 17 June 2000 */
-static int no_warn = 0;
-static int no_sleep = 1;
+static int no_warn  = FALSE;
+static int no_sleep = TRUE;
 static int grass_info_format;
 static char *logfile;
@@ -153,9 +153,11 @@
 	exit(EXIT_FAILURE);
     busy = 1;
-    va_start(ap, msg);
-    vfprint_error(ERR, msg, ap);
-    va_end(ap);
+    if (G_verbose() > -1) {
+        va_start(ap, msg);
+        vfprint_error(ERR, msg, ap);
+        va_end(ap);
     G__call_error_handlers();
@@ -185,7 +187,7 @@
     va_list ap;
-    if (no_warn)
+    if (no_warn || G_verbose() < 0)
 	return;
     va_start(ap, msg);
Modified: grass/trunk/lib/gis/parser.c
--- grass/trunk/lib/gis/parser.c	2012-04-17 21:03:14 UTC (rev 51465)
+++ grass/trunk/lib/gis/parser.c	2012-04-17 21:34:57 UTC (rev 51466)
@@ -554,12 +554,14 @@
 	check_required();
     if (st->n_errors > 0) {
-	if (G_verbose() > G_verbose_min())
-	    G_usage();
-	fprintf(stderr, "\n");
-	for (i = 0; i < st->n_errors; i++) {
-	    fprintf(stderr, "%s: %s\n", _("ERROR"), st->error[i]);
+            if (G_verbose() > G_verbose_min())
+                G_usage();
+            fprintf(stderr, "\n");
+            for (i = 0; i < st->n_errors; i++) {
+                fprintf(stderr, "%s: %s\n", _("ERROR"), st->error[i]);
 	return -1;
@@ -1330,19 +1332,20 @@
 		    if (found) {	/* found */
 			if (!st->overwrite && !over) {
-			    if (G_info_format() != G_INFO_FORMAT_GUI) {
-				fprintf(stderr,
-					_("ERROR: option <%s>: <%s> exists.\n"),
-					opt->key, opt->answers[i]);
-			    else {
-				fprintf(stderr,
-					"GRASS_INFO_ERROR(%d,1): option <%s>: <%s> exists.\n",
-					getpid(), opt->key, opt->answers[i]);
-				fprintf(stderr, "GRASS_INFO_END(%d,1)\n",
-					getpid());
+                                if (G_info_format() != G_INFO_FORMAT_GUI) {
+                                    fprintf(stderr,
+                                            _("ERROR: option <%s>: <%s> exists.\n"),
+                                            opt->key, opt->answers[i]);
+                                else {
+                                    fprintf(stderr,
+                                            "GRASS_INFO_ERROR(%d,1): option <%s>: <%s> exists.\n",
+                                            getpid(), opt->key, opt->answers[i]);
+                                    fprintf(stderr, "GRASS_INFO_END(%d,1)\n",
+                                            getpid());
 			    error = 1;
Modified: grass/trunk/lib/gis/verbose.c
--- grass/trunk/lib/gis/verbose.c	2012-04-17 21:03:14 UTC (rev 51465)
+++ grass/trunk/lib/gis/verbose.c	2012-04-17 21:34:57 UTC (rev 51466)
@@ -1,114 +1,118 @@
- * \file verbose.c
+ * \file lib/gis/verbose.c
- * \brief GIS Library - Functions to check for GRASS_VERBOSE environment variable.
+ * \brief GIS Library - Subroutines to manage verbosity level
+ * (GRASS_VERBOSE environment variable)
- * see also:
+ * See also:
  *  - G_percent()
+ *  - G_important_message()
  *  - G_message()
+ *  - G_verbose_message()
  *  - G_warning()
+ *  - G_fatal_error()
- * (C) 2001-2008 by the GRASS Development Team
+ * (C) 2001-2008, 2012 by the GRASS Development Team
  * This program is free software under the GNU General Public License
  * (>=v2). Read the file COPYING that comes with GRASS for details.
  * \author Jachym Cepicky - jachym.cepicky at gmail.com
- * \date 2006-2008
 #include <stdlib.h>
 #include <grass/config.h>
 #include <grass/gis.h>
-#define MAXLEVEL 3
+#define MAXLEVEL 3 /* verbose */
 #define STDLEVEL 2
-#define MINLEVEL 0
+#define MINLEVEL 0 /* quiet */
-static int initialized;
-static int verbose;	/* current verbosity level */
+static struct state {
+    int initialized;
+    int verbose;       /* current verbosity level */
+} state;
+static struct state *st = &state;
  * \brief Get current verbosity level.
- * Currently, there are 4 levels of verbosity.
+ * Currently, there are 5 levels of verbosity (see return codes)
- * \return 0 - module should print nothing but errors and warnings
- *		(G_fatal_error, G_warning). Triggered by "--q" or "--quiet".
- * \return 1 - module will print progress information (G_percent)
- * \return 2 - module will print all messages (G_message)
- * \return 3 - module will be very verbose. Triggered by "--v" or "--verbose".
+ * \return -1 - nothing will be printed (also errors and warnings will be also discarded)
+ * \return  0 - nothing will be printed except of errors and warnings
+ *              (G_fatal_error(), G_warning()). Triggered by "--q" or "--quiet".
+ * \return  1 - only progress information (G_percent()) and important messages (G_important_message()) will be printed
+ * \return  2 - all messages (G_message() and G_important_message()) will be printed
+ * \return  3 - also verbose messages (G_verbose_message()) will be printed. Triggered by "--v" or "--verbose".
 int G_verbose(void)
-    const char *verstr;		/* string for GRASS_VERBOSE content */
+    const char *verstr;         /* string for GRASS_VERBOSE content */
-    if (G_is_initialized(&initialized))
-	return verbose;
+    if (G_is_initialized(&(st->initialized)))
+        return st->verbose;
     /* verbose not defined -> get it from env. */
     verstr = getenv("GRASS_VERBOSE");
-    verbose = verstr ? atoi(verstr) : STDLEVEL;
+    st->verbose = verstr ? atoi(verstr) : STDLEVEL;
-    G_initialize_done(&initialized);
+    G_initialize_done(&(st->initialized));
-    return verbose;
  * \brief Get max verbosity level.
  * \return max verbosity level
 int G_verbose_max(void)
     return MAXLEVEL;
  * \brief Get standard verbosity level.
  * \return standard verbosity level
 int G_verbose_std(void)
     return STDLEVEL;
  * \brief Get min verbosity level.
  * \return min verbosity level
 int G_verbose_min(void)
     return MINLEVEL;
  * \brief Set verbosity level.
- * \param level: new verbosity level
+ * - -1 - nothing will be printed (also errors and warnings will be also discarded)
+ * -  0 - nothing will be printed except of errors and warnings
+ * -  1 - only progress information (G_percent()) and important messages (G_important_message()) will be printed
+ * -  2 - all messages (G_message() and G_important_message()) will be printed
+ * -  3 - also verbose messages (G_verbose_message()) will be printed. Triggered by "--v" or "--verbose".
- * \return 0 - failed (verbosity level untouched)
- * \return 1 - success
+ * \param level new verbosity level (-1,0,1,2,3)
+ * \return 0 on invalid verbosity level (verbosity level untouched)
+ * \return 1 on success
 int G_set_verbose(int level)
-    if (level >= MINLEVEL && level <= MAXLEVEL) {
-	verbose = level;
-	return 1;
+    if (level == -1 || (level >= MINLEVEL && level <= MAXLEVEL)) {
+        st->verbose = level;
+        return 1;
     return 0;
