[GRASS-SVN] r51490 - grass/trunk/raster/r.watershed/seg
Mon Apr 23 08:44:53 EDT 2012
Author: mmetz
Date: 2012-04-23 05:44:53 -0700 (Mon, 23 Apr 2012)
New Revision: 51490
   grass/trunk/raster/r.watershed/seg/Gwater.h
   grass/trunk/raster/r.watershed/seg/close_maps.c
   grass/trunk/raster/r.watershed/seg/cseg.h
   grass/trunk/raster/r.watershed/seg/do_cum.c
   grass/trunk/raster/r.watershed/seg/dseg_get.c
   grass/trunk/raster/r.watershed/seg/init_vars.c
   grass/trunk/raster/r.watershed/seg/main.c
r.watershed: add TCI, remove edge artefacts for SFD (seg)
Modified: grass/trunk/raster/r.watershed/seg/Gwater.h
--- grass/trunk/raster/r.watershed/seg/Gwater.h	2012-04-23 12:44:35 UTC (rev 51489)
+++ grass/trunk/raster/r.watershed/seg/Gwater.h	2012-04-23 12:44:53 UTC (rev 51490)
@@ -90,7 +90,7 @@
 extern BSEG s_b;
 extern CSEG dis, bas, haf, r_h, dep;
 extern SSEG watalt, aspflag;
-extern DSEG slp, s_l, s_g, l_s, ril;
+extern DSEG tci, slp, s_l, s_g, l_s, ril;
 extern double segs_mb;
 extern char zero, one;
 extern double ril_value, d_zero, d_one;
@@ -106,9 +106,10 @@
 extern const char *this_mapset;
 extern char seg_name[GNAME_MAX], bas_name[GNAME_MAX], haf_name[GNAME_MAX], thr_name[8];
 extern char ls_name[GNAME_MAX], st_name[GNAME_MAX], sl_name[GNAME_MAX], sg_name[GNAME_MAX];
-extern char wat_name[GNAME_MAX], asp_name[GNAME_MAX], arm_name[GNAME_MAX], dis_name[GNAME_MAX];
+extern char wat_name[GNAME_MAX], asp_name[GNAME_MAX], tci_name[GNAME_MAX];
+extern char arm_name[GNAME_MAX], dis_name[GNAME_MAX];
 extern char ele_flag, pit_flag, run_flag, dis_flag, ob_flag;
-extern char wat_flag, asp_flag, arm_flag, ril_flag, dep_flag;
+extern char wat_flag, asp_flag, arm_flag, ril_flag, dep_flag, tci_flag;
 extern char bas_flag, seg_flag, haf_flag, er_flag;
 extern char st_flag, sb_flag, sg_flag, sl_flag, ls_flag;
 extern FILE *fp;
Modified: grass/trunk/raster/r.watershed/seg/close_maps.c
--- grass/trunk/raster/r.watershed/seg/close_maps.c	2012-04-23 12:44:35 UTC (rev 51489)
+++ grass/trunk/raster/r.watershed/seg/close_maps.c	2012-04-23 12:44:53 UTC (rev 51490)
@@ -123,6 +123,85 @@
 	Rast_write_colors(wat_name, this_mapset, &colors);
+    /* TCI */
+    if (tci_flag) {
+	DCELL watvalue;
+	G_message(_("Closing tci map"));
+	sum = sum_sqr = stddev = 0.0;
+	dbuf = Rast_allocate_d_buf();
+	wabuf = G_malloc(ncols * sizeof(WAT_ALT));
+	dseg_flush(&tci);
+	if (!wat_flag)
+	    seg_flush(&watalt);
+	fd = Rast_open_new(tci_name, DCELL_TYPE);
+	for (r = 0; r < nrows; r++) {
+	    G_percent(r, nrows, 1);
+	    Rast_set_d_null_value(dbuf, ncols);	/* reset row to all NULL */
+	    seg_get_row(&watalt, (char *)wabuf, r);
+	    for (c = 0; c < ncols; c++) {
+		dseg_get(&tci, &dvalue, r, c);
+		watvalue = wabuf[c].wat;
+		if (!Rast_is_d_null_value(&watvalue)) {
+		    dbuf[c] = dvalue;
+		    sum += dvalue;
+		    sum_sqr += dvalue * dvalue;
+	    Rast_put_row(fd, dbuf, DCELL_TYPE);
+	G_percent(r, nrows, 1);    /* finish it */
+	Rast_close(fd);
+	G_free(wabuf);
+	G_free(dbuf);
+	dseg_close(&tci);
+	stddev = sqrt((sum_sqr - (sum + sum / do_points)) / (do_points - 1));
+	G_debug(1, "stddev: %f", stddev);
+	/* set nice color rules: yellow, green, cyan, blue, black */
+	/* start with white to get more detail? NULL cells are white by default, may be confusing */
+	lstddev = log(stddev);
+	Rast_read_fp_range(tci_name, this_mapset, &accRange);
+	min = max = 0;
+	Rast_get_fp_range_min_max(&accRange, &min, &max);
+	Rast_init_colors(&colors);
+	clr_min = min - 1;
+	clr_max = min + (max - min) * 0.3;
+	Rast_add_d_color_rule(&clr_min, 255, 255, 0, &clr_max, 255,
+				  255, 0, &colors);
+	clr_min = clr_max;
+	clr_max = min + (max - min) * 0.5;
+	Rast_add_d_color_rule(&clr_min, 255, 255, 0, &clr_max, 0,
+				  255, 0, &colors);
+	clr_max = min + (max - min) * 0.6;
+	Rast_add_d_color_rule(&clr_min, 0, 255, 0, &clr_max, 0,
+				  255, 255, &colors);
+	clr_max = min + (max - min) * 0.7;
+	Rast_add_d_color_rule(&clr_min, 0, 255, 255, &clr_max, 0,
+				  0, 255, &colors);
+	clr_max = max + 1.;
+	Rast_add_d_color_rule(&clr_min, 0, 0, 255, &clr_max, 0, 0,
+				  0, &colors);
+	clr_max = max + 1;
+	Rast_add_d_color_rule(&clr_min, 0, 0, 0, &clr_max, 0, 0,
+				  0, &colors);
+	Rast_write_colors(tci_name, this_mapset, &colors);
     seg_close(&watalt);
     if (asp_flag) {
 	G_message(_("Closing flow direction map"));
Modified: grass/trunk/raster/r.watershed/seg/cseg.h
--- grass/trunk/raster/r.watershed/seg/cseg.h	2012-04-23 12:44:35 UTC (rev 51489)
+++ grass/trunk/raster/r.watershed/seg/cseg.h	2012-04-23 12:44:53 UTC (rev 51490)
@@ -81,6 +81,7 @@
 /* dseg_get.c */
 int dseg_get(DSEG *, double *, GW_LARGE_INT, GW_LARGE_INT);
+int dseg_flush(DSEG *);
 /* dseg_open.c */
 int dseg_open(DSEG *, int, int, int);
Modified: grass/trunk/raster/r.watershed/seg/do_cum.c
--- grass/trunk/raster/r.watershed/seg/do_cum.c	2012-04-23 12:44:35 UTC (rev 51489)
+++ grass/trunk/raster/r.watershed/seg/do_cum.c	2012-04-23 12:44:53 UTC (rev 51490)
@@ -4,10 +4,78 @@
 #include <grass/raster.h>
 #include <grass/glocale.h>
+int get_dist(double *dist_to_nbr, double *contour)
+    int ct_dir, r_nbr, c_nbr;
+    double dx, dy;
+    double ns_res, ew_res;
+    if (G_projection() == PROJECTION_LL) {
+	double ew_dist1, ew_dist2, ew_dist3;
+	double ns_dist1, ns_dist2, ns_dist3;
+	G_begin_distance_calculations();
+	/* EW Dist at North edge */
+	ew_dist1 = G_distance(window.east, window.north,
+	                      window.west, window.north);
+	/* EW Dist at Center */
+	ew_dist2 = G_distance(window.east, (window.north + window.south) / 2.,
+	                      window.west, (window.north + window.south) / 2.);
+	/* EW Dist at South Edge */
+	ew_dist3 = G_distance(window.east, window.south,
+	                      window.west, window.south);
+	/* NS Dist at East edge */
+	ns_dist1 = G_distance(window.east, window.north,
+	                      window.east, window.south);
+	/* NS Dist at Center */
+	ns_dist2 = G_distance((window.west + window.east) / 2., window.north,
+	                      (window.west + window.east) / 2., window.south);
+	/* NS Dist at West edge */
+	ns_dist3 = G_distance(window.west, window.north,
+	ew_res = (ew_dist1 + ew_dist2 + ew_dist3) / (3 * window.cols);
+	ns_res = (ns_dist1 + ns_dist2 + ns_dist3) / (3 * window.rows);
+    else {
+	ns_res = window.ns_res;
+	ew_res = window.ew_res;
+    for (ct_dir = 0; ct_dir < sides; ct_dir++) {
+	/* get r, c (r_nbr, c_nbr) for neighbours */
+	r_nbr = nextdr[ct_dir];
+	c_nbr = nextdc[ct_dir];
+	/* account for rare cases when ns_res != ew_res */
+	dy = ABS(r_nbr) * ns_res;
+	dx = ABS(c_nbr) * ew_res;
+	if (ct_dir < 4)
+	    dist_to_nbr[ct_dir] = dx + dy;
+	else
+	    dist_to_nbr[ct_dir] = sqrt(dx * dx + dy * dy);
+    contour[0] = contour[1] = ew_res;
+    contour[2] = contour[3] = ns_res;
+    if (sides == 8) {
+	contour[4] = contour[5] = contour[6] = contour[7] = (ew_res + ns_res) / 2.;
+    return 1;
+double get_slope_tci(CELL ele, CELL down_ele, double dist)
+    if (down_ele >= ele)
+	return 0.5 / dist;
+    else
+	return (double)(ele - down_ele) / dist;
 int do_cum(void)
     int r, c, dr, dc;
+    int r_nbr, c_nbr, ct_dir, np_side;
     char is_swale;
     DCELL value, valued;
     POINT point;
@@ -17,9 +85,17 @@
     int asp_c[9] = { 0, 1, 0, -1, -1, -1, 0, 1, 1 };
     WAT_ALT wa, wadown;
     ASP_FLAG af, afdown;
+    double *dist_to_nbr, *contour;
+    double tci_val, tci_div;
     G_message(_("SECTION 3: Accumulating Surface Flow with SFD."));
+    /* distances to neighbours, contour lengths */
+    dist_to_nbr = (double *)G_malloc(sides * sizeof(double));
+    contour = (double *)G_malloc(sides * sizeof(double));
+    get_dist(dist_to_nbr, contour);
     if (bas_thres <= 0)
 	threshold = 60;
     else
@@ -41,7 +117,35 @@
 	FLAG_UNSET(af.flag, WORKEDFLAG);
 	if (dr >= 0 && dr < nrows && dc >= 0 && dc < ncols) {
-	    /* TODO: do not distribute flow along edges, this causes artifacts */
+	    np_side = -1;
+	    r_nbr = dr;
+	    c_nbr = dc;
+		r_nbr = r + nextdr[ct_dir];
+		c_nbr = c + nextdc[ct_dir];
+		if (dr == r_nbr && dc == c_nbr)
+		    np_side = ct_dir;
+		/* check that neighbour is within region */
+		if (r_nbr >= 0 && r_nbr < nrows && c_nbr >= 0 &&
+		    c_nbr < ncols) {
+		    seg_get(&aspflag, (char *)&afdown, r_nbr, c_nbr);
+		    if (FLAG_GET(afdown.flag, NULLFLAG))
+			break;
+	    /* do not distribute flow along edges, this causes artifacts */
+	    if (FLAG_GET(af.flag, EDGEFLAG)) {
+		if (FLAG_GET(af.flag, SWALEFLAG) && af.asp > 0) {
+		    af.asp = -1 * drain[r - r_nbr + 1][c - c_nbr + 1];
+		seg_put(&aspflag, (char *)&af, r, c);
+		continue;
 	    seg_get(&watalt, (char *)&wa, r, c);
 	    value = wa.wat;
 	    is_swale = FLAG_GET(af.flag, SWALEFLAG);
@@ -65,6 +169,16 @@
 	    wadown.wat = valued;
 	    seg_put(&watalt, (char *)&wadown, dr, dc);
+	    /* topographic wetness index ln(a / tan(beta)) */
+	    if (tci_flag) {
+		tci_div = contour[np_side] *
+		       get_slope_tci(wa.ele, wadown.ele,
+				     dist_to_nbr[np_side]);
+		tci_val = log(fabs(wa.wat) / tci_div);
+		dseg_put(&tci, &tci_val, r, c);
 	    /* update asp for depression */
 	    if (is_swale || fabs(valued) >= threshold) {
 		seg_get(&aspflag, (char *)&afdown, dr, dc);
@@ -112,6 +226,7 @@
     int r, c, dr, dc;
     DCELL value, valued, *wat_nbr;
     POINT point;
     WAT_ALT wa;
@@ -120,9 +235,8 @@
     /* MFD */
     int mfd_cells, stream_cells, swale_cells, astar_not_set, is_null;
-    double *dist_to_nbr, *weight, sum_weight, max_weight;
-    int r_nbr, c_nbr, r_max, c_max, ct_dir, np_side, max_side;
-    double dx, dy;
+    double *dist_to_nbr, *contour, *weight, sum_weight, max_weight;
+    int r_nbr, c_nbr, r_max, c_max, ct_dir, np_side;
     CELL ele, *ele_nbr;
     double prop, max_acc;
     int workedon, edge, is_swale, flat;
@@ -136,20 +250,10 @@
     /* distances to neighbours */
     weight = (double *)G_malloc(sides * sizeof(double));
-    for (ct_dir = 0; ct_dir < sides; ct_dir++) {
-	/* get r, c (r_nbr, c_nbr) for neighbours */
-	r_nbr = nextdr[ct_dir];
-	c_nbr = nextdc[ct_dir];
-	/* account for rare cases when ns_res != ew_res */
-	dy = ABS(r_nbr) * window.ns_res;
-	dx = ABS(c_nbr) * window.ew_res;
-	if (ct_dir < 4)
-	    dist_to_nbr[ct_dir] = dx + dy;
-	else
-	    dist_to_nbr[ct_dir] = sqrt(dx * dx + dy * dy);
     flag_nbr = (char *)G_malloc(sides * sizeof(char));
     wat_nbr = (DCELL *)G_malloc(sides * sizeof(DCELL));
     ele_nbr = (CELL *)G_malloc(sides * sizeof(CELL));
@@ -287,13 +391,13 @@
 		mfd_cells++;
 		sum_weight += max_weight;
 		weight[np_side] = max_weight;
-		max_side = np_side;
 	    /* set flow accumulation for neighbours */
 	    max_acc = -1;
+	    tci_div = 0.;
 	    if (mfd_cells > 1) {
 		prop = 0.0;
@@ -327,12 +431,16 @@
 			    wa.ele = ele_nbr[ct_dir];
 			    seg_put(&watalt, (char *)&wa, r_nbr, c_nbr);
+			    if (tci_flag)
+				tci_div += contour[ct_dir] *
+				           get_slope_tci(ele, ele_nbr[ct_dir],
+				                         dist_to_nbr[ct_dir]);
 			    /* get main drainage direction */
 			    if (fabs(wat_nbr[ct_dir]) >= max_acc) {
 				max_acc = ABS(wat_nbr[ct_dir]);
 				r_max = r_nbr;
 				c_max = c_nbr;
-				max_side = ct_dir;
 			else if (ct_dir == np_side) {
@@ -372,8 +480,19 @@
 		wa.wat = valued;
 		wa.ele = ele_nbr[np_side];
 		seg_put(&watalt, (char *)&wa, dr, dc);
+		if (tci_flag)
+			      get_slope_tci(ele, ele_nbr[np_side],
+	    if (tci_flag) {
+		tci_val = log(fabs(value) / tci_div);
 	    /* update asp */
 	    if (dr != r_max || dc != c_max) {
 		if (af.asp < 0) {
Modified: grass/trunk/raster/r.watershed/seg/dseg_get.c
--- grass/trunk/raster/r.watershed/seg/dseg_get.c	2012-04-23 12:44:35 UTC (rev 51489)
+++ grass/trunk/raster/r.watershed/seg/dseg_get.c	2012-04-23 12:44:53 UTC (rev 51490)
@@ -10,3 +10,9 @@
     return 0;
+int dseg_flush(DSEG * dseg)
+    segment_flush(&(dseg->seg));
+    return 0;
Modified: grass/trunk/raster/r.watershed/seg/init_vars.c
--- grass/trunk/raster/r.watershed/seg/init_vars.c	2012-04-23 12:44:35 UTC (rev 51489)
+++ grass/trunk/raster/r.watershed/seg/init_vars.c	2012-04-23 12:44:53 UTC (rev 51490)
@@ -29,9 +29,15 @@
     G_gisinit(argv[0]);
-    ele_flag = wat_flag = asp_flag = pit_flag = run_flag = ril_flag = 0;
-    st_flag = bas_flag = seg_flag = haf_flag = arm_flag = dis_flag = 0;
-    ob_flag = sl_flag = sg_flag = ls_flag = er_flag = bas_thres = 0;
+    /* input */
+    ele_flag = pit_flag = run_flag = ril_flag = 0;
+    /* output */
+    wat_flag = asp_flag = bas_flag = seg_flag = haf_flag = tci_flag = 0;
+    bas_thres = 0;
+    /* shed, unused */
+    arm_flag = dis_flag = 0;
+    /* RUSLE */
+    ob_flag = st_flag = sl_flag = sg_flag = ls_flag = er_flag = 0;
     nxt_avail_pt = 0;
     /* dep_flag = 0; */
     max_length = d_zero = 0.0;
@@ -51,6 +57,8 @@
 	    ele_flag++;
 	else if (sscanf(argv[r], "accumulation=%s", wat_name) == 1)
 	    wat_flag++;
+	else if (sscanf(argv[r], "tci=%s", tci_name) == 1)
+	    tci_flag++;
 	else if (sscanf(argv[r], "drainage=%s", asp_name) == 1)
 	    asp_flag++;
 	else if (sscanf(argv[r], "depression=%s", pit_name) == 1)
@@ -173,6 +181,11 @@
     /* heap points: / 4 */
     memory_divisor += sizeof(HEAP_PNT) / 4.;
     disk_space += sizeof(HEAP_PNT);
+    /* TCI: as is */
+    if (tci_flag) {
+	memory_divisor += sizeof(double);
+	disk_space += sizeof(double);
     /* RUSLE */
     if (er_flag) {
 	/* r_h */
@@ -243,6 +256,9 @@
     seg_open(&watalt, nrows, ncols, seg_rows, seg_cols, num_open_segs * 2, sizeof(WAT_ALT));
     seg_open(&aspflag, nrows, ncols, seg_rows, seg_cols, num_open_segs * 4, sizeof(ASP_FLAG));
+    if (tci_flag)
+	dseg_open(&tci, seg_rows, seg_cols, num_open_segs);
     /* open elevation input */
     ele_fd = Rast_open_old(ele_name, "");
@@ -385,7 +401,7 @@
 	if (ril_flag) {
-	    dseg_open(&ril, 1, seg_rows * seg_cols, num_open_segs);
+	    dseg_open(&ril, seg_rows, seg_cols, num_open_segs);
 	    dseg_read_cell(&ril, ril_name, "");
@@ -393,9 +409,9 @@
 	dseg_open(&s_l, seg_rows, seg_cols, num_open_segs);
 	if (sg_flag)
-	    dseg_open(&s_g, 1, seg_rows * seg_cols, num_open_segs);
+	    dseg_open(&s_g, seg_rows, seg_cols, num_open_segs);
 	if (ls_flag)
-	    dseg_open(&l_s, 1, seg_rows * seg_cols, num_open_segs);
+	    dseg_open(&l_s, seg_rows, seg_cols, num_open_segs);
     G_debug(1, "open segments for A* points");
Modified: grass/trunk/raster/r.watershed/seg/main.c
--- grass/trunk/raster/r.watershed/seg/main.c	2012-04-23 12:44:35 UTC (rev 51489)
+++ grass/trunk/raster/r.watershed/seg/main.c	2012-04-23 12:44:53 UTC (rev 51490)
@@ -39,7 +39,7 @@
 BSEG s_b;
 CSEG dis, alt, bas, haf, r_h, dep;
-DSEG slp, s_l, s_g, l_s, ril;
+DSEG tci, slp, s_l, s_g, l_s, ril;
 double segs_mb;
 char zero, one;
@@ -56,11 +56,11 @@
     thr_name[8];
     sg_name[GNAME_MAX];
-char wat_name[GNAME_MAX], asp_name[GNAME_MAX], arm_name[GNAME_MAX],
-    dis_name[GNAME_MAX];
+char wat_name[GNAME_MAX], asp_name[GNAME_MAX], tci_name[GNAME_MAX];
+char arm_name[GNAME_MAX], dis_name[GNAME_MAX];
-char bas_flag, seg_flag, haf_flag, er_flag;
+char bas_flag, seg_flag, haf_flag, er_flag, tci_flag;
 FILE *fp;
