[GRASS-SVN] r51494 - grass/trunk/locale/po
svn_grass at osgeo.org
Mon Apr 23 10:58:36 EDT 2012
Author: neteler
Date: 2012-04-23 07:58:35 -0700 (Mon, 23 Apr 2012)
New Revision: 51494
grass/trunk/locale/po/grassmods_de.po
don't translate method names
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po 2012-04-23 13:14:01 UTC (rev 51493)
+++ grass/trunk/locale/po/grassmods_de.po 2012-04-23 14:58:35 UTC (rev 51494)
@@ -27172,7 +27172,7 @@
#: ../vector/v.select/args.c:52
msgid "overlap;features partially or completely overlap"
-msgstr "Überlappung; Feature überlappen sich teilweise oder vollständig"
+msgstr "overlap; Feature überlappen sich teilweise oder vollständig"
#: ../vector/v.select/args.c:57
msgid "overlap;features partially or completely overlap;equals;features are spatially equals (using GEOS);disjoint;features do not spatially intersect (using GEOS);intersects;features spatially intersect (using GEOS);touches;features spatially touches (using GEOS);crosses;features spatially crosses (using GEOS);within;feature A is completely inside feature B (using GEOS);contains;feature B is completely inside feature A (using GEOS);overlaps;features spatially overlap (using GEOS);relate;feature A is spatially related to feature B (using GEOS, requires 'relate' option);"
