[GRASS-SVN] r51520 - in grass/trunk/temporal: t.create t.info
t.list t.rast.aggregate t.rast.aggregate.ds t.rast.export
t.rast.extract t.rast.import t.rast.list t.rast.mapcalc
t.rast.out.vtk t.rast.series t.rast.to.rast3 t.rast.univar
t.rast3d.extract t.rast3d.list t.rast3d.mapcalc
t.rast3d.univar t.register t.remove t.sample t.support
t.topology t.unregister t.vect.extract t.vect.list
t.vect.observe.strds t.vect.univar t.vect.what.strds
svn_grass at osgeo.org
Tue Apr 24 08:21:47 EDT 2012
Author: neteler
Date: 2012-04-24 05:21:46 -0700 (Tue, 24 Apr 2012)
New Revision: 51520
grass/trunk/temporal/t.create/t.create.py
grass/trunk/temporal/t.info/t.info.py
grass/trunk/temporal/t.list/t.list.py
grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py
grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py
grass/trunk/temporal/t.rast.export/t.rast.export.py
grass/trunk/temporal/t.rast.extract/t.rast.extract.py
grass/trunk/temporal/t.rast.import/t.rast.import.py
grass/trunk/temporal/t.rast.list/t.rast.list.py
grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py
grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py
grass/trunk/temporal/t.rast.series/t.rast.series.py
grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py
grass/trunk/temporal/t.rast.univar/t.rast.univar.py
grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.py
grass/trunk/temporal/t.rast3d.list/t.rast3d.list.py
grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py
grass/trunk/temporal/t.rast3d.univar/t.rast3d.univar.py
grass/trunk/temporal/t.register/t.register.py
grass/trunk/temporal/t.remove/t.remove.py
grass/trunk/temporal/t.sample/t.sample.py
grass/trunk/temporal/t.support/t.support.py
grass/trunk/temporal/t.topology/t.topology.py
grass/trunk/temporal/t.unregister/t.unregister.py
grass/trunk/temporal/t.vect.extract/t.vect.extract.py
grass/trunk/temporal/t.vect.list/t.vect.list.py
grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py
grass/trunk/temporal/t.vect.univar/t.vect.univar.py
grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py
standardize module descriptions
Modified: grass/trunk/temporal/t.create/t.create.py
--- grass/trunk/temporal/t.create/t.create.py 2012-04-24 12:01:32 UTC (rev 51519)
+++ grass/trunk/temporal/t.create/t.create.py 2012-04-24 12:21:46 UTC (rev 51520)
@@ -15,7 +15,7 @@
#%module
-#% description: Create a space time dataset
+#% description: Creates a space time dataset.
#% keywords: temporal
#% keywords: create
#%end
Modified: grass/trunk/temporal/t.info/t.info.py
--- grass/trunk/temporal/t.info/t.info.py 2012-04-24 12:01:32 UTC (rev 51519)
+++ grass/trunk/temporal/t.info/t.info.py 2012-04-24 12:21:46 UTC (rev 51520)
@@ -15,7 +15,7 @@
#%module
-#% description: List information about space time datasets and maps
+#% description: Lists information about space time datasets and maps.
#% keywords: info
#%end
Modified: grass/trunk/temporal/t.list/t.list.py
--- grass/trunk/temporal/t.list/t.list.py 2012-04-24 12:01:32 UTC (rev 51519)
+++ grass/trunk/temporal/t.list/t.list.py 2012-04-24 12:21:46 UTC (rev 51520)
@@ -15,7 +15,7 @@
#%module
-#% description: List space time datasets and map
+#% description: Lists space time datasets and map.
#% keywords: list
#%end
Modified: grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py
--- grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py 2012-04-24 12:01:32 UTC (rev 51519)
+++ grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py 2012-04-24 12:21:46 UTC (rev 51520)
@@ -15,7 +15,7 @@
#%module
-#% description: Create a new space time raster dataset from the aggregated data of an existing space time raster dataset
+#% description: Create a new space time raster dataset from the aggregated data of an existing space time raster dataset.
#% keywords: aggregation
#%end
Modified: grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py
--- grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py 2012-04-24 12:01:32 UTC (rev 51519)
+++ grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py 2012-04-24 12:21:46 UTC (rev 51520)
@@ -15,7 +15,7 @@
#%module
-#% description: Aggregated data of an existing space time raster dataset using the temporal topology of a second space time dataset
+#% description: Aggregated data of an existing space time raster dataset using the temporal topology of a second space time dataset.
#%end
Modified: grass/trunk/temporal/t.rast.export/t.rast.export.py
--- grass/trunk/temporal/t.rast.export/t.rast.export.py 2012-04-24 12:01:32 UTC (rev 51519)
+++ grass/trunk/temporal/t.rast.export/t.rast.export.py 2012-04-24 12:21:46 UTC (rev 51520)
@@ -15,7 +15,7 @@
#%module
-#% description: Export space time raster dataset
+#% description: Exports space time raster dataset.
#% keywords: export
#%end
Modified: grass/trunk/temporal/t.rast.extract/t.rast.extract.py
--- grass/trunk/temporal/t.rast.extract/t.rast.extract.py 2012-04-24 12:01:32 UTC (rev 51519)
+++ grass/trunk/temporal/t.rast.extract/t.rast.extract.py 2012-04-24 12:21:46 UTC (rev 51520)
@@ -15,7 +15,7 @@
#%module
-#% description: Extract a subset of a space time raster dataset
+#% description: Extracts a subset of a space time raster datasets.
#% keywords: extract
#%end
Modified: grass/trunk/temporal/t.rast.import/t.rast.import.py
--- grass/trunk/temporal/t.rast.import/t.rast.import.py 2012-04-24 12:01:32 UTC (rev 51519)
+++ grass/trunk/temporal/t.rast.import/t.rast.import.py 2012-04-24 12:21:46 UTC (rev 51520)
@@ -15,7 +15,7 @@
#%module
-#% description: Import space time raster dataset
+#% description: Imports space time raster dataset.
#% keywords: import
#%end
Modified: grass/trunk/temporal/t.rast.list/t.rast.list.py
--- grass/trunk/temporal/t.rast.list/t.rast.list.py 2012-04-24 12:01:32 UTC (rev 51519)
+++ grass/trunk/temporal/t.rast.list/t.rast.list.py 2012-04-24 12:21:46 UTC (rev 51520)
@@ -15,7 +15,7 @@
#%module
-#% description: List registered maps of a space time raster dataset
+#% description: Lists registered maps of a space time raster dataset.
#% keywords: raster
#% keywords: list
Modified: grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py
--- grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py 2012-04-24 12:01:32 UTC (rev 51519)
+++ grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py 2012-04-24 12:21:46 UTC (rev 51520)
@@ -15,7 +15,7 @@
#%module
-#% description: Perform r.mapcalc expressions on maps of sampled space time raster datasets
+#% description: Performs r.mapcalc expressions on maps of sampled space time raster datasets.
#% keywords: mapcalc
#%end
Modified: grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py
--- grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py 2012-04-24 12:01:32 UTC (rev 51519)
+++ grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py 2012-04-24 12:21:46 UTC (rev 51520)
@@ -15,7 +15,7 @@
#%module
-#% description: Export space time raster dataset as VTK time series
+#% description: Exports space time raster dataset as VTK time series.
#% keywords: dataset
#% keywords: spacetime
#% keywords: raster
Modified: grass/trunk/temporal/t.rast.series/t.rast.series.py
--- grass/trunk/temporal/t.rast.series/t.rast.series.py 2012-04-24 12:01:32 UTC (rev 51519)
+++ grass/trunk/temporal/t.rast.series/t.rast.series.py 2012-04-24 12:21:46 UTC (rev 51520)
@@ -15,7 +15,7 @@
#%module
-#% description: Perform different aggregation algorithms from r.series on all or a subset of raster maps in a space time raster dataset
+#% description: Performs different aggregation algorithms from r.series on all or a subset of raster maps in a space time raster dataset.
#% keywords: series
#%end
Modified: grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py
--- grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py 2012-04-24 12:01:32 UTC (rev 51519)
+++ grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py 2012-04-24 12:21:46 UTC (rev 51520)
@@ -15,7 +15,7 @@
#%module
-#% description: Convert a space time raster dataset into a rast3d map
+#% description: Converts a space time raster dataset into a raster3d map.
#% keywords: raster3d
#% keywords: convert
Modified: grass/trunk/temporal/t.rast.univar/t.rast.univar.py
--- grass/trunk/temporal/t.rast.univar/t.rast.univar.py 2012-04-24 12:01:32 UTC (rev 51519)
+++ grass/trunk/temporal/t.rast.univar/t.rast.univar.py 2012-04-24 12:21:46 UTC (rev 51520)
@@ -15,7 +15,7 @@
#%module
-#% description: Calculates univariate statistics from the non-null cells for each registered raster map of a space time raster dataset
+#% description: Calculates univariate statistics from the non-null cells for each registered raster map of a space time raster dataset.
#% keywords: statistics
#% keywords: raster
Modified: grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.py
--- grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.py 2012-04-24 12:01:32 UTC (rev 51519)
+++ grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.py 2012-04-24 12:21:46 UTC (rev 51520)
@@ -15,7 +15,7 @@
#%module
-#% description: Extract a subset of a space time raster3d dataset
+#% description: Extracts a subset of a space time raster3d dataset.
#%end
Modified: grass/trunk/temporal/t.rast3d.list/t.rast3d.list.py
--- grass/trunk/temporal/t.rast3d.list/t.rast3d.list.py 2012-04-24 12:01:32 UTC (rev 51519)
+++ grass/trunk/temporal/t.rast3d.list/t.rast3d.list.py 2012-04-24 12:21:46 UTC (rev 51520)
@@ -15,7 +15,7 @@
#%module
-#% description: List registered maps of a space time raster3d dataset
+#% description: Lists registered maps of a space time raster3d dataset.
Modified: grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py
--- grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py 2012-04-24 12:01:32 UTC (rev 51519)
+++ grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py 2012-04-24 12:21:46 UTC (rev 51520)
@@ -15,7 +15,7 @@
#%module
-#% description: Perform r3.mapcalc expressions on maps of sampled space time raster3d datasets
+#% description: Performs r3.mapcalc expressions on maps of sampled space time raster3d datasets.
#%end
Modified: grass/trunk/temporal/t.rast3d.univar/t.rast3d.univar.py
--- grass/trunk/temporal/t.rast3d.univar/t.rast3d.univar.py 2012-04-24 12:01:32 UTC (rev 51519)
+++ grass/trunk/temporal/t.rast3d.univar/t.rast3d.univar.py 2012-04-24 12:21:46 UTC (rev 51520)
@@ -15,7 +15,7 @@
#%module
-#% description: Calculates univariate statistics from the non-null cells for each registered raster3d map of a space time raster3d dataset
+#% description: Calculates univariate statistics from the non-null cells for each registered raster3d map of a space time raster3d dataset.
#% keywords: raster
Modified: grass/trunk/temporal/t.register/t.register.py
--- grass/trunk/temporal/t.register/t.register.py 2012-04-24 12:01:32 UTC (rev 51519)
+++ grass/trunk/temporal/t.register/t.register.py 2012-04-24 12:21:46 UTC (rev 51520)
@@ -15,7 +15,7 @@
#%module
-#% description: Register raster, vector adn raster3d maps in a space time datasets
+#% description: Registers raster, vector adn raster3d maps in a space time datasets.
#% keywords: register
#%end
Modified: grass/trunk/temporal/t.remove/t.remove.py
--- grass/trunk/temporal/t.remove/t.remove.py 2012-04-24 12:01:32 UTC (rev 51519)
+++ grass/trunk/temporal/t.remove/t.remove.py 2012-04-24 12:21:46 UTC (rev 51520)
@@ -15,7 +15,7 @@
#%module
-#% description: Remove space time datasets from temporal database
+#% description: Removes space time datasets from temporal database.
#% keywords: remove
#%end
Modified: grass/trunk/temporal/t.sample/t.sample.py
--- grass/trunk/temporal/t.sample/t.sample.py 2012-04-24 12:01:32 UTC (rev 51519)
+++ grass/trunk/temporal/t.sample/t.sample.py 2012-04-24 12:21:46 UTC (rev 51520)
@@ -15,7 +15,7 @@
#%module
-#% description: Sample the input space time dataset(s) with a sample space time dataset and print the result to stdout
+#% description: Samples the input space time dataset(s) with a sample space time dataset and print the result to stdout.
#% keywords: sample
#%end
Modified: grass/trunk/temporal/t.support/t.support.py
--- grass/trunk/temporal/t.support/t.support.py 2012-04-24 12:01:32 UTC (rev 51519)
+++ grass/trunk/temporal/t.support/t.support.py 2012-04-24 12:21:46 UTC (rev 51520)
@@ -15,7 +15,7 @@
#%module
-#% description: Modify the metadata of a space time dataset
+#% description: Modifies the metadata of a space time dataset.
#% keywords: support
#%end
Modified: grass/trunk/temporal/t.topology/t.topology.py
--- grass/trunk/temporal/t.topology/t.topology.py 2012-04-24 12:01:32 UTC (rev 51519)
+++ grass/trunk/temporal/t.topology/t.topology.py 2012-04-24 12:21:46 UTC (rev 51520)
@@ -15,7 +15,7 @@
#%module
-#% description: List and modify temporal topology of a space time dataset
+#% description: Lists and modifies temporal topology of a space time dataset.
#% keywords: topology
#%end
Modified: grass/trunk/temporal/t.unregister/t.unregister.py
--- grass/trunk/temporal/t.unregister/t.unregister.py 2012-04-24 12:01:32 UTC (rev 51519)
+++ grass/trunk/temporal/t.unregister/t.unregister.py 2012-04-24 12:21:46 UTC (rev 51520)
@@ -15,7 +15,7 @@
#%module
-#% description: Unregister raster, vector and raster3d maps from the temporal database or a specific space time dataset
+#% description: Unregisters raster, vector and raster3d maps from the temporal database or a specific space time dataset.
#% keywords: unregister
#%end
Modified: grass/trunk/temporal/t.vect.extract/t.vect.extract.py
--- grass/trunk/temporal/t.vect.extract/t.vect.extract.py 2012-04-24 12:01:32 UTC (rev 51519)
+++ grass/trunk/temporal/t.vect.extract/t.vect.extract.py 2012-04-24 12:21:46 UTC (rev 51520)
@@ -15,7 +15,7 @@
#%module
+#% description: Extracts a subset of a space time raster dataset.
#%end
Modified: grass/trunk/temporal/t.vect.list/t.vect.list.py
--- grass/trunk/temporal/t.vect.list/t.vect.list.py 2012-04-24 12:01:32 UTC (rev 51519)
+++ grass/trunk/temporal/t.vect.list/t.vect.list.py 2012-04-24 12:21:46 UTC (rev 51520)
@@ -15,7 +15,7 @@
#%module
-#% description: List registered maps of a space time vector dataset
+#% description: Lists registered maps of a space time vector dataset.
#% keywords: list
#%end
Modified: grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py
--- grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py 2012-04-24 12:01:32 UTC (rev 51519)
+++ grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py 2012-04-24 12:21:46 UTC (rev 51520)
@@ -15,7 +15,7 @@
#%module
-#% description: Observe specific locations in a space time raster dataset over a periode of time using vector points
+#% description: Observes specific locations in a space time raster dataset over a periode of time using vector points.
#% keywords: sampling
#%end
Modified: grass/trunk/temporal/t.vect.univar/t.vect.univar.py
--- grass/trunk/temporal/t.vect.univar/t.vect.univar.py 2012-04-24 12:01:32 UTC (rev 51519)
+++ grass/trunk/temporal/t.vect.univar/t.vect.univar.py 2012-04-24 12:21:46 UTC (rev 51520)
@@ -15,7 +15,7 @@
#%module
-#% description: Calculates univariate statistics from the non-null cells for each registered vector map of a space time vector dataset
+#% description: Calculates univariate statistics from the non-null cells for each registered vector map of a space time vector dataset.
#% keywords: vector
Modified: grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py
--- grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py 2012-04-24 12:01:32 UTC (rev 51519)
+++ grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py 2012-04-24 12:21:46 UTC (rev 51520)
@@ -15,7 +15,7 @@
#%module
-#% description: Uploads raster map values at spatial and temporal positions of vector points to the tables. The maps are registered in space time datasets
+#% description: Uploads raster map values at spatial and temporal positions of vector points to the tables. The maps are registered in space time datasets.
#%end
@@ -30,7 +30,7 @@
#%option
#% key: column
#% type: string
-#% description: Name of the vector column to be created and to store sampled raster values. The use of a column name forces t.vect.what.rast to sample only values from the first map found in an interval. Otherwise the raster map names are used as column names.
+#% description: Name of the vector column to be created and to store sampled raster values. The use of a column name forces t.vect.what.rast to sample only values from the first map found in an interval. Otherwise the raster map names are used as column names
#% required: no
#% multiple: no
#%end
