[GRASS-SVN] r51526 - in grass-addons/grass7/raster: . r.vol.dem
Tue Apr 24 17:23:22 EDT 2012
Author: neteler
Date: 2012-04-24 14:23:22 -0700 (Tue, 24 Apr 2012)
New Revision: 51526
Added:
   grass-addons/grass7/raster/r.vol.dem/
   grass-addons/grass7/raster/r.vol.dem/Makefile
   grass-addons/grass7/raster/r.vol.dem/chull.c
   grass-addons/grass7/raster/r.vol.dem/chull.h
   grass-addons/grass7/raster/r.vol.dem/globals.h
   grass-addons/grass7/raster/r.vol.dem/macros.h
   grass-addons/grass7/raster/r.vol.dem/main.c
Benjamin Ducke: new (few G7 updates lacking)
Added: grass-addons/grass7/raster/r.vol.dem/Makefile
--- grass-addons/grass7/raster/r.vol.dem/Makefile	                        (rev 0)
+++ grass-addons/grass7/raster/r.vol.dem/Makefile	2012-04-24 21:23:22 UTC (rev 51526)
@@ -0,0 +1,4 @@
+MODULE_TOPDIR =.. /..PGM = r.vol.dem LIBES = $(GISLIB) $(DATETIMELIB)
+EXTRA_CFLAGS = -I.. /.. / include include $(MODULE_TOPDIR) / include / Make / Module.make default:
+cmd
Added: grass-addons/grass7/raster/r.vol.dem/chull.c
--- grass-addons/grass7/raster/r.vol.dem/chull.c	                        (rev 0)
+++ grass-addons/grass7/raster/r.vol.dem/chull.c	2012-04-24 21:23:22 UTC (rev 51526)
@@ -0,0 +1,1283 @@
+   This code is described in "Computational Geometry in C" (Second Edition),
+   Chapter 4.  It is not written to be comprehensible without the
+   explanation in that book.
+   Input: 3n integer coordinates for the points.
+   Output: the 3D convex hull, in postscript with embedded comments
+   showing the vertices and faces.
+   Compile: gcc -o chull chull.c
+   Written by Joseph O'Rourke, with contributions by
+   Kristy Anderson, John Kutcher, Catherine Schevon, Susan Weller.
+   Last modified: March 1998
+   Questions to orourke at cs.smith.edu.
+   This code is Copyright 1998 by Joseph O'Rourke.  It may be freely
+   redistributed in its entirety provided that this copyright notice is
+   not removed.
+#include <stdio.h>
+#include <stdlib.h>
+#include <math.h>
+#include <grass/gis.h>
+#include "globals.h"
+/*Define Boolean type */
+typedef enum
+{ BFALSE, BTRUE } bool;
+/* Define vertex indices. */
+#define X   0
+#define Y   1
+#define Z   2
+/* Define structures for vertices, edges and faces */
+typedef struct tVertexStructure tsVertex;
+typedef tsVertex *tVertex;
+typedef struct tEdgeStructure tsEdge;
+typedef tsEdge *tEdge;
+typedef struct tFaceStructure tsFace;
+typedef tsFace *tFace;
+struct tVertexStructure
+    long int v[3];
+    int vnum;
+    tEdge duplicate;		/* pointer to incident cone edge (or NULL) */
+    bool onhull;		/* T iff point on hull. */
+    bool mark;			/* T iff point already processed. */
+    tVertex next, prev;
+struct tEdgeStructure
+    tFace adjface[2];
+    tVertex endpts[2];
+    tFace newface;		/* pointer to incident cone face. */
+    bool delete;		/* T iff edge should be delete. */
+    tEdge next, prev;
+struct tFaceStructure
+    tEdge edge[3];
+    tVertex vertex[3];
+    bool visible;		/* T iff face visible from new point. */
+    tFace next, prev;
+/* Define flags */
+#define ONHULL   	BTRUE
+#define REMOVED  	BTRUE
+#define VISIBLE  	BTRUE
+#define PROCESSED	BTRUE
+#define SAFE		2000000000	/* Range of safe coord values. */
+/* Global variable definitions */
+tVertex vertices = NULL;
+tEdge edges = NULL;
+tFace faces = NULL;
+bool debug = BFALSE;
+bool check = BFALSE;
+/* Function declarations */
+tVertex MakeNullVertex(void);
+void ReadVertices(long int *px, long int *py, long int *pz, int num_points);
+void Print(void);
+void Dump(FILE * tmpfile);
+void SubVec(long int a[3], long int b[3], long int c[3]);
+int DoubleTriangle(void);
+void ConstructHull(void);
+bool AddOne(tVertex p);
+int VolumeSign(tFace f, tVertex p);
+int Volumei(tFace f, tVertex p);
+tFace MakeConeFace(tEdge e, tVertex p);
+void MakeCcw(tFace f, tEdge e, tVertex p);
+tEdge MakeNullEdge(void);
+tFace MakeNullFace(void);
+tFace MakeFace(tVertex v0, tVertex v1, tVertex v2, tFace f);
+void CleanUp(void);
+void CleanEdges(void);
+void CleanFaces(void);
+void CleanVertices(void);
+bool Collinear(tVertex a, tVertex b, tVertex c);
+void CheckEuler(long int V, long int E, long int F);
+void PrintPoint(tVertex p);
+void Checks(void);
+void Consistency(void);
+void Convexity(void);
+void PrintOut(tVertex v);
+void PrintVertices(void);
+void PrintEdges(void);
+void PrintFaces(void);
+#include "macros.h"
+   Release all memory allocated for edges, faces and vertices
+void freeMem(void)
+    tEdge e;			/* Primary index into edge list. */
+    tFace f;			/* Primary pointer into face list. */
+    tVertex v;
+    tEdge te;			/* Temporary edge pointer. */
+    tFace tf;			/* Temporary face pointer. */
+    tVertex tv;			/* Temporary vertex pointer. */
+    if (DEBUG) {
+	fprintf(stdout, "FREE MEM:\n");
+	fflush(stdout);
+    if (DEBUG) {
+	fprintf(stdout, "  EDGES:\n");
+	fflush(stdout);
+    e = edges;
+    do {
+	te = e;
+	e = e->next;
+	DELETE(edges, te);
+    } while (e != edges);
+    if (DEBUG) {
+	fprintf(stdout, "  FACES:\n");
+	fflush(stdout);
+    f = faces;
+    do {
+	tf = f;
+	f = f->next;
+	DELETE(faces, tf);
+    } while (f != faces);
+    if (DEBUG) {
+	fprintf(stdout, "  VERTICES:\n");
+	fflush(stdout);
+    v = vertices;
+    do {
+	tv = v;
+	v = v->next;
+	DELETE(vertices, tv);
+    } while (v != vertices);
+    FREE(te);
+    FREE(tf);
+    FREE(tv);
+    DELETE(edges, e);
+    DELETE(faces, f);
+    DELETE(vertices, v);
+    FREE(edges);
+    FREE(faces);
+    FREE(vertices);
+    if (DEBUG) {
+	fprintf(stdout, "MEM FREE'D!\n");
+	fflush(stdout);
+int make3DHull(long int *px, long int *py, long int *pz, int num_points,
+	       FILE * tmpfile)
+    int error;
+    check = BFALSE;
+    debug = BFALSE;
+    if (DEBUG > 1)
+	check = BTRUE;
+    if (DEBUG > 2)
+	debug = BTRUE;
+    ReadVertices(px, py, pz, num_points);
+    error = DoubleTriangle();
+    if (error < 0) {
+	G_warning("All points of this layer are in the same voxel plane.\n");
+	freeMem();
+	return (error);
+    ConstructHull();
+    Dump(tmpfile);
+    freeMem();
+    return (0);
+MakeNullVertex: Makes a vertex, nulls out fields.
+    tVertex v;
+    NEW(v, tsVertex);
+    v->duplicate = NULL;
+    v->onhull = !ONHULL;
+    v->mark = !PROCESSED;
+    ADD(vertices, v);
+    return v;
+ReadVertices: Reads in the vertices, and links them into a circular
+list with MakeNullVertex.  There is no need for the # of vertices to be
+the first line: the function looks for EOF instead.  Sets the global
+variable vertices via the ADD macro.
+    tVertex v;
+    int vnum = 0;
+    int i;
+    for (i = 0; i < num_points; i++) {
+	v = MakeNullVertex();
+	v->v[X] = px[i];
+	v->v[Y] = py[i];
+	v->v[Z] = pz[i];
+	v->vnum = vnum++;
+	if ((abs(px[i]) > SAFE) || (abs(py[i]) > SAFE) || (abs(pz[i]) > SAFE)) {
+	    printf
+		("Coordinate of vertex below might be too large: run with -c flag\n");
+	    PrintPoint(v);
+Dump: Dumps out the vertices and the faces to a file.
+Uses the vnum indices  corresponding to the order in which the vertices
+were input.
+Output is in GRASS ASCII file format.
+    /* Pointers to vertices, edges, faces. */
+    tVertex v;
+    tEdge e;
+    tFace f;
+    double dx, dy, dz;
+    long int a[3], b[3];	/* used to compute normal vector */
+    /* Counters for Euler's formula. */
+    long int V = 0, E = 0, F = 0;
+    /* Note: lowercase==pointer, uppercase==counter. */
+    long int cat;
+    f = faces;
+    do {
+	++F;
+	f = f->next;
+    /* GRASS 6 map header */
+    fprintf(tmpfile, "ORGANIZATION: \n");
+    fprintf(tmpfile, "DIGIT DATE: \n");
+    fprintf(tmpfile, "DIGIT NAME: \n");
+    fprintf(tmpfile, "MAP NAME: \n");
+    fprintf(tmpfile, "MAP DATE: \n");
+    fprintf(tmpfile, "MAP SCALE: 10000\n");
+    fprintf(tmpfile, "OTHER INFO: %li faces.\n", F);
+    fprintf(tmpfile, "ZONE: 0\n");
+    fprintf(tmpfile, "MAP THRESH: 0.5\n");
+    fprintf(tmpfile, "VERTI:\n");
+    cat = 1;
+    /* putting all faces into one object does not produce nice output in NVIZ !
+       If we decided to dump all layers into a single file, we would also need
+       a cat for each object to be passed from the main program.
+       printf("F  %li 1\n", F*4);
+       do {
+       dx = ((double) ( f->vertex[0]->v[X] ) / (1000));
+       dy = ((double) ( f->vertex[0]->v[Y] ) / (1000));
+       dz = ((double) ( f->vertex[0]->v[Z] ) / (1000));
+       printf(" %.3f %.3f %.3f\n", dx, dy, dz);
+       dx = ((double) ( f->vertex[1]->v[X] ) / (1000));
+       dy = ((double) ( f->vertex[1]->v[Y] ) / (1000));
+       dz = ((double) ( f->vertex[1]->v[Z] ) / (1000));
+       dx = ((double) ( f->vertex[2]->v[X] ) / (1000));
+       dy = ((double) ( f->vertex[2]->v[Y] ) / (1000));
+       dz = ((double) ( f->vertex[2]->v[Z] ) / (1000));
+       f = f->next;
+       } while ( f != faces );
+       printf(" %li 1\n", cat);
+    do {
+	fprintf(tmpfile, "F  4 1\n");
+	dx = ((double)(f->vertex[0]->v[X]) / (PRECISION));
+	dy = ((double)(f->vertex[0]->v[Y]) / (PRECISION));
+	dz = ((double)(f->vertex[0]->v[Z]) / (PRECISION));
+	fprintf(tmpfile, " %.3f %.3f %.3f\n", dx, dy, dz);
+	dx = ((double)(f->vertex[1]->v[X]) / (PRECISION));
+	dy = ((double)(f->vertex[1]->v[Y]) / (PRECISION));
+	dz = ((double)(f->vertex[1]->v[Z]) / (PRECISION));
+	dx = ((double)(f->vertex[2]->v[X]) / (PRECISION));
+	dy = ((double)(f->vertex[2]->v[Y]) / (PRECISION));
+	dz = ((double)(f->vertex[2]->v[Z]) / (PRECISION));
+	fprintf(tmpfile, " %li 1\n", cat);
+	cat++;
+	f = f->next;
+    if (DEBUG > 0) {
+	fprintf(stdout, "3D Convex hull check (Euler):\n");
+	check = BTRUE;
+	CheckEuler(V, E, F);
+Print: Prints out the vertices and the faces.  Uses the vnum indices
+corresponding to the order in which the vertices were input.
+Output is in PostScript format.
+void Print(void)
+    tVertex v;
+    tEdge e;
+    tFace f;
+    long int xmin, ymin, xmax, ymax;
+   /*-- find X min & max --*/
+    v = vertices;
+    xmin = xmax = v->v[X];
+    do {
+	if (v->v[X] > xmax)
+	    xmax = v->v[X];
+	else if (v->v[X] < xmin)
+	    xmin = v->v[X];
+	v = v->next;
+   /*-- find Y min & max --*/
+    v = vertices;
+    ymin = ymax = v->v[Y];
+    do {
+	if (v->v[Y] > ymax)
+	    ymax = v->v[Y];
+	else if (v->v[Y] < ymin)
+	    ymin = v->v[Y];
+	v = v->next;
+    /* PostScript header */
+    printf("%%!PS\n");
+    printf("%%%%BoundingBox: %li %li %li %li\n", xmin, ymin, xmax, ymax);
+    printf(".00 .00 setlinewidth\n");
+    printf("%li %li translate\n", -xmin + 72, -ymin + 72);
+    /* The +72 shifts the figure one inch from the lower left corner */
+    /* Vertices. */
+    v = vertices;
+    do {
+	if (v->mark)
+	    V++;
+	v = v->next;
+    printf("\n%%%% Vertices:\tV = %li\n", V);
+    printf("%%%% index:\tx\ty\tz\n");
+    do {
+	printf("%%%% %5d:\t%li\t%li\t%li\n",
+	       v->vnum, v->v[X], v->v[Y], v->v[Z]);
+	v = v->next;
+    /* Faces. */
+    /* visible faces are printed as PS output */
+    f = faces;
+    do {
+	++F;
+	f = f->next;
+    printf("\n%%%% Faces:\tF = %li\n", F);
+    printf("%%%% Visible faces only: \n");
+    do {
+	/* Print face only if it is visible: if normal vector >= 0 */
+	SubVec(f->vertex[1]->v, f->vertex[0]->v, a);
+	SubVec(f->vertex[2]->v, f->vertex[1]->v, b);
+	if ((a[0] * b[1] - a[1] * b[0]) >= 0) {
+	    printf("%%%% vnums:  %d  %d  %d\n",
+		   f->vertex[0]->vnum,
+		   f->vertex[1]->vnum, f->vertex[2]->vnum);
+	    printf("newpath\n");
+	    printf("%li\t%li\tmoveto\n",
+		   f->vertex[0]->v[X], f->vertex[0]->v[Y]);
+	    printf("%li\t%li\tlineto\n",
+		   f->vertex[1]->v[X], f->vertex[1]->v[Y]);
+		   f->vertex[2]->v[X], f->vertex[2]->v[Y]);
+	    printf("closepath stroke\n\n");
+	f = f->next;
+    /* prints a list of all faces */
+    printf("%%%% List of all faces: \n");
+    printf("%%%%\tv0\tv1\tv2\t(vertex indices)\n");
+    do {
+	printf("%%%%\t%d\t%d\t%d\n",
+	       f->vertex[0]->vnum, f->vertex[1]->vnum, f->vertex[2]->vnum);
+	f = f->next;
+    /* Edges. */
+    e = edges;
+    do {
+	E++;
+	e = e->next;
+    printf("\n%%%% Edges:\tE = %li\n", E);
+    /* Edges not printed out (but easily added). */
+    printf("\nshowpage\n\n");
+    if (DEBUG > 0) {
+	check = BTRUE;
+SubVec:  Computes a - b and puts it into c.
+    long int i;
+    for (i = 0; i < 2; i++)
+	c[i] = a[i] - b[i];
+ DoubleTriangle builds the initial double triangle.  It first finds 3
+ noncollinear points and makes two faces out of them, in opposite order.
+ It then finds a fourth point that is not coplanar with that face.  The
+ vertices are stored in the face structure in counterclockwise order so
+ that the volume between the face and the point is negative. Lastly, the
+ 3 newfaces to the fourth point are constructed and the data structures
+ are cleaned up.
+/* RETURN:      0 if OK */
+/*              -1 if all points collinear */
+/*              -2 if all points coplanar */
+    tVertex v0, v1, v2, v3, t;
+    tFace f0, f1 = NULL;
+    tEdge e0, e1, e2, s;
+    long int vol;
+    /* Find 3 noncollinear points. */
+    v0 = vertices;
+    while (Collinear(v0, v0->next, v0->next->next)) {
+	if ((v0 = v0->next) == vertices) {
+	    if (debug) {
+		printf("DoubleTriangle:  All points are collinear!\n");
+	    return (-1);
+    v1 = v0->next;
+    v2 = v1->next;
+    /* Mark the vertices as processed. */
+    v0->mark = PROCESSED;
+    v1->mark = PROCESSED;
+    v2->mark = PROCESSED;
+    /* Create the two "twin" faces. */
+    f0 = MakeFace(v0, v1, v2, f1);
+    f1 = MakeFace(v2, v1, v0, f0);
+    /* Link adjacent face fields. */
+    f0->edge[0]->adjface[1] = f1;
+    f0->edge[1]->adjface[1] = f1;
+    f0->edge[2]->adjface[1] = f1;
+    f1->edge[0]->adjface[1] = f0;
+    f1->edge[1]->adjface[1] = f0;
+    f1->edge[2]->adjface[1] = f0;
+    /* Find a fourth, noncoplanar point to form tetrahedron. */
+    v3 = v2->next;
+    vol = VolumeSign(f0, v3);
+    while (!vol) {
+	if ((v3 = v3->next) == v0) {
+	    if (debug) {
+		printf("DoubleTriangle:  All points are coplanar!\n");
+	    return (-2);
+    /* Insure that v3 will be the first added. */
+    vertices = v3;
+    if (debug) {
+	fprintf(stderr,
+		"DoubleTriangle: finished. Head repositioned at v3.\n");
+	PrintOut(vertices);
+    return (0);
+ConstructHull adds the vertices to the hull one at a time.  The hull
+vertices are those in the list marked as onhull.
+    tVertex v, vnext;
+    long int vol;
+    bool changed;		/* T if addition changes hull; not used. */
+    int i;
+    int numVertices;
+    if (VERBOSE) {
+	fprintf(stdout, "  Constructing 3D hull: \n");
+    v = vertices;
+    i = 0;
+    do {
+	vnext = v->next;
+	v = vnext;
+	i++;
+    numVertices = i;
+    v = vertices;
+    i = 0;
+    do {
+	vnext = v->next;
+	if (!v->mark) {
+	    v->mark = PROCESSED;
+	    changed = AddOne(v);
+	    CleanUp();
+	    if (check) {
+		fprintf(stderr, "ConstructHull: After Add of %d & Cleanup:\n",
+			v->vnum);
+		Checks();
+	    if (debug)
+		PrintOut(v);
+	v = vnext;
+	i++;
+	if (VERBOSE) {
+	    G_percent(i, numVertices, 1);
+    fflush(stdout);
+AddOne is passed a vertex.  It first determines all faces visible from
+that point.  If none are visible then the point is marked as not
+onhull.  Next is a loop over edges.  If both faces adjacent to an edge
+are visible, then the edge is marked for deletion.  If just one of the
+adjacent faces is visible then a new face is constructed.
+    tFace f;
+    tEdge e, temp;
+    long int vol;
+    bool vis = BFALSE;
+    if (debug) {
+	fprintf(stderr, "AddOne: starting to add v%d.\n", p->vnum);
+    /* Mark faces visible from p. */
+    f = faces;
+    do {
+	vol = VolumeSign(f, p);
+	if (debug)
+	    fprintf(stderr,
+		    "faddr: %6x   paddr: %6x   Vol = %li\n", (unsigned int)f,
+		    (unsigned int)p, vol);
+	if (vol < 0) {
+	    f->visible = VISIBLE;
+	    vis = BTRUE;
+	f = f->next;
+    /* If no faces are visible from p, then p is inside the hull. */
+    if (!vis) {
+	p->onhull = !ONHULL;
+	return BFALSE;
+    /* Mark edges in interior of visible region for deletion.
+       Erect a newface based on each border edge. */
+    e = edges;
+    do {
+	temp = e->next;
+	if (e->adjface[0]->visible && e->adjface[1]->visible)
+	    /* e interior: mark for deletion. */
+	    e->delete = REMOVED;
+	else if (e->adjface[0]->visible || e->adjface[1]->visible)
+	    /* e border: make a new face. */
+	    e->newface = MakeConeFace(e, p);
+	e = temp;
+    return BTRUE;
+VolumeSign returns the sign of the volume of the tetrahedron determined by f
+and p.  VolumeSign is +1 iff p is on the negative side of f,
+where the positive side is determined by the rh-rule.  So the volume
+is positive if the ccw normal to f points outside the tetrahedron.
+The final fewer-multiplications form is due to Bob Williamson.
+    double vol;
+    long int voli;
+    double ax, ay, az, bx, by, bz, cx, cy, cz;
+    ax = f->vertex[0]->v[X] - p->v[X];
+    ay = f->vertex[0]->v[Y] - p->v[Y];
+    az = f->vertex[0]->v[Z] - p->v[Z];
+    bx = f->vertex[1]->v[X] - p->v[X];
+    by = f->vertex[1]->v[Y] - p->v[Y];
+    bz = f->vertex[1]->v[Z] - p->v[Z];
+    cx = f->vertex[2]->v[X] - p->v[X];
+    cy = f->vertex[2]->v[Y] - p->v[Y];
+    cz = f->vertex[2]->v[Z] - p->v[Z];
+    vol = ax * (by * cz - bz * cy)
+	+ ay * (bz * cx - bx * cz)
+	+ az * (bx * cy - by * cx);
+    if (debug)
+	fprintf(stderr,
+		"Face=%6x; Vertex=%d: vol(int) = %li, vol(double) = %.f\n",
+		(unsigned int)f, p->vnum, voli, vol);
+    /* The volume should be an integer. */
+    if (vol > 0.5)
+	return 1;
+    else if (vol < -0.5)
+	return -1;
+    else
+	return 0;
+    double vol;
+    long int voli;
+    double ax, ay, az, bx, by, bz, cx, cy, cz, dx, dy, dz;
+    vol = (ax * (by * cz - bz * cy)
+	   + az * (bx * cy - by * cx));
+    if (debug)
+	fprintf(stderr,
+    if (vol > 0.5)
+	return 1;
+	return -1;
+    else
+	return 0;
+    int i;
+    for (i = 0; i < 3; i++)
+	printf("\t%li", p->v[i]);
+    putchar('\n');
+MakeConeFace makes a new face and two new edges between the
+edge and the point that are passed to it. It returns a pointer to
+the new face.
+    tEdge new_edge[2];
+    tFace new_face;
+    int i, j;
+    /* Make two new edges (if don't already exist). */
+    for (i = 0; i < 2; ++i)
+	/* If the edge exists, copy it into new_edge. */
+	if (!(new_edge[i] = e->endpts[i]->duplicate)) {
+	    /* Otherwise (duplicate is NULL), MakeNullEdge. */
+	    new_edge[i] = MakeNullEdge();
+	    new_edge[i]->endpts[0] = e->endpts[i];
+	    new_edge[i]->endpts[1] = p;
+	    e->endpts[i]->duplicate = new_edge[i];
+    /* Make the new face. */
+    new_face = MakeNullFace();
+    new_face->edge[0] = e;
+    new_face->edge[1] = new_edge[0];
+    new_face->edge[2] = new_edge[1];
+    MakeCcw(new_face, e, p);
+    /* Set the adjacent face pointers. */
+	for (j = 0; j < 2; ++j)
+	    /* Only one NULL link should be set to new_face. */
+	    if (!new_edge[i]->adjface[j]) {
+		new_edge[i]->adjface[j] = new_face;
+		break;
+    return new_face;
+MakeCcw puts the vertices in the face structure in counterclock wise
+order.  We want to store the vertices in the same
+order as in the visible face.  The third vertex is always p.
+    tFace fv;			/* The visible face adjacent to e */
+    int i;			/* Index of e->endpoint[0] in fv. */
+    tEdge s;			/* Temporary, for swapping */
+    if (e->adjface[0]->visible)
+	fv = e->adjface[0];
+    else
+	fv = e->adjface[1];
+    /* Set vertex[0] & [1] of f to have the same orientation
+       as do the corresponding vertices of fv. */
+    for (i = 0; fv->vertex[i] != e->endpts[0]; ++i) ;
+    /* Orient f the same as fv. */
+    if (fv->vertex[(i + 1) % 3] != e->endpts[1]) {
+	f->vertex[0] = e->endpts[1];
+	f->vertex[1] = e->endpts[0];
+    else {
+	f->vertex[0] = e->endpts[0];
+	f->vertex[1] = e->endpts[1];
+	SWAP(s, f->edge[1], f->edge[2]);
+    /* This swap is tricky. e is edge[0]. edge[1] is based on endpt[0],
+       edge[2] on endpt[1].  So if e is oriented "forwards," we
+       need to move edge[1] to follow [0], because it precedes. */
+    f->vertex[2] = p;
+MakeNullEdge creates a new cell and initializes all pointers to NULL
+and sets all flags to off.  It returns a pointer to the empty cell.
+    tEdge e;
+    NEW(e, tsEdge);
+    e->adjface[0] = e->adjface[1] = e->newface = NULL;
+    e->endpts[0] = e->endpts[1] = NULL;
+    e->delete = !REMOVED;
+    ADD(edges, e);
+    return e;
+MakeNullFace creates a new face structure and initializes all of its
+flags to NULL and sets all the flags to off.  It returns a pointer
+to the empty cell.
+    tFace f;
+    int i;
+    NEW(f, tsFace);
+    for (i = 0; i < 3; ++i) {
+	f->edge[i] = NULL;
+	f->vertex[i] = NULL;
+    f->visible = !VISIBLE;
+    ADD(faces, f);
+    return f;
+MakeFace creates a new face structure from three vertices (in ccw
+order).  It returns a pointer to the face.
+tFace MakeFace(tVertex v0, tVertex v1, tVertex v2, tFace fold)
+    tFace f;
+    tEdge e0, e1, e2;
+    /* Create edges of the initial triangle. */
+    if (!fold) {
+	e0 = MakeNullEdge();
+	e1 = MakeNullEdge();
+	e2 = MakeNullEdge();
+    else {			/* Copy from fold, in reverse order. */
+	e0 = fold->edge[2];
+	e1 = fold->edge[1];
+	e2 = fold->edge[0];
+    e0->endpts[0] = v0;
+    e0->endpts[1] = v1;
+    e1->endpts[0] = v1;
+    e1->endpts[1] = v2;
+    e2->endpts[0] = v2;
+    e2->endpts[1] = v0;
+    /* Create face for triangle. */
+    f = MakeNullFace();
+    f->edge[0] = e0;
+    f->edge[1] = e1;
+    f->edge[2] = e2;
+    f->vertex[0] = v0;
+    f->vertex[1] = v1;
+    f->vertex[2] = v2;
+    /* Link edges to face. */
+    e0->adjface[0] = e1->adjface[0] = e2->adjface[0] = f;
+    return f;
+CleanUp goes through each data structure list and clears all
+flags and NULLs out some pointers.  The order of processing
+(edges, faces, vertices) is important.
+void CleanUp(void)
+    CleanEdges();
+    CleanFaces();
+    CleanVertices();
+CleanEdges runs through the edge list and cleans up the structure.
+If there is a newface then it will put that face in place of the
+visible face and NULL out newface. It also deletes so marked edges.
+    tEdge t;			/* Temporary edge pointer. */
+    /* Integrate the newface's into the data structure. */
+    /* Check every edge. */
+    e = edges;
+    do {
+	if (e->newface) {
+		e->adjface[0] = e->newface;
+	    else
+		e->adjface[1] = e->newface;
+	    e->newface = NULL;
+	e = e->next;
+    /* Delete any edges marked for deletion. */
+    while (edges && edges->delete) {
+	e = edges;
+	DELETE(edges, e);
+    e = edges->next;
+    do {
+	if (e->delete) {
+	    t = e;
+	    e = e->next;
+	    DELETE(edges, t);
+	else
+	    e = e->next;
+CleanFaces runs through the face list and deletes any face marked visible.
+    tFace t;			/* Temporary pointer, for deleting. */
+    while (faces && faces->visible) {
+	f = faces;
+	DELETE(faces, f);
+    f = faces->next;
+    do {
+	if (f->visible) {
+	    t = f;
+	    f = f->next;
+	    DELETE(faces, t);
+	else
+	    f = f->next;
+CleanVertices runs through the vertex list and deletes the
+vertices that are marked as processed but are not incident to any
+undeleted edges.
+    tEdge e;
+    tVertex v, t;
+    /* Mark all vertices incident to some undeleted edge as on the hull. */
+    e = edges;
+    do {
+	e->endpts[0]->onhull = e->endpts[1]->onhull = ONHULL;
+	e = e->next;
+    /* Delete all vertices that have been processed but
+       are not on the hull. */
+    while (vertices && vertices->mark && !vertices->onhull) {
+	v = vertices;
+    v = vertices->next;
+    do {
+	if (v->mark && !v->onhull) {
+	    t = v;
+	    v = v->next;
+	    DELETE(vertices, t)
+	else
+	    v = v->next;
+    /* Reset flags. */
+    v = vertices;
+    do {
+	v = v->next;
+Collinear checks to see if the three points given are collinear,
+by checking to see if each element of the cross product is zero.
+    return
+	(c->v[Z] - a->v[Z]) * (b->v[Y] - a->v[Y]) -
+	(b->v[Z] - a->v[Z]) * (c->v[Y] - a->v[Y]) == 0
+	&& (b->v[Z] - a->v[Z]) * (c->v[X] - a->v[X]) -
+	(b->v[X] - a->v[X]) * (c->v[Z] - a->v[Z]) == 0
+	&& (b->v[X] - a->v[X]) * (c->v[Y] - a->v[Y]) -
+	(b->v[Y] - a->v[Y]) * (c->v[X] - a->v[X]) == 0;
+Consistency runs through the edge list and checks that all
+adjacent faces have their endpoints in opposite order.  This verifies
+that the vertices are in counterclockwise order.
+    register tEdge e;
+    register int i, j;
+    e = edges;
+    do {
+	/* find index of endpoint[0] in adjacent face[0] */
+	for (i = 0; e->adjface[0]->vertex[i] != e->endpts[0]; ++i) ;
+	/* find index of endpoint[0] in adjacent face[1] */
+	for (j = 0; e->adjface[1]->vertex[j] != e->endpts[0]; ++j) ;
+	/* check if the endpoints occur in opposite order */
+	if (!(e->adjface[0]->vertex[(i + 1) % 3] ==
+	      e->adjface[1]->vertex[(j + 2) % 3] ||
+	      e->adjface[0]->vertex[(i + 2) % 3] ==
+	      e->adjface[1]->vertex[(j + 1) % 3]))
+	    break;
+	e = e->next;
+    if (e != edges)
+	fprintf(stderr, "Checks: edges are NOT consistent.\n");
+    else
+	fprintf(stderr, "Checks: edges consistent.\n");
+Convexity checks that the volume between every face and every
+point is negative.  This shows that each point is inside every face
+and therefore the hull is convex.
+    register tFace f;
+    register tVertex v;
+    long int vol;
+    f = faces;
+    do {
+	v = vertices;
+	do {
+	    if (v->mark) {
+		vol = VolumeSign(f, v);
+		if (vol < 0)
+		    break;
+	    v = v->next;
+	f = f->next;
+    if (f != faces)
+	fprintf(stderr, "Checks: NOT convex.\n");
+    else if (check)
+	fprintf(stderr, "Checks: convex.\n");
+CheckEuler checks Euler's relation, as well as its implications when
+all faces are known to be triangles.  Only prints positive information
+when debug is true, but always prints negative information.
+    if (check)
+	fprintf(stderr, "Checks: V, E, F = %li %li %li:\t", V, E, F);
+    if ((V - E + F) != 2)
+	fprintf(stderr, "Checks: V-E+F != 2\n");
+    else if (check)
+	fprintf(stderr, "V-E+F = 2\t");
+    if (F != (2 * V - 4))
+	fprintf(stderr, "Checks: F=%li != 2V-4=%li; V=%li\n",
+		F, 2 * V - 4, V);
+    else if (check)
+	fprintf(stderr, "F = 2V-4\t");
+    if ((2 * E) != (3 * F))
+	fprintf(stderr, "Checks: 2E=%li != 3F=%li; E=%li, F=%li\n",
+		2 * E, 3 * F, E, F);
+    else if (check)
+	fprintf(stderr, "2E = 3F\n");
+void Checks(void)
+    tVertex v;
+    tEdge e;
+    tFace f;
+    Consistency();
+    Convexity();
+    if (v = vertices)
+	do {
+	    if (v->mark)
+		V++;
+	    v = v->next;
+    if (e = edges)
+	do {
+	    E++;
+	    e = e->next;
+    if (f = faces)
+	do {
+	    F++;
+	    f = f->next;
+These functions are used whenever the debug flag is set.
+They print out the entire contents of each data structure.
+Printing is to standard error.  To grab the output in a file in the csh,
+use this:
+	chull < i.file >&! o.file
+    fprintf(stderr, "\nHead vertex %d = %6x :\n", v->vnum, (unsigned int)v);
+    PrintVertices();
+    PrintEdges();
+    PrintFaces();
+    tVertex temp;
+    temp = vertices;
+    fprintf(stderr, "Vertex List\n");
+    if (vertices)
+	do {
+	    fprintf(stderr, "  addr %6x\t", (unsigned int)vertices);
+	    fprintf(stderr, "  vnum %4d", vertices->vnum);
+	    fprintf(stderr, "   (%6li,%6li,%6li)", vertices->v[X],
+		    vertices->v[Y], vertices->v[Z]);
+	    fprintf(stderr, "   active:%3d", vertices->onhull);
+	    fprintf(stderr, "   dup:%5x", (unsigned int)vertices->duplicate);
+	    fprintf(stderr, "   mark:%2d\n", vertices->mark);
+	    vertices = vertices->next;
+	} while (vertices != temp);
+    tEdge temp;
+    int i;
+    temp = edges;
+    fprintf(stderr, "Edge List\n");
+    if (edges)
+	do {
+	    fprintf(stderr, "  addr: %6x\t", (unsigned int)edges);
+	    fprintf(stderr, "adj: ");
+		fprintf(stderr, "%6x", (unsigned int)edges->adjface[i]);
+	    fprintf(stderr, "  endpts:");
+		fprintf(stderr, "%4d", edges->endpts[i]->vnum);
+	    fprintf(stderr, "  del:%3d\n", edges->delete);
+	    edges = edges->next;
+	} while (edges != temp);
+    int i;
+    tFace temp;
+    temp = faces;
+    fprintf(stderr, "Face List\n");
+    if (faces)
+	do {
+	    fprintf(stderr, "  addr: %6x\t", (unsigned int)faces);
+	    fprintf(stderr, "  edges:");
+		fprintf(stderr, "%6x", (unsigned int)faces->edge[i]);
+	    fprintf(stderr, "  vert:");
+		fprintf(stderr, "%4d", faces->vertex[i]->vnum);
+	    fprintf(stderr, "  vis: %d\n", faces->visible);
+	    faces = faces->next;
+	} while (faces != temp);
Property changes on: grass-addons/grass7/raster/r.vol.dem/chull.c
___________________________________________________________________
Added: svn:mime-type
   + text/x-csrc
Added: svn:eol-style
   + native
Added: grass-addons/grass7/raster/r.vol.dem/chull.h
--- grass-addons/grass7/raster/r.vol.dem/chull.h	                        (rev 0)
+++ grass-addons/grass7/raster/r.vol.dem/chull.h	2012-04-24 21:23:22 UTC (rev 51526)
@@ -0,0 +1,2 @@
+int make3DHull(long int *X, long int *Y, long int *Z, int num_points,
+	       FILE * tmpfile);
Property changes on: grass-addons/grass7/raster/r.vol.dem/chull.h
   + text/x-chdr
   + native
Added: grass-addons/grass7/raster/r.vol.dem/globals.h
--- grass-addons/grass7/raster/r.vol.dem/globals.h	                        (rev 0)
+++ grass-addons/grass7/raster/r.vol.dem/globals.h	2012-04-24 21:23:22 UTC (rev 51526)
@@ -0,0 +1,40 @@
+#ifndef GLOBAL_H
+#define GLOBAL_H
+#define PROGVERSION 0.55
+#define PROGNAME "r.vol.dem"
+/* if DEBUG > 1 we will dump even more details */
+#define DEBUG 0
+/* NULL valued cells */
+#define NULLVALUE -1
+/* masked cells */
+#define MASKVALUE -2
+/* unset cells */
+#define UNSET -3
+/* value to represent NULL in VTK files */
+#define DNULLVALUE -99999.99
+#define TMPFILE "voxeltmp.tmp"
+#ifdef MAIN
+/* number of decimal places with which coordinates are stored */
+double PRECISION;
+/* verbose output includes progress display */
+int VERBOSE;
+/* number of DEMs in the input */
+int NSLICES;
+#else
+extern double PRECISION;
+extern int VERBOSE;
+extern int NSLICES;
+#endif /* MAIN */
+#endif /* GLOBAL_H */
Property changes on: grass-addons/grass7/raster/r.vol.dem/globals.h
   + text/x-chdr
   + native
Added: grass-addons/grass7/raster/r.vol.dem/macros.h
--- grass-addons/grass7/raster/r.vol.dem/macros.h	                        (rev 0)
+++ grass-addons/grass7/raster/r.vol.dem/macros.h	2012-04-24 21:23:22 UTC (rev 51526)
@@ -0,0 +1,39 @@
+    macros.h
+ 	macros used to access data structures and perform quick tests.
+/* general-purpose macros */
+#define SWAP(t,x,y)	{ t = x; x = y; y = t; }
+#define NEW(p,type)	if ((p=(type *) malloc (sizeof(type))) == NULL) {\
+				printf ("Out of Memory!\n");\
+				exit(0);\
+#define FREE(p)		if (p) { free ((char *) p); p = NULL; }
+#define ADD( head, p )  if ( head )  { \
+				p->next = head; \
+				p->prev = head->prev; \
+				head->prev = p; \
+				p->prev->next = p; \
+			else { \
+				head = p; \
+				head->next = head->prev = p; \
+#define DELETE( head, p ) if ( head )  { \
+				if ( head == head->next ) \
+					head = NULL;  \
+				else if ( p == head ) \
+					head = head->next; \
+				p->next->prev = p->prev;  \
+				p->prev->next = p->next;  \
+				FREE( p ); \
Property changes on: grass-addons/grass7/raster/r.vol.dem/macros.h
   + text/x-chdr
   + native
Added: grass-addons/grass7/raster/r.vol.dem/main.c
--- grass-addons/grass7/raster/r.vol.dem/main.c	                        (rev 0)
+++ grass-addons/grass7/raster/r.vol.dem/main.c	2012-04-24 21:23:22 UTC (rev 51526)
@@ -0,0 +1,1445 @@
+/* r.vol.dem */
+/* Purpose: Interpolate a voxel model from a series of DEMs by flood filling the voxel space in between. */
+/* TODO:
+   BUG: output_ascii_points (): when option -f is given, the v.in.ascii module aborts with an error message!
+   strangely, if you copy and paste the line from the tmpfile, which is exactly the same syntax,
+   it works! (???)
+   - fix warnings and license issues for chull.c (provide complete copy of the original sources)
+   - tempfiles
+   this program leaves lots of them around right now ...
+   - cell counts: AVOID counting cells twice for layers that have the same label!
+   - USER MAN PAGE:
+   filling up or down does not make a difference in volume, unless -f option is also given!
+   BUT: it makes a difference in the labeling of layers:
+   When filling down, the bottom DEM
+   is interpreted as the last boundary of a layer and is thus assigned an individual label
+   When fillin up, the top DEM
+   Where this is undesirable, boundaries can be dissolved by giving them identical labels using the labels= option!
+   Visible differences in Paraview are due to rounding effects in the software. Displaying points in NVIZ will show you
+   that both data sets are the same [check if this ist true: same number of points in both cases?]
+   Vector hulls are currently very rough approximations with lots of shortcomings
+   Layers are numbered from bottom to top : 0 .. n
+   DEMs have to be given from bottom to top as well. Order matters!
+   - LICENSE ISSUES with convex hull 3D code !(?): include at least a full version of original chull.c and add some comments!
+   - also replace warinng messages (e.g. all points colinear) with own versions.
+   - make clean and get rid of compiler warnings
+   in a first pass, that can also be disabled by the user
+   - check for overlaps
+   in a second pass, to be optionally enabled by user:
+   - create a 0/1 mask file for each DEM to mask
+   out interpolation for edges that are not straight
+   - fuzzy layer boundaries (!)
+   - in mode -f revert interpolation direction once at the end to make sure everything gets filled (?)!
+   - maybe as a separate option -r if it will be good for anything
+   - standard options for voxels (data type ...)
+   - automatically adjust 3D region to fit full DEM data (x,y,z)
+   - output a map that shows areas with topologic problems. User can overlay all DEMs and this map and query for problems.
+   Map will contain highest ID of the DEM(s)
+   that caused a problem here. After clearing all problems, user might have to generate another map with errors from lower ID DEMs ...
+   [DONE BUT UNTESTED]
+   - DNULLVALUE needs to be adjustable, also many other vars in globals.h: PRECISION, TMPFILE, ...
+   - EXPORTS: switch all export functions away from ASCII bridge:
+   3D vector hulls output:
+   - export 3D vector hulls into one GRASS bin file and create proper attribute table
+   - 3D vector hulls don't overlap nicely, because the points are in the voxel centers.
+   all hull points have to be extruded half a voxel size into normal direction!
+   - layers with all points on one voxel plane do not get turned into a hull currently!
+   - RRR:GGG:BBB color option for each layer
+   voxel output:
+   - add history information
+   - a category number for each DEM (3d raster cats?)
+   - surface smoothing for VTK file output
+   smoothing surfaces for VTK-output with top= and bottom= options (r3.out.vtk) smoothes all surfaces by degrees!
+   - more progress indicators in export functions!  [lots done but test what it looks like]
+   - implement quite operation: most messages don't respect VERBOSE! [lots done, but needs testing]
+   - v.in.ascii now takes --o for overwrite. Since when?
+#define MAIN
+#include <stdio.h>
+#include <errno.h>
+#include <string.h>
+#include <math.h>
+#include <time.h>
+#include <grass/raster3d.h>
+#include <grass/glocale.h>
+#include "chull.h"
+   GLOBAL DECLARATIONS
+/* by making this global, all func's will have access to module options and flags */
+struct
+    struct Option *maps;	/* raster DEM(s) to work on */
+    struct Option *output;	/* output rast3d map */
+    struct Option *values;	/* specify the value that each layer represents */
+    struct Option *colors;	/* RRR:GGG:BBB triplets for each layer */
+    struct Option *error;	/* raster map to represent topology errors in input DEMs */
+    struct Option *algorithm;	/* choose interpolation algorithm */
+parm;
+struct
+    struct Flag *countcells;	/* calculate 3D cell stats for each layer */
+    struct Flag *fillnull;	/* fill NULL areas in input DEMs from above or below */
+    struct Flag *hull;		/* export a 3D hull polygon for every layer */
+    struct Flag *grasspts;	/* produce a GRASS points vector file */
+    struct Flag *points;	/* produce VTK point data instead of cells */
+    struct Flag *quiet;		/* no status display on screen */
+    struct Flag *skip;		/* start interpolation even if topology errors were detected */
+    struct Flag *vtk;		/* generate a VTK file */
+    struct Flag *zadjust;	/* adjust z range of current region to fit DEM data */
+flag;
+   UTILITY FUNCTIONS
+/* returns 1 if the integer is a DEM ID, not a MASKED or NULL value or UNSET,
+   0 otherwise */
+int isValue(int val)
+    if (val == UNSET) {
+	return (0);
+    if (val == NULLVALUE) {
+	return (0);
+    if (val == MASKVALUE) {
+	return (0);
+    return (1);
+int isUnset(int val)
+	return (1);
+    return (0);
+int isMask(int val)
+	return (1);
+    return (0);
+int isNull(int val)
+	return (1);
+    return (0);
+/* returns 1 if the string contains a valid RRR:GGG:BBB color triplet,
+   0 otherwise
+   IF the string is valid, the R, G and B levels (0-255) will be
+   stored at the int pointers (NULL otherwise)
+int isRGB(char *triplet, unsigned short int *R, unsigned short int *G,
+	  unsigned short int *B)
+    R = NULL;
+    G = NULL;
+    B = NULL;
+    return (0);
+   Z-RANGE AND TOPOLOGY CHECKING
+/* checks if a DEM value intersects a voxel at a given depth */
+/* depth goes from 0 (bottom voxel) to slices-1 (top voxel) */
+/* returns 1 if DEM intersects, 0 if not */
+/* if a DEM intersects the top surface of a voxel, that counts as */
+/* a cut, the bottom does not. */
+int cut(DCELL val, int depth, struct Cell_head window)
+    if (DEBUG > 2) {
+	fprintf(stdout, "CUT: %.3f at depth %i", (double)val, depth);
+    if ((val > (window.bottom + depth * window.tb_res)) &&
+	(val < (window.bottom + (depth + 1) * window.tb_res))) {
+	if (DEBUG > 2) {
+	    fprintf(stdout, " = YES\n");
+	return (1);
+    if (val == window.bottom + (depth + 1) * window.tb_res) {
+	if (DEBUG > 1) {
+	return (1);
+    if (DEBUG > 2) {
+	fprintf(stdout, " = NO\n");
+    return (0);
+/* Adjust the ACTIVE region's Z range so that it will be big enough for the
+   highest and lowest point in the input DEMs.
+   This setting will stay in effect even after r.vol.dem exits!
+void adjust_zrange(void)
+    fprintf(stderr, "DEBUG: Adjustment of Z range not implemented yet.\n");
+    return;
+/* check if DEMs are within z-range of current 3d region */
+void check_zrange(int *fd, DCELL ** dcell, int nfiles)
+    struct Cell_head window;
+    int i;
+    int row, col, nrows, ncols;
+    double top, bottom;
+    int topDEM, bottomDEM;
+    nrows = Rast_window_rows();
+    ncols = Rast_window_cols();
+    G_get_window(&window);
+    if (flag.zadjust->answer) {
+	adjust_zrange();
+	fprintf(stderr, "DEBUG: Insert a return() statement here.\n");
+    if (VERBOSE)
+	fprintf(stdout, " Z-range checking, pass 1: \n");
+    /* get maximum and minimum elevation from all DEMs */
+    row = 0;
+    if (Rast_get_d_row(fd[0], dcell[0], row) < 0) {
+	G_fatal_error(_("Could not read row number %i from map %s."), row,
+		      parm.maps->answers[0]);
+    top = dcell[0][0];
+    topDEM = 0;
+    for (i = 0; i < nfiles; i++) {
+	for (row = 0; row < nrows; row++) {
+	    if (Rast_get_d_row(fd[i], dcell[i], row) < 0) {
+			      row, parm.maps->answers[i]);
+	    for (col = 0; col < ncols; col++) {
+		if (dcell[i][col] > top) {
+		    top = dcell[i][col];
+		    topDEM = i;
+	G_percent(i, (nfiles - 1), 1);
+    fflush(stdout);
+    if (DEBUG)
+	fprintf(stdout, "TOP = %.2f in %s\n", top,
+		parm.maps->answers[topDEM]);
+    if (VERBOSE)
+	fprintf(stdout, " z-range-checking, pass 2: \n");
+    row = 0;
+    bottom = dcell[0][0];
+    bottomDEM = 0;
+		if (dcell[i][col] < bottom) {
+		    bottom = dcell[i][col];
+		    bottomDEM = i;
+    fflush(stdout);
+    if (DEBUG)
+	fprintf(stdout, "BOTTOM = %.2f in %s\n", bottom,
+		parm.maps->answers[bottomDEM]);
+    if (top > window.top) {
+	G_fatal_error(_("Highest DEM value (%.3f in %s) outside extent of current 3d region (top=%.3f) "),
+		      top, parm.maps->answers[topDEM], window.top);
+    if (bottom < window.bottom) {
+	G_fatal_error(_("Lowest DEM value (%.3f in %s) outside extent of current 3d region (bottom=%.3f) "),
+		      bottom, parm.maps->answers[bottomDEM], window.bottom);
+    return;
+void check_topologies(int *fd, DCELL ** dcell, int nfiles)
+    int i, j;
+    int nerrors;
+    CELL **c_error = NULL;
+    int f_error = 0;
+    if (VERBOSE)
+	fprintf(stdout, " Checking DEM topologies: \n");
+    nerrors = 0;
+    Rast_get_window(&window);
+    /* does the user want a topology error map? */
+    /* if so, we need to alloc mem and create a new CELL map */
+    if (parm.error->answer != NULL) {
+	/* KILL ME */
+	fprintf(stderr,
+		"DEBUG: Topology error mapping is an untested feature.\n");
+	/* KILL ME */
+	c_error = (CELL **) G_malloc(nrows * sizeof(CELL *));
+	    c_error[row] = Rast_allocate_c_buf();
+	f_error = Rast_open_new(parm.error->answer, CELL_TYPE);
+	if (f_error < 0) {
+	    G_fatal_error
+		("Could not create new CELL raster map for mapping topology errors.");
+	/* initialise error map */
+	    Rast_set_c_null_value(&c_error[row][0], ncols);
+		/* check for undershoots from DEMs above */
+		for (j = i + 1; j < nfiles; j++) {
+		    if (dcell[j][col] <= dcell[i][col]) {
+			/* UNDERSHOOT */
+			G_warning(_("Z value in %s undershoots Z value in %s at cells %i,%i, \ncoordinates: E=%f, N=%f.\n"),
+				  parm.maps->answers[j],
+				  parm.maps->answers[i], col, row,
+				  Rast_col_to_easting((double)col, &window),
+				  Rast_row_to_northing((double)row, &window)
+			nerrors++;
+			    c_error[row][col] = j;
+		/* check for overshoots from DEMs below */
+		for (j = i - 1; j >= 0; j--) {
+		    if (dcell[j][col] >= dcell[i][col]) {
+			/* OVERSHOOT! */
+			G_warning(_("Z value in %s overshoots Z value in %s at cells %i,%i, \ncoordinates: E=%f, N=%f.\n"),
+			nerrors++;
+	if (VERBOSE)
+	    G_percent(row, (nrows - 1), 2);
+    fflush(stdout);
+	    Rast_put_c_row(f_error, c_error[row]);
+	Rast_close(f_error);
+    if (nerrors > 0) {
+	G_fatal_error(_("Found %i errors in DEM topology! Aborting."),
+		      nerrors);
+    return;
+   CORE INTERPOLATION ROUTINES
+void interpolate_up(int *flist, DCELL ** dcell, int col, int nfiles)
+    int fillval;
+    double level;
+    double stopat;
+    int i, j, k;
+    int DEMAbove;
+    int highestDEMValue;
+    /* DEMs must be provided in this order: bottom,...,top ... */
+    for (i = 0; i < NSLICES; i++) {
+	/* ... the interpolated column, however, has its lowest value */
+	/* at the bottom (last element of array), so that order needs to be switched! */
+	flist[(NSLICES - 1) - i] = NULLVALUE;	/* NULLVALUE = no DEM cuts at this point */
+	for (j = 0; j < nfiles; j++) {
+	    if (!Rast_is_d_null_value(&dcell[j][col])) {	/* SKIP NULL VALUED CELLS */
+		if (cut(dcell[j][col], i, window)) {
+		    flist[(NSLICES - 1) - i] = j;
+    /* interpolate one column by 'flood filling' DEM values up from the bottom */
+    fillval = flist[0];
+    /* first we need to know where to stop the interpolation ! */
+    /* find the highest DEM that has a data value at this point! */
+    highestDEMValue = -1;
+    i = (nfiles - 1);
+    while ((i >= 0) && (highestDEMValue == -1)) {
+	if (!Rast_is_d_null_value(&dcell[i][col])) {
+	    highestDEMValue = i;
+	i--;
+    i++;
+    if (highestDEMValue == -1) {
+	/* there is no DEM with any data at this point ! */
+	stopat = window.bottom - 1;	/* this will prevent any interpolation from happening here ! */
+    else {
+	/* we found a DEM with a value ... */
+	if (highestDEMValue == (nfiles - 1)) {
+	    /* ... and it is the top one, so we just set this as interpolation stop */
+	    stopat = dcell[(nfiles - 1)][col];
+	else {
+	    /* ... but it is not the top one, so we need to decide what to do */
+	    if (flag.fillnull->answer) {
+		/* this flag forces us to keep filling (all the way up to the top of the current 3D region) */
+		stopat = window.top;
+	    else {
+		/* we will only fill up to the highest DEM with a value */
+		/* but we make sure to fill up at least one slice ! */
+		stopat =
+		    dcell[highestDEMValue][col] + (window.tb_res +
+						   (window.tb_res * 0.5));
+    if (DEBUG > 1) {
+	fprintf(stderr, "  STOPAT = %.2f\n", stopat);
+    for (i = (NSLICES - 1); i >= 0; i--) {
+	if (isValue(flist[i])) {
+	    /* check, if there is another DEM cutting point above this slice */
+	    /* if not, only keep filling, if flag -f has been set ! */
+		fillval = flist[i];
+	    else {
+		DEMAbove = 0;
+		for (k = i; k >= 0; k--) {
+		    if (isValue(flist[k])) {
+			DEMAbove = 1;
+		if (DEMAbove) {
+	else {
+	    /* check if we are still below top level */
+	    level = window.bottom + (((NSLICES - 1) - i) * window.tb_res);
+	    if (level < stopat) {
+		flist[i] = fillval;
+	    else {
+		flist[i] = NULLVALUE;
+    return;
+void interpolate_down(int *flist, DCELL ** dcell, int col, int nfiles)
+    int fillval;
+    double level;
+    double stopat = 0.0;
+    int i, j, k;
+    int DEMBelow;
+    int lowestDEMValue;
+	/* at the bottom, so that order needs to be switched! */
+    /* interpolate one column by 'flood filling' DEM values down from the top */
+    /* find the lowest DEM that has a data value at this point! */
+    lowestDEMValue = -1;
+    i = 0;
+    while ((i < nfiles) && (lowestDEMValue == -1)) {
+	    lowestDEMValue = i;
+	i++;
+    i--;
+    if (lowestDEMValue == -1) {
+	stopat = window.top + 1;	/* this will prevent any interpolation from happening here ! */
+    else {
+	if (lowestDEMValue == 0) {
+	    /* ... and it is the bottom one, so we just set this as interpolation stop */
+	    stopat = dcell[0][col];
+	else {
+	    /* ... but it is not the bottom one, so we need to decide what to do */
+		/* this flag forces us to keep filling (all the way down to the bottom of the current 3D region) */
+		stopat = window.bottom;
+	    else {
+		/* we will only fill down to the lowest DEM with a value */
+		/* but we make sure to fill down at least one slice ! */
+		stopat =
+		    dcell[lowestDEMValue][col] - (window.tb_res +
+    if (DEBUG > 1) {
+    for (i = 1; i < NSLICES; i++) {
+	    /* check, if there is another DEM cutting point below this slice */
+	    else {
+		DEMBelow = 0;
+		for (k = i; k <= NSLICES; k++) {
+			DEMBelow = 1;
+		if (DEMBelow) {
+	else {
+	    /* check if we are still above bottom level */
+	    if (level >= stopat) {
+	    else {
+    return;
+void interpolate(int *fd, DCELL ** dcell, int nfiles, int nvalues,
+		 double ***ascii)
+    int *flist;
+    int i;
+    flist = G_malloc(sizeof(int) * NSLICES);
+    if (VERBOSE)
+	fprintf(stdout, "\nInterpolating: \n");
+	/* read one row from all layers */
+	    if (!strcmp(parm.algorithm->answer, "up")) {
+		interpolate_up(flist, dcell, col, nfiles);
+	    if (!strcmp(parm.algorithm->answer, "down")) {
+		interpolate_down(flist, dcell, col, nfiles);
+		    if (nvalues == 0) {
+			/* either enumerate layers from 0 .. n */
+			ascii[i][row][col] = (double)(flist[i]);
+		    else {
+			/* OR write user-provided values for layers? */
+			    atof(parm.values->answers[flist[i]]);
+		else {
+		    /* write a NULL valued voxel */
+		    ascii[i][row][col] = DNULLVALUE;
+	    if (DEBUG > 1) {
+		fprintf(stdout, "col %i (", col);
+			fprintf(stdout, "%i ", flist[i]);
+		    if (isNull(flist[i])) {
+			fprintf(stdout, "N ");
+		    if (isMask(flist[i])) {
+			fprintf(stdout, "M ");
+		fprintf(stdout, ")\n");
+	if (VERBOSE) {
+	    G_percent(row, nrows - 1, 2);
+	if (DEBUG > 1)
+	    fprintf(stdout, "row=%i\n", row);
+    fprintf(stdout, "\n");
+    fflush(stdout);
+   DATA OUTPUT AND EXPORT
+void count_3d_cells(double ***ascii, int nfiles, int nvalues)
+    int a, i, j, k;
+    unsigned long int sum;
+    int nrows, ncols;
+    fprintf(stdout, "\nCell counts: \n");
+    for (a = 0; a < nfiles; a++) {
+	sum = 0;
+	    for (j = 0; j < nrows; j++) {
+		for (k = 0; k < ncols; k++) {
+			if (a == (int)ascii[i][j][k]) {
+			    sum++;
+		    else {
+			if (atof(parm.values->answers[a]) == ascii[i][j][k]) {
+			    sum++;
+	    fprintf(stdout, "  Layer %i has %li 3D cells\n", a, sum);
+	else {
+	    fprintf(stdout, "  Layer %i (label=%f) has %li 3D cells\n", a,
+		    atof(parm.values->answers[a]), sum);
+void output_ascii(double ***ascii)
+    int i, j, k;
+    int nrows, ncols;
+    FILE *tmpfile;
+    /* open a tmp file for writing ascii output data */
+    tmpfile = fopen(TMPFILE, "w+");
+    if (tmpfile == NULL) {
+	G_fatal_error(_("Could not create temporary file for writing ASCII output (%s)"),
+		      TMPFILE);
+    /* write output to ASCII file */
+    fprintf(tmpfile, "north: %f\n", window.north);
+    fprintf(tmpfile, "south: %f\n", window.south);
+    fprintf(tmpfile, "east: %f\n", window.east);
+    fprintf(tmpfile, "west: %f\n", window.west);
+    fprintf(tmpfile, "top: %f\n", window.top);
+    fprintf(tmpfile, "bottom: %f\n", window.bottom);
+    fprintf(tmpfile, "rows: %i\n", nrows);
+    fprintf(tmpfile, "cols: %i\n", ncols);
+    fprintf(tmpfile, "levels:%i\n", NSLICES);
+		/* below is the correct data order for Paraview and GRASS rast3d ASCII files ! */
+		fprintf(tmpfile, "%f ",
+			ascii[(NSLICES - 1) - i][(nrows - 1) - j][k]);
+	    fprintf(tmpfile, "\n");
+    fclose(tmpfile);
+void output_ascii_points(double ***ascii)
+    int i, j, k;
+    int nrows, ncols;
+    FILE *tmpfile;
+    char tmp[2048];
+    double x, y, z, w;
+    int error;
+    sprintf(tmp, "%s.points.txt", parm.output->answer);
+    tmpfile = fopen(tmp, "w+");
+		      tmp);
+    fprintf(tmpfile, "# Simple 3D vector points file.\n");
+    fprintf(tmpfile, "# This file was created by %s version %.2f \n",
+	    PROGNAME, PROGVERSION);
+    fprintf(tmpfile, "# Tab delimited point data: x, y, z, value. \n");
+    fprintf(tmpfile, "# Import into GRASS GIS using this command:\n");
+    fprintf(tmpfile,
+	    "#   v.in.ascii in=%s.points.txt out=%s -z x=1 y=2 z=3 cat=0 columns='x double, y double, z double, w double' fs=tab\n",
+	    parm.output->answer, parm.output->answer);
+		/* coordinates for points will be centers of 3D raster cells ! */
+		/* only produce points at non-NULL locations ! */
+		w = ascii[i][(nrows - 1) - j][k];
+		if (w != DNULLVALUE) {
+		    x = window.west + (window.ew_res * k) +
+			(window.ew_res * 0.5);
+		    y = window.south + (window.ns_res * j) +
+			(window.ns_res * 0.5);
+		    z = window.top - (window.tb_res * i) -
+			(window.tb_res * 0.5);
+		    fprintf(tmpfile, "%.6f\t%.6f\t%.6f\t%.6f\n", x, y, z, w);
+    if (VERBOSE) {
+	fprintf(stdout, "\nRunning v.in.ascii to create 3D points map: \n");
+    /* TODO: KILL THIS AND REPLACE WITH NEAT --o OPTION CHECK */
+    /* remove output map, if exists */
+    sprintf(tmp, "g.remove vect=%s", parm.output->answer);
+    error = system(tmp);
+    if (error != EXIT_SUCCESS) {
+	G_fatal_error("Error running command: %s", tmp);
+    /* call v.in.ascii to make GRASS native vector map */
+    sprintf(tmp,
+	    "v.in.ascii in=%s.points.txt out=%s -z x=1 y=2 z=3 cat=0 columns='x double, y double, z double, w double' fs=tab\n",
+    if (VERBOSE)
+	fprintf(stdout, " DONE \n");
+    fclose(tmpfile);
+void output_ascii_hulls(double ***ascii, int nvalues, int nfiles)
+    int i, j, k, l;
+    double label;
+    int num_points;
+    int nrows, ncols;
+    FILE *tmpfile;
+    char tmp[2048];
+    double w;
+    long int *px;
+    long int *py;
+    long int *pz;
+    int curPoint;
+    int error;
+    /* MAIN LOOP START */
+    /* do this vor every layer, i.e. all 3D cells with the same label */
+    for (l = 0; l < nfiles; l++) {
+	/* open tmp file for writing ascii output data */
+	sprintf(tmp, "%s.hull.%i.txt", parm.output->answer, l);
+			  tmp);
+	    /* either enumerate layers from 0 .. (nfiles-1) */
+	    label = (double)l;
+	else {
+	    /* OR use user-provided values for layers? */
+	    label = atof(parm.values->answers[l]);
+	num_points = 0;
+	/* create arrays large enough to store all points of the current layer */
+		    w = ascii[i][j][k];
+		    if (w == label) {
+			num_points++;
+	if (DEBUG) {
+	    fprintf(stderr, "EXPORT HULLS: %i points with label %.6f\n",
+		    num_points, label);
+	px = (long int *)malloc(num_points * sizeof(long int));
+	py = (long int *)malloc(num_points * sizeof(long int));
+	pz = (long int *)malloc(num_points * sizeof(long int));
+	/* pick points with current label from ASCII array */
+	curPoint = 0;
+		    /* we have to store them as int values for performance reasons, so we will multiply by PRECISION */
+		    /* PRECISION = 1000 = 10^3 = 3 decimal places precision! */
+		    if (w == label) {
+			px[curPoint] =
+			    ((long int)window.west + (window.ew_res * k)
+			     + (window.ew_res * 0.5)) * (PRECISION);
+			py[curPoint] =
+			    ((long int)window.south + (window.ns_res * j)
+			     + (window.ns_res * 0.5)) * (PRECISION);
+			pz[curPoint] =
+			    ((long int)window.top - (window.tb_res * i)
+			     - (window.tb_res * 0.5)) * (PRECISION);
+			curPoint++;
+	if (VERBOSE) {
+	    fprintf(stdout, "\nExporting 3D convex hull for layer %i: \n", l);
+	/* make 3D hull */
+	error = make3DHull(px, py, pz, num_points, tmpfile);
+	if (error < 0) {
+	    fprintf(stdout,
+		    "DEBUG: Simple planar hulls not implemented yet.\n");
+	    fprintf(stdout, "DEBUG: This layer will not be exported.\n");
+	    /* all points in the same voxel plane. Let's output a very simple hull with 8 vertices */
+	    /* ONCE THIS IS IMPLEMENTED: call v.in.ascii for these hulls, too! */
+	    if (l == 0) {
+		/* this is the bottom DEM: we will extend it half a slice (tbres) down */
+		fprintf(tmpfile,
+		fprintf(tmpfile, "DEBUG: This layer was not exported.\n");
+	    else {
+		if (l == (nfiles - 1)) {
+		    /* this is the top DEM: we will extend it half a slice (tbres) up */
+		    fprintf(tmpfile,
+		    fprintf(stdout, "DEBUG: This layer was not exported.\n");
+		else {
+		    /* this DEM is somewhare in between, its vector representation will be planar! */
+		    fprintf(tmpfile,
+	/* free memory for points */
+	free(px);
+	free(py);
+	free(pz);
+	fclose(tmpfile);
+	/* call v.in.ascii to create a native GRASS vector map */
+	/* DEBUG: remove once planar hulls are implemented */
+	if (error > -1) {
+	    if (VERBOSE) {
+		fprintf(stdout,
+			"\nRunning v.in.ascii to create 3D points map: \n");
+	    sprintf(tmp,
+		    "v.in.ascii -z in=%s.hull.%i.txt out=%s_hull_%i form=standard",
+		    parm.output->answer, l, parm.output->answer, l);
+	    if (VERBOSE)
+    /* MAIN LOOP END */
+void output_vtk()
+    char sys[2048];
+    int error;
+    if (flag.vtk->answer) {
+	/* write a VTK file for visualisation in paraview etc. */
+	if (VERBOSE)
+	    fprintf(stdout, "\nCreating VTK file (%s.vtk): \n",
+		    parm.output->answer);
+	if (flag.points->answer) {
+	    sprintf(sys, "r3.out.vtk -p in=%s out=%s.vtk null=%f",
+		    parm.output->answer, parm.output->answer, DNULLVALUE);
+	else {
+	    sprintf(sys, "r3.out.vtk in=%s out=%s.vtk null=%f",
+	if (DEBUG > 0) {
+	    fprintf(stdout, "%s\n", sys);
+	error = system(sys);
+	if (error != 0) {
+	    G_fatal_error("Error running command: %s", sys);
+   MAIN
+int main(int argc, char *argv[])
+    struct GModule *module;
+    int i, j, k;
+    int nrows, ncols;
+    int *fd;
+    int nfiles, nvalues, ncolors;
+    double dslices;
+    char *name, *mapset;
+    DCELL **dcell;
+    double ***ascii;		/* 3D array that holds values to print into ASCII file */
+    unsigned short int *R;
+    unsigned short int *G;
+    unsigned short int *B;
+    char sys[2048];
+    module = G_define_module();
+    module->description =
+	"Creates a 3D raster model (voxels) from a series of raster DEMs";
+    /* do not pause after a warning message was displayed */
+    G_sleep_on_error(0);
+    /* DEFINE OPTIONS AND FLAGS */
+    /* input raster map */
+    parm.maps = G_define_standard_option(G_OPT_R_MAPS);
+    parm.maps->key = "map";
+    parm.maps->type = TYPE_STRING;
+    parm.maps->required = YES;
+    parm.maps->description =
+	"Input DEMs (at least 2) in raster format. Bottom DEM first";
+    parm.maps->gisprompt = "old,cell,raster";
+    parm.maps->multiple = YES;
+    /* Output map name */
+    parm.output = G_define_option();
+    parm.output->key = "output";
+    parm.output->type = TYPE_STRING;
+    parm.output->required = YES;
+    parm.output->description = "Output rast3d map name";
+    /* optional: specify a value for each layer */
+    parm.values = G_define_option();
+    parm.values->key = "labels";
+    parm.values->type = TYPE_DOUBLE;
+    parm.values->required = NO;
+    parm.values->description = "List of label values, one for each 3D layer";
+    /* optional: specify an RRR:GGG:BBB color triplet for each layer */
+    parm.colors = G_define_option();
+    parm.colors->key = "colors";
+    parm.colors->type = TYPE_STRING;
+    parm.colors->required = NO;
+    parm.colors->description =
+	"List of RRR:GGG:BBB color triplets, one for each layer";
+    /* optional: Raster map to represent topology errors in input DEMs */
+    parm.error = G_define_option();
+    parm.error->key = "errormap";
+    parm.error->type = TYPE_STRING;
+    parm.error->required = NO;
+    parm.error->description =
+	"Raster map to represent topology errors in input DEMs";
+    /* algorithm to use for flood filling */
+    parm.algorithm = G_define_option();
+    parm.algorithm->key = "algorithm";
+    parm.algorithm->type = TYPE_STRING;
+    parm.algorithm->required = NO;
+    parm.algorithm->options = "up,down";
+    parm.algorithm->answer = "up";
+    parm.algorithm->description = "3D flood fill algorithm to use";
+    /* 3D cell stats? */
+    flag.countcells = G_define_flag();
+    flag.countcells->key = 'c';
+    flag.countcells->description = "Calculate 3D cell counts for each layer.";
+    /* VTK point data output ? */
+    flag.fillnull = G_define_flag();
+    flag.fillnull->key = 'f';
+    flag.fillnull->description = "Fill through NULL value areas in DEMs";
+    /* export a 3D hull polygon for every layer ? */
+    flag.hull = G_define_flag();
+    flag.hull->key = 'h';
+    flag.hull->description = "Export convex hull polygons for layers";
+    /* GRASS ASCII vector point data output ? */
+    flag.grasspts = G_define_flag();
+    flag.grasspts->key = 'g';
+    flag.grasspts->description = "Export voxel model as vector points";
+    flag.points = G_define_flag();
+    flag.points->key = 'p';
+    flag.points->description = "Export VTK point data instead of cell data";
+    /* quiet operation? */
+    flag.quiet = G_define_flag();
+    flag.quiet->key = 'q';
+    flag.quiet->description = "Disable on-screen progress display";
+    /* skip DEM topology checks? */
+    flag.skip = G_define_flag();
+    flag.skip->key = 's';
+    flag.skip->description = "Skip topology error checking";
+    /* generate a VTK file? */
+    flag.vtk = G_define_flag();
+    flag.vtk->key = 'v';
+    flag.vtk->description =
+	"Generate a .vtk file for visualisation with e.g. paraview";
+    /* adjust Z-region settings to fit DEM values? */
+    flag.zadjust = G_define_flag();
+    flag.zadjust->key = 'z';
+    flag.zadjust->description = "Fit active region's Z range to input DEMs";
+    int error;
+    /* INIT GLOBAL VARIABLES */
+    VERBOSE = 1;
+    NSLICES = 0;
+    PRECISION = 1000;
+    /* setup some basic GIS stuff */
+    G_gisinit(argv[0]);
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    if (flag.quiet->answer) {
+	VERBOSE = 0;
+    /*      STEP 1: VALIDATE input data and topology        */
+    fprintf(stdout, "Validating data: \n");
+    /* check if input DEMs are available */
+    /* allocate all necessary handles */
+    for (nfiles = 0; parm.maps->answers[nfiles]; nfiles++) ;
+    if (DEBUG)
+	fprintf(stdout, "nfiles = %i\n", nfiles);
+    fd = (int *)G_malloc(nfiles * sizeof(int));
+    dcell = (DCELL **) G_malloc(nfiles * sizeof(DCELL *));
+    if (nfiles < 2) {
+	G_fatal_error("Need at least two raster maps!");
+	dcell[i] = Rast_allocate_d_buf();
+	name = parm.maps->answers[i];
+	mapset = G_find_raster2(name, "");
+	if (!mapset)
+	    G_fatal_error(_("%s - raster map not found"), name);
+	fd[i] = Rast_open_old(name, mapset);
+	if (fd[i] < 0)
+	    G_fatal_error(_("%s - can't open raster map"), name);
+    nvalues = 0;
+    ncolors = 0;
+    /* if values and/or colors have been specified for the model: check these parameters */
+    if (parm.values->answers != NULL)
+	for (nvalues = 0; parm.values->answers[nvalues]; nvalues++) ;
+    if (nvalues > 0) {
+	if (nvalues != nfiles) {
+	    G_fatal_error(_("Number of values (%i) does not match number of DEMs (%i)!"),
+			  nvalues, nfiles);
+    if (parm.colors->answers != NULL) {
+	for (ncolors = 0; parm.colors->answers[ncolors]; ncolors++) ;
+	/* KILL ME */
+	fprintf(stdout, "DEBUG: custom RGB colouring not implemented yet.\n");
+	/* KILL ME */
+    if (ncolors > 0) {
+	R = G_malloc(ncolors * sizeof(unsigned short int));
+	G = G_malloc(ncolors * sizeof(unsigned short int));
+	B = G_malloc(ncolors * sizeof(unsigned short int));
+	if (ncolors != nfiles) {
+	    G_fatal_error(_("Number of RGB triplets (%i) does not match number of DEMs (%i)!"),
+			  ncolors, nfiles);
+	for (i = 0; i < ncolors; i++) {
+	    if (!isRGB(parm.colors->answers[i], &R[i], &G[i], &B[i])) {
+		G_fatal_error(_("%s is not a valid RRR:GGG:BBB code!"),
+			      parm.colors->answers[i]);
+    check_zrange(fd, dcell, nfiles);
+    if (!flag.skip->answer) {
+	check_topologies(fd, dcell, nfiles);
+    /* let's see how many slices we will make */
+    dslices = ((window.top - window.bottom) / window.tb_res);
+    NSLICES = (int)rint(dslices);
+    if (NSLICES < 1) {
+	G_fatal_error
+	    ("This would produce < 1 slice. Adjust active 3d region resolution.");
+    if (DEBUG) {
+	fprintf(stdout, "%i DEMS, NSLICES = %i (%f)\n", nfiles, NSLICES,
+		dslices);
+	fflush(stdout);
+    /*      STEP 2: INTERPOLATE volume from DEMs            */
+    /* allocate array for storing voxel data and initialise it with DNULLVALUE */
+    ascii = (double ***)G_malloc(NSLICES * sizeof(double **));
+	ascii[i] = (double **)G_malloc(nrows * sizeof(double *));
+	    ascii[i][j] = G_malloc(ncols * sizeof(double));
+		ascii[i][j][k] = DNULLVALUE;
+    interpolate(fd, dcell, nfiles, nvalues, ascii);
+    /*      STEP 3: OUTPUT volume data                      */
+    /* TEMP SECTION */
+    /* this will only stay in here temporarily until this
+       program will be able to write voxel maps directly !!! */
+    output_ascii(ascii);
+    /* now call r3.in.ascii to write a voxel model for us */
+    if (VERBOSE)
+	fprintf(stdout, "Running r3.in.ascii to create voxel model: \n");
+    sprintf(sys, "r3.in.ascii in=%s out=%s nv=%f", TMPFILE,
+	    parm.output->answer, DNULLVALUE);
+    if (DEBUG > 0) {
+    if (VERBOSE)
+    /* END (TEMP SECTION) */
+    /* VTK output */
+	output_vtk();
+    /* ASCII vector points output */
+    if (flag.grasspts->answer) {
+	output_ascii_points(ascii);
+    /* ASCII convex hulls ouput */
+    if (flag.hull->answer) {
+	output_ascii_hulls(ascii, nvalues, nfiles);
+    /* show cell count stats? */
+    if (flag.countcells->answer) {
+	count_3d_cells(ascii, nfiles, nvalues);
+    fprintf(stdout, "\nJOB DONE.\n");
+    fflush(stdout);
+    return (EXIT_SUCCESS);
Property changes on: grass-addons/grass7/raster/r.vol.dem/main.c
   + text/x-csrc
   + native
