[GRASS-SVN] r51548 - in grass/trunk: lib/python lib/python/temporal
raster temporal temporal/t.rast.aggregate
temporal/t.rast.gapfill temporal/t.rast.mapcalc
temporal/t.rast.series temporal/t.rast3d.mapcalc temporal/t.topology
svn_grass at osgeo.org
Thu Apr 26 12:21:52 EDT 2012
Author: huhabla
Date: 2012-04-26 09:21:52 -0700 (Thu, 26 Apr 2012)
New Revision: 51548
Added:
grass/trunk/temporal/t.rast.gapfill/
grass/trunk/temporal/t.rast.gapfill/Makefile
grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.html
grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.py
grass/trunk/temporal/t.rast.gapfill/test.t.rast.gapfill.sh
grass/trunk/lib/python/array.py
grass/trunk/lib/python/temporal/abstract_dataset.py
grass/trunk/lib/python/temporal/abstract_map_dataset.py
grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
grass/trunk/lib/python/temporal/base.py
grass/trunk/lib/python/temporal/space_time_datasets.py
grass/trunk/lib/python/temporal/spatial_extent.py
grass/trunk/lib/python/temporal/temporal_relationships.py
grass/trunk/lib/python/temporal/unit_tests.py
grass/trunk/lib/python/temporal/univar_statistics.py
grass/trunk/raster/Makefile
grass/trunk/temporal/Makefile
grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py
grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py
grass/trunk/temporal/t.rast.series/t.rast.series.py
grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py
grass/trunk/temporal/t.topology/t.topology.py
New module to fill gaps in space time raster datasets using raster to raster interpolation of r.series.interp.
Keys for temporal sorting of dataset lists by start or end time.
Many new unit tests about sorting and temporal topology building.
Temporal topology computation.
Modified: grass/trunk/lib/python/array.py
--- grass/trunk/lib/python/array.py 2012-04-26 14:35:48 UTC (rev 51547)
+++ grass/trunk/lib/python/array.py 2012-04-26 16:21:52 UTC (rev 51548)
@@ -7,6 +7,8 @@
Usage:
@code
+from grass.script import array as garray
map = 'elevation'
x = garray.array()
x.read(map)
Modified: grass/trunk/lib/python/temporal/abstract_dataset.py
--- grass/trunk/lib/python/temporal/abstract_dataset.py 2012-04-26 14:35:48 UTC (rev 51547)
+++ grass/trunk/lib/python/temporal/abstract_dataset.py 2012-04-26 16:21:52 UTC (rev 51548)
@@ -74,6 +74,15 @@
self.relative_time.print_self()
self.spatial_extent.print_self()
self.metadata.print_self()
+ def set_id(self, ident):
+ self.base.set_id(ident)
+ if self.is_time_absolute():
+ self.absolute_time.set_id(ident)
+ if self.is_time_relative():
+ self.relative_time.set_id(ident)
+ self.spatial_extent.set_id(ident)
+ self.metadata.set_id(ident)
def get_id(self):
"""!Return the unique identifier of the dataset"""
@@ -325,3 +334,82 @@
return self.relative_time.temporal_relation(map.relative_time)
return None
+class abstract_dataset_comparison_key_start_time(object):
+ """!This comparison key can be used to sort lists of abstract datasets by start time
+ Example:
+ # Return all maps in a space time raster dataset as map objects
+ map_list = strds.get_registered_maps_as_objects()
+ # Sort the maps in the list by start time
+ sorted_map_list = sorted(map_list, key=abstract_dataset_comparison_key_start_time)
+ def __init__(self, obj, *args):
+ self.obj = obj
+ def __lt__(self, other):
+ startA, endA = self.obj.get_valid_time()
+ startB, endB = other.obj.get_valid_time()
+ return startA < startB
+ def __gt__(self, other):
+ return startA > startB
+ def __eq__(self, other):
+ return startA == startB
+ def __le__(self, other):
+ return startA <= startB
+ def __ge__(self, other):
+ return startA >= startB
+ def __ne__(self, other):
+ return startA != startB
+class abstract_dataset_comparison_key_end_time(object):
+ """!This comparison key can be used to sort lists of abstract datasets by end time
+ Example:
+ # Sort the maps in the list by end time
+ sorted_map_list = sorted(map_list, key=abstract_dataset_comparison_key_end_time)
+ self.obj = obj
+ return endA < endB
+ return endA > endB
+ return endA == endB
+ return endA <= endB
+ return endA >= endB
+ return endA != endB
\ No newline at end of file
Modified: grass/trunk/lib/python/temporal/abstract_map_dataset.py
--- grass/trunk/lib/python/temporal/abstract_map_dataset.py 2012-04-26 14:35:48 UTC (rev 51547)
+++ grass/trunk/lib/python/temporal/abstract_map_dataset.py 2012-04-26 16:21:52 UTC (rev 51548)
@@ -28,7 +28,7 @@
This object will be set up by temporal topology creation methods.
- If correctly initialize the calls get_next() and get_prev() let the user walk temporally forward
+ If correctly initialize the calls next() and prev() let the user walk temporally forward
and backward in time.
The following temporal relations with access methods are supported:
@@ -51,7 +51,7 @@
for _map in dlist:
_map.print_info()
- start = start.get_next()
+ start = start.next()
def __init__(self):
@@ -81,7 +81,7 @@
temporally located AFTER the start time of this map, but temporally
near than other maps of the same dataset.
- @param _map This object should be of type abstract_map_dataset or derived classes
+ @param _map: This object should be of type abstract_map_dataset or derived classes
self._temporal_topology["NEXT"] = _map
@@ -92,7 +92,7 @@
temporally located BEFORE the start time of this map, but temporally
self._temporal_topology["PREV"] = _map
@@ -119,7 +119,7 @@
def append_equivalent(self, _map):
"""!Append a map with equivalent temporal extent as this map
if not self._temporal_topology.has_key("EQUAL"):
self._temporal_topology["EQUAL"] = []
@@ -137,7 +137,7 @@
def append_overlaps(self, _map):
"""!Append a map that this map temporally overlaps
if not self._temporal_topology.has_key("OVERLAPS"):
self._temporal_topology["OVERLAPS"] = []
@@ -155,7 +155,7 @@
def append_overlapped(self, _map):
"""!Append a map that this map temporally overlapped
if not self._temporal_topology.has_key("OVERLAPPED"):
self._temporal_topology["OVERLAPPED"] = []
@@ -173,7 +173,7 @@
def append_follows(self, _map):
"""!Append a map that this map temporally follows
if not self._temporal_topology.has_key("FOLLOWS"):
self._temporal_topology["FOLLOWS"] = []
@@ -191,7 +191,7 @@
def append_precedes(self, _map):
"""!Append a map that this map temporally precedes
if not self._temporal_topology.has_key("PRECEDES"):
self._temporal_topology["PRECEDES"] = []
@@ -210,7 +210,7 @@
"""!Append a map that this map is temporally located during
This includes temporal relationships starts and finishes
if not self._temporal_topology.has_key("DURING"):
self._temporal_topology["DURING"] = []
@@ -230,7 +230,7 @@
"""!Append a map that this map temporally contains
This includes temporal relationships started and finished
if not self._temporal_topology.has_key("CONTAINS"):
self._temporal_topology["CONTAINS"] = []
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2012-04-26 14:35:48 UTC (rev 51547)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2012-04-26 16:21:52 UTC (rev 51548)
@@ -246,7 +246,7 @@
if maps == None:
- maps = get_registered_maps_as_objects(where=None, order="start_time", dbif=dbif)
+ maps = self.get_registered_maps_as_objects(where=None, order="start_time", dbif=dbif)
gaps = 0
@@ -259,7 +259,7 @@
return gaps
- def print_temporal_relation_matrix(self, maps=None, dbif=None):
+ def print_temporal_relationships(self, maps=None, dbif=None):
"""!Print the temporal relation matrix of all registered maps to stdout
The temporal relation matrix includes the temporal relations between
@@ -270,26 +270,10 @@
if maps == None:
- print_temporal_relations(maps, maps)
+ print_temporal_topology_relationships(maps, maps)
- def get_temporal_relation_matrix(self, maps=None, dbif=None):
- """!Return the temporal relation matrix of all registered maps as list of lists
- The map list must be ordered by start time
- The temporal relation matrix includes the temporal relations between
- all registered maps. The relations are strings stored in a list of lists.
- @param maps: a ordered by start_time list of map objects
- @param dbif: The database interface to be used
- if maps == None:
- return get_temporal_relation_matrix(maps, maps)
def count_temporal_relations(self, maps=None, dbif=None):
"""!Count the temporal relations between the registered maps.
@@ -302,9 +286,9 @@
if maps == None:
- return count_temporal_relations(maps, maps)
+ return count_temporal_topology_relationships(maps, maps)
def check_temporal_topology(self, maps=None, dbif=None):
"""!Check the temporal topology
@@ -335,9 +319,9 @@
@return True if topology is correct
if maps == None:
- relations = self.count_temporal_relations(maps)
+ relations = count_temporal_topology_relationships(maps, maps)
map_time = self.get_map_time()
Modified: grass/trunk/lib/python/temporal/base.py
--- grass/trunk/lib/python/temporal/base.py 2012-04-26 14:35:48 UTC (rev 51547)
+++ grass/trunk/lib/python/temporal/base.py 2012-04-26 16:21:52 UTC (rev 51548)
@@ -438,6 +438,16 @@
self.ident = ident
self.D["id"] = ident
+ if ident != None:
+ if ident.find("@") >= 0:
+ name, mapset = ident.split("@")
+ self.set_mapset(mapset)
+ if name.find(":") >= 0:
+ name, layer = ident.split(":")
+ self.set_layer(layer)
+ self.set_name(name)
def set_name(self, name):
"""!Set the name of the dataset
Modified: grass/trunk/lib/python/temporal/space_time_datasets.py
--- grass/trunk/lib/python/temporal/space_time_datasets.py 2012-04-26 14:35:48 UTC (rev 51547)
+++ grass/trunk/lib/python/temporal/space_time_datasets.py 2012-04-26 16:21:52 UTC (rev 51548)
@@ -27,6 +27,7 @@
import grass.lib.raster as libraster
import grass.lib.vector as libvector
import grass.lib.raster3d as libraster3d
+import grass.script.array as garray
from datetime_math import *
from abstract_map_dataset import *
@@ -73,11 +74,30 @@
"""Return the two dimensional spatial relation"""
return self.spatial_extent.spatial_relation_2d(dataset.spatial_extent)
+ def get_np_array(self):
+ """Return this raster map as memmap numpy style array to access the raster
+ values in numpy style without loading the whole map in the RAM.
+ In case this raster map does exists in the grass spatial database, the map
+ will be exported using r.out.bin to a temporary location and assigned to the
+ memmap object that is returned by this function.
+ In case the raster map does not exists, an empty temporary binary file will be created
+ and assigned to the memap object.
+ You need to call the write function to write the memmap array back into grass.
+ a = garray.array()
+ if self.map_exists():
+ a.read(self.get_map_id())
+ return a
def reset(self, ident):
"""!Reset the internal structure and set the identifier"""
- self.ident = ident
self.base = raster_base(ident=ident)
self.absolute_time = raster_absolute_time(ident=ident)
self.relative_time = raster_relative_time(ident=ident)
@@ -210,9 +230,6 @@
# Fill base information
- self.base.set_name(self.ident.split("@")[0])
- self.base.set_mapset(self.ident.split("@")[1])
self.base.set_creator(str(getpass.getuser()))
# Get the data from an existing raster map
@@ -289,8 +306,6 @@
self.base = raster3d_base(ident=ident)
self.absolute_time = raster3d_absolute_time(ident=ident)
self.relative_time = raster3d_relative_time(ident=ident)
@@ -421,8 +436,6 @@
"""!Load all info from an existing raster3d map into the internal structure"""
# Fill spatial extent
@@ -502,8 +515,6 @@
self.base = vector_base(ident=ident)
self.absolute_time = vector_absolute_time(ident=ident)
self.relative_time = vector_relative_time(ident=ident)
@@ -648,12 +659,6 @@
- if self.ident.find(":") >= 0:
- self.base.set_name(self.ident.split("@")[0].split(":")[0])
- self.base.set_layer(self.ident.split("@")[0].split(":")[1])
- else:
@@ -719,13 +724,7 @@
self.base = strds_base(ident=ident)
- if ident != None:
self.absolute_time = strds_absolute_time(ident=ident)
self.relative_time = strds_relative_time(ident=ident)
@@ -779,13 +778,7 @@
self.base = str3ds_base(ident=ident)
- if ident != None:
self.absolute_time = str3ds_absolute_time(ident=ident)
self.relative_time = str3ds_relative_time(ident=ident)
@@ -833,13 +826,7 @@
self.base = stvds_base(ident=ident)
- if ident != None:
self.absolute_time = stvds_absolute_time(ident=ident)
self.relative_time = stvds_relative_time(ident=ident)
Modified: grass/trunk/lib/python/temporal/spatial_extent.py
--- grass/trunk/lib/python/temporal/spatial_extent.py 2012-04-26 14:35:48 UTC (rev 51547)
+++ grass/trunk/lib/python/temporal/spatial_extent.py 2012-04-26 16:21:52 UTC (rev 51548)
@@ -23,7 +23,7 @@
from base import *
class spatial_extent(sql_database_interface):
- """!This is the spatial extent base class for all maps and spacetime datasets"""
+ """!This is the spatial extent base class for all maps and space time datasets"""
def __init__(self, table=None, ident=None, north=None, south=None, east=None, west=None, top=None, bottom=None, proj="XY"):
sql_database_interface.__init__(self, table, ident)
@@ -61,16 +61,16 @@
E -= 360.0
W -= 360.0
- if(self.get_north() < S):
+ if(self.get_north() <= S):
return False
- if(self.get_south() > N):
+ if(self.get_south() >= N):
return False
- if self.get_east() < W:
+ if self.get_east() <= W:
return False
- if self.get_west() > E:
+ if self.get_west() >= E:
return False
return True
@@ -92,10 +92,10 @@
T = extent.get_top()
B = extent.get_bottom()
- if self.get_top() < B:
+ if self.get_top() <= B:
return False
- if self.get_bottom() > T:
+ if self.get_bottom() >= T:
return False
return True
@@ -678,7 +678,7 @@
return True
def meet(self,extent):
- """ Check if self and extent touch meet other in three dimensions"""
+ """ Check if self and extent meet other in three dimensions"""
eN = extent.get_north()
eS = extent.get_south()
eE = extent.get_east()
@@ -727,7 +727,7 @@
edge = "B"
edge_count += 1
- # Meet a a single edge only
+ # Meet a single edge only
if edge_count != 1:
return False
Modified: grass/trunk/lib/python/temporal/temporal_relationships.py
--- grass/trunk/lib/python/temporal/temporal_relationships.py 2012-04-26 14:35:48 UTC (rev 51547)
+++ grass/trunk/lib/python/temporal/temporal_relationships.py 2012-04-26 16:21:52 UTC (rev 51548)
@@ -23,8 +23,10 @@
class temporal_topology_builder(object):
- """!This class is designed to build the temporal topology based on a list of maps
+ """!This class is designed to build the temporal topology based on a lists of maps
Example:
@@ -34,7 +36,7 @@
# Now lets build the temporal topology of the maps in the list
tb = temporal_topology_builder()
- tb.build(maps, True)
+ tb.build(maps)
for _map in tb:
_map.print_temporal_topology_info()
@@ -63,6 +65,7 @@
def _reset(self):
self._store = {}
self._first = None
+ self._temporal_iteratable = False
def _set_first(self, first):
self._first = first
@@ -84,8 +87,117 @@
@return The map with the earliest start time
return self._first
+ def _build_internal_iteratable(self, maps):
+ """!Build an iteratable temporal topology structure for all maps in the list and store the maps internally
- def build(self, maps, is_sorted = False):
+ Basically the "next" and "prev" relations will be set in the temporal topology structure of each map
+ The maps will be added to the object, so they can be accessed using the iterator of this class
+ @param maps: A sorted (by start_time)list of abstract_dataset objects with initiated temporal extent
+ self._build_iteratable(maps)
+ for _map in maps:
+ self._insert(_map)
+ # Detect the first map
+ self._detect_first()
+ def _build_iteratable(self, maps):
+ Basically the "next" and "prev" relations will be set in the temporal topology structure of each map.
+ for i in xrange(len(maps)):
+ offset = i + 1
+ for j in xrange(offset, len(maps)):
+ # Get the temporal relationship
+ relation = maps[j].temporal_relation(maps[i])
+ # Build the next reference
+ if relation != "equivalent" and relation != "started":
+ maps[i].set_next(maps[j])
+ break
+ for _map in maps:
+ _next = _map.next()
+ if _next:
+ _next.set_prev(_map)
+ _map.set_temporal_topology_build_true()
+ def build2(self, mapsA, mapsB):
+ """!Build the temporal topology structure between two ordered lists of maps
+ This method builds the temporal topology from mapsA to mapsB and vice verse.
+ The temporal topology structure of each map, defined in class temporal_map_relations,
+ will be reseted and rebuild for mapsA and mapsB.
+ After building the temporal topology the modified map objects of mapsA can be accessed
+ in the same way as a dictionary using there id. The implemented iterator assures
+ the chronological iteration over the mapsA.
+ @param mapsA: A sorted list (by start_time) of abstract_dataset objects with initiated temporal extent
+ @param mapsB: A sorted list (by start_time) of abstract_dataset objects with initiated temporal extent
+ if mapsA == mapsB:
+ self.build(mapsA, True)
+ return
+ for _map in mapsA:
+ _map.reset_temporal_topology()
+ for _map in mapsB:
+ for i in xrange(len(mapsA)):
+ for j in xrange(len(mapsB)):
+ relation = mapsB[j].temporal_relation(mapsA[i])
+ if relation == "before":
+ continue
+ if relation == "equivalent":
+ mapsB[j].append_equivalent(mapsA[i])
+ mapsA[i].append_equivalent(mapsB[j])
+ elif relation == "follows":
+ mapsB[j].append_follows(mapsA[i])
+ mapsA[i].append_precedes(mapsB[j])
+ elif relation == "precedes":
+ mapsB[j].append_precedes(mapsA[i])
+ mapsA[i].append_follows(mapsB[j])
+ elif relation == "during" or relation == "starts" or relation == "finishes":
+ mapsB[j].append_during(mapsA[i])
+ mapsA[i].append_contains(mapsB[j])
+ elif relation == "contains" or relation == "started" or relation == "finished":
+ mapsB[j].append_contains(mapsA[i])
+ mapsA[i].append_during(mapsB[j])
+ elif relation == "overlaps":
+ mapsB[j].append_overlaps(mapsA[i])
+ mapsA[i].append_overlapped(mapsB[j])
+ elif relation == "overlapped":
+ mapsB[j].append_overlapped(mapsA[i])
+ mapsA[i].append_overlaps(mapsB[j])
+ # Break if the next map follows and the over-next maps is after
+ if relation == "follows":
+ if j < len(mapsB) - 1:
+ relation = mapsB[j + 1].temporal_relation(mapsA[i])
+ if relation == "after":
+ break
+ # Break if the the next map is after
+ break
+ self._build_internal_iteratable(mapsA)
+ self._build_iteratable(mapsB)
+ def build(self, maps):
This method builds the temporal topology based on all maps in the provided map list.
@@ -94,58 +206,19 @@
After building the temporal topology the modified map objects can be accessed
- the chronological iteration over the maps.
+ the chronological iteration over the maps.
- @param maps: A list of abstract_dataset objects with initiated temporal extent
- @param is_sorted Set to True if the map list is sorted by start time, sorting will dramatically reduce computation time
+ @param maps: A sorted list (by start_time) of abstract_dataset objects with initiated temporal extent
for _map in maps:
- if is_sorted:
- offset = i + 1
- found_next = False
- else:
- offset = 0
- # Needed for "next" computation
- start0, end0 = maps[i].get_valid_time()
+ offset = i + 1
- # Do not build topology of the same maps
- if maps[i] == maps[j]:
- continue
- # We can skip several relationships if not sorted
- if not is_sorted:
- if relation == "before":
- continue
- if relation == "precedes":
- continue
- if relation == "overlapped":
- continue
- if relation == "finished":
- continue
- # Build the next reference
- if is_sorted:
- if not found_next and relation != "equivalent" and relation != "started":
- maps[i].set_next(maps[j])
- found_next = True
- else:
- start2, end2 = maps[j].get_valid_time()
- if maps[i].next():
- start1, end1 = maps[i].next().get_valid_time()
- if start2 > start0 and start2 < start1:
- else:
- if start2 > start0:
# The start time of map j is equal or later than map i
@@ -174,23 +247,14 @@
break
+ self._build_internal_iteratable(maps)
- # Build the previous pointer and store the map internally
- for _map in maps:
- _next = _map.next()
- if _next:
- _next.set_prev(_map)
- _map.set_temporal_topology_build_true()
- self._insert(_map)
- # Detect the first map
- self._detect_first()
def __iter__(self):
- _start = self._first
- while _start != None:
- yield _start
- _start = _start.next()
+ _start = self._first
+ while _start != None:
+ yield _start
+ _start = _start.next()
def __getitem__(self, index):
return self._store[index.get_id()]
@@ -202,12 +266,14 @@
return _map in self._store.values()
-def print_temporal_relations(maps1, maps2):
+def print_temporal_topology_relationships(maps1, maps2):
"""!Print the temporal relation matrix of the temporal ordered map lists maps1 and maps2
to stdout.
- @param maps1: a ordered by start_time list of map objects with initiated temporal extent
- @param maps2: a ordered by start_time list of map objects with initiated temporal extent
+ @param maps1: A sorted (by start_time) list of abstract_dataset objects with initiated temporal extent
+ @param maps2: A sorted (by start_time) list of abstract_dataset objects with initiated temporal extent
identical = False
@@ -240,60 +306,16 @@
break
-def get_temporal_relation_matrix(maps1, maps2):
- """!Return the temporal relation matrix of two map lists
- Booth map lists must be ordered by start time
- The temporal relationship matrix includes the temporal relations between
- the two map lists. Returned is a nested dict representing
- a sparse (upper right side in case maps1 == maps2) relationship matrix.
- @param maps1: A sorted (start_time) list of abstract_dataset objects with initiated temporal extent
- @param maps2: A sorted (start_time) list of abstract_dataset objects with initiated temporal extent
- matrix = {}
- identical = False
- if maps1 == maps2:
- identical = True
- for i in range(len(maps1)):
- if identical == True:
- start = i + 1
- else:
- start = 0
- row = {}
- for j in range(start, len(maps2)):
- relation = maps1[j].temporal_relation(maps2[i])
- row[maps2[j].base.get_id()] = relation
- # Break if the last map follows
- if relation == "follows":
- if j < len(maps1) - 1:
- relation = maps1[j + 1].temporal_relation(maps2[i])
- if relation == "after":
- break
- # Break if the the next map is after
- break
- matrix[maps1[i].base.get_id()] = row
- return matrix
-def count_temporal_relations(maps1, maps2):
+def count_temporal_topology_relationships(maps1, maps2):
"""!Count the temporal relations between the two lists of maps
The map lists must be ordered by start time. Temporal relations are counted
by analyzing the sparse (upper right side in case maps1 == maps2) temporal relationships matrix.
@return A dictionary with counted temporal relationships
@@ -330,4 +352,3 @@
break
return tcount
Modified: grass/trunk/lib/python/temporal/unit_tests.py
--- grass/trunk/lib/python/temporal/unit_tests.py 2012-04-26 14:35:48 UTC (rev 51547)
+++ grass/trunk/lib/python/temporal/unit_tests.py 2012-04-26 16:21:52 UTC (rev 51548)
@@ -20,12 +20,16 @@
@author Soeren Gebbert
+import copy
from datetime import datetime, date, time, timedelta
import grass.script.core as core
from temporal_granularity import *
from space_time_datasets import *
+# Uncomment this to detect the error
+#core.set_raise_on_error(True)
def test_increment_datetime_by_string():
@@ -44,7 +48,7 @@
delta = dt1 -dt2
if delta.days != 0 or delta.seconds != 0:
- core.error("increment computation is wrong %s" % (delta))
+ core.fatal("increment computation is wrong %s" % (delta))
# Second test
print "# Test 2"
@@ -60,7 +64,7 @@
delta = dt1 -dt2
# Third test
print "# Test 3"
@@ -76,7 +80,7 @@
delta = dt1 -dt2
# 4. test
print "# Test 4"
@@ -92,7 +96,7 @@
delta = dt1 -dt2
@@ -107,7 +111,7 @@
delta = correct - result
- core.error("Granularity adjustment computation is wrong %s" % (delta))
+ core.fatal("Granularity adjustment computation is wrong %s" % (delta))
# Second test
print "Test 2"
@@ -117,7 +121,7 @@
# Third test
print "Test 2"
@@ -127,7 +131,7 @@
# 4. test
print "Test 4"
@@ -137,7 +141,7 @@
# 5. test
print "Test 5"
@@ -147,7 +151,7 @@
# 6. test
print "Test 6"
@@ -157,7 +161,7 @@
# 7. test
print "Test 7"
@@ -167,7 +171,7 @@
# 8. test
print "Test 8"
@@ -177,7 +181,7 @@
# 9. test
print "Test 9"
@@ -187,7 +191,7 @@
# 10. test
print "Test 10"
@@ -197,7 +201,7 @@
# 11. test
print "Test 11"
@@ -207,7 +211,7 @@
@@ -225,7 +229,7 @@
if delta != 0:
- core.error("Compute datetime delta is wrong %s" % (delta))
+ core.fatal("Compute datetime delta is wrong %s" % (delta))
print "Test 2"
start = datetime(2001, 1, 1, 00,00,14)
@@ -239,7 +243,7 @@
if delta != 0:
print "Test 3"
start = datetime(2001, 1, 1, 00,00,44)
@@ -253,7 +257,7 @@
if delta != 0:
print "Test 4"
start = datetime(2001, 1, 1, 00,00,30)
@@ -267,7 +271,7 @@
if delta != 0:
print "Test 5"
start = datetime(2001, 1, 1, 00,00,00)
@@ -281,7 +285,7 @@
if delta != 0:
print "Test 6"
start = datetime(2011,10,31, 00,45,00)
@@ -295,7 +299,7 @@
if delta != 0:
print "Test 7"
@@ -309,7 +313,7 @@
if delta != 0:
print "Test 8"
@@ -323,7 +327,7 @@
if delta != 0:
print "Test 9"
start = datetime(2011,10,31, 00,00,00)
@@ -337,7 +341,7 @@
if delta != 0:
print "Test 10"
@@ -351,7 +355,7 @@
if delta != 0:
print "Test 11"
start = datetime(2011,10,31, 12,00,00)
@@ -365,7 +369,7 @@
if delta != 0:
print "Test 12"
start = datetime(2011,11,01, 00,00,00)
@@ -379,7 +383,7 @@
if delta != 0:
print "Test 13"
@@ -394,7 +398,7 @@
if delta != 0:
print "Test 14"
start = datetime(2011,10,06, 00,00,00)
@@ -408,7 +412,7 @@
if delta != 0:
print "Test 15"
start = datetime(2011,12,02, 00,00,00)
@@ -422,7 +426,7 @@
if delta != 0:
print "Test 16"
start = datetime(2011,01,01, 00,00,00)
@@ -436,7 +440,7 @@
if delta != 0:
print "Test 17"
start = datetime(2011,12,01, 00,00,00)
@@ -450,7 +454,7 @@
if delta != 0:
print "Test 18"
@@ -464,7 +468,7 @@
if delta != 0:
print "Test 19"
start = datetime(2011,06,01, 00,00,00)
@@ -478,7 +482,7 @@
if delta != 0:
print "Test 20"
@@ -493,7 +497,7 @@
if delta != 0:
print "Test 21"
@@ -508,7 +512,7 @@
if delta != 0:
print "Test 22"
@@ -523,7 +527,7 @@
if delta != 0:
print "Test 23"
@@ -538,7 +542,7 @@
if delta != 0:
print "Test 24"
@@ -553,7 +557,7 @@
if delta != 0:
@@ -577,7 +581,7 @@
fact = fact - 1
gran = round(compute_relative_time_granularity(maps))
if fact - gran != 0:
- core.error("Wrong granularity reference %i != gran %i" % (fact, gran))
+ core.fatal("Wrong granularity reference %i != gran %i" % (fact, gran))
print "Test 2"
maps = []
@@ -594,7 +598,7 @@
fact = fact - 1
gran = round(compute_relative_time_granularity(maps) * 86400)
print "Test 3 with gaps"
maps = []
@@ -612,7 +616,7 @@
# Second we test intervals and points mixed
@@ -636,7 +640,7 @@
fact = fact - 1
# Second we test points only
@@ -652,7 +656,7 @@
@@ -674,7 +678,7 @@
gran = compute_absolute_time_granularity(maps)
if increment != gran:
- core.error("Wrong granularity reference %s != gran %s" % (increment, gran))
+ core.fatal("Wrong granularity reference %s != gran %s" % (increment, gran))
print "Test 2"
maps = []
@@ -689,7 +693,7 @@
print "Test 3"
maps = []
@@ -704,7 +708,7 @@
print "Test 4"
maps = []
@@ -719,7 +723,7 @@
print "Test 3"
maps = []
@@ -734,7 +738,7 @@
print "Test 4"
maps = []
@@ -749,7 +753,7 @@
print "Test 5"
maps = []
@@ -765,7 +769,7 @@
increment = "1 days"
print "Test 6"
maps = []
@@ -781,7 +785,7 @@
increment = "25 hours"
print "Test 7"
maps = []
@@ -796,7 +800,7 @@
print "Test 8"
maps = []
@@ -811,7 +815,7 @@
print "Test 9"
maps = []
@@ -827,7 +831,7 @@
increment = "325 minutes"
print "Test 10"
maps = []
@@ -843,7 +847,7 @@
increment = "330 seconds"
print "Test 11"
maps = []
@@ -859,7 +863,7 @@
increment = "3630 seconds"
print "Test 12"
maps = []
@@ -874,7 +878,7 @@
# Test absolute time points
@@ -891,7 +895,7 @@
print "Test 14"
maps = []
@@ -906,7 +910,7 @@
print "Test 15"
maps = []
@@ -921,7 +925,7 @@
# Test absolute time interval and points
@@ -947,7 +951,7 @@
print "Test 17"
maps = []
@@ -971,7 +975,7 @@
@@ -988,7 +992,7 @@
if C.get_north() != B.get_north() or C.get_south() != B.get_south() or \
C.get_west() != B.get_west() or C.get_east() != B.get_east() or \
C.get_bottom() != B.get_bottom() or C.get_top() != B.get_top():
- core.error("Wrong intersection computation")
+ core.fatal("Wrong intersection computation")
B = spatial_extent(north=40, south=30, east=60, west=10, bottom=-50, top=50)
B.print_info()
@@ -998,7 +1002,7 @@
B = spatial_extent(north=40, south=30, east=60, west=30, bottom=-50, top=50)
B.print_info()
@@ -1008,7 +1012,7 @@
B = spatial_extent(north=40, south=30, east=60, west=30, bottom=-30, top=50)
B.print_info()
@@ -1018,7 +1022,7 @@
B = spatial_extent(north=40, south=30, east=60, west=30, bottom=-30, top=30)
B.print_info()
@@ -1028,7 +1032,7 @@
@@ -1043,7 +1047,7 @@
relation = A.spatial_relation(B)
print relation
if relation!= "equivalent":
- core.error("Wrong spatial relation: %s"%(relation))
+ core.fatal("Wrong spatial relation: %s"%(relation))
B = spatial_extent(north=70, south=20, east=60, west=10, bottom=-50, top=50)
B.print_info()
@@ -1051,12 +1055,12 @@
relation = A.spatial_relation_2d(B)
print relation
if relation!= "cover":
print relation
B = spatial_extent(north=70, south=30, east=60, west=10, bottom=-50, top=50)
B.print_info()
@@ -1064,22 +1068,22 @@
print relation
print relation
relation = B.spatial_relation_2d(A)
print relation
if relation!= "covered":
relation = B.spatial_relation(A)
print relation
B = spatial_extent(north=70, south=30, east=50, west=10, bottom=-50, top=50)
B.print_info()
@@ -1087,24 +1091,24 @@
print relation
print relation
print relation
B = spatial_extent(north=70, south=30, east=50, west=20, bottom=-50, top=50)
print relation
B.print_info()
@@ -1112,12 +1116,12 @@
print relation
if relation!= "contain":
print relation
B = spatial_extent(north=70, south=30, east=50, west=20, bottom=-40, top=50)
B.print_info()
@@ -1125,7 +1129,7 @@
print relation
B = spatial_extent(north=70, south=30, east=50, west=20, bottom=-40, top=40)
B.print_info()
@@ -1133,12 +1137,12 @@
print relation
print relation
if relation!= "in":
B = spatial_extent(north=90, south=30, east=50, west=20, bottom=-40, top=40)
B.print_info()
@@ -1146,12 +1150,12 @@
print relation
if relation!= "overlap":
print relation
B = spatial_extent(north=90, south=5, east=70, west=5, bottom=-40, top=40)
A.print_info()
@@ -1160,12 +1164,12 @@
print relation
if relation!= "in":
print relation
B = spatial_extent(north=90, south=5, east=70, west=5, bottom=-40, top=60)
A.print_info()
@@ -1174,7 +1178,7 @@
print relation
B = spatial_extent(north=90, south=5, east=70, west=5, bottom=-60, top=60)
@@ -1184,7 +1188,7 @@
print relation
if relation!= "in":
A = spatial_extent(north=80, south=60, east=60, west=10, bottom=-50, top=50)
A.print_info()
@@ -1194,12 +1198,12 @@
print relation
if relation!= "meet":
print relation
A = spatial_extent(north=60, south=40, east=60, west=10, bottom=-50, top=50)
A.print_info()
@@ -1209,12 +1213,12 @@
print relation
print relation
A = spatial_extent(north=80, south=40, east=60, west=40, bottom=-50, top=50)
A.print_info()
@@ -1224,12 +1228,12 @@
print relation
print relation
A = spatial_extent(north=80, south=40, east=40, west=20, bottom=-50, top=50)
A.print_info()
@@ -1239,12 +1243,12 @@
print relation
print relation
A.print_info()
@@ -1254,12 +1258,12 @@
print relation
print relation
A.print_info()
@@ -1269,12 +1273,12 @@
print relation
print relation
A.print_info()
@@ -1284,12 +1288,12 @@
print relation
if relation!= "disjoint":
print relation
A.print_info()
@@ -1299,7 +1303,7 @@
print relation
A.print_info()
@@ -1309,7 +1313,7 @@
print relation
A = spatial_extent(north=80, south=40, east=60, west=20, bottom=0, top=50)
A.print_info()
@@ -1319,7 +1323,7 @@
print relation
A.print_info()
@@ -1329,7 +1333,7 @@
print relation
A.print_info()
@@ -1339,7 +1343,7 @@
print relation
A.print_info()
@@ -1349,7 +1353,7 @@
print relation
A.print_info()
@@ -1359,7 +1363,7 @@
print relation
A = spatial_extent(north=80, south=40, east=60, west=20, bottom=-50, top=0)
@@ -1370,7 +1374,7 @@
print relation
A.print_info()
@@ -1380,7 +1384,7 @@
print relation
A.print_info()
@@ -1390,7 +1394,7 @@
print relation
A.print_info()
@@ -1400,7 +1404,7 @@
print relation
A.print_info()
@@ -1410,77 +1414,159 @@
print relation
def test_temporal_topology_builder():
- map_list = []
- count = 0
- for year in xrange(0,1):
- for month in xrange(1,6):
- start = datetime(2001 + year, month, 01)
- end = datetime(2001 + year, month + 1, 01)
- _map = raster_dataset("%d at A"%(count))
- _map.set_absolute_time(start, end)
- map_list.append(_map)
- count += 1
+ map_listA = []
+ _map = raster_dataset(ident = "1 at a")
+ _map.set_absolute_time(datetime(2001, 01, 01), datetime(2001, 02, 01))
+ map_listA.append(copy.copy(_map))
+ _map = raster_dataset(ident = "2 at a")
+ _map.set_absolute_time(datetime(2001, 02, 01), datetime(2001, 03, 01))
+ _map = raster_dataset(ident = "3 at a")
+ _map.set_absolute_time(datetime(2001, 03, 01), datetime(2001, 04, 01))
+ _map = raster_dataset(ident = "4 at a")
+ _map.set_absolute_time(datetime(2001, 04, 01), datetime(2001, 05, 01))
+ _map = raster_dataset(ident = "5 at a")
+ _map.set_absolute_time(datetime(2001, 05, 01), datetime(2001, 06, 01))
- tb.build(map_list, True)
+ tb.build(map_listA)
+ count = 0
for _map in tb:
- _map.print_info()
- map_list = []
- count += 1
- start = datetime(2001 + year, month, 14)
- end = datetime(2001 + year, month + 1, 14)
- count += 1
- start = datetime(2001 + year, month, 8)
- end = datetime(2001 + year, month + 1, 21)
- count += 1
+ print "[%s]"%(_map.get_name())
+ _map.print_temporal_topology_info()
+ if _map.get_id() != map_listA[count].get_id():
+ core.fatal("Error building temporal topology <%s> != <%s>"%( _map.get_id(), map_listA[count].get_id()))
+ count += 1
+ map_listB = []
+ _map = raster_dataset(ident = "1 at b")
+ _map.set_absolute_time(datetime(2001, 01, 14), datetime(2001, 03, 14))
+ map_listB.append(copy.copy(_map))
+ _map = raster_dataset(ident = "2 at b")
+ _map.set_absolute_time(datetime(2001, 02, 01), datetime(2001, 04, 01))
+ _map = raster_dataset(ident = "3 at b")
+ _map.set_absolute_time(datetime(2001, 02, 14), datetime(2001, 04, 30))
+ _map = raster_dataset(ident = "4 at b")
+ _map.set_absolute_time(datetime(2001, 04, 02), datetime(2001, 04, 30))
+ _map = raster_dataset(ident = "5 at b")
+ _map.set_absolute_time(datetime(2001, 05, 01), datetime(2001, 05, 14))
+ tb = temporal_topology_builder()
+ tb.build(map_listB)
- tb = temporal_topology_builder()
- tb.build(map_list, False)
+ # Probing some relations
+ if map_listB[0].get_overlapped()[0] != map_listB[1]:
+ core.fatal("Error building temporal topology")
+ if map_listB[0].get_overlapped()[1] != map_listB[2]:
+ if map_listB[2].get_contains()[0] != map_listB[3]:
+ if map_listB[3].get_during()[0] != map_listB[2]:
+ count = 0
for _map in tb:
+ print "[%s]"%(_map.get_map_id
+ _map.print_temporal_topology_shell_info()
+ if _map.get_id() != map_listB[count].get_id():
+ core.fatal("Error building temporal topology <%s> != <%s>"%( _map.get_id(), map_listB[count].get_id()))
+ count += 1
- print _map.get_id()
- _map.absolute_time.print_info()
- _map.print_temporal_topology_info()
- # Test the performance of many overlapping maps
+ tb.build2(map_listA, map_listB)
count = 0
- for year in xrange(0,200):
- for month in xrange(1,12):
- start = datetime(1901 + year, month, 01)
- end = datetime(1904 + year, month + 1, 01)
- count += 1
+ for _map in tb:
+ print "[%s]"%(_map.get_map_id())
+ count += 1
+ count = 0
+ for _map in map_listB:
+ if map_listA[3].get_follows()[0] != map_listB[1]:
+ if map_listA[3].get_precedes()[0] != map_listB[4]:
+ if map_listA[3].get_overlaps()[0] != map_listB[2]:
+ if map_listA[3].get_contains()[0] != map_listB[3]:
- print "Build temporal topology with sorting for %i maps"%count
+ if map_listA[2].get_during()[0] != map_listB[1]:
+ if map_listA[2].get_during()[1] != map_listB[2]:
+def test_map_list_sorting():
+ map_list = []
+ map_list.append(copy.copy(_map))
+ print "Original"
+ for _map in map_list:
+ print _map.get_valid_time()[0], _map.get_valid_time()[1]
+ print "Sorted by start time"
+ new_list = sorted(map_list, key=abstract_dataset_comparison_key_start_time)
+ for _map in new_list:
- print "Build temporal topology without sorting for %i maps"%count
+ if new_list[0] != map_list[1]:
+ core.fatal("Sorting by start time failed")
+ if new_list[1] != map_list[0]:
+ if new_list[2] != map_list[2]:
+ print "Sorted by end time"
+ new_list = sorted(map_list, key=abstract_dataset_comparison_key_end_time)
+ core.fatal("Sorting by end time failed")
if __name__ == "__main__":
test_adjust_datetime_to_granularity()
@@ -1490,4 +1576,6 @@
test_compute_datetime_delta()
test_spatial_extent_intersection()
test_spatial_relations()
- test_temporal_topology_builder()
+ test_temporal_topology_builder()
+ test_map_list_sorting()
Modified: grass/trunk/lib/python/temporal/univar_statistics.py
--- grass/trunk/lib/python/temporal/univar_statistics.py 2012-04-26 14:35:48 UTC (rev 51547)
+++ grass/trunk/lib/python/temporal/univar_statistics.py 2012-04-26 16:21:52 UTC (rev 51548)
@@ -101,7 +101,7 @@
def print_vector_dataset_univar_statistics(input, twhere, layer, type, column, where, extended, header, fs):
- """!Print univariate statistics for a space time raster or raster3d dataset
+ """!Print univariate statistics for a space time vector dataset
@param input The name of the space time dataset
@param twhere A temporal database where statement
Modified: grass/trunk/raster/Makefile
--- grass/trunk/raster/Makefile 2012-04-26 14:35:48 UTC (rev 51547)
+++ grass/trunk/raster/Makefile 2012-04-26 16:21:52 UTC (rev 51548)
@@ -86,6 +86,7 @@
r.rescale.eq \
r.ros \
r.series \
+ r.series.interp \
r.slope.aspect \
r.solute.transport \
r.spread \
Modified: grass/trunk/temporal/Makefile
--- grass/trunk/temporal/Makefile 2012-04-26 14:35:48 UTC (rev 51547)
+++ grass/trunk/temporal/Makefile 2012-04-26 16:21:52 UTC (rev 51548)
@@ -20,6 +20,7 @@
t.rast.export \
t.rast.out.vtk \
t.rast.import \
+ t.rast.gapfill \
t.rast.extract \
t.rast3d.list \
t.rast3d.extract \
Modified: grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py
--- grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py 2012-04-26 14:35:48 UTC (rev 51547)
+++ grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py 2012-04-26 16:21:52 UTC (rev 51548)
@@ -58,15 +58,6 @@
#%option G_OPT_R_BASE
#%end
-#%option
-#% key: nprocs
-#% type: integer
-#% description: The number of r.mapcalc processes to run in parallel
-#% required: no
-#% multiple: no
-#% answer: 2
-#%end
#%flag
#% key: n
#% description: Register Null maps
@@ -89,7 +80,6 @@
register_null = flags["n"]
method = options["method"]
sampling = options["sampling"]
- nprocs = int(options["nprocs"])
# Make sure the temporal database exists
tgis.create_temporal_database()
Added: grass/trunk/temporal/t.rast.gapfill/Makefile
--- grass/trunk/temporal/t.rast.gapfill/Makefile (rev 0)
+++ grass/trunk/temporal/t.rast.gapfill/Makefile 2012-04-26 16:21:52 UTC (rev 51548)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../../
+PGM = t.rast.gapfill
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script $(TEST_DST)
Added: grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.html
Added: grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.py
--- grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.py (rev 0)
+++ grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.py 2012-04-26 16:21:52 UTC (rev 51548)
@@ -0,0 +1,176 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE: t.rast.gapfill
+# AUTHOR(S): Soeren Gebbert
+# PURPOSE: Replace gaps in a space time raster dataset with interpolated raster maps.
+# COPYRIGHT: (C) 2012 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (version 2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Replace gaps in a space time raster dataset with interpolated raster maps.
+#% keywords: temporal
+#% keywords: interpolation
+#%end
+#%option G_OPT_STRDS_INPUT
+#%end
+#%option G_OPT_T_WHERE
+#%end
+#%option
+#% key: base
+#% type: string
+#% description: The base name of the interpolated raster maps. This name will be extended with a numerical prefix
+#% required: yes
+#% multiple: no
+#%end
+#%option
+#% key: nprocs
+#% type: integer
+#% description: The number of interpolation processes to run in parallel
+#% required: no
+#% multiple: no
+#% answer: 1
+#%end
+#%flag
+#% key: t
+#% description: Assign the space time raster dataset start and end time to the output map
+#%end
+from multiprocessing import Process
+import grass.script as grass
+import grass.temporal as tgis
+def main():
+ # Get the options
+ input = options["input"]
+ base = options["base"]
+ where = options["where"]
+ nprocs = options["nprocs"]
+ # Make sure the temporal database exists
+ tgis.create_temporal_database()
+ if input.find("@") >= 0:
+ id = input
+ else:
+ mapset = grass.gisenv()["MAPSET"]
+ id = input + "@" + mapset
+ # We need a database interface
+ dbif = tgis.sql_database_interface_connection()
+ dbif.connect()
+ sp = tgis.space_time_raster_dataset(id)
+ if sp.is_in_db(dbif) == False:
+ grass.fatal(_("Space time %s dataset <%s> not found") % (sp.get_new_map_instance(None).get_type(), id))
+ sp.select(dbif)
+ maps = sp.get_registered_maps_as_objects_with_gaps(where, dbif)
+ num = len(maps)
+ gap_list = []
+ # Identify all gaps and create new names
+ count = 0
+ for _map in maps:
+ if _map.get_id() == None:
+ count += 1
+ _id = "%s_%d@%s"%(base, num + count, mapset)
+ print _id
+ _map.set_id(_id)
+ if _map.map_exists() or _map.is_in_db(dbif):
+ grass.fatal(_("Map with name <%s> already exists. Please use another base name."%(_id)))
+ gap_list.append(_map)
+ if len(gap_list) == 0:
+ grass.message(_("No gaps found"))
+ return
+ # Build the temporal topology
+ tb = tgis.temporal_topology_builder()
+ tb.build(maps)
+ # Do some checks before computation
+ for _map in gap_list:
+ if not _map.get_precedes() or not _map.get_follows():
+ grass.fatal(_("Unable to determine successor and predecessor of a gap."))
+ if len(_map.get_precedes()) > 1:
+ grass.warning(_("More than one successor of the gap found. Using the first found."))
+ if len(_map.get_follows()) > 1:
+ grass.warning(_("More than one predecessor of the gap found. Using the first found."))
+ # Interpolate the maps using parallel processing
+ proc_list = []
+ proc_count = 0
+ num = len(gap_list)
+ predecessor = _map.get_follows()[0]
+ successor = _map.get_precedes()[0]
+ # Build the module inputs strings
+ inputs = "%s,%s"%(predecessor.get_map_id(), successor.get_map_id())
+ dpos = "0,1"
+ output = "%s"%(_map.get_name())
+ outpos = "0.5"
+ # Start several processes in parallel
+ proc_list.append(Process(target=run_interp, args=(inputs,dpos,output,outpos)))
+ proc_list[proc_count].start()
+ proc_count += 1
+ if proc_count == nprocs or proc_count == num:
+ proc_count = 0
+ exitcodes = 0
+ for proc in proc_list:
+ proc.join()
+ exitcodes += proc.exitcode
+ if exitcodes != 0:
+ dbif.close()
+ grass.fatal(_("Error while interpolation computation"))
+ # Empty process list
+ proc_list = []
+ # Insert new interpolated maps in temporal database and dataset
+ _map.load()
+ _map.insert(dbif)
+ sp.register_map(_map, dbif)
+ sp.update_from_registered_maps(dbif)
+ dbif.close()
+def run_interp(inputs, dpos, output, outpos):
+ """Helper function to run r.series.interp in parallel"""
+ return grass.run_command("r.series.interp", input=inputs, datapos=dpos, output=output, samplingpos=outpos, overwrite=grass.overwrite(), quiet=True)
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
Property changes on: grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.py
___________________________________________________________________
Added: svn:executable
Added: grass/trunk/temporal/t.rast.gapfill/test.t.rast.gapfill.sh
--- grass/trunk/temporal/t.rast.gapfill/test.t.rast.gapfill.sh (rev 0)
+++ grass/trunk/temporal/t.rast.gapfill/test.t.rast.gapfill.sh 2012-04-26 16:21:52 UTC (rev 51548)
@@ -0,0 +1,32 @@
+# We need to set a specific region in the
+# @preprocess step of this test.
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
+r.mapcalc --o expr="prec_1 = 100"
+r.mapcalc --o expr="prec_2 = 300"
+r.mapcalc --o expr="prec_3 = 500"
+n1=`g.tempfile pid=1 -d`
+cat > "${n1}" << EOF
+prec_1|2001-01-01|2001-02-01
+prec_2|2001-03-01|2001-04-01
+prec_3|2001-05-01|2001-06-01
+EOF
+t.create --v --o type=strds temporaltype=absolute output=precip_abs title="A test" descr="A test"
+t.register --v type=rast input=precip_abs file=${n1}
+# @test
+t.rast.gapfill input=precip_abs base="prec" nprocs=2
+t.info precip_abs
+t.info type=rast input=prec_6
+t.info type=rast input=prec_7
+# @postprocess
+t.unregister --v type=rast maps=prec_1,prec_2,prec_3,prec_6,prec_7
+t.remove --v type=strds input=precip_abs
+g.remove rast=prec_1,prec_2,prec_3,prec_6,prec_7
Property changes on: grass/trunk/temporal/t.rast.gapfill/test.t.rast.gapfill.sh
Modified: grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py
--- grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py 2012-04-26 14:35:48 UTC (rev 51547)
+++ grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py 2012-04-26 16:21:52 UTC (rev 51548)
@@ -39,8 +39,12 @@
#%option G_OPT_STRDS_OUTPUT
#%end
-#%option G_OPT_R_BASE
+#%option
+#% key: base
+#% type: string
+#% description: The base name of the new created raster maps. This name will be extended with a numerical prefix
#% required: yes
+#% multiple: no
#%end
#%option
Modified: grass/trunk/temporal/t.rast.series/t.rast.series.py
--- grass/trunk/temporal/t.rast.series/t.rast.series.py 2012-04-26 14:35:48 UTC (rev 51547)
+++ grass/trunk/temporal/t.rast.series/t.rast.series.py 2012-04-26 16:21:52 UTC (rev 51548)
@@ -26,7 +26,7 @@
#%option
#% key: method
#% type: string
-#% description: Aggregate operation to be peformed on the raster maps
+#% description: Aggregate operation to be performed on the raster maps
#% required: yes
#% multiple: no
#% options: average,count,median,mode,minimum,min_raster,maximum,max_raster,stddev,range,sum,variance,diversity,slope,offset,detcoeff,quart1,quart3,perc90,quantile,skewness,kurtosis
Modified: grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py
--- grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py 2012-04-26 14:35:48 UTC (rev 51547)
+++ grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py 2012-04-26 16:21:52 UTC (rev 51548)
@@ -39,10 +39,12 @@
#%option G_OPT_STR3DS_OUTPUT
#%end
+#%option
+#% key: base
+#% type: string
+#% description: The base name of the new created 3d raster maps. This name will be extended with a numerical prefix
#% required: yes
-#% description: Name of the base raster3d map
-#% gisprompt: old,grid3,3d-raster
+#% multiple: no
#%end
#%option
Modified: grass/trunk/temporal/t.topology/t.topology.py
--- grass/trunk/temporal/t.topology/t.topology.py 2012-04-26 14:35:48 UTC (rev 51547)
+++ grass/trunk/temporal/t.topology/t.topology.py 2012-04-26 16:21:52 UTC (rev 51548)
@@ -69,7 +69,7 @@
maps = sp.get_registered_maps_as_objects(where=where, order="start_time", dbif=None)
if tmatrix:
- matrix = sp.print_temporal_relation_matrix(maps)
+ sp.print_temporal_relationships(maps)
return
sp.base.print_info()
