[GRASS-SVN] r51550 - grass-addons/grass6/raster/r.vol.dem
svn_grass at osgeo.org
Fri Apr 27 04:36:49 EDT 2012
Author: neteler
Date: 2012-04-27 01:36:48 -0700 (Fri, 27 Apr 2012)
New Revision: 51550
grass-addons/grass6/raster/r.vol.dem/description.html
grass-addons/grass6/raster/r.vol.dem/main.c
hull creation suffers from severe memory leak; commented for now
Modified: grass-addons/grass6/raster/r.vol.dem/description.html
--- grass-addons/grass6/raster/r.vol.dem/description.html 2012-04-26 17:44:32 UTC (rev 51549)
+++ grass-addons/grass6/raster/r.vol.dem/description.html 2012-04-27 08:36:48 UTC (rev 51550)
@@ -51,11 +51,17 @@
in the input command. In the case, where a 3D layer is limited not only
from one unit surface, e.g. on top, this flag allows a further 3D
interpolation until the next DEM or the region's margin.
+<!-- Suffers from severe memory leak! MN 4/2012
<p>
The <em>-h</em> flag export convex hull for polygon layers: This option
creates a 3D polygon out of the voxel model. This means, at first it will
be generated a voxel model. Afterwards, this will be converted into a
vector-file. However, the flag does not yet work properly.
<p>
The <em>-g</em> flag exports voxel model as vector points: This option
creates a vector point for each interpolated voxel. This became necessary
Modified: grass-addons/grass6/raster/r.vol.dem/main.c
--- grass-addons/grass6/raster/r.vol.dem/main.c 2012-04-26 17:44:32 UTC (rev 51549)
+++ grass-addons/grass6/raster/r.vol.dem/main.c 2012-04-27 08:36:48 UTC (rev 51550)
@@ -1223,9 +1223,12 @@
flag.fillnull->description = "Fill through NULL value areas in DEMs";
/* export a 3D hull polygon for every layer ? */
+/** Suffers from severe memory leak! MN 4/2012
flag.hull = G_define_flag();
flag.hull->key = 'h';
flag.hull->description = "Export convex hull polygons for layers";
/* GRASS ASCII vector point data output ? */
flag.grasspts = G_define_flag();
