[GRASS-SVN] r51570 - grass-addons/grass7/raster/r.stream.extract
svn_grass at osgeo.org
Sun Apr 29 11:28:30 EDT 2012
Author: mmetz
Date: 2012-04-29 08:28:30 -0700 (Sun, 29 Apr 2012)
New Revision: 51570
grass-addons/grass7/raster/r.stream.extract/close.c
grass-addons/grass7/raster/r.stream.extract/del_streams.c
grass-addons/grass7/raster/r.stream.extract/do_astar.c
grass-addons/grass7/raster/r.stream.extract/init_search.c
grass-addons/grass7/raster/r.stream.extract/load.c
grass-addons/grass7/raster/r.stream.extract/local_proto.h
grass-addons/grass7/raster/r.stream.extract/main.c
grass-addons/grass7/raster/r.stream.extract/streams.c
grass-addons/grass7/raster/r.stream.extract/thin.c
sync to r.watershed
Modified: grass-addons/grass7/raster/r.stream.extract/close.c
--- grass-addons/grass7/raster/r.stream.extract/close.c 2012-04-29 12:06:36 UTC (rev 51569)
+++ grass-addons/grass7/raster/r.stream.extract/close.c 2012-04-29 15:28:30 UTC (rev 51570)
@@ -30,7 +30,7 @@
double north_offset, west_offset, ns_res, ew_res;
int next_cat;
- G_message(_("Write vector map <%s>..."), stream_vect);
+ G_message(_("Writing vector map <%s>..."), stream_vect);
if (0 > Vect_open_new(&Out, stream_vect, 0)) {
G_fatal_error(_("Unable to create vector map <%s>"), stream_vect);
@@ -153,7 +153,7 @@
G_percent(n_outlets, n_outlets, 1); /* finish it */
- G_message(_("Write vector attribute table"));
+ G_message(_("Writing vector attribute table"));
/* Prepeare strings for use in db_* calls */
db_init_string(&dbsql);
@@ -244,8 +244,8 @@
stream_fd = dir_fd = -1;
cell_buf1 = cell_buf2 = NULL;
- G_message(_("Write raster %s"),
- (stream_rast != NULL) + (dir_rast != NULL) > 1 ? "maps" : "map");
+ G_message(_("Writing raster %s"),
+ (stream_rast != NULL) + (dir_rast != NULL) > 1 ? _("maps") : _("map"));
/* write requested output rasters */
if (stream_rast) {
Modified: grass-addons/grass7/raster/r.stream.extract/del_streams.c
--- grass-addons/grass7/raster/r.stream.extract/del_streams.c 2012-04-29 12:06:36 UTC (rev 51569)
+++ grass-addons/grass7/raster/r.stream.extract/del_streams.c 2012-04-29 15:28:30 UTC (rev 51570)
@@ -127,7 +127,7 @@
int other_trib, tmp_trib;
int slength;
- G_message(_("Delete stream segments shorter than %d cells..."), min_length);
+ G_message(_("Deleting stream segments shorter than %d cells..."), min_length);
/* TODO: proceed from stream heads to outlets
* -> use depth first post order traversal */
Modified: grass-addons/grass7/raster/r.stream.extract/do_astar.c
--- grass-addons/grass7/raster/r.stream.extract/do_astar.c 2012-04-29 12:06:36 UTC (rev 51569)
+++ grass-addons/grass7/raster/r.stream.extract/do_astar.c 2012-04-29 15:28:30 UTC (rev 51570)
@@ -4,17 +4,17 @@
#include <grass/glocale.h>
#include "local_proto.h"
-#define GET_PARENT(c) ((unsigned int)(((c) - 2) >> 2) + 1)
-#define GET_CHILD(p) ((unsigned int)((p) << 2) - 2)
+#define GET_PARENT(c) ((((c) - 2) >> 3) + 1)
+#define GET_CHILD(p) (((p) << 3) - 6)
HEAP_PNT heap_drop(void);
-int sift_up(unsigned int, HEAP_PNT);
+int sift_up(GW_LARGE_INT, HEAP_PNT);
double get_slope(CELL, CELL, double);
int do_astar(void)
int r, c, r_nbr, c_nbr, ct_dir;
- unsigned int first_cum, count;
+ GW_LARGE_INT first_cum, count;
int nextdr[8] = { 1, -1, 0, 0, -1, 1, 1, -1 };
int nextdc[8] = { 0, 0, -1, 1, 1, -1, 1, -1 };
CELL ele_val, ele_up, ele_nbr[8];
@@ -60,12 +60,12 @@
while (heap_size > 0) {
G_percent(count++, n_points, 1);
if (count > n_points)
- G_fatal_error(_("BUG in A* Search: %d surplus points"),
+ G_fatal_error(_("BUG in A* Search: %lld surplus points"),
heap_size);
if (heap_size > n_points)
G_fatal_error
- (_("BUG in A* Search: too many points in heap %d, should be %d"),
+ (_("BUG in A* Search: too many points in heap %lld, should be %lld"),
heap_size, n_points);
heap_p = heap_drop();
@@ -174,9 +174,9 @@
return 0;
-int sift_up(unsigned int start, HEAP_PNT child_p)
+int sift_up(GW_LARGE_INT start, HEAP_PNT child_p)
- unsigned int parent, child;
+ GW_LARGE_INT parent, child;
HEAP_PNT heap_p;
child = start;
@@ -205,7 +205,7 @@
* add item to heap
* returns heap_size
-unsigned int heap_add(int r, int c, CELL ele)
+GW_LARGE_INT heap_add(int r, int c, CELL ele)
HEAP_PNT heap_p;
@@ -232,8 +232,8 @@
- unsigned int child, childr, parent;
- int i;
+ GW_LARGE_INT child, childr, parent;
+ GW_LARGE_INT i;
HEAP_PNT child_p, childr_p, last_p, root_p;
seg_get(&search_heap, (char *)&last_p, 0, heap_size);
@@ -251,7 +251,7 @@
if (child < heap_size) {
childr = child + 1;
- i = child + 4;
+ i = child + 8;
while (childr < heap_size && childr < i) {
seg_get(&search_heap, (char *)&childr_p, 0, childr);
if (heap_cmp(&childr_p, &child_p)) {
Modified: grass-addons/grass7/raster/r.stream.extract/init_search.c
--- grass-addons/grass7/raster/r.stream.extract/init_search.c 2012-04-29 12:06:36 UTC (rev 51569)
+++ grass-addons/grass7/raster/r.stream.extract/init_search.c 2012-04-29 15:28:30 UTC (rev 51570)
@@ -11,7 +11,7 @@
char flag_value, flag_value_nbr, is_null;
WAT_ALT wa;
char asp_value;
- unsigned int n_depr_cells = 0;
+ GW_LARGE_INT n_depr_cells = 0;
nxt_avail_pt = heap_size = 0;
@@ -21,7 +21,7 @@
else
depr_buf = NULL;
- G_message(_("Initialize A* Search..."));
+ G_message(_("Initializing A* Search..."));
for (r = 0; r < nrows; r++) {
G_percent(r, nrows, 2);
@@ -114,9 +114,9 @@
G_free(depr_buf);
- G_debug(1, "%d edge cells", heap_size - n_depr_cells);
+ G_debug(1, "%lld edge cells", heap_size - n_depr_cells);
if (n_depr_cells)
- G_debug(1, "%d cells in depressions", n_depr_cells);
+ G_debug(1, "%lld cells in depressions", n_depr_cells);
return 1;
Modified: grass-addons/grass7/raster/r.stream.extract/load.c
--- grass-addons/grass7/raster/r.stream.extract/load.c 2012-04-29 12:06:36 UTC (rev 51569)
+++ grass-addons/grass7/raster/r.stream.extract/load.c 2012-04-29 15:28:30 UTC (rev 51570)
@@ -29,9 +29,9 @@
char *flag_value_buf, *aspect;
if (acc_fd < 0)
- G_message(_("Load elevation map..."));
+ G_message(_("Loading elevation map..."));
else
- G_message(_("Load input maps..."));
+ G_message(_("Loading input maps..."));
n_search_points = n_points = 0;
@@ -85,16 +85,16 @@
/* check for masked and NULL cells */
if (Rast_is_null_value(ptr, ele_map_type)) {
- if (acc_fd >= 0) {
- if (!Rast_is_null_value(acc_ptr, acc_map_type))
- G_fatal_error(_("Accumulation map does not match elevation map!"));
FLAG_SET(flag_value_buf[c], NULLFLAG);
FLAG_SET(flag_value_buf[c], INLISTFLAG);
FLAG_SET(flag_value_buf[c], WORKEDFLAG);
FLAG_SET(flag_value_buf[c], WORKED2FLAG);
Rast_set_c_null_value(&ele_value, 1);
/* flow accumulation */
+ if (acc_fd >= 0) {
+ if (!Rast_is_null_value(acc_ptr, acc_map_type))
+ G_fatal_error(_("Elevation map is NULL but accumulation map is not NULL!"));
Rast_set_d_null_value(&acc_value, 1);
else {
@@ -118,7 +118,7 @@
else {
if (Rast_is_null_value(acc_ptr, acc_map_type)) {
/* can this be ok after weighing ? */
+ G_fatal_error(_("Accumulation map is NULL but elevation map is not NULL!"));
switch (acc_map_type) {
@@ -162,7 +162,7 @@
G_free(acc_buf);
- G_debug(1, "%d non-NULL cells", n_points);
+ G_debug(1, "%lld non-NULL cells", n_points);
return n_points;
Modified: grass-addons/grass7/raster/r.stream.extract/local_proto.h
--- grass-addons/grass7/raster/r.stream.extract/local_proto.h 2012-04-29 12:06:36 UTC (rev 51569)
+++ grass-addons/grass7/raster/r.stream.extract/local_proto.h 2012-04-29 15:28:30 UTC (rev 51570)
@@ -6,6 +6,8 @@
#include "flag.h"
#include "seg.h"
+#define GW_LARGE_INT off_t
#define INDEX(r, c) ((r) * ncols + (c))
#define MAXDEPTH 1000 /* maximum supported tree depth of stream network */
@@ -16,7 +18,7 @@
#define HEAP_PNT struct heap_point
HEAP_PNT {
- unsigned int added;
+ GW_LARGE_INT added;
CELL ele;
POINT pnt;
@@ -27,14 +29,7 @@
DCELL wat;
-/* global variables */
-#ifdef MAIN
-# define GLOBAL
-#else
-# define GLOBAL extern
-#endif
-GLOBAL struct snode
+struct snode
int r, c;
int id;
@@ -42,26 +37,28 @@
int n_trib_total; /* number of all upstream stream segments */
int n_alloc; /* n allocated tributaries */
int *trib;
-} *stream_node;
-GLOBAL int nrows, ncols;
-GLOBAL unsigned int n_search_points, n_points, nxt_avail_pt;
-GLOBAL unsigned int heap_size;
-GLOBAL unsigned int n_stream_nodes, n_alloc_nodes;
-GLOBAL POINT *outlets;
-GLOBAL unsigned int n_outlets, n_alloc_outlets;
-GLOBAL char drain[3][3];
-GLOBAL char sides;
-GLOBAL int c_fac;
-GLOBAL int ele_scale;
-GLOBAL int have_depressions;
+/* extern variables */
+extern struct snode *stream_node;
+extern int nrows, ncols;
+extern GW_LARGE_INT n_search_points, n_points, nxt_avail_pt;
+extern GW_LARGE_INT heap_size;
+extern unsigned int n_stream_nodes, n_alloc_nodes;
+extern POINT *outlets;
+extern unsigned int n_outlets, n_alloc_outlets;
+extern char drain[3][3];
+extern char sides;
+extern int c_fac;
+extern int ele_scale;
+extern int have_depressions;
-GLOBAL SSEG search_heap;
-GLOBAL SSEG astar_pts;
-GLOBAL BSEG bitflags;
-GLOBAL SSEG watalt;
-GLOBAL BSEG asp;
-GLOBAL CSEG stream;
+extern SSEG search_heap;
+extern SSEG astar_pts;
+extern BSEG bitflags;
+extern SSEG watalt;
+extern BSEG asp;
+extern CSEG stream;
/* load.c */
int load_maps(int, int);
@@ -71,7 +68,7 @@
/* do_astar.c */
int do_astar(void);
-unsigned int heap_add(int, int, CELL);
+GW_LARGE_INT heap_add(int, int, CELL);
/* streams.c */
int do_accum(double);
Modified: grass-addons/grass7/raster/r.stream.extract/main.c
--- grass-addons/grass7/raster/r.stream.extract/main.c 2012-04-29 12:06:36 UTC (rev 51569)
+++ grass-addons/grass7/raster/r.stream.extract/main.c 2012-04-29 15:28:30 UTC (rev 51570)
@@ -19,13 +19,13 @@
#include <math.h>
#include <grass/raster.h>
-#define MAIN
+struct snode *stream_node;
int nrows, ncols;
-unsigned int n_search_points, n_points, nxt_avail_pt;
-unsigned int heap_size;
+GW_LARGE_INT n_search_points, n_points, nxt_avail_pt;
+GW_LARGE_INT heap_size;
POINT *outlets;
@@ -280,19 +280,7 @@
/* segment structures */
seg_rows = seg_cols = 64;
seg2kb = seg_rows * seg_cols / 1024.;
- /* elevation + accumulation: 12 byte -> 48 KB / segment
- * aspect: 1 byte -> 4 KB / segment
- * stream: 4 byte -> 16 KB / segment
- * flag: 1 byte -> 4 KB / segment
- * Total MB / segment so far: 0.07
- * astar_points: 8 byte -> 32 KB / segment
- * heap_points: 16 byte -> 64 KB / segment
- * Total MB / segment: 0.16
/* balance segment files */
/* elevation + accumulation: * 2 */
memory_divisor = sizeof(WAT_ALT) * 2;
@@ -333,7 +321,7 @@
heap_mem = num_open_segs * seg2kb * sizeof(HEAP_PNT) /
(4. * 1024.);
- G_verbose_message(_("%.2f of data are kept in memory"),
+ G_verbose_message(_("%.2f%% of data are kept in memory"),
100. * num_open_segs / num_seg_total);
disk_space *= num_seg_total;
if (disk_space < 1024.0)
@@ -343,7 +331,7 @@
disk_space / 1024.0, disk_space);
/* open segment files */
- G_verbose_message(_("Create temporary files..."));
+ G_verbose_message(_("Creating temporary files..."));
seg_open(&watalt, nrows, ncols, seg_rows, seg_cols, num_open_segs * 2,
sizeof(WAT_ALT), 1);
if (num_open_segs * 2 > num_seg_total)
Modified: grass-addons/grass7/raster/r.stream.extract/streams.c
--- grass-addons/grass7/raster/r.stream.extract/streams.c 2012-04-29 12:06:36 UTC (rev 51569)
+++ grass-addons/grass7/raster/r.stream.extract/streams.c 2012-04-29 15:28:30 UTC (rev 51570)
@@ -159,7 +159,7 @@
POINT astarpoint;
WAT_ALT wa;
- G_message(_("Calculate flow accumulation..."));
+ G_message(_("Calculating flow accumulation..."));
/* distances to neighbours */
dist_to_nbr = (double *)G_malloc(sides * sizeof(double));
@@ -391,14 +391,14 @@
* | 2 | | 3 |
* | 5 | 0 | 6 |
- unsigned int workedon, killer, count;
+ GW_LARGE_INT workedon, killer, count;
int stream_no = 0, stream_node_step = 1000;
double slope, diag;
char *flag_nbr, this_flag_value;
POINT astarpoint;
WAT_ALT wa;
- G_message(_("Extract streams..."));
+ G_message(_("Extracting streams..."));
/* init stream nodes */
n_alloc_nodes = stream_node_step;
@@ -714,7 +714,7 @@
G_percent(1, 1, 2);
if (workedon)
- G_warning(_("MFD: A * path already processed when setting drainage direction: %d of %d cells"),
+ G_warning(_("MFD: A * path already processed when setting drainage direction: %lld of %lld cells"),
workedon, n_points);
G_free(dist_to_nbr);
Modified: grass-addons/grass7/raster/r.stream.extract/thin.c
--- grass-addons/grass7/raster/r.stream.extract/thin.c 2012-04-29 12:06:36 UTC (rev 51569)
+++ grass-addons/grass7/raster/r.stream.extract/thin.c 2012-04-29 15:28:30 UTC (rev 51570)
@@ -80,7 +80,7 @@
int n_trib_total;
int n_thinned = 0;
- G_message(_("Thin stream segments..."));
+ G_message(_("Thinning stream segments..."));
nodestack = (struct sstack *)G_malloc(stack_step * sizeof(struct sstack));
