[GRASS-SVN] r51576 - grass/branches/releasebranch_6_4/vector
svn_grass at osgeo.org
Mon Apr 30 05:01:26 EDT 2012
Author: mlennert
Date: 2012-04-30 02:01:26 -0700 (Mon, 30 Apr 2012)
New Revision: 51576
grass/branches/releasebranch_6_4/vector/vectorintro.html
Cleaning up
Modified: grass/branches/releasebranch_6_4/vector/vectorintro.html
--- grass/branches/releasebranch_6_4/vector/vectorintro.html 2012-04-30 03:10:04 UTC (rev 51575)
+++ grass/branches/releasebranch_6_4/vector/vectorintro.html 2012-04-30 09:01:26 UTC (rev 51576)
@@ -190,9 +190,9 @@
appear in that layer. In this fashion some vector objects may appear
in some layers but not in others. Taking the example of the fields
and paths, only some boundaries, but not all, might have a category
-value in layer 2. With <em>option=report</em>, <a href=
- +"v.category.html">v.category</a> lists available categories in each
-layer.
+value in layer 2. With <em>option=report</em>,
+<a href="v.category.html">v.category</a> lists available categories
+in each layer.
<br>
Optionally, each layer can (but does not have
to) be linked to an attribute table. The link is made by the
@@ -204,7 +204,6 @@
In most modules, the first layer (<em>layer=1</em>) is active by
default. Using <em>layer=-1</em> one can access all layers.
</li>
-<br><br></li>
<li><b>SQL support</b><br>
The DBF driver provides only very limited SQL support (as DBF is not an
