[GRASS-SVN] r52504 - grass-addons/grass7/raster/r.houghtransform
svn_grass at osgeo.org
Thu Aug 2 06:25:42 PDT 2012
Author: annakrat
Date: 2012-08-02 06:25:40 -0700 (Thu, 02 Aug 2012)
New Revision: 52504
grass-addons/grass7/raster/r.houghtransform/main.cpp
r.houghtransform: description fixed
Modified: grass-addons/grass7/raster/r.houghtransform/main.cpp
--- grass-addons/grass7/raster/r.houghtransform/main.cpp 2012-08-02 13:16:01 UTC (rev 52503)
+++ grass-addons/grass7/raster/r.houghtransform/main.cpp 2012-08-02 13:25:40 UTC (rev 52504)
@@ -76,7 +76,7 @@
anglesOption = G_define_standard_option(G_OPT_R_INPUT);
anglesOption->key = "angles";
anglesOption->required = NO;
- anglesOption->description = _("Approximate number of line segments.");
+ anglesOption->description = _("Name of input image with angles from i.edge.");
houghImageNameOption = G_define_standard_option(G_OPT_R_OUTPUT);
houghImageNameOption->key = "hough_image";
@@ -88,7 +88,7 @@
angleWidthOption->type = TYPE_INTEGER;
angleWidthOption->required = NO;
angleWidthOption->multiple = NO;
- angleWidthOption->description = _("Width of circle sector (only when you provide angle map).");
+ angleWidthOption->description = _("Width of circle sector (only when you provide angle map)");
angleWidthOption->answer = const_cast<char *>("5");
// this option will become max peaks number to find in HT
@@ -97,13 +97,13 @@
maxLinesOption->type = TYPE_INTEGER;
maxLinesOption->required = NO;
maxLinesOption->multiple = NO;
- maxLinesOption->description = _("Approximate number of line segments."
- " Actually, this option will become"
- " maximal number of line candidates"
- " detected in Hough transform image."
- " Final number of line segments can be"
- " smaller or greater."
+ maxLinesOption->label = _("Approximate number of line segments");
+ maxLinesOption->description = _(
+ "This number represents"
+ " maximal number of line candidates"
+ " detected in Hough transform image."
+ " Final number of line segments can be"
+ " smaller or greater.");
maxLinesOption->answer = const_cast<char *>("20");
minGapOption = G_define_option();
