[GRASS-SVN] r52509 - in grass/trunk/scripts: r.pack r.unpack r.unpack/test_suite
Thu Aug 2 16:26:51 PDT 2012
Author: huhabla
Date: 2012-08-02 16:26:50 -0700 (Thu, 02 Aug 2012)
New Revision: 52509
Added:
   grass/trunk/scripts/r.unpack/test_suite/
   grass/trunk/scripts/r.unpack/test_suite/test.r.unpack.sh
   grass/trunk/scripts/r.unpack/test_suite/test_double.ref
   grass/trunk/scripts/r.unpack/test_suite/test_double_uncompressed.ref
   grass/trunk/scripts/r.unpack/test_suite/test_float.ref
   grass/trunk/scripts/r.unpack/test_suite/test_float_uncompressed.ref
   grass/trunk/scripts/r.unpack/test_suite/test_int.ref
   grass/trunk/scripts/r.unpack/test_suite/test_int_uncompressed.ref
   grass/trunk/scripts/r.pack/r.pack.py
   grass/trunk/scripts/r.unpack/r.unpack.py
Fixed small bugs (output name handling in r.unpack), added
more robust projection file comparison, added compression flag
and tests
Modified: grass/trunk/scripts/r.pack/r.pack.py
--- grass/trunk/scripts/r.pack/r.pack.py	2012-08-02 23:24:51 UTC (rev 52508)
+++ grass/trunk/scripts/r.pack/r.pack.py	2012-08-02 23:26:50 UTC (rev 52509)
@@ -26,6 +26,10 @@
 #% description: Name for output file (default is <input>.pack)
 #% required : no
 #%end
+#%flag
+#% key: c
+#% description: Switch the compression off
+#%end
 import os
 import sys
@@ -40,17 +44,19 @@
 def main():
     infile = options['input']
+    compression_off = flags['c']
     mapset = None
     if '@' in infile:
         infile, mapset = infile.split('@')
     if options['output']:
-        outfile_path, outfile_base = os.path.split(options['output'])
+        outfile_path, outfile_base = os.path.split(os.path.abspath(options['output']))
     else:
-        outfile_path = os.getcwd()
-        outfile_base = infile + '.pack'
+        outfile_path, outfile_base = os.path.split(os.path.abspath(infile + ".pack"))
     outfile = os.path.join(outfile_path, outfile_base)
+    print outfile
     global tmp
     tmp = grass.tempdir()
@@ -99,7 +105,10 @@
     # pack it all up
     os.chdir(tmp)
-    tar = tarfile.TarFile.open(name = outfile_base, mode = 'w:gz')
+    if compression_off:
+        tar = tarfile.TarFile.open(name = outfile_base, mode = 'w:')
+    else:
+        tar = tarfile.TarFile.open(name = outfile_base, mode = 'w:gz')
     tar.add(infile, recursive = True)
     tar.close()
     try:
Modified: grass/trunk/scripts/r.unpack/r.unpack.py
--- grass/trunk/scripts/r.unpack/r.unpack.py	2012-08-02 23:24:51 UTC (rev 52508)
+++ grass/trunk/scripts/r.unpack/r.unpack.py	2012-08-02 23:26:50 UTC (rev 52509)
@@ -1,7 +1,7 @@
 #!/usr/bin/env python
-# MODULE:	r.pack
+# MODULE:	r.unpack
 # AUTHOR(S):	Hamish Bowman, Otago University, New Zealand
 #               Converted to Python by Martin Landa <landa.martin gmail.com>
 # PURPOSE:	Unpack up a raster map packed with r.pack
@@ -61,7 +61,7 @@
     input_base = os.path.basename(infile)
     shutil.copyfile(infile, os.path.join(tmp_dir, input_base))
     os.chdir(tmp_dir)
-    tar = tarfile.TarFile.open(name = input_base, mode = 'r:gz')
+    tar = tarfile.TarFile.open(name = input_base, mode = 'r')
     try:
         data_name = tar.getnames()[0]
     except:
@@ -83,7 +83,8 @@
     os.chdir(data_name)
     # check projection compatibility in a rather crappy way
-    if not filecmp.cmp('PROJ_INFO', os.path.join(mset_dir, '..', 'PERMANENT', 'PROJ_INFO')):
+    if not grass.compare_key_value_text_files('PROJ_INFO', os.path.join(mset_dir, '..', 'PERMANENT', 'PROJ_INFO')) or\
+       not grass.compare_key_value_text_files('PROJ_UNITS', os.path.join(mset_dir, '..', 'PERMANENT', 'PROJ_UNITS')):
         if flags['o']:
             grass.warning(_("Projection information does not match. Proceeding..."))
         else:
Added: grass/trunk/scripts/r.unpack/test_suite/test.r.unpack.sh
--- grass/trunk/scripts/r.unpack/test_suite/test.r.unpack.sh	                        (rev 0)
+++ grass/trunk/scripts/r.unpack/test_suite/test.r.unpack.sh	2012-08-02 23:26:50 UTC (rev 52509)
@@ -0,0 +1,46 @@
+# This script tests r.pack and r.unpack
+# We specify a small region in the @preprocess step
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=70 w=0 e=100 b=0 t=50 -p
+# Map generation
+r.mapcalc --o expr="test_int = 1"
+r.mapcalc --o expr="test_float = float(2.0)"
+r.mapcalc --o expr="test_double = double(3.0)"
+# @test packing and unpacking with @precision=1
+# First we pack the different raster maps with and without compression
+r.pack --o --v input=test_int
+r.pack --o --v input=test_float
+r.pack --o --v input=test_double
+r.pack --o --v -c input=test_int    output=test_int_uncompressed.pack
+r.pack --o --v -c input=test_float  output=test_float_uncompressed.pack
+r.pack --o --v -c input=test_double output=test_double_uncompressed.pack
+# Remove generated maps and re-import
+g.remove rast=test_int,test_float,test_double
+# Second we check the import with r.unpack
+r.unpack --o --v input=test_int.pack
+r.unpack --o --v input=test_float.pack
+r.unpack --o --v input=test_double.pack
+# Generating reference data
+#r.out.ascii --o input=test_int output=test_int.ref dp=1
+#r.out.ascii --o input=test_float output=test_float.ref dp=1
+#r.out.ascii --o input=test_double output=test_double.ref dp=1
+r.unpack -o --v input=test_int_uncompressed.pack    output=test_int_uncompressed
+r.unpack -o --v input=test_float_uncompressed.pack  output=test_float_uncompressed
+r.unpack -o --v -o input=test_double_uncompressed.pack output=test_double_uncompressed
+#r.out.ascii --o input=test_int_uncompressed output=test_int_uncompressed.ref dp=1
+#r.out.ascii --o input=test_float_uncompressed output=test_float_uncompressed.ref dp=1
+#r.out.ascii --o input=test_double_uncompressed output=test_double_uncompressed.ref dp=1
+g.remove rast=test_int,test_float,test_double,test_int_uncompressed,test_float_uncompressed,test_double_uncompressed
+rm *.pack
\ No newline at end of file
Added: grass/trunk/scripts/r.unpack/test_suite/test_double.ref
--- grass/trunk/scripts/r.unpack/test_suite/test_double.ref	                        (rev 0)
+++ grass/trunk/scripts/r.unpack/test_suite/test_double.ref	2012-08-02 23:26:50 UTC (rev 52509)
@@ -0,0 +1,76 @@
+north: 70N
+south: 0
+east: 100E
+west: 0
+rows: 70
+cols: 100
+3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3
Added: grass/trunk/scripts/r.unpack/test_suite/test_double_uncompressed.ref
--- grass/trunk/scripts/r.unpack/test_suite/test_double_uncompressed.ref	                        (rev 0)
+++ grass/trunk/scripts/r.unpack/test_suite/test_double_uncompressed.ref	2012-08-02 23:26:50 UTC (rev 52509)
@@ -0,0 +1,76 @@
+north: 70N
+south: 0
+east: 100E
+west: 0
+rows: 70
+cols: 100
Added: grass/trunk/scripts/r.unpack/test_suite/test_float.ref
--- grass/trunk/scripts/r.unpack/test_suite/test_float.ref	                        (rev 0)
+++ grass/trunk/scripts/r.unpack/test_suite/test_float.ref	2012-08-02 23:26:50 UTC (rev 52509)
@@ -0,0 +1,76 @@
+north: 70N
+south: 0
+east: 100E
+west: 0
+rows: 70
+cols: 100
+2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2
Added: grass/trunk/scripts/r.unpack/test_suite/test_float_uncompressed.ref
--- grass/trunk/scripts/r.unpack/test_suite/test_float_uncompressed.ref	                        (rev 0)
+++ grass/trunk/scripts/r.unpack/test_suite/test_float_uncompressed.ref	2012-08-02 23:26:50 UTC (rev 52509)
@@ -0,0 +1,76 @@
+north: 70N
+south: 0
+east: 100E
+west: 0
+rows: 70
+cols: 100
Added: grass/trunk/scripts/r.unpack/test_suite/test_int.ref
--- grass/trunk/scripts/r.unpack/test_suite/test_int.ref	                        (rev 0)
+++ grass/trunk/scripts/r.unpack/test_suite/test_int.ref	2012-08-02 23:26:50 UTC (rev 52509)
@@ -0,0 +1,76 @@
+north: 70N
+south: 0
+east: 100E
+west: 0
+rows: 70
+cols: 100
+1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1
Added: grass/trunk/scripts/r.unpack/test_suite/test_int_uncompressed.ref
--- grass/trunk/scripts/r.unpack/test_suite/test_int_uncompressed.ref	                        (rev 0)
+++ grass/trunk/scripts/r.unpack/test_suite/test_int_uncompressed.ref	2012-08-02 23:26:50 UTC (rev 52509)
@@ -0,0 +1,76 @@
+north: 70N
+south: 0
+east: 100E
+west: 0
+rows: 70
+cols: 100
