[GRASS-SVN] r52516 - grass/trunk/general/g.proj
svn_grass at osgeo.org
Fri Aug 3 22:06:23 PDT 2012
Author: marisn
Date: 2012-08-03 22:06:23 -0700 (Fri, 03 Aug 2012)
New Revision: 52516
grass/trunk/general/g.proj/input.c
Silence compiler warnings
Modified: grass/trunk/general/g.proj/input.c
--- grass/trunk/general/g.proj/input.c 2012-08-04 01:54:31 UTC (rev 52515)
+++ grass/trunk/general/g.proj/input.c 2012-08-04 05:06:23 UTC (rev 52516)
@@ -88,7 +88,7 @@
if (infd) {
fread(buff, sizeof(buff), 1, infd);
if (ferror(infd))
- G_fatal_error(_("Error reading WKT projection description"));
+ G_fatal_error("%s", _("Error reading WKT projection description"));
else
fclose(infd);
/* Get rid of newlines */
@@ -140,7 +140,7 @@
hSRS = OSRNewSpatialReference(NULL);
if (OSRImportFromProj4(hSRS, proj4string) != OGRERR_NONE)
- G_fatal_error(_("Can't parse PROJ.4-style parameter string"));
+ G_fatal_error("%s", _("Can't parse PROJ.4-style parameter string"));
G_free(proj4string);
@@ -178,7 +178,7 @@
if (OSRImportFromEPSG(hSRS, epsg_num) != OGRERR_NONE)
- G_fatal_error(_("Unable to translate EPSG code"));
+ G_fatal_error("%s", _("Unable to translate EPSG code"));
ret = GPJ_osr_to_grass(&cellhd, &projinfo, &projunits, hSRS, 0);
@@ -215,7 +215,7 @@
/* Try opening file with OGR first because it doesn't output a
* (potentially confusing) error message if it can't open the file */
- G_message(_("Trying to open with OGR..."));
+ G_message("%s", _("Trying to open with OGR..."));
OGRRegisterAll();
if ((ogr_ds = OGROpen(geofile, FALSE, NULL))
@@ -223,7 +223,7 @@
OGRLayerH ogr_layer;
OGRSpatialReferenceH ogr_srs;
- G_message(_("...succeeded."));
+ G_message("%s", _("...succeeded."));
/* Get the first layer */
ogr_layer = OGR_DS_GetLayer(ogr_ds, 0);
ogr_srs = OGR_L_GetSpatialRef(ogr_layer);
@@ -236,13 +236,13 @@
/* Try opening with GDAL */
GDALDatasetH gdal_ds;
- G_message(_("Trying to open with GDAL..."));
+ G_message("%s", _("Trying to open with GDAL..."));
GDALAllRegister();
if ((gdal_ds = GDALOpen(geofile, GA_ReadOnly))) {
char *wktstring;
wktstring = (char *)GDALGetProjectionRef(gdal_ds);
ret =
GPJ_wkt_to_grass(&cellhd, &projinfo, &projunits, wktstring,
