[GRASS-SVN] r52535 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Sun Aug 5 01:14:14 PDT 2012
Author: mmetz
Date: 2012-08-05 01:14:14 -0700 (Sun, 05 Aug 2012)
New Revision: 52535
grass/trunk/lib/vector/Vlib/area.c
grass/trunk/lib/vector/Vlib/bridges.c
grass/trunk/lib/vector/Vlib/find.c
grass/trunk/lib/vector/Vlib/poly.c
grass/trunk/lib/vector/Vlib/write_nat.c
Vlib: update for changed fn defs
Modified: grass/trunk/lib/vector/Vlib/area.c
--- grass/trunk/lib/vector/Vlib/area.c 2012-08-05 08:12:45 UTC (rev 52534)
+++ grass/trunk/lib/vector/Vlib/area.c 2012-08-05 08:14:14 UTC (rev 52535)
@@ -342,7 +342,7 @@
\return 0 if not
int Vect_point_in_area(double x, double y, const struct Map_info *Map,
- int area, struct bound_box box)
+ int area, struct bound_box *box)
int i, isle;
const struct Plus_head *Plus;
@@ -363,7 +363,7 @@
for (i = 0; i < Area->n_isles; i++) {
isle = Area->isles[i];
Vect_get_isle_box(Map, isle, &ibox);
- poly = Vect_point_in_island(x, y, Map, isle, ibox);
+ poly = Vect_point_in_island(x, y, Map, isle, &ibox);
if (poly >= 1)
return 0; /* excludes island boundary (poly == 2), OK? */
Modified: grass/trunk/lib/vector/Vlib/bridges.c
--- grass/trunk/lib/vector/Vlib/bridges.c 2012-08-05 08:12:45 UTC (rev 52534)
+++ grass/trunk/lib/vector/Vlib/bridges.c 2012-08-05 08:14:14 UTC (rev 52535)
@@ -133,7 +133,7 @@
while (1) {
next_line =
dig_angle_next_line(Plus, current_line, GV_RIGHT,
- GV_BOUNDARY);
+ GV_BOUNDARY, NULL);
/* Add this line to the list */
/* TODO: Vect_val_in_list() and Vect_list_append() behave O(n)
Modified: grass/trunk/lib/vector/Vlib/find.c
--- grass/trunk/lib/vector/Vlib/find.c 2012-08-05 08:12:45 UTC (rev 52534)
+++ grass/trunk/lib/vector/Vlib/find.c 2012-08-05 08:14:14 UTC (rev 52535)
@@ -38,8 +38,8 @@
if (as->size < bs->size)
return -1;
- else
- return (as->size > bs->size);
+ return (as->size > bs->size);
@@ -264,17 +264,15 @@
int Vect_find_area(struct Map_info *Map, double x, double y)
int i, ret, area;
- static int first = 1;
struct bound_box box;
- static struct boxlist *List;
+ static struct boxlist *List = NULL;
static BOX_SIZE *size_list;
static int alloc_size_list = 0;
G_debug(3, "Vect_find_area() x = %f y = %f", x, y);
- if (first) {
+ if (!List) {
List = Vect_new_boxlist(1);
- first = 0;
alloc_size_list = 10;
size_list = G_malloc(alloc_size_list * sizeof(BOX_SIZE));
@@ -316,7 +314,7 @@
for (i = 0; i < List->n_values; i++) {
area = size_list[i].i;
- ret = Vect_point_in_area(x, y, Map, area, size_list[i].box);
+ ret = Vect_point_in_area(x, y, Map, area, &size_list[i].box);
G_debug(3, " area = %d Vect_point_in_area() = %d", area, ret);
@@ -366,7 +364,7 @@
current = 0;
island = List->id[i];
- ret = Vect_point_in_island(x, y, Map, island, List->box[i]);
+ ret = Vect_point_in_island(x, y, Map, island, &List->box[i]);
if (ret >= 1) { /* inside */
if (current > 0) { /* not first */
Modified: grass/trunk/lib/vector/Vlib/poly.c
--- grass/trunk/lib/vector/Vlib/poly.c 2012-08-05 08:12:45 UTC (rev 52534)
+++ grass/trunk/lib/vector/Vlib/poly.c 2012-08-05 08:14:14 UTC (rev 52535)
@@ -684,7 +684,7 @@
int
Vect_point_in_area_outer_ring(double X, double Y, const struct Map_info *Map,
int n_intersects, inter;
@@ -706,7 +706,7 @@
Area = Plus->Area[area];
/* First it must be in box */
- if (X < box.W || X > box.E || Y > box.N || Y < box.S)
+ if (X < box->W || X > box->E || Y > box->N || Y < box->S)
return 0;
n_intersects = 0;
@@ -757,7 +757,7 @@
\return 2 - on the boundary (exactly may be said only for vertex of vertical/horizontal line)
int Vect_point_in_island(double X, double Y, const struct Map_info *Map,
- int isle, struct bound_box box)
+ int isle, struct bound_box *box)
@@ -777,7 +777,7 @@
Plus = &(Map->plus);
Isle = Plus->Isle[isle];
return 0;
n_intersects = 0;
Modified: grass/trunk/lib/vector/Vlib/write_nat.c
--- grass/trunk/lib/vector/Vlib/write_nat.c 2012-08-05 08:12:45 UTC (rev 52534)
+++ grass/trunk/lib/vector/Vlib/write_nat.c 2012-08-05 08:14:14 UTC (rev 52535)
@@ -180,11 +180,11 @@
if (!s)
next_line =
dig_angle_next_line(plus, line, GV_RIGHT,
- GV_BOUNDARY);
else
next_line =
dig_angle_next_line(plus, -line, GV_RIGHT,
- GV_BOUNDARY);
if (next_line != 0) { /* there is a boundary to the right */
NLine = plus->Line[abs(next_line)];
@@ -707,25 +707,25 @@
/* Adjacent are stored: > 0 - we want right side; < 0 - we want left side */
n_adjacent = 0;
- next_line = dig_angle_next_line(plus, line, GV_RIGHT, GV_BOUNDARY);
+ next_line = dig_angle_next_line(plus, line, GV_RIGHT, GV_BOUNDARY, NULL);
if (next_line != 0 && abs(next_line) != line) {
/* N1, to the right -> we want the right side for > 0 and left for < 0 */
adjacent[n_adjacent] = next_line;
n_adjacent++;
- next_line = dig_angle_next_line(plus, line, GV_LEFT, GV_BOUNDARY);
+ next_line = dig_angle_next_line(plus, line, GV_LEFT, GV_BOUNDARY, NULL);
/* N1, to the left -> we want the left side for > 0 and right for < 0 */
adjacent[n_adjacent] = -next_line;
n_adjacent++;
- next_line = dig_angle_next_line(plus, -line, GV_RIGHT, GV_BOUNDARY);
+ next_line = dig_angle_next_line(plus, -line, GV_RIGHT, GV_BOUNDARY, NULL);
/* N2, to the right -> we want the right side for > 0 and left for < 0 */
n_adjacent++;
- next_line = dig_angle_next_line(plus, -line, GV_LEFT, GV_BOUNDARY);
+ next_line = dig_angle_next_line(plus, -line, GV_LEFT, GV_BOUNDARY, NULL);
/* N2, to the left -> we want the left side for > 0 and right for < 0 */
