[GRASS-SVN] r52537 - grass/trunk/vector/v.select
svn_grass at osgeo.org
Sun Aug 5 01:17:11 PDT 2012
Author: mmetz
Date: 2012-08-05 01:17:10 -0700 (Sun, 05 Aug 2012)
New Revision: 52537
grass/trunk/vector/v.select/overlap.c
grass/trunk/vector/v.select/select.c
v.select fn def update
Modified: grass/trunk/vector/v.select/overlap.c
--- grass/trunk/vector/v.select/overlap.c 2012-08-05 08:16:27 UTC (rev 52536)
+++ grass/trunk/vector/v.select/overlap.c 2012-08-05 08:17:10 UTC (rev 52537)
@@ -57,7 +57,7 @@
/* Try if any of line vertices is within area */
for (i = 0; i < LPoints->n_points; i++) {
- if (Vect_point_in_area(LPoints->x[i], LPoints->y[i], AMap, area, box)) {
+ if (Vect_point_in_area(LPoints->x[i], LPoints->y[i], AMap, area, &box)) {
G_debug(4, " -> line vertex inside area");
return 1;
Modified: grass/trunk/vector/v.select/select.c
--- grass/trunk/vector/v.select/select.c 2012-08-05 08:16:27 UTC (rev 52536)
+++ grass/trunk/vector/v.select/select.c 2012-08-05 08:17:10 UTC (rev 52537)
@@ -292,7 +292,7 @@
else {
if (Vect_point_in_area(BPoints->x[0], BPoints->y[0], aIn,
- aarea, abox)) {
+ aarea, &abox)) {
found = 1;
break;
